[petsc-users] SLEPc EPSGD: Can not converge, error estimation floats over 1e-6
Runfeng Jin
jsfaraway at gmail.com
Tue Jul 12 21:59:34 CDT 2022
Hi!
I am trying to find 3 eigenvalues of a matrix 81,160*81,160, and it get 0
eigenvalue after 162320 iterations. I use *-eps_monitor* and find error
estimation floats over 1e-6, I didn't set the tolerance so it should be the
default 1e-8. Actually it should achieve 1e-10.
I have tried JD and GD, both of them can not converge. Does there any ways
to help it converge to the 1e-10?
By the way, I use default Convergence criterion, the output of *-log_view*
and *-eps_monitor* are shown in attachment.
Thank you!
Runfeng Jin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220713/034ec6a4/attachment-0001.html>
142639 EPS nconv=0 first unconverged value (error) -302.035 (1.79535899e-06)
142640 EPS nconv=0 first unconverged value (error) -302.035 (2.42501766e-06)
142641 EPS nconv=0 first unconverged value (error) -302.035 (2.38455514e-06)
142642 EPS nconv=0 first unconverged value (error) -302.035 (2.30574015e-06)
142643 EPS nconv=0 first unconverged value (error) -302.035 (2.25409948e-06)
142644 EPS nconv=0 first unconverged value (error) -302.035 (2.22352766e-06)
142645 EPS nconv=0 first unconverged value (error) -302.035 (2.22352766e-06)
142646 EPS nconv=0 first unconverged value (error) -302.035 (2.68459761e-06)
142647 EPS nconv=0 first unconverged value (error) -302.035 (2.32889243e-06)
142648 EPS nconv=0 first unconverged value (error) -302.035 (2.14172757e-06)
142649 EPS nconv=0 first unconverged value (error) -302.035 (2.12903731e-06)
142650 EPS nconv=0 first unconverged value (error) -302.035 (2.09595181e-06)
142651 EPS nconv=0 first unconverged value (error) -302.035 (2.09595181e-06)
142652 EPS nconv=0 first unconverged value (error) -302.035 (2.18297806e-06)
142653 EPS nconv=0 first unconverged value (error) -302.035 (2.37509626e-06)
142654 EPS nconv=0 first unconverged value (error) -302.035 (2.10315813e-06)
142655 EPS nconv=0 first unconverged value (error) -302.035 (1.99559442e-06)
142656 EPS nconv=0 first unconverged value (error) -302.035 (1.89919014e-06)
142657 EPS nconv=0 first unconverged value (error) -302.035 (1.89919014e-06)
142658 EPS nconv=0 first unconverged value (error) -302.035 (2.65594682e-06)
142659 EPS nconv=0 first unconverged value (error) -302.035 (2.63023919e-06)
142660 EPS nconv=0 first unconverged value (error) -302.035 (2.46632309e-06)
142661 EPS nconv=0 first unconverged value (error) -302.035 (2.32509006e-06)
142662 EPS nconv=0 first unconverged value (error) -302.035 (2.23128284e-06)
142663 EPS nconv=0 first unconverged value (error) -302.035 (2.23128284e-06)
142664 EPS nconv=0 first unconverged value (error) -302.035 (2.46300085e-06)
142665 EPS nconv=0 first unconverged value (error) -302.035 (2.36182190e-06)
142666 EPS nconv=0 first unconverged value (error) -302.035 (2.17688580e-06)
142667 EPS nconv=0 first unconverged value (error) -302.035 (2.06395519e-06)
142668 EPS nconv=0 first unconverged value (error) -302.035 (2.05163935e-06)
142669 EPS nconv=0 first unconverged value (error) -302.035 (2.05163935e-06)
142670 EPS nconv=0 first unconverged value (error) -302.035 (2.04073181e-06)
142671 EPS nconv=0 first unconverged value (error) -302.035 (1.99442176e-06)
142672 EPS nconv=0 first unconverged value (error) -302.035 (1.92060129e-06)
142673 EPS nconv=0 first unconverged value (error) -302.035 (1.86217431e-06)
142674 EPS nconv=0 first unconverged value (error) -302.035 (1.83873056e-06)
142675 EPS nconv=0 first unconverged value (error) -302.035 (1.83873056e-06)
142676 EPS nconv=0 first unconverged value (error) -302.035 (2.25155496e-06)
142677 EPS nconv=0 first unconverged value (error) -302.035 (2.12025758e-06)
142678 EPS nconv=0 first unconverged value (error) -302.035 (2.03219603e-06)
142679 EPS nconv=0 first unconverged value (error) -302.035 (2.01101216e-06)
142680 EPS nconv=0 first unconverged value (error) -302.035 (1.99228424e-06)
142681 EPS nconv=0 first unconverged value (error) -302.035 (1.99228424e-06)
142682 EPS nconv=0 first unconverged value (error) -302.035 (2.11674046e-06)
142683 EPS nconv=0 first unconverged value (error) -302.035 (2.23245596e-06)
142684 EPS nconv=0 first unconverged value (error) -302.035 (2.04648693e-06)
142685 EPS nconv=0 first unconverged value (error) -302.035 (1.96835969e-06)
142686 EPS nconv=0 first unconverged value (error) -302.035 (1.94404833e-06)
142687 EPS nconv=0 first unconverged value (error) -302.035 (1.94404833e-06)
142688 EPS nconv=0 first unconverged value (error) -302.035 (1.92643044e-06)
142689 EPS nconv=0 first unconverged value (error) -302.035 (1.88567748e-06)
142690 EPS nconv=0 first unconverged value (error) -302.035 (1.83845691e-06)
142691 EPS nconv=0 first unconverged value (error) -302.035 (1.83347180e-06)
142692 EPS nconv=0 first unconverged value (error) -302.035 (1.82225590e-06)
142693 EPS nconv=0 first unconverged value (error) -302.035 (1.82225590e-06)
142694 EPS nconv=0 first unconverged value (error) -302.035 (1.83560394e-06)
142695 EPS nconv=0 first unconverged value (error) -302.035 (1.84127383e-06)
142696 EPS nconv=0 first unconverged value (error) -302.035 (1.82083737e-06)
142697 EPS nconv=0 first unconverged value (error) -302.035 (1.81134336e-06)
142698 EPS nconv=0 first unconverged value (error) -302.035 (1.80857215e-06)
142699 EPS nconv=0 first unconverged value (error) -302.035 (1.80857215e-06)
142700 EPS nconv=0 first unconverged value (error) -302.035 (1.82552682e-06)
142701 EPS nconv=0 first unconverged value (error) -302.035 (1.81970922e-06)
142702 EPS nconv=0 first unconverged value (error) -302.035 (1.81358313e-06)
142703 EPS nconv=0 first unconverged value (error) -302.035 (1.80798801e-06)
142704 EPS nconv=0 first unconverged value (error) -302.035 (1.80360283e-06)
142705 EPS nconv=0 first unconverged value (error) -302.035 (1.80360283e-06)
142706 EPS nconv=0 first unconverged value (error) -302.035 (2.00611159e-06)
142707 EPS nconv=0 first unconverged value (error) -302.035 (1.99496964e-06)
142708 EPS nconv=0 first unconverged value (error) -302.035 (1.96625539e-06)
142709 EPS nconv=0 first unconverged value (error) -302.035 (1.90981066e-06)
142710 EPS nconv=0 first unconverged value (error) -302.035 (1.89575897e-06)
142711 EPS nconv=0 first unconverged value (error) -302.035 (1.89575897e-06)
142712 EPS nconv=0 first unconverged value (error) -302.035 (1.99173896e-06)
142713 EPS nconv=0 first unconverged value (error) -302.035 (1.94158107e-06)
142714 EPS nconv=0 first unconverged value (error) -302.035 (1.90539755e-06)
142715 EPS nconv=0 first unconverged value (error) -302.035 (1.87115652e-06)
142716 EPS nconv=0 first unconverged value (error) -302.035 (1.86918280e-06)
142717 EPS nconv=0 first unconverged value (error) -302.035 (1.86918280e-06)
142718 EPS nconv=0 first unconverged value (error) -302.035 (1.86328962e-06)
142719 EPS nconv=0 first unconverged value (error) -302.035 (1.85603899e-06)
142720 EPS nconv=0 first unconverged value (error) -302.035 (1.81436413e-06)
142721 EPS nconv=0 first unconverged value (error) -302.035 (1.80790211e-06)
142722 EPS nconv=0 first unconverged value (error) -302.035 (1.80410084e-06)
142723 EPS nconv=0 first unconverged value (error) -302.035 (1.80410084e-06)
142724 EPS nconv=0 first unconverged value (error) -302.035 (2.41857231e-06)
142725 EPS nconv=0 first unconverged value (error) -302.035 (2.20844103e-06)
142726 EPS nconv=0 first unconverged value (error) -302.035 (2.07471893e-06)
142727 EPS nconv=0 first unconverged value (error) -302.035 (2.04130779e-06)
142728 EPS nconv=0 first unconverged value (error) -302.035 (2.01049072e-06)
142729 EPS nconv=0 first unconverged value (error) -302.035 (2.01049072e-06)
142730 EPS nconv=0 first unconverged value (error) -302.035 (3.27432039e-06)
142731 EPS nconv=0 first unconverged value (error) -302.035 (3.17779905e-06)
142732 EPS nconv=0 first unconverged value (error) -302.035 (3.02157212e-06)
142733 EPS nconv=0 first unconverged value (error) -302.035 (2.96872485e-06)
142734 EPS nconv=0 first unconverged value (error) -302.035 (2.95798905e-06)
142735 EPS nconv=0 first unconverged value (error) -302.035 (2.95798905e-06)
142736 EPS nconv=0 first unconverged value (error) -302.035 (3.06191502e-06)
142737 EPS nconv=0 first unconverged value (error) -302.035 (2.29805927e-06)
142738 EPS nconv=0 first unconverged value (error) -302.035 (2.08594436e-06)
142739 EPS nconv=0 first unconverged value (error) -302.035 (2.07904267e-06)
142740 EPS nconv=0 first unconverged value (error) -302.035 (1.94394343e-06)
142741 EPS nconv=0 first unconverged value (error) -302.035 (1.94394343e-06)
142742 EPS nconv=0 first unconverged value (error) -302.035 (2.19541042e-06)
142743 EPS nconv=0 first unconverged value (error) -302.035 (2.14111395e-06)
142744 EPS nconv=0 first unconverged value (error) -302.035 (1.96400454e-06)
142745 EPS nconv=0 first unconverged value (error) -302.035 (1.90945818e-06)
142746 EPS nconv=0 first unconverged value (error) -302.035 (1.88938227e-06)
142747 EPS nconv=0 first unconverged value (error) -302.035 (1.88938227e-06)
142748 EPS nconv=0 first unconverged value (error) -302.035 (1.97767934e-06)
142749 EPS nconv=0 first unconverged value (error) -302.035 (2.04699359e-06)
142750 EPS nconv=0 first unconverged value (error) -302.035 (1.99556520e-06)
142751 EPS nconv=0 first unconverged value (error) -302.035 (1.85787360e-06)
142752 EPS nconv=0 first unconverged value (error) -302.035 (1.84128957e-06)
142753 EPS nconv=0 first unconverged value (error) -302.035 (1.84128957e-06)
142754 EPS nconv=0 first unconverged value (error) -302.035 (1.86847109e-06)
142755 EPS nconv=0 first unconverged value (error) -302.035 (1.87928079e-06)
142756 EPS nconv=0 first unconverged value (error) -302.035 (1.85244751e-06)
142757 EPS nconv=0 first unconverged value (error) -302.035 (1.83199221e-06)
142758 EPS nconv=0 first unconverged value (error) -302.035 (1.82376846e-06)
142759 EPS nconv=0 first unconverged value (error) -302.035 (1.82376846e-06)
142760 EPS nconv=0 first unconverged value (error) -302.035 (2.26633093e-06)
142761 EPS nconv=0 first unconverged value (error) -302.035 (2.17795988e-06)
142762 EPS nconv=0 first unconverged value (error) -302.035 (2.12007921e-06)
142763 EPS nconv=0 first unconverged value (error) -302.035 (2.03558857e-06)
142764 EPS nconv=0 first unconverged value (error) -302.035 (1.99447214e-06)
142765 EPS nconv=0 first unconverged value (error) -302.035 (1.99447214e-06)
142766 EPS nconv=0 first unconverged value (error) -302.035 (2.93725848e-06)
142767 EPS nconv=0 first unconverged value (error) -302.035 (2.76773164e-06)
142768 EPS nconv=0 first unconverged value (error) -302.035 (2.59617569e-06)
142769 EPS nconv=0 first unconverged value (error) -302.035 (2.59943425e-06)
142770 EPS nconv=0 first unconverged value (error) -302.035 (2.54103266e-06)
142771 EPS nconv=0 first unconverged value (error) -302.035 (2.54103266e-06)
142772 EPS nconv=0 first unconverged value (error) -302.035 (3.21424607e-06)
142773 EPS nconv=0 first unconverged value (error) -302.035 (3.02724530e-06)
142774 EPS nconv=0 first unconverged value (error) -302.035 (2.63433276e-06)
142775 EPS nconv=0 first unconverged value (error) -302.035 (2.60980875e-06)
142776 EPS nconv=0 first unconverged value (error) -302.035 (2.53361800e-06)
142777 EPS nconv=0 first unconverged value (error) -302.035 (2.53361800e-06)
142778 EPS nconv=0 first unconverged value (error) -302.035 (2.56519923e-06)
142779 EPS nconv=0 first unconverged value (error) -302.035 (2.46634678e-06)
142780 EPS nconv=0 first unconverged value (error) -302.035 (2.49397035e-06)
142781 EPS nconv=0 first unconverged value (error) -302.035 (2.08013110e-06)
142782 EPS nconv=0 first unconverged value (error) -302.035 (1.88565151e-06)
142783 EPS nconv=0 first unconverged value (error) -302.035 (1.88565151e-06)
142784 EPS nconv=0 first unconverged value (error) -302.035 (1.93799887e-06)
142785 EPS nconv=0 first unconverged value (error) -302.035 (1.97684002e-06)
142786 EPS nconv=0 first unconverged value (error) -302.035 (1.95521926e-06)
142787 EPS nconv=0 first unconverged value (error) -302.035 (1.88098099e-06)
142788 EPS nconv=0 first unconverged value (error) -302.035 (1.86885455e-06)
142789 EPS nconv=0 first unconverged value (error) -302.035 (1.86885455e-06)
142790 EPS nconv=0 first unconverged value (error) -302.035 (2.20123699e-06)
142791 EPS nconv=0 first unconverged value (error) -302.035 (2.01320308e-06)
142792 EPS nconv=0 first unconverged value (error) -302.035 (1.90530982e-06)
142793 EPS nconv=0 first unconverged value (error) -302.035 (1.89917188e-06)
142794 EPS nconv=0 first unconverged value (error) -302.035 (1.87648189e-06)
142795 EPS nconv=0 first unconverged value (error) -302.035 (1.87648189e-06)
142796 EPS nconv=0 first unconverged value (error) -302.035 (2.81389647e-06)
142797 EPS nconv=0 first unconverged value (error) -302.035 (2.74951593e-06)
142798 EPS nconv=0 first unconverged value (error) -302.035 (2.41248120e-06)
142799 EPS nconv=0 first unconverged value (error) -302.035 (2.33317556e-06)
142800 EPS nconv=0 first unconverged value (error) -302.035 (2.26949173e-06)
142801 EPS nconv=0 first unconverged value (error) -302.035 (2.26949173e-06)
142802 EPS nconv=0 first unconverged value (error) -302.035 (2.77437174e-06)
142803 EPS nconv=0 first unconverged value (error) -302.035 (2.65794510e-06)
142804 EPS nconv=0 first unconverged value (error) -302.035 (2.44916902e-06)
142805 EPS nconv=0 first unconverged value (error) -302.035 (2.31220313e-06)
142806 EPS nconv=0 first unconverged value (error) -302.035 (2.20561813e-06)
142807 EPS nconv=0 first unconverged value (error) -302.035 (2.20561813e-06)
142808 EPS nconv=0 first unconverged value (error) -302.035 (3.09186208e-06)
142809 EPS nconv=0 first unconverged value (error) -302.035 (2.92561327e-06)
142810 EPS nconv=0 first unconverged value (error) -302.035 (2.57623839e-06)
142811 EPS nconv=0 first unconverged value (error) -302.035 (2.55403462e-06)
142812 EPS nconv=0 first unconverged value (error) -302.035 (2.50028916e-06)
142813 EPS nconv=0 first unconverged value (error) -302.035 (2.50028916e-06)
142814 EPS nconv=0 first unconverged value (error) -302.035 (2.59055540e-06)
142815 EPS nconv=0 first unconverged value (error) -302.035 (2.65392624e-06)
142816 EPS nconv=0 first unconverged value (error) -302.035 (2.47507690e-06)
142817 EPS nconv=0 first unconverged value (error) -302.035 (2.08412302e-06)
142818 EPS nconv=0 first unconverged value (error) -302.035 (1.92198479e-06)
142819 EPS nconv=0 first unconverged value (error) -302.035 (1.92198479e-06)
142820 EPS nconv=0 first unconverged value (error) -302.035 (2.40814543e-06)
142821 EPS nconv=0 first unconverged value (error) -302.035 (2.35628243e-06)
142822 EPS nconv=0 first unconverged value (error) -302.035 (2.23928535e-06)
142823 EPS nconv=0 first unconverged value (error) -302.035 (2.17803953e-06)
142824 EPS nconv=0 first unconverged value (error) -302.035 (2.15312754e-06)
142825 EPS nconv=0 first unconverged value (error) -302.035 (2.15312754e-06)
142826 EPS nconv=0 first unconverged value (error) -302.035 (2.16148560e-06)
142827 EPS nconv=0 first unconverged value (error) -302.035 (2.18501644e-06)
142828 EPS nconv=0 first unconverged value (error) -302.035 (2.07995378e-06)
142829 EPS nconv=0 first unconverged value (error) -302.035 (1.91079894e-06)
142830 EPS nconv=0 first unconverged value (error) -302.035 (1.84735371e-06)
142831 EPS nconv=0 first unconverged value (error) -302.035 (1.84735371e-06)
142832 EPS nconv=0 first unconverged value (error) -302.035 (2.01622401e-06)
142833 EPS nconv=0 first unconverged value (error) -302.035 (1.94815765e-06)
142834 EPS nconv=0 first unconverged value (error) -302.035 (1.90358908e-06)
142835 EPS nconv=0 first unconverged value (error) -302.035 (1.88956413e-06)
142836 EPS nconv=0 first unconverged value (error) -302.035 (1.88113568e-06)
142837 EPS nconv=0 first unconverged value (error) -302.035 (1.88113568e-06)
142838 EPS nconv=0 first unconverged value (error) -302.035 (1.88330848e-06)
142839 EPS nconv=0 first unconverged value (error) -302.035 (1.96619161e-06)
142840 EPS nconv=0 first unconverged value (error) -302.035 (1.89155639e-06)
142841 EPS nconv=0 first unconverged value (error) -302.035 (1.83707183e-06)
142842 EPS nconv=0 first unconverged value (error) -302.035 (1.81281685e-06)
142843 EPS nconv=0 first unconverged value (error) -302.035 (1.81281685e-06)
142844 EPS nconv=0 first unconverged value (error) -302.035 (1.89833062e-06)
142845 EPS nconv=0 first unconverged value (error) -302.035 (1.89114990e-06)
142846 EPS nconv=0 first unconverged value (error) -302.035 (1.87959562e-06)
142847 EPS nconv=0 first unconverged value (error) -302.035 (1.86108103e-06)
142848 EPS nconv=0 first unconverged value (error) -302.035 (1.84747913e-06)
142849 EPS nconv=0 first unconverged value (error) -302.035 (1.84747913e-06)
142850 EPS nconv=0 first unconverged value (error) -302.035 (2.11865971e-06)
142851 EPS nconv=0 first unconverged value (error) -302.035 (2.02640881e-06)
142852 EPS nconv=0 first unconverged value (error) -302.035 (1.99192739e-06)
142853 EPS nconv=0 first unconverged value (error) -302.035 (1.98642511e-06)
142854 EPS nconv=0 first unconverged value (error) -302.035 (1.98720829e-06)
142855 EPS nconv=0 first unconverged value (error) -302.035 (1.98720829e-06)
142856 EPS nconv=0 first unconverged value (error) -302.035 (1.98264115e-06)
142857 EPS nconv=0 first unconverged value (error) -302.035 (1.92351966e-06)
142858 EPS nconv=0 first unconverged value (error) -302.035 (1.84578229e-06)
142859 EPS nconv=0 first unconverged value (error) -302.035 (1.82826762e-06)
142860 EPS nconv=0 first unconverged value (error) -302.035 (1.82284314e-06)
142861 EPS nconv=0 first unconverged value (error) -302.035 (1.82284314e-06)
142862 EPS nconv=0 first unconverged value (error) -302.035 (1.84648187e-06)
142863 EPS nconv=0 first unconverged value (error) -302.035 (1.82516937e-06)
142864 EPS nconv=0 first unconverged value (error) -302.035 (1.81650730e-06)
142865 EPS nconv=0 first unconverged value (error) -302.035 (1.81392534e-06)
142866 EPS nconv=0 first unconverged value (error) -302.035 (1.81202365e-06)
142867 EPS nconv=0 first unconverged value (error) -302.035 (1.81202365e-06)
142868 EPS nconv=0 first unconverged value (error) -302.035 (2.01796618e-06)
142869 EPS nconv=0 first unconverged value (error) -302.035 (1.97585920e-06)
142870 EPS nconv=0 first unconverged value (error) -302.035 (1.91899307e-06)
142871 EPS nconv=0 first unconverged value (error) -302.035 (1.90433646e-06)
142872 EPS nconv=0 first unconverged value (error) -302.035 (1.90037276e-06)
142873 EPS nconv=0 first unconverged value (error) -302.035 (1.90037276e-06)
142874 EPS nconv=0 first unconverged value (error) -302.035 (1.89929866e-06)
142875 EPS nconv=0 first unconverged value (error) -302.035 (1.89234747e-06)
142876 EPS nconv=0 first unconverged value (error) -302.035 (1.83142832e-06)
142877 EPS nconv=0 first unconverged value (error) -302.035 (1.80276040e-06)
142878 EPS nconv=0 first unconverged value (error) -302.035 (1.79983805e-06)
142879 EPS nconv=0 first unconverged value (error) -302.035 (1.79983805e-06)
142880 EPS nconv=0 first unconverged value (error) -302.035 (1.85213968e-06)
142881 EPS nconv=0 first unconverged value (error) -302.035 (1.84572863e-06)
142882 EPS nconv=0 first unconverged value (error) -302.035 (1.82973487e-06)
142883 EPS nconv=0 first unconverged value (error) -302.035 (1.82565999e-06)
142884 EPS nconv=0 first unconverged value (error) -302.035 (1.82309544e-06)
142885 EPS nconv=0 first unconverged value (error) -302.035 (1.82309544e-06)
142886 EPS nconv=0 first unconverged value (error) -302.035 (1.82428653e-06)
142887 EPS nconv=0 first unconverged value (error) -302.035 (1.82656535e-06)
142888 EPS nconv=0 first unconverged value (error) -302.035 (1.81884844e-06)
142889 EPS nconv=0 first unconverged value (error) -302.035 (1.79869949e-06)
142890 EPS nconv=0 first unconverged value (error) -302.035 (1.79689042e-06)
142891 EPS nconv=0 first unconverged value (error) -302.035 (1.79689042e-06)
142892 EPS nconv=0 first unconverged value (error) -302.035 (1.79733255e-06)
142893 EPS nconv=0 first unconverged value (error) -302.035 (1.79655453e-06)
142894 EPS nconv=0 first unconverged value (error) -302.035 (1.79578281e-06)
142895 EPS nconv=0 first unconverged value (error) -302.035 (1.79529091e-06)
142896 EPS nconv=0 first unconverged value (error) -302.035 (1.79518007e-06)
142897 EPS nconv=0 first unconverged value (error) -302.035 (1.79518007e-06)
142898 EPS nconv=0 first unconverged value (error) -302.035 (1.84283520e-06)
142899 EPS nconv=0 first unconverged value (error) -302.035 (1.82864867e-06)
142900 EPS nconv=0 first unconverged value (error) -302.035 (1.81796659e-06)
142901 EPS nconv=0 first unconverged value (error) -302.035 (1.81527596e-06)
142902 EPS nconv=0 first unconverged value (error) -302.035 (1.81454757e-06)
142903 EPS nconv=0 first unconverged value (error) -302.035 (1.81454757e-06)
142904 EPS nconv=0 first unconverged value (error) -302.035 (1.81373097e-06)
142905 EPS nconv=0 first unconverged value (error) -302.035 (1.82229191e-06)
142906 EPS nconv=0 first unconverged value (error) -302.035 (1.81063820e-06)
142907 EPS nconv=0 first unconverged value (error) -302.035 (1.79522294e-06)
142908 EPS nconv=0 first unconverged value (error) -302.035 (1.79480845e-06)
142909 EPS nconv=0 first unconverged value (error) -302.035 (1.79480845e-06)
142910 EPS nconv=0 first unconverged value (error) -302.035 (1.81848414e-06)
142911 EPS nconv=0 first unconverged value (error) -302.035 (1.81416856e-06)
142912 EPS nconv=0 first unconverged value (error) -302.035 (1.80733241e-06)
142913 EPS nconv=0 first unconverged value (error) -302.035 (1.80522413e-06)
142914 EPS nconv=0 first unconverged value (error) -302.035 (1.80474223e-06)
142915 EPS nconv=0 first unconverged value (error) -302.035 (1.80474223e-06)
142916 EPS nconv=0 first unconverged value (error) -302.035 (2.17653719e-06)
142917 EPS nconv=0 first unconverged value (error) -302.035 (2.06198691e-06)
142918 EPS nconv=0 first unconverged value (error) -302.035 (2.03095733e-06)
142919 EPS nconv=0 first unconverged value (error) -302.035 (2.00689078e-06)
142920 EPS nconv=0 first unconverged value (error) -302.035 (1.98424474e-06)
142921 EPS nconv=0 first unconverged value (error) -302.035 (1.98424474e-06)
142922 EPS nconv=0 first unconverged value (error) -302.035 (2.50277309e-06)
142923 EPS nconv=0 first unconverged value (error) -302.035 (2.30485410e-06)
142924 EPS nconv=0 first unconverged value (error) -302.035 (2.13975964e-06)
142925 EPS nconv=0 first unconverged value (error) -302.035 (2.13647248e-06)
142926 EPS nconv=0 first unconverged value (error) -302.035 (2.12190866e-06)
142927 EPS nconv=0 first unconverged value (error) -302.035 (2.12190866e-06)
142928 EPS nconv=0 first unconverged value (error) -302.035 (2.12669950e-06)
142929 EPS nconv=0 first unconverged value (error) -302.035 (2.25103159e-06)
142930 EPS nconv=0 first unconverged value (error) -302.035 (2.05486482e-06)
142931 EPS nconv=0 first unconverged value (error) -302.035 (1.95209224e-06)
142932 EPS nconv=0 first unconverged value (error) -302.035 (1.85248218e-06)
142933 EPS nconv=0 first unconverged value (error) -302.035 (1.85248218e-06)
142934 EPS nconv=0 first unconverged value (error) -302.035 (2.49444890e-06)
142935 EPS nconv=0 first unconverged value (error) -302.035 (2.28538253e-06)
142936 EPS nconv=0 first unconverged value (error) -302.035 (2.22048629e-06)
142937 EPS nconv=0 first unconverged value (error) -302.035 (2.18219481e-06)
142938 EPS nconv=0 first unconverged value (error) -302.035 (2.11843569e-06)
142939 EPS nconv=0 first unconverged value (error) -302.035 (2.11843569e-06)
142940 EPS nconv=0 first unconverged value (error) -302.035 (2.54151734e-06)
142941 EPS nconv=0 first unconverged value (error) -302.035 (2.59650239e-06)
142942 EPS nconv=0 first unconverged value (error) -302.035 (2.26193734e-06)
142943 EPS nconv=0 first unconverged value (error) -302.035 (2.22058144e-06)
142944 EPS nconv=0 first unconverged value (error) -302.035 (2.17609173e-06)
142945 EPS nconv=0 first unconverged value (error) -302.035 (2.17609173e-06)
142946 EPS nconv=0 first unconverged value (error) -302.035 (2.65730021e-06)
142947 EPS nconv=0 first unconverged value (error) -302.035 (2.47568392e-06)
142948 EPS nconv=0 first unconverged value (error) -302.035 (2.39109405e-06)
142949 EPS nconv=0 first unconverged value (error) -302.035 (2.15192831e-06)
142950 EPS nconv=0 first unconverged value (error) -302.035 (2.07158770e-06)
142951 EPS nconv=0 first unconverged value (error) -302.035 (2.07158770e-06)
142952 EPS nconv=0 first unconverged value (error) -302.035 (2.15334054e-06)
142953 EPS nconv=0 first unconverged value (error) -302.035 (2.24432410e-06)
142954 EPS nconv=0 first unconverged value (error) -302.035 (2.03603278e-06)
142955 EPS nconv=0 first unconverged value (error) -302.035 (1.92884111e-06)
142956 EPS nconv=0 first unconverged value (error) -302.035 (1.87268628e-06)
142957 EPS nconv=0 first unconverged value (error) -302.035 (1.87268628e-06)
142958 EPS nconv=0 first unconverged value (error) -302.035 (1.93953851e-06)
142959 EPS nconv=0 first unconverged value (error) -302.035 (1.95589790e-06)
142960 EPS nconv=0 first unconverged value (error) -302.035 (1.92493401e-06)
142961 EPS nconv=0 first unconverged value (error) -302.035 (1.87358319e-06)
142962 EPS nconv=0 first unconverged value (error) -302.035 (1.85142973e-06)
142963 EPS nconv=0 first unconverged value (error) -302.035 (1.85142973e-06)
142964 EPS nconv=0 first unconverged value (error) -302.035 (1.85569126e-06)
142965 EPS nconv=0 first unconverged value (error) -302.035 (1.86446955e-06)
142966 EPS nconv=0 first unconverged value (error) -302.035 (1.82506882e-06)
142967 EPS nconv=0 first unconverged value (error) -302.035 (1.81018220e-06)
142968 EPS nconv=0 first unconverged value (error) -302.035 (1.80500643e-06)
142969 EPS nconv=0 first unconverged value (error) -302.035 (1.80500643e-06)
142970 EPS nconv=0 first unconverged value (error) -302.035 (2.26056748e-06)
142971 EPS nconv=0 first unconverged value (error) -302.035 (2.12413101e-06)
142972 EPS nconv=0 first unconverged value (error) -302.035 (2.03482760e-06)
142973 EPS nconv=0 first unconverged value (error) -302.035 (2.01248807e-06)
142974 EPS nconv=0 first unconverged value (error) -302.035 (1.98265273e-06)
142975 EPS nconv=0 first unconverged value (error) -302.035 (1.98265273e-06)
142976 EPS nconv=0 first unconverged value (error) -302.035 (2.76652309e-06)
142977 EPS nconv=0 first unconverged value (error) -302.035 (2.66097353e-06)
142978 EPS nconv=0 first unconverged value (error) -302.035 (2.38352205e-06)
142979 EPS nconv=0 first unconverged value (error) -302.035 (2.35148653e-06)
142980 EPS nconv=0 first unconverged value (error) -302.035 (2.29412926e-06)
142981 EPS nconv=0 first unconverged value (error) -302.035 (2.29412926e-06)
142982 EPS nconv=0 first unconverged value (error) -302.035 (2.35038236e-06)
142983 EPS nconv=0 first unconverged value (error) -302.035 (2.36114012e-06)
142984 EPS nconv=0 first unconverged value (error) -302.035 (2.18510450e-06)
142985 EPS nconv=0 first unconverged value (error) -302.035 (1.98335801e-06)
142986 EPS nconv=0 first unconverged value (error) -302.035 (1.93518510e-06)
142987 EPS nconv=0 first unconverged value (error) -302.035 (1.93518510e-06)
142988 EPS nconv=0 first unconverged value (error) -302.035 (2.02927436e-06)
142989 EPS nconv=0 first unconverged value (error) -302.035 (2.04790609e-06)
142990 EPS nconv=0 first unconverged value (error) -302.035 (1.98755545e-06)
142991 EPS nconv=0 first unconverged value (error) -302.035 (1.87335183e-06)
142992 EPS nconv=0 first unconverged value (error) -302.035 (1.85973196e-06)
142993 EPS nconv=0 first unconverged value (error) -302.035 (1.85973196e-06)
142994 EPS nconv=0 first unconverged value (error) -302.035 (2.52067397e-06)
142995 EPS nconv=0 first unconverged value (error) -302.035 (2.41028961e-06)
142996 EPS nconv=0 first unconverged value (error) -302.035 (2.23919947e-06)
142997 EPS nconv=0 first unconverged value (error) -302.035 (2.16920061e-06)
142998 EPS nconv=0 first unconverged value (error) -302.035 (2.12625670e-06)
142999 EPS nconv=0 first unconverged value (error) -302.035 (2.12625670e-06)
143000 EPS nconv=0 first unconverged value (error) -302.035 (2.16703880e-06)
143001 EPS nconv=0 first unconverged value (error) -302.035 (2.20377133e-06)
143002 EPS nconv=0 first unconverged value (error) -302.035 (2.06132405e-06)
143003 EPS nconv=0 first unconverged value (error) -302.035 (1.89387314e-06)
143004 EPS nconv=0 first unconverged value (error) -302.035 (1.85237476e-06)
143005 EPS nconv=0 first unconverged value (error) -302.035 (1.85237476e-06)
143006 EPS nconv=0 first unconverged value (error) -302.035 (2.03329172e-06)
143007 EPS nconv=0 first unconverged value (error) -302.035 (2.00331364e-06)
143008 EPS nconv=0 first unconverged value (error) -302.035 (1.95924160e-06)
143009 EPS nconv=0 first unconverged value (error) -302.035 (1.92772245e-06)
143010 EPS nconv=0 first unconverged value (error) -302.035 (1.91404527e-06)
143011 EPS nconv=0 first unconverged value (error) -302.035 (1.91404527e-06)
143012 EPS nconv=0 first unconverged value (error) -302.035 (1.93156598e-06)
143013 EPS nconv=0 first unconverged value (error) -302.035 (1.92760683e-06)
143014 EPS nconv=0 first unconverged value (error) -302.035 (1.86720166e-06)
143015 EPS nconv=0 first unconverged value (error) -302.035 (1.86208337e-06)
143016 EPS nconv=0 first unconverged value (error) -302.035 (1.82680412e-06)
143017 EPS nconv=0 first unconverged value (error) -302.035 (1.82680412e-06)
143018 EPS nconv=0 first unconverged value (error) -302.035 (2.03703486e-06)
143019 EPS nconv=0 first unconverged value (error) -302.035 (2.02500430e-06)
143020 EPS nconv=0 first unconverged value (error) -302.035 (1.94953494e-06)
143021 EPS nconv=0 first unconverged value (error) -302.035 (1.92044220e-06)
143022 EPS nconv=0 first unconverged value (error) -302.035 (1.90063886e-06)
143023 EPS nconv=0 first unconverged value (error) -302.035 (1.90063886e-06)
143024 EPS nconv=0 first unconverged value (error) -302.035 (2.37095563e-06)
143025 EPS nconv=0 first unconverged value (error) -302.035 (2.21337358e-06)
143026 EPS nconv=0 first unconverged value (error) -302.035 (2.14013505e-06)
143027 EPS nconv=0 first unconverged value (error) -302.035 (2.11447928e-06)
143028 EPS nconv=0 first unconverged value (error) -302.035 (2.06901208e-06)
143029 EPS nconv=0 first unconverged value (error) -302.035 (2.06901208e-06)
143030 EPS nconv=0 first unconverged value (error) -302.035 (2.12197895e-06)
143031 EPS nconv=0 first unconverged value (error) -302.035 (2.11798902e-06)
143032 EPS nconv=0 first unconverged value (error) -302.035 (1.96412404e-06)
143033 EPS nconv=0 first unconverged value (error) -302.035 (1.93218377e-06)
143034 EPS nconv=0 first unconverged value (error) -302.035 (1.87580081e-06)
143035 EPS nconv=0 first unconverged value (error) -302.035 (1.87580081e-06)
143036 EPS nconv=0 first unconverged value (error) -302.035 (3.00289517e-06)
143037 EPS nconv=0 first unconverged value (error) -302.035 (2.91543885e-06)
143038 EPS nconv=0 first unconverged value (error) -302.035 (2.58680143e-06)
143039 EPS nconv=0 first unconverged value (error) -302.035 (2.39509315e-06)
143040 EPS nconv=0 first unconverged value (error) -302.035 (2.33079230e-06)
143041 EPS nconv=0 first unconverged value (error) -302.035 (2.33079230e-06)
143042 EPS nconv=0 first unconverged value (error) -302.035 (2.83048491e-06)
143043 EPS nconv=0 first unconverged value (error) -302.035 (2.87073916e-06)
143044 EPS nconv=0 first unconverged value (error) -302.035 (2.64210518e-06)
143045 EPS nconv=0 first unconverged value (error) -302.035 (2.38672245e-06)
143046 EPS nconv=0 first unconverged value (error) -302.035 (2.28835069e-06)
143047 EPS nconv=0 first unconverged value (error) -302.035 (2.28835069e-06)
143048 EPS nconv=0 first unconverged value (error) -302.035 (2.55228823e-06)
143049 EPS nconv=0 first unconverged value (error) -302.035 (2.36627540e-06)
143050 EPS nconv=0 first unconverged value (error) -302.035 (2.18951104e-06)
143051 EPS nconv=0 first unconverged value (error) -302.035 (2.05048858e-06)
143052 EPS nconv=0 first unconverged value (error) -302.035 (2.01788277e-06)
143053 EPS nconv=0 first unconverged value (error) -302.035 (2.01788277e-06)
143054 EPS nconv=0 first unconverged value (error) -302.035 (2.26630435e-06)
143055 EPS nconv=0 first unconverged value (error) -302.035 (2.18017354e-06)
143056 EPS nconv=0 first unconverged value (error) -302.035 (2.03087754e-06)
143057 EPS nconv=0 first unconverged value (error) -302.035 (1.95177169e-06)
143058 EPS nconv=0 first unconverged value (error) -302.035 (1.93638304e-06)
143059 EPS nconv=0 first unconverged value (error) -302.035 (1.93638304e-06)
143060 EPS nconv=0 first unconverged value (error) -302.035 (1.94741707e-06)
143061 EPS nconv=0 first unconverged value (error) -302.035 (2.09253207e-06)
143062 EPS nconv=0 first unconverged value (error) -302.035 (1.91824834e-06)
143063 EPS nconv=0 first unconverged value (error) -302.035 (1.86808864e-06)
143064 EPS nconv=0 first unconverged value (error) -302.035 (1.83208531e-06)
143065 EPS nconv=0 first unconverged value (error) -302.035 (1.83208531e-06)
143066 EPS nconv=0 first unconverged value (error) -302.035 (1.86460936e-06)
143067 EPS nconv=0 first unconverged value (error) -302.035 (1.87424776e-06)
143068 EPS nconv=0 first unconverged value (error) -302.035 (1.84462859e-06)
143069 EPS nconv=0 first unconverged value (error) -302.035 (1.83336371e-06)
143070 EPS nconv=0 first unconverged value (error) -302.035 (1.82458595e-06)
143071 EPS nconv=0 first unconverged value (error) -302.035 (1.82458595e-06)
143072 EPS nconv=0 first unconverged value (error) -302.035 (1.82391267e-06)
143073 EPS nconv=0 first unconverged value (error) -302.035 (1.82804998e-06)
143074 EPS nconv=0 first unconverged value (error) -302.035 (1.81887478e-06)
143075 EPS nconv=0 first unconverged value (error) -302.035 (1.80538684e-06)
143076 EPS nconv=0 first unconverged value (error) -302.035 (1.80164688e-06)
143077 EPS nconv=0 first unconverged value (error) -302.035 (1.80164688e-06)
143078 EPS nconv=0 first unconverged value (error) -302.035 (2.05541196e-06)
143079 EPS nconv=0 first unconverged value (error) -302.035 (1.98155602e-06)
143080 EPS nconv=0 first unconverged value (error) -302.035 (1.95496244e-06)
143081 EPS nconv=0 first unconverged value (error) -302.035 (1.92113035e-06)
143082 EPS nconv=0 first unconverged value (error) -302.035 (1.89724057e-06)
143083 EPS nconv=0 first unconverged value (error) -302.035 (1.89724057e-06)
143084 EPS nconv=0 first unconverged value (error) -302.035 (1.90654391e-06)
143085 EPS nconv=0 first unconverged value (error) -302.035 (1.96363570e-06)
143086 EPS nconv=0 first unconverged value (error) -302.035 (1.88436296e-06)
143087 EPS nconv=0 first unconverged value (error) -302.035 (1.85053200e-06)
143088 EPS nconv=0 first unconverged value (error) -302.035 (1.82645452e-06)
143089 EPS nconv=0 first unconverged value (error) -302.035 (1.82645452e-06)
143090 EPS nconv=0 first unconverged value (error) -302.035 (2.10130369e-06)
143091 EPS nconv=0 first unconverged value (error) -302.035 (2.05720696e-06)
143092 EPS nconv=0 first unconverged value (error) -302.035 (1.98576408e-06)
143093 EPS nconv=0 first unconverged value (error) -302.035 (1.96416128e-06)
143094 EPS nconv=0 first unconverged value (error) -302.035 (1.93530429e-06)
143095 EPS nconv=0 first unconverged value (error) -302.035 (1.93530429e-06)
143096 EPS nconv=0 first unconverged value (error) -302.035 (2.04133336e-06)
143097 EPS nconv=0 first unconverged value (error) -302.035 (2.03635652e-06)
143098 EPS nconv=0 first unconverged value (error) -302.035 (1.95668364e-06)
143099 EPS nconv=0 first unconverged value (error) -302.035 (1.91298431e-06)
143100 EPS nconv=0 first unconverged value (error) -302.035 (1.88643210e-06)
143101 EPS nconv=0 first unconverged value (error) -302.035 (1.88643210e-06)
143102 EPS nconv=0 first unconverged value (error) -302.035 (1.91545755e-06)
143103 EPS nconv=0 first unconverged value (error) -302.035 (1.91479518e-06)
143104 EPS nconv=0 first unconverged value (error) -302.035 (1.89678677e-06)
143105 EPS nconv=0 first unconverged value (error) -302.035 (1.82710534e-06)
143106 EPS nconv=0 first unconverged value (error) -302.035 (1.82019324e-06)
143107 EPS nconv=0 first unconverged value (error) -302.035 (1.82019324e-06)
143108 EPS nconv=0 first unconverged value (error) -302.035 (1.82577693e-06)
143109 EPS nconv=0 first unconverged value (error) -302.035 (1.83303365e-06)
143110 EPS nconv=0 first unconverged value (error) -302.035 (1.82066199e-06)
143111 EPS nconv=0 first unconverged value (error) -302.035 (1.81022460e-06)
143112 EPS nconv=0 first unconverged value (error) -302.035 (1.80579253e-06)
143113 EPS nconv=0 first unconverged value (error) -302.035 (1.80579253e-06)
143114 EPS nconv=0 first unconverged value (error) -302.035 (2.26219561e-06)
143115 EPS nconv=0 first unconverged value (error) -302.035 (2.15993748e-06)
143116 EPS nconv=0 first unconverged value (error) -302.035 (2.10066657e-06)
143117 EPS nconv=0 first unconverged value (error) -302.035 (2.04307589e-06)
143118 EPS nconv=0 first unconverged value (error) -302.035 (1.99178448e-06)
143119 EPS nconv=0 first unconverged value (error) -302.035 (1.99178448e-06)
143120 EPS nconv=0 first unconverged value (error) -302.035 (2.03672379e-06)
143121 EPS nconv=0 first unconverged value (error) -302.035 (2.11407565e-06)
143122 EPS nconv=0 first unconverged value (error) -302.035 (1.99109637e-06)
143123 EPS nconv=0 first unconverged value (error) -302.035 (1.91046414e-06)
143124 EPS nconv=0 first unconverged value (error) -302.035 (1.87748084e-06)
143125 EPS nconv=0 first unconverged value (error) -302.035 (1.87748084e-06)
143126 EPS nconv=0 first unconverged value (error) -302.035 (1.95268295e-06)
143127 EPS nconv=0 first unconverged value (error) -302.035 (1.90214359e-06)
143128 EPS nconv=0 first unconverged value (error) -302.035 (1.87206142e-06)
143129 EPS nconv=0 first unconverged value (error) -302.035 (1.85430825e-06)
143130 EPS nconv=0 first unconverged value (error) -302.035 (1.84188716e-06)
143131 EPS nconv=0 first unconverged value (error) -302.035 (1.84188716e-06)
143132 EPS nconv=0 first unconverged value (error) -302.035 (2.06178469e-06)
143133 EPS nconv=0 first unconverged value (error) -302.035 (2.00052236e-06)
143134 EPS nconv=0 first unconverged value (error) -302.035 (1.94679391e-06)
143135 EPS nconv=0 first unconverged value (error) -302.035 (1.89317863e-06)
143136 EPS nconv=0 first unconverged value (error) -302.035 (1.88237378e-06)
143137 EPS nconv=0 first unconverged value (error) -302.035 (1.88237378e-06)
143138 EPS nconv=0 first unconverged value (error) -302.035 (2.25387081e-06)
143139 EPS nconv=0 first unconverged value (error) -302.035 (2.26632113e-06)
143140 EPS nconv=0 first unconverged value (error) -302.035 (2.14761052e-06)
143141 EPS nconv=0 first unconverged value (error) -302.035 (2.04613196e-06)
143142 EPS nconv=0 first unconverged value (error) -302.035 (1.99111609e-06)
143143 EPS nconv=0 first unconverged value (error) -302.035 (1.99111609e-06)
143144 EPS nconv=0 first unconverged value (error) -302.035 (1.99317427e-06)
143145 EPS nconv=0 first unconverged value (error) -302.035 (2.00626667e-06)
143146 EPS nconv=0 first unconverged value (error) -302.035 (1.89592156e-06)
143147 EPS nconv=0 first unconverged value (error) -302.035 (1.86572347e-06)
143148 EPS nconv=0 first unconverged value (error) -302.035 (1.85416899e-06)
143149 EPS nconv=0 first unconverged value (error) -302.035 (1.85416899e-06)
143150 EPS nconv=0 first unconverged value (error) -302.035 (2.01446325e-06)
143151 EPS nconv=0 first unconverged value (error) -302.035 (1.94122229e-06)
143152 EPS nconv=0 first unconverged value (error) -302.035 (1.89599715e-06)
143153 EPS nconv=0 first unconverged value (error) -302.035 (1.88263286e-06)
143154 EPS nconv=0 first unconverged value (error) -302.035 (1.86740954e-06)
143155 EPS nconv=0 first unconverged value (error) -302.035 (1.86740954e-06)
143156 EPS nconv=0 first unconverged value (error) -302.035 (1.91467757e-06)
143157 EPS nconv=0 first unconverged value (error) -302.035 (1.99201138e-06)
143158 EPS nconv=0 first unconverged value (error) -302.035 (1.89536739e-06)
143159 EPS nconv=0 first unconverged value (error) -302.035 (1.84617464e-06)
143160 EPS nconv=0 first unconverged value (error) -302.035 (1.83092731e-06)
143161 EPS nconv=0 first unconverged value (error) -302.035 (1.83092731e-06)
143162 EPS nconv=0 first unconverged value (error) -302.035 (2.26723455e-06)
143163 EPS nconv=0 first unconverged value (error) -302.035 (2.16587138e-06)
143164 EPS nconv=0 first unconverged value (error) -302.035 (2.13667607e-06)
143165 EPS nconv=0 first unconverged value (error) -302.035 (2.08806409e-06)
143166 EPS nconv=0 first unconverged value (error) -302.035 (2.02241224e-06)
143167 EPS nconv=0 first unconverged value (error) -302.035 (2.02241224e-06)
143168 EPS nconv=0 first unconverged value (error) -302.035 (2.03291204e-06)
143169 EPS nconv=0 first unconverged value (error) -302.035 (2.07594969e-06)
143170 EPS nconv=0 first unconverged value (error) -302.035 (1.96493948e-06)
143171 EPS nconv=0 first unconverged value (error) -302.035 (1.87520030e-06)
143172 EPS nconv=0 first unconverged value (error) -302.035 (1.86068146e-06)
143173 EPS nconv=0 first unconverged value (error) -302.035 (1.86068146e-06)
143174 EPS nconv=0 first unconverged value (error) -302.035 (1.95223335e-06)
143175 EPS nconv=0 first unconverged value (error) -302.035 (1.88810471e-06)
143176 EPS nconv=0 first unconverged value (error) -302.035 (1.86271280e-06)
143177 EPS nconv=0 first unconverged value (error) -302.035 (1.85488372e-06)
143178 EPS nconv=0 first unconverged value (error) -302.035 (1.84637602e-06)
143179 EPS nconv=0 first unconverged value (error) -302.035 (1.84637602e-06)
143180 EPS nconv=0 first unconverged value (error) -302.035 (2.11218575e-06)
143181 EPS nconv=0 first unconverged value (error) -302.035 (2.02672644e-06)
143182 EPS nconv=0 first unconverged value (error) -302.035 (1.93483952e-06)
143183 EPS nconv=0 first unconverged value (error) -302.035 (1.92011453e-06)
143184 EPS nconv=0 first unconverged value (error) -302.035 (1.90974477e-06)
143185 EPS nconv=0 first unconverged value (error) -302.035 (1.90974477e-06)
143186 EPS nconv=0 first unconverged value (error) -302.035 (2.15351954e-06)
143187 EPS nconv=0 first unconverged value (error) -302.035 (2.17954232e-06)
143188 EPS nconv=0 first unconverged value (error) -302.035 (2.03695836e-06)
143189 EPS nconv=0 first unconverged value (error) -302.035 (1.94999682e-06)
143190 EPS nconv=0 first unconverged value (error) -302.035 (1.92366322e-06)
143191 EPS nconv=0 first unconverged value (error) -302.035 (1.92366322e-06)
143192 EPS nconv=0 first unconverged value (error) -302.035 (1.92463087e-06)
143193 EPS nconv=0 first unconverged value (error) -302.035 (1.94768522e-06)
143194 EPS nconv=0 first unconverged value (error) -302.035 (1.85471081e-06)
143195 EPS nconv=0 first unconverged value (error) -302.035 (1.82475560e-06)
143196 EPS nconv=0 first unconverged value (error) -302.035 (1.81971047e-06)
143197 EPS nconv=0 first unconverged value (error) -302.035 (1.81971047e-06)
143198 EPS nconv=0 first unconverged value (error) -302.035 (1.82100229e-06)
143199 EPS nconv=0 first unconverged value (error) -302.035 (1.82000174e-06)
143200 EPS nconv=0 first unconverged value (error) -302.035 (1.80667452e-06)
143201 EPS nconv=0 first unconverged value (error) -302.035 (1.80368706e-06)
143202 EPS nconv=0 first unconverged value (error) -302.035 (1.80288661e-06)
143203 EPS nconv=0 first unconverged value (error) -302.035 (1.80288661e-06)
143204 EPS nconv=0 first unconverged value (error) -302.035 (2.02718324e-06)
143205 EPS nconv=0 first unconverged value (error) -302.035 (1.95392078e-06)
143206 EPS nconv=0 first unconverged value (error) -302.035 (1.91145017e-06)
143207 EPS nconv=0 first unconverged value (error) -302.035 (1.89842752e-06)
143208 EPS nconv=0 first unconverged value (error) -302.035 (1.87723870e-06)
143209 EPS nconv=0 first unconverged value (error) -302.035 (1.87723870e-06)
143210 EPS nconv=0 first unconverged value (error) -302.035 (2.03138920e-06)
143211 EPS nconv=0 first unconverged value (error) -302.035 (2.13112452e-06)
143212 EPS nconv=0 first unconverged value (error) -302.035 (2.04208440e-06)
143213 EPS nconv=0 first unconverged value (error) -302.035 (1.91646278e-06)
143214 EPS nconv=0 first unconverged value (error) -302.035 (1.89724976e-06)
143215 EPS nconv=0 first unconverged value (error) -302.035 (1.89724976e-06)
143216 EPS nconv=0 first unconverged value (error) -302.035 (1.89121524e-06)
143217 EPS nconv=0 first unconverged value (error) -302.035 (1.85994184e-06)
143218 EPS nconv=0 first unconverged value (error) -302.035 (1.84701058e-06)
143219 EPS nconv=0 first unconverged value (error) -302.035 (1.81661475e-06)
143220 EPS nconv=0 first unconverged value (error) -302.035 (1.80323931e-06)
143221 EPS nconv=0 first unconverged value (error) -302.035 (1.80323931e-06)
143222 EPS nconv=0 first unconverged value (error) -302.035 (1.80100411e-06)
143223 EPS nconv=0 first unconverged value (error) -302.035 (1.79723037e-06)
143224 EPS nconv=0 first unconverged value (error) -302.035 (1.79537696e-06)
143225 EPS nconv=0 first unconverged value (error) -302.035 (1.79504101e-06)
143226 EPS nconv=0 first unconverged value (error) -302.035 (1.79465423e-06)
143227 EPS nconv=0 first unconverged value (error) -302.035 (1.79465423e-06)
143228 EPS nconv=0 first unconverged value (error) -302.035 (1.84677677e-06)
143229 EPS nconv=0 first unconverged value (error) -302.035 (1.83375028e-06)
143230 EPS nconv=0 first unconverged value (error) -302.035 (1.82224520e-06)
143231 EPS nconv=0 first unconverged value (error) -302.035 (1.81945341e-06)
143232 EPS nconv=0 first unconverged value (error) -302.035 (1.81590425e-06)
143233 EPS nconv=0 first unconverged value (error) -302.035 (1.81590425e-06)
143234 EPS nconv=0 first unconverged value (error) -302.035 (1.86030581e-06)
143235 EPS nconv=0 first unconverged value (error) -302.035 (1.87685440e-06)
143236 EPS nconv=0 first unconverged value (error) -302.035 (1.86004953e-06)
143237 EPS nconv=0 first unconverged value (error) -302.035 (1.82202927e-06)
143238 EPS nconv=0 first unconverged value (error) -302.035 (1.81899700e-06)
143239 EPS nconv=0 first unconverged value (error) -302.035 (1.81899700e-06)
143240 EPS nconv=0 first unconverged value (error) -302.035 (1.83533486e-06)
143241 EPS nconv=0 first unconverged value (error) -302.035 (1.82812128e-06)
143242 EPS nconv=0 first unconverged value (error) -302.035 (1.82453945e-06)
143243 EPS nconv=0 first unconverged value (error) -302.035 (1.80458475e-06)
143244 EPS nconv=0 first unconverged value (error) -302.035 (1.80153204e-06)
143245 EPS nconv=0 first unconverged value (error) -302.035 (1.80153204e-06)
143246 EPS nconv=0 first unconverged value (error) -302.035 (1.98031508e-06)
143247 EPS nconv=0 first unconverged value (error) -302.035 (1.90673907e-06)
143248 EPS nconv=0 first unconverged value (error) -302.035 (1.87596663e-06)
143249 EPS nconv=0 first unconverged value (error) -302.035 (1.87096310e-06)
143250 EPS nconv=0 first unconverged value (error) -302.035 (1.86440677e-06)
143251 EPS nconv=0 first unconverged value (error) -302.035 (1.86440677e-06)
143252 EPS nconv=0 first unconverged value (error) -302.035 (1.86378862e-06)
143253 EPS nconv=0 first unconverged value (error) -302.035 (1.90680817e-06)
143254 EPS nconv=0 first unconverged value (error) -302.035 (1.84357930e-06)
143255 EPS nconv=0 first unconverged value (error) -302.035 (1.80282504e-06)
143256 EPS nconv=0 first unconverged value (error) -302.035 (1.80104392e-06)
143257 EPS nconv=0 first unconverged value (error) -302.035 (1.80104392e-06)
143258 EPS nconv=0 first unconverged value (error) -302.035 (1.83255693e-06)
143259 EPS nconv=0 first unconverged value (error) -302.035 (1.81671675e-06)
143260 EPS nconv=0 first unconverged value (error) -302.035 (1.81351640e-06)
143261 EPS nconv=0 first unconverged value (error) -302.035 (1.81231776e-06)
143262 EPS nconv=0 first unconverged value (error) -302.035 (1.81055691e-06)
143263 EPS nconv=0 first unconverged value (error) -302.035 (1.81055691e-06)
143264 EPS nconv=0 first unconverged value (error) -302.035 (2.17078097e-06)
143265 EPS nconv=0 first unconverged value (error) -302.035 (2.07835843e-06)
143266 EPS nconv=0 first unconverged value (error) -302.035 (2.01720017e-06)
143267 EPS nconv=0 first unconverged value (error) -302.035 (1.98595910e-06)
143268 EPS nconv=0 first unconverged value (error) -302.035 (1.97974650e-06)
143269 EPS nconv=0 first unconverged value (error) -302.035 (1.97974650e-06)
143270 EPS nconv=0 first unconverged value (error) -302.035 (1.97821842e-06)
143271 EPS nconv=0 first unconverged value (error) -302.035 (2.03694885e-06)
143272 EPS nconv=0 first unconverged value (error) -302.035 (1.94375114e-06)
143273 EPS nconv=0 first unconverged value (error) -302.035 (1.86840888e-06)
143274 EPS nconv=0 first unconverged value (error) -302.035 (1.82733576e-06)
143275 EPS nconv=0 first unconverged value (error) -302.035 (1.82733576e-06)
143276 EPS nconv=0 first unconverged value (error) -302.035 (1.81135930e-06)
143277 EPS nconv=0 first unconverged value (error) -302.035 (1.80973656e-06)
143278 EPS nconv=0 first unconverged value (error) -302.035 (1.80550991e-06)
143279 EPS nconv=0 first unconverged value (error) -302.035 (1.80296712e-06)
143280 EPS nconv=0 first unconverged value (error) -302.035 (1.80152435e-06)
143281 EPS nconv=0 first unconverged value (error) -302.035 (1.80152435e-06)
143282 EPS nconv=0 first unconverged value (error) -302.035 (1.84068875e-06)
143283 EPS nconv=0 first unconverged value (error) -302.035 (1.83137130e-06)
143284 EPS nconv=0 first unconverged value (error) -302.035 (1.82268385e-06)
143285 EPS nconv=0 first unconverged value (error) -302.035 (1.81453493e-06)
143286 EPS nconv=0 first unconverged value (error) -302.035 (1.81188866e-06)
143287 EPS nconv=0 first unconverged value (error) -302.035 (1.81188866e-06)
143288 EPS nconv=0 first unconverged value (error) -302.035 (1.94147931e-06)
143289 EPS nconv=0 first unconverged value (error) -302.035 (1.91071413e-06)
143290 EPS nconv=0 first unconverged value (error) -302.035 (1.88599727e-06)
143291 EPS nconv=0 first unconverged value (error) -302.035 (1.86659959e-06)
143292 EPS nconv=0 first unconverged value (error) -302.035 (1.85233613e-06)
143293 EPS nconv=0 first unconverged value (error) -302.035 (1.85233613e-06)
143294 EPS nconv=0 first unconverged value (error) -302.035 (1.99118191e-06)
143295 EPS nconv=0 first unconverged value (error) -302.035 (2.02890099e-06)
143296 EPS nconv=0 first unconverged value (error) -302.035 (1.97900345e-06)
143297 EPS nconv=0 first unconverged value (error) -302.035 (1.88252785e-06)
143298 EPS nconv=0 first unconverged value (error) -302.035 (1.87418835e-06)
143299 EPS nconv=0 first unconverged value (error) -302.035 (1.87418835e-06)
143300 EPS nconv=0 first unconverged value (error) -302.035 (1.88057777e-06)
143301 EPS nconv=0 first unconverged value (error) -302.035 (1.87243586e-06)
143302 EPS nconv=0 first unconverged value (error) -302.035 (1.84288264e-06)
143303 EPS nconv=0 first unconverged value (error) -302.035 (1.81742517e-06)
143304 EPS nconv=0 first unconverged value (error) -302.035 (1.80624693e-06)
143305 EPS nconv=0 first unconverged value (error) -302.035 (1.80624693e-06)
143306 EPS nconv=0 first unconverged value (error) -302.035 (1.82035974e-06)
143307 EPS nconv=0 first unconverged value (error) -302.035 (1.80903478e-06)
143308 EPS nconv=0 first unconverged value (error) -302.035 (1.80259220e-06)
143309 EPS nconv=0 first unconverged value (error) -302.035 (1.80035099e-06)
143310 EPS nconv=0 first unconverged value (error) -302.035 (1.79978196e-06)
143311 EPS nconv=0 first unconverged value (error) -302.035 (1.79978196e-06)
143312 EPS nconv=0 first unconverged value (error) -302.035 (2.49943310e-06)
143313 EPS nconv=0 first unconverged value (error) -302.035 (2.18354632e-06)
143314 EPS nconv=0 first unconverged value (error) -302.035 (2.09615962e-06)
143315 EPS nconv=0 first unconverged value (error) -302.035 (2.05044489e-06)
143316 EPS nconv=0 first unconverged value (error) -302.035 (2.02920337e-06)
143317 EPS nconv=0 first unconverged value (error) -302.035 (2.02920337e-06)
143318 EPS nconv=0 first unconverged value (error) -302.035 (2.28174109e-06)
143319 EPS nconv=0 first unconverged value (error) -302.035 (2.37722205e-06)
143320 EPS nconv=0 first unconverged value (error) -302.035 (2.06737207e-06)
143321 EPS nconv=0 first unconverged value (error) -302.035 (2.02966041e-06)
143322 EPS nconv=0 first unconverged value (error) -302.035 (1.99934634e-06)
143323 EPS nconv=0 first unconverged value (error) -302.035 (1.99934634e-06)
143324 EPS nconv=0 first unconverged value (error) -302.035 (2.03227857e-06)
143325 EPS nconv=0 first unconverged value (error) -302.035 (2.05430575e-06)
143326 EPS nconv=0 first unconverged value (error) -302.035 (1.95495239e-06)
143327 EPS nconv=0 first unconverged value (error) -302.035 (1.87480876e-06)
143328 EPS nconv=0 first unconverged value (error) -302.035 (1.83962265e-06)
143329 EPS nconv=0 first unconverged value (error) -302.035 (1.83962265e-06)
143330 EPS nconv=0 first unconverged value (error) -302.035 (2.37750257e-06)
143331 EPS nconv=0 first unconverged value (error) -302.035 (2.26549838e-06)
143332 EPS nconv=0 first unconverged value (error) -302.035 (2.12360904e-06)
143333 EPS nconv=0 first unconverged value (error) -302.035 (2.07307377e-06)
143334 EPS nconv=0 first unconverged value (error) -302.035 (2.04968642e-06)
143335 EPS nconv=0 first unconverged value (error) -302.035 (2.04968642e-06)
143336 EPS nconv=0 first unconverged value (error) -302.035 (2.04228752e-06)
143337 EPS nconv=0 first unconverged value (error) -302.035 (2.26019322e-06)
143338 EPS nconv=0 first unconverged value (error) -302.035 (2.11593812e-06)
143339 EPS nconv=0 first unconverged value (error) -302.035 (1.88916308e-06)
143340 EPS nconv=0 first unconverged value (error) -302.035 (1.82246267e-06)
143341 EPS nconv=0 first unconverged value (error) -302.035 (1.82246267e-06)
143342 EPS nconv=0 first unconverged value (error) -302.035 (2.28273318e-06)
143343 EPS nconv=0 first unconverged value (error) -302.035 (2.22734802e-06)
143344 EPS nconv=0 first unconverged value (error) -302.035 (2.18728447e-06)
143345 EPS nconv=0 first unconverged value (error) -302.035 (2.14423077e-06)
143346 EPS nconv=0 first unconverged value (error) -302.035 (2.09851908e-06)
143347 EPS nconv=0 first unconverged value (error) -302.035 (2.09851908e-06)
143348 EPS nconv=0 first unconverged value (error) -302.035 (2.58300418e-06)
143349 EPS nconv=0 first unconverged value (error) -302.035 (2.38791283e-06)
143350 EPS nconv=0 first unconverged value (error) -302.035 (2.19902256e-06)
143351 EPS nconv=0 first unconverged value (error) -302.035 (2.19447343e-06)
143352 EPS nconv=0 first unconverged value (error) -302.035 (2.13697867e-06)
143353 EPS nconv=0 first unconverged value (error) -302.035 (2.13697867e-06)
143354 EPS nconv=0 first unconverged value (error) -302.035 (2.12883497e-06)
143355 EPS nconv=0 first unconverged value (error) -302.035 (2.23859368e-06)
143356 EPS nconv=0 first unconverged value (error) -302.035 (2.10345236e-06)
143357 EPS nconv=0 first unconverged value (error) -302.035 (1.96768455e-06)
143358 EPS nconv=0 first unconverged value (error) -302.035 (1.88808345e-06)
143359 EPS nconv=0 first unconverged value (error) -302.035 (1.88808345e-06)
143360 EPS nconv=0 first unconverged value (error) -302.035 (1.89138103e-06)
143361 EPS nconv=0 first unconverged value (error) -302.035 (1.89408247e-06)
143362 EPS nconv=0 first unconverged value (error) -302.035 (1.87657052e-06)
143363 EPS nconv=0 first unconverged value (error) -302.035 (1.83765341e-06)
143364 EPS nconv=0 first unconverged value (error) -302.035 (1.82828595e-06)
143365 EPS nconv=0 first unconverged value (error) -302.035 (1.82828595e-06)
143366 EPS nconv=0 first unconverged value (error) -302.035 (1.89420631e-06)
143367 EPS nconv=0 first unconverged value (error) -302.035 (1.87597834e-06)
143368 EPS nconv=0 first unconverged value (error) -302.035 (1.86030525e-06)
143369 EPS nconv=0 first unconverged value (error) -302.035 (1.84140585e-06)
143370 EPS nconv=0 first unconverged value (error) -302.035 (1.82700077e-06)
143371 EPS nconv=0 first unconverged value (error) -302.035 (1.82700077e-06)
143372 EPS nconv=0 first unconverged value (error) -302.035 (2.17337939e-06)
143373 EPS nconv=0 first unconverged value (error) -302.035 (2.12878157e-06)
143374 EPS nconv=0 first unconverged value (error) -302.035 (2.04068824e-06)
143375 EPS nconv=0 first unconverged value (error) -302.035 (2.00239405e-06)
143376 EPS nconv=0 first unconverged value (error) -302.035 (1.96346431e-06)
143377 EPS nconv=0 first unconverged value (error) -302.035 (1.96346431e-06)
143378 EPS nconv=0 first unconverged value (error) -302.035 (1.96532265e-06)
143379 EPS nconv=0 first unconverged value (error) -302.035 (2.02198933e-06)
143380 EPS nconv=0 first unconverged value (error) -302.035 (1.95514897e-06)
143381 EPS nconv=0 first unconverged value (error) -302.035 (1.87562668e-06)
143382 EPS nconv=0 first unconverged value (error) -302.035 (1.85103448e-06)
143383 EPS nconv=0 first unconverged value (error) -302.035 (1.85103448e-06)
143384 EPS nconv=0 first unconverged value (error) -302.035 (1.88740340e-06)
143385 EPS nconv=0 first unconverged value (error) -302.035 (1.86426968e-06)
143386 EPS nconv=0 first unconverged value (error) -302.035 (1.85318676e-06)
143387 EPS nconv=0 first unconverged value (error) -302.035 (1.83992113e-06)
143388 EPS nconv=0 first unconverged value (error) -302.035 (1.82945288e-06)
143389 EPS nconv=0 first unconverged value (error) -302.035 (1.82945288e-06)
143390 EPS nconv=0 first unconverged value (error) -302.035 (1.91170827e-06)
143391 EPS nconv=0 first unconverged value (error) -302.035 (1.89927457e-06)
143392 EPS nconv=0 first unconverged value (error) -302.035 (1.87036789e-06)
143393 EPS nconv=0 first unconverged value (error) -302.035 (1.85651457e-06)
143394 EPS nconv=0 first unconverged value (error) -302.035 (1.83969999e-06)
143395 EPS nconv=0 first unconverged value (error) -302.035 (1.83969999e-06)
143396 EPS nconv=0 first unconverged value (error) -302.035 (1.82939010e-06)
143397 EPS nconv=0 first unconverged value (error) -302.035 (1.84182783e-06)
143398 EPS nconv=0 first unconverged value (error) -302.035 (1.81036676e-06)
143399 EPS nconv=0 first unconverged value (error) -302.035 (1.80593305e-06)
143400 EPS nconv=0 first unconverged value (error) -302.035 (1.80065053e-06)
143401 EPS nconv=0 first unconverged value (error) -302.035 (1.80065053e-06)
143402 EPS nconv=0 first unconverged value (error) -302.035 (1.79977937e-06)
143403 EPS nconv=0 first unconverged value (error) -302.035 (1.79873384e-06)
143404 EPS nconv=0 first unconverged value (error) -302.035 (1.79758432e-06)
143405 EPS nconv=0 first unconverged value (error) -302.035 (1.79737442e-06)
143406 EPS nconv=0 first unconverged value (error) -302.035 (1.79695545e-06)
143407 EPS nconv=0 first unconverged value (error) -302.035 (1.79695545e-06)
143408 EPS nconv=0 first unconverged value (error) -302.035 (1.86798895e-06)
143409 EPS nconv=0 first unconverged value (error) -302.035 (1.86094786e-06)
143410 EPS nconv=0 first unconverged value (error) -302.035 (1.85353424e-06)
143411 EPS nconv=0 first unconverged value (error) -302.035 (1.84195917e-06)
143412 EPS nconv=0 first unconverged value (error) -302.035 (1.83710578e-06)
143413 EPS nconv=0 first unconverged value (error) -302.035 (1.83710578e-06)
143414 EPS nconv=0 first unconverged value (error) -302.035 (2.43451528e-06)
143415 EPS nconv=0 first unconverged value (error) -302.035 (2.29751575e-06)
143416 EPS nconv=0 first unconverged value (error) -302.035 (2.20954672e-06)
143417 EPS nconv=0 first unconverged value (error) -302.035 (2.14936743e-06)
143418 EPS nconv=0 first unconverged value (error) -302.035 (2.13061029e-06)
143419 EPS nconv=0 first unconverged value (error) -302.035 (2.13061029e-06)
