[petsc-users] Efficiently build a matrix from two asymmetric diagonal block matrices
Thu Jul 21 07:03:37 CDT 2022
On Thu, Jul 21, 2022 at 6:28 AM Emile Soutter <emile.soutter at corintis.com>
wrote:
> Dear all,
> I am struggling with the simple following problem : Having a first matrix
> B1 of size n1xm1, a second matrix B2 of size n2 x m2, build a matrix M of
> size (n1+n2)x(m1+m2) where the blocks B1 and B2 are the "diagonal" of M
> (M[0:n1,0:m1]=B1, M[n1:(n1+n2),m1:(m1+m2)]=B2). In my case, the blocks B1
> and B2 are obtained from another routine, directly in the petsc matrix form
> (or pyop2.Sparsity form). However the blocks are not squared (n1,n2,m1,m2
> are all different integers). The operation is easy to do with the SetValues
> option. However, it takes a large amount of time (too much) when the system
> becomes large. I struggle to do it efficiently and in parallel. What method
> do you recommend to use to do this as fast as possible?
> Thanks you for any tips,
I think it depends on what you want to do with the final matrix. If you
only want MatMult, then I think you can just use MatNest
  https://petsc.org/main/docs/manualpages/Mat/MatCreateNest/
which will wrap up the submatrices. However, if you want to manipulate the
values (factorization, relaxation, etc) then you need
to assemble a monolithic matrix. For this you could create the global
matrix, and then use
  https://petsc.org/main/docs/manualpages/Mat/MatCreateLocalRef/
to get a submatrix to assemble directly into, which you pass to your
assembly routine. Clearly this is more complicated, but
sometimes necessary.
      Matt
> Emile
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220721/1793fb48/attachment.html>
