[petsc-users] DMPlex: a Mapping Array between Natural and Distributed Cell Index
Bora Jeong
boraj1021 at gmail.com
Wed Jul 20 18:23:37 CDT 2022
Thank you for the comments.
If you define a scalar P1 field of one component, then the dof index will
be the vertex index.
*-> When you say P1 field of one component, what does exactly mean? I put
1dof scalar field on vertex when the Petsc section is defined. Is this P0
or P1 in Petsc's convention?*
If you look at the SF, it tells you the mapping. However, you could get it
in a round about way from a Vec. You could
put the index number at each position (e.g. put 5 at index 5). Then call
GlobalToNatural(). This would tell you which
global index corresponds to each natural index.
*-> I did tests A and B;A. (1) Define a global Vec, (2) set value as index
given by looping over the size of the global Vec (i.e., Vec(1)=1, Vec(2)=2,
etc.), (3) GlobalToNatural(), (4) VecView()B. (1) DMGetCoordinates() on
global coordinate Vec, (2) VecView()The index from A. and coordinate Vec
from B. do not match with the natural vertex index written in the mesh
file. I think I need to do opposite; NaturalToGlobal(). What do you think?*
Best
On Wed, Jul 20, 2022 at 3:24 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jul 20, 2022 at 2:27 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>> I am not seeing DMPlexDistributeSetDefault(dm,PETSC_FALSE) after you
>> create your DM from the GMSH file. Your DM is then automatically
>> distributed and the natural ordering won't be a priori the one from your
>> file. I don't know how Petsc distributes a DM during the load step from a
>> file.
>> *-> PetscSFView() gives me the same Natural SF whether I have
>> DMPlexDistributeSetDefault(dm,PETSC_FALSE) after DMPlexCreateGmshFromFile()
>> or not. In addition, in my opinion if the Natural SF is not defined
>> properly due to the distribution, I might see Null from PetscSFView(). This
>> might be previously checked with Matt thanks to the help. *
>> a) You have here two differents ordering and distribution: the one given
>> by Petsc after creating your DM from your file (which is distributed), i.e.
>> before DMPlexDistribute and which is considered natural, and the one after
>> DMPlexDistribute.
>> *-> This ordering you mentioned (i.e., the ordering made after creating
>> DM from mesh file but before distribution) is exactly what I want to have.
>> Natural SF can show me its roots and leaves (i.e., graphs), but not the
>> actual index written in the mesh file (i.e., start from 1 to number of
>> total vertex, for example). Adding
>> DMPlexDistributeSetDefault(dm,PETSC_FALSE) does not really change my
>> Natural SF. When you mention "sequantial" ordering, does it mean the same
>> order written in the mesh file, instead of the graphs (i.e., roots and
>> leaves)?*
>> b) I am not familiar with the overlap. From my understanding, even when
>> you pass overlap = 0 to DMPlexDistribute, there is still an "overlap", i.e.
>> points shared between procs. For your run on 2 procs, some dofs (5 dofs in
>> your case) are on both procs when it comes to local Vec but only one proc
>> owes these dofs concerning global Vec. That's why your natural SF shows 5
>> dofs less on proc 0.
>> *-> Thanks, makes sense. The number of stratum points I get from
>> DMPlexGetDepthStratum() for vertex is the size of local Vec with 1dof on
>> vertex. *
>> Are you on the 'release' branch? On 'main', the creation of the natural
>> SF raises an error (duplicate leave entries) when the section includes
>> constraint dofs.
>> *-> I am in the main branch of 3.17.0. It is unclear your comment to me,
>> but I cannot see any duplicated leave entries in this case. There is 1dof
>> on vertex. *
>> Based on your comment, I might need to do;
>> *1) Convert Natural SF's roots & leaves into the actual vertex index,
>> which is written in the mesh file (i.e., from 1 to 25 in my case).*
>> 2) DMPlexNaturalToGlobalBegin() and End() to pass the index from step 1)
>> to global Vec
> I don't think you need this.
>> 3) DMGlobalToLocalBegin() and End() to pass the index to local Vec,
>> finally.
> Thanks,
> Matt
>> Does this make sense? My questions so far are actually about step 1). As
>> you see from the example code, I already defined Natural SF, which gives
>> roots and leaves. Then how can I convert those graphs into the actual
>> index, which is written in the mesh file?
