[petsc-users] DMPlex: a Mapping Array between Natural and Distributed Cell Index
Matthew Knepley
knepley at gmail.com
Thu Jul 14 18:43:44 CDT 2022
On Thu, Jul 14, 2022 at 5:47 PM Bora Jeong <boraj1021 at gmail.com> wrote:
> Thank you for the comments. I have these errors when I call PetscSFView()
> after DMGetNaturalSF()
> [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Null argument, when expecting valid pointer
> [2]PETSC ERROR: Null Pointer: Parameter # 1
> [2]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [2]PETSC ERROR: Petsc Release Version 3.17.0, unknown
> [2]PETSC ERROR: #1 PetscSFView() at
> [2]PETSC ERROR: #2 User provided function() at User file:0
> Abort(85) on node 2 (rank 0 in comm 16): application called
> MPI_Abort(MPI_COMM_SELF, 85) - process 0
Clearly NULL was returned, which means no natural SF was created.
> Below is the structure to load a mesh file from gmsh;
> call DMCreate(PETSC_COMM_WORLD, dm, ierr);CHKERRA(ierr)
> call DMSetType(dm, plex, ierr);CHKERRA(ierr)
> call DMSetUseNatural(dm, PETSC_TRUE, ierr);CHKERRA(ierr)
> call DMSetFromOptions(dm, ierr);CHKERRA(ierr)
> call DMGetNaturalSF(dm, sf_nat, ierr);CHKERRA(ierr)
> call PetscSFView(sf_nat, PETSC_VIEWER_STDOUT_WORLD, ierr);CHKERRA(ierr)
The natural SF is created during mesh distribution. That has not happened
here. This means that
the order of cells is identical to the file it was read from.
Matt
> Best
> On Thu, Jul 14, 2022 at 10:49 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jul 13, 2022 at 10:17 PM Bora Jeong <boraj1021 at gmail.com> wrote:
>>> Dear petsc team,
>>> I am a user of DMPlex for a finite volume code and there is a necessity
>>> to know global index of each cell. Here the global index means the indexing
>>> that can be found from a mesh file itself without distribution over
>>> processors. It seems petsc community denotes this indexing term as
>>> "natural".
>>> What I want to do is to create a local array (not petsc vector but just
>>> an array variable in the program) to map distributed cell ID to natual cell
>>> ID, for example, an array "A";
>>> A(distributed_node_ID) = natural_node_ID
>>> There are some petsc functions to support mapping between global and
>>> natural vectors. However, I just need to define the array "A" as above
>>> example. To achieve this, what is a proper/smart way? In other words, how
>>> can I extract the natural_cell_ID from a distributed local_cell_ID?
>>> I turned on DMSetUseNatural(DM, PETSC_TRUE) before distribution, but
>>> after this, defining all the required section and star forest objects to
>>> get natural and global vectors seems not that direct way for my purpose,
>>> which is just to extract the above mapping array "A". Can I get any
>>> comments about it?
>> There is only one thing created, the sfNatural PetscSF object, which you
>> can get with DMGetNaturalSF(). The roots of this SF are
>> the global numbers of dofs stored in PETSc vectors, and the leaves are
>> natural numbers for these dofs. Thus, when we map global
>> vectors to natural vectors in DMPlexGlobalToNaturalBegin/End(), we
>> call PetscSFBcastBegin/End(). Mapping natural to global we call
>> PetscSFReduceBegin/End(). You could pull the information out of the SF
>> using PetscSFGetGraph() if you want.
>> Thanks,
>> Matt
>>> Regards
>>> Mo
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220714/fee68760/attachment.html>