143420 EPS nconv=0 first unconverged value (error) -302.035 (2.12881733e-06)
143421 EPS nconv=0 first unconverged value (error) -302.035 (2.15745207e-06)
143422 EPS nconv=0 first unconverged value (error) -302.035 (2.05030529e-06)
143423 EPS nconv=0 first unconverged value (error) -302.035 (1.92246594e-06)
143424 EPS nconv=0 first unconverged value (error) -302.035 (1.85034463e-06)
143425 EPS nconv=0 first unconverged value (error) -302.035 (1.85034463e-06)
143426 EPS nconv=0 first unconverged value (error) -302.035 (1.83748498e-06)
143427 EPS nconv=0 first unconverged value (error) -302.035 (1.82799778e-06)
143428 EPS nconv=0 first unconverged value (error) -302.035 (1.81395872e-06)
143429 EPS nconv=0 first unconverged value (error) -302.035 (1.80612296e-06)
143430 EPS nconv=0 first unconverged value (error) -302.035 (1.80128084e-06)
143431 EPS nconv=0 first unconverged value (error) -302.035 (1.80128084e-06)
143432 EPS nconv=0 first unconverged value (error) -302.035 (1.79907568e-06)
143433 EPS nconv=0 first unconverged value (error) -302.035 (1.80116098e-06)
143434 EPS nconv=0 first unconverged value (error) -302.035 (1.79945605e-06)
143435 EPS nconv=0 first unconverged value (error) -302.035 (1.79595204e-06)
143436 EPS nconv=0 first unconverged value (error) -302.035 (1.79537542e-06)
143437 EPS nconv=0 first unconverged value (error) -302.035 (1.79537542e-06)
143438 EPS nconv=0 first unconverged value (error) -302.035 (2.08570742e-06)
143439 EPS nconv=0 first unconverged value (error) -302.035 (1.96870852e-06)
143440 EPS nconv=0 first unconverged value (error) -302.035 (1.93993116e-06)
143441 EPS nconv=0 first unconverged value (error) -302.035 (1.92867167e-06)
143442 EPS nconv=0 first unconverged value (error) -302.035 (1.90936412e-06)
143443 EPS nconv=0 first unconverged value (error) -302.035 (1.90936412e-06)
143444 EPS nconv=0 first unconverged value (error) -302.035 (2.00423350e-06)
143445 EPS nconv=0 first unconverged value (error) -302.035 (2.10605914e-06)
143446 EPS nconv=0 first unconverged value (error) -302.035 (1.97920077e-06)
143447 EPS nconv=0 first unconverged value (error) -302.035 (1.85497184e-06)
143448 EPS nconv=0 first unconverged value (error) -302.035 (1.84502968e-06)
143449 EPS nconv=0 first unconverged value (error) -302.035 (1.84502968e-06)
143450 EPS nconv=0 first unconverged value (error) -302.035 (1.90909003e-06)
143451 EPS nconv=0 first unconverged value (error) -302.035 (1.85678755e-06)
143452 EPS nconv=0 first unconverged value (error) -302.035 (1.83683007e-06)
143453 EPS nconv=0 first unconverged value (error) -302.035 (1.82716498e-06)
143454 EPS nconv=0 first unconverged value (error) -302.035 (1.82251971e-06)
143455 EPS nconv=0 first unconverged value (error) -302.035 (1.82251971e-06)
143456 EPS nconv=0 first unconverged value (error) -302.035 (1.82446657e-06)
143457 EPS nconv=0 first unconverged value (error) -302.035 (1.84428720e-06)
143458 EPS nconv=0 first unconverged value (error) -302.035 (1.80830282e-06)
143459 EPS nconv=0 first unconverged value (error) -302.035 (1.80239587e-06)
143460 EPS nconv=0 first unconverged value (error) -302.035 (1.80148859e-06)
143461 EPS nconv=0 first unconverged value (error) -302.035 (1.80148859e-06)
143462 EPS nconv=0 first unconverged value (error) -302.035 (1.89056323e-06)
143463 EPS nconv=0 first unconverged value (error) -302.035 (1.86267823e-06)
143464 EPS nconv=0 first unconverged value (error) -302.035 (1.84139399e-06)
143465 EPS nconv=0 first unconverged value (error) -302.035 (1.83221038e-06)
143466 EPS nconv=0 first unconverged value (error) -302.035 (1.82514620e-06)
143467 EPS nconv=0 first unconverged value (error) -302.035 (1.82514620e-06)
143468 EPS nconv=0 first unconverged value (error) -302.035 (1.90606880e-06)
143469 EPS nconv=0 first unconverged value (error) -302.035 (1.93784685e-06)
143470 EPS nconv=0 first unconverged value (error) -302.035 (1.90084481e-06)
143471 EPS nconv=0 first unconverged value (error) -302.035 (1.84605303e-06)
143472 EPS nconv=0 first unconverged value (error) -302.035 (1.83723418e-06)
143473 EPS nconv=0 first unconverged value (error) -302.035 (1.83723418e-06)
143474 EPS nconv=0 first unconverged value (error) -302.035 (1.83534681e-06)
143475 EPS nconv=0 first unconverged value (error) -302.035 (1.83267015e-06)
143476 EPS nconv=0 first unconverged value (error) -302.035 (1.81443503e-06)
143477 EPS nconv=0 first unconverged value (error) -302.035 (1.80304041e-06)
143478 EPS nconv=0 first unconverged value (error) -302.035 (1.80279312e-06)
143479 EPS nconv=0 first unconverged value (error) -302.035 (1.80279312e-06)
143480 EPS nconv=0 first unconverged value (error) -302.035 (1.86229908e-06)
143481 EPS nconv=0 first unconverged value (error) -302.035 (1.82834407e-06)
143482 EPS nconv=0 first unconverged value (error) -302.035 (1.82023978e-06)
143483 EPS nconv=0 first unconverged value (error) -302.035 (1.81563881e-06)
143484 EPS nconv=0 first unconverged value (error) -302.035 (1.81281790e-06)
143485 EPS nconv=0 first unconverged value (error) -302.035 (1.81281790e-06)
143486 EPS nconv=0 first unconverged value (error) -302.035 (1.84714737e-06)
143487 EPS nconv=0 first unconverged value (error) -302.035 (1.86812165e-06)
143488 EPS nconv=0 first unconverged value (error) -302.035 (1.83250332e-06)
143489 EPS nconv=0 first unconverged value (error) -302.035 (1.81235335e-06)
143490 EPS nconv=0 first unconverged value (error) -302.035 (1.80913877e-06)
143491 EPS nconv=0 first unconverged value (error) -302.035 (1.80913877e-06)
143492 EPS nconv=0 first unconverged value (error) -302.035 (1.80603713e-06)
143493 EPS nconv=0 first unconverged value (error) -302.035 (1.81262265e-06)
143494 EPS nconv=0 first unconverged value (error) -302.035 (1.80311147e-06)
143495 EPS nconv=0 first unconverged value (error) -302.035 (1.79779721e-06)
143496 EPS nconv=0 first unconverged value (error) -302.035 (1.79720587e-06)
143497 EPS nconv=0 first unconverged value (error) -302.035 (1.79720587e-06)
143498 EPS nconv=0 first unconverged value (error) -302.035 (1.81052086e-06)
143499 EPS nconv=0 first unconverged value (error) -302.035 (1.80345822e-06)
143500 EPS nconv=0 first unconverged value (error) -302.035 (1.80210434e-06)
143501 EPS nconv=0 first unconverged value (error) -302.035 (1.80095617e-06)
143502 EPS nconv=0 first unconverged value (error) -302.035 (1.79990049e-06)
143503 EPS nconv=0 first unconverged value (error) -302.035 (1.79990049e-06)
143504 EPS nconv=0 first unconverged value (error) -302.035 (1.80102312e-06)
143505 EPS nconv=0 first unconverged value (error) -302.035 (1.80406682e-06)
143506 EPS nconv=0 first unconverged value (error) -302.035 (1.79849020e-06)
143507 EPS nconv=0 first unconverged value (error) -302.035 (1.79762048e-06)
143508 EPS nconv=0 first unconverged value (error) -302.035 (1.79684379e-06)
143509 EPS nconv=0 first unconverged value (error) -302.035 (1.79684379e-06)
143510 EPS nconv=0 first unconverged value (error) -302.035 (1.80995649e-06)
143511 EPS nconv=0 first unconverged value (error) -302.035 (1.80575049e-06)
143512 EPS nconv=0 first unconverged value (error) -302.035 (1.80342189e-06)
143513 EPS nconv=0 first unconverged value (error) -302.035 (1.80234685e-06)
143514 EPS nconv=0 first unconverged value (error) -302.035 (1.80102711e-06)
143515 EPS nconv=0 first unconverged value (error) -302.035 (1.80102711e-06)
143516 EPS nconv=0 first unconverged value (error) -302.035 (1.94406483e-06)
143517 EPS nconv=0 first unconverged value (error) -302.035 (1.92336337e-06)
143518 EPS nconv=0 first unconverged value (error) -302.035 (1.90302079e-06)
143519 EPS nconv=0 first unconverged value (error) -302.035 (1.86854811e-06)
143520 EPS nconv=0 first unconverged value (error) -302.035 (1.85637793e-06)
143521 EPS nconv=0 first unconverged value (error) -302.035 (1.85637793e-06)
143522 EPS nconv=0 first unconverged value (error) -302.035 (1.85986354e-06)
143523 EPS nconv=0 first unconverged value (error) -302.035 (1.87365458e-06)
143524 EPS nconv=0 first unconverged value (error) -302.035 (1.84618004e-06)
143525 EPS nconv=0 first unconverged value (error) -302.035 (1.82086424e-06)
143526 EPS nconv=0 first unconverged value (error) -302.035 (1.81421966e-06)
143527 EPS nconv=0 first unconverged value (error) -302.035 (1.81421966e-06)
143528 EPS nconv=0 first unconverged value (error) -302.035 (1.81482619e-06)
143529 EPS nconv=0 first unconverged value (error) -302.035 (1.80854166e-06)
143530 EPS nconv=0 first unconverged value (error) -302.035 (1.80427795e-06)
143531 EPS nconv=0 first unconverged value (error) -302.035 (1.80327978e-06)
143532 EPS nconv=0 first unconverged value (error) -302.035 (1.80168119e-06)
143533 EPS nconv=0 first unconverged value (error) -302.035 (1.80168119e-06)
143534 EPS nconv=0 first unconverged value (error) -302.035 (1.80212013e-06)
143535 EPS nconv=0 first unconverged value (error) -302.035 (1.80782724e-06)
143536 EPS nconv=0 first unconverged value (error) -302.035 (1.80072704e-06)
143537 EPS nconv=0 first unconverged value (error) -302.035 (1.79813736e-06)
143538 EPS nconv=0 first unconverged value (error) -302.035 (1.79729460e-06)
143539 EPS nconv=0 first unconverged value (error) -302.035 (1.79729460e-06)
143540 EPS nconv=0 first unconverged value (error) -302.035 (1.84801297e-06)
143541 EPS nconv=0 first unconverged value (error) -302.035 (1.83078908e-06)
143542 EPS nconv=0 first unconverged value (error) -302.035 (1.82290097e-06)
143543 EPS nconv=0 first unconverged value (error) -302.035 (1.82190754e-06)
143544 EPS nconv=0 first unconverged value (error) -302.035 (1.81637479e-06)
143545 EPS nconv=0 first unconverged value (error) -302.035 (1.81637479e-06)
143546 EPS nconv=0 first unconverged value (error) -302.035 (1.81944527e-06)
143547 EPS nconv=0 first unconverged value (error) -302.035 (1.83518117e-06)
143548 EPS nconv=0 first unconverged value (error) -302.035 (1.80713622e-06)
143549 EPS nconv=0 first unconverged value (error) -302.035 (1.79956643e-06)
143550 EPS nconv=0 first unconverged value (error) -302.035 (1.79841602e-06)
143551 EPS nconv=0 first unconverged value (error) -302.035 (1.79841602e-06)
143552 EPS nconv=0 first unconverged value (error) -302.035 (1.94243377e-06)
143553 EPS nconv=0 first unconverged value (error) -302.035 (1.90909783e-06)
143554 EPS nconv=0 first unconverged value (error) -302.035 (1.89114537e-06)
143555 EPS nconv=0 first unconverged value (error) -302.035 (1.88284681e-06)
143556 EPS nconv=0 first unconverged value (error) -302.035 (1.88064712e-06)
143557 EPS nconv=0 first unconverged value (error) -302.035 (1.88064712e-06)
143558 EPS nconv=0 first unconverged value (error) -302.035 (1.95305219e-06)
143559 EPS nconv=0 first unconverged value (error) -302.035 (1.89708801e-06)
143560 EPS nconv=0 first unconverged value (error) -302.035 (1.85064459e-06)
143561 EPS nconv=0 first unconverged value (error) -302.035 (1.84223222e-06)
143562 EPS nconv=0 first unconverged value (error) -302.035 (1.83824339e-06)
143563 EPS nconv=0 first unconverged value (error) -302.035 (1.83824339e-06)
143564 EPS nconv=0 first unconverged value (error) -302.035 (1.84335140e-06)
143565 EPS nconv=0 first unconverged value (error) -302.035 (1.86325427e-06)
143566 EPS nconv=0 first unconverged value (error) -302.035 (1.82583493e-06)
143567 EPS nconv=0 first unconverged value (error) -302.035 (1.80977545e-06)
143568 EPS nconv=0 first unconverged value (error) -302.035 (1.80381745e-06)
143569 EPS nconv=0 first unconverged value (error) -302.035 (1.80381745e-06)
143570 EPS nconv=0 first unconverged value (error) -302.035 (2.08842052e-06)
143571 EPS nconv=0 first unconverged value (error) -302.035 (2.00240664e-06)
143572 EPS nconv=0 first unconverged value (error) -302.035 (1.95698805e-06)
143573 EPS nconv=0 first unconverged value (error) -302.035 (1.94726944e-06)
143574 EPS nconv=0 first unconverged value (error) -302.035 (1.92379696e-06)
143575 EPS nconv=0 first unconverged value (error) -302.035 (1.92379696e-06)
143576 EPS nconv=0 first unconverged value (error) -302.035 (1.94851012e-06)
143577 EPS nconv=0 first unconverged value (error) -302.035 (1.99216028e-06)
143578 EPS nconv=0 first unconverged value (error) -302.035 (1.89393168e-06)
143579 EPS nconv=0 first unconverged value (error) -302.035 (1.83880290e-06)
143580 EPS nconv=0 first unconverged value (error) -302.035 (1.83311865e-06)
143581 EPS nconv=0 first unconverged value (error) -302.035 (1.83311865e-06)
143582 EPS nconv=0 first unconverged value (error) -302.035 (1.89675853e-06)
143583 EPS nconv=0 first unconverged value (error) -302.035 (1.87153886e-06)
143584 EPS nconv=0 first unconverged value (error) -302.035 (1.85069381e-06)
143585 EPS nconv=0 first unconverged value (error) -302.035 (1.83392888e-06)
143586 EPS nconv=0 first unconverged value (error) -302.035 (1.82775946e-06)
143587 EPS nconv=0 first unconverged value (error) -302.035 (1.82775946e-06)
143588 EPS nconv=0 first unconverged value (error) -302.035 (1.93717867e-06)
143589 EPS nconv=0 first unconverged value (error) -302.035 (1.93150308e-06)
143590 EPS nconv=0 first unconverged value (error) -302.035 (1.87946021e-06)
143591 EPS nconv=0 first unconverged value (error) -302.035 (1.85527041e-06)
143592 EPS nconv=0 first unconverged value (error) -302.035 (1.84711854e-06)
143593 EPS nconv=0 first unconverged value (error) -302.035 (1.84711854e-06)
143594 EPS nconv=0 first unconverged value (error) -302.035 (1.90401095e-06)
143595 EPS nconv=0 first unconverged value (error) -302.035 (1.92965021e-06)
143596 EPS nconv=0 first unconverged value (error) -302.035 (1.87601103e-06)
143597 EPS nconv=0 first unconverged value (error) -302.035 (1.84609710e-06)
143598 EPS nconv=0 first unconverged value (error) -302.035 (1.83142556e-06)
143599 EPS nconv=0 first unconverged value (error) -302.035 (1.83142556e-06)
143600 EPS nconv=0 first unconverged value (error) -302.035 (1.82256095e-06)
143601 EPS nconv=0 first unconverged value (error) -302.035 (1.83353615e-06)
143602 EPS nconv=0 first unconverged value (error) -302.035 (1.80766945e-06)
143603 EPS nconv=0 first unconverged value (error) -302.035 (1.80304114e-06)
143604 EPS nconv=0 first unconverged value (error) -302.035 (1.80118637e-06)
143605 EPS nconv=0 first unconverged value (error) -302.035 (1.80118637e-06)
143606 EPS nconv=0 first unconverged value (error) -302.035 (1.81085971e-06)
143607 EPS nconv=0 first unconverged value (error) -302.035 (1.80500356e-06)
143608 EPS nconv=0 first unconverged value (error) -302.035 (1.80212002e-06)
143609 EPS nconv=0 first unconverged value (error) -302.035 (1.80138739e-06)
143610 EPS nconv=0 first unconverged value (error) -302.035 (1.80022889e-06)
143611 EPS nconv=0 first unconverged value (error) -302.035 (1.80022889e-06)
143612 EPS nconv=0 first unconverged value (error) -302.035 (1.94628167e-06)
143613 EPS nconv=0 first unconverged value (error) -302.035 (1.93679726e-06)
143614 EPS nconv=0 first unconverged value (error) -302.035 (1.89900722e-06)
143615 EPS nconv=0 first unconverged value (error) -302.035 (1.87747361e-06)
143616 EPS nconv=0 first unconverged value (error) -302.035 (1.86325484e-06)
143617 EPS nconv=0 first unconverged value (error) -302.035 (1.86325484e-06)
143618 EPS nconv=0 first unconverged value (error) -302.035 (1.86196124e-06)
143619 EPS nconv=0 first unconverged value (error) -302.035 (1.87501426e-06)
143620 EPS nconv=0 first unconverged value (error) -302.035 (1.85756141e-06)
143621 EPS nconv=0 first unconverged value (error) -302.035 (1.81400673e-06)
143622 EPS nconv=0 first unconverged value (error) -302.035 (1.80982738e-06)
143623 EPS nconv=0 first unconverged value (error) -302.035 (1.80982738e-06)
143624 EPS nconv=0 first unconverged value (error) -302.035 (1.85863924e-06)
143625 EPS nconv=0 first unconverged value (error) -302.035 (1.83364886e-06)
143626 EPS nconv=0 first unconverged value (error) -302.035 (1.83227635e-06)
143627 EPS nconv=0 first unconverged value (error) -302.035 (1.82608014e-06)
143628 EPS nconv=0 first unconverged value (error) -302.035 (1.82039552e-06)
143629 EPS nconv=0 first unconverged value (error) -302.035 (1.82039552e-06)
143630 EPS nconv=0 first unconverged value (error) -302.035 (1.82015783e-06)
143631 EPS nconv=0 first unconverged value (error) -302.035 (1.83654522e-06)
143632 EPS nconv=0 first unconverged value (error) -302.035 (1.80999024e-06)
143633 EPS nconv=0 first unconverged value (error) -302.035 (1.80496736e-06)
143634 EPS nconv=0 first unconverged value (error) -302.035 (1.80125012e-06)
143635 EPS nconv=0 first unconverged value (error) -302.035 (1.80125012e-06)
143636 EPS nconv=0 first unconverged value (error) -302.035 (1.95665941e-06)
143637 EPS nconv=0 first unconverged value (error) -302.035 (1.91871648e-06)
143638 EPS nconv=0 first unconverged value (error) -302.035 (1.87889792e-06)
143639 EPS nconv=0 first unconverged value (error) -302.035 (1.87339396e-06)
143640 EPS nconv=0 first unconverged value (error) -302.035 (1.85914451e-06)
143641 EPS nconv=0 first unconverged value (error) -302.035 (1.85914451e-06)
143642 EPS nconv=0 first unconverged value (error) -302.035 (1.86322507e-06)
143643 EPS nconv=0 first unconverged value (error) -302.035 (1.89929041e-06)
143644 EPS nconv=0 first unconverged value (error) -302.035 (1.86196695e-06)
143645 EPS nconv=0 first unconverged value (error) -302.035 (1.81402530e-06)
143646 EPS nconv=0 first unconverged value (error) -302.035 (1.81141269e-06)
143647 EPS nconv=0 first unconverged value (error) -302.035 (1.81141269e-06)
143648 EPS nconv=0 first unconverged value (error) -302.035 (1.83983328e-06)
143649 EPS nconv=0 first unconverged value (error) -302.035 (1.82348958e-06)
143650 EPS nconv=0 first unconverged value (error) -302.035 (1.81872413e-06)
143651 EPS nconv=0 first unconverged value (error) -302.035 (1.81486773e-06)
143652 EPS nconv=0 first unconverged value (error) -302.035 (1.81169257e-06)
143653 EPS nconv=0 first unconverged value (error) -302.035 (1.81169257e-06)
143654 EPS nconv=0 first unconverged value (error) -302.035 (1.81537473e-06)
143655 EPS nconv=0 first unconverged value (error) -302.035 (1.82179530e-06)
143656 EPS nconv=0 first unconverged value (error) -302.035 (1.80425577e-06)
143657 EPS nconv=0 first unconverged value (error) -302.035 (1.80212686e-06)
143658 EPS nconv=0 first unconverged value (error) -302.035 (1.79895522e-06)
143659 EPS nconv=0 first unconverged value (error) -302.035 (1.79895522e-06)
143660 EPS nconv=0 first unconverged value (error) -302.035 (1.90023841e-06)
143661 EPS nconv=0 first unconverged value (error) -302.035 (1.87700870e-06)
143662 EPS nconv=0 first unconverged value (error) -302.035 (1.85203876e-06)
143663 EPS nconv=0 first unconverged value (error) -302.035 (1.84872880e-06)
143664 EPS nconv=0 first unconverged value (error) -302.035 (1.83839625e-06)
143665 EPS nconv=0 first unconverged value (error) -302.035 (1.83839625e-06)
143666 EPS nconv=0 first unconverged value (error) -302.035 (1.83830170e-06)
143667 EPS nconv=0 first unconverged value (error) -302.035 (1.85919946e-06)
143668 EPS nconv=0 first unconverged value (error) -302.035 (1.83379845e-06)
143669 EPS nconv=0 first unconverged value (error) -302.035 (1.80683158e-06)
143670 EPS nconv=0 first unconverged value (error) -302.035 (1.80417374e-06)
143671 EPS nconv=0 first unconverged value (error) -302.035 (1.80417374e-06)
143672 EPS nconv=0 first unconverged value (error) -302.035 (1.81392352e-06)
143673 EPS nconv=0 first unconverged value (error) -302.035 (1.80683165e-06)
143674 EPS nconv=0 first unconverged value (error) -302.035 (1.80549120e-06)
143675 EPS nconv=0 first unconverged value (error) -302.035 (1.80429482e-06)
143676 EPS nconv=0 first unconverged value (error) -302.035 (1.80279854e-06)
143677 EPS nconv=0 first unconverged value (error) -302.035 (1.80279854e-06)
143678 EPS nconv=0 first unconverged value (error) -302.035 (1.86976783e-06)
143679 EPS nconv=0 first unconverged value (error) -302.035 (1.85310240e-06)
143680 EPS nconv=0 first unconverged value (error) -302.035 (1.84065913e-06)
143681 EPS nconv=0 first unconverged value (error) -302.035 (1.83342072e-06)
143682 EPS nconv=0 first unconverged value (error) -302.035 (1.82979161e-06)
143683 EPS nconv=0 first unconverged value (error) -302.035 (1.82979161e-06)
143684 EPS nconv=0 first unconverged value (error) -302.035 (2.00987598e-06)
143685 EPS nconv=0 first unconverged value (error) -302.035 (1.97927900e-06)
143686 EPS nconv=0 first unconverged value (error) -302.035 (1.93897142e-06)
143687 EPS nconv=0 first unconverged value (error) -302.035 (1.87835823e-06)
143688 EPS nconv=0 first unconverged value (error) -302.035 (1.85902890e-06)
143689 EPS nconv=0 first unconverged value (error) -302.035 (1.85902890e-06)
143690 EPS nconv=0 first unconverged value (error) -302.035 (1.88152370e-06)
143691 EPS nconv=0 first unconverged value (error) -302.035 (1.91156962e-06)
143692 EPS nconv=0 first unconverged value (error) -302.035 (1.85648061e-06)
143693 EPS nconv=0 first unconverged value (error) -302.035 (1.82473742e-06)
143694 EPS nconv=0 first unconverged value (error) -302.035 (1.81808857e-06)
143695 EPS nconv=0 first unconverged value (error) -302.035 (1.81808857e-06)
143696 EPS nconv=0 first unconverged value (error) -302.035 (1.86165817e-06)
143697 EPS nconv=0 first unconverged value (error) -302.035 (1.84224612e-06)
143698 EPS nconv=0 first unconverged value (error) -302.035 (1.82988226e-06)
143699 EPS nconv=0 first unconverged value (error) -302.035 (1.82344633e-06)
143700 EPS nconv=0 first unconverged value (error) -302.035 (1.81754572e-06)
143701 EPS nconv=0 first unconverged value (error) -302.035 (1.81754572e-06)
143702 EPS nconv=0 first unconverged value (error) -302.035 (1.91129869e-06)
143703 EPS nconv=0 first unconverged value (error) -302.035 (1.89545942e-06)
143704 EPS nconv=0 first unconverged value (error) -302.035 (1.87039660e-06)
143705 EPS nconv=0 first unconverged value (error) -302.035 (1.85659757e-06)
143706 EPS nconv=0 first unconverged value (error) -302.035 (1.84840172e-06)
143707 EPS nconv=0 first unconverged value (error) -302.035 (1.84840172e-06)
143708 EPS nconv=0 first unconverged value (error) -302.035 (1.86399923e-06)
143709 EPS nconv=0 first unconverged value (error) -302.035 (1.86411724e-06)
143710 EPS nconv=0 first unconverged value (error) -302.035 (1.84586112e-06)
143711 EPS nconv=0 first unconverged value (error) -302.035 (1.81412385e-06)
143712 EPS nconv=0 first unconverged value (error) -302.035 (1.80927578e-06)
143713 EPS nconv=0 first unconverged value (error) -302.035 (1.80927578e-06)
143714 EPS nconv=0 first unconverged value (error) -302.035 (1.85306658e-06)
143715 EPS nconv=0 first unconverged value (error) -302.035 (1.83719756e-06)
143716 EPS nconv=0 first unconverged value (error) -302.035 (1.82325941e-06)
143717 EPS nconv=0 first unconverged value (error) -302.035 (1.81741775e-06)
143718 EPS nconv=0 first unconverged value (error) -302.035 (1.81233762e-06)
143719 EPS nconv=0 first unconverged value (error) -302.035 (1.81233762e-06)
143720 EPS nconv=0 first unconverged value (error) -302.035 (1.92151979e-06)
143721 EPS nconv=0 first unconverged value (error) -302.035 (1.90341568e-06)
143722 EPS nconv=0 first unconverged value (error) -302.035 (1.88196629e-06)
143723 EPS nconv=0 first unconverged value (error) -302.035 (1.86915245e-06)
143724 EPS nconv=0 first unconverged value (error) -302.035 (1.85840362e-06)
143725 EPS nconv=0 first unconverged value (error) -302.035 (1.85840362e-06)
143726 EPS nconv=0 first unconverged value (error) -302.035 (1.87255210e-06)
143727 EPS nconv=0 first unconverged value (error) -302.035 (1.87883784e-06)
143728 EPS nconv=0 first unconverged value (error) -302.035 (1.85260515e-06)
143729 EPS nconv=0 first unconverged value (error) -302.035 (1.81447065e-06)
143730 EPS nconv=0 first unconverged value (error) -302.035 (1.80622264e-06)
143731 EPS nconv=0 first unconverged value (error) -302.035 (1.80622264e-06)
143732 EPS nconv=0 first unconverged value (error) -302.035 (1.88949484e-06)
143733 EPS nconv=0 first unconverged value (error) -302.035 (1.85258350e-06)
143734 EPS nconv=0 first unconverged value (error) -302.035 (1.83900287e-06)
143735 EPS nconv=0 first unconverged value (error) -302.035 (1.83219694e-06)
143736 EPS nconv=0 first unconverged value (error) -302.035 (1.82686943e-06)
143737 EPS nconv=0 first unconverged value (error) -302.035 (1.82686943e-06)
143738 EPS nconv=0 first unconverged value (error) -302.035 (2.00137967e-06)
143739 EPS nconv=0 first unconverged value (error) -302.035 (1.96666811e-06)
143740 EPS nconv=0 first unconverged value (error) -302.035 (1.89890768e-06)
143741 EPS nconv=0 first unconverged value (error) -302.035 (1.89059564e-06)
143742 EPS nconv=0 first unconverged value (error) -302.035 (1.87778143e-06)
143743 EPS nconv=0 first unconverged value (error) -302.035 (1.87778143e-06)
143744 EPS nconv=0 first unconverged value (error) -302.035 (1.90418171e-06)
143745 EPS nconv=0 first unconverged value (error) -302.035 (1.91918845e-06)
143746 EPS nconv=0 first unconverged value (error) -302.035 (1.86683577e-06)
143747 EPS nconv=0 first unconverged value (error) -302.035 (1.83379218e-06)
143748 EPS nconv=0 first unconverged value (error) -302.035 (1.81821205e-06)
143749 EPS nconv=0 first unconverged value (error) -302.035 (1.81821205e-06)
143750 EPS nconv=0 first unconverged value (error) -302.035 (1.90058569e-06)
143751 EPS nconv=0 first unconverged value (error) -302.035 (1.88402841e-06)
143752 EPS nconv=0 first unconverged value (error) -302.035 (1.87315900e-06)
143753 EPS nconv=0 first unconverged value (error) -302.035 (1.84976184e-06)
143754 EPS nconv=0 first unconverged value (error) -302.035 (1.83999926e-06)
143755 EPS nconv=0 first unconverged value (error) -302.035 (1.83999926e-06)
143756 EPS nconv=0 first unconverged value (error) -302.035 (2.03965670e-06)
143757 EPS nconv=0 first unconverged value (error) -302.035 (1.99537526e-06)
143758 EPS nconv=0 first unconverged value (error) -302.035 (1.93922987e-06)
143759 EPS nconv=0 first unconverged value (error) -302.035 (1.90916781e-06)
143760 EPS nconv=0 first unconverged value (error) -302.035 (1.87735550e-06)
143761 EPS nconv=0 first unconverged value (error) -302.035 (1.87735550e-06)
143762 EPS nconv=0 first unconverged value (error) -302.035 (2.02041891e-06)
143763 EPS nconv=0 first unconverged value (error) -302.035 (2.02941963e-06)
143764 EPS nconv=0 first unconverged value (error) -302.035 (1.93841538e-06)
143765 EPS nconv=0 first unconverged value (error) -302.035 (1.91910649e-06)
143766 EPS nconv=0 first unconverged value (error) -302.035 (1.89077216e-06)
143767 EPS nconv=0 first unconverged value (error) -302.035 (1.89077216e-06)
143768 EPS nconv=0 first unconverged value (error) -302.035 (1.87628100e-06)
143769 EPS nconv=0 first unconverged value (error) -302.035 (1.89750609e-06)
143770 EPS nconv=0 first unconverged value (error) -302.035 (1.84862878e-06)
143771 EPS nconv=0 first unconverged value (error) -302.035 (1.82276589e-06)
143772 EPS nconv=0 first unconverged value (error) -302.035 (1.81233564e-06)
143773 EPS nconv=0 first unconverged value (error) -302.035 (1.81233564e-06)
143774 EPS nconv=0 first unconverged value (error) -302.035 (1.81810072e-06)
143775 EPS nconv=0 first unconverged value (error) -302.035 (1.81493916e-06)
143776 EPS nconv=0 first unconverged value (error) -302.035 (1.81167380e-06)
143777 EPS nconv=0 first unconverged value (error) -302.035 (1.80696306e-06)
143778 EPS nconv=0 first unconverged value (error) -302.035 (1.80454103e-06)
143779 EPS nconv=0 first unconverged value (error) -302.035 (1.80454103e-06)
143780 EPS nconv=0 first unconverged value (error) -302.035 (1.92535606e-06)
143781 EPS nconv=0 first unconverged value (error) -302.035 (1.88806350e-06)
143782 EPS nconv=0 first unconverged value (error) -302.035 (1.86820035e-06)
143783 EPS nconv=0 first unconverged value (error) -302.035 (1.85704700e-06)
143784 EPS nconv=0 first unconverged value (error) -302.035 (1.84328403e-06)
143785 EPS nconv=0 first unconverged value (error) -302.035 (1.84328403e-06)
143786 EPS nconv=0 first unconverged value (error) -302.035 (2.14007544e-06)
143787 EPS nconv=0 first unconverged value (error) -302.035 (2.08657644e-06)
143788 EPS nconv=0 first unconverged value (error) -302.035 (1.99376522e-06)
143789 EPS nconv=0 first unconverged value (error) -302.035 (1.98560791e-06)
143790 EPS nconv=0 first unconverged value (error) -302.035 (1.95543903e-06)
143791 EPS nconv=0 first unconverged value (error) -302.035 (1.95543903e-06)
143792 EPS nconv=0 first unconverged value (error) -302.035 (2.06448130e-06)
143793 EPS nconv=0 first unconverged value (error) -302.035 (2.05185581e-06)
143794 EPS nconv=0 first unconverged value (error) -302.035 (1.94835721e-06)
143795 EPS nconv=0 first unconverged value (error) -302.035 (1.90789483e-06)
143796 EPS nconv=0 first unconverged value (error) -302.035 (1.88989783e-06)
143797 EPS nconv=0 first unconverged value (error) -302.035 (1.88989783e-06)
143798 EPS nconv=0 first unconverged value (error) -302.035 (2.05176121e-06)
143799 EPS nconv=0 first unconverged value (error) -302.035 (2.02357342e-06)
143800 EPS nconv=0 first unconverged value (error) -302.035 (1.99151171e-06)
143801 EPS nconv=0 first unconverged value (error) -302.035 (1.90819594e-06)
143802 EPS nconv=0 first unconverged value (error) -302.035 (1.87962772e-06)
143803 EPS nconv=0 first unconverged value (error) -302.035 (1.87962772e-06)
143804 EPS nconv=0 first unconverged value (error) -302.035 (1.89106898e-06)
143805 EPS nconv=0 first unconverged value (error) -302.035 (1.93978303e-06)
143806 EPS nconv=0 first unconverged value (error) -302.035 (1.86108047e-06)
143807 EPS nconv=0 first unconverged value (error) -302.035 (1.82541771e-06)
143808 EPS nconv=0 first unconverged value (error) -302.035 (1.81567240e-06)
143809 EPS nconv=0 first unconverged value (error) -302.035 (1.81567240e-06)
143810 EPS nconv=0 first unconverged value (error) -302.035 (1.83681275e-06)
143811 EPS nconv=0 first unconverged value (error) -302.035 (1.82698260e-06)
143812 EPS nconv=0 first unconverged value (error) -302.035 (1.81982479e-06)
143813 EPS nconv=0 first unconverged value (error) -302.035 (1.81567268e-06)
143814 EPS nconv=0 first unconverged value (error) -302.035 (1.81249353e-06)
143815 EPS nconv=0 first unconverged value (error) -302.035 (1.81249353e-06)
143816 EPS nconv=0 first unconverged value (error) -302.035 (1.82240480e-06)
143817 EPS nconv=0 first unconverged value (error) -302.035 (1.82695955e-06)
143818 EPS nconv=0 first unconverged value (error) -302.035 (1.81285816e-06)
143819 EPS nconv=0 first unconverged value (error) -302.035 (1.80477654e-06)
143820 EPS nconv=0 first unconverged value (error) -302.035 (1.80227053e-06)
143821 EPS nconv=0 first unconverged value (error) -302.035 (1.80227053e-06)
143822 EPS nconv=0 first unconverged value (error) -302.035 (2.22176326e-06)
143823 EPS nconv=0 first unconverged value (error) -302.035 (2.10075285e-06)
143824 EPS nconv=0 first unconverged value (error) -302.035 (2.03829028e-06)
143825 EPS nconv=0 first unconverged value (error) -302.035 (2.01381852e-06)
143826 EPS nconv=0 first unconverged value (error) -302.035 (1.97527065e-06)
143827 EPS nconv=0 first unconverged value (error) -302.035 (1.97527065e-06)
143828 EPS nconv=0 first unconverged value (error) -302.035 (2.65185398e-06)
143829 EPS nconv=0 first unconverged value (error) -302.035 (2.57085466e-06)
143830 EPS nconv=0 first unconverged value (error) -302.035 (2.38895083e-06)
143831 EPS nconv=0 first unconverged value (error) -302.035 (2.38477156e-06)
143832 EPS nconv=0 first unconverged value (error) -302.035 (2.32812238e-06)
143833 EPS nconv=0 first unconverged value (error) -302.035 (2.32812238e-06)
143834 EPS nconv=0 first unconverged value (error) -302.035 (2.32979414e-06)
143835 EPS nconv=0 first unconverged value (error) -302.035 (2.17446605e-06)
143836 EPS nconv=0 first unconverged value (error) -302.035 (2.05311193e-06)
143837 EPS nconv=0 first unconverged value (error) -302.035 (1.96386180e-06)
143838 EPS nconv=0 first unconverged value (error) -302.035 (1.90215381e-06)
143839 EPS nconv=0 first unconverged value (error) -302.035 (1.90215381e-06)
143840 EPS nconv=0 first unconverged value (error) -302.035 (1.92756551e-06)
143841 EPS nconv=0 first unconverged value (error) -302.035 (1.95140572e-06)
143842 EPS nconv=0 first unconverged value (error) -302.035 (1.90627120e-06)
143843 EPS nconv=0 first unconverged value (error) -302.035 (1.84063016e-06)
143844 EPS nconv=0 first unconverged value (error) -302.035 (1.82955084e-06)
143845 EPS nconv=0 first unconverged value (error) -302.035 (1.82955084e-06)
143846 EPS nconv=0 first unconverged value (error) -302.035 (2.35389594e-06)
143847 EPS nconv=0 first unconverged value (error) -302.035 (2.09711773e-06)
143848 EPS nconv=0 first unconverged value (error) -302.035 (2.02756798e-06)
143849 EPS nconv=0 first unconverged value (error) -302.035 (1.99385937e-06)
143850 EPS nconv=0 first unconverged value (error) -302.035 (1.98414025e-06)
143851 EPS nconv=0 first unconverged value (error) -302.035 (1.98414025e-06)
143852 EPS nconv=0 first unconverged value (error) -302.035 (2.51197500e-06)
143853 EPS nconv=0 first unconverged value (error) -302.035 (2.27991809e-06)
143854 EPS nconv=0 first unconverged value (error) -302.035 (2.08640515e-06)
143855 EPS nconv=0 first unconverged value (error) -302.035 (2.06016280e-06)
143856 EPS nconv=0 first unconverged value (error) -302.035 (2.03066041e-06)
143857 EPS nconv=0 first unconverged value (error) -302.035 (2.03066041e-06)
143858 EPS nconv=0 first unconverged value (error) -302.035 (2.22168084e-06)
143859 EPS nconv=0 first unconverged value (error) -302.035 (2.41679838e-06)
143860 EPS nconv=0 first unconverged value (error) -302.035 (2.04347542e-06)
143861 EPS nconv=0 first unconverged value (error) -302.035 (1.95844770e-06)
143862 EPS nconv=0 first unconverged value (error) -302.035 (1.92256109e-06)
143863 EPS nconv=0 first unconverged value (error) -302.035 (1.92256109e-06)
143864 EPS nconv=0 first unconverged value (error) -302.035 (2.72648910e-06)
143865 EPS nconv=0 first unconverged value (error) -302.035 (2.47214950e-06)
143866 EPS nconv=0 first unconverged value (error) -302.035 (2.29959720e-06)
143867 EPS nconv=0 first unconverged value (error) -302.035 (2.24372007e-06)
143868 EPS nconv=0 first unconverged value (error) -302.035 (2.18793004e-06)
143869 EPS nconv=0 first unconverged value (error) -302.035 (2.18793004e-06)
143870 EPS nconv=0 first unconverged value (error) -302.035 (2.30616295e-06)
143871 EPS nconv=0 first unconverged value (error) -302.035 (2.63742160e-06)
143872 EPS nconv=0 first unconverged value (error) -302.035 (2.29102998e-06)
143873 EPS nconv=0 first unconverged value (error) -302.035 (1.96280055e-06)
143874 EPS nconv=0 first unconverged value (error) -302.035 (1.92555659e-06)
143875 EPS nconv=0 first unconverged value (error) -302.035 (1.92555659e-06)
143876 EPS nconv=0 first unconverged value (error) -302.035 (2.09637235e-06)
143877 EPS nconv=0 first unconverged value (error) -302.035 (2.00647385e-06)
143878 EPS nconv=0 first unconverged value (error) -302.035 (1.93438440e-06)
143879 EPS nconv=0 first unconverged value (error) -302.035 (1.92683335e-06)
143880 EPS nconv=0 first unconverged value (error) -302.035 (1.90283827e-06)
143881 EPS nconv=0 first unconverged value (error) -302.035 (1.90283827e-06)
143882 EPS nconv=0 first unconverged value (error) -302.035 (1.96568033e-06)
143883 EPS nconv=0 first unconverged value (error) -302.035 (2.06043171e-06)
143884 EPS nconv=0 first unconverged value (error) -302.035 (1.92135285e-06)
143885 EPS nconv=0 first unconverged value (error) -302.035 (1.86700264e-06)
143886 EPS nconv=0 first unconverged value (error) -302.035 (1.84673921e-06)
143887 EPS nconv=0 first unconverged value (error) -302.035 (1.84673921e-06)
143888 EPS nconv=0 first unconverged value (error) -302.035 (1.89110608e-06)
143889 EPS nconv=0 first unconverged value (error) -302.035 (1.89815828e-06)
143890 EPS nconv=0 first unconverged value (error) -302.035 (1.85233266e-06)
143891 EPS nconv=0 first unconverged value (error) -302.035 (1.84228272e-06)
143892 EPS nconv=0 first unconverged value (error) -302.035 (1.83215074e-06)
143893 EPS nconv=0 first unconverged value (error) -302.035 (1.83215074e-06)
143894 EPS nconv=0 first unconverged value (error) -302.035 (2.17105279e-06)
143895 EPS nconv=0 first unconverged value (error) -302.035 (2.09360395e-06)
143896 EPS nconv=0 first unconverged value (error) -302.035 (2.03305388e-06)
143897 EPS nconv=0 first unconverged value (error) -302.035 (1.98243191e-06)
143898 EPS nconv=0 first unconverged value (error) -302.035 (1.93830375e-06)
143899 EPS nconv=0 first unconverged value (error) -302.035 (1.93830375e-06)
143900 EPS nconv=0 first unconverged value (error) -302.035 (1.95907032e-06)
143901 EPS nconv=0 first unconverged value (error) -302.035 (2.02889583e-06)
143902 EPS nconv=0 first unconverged value (error) -302.035 (1.89360269e-06)
143903 EPS nconv=0 first unconverged value (error) -302.035 (1.85512053e-06)
143904 EPS nconv=0 first unconverged value (error) -302.035 (1.84227118e-06)
143905 EPS nconv=0 first unconverged value (error) -302.035 (1.84227118e-06)
143906 EPS nconv=0 first unconverged value (error) -302.035 (1.85464919e-06)
143907 EPS nconv=0 first unconverged value (error) -302.035 (1.84078522e-06)
143908 EPS nconv=0 first unconverged value (error) -302.035 (1.82134273e-06)
143909 EPS nconv=0 first unconverged value (error) -302.035 (1.81132074e-06)
143910 EPS nconv=0 first unconverged value (error) -302.035 (1.80660164e-06)
143911 EPS nconv=0 first unconverged value (error) -302.035 (1.80660164e-06)
143912 EPS nconv=0 first unconverged value (error) -302.035 (1.83670473e-06)
143913 EPS nconv=0 first unconverged value (error) -302.035 (1.82891938e-06)
143914 EPS nconv=0 first unconverged value (error) -302.035 (1.82100356e-06)
143915 EPS nconv=0 first unconverged value (error) -302.035 (1.81648165e-06)
143916 EPS nconv=0 first unconverged value (error) -302.035 (1.81026572e-06)
143917 EPS nconv=0 first unconverged value (error) -302.035 (1.81026572e-06)
143918 EPS nconv=0 first unconverged value (error) -302.035 (2.06301212e-06)
143919 EPS nconv=0 first unconverged value (error) -302.035 (1.96120121e-06)
143920 EPS nconv=0 first unconverged value (error) -302.035 (1.92709007e-06)
143921 EPS nconv=0 first unconverged value (error) -302.035 (1.91710736e-06)
143922 EPS nconv=0 first unconverged value (error) -302.035 (1.89527494e-06)
143923 EPS nconv=0 first unconverged value (error) -302.035 (1.89527494e-06)
143924 EPS nconv=0 first unconverged value (error) -302.035 (2.04363325e-06)
143925 EPS nconv=0 first unconverged value (error) -302.035 (2.11743501e-06)
143926 EPS nconv=0 first unconverged value (error) -302.035 (1.97067744e-06)
143927 EPS nconv=0 first unconverged value (error) -302.035 (1.90812941e-06)
143928 EPS nconv=0 first unconverged value (error) -302.035 (1.88792760e-06)
143929 EPS nconv=0 first unconverged value (error) -302.035 (1.88792760e-06)
143930 EPS nconv=0 first unconverged value (error) -302.035 (1.86968067e-06)
143931 EPS nconv=0 first unconverged value (error) -302.035 (1.87195914e-06)
143932 EPS nconv=0 first unconverged value (error) -302.035 (1.85633817e-06)
143933 EPS nconv=0 first unconverged value (error) -302.035 (1.81457016e-06)
143934 EPS nconv=0 first unconverged value (error) -302.035 (1.81251217e-06)
143935 EPS nconv=0 first unconverged value (error) -302.035 (1.81251217e-06)
143936 EPS nconv=0 first unconverged value (error) -302.035 (1.85626160e-06)
143937 EPS nconv=0 first unconverged value (error) -302.035 (1.83016531e-06)
143938 EPS nconv=0 first unconverged value (error) -302.035 (1.82717440e-06)
143939 EPS nconv=0 first unconverged value (error) -302.035 (1.82262658e-06)
143940 EPS nconv=0 first unconverged value (error) -302.035 (1.81803472e-06)
143941 EPS nconv=0 first unconverged value (error) -302.035 (1.81803472e-06)
143942 EPS nconv=0 first unconverged value (error) -302.035 (1.87329001e-06)
143943 EPS nconv=0 first unconverged value (error) -302.035 (1.87350447e-06)
143944 EPS nconv=0 first unconverged value (error) -302.035 (1.83434720e-06)
143945 EPS nconv=0 first unconverged value (error) -302.035 (1.83170062e-06)
143946 EPS nconv=0 first unconverged value (error) -302.035 (1.82390048e-06)
143947 EPS nconv=0 first unconverged value (error) -302.035 (1.82390048e-06)
143948 EPS nconv=0 first unconverged value (error) -302.035 (1.81913637e-06)
143949 EPS nconv=0 first unconverged value (error) -302.035 (1.83089108e-06)
143950 EPS nconv=0 first unconverged value (error) -302.035 (1.81673944e-06)
143951 EPS nconv=0 first unconverged value (error) -302.035 (1.80242194e-06)
143952 EPS nconv=0 first unconverged value (error) -302.035 (1.79984308e-06)
143953 EPS nconv=0 first unconverged value (error) -302.035 (1.79984308e-06)
143954 EPS nconv=0 first unconverged value (error) -302.035 (2.19119040e-06)
143955 EPS nconv=0 first unconverged value (error) -302.035 (2.05635537e-06)
143956 EPS nconv=0 first unconverged value (error) -302.035 (2.00014230e-06)
143957 EPS nconv=0 first unconverged value (error) -302.035 (1.96941567e-06)
143958 EPS nconv=0 first unconverged value (error) -302.035 (1.94263479e-06)
143959 EPS nconv=0 first unconverged value (error) -302.035 (1.94263479e-06)
143960 EPS nconv=0 first unconverged value (error) -302.035 (2.00132072e-06)
143961 EPS nconv=0 first unconverged value (error) -302.035 (2.07102189e-06)
143962 EPS nconv=0 first unconverged value (error) -302.035 (1.93611765e-06)
143963 EPS nconv=0 first unconverged value (error) -302.035 (1.87623814e-06)
143964 EPS nconv=0 first unconverged value (error) -302.035 (1.86851713e-06)
143965 EPS nconv=0 first unconverged value (error) -302.035 (1.86851713e-06)
143966 EPS nconv=0 first unconverged value (error) -302.035 (1.85460622e-06)
143967 EPS nconv=0 first unconverged value (error) -302.035 (1.85243122e-06)
143968 EPS nconv=0 first unconverged value (error) -302.035 (1.82138241e-06)
143969 EPS nconv=0 first unconverged value (error) -302.035 (1.81000211e-06)
143970 EPS nconv=0 first unconverged value (error) -302.035 (1.80491099e-06)
143971 EPS nconv=0 first unconverged value (error) -302.035 (1.80491099e-06)
143972 EPS nconv=0 first unconverged value (error) -302.035 (2.23015501e-06)
143973 EPS nconv=0 first unconverged value (error) -302.035 (2.03488895e-06)
143974 EPS nconv=0 first unconverged value (error) -302.035 (1.96710598e-06)
143975 EPS nconv=0 first unconverged value (error) -302.035 (1.95061687e-06)
143976 EPS nconv=0 first unconverged value (error) -302.035 (1.93419573e-06)
143977 EPS nconv=0 first unconverged value (error) -302.035 (1.93419573e-06)
143978 EPS nconv=0 first unconverged value (error) -302.035 (1.93604766e-06)
143979 EPS nconv=0 first unconverged value (error) -302.035 (2.17111837e-06)
143980 EPS nconv=0 first unconverged value (error) -302.035 (1.93496745e-06)
143981 EPS nconv=0 first unconverged value (error) -302.035 (1.83673082e-06)
143982 EPS nconv=0 first unconverged value (error) -302.035 (1.81450572e-06)
143983 EPS nconv=0 first unconverged value (error) -302.035 (1.81450572e-06)
143984 EPS nconv=0 first unconverged value (error) -302.035 (1.80576153e-06)
143985 EPS nconv=0 first unconverged value (error) -302.035 (1.80288786e-06)
143986 EPS nconv=0 first unconverged value (error) -302.035 (1.80167104e-06)
143987 EPS nconv=0 first unconverged value (error) -302.035 (1.80145232e-06)
143988 EPS nconv=0 first unconverged value (error) -302.035 (1.80051290e-06)
143989 EPS nconv=0 first unconverged value (error) -302.035 (1.80051290e-06)
143990 EPS nconv=0 first unconverged value (error) -302.035 (1.90784367e-06)
143991 EPS nconv=0 first unconverged value (error) -302.035 (1.86678507e-06)
143992 EPS nconv=0 first unconverged value (error) -302.035 (1.84912396e-06)
143993 EPS nconv=0 first unconverged value (error) -302.035 (1.84302836e-06)
143994 EPS nconv=0 first unconverged value (error) -302.035 (1.83929219e-06)
143995 EPS nconv=0 first unconverged value (error) -302.035 (1.83929219e-06)
143996 EPS nconv=0 first unconverged value (error) -302.035 (2.03292102e-06)
143997 EPS nconv=0 first unconverged value (error) -302.035 (2.08798109e-06)
143998 EPS nconv=0 first unconverged value (error) -302.035 (2.00560283e-06)
143999 EPS nconv=0 first unconverged value (error) -302.035 (1.90110357e-06)
144000 EPS nconv=0 first unconverged value (error) -302.035 (1.89188534e-06)
144001 EPS nconv=0 first unconverged value (error) -302.035 (1.89188534e-06)
144002 EPS nconv=0 first unconverged value (error) -302.035 (1.93649944e-06)
144003 EPS nconv=0 first unconverged value (error) -302.035 (1.91244419e-06)
144004 EPS nconv=0 first unconverged value (error) -302.035 (1.89928703e-06)
144005 EPS nconv=0 first unconverged value (error) -302.035 (1.85592657e-06)
144006 EPS nconv=0 first unconverged value (error) -302.035 (1.83886918e-06)
144007 EPS nconv=0 first unconverged value (error) -302.035 (1.83886918e-06)
144008 EPS nconv=0 first unconverged value (error) -302.035 (2.08594995e-06)
144009 EPS nconv=0 first unconverged value (error) -302.035 (1.97261546e-06)
144010 EPS nconv=0 first unconverged value (error) -302.035 (1.92862471e-06)
144011 EPS nconv=0 first unconverged value (error) -302.035 (1.91749453e-06)
144012 EPS nconv=0 first unconverged value (error) -302.035 (1.90208091e-06)
144013 EPS nconv=0 first unconverged value (error) -302.035 (1.90208091e-06)
144014 EPS nconv=0 first unconverged value (error) -302.035 (1.90505832e-06)
144015 EPS nconv=0 first unconverged value (error) -302.035 (1.95744634e-06)
144016 EPS nconv=0 first unconverged value (error) -302.035 (1.86631194e-06)
144017 EPS nconv=0 first unconverged value (error) -302.035 (1.83629820e-06)
144018 EPS nconv=0 first unconverged value (error) -302.035 (1.82365684e-06)
144019 EPS nconv=0 first unconverged value (error) -302.035 (1.82365684e-06)
144020 EPS nconv=0 first unconverged value (error) -302.035 (1.80375455e-06)
144021 EPS nconv=0 first unconverged value (error) -302.035 (1.80616709e-06)
144022 EPS nconv=0 first unconverged value (error) -302.035 (1.80225671e-06)
144023 EPS nconv=0 first unconverged value (error) -302.035 (1.79796093e-06)
144024 EPS nconv=0 first unconverged value (error) -302.035 (1.79690698e-06)
144025 EPS nconv=0 first unconverged value (error) -302.035 (1.79690698e-06)
144026 EPS nconv=0 first unconverged value (error) -302.035 (1.79954086e-06)
144027 EPS nconv=0 first unconverged value (error) -302.035 (1.79947770e-06)
144028 EPS nconv=0 first unconverged value (error) -302.035 (1.79799137e-06)
144029 EPS nconv=0 first unconverged value (error) -302.035 (1.79723964e-06)
144030 EPS nconv=0 first unconverged value (error) -302.035 (1.79697299e-06)
144031 EPS nconv=0 first unconverged value (error) -302.035 (1.79697299e-06)
144032 EPS nconv=0 first unconverged value (error) -302.035 (2.00178140e-06)
144033 EPS nconv=0 first unconverged value (error) -302.035 (1.93025990e-06)
144034 EPS nconv=0 first unconverged value (error) -302.035 (1.90791540e-06)
144035 EPS nconv=0 first unconverged value (error) -302.035 (1.88609068e-06)
144036 EPS nconv=0 first unconverged value (error) -302.035 (1.86782726e-06)
144037 EPS nconv=0 first unconverged value (error) -302.035 (1.86782726e-06)
144038 EPS nconv=0 first unconverged value (error) -302.035 (1.89104312e-06)
144039 EPS nconv=0 first unconverged value (error) -302.035 (1.94431836e-06)
144040 EPS nconv=0 first unconverged value (error) -302.035 (1.86154175e-06)
144041 EPS nconv=0 first unconverged value (error) -302.035 (1.84556243e-06)
144042 EPS nconv=0 first unconverged value (error) -302.035 (1.82716318e-06)
144043 EPS nconv=0 first unconverged value (error) -302.035 (1.82716318e-06)
144044 EPS nconv=0 first unconverged value (error) -302.035 (1.82077325e-06)
144045 EPS nconv=0 first unconverged value (error) -302.035 (1.81520804e-06)
144046 EPS nconv=0 first unconverged value (error) -302.035 (1.81123951e-06)
144047 EPS nconv=0 first unconverged value (error) -302.035 (1.80449316e-06)
144048 EPS nconv=0 first unconverged value (error) -302.035 (1.80252035e-06)
144049 EPS nconv=0 first unconverged value (error) -302.035 (1.80252035e-06)
144050 EPS nconv=0 first unconverged value (error) -302.035 (1.80243332e-06)
144051 EPS nconv=0 first unconverged value (error) -302.035 (1.80387964e-06)
144052 EPS nconv=0 first unconverged value (error) -302.035 (1.80035133e-06)
144053 EPS nconv=0 first unconverged value (error) -302.035 (1.79792540e-06)
144054 EPS nconv=0 first unconverged value (error) -302.035 (1.79762259e-06)
144055 EPS nconv=0 first unconverged value (error) -302.035 (1.79762259e-06)
144056 EPS nconv=0 first unconverged value (error) -302.035 (1.95451022e-06)
144057 EPS nconv=0 first unconverged value (error) -302.035 (1.89116411e-06)
144058 EPS nconv=0 first unconverged value (error) -302.035 (1.87592367e-06)
144059 EPS nconv=0 first unconverged value (error) -302.035 (1.86549496e-06)
144060 EPS nconv=0 first unconverged value (error) -302.035 (1.85137516e-06)
144061 EPS nconv=0 first unconverged value (error) -302.035 (1.85137516e-06)
144062 EPS nconv=0 first unconverged value (error) -302.035 (1.86153358e-06)
144063 EPS nconv=0 first unconverged value (error) -302.035 (1.91748245e-06)
144064 EPS nconv=0 first unconverged value (error) -302.035 (1.84915051e-06)
144065 EPS nconv=0 first unconverged value (error) -302.035 (1.82388635e-06)
144066 EPS nconv=0 first unconverged value (error) -302.035 (1.81423921e-06)
144067 EPS nconv=0 first unconverged value (error) -302.035 (1.81423921e-06)
144068 EPS nconv=0 first unconverged value (error) -302.035 (1.81580917e-06)
144069 EPS nconv=0 first unconverged value (error) -302.035 (1.81036351e-06)
144070 EPS nconv=0 first unconverged value (error) -302.035 (1.80562816e-06)
144071 EPS nconv=0 first unconverged value (error) -302.035 (1.80455052e-06)
144072 EPS nconv=0 first unconverged value (error) -302.035 (1.80244664e-06)
144073 EPS nconv=0 first unconverged value (error) -302.035 (1.80244664e-06)
144074 EPS nconv=0 first unconverged value (error) -302.035 (1.92036329e-06)
144075 EPS nconv=0 first unconverged value (error) -302.035 (1.87795585e-06)
144076 EPS nconv=0 first unconverged value (error) -302.035 (1.85940238e-06)
144077 EPS nconv=0 first unconverged value (error) -302.035 (1.85201464e-06)
144078 EPS nconv=0 first unconverged value (error) -302.035 (1.84728171e-06)
144079 EPS nconv=0 first unconverged value (error) -302.035 (1.84728171e-06)
144080 EPS nconv=0 first unconverged value (error) -302.035 (1.97909152e-06)
144081 EPS nconv=0 first unconverged value (error) -302.035 (1.96453584e-06)
144082 EPS nconv=0 first unconverged value (error) -302.035 (1.90553405e-06)
144083 EPS nconv=0 first unconverged value (error) -302.035 (1.85423430e-06)
144084 EPS nconv=0 first unconverged value (error) -302.035 (1.84443946e-06)
144085 EPS nconv=0 first unconverged value (error) -302.035 (1.84443946e-06)
144086 EPS nconv=0 first unconverged value (error) -302.035 (1.85675235e-06)
144087 EPS nconv=0 first unconverged value (error) -302.035 (1.89584962e-06)
144088 EPS nconv=0 first unconverged value (error) -302.035 (1.84617346e-06)
144089 EPS nconv=0 first unconverged value (error) -302.035 (1.82057719e-06)
144090 EPS nconv=0 first unconverged value (error) -302.035 (1.81551581e-06)
144091 EPS nconv=0 first unconverged value (error) -302.035 (1.81551581e-06)
144092 EPS nconv=0 first unconverged value (error) -302.035 (1.80642011e-06)
144093 EPS nconv=0 first unconverged value (error) -302.035 (1.80772715e-06)
144094 EPS nconv=0 first unconverged value (error) -302.035 (1.80136768e-06)
144095 EPS nconv=0 first unconverged value (error) -302.035 (1.79922837e-06)
144096 EPS nconv=0 first unconverged value (error) -302.035 (1.79690446e-06)
144097 EPS nconv=0 first unconverged value (error) -302.035 (1.79690446e-06)
144098 EPS nconv=0 first unconverged value (error) -302.035 (1.80016227e-06)
144099 EPS nconv=0 first unconverged value (error) -302.035 (1.79877700e-06)
144100 EPS nconv=0 first unconverged value (error) -302.035 (1.79809570e-06)
144101 EPS nconv=0 first unconverged value (error) -302.035 (1.79735613e-06)
144102 EPS nconv=0 first unconverged value (error) -302.035 (1.79684314e-06)
144103 EPS nconv=0 first unconverged value (error) -302.035 (1.79684314e-06)
144104 EPS nconv=0 first unconverged value (error) -302.035 (1.92119596e-06)
144105 EPS nconv=0 first unconverged value (error) -302.035 (1.87955506e-06)
144106 EPS nconv=0 first unconverged value (error) -302.035 (1.86858826e-06)
144107 EPS nconv=0 first unconverged value (error) -302.035 (1.85860709e-06)
144108 EPS nconv=0 first unconverged value (error) -302.035 (1.84754624e-06)
144109 EPS nconv=0 first unconverged value (error) -302.035 (1.84754624e-06)
144110 EPS nconv=0 first unconverged value (error) -302.035 (1.86090065e-06)
144111 EPS nconv=0 first unconverged value (error) -302.035 (1.89423675e-06)
144112 EPS nconv=0 first unconverged value (error) -302.035 (1.85007824e-06)
144113 EPS nconv=0 first unconverged value (error) -302.035 (1.81871105e-06)
144114 EPS nconv=0 first unconverged value (error) -302.035 (1.81003667e-06)
144115 EPS nconv=0 first unconverged value (error) -302.035 (1.81003667e-06)
144116 EPS nconv=0 first unconverged value (error) -302.035 (1.80132460e-06)
144117 EPS nconv=0 first unconverged value (error) -302.035 (1.80014480e-06)
144118 EPS nconv=0 first unconverged value (error) -302.035 (1.79752597e-06)
144119 EPS nconv=0 first unconverged value (error) -302.035 (1.79661903e-06)
144120 EPS nconv=0 first unconverged value (error) -302.035 (1.79564266e-06)
144121 EPS nconv=0 first unconverged value (error) -302.035 (1.79564266e-06)
144122 EPS nconv=0 first unconverged value (error) -302.035 (1.88322168e-06)
144123 EPS nconv=0 first unconverged value (error) -302.035 (1.85406109e-06)
144124 EPS nconv=0 first unconverged value (error) -302.035 (1.83279738e-06)
144125 EPS nconv=0 first unconverged value (error) -302.035 (1.82734985e-06)
144126 EPS nconv=0 first unconverged value (error) -302.035 (1.82311057e-06)
144127 EPS nconv=0 first unconverged value (error) -302.035 (1.82311057e-06)
144128 EPS nconv=0 first unconverged value (error) -302.035 (1.87797907e-06)
144129 EPS nconv=0 first unconverged value (error) -302.035 (1.88367686e-06)
144130 EPS nconv=0 first unconverged value (error) -302.035 (1.85472368e-06)
144131 EPS nconv=0 first unconverged value (error) -302.035 (1.84263578e-06)
144132 EPS nconv=0 first unconverged value (error) -302.035 (1.83847294e-06)
144133 EPS nconv=0 first unconverged value (error) -302.035 (1.83847294e-06)
144134 EPS nconv=0 first unconverged value (error) -302.035 (1.85450912e-06)
144135 EPS nconv=0 first unconverged value (error) -302.035 (1.83323700e-06)
144136 EPS nconv=0 first unconverged value (error) -302.035 (1.81752550e-06)
144137 EPS nconv=0 first unconverged value (error) -302.035 (1.81350317e-06)
144138 EPS nconv=0 first unconverged value (error) -302.035 (1.80754053e-06)
144139 EPS nconv=0 first unconverged value (error) -302.035 (1.80754053e-06)
144140 EPS nconv=0 first unconverged value (error) -302.035 (1.85251455e-06)
144141 EPS nconv=0 first unconverged value (error) -302.035 (1.83744076e-06)
144142 EPS nconv=0 first unconverged value (error) -302.035 (1.82257364e-06)
144143 EPS nconv=0 first unconverged value (error) -302.035 (1.82002277e-06)
144144 EPS nconv=0 first unconverged value (error) -302.035 (1.81829648e-06)
144145 EPS nconv=0 first unconverged value (error) -302.035 (1.81829648e-06)
144146 EPS nconv=0 first unconverged value (error) -302.035 (2.45014507e-06)
144147 EPS nconv=0 first unconverged value (error) -302.035 (2.25490810e-06)
144148 EPS nconv=0 first unconverged value (error) -302.035 (2.15787069e-06)
144149 EPS nconv=0 first unconverged value (error) -302.035 (2.11725122e-06)
144150 EPS nconv=0 first unconverged value (error) -302.035 (2.07350310e-06)
144151 EPS nconv=0 first unconverged value (error) -302.035 (2.07350310e-06)
144152 EPS nconv=0 first unconverged value (error) -302.035 (2.19463550e-06)
144153 EPS nconv=0 first unconverged value (error) -302.035 (2.25501027e-06)
144154 EPS nconv=0 first unconverged value (error) -302.035 (2.04594237e-06)
144155 EPS nconv=0 first unconverged value (error) -302.035 (1.96359474e-06)
144156 EPS nconv=0 first unconverged value (error) -302.035 (1.94793699e-06)
144157 EPS nconv=0 first unconverged value (error) -302.035 (1.94793699e-06)
144158 EPS nconv=0 first unconverged value (error) -302.035 (1.91976307e-06)
144159 EPS nconv=0 first unconverged value (error) -302.035 (1.93878783e-06)
144160 EPS nconv=0 first unconverged value (error) -302.035 (1.88188133e-06)
144161 EPS nconv=0 first unconverged value (error) -302.035 (1.86572908e-06)
144162 EPS nconv=0 first unconverged value (error) -302.035 (1.82550476e-06)
144163 EPS nconv=0 first unconverged value (error) -302.035 (1.82550476e-06)
144164 EPS nconv=0 first unconverged value (error) -302.035 (2.24360015e-06)
144165 EPS nconv=0 first unconverged value (error) -302.035 (2.20085226e-06)
144166 EPS nconv=0 first unconverged value (error) -302.035 (2.08908422e-06)
144167 EPS nconv=0 first unconverged value (error) -302.035 (2.02081451e-06)
144168 EPS nconv=0 first unconverged value (error) -302.035 (1.98720232e-06)
144169 EPS nconv=0 first unconverged value (error) -302.035 (1.98720232e-06)
144170 EPS nconv=0 first unconverged value (error) -302.035 (2.83617201e-06)
144171 EPS nconv=0 first unconverged value (error) -302.035 (2.71660207e-06)
144172 EPS nconv=0 first unconverged value (error) -302.035 (2.48686960e-06)
144173 EPS nconv=0 first unconverged value (error) -302.035 (2.46356582e-06)
144174 EPS nconv=0 first unconverged value (error) -302.035 (2.43131295e-06)
144175 EPS nconv=0 first unconverged value (error) -302.035 (2.43131295e-06)
144176 EPS nconv=0 first unconverged value (error) -302.035 (2.47042922e-06)
144177 EPS nconv=0 first unconverged value (error) -302.035 (2.30727173e-06)
144178 EPS nconv=0 first unconverged value (error) -302.035 (2.17694983e-06)
144179 EPS nconv=0 first unconverged value (error) -302.035 (2.03873402e-06)
144180 EPS nconv=0 first unconverged value (error) -302.035 (1.89486962e-06)
144181 EPS nconv=0 first unconverged value (error) -302.035 (1.89486962e-06)
144182 EPS nconv=0 first unconverged value (error) -302.035 (2.06171715e-06)
144183 EPS nconv=0 first unconverged value (error) -302.035 (2.05760502e-06)
144184 EPS nconv=0 first unconverged value (error) -302.035 (1.99078986e-06)
144185 EPS nconv=0 first unconverged value (error) -302.035 (1.91419480e-06)
144186 EPS nconv=0 first unconverged value (error) -302.035 (1.90042911e-06)
144187 EPS nconv=0 first unconverged value (error) -302.035 (1.90042911e-06)
144188 EPS nconv=0 first unconverged value (error) -302.035 (1.93607070e-06)
144189 EPS nconv=0 first unconverged value (error) -302.035 (1.99690213e-06)
144190 EPS nconv=0 first unconverged value (error) -302.035 (1.96017016e-06)
144191 EPS nconv=0 first unconverged value (error) -302.035 (1.85965890e-06)
144192 EPS nconv=0 first unconverged value (error) -302.035 (1.83033742e-06)
144193 EPS nconv=0 first unconverged value (error) -302.035 (1.83033742e-06)
144194 EPS nconv=0 first unconverged value (error) -302.035 (1.84886319e-06)
144195 EPS nconv=0 first unconverged value (error) -302.035 (1.83510098e-06)
144196 EPS nconv=0 first unconverged value (error) -302.035 (1.81921883e-06)
144197 EPS nconv=0 first unconverged value (error) -302.035 (1.81463823e-06)
144198 EPS nconv=0 first unconverged value (error) -302.035 (1.81124622e-06)
144199 EPS nconv=0 first unconverged value (error) -302.035 (1.81124622e-06)
144200 EPS nconv=0 first unconverged value (error) -302.035 (1.84677218e-06)
144201 EPS nconv=0 first unconverged value (error) -302.035 (1.83295721e-06)
144202 EPS nconv=0 first unconverged value (error) -302.035 (1.81989827e-06)
144203 EPS nconv=0 first unconverged value (error) -302.035 (1.81400686e-06)
144204 EPS nconv=0 first unconverged value (error) -302.035 (1.81102462e-06)
144205 EPS nconv=0 first unconverged value (error) -302.035 (1.81102462e-06)
144206 EPS nconv=0 first unconverged value (error) -302.035 (1.83735901e-06)
144207 EPS nconv=0 first unconverged value (error) -302.035 (1.84322001e-06)
144208 EPS nconv=0 first unconverged value (error) -302.035 (1.81958473e-06)
144209 EPS nconv=0 first unconverged value (error) -302.035 (1.80866866e-06)