>> Best
>> On Tue, Jul 19, 2022 at 6:11 PM Alexis Marboeuf <marboeua at mcmaster.ca>
>> wrote:
>>> Hi Bora,
>>> Thanks for your file.
>>> file.
>>> To address point after point your concerns:
>>> - a) You have here two differents ordering and distribution: the one
>>> given by Petsc after creating your DM from your file (which is
>>> distributed), i.e. before DMPlexDistribute and which is considered natural,
>>> and the one after DMPlexDistribute. Your natural SF maps between
>>> these two orderings. It means that you have 10 dofs (resp. 15 dofs) on proc
>>> 0 (resp. on proc 1) for both ordering. There is nothing wrong to me here.
>>> If you call "natural" the ordering from your file then you should call
>>> DMPlexDistributeSetDefault(dm,PETSC_FALSE) to disable the automatic
>>> distribution by Petsc when you load from the file. It will give you a
>>> "sequential" ordering.
>>> - b) I am not familiar with the overlap. From my understanding, even
>>> when you pass overlap = 0 to DMPlexDistribute, there is still an "overlap",
>>> i.e. points shared between procs. For your run on 2 procs, some dofs (5
>>> dofs in your case) are on both procs when it comes to local Vec but only
>>> one proc owes these dofs concerning global Vec. That's why your natural SF
>>> shows 5 dofs less on proc 0.
>>> - c) When the storage is contiguous, PetscSFGetGraph gives NULL for
>>> ilocal.
>>> I have an additional question constraint dofs and the natural SF. Are
>>> you on the 'release' branch? On 'main', the creation of the natural SF
>>> constraint dofs. I will submit a MR very soon about that. But it will be
>>> merged to main.
>>> Does this help?
>>> Best
>>> Alexis Marboeuf
>>> Postdoctoral fellow, Department of Mathematics & Statistics
>>> Hamilton Hall room 409B, McMaster University
>>> 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
>>> EMail: marboeua at mcmaster.ca
>>> Tel. +1 (905) 525 9140 ext. 27031
>>> *From:* Bora Jeong <boraj1021 at gmail.com>
>>> *Sent:* July 19, 2022 1:05 PM
>>> *To:* Alexis Marboeuf <marboeua at mcmaster.ca>
>>> *Cc:* Blaise Bourdin <bourdin at mcmaster.ca>; Matthew Knepley <
>>> knepley at gmail.com>; PETSc <petsc-users at mcs.anl.gov>
>>> *Subject:* Re: [petsc-users] DMPlex: a Mapping Array between Natural
>>> Alexis,
>>> Thanks for the reply with notes. The sample code with 2d square mesh is
>>> attached here. I am not sure either there is something wrong with Natural
>>> SF or some limitations in my understanding. Hopefully, the latter one is
>>> the thing.
>>> The attached sample code follows the similar procedures that you & Matt
>>> have suggested;
>>> - turn on DMSetUseNatural()
>>> - define section with 1dof on vertex before distribution of dm
>>> - manually distributing dm using DMPlexDistribute(), instead of relying
>>> on automatic distribution (e.g., DMSetFromOptions())
>>> - access graphs of Natural SF via PetscSFGetGraph()
>>> What I want to achieve;
>>> 1) define my own local array "A" that maps local vertex index to natural
>>> order, for example,
>>> A(local vertex index) = natural order of that local vertex.
>>> Here the "local vertex index" is obtained from DMPlexGetDepthStratum()
>>> with zero depth stratum, and mapped into 1 to number of vertex that each
>>> processor owns, for simplicity.
>>> Also, the "natural order" means the same indexing written in the mesh
>>> file.
>>> *2) Indeed, my inquiry is related to converting the vertex stratum from
>>> DMPlexGetDepthStratum() to the natural vertex index, which is written in
>>> the mesh file. *
>>> The problems, I have, are;
>>> a) I am a bit lost to interpret the meaning of values owned by the
>>> Natural SF. In the attached sample square mesh file, there are 25 vertex
>>> points. In the attached monitor file, Natural SF owns 10 roots & leaves for
>>> proc=0, and 15 roots & leaves for proc=1. In this case, how can I map these
>>> "local" and "remote" arrays into the natural vertex index?
>>> b) related to item a), DMPlexGetDepthStratum() is saying each processor
>>> owns 15 vertex points if np=2 without overlap. But Natural SF gives only 10
>>> roots & leaves for proc=0. Is there anything wrong? or did I misunderstand
>>> something?
