[petsc-users] DMPlex: a Mapping Array between Natural and Distributed Cell Index
Matthew Knepley
knepley at gmail.com
Sun Jul 17 09:59:03 CDT 2022
On Fri, Jul 15, 2022 at 7:05 PM Bora Jeong <boraj1021 at gmail.com> wrote:
> I found that iroots() and ileaves() have size of nleaves and tested
> through the attached sample code with the grid previously shared. Then I
> get the results written in the attached monitor file.
> It seems ileaves(i)%rank and ileaves(i)%index at line 127 of the attached
> code have garbage values, different from displayed values by PetscSFView()
> at line 113.
> It is tough to get it why the garbage values are returned from
> PetscSFGetGraph(). Any comments will be very appreciated.
Unfortunately, Fortran is not very good at reporting declaration errors.
The problem is that you did not include or use the Vec module. I have done
this and your example runs for me. I have included the modified code.
Matt
> Best
> On Fri, Jul 15, 2022 at 3:53 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jul 15, 2022 at 2:25 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Thank you for the comments. Updated sample code is attached here;
>>> DMPlexDistribute() is explicitly called and by defining a section before
>>> mesh distribution, a Natural SF was able to be defined as found from
>>> PetscSFView().
>>> However, I am still struggling to call PetscSFGetGraph()
>>> https://petsc.org/main/docs/manualpages/PetscSF/PetscSFGetGraph/
>>> due to data type definition of ilocal and iremote. What is the proper
>>> size allocation for those two variables? Does this size for the number of
>>> processors? or the number of vertex?
>> Since we need to pass back arrays, you need to pass us in F90 pointers.
>> Here is an example of doing such a thing:
>> https://gitlab.com/petsc/petsc/-/blob/main/src/vec/is/sf/tutorials/ex1f.F90#L94
>> Thanks,
>> Matt
>>> Best
>>> On Fri, Jul 15, 2022 at 9:09 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Jul 15, 2022 at 8:46 AM Bora Jeong <boraj1021 at gmail.com> wrote:
>>>>> Okay, I got it what's happening. First, this very bright functionality
>>>>> of petsc (the natural-global converting) needs to be documented in a better
>>>>> way for sure. Currently, it is very difficult to use/follow this features
>>>>> as an external user. Hope this will move forward in a better way.
>>>>> Then next question is if I load/distribute mesh just like I am doing
>>>>> right now shown in the sample code, can I assume that my code does not
>>>>> create natural sf during the distribution(always)? In other words, can I
>>>>> always get the natural order of each node by simply stacking the preceding
>>>>> processor's number of node? For example, for proc=0, natural node ID might
>>>>> be just 1 to nnode_proc_0,
>>>>> for proc=1, it might be {nnode_proc_0 + 1 to nnode_proc_0 +
>>>>> nnode_proc_1} and so on.
>>>>> Does that always make sense in this case?
>>>> No, but if you call DMPlexDistribute() yourself, rather than having it
>>>> called automatically by DMSetFromOptions(), you can
>>>> preserve the mapping:
>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexDistribute/
>>>> The SF returned maps the original point distribution, which is in the
>>>> same order as the file, to the redistributed points, which are determined
>>>> by the mesh partitioner.
>>>> Thanks,
>>>> Matt
>>>>> Best
>>>>> On Fri, Jul 15, 2022 at 8:07 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Fri, Jul 15, 2022 at 7:17 AM Bora Jeong <boraj1021 at gmail.com>
>>>>>> wrote:
>>>>>>> A sample code for loading dm and declaring Natural SF from a sphere
>>>>>>> mesh is attached here. PetscSFView() returns NULL from sf_nat.
>>>>>> The Global-to-Natural mapping relates global dofs to natural dofs.
>>>>>> Thus, in order to compute this mapping the DM has to know
>>>>>> about the dof layout before distribution. This means you need to
>>>>>> setup a local section before distributing, as we do for example in
>>>>>> Plex test ex15. This makes things more complicated since everything
>>>>>> cannot be packaged up into DMSetFromOptions(), but we need
>>>>>> user input so I do not see a simpler way to do things.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Best
>>>>>>> On Fri, Jul 15, 2022 at 6:39 AM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Thu, Jul 14, 2022 at 8:25 PM Bora Jeong <boraj1021 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Okay, I checked it and you are correct. In my case, simply,
>>>>>>>>> natural node index can be identified by stacking all the preceding
>>>>>>>>> processor's numbers of nodes for a particular processor, which is good due
>>>>>>>>> to simplicity. However, one serious question is why this is happening in my
>>>>>>>>> code? In other words, why the natural SF is not created during the mesh
>>>>>>>>> distribution? My code wants to have consistency in dealing with this
>>>>>>>>> natural indexing for several different kinds of mesh files. So there is a
>>>>>>>>> necessity to guarantee of consistency in this weird behavior.
>>>>>>>> I can't tell what is going on in your code unless I can run it. Do
>>>>>>>> you have a simple example?