144210 EPS nconv=0 first unconverged value (error) -302.035 (1.80482146e-06)
144211 EPS nconv=0 first unconverged value (error) -302.035 (1.80482146e-06)
144212 EPS nconv=0 first unconverged value (error) -302.035 (1.81259528e-06)
144213 EPS nconv=0 first unconverged value (error) -302.035 (1.81822537e-06)
144214 EPS nconv=0 first unconverged value (error) -302.035 (1.81162518e-06)
144215 EPS nconv=0 first unconverged value (error) -302.035 (1.80320050e-06)
144216 EPS nconv=0 first unconverged value (error) -302.035 (1.80085457e-06)
144217 EPS nconv=0 first unconverged value (error) -302.035 (1.80085457e-06)
144218 EPS nconv=0 first unconverged value (error) -302.035 (1.79958140e-06)
144219 EPS nconv=0 first unconverged value (error) -302.035 (1.80149744e-06)
144220 EPS nconv=0 first unconverged value (error) -302.035 (1.79695210e-06)
144221 EPS nconv=0 first unconverged value (error) -302.035 (1.79574124e-06)
144222 EPS nconv=0 first unconverged value (error) -302.035 (1.79583155e-06)
144223 EPS nconv=0 first unconverged value (error) -302.035 (1.79583155e-06)
144224 EPS nconv=0 first unconverged value (error) -302.035 (1.80188906e-06)
144225 EPS nconv=0 first unconverged value (error) -302.035 (1.79848943e-06)
144226 EPS nconv=0 first unconverged value (error) -302.035 (1.79746483e-06)
144227 EPS nconv=0 first unconverged value (error) -302.035 (1.79722925e-06)
144228 EPS nconv=0 first unconverged value (error) -302.035 (1.79668230e-06)
144229 EPS nconv=0 first unconverged value (error) -302.035 (1.79668230e-06)
144230 EPS nconv=0 first unconverged value (error) -302.035 (1.86856534e-06)
144231 EPS nconv=0 first unconverged value (error) -302.035 (1.86076849e-06)
144232 EPS nconv=0 first unconverged value (error) -302.035 (1.83647484e-06)
144233 EPS nconv=0 first unconverged value (error) -302.035 (1.83075427e-06)
144234 EPS nconv=0 first unconverged value (error) -302.035 (1.82285948e-06)
144235 EPS nconv=0 first unconverged value (error) -302.035 (1.82285948e-06)
144236 EPS nconv=0 first unconverged value (error) -302.035 (1.91845386e-06)
144237 EPS nconv=0 first unconverged value (error) -302.035 (1.91955663e-06)
144238 EPS nconv=0 first unconverged value (error) -302.035 (1.89552579e-06)
144239 EPS nconv=0 first unconverged value (error) -302.035 (1.86476097e-06)
144240 EPS nconv=0 first unconverged value (error) -302.035 (1.85113684e-06)
144241 EPS nconv=0 first unconverged value (error) -302.035 (1.85113684e-06)
144242 EPS nconv=0 first unconverged value (error) -302.035 (1.86008473e-06)
144243 EPS nconv=0 first unconverged value (error) -302.035 (1.84894235e-06)
144244 EPS nconv=0 first unconverged value (error) -302.035 (1.82531021e-06)
144245 EPS nconv=0 first unconverged value (error) -302.035 (1.81615530e-06)
144246 EPS nconv=0 first unconverged value (error) -302.035 (1.81617625e-06)
144247 EPS nconv=0 first unconverged value (error) -302.035 (1.81617625e-06)
144248 EPS nconv=0 first unconverged value (error) -302.035 (1.89643193e-06)
144249 EPS nconv=0 first unconverged value (error) -302.035 (1.85549354e-06)
144250 EPS nconv=0 first unconverged value (error) -302.035 (1.83762606e-06)
144251 EPS nconv=0 first unconverged value (error) -302.035 (1.83229571e-06)
144252 EPS nconv=0 first unconverged value (error) -302.035 (1.82580214e-06)
144253 EPS nconv=0 first unconverged value (error) -302.035 (1.82580214e-06)
144254 EPS nconv=0 first unconverged value (error) -302.035 (1.89253258e-06)
144255 EPS nconv=0 first unconverged value (error) -302.035 (1.91219170e-06)
144256 EPS nconv=0 first unconverged value (error) -302.035 (1.84443851e-06)
144257 EPS nconv=0 first unconverged value (error) -302.035 (1.82937178e-06)
144258 EPS nconv=0 first unconverged value (error) -302.035 (1.81986081e-06)
144259 EPS nconv=0 first unconverged value (error) -302.035 (1.81986081e-06)
144260 EPS nconv=0 first unconverged value (error) -302.035 (1.82097011e-06)
144261 EPS nconv=0 first unconverged value (error) -302.035 (1.83931932e-06)
144262 EPS nconv=0 first unconverged value (error) -302.035 (1.81949794e-06)
144263 EPS nconv=0 first unconverged value (error) -302.035 (1.80625270e-06)
144264 EPS nconv=0 first unconverged value (error) -302.035 (1.80238659e-06)
144265 EPS nconv=0 first unconverged value (error) -302.035 (1.80238659e-06)
144266 EPS nconv=0 first unconverged value (error) -302.035 (1.80522014e-06)
144267 EPS nconv=0 first unconverged value (error) -302.035 (1.80298424e-06)
144268 EPS nconv=0 first unconverged value (error) -302.035 (1.80110578e-06)
144269 EPS nconv=0 first unconverged value (error) -302.035 (1.79956103e-06)
144270 EPS nconv=0 first unconverged value (error) -302.035 (1.79833181e-06)
144271 EPS nconv=0 first unconverged value (error) -302.035 (1.79833181e-06)
144272 EPS nconv=0 first unconverged value (error) -302.035 (1.86919129e-06)
144273 EPS nconv=0 first unconverged value (error) -302.035 (1.83445595e-06)
144274 EPS nconv=0 first unconverged value (error) -302.035 (1.82902092e-06)
144275 EPS nconv=0 first unconverged value (error) -302.035 (1.82396911e-06)
144276 EPS nconv=0 first unconverged value (error) -302.035 (1.82054063e-06)
144277 EPS nconv=0 first unconverged value (error) -302.035 (1.82054063e-06)
144278 EPS nconv=0 first unconverged value (error) -302.035 (2.10337486e-06)
144279 EPS nconv=0 first unconverged value (error) -302.035 (2.06010964e-06)
144280 EPS nconv=0 first unconverged value (error) -302.035 (1.96547507e-06)
144281 EPS nconv=0 first unconverged value (error) -302.035 (1.92404383e-06)
144282 EPS nconv=0 first unconverged value (error) -302.035 (1.89766232e-06)
144283 EPS nconv=0 first unconverged value (error) -302.035 (1.89766232e-06)
144284 EPS nconv=0 first unconverged value (error) -302.035 (2.04107212e-06)
144285 EPS nconv=0 first unconverged value (error) -302.035 (2.06163424e-06)
144286 EPS nconv=0 first unconverged value (error) -302.035 (1.97396848e-06)
144287 EPS nconv=0 first unconverged value (error) -302.035 (1.93897460e-06)
144288 EPS nconv=0 first unconverged value (error) -302.035 (1.91685021e-06)
144289 EPS nconv=0 first unconverged value (error) -302.035 (1.91685021e-06)
144290 EPS nconv=0 first unconverged value (error) -302.035 (1.89866170e-06)
144291 EPS nconv=0 first unconverged value (error) -302.035 (1.87453026e-06)
144292 EPS nconv=0 first unconverged value (error) -302.035 (1.83525062e-06)
144293 EPS nconv=0 first unconverged value (error) -302.035 (1.81711916e-06)
144294 EPS nconv=0 first unconverged value (error) -302.035 (1.80655419e-06)
144295 EPS nconv=0 first unconverged value (error) -302.035 (1.80655419e-06)
144296 EPS nconv=0 first unconverged value (error) -302.035 (1.84544390e-06)
144297 EPS nconv=0 first unconverged value (error) -302.035 (1.81384578e-06)
144298 EPS nconv=0 first unconverged value (error) -302.035 (1.80791195e-06)
144299 EPS nconv=0 first unconverged value (error) -302.035 (1.80572163e-06)
144300 EPS nconv=0 first unconverged value (error) -302.035 (1.80390919e-06)
144301 EPS nconv=0 first unconverged value (error) -302.035 (1.80390919e-06)
144302 EPS nconv=0 first unconverged value (error) -302.035 (1.97677653e-06)
144303 EPS nconv=0 first unconverged value (error) -302.035 (1.93433119e-06)
144304 EPS nconv=0 first unconverged value (error) -302.035 (1.89781722e-06)
144305 EPS nconv=0 first unconverged value (error) -302.035 (1.89104384e-06)
144306 EPS nconv=0 first unconverged value (error) -302.035 (1.87835604e-06)
144307 EPS nconv=0 first unconverged value (error) -302.035 (1.87835604e-06)
144308 EPS nconv=0 first unconverged value (error) -302.035 (2.22302447e-06)
144309 EPS nconv=0 first unconverged value (error) -302.035 (2.14618417e-06)
144310 EPS nconv=0 first unconverged value (error) -302.035 (2.04114866e-06)
144311 EPS nconv=0 first unconverged value (error) -302.035 (2.03640001e-06)
144312 EPS nconv=0 first unconverged value (error) -302.035 (2.01114727e-06)
144313 EPS nconv=0 first unconverged value (error) -302.035 (2.01114727e-06)
144314 EPS nconv=0 first unconverged value (error) -302.035 (2.00178425e-06)
144315 EPS nconv=0 first unconverged value (error) -302.035 (2.02643957e-06)
144316 EPS nconv=0 first unconverged value (error) -302.035 (1.96152619e-06)
144317 EPS nconv=0 first unconverged value (error) -302.035 (1.85835950e-06)
144318 EPS nconv=0 first unconverged value (error) -302.035 (1.84307348e-06)
144319 EPS nconv=0 first unconverged value (error) -302.035 (1.84307348e-06)
144320 EPS nconv=0 first unconverged value (error) -302.035 (1.82141106e-06)
144321 EPS nconv=0 first unconverged value (error) -302.035 (1.81180878e-06)
144322 EPS nconv=0 first unconverged value (error) -302.035 (1.80798293e-06)
144323 EPS nconv=0 first unconverged value (error) -302.035 (1.80497558e-06)
144324 EPS nconv=0 first unconverged value (error) -302.035 (1.79883673e-06)
144325 EPS nconv=0 first unconverged value (error) -302.035 (1.79883673e-06)
144326 EPS nconv=0 first unconverged value (error) -302.035 (1.80176618e-06)
144327 EPS nconv=0 first unconverged value (error) -302.035 (1.80537530e-06)
144328 EPS nconv=0 first unconverged value (error) -302.035 (1.80079940e-06)
144329 EPS nconv=0 first unconverged value (error) -302.035 (1.79705163e-06)
144330 EPS nconv=0 first unconverged value (error) -302.035 (1.79681420e-06)
144331 EPS nconv=0 first unconverged value (error) -302.035 (1.79681420e-06)
144332 EPS nconv=0 first unconverged value (error) -302.035 (1.97802809e-06)
144333 EPS nconv=0 first unconverged value (error) -302.035 (1.94386349e-06)
144334 EPS nconv=0 first unconverged value (error) -302.035 (1.90948051e-06)
144335 EPS nconv=0 first unconverged value (error) -302.035 (1.89404838e-06)
144336 EPS nconv=0 first unconverged value (error) -302.035 (1.88262342e-06)
144337 EPS nconv=0 first unconverged value (error) -302.035 (1.88262342e-06)
144338 EPS nconv=0 first unconverged value (error) -302.035 (2.08162368e-06)
144339 EPS nconv=0 first unconverged value (error) -302.035 (2.00510047e-06)
144340 EPS nconv=0 first unconverged value (error) -302.035 (1.94487415e-06)
144341 EPS nconv=0 first unconverged value (error) -302.035 (1.93651878e-06)
144342 EPS nconv=0 first unconverged value (error) -302.035 (1.93401097e-06)
144343 EPS nconv=0 first unconverged value (error) -302.035 (1.93401097e-06)
144344 EPS nconv=0 first unconverged value (error) -302.035 (2.11461260e-06)
144345 EPS nconv=0 first unconverged value (error) -302.035 (2.03058894e-06)
144346 EPS nconv=0 first unconverged value (error) -302.035 (1.94017882e-06)
144347 EPS nconv=0 first unconverged value (error) -302.035 (1.94139721e-06)
144348 EPS nconv=0 first unconverged value (error) -302.035 (1.87934199e-06)
144349 EPS nconv=0 first unconverged value (error) -302.035 (1.87934199e-06)
144350 EPS nconv=0 first unconverged value (error) -302.035 (2.00048578e-06)
144351 EPS nconv=0 first unconverged value (error) -302.035 (2.05559275e-06)
144352 EPS nconv=0 first unconverged value (error) -302.035 (1.93992436e-06)
144353 EPS nconv=0 first unconverged value (error) -302.035 (1.88226055e-06)
144354 EPS nconv=0 first unconverged value (error) -302.035 (1.87147548e-06)
144355 EPS nconv=0 first unconverged value (error) -302.035 (1.87147548e-06)
144356 EPS nconv=0 first unconverged value (error) -302.035 (1.90717041e-06)
144357 EPS nconv=0 first unconverged value (error) -302.035 (1.89350063e-06)
144358 EPS nconv=0 first unconverged value (error) -302.035 (1.86342031e-06)
144359 EPS nconv=0 first unconverged value (error) -302.035 (1.85576619e-06)
144360 EPS nconv=0 first unconverged value (error) -302.035 (1.82290570e-06)
144361 EPS nconv=0 first unconverged value (error) -302.035 (1.82290570e-06)
144362 EPS nconv=0 first unconverged value (error) -302.035 (1.84695599e-06)
144363 EPS nconv=0 first unconverged value (error) -302.035 (1.87134201e-06)
144364 EPS nconv=0 first unconverged value (error) -302.035 (1.83506688e-06)
144365 EPS nconv=0 first unconverged value (error) -302.035 (1.82684392e-06)
144366 EPS nconv=0 first unconverged value (error) -302.035 (1.81767458e-06)
144367 EPS nconv=0 first unconverged value (error) -302.035 (1.81767458e-06)
144368 EPS nconv=0 first unconverged value (error) -302.035 (1.97162910e-06)
144369 EPS nconv=0 first unconverged value (error) -302.035 (1.94012976e-06)
144370 EPS nconv=0 first unconverged value (error) -302.035 (1.89720089e-06)
144371 EPS nconv=0 first unconverged value (error) -302.035 (1.89429079e-06)
144372 EPS nconv=0 first unconverged value (error) -302.035 (1.87410793e-06)
144373 EPS nconv=0 first unconverged value (error) -302.035 (1.87410793e-06)
144374 EPS nconv=0 first unconverged value (error) -302.035 (1.89036614e-06)
144375 EPS nconv=0 first unconverged value (error) -302.035 (1.90094478e-06)
144376 EPS nconv=0 first unconverged value (error) -302.035 (1.86284886e-06)
144377 EPS nconv=0 first unconverged value (error) -302.035 (1.83107379e-06)
144378 EPS nconv=0 first unconverged value (error) -302.035 (1.82771785e-06)
144379 EPS nconv=0 first unconverged value (error) -302.035 (1.82771785e-06)
144380 EPS nconv=0 first unconverged value (error) -302.035 (1.82007479e-06)
144381 EPS nconv=0 first unconverged value (error) -302.035 (1.81306832e-06)
144382 EPS nconv=0 first unconverged value (error) -302.035 (1.81216548e-06)
144383 EPS nconv=0 first unconverged value (error) -302.035 (1.80186716e-06)
144384 EPS nconv=0 first unconverged value (error) -302.035 (1.79832577e-06)
144385 EPS nconv=0 first unconverged value (error) -302.035 (1.79832577e-06)
144386 EPS nconv=0 first unconverged value (error) -302.035 (1.83095913e-06)
144387 EPS nconv=0 first unconverged value (error) -302.035 (1.82077057e-06)
144388 EPS nconv=0 first unconverged value (error) -302.035 (1.81485952e-06)
144389 EPS nconv=0 first unconverged value (error) -302.035 (1.81055438e-06)
144390 EPS nconv=0 first unconverged value (error) -302.035 (1.80926230e-06)
144391 EPS nconv=0 first unconverged value (error) -302.035 (1.80926230e-06)
144392 EPS nconv=0 first unconverged value (error) -302.035 (1.84644624e-06)
144393 EPS nconv=0 first unconverged value (error) -302.035 (1.84371567e-06)
144394 EPS nconv=0 first unconverged value (error) -302.035 (1.82689793e-06)
144395 EPS nconv=0 first unconverged value (error) -302.035 (1.81250200e-06)
144396 EPS nconv=0 first unconverged value (error) -302.035 (1.80863992e-06)
144397 EPS nconv=0 first unconverged value (error) -302.035 (1.80863992e-06)
144398 EPS nconv=0 first unconverged value (error) -302.035 (1.82093564e-06)
144399 EPS nconv=0 first unconverged value (error) -302.035 (1.82864744e-06)
144400 EPS nconv=0 first unconverged value (error) -302.035 (1.80999655e-06)
144401 EPS nconv=0 first unconverged value (error) -302.035 (1.80828799e-06)
144402 EPS nconv=0 first unconverged value (error) -302.035 (1.80468892e-06)
144403 EPS nconv=0 first unconverged value (error) -302.035 (1.80468892e-06)
144404 EPS nconv=0 first unconverged value (error) -302.035 (1.81608137e-06)
144405 EPS nconv=0 first unconverged value (error) -302.035 (1.81171153e-06)
144406 EPS nconv=0 first unconverged value (error) -302.035 (1.80733995e-06)
144407 EPS nconv=0 first unconverged value (error) -302.035 (1.80511466e-06)
144408 EPS nconv=0 first unconverged value (error) -302.035 (1.80308852e-06)
144409 EPS nconv=0 first unconverged value (error) -302.035 (1.80308852e-06)
144410 EPS nconv=0 first unconverged value (error) -302.035 (1.86348258e-06)
144411 EPS nconv=0 first unconverged value (error) -302.035 (1.85384642e-06)
144412 EPS nconv=0 first unconverged value (error) -302.035 (1.84128519e-06)
144413 EPS nconv=0 first unconverged value (error) -302.035 (1.82023767e-06)
144414 EPS nconv=0 first unconverged value (error) -302.035 (1.81691423e-06)
144415 EPS nconv=0 first unconverged value (error) -302.035 (1.81691423e-06)
144416 EPS nconv=0 first unconverged value (error) -302.035 (1.81778175e-06)
144417 EPS nconv=0 first unconverged value (error) -302.035 (1.83155916e-06)
144418 EPS nconv=0 first unconverged value (error) -302.035 (1.81667179e-06)
144419 EPS nconv=0 first unconverged value (error) -302.035 (1.80715922e-06)
144420 EPS nconv=0 first unconverged value (error) -302.035 (1.80036336e-06)
144421 EPS nconv=0 first unconverged value (error) -302.035 (1.80036336e-06)
144422 EPS nconv=0 first unconverged value (error) -302.035 (1.81365516e-06)
144423 EPS nconv=0 first unconverged value (error) -302.035 (1.80595416e-06)
144424 EPS nconv=0 first unconverged value (error) -302.035 (1.80400026e-06)
144425 EPS nconv=0 first unconverged value (error) -302.035 (1.80383356e-06)
144426 EPS nconv=0 first unconverged value (error) -302.035 (1.80166753e-06)
144427 EPS nconv=0 first unconverged value (error) -302.035 (1.80166753e-06)
144428 EPS nconv=0 first unconverged value (error) -302.035 (1.94805839e-06)
144429 EPS nconv=0 first unconverged value (error) -302.035 (1.92597005e-06)
144430 EPS nconv=0 first unconverged value (error) -302.035 (1.90131920e-06)
144431 EPS nconv=0 first unconverged value (error) -302.035 (1.88289847e-06)
144432 EPS nconv=0 first unconverged value (error) -302.035 (1.87641754e-06)
144433 EPS nconv=0 first unconverged value (error) -302.035 (1.87641754e-06)
144434 EPS nconv=0 first unconverged value (error) -302.035 (1.98560045e-06)
144435 EPS nconv=0 first unconverged value (error) -302.035 (1.93203619e-06)
144436 EPS nconv=0 first unconverged value (error) -302.035 (1.88787105e-06)
144437 EPS nconv=0 first unconverged value (error) -302.035 (1.89458586e-06)
144438 EPS nconv=0 first unconverged value (error) -302.035 (1.86275232e-06)
144439 EPS nconv=0 first unconverged value (error) -302.035 (1.86275232e-06)
144440 EPS nconv=0 first unconverged value (error) -302.035 (2.08548029e-06)
144441 EPS nconv=0 first unconverged value (error) -302.035 (2.10440632e-06)
144442 EPS nconv=0 first unconverged value (error) -302.035 (1.99496806e-06)
144443 EPS nconv=0 first unconverged value (error) -302.035 (1.95483527e-06)
144444 EPS nconv=0 first unconverged value (error) -302.035 (1.93653427e-06)
144445 EPS nconv=0 first unconverged value (error) -302.035 (1.93653427e-06)
144446 EPS nconv=0 first unconverged value (error) -302.035 (1.93069926e-06)
144447 EPS nconv=0 first unconverged value (error) -302.035 (1.92585250e-06)
144448 EPS nconv=0 first unconverged value (error) -302.035 (1.94529642e-06)
144449 EPS nconv=0 first unconverged value (error) -302.035 (1.85175878e-06)
144450 EPS nconv=0 first unconverged value (error) -302.035 (1.81217084e-06)
144451 EPS nconv=0 first unconverged value (error) -302.035 (1.81217084e-06)
144452 EPS nconv=0 first unconverged value (error) -302.035 (1.83065697e-06)
144453 EPS nconv=0 first unconverged value (error) -302.035 (1.83298181e-06)
144454 EPS nconv=0 first unconverged value (error) -302.035 (1.82475697e-06)
144455 EPS nconv=0 first unconverged value (error) -302.035 (1.81490025e-06)
144456 EPS nconv=0 first unconverged value (error) -302.035 (1.81294418e-06)
144457 EPS nconv=0 first unconverged value (error) -302.035 (1.81294418e-06)
144458 EPS nconv=0 first unconverged value (error) -302.035 (1.81335660e-06)
144459 EPS nconv=0 first unconverged value (error) -302.035 (1.81460647e-06)
144460 EPS nconv=0 first unconverged value (error) -302.035 (1.80755690e-06)
144461 EPS nconv=0 first unconverged value (error) -302.035 (1.80331127e-06)
144462 EPS nconv=0 first unconverged value (error) -302.035 (1.79804334e-06)
144463 EPS nconv=0 first unconverged value (error) -302.035 (1.79804334e-06)
144464 EPS nconv=0 first unconverged value (error) -302.035 (1.84426337e-06)
144465 EPS nconv=0 first unconverged value (error) -302.035 (1.82323580e-06)
144466 EPS nconv=0 first unconverged value (error) -302.035 (1.81837827e-06)
144467 EPS nconv=0 first unconverged value (error) -302.035 (1.81567028e-06)
144468 EPS nconv=0 first unconverged value (error) -302.035 (1.81341597e-06)
144469 EPS nconv=0 first unconverged value (error) -302.035 (1.81341597e-06)
144470 EPS nconv=0 first unconverged value (error) -302.035 (1.82662034e-06)
144471 EPS nconv=0 first unconverged value (error) -302.035 (1.83494534e-06)
144472 EPS nconv=0 first unconverged value (error) -302.035 (1.81013222e-06)
144473 EPS nconv=0 first unconverged value (error) -302.035 (1.80864215e-06)
144474 EPS nconv=0 first unconverged value (error) -302.035 (1.80334907e-06)
144475 EPS nconv=0 first unconverged value (error) -302.035 (1.80334907e-06)
144476 EPS nconv=0 first unconverged value (error) -302.035 (1.80167230e-06)
144477 EPS nconv=0 first unconverged value (error) -302.035 (1.80578058e-06)
144478 EPS nconv=0 first unconverged value (error) -302.035 (1.80190595e-06)
144479 EPS nconv=0 first unconverged value (error) -302.035 (1.79686186e-06)
144480 EPS nconv=0 first unconverged value (error) -302.035 (1.79537365e-06)
144481 EPS nconv=0 first unconverged value (error) -302.035 (1.79537365e-06)
144482 EPS nconv=0 first unconverged value (error) -302.035 (1.93611260e-06)
144483 EPS nconv=0 first unconverged value (error) -302.035 (1.87485380e-06)
144484 EPS nconv=0 first unconverged value (error) -302.035 (1.86870110e-06)
144485 EPS nconv=0 first unconverged value (error) -302.035 (1.85658251e-06)
144486 EPS nconv=0 first unconverged value (error) -302.035 (1.84730667e-06)
144487 EPS nconv=0 first unconverged value (error) -302.035 (1.84730667e-06)
144488 EPS nconv=0 first unconverged value (error) -302.035 (1.86743077e-06)
144489 EPS nconv=0 first unconverged value (error) -302.035 (1.89684969e-06)
144490 EPS nconv=0 first unconverged value (error) -302.035 (1.83354344e-06)
144491 EPS nconv=0 first unconverged value (error) -302.035 (1.81572500e-06)
144492 EPS nconv=0 first unconverged value (error) -302.035 (1.81379061e-06)
144493 EPS nconv=0 first unconverged value (error) -302.035 (1.81379061e-06)
144494 EPS nconv=0 first unconverged value (error) -302.035 (1.86119012e-06)
144495 EPS nconv=0 first unconverged value (error) -302.035 (1.83884309e-06)
144496 EPS nconv=0 first unconverged value (error) -302.035 (1.81891462e-06)
144497 EPS nconv=0 first unconverged value (error) -302.035 (1.81348607e-06)
144498 EPS nconv=0 first unconverged value (error) -302.035 (1.81269538e-06)
144499 EPS nconv=0 first unconverged value (error) -302.035 (1.81269538e-06)
144500 EPS nconv=0 first unconverged value (error) -302.035 (1.83320500e-06)
144501 EPS nconv=0 first unconverged value (error) -302.035 (1.84624462e-06)
144502 EPS nconv=0 first unconverged value (error) -302.035 (1.82161897e-06)
144503 EPS nconv=0 first unconverged value (error) -302.035 (1.80503560e-06)
144504 EPS nconv=0 first unconverged value (error) -302.035 (1.80244393e-06)
144505 EPS nconv=0 first unconverged value (error) -302.035 (1.80244393e-06)
144506 EPS nconv=0 first unconverged value (error) -302.035 (1.80174539e-06)
144507 EPS nconv=0 first unconverged value (error) -302.035 (1.81341810e-06)
144508 EPS nconv=0 first unconverged value (error) -302.035 (1.80195342e-06)
144509 EPS nconv=0 first unconverged value (error) -302.035 (1.79606708e-06)
144510 EPS nconv=0 first unconverged value (error) -302.035 (1.79535571e-06)
144511 EPS nconv=0 first unconverged value (error) -302.035 (1.79535571e-06)
144512 EPS nconv=0 first unconverged value (error) -302.035 (1.79839568e-06)
144513 EPS nconv=0 first unconverged value (error) -302.035 (1.79694641e-06)
144514 EPS nconv=0 first unconverged value (error) -302.035 (1.79656362e-06)
144515 EPS nconv=0 first unconverged value (error) -302.035 (1.79644807e-06)
144516 EPS nconv=0 first unconverged value (error) -302.035 (1.79610044e-06)
144517 EPS nconv=0 first unconverged value (error) -302.035 (1.79610044e-06)
144518 EPS nconv=0 first unconverged value (error) -302.035 (1.79622393e-06)
144519 EPS nconv=0 first unconverged value (error) -302.035 (1.79727146e-06)
144520 EPS nconv=0 first unconverged value (error) -302.035 (1.79537791e-06)
144521 EPS nconv=0 first unconverged value (error) -302.035 (1.79471221e-06)
144522 EPS nconv=0 first unconverged value (error) -302.035 (1.79453175e-06)
144523 EPS nconv=0 first unconverged value (error) -302.035 (1.79453175e-06)
144524 EPS nconv=0 first unconverged value (error) -302.035 (1.84232519e-06)
144525 EPS nconv=0 first unconverged value (error) -302.035 (1.82180274e-06)
144526 EPS nconv=0 first unconverged value (error) -302.035 (1.81595135e-06)
144527 EPS nconv=0 first unconverged value (error) -302.035 (1.81401496e-06)
144528 EPS nconv=0 first unconverged value (error) -302.035 (1.81060015e-06)
144529 EPS nconv=0 first unconverged value (error) -302.035 (1.81060015e-06)
144530 EPS nconv=0 first unconverged value (error) -302.035 (1.82770704e-06)
144531 EPS nconv=0 first unconverged value (error) -302.035 (1.85483952e-06)
144532 EPS nconv=0 first unconverged value (error) -302.035 (1.83133204e-06)
144533 EPS nconv=0 first unconverged value (error) -302.035 (1.80609398e-06)
144534 EPS nconv=0 first unconverged value (error) -302.035 (1.80465912e-06)
144535 EPS nconv=0 first unconverged value (error) -302.035 (1.80465912e-06)
144536 EPS nconv=0 first unconverged value (error) -302.035 (1.82083561e-06)
144537 EPS nconv=0 first unconverged value (error) -302.035 (1.80856877e-06)
144538 EPS nconv=0 first unconverged value (error) -302.035 (1.80580356e-06)
144539 EPS nconv=0 first unconverged value (error) -302.035 (1.80483367e-06)
144540 EPS nconv=0 first unconverged value (error) -302.035 (1.80237337e-06)
144541 EPS nconv=0 first unconverged value (error) -302.035 (1.80237337e-06)
144542 EPS nconv=0 first unconverged value (error) -302.035 (1.95978348e-06)
144543 EPS nconv=0 first unconverged value (error) -302.035 (1.88909080e-06)
144544 EPS nconv=0 first unconverged value (error) -302.035 (1.87003682e-06)
144545 EPS nconv=0 first unconverged value (error) -302.035 (1.84955353e-06)
144546 EPS nconv=0 first unconverged value (error) -302.035 (1.84426064e-06)
144547 EPS nconv=0 first unconverged value (error) -302.035 (1.84426064e-06)
144548 EPS nconv=0 first unconverged value (error) -302.035 (1.99006719e-06)
144549 EPS nconv=0 first unconverged value (error) -302.035 (1.96876065e-06)
144550 EPS nconv=0 first unconverged value (error) -302.035 (1.88805932e-06)
144551 EPS nconv=0 first unconverged value (error) -302.035 (1.88654662e-06)
144552 EPS nconv=0 first unconverged value (error) -302.035 (1.87290018e-06)
144553 EPS nconv=0 first unconverged value (error) -302.035 (1.87290018e-06)
144554 EPS nconv=0 first unconverged value (error) -302.035 (1.87076179e-06)
144555 EPS nconv=0 first unconverged value (error) -302.035 (1.90260306e-06)
144556 EPS nconv=0 first unconverged value (error) -302.035 (1.85103218e-06)
144557 EPS nconv=0 first unconverged value (error) -302.035 (1.81568976e-06)
144558 EPS nconv=0 first unconverged value (error) -302.035 (1.81309756e-06)
144559 EPS nconv=0 first unconverged value (error) -302.035 (1.81309756e-06)
144560 EPS nconv=0 first unconverged value (error) -302.035 (1.82051979e-06)
144561 EPS nconv=0 first unconverged value (error) -302.035 (1.81167239e-06)
144562 EPS nconv=0 first unconverged value (error) -302.035 (1.80751845e-06)
144563 EPS nconv=0 first unconverged value (error) -302.035 (1.80238646e-06)
144564 EPS nconv=0 first unconverged value (error) -302.035 (1.80110128e-06)
144565 EPS nconv=0 first unconverged value (error) -302.035 (1.80110128e-06)
144566 EPS nconv=0 first unconverged value (error) -302.035 (1.80875052e-06)
144567 EPS nconv=0 first unconverged value (error) -302.035 (1.81702946e-06)
144568 EPS nconv=0 first unconverged value (error) -302.035 (1.80319743e-06)
144569 EPS nconv=0 first unconverged value (error) -302.035 (1.80030087e-06)
144570 EPS nconv=0 first unconverged value (error) -302.035 (1.79871496e-06)
144571 EPS nconv=0 first unconverged value (error) -302.035 (1.79871496e-06)
144572 EPS nconv=0 first unconverged value (error) -302.035 (1.85560366e-06)
144573 EPS nconv=0 first unconverged value (error) -302.035 (1.84552842e-06)
144574 EPS nconv=0 first unconverged value (error) -302.035 (1.83310599e-06)
144575 EPS nconv=0 first unconverged value (error) -302.035 (1.82600996e-06)
144576 EPS nconv=0 first unconverged value (error) -302.035 (1.82040490e-06)
144577 EPS nconv=0 first unconverged value (error) -302.035 (1.82040490e-06)
144578 EPS nconv=0 first unconverged value (error) -302.035 (1.82240974e-06)
144579 EPS nconv=0 first unconverged value (error) -302.035 (1.83270146e-06)
144580 EPS nconv=0 first unconverged value (error) -302.035 (1.82560143e-06)
144581 EPS nconv=0 first unconverged value (error) -302.035 (1.79910443e-06)
144582 EPS nconv=0 first unconverged value (error) -302.035 (1.79654607e-06)
144583 EPS nconv=0 first unconverged value (error) -302.035 (1.79654607e-06)
144584 EPS nconv=0 first unconverged value (error) -302.035 (1.79602213e-06)
144585 EPS nconv=0 first unconverged value (error) -302.035 (1.79560044e-06)
144586 EPS nconv=0 first unconverged value (error) -302.035 (1.79535443e-06)
144587 EPS nconv=0 first unconverged value (error) -302.035 (1.79520642e-06)
144588 EPS nconv=0 first unconverged value (error) -302.035 (1.79508415e-06)
144589 EPS nconv=0 first unconverged value (error) -302.035 (1.79508415e-06)
144590 EPS nconv=0 first unconverged value (error) -302.035 (1.83196012e-06)
144591 EPS nconv=0 first unconverged value (error) -302.035 (1.81955638e-06)
144592 EPS nconv=0 first unconverged value (error) -302.035 (1.81443562e-06)
144593 EPS nconv=0 first unconverged value (error) -302.035 (1.81121662e-06)
144594 EPS nconv=0 first unconverged value (error) -302.035 (1.80934612e-06)
144595 EPS nconv=0 first unconverged value (error) -302.035 (1.80934612e-06)
144596 EPS nconv=0 first unconverged value (error) -302.035 (1.81148607e-06)
144597 EPS nconv=0 first unconverged value (error) -302.035 (1.81785200e-06)
144598 EPS nconv=0 first unconverged value (error) -302.035 (1.80702927e-06)
144599 EPS nconv=0 first unconverged value (error) -302.035 (1.80219722e-06)
144600 EPS nconv=0 first unconverged value (error) -302.035 (1.79890342e-06)
144601 EPS nconv=0 first unconverged value (error) -302.035 (1.79890342e-06)
144602 EPS nconv=0 first unconverged value (error) -302.035 (1.89919851e-06)
144603 EPS nconv=0 first unconverged value (error) -302.035 (1.87689774e-06)
144604 EPS nconv=0 first unconverged value (error) -302.035 (1.85866326e-06)
144605 EPS nconv=0 first unconverged value (error) -302.035 (1.84838939e-06)
144606 EPS nconv=0 first unconverged value (error) -302.035 (1.83962314e-06)
144607 EPS nconv=0 first unconverged value (error) -302.035 (1.83962314e-06)
144608 EPS nconv=0 first unconverged value (error) -302.035 (1.93008777e-06)
144609 EPS nconv=0 first unconverged value (error) -302.035 (1.91346115e-06)
144610 EPS nconv=0 first unconverged value (error) -302.035 (1.87129816e-06)
144611 EPS nconv=0 first unconverged value (error) -302.035 (1.86199116e-06)
144612 EPS nconv=0 first unconverged value (error) -302.035 (1.85733103e-06)
144613 EPS nconv=0 first unconverged value (error) -302.035 (1.85733103e-06)
144614 EPS nconv=0 first unconverged value (error) -302.035 (1.85534361e-06)
144615 EPS nconv=0 first unconverged value (error) -302.035 (1.85446537e-06)
144616 EPS nconv=0 first unconverged value (error) -302.035 (1.83785446e-06)
144617 EPS nconv=0 first unconverged value (error) -302.035 (1.81592070e-06)
144618 EPS nconv=0 first unconverged value (error) -302.035 (1.80502661e-06)
144619 EPS nconv=0 first unconverged value (error) -302.035 (1.80502661e-06)
144620 EPS nconv=0 first unconverged value (error) -302.035 (2.08267070e-06)
144621 EPS nconv=0 first unconverged value (error) -302.035 (2.03610357e-06)
144622 EPS nconv=0 first unconverged value (error) -302.035 (1.97038961e-06)
144623 EPS nconv=0 first unconverged value (error) -302.035 (1.92697992e-06)
144624 EPS nconv=0 first unconverged value (error) -302.035 (1.91250130e-06)
144625 EPS nconv=0 first unconverged value (error) -302.035 (1.91250130e-06)
144626 EPS nconv=0 first unconverged value (error) -302.035 (1.91703286e-06)
144627 EPS nconv=0 first unconverged value (error) -302.035 (2.00516760e-06)
144628 EPS nconv=0 first unconverged value (error) -302.035 (1.95942054e-06)
144629 EPS nconv=0 first unconverged value (error) -302.035 (1.85456878e-06)
144630 EPS nconv=0 first unconverged value (error) -302.035 (1.81005197e-06)
144631 EPS nconv=0 first unconverged value (error) -302.035 (1.81005197e-06)
144632 EPS nconv=0 first unconverged value (error) -302.035 (1.85119203e-06)
144633 EPS nconv=0 first unconverged value (error) -302.035 (1.84525399e-06)
144634 EPS nconv=0 first unconverged value (error) -302.035 (1.83970108e-06)
144635 EPS nconv=0 first unconverged value (error) -302.035 (1.83879183e-06)
144636 EPS nconv=0 first unconverged value (error) -302.035 (1.83148046e-06)
144637 EPS nconv=0 first unconverged value (error) -302.035 (1.83148046e-06)
144638 EPS nconv=0 first unconverged value (error) -302.035 (1.86261092e-06)
144639 EPS nconv=0 first unconverged value (error) -302.035 (1.83720659e-06)
144640 EPS nconv=0 first unconverged value (error) -302.035 (1.82147756e-06)
144641 EPS nconv=0 first unconverged value (error) -302.035 (1.81826254e-06)
144642 EPS nconv=0 first unconverged value (error) -302.035 (1.81723112e-06)
144643 EPS nconv=0 first unconverged value (error) -302.035 (1.81723112e-06)
144644 EPS nconv=0 first unconverged value (error) -302.035 (1.91233418e-06)
144645 EPS nconv=0 first unconverged value (error) -302.035 (1.87761905e-06)
144646 EPS nconv=0 first unconverged value (error) -302.035 (1.85660488e-06)
144647 EPS nconv=0 first unconverged value (error) -302.035 (1.83973650e-06)
144648 EPS nconv=0 first unconverged value (error) -302.035 (1.83683030e-06)
144649 EPS nconv=0 first unconverged value (error) -302.035 (1.83683030e-06)
144650 EPS nconv=0 first unconverged value (error) -302.035 (1.91391393e-06)
144651 EPS nconv=0 first unconverged value (error) -302.035 (1.91106038e-06)
144652 EPS nconv=0 first unconverged value (error) -302.035 (1.86518909e-06)
144653 EPS nconv=0 first unconverged value (error) -302.035 (1.83251143e-06)
144654 EPS nconv=0 first unconverged value (error) -302.035 (1.82698433e-06)
144655 EPS nconv=0 first unconverged value (error) -302.035 (1.82698433e-06)
144656 EPS nconv=0 first unconverged value (error) -302.035 (1.83629273e-06)
144657 EPS nconv=0 first unconverged value (error) -302.035 (1.87097504e-06)
144658 EPS nconv=0 first unconverged value (error) -302.035 (1.83297502e-06)
144659 EPS nconv=0 first unconverged value (error) -302.035 (1.80930181e-06)
144660 EPS nconv=0 first unconverged value (error) -302.035 (1.80543867e-06)
144661 EPS nconv=0 first unconverged value (error) -302.035 (1.80543867e-06)
144662 EPS nconv=0 first unconverged value (error) -302.035 (1.80558873e-06)
144663 EPS nconv=0 first unconverged value (error) -302.035 (1.80556290e-06)
144664 EPS nconv=0 first unconverged value (error) -302.035 (1.80051802e-06)
144665 EPS nconv=0 first unconverged value (error) -302.035 (1.79974446e-06)
144666 EPS nconv=0 first unconverged value (error) -302.035 (1.79778105e-06)
144667 EPS nconv=0 first unconverged value (error) -302.035 (1.79778105e-06)
144668 EPS nconv=0 first unconverged value (error) -302.035 (1.86648708e-06)
144669 EPS nconv=0 first unconverged value (error) -302.035 (1.85171474e-06)
144670 EPS nconv=0 first unconverged value (error) -302.035 (1.83624485e-06)
144671 EPS nconv=0 first unconverged value (error) -302.035 (1.82970435e-06)
144672 EPS nconv=0 first unconverged value (error) -302.035 (1.82352972e-06)
144673 EPS nconv=0 first unconverged value (error) -302.035 (1.82352972e-06)
144674 EPS nconv=0 first unconverged value (error) -302.035 (1.82878889e-06)
144675 EPS nconv=0 first unconverged value (error) -302.035 (1.84648528e-06)
144676 EPS nconv=0 first unconverged value (error) -302.035 (1.82922445e-06)
144677 EPS nconv=0 first unconverged value (error) -302.035 (1.80820379e-06)
144678 EPS nconv=0 first unconverged value (error) -302.035 (1.80382012e-06)
144679 EPS nconv=0 first unconverged value (error) -302.035 (1.80382012e-06)
144680 EPS nconv=0 first unconverged value (error) -302.035 (1.79691167e-06)
144681 EPS nconv=0 first unconverged value (error) -302.035 (1.79751905e-06)
144682 EPS nconv=0 first unconverged value (error) -302.035 (1.79673830e-06)
144683 EPS nconv=0 first unconverged value (error) -302.035 (1.79538261e-06)
144684 EPS nconv=0 first unconverged value (error) -302.035 (1.79509824e-06)
144685 EPS nconv=0 first unconverged value (error) -302.035 (1.79509824e-06)
144686 EPS nconv=0 first unconverged value (error) -302.035 (1.79554168e-06)
144687 EPS nconv=0 first unconverged value (error) -302.035 (1.79541276e-06)
144688 EPS nconv=0 first unconverged value (error) -302.035 (1.79529378e-06)
144689 EPS nconv=0 first unconverged value (error) -302.035 (1.79525682e-06)
144690 EPS nconv=0 first unconverged value (error) -302.035 (1.79522164e-06)
144691 EPS nconv=0 first unconverged value (error) -302.035 (1.79522164e-06)
144692 EPS nconv=0 first unconverged value (error) -302.035 (2.20937257e-06)
144693 EPS nconv=0 first unconverged value (error) -302.035 (2.11455776e-06)
144694 EPS nconv=0 first unconverged value (error) -302.035 (2.00180172e-06)
144695 EPS nconv=0 first unconverged value (error) -302.035 (1.97669271e-06)
144696 EPS nconv=0 first unconverged value (error) -302.035 (1.95447285e-06)
144697 EPS nconv=0 first unconverged value (error) -302.035 (1.95447285e-06)
144698 EPS nconv=0 first unconverged value (error) -302.035 (2.27970875e-06)
144699 EPS nconv=0 first unconverged value (error) -302.035 (2.26503308e-06)
144700 EPS nconv=0 first unconverged value (error) -302.035 (2.09758076e-06)
144701 EPS nconv=0 first unconverged value (error) -302.035 (2.06078790e-06)
144702 EPS nconv=0 first unconverged value (error) -302.035 (2.02648915e-06)
144703 EPS nconv=0 first unconverged value (error) -302.035 (2.02648915e-06)
144704 EPS nconv=0 first unconverged value (error) -302.035 (2.37628822e-06)
144705 EPS nconv=0 first unconverged value (error) -302.035 (2.23841148e-06)
144706 EPS nconv=0 first unconverged value (error) -302.035 (2.07985365e-06)
144707 EPS nconv=0 first unconverged value (error) -302.035 (2.04040782e-06)
144708 EPS nconv=0 first unconverged value (error) -302.035 (2.01511151e-06)
144709 EPS nconv=0 first unconverged value (error) -302.035 (2.01511151e-06)
144710 EPS nconv=0 first unconverged value (error) -302.035 (2.00908797e-06)
144711 EPS nconv=0 first unconverged value (error) -302.035 (2.12863563e-06)
144712 EPS nconv=0 first unconverged value (error) -302.035 (2.01342020e-06)
144713 EPS nconv=0 first unconverged value (error) -302.035 (1.85706974e-06)
144714 EPS nconv=0 first unconverged value (error) -302.035 (1.82632995e-06)
144715 EPS nconv=0 first unconverged value (error) -302.035 (1.82632995e-06)
144716 EPS nconv=0 first unconverged value (error) -302.035 (1.81428421e-06)
144717 EPS nconv=0 first unconverged value (error) -302.035 (1.81490528e-06)
144718 EPS nconv=0 first unconverged value (error) -302.035 (1.80799891e-06)
144719 EPS nconv=0 first unconverged value (error) -302.035 (1.80539126e-06)
144720 EPS nconv=0 first unconverged value (error) -302.035 (1.80343527e-06)
144721 EPS nconv=0 first unconverged value (error) -302.035 (1.80343527e-06)
144722 EPS nconv=0 first unconverged value (error) -302.035 (1.86050616e-06)
144723 EPS nconv=0 first unconverged value (error) -302.035 (1.85473215e-06)
144724 EPS nconv=0 first unconverged value (error) -302.035 (1.83995862e-06)
144725 EPS nconv=0 first unconverged value (error) -302.035 (1.82716952e-06)
144726 EPS nconv=0 first unconverged value (error) -302.035 (1.82015579e-06)
144727 EPS nconv=0 first unconverged value (error) -302.035 (1.82015579e-06)
144728 EPS nconv=0 first unconverged value (error) -302.035 (1.85670763e-06)
144729 EPS nconv=0 first unconverged value (error) -302.035 (1.85362234e-06)
144730 EPS nconv=0 first unconverged value (error) -302.035 (1.83255930e-06)
144731 EPS nconv=0 first unconverged value (error) -302.035 (1.81998280e-06)
144732 EPS nconv=0 first unconverged value (error) -302.035 (1.81497157e-06)
144733 EPS nconv=0 first unconverged value (error) -302.035 (1.81497157e-06)
144734 EPS nconv=0 first unconverged value (error) -302.035 (1.80880701e-06)
144735 EPS nconv=0 first unconverged value (error) -302.035 (1.81457567e-06)
144736 EPS nconv=0 first unconverged value (error) -302.035 (1.80617899e-06)
144737 EPS nconv=0 first unconverged value (error) -302.035 (1.79778724e-06)
144738 EPS nconv=0 first unconverged value (error) -302.035 (1.79643354e-06)
144739 EPS nconv=0 first unconverged value (error) -302.035 (1.79643354e-06)
144740 EPS nconv=0 first unconverged value (error) -302.035 (1.96973017e-06)
144741 EPS nconv=0 first unconverged value (error) -302.035 (1.88864288e-06)
144742 EPS nconv=0 first unconverged value (error) -302.035 (1.86668569e-06)
144743 EPS nconv=0 first unconverged value (error) -302.035 (1.85537533e-06)
144744 EPS nconv=0 first unconverged value (error) -302.035 (1.84596356e-06)
144745 EPS nconv=0 first unconverged value (error) -302.035 (1.84596356e-06)
144746 EPS nconv=0 first unconverged value (error) -302.035 (2.09063547e-06)
144747 EPS nconv=0 first unconverged value (error) -302.035 (2.04217454e-06)
144748 EPS nconv=0 first unconverged value (error) -302.035 (1.94981732e-06)
144749 EPS nconv=0 first unconverged value (error) -302.035 (1.94613646e-06)
144750 EPS nconv=0 first unconverged value (error) -302.035 (1.93574558e-06)
144751 EPS nconv=0 first unconverged value (error) -302.035 (1.93574558e-06)
144752 EPS nconv=0 first unconverged value (error) -302.035 (2.10467670e-06)
144753 EPS nconv=0 first unconverged value (error) -302.035 (2.05934725e-06)
144754 EPS nconv=0 first unconverged value (error) -302.035 (1.94749910e-06)
144755 EPS nconv=0 first unconverged value (error) -302.035 (1.93507643e-06)
144756 EPS nconv=0 first unconverged value (error) -302.035 (1.90675385e-06)
144757 EPS nconv=0 first unconverged value (error) -302.035 (1.90675385e-06)
144758 EPS nconv=0 first unconverged value (error) -302.035 (2.07281654e-06)
144759 EPS nconv=0 first unconverged value (error) -302.035 (2.06224495e-06)
144760 EPS nconv=0 first unconverged value (error) -302.035 (1.98316103e-06)
144761 EPS nconv=0 first unconverged value (error) -302.035 (1.88162252e-06)
144762 EPS nconv=0 first unconverged value (error) -302.035 (1.86346031e-06)
144763 EPS nconv=0 first unconverged value (error) -302.035 (1.86346031e-06)
144764 EPS nconv=0 first unconverged value (error) -302.035 (1.94488970e-06)
144765 EPS nconv=0 first unconverged value (error) -302.035 (1.97958661e-06)
144766 EPS nconv=0 first unconverged value (error) -302.035 (1.90115185e-06)
144767 EPS nconv=0 first unconverged value (error) -302.035 (1.85038062e-06)
144768 EPS nconv=0 first unconverged value (error) -302.035 (1.83742877e-06)
144769 EPS nconv=0 first unconverged value (error) -302.035 (1.83742877e-06)
144770 EPS nconv=0 first unconverged value (error) -302.035 (1.83789077e-06)
144771 EPS nconv=0 first unconverged value (error) -302.035 (1.85046709e-06)
144772 EPS nconv=0 first unconverged value (error) -302.035 (1.81472829e-06)
144773 EPS nconv=0 first unconverged value (error) -302.035 (1.80913375e-06)
144774 EPS nconv=0 first unconverged value (error) -302.035 (1.80622795e-06)
144775 EPS nconv=0 first unconverged value (error) -302.035 (1.80622795e-06)
144776 EPS nconv=0 first unconverged value (error) -302.035 (1.80246286e-06)
144777 EPS nconv=0 first unconverged value (error) -302.035 (1.80471987e-06)
144778 EPS nconv=0 first unconverged value (error) -302.035 (1.79847820e-06)
144779 EPS nconv=0 first unconverged value (error) -302.035 (1.79693005e-06)
144780 EPS nconv=0 first unconverged value (error) -302.035 (1.79662977e-06)
144781 EPS nconv=0 first unconverged value (error) -302.035 (1.79662977e-06)
144782 EPS nconv=0 first unconverged value (error) -302.035 (1.79613198e-06)
144783 EPS nconv=0 first unconverged value (error) -302.035 (1.79623055e-06)
144784 EPS nconv=0 first unconverged value (error) -302.035 (1.79538265e-06)
144785 EPS nconv=0 first unconverged value (error) -302.035 (1.79502467e-06)
144786 EPS nconv=0 first unconverged value (error) -302.035 (1.79490504e-06)
144787 EPS nconv=0 first unconverged value (error) -302.035 (1.79490504e-06)
144788 EPS nconv=0 first unconverged value (error) -302.035 (1.82929987e-06)
144789 EPS nconv=0 first unconverged value (error) -302.035 (1.81649236e-06)
144790 EPS nconv=0 first unconverged value (error) -302.035 (1.81243864e-06)
144791 EPS nconv=0 first unconverged value (error) -302.035 (1.81111431e-06)
144792 EPS nconv=0 first unconverged value (error) -302.035 (1.80800383e-06)
144793 EPS nconv=0 first unconverged value (error) -302.035 (1.80800383e-06)
144794 EPS nconv=0 first unconverged value (error) -302.035 (1.96757254e-06)
144795 EPS nconv=0 first unconverged value (error) -302.035 (1.90797056e-06)
144796 EPS nconv=0 first unconverged value (error) -302.035 (1.87921613e-06)
144797 EPS nconv=0 first unconverged value (error) -302.035 (1.87215960e-06)
144798 EPS nconv=0 first unconverged value (error) -302.035 (1.86231813e-06)
144799 EPS nconv=0 first unconverged value (error) -302.035 (1.86231813e-06)
144800 EPS nconv=0 first unconverged value (error) -302.035 (1.85953084e-06)
144801 EPS nconv=0 first unconverged value (error) -302.035 (1.90189444e-06)
144802 EPS nconv=0 first unconverged value (error) -302.035 (1.84426859e-06)
144803 EPS nconv=0 first unconverged value (error) -302.035 (1.81764620e-06)
144804 EPS nconv=0 first unconverged value (error) -302.035 (1.80346507e-06)
144805 EPS nconv=0 first unconverged value (error) -302.035 (1.80346507e-06)
144806 EPS nconv=0 first unconverged value (error) -302.035 (1.79642510e-06)
144807 EPS nconv=0 first unconverged value (error) -302.035 (1.79657718e-06)
144808 EPS nconv=0 first unconverged value (error) -302.035 (1.79575351e-06)
144809 EPS nconv=0 first unconverged value (error) -302.035 (1.79508091e-06)
144810 EPS nconv=0 first unconverged value (error) -302.035 (1.79470173e-06)
144811 EPS nconv=0 first unconverged value (error) -302.035 (1.79470173e-06)
144812 EPS nconv=0 first unconverged value (error) -302.035 (1.80609695e-06)
144813 EPS nconv=0 first unconverged value (error) -302.035 (1.80304420e-06)
144814 EPS nconv=0 first unconverged value (error) -302.035 (1.80054414e-06)
144815 EPS nconv=0 first unconverged value (error) -302.035 (1.79864183e-06)
144816 EPS nconv=0 first unconverged value (error) -302.035 (1.79807327e-06)
144817 EPS nconv=0 first unconverged value (error) -302.035 (1.79807327e-06)
144818 EPS nconv=0 first unconverged value (error) -302.035 (1.80513788e-06)
144819 EPS nconv=0 first unconverged value (error) -302.035 (1.80452396e-06)
144820 EPS nconv=0 first unconverged value (error) -302.035 (1.80043603e-06)
144821 EPS nconv=0 first unconverged value (error) -302.035 (1.79955249e-06)
144822 EPS nconv=0 first unconverged value (error) -302.035 (1.79740109e-06)
144823 EPS nconv=0 first unconverged value (error) -302.035 (1.79740109e-06)
144824 EPS nconv=0 first unconverged value (error) -302.035 (1.83192415e-06)
144825 EPS nconv=0 first unconverged value (error) -302.035 (1.82931860e-06)
144826 EPS nconv=0 first unconverged value (error) -302.035 (1.81882150e-06)
144827 EPS nconv=0 first unconverged value (error) -302.035 (1.81406055e-06)
144828 EPS nconv=0 first unconverged value (error) -302.035 (1.81063407e-06)
144829 EPS nconv=0 first unconverged value (error) -302.035 (1.81063407e-06)
144830 EPS nconv=0 first unconverged value (error) -302.035 (1.81135440e-06)
144831 EPS nconv=0 first unconverged value (error) -302.035 (1.81776831e-06)
144832 EPS nconv=0 first unconverged value (error) -302.035 (1.81015562e-06)
144833 EPS nconv=0 first unconverged value (error) -302.035 (1.79769679e-06)
144834 EPS nconv=0 first unconverged value (error) -302.035 (1.79808978e-06)
144835 EPS nconv=0 first unconverged value (error) -302.035 (1.79808978e-06)
144836 EPS nconv=0 first unconverged value (error) -302.035 (1.88256281e-06)
144837 EPS nconv=0 first unconverged value (error) -302.035 (1.83824968e-06)
144838 EPS nconv=0 first unconverged value (error) -302.035 (1.83151038e-06)
144839 EPS nconv=0 first unconverged value (error) -302.035 (1.82678075e-06)
144840 EPS nconv=0 first unconverged value (error) -302.035 (1.82231795e-06)
144841 EPS nconv=0 first unconverged value (error) -302.035 (1.82231795e-06)
144842 EPS nconv=0 first unconverged value (error) -302.035 (2.21966050e-06)
144843 EPS nconv=0 first unconverged value (error) -302.035 (2.07231313e-06)
144844 EPS nconv=0 first unconverged value (error) -302.035 (2.01354523e-06)
144845 EPS nconv=0 first unconverged value (error) -302.035 (1.98922801e-06)
144846 EPS nconv=0 first unconverged value (error) -302.035 (1.98226131e-06)
144847 EPS nconv=0 first unconverged value (error) -302.035 (1.98226131e-06)
144848 EPS nconv=0 first unconverged value (error) -302.035 (1.97887170e-06)
144849 EPS nconv=0 first unconverged value (error) -302.035 (2.04712963e-06)
144850 EPS nconv=0 first unconverged value (error) -302.035 (1.90512705e-06)
144851 EPS nconv=0 first unconverged value (error) -302.035 (1.84010737e-06)
144852 EPS nconv=0 first unconverged value (error) -302.035 (1.82312164e-06)
144853 EPS nconv=0 first unconverged value (error) -302.035 (1.82312164e-06)
144854 EPS nconv=0 first unconverged value (error) -302.035 (1.84792003e-06)
144855 EPS nconv=0 first unconverged value (error) -302.035 (1.83612775e-06)
144856 EPS nconv=0 first unconverged value (error) -302.035 (1.82310612e-06)
144857 EPS nconv=0 first unconverged value (error) -302.035 (1.81950290e-06)
144858 EPS nconv=0 first unconverged value (error) -302.035 (1.81608741e-06)
144859 EPS nconv=0 first unconverged value (error) -302.035 (1.81608741e-06)
144860 EPS nconv=0 first unconverged value (error) -302.035 (1.84593270e-06)
144861 EPS nconv=0 first unconverged value (error) -302.035 (1.86324980e-06)
144862 EPS nconv=0 first unconverged value (error) -302.035 (1.84637457e-06)
144863 EPS nconv=0 first unconverged value (error) -302.035 (1.81359482e-06)
144864 EPS nconv=0 first unconverged value (error) -302.035 (1.81020132e-06)
144865 EPS nconv=0 first unconverged value (error) -302.035 (1.81020132e-06)
144866 EPS nconv=0 first unconverged value (error) -302.035 (1.91253607e-06)
144867 EPS nconv=0 first unconverged value (error) -302.035 (1.88302136e-06)
144868 EPS nconv=0 first unconverged value (error) -302.035 (1.86670378e-06)
144869 EPS nconv=0 first unconverged value (error) -302.035 (1.85672609e-06)
144870 EPS nconv=0 first unconverged value (error) -302.035 (1.84663736e-06)
144871 EPS nconv=0 first unconverged value (error) -302.035 (1.84663736e-06)
144872 EPS nconv=0 first unconverged value (error) -302.035 (1.85193616e-06)
144873 EPS nconv=0 first unconverged value (error) -302.035 (1.87631106e-06)
144874 EPS nconv=0 first unconverged value (error) -302.035 (1.83954359e-06)
144875 EPS nconv=0 first unconverged value (error) -302.035 (1.80725247e-06)
144876 EPS nconv=0 first unconverged value (error) -302.035 (1.80517080e-06)
144877 EPS nconv=0 first unconverged value (error) -302.035 (1.80517080e-06)
144878 EPS nconv=0 first unconverged value (error) -302.035 (1.79902090e-06)
144879 EPS nconv=0 first unconverged value (error) -302.035 (1.79858051e-06)
144880 EPS nconv=0 first unconverged value (error) -302.035 (1.79659585e-06)
144881 EPS nconv=0 first unconverged value (error) -302.035 (1.79553777e-06)
144882 EPS nconv=0 first unconverged value (error) -302.035 (1.79502594e-06)
144883 EPS nconv=0 first unconverged value (error) -302.035 (1.79502594e-06)
144884 EPS nconv=0 first unconverged value (error) -302.035 (1.79574587e-06)
144885 EPS nconv=0 first unconverged value (error) -302.035 (1.79543298e-06)
144886 EPS nconv=0 first unconverged value (error) -302.035 (1.79532748e-06)
144887 EPS nconv=0 first unconverged value (error) -302.035 (1.79524125e-06)
144888 EPS nconv=0 first unconverged value (error) -302.035 (1.79516598e-06)
144889 EPS nconv=0 first unconverged value (error) -302.035 (1.79516598e-06)
144890 EPS nconv=0 first unconverged value (error) -302.035 (2.34856806e-06)
144891 EPS nconv=0 first unconverged value (error) -302.035 (2.24143082e-06)
144892 EPS nconv=0 first unconverged value (error) -302.035 (2.15034479e-06)
144893 EPS nconv=0 first unconverged value (error) -302.035 (2.08894764e-06)
144894 EPS nconv=0 first unconverged value (error) -302.035 (2.08227157e-06)
144895 EPS nconv=0 first unconverged value (error) -302.035 (2.08227157e-06)
144896 EPS nconv=0 first unconverged value (error) -302.035 (2.38568074e-06)
144897 EPS nconv=0 first unconverged value (error) -302.035 (2.22308099e-06)
144898 EPS nconv=0 first unconverged value (error) -302.035 (2.07656391e-06)
144899 EPS nconv=0 first unconverged value (error) -302.035 (2.02419947e-06)
144900 EPS nconv=0 first unconverged value (error) -302.035 (2.00089206e-06)
144901 EPS nconv=0 first unconverged value (error) -302.035 (2.00089206e-06)
144902 EPS nconv=0 first unconverged value (error) -302.035 (2.14482761e-06)
144903 EPS nconv=0 first unconverged value (error) -302.035 (2.14721850e-06)
144904 EPS nconv=0 first unconverged value (error) -302.035 (1.94950201e-06)
144905 EPS nconv=0 first unconverged value (error) -302.035 (1.93412776e-06)
144906 EPS nconv=0 first unconverged value (error) -302.035 (1.87476408e-06)
144907 EPS nconv=0 first unconverged value (error) -302.035 (1.87476408e-06)
144908 EPS nconv=0 first unconverged value (error) -302.035 (2.26463442e-06)
144909 EPS nconv=0 first unconverged value (error) -302.035 (2.23425647e-06)
144910 EPS nconv=0 first unconverged value (error) -302.035 (2.12470776e-06)
144911 EPS nconv=0 first unconverged value (error) -302.035 (2.03154750e-06)
144912 EPS nconv=0 first unconverged value (error) -302.035 (1.99469827e-06)
144913 EPS nconv=0 first unconverged value (error) -302.035 (1.99469827e-06)
144914 EPS nconv=0 first unconverged value (error) -302.035 (2.30834694e-06)
144915 EPS nconv=0 first unconverged value (error) -302.035 (2.28839504e-06)
144916 EPS nconv=0 first unconverged value (error) -302.035 (2.14126590e-06)
144917 EPS nconv=0 first unconverged value (error) -302.035 (2.10581131e-06)
144918 EPS nconv=0 first unconverged value (error) -302.035 (1.99193058e-06)
144919 EPS nconv=0 first unconverged value (error) -302.035 (1.99193058e-06)
144920 EPS nconv=0 first unconverged value (error) -302.035 (2.00935675e-06)
144921 EPS nconv=0 first unconverged value (error) -302.035 (2.03352893e-06)
144922 EPS nconv=0 first unconverged value (error) -302.035 (1.93211579e-06)
144923 EPS nconv=0 first unconverged value (error) -302.035 (1.85730184e-06)
144924 EPS nconv=0 first unconverged value (error) -302.035 (1.85759757e-06)
144925 EPS nconv=0 first unconverged value (error) -302.035 (1.85759757e-06)
144926 EPS nconv=0 first unconverged value (error) -302.035 (1.88731918e-06)
144927 EPS nconv=0 first unconverged value (error) -302.035 (1.83564671e-06)
144928 EPS nconv=0 first unconverged value (error) -302.035 (1.82392443e-06)
144929 EPS nconv=0 first unconverged value (error) -302.035 (1.81240616e-06)
144930 EPS nconv=0 first unconverged value (error) -302.035 (1.80865154e-06)
144931 EPS nconv=0 first unconverged value (error) -302.035 (1.80865154e-06)
144932 EPS nconv=0 first unconverged value (error) -302.035 (1.80750780e-06)
144933 EPS nconv=0 first unconverged value (error) -302.035 (1.82450009e-06)
144934 EPS nconv=0 first unconverged value (error) -302.035 (1.80306954e-06)
144935 EPS nconv=0 first unconverged value (error) -302.035 (1.79925883e-06)
144936 EPS nconv=0 first unconverged value (error) -302.035 (1.79743068e-06)
144937 EPS nconv=0 first unconverged value (error) -302.035 (1.79743068e-06)
144938 EPS nconv=0 first unconverged value (error) -302.035 (2.07828411e-06)
144939 EPS nconv=0 first unconverged value (error) -302.035 (2.00007021e-06)
144940 EPS nconv=0 first unconverged value (error) -302.035 (1.94504653e-06)
144941 EPS nconv=0 first unconverged value (error) -302.035 (1.94811242e-06)
144942 EPS nconv=0 first unconverged value (error) -302.035 (1.90836516e-06)
144943 EPS nconv=0 first unconverged value (error) -302.035 (1.90836516e-06)
144944 EPS nconv=0 first unconverged value (error) -302.035 (2.06121053e-06)
144945 EPS nconv=0 first unconverged value (error) -302.035 (2.06364727e-06)
144946 EPS nconv=0 first unconverged value (error) -302.035 (1.96539456e-06)
144947 EPS nconv=0 first unconverged value (error) -302.035 (1.93899091e-06)
144948 EPS nconv=0 first unconverged value (error) -302.035 (1.93927092e-06)
144949 EPS nconv=0 first unconverged value (error) -302.035 (1.93927092e-06)
144950 EPS nconv=0 first unconverged value (error) -302.035 (1.97336012e-06)
144951 EPS nconv=0 first unconverged value (error) -302.035 (1.88976045e-06)
144952 EPS nconv=0 first unconverged value (error) -302.035 (1.85957540e-06)
144953 EPS nconv=0 first unconverged value (error) -302.035 (1.83772326e-06)
144954 EPS nconv=0 first unconverged value (error) -302.035 (1.81902406e-06)
144955 EPS nconv=0 first unconverged value (error) -302.035 (1.81902406e-06)
144956 EPS nconv=0 first unconverged value (error) -302.035 (2.09439409e-06)
144957 EPS nconv=0 first unconverged value (error) -302.035 (2.00943252e-06)
144958 EPS nconv=0 first unconverged value (error) -302.035 (1.92323867e-06)
144959 EPS nconv=0 first unconverged value (error) -302.035 (1.89466182e-06)
144960 EPS nconv=0 first unconverged value (error) -302.035 (1.88721913e-06)
144961 EPS nconv=0 first unconverged value (error) -302.035 (1.88721913e-06)
144962 EPS nconv=0 first unconverged value (error) -302.035 (2.02885635e-06)
144963 EPS nconv=0 first unconverged value (error) -302.035 (2.05314191e-06)
144964 EPS nconv=0 first unconverged value (error) -302.035 (1.94659248e-06)
144965 EPS nconv=0 first unconverged value (error) -302.035 (1.92078133e-06)
144966 EPS nconv=0 first unconverged value (error) -302.035 (1.88316844e-06)
144967 EPS nconv=0 first unconverged value (error) -302.035 (1.88316844e-06)
144968 EPS nconv=0 first unconverged value (error) -302.035 (2.08628444e-06)
144969 EPS nconv=0 first unconverged value (error) -302.035 (2.11116198e-06)
144970 EPS nconv=0 first unconverged value (error) -302.035 (2.01292275e-06)
144971 EPS nconv=0 first unconverged value (error) -302.035 (1.93042040e-06)
144972 EPS nconv=0 first unconverged value (error) -302.035 (1.91101883e-06)
144973 EPS nconv=0 first unconverged value (error) -302.035 (1.91101883e-06)
144974 EPS nconv=0 first unconverged value (error) -302.035 (1.93040288e-06)
144975 EPS nconv=0 first unconverged value (error) -302.035 (1.91346736e-06)
144976 EPS nconv=0 first unconverged value (error) -302.035 (1.88628165e-06)
144977 EPS nconv=0 first unconverged value (error) -302.035 (1.83190941e-06)
144978 EPS nconv=0 first unconverged value (error) -302.035 (1.82095055e-06)
144979 EPS nconv=0 first unconverged value (error) -302.035 (1.82095055e-06)
144980 EPS nconv=0 first unconverged value (error) -302.035 (1.83456057e-06)
144981 EPS nconv=0 first unconverged value (error) -302.035 (1.83783569e-06)
144982 EPS nconv=0 first unconverged value (error) -302.035 (1.82048255e-06)
144983 EPS nconv=0 first unconverged value (error) -302.035 (1.81227422e-06)
144984 EPS nconv=0 first unconverged value (error) -302.035 (1.80998987e-06)
144985 EPS nconv=0 first unconverged value (error) -302.035 (1.80998987e-06)
144986 EPS nconv=0 first unconverged value (error) -302.035 (1.82353286e-06)
144987 EPS nconv=0 first unconverged value (error) -302.035 (1.82580864e-06)
144988 EPS nconv=0 first unconverged value (error) -302.035 (1.81167342e-06)
144989 EPS nconv=0 first unconverged value (error) -302.035 (1.80498550e-06)
144990 EPS nconv=0 first unconverged value (error) -302.035 (1.80145229e-06)
144991 EPS nconv=0 first unconverged value (error) -302.035 (1.80145229e-06)
144992 EPS nconv=0 first unconverged value (error) -302.035 (1.80010734e-06)
144993 EPS nconv=0 first unconverged value (error) -302.035 (1.80281127e-06)
144994 EPS nconv=0 first unconverged value (error) -302.035 (1.79751032e-06)
144995 EPS nconv=0 first unconverged value (error) -302.035 (1.79566065e-06)
144996 EPS nconv=0 first unconverged value (error) -302.035 (1.79522991e-06)
144997 EPS nconv=0 first unconverged value (error) -302.035 (1.79522991e-06)
144998 EPS nconv=0 first unconverged value (error) -302.035 (1.80037385e-06)
144999 EPS nconv=0 first unconverged value (error) -302.035 (1.79765307e-06)
145000 EPS nconv=0 first unconverged value (error) -302.035 (1.79671914e-06)