>>> c) iroots pointer from PetscSFGetGraph() seems to have garbage data. By
>>> any chance, is it related to Fortran?
>>> Best
>>> On Tue, Jul 19, 2022 at 11:01 AM Alexis Marboeuf <marboeua at mcmaster.ca>
>>> wrote:
>>> I am unfortunately unable to access the attached code.
>>> Bora: have you defined constraint dofs in your section? In that case the
>>> natural SF is wrong, and you can notice duplicate entries for the roots if
>>> I remember correctly. I'll do a MR soon about that.
>>> The natural ordering and distribution is the one implemented by the DM
>>> before you call DMPlexDistribute. If your DM is automatically distributed
>>> when you load it from your GMSH file thanks to DMPlexCreateFromFile for
>>> example, you're not going to find your file ordering in the natural SF. You
>>> may call DMPlexDistributeSetDefault(dm,PETSC_FALE) to disable the automatic
>>> distribution.
>>> Best
>>> Alexis Marboeuf
>>> *From:* Blaise Bourdin <bourdin at mcmaster.ca>
>>> *Sent:* July 18, 2022 8:52 PM
>>> *To:* Bora Jeong <boraj1021 at gmail.com>
>>> *Cc:* Matthew Knepley <knepley at gmail.com>; PETSc <
>>> petsc-users at mcs.anl.gov>; Alexis Marboeuf <marboeua at mcmaster.ca>
>>> Alexis noticed a problem with the natural SF when constraints are
>>> defined. He has a MR coming.
>>> @Alexis: Could it be that what Bora sees is exactly what you fixed?
>>> Blaise
>>> On Jul 18, 2022, at 8:35 PM, Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Thank you for the reply.
>>> I am actually putting 1dof on the vertex points.
>>> In the attached sample code, from line 63 to line 99, 1dof on all vertex
>>> points is defined for the section. But my problem is, if I print out
>>> Natural SF using the viewer, I only have 10 vertex points, instead of 15.
>>> Here 15 is the size of the global vector defined by the aforementioned
>>> section. The working example code was attached to the previous email with a
>>> small grid.
>>> Best
>>> On Mon, Jul 18, 2022 at 6:50 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Mon, Jul 18, 2022 at 4:30 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Actually, it seems that my problem is that I do not properly understand
>>> what Natural SF means.
>>> What I want to achieve is to extract natural vertex index from Natural
>>> SF, and make sure this natural vertex index is the same with what is
>>> written in a mesh file from Gmsh. The natural vertex index defined by Gmsh
>>> is attached as a snapshot with sample code and mesh. I want to reproduce
>>> this indexing based on the Natural SF that Petsc defines.
>>> I am struggling with that because the number of entries defined in the
>>> Natural SF that I can see through PetscSFView() is different from the
>>> number of vertex points that each processor actually owns. For example,
>>> with two processors and with the attached "square.msh", each processor
>>> might have 15 vertex points if I configure Petsc with ParMetis. However,
>>> the defined Natural SF for proc=0 only has 10 roots. I expected, for each
>>> processor, the Natural SF would show me 15 entries through PetscSFView(),
>>> if I define 1 degree of freedom on vertex when the Petsc Section is
>>> defined.
>>> When Petsc defines the Natural SF, are there any omitted components
>>> since they are trivial to save?
>>> The naturalSF is mapping the field defined by the Section, not the mesh.
>>> You can get the effect you are asking for by putting one
>>> degree of freedom (dof) on every vertex for the Section. How are you
>>> defining your Section now?
>>> Thanks,
>>> Matt
>>> Best
>>> On Mon, Jul 18, 2022 at 3:50 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Mon, Jul 18, 2022 at 12:14 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Thank you for the corrections. It works.
>>> However, I still have a problem.
>>> I tested zero stratum for DMGetStratumIS() with the default depth label,
>>> since the graph of vertex is needed. Then, PetscSFGetGraph() from the
>>> Natural SF is crashed. I checked that pBcCompIS contains proper set of
>>> integers via ISView().
>>> On the other hand, it works okay if DMGetStratumIS() is with dim
>>> stratum, which is for cell stratum.
