[petsc-users] DMPlexCreateSection crashed with larger number of processors
Mike Michell
mi.mike1021 at gmail.com
Wed Jul 13 10:08:16 CDT 2022
What I did to avoid the crash is to provide bcPointIS from "call
DMGetStratumIS(dm_geom, "depth", dim, bcPointIS(1),ierr);CHKERRA(ierr)",
instead of "marker" for calling DMGetStratumIS().
The petscsection building part is
from src/dm/impls/plex/tutorials/ex1f90.F90 (See line 72).
> On Sat, Jul 9, 2022 at 8:34 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jul 8, 2022 at 7:41 PM Mike Michell <mi.mike1021 at gmail.com>
>> wrote:
>>> As a follow-up, just "depth" default label was provided to avoid NULL
>>> PETScIS, and it seems working.
>> Ah, "depth" is definitely required and is produced by DMPlexStratify(). I
>> will put in a check for this so that you get a good error message.
> I cannot find an instance of an IS being pulled from the depth label here.
> Do you have something I can run that shows this fault?
> Thanks,
> Matt
>> Thanks!
>> Matt
>>> Thanks,
>>> Mike
>>>> It looks like NULL PETScIS is obtained from DMGetStratumIS() which is
>>>> shown in the previously attached code. Currently, "marker" label is used to
>>>> define default bcPointIS pointer with numBC=1 through DMGetStratumIS(), and
>>>> it seems that if a certain proc does not have any boundary from this
>>>> "marker" label, the DMPlexCreateSection() crashes.
>>>> The PETSc's manual page for DMPlexCreateSection() says "bcPoints" is an
>>>> IS holding points to which each boundary condition applies. So, by
>>>> including no boundary for a certain distributed mesh block, it looks very
>>>> natural that this function crashes. How can I not to pass a NULL PETScIS in
>>>> this case? Is there any specific way for that (or a trick)?
>>>> Thanks,
>>>> Mike
>>>>> On Wed, Jul 6, 2022 at 3:42 PM Mike Michell <mi.mike1021 at gmail.com>
>>>>> wrote:
>>>>>> I am passing NULL for IS Permutation as;
>>>>>> call
>>>>>> DMPlexCreateSection(dm_geom,nolabel,pNumComp,pNumDof,numBC,pBcField,pBcCompIS,pBcPointIS,PETSC_NULL_IS,section,ierr)
>>>>>> Should I define non-NULL IS Permutation before I call
>>>>>> DMPlexCreateSection() to avoid the issue?
>>>>> No, the problem is not the perm argument. To be sure, we should get a
>>>>> stack trace with line numbers (use a debug build). To me it looked
>>>>> like you passed a NULL IS to DMAddBoundary().
>>>>> Thanks,
>>>>> Matt
>>>>>> Thanks,
>>>>>> Mike
>>>>>> On Wed, Jul 6, 2022 at 12:57 PM Mike Michell <mi.mike1021 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi, I am using DMPlex for a FVM code written in Fortran that uses
>>>>>>>> DMPlexCreateSection() to prepare an output file in vtu format. A domain of
>>>>>>>> interest has around 5000 node points and with small number of processors
>>>>>>>> (such as nproc=3), the DMPlexCreateSection() works fine. However, if a
>>>>>>>> larger number of procs (such as nproc=20) is used, DMPlexCreateSection()
>>>>>>>> crashes with error message below. It looks very similar problem in a
>>>>>>>> previous PETSc user inquiry: " [petsc-dev] DMPlexCreateSection
>>>>>>>> crash in a no-boundary corner case
>>>>>>>> <https://lists.mcs.anl.gov/pipermail/petsc-dev/2013-November/014049.html>
>>>>>>> Yes, the recommendation is not to pass a NULL PetscIS to the
>>>>>>> AddBoundary() routine. Are you doing this?
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> When I call DMPlexCreateSection(), a nullified pointer
>>>>>>>> "nolabel(:)=>NULL()" is provided. What is a possible solution to this
>>>>>>>> problem? It looks like there is a problem with a processor that does not
>>>>>>>> have any boundaries. A piece of the source code is attached to show how
>>>>>>>> the DMPlexCreateSection() is used in the code.
>>>>>>>> Thanks,
>>>>>>>> Mike
>>>>>>>> [16]PETSC ERROR: --------------------- Error Message
>>>>>>>> [16]PETSC ERROR: Null argument, when expecting valid pointer
>>>>>>>> [16]PETSC ERROR: Null Pointer: Parameter # 1
>>>>>>>> [16]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>>>> shooting.
>>>>>>>> [16]PETSC ERROR: Petsc Release Version 3.17.0, unknown
>>>>>>>> [16]PETSC ERROR: #1 ISGetLocalSize() at
>>>>>>>> [16]PETSC ERROR: #2 DMPlexCreateSectionBCDof() at
>>>>>>>> [16]PETSC ERROR: #3 DMPlexCreateSection() at
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220713/c5cc9e0e/attachment.html>