145001 EPS nconv=0 first unconverged value (error) -302.035 (1.79646945e-06)
145002 EPS nconv=0 first unconverged value (error) -302.035 (1.79570986e-06)
145003 EPS nconv=0 first unconverged value (error) -302.035 (1.79570986e-06)
145004 EPS nconv=0 first unconverged value (error) -302.035 (2.35163649e-06)
145005 EPS nconv=0 first unconverged value (error) -302.035 (2.19945146e-06)
145006 EPS nconv=0 first unconverged value (error) -302.035 (2.11707452e-06)
145007 EPS nconv=0 first unconverged value (error) -302.035 (2.08518847e-06)
145008 EPS nconv=0 first unconverged value (error) -302.035 (2.05548906e-06)
145009 EPS nconv=0 first unconverged value (error) -302.035 (2.05548906e-06)
145010 EPS nconv=0 first unconverged value (error) -302.035 (2.13273194e-06)
145011 EPS nconv=0 first unconverged value (error) -302.035 (2.13637159e-06)
145012 EPS nconv=0 first unconverged value (error) -302.035 (1.98112136e-06)
145013 EPS nconv=0 first unconverged value (error) -302.035 (1.90112909e-06)
145014 EPS nconv=0 first unconverged value (error) -302.035 (1.88891720e-06)
145015 EPS nconv=0 first unconverged value (error) -302.035 (1.88891720e-06)
145016 EPS nconv=0 first unconverged value (error) -302.035 (1.91858128e-06)
145017 EPS nconv=0 first unconverged value (error) -302.035 (1.92472447e-06)
145018 EPS nconv=0 first unconverged value (error) -302.035 (1.88526592e-06)
145019 EPS nconv=0 first unconverged value (error) -302.035 (1.83371149e-06)
145020 EPS nconv=0 first unconverged value (error) -302.035 (1.82247673e-06)
145021 EPS nconv=0 first unconverged value (error) -302.035 (1.82247673e-06)
145022 EPS nconv=0 first unconverged value (error) -302.035 (2.04438570e-06)
145023 EPS nconv=0 first unconverged value (error) -302.035 (1.90480166e-06)
145024 EPS nconv=0 first unconverged value (error) -302.035 (1.86669062e-06)
145025 EPS nconv=0 first unconverged value (error) -302.035 (1.85346412e-06)
145026 EPS nconv=0 first unconverged value (error) -302.035 (1.84704636e-06)
145027 EPS nconv=0 first unconverged value (error) -302.035 (1.84704636e-06)
145028 EPS nconv=0 first unconverged value (error) -302.035 (1.84919223e-06)
145029 EPS nconv=0 first unconverged value (error) -302.035 (1.93244285e-06)
145030 EPS nconv=0 first unconverged value (error) -302.035 (1.82829969e-06)
145031 EPS nconv=0 first unconverged value (error) -302.035 (1.81271172e-06)
145032 EPS nconv=0 first unconverged value (error) -302.035 (1.80452294e-06)
145033 EPS nconv=0 first unconverged value (error) -302.035 (1.80452294e-06)
145034 EPS nconv=0 first unconverged value (error) -302.035 (1.92443911e-06)
145035 EPS nconv=0 first unconverged value (error) -302.035 (1.88207910e-06)
145036 EPS nconv=0 first unconverged value (error) -302.035 (1.86523434e-06)
145037 EPS nconv=0 first unconverged value (error) -302.035 (1.86896423e-06)
145038 EPS nconv=0 first unconverged value (error) -302.035 (1.85157892e-06)
145039 EPS nconv=0 first unconverged value (error) -302.035 (1.85157892e-06)
145040 EPS nconv=0 first unconverged value (error) -302.035 (1.84977190e-06)
145041 EPS nconv=0 first unconverged value (error) -302.035 (1.87907672e-06)
145042 EPS nconv=0 first unconverged value (error) -302.035 (1.83391417e-06)
145043 EPS nconv=0 first unconverged value (error) -302.035 (1.80062244e-06)
145044 EPS nconv=0 first unconverged value (error) -302.035 (1.80209272e-06)
145045 EPS nconv=0 first unconverged value (error) -302.035 (1.80209272e-06)
145046 EPS nconv=0 first unconverged value (error) -302.035 (1.79868384e-06)
145047 EPS nconv=0 first unconverged value (error) -302.035 (1.79679399e-06)
145048 EPS nconv=0 first unconverged value (error) -302.035 (1.79678385e-06)
145049 EPS nconv=0 first unconverged value (error) -302.035 (1.79611583e-06)
145050 EPS nconv=0 first unconverged value (error) -302.035 (1.79575308e-06)
145051 EPS nconv=0 first unconverged value (error) -302.035 (1.79575308e-06)
145052 EPS nconv=0 first unconverged value (error) -302.035 (1.84672553e-06)
145053 EPS nconv=0 first unconverged value (error) -302.035 (1.82411654e-06)
145054 EPS nconv=0 first unconverged value (error) -302.035 (1.81407232e-06)
145055 EPS nconv=0 first unconverged value (error) -302.035 (1.81140614e-06)
145056 EPS nconv=0 first unconverged value (error) -302.035 (1.81015311e-06)
145057 EPS nconv=0 first unconverged value (error) -302.035 (1.81015311e-06)
145058 EPS nconv=0 first unconverged value (error) -302.035 (1.81810099e-06)
145059 EPS nconv=0 first unconverged value (error) -302.035 (1.83443533e-06)
145060 EPS nconv=0 first unconverged value (error) -302.035 (1.80893727e-06)
145061 EPS nconv=0 first unconverged value (error) -302.035 (1.80211831e-06)
145062 EPS nconv=0 first unconverged value (error) -302.035 (1.80114886e-06)
145063 EPS nconv=0 first unconverged value (error) -302.035 (1.80114886e-06)
145064 EPS nconv=0 first unconverged value (error) -302.035 (1.81872356e-06)
145065 EPS nconv=0 first unconverged value (error) -302.035 (1.81278830e-06)
145066 EPS nconv=0 first unconverged value (error) -302.035 (1.80614227e-06)
145067 EPS nconv=0 first unconverged value (error) -302.035 (1.80488201e-06)
145068 EPS nconv=0 first unconverged value (error) -302.035 (1.80291233e-06)
145069 EPS nconv=0 first unconverged value (error) -302.035 (1.80291233e-06)
145070 EPS nconv=0 first unconverged value (error) -302.035 (1.80289164e-06)
145071 EPS nconv=0 first unconverged value (error) -302.035 (1.80410723e-06)
145072 EPS nconv=0 first unconverged value (error) -302.035 (1.79772500e-06)
145073 EPS nconv=0 first unconverged value (error) -302.035 (1.79580618e-06)
145074 EPS nconv=0 first unconverged value (error) -302.035 (1.79580387e-06)
145075 EPS nconv=0 first unconverged value (error) -302.035 (1.79580387e-06)
145076 EPS nconv=0 first unconverged value (error) -302.035 (1.79915351e-06)
145077 EPS nconv=0 first unconverged value (error) -302.035 (1.79733599e-06)
145078 EPS nconv=0 first unconverged value (error) -302.035 (1.79635001e-06)
145079 EPS nconv=0 first unconverged value (error) -302.035 (1.79600989e-06)
145080 EPS nconv=0 first unconverged value (error) -302.035 (1.79586074e-06)
145081 EPS nconv=0 first unconverged value (error) -302.035 (1.79586074e-06)
145082 EPS nconv=0 first unconverged value (error) -302.035 (1.79604227e-06)
145083 EPS nconv=0 first unconverged value (error) -302.035 (1.79680424e-06)
145084 EPS nconv=0 first unconverged value (error) -302.035 (1.79516675e-06)
145085 EPS nconv=0 first unconverged value (error) -302.035 (1.79473963e-06)
145086 EPS nconv=0 first unconverged value (error) -302.035 (1.79456620e-06)
145087 EPS nconv=0 first unconverged value (error) -302.035 (1.79456620e-06)
145088 EPS nconv=0 first unconverged value (error) -302.035 (1.79459891e-06)
145089 EPS nconv=0 first unconverged value (error) -302.035 (1.79465887e-06)
145090 EPS nconv=0 first unconverged value (error) -302.035 (1.79458553e-06)
145091 EPS nconv=0 first unconverged value (error) -302.035 (1.79444417e-06)
145092 EPS nconv=0 first unconverged value (error) -302.035 (1.79441235e-06)
145093 EPS nconv=0 first unconverged value (error) -302.035 (1.79441235e-06)
145094 EPS nconv=0 first unconverged value (error) -302.035 (1.79793031e-06)
145095 EPS nconv=0 first unconverged value (error) -302.035 (1.79632420e-06)
145096 EPS nconv=0 first unconverged value (error) -302.035 (1.79586189e-06)
145097 EPS nconv=0 first unconverged value (error) -302.035 (1.79574999e-06)
145098 EPS nconv=0 first unconverged value (error) -302.035 (1.79550792e-06)
145099 EPS nconv=0 first unconverged value (error) -302.035 (1.79550792e-06)
145100 EPS nconv=0 first unconverged value (error) -302.035 (1.97238539e-06)
145101 EPS nconv=0 first unconverged value (error) -302.035 (1.96691818e-06)
145102 EPS nconv=0 first unconverged value (error) -302.035 (1.90481350e-06)
145103 EPS nconv=0 first unconverged value (error) -302.035 (1.88535105e-06)
145104 EPS nconv=0 first unconverged value (error) -302.035 (1.88354264e-06)
145105 EPS nconv=0 first unconverged value (error) -302.035 (1.88354264e-06)
145106 EPS nconv=0 first unconverged value (error) -302.035 (1.87999205e-06)
145107 EPS nconv=0 first unconverged value (error) -302.035 (1.89252185e-06)
145108 EPS nconv=0 first unconverged value (error) -302.035 (1.89399302e-06)
145109 EPS nconv=0 first unconverged value (error) -302.035 (1.81270126e-06)
145110 EPS nconv=0 first unconverged value (error) -302.035 (1.79926333e-06)
145111 EPS nconv=0 first unconverged value (error) -302.035 (1.79926333e-06)
145112 EPS nconv=0 first unconverged value (error) -302.035 (1.97990221e-06)
145113 EPS nconv=0 first unconverged value (error) -302.035 (1.90819171e-06)
145114 EPS nconv=0 first unconverged value (error) -302.035 (1.86470368e-06)
145115 EPS nconv=0 first unconverged value (error) -302.035 (1.85822423e-06)
145116 EPS nconv=0 first unconverged value (error) -302.035 (1.85518361e-06)
145117 EPS nconv=0 first unconverged value (error) -302.035 (1.85518361e-06)
145118 EPS nconv=0 first unconverged value (error) -302.035 (1.85362521e-06)
145119 EPS nconv=0 first unconverged value (error) -302.035 (1.89588171e-06)
145120 EPS nconv=0 first unconverged value (error) -302.035 (1.84257056e-06)
145121 EPS nconv=0 first unconverged value (error) -302.035 (1.80596144e-06)
145122 EPS nconv=0 first unconverged value (error) -302.035 (1.80140826e-06)
145123 EPS nconv=0 first unconverged value (error) -302.035 (1.80140826e-06)
145124 EPS nconv=0 first unconverged value (error) -302.035 (1.80294731e-06)
145125 EPS nconv=0 first unconverged value (error) -302.035 (1.80470369e-06)
145126 EPS nconv=0 first unconverged value (error) -302.035 (1.79966706e-06)
145127 EPS nconv=0 first unconverged value (error) -302.035 (1.79780106e-06)
145128 EPS nconv=0 first unconverged value (error) -302.035 (1.79695540e-06)
145129 EPS nconv=0 first unconverged value (error) -302.035 (1.79695540e-06)
145130 EPS nconv=0 first unconverged value (error) -302.035 (1.79700581e-06)
145131 EPS nconv=0 first unconverged value (error) -302.035 (1.79657110e-06)
145132 EPS nconv=0 first unconverged value (error) -302.035 (1.79550470e-06)
145133 EPS nconv=0 first unconverged value (error) -302.035 (1.79481534e-06)
145134 EPS nconv=0 first unconverged value (error) -302.035 (1.79448164e-06)
145135 EPS nconv=0 first unconverged value (error) -302.035 (1.79448164e-06)
145136 EPS nconv=0 first unconverged value (error) -302.035 (1.99633036e-06)
145137 EPS nconv=0 first unconverged value (error) -302.035 (1.95170844e-06)
145138 EPS nconv=0 first unconverged value (error) -302.035 (1.89447531e-06)
145139 EPS nconv=0 first unconverged value (error) -302.035 (1.87819076e-06)
145140 EPS nconv=0 first unconverged value (error) -302.035 (1.87358319e-06)
145141 EPS nconv=0 first unconverged value (error) -302.035 (1.87358319e-06)
145142 EPS nconv=0 first unconverged value (error) -302.035 (2.14456269e-06)
145143 EPS nconv=0 first unconverged value (error) -302.035 (2.06040389e-06)
145144 EPS nconv=0 first unconverged value (error) -302.035 (1.99705639e-06)
145145 EPS nconv=0 first unconverged value (error) -302.035 (1.98179146e-06)
145146 EPS nconv=0 first unconverged value (error) -302.035 (1.97471209e-06)
145147 EPS nconv=0 first unconverged value (error) -302.035 (1.97471209e-06)
145148 EPS nconv=0 first unconverged value (error) -302.035 (2.12587004e-06)
145149 EPS nconv=0 first unconverged value (error) -302.035 (2.06674583e-06)
145150 EPS nconv=0 first unconverged value (error) -302.035 (1.92053853e-06)
145151 EPS nconv=0 first unconverged value (error) -302.035 (1.92327183e-06)
145152 EPS nconv=0 first unconverged value (error) -302.035 (1.88417733e-06)
145153 EPS nconv=0 first unconverged value (error) -302.035 (1.88417733e-06)
145154 EPS nconv=0 first unconverged value (error) -302.035 (1.91377762e-06)
145155 EPS nconv=0 first unconverged value (error) -302.035 (1.98082286e-06)
145156 EPS nconv=0 first unconverged value (error) -302.035 (1.91045028e-06)
145157 EPS nconv=0 first unconverged value (error) -302.035 (1.82835744e-06)
145158 EPS nconv=0 first unconverged value (error) -302.035 (1.81731597e-06)
145159 EPS nconv=0 first unconverged value (error) -302.035 (1.81731597e-06)
145160 EPS nconv=0 first unconverged value (error) -302.035 (1.81351789e-06)
145161 EPS nconv=0 first unconverged value (error) -302.035 (1.81967080e-06)
145162 EPS nconv=0 first unconverged value (error) -302.035 (1.81289909e-06)
145163 EPS nconv=0 first unconverged value (error) -302.035 (1.79936874e-06)
145164 EPS nconv=0 first unconverged value (error) -302.035 (1.79620605e-06)
145165 EPS nconv=0 first unconverged value (error) -302.035 (1.79620605e-06)
145166 EPS nconv=0 first unconverged value (error) -302.035 (1.86336420e-06)
145167 EPS nconv=0 first unconverged value (error) -302.035 (1.84385452e-06)
145168 EPS nconv=0 first unconverged value (error) -302.035 (1.83642605e-06)
145169 EPS nconv=0 first unconverged value (error) -302.035 (1.83145107e-06)
145170 EPS nconv=0 first unconverged value (error) -302.035 (1.82706708e-06)
145171 EPS nconv=0 first unconverged value (error) -302.035 (1.82706708e-06)
145172 EPS nconv=0 first unconverged value (error) -302.035 (1.96676695e-06)
145173 EPS nconv=0 first unconverged value (error) -302.035 (1.92302701e-06)
145174 EPS nconv=0 first unconverged value (error) -302.035 (1.88047681e-06)
145175 EPS nconv=0 first unconverged value (error) -302.035 (1.87938219e-06)
145176 EPS nconv=0 first unconverged value (error) -302.035 (1.87714985e-06)
145177 EPS nconv=0 first unconverged value (error) -302.035 (1.87714985e-06)
145178 EPS nconv=0 first unconverged value (error) -302.035 (2.18577229e-06)
145179 EPS nconv=0 first unconverged value (error) -302.035 (2.08919716e-06)
145180 EPS nconv=0 first unconverged value (error) -302.035 (1.96124518e-06)
145181 EPS nconv=0 first unconverged value (error) -302.035 (1.96304650e-06)
145182 EPS nconv=0 first unconverged value (error) -302.035 (1.91746388e-06)
145183 EPS nconv=0 first unconverged value (error) -302.035 (1.91746388e-06)
145184 EPS nconv=0 first unconverged value (error) -302.035 (2.08183287e-06)
145185 EPS nconv=0 first unconverged value (error) -302.035 (2.14166604e-06)
145186 EPS nconv=0 first unconverged value (error) -302.035 (2.00996826e-06)
145187 EPS nconv=0 first unconverged value (error) -302.035 (1.94982008e-06)
145188 EPS nconv=0 first unconverged value (error) -302.035 (1.94144415e-06)
145189 EPS nconv=0 first unconverged value (error) -302.035 (1.94144415e-06)
145190 EPS nconv=0 first unconverged value (error) -302.035 (1.92792357e-06)
145191 EPS nconv=0 first unconverged value (error) -302.035 (1.90057566e-06)
145192 EPS nconv=0 first unconverged value (error) -302.035 (1.90119389e-06)
145193 EPS nconv=0 first unconverged value (error) -302.035 (1.83589259e-06)
145194 EPS nconv=0 first unconverged value (error) -302.035 (1.82169321e-06)
145195 EPS nconv=0 first unconverged value (error) -302.035 (1.82169321e-06)
145196 EPS nconv=0 first unconverged value (error) -302.035 (1.83170179e-06)
145197 EPS nconv=0 first unconverged value (error) -302.035 (1.83119304e-06)
145198 EPS nconv=0 first unconverged value (error) -302.035 (1.81481614e-06)
145199 EPS nconv=0 first unconverged value (error) -302.035 (1.80480080e-06)
145200 EPS nconv=0 first unconverged value (error) -302.035 (1.80380282e-06)
145201 EPS nconv=0 first unconverged value (error) -302.035 (1.80380282e-06)
145202 EPS nconv=0 first unconverged value (error) -302.035 (1.80420874e-06)
145203 EPS nconv=0 first unconverged value (error) -302.035 (1.81523270e-06)
145204 EPS nconv=0 first unconverged value (error) -302.035 (1.80681623e-06)
145205 EPS nconv=0 first unconverged value (error) -302.035 (1.79706363e-06)
145206 EPS nconv=0 first unconverged value (error) -302.035 (1.79513841e-06)
145207 EPS nconv=0 first unconverged value (error) -302.035 (1.79513841e-06)
145208 EPS nconv=0 first unconverged value (error) -302.035 (1.79483404e-06)
145209 EPS nconv=0 first unconverged value (error) -302.035 (1.79481099e-06)
145210 EPS nconv=0 first unconverged value (error) -302.035 (1.79471302e-06)
145211 EPS nconv=0 first unconverged value (error) -302.035 (1.79465255e-06)
145212 EPS nconv=0 first unconverged value (error) -302.035 (1.79459618e-06)
145213 EPS nconv=0 first unconverged value (error) -302.035 (1.79459618e-06)
145214 EPS nconv=0 first unconverged value (error) -302.035 (1.80512177e-06)
145215 EPS nconv=0 first unconverged value (error) -302.035 (1.80110130e-06)
145216 EPS nconv=0 first unconverged value (error) -302.035 (1.80024773e-06)
145217 EPS nconv=0 first unconverged value (error) -302.035 (1.79946567e-06)
145218 EPS nconv=0 first unconverged value (error) -302.035 (1.79883945e-06)
145219 EPS nconv=0 first unconverged value (error) -302.035 (1.79883945e-06)
145220 EPS nconv=0 first unconverged value (error) -302.035 (1.97362380e-06)
145221 EPS nconv=0 first unconverged value (error) -302.035 (1.93226434e-06)
145222 EPS nconv=0 first unconverged value (error) -302.035 (1.91236132e-06)
145223 EPS nconv=0 first unconverged value (error) -302.035 (1.90236058e-06)
145224 EPS nconv=0 first unconverged value (error) -302.035 (1.89592983e-06)
145225 EPS nconv=0 first unconverged value (error) -302.035 (1.89592983e-06)
145226 EPS nconv=0 first unconverged value (error) -302.035 (1.92458911e-06)
145227 EPS nconv=0 first unconverged value (error) -302.035 (1.89313631e-06)
145228 EPS nconv=0 first unconverged value (error) -302.035 (1.84944844e-06)
145229 EPS nconv=0 first unconverged value (error) -302.035 (1.83397527e-06)
145230 EPS nconv=0 first unconverged value (error) -302.035 (1.82893174e-06)
145231 EPS nconv=0 first unconverged value (error) -302.035 (1.82893174e-06)
145232 EPS nconv=0 first unconverged value (error) -302.035 (1.85408407e-06)
145233 EPS nconv=0 first unconverged value (error) -302.035 (1.84751457e-06)
145234 EPS nconv=0 first unconverged value (error) -302.035 (1.82779777e-06)
145235 EPS nconv=0 first unconverged value (error) -302.035 (1.81733731e-06)
145236 EPS nconv=0 first unconverged value (error) -302.035 (1.81197087e-06)
145237 EPS nconv=0 first unconverged value (error) -302.035 (1.81197087e-06)
145238 EPS nconv=0 first unconverged value (error) -302.035 (1.81039535e-06)
145239 EPS nconv=0 first unconverged value (error) -302.035 (1.82977240e-06)
145240 EPS nconv=0 first unconverged value (error) -302.035 (1.81015331e-06)
145241 EPS nconv=0 first unconverged value (error) -302.035 (1.79802946e-06)
145242 EPS nconv=0 first unconverged value (error) -302.035 (1.79719086e-06)
145243 EPS nconv=0 first unconverged value (error) -302.035 (1.79719086e-06)
145244 EPS nconv=0 first unconverged value (error) -302.035 (1.83644530e-06)
145245 EPS nconv=0 first unconverged value (error) -302.035 (1.81972751e-06)
145246 EPS nconv=0 first unconverged value (error) -302.035 (1.81665016e-06)
145247 EPS nconv=0 first unconverged value (error) -302.035 (1.81511831e-06)
145248 EPS nconv=0 first unconverged value (error) -302.035 (1.81188410e-06)
145249 EPS nconv=0 first unconverged value (error) -302.035 (1.81188410e-06)
145250 EPS nconv=0 first unconverged value (error) -302.035 (1.82963900e-06)
145251 EPS nconv=0 first unconverged value (error) -302.035 (1.84384411e-06)
145252 EPS nconv=0 first unconverged value (error) -302.035 (1.82177783e-06)
145253 EPS nconv=0 first unconverged value (error) -302.035 (1.80582435e-06)
145254 EPS nconv=0 first unconverged value (error) -302.035 (1.80303774e-06)
145255 EPS nconv=0 first unconverged value (error) -302.035 (1.80303774e-06)
145256 EPS nconv=0 first unconverged value (error) -302.035 (1.80227673e-06)
145257 EPS nconv=0 first unconverged value (error) -302.035 (1.80427665e-06)
145258 EPS nconv=0 first unconverged value (error) -302.035 (1.80096370e-06)
145259 EPS nconv=0 first unconverged value (error) -302.035 (1.79761642e-06)
145260 EPS nconv=0 first unconverged value (error) -302.035 (1.79651664e-06)
145261 EPS nconv=0 first unconverged value (error) -302.035 (1.79651664e-06)
145262 EPS nconv=0 first unconverged value (error) -302.035 (1.88623882e-06)
145263 EPS nconv=0 first unconverged value (error) -302.035 (1.85315567e-06)
145264 EPS nconv=0 first unconverged value (error) -302.035 (1.84719121e-06)
145265 EPS nconv=0 first unconverged value (error) -302.035 (1.83475114e-06)
145266 EPS nconv=0 first unconverged value (error) -302.035 (1.82843735e-06)
145267 EPS nconv=0 first unconverged value (error) -302.035 (1.82843735e-06)
145268 EPS nconv=0 first unconverged value (error) -302.035 (2.47679917e-06)
145269 EPS nconv=0 first unconverged value (error) -302.035 (2.36127223e-06)
145270 EPS nconv=0 first unconverged value (error) -302.035 (2.29997004e-06)
145271 EPS nconv=0 first unconverged value (error) -302.035 (2.27530120e-06)
145272 EPS nconv=0 first unconverged value (error) -302.035 (2.27118948e-06)
145273 EPS nconv=0 first unconverged value (error) -302.035 (2.27118948e-06)
145274 EPS nconv=0 first unconverged value (error) -302.035 (2.35304641e-06)
145275 EPS nconv=0 first unconverged value (error) -302.035 (2.10346792e-06)
145276 EPS nconv=0 first unconverged value (error) -302.035 (1.97928165e-06)
145277 EPS nconv=0 first unconverged value (error) -302.035 (1.90203264e-06)
145278 EPS nconv=0 first unconverged value (error) -302.035 (1.89273800e-06)
145279 EPS nconv=0 first unconverged value (error) -302.035 (1.89273800e-06)
145280 EPS nconv=0 first unconverged value (error) -302.035 (1.88415370e-06)
145281 EPS nconv=0 first unconverged value (error) -302.035 (1.90526880e-06)
145282 EPS nconv=0 first unconverged value (error) -302.035 (1.83784835e-06)
145283 EPS nconv=0 first unconverged value (error) -302.035 (1.82105790e-06)
145284 EPS nconv=0 first unconverged value (error) -302.035 (1.80680906e-06)
145285 EPS nconv=0 first unconverged value (error) -302.035 (1.80680906e-06)
145286 EPS nconv=0 first unconverged value (error) -302.035 (2.27787240e-06)
145287 EPS nconv=0 first unconverged value (error) -302.035 (2.15008380e-06)
145288 EPS nconv=0 first unconverged value (error) -302.035 (2.06798410e-06)
145289 EPS nconv=0 first unconverged value (error) -302.035 (2.04309948e-06)
145290 EPS nconv=0 first unconverged value (error) -302.035 (2.01054082e-06)
145291 EPS nconv=0 first unconverged value (error) -302.035 (2.01054082e-06)
145292 EPS nconv=0 first unconverged value (error) -302.035 (3.25768665e-06)
145293 EPS nconv=0 first unconverged value (error) -302.035 (3.00336751e-06)
145294 EPS nconv=0 first unconverged value (error) -302.035 (2.78513185e-06)
145295 EPS nconv=0 first unconverged value (error) -302.035 (2.76178208e-06)
145296 EPS nconv=0 first unconverged value (error) -302.035 (2.71500305e-06)
145297 EPS nconv=0 first unconverged value (error) -302.035 (2.71500305e-06)
145298 EPS nconv=0 first unconverged value (error) -302.035 (2.75591321e-06)
145299 EPS nconv=0 first unconverged value (error) -302.035 (2.57390101e-06)
145300 EPS nconv=0 first unconverged value (error) -302.035 (2.26396307e-06)
145301 EPS nconv=0 first unconverged value (error) -302.035 (2.08127738e-06)
145302 EPS nconv=0 first unconverged value (error) -302.035 (1.95947906e-06)
145303 EPS nconv=0 first unconverged value (error) -302.035 (1.95947906e-06)
145304 EPS nconv=0 first unconverged value (error) -302.035 (2.11993007e-06)
145305 EPS nconv=0 first unconverged value (error) -302.035 (2.07782608e-06)
145306 EPS nconv=0 first unconverged value (error) -302.035 (2.00558244e-06)
145307 EPS nconv=0 first unconverged value (error) -302.035 (1.95099501e-06)
145308 EPS nconv=0 first unconverged value (error) -302.035 (1.92910542e-06)
145309 EPS nconv=0 first unconverged value (error) -302.035 (1.92910542e-06)
145310 EPS nconv=0 first unconverged value (error) -302.035 (1.93198166e-06)
145311 EPS nconv=0 first unconverged value (error) -302.035 (2.04759866e-06)
145312 EPS nconv=0 first unconverged value (error) -302.035 (1.92418854e-06)
145313 EPS nconv=0 first unconverged value (error) -302.035 (1.84294012e-06)
145314 EPS nconv=0 first unconverged value (error) -302.035 (1.81537868e-06)
145315 EPS nconv=0 first unconverged value (error) -302.035 (1.81537868e-06)
145316 EPS nconv=0 first unconverged value (error) -302.035 (1.95646268e-06)
145317 EPS nconv=0 first unconverged value (error) -302.035 (1.91767821e-06)
145318 EPS nconv=0 first unconverged value (error) -302.035 (1.90495078e-06)
145319 EPS nconv=0 first unconverged value (error) -302.035 (1.89922495e-06)
145320 EPS nconv=0 first unconverged value (error) -302.035 (1.88047406e-06)
145321 EPS nconv=0 first unconverged value (error) -302.035 (1.88047406e-06)
145322 EPS nconv=0 first unconverged value (error) -302.035 (2.92757795e-06)
145323 EPS nconv=0 first unconverged value (error) -302.035 (2.59508054e-06)
145324 EPS nconv=0 first unconverged value (error) -302.035 (2.37732519e-06)
145325 EPS nconv=0 first unconverged value (error) -302.035 (2.32286908e-06)
145326 EPS nconv=0 first unconverged value (error) -302.035 (2.30461744e-06)
145327 EPS nconv=0 first unconverged value (error) -302.035 (2.30461744e-06)
145328 EPS nconv=0 first unconverged value (error) -302.035 (3.30711122e-06)
145329 EPS nconv=0 first unconverged value (error) -302.035 (3.13740337e-06)
145330 EPS nconv=0 first unconverged value (error) -302.035 (2.64438008e-06)
145331 EPS nconv=0 first unconverged value (error) -302.035 (2.53599016e-06)
145332 EPS nconv=0 first unconverged value (error) -302.035 (2.36489011e-06)
145333 EPS nconv=0 first unconverged value (error) -302.035 (2.36489011e-06)
145334 EPS nconv=0 first unconverged value (error) -302.035 (2.32122836e-06)
145335 EPS nconv=0 first unconverged value (error) -302.035 (2.72704766e-06)
145336 EPS nconv=0 first unconverged value (error) -302.035 (2.34023831e-06)
145337 EPS nconv=0 first unconverged value (error) -302.035 (1.90378203e-06)
145338 EPS nconv=0 first unconverged value (error) -302.035 (1.84909872e-06)
145339 EPS nconv=0 first unconverged value (error) -302.035 (1.84909872e-06)
145340 EPS nconv=0 first unconverged value (error) -302.035 (1.93589448e-06)
145341 EPS nconv=0 first unconverged value (error) -302.035 (1.90220917e-06)
145342 EPS nconv=0 first unconverged value (error) -302.035 (1.87941348e-06)
145343 EPS nconv=0 first unconverged value (error) -302.035 (1.86816778e-06)
145344 EPS nconv=0 first unconverged value (error) -302.035 (1.86234197e-06)
145345 EPS nconv=0 first unconverged value (error) -302.035 (1.86234197e-06)
145346 EPS nconv=0 first unconverged value (error) -302.035 (2.76056105e-06)
145347 EPS nconv=0 first unconverged value (error) -302.035 (2.56495835e-06)
145348 EPS nconv=0 first unconverged value (error) -302.035 (2.33887306e-06)
145349 EPS nconv=0 first unconverged value (error) -302.035 (2.19154782e-06)
145350 EPS nconv=0 first unconverged value (error) -302.035 (2.15381145e-06)
145351 EPS nconv=0 first unconverged value (error) -302.035 (2.15381145e-06)
145352 EPS nconv=0 first unconverged value (error) -302.035 (3.31951564e-06)
145353 EPS nconv=0 first unconverged value (error) -302.035 (3.25345055e-06)
145354 EPS nconv=0 first unconverged value (error) -302.035 (2.93823771e-06)
145355 EPS nconv=0 first unconverged value (error) -302.035 (2.82385278e-06)
145356 EPS nconv=0 first unconverged value (error) -302.035 (2.75112872e-06)
145357 EPS nconv=0 first unconverged value (error) -302.035 (2.75112872e-06)
145358 EPS nconv=0 first unconverged value (error) -302.035 (2.96346456e-06)
145359 EPS nconv=0 first unconverged value (error) -302.035 (2.50272670e-06)
145360 EPS nconv=0 first unconverged value (error) -302.035 (2.13571885e-06)
145361 EPS nconv=0 first unconverged value (error) -302.035 (2.00526277e-06)
145362 EPS nconv=0 first unconverged value (error) -302.035 (1.97986353e-06)
145363 EPS nconv=0 first unconverged value (error) -302.035 (1.97986353e-06)
145364 EPS nconv=0 first unconverged value (error) -302.035 (2.16459368e-06)
145365 EPS nconv=0 first unconverged value (error) -302.035 (2.16554479e-06)
145366 EPS nconv=0 first unconverged value (error) -302.035 (1.98247632e-06)
145367 EPS nconv=0 first unconverged value (error) -302.035 (1.92917767e-06)
145368 EPS nconv=0 first unconverged value (error) -302.035 (1.89458850e-06)
145369 EPS nconv=0 first unconverged value (error) -302.035 (1.89458850e-06)
145370 EPS nconv=0 first unconverged value (error) -302.035 (3.08596100e-06)
145371 EPS nconv=0 first unconverged value (error) -302.035 (2.77295529e-06)
145372 EPS nconv=0 first unconverged value (error) -302.035 (2.57420196e-06)
145373 EPS nconv=0 first unconverged value (error) -302.035 (2.46392891e-06)
145374 EPS nconv=0 first unconverged value (error) -302.035 (2.34345509e-06)
145375 EPS nconv=0 first unconverged value (error) -302.035 (2.34345509e-06)
145376 EPS nconv=0 first unconverged value (error) -302.035 (5.85282804e-06)
145377 EPS nconv=0 first unconverged value (error) -302.035 (5.18229699e-06)
145378 EPS nconv=0 first unconverged value (error) -302.035 (4.61371210e-06)
145379 EPS nconv=0 first unconverged value (error) -302.035 (4.49636514e-06)
145380 EPS nconv=0 first unconverged value (error) -302.035 (4.46301508e-06)
145381 EPS nconv=0 first unconverged value (error) -302.035 (4.46301508e-06)
145382 EPS nconv=0 first unconverged value (error) -302.035 (4.74916446e-06)
145383 EPS nconv=0 first unconverged value (error) -302.035 (4.41128975e-06)
145384 EPS nconv=0 first unconverged value (error) -302.035 (3.58088909e-06)
145385 EPS nconv=0 first unconverged value (error) -302.035 (3.25640018e-06)
145386 EPS nconv=0 first unconverged value (error) -302.035 (2.52420458e-06)
145387 EPS nconv=0 first unconverged value (error) -302.035 (2.52420458e-06)
145388 EPS nconv=0 first unconverged value (error) -302.035 (3.69462398e-06)
145389 EPS nconv=0 first unconverged value (error) -302.035 (3.83553940e-06)
145390 EPS nconv=0 first unconverged value (error) -302.035 (3.20647471e-06)
145391 EPS nconv=0 first unconverged value (error) -302.035 (2.70125448e-06)
145392 EPS nconv=0 first unconverged value (error) -302.035 (2.63802292e-06)
145393 EPS nconv=0 first unconverged value (error) -302.035 (2.63802292e-06)
145394 EPS nconv=0 first unconverged value (error) -302.035 (3.35155909e-06)
145395 EPS nconv=0 first unconverged value (error) -302.035 (3.47237145e-06)
145396 EPS nconv=0 first unconverged value (error) -302.035 (2.87175527e-06)
145397 EPS nconv=0 first unconverged value (error) -302.035 (2.58472779e-06)
145398 EPS nconv=0 first unconverged value (error) -302.035 (2.28004853e-06)
145399 EPS nconv=0 first unconverged value (error) -302.035 (2.28004853e-06)
145400 EPS nconv=0 first unconverged value (error) -302.035 (2.24303871e-06)
145401 EPS nconv=0 first unconverged value (error) -302.035 (2.43563011e-06)
145402 EPS nconv=0 first unconverged value (error) -302.035 (2.01369243e-06)
145403 EPS nconv=0 first unconverged value (error) -302.035 (1.92315371e-06)
145404 EPS nconv=0 first unconverged value (error) -302.035 (1.91595909e-06)
145405 EPS nconv=0 first unconverged value (error) -302.035 (1.91595909e-06)
145406 EPS nconv=0 first unconverged value (error) -302.035 (2.40883505e-06)
145407 EPS nconv=0 first unconverged value (error) -302.035 (2.15735850e-06)
145408 EPS nconv=0 first unconverged value (error) -302.035 (2.05274152e-06)
145409 EPS nconv=0 first unconverged value (error) -302.035 (2.02392955e-06)
145410 EPS nconv=0 first unconverged value (error) -302.035 (2.00221759e-06)
145411 EPS nconv=0 first unconverged value (error) -302.035 (2.00221759e-06)
145412 EPS nconv=0 first unconverged value (error) -302.035 (2.46170873e-06)
145413 EPS nconv=0 first unconverged value (error) -302.035 (2.46447015e-06)
145414 EPS nconv=0 first unconverged value (error) -302.035 (2.08773619e-06)
145415 EPS nconv=0 first unconverged value (error) -302.035 (2.03185227e-06)
145416 EPS nconv=0 first unconverged value (error) -302.035 (1.97503459e-06)
145417 EPS nconv=0 first unconverged value (error) -302.035 (1.97503459e-06)
145418 EPS nconv=0 first unconverged value (error) -302.035 (2.04462123e-06)
145419 EPS nconv=0 first unconverged value (error) -302.035 (2.18408665e-06)
145420 EPS nconv=0 first unconverged value (error) -302.035 (1.91763043e-06)
145421 EPS nconv=0 first unconverged value (error) -302.035 (1.88703669e-06)
145422 EPS nconv=0 first unconverged value (error) -302.035 (1.87728303e-06)
145423 EPS nconv=0 first unconverged value (error) -302.035 (1.87728303e-06)
145424 EPS nconv=0 first unconverged value (error) -302.035 (2.26475501e-06)
145425 EPS nconv=0 first unconverged value (error) -302.035 (2.14912787e-06)
145426 EPS nconv=0 first unconverged value (error) -302.035 (2.03673874e-06)
145427 EPS nconv=0 first unconverged value (error) -302.035 (2.00255388e-06)
145428 EPS nconv=0 first unconverged value (error) -302.035 (1.96207473e-06)
145429 EPS nconv=0 first unconverged value (error) -302.035 (1.96207473e-06)
145430 EPS nconv=0 first unconverged value (error) -302.035 (2.13211575e-06)
145431 EPS nconv=0 first unconverged value (error) -302.035 (2.21911279e-06)
145432 EPS nconv=0 first unconverged value (error) -302.035 (1.97776586e-06)
145433 EPS nconv=0 first unconverged value (error) -302.035 (1.93293007e-06)
145434 EPS nconv=0 first unconverged value (error) -302.035 (1.89951705e-06)
145435 EPS nconv=0 first unconverged value (error) -302.035 (1.89951705e-06)
145436 EPS nconv=0 first unconverged value (error) -302.035 (2.28414040e-06)
145437 EPS nconv=0 first unconverged value (error) -302.035 (2.20498964e-06)
145438 EPS nconv=0 first unconverged value (error) -302.035 (2.09668425e-06)
145439 EPS nconv=0 first unconverged value (error) -302.035 (2.03186061e-06)
145440 EPS nconv=0 first unconverged value (error) -302.035 (1.98904329e-06)
145441 EPS nconv=0 first unconverged value (error) -302.035 (1.98904329e-06)
145442 EPS nconv=0 first unconverged value (error) -302.035 (1.97146721e-06)
145443 EPS nconv=0 first unconverged value (error) -302.035 (2.11876720e-06)
145444 EPS nconv=0 first unconverged value (error) -302.035 (1.93220977e-06)
145445 EPS nconv=0 first unconverged value (error) -302.035 (1.84526560e-06)
145446 EPS nconv=0 first unconverged value (error) -302.035 (1.83763919e-06)
145447 EPS nconv=0 first unconverged value (error) -302.035 (1.83763919e-06)
145448 EPS nconv=0 first unconverged value (error) -302.035 (1.83072893e-06)
145449 EPS nconv=0 first unconverged value (error) -302.035 (1.81682628e-06)
145450 EPS nconv=0 first unconverged value (error) -302.035 (1.81395100e-06)
145451 EPS nconv=0 first unconverged value (error) -302.035 (1.81212346e-06)
145452 EPS nconv=0 first unconverged value (error) -302.035 (1.80921703e-06)
145453 EPS nconv=0 first unconverged value (error) -302.035 (1.80921703e-06)
145454 EPS nconv=0 first unconverged value (error) -302.035 (1.87434238e-06)
145455 EPS nconv=0 first unconverged value (error) -302.035 (1.85288021e-06)
145456 EPS nconv=0 first unconverged value (error) -302.035 (1.83243557e-06)
145457 EPS nconv=0 first unconverged value (error) -302.035 (1.83138900e-06)
145458 EPS nconv=0 first unconverged value (error) -302.035 (1.82267883e-06)
145459 EPS nconv=0 first unconverged value (error) -302.035 (1.82267883e-06)
145460 EPS nconv=0 first unconverged value (error) -302.035 (2.54856502e-06)
145461 EPS nconv=0 first unconverged value (error) -302.035 (2.34292952e-06)
145462 EPS nconv=0 first unconverged value (error) -302.035 (2.17746731e-06)
145463 EPS nconv=0 first unconverged value (error) -302.035 (2.16776971e-06)
145464 EPS nconv=0 first unconverged value (error) -302.035 (2.11802034e-06)
145465 EPS nconv=0 first unconverged value (error) -302.035 (2.11802034e-06)
145466 EPS nconv=0 first unconverged value (error) -302.035 (3.56695613e-06)
145467 EPS nconv=0 first unconverged value (error) -302.035 (3.54220936e-06)
145468 EPS nconv=0 first unconverged value (error) -302.035 (3.04285982e-06)
145469 EPS nconv=0 first unconverged value (error) -302.035 (3.05906628e-06)
145470 EPS nconv=0 first unconverged value (error) -302.035 (2.98073980e-06)
145471 EPS nconv=0 first unconverged value (error) -302.035 (2.98073980e-06)
145472 EPS nconv=0 first unconverged value (error) -302.035 (2.92190027e-06)
145473 EPS nconv=0 first unconverged value (error) -302.035 (2.79256889e-06)
145474 EPS nconv=0 first unconverged value (error) -302.035 (2.82673392e-06)
145475 EPS nconv=0 first unconverged value (error) -302.035 (2.10865065e-06)
145476 EPS nconv=0 first unconverged value (error) -302.035 (1.89943183e-06)
145477 EPS nconv=0 first unconverged value (error) -302.035 (1.89943183e-06)
145478 EPS nconv=0 first unconverged value (error) -302.035 (2.37965730e-06)
145479 EPS nconv=0 first unconverged value (error) -302.035 (2.22978786e-06)
145480 EPS nconv=0 first unconverged value (error) -302.035 (2.11087043e-06)
145481 EPS nconv=0 first unconverged value (error) -302.035 (2.03080681e-06)
145482 EPS nconv=0 first unconverged value (error) -302.035 (2.01877958e-06)
145483 EPS nconv=0 first unconverged value (error) -302.035 (2.01877958e-06)
145484 EPS nconv=0 first unconverged value (error) -302.035 (2.17675960e-06)
145485 EPS nconv=0 first unconverged value (error) -302.035 (2.13238886e-06)
145486 EPS nconv=0 first unconverged value (error) -302.035 (2.01186166e-06)
145487 EPS nconv=0 first unconverged value (error) -302.035 (1.99439780e-06)
145488 EPS nconv=0 first unconverged value (error) -302.035 (1.91479852e-06)
145489 EPS nconv=0 first unconverged value (error) -302.035 (1.91479852e-06)
145490 EPS nconv=0 first unconverged value (error) -302.035 (1.91567176e-06)
145491 EPS nconv=0 first unconverged value (error) -302.035 (1.98160152e-06)
145492 EPS nconv=0 first unconverged value (error) -302.035 (1.87187254e-06)
145493 EPS nconv=0 first unconverged value (error) -302.035 (1.83840054e-06)
145494 EPS nconv=0 first unconverged value (error) -302.035 (1.84393681e-06)
145495 EPS nconv=0 first unconverged value (error) -302.035 (1.84393681e-06)
145496 EPS nconv=0 first unconverged value (error) -302.035 (1.86770358e-06)
145497 EPS nconv=0 first unconverged value (error) -302.035 (1.83770223e-06)
145498 EPS nconv=0 first unconverged value (error) -302.035 (1.83317401e-06)
145499 EPS nconv=0 first unconverged value (error) -302.035 (1.81822584e-06)
145500 EPS nconv=0 first unconverged value (error) -302.035 (1.81298740e-06)
145501 EPS nconv=0 first unconverged value (error) -302.035 (1.81298740e-06)
145502 EPS nconv=0 first unconverged value (error) -302.035 (1.87506153e-06)
145503 EPS nconv=0 first unconverged value (error) -302.035 (1.88740222e-06)
145504 EPS nconv=0 first unconverged value (error) -302.035 (1.84818638e-06)
145505 EPS nconv=0 first unconverged value (error) -302.035 (1.83011818e-06)
145506 EPS nconv=0 first unconverged value (error) -302.035 (1.82236312e-06)
145507 EPS nconv=0 first unconverged value (error) -302.035 (1.82236312e-06)
145508 EPS nconv=0 first unconverged value (error) -302.035 (2.27341284e-06)
145509 EPS nconv=0 first unconverged value (error) -302.035 (2.09905652e-06)
145510 EPS nconv=0 first unconverged value (error) -302.035 (2.04693358e-06)
145511 EPS nconv=0 first unconverged value (error) -302.035 (2.05324348e-06)
145512 EPS nconv=0 first unconverged value (error) -302.035 (1.98873195e-06)
145513 EPS nconv=0 first unconverged value (error) -302.035 (1.98873195e-06)
145514 EPS nconv=0 first unconverged value (error) -302.035 (4.35465814e-06)
145515 EPS nconv=0 first unconverged value (error) -302.035 (3.94940712e-06)
145516 EPS nconv=0 first unconverged value (error) -302.035 (3.55894573e-06)
145517 EPS nconv=0 first unconverged value (error) -302.035 (3.39768823e-06)
145518 EPS nconv=0 first unconverged value (error) -302.035 (3.36764532e-06)
145519 EPS nconv=0 first unconverged value (error) -302.035 (3.36764532e-06)
145520 EPS nconv=0 first unconverged value (error) -302.035 (3.31162743e-06)
145521 EPS nconv=0 first unconverged value (error) -302.035 (3.46284038e-06)
145522 EPS nconv=0 first unconverged value (error) -302.035 (2.93910538e-06)
145523 EPS nconv=0 first unconverged value (error) -302.035 (2.35866614e-06)
145524 EPS nconv=0 first unconverged value (error) -302.035 (2.21055221e-06)
145525 EPS nconv=0 first unconverged value (error) -302.035 (2.21055221e-06)
145526 EPS nconv=0 first unconverged value (error) -302.035 (2.90126228e-06)
145527 EPS nconv=0 first unconverged value (error) -302.035 (2.54339428e-06)
145528 EPS nconv=0 first unconverged value (error) -302.035 (2.46553074e-06)
145529 EPS nconv=0 first unconverged value (error) -302.035 (2.33864033e-06)
145530 EPS nconv=0 first unconverged value (error) -302.035 (2.26806456e-06)
145531 EPS nconv=0 first unconverged value (error) -302.035 (2.26806456e-06)
145532 EPS nconv=0 first unconverged value (error) -302.035 (6.05125298e-06)
145533 EPS nconv=0 first unconverged value (error) -302.035 (5.20428525e-06)
145534 EPS nconv=0 first unconverged value (error) -302.035 (4.68912300e-06)
145535 EPS nconv=0 first unconverged value (error) -302.035 (4.73329545e-06)
145536 EPS nconv=0 first unconverged value (error) -302.035 (4.59042523e-06)
145537 EPS nconv=0 first unconverged value (error) -302.035 (4.59042523e-06)
145538 EPS nconv=0 first unconverged value (error) -302.035 (5.87350099e-06)
145539 EPS nconv=0 first unconverged value (error) -302.035 (5.23262675e-06)
145540 EPS nconv=0 first unconverged value (error) -302.035 (3.91882316e-06)
145541 EPS nconv=0 first unconverged value (error) -302.035 (3.67628427e-06)
145542 EPS nconv=0 first unconverged value (error) -302.035 (3.65561101e-06)
145543 EPS nconv=0 first unconverged value (error) -302.035 (3.65561101e-06)
145544 EPS nconv=0 first unconverged value (error) -302.035 (4.24282152e-06)
145545 EPS nconv=0 first unconverged value (error) -302.035 (4.11577044e-06)
145546 EPS nconv=0 first unconverged value (error) -302.035 (3.60564956e-06)
145547 EPS nconv=0 first unconverged value (error) -302.035 (2.64254996e-06)
145548 EPS nconv=0 first unconverged value (error) -302.035 (2.32409496e-06)
145549 EPS nconv=0 first unconverged value (error) -302.035 (2.32409496e-06)
145550 EPS nconv=0 first unconverged value (error) -302.035 (2.28958750e-06)
145551 EPS nconv=0 first unconverged value (error) -302.035 (2.73517175e-06)
145552 EPS nconv=0 first unconverged value (error) -302.035 (2.23625739e-06)
145553 EPS nconv=0 first unconverged value (error) -302.035 (1.98299213e-06)
145554 EPS nconv=0 first unconverged value (error) -302.035 (1.95081843e-06)
145555 EPS nconv=0 first unconverged value (error) -302.035 (1.95081843e-06)
145556 EPS nconv=0 first unconverged value (error) -302.035 (2.53230266e-06)
145557 EPS nconv=0 first unconverged value (error) -302.035 (2.33273506e-06)
145558 EPS nconv=0 first unconverged value (error) -302.035 (2.18127209e-06)
145559 EPS nconv=0 first unconverged value (error) -302.035 (2.17415857e-06)
145560 EPS nconv=0 first unconverged value (error) -302.035 (2.09887416e-06)
145561 EPS nconv=0 first unconverged value (error) -302.035 (2.09887416e-06)
145562 EPS nconv=0 first unconverged value (error) -302.035 (2.68844968e-06)
145563 EPS nconv=0 first unconverged value (error) -302.035 (2.56638147e-06)
145564 EPS nconv=0 first unconverged value (error) -302.035 (2.18781571e-06)
145565 EPS nconv=0 first unconverged value (error) -302.035 (2.15424626e-06)
145566 EPS nconv=0 first unconverged value (error) -302.035 (2.13460784e-06)
145567 EPS nconv=0 first unconverged value (error) -302.035 (2.13460784e-06)
145568 EPS nconv=0 first unconverged value (error) -302.035 (2.13014578e-06)
145569 EPS nconv=0 first unconverged value (error) -302.035 (2.24524285e-06)
145570 EPS nconv=0 first unconverged value (error) -302.035 (2.08219983e-06)
145571 EPS nconv=0 first unconverged value (error) -302.035 (1.90975588e-06)
145572 EPS nconv=0 first unconverged value (error) -302.035 (1.86417879e-06)
145573 EPS nconv=0 first unconverged value (error) -302.035 (1.86417879e-06)
145574 EPS nconv=0 first unconverged value (error) -302.035 (1.90589981e-06)
145575 EPS nconv=0 first unconverged value (error) -302.035 (1.90159202e-06)
145576 EPS nconv=0 first unconverged value (error) -302.035 (1.87285757e-06)
145577 EPS nconv=0 first unconverged value (error) -302.035 (1.85376027e-06)
145578 EPS nconv=0 first unconverged value (error) -302.035 (1.84323040e-06)
145579 EPS nconv=0 first unconverged value (error) -302.035 (1.84323040e-06)
145580 EPS nconv=0 first unconverged value (error) -302.035 (1.92881942e-06)
145581 EPS nconv=0 first unconverged value (error) -302.035 (1.90779038e-06)
145582 EPS nconv=0 first unconverged value (error) -302.035 (1.85741781e-06)
145583 EPS nconv=0 first unconverged value (error) -302.035 (1.85357007e-06)
145584 EPS nconv=0 first unconverged value (error) -302.035 (1.84284102e-06)
145585 EPS nconv=0 first unconverged value (error) -302.035 (1.84284102e-06)
145586 EPS nconv=0 first unconverged value (error) -302.035 (2.39763355e-06)
145587 EPS nconv=0 first unconverged value (error) -302.035 (2.18948937e-06)
145588 EPS nconv=0 first unconverged value (error) -302.035 (2.06238047e-06)
145589 EPS nconv=0 first unconverged value (error) -302.035 (2.04044856e-06)
145590 EPS nconv=0 first unconverged value (error) -302.035 (2.00694214e-06)
145591 EPS nconv=0 first unconverged value (error) -302.035 (2.00694214e-06)
145592 EPS nconv=0 first unconverged value (error) -302.035 (2.60434311e-06)
145593 EPS nconv=0 first unconverged value (error) -302.035 (2.46304795e-06)
145594 EPS nconv=0 first unconverged value (error) -302.035 (2.20234553e-06)
145595 EPS nconv=0 first unconverged value (error) -302.035 (2.09904817e-06)
145596 EPS nconv=0 first unconverged value (error) -302.035 (2.05175449e-06)
145597 EPS nconv=0 first unconverged value (error) -302.035 (2.05175449e-06)
145598 EPS nconv=0 first unconverged value (error) -302.035 (2.37253624e-06)
145599 EPS nconv=0 first unconverged value (error) -302.035 (2.44607525e-06)
145600 EPS nconv=0 first unconverged value (error) -302.035 (2.15360677e-06)
145601 EPS nconv=0 first unconverged value (error) -302.035 (2.11327289e-06)
145602 EPS nconv=0 first unconverged value (error) -302.035 (2.02143261e-06)
145603 EPS nconv=0 first unconverged value (error) -302.035 (2.02143261e-06)
145604 EPS nconv=0 first unconverged value (error) -302.035 (3.15769240e-06)
145605 EPS nconv=0 first unconverged value (error) -302.035 (2.93977638e-06)
145606 EPS nconv=0 first unconverged value (error) -302.035 (2.66972963e-06)
145607 EPS nconv=0 first unconverged value (error) -302.035 (2.59974941e-06)
145608 EPS nconv=0 first unconverged value (error) -302.035 (2.45333186e-06)
145609 EPS nconv=0 first unconverged value (error) -302.035 (2.45333186e-06)
145610 EPS nconv=0 first unconverged value (error) -302.035 (2.79453420e-06)
145611 EPS nconv=0 first unconverged value (error) -302.035 (2.68374162e-06)
145612 EPS nconv=0 first unconverged value (error) -302.035 (2.35583838e-06)
145613 EPS nconv=0 first unconverged value (error) -302.035 (2.19297709e-06)
145614 EPS nconv=0 first unconverged value (error) -302.035 (2.18980773e-06)
145615 EPS nconv=0 first unconverged value (error) -302.035 (2.18980773e-06)
145616 EPS nconv=0 first unconverged value (error) -302.035 (2.59223211e-06)
145617 EPS nconv=0 first unconverged value (error) -302.035 (2.44971521e-06)
145618 EPS nconv=0 first unconverged value (error) -302.035 (2.24514264e-06)
145619 EPS nconv=0 first unconverged value (error) -302.035 (2.06741845e-06)
145620 EPS nconv=0 first unconverged value (error) -302.035 (2.00638083e-06)
145621 EPS nconv=0 first unconverged value (error) -302.035 (2.00638083e-06)
145622 EPS nconv=0 first unconverged value (error) -302.035 (3.99558584e-06)
145623 EPS nconv=0 first unconverged value (error) -302.035 (3.61872190e-06)
145624 EPS nconv=0 first unconverged value (error) -302.035 (3.09155285e-06)
145625 EPS nconv=0 first unconverged value (error) -302.035 (3.04185108e-06)
145626 EPS nconv=0 first unconverged value (error) -302.035 (2.89037019e-06)
145627 EPS nconv=0 first unconverged value (error) -302.035 (2.89037019e-06)
145628 EPS nconv=0 first unconverged value (error) -302.035 (3.59753133e-06)
145629 EPS nconv=0 first unconverged value (error) -302.035 (3.71657085e-06)
145630 EPS nconv=0 first unconverged value (error) -302.035 (3.06840174e-06)
145631 EPS nconv=0 first unconverged value (error) -302.035 (2.86341155e-06)
145632 EPS nconv=0 first unconverged value (error) -302.035 (2.76039663e-06)
145633 EPS nconv=0 first unconverged value (error) -302.035 (2.76039663e-06)
145634 EPS nconv=0 first unconverged value (error) -302.035 (3.27409041e-06)
145635 EPS nconv=0 first unconverged value (error) -302.035 (3.19039147e-06)
145636 EPS nconv=0 first unconverged value (error) -302.035 (2.84836607e-06)
145637 EPS nconv=0 first unconverged value (error) -302.035 (2.28468820e-06)
145638 EPS nconv=0 first unconverged value (error) -302.035 (2.16461799e-06)
145639 EPS nconv=0 first unconverged value (error) -302.035 (2.16461799e-06)
145640 EPS nconv=0 first unconverged value (error) -302.035 (2.83362126e-06)
145641 EPS nconv=0 first unconverged value (error) -302.035 (2.81712498e-06)
145642 EPS nconv=0 first unconverged value (error) -302.035 (2.58370025e-06)
145643 EPS nconv=0 first unconverged value (error) -302.035 (2.28384489e-06)
145644 EPS nconv=0 first unconverged value (error) -302.035 (2.25890636e-06)
145645 EPS nconv=0 first unconverged value (error) -302.035 (2.25890636e-06)
145646 EPS nconv=0 first unconverged value (error) -302.035 (2.18815736e-06)
145647 EPS nconv=0 first unconverged value (error) -302.035 (2.47940355e-06)
145648 EPS nconv=0 first unconverged value (error) -302.035 (2.13689783e-06)
145649 EPS nconv=0 first unconverged value (error) -302.035 (1.96497705e-06)
145650 EPS nconv=0 first unconverged value (error) -302.035 (1.83759698e-06)
145651 EPS nconv=0 first unconverged value (error) -302.035 (1.83759698e-06)
145652 EPS nconv=0 first unconverged value (error) -302.035 (1.20455685e-05)
145653 EPS nconv=0 first unconverged value (error) -302.035 (1.12630819e-05)
145654 EPS nconv=0 first unconverged value (error) -302.035 (9.99905363e-06)
145655 EPS nconv=0 first unconverged value (error) -302.035 (9.52392106e-06)
145656 EPS nconv=0 first unconverged value (error) -302.035 (8.89810544e-06)
145657 EPS nconv=0 first unconverged value (error) -302.035 (8.89810544e-06)
145658 EPS nconv=0 first unconverged value (error) -302.035 (9.80661723e-06)
145659 EPS nconv=0 first unconverged value (error) -302.035 (8.71205241e-06)
145660 EPS nconv=0 first unconverged value (error) -302.035 (7.11898407e-06)
145661 EPS nconv=0 first unconverged value (error) -302.035 (5.50397829e-06)
145662 EPS nconv=0 first unconverged value (error) -302.035 (4.80154692e-06)
145663 EPS nconv=0 first unconverged value (error) -302.035 (4.80154692e-06)
145664 EPS nconv=0 first unconverged value (error) -302.035 (5.36669385e-06)
145665 EPS nconv=0 first unconverged value (error) -302.035 (5.42729583e-06)
145666 EPS nconv=0 first unconverged value (error) -302.035 (4.03353639e-06)
145667 EPS nconv=0 first unconverged value (error) -302.035 (3.38780642e-06)
145668 EPS nconv=0 first unconverged value (error) -302.035 (3.27174166e-06)
145669 EPS nconv=0 first unconverged value (error) -302.035 (3.27174166e-06)
145670 EPS nconv=0 first unconverged value (error) -302.035 (3.33858226e-06)
145671 EPS nconv=0 first unconverged value (error) -302.035 (4.15006278e-06)
145672 EPS nconv=0 first unconverged value (error) -302.035 (2.85515336e-06)
145673 EPS nconv=0 first unconverged value (error) -302.035 (2.41966813e-06)
145674 EPS nconv=0 first unconverged value (error) -302.035 (2.18267220e-06)
145675 EPS nconv=0 first unconverged value (error) -302.035 (2.18267220e-06)
145676 EPS nconv=0 first unconverged value (error) -302.035 (1.15755164e-05)
145677 EPS nconv=0 first unconverged value (error) -302.035 (9.76207157e-06)
145678 EPS nconv=0 first unconverged value (error) -302.035 (8.69569733e-06)
145679 EPS nconv=0 first unconverged value (error) -302.035 (8.55979732e-06)
145680 EPS nconv=0 first unconverged value (error) -302.035 (7.85090646e-06)
145681 EPS nconv=0 first unconverged value (error) -302.035 (7.85090646e-06)
145682 EPS nconv=0 first unconverged value (error) -302.035 (1.09226034e-05)
145683 EPS nconv=0 first unconverged value (error) -302.035 (1.05599703e-05)
145684 EPS nconv=0 first unconverged value (error) -302.035 (8.23781875e-06)
145685 EPS nconv=0 first unconverged value (error) -302.035 (7.24446082e-06)
145686 EPS nconv=0 first unconverged value (error) -302.035 (7.17945128e-06)
145687 EPS nconv=0 first unconverged value (error) -302.035 (7.17945128e-06)
145688 EPS nconv=0 first unconverged value (error) -302.035 (7.09141900e-06)
145689 EPS nconv=0 first unconverged value (error) -302.035 (5.90360603e-06)
145690 EPS nconv=0 first unconverged value (error) -302.035 (5.13435451e-06)
145691 EPS nconv=0 first unconverged value (error) -302.035 (3.56225681e-06)
145692 EPS nconv=0 first unconverged value (error) -302.035 (2.73314116e-06)
145693 EPS nconv=0 first unconverged value (error) -302.035 (2.73314116e-06)
145694 EPS nconv=0 first unconverged value (error) -302.035 (2.48366164e-06)
145695 EPS nconv=0 first unconverged value (error) -302.035 (2.15491278e-06)
145696 EPS nconv=0 first unconverged value (error) -302.035 (1.92515735e-06)
145697 EPS nconv=0 first unconverged value (error) -302.035 (1.84804180e-06)
145698 EPS nconv=0 first unconverged value (error) -302.035 (1.83677051e-06)
145699 EPS nconv=0 first unconverged value (error) -302.035 (1.83677051e-06)
145700 EPS nconv=0 first unconverged value (error) -302.035 (5.77410064e-06)
145701 EPS nconv=0 first unconverged value (error) -302.035 (4.38219097e-06)
145702 EPS nconv=0 first unconverged value (error) -302.035 (3.87056394e-06)
145703 EPS nconv=0 first unconverged value (error) -302.035 (3.60281283e-06)
145704 EPS nconv=0 first unconverged value (error) -302.035 (3.53052476e-06)
145705 EPS nconv=0 first unconverged value (error) -302.035 (3.53052476e-06)
145706 EPS nconv=0 first unconverged value (error) -302.035 (7.87367565e-06)
145707 EPS nconv=0 first unconverged value (error) -302.035 (6.95022274e-06)
145708 EPS nconv=0 first unconverged value (error) -302.035 (5.76252689e-06)
145709 EPS nconv=0 first unconverged value (error) -302.035 (5.65466310e-06)
145710 EPS nconv=0 first unconverged value (error) -302.035 (5.29184937e-06)
145711 EPS nconv=0 first unconverged value (error) -302.035 (5.29184937e-06)
145712 EPS nconv=0 first unconverged value (error) -302.035 (5.46502605e-06)
145713 EPS nconv=0 first unconverged value (error) -302.035 (6.04415944e-06)
145714 EPS nconv=0 first unconverged value (error) -302.035 (4.48832682e-06)
145715 EPS nconv=0 first unconverged value (error) -302.035 (3.84568752e-06)
145716 EPS nconv=0 first unconverged value (error) -302.035 (2.92803223e-06)
145717 EPS nconv=0 first unconverged value (error) -302.035 (2.92803223e-06)
145718 EPS nconv=0 first unconverged value (error) -302.035 (7.28812389e-06)
145719 EPS nconv=0 first unconverged value (error) -302.035 (7.19547286e-06)
145720 EPS nconv=0 first unconverged value (error) -302.035 (5.50099165e-06)
145721 EPS nconv=0 first unconverged value (error) -302.035 (4.83749352e-06)
145722 EPS nconv=0 first unconverged value (error) -302.035 (4.67103378e-06)
145723 EPS nconv=0 first unconverged value (error) -302.035 (4.67103378e-06)
145724 EPS nconv=0 first unconverged value (error) -302.035 (9.45572734e-06)
145725 EPS nconv=0 first unconverged value (error) -302.035 (8.91396622e-06)
145726 EPS nconv=0 first unconverged value (error) -302.035 (7.74452538e-06)
145727 EPS nconv=0 first unconverged value (error) -302.035 (7.46983803e-06)
145728 EPS nconv=0 first unconverged value (error) -302.035 (7.24884843e-06)
145729 EPS nconv=0 first unconverged value (error) -302.035 (7.24884843e-06)
145730 EPS nconv=0 first unconverged value (error) -302.035 (7.28964920e-06)
145731 EPS nconv=0 first unconverged value (error) -302.035 (6.27317865e-06)
145732 EPS nconv=0 first unconverged value (error) -302.035 (5.60250624e-06)
145733 EPS nconv=0 first unconverged value (error) -302.035 (4.05422438e-06)
145734 EPS nconv=0 first unconverged value (error) -302.035 (2.97741720e-06)
145735 EPS nconv=0 first unconverged value (error) -302.035 (2.97741720e-06)
145736 EPS nconv=0 first unconverged value (error) -302.035 (6.25842551e-06)
145737 EPS nconv=0 first unconverged value (error) -302.035 (5.50093963e-06)
145738 EPS nconv=0 first unconverged value (error) -302.035 (4.31849219e-06)
145739 EPS nconv=0 first unconverged value (error) -302.035 (4.21474448e-06)
145740 EPS nconv=0 first unconverged value (error) -302.035 (3.99089736e-06)
145741 EPS nconv=0 first unconverged value (error) -302.035 (3.99089736e-06)
145742 EPS nconv=0 first unconverged value (error) -302.035 (5.92477448e-06)
145743 EPS nconv=0 first unconverged value (error) -302.035 (6.12650779e-06)
145744 EPS nconv=0 first unconverged value (error) -302.035 (4.97032138e-06)
145745 EPS nconv=0 first unconverged value (error) -302.035 (4.33017290e-06)
145746 EPS nconv=0 first unconverged value (error) -302.035 (4.05446376e-06)
145747 EPS nconv=0 first unconverged value (error) -302.035 (4.05446376e-06)
145748 EPS nconv=0 first unconverged value (error) -302.035 (6.05086846e-06)
145749 EPS nconv=0 first unconverged value (error) -302.035 (5.41864352e-06)
145750 EPS nconv=0 first unconverged value (error) -302.035 (4.43810930e-06)
145751 EPS nconv=0 first unconverged value (error) -302.035 (4.16894157e-06)
145752 EPS nconv=0 first unconverged value (error) -302.035 (4.05418229e-06)
145753 EPS nconv=0 first unconverged value (error) -302.035 (4.05418229e-06)
145754 EPS nconv=0 first unconverged value (error) -302.035 (3.86138162e-06)
145755 EPS nconv=0 first unconverged value (error) -302.035 (3.92714323e-06)
145756 EPS nconv=0 first unconverged value (error) -302.035 (3.29552715e-06)
145757 EPS nconv=0 first unconverged value (error) -302.035 (2.42566695e-06)
145758 EPS nconv=0 first unconverged value (error) -302.035 (2.29776921e-06)
145759 EPS nconv=0 first unconverged value (error) -302.035 (2.29776921e-06)
145760 EPS nconv=0 first unconverged value (error) -302.035 (1.97627824e-06)
145761 EPS nconv=0 first unconverged value (error) -302.035 (2.12048322e-06)
145762 EPS nconv=0 first unconverged value (error) -302.035 (1.93687870e-06)
145763 EPS nconv=0 first unconverged value (error) -302.035 (1.85522753e-06)
145764 EPS nconv=0 first unconverged value (error) -302.035 (1.81893812e-06)
145765 EPS nconv=0 first unconverged value (error) -302.035 (1.81893812e-06)
145766 EPS nconv=0 first unconverged value (error) -302.035 (3.89843659e-06)
145767 EPS nconv=0 first unconverged value (error) -302.035 (3.70781767e-06)
145768 EPS nconv=0 first unconverged value (error) -302.035 (3.33058468e-06)
145769 EPS nconv=0 first unconverged value (error) -302.035 (3.13436994e-06)
145770 EPS nconv=0 first unconverged value (error) -302.035 (3.00437163e-06)
145771 EPS nconv=0 first unconverged value (error) -302.035 (3.00437163e-06)
145772 EPS nconv=0 first unconverged value (error) -302.035 (8.73848369e-06)
145773 EPS nconv=0 first unconverged value (error) -302.035 (7.53056230e-06)
145774 EPS nconv=0 first unconverged value (error) -302.035 (6.23603410e-06)
145775 EPS nconv=0 first unconverged value (error) -302.035 (6.05305800e-06)
145776 EPS nconv=0 first unconverged value (error) -302.035 (5.96504518e-06)
145777 EPS nconv=0 first unconverged value (error) -302.035 (5.96504518e-06)
145778 EPS nconv=0 first unconverged value (error) -302.035 (9.20412368e-06)
145779 EPS nconv=0 first unconverged value (error) -302.035 (8.65301599e-06)
145780 EPS nconv=0 first unconverged value (error) -302.035 (7.13659587e-06)
145781 EPS nconv=0 first unconverged value (error) -302.035 (7.03981151e-06)
145782 EPS nconv=0 first unconverged value (error) -302.035 (5.31958878e-06)
145783 EPS nconv=0 first unconverged value (error) -302.035 (5.31958878e-06)
145784 EPS nconv=0 first unconverged value (error) -302.035 (7.00089567e-06)
145785 EPS nconv=0 first unconverged value (error) -302.035 (7.09221021e-06)
145786 EPS nconv=0 first unconverged value (error) -302.035 (5.31908518e-06)
145787 EPS nconv=0 first unconverged value (error) -302.035 (4.84306773e-06)
145788 EPS nconv=0 first unconverged value (error) -302.035 (4.60453287e-06)
145789 EPS nconv=0 first unconverged value (error) -302.035 (4.60453287e-06)
145790 EPS nconv=0 first unconverged value (error) -302.035 (6.91799663e-06)
145791 EPS nconv=0 first unconverged value (error) -302.035 (5.71602528e-06)