>>> The problem is that if the dim stratum is used, the number of entry in
>>> ileaves(i)% pointer does not match with the actual number of vertex that
>>> each processor has. That is why I tried to put the zero stratum on
>>> DMGetStratumIS(), instead of the stratum for cell (i.e., "dim") to see if
>>> any changes on the graph. Can I get comments?
>>> I cannot understand your question. I am not sure what you are using the
>>> set of vertices or cell for.
>>> Thanks,
>>> Matt
>>> Best
>>> On Sun, Jul 17, 2022 at 9:59 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Fri, Jul 15, 2022 at 7:05 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> I found that iroots() and ileaves() have size of nleaves and tested
>>> through the attached sample code with the grid previously shared. Then I
>>> get the results written in the attached monitor file.
>>> It seems ileaves(i)%rank and ileaves(i)%index at line 127 of the
>>> attached code have garbage values, different from displayed values by
>>> PetscSFView() at line 113.
>>> It is tough to get it why the garbage values are returned from
>>> PetscSFGetGraph(). Any comments will be very appreciated.
>>> Unfortunately, Fortran is not very good at reporting declaration errors.
>>> The problem is that you did not include or use the Vec module. I have done
>>> this and your example runs for me. I have included the modified code.
>>> Thanks,
>>> Matt
>>> Best
>>> On Fri, Jul 15, 2022 at 3:53 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Fri, Jul 15, 2022 at 2:25 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Thank you for the comments. Updated sample code is attached here;
>>> DMPlexDistribute() is explicitly called and by defining a section before
>>> mesh distribution, a Natural SF was able to be defined as found from
>>> PetscSFView().
>>> However, I am still struggling to call PetscSFGetGraph()
>>> https://petsc.org/main/docs/manualpages/PetscSF/PetscSFGetGraph/
>>> due to data type definition of ilocal and iremote. What is the proper
>>> size allocation for those two variables? Does this size for the number of
>>> processors? or the number of vertex?
>>> Since we need to pass back arrays, you need to pass us in F90 pointers.
>>> Here is an example of doing such a thing:
>>> https://gitlab.com/petsc/petsc/-/blob/main/src/vec/is/sf/tutorials/ex1f.F90#L94
>>> Thanks,
>>> Matt
>>> Best
>>> On Fri, Jul 15, 2022 at 9:09 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Fri, Jul 15, 2022 at 8:46 AM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Okay, I got it what's happening. First, this very bright functionality
>>> of petsc (the natural-global converting) needs to be documented in a better
>>> way for sure. Currently, it is very difficult to use/follow this features
>>> as an external user. Hope this will move forward in a better way.
>>> Then next question is if I load/distribute mesh just like I am doing
>>> right now shown in the sample code, can I assume that my code does not
>>> create natural sf during the distribution(always)? In other words, can I
>>> always get the natural order of each node by simply stacking the preceding
>>> processor's number of node? For example, for proc=0, natural node ID might
>>> be just 1 to nnode_proc_0,
>>> for proc=1, it might be {nnode_proc_0 + 1 to nnode_proc_0 +
>>> nnode_proc_1} and so on.
>>> Does that always make sense in this case?
>>> No, but if you call DMPlexDistribute() yourself, rather than having it
>>> called automatically by DMSetFromOptions(), you can
>>> preserve the mapping:
>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexDistribute/
>>> The SF returned maps the original point distribution, which is in the
>>> same order as the file, to the redistributed points, which are determined
>>> by the mesh partitioner.
>>> Thanks,
>>> Matt
>>> Best
>>> On Fri, Jul 15, 2022 at 8:07 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Fri, Jul 15, 2022 at 7:17 AM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> A sample code for loading dm and declaring Natural SF from a sphere mesh
>>> is attached here. PetscSFView() returns NULL from sf_nat.
>>> The Global-to-Natural mapping relates global dofs to natural dofs. Thus,
>>> in order to compute this mapping the DM has to know
>>> about the dof layout before distribution. This means you need to setup a
>>> local section before distributing, as we do for example in
>>> Plex test ex15. This makes things more complicated since everything
>>> cannot be packaged up into DMSetFromOptions(), but we need
>>> user input so I do not see a simpler way to do things.
>>> Thanks,
>>> Matt
>>> Best
>>> On Fri, Jul 15, 2022 at 6:39 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Thu, Jul 14, 2022 at 8:25 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Okay, I checked it and you are correct. In my case, simply, natural node
>>> index can be identified by stacking all the preceding processor's numbers
>>> of nodes for a particular processor, which is good due to simplicity.