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>>> Best,
>>>>>>>>> On Thu, Jul 14, 2022 at 6:43 PM Matthew Knepley <knepley at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> On Thu, Jul 14, 2022 at 5:47 PM Bora Jeong <boraj1021 at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Thank you for the comments. I have these errors when I call
>>>>>>>>>>> PetscSFView() after DMGetNaturalSF()
>>>>>>>>>>> [2]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>> [2]PETSC ERROR: Null argument, when expecting valid pointer
>>>>>>>>>>> [2]PETSC ERROR: Null Pointer: Parameter # 1
>>>>>>>>>>> [2]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>>>>>>> shooting.
>>>>>>>>>>> [2]PETSC ERROR: Petsc Release Version 3.17.0, unknown
>>>>>>>>>>> [2]PETSC ERROR: #1 PetscSFView() at
>>>>>>>>>>> [2]PETSC ERROR: #2 User provided function() at User file:0
>>>>>>>>>>> Abort(85) on node 2 (rank 0 in comm 16): application called
>>>>>>>>>>> MPI_Abort(MPI_COMM_SELF, 85) - process 0
>>>>>>>>>> Clearly NULL was returned, which means no natural SF was created.
>>>>>>>>>>> Below is the structure to load a mesh file from gmsh;
>>>>>>>>>>> call DMCreate(PETSC_COMM_WORLD, dm, ierr);CHKERRA(ierr)
>>>>>>>>>>> call DMSetType(dm, plex, ierr);CHKERRA(ierr)
>>>>>>>>>>> call DMSetUseNatural(dm, PETSC_TRUE, ierr);CHKERRA(ierr)
>>>>>>>>>>> call DMSetFromOptions(dm, ierr);CHKERRA(ierr)
>>>>>>>>>>> call DMGetNaturalSF(dm, sf_nat, ierr);CHKERRA(ierr)
>>>>>>>>>>> call PetscSFView(sf_nat, PETSC_VIEWER_STDOUT_WORLD,
>>>>>>>>>>> ierr);CHKERRA(ierr)
>>>>>>>>>> The natural SF is created during mesh distribution. That has not
>>>>>>>>>> happened here. This means that
>>>>>>>>>> the order of cells is identical to the file it was read from.
>>>>>>>>>> Thanks,
>>>>>>>>>> Matt
>>>>>>>>>>> Best
>>>>>>>>>>> On Thu, Jul 14, 2022 at 10:49 AM Matthew Knepley <
>>>>>>>>>>>> On Wed, Jul 13, 2022 at 10:17 PM Bora Jeong <
>>>>>>>>>>>>> Dear petsc team,
>>>>>>>>>>>>> I am a user of DMPlex for a finite volume code and there is a
>>>>>>>>>>>>> necessity to know global index of each cell. Here the global index means
>>>>>>>>>>>>> the indexing that can be found from a mesh file itself without distribution
>>>>>>>>>>>>> over processors. It seems petsc community denotes this indexing term as
>>>>>>>>>>>>> "natural".
>>>>>>>>>>>>> What I want to do is to create a local array (not petsc vector
>>>>>>>>>>>>> but just an array variable in the program) to map distributed cell ID to
>>>>>>>>>>>>> natual cell ID, for example, an array "A";
>>>>>>>>>>>>> A(distributed_node_ID) = natural_node_ID
>>>>>>>>>>>>> There are some petsc functions to support mapping between
>>>>>>>>>>>>> global and natural vectors. However, I just need to define the array "A" as
>>>>>>>>>>>>> above example. To achieve this, what is a proper/smart way? In other words,
>>>>>>>>>>>>> how can I extract the natural_cell_ID from a distributed local_cell_ID?
>>>>>>>>>>>>> I turned on DMSetUseNatural(DM, PETSC_TRUE) before
>>>>>>>>>>>>> distribution, but after this, defining all the required section and star
>>>>>>>>>>>>> forest objects to get natural and global vectors seems not that direct way
>>>>>>>>>>>>> for my purpose, which is just to extract the above mapping array "A". Can I
>>>>>>>>>>>>> get any comments about it?
>>>>>>>>>>>> There is only one thing created, the sfNatural PetscSF object,
>>>>>>>>>>>> which you can get with DMGetNaturalSF(). The roots of this SF are
>>>>>>>>>>>> the global numbers of dofs stored in PETSc vectors, and the
>>>>>>>>>>>> leaves are natural numbers for these dofs. Thus, when we map global
>>>>>>>>>>>> vectors to natural vectors in DMPlexGlobalToNaturalBegin/End(),
>>>>>>>>>>>> we call PetscSFBcastBegin/End(). Mapping natural to global we call
>>>>>>>>>>>> PetscSFReduceBegin/End(). You could pull the information out of
>>>>>>>>>>>> the SF using PetscSFGetGraph() if you want.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Matt
>>>>>>>>>>>>> Regards
>>>>>>>>>>>>> Mo
>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220717/798439b0/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220717/798439b0/attachment-0001.obj>