145792 EPS nconv=0 first unconverged value (error) -302.035 (4.90636642e-06)
145793 EPS nconv=0 first unconverged value (error) -302.035 (4.67856409e-06)
145794 EPS nconv=0 first unconverged value (error) -302.035 (4.50331523e-06)
145795 EPS nconv=0 first unconverged value (error) -302.035 (4.50331523e-06)
145796 EPS nconv=0 first unconverged value (error) -302.035 (6.45592648e-06)
145797 EPS nconv=0 first unconverged value (error) -302.035 (6.52818503e-06)
145798 EPS nconv=0 first unconverged value (error) -302.035 (4.99201468e-06)
145799 EPS nconv=0 first unconverged value (error) -302.035 (4.49266091e-06)
145800 EPS nconv=0 first unconverged value (error) -302.035 (4.10936255e-06)
145801 EPS nconv=0 first unconverged value (error) -302.035 (4.10936255e-06)
145802 EPS nconv=0 first unconverged value (error) -302.035 (4.96325874e-06)
145803 EPS nconv=0 first unconverged value (error) -302.035 (4.40091188e-06)
145804 EPS nconv=0 first unconverged value (error) -302.035 (3.87903281e-06)
145805 EPS nconv=0 first unconverged value (error) -302.035 (3.43976688e-06)
145806 EPS nconv=0 first unconverged value (error) -302.035 (3.12773780e-06)
145807 EPS nconv=0 first unconverged value (error) -302.035 (3.12773780e-06)
145808 EPS nconv=0 first unconverged value (error) -302.035 (5.76539671e-06)
145809 EPS nconv=0 first unconverged value (error) -302.035 (5.26863631e-06)
145810 EPS nconv=0 first unconverged value (error) -302.035 (4.49513567e-06)
145811 EPS nconv=0 first unconverged value (error) -302.035 (4.36130055e-06)
145812 EPS nconv=0 first unconverged value (error) -302.035 (4.37550063e-06)
145813 EPS nconv=0 first unconverged value (error) -302.035 (4.37550063e-06)
145814 EPS nconv=0 first unconverged value (error) -302.035 (5.23045394e-06)
145815 EPS nconv=0 first unconverged value (error) -302.035 (4.65368274e-06)
145816 EPS nconv=0 first unconverged value (error) -302.035 (3.91679531e-06)
145817 EPS nconv=0 first unconverged value (error) -302.035 (3.68746855e-06)
145818 EPS nconv=0 first unconverged value (error) -302.035 (2.84207382e-06)
145819 EPS nconv=0 first unconverged value (error) -302.035 (2.84207382e-06)
145820 EPS nconv=0 first unconverged value (error) -302.035 (2.58539674e-06)
145821 EPS nconv=0 first unconverged value (error) -302.035 (3.44251894e-06)
145822 EPS nconv=0 first unconverged value (error) -302.035 (2.46900780e-06)
145823 EPS nconv=0 first unconverged value (error) -302.035 (1.99201414e-06)
145824 EPS nconv=0 first unconverged value (error) -302.035 (1.92532913e-06)
145825 EPS nconv=0 first unconverged value (error) -302.035 (1.92532913e-06)
145826 EPS nconv=0 first unconverged value (error) -302.035 (1.80781051e-06)
145827 EPS nconv=0 first unconverged value (error) -302.035 (1.79734242e-06)
145828 EPS nconv=0 first unconverged value (error) -302.035 (1.79707543e-06)
145829 EPS nconv=0 first unconverged value (error) -302.035 (1.79651758e-06)
145830 EPS nconv=0 first unconverged value (error) -302.035 (1.79611575e-06)
145831 EPS nconv=0 first unconverged value (error) -302.035 (1.79611575e-06)
145832 EPS nconv=0 first unconverged value (error) -302.035 (2.01661012e-06)
145833 EPS nconv=0 first unconverged value (error) -302.035 (1.91320144e-06)
145834 EPS nconv=0 first unconverged value (error) -302.035 (1.88581461e-06)
145835 EPS nconv=0 first unconverged value (error) -302.035 (1.86361333e-06)
145836 EPS nconv=0 first unconverged value (error) -302.035 (1.86188911e-06)
145837 EPS nconv=0 first unconverged value (error) -302.035 (1.86188911e-06)
145838 EPS nconv=0 first unconverged value (error) -302.035 (1.91669785e-06)
145839 EPS nconv=0 first unconverged value (error) -302.035 (1.94835007e-06)
145840 EPS nconv=0 first unconverged value (error) -302.035 (1.86478686e-06)
145841 EPS nconv=0 first unconverged value (error) -302.035 (1.83986391e-06)
145842 EPS nconv=0 first unconverged value (error) -302.035 (1.82324275e-06)
145843 EPS nconv=0 first unconverged value (error) -302.035 (1.82324275e-06)
145844 EPS nconv=0 first unconverged value (error) -302.035 (2.85812090e-06)
145845 EPS nconv=0 first unconverged value (error) -302.035 (2.78370120e-06)
145846 EPS nconv=0 first unconverged value (error) -302.035 (2.61322763e-06)
145847 EPS nconv=0 first unconverged value (error) -302.035 (2.53226928e-06)
145848 EPS nconv=0 first unconverged value (error) -302.035 (2.49804352e-06)
145849 EPS nconv=0 first unconverged value (error) -302.035 (2.49804352e-06)
145850 EPS nconv=0 first unconverged value (error) -302.035 (3.12258043e-06)
145851 EPS nconv=0 first unconverged value (error) -302.035 (2.62091820e-06)
145852 EPS nconv=0 first unconverged value (error) -302.035 (2.35714693e-06)
145853 EPS nconv=0 first unconverged value (error) -302.035 (2.30608317e-06)
145854 EPS nconv=0 first unconverged value (error) -302.035 (2.28951947e-06)
145855 EPS nconv=0 first unconverged value (error) -302.035 (2.28951947e-06)
145856 EPS nconv=0 first unconverged value (error) -302.035 (3.11478377e-06)
145857 EPS nconv=0 first unconverged value (error) -302.035 (2.92073003e-06)
145858 EPS nconv=0 first unconverged value (error) -302.035 (2.42941208e-06)
145859 EPS nconv=0 first unconverged value (error) -302.035 (2.33154077e-06)
145860 EPS nconv=0 first unconverged value (error) -302.035 (2.23720219e-06)
145861 EPS nconv=0 first unconverged value (error) -302.035 (2.23720219e-06)
145862 EPS nconv=0 first unconverged value (error) -302.035 (2.19769890e-06)
145863 EPS nconv=0 first unconverged value (error) -302.035 (2.58035549e-06)
145864 EPS nconv=0 first unconverged value (error) -302.035 (2.17226142e-06)
145865 EPS nconv=0 first unconverged value (error) -302.035 (1.87155872e-06)
145866 EPS nconv=0 first unconverged value (error) -302.035 (1.81966052e-06)
145867 EPS nconv=0 first unconverged value (error) -302.035 (1.81966052e-06)
145868 EPS nconv=0 first unconverged value (error) -302.035 (2.24175671e-06)
145869 EPS nconv=0 first unconverged value (error) -302.035 (2.13700861e-06)
145870 EPS nconv=0 first unconverged value (error) -302.035 (2.07124094e-06)
145871 EPS nconv=0 first unconverged value (error) -302.035 (2.04014276e-06)
145872 EPS nconv=0 first unconverged value (error) -302.035 (2.02240759e-06)
145873 EPS nconv=0 first unconverged value (error) -302.035 (2.02240759e-06)
145874 EPS nconv=0 first unconverged value (error) -302.035 (2.09129328e-06)
145875 EPS nconv=0 first unconverged value (error) -302.035 (2.04727979e-06)
145876 EPS nconv=0 first unconverged value (error) -302.035 (1.93526007e-06)
145877 EPS nconv=0 first unconverged value (error) -302.035 (1.89755455e-06)
145878 EPS nconv=0 first unconverged value (error) -302.035 (1.88097766e-06)
145879 EPS nconv=0 first unconverged value (error) -302.035 (1.88097766e-06)
145880 EPS nconv=0 first unconverged value (error) -302.035 (2.14028515e-06)
145881 EPS nconv=0 first unconverged value (error) -302.035 (2.11026708e-06)
145882 EPS nconv=0 first unconverged value (error) -302.035 (2.00195195e-06)
145883 EPS nconv=0 first unconverged value (error) -302.035 (1.92241517e-06)
145884 EPS nconv=0 first unconverged value (error) -302.035 (1.90502295e-06)
145885 EPS nconv=0 first unconverged value (error) -302.035 (1.90502295e-06)
145886 EPS nconv=0 first unconverged value (error) -302.035 (2.52157135e-06)
145887 EPS nconv=0 first unconverged value (error) -302.035 (2.25133984e-06)
145888 EPS nconv=0 first unconverged value (error) -302.035 (2.14130787e-06)
145889 EPS nconv=0 first unconverged value (error) -302.035 (2.07455365e-06)
145890 EPS nconv=0 first unconverged value (error) -302.035 (2.03382729e-06)
145891 EPS nconv=0 first unconverged value (error) -302.035 (2.03382729e-06)
145892 EPS nconv=0 first unconverged value (error) -302.035 (2.37215149e-06)
145893 EPS nconv=0 first unconverged value (error) -302.035 (2.39564380e-06)
145894 EPS nconv=0 first unconverged value (error) -302.035 (2.07852276e-06)
145895 EPS nconv=0 first unconverged value (error) -302.035 (2.01973620e-06)
145896 EPS nconv=0 first unconverged value (error) -302.035 (1.98938740e-06)
145897 EPS nconv=0 first unconverged value (error) -302.035 (1.98938740e-06)
145898 EPS nconv=0 first unconverged value (error) -302.035 (2.12163199e-06)
145899 EPS nconv=0 first unconverged value (error) -302.035 (2.10760795e-06)
145900 EPS nconv=0 first unconverged value (error) -302.035 (1.95444068e-06)
145901 EPS nconv=0 first unconverged value (error) -302.035 (1.92009192e-06)
145902 EPS nconv=0 first unconverged value (error) -302.035 (1.91239878e-06)
145903 EPS nconv=0 first unconverged value (error) -302.035 (1.91239878e-06)
145904 EPS nconv=0 first unconverged value (error) -302.035 (1.87485204e-06)
145905 EPS nconv=0 first unconverged value (error) -302.035 (1.93187140e-06)
145906 EPS nconv=0 first unconverged value (error) -302.035 (1.88827618e-06)
145907 EPS nconv=0 first unconverged value (error) -302.035 (1.82093313e-06)
145908 EPS nconv=0 first unconverged value (error) -302.035 (1.80803467e-06)
145909 EPS nconv=0 first unconverged value (error) -302.035 (1.80803467e-06)
145910 EPS nconv=0 first unconverged value (error) -302.035 (1.87606358e-06)
145911 EPS nconv=0 first unconverged value (error) -302.035 (1.83848787e-06)
145912 EPS nconv=0 first unconverged value (error) -302.035 (1.83283297e-06)
145913 EPS nconv=0 first unconverged value (error) -302.035 (1.82784984e-06)
145914 EPS nconv=0 first unconverged value (error) -302.035 (1.82145434e-06)
145915 EPS nconv=0 first unconverged value (error) -302.035 (1.82145434e-06)
145916 EPS nconv=0 first unconverged value (error) -302.035 (1.82224549e-06)
145917 EPS nconv=0 first unconverged value (error) -302.035 (1.83727992e-06)
145918 EPS nconv=0 first unconverged value (error) -302.035 (1.81386212e-06)
145919 EPS nconv=0 first unconverged value (error) -302.035 (1.80080271e-06)
145920 EPS nconv=0 first unconverged value (error) -302.035 (1.79921817e-06)
145921 EPS nconv=0 first unconverged value (error) -302.035 (1.79921817e-06)
145922 EPS nconv=0 first unconverged value (error) -302.035 (1.82085490e-06)
145923 EPS nconv=0 first unconverged value (error) -302.035 (1.81265763e-06)
145924 EPS nconv=0 first unconverged value (error) -302.035 (1.80760505e-06)
145925 EPS nconv=0 first unconverged value (error) -302.035 (1.80620070e-06)
145926 EPS nconv=0 first unconverged value (error) -302.035 (1.80466399e-06)
145927 EPS nconv=0 first unconverged value (error) -302.035 (1.80466399e-06)
145928 EPS nconv=0 first unconverged value (error) -302.035 (2.46660417e-06)
145929 EPS nconv=0 first unconverged value (error) -302.035 (2.25829854e-06)
145930 EPS nconv=0 first unconverged value (error) -302.035 (2.16006023e-06)
145931 EPS nconv=0 first unconverged value (error) -302.035 (2.08798295e-06)
145932 EPS nconv=0 first unconverged value (error) -302.035 (2.05838592e-06)
145933 EPS nconv=0 first unconverged value (error) -302.035 (2.05838592e-06)
145934 EPS nconv=0 first unconverged value (error) -302.035 (4.20133312e-06)
145935 EPS nconv=0 first unconverged value (error) -302.035 (3.71396563e-06)
145936 EPS nconv=0 first unconverged value (error) -302.035 (3.37943656e-06)
145937 EPS nconv=0 first unconverged value (error) -302.035 (3.37912341e-06)
145938 EPS nconv=0 first unconverged value (error) -302.035 (3.29535520e-06)
145939 EPS nconv=0 first unconverged value (error) -302.035 (3.29535520e-06)
145940 EPS nconv=0 first unconverged value (error) -302.035 (3.56743165e-06)
145941 EPS nconv=0 first unconverged value (error) -302.035 (3.30072175e-06)
145942 EPS nconv=0 first unconverged value (error) -302.035 (2.70246536e-06)
145943 EPS nconv=0 first unconverged value (error) -302.035 (2.37442428e-06)
145944 EPS nconv=0 first unconverged value (error) -302.035 (2.29615136e-06)
145945 EPS nconv=0 first unconverged value (error) -302.035 (2.29615136e-06)
145946 EPS nconv=0 first unconverged value (error) -302.035 (3.10846479e-06)
145947 EPS nconv=0 first unconverged value (error) -302.035 (2.67415713e-06)
145948 EPS nconv=0 first unconverged value (error) -302.035 (2.35695524e-06)
145949 EPS nconv=0 first unconverged value (error) -302.035 (2.14786936e-06)
145950 EPS nconv=0 first unconverged value (error) -302.035 (2.06689394e-06)
145951 EPS nconv=0 first unconverged value (error) -302.035 (2.06689394e-06)
145952 EPS nconv=0 first unconverged value (error) -302.035 (2.20319061e-06)
145953 EPS nconv=0 first unconverged value (error) -302.035 (2.36630148e-06)
145954 EPS nconv=0 first unconverged value (error) -302.035 (2.00747162e-06)
145955 EPS nconv=0 first unconverged value (error) -302.035 (1.93510444e-06)
145956 EPS nconv=0 first unconverged value (error) -302.035 (1.89956125e-06)
145957 EPS nconv=0 first unconverged value (error) -302.035 (1.89956125e-06)
145958 EPS nconv=0 first unconverged value (error) -302.035 (1.88260391e-06)
145959 EPS nconv=0 first unconverged value (error) -302.035 (1.93467020e-06)
145960 EPS nconv=0 first unconverged value (error) -302.035 (1.86339278e-06)
145961 EPS nconv=0 first unconverged value (error) -302.035 (1.82283832e-06)
145962 EPS nconv=0 first unconverged value (error) -302.035 (1.81801769e-06)
145963 EPS nconv=0 first unconverged value (error) -302.035 (1.81801769e-06)
145964 EPS nconv=0 first unconverged value (error) -302.035 (2.03326904e-06)
145965 EPS nconv=0 first unconverged value (error) -302.035 (1.93220794e-06)
145966 EPS nconv=0 first unconverged value (error) -302.035 (1.91097525e-06)
145967 EPS nconv=0 first unconverged value (error) -302.035 (1.89758016e-06)
145968 EPS nconv=0 first unconverged value (error) -302.035 (1.87651929e-06)
145969 EPS nconv=0 first unconverged value (error) -302.035 (1.87651929e-06)
145970 EPS nconv=0 first unconverged value (error) -302.035 (2.91190166e-06)
145971 EPS nconv=0 first unconverged value (error) -302.035 (2.86504032e-06)
145972 EPS nconv=0 first unconverged value (error) -302.035 (2.66467252e-06)
145973 EPS nconv=0 first unconverged value (error) -302.035 (2.60516952e-06)
145974 EPS nconv=0 first unconverged value (error) -302.035 (2.55531587e-06)
145975 EPS nconv=0 first unconverged value (error) -302.035 (2.55531587e-06)
145976 EPS nconv=0 first unconverged value (error) -302.035 (4.23937153e-06)
145977 EPS nconv=0 first unconverged value (error) -302.035 (3.56953673e-06)
145978 EPS nconv=0 first unconverged value (error) -302.035 (3.12943699e-06)
145979 EPS nconv=0 first unconverged value (error) -302.035 (3.13090432e-06)
145980 EPS nconv=0 first unconverged value (error) -302.035 (3.01057577e-06)
145981 EPS nconv=0 first unconverged value (error) -302.035 (3.01057577e-06)
145982 EPS nconv=0 first unconverged value (error) -302.035 (2.98310762e-06)
145983 EPS nconv=0 first unconverged value (error) -302.035 (3.32342971e-06)
145984 EPS nconv=0 first unconverged value (error) -302.035 (2.74250202e-06)
145985 EPS nconv=0 first unconverged value (error) -302.035 (2.35817425e-06)
145986 EPS nconv=0 first unconverged value (error) -302.035 (2.03565796e-06)
145987 EPS nconv=0 first unconverged value (error) -302.035 (2.03565796e-06)
145988 EPS nconv=0 first unconverged value (error) -302.035 (1.87694998e-06)
145989 EPS nconv=0 first unconverged value (error) -302.035 (1.90092692e-06)
145990 EPS nconv=0 first unconverged value (error) -302.035 (1.88168256e-06)
145991 EPS nconv=0 first unconverged value (error) -302.035 (1.81858005e-06)
145992 EPS nconv=0 first unconverged value (error) -302.035 (1.81027840e-06)
145993 EPS nconv=0 first unconverged value (error) -302.035 (1.81027840e-06)
145994 EPS nconv=0 first unconverged value (error) -302.035 (2.16106289e-06)
145995 EPS nconv=0 first unconverged value (error) -302.035 (2.02854122e-06)
145996 EPS nconv=0 first unconverged value (error) -302.035 (1.99101971e-06)
145997 EPS nconv=0 first unconverged value (error) -302.035 (1.94242488e-06)
145998 EPS nconv=0 first unconverged value (error) -302.035 (1.92920186e-06)
145999 EPS nconv=0 first unconverged value (error) -302.035 (1.92920186e-06)
146000 EPS nconv=0 first unconverged value (error) -302.035 (2.81156510e-06)
146001 EPS nconv=0 first unconverged value (error) -302.035 (2.55662807e-06)
146002 EPS nconv=0 first unconverged value (error) -302.035 (2.37727741e-06)
146003 EPS nconv=0 first unconverged value (error) -302.035 (2.34052540e-06)
146004 EPS nconv=0 first unconverged value (error) -302.035 (2.32740077e-06)
146005 EPS nconv=0 first unconverged value (error) -302.035 (2.32740077e-06)
146006 EPS nconv=0 first unconverged value (error) -302.035 (3.24051174e-06)
146007 EPS nconv=0 first unconverged value (error) -302.035 (2.94905699e-06)
146008 EPS nconv=0 first unconverged value (error) -302.035 (2.58787467e-06)
146009 EPS nconv=0 first unconverged value (error) -302.035 (2.60842242e-06)
146010 EPS nconv=0 first unconverged value (error) -302.035 (2.45852715e-06)
146011 EPS nconv=0 first unconverged value (error) -302.035 (2.45852715e-06)
146012 EPS nconv=0 first unconverged value (error) -302.035 (4.26474841e-06)
146013 EPS nconv=0 first unconverged value (error) -302.035 (4.17384612e-06)
146014 EPS nconv=0 first unconverged value (error) -302.035 (3.32566017e-06)
146015 EPS nconv=0 first unconverged value (error) -302.035 (2.99477183e-06)
146016 EPS nconv=0 first unconverged value (error) -302.035 (2.89295311e-06)
146017 EPS nconv=0 first unconverged value (error) -302.035 (2.89295311e-06)
146018 EPS nconv=0 first unconverged value (error) -302.035 (3.97770128e-06)
146019 EPS nconv=0 first unconverged value (error) -302.035 (4.10906764e-06)
146020 EPS nconv=0 first unconverged value (error) -302.035 (3.35566282e-06)
146021 EPS nconv=0 first unconverged value (error) -302.035 (2.79817657e-06)
146022 EPS nconv=0 first unconverged value (error) -302.035 (2.45986494e-06)
146023 EPS nconv=0 first unconverged value (error) -302.035 (2.45986494e-06)
146024 EPS nconv=0 first unconverged value (error) -302.035 (2.31469256e-06)
146025 EPS nconv=0 first unconverged value (error) -302.035 (2.74895316e-06)
146026 EPS nconv=0 first unconverged value (error) -302.035 (2.26610599e-06)
146027 EPS nconv=0 first unconverged value (error) -302.035 (1.94765378e-06)
146028 EPS nconv=0 first unconverged value (error) -302.035 (1.84333975e-06)
146029 EPS nconv=0 first unconverged value (error) -302.035 (1.84333975e-06)
146030 EPS nconv=0 first unconverged value (error) -302.035 (1.83778274e-06)
146031 EPS nconv=0 first unconverged value (error) -302.035 (1.82843014e-06)
146032 EPS nconv=0 first unconverged value (error) -302.035 (1.82438317e-06)
146033 EPS nconv=0 first unconverged value (error) -302.035 (1.82358667e-06)
146034 EPS nconv=0 first unconverged value (error) -302.035 (1.81915849e-06)
146035 EPS nconv=0 first unconverged value (error) -302.035 (1.81915849e-06)
146036 EPS nconv=0 first unconverged value (error) -302.035 (2.75759327e-06)
146037 EPS nconv=0 first unconverged value (error) -302.035 (2.73534828e-06)
146038 EPS nconv=0 first unconverged value (error) -302.035 (2.47189083e-06)
146039 EPS nconv=0 first unconverged value (error) -302.035 (2.36244995e-06)
146040 EPS nconv=0 first unconverged value (error) -302.035 (2.30388341e-06)
146041 EPS nconv=0 first unconverged value (error) -302.035 (2.30388341e-06)
146042 EPS nconv=0 first unconverged value (error) -302.035 (4.41811839e-06)
146043 EPS nconv=0 first unconverged value (error) -302.035 (3.93371111e-06)
146044 EPS nconv=0 first unconverged value (error) -302.035 (3.51642879e-06)
146045 EPS nconv=0 first unconverged value (error) -302.035 (3.42274934e-06)
146046 EPS nconv=0 first unconverged value (error) -302.035 (3.39630349e-06)
146047 EPS nconv=0 first unconverged value (error) -302.035 (3.39630349e-06)
146048 EPS nconv=0 first unconverged value (error) -302.035 (3.63549538e-06)
146049 EPS nconv=0 first unconverged value (error) -302.035 (3.42661062e-06)
146050 EPS nconv=0 first unconverged value (error) -302.035 (2.89219834e-06)
146051 EPS nconv=0 first unconverged value (error) -302.035 (2.54312529e-06)
146052 EPS nconv=0 first unconverged value (error) -302.035 (2.27461733e-06)
146053 EPS nconv=0 first unconverged value (error) -302.035 (2.27461733e-06)
146054 EPS nconv=0 first unconverged value (error) -302.035 (2.14915069e-06)
146055 EPS nconv=0 first unconverged value (error) -302.035 (2.28736670e-06)
146056 EPS nconv=0 first unconverged value (error) -302.035 (2.07123724e-06)
146057 EPS nconv=0 first unconverged value (error) -302.035 (1.90215698e-06)
146058 EPS nconv=0 first unconverged value (error) -302.035 (1.86262788e-06)
146059 EPS nconv=0 first unconverged value (error) -302.035 (1.86262788e-06)
146060 EPS nconv=0 first unconverged value (error) -302.035 (2.07357889e-06)
146061 EPS nconv=0 first unconverged value (error) -302.035 (1.99751036e-06)
146062 EPS nconv=0 first unconverged value (error) -302.035 (1.96238957e-06)
146063 EPS nconv=0 first unconverged value (error) -302.035 (1.95720006e-06)
146064 EPS nconv=0 first unconverged value (error) -302.035 (1.93119999e-06)
146065 EPS nconv=0 first unconverged value (error) -302.035 (1.93119999e-06)
146066 EPS nconv=0 first unconverged value (error) -302.035 (2.26145326e-06)
146067 EPS nconv=0 first unconverged value (error) -302.035 (2.25075251e-06)
146068 EPS nconv=0 first unconverged value (error) -302.035 (2.10001821e-06)
146069 EPS nconv=0 first unconverged value (error) -302.035 (2.07816530e-06)
146070 EPS nconv=0 first unconverged value (error) -302.035 (2.05448891e-06)
146071 EPS nconv=0 first unconverged value (error) -302.035 (2.05448891e-06)
146072 EPS nconv=0 first unconverged value (error) -302.035 (2.02207879e-06)
146073 EPS nconv=0 first unconverged value (error) -302.035 (2.00438317e-06)
146074 EPS nconv=0 first unconverged value (error) -302.035 (1.95850038e-06)
146075 EPS nconv=0 first unconverged value (error) -302.035 (1.86959923e-06)
146076 EPS nconv=0 first unconverged value (error) -302.035 (1.83794276e-06)
146077 EPS nconv=0 first unconverged value (error) -302.035 (1.83794276e-06)
146078 EPS nconv=0 first unconverged value (error) -302.035 (1.80077941e-06)
146079 EPS nconv=0 first unconverged value (error) -302.035 (1.80134803e-06)
146080 EPS nconv=0 first unconverged value (error) -302.035 (1.79826556e-06)
146081 EPS nconv=0 first unconverged value (error) -302.035 (1.79622612e-06)
146082 EPS nconv=0 first unconverged value (error) -302.035 (1.79603391e-06)
146083 EPS nconv=0 first unconverged value (error) -302.035 (1.79603391e-06)
146084 EPS nconv=0 first unconverged value (error) -302.035 (1.80793606e-06)
146085 EPS nconv=0 first unconverged value (error) -302.035 (1.80215583e-06)
146086 EPS nconv=0 first unconverged value (error) -302.035 (1.80111289e-06)
146087 EPS nconv=0 first unconverged value (error) -302.035 (1.80079377e-06)
146088 EPS nconv=0 first unconverged value (error) -302.035 (1.79929174e-06)
146089 EPS nconv=0 first unconverged value (error) -302.035 (1.79929174e-06)
146090 EPS nconv=0 first unconverged value (error) -302.035 (1.80657337e-06)
146091 EPS nconv=0 first unconverged value (error) -302.035 (1.80689262e-06)
146092 EPS nconv=0 first unconverged value (error) -302.035 (1.80110945e-06)
146093 EPS nconv=0 first unconverged value (error) -302.035 (1.80052265e-06)
146094 EPS nconv=0 first unconverged value (error) -302.035 (1.80030275e-06)
146095 EPS nconv=0 first unconverged value (error) -302.035 (1.80030275e-06)
146096 EPS nconv=0 first unconverged value (error) -302.035 (1.79953841e-06)
146097 EPS nconv=0 first unconverged value (error) -302.035 (1.79932485e-06)
146098 EPS nconv=0 first unconverged value (error) -302.035 (1.79743041e-06)
146099 EPS nconv=0 first unconverged value (error) -302.035 (1.79625237e-06)
146100 EPS nconv=0 first unconverged value (error) -302.035 (1.79550602e-06)
146101 EPS nconv=0 first unconverged value (error) -302.035 (1.79550602e-06)
146102 EPS nconv=0 first unconverged value (error) -302.035 (1.80659910e-06)
146103 EPS nconv=0 first unconverged value (error) -302.035 (1.80448357e-06)
146104 EPS nconv=0 first unconverged value (error) -302.035 (1.80132104e-06)
146105 EPS nconv=0 first unconverged value (error) -302.035 (1.80023596e-06)
146106 EPS nconv=0 first unconverged value (error) -302.035 (1.79952678e-06)
146107 EPS nconv=0 first unconverged value (error) -302.035 (1.79952678e-06)
146108 EPS nconv=0 first unconverged value (error) -302.035 (1.83727747e-06)
146109 EPS nconv=0 first unconverged value (error) -302.035 (1.82335217e-06)
146110 EPS nconv=0 first unconverged value (error) -302.035 (1.81611375e-06)
146111 EPS nconv=0 first unconverged value (error) -302.035 (1.81582829e-06)
146112 EPS nconv=0 first unconverged value (error) -302.035 (1.81358495e-06)
146113 EPS nconv=0 first unconverged value (error) -302.035 (1.81358495e-06)
146114 EPS nconv=0 first unconverged value (error) -302.035 (2.37055714e-06)
146115 EPS nconv=0 first unconverged value (error) -302.035 (2.27727733e-06)
146116 EPS nconv=0 first unconverged value (error) -302.035 (2.10776121e-06)
146117 EPS nconv=0 first unconverged value (error) -302.035 (2.00062575e-06)
146118 EPS nconv=0 first unconverged value (error) -302.035 (1.98614710e-06)
146119 EPS nconv=0 first unconverged value (error) -302.035 (1.98614710e-06)
146120 EPS nconv=0 first unconverged value (error) -302.035 (2.04263468e-06)
146121 EPS nconv=0 first unconverged value (error) -302.035 (2.17265609e-06)
146122 EPS nconv=0 first unconverged value (error) -302.035 (2.02786085e-06)
146123 EPS nconv=0 first unconverged value (error) -302.035 (1.92006523e-06)
146124 EPS nconv=0 first unconverged value (error) -302.035 (1.86299052e-06)
146125 EPS nconv=0 first unconverged value (error) -302.035 (1.86299052e-06)
146126 EPS nconv=0 first unconverged value (error) -302.035 (2.14531183e-06)
146127 EPS nconv=0 first unconverged value (error) -302.035 (2.07061678e-06)
146128 EPS nconv=0 first unconverged value (error) -302.035 (1.98801514e-06)
146129 EPS nconv=0 first unconverged value (error) -302.035 (1.98041436e-06)
146130 EPS nconv=0 first unconverged value (error) -302.035 (1.96719210e-06)
146131 EPS nconv=0 first unconverged value (error) -302.035 (1.96719210e-06)
146132 EPS nconv=0 first unconverged value (error) -302.035 (2.41595208e-06)
146133 EPS nconv=0 first unconverged value (error) -302.035 (2.28832347e-06)
146134 EPS nconv=0 first unconverged value (error) -302.035 (2.21940642e-06)
146135 EPS nconv=0 first unconverged value (error) -302.035 (1.99480833e-06)
146136 EPS nconv=0 first unconverged value (error) -302.035 (1.95163652e-06)
146137 EPS nconv=0 first unconverged value (error) -302.035 (1.95163652e-06)
146138 EPS nconv=0 first unconverged value (error) -302.035 (1.96596436e-06)
146139 EPS nconv=0 first unconverged value (error) -302.035 (2.10071544e-06)
146140 EPS nconv=0 first unconverged value (error) -302.035 (1.94394165e-06)
146141 EPS nconv=0 first unconverged value (error) -302.035 (1.86692982e-06)
146142 EPS nconv=0 first unconverged value (error) -302.035 (1.82402595e-06)
146143 EPS nconv=0 first unconverged value (error) -302.035 (1.82402595e-06)
146144 EPS nconv=0 first unconverged value (error) -302.035 (1.83984956e-06)
146145 EPS nconv=0 first unconverged value (error) -302.035 (1.82535258e-06)
146146 EPS nconv=0 first unconverged value (error) -302.035 (1.81734788e-06)
146147 EPS nconv=0 first unconverged value (error) -302.035 (1.81063466e-06)
146148 EPS nconv=0 first unconverged value (error) -302.035 (1.80647568e-06)
146149 EPS nconv=0 first unconverged value (error) -302.035 (1.80647568e-06)
146150 EPS nconv=0 first unconverged value (error) -302.035 (1.85779909e-06)
146151 EPS nconv=0 first unconverged value (error) -302.035 (1.85892851e-06)
146152 EPS nconv=0 first unconverged value (error) -302.035 (1.84565423e-06)
146153 EPS nconv=0 first unconverged value (error) -302.035 (1.83357312e-06)
146154 EPS nconv=0 first unconverged value (error) -302.035 (1.82907041e-06)
146155 EPS nconv=0 first unconverged value (error) -302.035 (1.82907041e-06)
146156 EPS nconv=0 first unconverged value (error) -302.035 (2.18811435e-06)
146157 EPS nconv=0 first unconverged value (error) -302.035 (2.04049184e-06)
146158 EPS nconv=0 first unconverged value (error) -302.035 (1.98705468e-06)
146159 EPS nconv=0 first unconverged value (error) -302.035 (1.96719387e-06)
146160 EPS nconv=0 first unconverged value (error) -302.035 (1.93842123e-06)
146161 EPS nconv=0 first unconverged value (error) -302.035 (1.93842123e-06)
146162 EPS nconv=0 first unconverged value (error) -302.035 (2.09181748e-06)
146163 EPS nconv=0 first unconverged value (error) -302.035 (2.13815885e-06)
146164 EPS nconv=0 first unconverged value (error) -302.035 (1.98534460e-06)
146165 EPS nconv=0 first unconverged value (error) -302.035 (1.96316388e-06)
146166 EPS nconv=0 first unconverged value (error) -302.035 (1.91941953e-06)
146167 EPS nconv=0 first unconverged value (error) -302.035 (1.91941953e-06)
146168 EPS nconv=0 first unconverged value (error) -302.035 (1.87944805e-06)
146169 EPS nconv=0 first unconverged value (error) -302.035 (1.88145670e-06)
146170 EPS nconv=0 first unconverged value (error) -302.035 (1.83102573e-06)
146171 EPS nconv=0 first unconverged value (error) -302.035 (1.80663874e-06)
146172 EPS nconv=0 first unconverged value (error) -302.035 (1.80341674e-06)
146173 EPS nconv=0 first unconverged value (error) -302.035 (1.80341674e-06)
146174 EPS nconv=0 first unconverged value (error) -302.035 (1.87851557e-06)
146175 EPS nconv=0 first unconverged value (error) -302.035 (1.84710983e-06)
146176 EPS nconv=0 first unconverged value (error) -302.035 (1.83854809e-06)
146177 EPS nconv=0 first unconverged value (error) -302.035 (1.82995520e-06)
146178 EPS nconv=0 first unconverged value (error) -302.035 (1.82703182e-06)
146179 EPS nconv=0 first unconverged value (error) -302.035 (1.82703182e-06)
146180 EPS nconv=0 first unconverged value (error) -302.035 (1.98556289e-06)
146181 EPS nconv=0 first unconverged value (error) -302.035 (1.94040246e-06)
146182 EPS nconv=0 first unconverged value (error) -302.035 (1.88261859e-06)
146183 EPS nconv=0 first unconverged value (error) -302.035 (1.87564957e-06)
146184 EPS nconv=0 first unconverged value (error) -302.035 (1.86866055e-06)
146185 EPS nconv=0 first unconverged value (error) -302.035 (1.86866055e-06)
146186 EPS nconv=0 first unconverged value (error) -302.035 (1.91841621e-06)
146187 EPS nconv=0 first unconverged value (error) -302.035 (1.91805911e-06)
146188 EPS nconv=0 first unconverged value (error) -302.035 (1.84883660e-06)
146189 EPS nconv=0 first unconverged value (error) -302.035 (1.82940283e-06)
146190 EPS nconv=0 first unconverged value (error) -302.035 (1.82810827e-06)
146191 EPS nconv=0 first unconverged value (error) -302.035 (1.82810827e-06)
146192 EPS nconv=0 first unconverged value (error) -302.035 (1.84662382e-06)
146193 EPS nconv=0 first unconverged value (error) -302.035 (1.83900477e-06)
146194 EPS nconv=0 first unconverged value (error) -302.035 (1.82985642e-06)
146195 EPS nconv=0 first unconverged value (error) -302.035 (1.81296760e-06)
146196 EPS nconv=0 first unconverged value (error) -302.035 (1.80505893e-06)
146197 EPS nconv=0 first unconverged value (error) -302.035 (1.80505893e-06)
146198 EPS nconv=0 first unconverged value (error) -302.035 (1.85357847e-06)
146199 EPS nconv=0 first unconverged value (error) -302.035 (1.83587034e-06)
146200 EPS nconv=0 first unconverged value (error) -302.035 (1.81530599e-06)
146201 EPS nconv=0 first unconverged value (error) -302.035 (1.81300242e-06)
146202 EPS nconv=0 first unconverged value (error) -302.035 (1.80997882e-06)
146203 EPS nconv=0 first unconverged value (error) -302.035 (1.80997882e-06)
146204 EPS nconv=0 first unconverged value (error) -302.035 (1.89191442e-06)
146205 EPS nconv=0 first unconverged value (error) -302.035 (1.87145624e-06)
146206 EPS nconv=0 first unconverged value (error) -302.035 (1.84548501e-06)
146207 EPS nconv=0 first unconverged value (error) -302.035 (1.84364887e-06)
146208 EPS nconv=0 first unconverged value (error) -302.035 (1.84175992e-06)
146209 EPS nconv=0 first unconverged value (error) -302.035 (1.84175992e-06)
146210 EPS nconv=0 first unconverged value (error) -302.035 (1.86652550e-06)
146211 EPS nconv=0 first unconverged value (error) -302.035 (1.86925152e-06)
146212 EPS nconv=0 first unconverged value (error) -302.035 (1.83971662e-06)
146213 EPS nconv=0 first unconverged value (error) -302.035 (1.81098820e-06)
146214 EPS nconv=0 first unconverged value (error) -302.035 (1.80915237e-06)
146215 EPS nconv=0 first unconverged value (error) -302.035 (1.80915237e-06)
146216 EPS nconv=0 first unconverged value (error) -302.035 (2.24870598e-06)
146217 EPS nconv=0 first unconverged value (error) -302.035 (2.07523624e-06)
146218 EPS nconv=0 first unconverged value (error) -302.035 (2.02098589e-06)
146219 EPS nconv=0 first unconverged value (error) -302.035 (1.97525047e-06)
146220 EPS nconv=0 first unconverged value (error) -302.035 (1.94497858e-06)
146221 EPS nconv=0 first unconverged value (error) -302.035 (1.94497858e-06)
146222 EPS nconv=0 first unconverged value (error) -302.035 (1.95207643e-06)
146223 EPS nconv=0 first unconverged value (error) -302.035 (2.11276168e-06)
146224 EPS nconv=0 first unconverged value (error) -302.035 (1.92496121e-06)
146225 EPS nconv=0 first unconverged value (error) -302.035 (1.85226338e-06)
146226 EPS nconv=0 first unconverged value (error) -302.035 (1.82492345e-06)
146227 EPS nconv=0 first unconverged value (error) -302.035 (1.82492345e-06)
146228 EPS nconv=0 first unconverged value (error) -302.035 (1.82980378e-06)
146229 EPS nconv=0 first unconverged value (error) -302.035 (1.81615781e-06)
146230 EPS nconv=0 first unconverged value (error) -302.035 (1.81062211e-06)
146231 EPS nconv=0 first unconverged value (error) -302.035 (1.80966596e-06)
146232 EPS nconv=0 first unconverged value (error) -302.035 (1.80681805e-06)
146233 EPS nconv=0 first unconverged value (error) -302.035 (1.80681805e-06)
146234 EPS nconv=0 first unconverged value (error) -302.035 (2.41318268e-06)
146235 EPS nconv=0 first unconverged value (error) -302.035 (2.19903748e-06)
146236 EPS nconv=0 first unconverged value (error) -302.035 (2.11400695e-06)
146237 EPS nconv=0 first unconverged value (error) -302.035 (2.06019559e-06)
146238 EPS nconv=0 first unconverged value (error) -302.035 (2.04984394e-06)
146239 EPS nconv=0 first unconverged value (error) -302.035 (2.04984394e-06)
146240 EPS nconv=0 first unconverged value (error) -302.035 (2.70110280e-06)
146241 EPS nconv=0 first unconverged value (error) -302.035 (2.50638818e-06)
146242 EPS nconv=0 first unconverged value (error) -302.035 (2.26042716e-06)
146243 EPS nconv=0 first unconverged value (error) -302.035 (2.24585036e-06)
146244 EPS nconv=0 first unconverged value (error) -302.035 (2.20288278e-06)
146245 EPS nconv=0 first unconverged value (error) -302.035 (2.20288278e-06)
146246 EPS nconv=0 first unconverged value (error) -302.035 (2.22606101e-06)
146247 EPS nconv=0 first unconverged value (error) -302.035 (2.41092449e-06)
146248 EPS nconv=0 first unconverged value (error) -302.035 (2.09948644e-06)
146249 EPS nconv=0 first unconverged value (error) -302.035 (1.92671363e-06)
146250 EPS nconv=0 first unconverged value (error) -302.035 (1.87413607e-06)
146251 EPS nconv=0 first unconverged value (error) -302.035 (1.87413607e-06)
146252 EPS nconv=0 first unconverged value (error) -302.035 (2.14693131e-06)
146253 EPS nconv=0 first unconverged value (error) -302.035 (2.03143525e-06)
146254 EPS nconv=0 first unconverged value (error) -302.035 (1.96191787e-06)
146255 EPS nconv=0 first unconverged value (error) -302.035 (1.95827472e-06)
146256 EPS nconv=0 first unconverged value (error) -302.035 (1.92833554e-06)
146257 EPS nconv=0 first unconverged value (error) -302.035 (1.92833554e-06)
146258 EPS nconv=0 first unconverged value (error) -302.035 (1.92584348e-06)
146259 EPS nconv=0 first unconverged value (error) -302.035 (2.06633299e-06)
146260 EPS nconv=0 first unconverged value (error) -302.035 (1.90535296e-06)
146261 EPS nconv=0 first unconverged value (error) -302.035 (1.82968911e-06)
146262 EPS nconv=0 first unconverged value (error) -302.035 (1.81025371e-06)
146263 EPS nconv=0 first unconverged value (error) -302.035 (1.81025371e-06)
146264 EPS nconv=0 first unconverged value (error) -302.035 (2.98597478e-06)
146265 EPS nconv=0 first unconverged value (error) -302.035 (2.63871235e-06)
146266 EPS nconv=0 first unconverged value (error) -302.035 (2.55322295e-06)
146267 EPS nconv=0 first unconverged value (error) -302.035 (2.52528777e-06)
146268 EPS nconv=0 first unconverged value (error) -302.035 (2.42475726e-06)
146269 EPS nconv=0 first unconverged value (error) -302.035 (2.42475726e-06)
146270 EPS nconv=0 first unconverged value (error) -302.035 (2.99900217e-06)
146271 EPS nconv=0 first unconverged value (error) -302.035 (2.96815375e-06)
146272 EPS nconv=0 first unconverged value (error) -302.035 (2.41108555e-06)
146273 EPS nconv=0 first unconverged value (error) -302.035 (2.41118542e-06)
146274 EPS nconv=0 first unconverged value (error) -302.035 (2.36136108e-06)
146275 EPS nconv=0 first unconverged value (error) -302.035 (2.36136108e-06)
146276 EPS nconv=0 first unconverged value (error) -302.035 (2.24937465e-06)
146277 EPS nconv=0 first unconverged value (error) -302.035 (2.33631303e-06)
146278 EPS nconv=0 first unconverged value (error) -302.035 (2.34125475e-06)
146279 EPS nconv=0 first unconverged value (error) -302.035 (1.98139246e-06)
146280 EPS nconv=0 first unconverged value (error) -302.035 (1.85792769e-06)
146281 EPS nconv=0 first unconverged value (error) -302.035 (1.85792769e-06)
146282 EPS nconv=0 first unconverged value (error) -302.035 (2.46745943e-06)
146283 EPS nconv=0 first unconverged value (error) -302.035 (2.32689877e-06)
146284 EPS nconv=0 first unconverged value (error) -302.035 (2.26622687e-06)
146285 EPS nconv=0 first unconverged value (error) -302.035 (2.19387356e-06)
146286 EPS nconv=0 first unconverged value (error) -302.035 (2.15557297e-06)
146287 EPS nconv=0 first unconverged value (error) -302.035 (2.15557297e-06)
146288 EPS nconv=0 first unconverged value (error) -302.035 (2.32405466e-06)
146289 EPS nconv=0 first unconverged value (error) -302.035 (2.28176794e-06)
146290 EPS nconv=0 first unconverged value (error) -302.035 (2.07222407e-06)
146291 EPS nconv=0 first unconverged value (error) -302.035 (2.01134306e-06)
146292 EPS nconv=0 first unconverged value (error) -302.035 (1.97434011e-06)
146293 EPS nconv=0 first unconverged value (error) -302.035 (1.97434011e-06)
146294 EPS nconv=0 first unconverged value (error) -302.035 (1.99982340e-06)
146295 EPS nconv=0 first unconverged value (error) -302.035 (2.03363273e-06)
146296 EPS nconv=0 first unconverged value (error) -302.035 (1.94282702e-06)
146297 EPS nconv=0 first unconverged value (error) -302.035 (1.88240230e-06)
146298 EPS nconv=0 first unconverged value (error) -302.035 (1.85866121e-06)
146299 EPS nconv=0 first unconverged value (error) -302.035 (1.85866121e-06)
146300 EPS nconv=0 first unconverged value (error) -302.035 (2.97437143e-06)
146301 EPS nconv=0 first unconverged value (error) -302.035 (2.60027867e-06)
146302 EPS nconv=0 first unconverged value (error) -302.035 (2.43176405e-06)
146303 EPS nconv=0 first unconverged value (error) -302.035 (2.36162427e-06)
146304 EPS nconv=0 first unconverged value (error) -302.035 (2.25687317e-06)
146305 EPS nconv=0 first unconverged value (error) -302.035 (2.25687317e-06)
146306 EPS nconv=0 first unconverged value (error) -302.035 (2.63503170e-06)
146307 EPS nconv=0 first unconverged value (error) -302.035 (2.88296573e-06)
146308 EPS nconv=0 first unconverged value (error) -302.035 (2.37534708e-06)
146309 EPS nconv=0 first unconverged value (error) -302.035 (2.25826385e-06)
146310 EPS nconv=0 first unconverged value (error) -302.035 (2.18190456e-06)
146311 EPS nconv=0 first unconverged value (error) -302.035 (2.18190456e-06)
146312 EPS nconv=0 first unconverged value (error) -302.035 (2.35027290e-06)
146313 EPS nconv=0 first unconverged value (error) -302.035 (2.26822819e-06)
146314 EPS nconv=0 first unconverged value (error) -302.035 (2.07462118e-06)
146315 EPS nconv=0 first unconverged value (error) -302.035 (2.03660756e-06)
146316 EPS nconv=0 first unconverged value (error) -302.035 (2.00678274e-06)
146317 EPS nconv=0 first unconverged value (error) -302.035 (2.00678274e-06)
146318 EPS nconv=0 first unconverged value (error) -302.035 (2.15638706e-06)
146319 EPS nconv=0 first unconverged value (error) -302.035 (2.15363861e-06)
146320 EPS nconv=0 first unconverged value (error) -302.035 (2.02728407e-06)
146321 EPS nconv=0 first unconverged value (error) -302.035 (1.92624249e-06)
146322 EPS nconv=0 first unconverged value (error) -302.035 (1.90352290e-06)
146323 EPS nconv=0 first unconverged value (error) -302.035 (1.90352290e-06)
146324 EPS nconv=0 first unconverged value (error) -302.035 (2.31799892e-06)
146325 EPS nconv=0 first unconverged value (error) -302.035 (2.19696571e-06)
146326 EPS nconv=0 first unconverged value (error) -302.035 (2.05820419e-06)
146327 EPS nconv=0 first unconverged value (error) -302.035 (2.00671011e-06)
146328 EPS nconv=0 first unconverged value (error) -302.035 (1.95896191e-06)
146329 EPS nconv=0 first unconverged value (error) -302.035 (1.95896191e-06)
146330 EPS nconv=0 first unconverged value (error) -302.035 (2.04836242e-06)
146331 EPS nconv=0 first unconverged value (error) -302.035 (2.15419417e-06)
146332 EPS nconv=0 first unconverged value (error) -302.035 (1.96599545e-06)
146333 EPS nconv=0 first unconverged value (error) -302.035 (1.92296133e-06)
146334 EPS nconv=0 first unconverged value (error) -302.035 (1.89689182e-06)
146335 EPS nconv=0 first unconverged value (error) -302.035 (1.89689182e-06)
146336 EPS nconv=0 first unconverged value (error) -302.035 (2.16006944e-06)
146337 EPS nconv=0 first unconverged value (error) -302.035 (2.05978482e-06)
146338 EPS nconv=0 first unconverged value (error) -302.035 (1.97938860e-06)
146339 EPS nconv=0 first unconverged value (error) -302.035 (1.96785814e-06)
146340 EPS nconv=0 first unconverged value (error) -302.035 (1.94388930e-06)
146341 EPS nconv=0 first unconverged value (error) -302.035 (1.94388930e-06)
146342 EPS nconv=0 first unconverged value (error) -302.035 (2.05904551e-06)
146343 EPS nconv=0 first unconverged value (error) -302.035 (2.07227217e-06)
146344 EPS nconv=0 first unconverged value (error) -302.035 (1.96710723e-06)
146345 EPS nconv=0 first unconverged value (error) -302.035 (1.87599340e-06)
146346 EPS nconv=0 first unconverged value (error) -302.035 (1.86398096e-06)
146347 EPS nconv=0 first unconverged value (error) -302.035 (1.86398096e-06)
146348 EPS nconv=0 first unconverged value (error) -302.035 (2.31952722e-06)
146349 EPS nconv=0 first unconverged value (error) -302.035 (2.13799724e-06)
146350 EPS nconv=0 first unconverged value (error) -302.035 (2.05835623e-06)
146351 EPS nconv=0 first unconverged value (error) -302.035 (2.03441655e-06)
146352 EPS nconv=0 first unconverged value (error) -302.035 (1.98229106e-06)
146353 EPS nconv=0 first unconverged value (error) -302.035 (1.98229106e-06)
146354 EPS nconv=0 first unconverged value (error) -302.035 (2.27989825e-06)
146355 EPS nconv=0 first unconverged value (error) -302.035 (2.35313973e-06)
146356 EPS nconv=0 first unconverged value (error) -302.035 (2.11915023e-06)
146357 EPS nconv=0 first unconverged value (error) -302.035 (2.05560734e-06)
146358 EPS nconv=0 first unconverged value (error) -302.035 (2.02952406e-06)
146359 EPS nconv=0 first unconverged value (error) -302.035 (2.02952406e-06)
146360 EPS nconv=0 first unconverged value (error) -302.035 (2.45493219e-06)
146361 EPS nconv=0 first unconverged value (error) -302.035 (2.23114010e-06)
146362 EPS nconv=0 first unconverged value (error) -302.035 (2.12134350e-06)
146363 EPS nconv=0 first unconverged value (error) -302.035 (2.10495244e-06)
146364 EPS nconv=0 first unconverged value (error) -302.035 (2.06292508e-06)
146365 EPS nconv=0 first unconverged value (error) -302.035 (2.06292508e-06)
146366 EPS nconv=0 first unconverged value (error) -302.035 (2.09435619e-06)
146367 EPS nconv=0 first unconverged value (error) -302.035 (2.22839726e-06)
146368 EPS nconv=0 first unconverged value (error) -302.035 (1.98803594e-06)
146369 EPS nconv=0 first unconverged value (error) -302.035 (1.88405785e-06)
146370 EPS nconv=0 first unconverged value (error) -302.035 (1.87632855e-06)
146371 EPS nconv=0 first unconverged value (error) -302.035 (1.87632855e-06)
146372 EPS nconv=0 first unconverged value (error) -302.035 (1.92693386e-06)
146373 EPS nconv=0 first unconverged value (error) -302.035 (1.90232500e-06)
146374 EPS nconv=0 first unconverged value (error) -302.035 (1.86475584e-06)
146375 EPS nconv=0 first unconverged value (error) -302.035 (1.84375094e-06)
146376 EPS nconv=0 first unconverged value (error) -302.035 (1.82875160e-06)
146377 EPS nconv=0 first unconverged value (error) -302.035 (1.82875160e-06)
146378 EPS nconv=0 first unconverged value (error) -302.035 (1.86310243e-06)
146379 EPS nconv=0 first unconverged value (error) -302.035 (1.87653497e-06)
146380 EPS nconv=0 first unconverged value (error) -302.035 (1.83499134e-06)
146381 EPS nconv=0 first unconverged value (error) -302.035 (1.82806871e-06)
146382 EPS nconv=0 first unconverged value (error) -302.035 (1.82199809e-06)
146383 EPS nconv=0 first unconverged value (error) -302.035 (1.82199809e-06)
146384 EPS nconv=0 first unconverged value (error) -302.035 (2.55219947e-06)
146385 EPS nconv=0 first unconverged value (error) -302.035 (2.27388402e-06)
146386 EPS nconv=0 first unconverged value (error) -302.035 (2.17284382e-06)
146387 EPS nconv=0 first unconverged value (error) -302.035 (2.17389521e-06)
146388 EPS nconv=0 first unconverged value (error) -302.035 (2.10524176e-06)
146389 EPS nconv=0 first unconverged value (error) -302.035 (2.10524176e-06)
146390 EPS nconv=0 first unconverged value (error) -302.035 (2.24878734e-06)
146391 EPS nconv=0 first unconverged value (error) -302.035 (2.37553999e-06)
146392 EPS nconv=0 first unconverged value (error) -302.035 (2.10409439e-06)
146393 EPS nconv=0 first unconverged value (error) -302.035 (1.95568765e-06)
146394 EPS nconv=0 first unconverged value (error) -302.035 (1.91190067e-06)
146395 EPS nconv=0 first unconverged value (error) -302.035 (1.91190067e-06)
146396 EPS nconv=0 first unconverged value (error) -302.035 (1.89189553e-06)
146397 EPS nconv=0 first unconverged value (error) -302.035 (1.88011022e-06)
146398 EPS nconv=0 first unconverged value (error) -302.035 (1.88353077e-06)
146399 EPS nconv=0 first unconverged value (error) -302.035 (1.83263377e-06)
146400 EPS nconv=0 first unconverged value (error) -302.035 (1.80268745e-06)
146401 EPS nconv=0 first unconverged value (error) -302.035 (1.80268745e-06)
146402 EPS nconv=0 first unconverged value (error) -302.035 (2.17829320e-06)
146403 EPS nconv=0 first unconverged value (error) -302.035 (2.07641799e-06)
146404 EPS nconv=0 first unconverged value (error) -302.035 (2.02652835e-06)
146405 EPS nconv=0 first unconverged value (error) -302.035 (1.98958270e-06)
146406 EPS nconv=0 first unconverged value (error) -302.035 (1.96737830e-06)
146407 EPS nconv=0 first unconverged value (error) -302.035 (1.96737830e-06)
146408 EPS nconv=0 first unconverged value (error) -302.035 (2.28921072e-06)
146409 EPS nconv=0 first unconverged value (error) -302.035 (2.17174005e-06)
146410 EPS nconv=0 first unconverged value (error) -302.035 (2.06127397e-06)
146411 EPS nconv=0 first unconverged value (error) -302.035 (2.05992682e-06)
146412 EPS nconv=0 first unconverged value (error) -302.035 (2.04492639e-06)
146413 EPS nconv=0 first unconverged value (error) -302.035 (2.04492639e-06)
146414 EPS nconv=0 first unconverged value (error) -302.035 (2.71309594e-06)
146415 EPS nconv=0 first unconverged value (error) -302.035 (2.45234018e-06)
146416 EPS nconv=0 first unconverged value (error) -302.035 (2.13742553e-06)
146417 EPS nconv=0 first unconverged value (error) -302.035 (2.18541705e-06)
146418 EPS nconv=0 first unconverged value (error) -302.035 (2.04811642e-06)
146419 EPS nconv=0 first unconverged value (error) -302.035 (2.04811642e-06)
146420 EPS nconv=0 first unconverged value (error) -302.035 (2.07401732e-06)
146421 EPS nconv=0 first unconverged value (error) -302.035 (2.30290091e-06)
146422 EPS nconv=0 first unconverged value (error) -302.035 (2.08025086e-06)
146423 EPS nconv=0 first unconverged value (error) -302.035 (1.86542985e-06)
146424 EPS nconv=0 first unconverged value (error) -302.035 (1.83687004e-06)
146425 EPS nconv=0 first unconverged value (error) -302.035 (1.83687004e-06)
146426 EPS nconv=0 first unconverged value (error) -302.035 (1.88317957e-06)
146427 EPS nconv=0 first unconverged value (error) -302.035 (1.85053285e-06)
146428 EPS nconv=0 first unconverged value (error) -302.035 (1.83706548e-06)
146429 EPS nconv=0 first unconverged value (error) -302.035 (1.83491680e-06)
146430 EPS nconv=0 first unconverged value (error) -302.035 (1.82713621e-06)
146431 EPS nconv=0 first unconverged value (error) -302.035 (1.82713621e-06)
146432 EPS nconv=0 first unconverged value (error) -302.035 (2.24254776e-06)
146433 EPS nconv=0 first unconverged value (error) -302.035 (2.20859730e-06)
146434 EPS nconv=0 first unconverged value (error) -302.035 (2.05312316e-06)
146435 EPS nconv=0 first unconverged value (error) -302.035 (1.97665654e-06)
146436 EPS nconv=0 first unconverged value (error) -302.035 (1.95798030e-06)
146437 EPS nconv=0 first unconverged value (error) -302.035 (1.95798030e-06)
146438 EPS nconv=0 first unconverged value (error) -302.035 (2.00675510e-06)
146439 EPS nconv=0 first unconverged value (error) -302.035 (2.09442069e-06)
146440 EPS nconv=0 first unconverged value (error) -302.035 (1.99953822e-06)
146441 EPS nconv=0 first unconverged value (error) -302.035 (1.90699638e-06)
146442 EPS nconv=0 first unconverged value (error) -302.035 (1.83769157e-06)
146443 EPS nconv=0 first unconverged value (error) -302.035 (1.83769157e-06)
146444 EPS nconv=0 first unconverged value (error) -302.035 (1.87810360e-06)
146445 EPS nconv=0 first unconverged value (error) -302.035 (1.86645592e-06)
146446 EPS nconv=0 first unconverged value (error) -302.035 (1.84782653e-06)
146447 EPS nconv=0 first unconverged value (error) -302.035 (1.83967660e-06)
146448 EPS nconv=0 first unconverged value (error) -302.035 (1.82958166e-06)
146449 EPS nconv=0 first unconverged value (error) -302.035 (1.82958166e-06)
146450 EPS nconv=0 first unconverged value (error) -302.035 (2.26637298e-06)
146451 EPS nconv=0 first unconverged value (error) -302.035 (2.21487300e-06)
146452 EPS nconv=0 first unconverged value (error) -302.035 (2.10385026e-06)
146453 EPS nconv=0 first unconverged value (error) -302.035 (2.01369004e-06)
146454 EPS nconv=0 first unconverged value (error) -302.035 (1.99237787e-06)
146455 EPS nconv=0 first unconverged value (error) -302.035 (1.99237787e-06)
146456 EPS nconv=0 first unconverged value (error) -302.035 (1.98761386e-06)
146457 EPS nconv=0 first unconverged value (error) -302.035 (2.04868257e-06)
146458 EPS nconv=0 first unconverged value (error) -302.035 (1.96141612e-06)
146459 EPS nconv=0 first unconverged value (error) -302.035 (1.85278306e-06)
146460 EPS nconv=0 first unconverged value (error) -302.035 (1.83231521e-06)
146461 EPS nconv=0 first unconverged value (error) -302.035 (1.83231521e-06)
146462 EPS nconv=0 first unconverged value (error) -302.035 (1.81960306e-06)
146463 EPS nconv=0 first unconverged value (error) -302.035 (1.81239769e-06)
146464 EPS nconv=0 first unconverged value (error) -302.035 (1.80991604e-06)
146465 EPS nconv=0 first unconverged value (error) -302.035 (1.80778735e-06)
146466 EPS nconv=0 first unconverged value (error) -302.035 (1.80551462e-06)
146467 EPS nconv=0 first unconverged value (error) -302.035 (1.80551462e-06)
146468 EPS nconv=0 first unconverged value (error) -302.035 (2.15405797e-06)
146469 EPS nconv=0 first unconverged value (error) -302.035 (2.02589568e-06)
146470 EPS nconv=0 first unconverged value (error) -302.035 (1.97699580e-06)
146471 EPS nconv=0 first unconverged value (error) -302.035 (1.95577737e-06)
146472 EPS nconv=0 first unconverged value (error) -302.035 (1.92233792e-06)
146473 EPS nconv=0 first unconverged value (error) -302.035 (1.92233792e-06)
146474 EPS nconv=0 first unconverged value (error) -302.035 (1.91686738e-06)
146475 EPS nconv=0 first unconverged value (error) -302.035 (2.03959852e-06)
146476 EPS nconv=0 first unconverged value (error) -302.035 (1.90217400e-06)
146477 EPS nconv=0 first unconverged value (error) -302.035 (1.83163345e-06)
146478 EPS nconv=0 first unconverged value (error) -302.035 (1.81973718e-06)
146479 EPS nconv=0 first unconverged value (error) -302.035 (1.81973718e-06)
146480 EPS nconv=0 first unconverged value (error) -302.035 (1.92435978e-06)
146481 EPS nconv=0 first unconverged value (error) -302.035 (1.88471420e-06)
146482 EPS nconv=0 first unconverged value (error) -302.035 (1.86356111e-06)
146483 EPS nconv=0 first unconverged value (error) -302.035 (1.85674190e-06)
146484 EPS nconv=0 first unconverged value (error) -302.035 (1.84663108e-06)
146485 EPS nconv=0 first unconverged value (error) -302.035 (1.84663108e-06)
146486 EPS nconv=0 first unconverged value (error) -302.035 (1.95397606e-06)
146487 EPS nconv=0 first unconverged value (error) -302.035 (1.93763641e-06)
146488 EPS nconv=0 first unconverged value (error) -302.035 (1.88345800e-06)
146489 EPS nconv=0 first unconverged value (error) -302.035 (1.87834029e-06)
146490 EPS nconv=0 first unconverged value (error) -302.035 (1.86846382e-06)
146491 EPS nconv=0 first unconverged value (error) -302.035 (1.86846382e-06)
146492 EPS nconv=0 first unconverged value (error) -302.035 (2.17932024e-06)
146493 EPS nconv=0 first unconverged value (error) -302.035 (2.12102795e-06)
146494 EPS nconv=0 first unconverged value (error) -302.035 (2.03868091e-06)
146495 EPS nconv=0 first unconverged value (error) -302.035 (1.96929048e-06)
146496 EPS nconv=0 first unconverged value (error) -302.035 (1.93471526e-06)
146497 EPS nconv=0 first unconverged value (error) -302.035 (1.93471526e-06)
146498 EPS nconv=0 first unconverged value (error) -302.035 (2.03050795e-06)
146499 EPS nconv=0 first unconverged value (error) -302.035 (2.07752380e-06)
146500 EPS nconv=0 first unconverged value (error) -302.035 (1.95713104e-06)
146501 EPS nconv=0 first unconverged value (error) -302.035 (1.88732075e-06)
146502 EPS nconv=0 first unconverged value (error) -302.035 (1.87317439e-06)
146503 EPS nconv=0 first unconverged value (error) -302.035 (1.87317439e-06)
146504 EPS nconv=0 first unconverged value (error) -302.035 (1.84453165e-06)
146505 EPS nconv=0 first unconverged value (error) -302.035 (1.87966417e-06)
146506 EPS nconv=0 first unconverged value (error) -302.035 (1.83542802e-06)
146507 EPS nconv=0 first unconverged value (error) -302.035 (1.81835298e-06)
146508 EPS nconv=0 first unconverged value (error) -302.035 (1.80431362e-06)
146509 EPS nconv=0 first unconverged value (error) -302.035 (1.80431362e-06)
146510 EPS nconv=0 first unconverged value (error) -302.035 (1.85180909e-06)
146511 EPS nconv=0 first unconverged value (error) -302.035 (1.83420552e-06)
146512 EPS nconv=0 first unconverged value (error) -302.035 (1.82338813e-06)
146513 EPS nconv=0 first unconverged value (error) -302.035 (1.81962738e-06)
146514 EPS nconv=0 first unconverged value (error) -302.035 (1.81364136e-06)
146515 EPS nconv=0 first unconverged value (error) -302.035 (1.81364136e-06)
146516 EPS nconv=0 first unconverged value (error) -302.035 (1.81826556e-06)
146517 EPS nconv=0 first unconverged value (error) -302.035 (1.82913025e-06)
146518 EPS nconv=0 first unconverged value (error) -302.035 (1.81855270e-06)
146519 EPS nconv=0 first unconverged value (error) -302.035 (1.80264487e-06)
146520 EPS nconv=0 first unconverged value (error) -302.035 (1.80085742e-06)
146521 EPS nconv=0 first unconverged value (error) -302.035 (1.80085742e-06)
146522 EPS nconv=0 first unconverged value (error) -302.035 (1.93170264e-06)
146523 EPS nconv=0 first unconverged value (error) -302.035 (1.88014322e-06)
146524 EPS nconv=0 first unconverged value (error) -302.035 (1.86471114e-06)
146525 EPS nconv=0 first unconverged value (error) -302.035 (1.85424218e-06)
146526 EPS nconv=0 first unconverged value (error) -302.035 (1.84490198e-06)
146527 EPS nconv=0 first unconverged value (error) -302.035 (1.84490198e-06)
146528 EPS nconv=0 first unconverged value (error) -302.035 (1.90644716e-06)
146529 EPS nconv=0 first unconverged value (error) -302.035 (1.90730447e-06)
146530 EPS nconv=0 first unconverged value (error) -302.035 (1.85838146e-06)
146531 EPS nconv=0 first unconverged value (error) -302.035 (1.85174826e-06)
146532 EPS nconv=0 first unconverged value (error) -302.035 (1.84573780e-06)
146533 EPS nconv=0 first unconverged value (error) -302.035 (1.84573780e-06)
146534 EPS nconv=0 first unconverged value (error) -302.035 (1.91917385e-06)
146535 EPS nconv=0 first unconverged value (error) -302.035 (1.88978515e-06)
146536 EPS nconv=0 first unconverged value (error) -302.035 (1.86236997e-06)
146537 EPS nconv=0 first unconverged value (error) -302.035 (1.85656384e-06)
146538 EPS nconv=0 first unconverged value (error) -302.035 (1.84022862e-06)
146539 EPS nconv=0 first unconverged value (error) -302.035 (1.84022862e-06)
146540 EPS nconv=0 first unconverged value (error) -302.035 (2.11908952e-06)
146541 EPS nconv=0 first unconverged value (error) -302.035 (2.11250252e-06)
146542 EPS nconv=0 first unconverged value (error) -302.035 (2.00944061e-06)
146543 EPS nconv=0 first unconverged value (error) -302.035 (1.92282759e-06)
146544 EPS nconv=0 first unconverged value (error) -302.035 (1.90783250e-06)
146545 EPS nconv=0 first unconverged value (error) -302.035 (1.90783250e-06)
146546 EPS nconv=0 first unconverged value (error) -302.035 (2.09154784e-06)
146547 EPS nconv=0 first unconverged value (error) -302.035 (2.08625824e-06)
146548 EPS nconv=0 first unconverged value (error) -302.035 (2.01099094e-06)
146549 EPS nconv=0 first unconverged value (error) -302.035 (1.94046243e-06)
146550 EPS nconv=0 first unconverged value (error) -302.035 (1.90181999e-06)
146551 EPS nconv=0 first unconverged value (error) -302.035 (1.90181999e-06)
146552 EPS nconv=0 first unconverged value (error) -302.035 (2.07421465e-06)
146553 EPS nconv=0 first unconverged value (error) -302.035 (2.03176952e-06)
146554 EPS nconv=0 first unconverged value (error) -302.035 (1.95718889e-06)
146555 EPS nconv=0 first unconverged value (error) -302.035 (1.91129453e-06)
146556 EPS nconv=0 first unconverged value (error) -302.035 (1.88395521e-06)
146557 EPS nconv=0 first unconverged value (error) -302.035 (1.88395521e-06)
146558 EPS nconv=0 first unconverged value (error) -302.035 (1.96259174e-06)
146559 EPS nconv=0 first unconverged value (error) -302.035 (1.97112064e-06)
146560 EPS nconv=0 first unconverged value (error) -302.035 (1.91533526e-06)
146561 EPS nconv=0 first unconverged value (error) -302.035 (1.86779024e-06)
146562 EPS nconv=0 first unconverged value (error) -302.035 (1.86553486e-06)
146563 EPS nconv=0 first unconverged value (error) -302.035 (1.86553486e-06)
146564 EPS nconv=0 first unconverged value (error) -302.035 (1.89131051e-06)
146565 EPS nconv=0 first unconverged value (error) -302.035 (1.86647234e-06)
146566 EPS nconv=0 first unconverged value (error) -302.035 (1.83360189e-06)
146567 EPS nconv=0 first unconverged value (error) -302.035 (1.81915518e-06)
146568 EPS nconv=0 first unconverged value (error) -302.035 (1.81187025e-06)
146569 EPS nconv=0 first unconverged value (error) -302.035 (1.81187025e-06)
146570 EPS nconv=0 first unconverged value (error) -302.035 (1.81114455e-06)
146571 EPS nconv=0 first unconverged value (error) -302.035 (1.83251222e-06)
146572 EPS nconv=0 first unconverged value (error) -302.035 (1.80809809e-06)
146573 EPS nconv=0 first unconverged value (error) -302.035 (1.79996542e-06)
146574 EPS nconv=0 first unconverged value (error) -302.035 (1.79770119e-06)
146575 EPS nconv=0 first unconverged value (error) -302.035 (1.79770119e-06)
146576 EPS nconv=0 first unconverged value (error) -302.035 (1.82193132e-06)
146577 EPS nconv=0 first unconverged value (error) -302.035 (1.81432255e-06)
146578 EPS nconv=0 first unconverged value (error) -302.035 (1.81120092e-06)
146579 EPS nconv=0 first unconverged value (error) -302.035 (1.81124048e-06)
146580 EPS nconv=0 first unconverged value (error) -302.035 (1.80736568e-06)
146581 EPS nconv=0 first unconverged value (error) -302.035 (1.80736568e-06)