>>> However, one serious question is why this is happening in my code? In other
>>> words, why the natural SF is not created during the mesh distribution? My
>>> code wants to have consistency in dealing with this natural indexing for
>>> several different kinds of mesh files. So there is a necessity to guarantee
>>> of consistency in this weird behavior.
>>> I can't tell what is going on in your code unless I can run it. Do you
>>> have a simple example?
>>> Thanks,
>>> Matt
>>> Best,
>>> On Thu, Jul 14, 2022 at 6:43 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Thu, Jul 14, 2022 at 5:47 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Thank you for the comments. I have these errors when I call
>>> PetscSFView() after DMGetNaturalSF()
>>> [2]PETSC ERROR: --------------------- Error Message
>>> [2]PETSC ERROR: Null argument, when expecting valid pointer
>>> [2]PETSC ERROR: Null Pointer: Parameter # 1
>>> [2]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>>> [2]PETSC ERROR: Petsc Release Version 3.17.0, unknown
>>> [2]PETSC ERROR: #1 PetscSFView() at
>>> [2]PETSC ERROR: #2 User provided function() at User file:0
>>> Abort(85) on node 2 (rank 0 in comm 16): application called
>>> MPI_Abort(MPI_COMM_SELF, 85) - process 0
>>> Clearly NULL was returned, which means no natural SF was created.
>>> Below is the structure to load a mesh file from gmsh;
>>> call DMCreate(PETSC_COMM_WORLD, dm, ierr);CHKERRA(ierr)
>>> call DMSetType(dm, plex, ierr);CHKERRA(ierr)
>>> call DMSetUseNatural(dm, PETSC_TRUE, ierr);CHKERRA(ierr)
>>> call DMSetFromOptions(dm, ierr);CHKERRA(ierr)
>>> call DMGetNaturalSF(dm, sf_nat, ierr);CHKERRA(ierr)
>>> call PetscSFView(sf_nat, PETSC_VIEWER_STDOUT_WORLD, ierr);CHKERRA(ierr)
>>> The natural SF is created during mesh distribution. That has not
>>> happened here. This means that
>>> the order of cells is identical to the file it was read from.
>>> Thanks,
>>> Matt
>>> Best
>>> On Thu, Jul 14, 2022 at 10:49 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Wed, Jul 13, 2022 at 10:17 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Dear petsc team,
>>> I am a user of DMPlex for a finite volume code and there is a necessity
>>> to know global index of each cell. Here the global index means the indexing
>>> that can be found from a mesh file itself without distribution over
>>> processors. It seems petsc community denotes this indexing term as
>>> "natural".
>>> What I want to do is to create a local array (not petsc vector but just
>>> an array variable in the program) to map distributed cell ID to natual cell
>>> ID, for example, an array "A";
>>> A(distributed_node_ID) = natural_node_ID
>>> There are some petsc functions to support mapping between global and
>>> natural vectors. However, I just need to define the array "A" as above
>>> example. To achieve this, what is a proper/smart way? In other words, how
>>> can I extract the natural_cell_ID from a distributed local_cell_ID?
>>> I turned on DMSetUseNatural(DM, PETSC_TRUE) before distribution, but
>>> after this, defining all the required section and star forest objects to
>>> get natural and global vectors seems not that direct way for my purpose,
>>> which is just to extract the above mapping array "A". Can I get any
>>> comments about it?
>>> There is only one thing created, the sfNatural PetscSF object, which you
>>> can get with DMGetNaturalSF(). The roots of this SF are
>>> the global numbers of dofs stored in PETSc vectors, and the leaves are
>>> natural numbers for these dofs. Thus, when we map global
>>> vectors to natural vectors in DMPlexGlobalToNaturalBegin/End(), we
>>> call PetscSFBcastBegin/End(). Mapping natural to global we call
>>> PetscSFReduceBegin/End(). You could pull the information out of the SF
>>> using PetscSFGetGraph() if you want.
>>> Thanks,
>>> Matt
>>> Regards
>>> Mo
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> <test.F90>
>>> Tier 1 Canada Research Chair in Mathematical and Computational Aspects
>>> of Solid Mechanics
>>> Professor, Department of Mathematics & Statistics
>>> Hamilton Hall room 409A, McMaster University
>>> https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220720/71e90716/attachment-0001.html>
