[petsc-users] Doubt about distribution of PETSc in a CMake project
Mon Jul 25 10:59:32 CDT 2022
Sorry - don't know how to help with cmake.
does 'make check' work for this static build of PETSc? Also can you 'rm -rf PETSC_ARCH' [and rebuild PETSc] - to make sure the static build is clean - before you attempt your build?
Also is this cmake build for your application - or a different package?
It appears to be using an old version of FindPETSc.cmake - you might need a newer version - that uses pkg-config [but don't know the details]
cc: Jed
Satish
On Mon, 25 Jul 2022, Sebastian Gutierrez wrote:
> Hello Satish,
> First of all, I want to thank you for your response. I have been trying to
> perform the second alternative you suggested, but I am having problem while
> I am executing the cmake command. Could you help me with it? I got this
> error in the image attached, additionally I config petsc with this
> configuration: *./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> --with-debugging=0 COPTFLAGS='-O3 -march=native -mtune=native'
> CXXOPTFLAGS='-O3 -march=native -mtune=native' FOPTFLAGS='-O3 -march=native
> -mtune=native' --with-shared-libraries=0 --download-mpich*
> And this cmake command: *cmake -DPETSC_DIR=/usr/lib/petsc-3.17.2
> -DPETSC_ARCH=arch-linux-c-opt all -DPETSC_CURRENT=ON ../*
> I hope you can help me, please.
> Best regards,
> Sebastian
> [image: imagen.png]
> El jue, 21 jul 2022 a las 15:41, Satish Balay (<balay at mcs.anl.gov>)
> escribió:
> > Another alternative: you can install PETSc with:
> > [but some of the dependent libraries might still be shared - if so -
> > you'll need to figure out static build for them. If they are installed with
> > --download-pkg option of configure - likely it will be static]
> > Satish
> > On Thu, 21 Jul 2022, Satish Balay via petsc-users wrote:
> > > You can try:
> > > ldd your-executable
> > > And copy over all the .so files listed by it [ignoring the system
> > libraries - that might be present on the remote machine
> > > Try setting LD_LIBRARY_PATH to this location [n the new machine]
> > > and retry 'ldd your-executable' on the new machine - and make sure there
> > are no 'not found' libraries in that list
> > > then your-executable is likely to work.
> > > Note: this might not work parallely - as you would need mpiexec for a
> > parallel run
> > > Satish
> > > On Thu, 21 Jul 2022, Sebastian Gutierrez wrote:
> > > > Good afternoon PETSc Development Team,
> > > > I have been trying to distribute your program as third party library
> > in my CMake Project. Because I do not want to my Linux users to have to
> > install petsc by their own. I just want them to use my final
> > > > product that uses petsc dependencies. When I execute make install  of
> > my Project in my own machine, it works perfectly but the problem appears
> > when I move the executable to another machine that does not have
> > > > installed petsc.
> > > > I honestly have no idea to solve this. I wrote this email in hopes
> > that you kindly help me out with this.
> > > > I am looking forward to your answer.
> > > > Best regards,
> > > > Sebastian Gutierrez