146582 EPS nconv=0 first unconverged value (error) -302.035 (2.32509376e-06)
146583 EPS nconv=0 first unconverged value (error) -302.035 (2.36184790e-06)
146584 EPS nconv=0 first unconverged value (error) -302.035 (2.24697857e-06)
146585 EPS nconv=0 first unconverged value (error) -302.035 (2.13163976e-06)
146586 EPS nconv=0 first unconverged value (error) -302.035 (2.11610332e-06)
146587 EPS nconv=0 first unconverged value (error) -302.035 (2.11610332e-06)
146588 EPS nconv=0 first unconverged value (error) -302.035 (2.10848638e-06)
146589 EPS nconv=0 first unconverged value (error) -302.035 (2.02044875e-06)
146590 EPS nconv=0 first unconverged value (error) -302.035 (2.01359908e-06)
146591 EPS nconv=0 first unconverged value (error) -302.035 (1.85238814e-06)
146592 EPS nconv=0 first unconverged value (error) -302.035 (1.83571913e-06)
146593 EPS nconv=0 first unconverged value (error) -302.035 (1.83571913e-06)
146594 EPS nconv=0 first unconverged value (error) -302.035 (2.34214705e-06)
146595 EPS nconv=0 first unconverged value (error) -302.035 (2.13571460e-06)
146596 EPS nconv=0 first unconverged value (error) -302.035 (2.07922403e-06)
146597 EPS nconv=0 first unconverged value (error) -302.035 (2.01375802e-06)
146598 EPS nconv=0 first unconverged value (error) -302.035 (1.99111515e-06)
146599 EPS nconv=0 first unconverged value (error) -302.035 (1.99111515e-06)
146600 EPS nconv=0 first unconverged value (error) -302.035 (2.08571930e-06)
146601 EPS nconv=0 first unconverged value (error) -302.035 (2.23217212e-06)
146602 EPS nconv=0 first unconverged value (error) -302.035 (2.02940014e-06)
146603 EPS nconv=0 first unconverged value (error) -302.035 (1.90832225e-06)
146604 EPS nconv=0 first unconverged value (error) -302.035 (1.86372072e-06)
146605 EPS nconv=0 first unconverged value (error) -302.035 (1.86372072e-06)
146606 EPS nconv=0 first unconverged value (error) -302.035 (1.84182001e-06)
146607 EPS nconv=0 first unconverged value (error) -302.035 (1.84526758e-06)
146608 EPS nconv=0 first unconverged value (error) -302.035 (1.82351447e-06)
146609 EPS nconv=0 first unconverged value (error) -302.035 (1.80212540e-06)
146610 EPS nconv=0 first unconverged value (error) -302.035 (1.79800609e-06)
146611 EPS nconv=0 first unconverged value (error) -302.035 (1.79800609e-06)
146612 EPS nconv=0 first unconverged value (error) -302.035 (1.79721145e-06)
146613 EPS nconv=0 first unconverged value (error) -302.035 (1.79610101e-06)
146614 EPS nconv=0 first unconverged value (error) -302.035 (1.79561581e-06)
146615 EPS nconv=0 first unconverged value (error) -302.035 (1.79541410e-06)
146616 EPS nconv=0 first unconverged value (error) -302.035 (1.79529384e-06)
146617 EPS nconv=0 first unconverged value (error) -302.035 (1.79529384e-06)
146618 EPS nconv=0 first unconverged value (error) -302.035 (2.06111559e-06)
146619 EPS nconv=0 first unconverged value (error) -302.035 (1.98111070e-06)
146620 EPS nconv=0 first unconverged value (error) -302.035 (1.93240128e-06)
146621 EPS nconv=0 first unconverged value (error) -302.035 (1.90400486e-06)
146622 EPS nconv=0 first unconverged value (error) -302.035 (1.89393607e-06)
146623 EPS nconv=0 first unconverged value (error) -302.035 (1.89393607e-06)
146624 EPS nconv=0 first unconverged value (error) -302.035 (1.89923182e-06)
146625 EPS nconv=0 first unconverged value (error) -302.035 (1.96561501e-06)
146626 EPS nconv=0 first unconverged value (error) -302.035 (1.89405521e-06)
146627 EPS nconv=0 first unconverged value (error) -302.035 (1.81336701e-06)
146628 EPS nconv=0 first unconverged value (error) -302.035 (1.80900164e-06)
146629 EPS nconv=0 first unconverged value (error) -302.035 (1.80900164e-06)
146630 EPS nconv=0 first unconverged value (error) -302.035 (1.91733280e-06)
146631 EPS nconv=0 first unconverged value (error) -302.035 (1.86900827e-06)
146632 EPS nconv=0 first unconverged value (error) -302.035 (1.86029236e-06)
146633 EPS nconv=0 first unconverged value (error) -302.035 (1.85486575e-06)
146634 EPS nconv=0 first unconverged value (error) -302.035 (1.85204751e-06)
146635 EPS nconv=0 first unconverged value (error) -302.035 (1.85204751e-06)
146636 EPS nconv=0 first unconverged value (error) -302.035 (1.91140232e-06)
146637 EPS nconv=0 first unconverged value (error) -302.035 (1.88151048e-06)
146638 EPS nconv=0 first unconverged value (error) -302.035 (1.82918712e-06)
146639 EPS nconv=0 first unconverged value (error) -302.035 (1.82513213e-06)
146640 EPS nconv=0 first unconverged value (error) -302.035 (1.82181661e-06)
146641 EPS nconv=0 first unconverged value (error) -302.035 (1.82181661e-06)
146642 EPS nconv=0 first unconverged value (error) -302.035 (1.93138546e-06)
146643 EPS nconv=0 first unconverged value (error) -302.035 (1.91610856e-06)
146644 EPS nconv=0 first unconverged value (error) -302.035 (1.86929877e-06)
146645 EPS nconv=0 first unconverged value (error) -302.035 (1.85685503e-06)
146646 EPS nconv=0 first unconverged value (error) -302.035 (1.84984941e-06)
146647 EPS nconv=0 first unconverged value (error) -302.035 (1.84984941e-06)
146648 EPS nconv=0 first unconverged value (error) -302.035 (2.01623368e-06)
146649 EPS nconv=0 first unconverged value (error) -302.035 (1.99771055e-06)
146650 EPS nconv=0 first unconverged value (error) -302.035 (1.93980928e-06)
146651 EPS nconv=0 first unconverged value (error) -302.035 (1.89919528e-06)
146652 EPS nconv=0 first unconverged value (error) -302.035 (1.87752675e-06)
146653 EPS nconv=0 first unconverged value (error) -302.035 (1.87752675e-06)
146654 EPS nconv=0 first unconverged value (error) -302.035 (1.91413923e-06)
146655 EPS nconv=0 first unconverged value (error) -302.035 (1.92303522e-06)
146656 EPS nconv=0 first unconverged value (error) -302.035 (1.87696507e-06)
146657 EPS nconv=0 first unconverged value (error) -302.035 (1.84132434e-06)
146658 EPS nconv=0 first unconverged value (error) -302.035 (1.84214435e-06)
146659 EPS nconv=0 first unconverged value (error) -302.035 (1.84214435e-06)
146660 EPS nconv=0 first unconverged value (error) -302.035 (1.85947531e-06)
146661 EPS nconv=0 first unconverged value (error) -302.035 (1.83485513e-06)
146662 EPS nconv=0 first unconverged value (error) -302.035 (1.82339444e-06)
146663 EPS nconv=0 first unconverged value (error) -302.035 (1.81448116e-06)
146664 EPS nconv=0 first unconverged value (error) -302.035 (1.81090909e-06)
146665 EPS nconv=0 first unconverged value (error) -302.035 (1.81090909e-06)
146666 EPS nconv=0 first unconverged value (error) -302.035 (1.84855276e-06)
146667 EPS nconv=0 first unconverged value (error) -302.035 (1.85145244e-06)
146668 EPS nconv=0 first unconverged value (error) -302.035 (1.82666293e-06)
146669 EPS nconv=0 first unconverged value (error) -302.035 (1.81830151e-06)
146670 EPS nconv=0 first unconverged value (error) -302.035 (1.81577415e-06)
146671 EPS nconv=0 first unconverged value (error) -302.035 (1.81577415e-06)
146672 EPS nconv=0 first unconverged value (error) -302.035 (2.17024634e-06)
146673 EPS nconv=0 first unconverged value (error) -302.035 (2.07051346e-06)
146674 EPS nconv=0 first unconverged value (error) -302.035 (2.02020323e-06)
146675 EPS nconv=0 first unconverged value (error) -302.035 (2.00022391e-06)
146676 EPS nconv=0 first unconverged value (error) -302.035 (1.95634459e-06)
146677 EPS nconv=0 first unconverged value (error) -302.035 (1.95634459e-06)
146678 EPS nconv=0 first unconverged value (error) -302.035 (2.34802165e-06)
146679 EPS nconv=0 first unconverged value (error) -302.035 (2.33443665e-06)
146680 EPS nconv=0 first unconverged value (error) -302.035 (2.22003835e-06)
146681 EPS nconv=0 first unconverged value (error) -302.035 (2.08588652e-06)
146682 EPS nconv=0 first unconverged value (error) -302.035 (2.05879112e-06)
146683 EPS nconv=0 first unconverged value (error) -302.035 (2.05879112e-06)
146684 EPS nconv=0 first unconverged value (error) -302.035 (2.03927724e-06)
146685 EPS nconv=0 first unconverged value (error) -302.035 (2.02176839e-06)
146686 EPS nconv=0 first unconverged value (error) -302.035 (1.88480660e-06)
146687 EPS nconv=0 first unconverged value (error) -302.035 (1.85127654e-06)
146688 EPS nconv=0 first unconverged value (error) -302.035 (1.84336001e-06)
146689 EPS nconv=0 first unconverged value (error) -302.035 (1.84336001e-06)
146690 EPS nconv=0 first unconverged value (error) -302.035 (1.81559668e-06)
146691 EPS nconv=0 first unconverged value (error) -302.035 (1.82058976e-06)
146692 EPS nconv=0 first unconverged value (error) -302.035 (1.80927465e-06)
146693 EPS nconv=0 first unconverged value (error) -302.035 (1.80433839e-06)
146694 EPS nconv=0 first unconverged value (error) -302.035 (1.80139663e-06)
146695 EPS nconv=0 first unconverged value (error) -302.035 (1.80139663e-06)
146696 EPS nconv=0 first unconverged value (error) -302.035 (2.10935617e-06)
146697 EPS nconv=0 first unconverged value (error) -302.035 (2.03375230e-06)
146698 EPS nconv=0 first unconverged value (error) -302.035 (1.98352426e-06)
146699 EPS nconv=0 first unconverged value (error) -302.035 (1.96159318e-06)
146700 EPS nconv=0 first unconverged value (error) -302.035 (1.92917532e-06)
146701 EPS nconv=0 first unconverged value (error) -302.035 (1.92917532e-06)
146702 EPS nconv=0 first unconverged value (error) -302.035 (2.05995111e-06)
146703 EPS nconv=0 first unconverged value (error) -302.035 (2.05753513e-06)
146704 EPS nconv=0 first unconverged value (error) -302.035 (1.96415068e-06)
146705 EPS nconv=0 first unconverged value (error) -302.035 (1.94222145e-06)
146706 EPS nconv=0 first unconverged value (error) -302.035 (1.93145188e-06)
146707 EPS nconv=0 first unconverged value (error) -302.035 (1.93145188e-06)
146708 EPS nconv=0 first unconverged value (error) -302.035 (1.91006410e-06)
146709 EPS nconv=0 first unconverged value (error) -302.035 (1.87359099e-06)
146710 EPS nconv=0 first unconverged value (error) -302.035 (1.85613183e-06)
146711 EPS nconv=0 first unconverged value (error) -302.035 (1.82158064e-06)
146712 EPS nconv=0 first unconverged value (error) -302.035 (1.81632206e-06)
146713 EPS nconv=0 first unconverged value (error) -302.035 (1.81632206e-06)
146714 EPS nconv=0 first unconverged value (error) -302.035 (1.97750187e-06)
146715 EPS nconv=0 first unconverged value (error) -302.035 (1.90805800e-06)
146716 EPS nconv=0 first unconverged value (error) -302.035 (1.87988785e-06)
146717 EPS nconv=0 first unconverged value (error) -302.035 (1.86440964e-06)
146718 EPS nconv=0 first unconverged value (error) -302.035 (1.85698257e-06)
146719 EPS nconv=0 first unconverged value (error) -302.035 (1.85698257e-06)
146720 EPS nconv=0 first unconverged value (error) -302.035 (1.95385116e-06)
146721 EPS nconv=0 first unconverged value (error) -302.035 (2.03918319e-06)
146722 EPS nconv=0 first unconverged value (error) -302.035 (1.94901765e-06)
146723 EPS nconv=0 first unconverged value (error) -302.035 (1.86614018e-06)
146724 EPS nconv=0 first unconverged value (error) -302.035 (1.84731930e-06)
146725 EPS nconv=0 first unconverged value (error) -302.035 (1.84731930e-06)
146726 EPS nconv=0 first unconverged value (error) -302.035 (1.85226307e-06)
146727 EPS nconv=0 first unconverged value (error) -302.035 (1.84805890e-06)
146728 EPS nconv=0 first unconverged value (error) -302.035 (1.82372472e-06)
146729 EPS nconv=0 first unconverged value (error) -302.035 (1.81157251e-06)
146730 EPS nconv=0 first unconverged value (error) -302.035 (1.80400887e-06)
146731 EPS nconv=0 first unconverged value (error) -302.035 (1.80400887e-06)
146732 EPS nconv=0 first unconverged value (error) -302.035 (1.94795463e-06)
146733 EPS nconv=0 first unconverged value (error) -302.035 (1.89898857e-06)
146734 EPS nconv=0 first unconverged value (error) -302.035 (1.86036158e-06)
146735 EPS nconv=0 first unconverged value (error) -302.035 (1.84715048e-06)
146736 EPS nconv=0 first unconverged value (error) -302.035 (1.84008397e-06)
146737 EPS nconv=0 first unconverged value (error) -302.035 (1.84008397e-06)
146738 EPS nconv=0 first unconverged value (error) -302.035 (2.17721730e-06)
146739 EPS nconv=0 first unconverged value (error) -302.035 (2.12120296e-06)
146740 EPS nconv=0 first unconverged value (error) -302.035 (2.04789146e-06)
146741 EPS nconv=0 first unconverged value (error) -302.035 (1.96950595e-06)
146742 EPS nconv=0 first unconverged value (error) -302.035 (1.94171267e-06)
146743 EPS nconv=0 first unconverged value (error) -302.035 (1.94171267e-06)
146744 EPS nconv=0 first unconverged value (error) -302.035 (3.41947355e-06)
146745 EPS nconv=0 first unconverged value (error) -302.035 (3.22682552e-06)
146746 EPS nconv=0 first unconverged value (error) -302.035 (2.93988828e-06)
146747 EPS nconv=0 first unconverged value (error) -302.035 (2.88343503e-06)
146748 EPS nconv=0 first unconverged value (error) -302.035 (2.80952469e-06)
146749 EPS nconv=0 first unconverged value (error) -302.035 (2.80952469e-06)
146750 EPS nconv=0 first unconverged value (error) -302.035 (2.91131758e-06)
146751 EPS nconv=0 first unconverged value (error) -302.035 (2.65600333e-06)
146752 EPS nconv=0 first unconverged value (error) -302.035 (2.36482186e-06)
146753 EPS nconv=0 first unconverged value (error) -302.035 (2.10600698e-06)
146754 EPS nconv=0 first unconverged value (error) -302.035 (2.01572685e-06)
146755 EPS nconv=0 first unconverged value (error) -302.035 (2.01572685e-06)
146756 EPS nconv=0 first unconverged value (error) -302.035 (2.54617523e-06)
146757 EPS nconv=0 first unconverged value (error) -302.035 (2.57426864e-06)
146758 EPS nconv=0 first unconverged value (error) -302.035 (2.34500772e-06)
146759 EPS nconv=0 first unconverged value (error) -302.035 (2.12665542e-06)
146760 EPS nconv=0 first unconverged value (error) -302.035 (2.07642455e-06)
146761 EPS nconv=0 first unconverged value (error) -302.035 (2.07642455e-06)
146762 EPS nconv=0 first unconverged value (error) -302.035 (2.26529445e-06)
146763 EPS nconv=0 first unconverged value (error) -302.035 (2.35461073e-06)
146764 EPS nconv=0 first unconverged value (error) -302.035 (2.20483187e-06)
146765 EPS nconv=0 first unconverged value (error) -302.035 (1.99153818e-06)
146766 EPS nconv=0 first unconverged value (error) -302.035 (1.93327188e-06)
146767 EPS nconv=0 first unconverged value (error) -302.035 (1.93327188e-06)
146768 EPS nconv=0 first unconverged value (error) -302.035 (2.72934463e-06)
146769 EPS nconv=0 first unconverged value (error) -302.035 (2.52456378e-06)
146770 EPS nconv=0 first unconverged value (error) -302.035 (2.45805163e-06)
146771 EPS nconv=0 first unconverged value (error) -302.035 (2.34033776e-06)
146772 EPS nconv=0 first unconverged value (error) -302.035 (2.24911818e-06)
146773 EPS nconv=0 first unconverged value (error) -302.035 (2.24911818e-06)
146774 EPS nconv=0 first unconverged value (error) -302.035 (3.50660335e-06)
146775 EPS nconv=0 first unconverged value (error) -302.035 (3.26559064e-06)
146776 EPS nconv=0 first unconverged value (error) -302.035 (2.85207627e-06)
146777 EPS nconv=0 first unconverged value (error) -302.035 (2.83274148e-06)
146778 EPS nconv=0 first unconverged value (error) -302.035 (2.64118616e-06)
146779 EPS nconv=0 first unconverged value (error) -302.035 (2.64118616e-06)
146780 EPS nconv=0 first unconverged value (error) -302.035 (2.63785554e-06)
146781 EPS nconv=0 first unconverged value (error) -302.035 (2.79761745e-06)
146782 EPS nconv=0 first unconverged value (error) -302.035 (2.43582980e-06)
146783 EPS nconv=0 first unconverged value (error) -302.035 (2.14499783e-06)
146784 EPS nconv=0 first unconverged value (error) -302.035 (2.00368081e-06)
146785 EPS nconv=0 first unconverged value (error) -302.035 (2.00368081e-06)
146786 EPS nconv=0 first unconverged value (error) -302.035 (2.17742707e-06)
146787 EPS nconv=0 first unconverged value (error) -302.035 (2.11836383e-06)
146788 EPS nconv=0 first unconverged value (error) -302.035 (2.06243486e-06)
146789 EPS nconv=0 first unconverged value (error) -302.035 (1.99843546e-06)
146790 EPS nconv=0 first unconverged value (error) -302.035 (1.96629742e-06)
146791 EPS nconv=0 first unconverged value (error) -302.035 (1.96629742e-06)
146792 EPS nconv=0 first unconverged value (error) -302.035 (1.96124889e-06)
146793 EPS nconv=0 first unconverged value (error) -302.035 (2.05199607e-06)
146794 EPS nconv=0 first unconverged value (error) -302.035 (1.91805268e-06)
146795 EPS nconv=0 first unconverged value (error) -302.035 (1.86871685e-06)
146796 EPS nconv=0 first unconverged value (error) -302.035 (1.83603298e-06)
146797 EPS nconv=0 first unconverged value (error) -302.035 (1.83603298e-06)
146798 EPS nconv=0 first unconverged value (error) -302.035 (2.15802135e-06)
146799 EPS nconv=0 first unconverged value (error) -302.035 (2.08489051e-06)
146800 EPS nconv=0 first unconverged value (error) -302.035 (2.02496268e-06)
146801 EPS nconv=0 first unconverged value (error) -302.035 (2.00623307e-06)
146802 EPS nconv=0 first unconverged value (error) -302.035 (1.96342703e-06)
146803 EPS nconv=0 first unconverged value (error) -302.035 (1.96342703e-06)
146804 EPS nconv=0 first unconverged value (error) -302.035 (2.34603329e-06)
146805 EPS nconv=0 first unconverged value (error) -302.035 (2.36828835e-06)
146806 EPS nconv=0 first unconverged value (error) -302.035 (2.27466439e-06)
146807 EPS nconv=0 first unconverged value (error) -302.035 (2.14045978e-06)
146808 EPS nconv=0 first unconverged value (error) -302.035 (2.08292551e-06)
146809 EPS nconv=0 first unconverged value (error) -302.035 (2.08292551e-06)
146810 EPS nconv=0 first unconverged value (error) -302.035 (2.07158836e-06)
146811 EPS nconv=0 first unconverged value (error) -302.035 (1.98495587e-06)
146812 EPS nconv=0 first unconverged value (error) -302.035 (1.90802328e-06)
146813 EPS nconv=0 first unconverged value (error) -302.035 (1.86907564e-06)
146814 EPS nconv=0 first unconverged value (error) -302.035 (1.84344929e-06)
146815 EPS nconv=0 first unconverged value (error) -302.035 (1.84344929e-06)
146816 EPS nconv=0 first unconverged value (error) -302.035 (2.02357969e-06)
146817 EPS nconv=0 first unconverged value (error) -302.035 (1.92093064e-06)
146818 EPS nconv=0 first unconverged value (error) -302.035 (1.86755194e-06)
146819 EPS nconv=0 first unconverged value (error) -302.035 (1.85456768e-06)
146820 EPS nconv=0 first unconverged value (error) -302.035 (1.84508871e-06)
146821 EPS nconv=0 first unconverged value (error) -302.035 (1.84508871e-06)
146822 EPS nconv=0 first unconverged value (error) -302.035 (2.24081234e-06)
146823 EPS nconv=0 first unconverged value (error) -302.035 (2.11937450e-06)
146824 EPS nconv=0 first unconverged value (error) -302.035 (1.99304929e-06)
146825 EPS nconv=0 first unconverged value (error) -302.035 (1.97124541e-06)
146826 EPS nconv=0 first unconverged value (error) -302.035 (1.94524304e-06)
146827 EPS nconv=0 first unconverged value (error) -302.035 (1.94524304e-06)
146828 EPS nconv=0 first unconverged value (error) -302.035 (4.39973090e-06)
146829 EPS nconv=0 first unconverged value (error) -302.035 (4.02274674e-06)
146830 EPS nconv=0 first unconverged value (error) -302.035 (3.59642121e-06)
146831 EPS nconv=0 first unconverged value (error) -302.035 (3.50719910e-06)
146832 EPS nconv=0 first unconverged value (error) -302.035 (3.42472608e-06)
146833 EPS nconv=0 first unconverged value (error) -302.035 (3.42472608e-06)
146834 EPS nconv=0 first unconverged value (error) -302.035 (3.81832156e-06)
146835 EPS nconv=0 first unconverged value (error) -302.035 (3.57647542e-06)
146836 EPS nconv=0 first unconverged value (error) -302.035 (3.02137544e-06)
146837 EPS nconv=0 first unconverged value (error) -302.035 (2.63727711e-06)
146838 EPS nconv=0 first unconverged value (error) -302.035 (2.39181916e-06)
146839 EPS nconv=0 first unconverged value (error) -302.035 (2.39181916e-06)
146840 EPS nconv=0 first unconverged value (error) -302.035 (2.21130606e-06)
146841 EPS nconv=0 first unconverged value (error) -302.035 (2.52561685e-06)
146842 EPS nconv=0 first unconverged value (error) -302.035 (2.23523872e-06)
146843 EPS nconv=0 first unconverged value (error) -302.035 (1.90848659e-06)
146844 EPS nconv=0 first unconverged value (error) -302.035 (1.85635312e-06)
146845 EPS nconv=0 first unconverged value (error) -302.035 (1.85635312e-06)
146846 EPS nconv=0 first unconverged value (error) -302.035 (1.92876115e-06)
146847 EPS nconv=0 first unconverged value (error) -302.035 (1.86678248e-06)
146848 EPS nconv=0 first unconverged value (error) -302.035 (1.84476291e-06)
146849 EPS nconv=0 first unconverged value (error) -302.035 (1.84120776e-06)
146850 EPS nconv=0 first unconverged value (error) -302.035 (1.83450513e-06)
146851 EPS nconv=0 first unconverged value (error) -302.035 (1.83450513e-06)
146852 EPS nconv=0 first unconverged value (error) -302.035 (1.85149009e-06)
146853 EPS nconv=0 first unconverged value (error) -302.035 (1.87751862e-06)
146854 EPS nconv=0 first unconverged value (error) -302.035 (1.83572603e-06)
146855 EPS nconv=0 first unconverged value (error) -302.035 (1.80402774e-06)
146856 EPS nconv=0 first unconverged value (error) -302.035 (1.80249845e-06)
146857 EPS nconv=0 first unconverged value (error) -302.035 (1.80249845e-06)
146858 EPS nconv=0 first unconverged value (error) -302.035 (1.84578354e-06)
146859 EPS nconv=0 first unconverged value (error) -302.035 (1.83040542e-06)
146860 EPS nconv=0 first unconverged value (error) -302.035 (1.82090915e-06)
146861 EPS nconv=0 first unconverged value (error) -302.035 (1.81263042e-06)
146862 EPS nconv=0 first unconverged value (error) -302.035 (1.81055748e-06)
146863 EPS nconv=0 first unconverged value (error) -302.035 (1.81055748e-06)
146864 EPS nconv=0 first unconverged value (error) -302.035 (1.97017157e-06)
146865 EPS nconv=0 first unconverged value (error) -302.035 (1.91246566e-06)
146866 EPS nconv=0 first unconverged value (error) -302.035 (1.87630772e-06)
146867 EPS nconv=0 first unconverged value (error) -302.035 (1.87523085e-06)
146868 EPS nconv=0 first unconverged value (error) -302.035 (1.86922125e-06)
146869 EPS nconv=0 first unconverged value (error) -302.035 (1.86922125e-06)
146870 EPS nconv=0 first unconverged value (error) -302.035 (1.94799307e-06)
146871 EPS nconv=0 first unconverged value (error) -302.035 (1.93295826e-06)
146872 EPS nconv=0 first unconverged value (error) -302.035 (1.85593478e-06)
146873 EPS nconv=0 first unconverged value (error) -302.035 (1.84982293e-06)
146874 EPS nconv=0 first unconverged value (error) -302.035 (1.84365978e-06)
146875 EPS nconv=0 first unconverged value (error) -302.035 (1.84365978e-06)
146876 EPS nconv=0 first unconverged value (error) -302.035 (2.01768431e-06)
146877 EPS nconv=0 first unconverged value (error) -302.035 (2.01296336e-06)
146878 EPS nconv=0 first unconverged value (error) -302.035 (1.96556086e-06)
146879 EPS nconv=0 first unconverged value (error) -302.035 (1.88092474e-06)
146880 EPS nconv=0 first unconverged value (error) -302.035 (1.86685202e-06)
146881 EPS nconv=0 first unconverged value (error) -302.035 (1.86685202e-06)
146882 EPS nconv=0 first unconverged value (error) -302.035 (2.16647727e-06)
146883 EPS nconv=0 first unconverged value (error) -302.035 (2.11687089e-06)
146884 EPS nconv=0 first unconverged value (error) -302.035 (2.00060675e-06)
146885 EPS nconv=0 first unconverged value (error) -302.035 (1.96059143e-06)
146886 EPS nconv=0 first unconverged value (error) -302.035 (1.94512606e-06)
146887 EPS nconv=0 first unconverged value (error) -302.035 (1.94512606e-06)
146888 EPS nconv=0 first unconverged value (error) -302.035 (2.27581283e-06)
146889 EPS nconv=0 first unconverged value (error) -302.035 (2.12174216e-06)
146890 EPS nconv=0 first unconverged value (error) -302.035 (1.98860350e-06)
146891 EPS nconv=0 first unconverged value (error) -302.035 (1.94710855e-06)
146892 EPS nconv=0 first unconverged value (error) -302.035 (1.93820380e-06)
146893 EPS nconv=0 first unconverged value (error) -302.035 (1.93820380e-06)
146894 EPS nconv=0 first unconverged value (error) -302.035 (2.12090361e-06)
146895 EPS nconv=0 first unconverged value (error) -302.035 (2.14945518e-06)
146896 EPS nconv=0 first unconverged value (error) -302.035 (1.97144920e-06)
146897 EPS nconv=0 first unconverged value (error) -302.035 (1.92323500e-06)
146898 EPS nconv=0 first unconverged value (error) -302.035 (1.89160049e-06)
146899 EPS nconv=0 first unconverged value (error) -302.035 (1.89160049e-06)
146900 EPS nconv=0 first unconverged value (error) -302.035 (2.23711326e-06)
146901 EPS nconv=0 first unconverged value (error) -302.035 (2.14500445e-06)
146902 EPS nconv=0 first unconverged value (error) -302.035 (2.01425555e-06)
146903 EPS nconv=0 first unconverged value (error) -302.035 (2.01409261e-06)
146904 EPS nconv=0 first unconverged value (error) -302.035 (1.97943720e-06)
146905 EPS nconv=0 first unconverged value (error) -302.035 (1.97943720e-06)
146906 EPS nconv=0 first unconverged value (error) -302.035 (2.13490312e-06)
146907 EPS nconv=0 first unconverged value (error) -302.035 (2.14631612e-06)
146908 EPS nconv=0 first unconverged value (error) -302.035 (1.99371656e-06)
146909 EPS nconv=0 first unconverged value (error) -302.035 (1.91108017e-06)
146910 EPS nconv=0 first unconverged value (error) -302.035 (1.91107048e-06)
146911 EPS nconv=0 first unconverged value (error) -302.035 (1.91107048e-06)
146912 EPS nconv=0 first unconverged value (error) -302.035 (1.86286470e-06)
146913 EPS nconv=0 first unconverged value (error) -302.035 (1.90931330e-06)
146914 EPS nconv=0 first unconverged value (error) -302.035 (1.85864168e-06)
146915 EPS nconv=0 first unconverged value (error) -302.035 (1.80785788e-06)
146916 EPS nconv=0 first unconverged value (error) -302.035 (1.79863801e-06)
146917 EPS nconv=0 first unconverged value (error) -302.035 (1.79863801e-06)
146918 EPS nconv=0 first unconverged value (error) -302.035 (1.81664841e-06)
146919 EPS nconv=0 first unconverged value (error) -302.035 (1.81331566e-06)
146920 EPS nconv=0 first unconverged value (error) -302.035 (1.80725445e-06)
146921 EPS nconv=0 first unconverged value (error) -302.035 (1.80541986e-06)
146922 EPS nconv=0 first unconverged value (error) -302.035 (1.80501947e-06)
146923 EPS nconv=0 first unconverged value (error) -302.035 (1.80501947e-06)
146924 EPS nconv=0 first unconverged value (error) -302.035 (1.87380742e-06)
146925 EPS nconv=0 first unconverged value (error) -302.035 (1.85139110e-06)
146926 EPS nconv=0 first unconverged value (error) -302.035 (1.83782076e-06)
146927 EPS nconv=0 first unconverged value (error) -302.035 (1.81837322e-06)
146928 EPS nconv=0 first unconverged value (error) -302.035 (1.81491747e-06)
146929 EPS nconv=0 first unconverged value (error) -302.035 (1.81491747e-06)
146930 EPS nconv=0 first unconverged value (error) -302.035 (2.02594942e-06)
146931 EPS nconv=0 first unconverged value (error) -302.035 (2.01567558e-06)
146932 EPS nconv=0 first unconverged value (error) -302.035 (1.98025681e-06)
146933 EPS nconv=0 first unconverged value (error) -302.035 (1.92862871e-06)
146934 EPS nconv=0 first unconverged value (error) -302.035 (1.91585178e-06)
146935 EPS nconv=0 first unconverged value (error) -302.035 (1.91585178e-06)
146936 EPS nconv=0 first unconverged value (error) -302.035 (2.77022371e-06)
146937 EPS nconv=0 first unconverged value (error) -302.035 (2.34840735e-06)
146938 EPS nconv=0 first unconverged value (error) -302.035 (2.25846172e-06)
146939 EPS nconv=0 first unconverged value (error) -302.035 (2.28393607e-06)
146940 EPS nconv=0 first unconverged value (error) -302.035 (2.19713796e-06)
146941 EPS nconv=0 first unconverged value (error) -302.035 (2.19713796e-06)
146942 EPS nconv=0 first unconverged value (error) -302.035 (3.39829440e-06)
146943 EPS nconv=0 first unconverged value (error) -302.035 (3.38412436e-06)
146944 EPS nconv=0 first unconverged value (error) -302.035 (2.82043499e-06)
146945 EPS nconv=0 first unconverged value (error) -302.035 (2.78683029e-06)
146946 EPS nconv=0 first unconverged value (error) -302.035 (2.76507059e-06)
146947 EPS nconv=0 first unconverged value (error) -302.035 (2.76507059e-06)
146948 EPS nconv=0 first unconverged value (error) -302.035 (3.01011180e-06)
146949 EPS nconv=0 first unconverged value (error) -302.035 (2.90195994e-06)
146950 EPS nconv=0 first unconverged value (error) -302.035 (2.84789941e-06)
146951 EPS nconv=0 first unconverged value (error) -302.035 (2.25412419e-06)
146952 EPS nconv=0 first unconverged value (error) -302.035 (1.97143831e-06)
146953 EPS nconv=0 first unconverged value (error) -302.035 (1.97143831e-06)
146954 EPS nconv=0 first unconverged value (error) -302.035 (1.93287421e-06)
146955 EPS nconv=0 first unconverged value (error) -302.035 (2.09214546e-06)
146956 EPS nconv=0 first unconverged value (error) -302.035 (1.95362502e-06)
146957 EPS nconv=0 first unconverged value (error) -302.035 (1.82962516e-06)
146958 EPS nconv=0 first unconverged value (error) -302.035 (1.82596816e-06)
146959 EPS nconv=0 first unconverged value (error) -302.035 (1.82596816e-06)
146960 EPS nconv=0 first unconverged value (error) -302.035 (1.86240112e-06)
146961 EPS nconv=0 first unconverged value (error) -302.035 (1.83711673e-06)
146962 EPS nconv=0 first unconverged value (error) -302.035 (1.83528044e-06)
146963 EPS nconv=0 first unconverged value (error) -302.035 (1.82951245e-06)
146964 EPS nconv=0 first unconverged value (error) -302.035 (1.82155072e-06)
146965 EPS nconv=0 first unconverged value (error) -302.035 (1.82155072e-06)
146966 EPS nconv=0 first unconverged value (error) -302.035 (3.70734462e-06)
146967 EPS nconv=0 first unconverged value (error) -302.035 (3.10721182e-06)
146968 EPS nconv=0 first unconverged value (error) -302.035 (2.86888343e-06)
146969 EPS nconv=0 first unconverged value (error) -302.035 (2.76995325e-06)
146970 EPS nconv=0 first unconverged value (error) -302.035 (2.65836623e-06)
146971 EPS nconv=0 first unconverged value (error) -302.035 (2.65836623e-06)
146972 EPS nconv=0 first unconverged value (error) -302.035 (4.99816641e-06)
146973 EPS nconv=0 first unconverged value (error) -302.035 (4.85321055e-06)
146974 EPS nconv=0 first unconverged value (error) -302.035 (3.87844928e-06)
146975 EPS nconv=0 first unconverged value (error) -302.035 (4.03471841e-06)
146976 EPS nconv=0 first unconverged value (error) -302.035 (3.67408346e-06)
146977 EPS nconv=0 first unconverged value (error) -302.035 (3.67408346e-06)
146978 EPS nconv=0 first unconverged value (error) -302.035 (3.97598380e-06)
146979 EPS nconv=0 first unconverged value (error) -302.035 (3.84699059e-06)
146980 EPS nconv=0 first unconverged value (error) -302.035 (3.53825317e-06)
146981 EPS nconv=0 first unconverged value (error) -302.035 (2.83852738e-06)
146982 EPS nconv=0 first unconverged value (error) -302.035 (2.52242630e-06)
146983 EPS nconv=0 first unconverged value (error) -302.035 (2.52242630e-06)
146984 EPS nconv=0 first unconverged value (error) -302.035 (2.56887920e-06)
146985 EPS nconv=0 first unconverged value (error) -302.035 (2.29467024e-06)
146986 EPS nconv=0 first unconverged value (error) -302.035 (2.23896679e-06)
146987 EPS nconv=0 first unconverged value (error) -302.035 (1.95865571e-06)
146988 EPS nconv=0 first unconverged value (error) -302.035 (1.91299432e-06)
146989 EPS nconv=0 first unconverged value (error) -302.035 (1.91299432e-06)
146990 EPS nconv=0 first unconverged value (error) -302.035 (3.66869785e-06)
146991 EPS nconv=0 first unconverged value (error) -302.035 (3.01395370e-06)
146992 EPS nconv=0 first unconverged value (error) -302.035 (2.73737226e-06)
146993 EPS nconv=0 first unconverged value (error) -302.035 (2.69251105e-06)
146994 EPS nconv=0 first unconverged value (error) -302.035 (2.57358366e-06)
146995 EPS nconv=0 first unconverged value (error) -302.035 (2.57358366e-06)
146996 EPS nconv=0 first unconverged value (error) -302.035 (2.67459376e-06)
146997 EPS nconv=0 first unconverged value (error) -302.035 (3.04493978e-06)
146998 EPS nconv=0 first unconverged value (error) -302.035 (2.38222539e-06)
146999 EPS nconv=0 first unconverged value (error) -302.035 (2.11831305e-06)
147000 EPS nconv=0 first unconverged value (error) -302.035 (2.07058465e-06)
147001 EPS nconv=0 first unconverged value (error) -302.035 (2.07058465e-06)
147002 EPS nconv=0 first unconverged value (error) -302.035 (2.28005535e-06)
147003 EPS nconv=0 first unconverged value (error) -302.035 (2.17356216e-06)
147004 EPS nconv=0 first unconverged value (error) -302.035 (2.11843703e-06)
147005 EPS nconv=0 first unconverged value (error) -302.035 (1.96997071e-06)
147006 EPS nconv=0 first unconverged value (error) -302.035 (1.93977065e-06)
147007 EPS nconv=0 first unconverged value (error) -302.035 (1.93977065e-06)
147008 EPS nconv=0 first unconverged value (error) -302.035 (2.40439326e-06)
147009 EPS nconv=0 first unconverged value (error) -302.035 (2.27572085e-06)
147010 EPS nconv=0 first unconverged value (error) -302.035 (2.11833488e-06)
147011 EPS nconv=0 first unconverged value (error) -302.035 (2.04461481e-06)
147012 EPS nconv=0 first unconverged value (error) -302.035 (2.02008510e-06)
147013 EPS nconv=0 first unconverged value (error) -302.035 (2.02008510e-06)
147014 EPS nconv=0 first unconverged value (error) -302.035 (2.08600045e-06)
147015 EPS nconv=0 first unconverged value (error) -302.035 (2.31908448e-06)
147016 EPS nconv=0 first unconverged value (error) -302.035 (2.02645242e-06)
147017 EPS nconv=0 first unconverged value (error) -302.035 (1.87677104e-06)
147018 EPS nconv=0 first unconverged value (error) -302.035 (1.85800515e-06)
147019 EPS nconv=0 first unconverged value (error) -302.035 (1.85800515e-06)
147020 EPS nconv=0 first unconverged value (error) -302.035 (2.24424796e-06)
147021 EPS nconv=0 first unconverged value (error) -302.035 (2.11008136e-06)
147022 EPS nconv=0 first unconverged value (error) -302.035 (2.04226708e-06)
147023 EPS nconv=0 first unconverged value (error) -302.035 (2.02473209e-06)
147024 EPS nconv=0 first unconverged value (error) -302.035 (1.98764197e-06)
147025 EPS nconv=0 first unconverged value (error) -302.035 (1.98764197e-06)
147026 EPS nconv=0 first unconverged value (error) -302.035 (3.35679673e-06)
147027 EPS nconv=0 first unconverged value (error) -302.035 (3.07690679e-06)
147028 EPS nconv=0 first unconverged value (error) -302.035 (2.79529050e-06)
147029 EPS nconv=0 first unconverged value (error) -302.035 (2.76352480e-06)
147030 EPS nconv=0 first unconverged value (error) -302.035 (2.67483792e-06)
147031 EPS nconv=0 first unconverged value (error) -302.035 (2.67483792e-06)
147032 EPS nconv=0 first unconverged value (error) -302.035 (2.72333636e-06)
147033 EPS nconv=0 first unconverged value (error) -302.035 (2.71780205e-06)
147034 EPS nconv=0 first unconverged value (error) -302.035 (2.33662049e-06)
147035 EPS nconv=0 first unconverged value (error) -302.035 (2.15204029e-06)
147036 EPS nconv=0 first unconverged value (error) -302.035 (2.03680344e-06)
147037 EPS nconv=0 first unconverged value (error) -302.035 (2.03680344e-06)
147038 EPS nconv=0 first unconverged value (error) -302.035 (2.40432594e-06)
147039 EPS nconv=0 first unconverged value (error) -302.035 (2.37085077e-06)
147040 EPS nconv=0 first unconverged value (error) -302.035 (2.22462385e-06)
147041 EPS nconv=0 first unconverged value (error) -302.035 (2.07713755e-06)
147042 EPS nconv=0 first unconverged value (error) -302.035 (2.02482681e-06)
147043 EPS nconv=0 first unconverged value (error) -302.035 (2.02482681e-06)
147044 EPS nconv=0 first unconverged value (error) -302.035 (2.13026641e-06)
147045 EPS nconv=0 first unconverged value (error) -302.035 (2.23861010e-06)
147046 EPS nconv=0 first unconverged value (error) -302.035 (2.10201850e-06)
147047 EPS nconv=0 first unconverged value (error) -302.035 (1.98841313e-06)
147048 EPS nconv=0 first unconverged value (error) -302.035 (1.91134609e-06)
147049 EPS nconv=0 first unconverged value (error) -302.035 (1.91134609e-06)
147050 EPS nconv=0 first unconverged value (error) -302.035 (2.64860440e-06)
147051 EPS nconv=0 first unconverged value (error) -302.035 (2.57175060e-06)
147052 EPS nconv=0 first unconverged value (error) -302.035 (2.48439561e-06)
147053 EPS nconv=0 first unconverged value (error) -302.035 (2.30767780e-06)
147054 EPS nconv=0 first unconverged value (error) -302.035 (2.20604262e-06)
147055 EPS nconv=0 first unconverged value (error) -302.035 (2.20604262e-06)
147056 EPS nconv=0 first unconverged value (error) -302.035 (3.25345930e-06)
147057 EPS nconv=0 first unconverged value (error) -302.035 (2.90885161e-06)
147058 EPS nconv=0 first unconverged value (error) -302.035 (2.61308135e-06)
147059 EPS nconv=0 first unconverged value (error) -302.035 (2.55786329e-06)
147060 EPS nconv=0 first unconverged value (error) -302.035 (2.37491221e-06)
147061 EPS nconv=0 first unconverged value (error) -302.035 (2.37491221e-06)
147062 EPS nconv=0 first unconverged value (error) -302.035 (2.29865215e-06)
147063 EPS nconv=0 first unconverged value (error) -302.035 (2.61745912e-06)
147064 EPS nconv=0 first unconverged value (error) -302.035 (2.16547862e-06)
147065 EPS nconv=0 first unconverged value (error) -302.035 (1.97770338e-06)
147066 EPS nconv=0 first unconverged value (error) -302.035 (1.92155631e-06)
147067 EPS nconv=0 first unconverged value (error) -302.035 (1.92155631e-06)
147068 EPS nconv=0 first unconverged value (error) -302.035 (2.27094796e-06)
147069 EPS nconv=0 first unconverged value (error) -302.035 (2.10739317e-06)
147070 EPS nconv=0 first unconverged value (error) -302.035 (2.05335955e-06)
147071 EPS nconv=0 first unconverged value (error) -302.035 (2.03081685e-06)
147072 EPS nconv=0 first unconverged value (error) -302.035 (1.99440914e-06)
147073 EPS nconv=0 first unconverged value (error) -302.035 (1.99440914e-06)
147074 EPS nconv=0 first unconverged value (error) -302.035 (2.80164491e-06)
147075 EPS nconv=0 first unconverged value (error) -302.035 (2.69524865e-06)
147076 EPS nconv=0 first unconverged value (error) -302.035 (2.52933990e-06)
147077 EPS nconv=0 first unconverged value (error) -302.035 (2.50704878e-06)
147078 EPS nconv=0 first unconverged value (error) -302.035 (2.49579077e-06)
147079 EPS nconv=0 first unconverged value (error) -302.035 (2.49579077e-06)
147080 EPS nconv=0 first unconverged value (error) -302.035 (2.69346514e-06)
147081 EPS nconv=0 first unconverged value (error) -302.035 (2.33105880e-06)
147082 EPS nconv=0 first unconverged value (error) -302.035 (2.14634982e-06)
147083 EPS nconv=0 first unconverged value (error) -302.035 (2.10218125e-06)
147084 EPS nconv=0 first unconverged value (error) -302.035 (1.94699742e-06)
147085 EPS nconv=0 first unconverged value (error) -302.035 (1.94699742e-06)
147086 EPS nconv=0 first unconverged value (error) -302.035 (3.70948478e-06)
147087 EPS nconv=0 first unconverged value (error) -302.035 (3.36386873e-06)
147088 EPS nconv=0 first unconverged value (error) -302.035 (2.84028096e-06)
147089 EPS nconv=0 first unconverged value (error) -302.035 (2.76203050e-06)
147090 EPS nconv=0 first unconverged value (error) -302.035 (2.66991484e-06)
147091 EPS nconv=0 first unconverged value (error) -302.035 (2.66991484e-06)
147092 EPS nconv=0 first unconverged value (error) -302.035 (3.82415972e-06)
147093 EPS nconv=0 first unconverged value (error) -302.035 (3.76126882e-06)
147094 EPS nconv=0 first unconverged value (error) -302.035 (3.38524665e-06)
147095 EPS nconv=0 first unconverged value (error) -302.035 (3.20027994e-06)
147096 EPS nconv=0 first unconverged value (error) -302.035 (3.10463430e-06)
147097 EPS nconv=0 first unconverged value (error) -302.035 (3.10463430e-06)
147098 EPS nconv=0 first unconverged value (error) -302.035 (3.11645355e-06)
147099 EPS nconv=0 first unconverged value (error) -302.035 (2.65473650e-06)
147100 EPS nconv=0 first unconverged value (error) -302.035 (2.41621806e-06)
147101 EPS nconv=0 first unconverged value (error) -302.035 (2.16372219e-06)
147102 EPS nconv=0 first unconverged value (error) -302.035 (2.06928331e-06)
147103 EPS nconv=0 first unconverged value (error) -302.035 (2.06928331e-06)
147104 EPS nconv=0 first unconverged value (error) -302.035 (1.93412042e-06)
147105 EPS nconv=0 first unconverged value (error) -302.035 (1.99910087e-06)
147106 EPS nconv=0 first unconverged value (error) -302.035 (1.90652498e-06)
147107 EPS nconv=0 first unconverged value (error) -302.035 (1.84565933e-06)
147108 EPS nconv=0 first unconverged value (error) -302.035 (1.82248701e-06)
147109 EPS nconv=0 first unconverged value (error) -302.035 (1.82248701e-06)
147110 EPS nconv=0 first unconverged value (error) -302.035 (2.31049126e-06)
147111 EPS nconv=0 first unconverged value (error) -302.035 (2.15879691e-06)
147112 EPS nconv=0 first unconverged value (error) -302.035 (2.07552839e-06)
147113 EPS nconv=0 first unconverged value (error) -302.035 (2.03056465e-06)
147114 EPS nconv=0 first unconverged value (error) -302.035 (1.98303913e-06)
147115 EPS nconv=0 first unconverged value (error) -302.035 (1.98303913e-06)
147116 EPS nconv=0 first unconverged value (error) -302.035 (2.82341697e-06)
147117 EPS nconv=0 first unconverged value (error) -302.035 (2.82107864e-06)
147118 EPS nconv=0 first unconverged value (error) -302.035 (2.58041900e-06)
147119 EPS nconv=0 first unconverged value (error) -302.035 (2.31181191e-06)
147120 EPS nconv=0 first unconverged value (error) -302.035 (2.27383042e-06)
147121 EPS nconv=0 first unconverged value (error) -302.035 (2.27383042e-06)
147122 EPS nconv=0 first unconverged value (error) -302.035 (3.03425065e-06)
147123 EPS nconv=0 first unconverged value (error) -302.035 (2.74196728e-06)
147124 EPS nconv=0 first unconverged value (error) -302.035 (2.47004950e-06)
147125 EPS nconv=0 first unconverged value (error) -302.035 (2.37039232e-06)
147126 EPS nconv=0 first unconverged value (error) -302.035 (2.26914460e-06)
147127 EPS nconv=0 first unconverged value (error) -302.035 (2.26914460e-06)
147128 EPS nconv=0 first unconverged value (error) -302.035 (2.69117036e-06)
147129 EPS nconv=0 first unconverged value (error) -302.035 (2.66823610e-06)
147130 EPS nconv=0 first unconverged value (error) -302.035 (2.28155373e-06)
147131 EPS nconv=0 first unconverged value (error) -302.035 (2.20103644e-06)
147132 EPS nconv=0 first unconverged value (error) -302.035 (2.15912035e-06)
147133 EPS nconv=0 first unconverged value (error) -302.035 (2.15912035e-06)
147134 EPS nconv=0 first unconverged value (error) -302.035 (2.13062131e-06)
147135 EPS nconv=0 first unconverged value (error) -302.035 (2.15524654e-06)
147136 EPS nconv=0 first unconverged value (error) -302.035 (2.01149323e-06)
147137 EPS nconv=0 first unconverged value (error) -302.035 (1.88637573e-06)
147138 EPS nconv=0 first unconverged value (error) -302.035 (1.86400798e-06)
147139 EPS nconv=0 first unconverged value (error) -302.035 (1.86400798e-06)
147140 EPS nconv=0 first unconverged value (error) -302.035 (1.82318221e-06)
147141 EPS nconv=0 first unconverged value (error) -302.035 (1.84372772e-06)
147142 EPS nconv=0 first unconverged value (error) -302.035 (1.82199574e-06)
147143 EPS nconv=0 first unconverged value (error) -302.035 (1.80447534e-06)
147144 EPS nconv=0 first unconverged value (error) -302.035 (1.80001662e-06)
147145 EPS nconv=0 first unconverged value (error) -302.035 (1.80001662e-06)
147146 EPS nconv=0 first unconverged value (error) -302.035 (1.89252143e-06)
147147 EPS nconv=0 first unconverged value (error) -302.035 (1.86222939e-06)
147148 EPS nconv=0 first unconverged value (error) -302.035 (1.85325414e-06)
147149 EPS nconv=0 first unconverged value (error) -302.035 (1.84633756e-06)
147150 EPS nconv=0 first unconverged value (error) -302.035 (1.83590129e-06)
147151 EPS nconv=0 first unconverged value (error) -302.035 (1.83590129e-06)
147152 EPS nconv=0 first unconverged value (error) -302.035 (2.11429196e-06)
147153 EPS nconv=0 first unconverged value (error) -302.035 (2.06376764e-06)
147154 EPS nconv=0 first unconverged value (error) -302.035 (2.03479794e-06)
147155 EPS nconv=0 first unconverged value (error) -302.035 (1.95926381e-06)
147156 EPS nconv=0 first unconverged value (error) -302.035 (1.94247328e-06)
147157 EPS nconv=0 first unconverged value (error) -302.035 (1.94247328e-06)
147158 EPS nconv=0 first unconverged value (error) -302.035 (1.92652209e-06)
147159 EPS nconv=0 first unconverged value (error) -302.035 (1.93990627e-06)
147160 EPS nconv=0 first unconverged value (error) -302.035 (1.85277621e-06)
147161 EPS nconv=0 first unconverged value (error) -302.035 (1.81816826e-06)
147162 EPS nconv=0 first unconverged value (error) -302.035 (1.80939548e-06)
147163 EPS nconv=0 first unconverged value (error) -302.035 (1.80939548e-06)
147164 EPS nconv=0 first unconverged value (error) -302.035 (2.11683290e-06)
147165 EPS nconv=0 first unconverged value (error) -302.035 (1.98799659e-06)
147166 EPS nconv=0 first unconverged value (error) -302.035 (1.94137116e-06)
147167 EPS nconv=0 first unconverged value (error) -302.035 (1.92603194e-06)
147168 EPS nconv=0 first unconverged value (error) -302.035 (1.90977585e-06)
147169 EPS nconv=0 first unconverged value (error) -302.035 (1.90977585e-06)
147170 EPS nconv=0 first unconverged value (error) -302.035 (2.06332983e-06)
147171 EPS nconv=0 first unconverged value (error) -302.035 (2.13551372e-06)
147172 EPS nconv=0 first unconverged value (error) -302.035 (1.99109067e-06)
147173 EPS nconv=0 first unconverged value (error) -302.035 (1.87769022e-06)
147174 EPS nconv=0 first unconverged value (error) -302.035 (1.86323745e-06)
147175 EPS nconv=0 first unconverged value (error) -302.035 (1.86323745e-06)
147176 EPS nconv=0 first unconverged value (error) -302.035 (2.15310117e-06)
147177 EPS nconv=0 first unconverged value (error) -302.035 (2.06357455e-06)
147178 EPS nconv=0 first unconverged value (error) -302.035 (2.00498761e-06)
147179 EPS nconv=0 first unconverged value (error) -302.035 (1.98814306e-06)
147180 EPS nconv=0 first unconverged value (error) -302.035 (1.95637889e-06)
147181 EPS nconv=0 first unconverged value (error) -302.035 (1.95637889e-06)
147182 EPS nconv=0 first unconverged value (error) -302.035 (2.00655877e-06)
147183 EPS nconv=0 first unconverged value (error) -302.035 (2.03323065e-06)
147184 EPS nconv=0 first unconverged value (error) -302.035 (1.91525286e-06)
147185 EPS nconv=0 first unconverged value (error) -302.035 (1.87525388e-06)
147186 EPS nconv=0 first unconverged value (error) -302.035 (1.84669460e-06)
147187 EPS nconv=0 first unconverged value (error) -302.035 (1.84669460e-06)
147188 EPS nconv=0 first unconverged value (error) -302.035 (2.06399619e-06)
147189 EPS nconv=0 first unconverged value (error) -302.035 (1.98643418e-06)
147190 EPS nconv=0 first unconverged value (error) -302.035 (1.93022090e-06)
147191 EPS nconv=0 first unconverged value (error) -302.035 (1.89532035e-06)
147192 EPS nconv=0 first unconverged value (error) -302.035 (1.87698040e-06)
147193 EPS nconv=0 first unconverged value (error) -302.035 (1.87698040e-06)
147194 EPS nconv=0 first unconverged value (error) -302.035 (1.89240003e-06)
147195 EPS nconv=0 first unconverged value (error) -302.035 (1.97217641e-06)
147196 EPS nconv=0 first unconverged value (error) -302.035 (1.89313810e-06)
147197 EPS nconv=0 first unconverged value (error) -302.035 (1.82999125e-06)
147198 EPS nconv=0 first unconverged value (error) -302.035 (1.81315231e-06)
147199 EPS nconv=0 first unconverged value (error) -302.035 (1.81315231e-06)
147200 EPS nconv=0 first unconverged value (error) -302.035 (1.86951233e-06)
147201 EPS nconv=0 first unconverged value (error) -302.035 (1.84873900e-06)
147202 EPS nconv=0 first unconverged value (error) -302.035 (1.83959247e-06)
147203 EPS nconv=0 first unconverged value (error) -302.035 (1.83391015e-06)
147204 EPS nconv=0 first unconverged value (error) -302.035 (1.82955271e-06)
147205 EPS nconv=0 first unconverged value (error) -302.035 (1.82955271e-06)
147206 EPS nconv=0 first unconverged value (error) -302.035 (1.86613113e-06)
147207 EPS nconv=0 first unconverged value (error) -302.035 (1.85825564e-06)
147208 EPS nconv=0 first unconverged value (error) -302.035 (1.83552794e-06)
147209 EPS nconv=0 first unconverged value (error) -302.035 (1.81585857e-06)
147210 EPS nconv=0 first unconverged value (error) -302.035 (1.81314652e-06)
147211 EPS nconv=0 first unconverged value (error) -302.035 (1.81314652e-06)
147212 EPS nconv=0 first unconverged value (error) -302.035 (2.45452334e-06)
147213 EPS nconv=0 first unconverged value (error) -302.035 (2.24507893e-06)
147214 EPS nconv=0 first unconverged value (error) -302.035 (2.14497348e-06)
147215 EPS nconv=0 first unconverged value (error) -302.035 (2.11278423e-06)
147216 EPS nconv=0 first unconverged value (error) -302.035 (2.04573696e-06)
147217 EPS nconv=0 first unconverged value (error) -302.035 (2.04573696e-06)
147218 EPS nconv=0 first unconverged value (error) -302.035 (2.04359523e-06)
147219 EPS nconv=0 first unconverged value (error) -302.035 (2.23557861e-06)
147220 EPS nconv=0 first unconverged value (error) -302.035 (1.99960626e-06)
147221 EPS nconv=0 first unconverged value (error) -302.035 (1.91141114e-06)
147222 EPS nconv=0 first unconverged value (error) -302.035 (1.82702537e-06)
147223 EPS nconv=0 first unconverged value (error) -302.035 (1.82702537e-06)
147224 EPS nconv=0 first unconverged value (error) -302.035 (1.81931012e-06)
147225 EPS nconv=0 first unconverged value (error) -302.035 (1.80413425e-06)
147226 EPS nconv=0 first unconverged value (error) -302.035 (1.80108737e-06)
147227 EPS nconv=0 first unconverged value (error) -302.035 (1.80046303e-06)
147228 EPS nconv=0 first unconverged value (error) -302.035 (1.79913604e-06)
147229 EPS nconv=0 first unconverged value (error) -302.035 (1.79913604e-06)
147230 EPS nconv=0 first unconverged value (error) -302.035 (2.19393825e-06)
147231 EPS nconv=0 first unconverged value (error) -302.035 (2.07962052e-06)
147232 EPS nconv=0 first unconverged value (error) -302.035 (1.99869041e-06)
147233 EPS nconv=0 first unconverged value (error) -302.035 (1.96205744e-06)
147234 EPS nconv=0 first unconverged value (error) -302.035 (1.95763186e-06)
147235 EPS nconv=0 first unconverged value (error) -302.035 (1.95763186e-06)
147236 EPS nconv=0 first unconverged value (error) -302.035 (2.09530671e-06)
147237 EPS nconv=0 first unconverged value (error) -302.035 (2.09692817e-06)
147238 EPS nconv=0 first unconverged value (error) -302.035 (1.95875659e-06)
147239 EPS nconv=0 first unconverged value (error) -302.035 (1.89469072e-06)
147240 EPS nconv=0 first unconverged value (error) -302.035 (1.87899574e-06)
147241 EPS nconv=0 first unconverged value (error) -302.035 (1.87899574e-06)
147242 EPS nconv=0 first unconverged value (error) -302.035 (2.39733697e-06)
147243 EPS nconv=0 first unconverged value (error) -302.035 (2.21501154e-06)
147244 EPS nconv=0 first unconverged value (error) -302.035 (2.09766869e-06)
147245 EPS nconv=0 first unconverged value (error) -302.035 (2.06942244e-06)
147246 EPS nconv=0 first unconverged value (error) -302.035 (2.05693152e-06)
147247 EPS nconv=0 first unconverged value (error) -302.035 (2.05693152e-06)
147248 EPS nconv=0 first unconverged value (error) -302.035 (2.08251584e-06)
147249 EPS nconv=0 first unconverged value (error) -302.035 (2.15096837e-06)
147250 EPS nconv=0 first unconverged value (error) -302.035 (1.93508272e-06)
147251 EPS nconv=0 first unconverged value (error) -302.035 (1.86778561e-06)
147252 EPS nconv=0 first unconverged value (error) -302.035 (1.85217098e-06)
147253 EPS nconv=0 first unconverged value (error) -302.035 (1.85217098e-06)
147254 EPS nconv=0 first unconverged value (error) -302.035 (1.87317061e-06)
147255 EPS nconv=0 first unconverged value (error) -302.035 (1.83113203e-06)
147256 EPS nconv=0 first unconverged value (error) -302.035 (1.81724767e-06)
147257 EPS nconv=0 first unconverged value (error) -302.035 (1.81285609e-06)
147258 EPS nconv=0 first unconverged value (error) -302.035 (1.80954462e-06)
147259 EPS nconv=0 first unconverged value (error) -302.035 (1.80954462e-06)
147260 EPS nconv=0 first unconverged value (error) -302.035 (2.03656110e-06)
147261 EPS nconv=0 first unconverged value (error) -302.035 (2.01704154e-06)
147262 EPS nconv=0 first unconverged value (error) -302.035 (1.95733622e-06)
147263 EPS nconv=0 first unconverged value (error) -302.035 (1.91031747e-06)
147264 EPS nconv=0 first unconverged value (error) -302.035 (1.90110661e-06)
147265 EPS nconv=0 first unconverged value (error) -302.035 (1.90110661e-06)
147266 EPS nconv=0 first unconverged value (error) -302.035 (2.04954830e-06)
147267 EPS nconv=0 first unconverged value (error) -302.035 (2.01095688e-06)
147268 EPS nconv=0 first unconverged value (error) -302.035 (1.94084287e-06)
147269 EPS nconv=0 first unconverged value (error) -302.035 (1.92705876e-06)
147270 EPS nconv=0 first unconverged value (error) -302.035 (1.90629704e-06)
147271 EPS nconv=0 first unconverged value (error) -302.035 (1.90629704e-06)
147272 EPS nconv=0 first unconverged value (error) -302.035 (1.90292850e-06)
147273 EPS nconv=0 first unconverged value (error) -302.035 (1.87873659e-06)
147274 EPS nconv=0 first unconverged value (error) -302.035 (1.83523377e-06)
147275 EPS nconv=0 first unconverged value (error) -302.035 (1.82044489e-06)
147276 EPS nconv=0 first unconverged value (error) -302.035 (1.80961436e-06)
147277 EPS nconv=0 first unconverged value (error) -302.035 (1.80961436e-06)
147278 EPS nconv=0 first unconverged value (error) -302.035 (1.80155663e-06)
147279 EPS nconv=0 first unconverged value (error) -302.035 (1.79977292e-06)
147280 EPS nconv=0 first unconverged value (error) -302.035 (1.79850724e-06)
147281 EPS nconv=0 first unconverged value (error) -302.035 (1.79784164e-06)
147282 EPS nconv=0 first unconverged value (error) -302.035 (1.79744954e-06)
147283 EPS nconv=0 first unconverged value (error) -302.035 (1.79744954e-06)
147284 EPS nconv=0 first unconverged value (error) -302.035 (1.80012866e-06)
147285 EPS nconv=0 first unconverged value (error) -302.035 (1.80169871e-06)
147286 EPS nconv=0 first unconverged value (error) -302.035 (1.79897422e-06)
147287 EPS nconv=0 first unconverged value (error) -302.035 (1.79720339e-06)
147288 EPS nconv=0 first unconverged value (error) -302.035 (1.79656337e-06)
147289 EPS nconv=0 first unconverged value (error) -302.035 (1.79656337e-06)
147290 EPS nconv=0 first unconverged value (error) -302.035 (1.99771510e-06)
147291 EPS nconv=0 first unconverged value (error) -302.035 (1.95087321e-06)
147292 EPS nconv=0 first unconverged value (error) -302.035 (1.93851285e-06)
147293 EPS nconv=0 first unconverged value (error) -302.035 (1.91705767e-06)
147294 EPS nconv=0 first unconverged value (error) -302.035 (1.89893131e-06)
147295 EPS nconv=0 first unconverged value (error) -302.035 (1.89893131e-06)
147296 EPS nconv=0 first unconverged value (error) -302.035 (2.13482821e-06)
147297 EPS nconv=0 first unconverged value (error) -302.035 (2.14577871e-06)
147298 EPS nconv=0 first unconverged value (error) -302.035 (2.10023592e-06)
147299 EPS nconv=0 first unconverged value (error) -302.035 (1.96356730e-06)
147300 EPS nconv=0 first unconverged value (error) -302.035 (1.93347175e-06)
147301 EPS nconv=0 first unconverged value (error) -302.035 (1.93347175e-06)
147302 EPS nconv=0 first unconverged value (error) -302.035 (2.08103795e-06)
147303 EPS nconv=0 first unconverged value (error) -302.035 (2.04916886e-06)
147304 EPS nconv=0 first unconverged value (error) -302.035 (2.04048417e-06)
147305 EPS nconv=0 first unconverged value (error) -302.035 (1.90394265e-06)
147306 EPS nconv=0 first unconverged value (error) -302.035 (1.88889040e-06)
147307 EPS nconv=0 first unconverged value (error) -302.035 (1.88889040e-06)
147308 EPS nconv=0 first unconverged value (error) -302.035 (1.87795894e-06)
147309 EPS nconv=0 first unconverged value (error) -302.035 (1.85889416e-06)
147310 EPS nconv=0 first unconverged value (error) -302.035 (1.82850111e-06)
147311 EPS nconv=0 first unconverged value (error) -302.035 (1.82360055e-06)
147312 EPS nconv=0 first unconverged value (error) -302.035 (1.80956357e-06)
147313 EPS nconv=0 first unconverged value (error) -302.035 (1.80956357e-06)
147314 EPS nconv=0 first unconverged value (error) -302.035 (1.80477789e-06)
147315 EPS nconv=0 first unconverged value (error) -302.035 (1.80276762e-06)
147316 EPS nconv=0 first unconverged value (error) -302.035 (1.80040124e-06)
147317 EPS nconv=0 first unconverged value (error) -302.035 (1.79917848e-06)
147318 EPS nconv=0 first unconverged value (error) -302.035 (1.79868526e-06)
147319 EPS nconv=0 first unconverged value (error) -302.035 (1.79868526e-06)
147320 EPS nconv=0 first unconverged value (error) -302.035 (2.10321285e-06)
147321 EPS nconv=0 first unconverged value (error) -302.035 (2.05851818e-06)
147322 EPS nconv=0 first unconverged value (error) -302.035 (2.01053001e-06)
147323 EPS nconv=0 first unconverged value (error) -302.035 (1.97959553e-06)
147324 EPS nconv=0 first unconverged value (error) -302.035 (1.95262505e-06)
147325 EPS nconv=0 first unconverged value (error) -302.035 (1.95262505e-06)
147326 EPS nconv=0 first unconverged value (error) -302.035 (1.99609515e-06)
147327 EPS nconv=0 first unconverged value (error) -302.035 (2.03992017e-06)
147328 EPS nconv=0 first unconverged value (error) -302.035 (2.00839004e-06)
147329 EPS nconv=0 first unconverged value (error) -302.035 (1.84960076e-06)
147330 EPS nconv=0 first unconverged value (error) -302.035 (1.83585361e-06)
147331 EPS nconv=0 first unconverged value (error) -302.035 (1.83585361e-06)
147332 EPS nconv=0 first unconverged value (error) -302.035 (2.18215574e-06)
147333 EPS nconv=0 first unconverged value (error) -302.035 (2.07275079e-06)
147334 EPS nconv=0 first unconverged value (error) -302.035 (2.03595322e-06)
147335 EPS nconv=0 first unconverged value (error) -302.035 (1.97556283e-06)
147336 EPS nconv=0 first unconverged value (error) -302.035 (1.95327272e-06)
147337 EPS nconv=0 first unconverged value (error) -302.035 (1.95327272e-06)
147338 EPS nconv=0 first unconverged value (error) -302.035 (2.04337618e-06)
147339 EPS nconv=0 first unconverged value (error) -302.035 (2.05907547e-06)
147340 EPS nconv=0 first unconverged value (error) -302.035 (1.93770733e-06)
147341 EPS nconv=0 first unconverged value (error) -302.035 (1.90914801e-06)
147342 EPS nconv=0 first unconverged value (error) -302.035 (1.86483499e-06)
147343 EPS nconv=0 first unconverged value (error) -302.035 (1.86483499e-06)
147344 EPS nconv=0 first unconverged value (error) -302.035 (1.95595152e-06)
147345 EPS nconv=0 first unconverged value (error) -302.035 (1.97473284e-06)
147346 EPS nconv=0 first unconverged value (error) -302.035 (1.91244626e-06)
147347 EPS nconv=0 first unconverged value (error) -302.035 (1.88478531e-06)
147348 EPS nconv=0 first unconverged value (error) -302.035 (1.86388213e-06)
147349 EPS nconv=0 first unconverged value (error) -302.035 (1.86388213e-06)
147350 EPS nconv=0 first unconverged value (error) -302.035 (1.87548437e-06)
147351 EPS nconv=0 first unconverged value (error) -302.035 (1.87943925e-06)
147352 EPS nconv=0 first unconverged value (error) -302.035 (1.86056840e-06)
147353 EPS nconv=0 first unconverged value (error) -302.035 (1.82972422e-06)
147354 EPS nconv=0 first unconverged value (error) -302.035 (1.82160886e-06)
147355 EPS nconv=0 first unconverged value (error) -302.035 (1.82160886e-06)
147356 EPS nconv=0 first unconverged value (error) -302.035 (2.07065616e-06)
147357 EPS nconv=0 first unconverged value (error) -302.035 (1.99449186e-06)
147358 EPS nconv=0 first unconverged value (error) -302.035 (1.96706329e-06)
147359 EPS nconv=0 first unconverged value (error) -302.035 (1.92910788e-06)
147360 EPS nconv=0 first unconverged value (error) -302.035 (1.90558981e-06)
147361 EPS nconv=0 first unconverged value (error) -302.035 (1.90558981e-06)
147362 EPS nconv=0 first unconverged value (error) -302.035 (2.14148943e-06)
147363 EPS nconv=0 first unconverged value (error) -302.035 (2.12645547e-06)
147364 EPS nconv=0 first unconverged value (error) -302.035 (2.01811889e-06)
147365 EPS nconv=0 first unconverged value (error) -302.035 (1.96746540e-06)
147366 EPS nconv=0 first unconverged value (error) -302.035 (1.92948547e-06)
147367 EPS nconv=0 first unconverged value (error) -302.035 (1.92948547e-06)
147368 EPS nconv=0 first unconverged value (error) -302.035 (1.95252438e-06)
147369 EPS nconv=0 first unconverged value (error) -302.035 (1.99954847e-06)
147370 EPS nconv=0 first unconverged value (error) -302.035 (1.90711580e-06)
147371 EPS nconv=0 first unconverged value (error) -302.035 (1.84166769e-06)
147372 EPS nconv=0 first unconverged value (error) -302.035 (1.83116132e-06)
147373 EPS nconv=0 first unconverged value (error) -302.035 (1.83116132e-06)
147374 EPS nconv=0 first unconverged value (error) -302.035 (1.87550290e-06)
147375 EPS nconv=0 first unconverged value (error) -302.035 (1.85204246e-06)
147376 EPS nconv=0 first unconverged value (error) -302.035 (1.83908513e-06)
147377 EPS nconv=0 first unconverged value (error) -302.035 (1.82860132e-06)
147378 EPS nconv=0 first unconverged value (error) -302.035 (1.82042002e-06)
147379 EPS nconv=0 first unconverged value (error) -302.035 (1.82042002e-06)
147380 EPS nconv=0 first unconverged value (error) -302.035 (2.06419106e-06)
147381 EPS nconv=0 first unconverged value (error) -302.035 (1.99570202e-06)
147382 EPS nconv=0 first unconverged value (error) -302.035 (1.95890549e-06)
147383 EPS nconv=0 first unconverged value (error) -302.035 (1.91533128e-06)
147384 EPS nconv=0 first unconverged value (error) -302.035 (1.89531314e-06)
147385 EPS nconv=0 first unconverged value (error) -302.035 (1.89531314e-06)
147386 EPS nconv=0 first unconverged value (error) -302.035 (1.99067637e-06)
147387 EPS nconv=0 first unconverged value (error) -302.035 (2.00787856e-06)
147388 EPS nconv=0 first unconverged value (error) -302.035 (1.89483286e-06)
147389 EPS nconv=0 first unconverged value (error) -302.035 (1.86232504e-06)
147390 EPS nconv=0 first unconverged value (error) -302.035 (1.83699856e-06)
147391 EPS nconv=0 first unconverged value (error) -302.035 (1.83699856e-06)
147392 EPS nconv=0 first unconverged value (error) -302.035 (1.93981018e-06)
147393 EPS nconv=0 first unconverged value (error) -302.035 (1.95372480e-06)
147394 EPS nconv=0 first unconverged value (error) -302.035 (1.89902051e-06)
147395 EPS nconv=0 first unconverged value (error) -302.035 (1.87470354e-06)
147396 EPS nconv=0 first unconverged value (error) -302.035 (1.85667358e-06)
147397 EPS nconv=0 first unconverged value (error) -302.035 (1.85667358e-06)
147398 EPS nconv=0 first unconverged value (error) -302.035 (1.86107190e-06)
147399 EPS nconv=0 first unconverged value (error) -302.035 (1.86304754e-06)
147400 EPS nconv=0 first unconverged value (error) -302.035 (1.84079992e-06)
147401 EPS nconv=0 first unconverged value (error) -302.035 (1.82099592e-06)
147402 EPS nconv=0 first unconverged value (error) -302.035 (1.81071822e-06)
147403 EPS nconv=0 first unconverged value (error) -302.035 (1.81071822e-06)
147404 EPS nconv=0 first unconverged value (error) -302.035 (1.92859413e-06)
147405 EPS nconv=0 first unconverged value (error) -302.035 (1.89036947e-06)
147406 EPS nconv=0 first unconverged value (error) -302.035 (1.87230675e-06)
147407 EPS nconv=0 first unconverged value (error) -302.035 (1.85904746e-06)
147408 EPS nconv=0 first unconverged value (error) -302.035 (1.84892886e-06)
147409 EPS nconv=0 first unconverged value (error) -302.035 (1.84892886e-06)
147410 EPS nconv=0 first unconverged value (error) -302.035 (2.08346828e-06)
147411 EPS nconv=0 first unconverged value (error) -302.035 (1.99747384e-06)
147412 EPS nconv=0 first unconverged value (error) -302.035 (1.94392616e-06)
147413 EPS nconv=0 first unconverged value (error) -302.035 (1.92740723e-06)
147414 EPS nconv=0 first unconverged value (error) -302.035 (1.90356527e-06)
147415 EPS nconv=0 first unconverged value (error) -302.035 (1.90356527e-06)
147416 EPS nconv=0 first unconverged value (error) -302.035 (2.35876994e-06)
147417 EPS nconv=0 first unconverged value (error) -302.035 (2.33205323e-06)
147418 EPS nconv=0 first unconverged value (error) -302.035 (2.16158557e-06)
147419 EPS nconv=0 first unconverged value (error) -302.035 (2.07295085e-06)
147420 EPS nconv=0 first unconverged value (error) -302.035 (2.01718295e-06)
147421 EPS nconv=0 first unconverged value (error) -302.035 (2.01718295e-06)
147422 EPS nconv=0 first unconverged value (error) -302.035 (2.28941905e-06)
147423 EPS nconv=0 first unconverged value (error) -302.035 (2.25026321e-06)
147424 EPS nconv=0 first unconverged value (error) -302.035 (2.10579085e-06)
147425 EPS nconv=0 first unconverged value (error) -302.035 (2.01696376e-06)
147426 EPS nconv=0 first unconverged value (error) -302.035 (1.97550369e-06)
147427 EPS nconv=0 first unconverged value (error) -302.035 (1.97550369e-06)
147428 EPS nconv=0 first unconverged value (error) -302.035 (1.96730991e-06)
147429 EPS nconv=0 first unconverged value (error) -302.035 (2.01999886e-06)
147430 EPS nconv=0 first unconverged value (error) -302.035 (1.92483813e-06)
147431 EPS nconv=0 first unconverged value (error) -302.035 (1.86182232e-06)
147432 EPS nconv=0 first unconverged value (error) -302.035 (1.84658017e-06)
147433 EPS nconv=0 first unconverged value (error) -302.035 (1.84658017e-06)
147434 EPS nconv=0 first unconverged value (error) -302.035 (2.14684465e-06)
147435 EPS nconv=0 first unconverged value (error) -302.035 (2.00363024e-06)
147436 EPS nconv=0 first unconverged value (error) -302.035 (1.95605593e-06)
147437 EPS nconv=0 first unconverged value (error) -302.035 (1.94162842e-06)
147438 EPS nconv=0 first unconverged value (error) -302.035 (1.90514440e-06)
147439 EPS nconv=0 first unconverged value (error) -302.035 (1.90514440e-06)
147440 EPS nconv=0 first unconverged value (error) -302.035 (1.90664012e-06)
147441 EPS nconv=0 first unconverged value (error) -302.035 (2.01105788e-06)
147442 EPS nconv=0 first unconverged value (error) -302.035 (1.88470038e-06)
147443 EPS nconv=0 first unconverged value (error) -302.035 (1.84326482e-06)
147444 EPS nconv=0 first unconverged value (error) -302.035 (1.82770287e-06)
147445 EPS nconv=0 first unconverged value (error) -302.035 (1.82770287e-06)
147446 EPS nconv=0 first unconverged value (error) -302.035 (1.95101410e-06)
147447 EPS nconv=0 first unconverged value (error) -302.035 (1.89217508e-06)
147448 EPS nconv=0 first unconverged value (error) -302.035 (1.87198417e-06)
147449 EPS nconv=0 first unconverged value (error) -302.035 (1.86713924e-06)
147450 EPS nconv=0 first unconverged value (error) -302.035 (1.84922613e-06)
147451 EPS nconv=0 first unconverged value (error) -302.035 (1.84922613e-06)
147452 EPS nconv=0 first unconverged value (error) -302.035 (2.06380194e-06)
147453 EPS nconv=0 first unconverged value (error) -302.035 (2.08926704e-06)
147454 EPS nconv=0 first unconverged value (error) -302.035 (1.97662501e-06)
147455 EPS nconv=0 first unconverged value (error) -302.035 (1.91034432e-06)
147456 EPS nconv=0 first unconverged value (error) -302.035 (1.90258686e-06)
147457 EPS nconv=0 first unconverged value (error) -302.035 (1.90258686e-06)
147458 EPS nconv=0 first unconverged value (error) -302.035 (2.24625465e-06)
147459 EPS nconv=0 first unconverged value (error) -302.035 (2.12291840e-06)
147460 EPS nconv=0 first unconverged value (error) -302.035 (2.06919536e-06)
147461 EPS nconv=0 first unconverged value (error) -302.035 (1.99813407e-06)
147462 EPS nconv=0 first unconverged value (error) -302.035 (1.94574930e-06)
147463 EPS nconv=0 first unconverged value (error) -302.035 (1.94574930e-06)
147464 EPS nconv=0 first unconverged value (error) -302.035 (2.23571963e-06)
147465 EPS nconv=0 first unconverged value (error) -302.035 (2.26265508e-06)
147466 EPS nconv=0 first unconverged value (error) -302.035 (2.06748011e-06)
147467 EPS nconv=0 first unconverged value (error) -302.035 (2.04184086e-06)
147468 EPS nconv=0 first unconverged value (error) -302.035 (1.99308944e-06)
147469 EPS nconv=0 first unconverged value (error) -302.035 (1.99308944e-06)
147470 EPS nconv=0 first unconverged value (error) -302.035 (1.97063705e-06)
147471 EPS nconv=0 first unconverged value (error) -302.035 (1.95815825e-06)
147472 EPS nconv=0 first unconverged value (error) -302.035 (1.88424175e-06)
147473 EPS nconv=0 first unconverged value (error) -302.035 (1.83648428e-06)
147474 EPS nconv=0 first unconverged value (error) -302.035 (1.83396466e-06)
147475 EPS nconv=0 first unconverged value (error) -302.035 (1.83396466e-06)
147476 EPS nconv=0 first unconverged value (error) -302.035 (1.81484517e-06)
147477 EPS nconv=0 first unconverged value (error) -302.035 (1.81652976e-06)
147478 EPS nconv=0 first unconverged value (error) -302.035 (1.80931106e-06)
147479 EPS nconv=0 first unconverged value (error) -302.035 (1.80034200e-06)
147480 EPS nconv=0 first unconverged value (error) -302.035 (1.79849050e-06)
147481 EPS nconv=0 first unconverged value (error) -302.035 (1.79849050e-06)
147482 EPS nconv=0 first unconverged value (error) -302.035 (1.89121380e-06)
147483 EPS nconv=0 first unconverged value (error) -302.035 (1.84648184e-06)
147484 EPS nconv=0 first unconverged value (error) -302.035 (1.83989573e-06)
147485 EPS nconv=0 first unconverged value (error) -302.035 (1.83332944e-06)
147486 EPS nconv=0 first unconverged value (error) -302.035 (1.82662895e-06)
147487 EPS nconv=0 first unconverged value (error) -302.035 (1.82662895e-06)
147488 EPS nconv=0 first unconverged value (error) -302.035 (1.86950452e-06)
147489 EPS nconv=0 first unconverged value (error) -302.035 (1.90622927e-06)
147490 EPS nconv=0 first unconverged value (error) -302.035 (1.86402881e-06)
147491 EPS nconv=0 first unconverged value (error) -302.035 (1.82201944e-06)
147492 EPS nconv=0 first unconverged value (error) -302.035 (1.81839950e-06)
147493 EPS nconv=0 first unconverged value (error) -302.035 (1.81839950e-06)
147494 EPS nconv=0 first unconverged value (error) -302.035 (2.41483991e-06)
147495 EPS nconv=0 first unconverged value (error) -302.035 (2.18698568e-06)
147496 EPS nconv=0 first unconverged value (error) -302.035 (2.12083549e-06)
147497 EPS nconv=0 first unconverged value (error) -302.035 (2.10652862e-06)
147498 EPS nconv=0 first unconverged value (error) -302.035 (2.06249295e-06)
147499 EPS nconv=0 first unconverged value (error) -302.035 (2.06249295e-06)
147500 EPS nconv=0 first unconverged value (error) -302.035 (2.06517386e-06)
147501 EPS nconv=0 first unconverged value (error) -302.035 (2.20113207e-06)
147502 EPS nconv=0 first unconverged value (error) -302.035 (1.99112049e-06)
147503 EPS nconv=0 first unconverged value (error) -302.035 (1.84120946e-06)
147504 EPS nconv=0 first unconverged value (error) -302.035 (1.80906502e-06)
147505 EPS nconv=0 first unconverged value (error) -302.035 (1.80906502e-06)
147506 EPS nconv=0 first unconverged value (error) -302.035 (2.40287558e-06)
147507 EPS nconv=0 first unconverged value (error) -302.035 (2.23118996e-06)
147508 EPS nconv=0 first unconverged value (error) -302.035 (2.17806754e-06)
147509 EPS nconv=0 first unconverged value (error) -302.035 (2.13665777e-06)
147510 EPS nconv=0 first unconverged value (error) -302.035 (2.09830105e-06)
147511 EPS nconv=0 first unconverged value (error) -302.035 (2.09830105e-06)
147512 EPS nconv=0 first unconverged value (error) -302.035 (2.09131608e-06)
147513 EPS nconv=0 first unconverged value (error) -302.035 (2.13299037e-06)
147514 EPS nconv=0 first unconverged value (error) -302.035 (2.00270646e-06)
147515 EPS nconv=0 first unconverged value (error) -302.035 (1.81134858e-06)
147516 EPS nconv=0 first unconverged value (error) -302.035 (1.80486346e-06)
147517 EPS nconv=0 first unconverged value (error) -302.035 (1.80486346e-06)
147518 EPS nconv=0 first unconverged value (error) -302.035 (1.86103146e-06)
147519 EPS nconv=0 first unconverged value (error) -302.035 (1.83415154e-06)
147520 EPS nconv=0 first unconverged value (error) -302.035 (1.82397976e-06)
147521 EPS nconv=0 first unconverged value (error) -302.035 (1.82155750e-06)
147522 EPS nconv=0 first unconverged value (error) -302.035 (1.82003612e-06)
147523 EPS nconv=0 first unconverged value (error) -302.035 (1.82003612e-06)
147524 EPS nconv=0 first unconverged value (error) -302.035 (1.99454925e-06)
147525 EPS nconv=0 first unconverged value (error) -302.035 (2.00069506e-06)
147526 EPS nconv=0 first unconverged value (error) -302.035 (1.92786963e-06)
147527 EPS nconv=0 first unconverged value (error) -302.035 (1.86823273e-06)
147528 EPS nconv=0 first unconverged value (error) -302.035 (1.86152059e-06)
147529 EPS nconv=0 first unconverged value (error) -302.035 (1.86152059e-06)
147530 EPS nconv=0 first unconverged value (error) -302.035 (1.87033899e-06)
147531 EPS nconv=0 first unconverged value (error) -302.035 (1.91524197e-06)
147532 EPS nconv=0 first unconverged value (error) -302.035 (1.88599467e-06)
147533 EPS nconv=0 first unconverged value (error) -302.035 (1.81028766e-06)
147534 EPS nconv=0 first unconverged value (error) -302.035 (1.80978288e-06)
147535 EPS nconv=0 first unconverged value (error) -302.035 (1.80978288e-06)
147536 EPS nconv=0 first unconverged value (error) -302.035 (1.84305876e-06)
147537 EPS nconv=0 first unconverged value (error) -302.035 (1.82693349e-06)
147538 EPS nconv=0 first unconverged value (error) -302.035 (1.82338163e-06)
147539 EPS nconv=0 first unconverged value (error) -302.035 (1.81542567e-06)
147540 EPS nconv=0 first unconverged value (error) -302.035 (1.81327948e-06)
147541 EPS nconv=0 first unconverged value (error) -302.035 (1.81327948e-06)
147542 EPS nconv=0 first unconverged value (error) -302.035 (1.81208503e-06)
147543 EPS nconv=0 first unconverged value (error) -302.035 (1.82585366e-06)
147544 EPS nconv=0 first unconverged value (error) -302.035 (1.80078105e-06)
147545 EPS nconv=0 first unconverged value (error) -302.035 (1.79990795e-06)
147546 EPS nconv=0 first unconverged value (error) -302.035 (1.79712476e-06)
147547 EPS nconv=0 first unconverged value (error) -302.035 (1.79712476e-06)
147548 EPS nconv=0 first unconverged value (error) -302.035 (2.10468164e-06)
147549 EPS nconv=0 first unconverged value (error) -302.035 (2.02254275e-06)
147550 EPS nconv=0 first unconverged value (error) -302.035 (1.94628820e-06)
147551 EPS nconv=0 first unconverged value (error) -302.035 (1.93940641e-06)
147552 EPS nconv=0 first unconverged value (error) -302.035 (1.91840621e-06)
147553 EPS nconv=0 first unconverged value (error) -302.035 (1.91840621e-06)
147554 EPS nconv=0 first unconverged value (error) -302.035 (1.92437767e-06)
147555 EPS nconv=0 first unconverged value (error) -302.035 (2.00214871e-06)
147556 EPS nconv=0 first unconverged value (error) -302.035 (1.92185283e-06)
147557 EPS nconv=0 first unconverged value (error) -302.035 (1.81864935e-06)
147558 EPS nconv=0 first unconverged value (error) -302.035 (1.81569387e-06)
147559 EPS nconv=0 first unconverged value (error) -302.035 (1.81569387e-06)
147560 EPS nconv=0 first unconverged value (error) -302.035 (2.08619460e-06)
147561 EPS nconv=0 first unconverged value (error) -302.035 (1.98107206e-06)
147562 EPS nconv=0 first unconverged value (error) -302.035 (1.95189155e-06)
147563 EPS nconv=0 first unconverged value (error) -302.035 (1.92410329e-06)
147564 EPS nconv=0 first unconverged value (error) -302.035 (1.90402660e-06)
147565 EPS nconv=0 first unconverged value (error) -302.035 (1.90402660e-06)
147566 EPS nconv=0 first unconverged value (error) -302.035 (2.53887138e-06)
147567 EPS nconv=0 first unconverged value (error) -302.035 (2.35088695e-06)
147568 EPS nconv=0 first unconverged value (error) -302.035 (2.13012237e-06)
147569 EPS nconv=0 first unconverged value (error) -302.035 (2.09472673e-06)
147570 EPS nconv=0 first unconverged value (error) -302.035 (2.04762074e-06)
147571 EPS nconv=0 first unconverged value (error) -302.035 (2.04762074e-06)
147572 EPS nconv=0 first unconverged value (error) -302.035 (2.96009023e-06)
147573 EPS nconv=0 first unconverged value (error) -302.035 (2.81131618e-06)
147574 EPS nconv=0 first unconverged value (error) -302.035 (2.47649354e-06)
147575 EPS nconv=0 first unconverged value (error) -302.035 (2.47994106e-06)
147576 EPS nconv=0 first unconverged value (error) -302.035 (2.37605381e-06)
147577 EPS nconv=0 first unconverged value (error) -302.035 (2.37605381e-06)
147578 EPS nconv=0 first unconverged value (error) -302.035 (2.41990610e-06)
147579 EPS nconv=0 first unconverged value (error) -302.035 (2.44368311e-06)
147580 EPS nconv=0 first unconverged value (error) -302.035 (2.21704200e-06)
147581 EPS nconv=0 first unconverged value (error) -302.035 (1.99767154e-06)
147582 EPS nconv=0 first unconverged value (error) -302.035 (1.93265884e-06)
147583 EPS nconv=0 first unconverged value (error) -302.035 (1.93265884e-06)
147584 EPS nconv=0 first unconverged value (error) -302.035 (2.17038067e-06)
147585 EPS nconv=0 first unconverged value (error) -302.035 (2.09492679e-06)
147586 EPS nconv=0 first unconverged value (error) -302.035 (1.96147680e-06)
147587 EPS nconv=0 first unconverged value (error) -302.035 (1.92742431e-06)
147588 EPS nconv=0 first unconverged value (error) -302.035 (1.90918400e-06)
147589 EPS nconv=0 first unconverged value (error) -302.035 (1.90918400e-06)
147590 EPS nconv=0 first unconverged value (error) -302.035 (2.03397942e-06)
147591 EPS nconv=0 first unconverged value (error) -302.035 (2.10349474e-06)
147592 EPS nconv=0 first unconverged value (error) -302.035 (2.03972697e-06)
147593 EPS nconv=0 first unconverged value (error) -302.035 (1.86135642e-06)
147594 EPS nconv=0 first unconverged value (error) -302.035 (1.85221053e-06)
147595 EPS nconv=0 first unconverged value (error) -302.035 (1.85221053e-06)
147596 EPS nconv=0 first unconverged value (error) -302.035 (2.32758654e-06)
147597 EPS nconv=0 first unconverged value (error) -302.035 (2.28024182e-06)
147598 EPS nconv=0 first unconverged value (error) -302.035 (2.19113493e-06)
147599 EPS nconv=0 first unconverged value (error) -302.035 (2.03431110e-06)
147600 EPS nconv=0 first unconverged value (error) -302.035 (1.99122277e-06)
147601 EPS nconv=0 first unconverged value (error) -302.035 (1.99122277e-06)
147602 EPS nconv=0 first unconverged value (error) -302.035 (2.22400681e-06)
147603 EPS nconv=0 first unconverged value (error) -302.035 (2.23005493e-06)
147604 EPS nconv=0 first unconverged value (error) -302.035 (2.11661932e-06)
147605 EPS nconv=0 first unconverged value (error) -302.035 (2.06095613e-06)
147606 EPS nconv=0 first unconverged value (error) -302.035 (1.97402745e-06)
147607 EPS nconv=0 first unconverged value (error) -302.035 (1.97402745e-06)
147608 EPS nconv=0 first unconverged value (error) -302.035 (1.95283314e-06)
147609 EPS nconv=0 first unconverged value (error) -302.035 (1.92168033e-06)
147610 EPS nconv=0 first unconverged value (error) -302.035 (1.85873097e-06)
147611 EPS nconv=0 first unconverged value (error) -302.035 (1.84006385e-06)
147612 EPS nconv=0 first unconverged value (error) -302.035 (1.81906851e-06)
147613 EPS nconv=0 first unconverged value (error) -302.035 (1.81906851e-06)
147614 EPS nconv=0 first unconverged value (error) -302.035 (1.94504477e-06)
147615 EPS nconv=0 first unconverged value (error) -302.035 (1.88072109e-06)
147616 EPS nconv=0 first unconverged value (error) -302.035 (1.85058998e-06)
147617 EPS nconv=0 first unconverged value (error) -302.035 (1.84077813e-06)
147618 EPS nconv=0 first unconverged value (error) -302.035 (1.83269080e-06)
147619 EPS nconv=0 first unconverged value (error) -302.035 (1.83269080e-06)
147620 EPS nconv=0 first unconverged value (error) -302.035 (1.84928399e-06)
147621 EPS nconv=0 first unconverged value (error) -302.035 (1.89293994e-06)
147622 EPS nconv=0 first unconverged value (error) -302.035 (1.84878036e-06)
147623 EPS nconv=0 first unconverged value (error) -302.035 (1.81546992e-06)
147624 EPS nconv=0 first unconverged value (error) -302.035 (1.80906811e-06)
147625 EPS nconv=0 first unconverged value (error) -302.035 (1.80906811e-06)
147626 EPS nconv=0 first unconverged value (error) -302.035 (1.99438934e-06)
147627 EPS nconv=0 first unconverged value (error) -302.035 (1.92697472e-06)
147628 EPS nconv=0 first unconverged value (error) -302.035 (1.91169018e-06)
147629 EPS nconv=0 first unconverged value (error) -302.035 (1.90765731e-06)
147630 EPS nconv=0 first unconverged value (error) -302.035 (1.88926765e-06)
147631 EPS nconv=0 first unconverged value (error) -302.035 (1.88926765e-06)
147632 EPS nconv=0 first unconverged value (error) -302.035 (1.90652726e-06)
147633 EPS nconv=0 first unconverged value (error) -302.035 (1.90031626e-06)
147634 EPS nconv=0 first unconverged value (error) -302.035 (1.84014592e-06)
147635 EPS nconv=0 first unconverged value (error) -302.035 (1.82476549e-06)
147636 EPS nconv=0 first unconverged value (error) -302.035 (1.83073390e-06)
147637 EPS nconv=0 first unconverged value (error) -302.035 (1.83073390e-06)
147638 EPS nconv=0 first unconverged value (error) -302.035 (2.08817778e-06)
147639 EPS nconv=0 first unconverged value (error) -302.035 (1.93738358e-06)
147640 EPS nconv=0 first unconverged value (error) -302.035 (1.88934224e-06)
147641 EPS nconv=0 first unconverged value (error) -302.035 (1.87934150e-06)
147642 EPS nconv=0 first unconverged value (error) -302.035 (1.86671277e-06)
147643 EPS nconv=0 first unconverged value (error) -302.035 (1.86671277e-06)
147644 EPS nconv=0 first unconverged value (error) -302.035 (1.87319313e-06)
147645 EPS nconv=0 first unconverged value (error) -302.035 (2.01892617e-06)
147646 EPS nconv=0 first unconverged value (error) -302.035 (1.86522329e-06)
147647 EPS nconv=0 first unconverged value (error) -302.035 (1.82218118e-06)
147648 EPS nconv=0 first unconverged value (error) -302.035 (1.80849558e-06)
147649 EPS nconv=0 first unconverged value (error) -302.035 (1.80849558e-06)
147650 EPS nconv=0 first unconverged value (error) -302.035 (1.79977578e-06)
147651 EPS nconv=0 first unconverged value (error) -302.035 (1.80017154e-06)
147652 EPS nconv=0 first unconverged value (error) -302.035 (1.79810878e-06)
147653 EPS nconv=0 first unconverged value (error) -302.035 (1.79645004e-06)
147654 EPS nconv=0 first unconverged value (error) -302.035 (1.79566809e-06)
147655 EPS nconv=0 first unconverged value (error) -302.035 (1.79566809e-06)
147656 EPS nconv=0 first unconverged value (error) -302.035 (2.19611432e-06)
147657 EPS nconv=0 first unconverged value (error) -302.035 (2.03876520e-06)
147658 EPS nconv=0 first unconverged value (error) -302.035 (1.98550572e-06)
147659 EPS nconv=0 first unconverged value (error) -302.035 (1.96127188e-06)
147660 EPS nconv=0 first unconverged value (error) -302.035 (1.93500597e-06)
147661 EPS nconv=0 first unconverged value (error) -302.035 (1.93500597e-06)
147662 EPS nconv=0 first unconverged value (error) -302.035 (2.12015520e-06)
147663 EPS nconv=0 first unconverged value (error) -302.035 (2.17738808e-06)
147664 EPS nconv=0 first unconverged value (error) -302.035 (2.01039104e-06)
147665 EPS nconv=0 first unconverged value (error) -302.035 (1.94713070e-06)
147666 EPS nconv=0 first unconverged value (error) -302.035 (1.91443120e-06)
147667 EPS nconv=0 first unconverged value (error) -302.035 (1.91443120e-06)
147668 EPS nconv=0 first unconverged value (error) -302.035 (1.89043360e-06)
147669 EPS nconv=0 first unconverged value (error) -302.035 (1.92160416e-06)
147670 EPS nconv=0 first unconverged value (error) -302.035 (1.87287912e-06)
147671 EPS nconv=0 first unconverged value (error) -302.035 (1.83679164e-06)
147672 EPS nconv=0 first unconverged value (error) -302.035 (1.81559056e-06)
147673 EPS nconv=0 first unconverged value (error) -302.035 (1.81559056e-06)
147674 EPS nconv=0 first unconverged value (error) -302.035 (1.80028727e-06)
147675 EPS nconv=0 first unconverged value (error) -302.035 (1.79911920e-06)
147676 EPS nconv=0 first unconverged value (error) -302.035 (1.79794690e-06)
147677 EPS nconv=0 first unconverged value (error) -302.035 (1.79713430e-06)
147678 EPS nconv=0 first unconverged value (error) -302.035 (1.79666817e-06)
147679 EPS nconv=0 first unconverged value (error) -302.035 (1.79666817e-06)
147680 EPS nconv=0 first unconverged value (error) -302.035 (2.41509353e-06)
147681 EPS nconv=0 first unconverged value (error) -302.035 (2.24281629e-06)
147682 EPS nconv=0 first unconverged value (error) -302.035 (2.14579403e-06)
147683 EPS nconv=0 first unconverged value (error) -302.035 (2.13269252e-06)
147684 EPS nconv=0 first unconverged value (error) -302.035 (2.09864517e-06)
147685 EPS nconv=0 first unconverged value (error) -302.035 (2.09864517e-06)
147686 EPS nconv=0 first unconverged value (error) -302.035 (2.09383127e-06)
147687 EPS nconv=0 first unconverged value (error) -302.035 (2.18224019e-06)
147688 EPS nconv=0 first unconverged value (error) -302.035 (2.00325916e-06)
147689 EPS nconv=0 first unconverged value (error) -302.035 (1.83603837e-06)
147690 EPS nconv=0 first unconverged value (error) -302.035 (1.83852868e-06)
147691 EPS nconv=0 first unconverged value (error) -302.035 (1.83852868e-06)
147692 EPS nconv=0 first unconverged value (error) -302.035 (1.80351492e-06)
147693 EPS nconv=0 first unconverged value (error) -302.035 (1.79897654e-06)
147694 EPS nconv=0 first unconverged value (error) -302.035 (1.79723413e-06)
147695 EPS nconv=0 first unconverged value (error) -302.035 (1.79583439e-06)
147696 EPS nconv=0 first unconverged value (error) -302.035 (1.79545195e-06)
147697 EPS nconv=0 first unconverged value (error) -302.035 (1.79545195e-06)
147698 EPS nconv=0 first unconverged value (error) -302.035 (2.07819598e-06)
147699 EPS nconv=0 first unconverged value (error) -302.035 (1.98424442e-06)
147700 EPS nconv=0 first unconverged value (error) -302.035 (1.94369966e-06)
147701 EPS nconv=0 first unconverged value (error) -302.035 (1.90789608e-06)
147702 EPS nconv=0 first unconverged value (error) -302.035 (1.90249295e-06)
147703 EPS nconv=0 first unconverged value (error) -302.035 (1.90249295e-06)
147704 EPS nconv=0 first unconverged value (error) -302.035 (1.93601065e-06)
147705 EPS nconv=0 first unconverged value (error) -302.035 (1.98442238e-06)
147706 EPS nconv=0 first unconverged value (error) -302.035 (1.87041450e-06)
147707 EPS nconv=0 first unconverged value (error) -302.035 (1.83900716e-06)
147708 EPS nconv=0 first unconverged value (error) -302.035 (1.82441499e-06)
147709 EPS nconv=0 first unconverged value (error) -302.035 (1.82441499e-06)
147710 EPS nconv=0 first unconverged value (error) -302.035 (1.82011090e-06)
147711 EPS nconv=0 first unconverged value (error) -302.035 (1.83151100e-06)
147712 EPS nconv=0 first unconverged value (error) -302.035 (1.81315743e-06)
147713 EPS nconv=0 first unconverged value (error) -302.035 (1.80195918e-06)
147714 EPS nconv=0 first unconverged value (error) -302.035 (1.79779127e-06)
147715 EPS nconv=0 first unconverged value (error) -302.035 (1.79779127e-06)
147716 EPS nconv=0 first unconverged value (error) -302.035 (1.82600338e-06)
147717 EPS nconv=0 first unconverged value (error) -302.035 (1.81151788e-06)
147718 EPS nconv=0 first unconverged value (error) -302.035 (1.80914459e-06)
147719 EPS nconv=0 first unconverged value (error) -302.035 (1.80707617e-06)
147720 EPS nconv=0 first unconverged value (error) -302.035 (1.80578011e-06)
147721 EPS nconv=0 first unconverged value (error) -302.035 (1.80578011e-06)
147722 EPS nconv=0 first unconverged value (error) -302.035 (2.38109809e-06)
147723 EPS nconv=0 first unconverged value (error) -302.035 (2.24837244e-06)
147724 EPS nconv=0 first unconverged value (error) -302.035 (2.17227948e-06)
147725 EPS nconv=0 first unconverged value (error) -302.035 (2.12190203e-06)
147726 EPS nconv=0 first unconverged value (error) -302.035 (2.09486433e-06)
147727 EPS nconv=0 first unconverged value (error) -302.035 (2.09486433e-06)
147728 EPS nconv=0 first unconverged value (error) -302.035 (2.13402063e-06)
147729 EPS nconv=0 first unconverged value (error) -302.035 (2.23794289e-06)
147730 EPS nconv=0 first unconverged value (error) -302.035 (2.09464462e-06)
147731 EPS nconv=0 first unconverged value (error) -302.035 (1.87864371e-06)
147732 EPS nconv=0 first unconverged value (error) -302.035 (1.83610087e-06)
147733 EPS nconv=0 first unconverged value (error) -302.035 (1.83610087e-06)
147734 EPS nconv=0 first unconverged value (error) -302.035 (1.82011559e-06)
147735 EPS nconv=0 first unconverged value (error) -302.035 (1.80563355e-06)
147736 EPS nconv=0 first unconverged value (error) -302.035 (1.80679072e-06)
147737 EPS nconv=0 first unconverged value (error) -302.035 (1.79709592e-06)
147738 EPS nconv=0 first unconverged value (error) -302.035 (1.79562900e-06)
147739 EPS nconv=0 first unconverged value (error) -302.035 (1.79562900e-06)
147740 EPS nconv=0 first unconverged value (error) -302.035 (1.79689835e-06)
147741 EPS nconv=0 first unconverged value (error) -302.035 (1.79571682e-06)
147742 EPS nconv=0 first unconverged value (error) -302.035 (1.79548390e-06)
147743 EPS nconv=0 first unconverged value (error) -302.035 (1.79526243e-06)
147744 EPS nconv=0 first unconverged value (error) -302.035 (1.79514422e-06)
147745 EPS nconv=0 first unconverged value (error) -302.035 (1.79514422e-06)
147746 EPS nconv=0 first unconverged value (error) -302.035 (1.79832743e-06)
147747 EPS nconv=0 first unconverged value (error) -302.035 (1.79796190e-06)
147748 EPS nconv=0 first unconverged value (error) -302.035 (1.79706613e-06)
147749 EPS nconv=0 first unconverged value (error) -302.035 (1.79555386e-06)
147750 EPS nconv=0 first unconverged value (error) -302.035 (1.79538310e-06)
147751 EPS nconv=0 first unconverged value (error) -302.035 (1.79538310e-06)
147752 EPS nconv=0 first unconverged value (error) -302.035 (1.79604588e-06)
147753 EPS nconv=0 first unconverged value (error) -302.035 (1.79622671e-06)
147754 EPS nconv=0 first unconverged value (error) -302.035 (1.79538874e-06)
147755 EPS nconv=0 first unconverged value (error) -302.035 (1.79520380e-06)
147756 EPS nconv=0 first unconverged value (error) -302.035 (1.79509055e-06)
147757 EPS nconv=0 first unconverged value (error) -302.035 (1.79509055e-06)
147758 EPS nconv=0 first unconverged value (error) -302.035 (1.92542478e-06)
147759 EPS nconv=0 first unconverged value (error) -302.035 (1.87581665e-06)
147760 EPS nconv=0 first unconverged value (error) -302.035 (1.85628297e-06)
147761 EPS nconv=0 first unconverged value (error) -302.035 (1.85304819e-06)
147762 EPS nconv=0 first unconverged value (error) -302.035 (1.84735021e-06)
147763 EPS nconv=0 first unconverged value (error) -302.035 (1.84735021e-06)
147764 EPS nconv=0 first unconverged value (error) -302.035 (1.91950635e-06)
147765 EPS nconv=0 first unconverged value (error) -302.035 (1.91354777e-06)
147766 EPS nconv=0 first unconverged value (error) -302.035 (1.85562335e-06)
147767 EPS nconv=0 first unconverged value (error) -302.035 (1.84850074e-06)
147768 EPS nconv=0 first unconverged value (error) -302.035 (1.84633204e-06)
147769 EPS nconv=0 first unconverged value (error) -302.035 (1.84633204e-06)
147770 EPS nconv=0 first unconverged value (error) -302.035 (2.01635868e-06)
147771 EPS nconv=0 first unconverged value (error) -302.035 (1.94160854e-06)
147772 EPS nconv=0 first unconverged value (error) -302.035 (1.90725981e-06)
147773 EPS nconv=0 first unconverged value (error) -302.035 (1.89402714e-06)
147774 EPS nconv=0 first unconverged value (error) -302.035 (1.87759395e-06)
147775 EPS nconv=0 first unconverged value (error) -302.035 (1.87759395e-06)
147776 EPS nconv=0 first unconverged value (error) -302.035 (1.88256238e-06)
147777 EPS nconv=0 first unconverged value (error) -302.035 (1.91760525e-06)
147778 EPS nconv=0 first unconverged value (error) -302.035 (1.84045843e-06)
147779 EPS nconv=0 first unconverged value (error) -302.035 (1.81841084e-06)
147780 EPS nconv=0 first unconverged value (error) -302.035 (1.81394484e-06)
147781 EPS nconv=0 first unconverged value (error) -302.035 (1.81394484e-06)
147782 EPS nconv=0 first unconverged value (error) -302.035 (1.81304120e-06)
147783 EPS nconv=0 first unconverged value (error) -302.035 (1.81022783e-06)
147784 EPS nconv=0 first unconverged value (error) -302.035 (1.80507556e-06)
147785 EPS nconv=0 first unconverged value (error) -302.035 (1.80183200e-06)
147786 EPS nconv=0 first unconverged value (error) -302.035 (1.79921661e-06)
147787 EPS nconv=0 first unconverged value (error) -302.035 (1.79921661e-06)
147788 EPS nconv=0 first unconverged value (error) -302.035 (1.91589142e-06)
147789 EPS nconv=0 first unconverged value (error) -302.035 (1.90046159e-06)
147790 EPS nconv=0 first unconverged value (error) -302.035 (1.86299709e-06)
147791 EPS nconv=0 first unconverged value (error) -302.035 (1.84359704e-06)
147792 EPS nconv=0 first unconverged value (error) -302.035 (1.83897059e-06)
147793 EPS nconv=0 first unconverged value (error) -302.035 (1.83897059e-06)
147794 EPS nconv=0 first unconverged value (error) -302.035 (1.93240338e-06)
147795 EPS nconv=0 first unconverged value (error) -302.035 (1.91769046e-06)
147796 EPS nconv=0 first unconverged value (error) -302.035 (1.87333133e-06)
147797 EPS nconv=0 first unconverged value (error) -302.035 (1.86196910e-06)
147798 EPS nconv=0 first unconverged value (error) -302.035 (1.85363461e-06)
147799 EPS nconv=0 first unconverged value (error) -302.035 (1.85363461e-06)
147800 EPS nconv=0 first unconverged value (error) -302.035 (1.92476306e-06)
147801 EPS nconv=0 first unconverged value (error) -302.035 (1.90139529e-06)
147802 EPS nconv=0 first unconverged value (error) -302.035 (1.86400890e-06)
147803 EPS nconv=0 first unconverged value (error) -302.035 (1.85109995e-06)
147804 EPS nconv=0 first unconverged value (error) -302.035 (1.83821153e-06)
147805 EPS nconv=0 first unconverged value (error) -302.035 (1.83821153e-06)
147806 EPS nconv=0 first unconverged value (error) -302.035 (2.25997176e-06)
147807 EPS nconv=0 first unconverged value (error) -302.035 (2.16836852e-06)
147808 EPS nconv=0 first unconverged value (error) -302.035 (2.06575809e-06)
147809 EPS nconv=0 first unconverged value (error) -302.035 (1.96031890e-06)
147810 EPS nconv=0 first unconverged value (error) -302.035 (1.94633028e-06)
147811 EPS nconv=0 first unconverged value (error) -302.035 (1.94633028e-06)
147812 EPS nconv=0 first unconverged value (error) -302.035 (1.95140355e-06)
147813 EPS nconv=0 first unconverged value (error) -302.035 (2.09313129e-06)
147814 EPS nconv=0 first unconverged value (error) -302.035 (1.95064241e-06)
147815 EPS nconv=0 first unconverged value (error) -302.035 (1.84945526e-06)
147816 EPS nconv=0 first unconverged value (error) -302.035 (1.81808838e-06)
147817 EPS nconv=0 first unconverged value (error) -302.035 (1.81808838e-06)
147818 EPS nconv=0 first unconverged value (error) -302.035 (1.85283088e-06)
147819 EPS nconv=0 first unconverged value (error) -302.035 (1.82594218e-06)
147820 EPS nconv=0 first unconverged value (error) -302.035 (1.81591485e-06)
147821 EPS nconv=0 first unconverged value (error) -302.035 (1.81271135e-06)
147822 EPS nconv=0 first unconverged value (error) -302.035 (1.80899243e-06)
147823 EPS nconv=0 first unconverged value (error) -302.035 (1.80899243e-06)
147824 EPS nconv=0 first unconverged value (error) -302.035 (1.86349236e-06)
147825 EPS nconv=0 first unconverged value (error) -302.035 (1.84377309e-06)
147826 EPS nconv=0 first unconverged value (error) -302.035 (1.82635729e-06)
147827 EPS nconv=0 first unconverged value (error) -302.035 (1.82289400e-06)
147828 EPS nconv=0 first unconverged value (error) -302.035 (1.81963498e-06)
147829 EPS nconv=0 first unconverged value (error) -302.035 (1.81963498e-06)
147830 EPS nconv=0 first unconverged value (error) -302.035 (1.97035167e-06)
147831 EPS nconv=0 first unconverged value (error) -302.035 (1.92513778e-06)
147832 EPS nconv=0 first unconverged value (error) -302.035 (1.87510003e-06)
147833 EPS nconv=0 first unconverged value (error) -302.035 (1.87089566e-06)
147834 EPS nconv=0 first unconverged value (error) -302.035 (1.86149276e-06)
147835 EPS nconv=0 first unconverged value (error) -302.035 (1.86149276e-06)
147836 EPS nconv=0 first unconverged value (error) -302.035 (1.89362843e-06)
147837 EPS nconv=0 first unconverged value (error) -302.035 (1.91101450e-06)
147838 EPS nconv=0 first unconverged value (error) -302.035 (1.85649312e-06)
147839 EPS nconv=0 first unconverged value (error) -302.035 (1.83051593e-06)
147840 EPS nconv=0 first unconverged value (error) -302.035 (1.82077669e-06)
147841 EPS nconv=0 first unconverged value (error) -302.035 (1.82077669e-06)
147842 EPS nconv=0 first unconverged value (error) -302.035 (1.87369118e-06)
147843 EPS nconv=0 first unconverged value (error) -302.035 (1.85951973e-06)
147844 EPS nconv=0 first unconverged value (error) -302.035 (1.83398074e-06)
147845 EPS nconv=0 first unconverged value (error) -302.035 (1.83034426e-06)
147846 EPS nconv=0 first unconverged value (error) -302.035 (1.82575047e-06)
147847 EPS nconv=0 first unconverged value (error) -302.035 (1.82575047e-06)
147848 EPS nconv=0 first unconverged value (error) -302.035 (1.92442088e-06)
147849 EPS nconv=0 first unconverged value (error) -302.035 (1.92006083e-06)
147850 EPS nconv=0 first unconverged value (error) -302.035 (1.87860547e-06)
147851 EPS nconv=0 first unconverged value (error) -302.035 (1.84170823e-06)
147852 EPS nconv=0 first unconverged value (error) -302.035 (1.83413972e-06)
147853 EPS nconv=0 first unconverged value (error) -302.035 (1.83413972e-06)
147854 EPS nconv=0 first unconverged value (error) -302.035 (1.93873445e-06)
147855 EPS nconv=0 first unconverged value (error) -302.035 (1.90763249e-06)
147856 EPS nconv=0 first unconverged value (error) -302.035 (1.87469652e-06)
147857 EPS nconv=0 first unconverged value (error) -302.035 (1.86292050e-06)
147858 EPS nconv=0 first unconverged value (error) -302.035 (1.83950498e-06)
147859 EPS nconv=0 first unconverged value (error) -302.035 (1.83950498e-06)
147860 EPS nconv=0 first unconverged value (error) -302.035 (1.83351700e-06)
147861 EPS nconv=0 first unconverged value (error) -302.035 (1.85877679e-06)
147862 EPS nconv=0 first unconverged value (error) -302.035 (1.81503855e-06)
147863 EPS nconv=0 first unconverged value (error) -302.035 (1.80328227e-06)
147864 EPS nconv=0 first unconverged value (error) -302.035 (1.80252116e-06)
147865 EPS nconv=0 first unconverged value (error) -302.035 (1.80252116e-06)
147866 EPS nconv=0 first unconverged value (error) -302.035 (1.84067073e-06)
147867 EPS nconv=0 first unconverged value (error) -302.035 (1.81567183e-06)
147868 EPS nconv=0 first unconverged value (error) -302.035 (1.81223343e-06)
147869 EPS nconv=0 first unconverged value (error) -302.035 (1.81034069e-06)
147870 EPS nconv=0 first unconverged value (error) -302.035 (1.80747762e-06)
147871 EPS nconv=0 first unconverged value (error) -302.035 (1.80747762e-06)
147872 EPS nconv=0 first unconverged value (error) -302.035 (1.80892341e-06)
147873 EPS nconv=0 first unconverged value (error) -302.035 (1.82109293e-06)
147874 EPS nconv=0 first unconverged value (error) -302.035 (1.80179063e-06)
147875 EPS nconv=0 first unconverged value (error) -302.035 (1.79875399e-06)
147876 EPS nconv=0 first unconverged value (error) -302.035 (1.79813026e-06)
147877 EPS nconv=0 first unconverged value (error) -302.035 (1.79813026e-06)
147878 EPS nconv=0 first unconverged value (error) -302.035 (1.90224272e-06)
147879 EPS nconv=0 first unconverged value (error) -302.035 (1.85875800e-06)
147880 EPS nconv=0 first unconverged value (error) -302.035 (1.84671666e-06)
147881 EPS nconv=0 first unconverged value (error) -302.035 (1.84529840e-06)
147882 EPS nconv=0 first unconverged value (error) -302.035 (1.83743720e-06)
147883 EPS nconv=0 first unconverged value (error) -302.035 (1.83743720e-06)
147884 EPS nconv=0 first unconverged value (error) -302.035 (1.83912227e-06)
147885 EPS nconv=0 first unconverged value (error) -302.035 (1.86640783e-06)
147886 EPS nconv=0 first unconverged value (error) -302.035 (1.82251326e-06)
147887 EPS nconv=0 first unconverged value (error) -302.035 (1.80307239e-06)
147888 EPS nconv=0 first unconverged value (error) -302.035 (1.80196357e-06)
147889 EPS nconv=0 first unconverged value (error) -302.035 (1.80196357e-06)
147890 EPS nconv=0 first unconverged value (error) -302.035 (1.80863732e-06)
147891 EPS nconv=0 first unconverged value (error) -302.035 (1.80264942e-06)
147892 EPS nconv=0 first unconverged value (error) -302.035 (1.80091480e-06)
147893 EPS nconv=0 first unconverged value (error) -302.035 (1.79962045e-06)
147894 EPS nconv=0 first unconverged value (error) -302.035 (1.79879640e-06)
147895 EPS nconv=0 first unconverged value (error) -302.035 (1.79879640e-06)
147896 EPS nconv=0 first unconverged value (error) -302.035 (1.81610771e-06)
147897 EPS nconv=0 first unconverged value (error) -302.035 (1.81491364e-06)
147898 EPS nconv=0 first unconverged value (error) -302.035 (1.80643519e-06)
147899 EPS nconv=0 first unconverged value (error) -302.035 (1.80456723e-06)
147900 EPS nconv=0 first unconverged value (error) -302.035 (1.80310582e-06)
147901 EPS nconv=0 first unconverged value (error) -302.035 (1.80310582e-06)
147902 EPS nconv=0 first unconverged value (error) -302.035 (1.88575915e-06)
147903 EPS nconv=0 first unconverged value (error) -302.035 (1.86633416e-06)
147904 EPS nconv=0 first unconverged value (error) -302.035 (1.84808127e-06)
147905 EPS nconv=0 first unconverged value (error) -302.035 (1.84655100e-06)
147906 EPS nconv=0 first unconverged value (error) -302.035 (1.83871173e-06)
147907 EPS nconv=0 first unconverged value (error) -302.035 (1.83871173e-06)
147908 EPS nconv=0 first unconverged value (error) -302.035 (1.95142608e-06)
147909 EPS nconv=0 first unconverged value (error) -302.035 (1.91524688e-06)
147910 EPS nconv=0 first unconverged value (error) -302.035 (1.86731175e-06)
147911 EPS nconv=0 first unconverged value (error) -302.035 (1.86593324e-06)
147912 EPS nconv=0 first unconverged value (error) -302.035 (1.85312129e-06)
147913 EPS nconv=0 first unconverged value (error) -302.035 (1.85312129e-06)
147914 EPS nconv=0 first unconverged value (error) -302.035 (1.93304172e-06)
147915 EPS nconv=0 first unconverged value (error) -302.035 (1.92748131e-06)
147916 EPS nconv=0 first unconverged value (error) -302.035 (1.87848736e-06)
147917 EPS nconv=0 first unconverged value (error) -302.035 (1.85821819e-06)
147918 EPS nconv=0 first unconverged value (error) -302.035 (1.84631853e-06)
147919 EPS nconv=0 first unconverged value (error) -302.035 (1.84631853e-06)
147920 EPS nconv=0 first unconverged value (error) -302.035 (1.85850181e-06)
147921 EPS nconv=0 first unconverged value (error) -302.035 (1.88187184e-06)
147922 EPS nconv=0 first unconverged value (error) -302.035 (1.85814872e-06)
147923 EPS nconv=0 first unconverged value (error) -302.035 (1.81903508e-06)
147924 EPS nconv=0 first unconverged value (error) -302.035 (1.80949451e-06)
147925 EPS nconv=0 first unconverged value (error) -302.035 (1.80949451e-06)
147926 EPS nconv=0 first unconverged value (error) -302.035 (1.80452236e-06)
147927 EPS nconv=0 first unconverged value (error) -302.035 (1.80744792e-06)
147928 EPS nconv=0 first unconverged value (error) -302.035 (1.79954223e-06)
147929 EPS nconv=0 first unconverged value (error) -302.035 (1.79789970e-06)
147930 EPS nconv=0 first unconverged value (error) -302.035 (1.79750802e-06)
147931 EPS nconv=0 first unconverged value (error) -302.035 (1.79750802e-06)
147932 EPS nconv=0 first unconverged value (error) -302.035 (1.82326905e-06)
147933 EPS nconv=0 first unconverged value (error) -302.035 (1.81297125e-06)
147934 EPS nconv=0 first unconverged value (error) -302.035 (1.80768046e-06)
147935 EPS nconv=0 first unconverged value (error) -302.035 (1.80599882e-06)
147936 EPS nconv=0 first unconverged value (error) -302.035 (1.80406975e-06)
147937 EPS nconv=0 first unconverged value (error) -302.035 (1.80406975e-06)
147938 EPS nconv=0 first unconverged value (error) -302.035 (1.89200701e-06)
147939 EPS nconv=0 first unconverged value (error) -302.035 (1.88619328e-06)
147940 EPS nconv=0 first unconverged value (error) -302.035 (1.85720684e-06)
147941 EPS nconv=0 first unconverged value (error) -302.035 (1.84774447e-06)
147942 EPS nconv=0 first unconverged value (error) -302.035 (1.83897974e-06)
147943 EPS nconv=0 first unconverged value (error) -302.035 (1.83897974e-06)
147944 EPS nconv=0 first unconverged value (error) -302.035 (1.85186057e-06)
147945 EPS nconv=0 first unconverged value (error) -302.035 (1.85101330e-06)
147946 EPS nconv=0 first unconverged value (error) -302.035 (1.83515126e-06)
147947 EPS nconv=0 first unconverged value (error) -302.035 (1.81906885e-06)
147948 EPS nconv=0 first unconverged value (error) -302.035 (1.81415337e-06)
147949 EPS nconv=0 first unconverged value (error) -302.035 (1.81415337e-06)
147950 EPS nconv=0 first unconverged value (error) -302.035 (1.97159442e-06)
147951 EPS nconv=0 first unconverged value (error) -302.035 (1.93201195e-06)
147952 EPS nconv=0 first unconverged value (error) -302.035 (1.89243929e-06)
147953 EPS nconv=0 first unconverged value (error) -302.035 (1.87638751e-06)
147954 EPS nconv=0 first unconverged value (error) -302.035 (1.86487989e-06)
147955 EPS nconv=0 first unconverged value (error) -302.035 (1.86487989e-06)
147956 EPS nconv=0 first unconverged value (error) -302.035 (1.97602040e-06)
147957 EPS nconv=0 first unconverged value (error) -302.035 (1.98874715e-06)
147958 EPS nconv=0 first unconverged value (error) -302.035 (1.94223315e-06)
147959 EPS nconv=0 first unconverged value (error) -302.035 (1.86228691e-06)
147960 EPS nconv=0 first unconverged value (error) -302.035 (1.84047782e-06)
147961 EPS nconv=0 first unconverged value (error) -302.035 (1.84047782e-06)
147962 EPS nconv=0 first unconverged value (error) -302.035 (1.83250446e-06)
147963 EPS nconv=0 first unconverged value (error) -302.035 (1.85995563e-06)
147964 EPS nconv=0 first unconverged value (error) -302.035 (1.82745567e-06)
147965 EPS nconv=0 first unconverged value (error) -302.035 (1.81264213e-06)
147966 EPS nconv=0 first unconverged value (error) -302.035 (1.80531675e-06)
147967 EPS nconv=0 first unconverged value (error) -302.035 (1.80531675e-06)
147968 EPS nconv=0 first unconverged value (error) -302.035 (1.82729425e-06)
147969 EPS nconv=0 first unconverged value (error) -302.035 (1.81548313e-06)
147970 EPS nconv=0 first unconverged value (error) -302.035 (1.81118731e-06)
147971 EPS nconv=0 first unconverged value (error) -302.035 (1.80993795e-06)
147972 EPS nconv=0 first unconverged value (error) -302.035 (1.80745386e-06)
147973 EPS nconv=0 first unconverged value (error) -302.035 (1.80745386e-06)
147974 EPS nconv=0 first unconverged value (error) -302.035 (2.18422876e-06)
147975 EPS nconv=0 first unconverged value (error) -302.035 (2.11614693e-06)
147976 EPS nconv=0 first unconverged value (error) -302.035 (2.03628609e-06)
147977 EPS nconv=0 first unconverged value (error) -302.035 (1.96846646e-06)
147978 EPS nconv=0 first unconverged value (error) -302.035 (1.95096397e-06)
147979 EPS nconv=0 first unconverged value (error) -302.035 (1.95096397e-06)
147980 EPS nconv=0 first unconverged value (error) -302.035 (2.10211335e-06)
147981 EPS nconv=0 first unconverged value (error) -302.035 (2.12477105e-06)
147982 EPS nconv=0 first unconverged value (error) -302.035 (2.02673311e-06)
147983 EPS nconv=0 first unconverged value (error) -302.035 (1.96234752e-06)
147984 EPS nconv=0 first unconverged value (error) -302.035 (1.89982348e-06)
147985 EPS nconv=0 first unconverged value (error) -302.035 (1.89982348e-06)
147986 EPS nconv=0 first unconverged value (error) -302.035 (1.95644020e-06)
147987 EPS nconv=0 first unconverged value (error) -302.035 (1.94652726e-06)
147988 EPS nconv=0 first unconverged value (error) -302.035 (1.89670208e-06)
147989 EPS nconv=0 first unconverged value (error) -302.035 (1.87959052e-06)
147990 EPS nconv=0 first unconverged value (error) -302.035 (1.83943144e-06)
147991 EPS nconv=0 first unconverged value (error) -302.035 (1.83943144e-06)
147992 EPS nconv=0 first unconverged value (error) -302.035 (1.83949701e-06)
147993 EPS nconv=0 first unconverged value (error) -302.035 (1.83857426e-06)
147994 EPS nconv=0 first unconverged value (error) -302.035 (1.82551723e-06)
147995 EPS nconv=0 first unconverged value (error) -302.035 (1.81027277e-06)
147996 EPS nconv=0 first unconverged value (error) -302.035 (1.80696269e-06)
147997 EPS nconv=0 first unconverged value (error) -302.035 (1.80696269e-06)
147998 EPS nconv=0 first unconverged value (error) -302.035 (2.03061450e-06)
147999 EPS nconv=0 first unconverged value (error) -302.035 (1.92151788e-06)
148000 EPS nconv=0 first unconverged value (error) -302.035 (1.90218117e-06)
148001 EPS nconv=0 first unconverged value (error) -302.035 (1.88538750e-06)
148002 EPS nconv=0 first unconverged value (error) -302.035 (1.87262490e-06)
148003 EPS nconv=0 first unconverged value (error) -302.035 (1.87262490e-06)
148004 EPS nconv=0 first unconverged value (error) -302.035 (2.00638359e-06)
148005 EPS nconv=0 first unconverged value (error) -302.035 (2.06894834e-06)
148006 EPS nconv=0 first unconverged value (error) -302.035 (1.94856857e-06)
148007 EPS nconv=0 first unconverged value (error) -302.035 (1.88168192e-06)
148008 EPS nconv=0 first unconverged value (error) -302.035 (1.86237986e-06)
148009 EPS nconv=0 first unconverged value (error) -302.035 (1.86237986e-06)
148010 EPS nconv=0 first unconverged value (error) -302.035 (1.88091575e-06)
148011 EPS nconv=0 first unconverged value (error) -302.035 (1.89475368e-06)
148012 EPS nconv=0 first unconverged value (error) -302.035 (1.86338390e-06)
148013 EPS nconv=0 first unconverged value (error) -302.035 (1.83319968e-06)
148014 EPS nconv=0 first unconverged value (error) -302.035 (1.82623505e-06)
148015 EPS nconv=0 first unconverged value (error) -302.035 (1.82623505e-06)
148016 EPS nconv=0 first unconverged value (error) -302.035 (1.83992880e-06)
148017 EPS nconv=0 first unconverged value (error) -302.035 (1.82677852e-06)
148018 EPS nconv=0 first unconverged value (error) -302.035 (1.81623124e-06)
148019 EPS nconv=0 first unconverged value (error) -302.035 (1.81258006e-06)
148020 EPS nconv=0 first unconverged value (error) -302.035 (1.80837899e-06)
148021 EPS nconv=0 first unconverged value (error) -302.035 (1.80837899e-06)
148022 EPS nconv=0 first unconverged value (error) -302.035 (1.97902214e-06)
148023 EPS nconv=0 first unconverged value (error) -302.035 (1.92624984e-06)
148024 EPS nconv=0 first unconverged value (error) -302.035 (1.88891184e-06)
148025 EPS nconv=0 first unconverged value (error) -302.035 (1.86471003e-06)
148026 EPS nconv=0 first unconverged value (error) -302.035 (1.85593951e-06)
148027 EPS nconv=0 first unconverged value (error) -302.035 (1.85593951e-06)
148028 EPS nconv=0 first unconverged value (error) -302.035 (2.26166787e-06)
148029 EPS nconv=0 first unconverged value (error) -302.035 (2.18715108e-06)
148030 EPS nconv=0 first unconverged value (error) -302.035 (2.07922602e-06)
148031 EPS nconv=0 first unconverged value (error) -302.035 (2.05940763e-06)
148032 EPS nconv=0 first unconverged value (error) -302.035 (1.99465112e-06)
148033 EPS nconv=0 first unconverged value (error) -302.035 (1.99465112e-06)
148034 EPS nconv=0 first unconverged value (error) -302.035 (2.25092312e-06)
148035 EPS nconv=0 first unconverged value (error) -302.035 (2.23578677e-06)
148036 EPS nconv=0 first unconverged value (error) -302.035 (2.08025100e-06)
148037 EPS nconv=0 first unconverged value (error) -302.035 (2.04800579e-06)
148038 EPS nconv=0 first unconverged value (error) -302.035 (2.01998486e-06)
148039 EPS nconv=0 first unconverged value (error) -302.035 (2.01998486e-06)
148040 EPS nconv=0 first unconverged value (error) -302.035 (1.96581879e-06)
148041 EPS nconv=0 first unconverged value (error) -302.035 (1.94221338e-06)
148042 EPS nconv=0 first unconverged value (error) -302.035 (1.89771423e-06)
148043 EPS nconv=0 first unconverged value (error) -302.035 (1.82747556e-06)
148044 EPS nconv=0 first unconverged value (error) -302.035 (1.82366807e-06)
148045 EPS nconv=0 first unconverged value (error) -302.035 (1.82366807e-06)
148046 EPS nconv=0 first unconverged value (error) -302.035 (1.83208041e-06)
148047 EPS nconv=0 first unconverged value (error) -302.035 (1.81402636e-06)
148048 EPS nconv=0 first unconverged value (error) -302.035 (1.81182911e-06)
148049 EPS nconv=0 first unconverged value (error) -302.035 (1.80955000e-06)
148050 EPS nconv=0 first unconverged value (error) -302.035 (1.80791245e-06)
148051 EPS nconv=0 first unconverged value (error) -302.035 (1.80791245e-06)
148052 EPS nconv=0 first unconverged value (error) -302.035 (1.81206662e-06)
148053 EPS nconv=0 first unconverged value (error) -302.035 (1.83913407e-06)
148054 EPS nconv=0 first unconverged value (error) -302.035 (1.80594722e-06)
148055 EPS nconv=0 first unconverged value (error) -302.035 (1.79957764e-06)
148056 EPS nconv=0 first unconverged value (error) -302.035 (1.79771491e-06)
148057 EPS nconv=0 first unconverged value (error) -302.035 (1.79771491e-06)
148058 EPS nconv=0 first unconverged value (error) -302.035 (2.02047528e-06)
148059 EPS nconv=0 first unconverged value (error) -302.035 (1.95056137e-06)
148060 EPS nconv=0 first unconverged value (error) -302.035 (1.92935893e-06)
148061 EPS nconv=0 first unconverged value (error) -302.035 (1.92963200e-06)
148062 EPS nconv=0 first unconverged value (error) -302.035 (1.91070184e-06)
148063 EPS nconv=0 first unconverged value (error) -302.035 (1.91070184e-06)
148064 EPS nconv=0 first unconverged value (error) -302.035 (1.90920217e-06)
148065 EPS nconv=0 first unconverged value (error) -302.035 (1.91718354e-06)
148066 EPS nconv=0 first unconverged value (error) -302.035 (1.84621498e-06)
148067 EPS nconv=0 first unconverged value (error) -302.035 (1.80515769e-06)
148068 EPS nconv=0 first unconverged value (error) -302.035 (1.80507358e-06)
148069 EPS nconv=0 first unconverged value (error) -302.035 (1.80507358e-06)
148070 EPS nconv=0 first unconverged value (error) -302.035 (1.80120925e-06)
148071 EPS nconv=0 first unconverged value (error) -302.035 (1.79988950e-06)
148072 EPS nconv=0 first unconverged value (error) -302.035 (1.79838220e-06)
148073 EPS nconv=0 first unconverged value (error) -302.035 (1.79661169e-06)
148074 EPS nconv=0 first unconverged value (error) -302.035 (1.79541231e-06)
148075 EPS nconv=0 first unconverged value (error) -302.035 (1.79541231e-06)
148076 EPS nconv=0 first unconverged value (error) -302.035 (1.91267701e-06)
148077 EPS nconv=0 first unconverged value (error) -302.035 (1.87875837e-06)
148078 EPS nconv=0 first unconverged value (error) -302.035 (1.86415106e-06)
148079 EPS nconv=0 first unconverged value (error) -302.035 (1.85295432e-06)
148080 EPS nconv=0 first unconverged value (error) -302.035 (1.84483869e-06)
148081 EPS nconv=0 first unconverged value (error) -302.035 (1.84483869e-06)
148082 EPS nconv=0 first unconverged value (error) -302.035 (2.10620278e-06)
148083 EPS nconv=0 first unconverged value (error) -302.035 (2.03624309e-06)
148084 EPS nconv=0 first unconverged value (error) -302.035 (1.98339255e-06)
148085 EPS nconv=0 first unconverged value (error) -302.035 (1.98229626e-06)
148086 EPS nconv=0 first unconverged value (error) -302.035 (1.97990657e-06)
148087 EPS nconv=0 first unconverged value (error) -302.035 (1.97990657e-06)
148088 EPS nconv=0 first unconverged value (error) -302.035 (2.02909810e-06)
148089 EPS nconv=0 first unconverged value (error) -302.035 (1.95002044e-06)
148090 EPS nconv=0 first unconverged value (error) -302.035 (1.86819679e-06)
148091 EPS nconv=0 first unconverged value (error) -302.035 (1.84277173e-06)
148092 EPS nconv=0 first unconverged value (error) -302.035 (1.83867535e-06)
148093 EPS nconv=0 first unconverged value (error) -302.035 (1.83867535e-06)
148094 EPS nconv=0 first unconverged value (error) -302.035 (1.97602365e-06)
148095 EPS nconv=0 first unconverged value (error) -302.035 (1.94725099e-06)
148096 EPS nconv=0 first unconverged value (error) -302.035 (1.88621212e-06)
148097 EPS nconv=0 first unconverged value (error) -302.035 (1.85662917e-06)
148098 EPS nconv=0 first unconverged value (error) -302.035 (1.85101464e-06)
148099 EPS nconv=0 first unconverged value (error) -302.035 (1.85101464e-06)
148100 EPS nconv=0 first unconverged value (error) -302.035 (1.98917239e-06)
148101 EPS nconv=0 first unconverged value (error) -302.035 (2.02081285e-06)
148102 EPS nconv=0 first unconverged value (error) -302.035 (1.94652510e-06)
148103 EPS nconv=0 first unconverged value (error) -302.035 (1.88380984e-06)
148104 EPS nconv=0 first unconverged value (error) -302.035 (1.86331388e-06)
148105 EPS nconv=0 first unconverged value (error) -302.035 (1.86331388e-06)
148106 EPS nconv=0 first unconverged value (error) -302.035 (2.01723605e-06)
148107 EPS nconv=0 first unconverged value (error) -302.035 (1.96782700e-06)
148108 EPS nconv=0 first unconverged value (error) -302.035 (1.90430851e-06)
148109 EPS nconv=0 first unconverged value (error) -302.035 (1.89226414e-06)
148110 EPS nconv=0 first unconverged value (error) -302.035 (1.88730546e-06)
148111 EPS nconv=0 first unconverged value (error) -302.035 (1.88730546e-06)
148112 EPS nconv=0 first unconverged value (error) -302.035 (2.23012073e-06)
148113 EPS nconv=0 first unconverged value (error) -302.035 (2.10679440e-06)
148114 EPS nconv=0 first unconverged value (error) -302.035 (2.01234876e-06)
148115 EPS nconv=0 first unconverged value (error) -302.035 (1.92924939e-06)
148116 EPS nconv=0 first unconverged value (error) -302.035 (1.91947136e-06)
148117 EPS nconv=0 first unconverged value (error) -302.035 (1.91947136e-06)
148118 EPS nconv=0 first unconverged value (error) -302.035 (2.57143363e-06)
148119 EPS nconv=0 first unconverged value (error) -302.035 (2.40749030e-06)
148120 EPS nconv=0 first unconverged value (error) -302.035 (2.19804783e-06)
148121 EPS nconv=0 first unconverged value (error) -302.035 (2.15651036e-06)
148122 EPS nconv=0 first unconverged value (error) -302.035 (2.10152060e-06)
148123 EPS nconv=0 first unconverged value (error) -302.035 (2.10152060e-06)
148124 EPS nconv=0 first unconverged value (error) -302.035 (2.16210162e-06)
148125 EPS nconv=0 first unconverged value (error) -302.035 (2.38534131e-06)
148126 EPS nconv=0 first unconverged value (error) -302.035 (2.09464951e-06)
148127 EPS nconv=0 first unconverged value (error) -302.035 (1.91134000e-06)
148128 EPS nconv=0 first unconverged value (error) -302.035 (1.85721359e-06)
148129 EPS nconv=0 first unconverged value (error) -302.035 (1.85721359e-06)
148130 EPS nconv=0 first unconverged value (error) -302.035 (2.50362838e-06)
148131 EPS nconv=0 first unconverged value (error) -302.035 (2.28057680e-06)
148132 EPS nconv=0 first unconverged value (error) -302.035 (2.20549091e-06)
148133 EPS nconv=0 first unconverged value (error) -302.035 (2.15698815e-06)
148134 EPS nconv=0 first unconverged value (error) -302.035 (2.12152853e-06)
148135 EPS nconv=0 first unconverged value (error) -302.035 (2.12152853e-06)
148136 EPS nconv=0 first unconverged value (error) -302.035 (2.18511951e-06)
148137 EPS nconv=0 first unconverged value (error) -302.035 (2.28233668e-06)
148138 EPS nconv=0 first unconverged value (error) -302.035 (2.00387865e-06)
148139 EPS nconv=0 first unconverged value (error) -302.035 (1.93072806e-06)
148140 EPS nconv=0 first unconverged value (error) -302.035 (1.90024813e-06)
148141 EPS nconv=0 first unconverged value (error) -302.035 (1.90024813e-06)
148142 EPS nconv=0 first unconverged value (error) -302.035 (2.81571972e-06)
148143 EPS nconv=0 first unconverged value (error) -302.035 (2.57909196e-06)
148144 EPS nconv=0 first unconverged value (error) -302.035 (2.39086510e-06)
148145 EPS nconv=0 first unconverged value (error) -302.035 (2.29161723e-06)
148146 EPS nconv=0 first unconverged value (error) -302.035 (2.20804538e-06)
148147 EPS nconv=0 first unconverged value (error) -302.035 (2.20804538e-06)
148148 EPS nconv=0 first unconverged value (error) -302.035 (2.20570101e-06)
148149 EPS nconv=0 first unconverged value (error) -302.035 (2.50146951e-06)
148150 EPS nconv=0 first unconverged value (error) -302.035 (2.13927242e-06)
148151 EPS nconv=0 first unconverged value (error) -302.035 (1.93782834e-06)
148152 EPS nconv=0 first unconverged value (error) -302.035 (1.88555016e-06)
148153 EPS nconv=0 first unconverged value (error) -302.035 (1.88555016e-06)
148154 EPS nconv=0 first unconverged value (error) -302.035 (1.90602669e-06)
148155 EPS nconv=0 first unconverged value (error) -302.035 (1.86615347e-06)
148156 EPS nconv=0 first unconverged value (error) -302.035 (1.85857639e-06)
148157 EPS nconv=0 first unconverged value (error) -302.035 (1.85507264e-06)
148158 EPS nconv=0 first unconverged value (error) -302.035 (1.84332211e-06)
148159 EPS nconv=0 first unconverged value (error) -302.035 (1.84332211e-06)
148160 EPS nconv=0 first unconverged value (error) -302.035 (2.66381894e-06)
148161 EPS nconv=0 first unconverged value (error) -302.035 (2.56922633e-06)
148162 EPS nconv=0 first unconverged value (error) -302.035 (2.41669061e-06)
148163 EPS nconv=0 first unconverged value (error) -302.035 (2.40123976e-06)
148164 EPS nconv=0 first unconverged value (error) -302.035 (2.38791588e-06)
148165 EPS nconv=0 first unconverged value (error) -302.035 (2.38791588e-06)
148166 EPS nconv=0 first unconverged value (error) -302.035 (2.60851427e-06)
148167 EPS nconv=0 first unconverged value (error) -302.035 (2.31462474e-06)
148168 EPS nconv=0 first unconverged value (error) -302.035 (2.17079588e-06)
148169 EPS nconv=0 first unconverged value (error) -302.035 (1.97495522e-06)
148170 EPS nconv=0 first unconverged value (error) -302.035 (1.92562411e-06)
148171 EPS nconv=0 first unconverged value (error) -302.035 (1.92562411e-06)
148172 EPS nconv=0 first unconverged value (error) -302.035 (1.91830276e-06)
148173 EPS nconv=0 first unconverged value (error) -302.035 (1.95594917e-06)
148174 EPS nconv=0 first unconverged value (error) -302.035 (1.86922131e-06)
148175 EPS nconv=0 first unconverged value (error) -302.035 (1.81390588e-06)
148176 EPS nconv=0 first unconverged value (error) -302.035 (1.81501486e-06)
148177 EPS nconv=0 first unconverged value (error) -302.035 (1.81501486e-06)
148178 EPS nconv=0 first unconverged value (error) -302.035 (2.13739465e-06)
148179 EPS nconv=0 first unconverged value (error) -302.035 (1.96818546e-06)
148180 EPS nconv=0 first unconverged value (error) -302.035 (1.94549191e-06)
148181 EPS nconv=0 first unconverged value (error) -302.035 (1.92347534e-06)
148182 EPS nconv=0 first unconverged value (error) -302.035 (1.90352839e-06)
148183 EPS nconv=0 first unconverged value (error) -302.035 (1.90352839e-06)
148184 EPS nconv=0 first unconverged value (error) -302.035 (2.55331230e-06)
148185 EPS nconv=0 first unconverged value (error) -302.035 (2.51594942e-06)
148186 EPS nconv=0 first unconverged value (error) -302.035 (2.25075043e-06)
148187 EPS nconv=0 first unconverged value (error) -302.035 (2.12818234e-06)
148188 EPS nconv=0 first unconverged value (error) -302.035 (2.08037340e-06)
148189 EPS nconv=0 first unconverged value (error) -302.035 (2.08037340e-06)
148190 EPS nconv=0 first unconverged value (error) -302.035 (3.27850715e-06)
148191 EPS nconv=0 first unconverged value (error) -302.035 (2.96692708e-06)
148192 EPS nconv=0 first unconverged value (error) -302.035 (2.69203972e-06)
148193 EPS nconv=0 first unconverged value (error) -302.035 (2.68342388e-06)
148194 EPS nconv=0 first unconverged value (error) -302.035 (2.56760045e-06)
148195 EPS nconv=0 first unconverged value (error) -302.035 (2.56760045e-06)
148196 EPS nconv=0 first unconverged value (error) -302.035 (2.62294936e-06)
148197 EPS nconv=0 first unconverged value (error) -302.035 (2.68042749e-06)
148198 EPS nconv=0 first unconverged value (error) -302.035 (2.24045161e-06)
148199 EPS nconv=0 first unconverged value (error) -302.035 (2.08275175e-06)
148200 EPS nconv=0 first unconverged value (error) -302.035 (1.97786596e-06)
148201 EPS nconv=0 first unconverged value (error) -302.035 (1.97786596e-06)
148202 EPS nconv=0 first unconverged value (error) -302.035 (1.87579035e-06)
148203 EPS nconv=0 first unconverged value (error) -302.035 (1.86857478e-06)
148204 EPS nconv=0 first unconverged value (error) -302.035 (1.86302616e-06)
148205 EPS nconv=0 first unconverged value (error) -302.035 (1.81348600e-06)
148206 EPS nconv=0 first unconverged value (error) -302.035 (1.80437912e-06)
148207 EPS nconv=0 first unconverged value (error) -302.035 (1.80437912e-06)
148208 EPS nconv=0 first unconverged value (error) -302.035 (2.02259755e-06)
148209 EPS nconv=0 first unconverged value (error) -302.035 (1.93961123e-06)
148210 EPS nconv=0 first unconverged value (error) -302.035 (1.93311186e-06)
148211 EPS nconv=0 first unconverged value (error) -302.035 (1.91015568e-06)
148212 EPS nconv=0 first unconverged value (error) -302.035 (1.89216133e-06)
148213 EPS nconv=0 first unconverged value (error) -302.035 (1.89216133e-06)
148214 EPS nconv=0 first unconverged value (error) -302.035 (1.93159488e-06)
148215 EPS nconv=0 first unconverged value (error) -302.035 (2.00889326e-06)
148216 EPS nconv=0 first unconverged value (error) -302.035 (1.90328799e-06)
148217 EPS nconv=0 first unconverged value (error) -302.035 (1.84157169e-06)
148218 EPS nconv=0 first unconverged value (error) -302.035 (1.82942136e-06)
148219 EPS nconv=0 first unconverged value (error) -302.035 (1.82942136e-06)
148220 EPS nconv=0 first unconverged value (error) -302.035 (1.95131608e-06)
148221 EPS nconv=0 first unconverged value (error) -302.035 (1.91139465e-06)
148222 EPS nconv=0 first unconverged value (error) -302.035 (1.89245228e-06)
148223 EPS nconv=0 first unconverged value (error) -302.035 (1.87071721e-06)
148224 EPS nconv=0 first unconverged value (error) -302.035 (1.85756486e-06)
148225 EPS nconv=0 first unconverged value (error) -302.035 (1.85756486e-06)
148226 EPS nconv=0 first unconverged value (error) -302.035 (2.05028177e-06)
148227 EPS nconv=0 first unconverged value (error) -302.035 (1.97246572e-06)
148228 EPS nconv=0 first unconverged value (error) -302.035 (1.91561824e-06)
148229 EPS nconv=0 first unconverged value (error) -302.035 (1.89945073e-06)
148230 EPS nconv=0 first unconverged value (error) -302.035 (1.89310884e-06)
148231 EPS nconv=0 first unconverged value (error) -302.035 (1.89310884e-06)
148232 EPS nconv=0 first unconverged value (error) -302.035 (1.87446358e-06)
148233 EPS nconv=0 first unconverged value (error) -302.035 (1.91905558e-06)
148234 EPS nconv=0 first unconverged value (error) -302.035 (1.83672312e-06)
148235 EPS nconv=0 first unconverged value (error) -302.035 (1.82245431e-06)
148236 EPS nconv=0 first unconverged value (error) -302.035 (1.81341683e-06)
148237 EPS nconv=0 first unconverged value (error) -302.035 (1.81341683e-06)
148238 EPS nconv=0 first unconverged value (error) -302.035 (1.80043335e-06)
148239 EPS nconv=0 first unconverged value (error) -302.035 (1.79879767e-06)
148240 EPS nconv=0 first unconverged value (error) -302.035 (1.79747062e-06)
148241 EPS nconv=0 first unconverged value (error) -302.035 (1.79705600e-06)
148242 EPS nconv=0 first unconverged value (error) -302.035 (1.79663811e-06)
148243 EPS nconv=0 first unconverged value (error) -302.035 (1.79663811e-06)
148244 EPS nconv=0 first unconverged value (error) -302.035 (1.79795742e-06)
148245 EPS nconv=0 first unconverged value (error) -302.035 (1.79894872e-06)
148246 EPS nconv=0 first unconverged value (error) -302.035 (1.79728814e-06)
148247 EPS nconv=0 first unconverged value (error) -302.035 (1.79596032e-06)
148248 EPS nconv=0 first unconverged value (error) -302.035 (1.79580535e-06)
148249 EPS nconv=0 first unconverged value (error) -302.035 (1.79580535e-06)
148250 EPS nconv=0 first unconverged value (error) -302.035 (1.97157470e-06)
148251 EPS nconv=0 first unconverged value (error) -302.035 (1.89893370e-06)
148252 EPS nconv=0 first unconverged value (error) -302.035 (1.89037182e-06)
148253 EPS nconv=0 first unconverged value (error) -302.035 (1.87895077e-06)
148254 EPS nconv=0 first unconverged value (error) -302.035 (1.86367996e-06)
148255 EPS nconv=0 first unconverged value (error) -302.035 (1.86367996e-06)
148256 EPS nconv=0 first unconverged value (error) -302.035 (1.88597123e-06)
148257 EPS nconv=0 first unconverged value (error) -302.035 (1.91158263e-06)
148258 EPS nconv=0 first unconverged value (error) -302.035 (1.83783697e-06)
148259 EPS nconv=0 first unconverged value (error) -302.035 (1.82558403e-06)
148260 EPS nconv=0 first unconverged value (error) -302.035 (1.82254241e-06)
148261 EPS nconv=0 first unconverged value (error) -302.035 (1.82254241e-06)
148262 EPS nconv=0 first unconverged value (error) -302.035 (1.82642344e-06)
148263 EPS nconv=0 first unconverged value (error) -302.035 (1.82367938e-06)
148264 EPS nconv=0 first unconverged value (error) -302.035 (1.81137944e-06)
148265 EPS nconv=0 first unconverged value (error) -302.035 (1.80455966e-06)
148266 EPS nconv=0 first unconverged value (error) -302.035 (1.80385218e-06)
148267 EPS nconv=0 first unconverged value (error) -302.035 (1.80385218e-06)
148268 EPS nconv=0 first unconverged value (error) -302.035 (1.85526956e-06)
148269 EPS nconv=0 first unconverged value (error) -302.035 (1.83719399e-06)
148270 EPS nconv=0 first unconverged value (error) -302.035 (1.82698122e-06)
148271 EPS nconv=0 first unconverged value (error) -302.035 (1.81499178e-06)
148272 EPS nconv=0 first unconverged value (error) -302.035 (1.81185456e-06)
148273 EPS nconv=0 first unconverged value (error) -302.035 (1.81185456e-06)
148274 EPS nconv=0 first unconverged value (error) -302.035 (2.02100494e-06)
148275 EPS nconv=0 first unconverged value (error) -302.035 (1.95122529e-06)
148276 EPS nconv=0 first unconverged value (error) -302.035 (1.90686831e-06)
148277 EPS nconv=0 first unconverged value (error) -302.035 (1.89746926e-06)
148278 EPS nconv=0 first unconverged value (error) -302.035 (1.88958153e-06)
148279 EPS nconv=0 first unconverged value (error) -302.035 (1.88958153e-06)
148280 EPS nconv=0 first unconverged value (error) -302.035 (1.88929365e-06)
148281 EPS nconv=0 first unconverged value (error) -302.035 (1.92111327e-06)
148282 EPS nconv=0 first unconverged value (error) -302.035 (1.83639038e-06)
148283 EPS nconv=0 first unconverged value (error) -302.035 (1.80821817e-06)
148284 EPS nconv=0 first unconverged value (error) -302.035 (1.80377976e-06)
148285 EPS nconv=0 first unconverged value (error) -302.035 (1.80377976e-06)
148286 EPS nconv=0 first unconverged value (error) -302.035 (1.81649463e-06)
148287 EPS nconv=0 first unconverged value (error) -302.035 (1.80903628e-06)
148288 EPS nconv=0 first unconverged value (error) -302.035 (1.80682129e-06)
148289 EPS nconv=0 first unconverged value (error) -302.035 (1.80594809e-06)
148290 EPS nconv=0 first unconverged value (error) -302.035 (1.80474106e-06)
148291 EPS nconv=0 first unconverged value (error) -302.035 (1.80474106e-06)
148292 EPS nconv=0 first unconverged value (error) -302.035 (1.80475261e-06)
148293 EPS nconv=0 first unconverged value (error) -302.035 (1.80907332e-06)
148294 EPS nconv=0 first unconverged value (error) -302.035 (1.80144564e-06)
148295 EPS nconv=0 first unconverged value (error) -302.035 (1.79623766e-06)
148296 EPS nconv=0 first unconverged value (error) -302.035 (1.79525280e-06)
148297 EPS nconv=0 first unconverged value (error) -302.035 (1.79525280e-06)
148298 EPS nconv=0 first unconverged value (error) -302.035 (1.84188500e-06)
148299 EPS nconv=0 first unconverged value (error) -302.035 (1.82814676e-06)
148300 EPS nconv=0 first unconverged value (error) -302.035 (1.82452644e-06)
148301 EPS nconv=0 first unconverged value (error) -302.035 (1.82072349e-06)
148302 EPS nconv=0 first unconverged value (error) -302.035 (1.81837598e-06)
148303 EPS nconv=0 first unconverged value (error) -302.035 (1.81837598e-06)
148304 EPS nconv=0 first unconverged value (error) -302.035 (1.84420642e-06)
148305 EPS nconv=0 first unconverged value (error) -302.035 (1.84200855e-06)
148306 EPS nconv=0 first unconverged value (error) -302.035 (1.82464116e-06)
148307 EPS nconv=0 first unconverged value (error) -302.035 (1.80908859e-06)
148308 EPS nconv=0 first unconverged value (error) -302.035 (1.80506057e-06)
148309 EPS nconv=0 first unconverged value (error) -302.035 (1.80506057e-06)
148310 EPS nconv=0 first unconverged value (error) -302.035 (1.83471158e-06)
148311 EPS nconv=0 first unconverged value (error) -302.035 (1.83118362e-06)
148312 EPS nconv=0 first unconverged value (error) -302.035 (1.82135518e-06)
148313 EPS nconv=0 first unconverged value (error) -302.035 (1.81639536e-06)
148314 EPS nconv=0 first unconverged value (error) -302.035 (1.81338145e-06)
148315 EPS nconv=0 first unconverged value (error) -302.035 (1.81338145e-06)
148316 EPS nconv=0 first unconverged value (error) -302.035 (2.53935626e-06)
148317 EPS nconv=0 first unconverged value (error) -302.035 (2.34152608e-06)
148318 EPS nconv=0 first unconverged value (error) -302.035 (2.23409059e-06)
148319 EPS nconv=0 first unconverged value (error) -302.035 (2.21620651e-06)
148320 EPS nconv=0 first unconverged value (error) -302.035 (2.17726522e-06)
148321 EPS nconv=0 first unconverged value (error) -302.035 (2.17726522e-06)
148322 EPS nconv=0 first unconverged value (error) -302.035 (2.63981608e-06)
148323 EPS nconv=0 first unconverged value (error) -302.035 (2.45235008e-06)
148324 EPS nconv=0 first unconverged value (error) -302.035 (2.18231962e-06)
148325 EPS nconv=0 first unconverged value (error) -302.035 (2.10482691e-06)
148326 EPS nconv=0 first unconverged value (error) -302.035 (2.10267880e-06)
148327 EPS nconv=0 first unconverged value (error) -302.035 (2.10267880e-06)
148328 EPS nconv=0 first unconverged value (error) -302.035 (2.37588089e-06)
148329 EPS nconv=0 first unconverged value (error) -302.035 (2.35980411e-06)
148330 EPS nconv=0 first unconverged value (error) -302.035 (2.15010713e-06)
148331 EPS nconv=0 first unconverged value (error) -302.035 (2.05200787e-06)
148332 EPS nconv=0 first unconverged value (error) -302.035 (1.96856781e-06)
148333 EPS nconv=0 first unconverged value (error) -302.035 (1.96856781e-06)
148334 EPS nconv=0 first unconverged value (error) -302.035 (2.00030889e-06)
148335 EPS nconv=0 first unconverged value (error) -302.035 (2.13130341e-06)
148336 EPS nconv=0 first unconverged value (error) -302.035 (1.93004814e-06)
148337 EPS nconv=0 first unconverged value (error) -302.035 (1.86216140e-06)
148338 EPS nconv=0 first unconverged value (error) -302.035 (1.83857497e-06)
148339 EPS nconv=0 first unconverged value (error) -302.035 (1.83857497e-06)
148340 EPS nconv=0 first unconverged value (error) -302.035 (1.86052875e-06)
148341 EPS nconv=0 first unconverged value (error) -302.035 (1.86642806e-06)
148342 EPS nconv=0 first unconverged value (error) -302.035 (1.83897933e-06)
148343 EPS nconv=0 first unconverged value (error) -302.035 (1.82185048e-06)
148344 EPS nconv=0 first unconverged value (error) -302.035 (1.81081275e-06)
148345 EPS nconv=0 first unconverged value (error) -302.035 (1.81081275e-06)
148346 EPS nconv=0 first unconverged value (error) -302.035 (1.81182090e-06)
148347 EPS nconv=0 first unconverged value (error) -302.035 (1.81265785e-06)
148348 EPS nconv=0 first unconverged value (error) -302.035 (1.80250807e-06)
148349 EPS nconv=0 first unconverged value (error) -302.035 (1.80053751e-06)
148350 EPS nconv=0 first unconverged value (error) -302.035 (1.79987762e-06)
148351 EPS nconv=0 first unconverged value (error) -302.035 (1.79987762e-06)
148352 EPS nconv=0 first unconverged value (error) -302.035 (2.22516920e-06)
148353 EPS nconv=0 first unconverged value (error) -302.035 (2.05155201e-06)
148354 EPS nconv=0 first unconverged value (error) -302.035 (1.99900152e-06)
148355 EPS nconv=0 first unconverged value (error) -302.035 (1.98744637e-06)
148356 EPS nconv=0 first unconverged value (error) -302.035 (1.96135436e-06)
148357 EPS nconv=0 first unconverged value (error) -302.035 (1.96135436e-06)
148358 EPS nconv=0 first unconverged value (error) -302.035 (2.45509568e-06)
148359 EPS nconv=0 first unconverged value (error) -302.035 (2.46338506e-06)
148360 EPS nconv=0 first unconverged value (error) -302.035 (2.19901553e-06)
148361 EPS nconv=0 first unconverged value (error) -302.035 (2.18971000e-06)
148362 EPS nconv=0 first unconverged value (error) -302.035 (2.14395377e-06)
148363 EPS nconv=0 first unconverged value (error) -302.035 (2.14395377e-06)
148364 EPS nconv=0 first unconverged value (error) -302.035 (2.35656859e-06)
148365 EPS nconv=0 first unconverged value (error) -302.035 (2.23241945e-06)
148366 EPS nconv=0 first unconverged value (error) -302.035 (2.11953003e-06)
148367 EPS nconv=0 first unconverged value (error) -302.035 (2.03295487e-06)
148368 EPS nconv=0 first unconverged value (error) -302.035 (2.01810075e-06)
148369 EPS nconv=0 first unconverged value (error) -302.035 (2.01810075e-06)
148370 EPS nconv=0 first unconverged value (error) -302.035 (2.09260752e-06)
148371 EPS nconv=0 first unconverged value (error) -302.035 (2.10840185e-06)
148372 EPS nconv=0 first unconverged value (error) -302.035 (2.02177171e-06)
148373 EPS nconv=0 first unconverged value (error) -302.035 (1.88424526e-06)
148374 EPS nconv=0 first unconverged value (error) -302.035 (1.86496213e-06)
148375 EPS nconv=0 first unconverged value (error) -302.035 (1.86496213e-06)
148376 EPS nconv=0 first unconverged value (error) -302.035 (1.86317344e-06)
148377 EPS nconv=0 first unconverged value (error) -302.035 (1.91208710e-06)
148378 EPS nconv=0 first unconverged value (error) -302.035 (1.84408084e-06)
148379 EPS nconv=0 first unconverged value (error) -302.035 (1.82608192e-06)
148380 EPS nconv=0 first unconverged value (error) -302.035 (1.81760521e-06)
148381 EPS nconv=0 first unconverged value (error) -302.035 (1.81760521e-06)
148382 EPS nconv=0 first unconverged value (error) -302.035 (1.80861514e-06)
148383 EPS nconv=0 first unconverged value (error) -302.035 (1.81919782e-06)
148384 EPS nconv=0 first unconverged value (error) -302.035 (1.80296970e-06)
148385 EPS nconv=0 first unconverged value (error) -302.035 (1.79999357e-06)
148386 EPS nconv=0 first unconverged value (error) -302.035 (1.79760715e-06)
148387 EPS nconv=0 first unconverged value (error) -302.035 (1.79760715e-06)
148388 EPS nconv=0 first unconverged value (error) -302.035 (2.43084875e-06)
148389 EPS nconv=0 first unconverged value (error) -302.035 (2.28741152e-06)
148390 EPS nconv=0 first unconverged value (error) -302.035 (2.13944207e-06)
148391 EPS nconv=0 first unconverged value (error) -302.035 (2.11957465e-06)
148392 EPS nconv=0 first unconverged value (error) -302.035 (2.06253902e-06)
148393 EPS nconv=0 first unconverged value (error) -302.035 (2.06253902e-06)
148394 EPS nconv=0 first unconverged value (error) -302.035 (3.38619785e-06)
148395 EPS nconv=0 first unconverged value (error) -302.035 (3.26813290e-06)
148396 EPS nconv=0 first unconverged value (error) -302.035 (2.85511222e-06)
148397 EPS nconv=0 first unconverged value (error) -302.035 (2.79985641e-06)
148398 EPS nconv=0 first unconverged value (error) -302.035 (2.75803026e-06)
148399 EPS nconv=0 first unconverged value (error) -302.035 (2.75803026e-06)
148400 EPS nconv=0 first unconverged value (error) -302.035 (2.63542192e-06)
148401 EPS nconv=0 first unconverged value (error) -302.035 (2.69195214e-06)
148402 EPS nconv=0 first unconverged value (error) -302.035 (2.52975443e-06)
148403 EPS nconv=0 first unconverged value (error) -302.035 (2.08437569e-06)
148404 EPS nconv=0 first unconverged value (error) -302.035 (1.95430006e-06)
148405 EPS nconv=0 first unconverged value (error) -302.035 (1.95430006e-06)
148406 EPS nconv=0 first unconverged value (error) -302.035 (2.00573750e-06)
148407 EPS nconv=0 first unconverged value (error) -302.035 (2.05673751e-06)
148408 EPS nconv=0 first unconverged value (error) -302.035 (1.97936275e-06)
148409 EPS nconv=0 first unconverged value (error) -302.035 (1.88865324e-06)
148410 EPS nconv=0 first unconverged value (error) -302.035 (1.87400602e-06)
148411 EPS nconv=0 first unconverged value (error) -302.035 (1.87400602e-06)
148412 EPS nconv=0 first unconverged value (error) -302.035 (1.92074758e-06)
148413 EPS nconv=0 first unconverged value (error) -302.035 (1.94514477e-06)
148414 EPS nconv=0 first unconverged value (error) -302.035 (1.88444118e-06)
148415 EPS nconv=0 first unconverged value (error) -302.035 (1.83744217e-06)
148416 EPS nconv=0 first unconverged value (error) -302.035 (1.81918259e-06)
148417 EPS nconv=0 first unconverged value (error) -302.035 (1.81918259e-06)
148418 EPS nconv=0 first unconverged value (error) -302.035 (2.19079886e-06)
148419 EPS nconv=0 first unconverged value (error) -302.035 (2.08967586e-06)
148420 EPS nconv=0 first unconverged value (error) -302.035 (2.01663817e-06)
148421 EPS nconv=0 first unconverged value (error) -302.035 (1.99707731e-06)
148422 EPS nconv=0 first unconverged value (error) -302.035 (1.96793062e-06)
148423 EPS nconv=0 first unconverged value (error) -302.035 (1.96793062e-06)
148424 EPS nconv=0 first unconverged value (error) -302.035 (2.03086109e-06)
148425 EPS nconv=0 first unconverged value (error) -302.035 (2.08843803e-06)
148426 EPS nconv=0 first unconverged value (error) -302.035 (1.96051778e-06)
148427 EPS nconv=0 first unconverged value (error) -302.035 (1.91381040e-06)
148428 EPS nconv=0 first unconverged value (error) -302.035 (1.87676999e-06)
148429 EPS nconv=0 first unconverged value (error) -302.035 (1.87676999e-06)
148430 EPS nconv=0 first unconverged value (error) -302.035 (2.07776392e-06)
148431 EPS nconv=0 first unconverged value (error) -302.035 (2.05348197e-06)
148432 EPS nconv=0 first unconverged value (error) -302.035 (1.99319774e-06)
148433 EPS nconv=0 first unconverged value (error) -302.035 (1.93708062e-06)
148434 EPS nconv=0 first unconverged value (error) -302.035 (1.90041199e-06)
148435 EPS nconv=0 first unconverged value (error) -302.035 (1.90041199e-06)
148436 EPS nconv=0 first unconverged value (error) -302.035 (2.27141767e-06)
148437 EPS nconv=0 first unconverged value (error) -302.035 (2.15817219e-06)
148438 EPS nconv=0 first unconverged value (error) -302.035 (2.06985507e-06)
148439 EPS nconv=0 first unconverged value (error) -302.035 (2.00332994e-06)
148440 EPS nconv=0 first unconverged value (error) -302.035 (1.94447303e-06)
148441 EPS nconv=0 first unconverged value (error) -302.035 (1.94447303e-06)
148442 EPS nconv=0 first unconverged value (error) -302.035 (1.95677837e-06)
148443 EPS nconv=0 first unconverged value (error) -302.035 (2.06672843e-06)
148444 EPS nconv=0 first unconverged value (error) -302.035 (1.88630942e-06)
148445 EPS nconv=0 first unconverged value (error) -302.035 (1.86174182e-06)
148446 EPS nconv=0 first unconverged value (error) -302.035 (1.85098150e-06)
148447 EPS nconv=0 first unconverged value (error) -302.035 (1.85098150e-06)
148448 EPS nconv=0 first unconverged value (error) -302.035 (1.82382462e-06)
148449 EPS nconv=0 first unconverged value (error) -302.035 (1.82774947e-06)
148450 EPS nconv=0 first unconverged value (error) -302.035 (1.81781526e-06)
148451 EPS nconv=0 first unconverged value (error) -302.035 (1.80844946e-06)
148452 EPS nconv=0 first unconverged value (error) -302.035 (1.80323559e-06)
148453 EPS nconv=0 first unconverged value (error) -302.035 (1.80323559e-06)
148454 EPS nconv=0 first unconverged value (error) -302.035 (1.81088760e-06)
148455 EPS nconv=0 first unconverged value (error) -302.035 (1.80984700e-06)
148456 EPS nconv=0 first unconverged value (error) -302.035 (1.80470914e-06)
148457 EPS nconv=0 first unconverged value (error) -302.035 (1.80235307e-06)
148458 EPS nconv=0 first unconverged value (error) -302.035 (1.80099924e-06)
148459 EPS nconv=0 first unconverged value (error) -302.035 (1.80099924e-06)
148460 EPS nconv=0 first unconverged value (error) -302.035 (2.22364330e-06)
148461 EPS nconv=0 first unconverged value (error) -302.035 (2.05210164e-06)
148462 EPS nconv=0 first unconverged value (error) -302.035 (2.01917005e-06)
148463 EPS nconv=0 first unconverged value (error) -302.035 (1.99723877e-06)
148464 EPS nconv=0 first unconverged value (error) -302.035 (1.95792889e-06)
148465 EPS nconv=0 first unconverged value (error) -302.035 (1.95792889e-06)
148466 EPS nconv=0 first unconverged value (error) -302.035 (2.64237717e-06)
148467 EPS nconv=0 first unconverged value (error) -302.035 (2.58746499e-06)
148468 EPS nconv=0 first unconverged value (error) -302.035 (2.42200765e-06)
148469 EPS nconv=0 first unconverged value (error) -302.035 (2.42995281e-06)
148470 EPS nconv=0 first unconverged value (error) -302.035 (2.39746978e-06)
148471 EPS nconv=0 first unconverged value (error) -302.035 (2.39746978e-06)
148472 EPS nconv=0 first unconverged value (error) -302.035 (2.59983121e-06)
148473 EPS nconv=0 first unconverged value (error) -302.035 (2.34241294e-06)
148474 EPS nconv=0 first unconverged value (error) -302.035 (2.19043724e-06)
148475 EPS nconv=0 first unconverged value (error) -302.035 (2.04846258e-06)
148476 EPS nconv=0 first unconverged value (error) -302.035 (1.96127935e-06)
148477 EPS nconv=0 first unconverged value (error) -302.035 (1.96127935e-06)
148478 EPS nconv=0 first unconverged value (error) -302.035 (2.10677753e-06)
148479 EPS nconv=0 first unconverged value (error) -302.035 (2.08475142e-06)
148480 EPS nconv=0 first unconverged value (error) -302.035 (1.97882343e-06)
148481 EPS nconv=0 first unconverged value (error) -302.035 (1.87991996e-06)
148482 EPS nconv=0 first unconverged value (error) -302.035 (1.86215365e-06)
148483 EPS nconv=0 first unconverged value (error) -302.035 (1.86215365e-06)
148484 EPS nconv=0 first unconverged value (error) -302.035 (1.88363255e-06)
148485 EPS nconv=0 first unconverged value (error) -302.035 (1.91801317e-06)
148486 EPS nconv=0 first unconverged value (error) -302.035 (1.87193358e-06)
148487 EPS nconv=0 first unconverged value (error) -302.035 (1.83991467e-06)
148488 EPS nconv=0 first unconverged value (error) -302.035 (1.82183539e-06)
148489 EPS nconv=0 first unconverged value (error) -302.035 (1.82183539e-06)
148490 EPS nconv=0 first unconverged value (error) -302.035 (2.10530027e-06)
148491 EPS nconv=0 first unconverged value (error) -302.035 (2.05441141e-06)
148492 EPS nconv=0 first unconverged value (error) -302.035 (2.00819112e-06)
148493 EPS nconv=0 first unconverged value (error) -302.035 (1.98974012e-06)
148494 EPS nconv=0 first unconverged value (error) -302.035 (1.96025684e-06)
148495 EPS nconv=0 first unconverged value (error) -302.035 (1.96025684e-06)
148496 EPS nconv=0 first unconverged value (error) -302.035 (3.34158042e-06)
148497 EPS nconv=0 first unconverged value (error) -302.035 (2.93186038e-06)
148498 EPS nconv=0 first unconverged value (error) -302.035 (2.61625693e-06)
148499 EPS nconv=0 first unconverged value (error) -302.035 (2.56092219e-06)
148500 EPS nconv=0 first unconverged value (error) -302.035 (2.47693337e-06)
148501 EPS nconv=0 first unconverged value (error) -302.035 (2.47693337e-06)
148502 EPS nconv=0 first unconverged value (error) -302.035 (2.45073154e-06)
148503 EPS nconv=0 first unconverged value (error) -302.035 (2.83543213e-06)
148504 EPS nconv=0 first unconverged value (error) -302.035 (2.43971152e-06)
148505 EPS nconv=0 first unconverged value (error) -302.035 (2.03025399e-06)
148506 EPS nconv=0 first unconverged value (error) -302.035 (1.92157926e-06)
148507 EPS nconv=0 first unconverged value (error) -302.035 (1.92157926e-06)
148508 EPS nconv=0 first unconverged value (error) -302.035 (1.85235809e-06)
148509 EPS nconv=0 first unconverged value (error) -302.035 (1.85753372e-06)
148510 EPS nconv=0 first unconverged value (error) -302.035 (1.84563668e-06)
148511 EPS nconv=0 first unconverged value (error) -302.035 (1.82118653e-06)
148512 EPS nconv=0 first unconverged value (error) -302.035 (1.81388590e-06)
148513 EPS nconv=0 first unconverged value (error) -302.035 (1.81388590e-06)
148514 EPS nconv=0 first unconverged value (error) -302.035 (1.84023772e-06)
148515 EPS nconv=0 first unconverged value (error) -302.035 (1.83948373e-06)
148516 EPS nconv=0 first unconverged value (error) -302.035 (1.82514732e-06)
148517 EPS nconv=0 first unconverged value (error) -302.035 (1.81179489e-06)
148518 EPS nconv=0 first unconverged value (error) -302.035 (1.80710972e-06)
148519 EPS nconv=0 first unconverged value (error) -302.035 (1.80710972e-06)
148520 EPS nconv=0 first unconverged value (error) -302.035 (1.96712262e-06)
148521 EPS nconv=0 first unconverged value (error) -302.035 (1.91555516e-06)
148522 EPS nconv=0 first unconverged value (error) -302.035 (1.88485417e-06)
148523 EPS nconv=0 first unconverged value (error) -302.035 (1.87008628e-06)
148524 EPS nconv=0 first unconverged value (error) -302.035 (1.86116433e-06)
148525 EPS nconv=0 first unconverged value (error) -302.035 (1.86116433e-06)
148526 EPS nconv=0 first unconverged value (error) -302.035 (2.01642246e-06)
148527 EPS nconv=0 first unconverged value (error) -302.035 (2.03355558e-06)
148528 EPS nconv=0 first unconverged value (error) -302.035 (1.96034763e-06)
148529 EPS nconv=0 first unconverged value (error) -302.035 (1.87723248e-06)
148530 EPS nconv=0 first unconverged value (error) -302.035 (1.85999643e-06)
148531 EPS nconv=0 first unconverged value (error) -302.035 (1.85999643e-06)
148532 EPS nconv=0 first unconverged value (error) -302.035 (1.95328733e-06)
148533 EPS nconv=0 first unconverged value (error) -302.035 (1.95543814e-06)
148534 EPS nconv=0 first unconverged value (error) -302.035 (1.90247222e-06)
148535 EPS nconv=0 first unconverged value (error) -302.035 (1.87811974e-06)
148536 EPS nconv=0 first unconverged value (error) -302.035 (1.86538520e-06)
148537 EPS nconv=0 first unconverged value (error) -302.035 (1.86538520e-06)
148538 EPS nconv=0 first unconverged value (error) -302.035 (1.94988986e-06)
148539 EPS nconv=0 first unconverged value (error) -302.035 (1.91707096e-06)
148540 EPS nconv=0 first unconverged value (error) -302.035 (1.86551821e-06)
148541 EPS nconv=0 first unconverged value (error) -302.035 (1.86739815e-06)
148542 EPS nconv=0 first unconverged value (error) -302.035 (1.85384708e-06)
148543 EPS nconv=0 first unconverged value (error) -302.035 (1.85384708e-06)
148544 EPS nconv=0 first unconverged value (error) -302.035 (1.85438431e-06)
148545 EPS nconv=0 first unconverged value (error) -302.035 (1.87286843e-06)
148546 EPS nconv=0 first unconverged value (error) -302.035 (1.83665108e-06)
148547 EPS nconv=0 first unconverged value (error) -302.035 (1.81833623e-06)
148548 EPS nconv=0 first unconverged value (error) -302.035 (1.81352330e-06)
148549 EPS nconv=0 first unconverged value (error) -302.035 (1.81352330e-06)
148550 EPS nconv=0 first unconverged value (error) -302.035 (1.91318721e-06)
148551 EPS nconv=0 first unconverged value (error) -302.035 (1.87593347e-06)
148552 EPS nconv=0 first unconverged value (error) -302.035 (1.85715622e-06)
148553 EPS nconv=0 first unconverged value (error) -302.035 (1.85105136e-06)
148554 EPS nconv=0 first unconverged value (error) -302.035 (1.83821465e-06)
148555 EPS nconv=0 first unconverged value (error) -302.035 (1.83821465e-06)
148556 EPS nconv=0 first unconverged value (error) -302.035 (2.57151119e-06)
148557 EPS nconv=0 first unconverged value (error) -302.035 (2.45791775e-06)
148558 EPS nconv=0 first unconverged value (error) -302.035 (2.39686679e-06)
148559 EPS nconv=0 first unconverged value (error) -302.035 (2.26935562e-06)
148560 EPS nconv=0 first unconverged value (error) -302.035 (2.18099803e-06)
148561 EPS nconv=0 first unconverged value (error) -302.035 (2.18099803e-06)
148562 EPS nconv=0 first unconverged value (error) -302.035 (3.05269391e-06)
148563 EPS nconv=0 first unconverged value (error) -302.035 (2.74994654e-06)
148564 EPS nconv=0 first unconverged value (error) -302.035 (2.53294591e-06)
148565 EPS nconv=0 first unconverged value (error) -302.035 (2.46937783e-06)
148566 EPS nconv=0 first unconverged value (error) -302.035 (2.45454384e-06)
148567 EPS nconv=0 first unconverged value (error) -302.035 (2.45454384e-06)
148568 EPS nconv=0 first unconverged value (error) -302.035 (2.44440279e-06)
148569 EPS nconv=0 first unconverged value (error) -302.035 (2.40967191e-06)
148570 EPS nconv=0 first unconverged value (error) -302.035 (2.11621876e-06)
148571 EPS nconv=0 first unconverged value (error) -302.035 (2.11403863e-06)
148572 EPS nconv=0 first unconverged value (error) -302.035 (1.87989760e-06)
148573 EPS nconv=0 first unconverged value (error) -302.035 (1.87989760e-06)
148574 EPS nconv=0 first unconverged value (error) -302.035 (3.55345128e-06)
148575 EPS nconv=0 first unconverged value (error) -302.035 (3.52101193e-06)
148576 EPS nconv=0 first unconverged value (error) -302.035 (3.09829478e-06)
148577 EPS nconv=0 first unconverged value (error) -302.035 (2.89744295e-06)
148578 EPS nconv=0 first unconverged value (error) -302.035 (2.78878018e-06)
148579 EPS nconv=0 first unconverged value (error) -302.035 (2.78878018e-06)
148580 EPS nconv=0 first unconverged value (error) -302.035 (4.44536393e-06)
148581 EPS nconv=0 first unconverged value (error) -302.035 (3.95052986e-06)
148582 EPS nconv=0 first unconverged value (error) -302.035 (3.45721475e-06)
148583 EPS nconv=0 first unconverged value (error) -302.035 (3.48248153e-06)
148584 EPS nconv=0 first unconverged value (error) -302.035 (3.24575213e-06)
148585 EPS nconv=0 first unconverged value (error) -302.035 (3.24575213e-06)
148586 EPS nconv=0 first unconverged value (error) -302.035 (3.41264212e-06)
148587 EPS nconv=0 first unconverged value (error) -302.035 (3.52491642e-06)
148588 EPS nconv=0 first unconverged value (error) -302.035 (2.93350471e-06)
148589 EPS nconv=0 first unconverged value (error) -302.035 (2.42956000e-06)
148590 EPS nconv=0 first unconverged value (error) -302.035 (2.25875296e-06)
148591 EPS nconv=0 first unconverged value (error) -302.035 (2.25875296e-06)
148592 EPS nconv=0 first unconverged value (error) -302.035 (2.06437473e-06)
148593 EPS nconv=0 first unconverged value (error) -302.035 (2.00368500e-06)
148594 EPS nconv=0 first unconverged value (error) -302.035 (2.00147738e-06)
148595 EPS nconv=0 first unconverged value (error) -302.035 (1.86995536e-06)
148596 EPS nconv=0 first unconverged value (error) -302.035 (1.84002210e-06)
148597 EPS nconv=0 first unconverged value (error) -302.035 (1.84002210e-06)
148598 EPS nconv=0 first unconverged value (error) -302.035 (1.97532848e-06)
148599 EPS nconv=0 first unconverged value (error) -302.035 (1.89587308e-06)
148600 EPS nconv=0 first unconverged value (error) -302.035 (1.87706223e-06)
148601 EPS nconv=0 first unconverged value (error) -302.035 (1.86317816e-06)
148602 EPS nconv=0 first unconverged value (error) -302.035 (1.84718147e-06)
148603 EPS nconv=0 first unconverged value (error) -302.035 (1.84718147e-06)
148604 EPS nconv=0 first unconverged value (error) -302.035 (2.09539860e-06)
148605 EPS nconv=0 first unconverged value (error) -302.035 (2.16022917e-06)
148606 EPS nconv=0 first unconverged value (error) -302.035 (2.03070012e-06)
148607 EPS nconv=0 first unconverged value (error) -302.035 (1.94935207e-06)
148608 EPS nconv=0 first unconverged value (error) -302.035 (1.92787313e-06)
148609 EPS nconv=0 first unconverged value (error) -302.035 (1.92787313e-06)
148610 EPS nconv=0 first unconverged value (error) -302.035 (2.78764595e-06)
148611 EPS nconv=0 first unconverged value (error) -302.035 (2.60117576e-06)
148612 EPS nconv=0 first unconverged value (error) -302.035 (2.59044234e-06)
148613 EPS nconv=0 first unconverged value (error) -302.035 (2.37093139e-06)
148614 EPS nconv=0 first unconverged value (error) -302.035 (2.24444237e-06)
148615 EPS nconv=0 first unconverged value (error) -302.035 (2.24444237e-06)
148616 EPS nconv=0 first unconverged value (error) -302.035 (4.36845751e-06)
148617 EPS nconv=0 first unconverged value (error) -302.035 (3.89112607e-06)
148618 EPS nconv=0 first unconverged value (error) -302.035 (3.59030780e-06)
148619 EPS nconv=0 first unconverged value (error) -302.035 (3.51204284e-06)
148620 EPS nconv=0 first unconverged value (error) -302.035 (3.43618220e-06)
148621 EPS nconv=0 first unconverged value (error) -302.035 (3.43618220e-06)
148622 EPS nconv=0 first unconverged value (error) -302.035 (3.83391364e-06)
148623 EPS nconv=0 first unconverged value (error) -302.035 (3.37268839e-06)
148624 EPS nconv=0 first unconverged value (error) -302.035 (2.75960209e-06)
148625 EPS nconv=0 first unconverged value (error) -302.035 (2.82256727e-06)
148626 EPS nconv=0 first unconverged value (error) -302.035 (2.42977735e-06)
148627 EPS nconv=0 first unconverged value (error) -302.035 (2.42977735e-06)
148628 EPS nconv=0 first unconverged value (error) -302.035 (2.41798366e-06)
148629 EPS nconv=0 first unconverged value (error) -302.035 (2.45182241e-06)
148630 EPS nconv=0 first unconverged value (error) -302.035 (2.17296171e-06)
148631 EPS nconv=0 first unconverged value (error) -302.035 (1.95698767e-06)
148632 EPS nconv=0 first unconverged value (error) -302.035 (1.91066940e-06)
148633 EPS nconv=0 first unconverged value (error) -302.035 (1.91066940e-06)
148634 EPS nconv=0 first unconverged value (error) -302.035 (2.13549587e-06)
148635 EPS nconv=0 first unconverged value (error) -302.035 (2.10181342e-06)
148636 EPS nconv=0 first unconverged value (error) -302.035 (2.05235304e-06)
148637 EPS nconv=0 first unconverged value (error) -302.035 (1.98170740e-06)
148638 EPS nconv=0 first unconverged value (error) -302.035 (1.95244392e-06)
148639 EPS nconv=0 first unconverged value (error) -302.035 (1.95244392e-06)
148640 EPS nconv=0 first unconverged value (error) -302.035 (1.95699109e-06)
148641 EPS nconv=0 first unconverged value (error) -302.035 (1.97814630e-06)
148642 EPS nconv=0 first unconverged value (error) -302.035 (1.85712653e-06)
148643 EPS nconv=0 first unconverged value (error) -302.035 (1.82904630e-06)
148644 EPS nconv=0 first unconverged value (error) -302.035 (1.82110534e-06)
148645 EPS nconv=0 first unconverged value (error) -302.035 (1.82110534e-06)
148646 EPS nconv=0 first unconverged value (error) -302.035 (1.80907907e-06)
148647 EPS nconv=0 first unconverged value (error) -302.035 (1.81097865e-06)
148648 EPS nconv=0 first unconverged value (error) -302.035 (1.80291569e-06)
148649 EPS nconv=0 first unconverged value (error) -302.035 (1.80126290e-06)
148650 EPS nconv=0 first unconverged value (error) -302.035 (1.79973807e-06)
148651 EPS nconv=0 first unconverged value (error) -302.035 (1.79973807e-06)
148652 EPS nconv=0 first unconverged value (error) -302.035 (1.92224347e-06)
148653 EPS nconv=0 first unconverged value (error) -302.035 (1.88287177e-06)
148654 EPS nconv=0 first unconverged value (error) -302.035 (1.85647622e-06)
148655 EPS nconv=0 first unconverged value (error) -302.035 (1.85066774e-06)
148656 EPS nconv=0 first unconverged value (error) -302.035 (1.83888003e-06)
148657 EPS nconv=0 first unconverged value (error) -302.035 (1.83888003e-06)
148658 EPS nconv=0 first unconverged value (error) -302.035 (2.05582237e-06)
148659 EPS nconv=0 first unconverged value (error) -302.035 (2.04921567e-06)
148660 EPS nconv=0 first unconverged value (error) -302.035 (1.97506146e-06)
148661 EPS nconv=0 first unconverged value (error) -302.035 (1.92424457e-06)
148662 EPS nconv=0 first unconverged value (error) -302.035 (1.91028725e-06)
148663 EPS nconv=0 first unconverged value (error) -302.035 (1.91028725e-06)
148664 EPS nconv=0 first unconverged value (error) -302.035 (1.94511317e-06)
148665 EPS nconv=0 first unconverged value (error) -302.035 (1.93748671e-06)
148666 EPS nconv=0 first unconverged value (error) -302.035 (1.87573802e-06)
148667 EPS nconv=0 first unconverged value (error) -302.035 (1.84469813e-06)
148668 EPS nconv=0 first unconverged value (error) -302.035 (1.83818414e-06)
148669 EPS nconv=0 first unconverged value (error) -302.035 (1.83818414e-06)
148670 EPS nconv=0 first unconverged value (error) -302.035 (1.83432601e-06)
148671 EPS nconv=0 first unconverged value (error) -302.035 (1.84046988e-06)
148672 EPS nconv=0 first unconverged value (error) -302.035 (1.81791085e-06)
148673 EPS nconv=0 first unconverged value (error) -302.035 (1.81157855e-06)
148674 EPS nconv=0 first unconverged value (error) -302.035 (1.80722510e-06)
148675 EPS nconv=0 first unconverged value (error) -302.035 (1.80722510e-06)
148676 EPS nconv=0 first unconverged value (error) -302.035 (1.85495794e-06)
148677 EPS nconv=0 first unconverged value (error) -302.035 (1.83701819e-06)
148678 EPS nconv=0 first unconverged value (error) -302.035 (1.82064101e-06)
148679 EPS nconv=0 first unconverged value (error) -302.035 (1.81685683e-06)
148680 EPS nconv=0 first unconverged value (error) -302.035 (1.81197997e-06)
148681 EPS nconv=0 first unconverged value (error) -302.035 (1.81197997e-06)
148682 EPS nconv=0 first unconverged value (error) -302.035 (2.10273169e-06)
148683 EPS nconv=0 first unconverged value (error) -302.035 (2.01249638e-06)
148684 EPS nconv=0 first unconverged value (error) -302.035 (1.97204841e-06)
148685 EPS nconv=0 first unconverged value (error) -302.035 (1.94964124e-06)
148686 EPS nconv=0 first unconverged value (error) -302.035 (1.92240734e-06)
148687 EPS nconv=0 first unconverged value (error) -302.035 (1.92240734e-06)
148688 EPS nconv=0 first unconverged value (error) -302.035 (2.63063192e-06)
148689 EPS nconv=0 first unconverged value (error) -302.035 (2.44675458e-06)
148690 EPS nconv=0 first unconverged value (error) -302.035 (2.28008533e-06)
148691 EPS nconv=0 first unconverged value (error) -302.035 (2.22825829e-06)
148692 EPS nconv=0 first unconverged value (error) -302.035 (2.15503459e-06)
148693 EPS nconv=0 first unconverged value (error) -302.035 (2.15503459e-06)
148694 EPS nconv=0 first unconverged value (error) -302.035 (2.12206246e-06)
148695 EPS nconv=0 first unconverged value (error) -302.035 (2.26829929e-06)
148696 EPS nconv=0 first unconverged value (error) -302.035 (2.01167970e-06)
148697 EPS nconv=0 first unconverged value (error) -302.035 (1.98654287e-06)
148698 EPS nconv=0 first unconverged value (error) -302.035 (1.84881064e-06)
148699 EPS nconv=0 first unconverged value (error) -302.035 (1.84881064e-06)
148700 EPS nconv=0 first unconverged value (error) -302.035 (1.85538568e-06)
148701 EPS nconv=0 first unconverged value (error) -302.035 (1.85682390e-06)
148702 EPS nconv=0 first unconverged value (error) -302.035 (1.83900609e-06)
148703 EPS nconv=0 first unconverged value (error) -302.035 (1.83243740e-06)
148704 EPS nconv=0 first unconverged value (error) -302.035 (1.82484937e-06)
148705 EPS nconv=0 first unconverged value (error) -302.035 (1.82484937e-06)
148706 EPS nconv=0 first unconverged value (error) -302.035 (2.31209848e-06)
148707 EPS nconv=0 first unconverged value (error) -302.035 (2.13176802e-06)
148708 EPS nconv=0 first unconverged value (error) -302.035 (2.07510897e-06)
148709 EPS nconv=0 first unconverged value (error) -302.035 (2.05591110e-06)
148710 EPS nconv=0 first unconverged value (error) -302.035 (2.00445477e-06)
148711 EPS nconv=0 first unconverged value (error) -302.035 (2.00445477e-06)
148712 EPS nconv=0 first unconverged value (error) -302.035 (2.09940205e-06)
148713 EPS nconv=0 first unconverged value (error) -302.035 (2.17612228e-06)
148714 EPS nconv=0 first unconverged value (error) -302.035 (1.96232243e-06)
148715 EPS nconv=0 first unconverged value (error) -302.035 (1.95542888e-06)
148716 EPS nconv=0 first unconverged value (error) -302.035 (1.90093853e-06)
148717 EPS nconv=0 first unconverged value (error) -302.035 (1.90093853e-06)
148718 EPS nconv=0 first unconverged value (error) -302.035 (3.11388410e-06)
148719 EPS nconv=0 first unconverged value (error) -302.035 (2.80916974e-06)
148720 EPS nconv=0 first unconverged value (error) -302.035 (2.62033921e-06)
148721 EPS nconv=0 first unconverged value (error) -302.035 (2.52933532e-06)
148722 EPS nconv=0 first unconverged value (error) -302.035 (2.38500363e-06)
148723 EPS nconv=0 first unconverged value (error) -302.035 (2.38500363e-06)
148724 EPS nconv=0 first unconverged value (error) -302.035 (2.42103550e-06)
148725 EPS nconv=0 first unconverged value (error) -302.035 (2.80415654e-06)
148726 EPS nconv=0 first unconverged value (error) -302.035 (2.48095963e-06)
148727 EPS nconv=0 first unconverged value (error) -302.035 (1.96567677e-06)
148728 EPS nconv=0 first unconverged value (error) -302.035 (1.87906076e-06)
148729 EPS nconv=0 first unconverged value (error) -302.035 (1.87906076e-06)
148730 EPS nconv=0 first unconverged value (error) -302.035 (2.12359183e-06)
148731 EPS nconv=0 first unconverged value (error) -302.035 (2.01097424e-06)
148732 EPS nconv=0 first unconverged value (error) -302.035 (1.95940863e-06)
148733 EPS nconv=0 first unconverged value (error) -302.035 (1.94398461e-06)
148734 EPS nconv=0 first unconverged value (error) -302.035 (1.93054811e-06)
148735 EPS nconv=0 first unconverged value (error) -302.035 (1.93054811e-06)
148736 EPS nconv=0 first unconverged value (error) -302.035 (3.25225465e-06)
148737 EPS nconv=0 first unconverged value (error) -302.035 (2.86170510e-06)
148738 EPS nconv=0 first unconverged value (error) -302.035 (2.47003602e-06)
148739 EPS nconv=0 first unconverged value (error) -302.035 (2.38824967e-06)
148740 EPS nconv=0 first unconverged value (error) -302.035 (2.33648730e-06)
148741 EPS nconv=0 first unconverged value (error) -302.035 (2.33648730e-06)
148742 EPS nconv=0 first unconverged value (error) -302.035 (2.94660103e-06)
148743 EPS nconv=0 first unconverged value (error) -302.035 (3.42085754e-06)
148744 EPS nconv=0 first unconverged value (error) -302.035 (2.95515379e-06)
148745 EPS nconv=0 first unconverged value (error) -302.035 (2.30316902e-06)
148746 EPS nconv=0 first unconverged value (error) -302.035 (2.17652370e-06)
148747 EPS nconv=0 first unconverged value (error) -302.035 (2.17652370e-06)
148748 EPS nconv=0 first unconverged value (error) -302.035 (2.15254360e-06)
148749 EPS nconv=0 first unconverged value (error) -302.035 (2.19508677e-06)
148750 EPS nconv=0 first unconverged value (error) -302.035 (2.08592447e-06)
148751 EPS nconv=0 first unconverged value (error) -302.035 (1.90272642e-06)
148752 EPS nconv=0 first unconverged value (error) -302.035 (1.86451417e-06)
148753 EPS nconv=0 first unconverged value (error) -302.035 (1.86451417e-06)
148754 EPS nconv=0 first unconverged value (error) -302.035 (1.94787236e-06)
148755 EPS nconv=0 first unconverged value (error) -302.035 (1.86158486e-06)
148756 EPS nconv=0 first unconverged value (error) -302.035 (1.83680916e-06)
148757 EPS nconv=0 first unconverged value (error) -302.035 (1.82935373e-06)
148758 EPS nconv=0 first unconverged value (error) -302.035 (1.82442177e-06)
148759 EPS nconv=0 first unconverged value (error) -302.035 (1.82442177e-06)
148760 EPS nconv=0 first unconverged value (error) -302.035 (2.30271104e-06)
148761 EPS nconv=0 first unconverged value (error) -302.035 (2.21402959e-06)
148762 EPS nconv=0 first unconverged value (error) -302.035 (2.11380508e-06)
148763 EPS nconv=0 first unconverged value (error) -302.035 (2.05386242e-06)
148764 EPS nconv=0 first unconverged value (error) -302.035 (2.02408089e-06)
148765 EPS nconv=0 first unconverged value (error) -302.035 (2.02408089e-06)
148766 EPS nconv=0 first unconverged value (error) -302.035 (2.04307881e-06)
148767 EPS nconv=0 first unconverged value (error) -302.035 (2.11717857e-06)
148768 EPS nconv=0 first unconverged value (error) -302.035 (2.02091957e-06)
148769 EPS nconv=0 first unconverged value (error) -302.035 (1.86005496e-06)
148770 EPS nconv=0 first unconverged value (error) -302.035 (1.83521217e-06)
148771 EPS nconv=0 first unconverged value (error) -302.035 (1.83521217e-06)
148772 EPS nconv=0 first unconverged value (error) -302.035 (2.02367821e-06)
148773 EPS nconv=0 first unconverged value (error) -302.035 (1.96879854e-06)
148774 EPS nconv=0 first unconverged value (error) -302.035 (1.93718448e-06)
148775 EPS nconv=0 first unconverged value (error) -302.035 (1.90467815e-06)
148776 EPS nconv=0 first unconverged value (error) -302.035 (1.89386396e-06)
148777 EPS nconv=0 first unconverged value (error) -302.035 (1.89386396e-06)
148778 EPS nconv=0 first unconverged value (error) -302.035 (2.08627702e-06)
148779 EPS nconv=0 first unconverged value (error) -302.035 (2.05195095e-06)
148780 EPS nconv=0 first unconverged value (error) -302.035 (1.95596802e-06)
148781 EPS nconv=0 first unconverged value (error) -302.035 (1.95153594e-06)
148782 EPS nconv=0 first unconverged value (error) -302.035 (1.89919175e-06)
148783 EPS nconv=0 first unconverged value (error) -302.035 (1.89919175e-06)
148784 EPS nconv=0 first unconverged value (error) -302.035 (2.52075409e-06)
148785 EPS nconv=0 first unconverged value (error) -302.035 (2.52209873e-06)
148786 EPS nconv=0 first unconverged value (error) -302.035 (2.33432066e-06)
148787 EPS nconv=0 first unconverged value (error) -302.035 (2.20984325e-06)
148788 EPS nconv=0 first unconverged value (error) -302.035 (2.12011283e-06)
148789 EPS nconv=0 first unconverged value (error) -302.035 (2.12011283e-06)
148790 EPS nconv=0 first unconverged value (error) -302.035 (2.16553490e-06)
148791 EPS nconv=0 first unconverged value (error) -302.035 (2.23547702e-06)
148792 EPS nconv=0 first unconverged value (error) -302.035 (2.14059623e-06)
148793 EPS nconv=0 first unconverged value (error) -302.035 (1.98221552e-06)
148794 EPS nconv=0 first unconverged value (error) -302.035 (1.91885295e-06)
148795 EPS nconv=0 first unconverged value (error) -302.035 (1.91885295e-06)
148796 EPS nconv=0 first unconverged value (error) -302.035 (1.86338898e-06)
148797 EPS nconv=0 first unconverged value (error) -302.035 (1.86683103e-06)
148798 EPS nconv=0 first unconverged value (error) -302.035 (1.84539957e-06)
148799 EPS nconv=0 first unconverged value (error) -302.035 (1.82119543e-06)
148800 EPS nconv=0 first unconverged value (error) -302.035 (1.81424888e-06)
148801 EPS nconv=0 first unconverged value (error) -302.035 (1.81424888e-06)
148802 EPS nconv=0 first unconverged value (error) -302.035 (1.82111289e-06)
148803 EPS nconv=0 first unconverged value (error) -302.035 (1.82519209e-06)
148804 EPS nconv=0 first unconverged value (error) -302.035 (1.81305234e-06)
148805 EPS nconv=0 first unconverged value (error) -302.035 (1.80876465e-06)
148806 EPS nconv=0 first unconverged value (error) -302.035 (1.80507720e-06)
148807 EPS nconv=0 first unconverged value (error) -302.035 (1.80507720e-06)
148808 EPS nconv=0 first unconverged value (error) -302.035 (2.55156684e-06)
148809 EPS nconv=0 first unconverged value (error) -302.035 (2.40954914e-06)
148810 EPS nconv=0 first unconverged value (error) -302.035 (2.27193438e-06)
148811 EPS nconv=0 first unconverged value (error) -302.035 (2.20566325e-06)
148812 EPS nconv=0 first unconverged value (error) -302.035 (2.11900330e-06)
148813 EPS nconv=0 first unconverged value (error) -302.035 (2.11900330e-06)
148814 EPS nconv=0 first unconverged value (error) -302.035 (2.25094155e-06)
148815 EPS nconv=0 first unconverged value (error) -302.035 (2.39563193e-06)
148816 EPS nconv=0 first unconverged value (error) -302.035 (2.22922742e-06)
148817 EPS nconv=0 first unconverged value (error) -302.035 (1.97320000e-06)
148818 EPS nconv=0 first unconverged value (error) -302.035 (1.93894699e-06)
148819 EPS nconv=0 first unconverged value (error) -302.035 (1.93894699e-06)
148820 EPS nconv=0 first unconverged value (error) -302.035 (1.88023392e-06)
148821 EPS nconv=0 first unconverged value (error) -302.035 (1.88654608e-06)
148822 EPS nconv=0 first unconverged value (error) -302.035 (1.85056215e-06)
148823 EPS nconv=0 first unconverged value (error) -302.035 (1.81733139e-06)
148824 EPS nconv=0 first unconverged value (error) -302.035 (1.81271175e-06)
148825 EPS nconv=0 first unconverged value (error) -302.035 (1.81271175e-06)
148826 EPS nconv=0 first unconverged value (error) -302.035 (1.80942111e-06)
148827 EPS nconv=0 first unconverged value (error) -302.035 (1.81223169e-06)
148828 EPS nconv=0 first unconverged value (error) -302.035 (1.80189301e-06)
148829 EPS nconv=0 first unconverged value (error) -302.035 (1.79932459e-06)
148830 EPS nconv=0 first unconverged value (error) -302.035 (1.79821725e-06)
148831 EPS nconv=0 first unconverged value (error) -302.035 (1.79821725e-06)
148832 EPS nconv=0 first unconverged value (error) -302.035 (2.44717424e-06)
148833 EPS nconv=0 first unconverged value (error) -302.035 (2.23856807e-06)
148834 EPS nconv=0 first unconverged value (error) -302.035 (2.12388218e-06)
148835 EPS nconv=0 first unconverged value (error) -302.035 (2.09386576e-06)
148836 EPS nconv=0 first unconverged value (error) -302.035 (2.03270581e-06)
148837 EPS nconv=0 first unconverged value (error) -302.035 (2.03270581e-06)
148838 EPS nconv=0 first unconverged value (error) -302.035 (2.50528080e-06)
148839 EPS nconv=0 first unconverged value (error) -302.035 (2.77294695e-06)
148840 EPS nconv=0 first unconverged value (error) -302.035 (2.43300160e-06)
148841 EPS nconv=0 first unconverged value (error) -302.035 (2.13797546e-06)
148842 EPS nconv=0 first unconverged value (error) -302.035 (2.09405435e-06)
148843 EPS nconv=0 first unconverged value (error) -302.035 (2.09405435e-06)
148844 EPS nconv=0 first unconverged value (error) -302.035 (2.05478635e-06)
148845 EPS nconv=0 first unconverged value (error) -302.035 (2.03056313e-06)
148846 EPS nconv=0 first unconverged value (error) -302.035 (1.99416200e-06)
148847 EPS nconv=0 first unconverged value (error) -302.035 (1.86647435e-06)
148848 EPS nconv=0 first unconverged value (error) -302.035 (1.84154321e-06)
148849 EPS nconv=0 first unconverged value (error) -302.035 (1.84154321e-06)
148850 EPS nconv=0 first unconverged value (error) -302.035 (1.85268814e-06)
148851 EPS nconv=0 first unconverged value (error) -302.035 (1.82824436e-06)
148852 EPS nconv=0 first unconverged value (error) -302.035 (1.81533253e-06)
148853 EPS nconv=0 first unconverged value (error) -302.035 (1.80931075e-06)
148854 EPS nconv=0 first unconverged value (error) -302.035 (1.80772837e-06)
148855 EPS nconv=0 first unconverged value (error) -302.035 (1.80772837e-06)
148856 EPS nconv=0 first unconverged value (error) -302.035 (1.89167183e-06)
148857 EPS nconv=0 first unconverged value (error) -302.035 (1.85540770e-06)
148858 EPS nconv=0 first unconverged value (error) -302.035 (1.83353556e-06)
148859 EPS nconv=0 first unconverged value (error) -302.035 (1.83077214e-06)
148860 EPS nconv=0 first unconverged value (error) -302.035 (1.82399351e-06)
148861 EPS nconv=0 first unconverged value (error) -302.035 (1.82399351e-06)
148862 EPS nconv=0 first unconverged value (error) -302.035 (1.82173850e-06)
148863 EPS nconv=0 first unconverged value (error) -302.035 (1.85672443e-06)
148864 EPS nconv=0 first unconverged value (error) -302.035 (1.82067421e-06)
148865 EPS nconv=0 first unconverged value (error) -302.035 (1.80533810e-06)
148866 EPS nconv=0 first unconverged value (error) -302.035 (1.80208837e-06)
148867 EPS nconv=0 first unconverged value (error) -302.035 (1.80208837e-06)
148868 EPS nconv=0 first unconverged value (error) -302.035 (1.95233606e-06)
148869 EPS nconv=0 first unconverged value (error) -302.035 (1.89319502e-06)
148870 EPS nconv=0 first unconverged value (error) -302.035 (1.88051516e-06)
148871 EPS nconv=0 first unconverged value (error) -302.035 (1.87549018e-06)
148872 EPS nconv=0 first unconverged value (error) -302.035 (1.85549219e-06)
148873 EPS nconv=0 first unconverged value (error) -302.035 (1.85549219e-06)
148874 EPS nconv=0 first unconverged value (error) -302.035 (2.25306638e-06)
148875 EPS nconv=0 first unconverged value (error) -302.035 (2.12126822e-06)
148876 EPS nconv=0 first unconverged value (error) -302.035 (2.01931226e-06)
148877 EPS nconv=0 first unconverged value (error) -302.035 (2.01600181e-06)
148878 EPS nconv=0 first unconverged value (error) -302.035 (1.99955348e-06)
148879 EPS nconv=0 first unconverged value (error) -302.035 (1.99955348e-06)
148880 EPS nconv=0 first unconverged value (error) -302.035 (2.23516082e-06)
148881 EPS nconv=0 first unconverged value (error) -302.035 (2.19837383e-06)
148882 EPS nconv=0 first unconverged value (error) -302.035 (2.02671499e-06)
148883 EPS nconv=0 first unconverged value (error) -302.035 (1.97100765e-06)
148884 EPS nconv=0 first unconverged value (error) -302.035 (1.95506916e-06)
148885 EPS nconv=0 first unconverged value (error) -302.035 (1.95506916e-06)
148886 EPS nconv=0 first unconverged value (error) -302.035 (2.03293143e-06)
148887 EPS nconv=0 first unconverged value (error) -302.035 (2.11739968e-06)
148888 EPS nconv=0 first unconverged value (error) -302.035 (1.97772643e-06)
148889 EPS nconv=0 first unconverged value (error) -302.035 (1.86938287e-06)
148890 EPS nconv=0 first unconverged value (error) -302.035 (1.84837299e-06)
148891 EPS nconv=0 first unconverged value (error) -302.035 (1.84837299e-06)
148892 EPS nconv=0 first unconverged value (error) -302.035 (1.92029161e-06)
148893 EPS nconv=0 first unconverged value (error) -302.035 (1.93006617e-06)
148894 EPS nconv=0 first unconverged value (error) -302.035 (1.87027949e-06)
148895 EPS nconv=0 first unconverged value (error) -302.035 (1.84255622e-06)
148896 EPS nconv=0 first unconverged value (error) -302.035 (1.82801411e-06)
148897 EPS nconv=0 first unconverged value (error) -302.035 (1.82801411e-06)
148898 EPS nconv=0 first unconverged value (error) -302.035 (1.82390735e-06)
148899 EPS nconv=0 first unconverged value (error) -302.035 (1.83556762e-06)
148900 EPS nconv=0 first unconverged value (error) -302.035 (1.81019456e-06)
148901 EPS nconv=0 first unconverged value (error) -302.035 (1.80266422e-06)
148902 EPS nconv=0 first unconverged value (error) -302.035 (1.80140074e-06)
148903 EPS nconv=0 first unconverged value (error) -302.035 (1.80140074e-06)
148904 EPS nconv=0 first unconverged value (error) -302.035 (1.79536873e-06)
148905 EPS nconv=0 first unconverged value (error) -302.035 (1.79503214e-06)
148906 EPS nconv=0 first unconverged value (error) -302.035 (1.79484634e-06)
148907 EPS nconv=0 first unconverged value (error) -302.035 (1.79477405e-06)
148908 EPS nconv=0 first unconverged value (error) -302.035 (1.79472983e-06)
148909 EPS nconv=0 first unconverged value (error) -302.035 (1.79472983e-06)
148910 EPS nconv=0 first unconverged value (error) -302.035 (1.85531516e-06)
148911 EPS nconv=0 first unconverged value (error) -302.035 (1.82837025e-06)
148912 EPS nconv=0 first unconverged value (error) -302.035 (1.82139113e-06)
148913 EPS nconv=0 first unconverged value (error) -302.035 (1.81854584e-06)
148914 EPS nconv=0 first unconverged value (error) -302.035 (1.81352115e-06)
148915 EPS nconv=0 first unconverged value (error) -302.035 (1.81352115e-06)
148916 EPS nconv=0 first unconverged value (error) -302.035 (2.04972133e-06)
148917 EPS nconv=0 first unconverged value (error) -302.035 (1.98786138e-06)
148918 EPS nconv=0 first unconverged value (error) -302.035 (1.95982627e-06)
148919 EPS nconv=0 first unconverged value (error) -302.035 (1.95240275e-06)
148920 EPS nconv=0 first unconverged value (error) -302.035 (1.94803526e-06)
148921 EPS nconv=0 first unconverged value (error) -302.035 (1.94803526e-06)
148922 EPS nconv=0 first unconverged value (error) -302.035 (2.33773723e-06)
148923 EPS nconv=0 first unconverged value (error) -302.035 (2.12699656e-06)
148924 EPS nconv=0 first unconverged value (error) -302.035 (2.01419418e-06)
148925 EPS nconv=0 first unconverged value (error) -302.035 (2.01579273e-06)
148926 EPS nconv=0 first unconverged value (error) -302.035 (1.99719375e-06)
148927 EPS nconv=0 first unconverged value (error) -302.035 (1.99719375e-06)
148928 EPS nconv=0 first unconverged value (error) -302.035 (1.98836158e-06)
148929 EPS nconv=0 first unconverged value (error) -302.035 (2.10360295e-06)
148930 EPS nconv=0 first unconverged value (error) -302.035 (1.90492337e-06)
148931 EPS nconv=0 first unconverged value (error) -302.035 (1.83713756e-06)
148932 EPS nconv=0 first unconverged value (error) -302.035 (1.81553038e-06)
148933 EPS nconv=0 first unconverged value (error) -302.035 (1.81553038e-06)
148934 EPS nconv=0 first unconverged value (error) -302.035 (2.40910783e-06)
148935 EPS nconv=0 first unconverged value (error) -302.035 (2.22307805e-06)
148936 EPS nconv=0 first unconverged value (error) -302.035 (2.14170560e-06)
148937 EPS nconv=0 first unconverged value (error) -302.035 (2.09872056e-06)
148938 EPS nconv=0 first unconverged value (error) -302.035 (2.06589283e-06)
148939 EPS nconv=0 first unconverged value (error) -302.035 (2.06589283e-06)
148940 EPS nconv=0 first unconverged value (error) -302.035 (3.11484328e-06)
148941 EPS nconv=0 first unconverged value (error) -302.035 (2.93960419e-06)
148942 EPS nconv=0 first unconverged value (error) -302.035 (2.59714802e-06)
148943 EPS nconv=0 first unconverged value (error) -302.035 (2.57326828e-06)
148944 EPS nconv=0 first unconverged value (error) -302.035 (2.58301718e-06)
148945 EPS nconv=0 first unconverged value (error) -302.035 (2.58301718e-06)
148946 EPS nconv=0 first unconverged value (error) -302.035 (2.54587889e-06)
148947 EPS nconv=0 first unconverged value (error) -302.035 (2.48203987e-06)
148948 EPS nconv=0 first unconverged value (error) -302.035 (2.24896949e-06)
148949 EPS nconv=0 first unconverged value (error) -302.035 (1.96138444e-06)
148950 EPS nconv=0 first unconverged value (error) -302.035 (1.83192877e-06)
148951 EPS nconv=0 first unconverged value (error) -302.035 (1.83192877e-06)
148952 EPS nconv=0 first unconverged value (error) -302.035 (2.22079828e-06)
148953 EPS nconv=0 first unconverged value (error) -302.035 (2.17113869e-06)
148954 EPS nconv=0 first unconverged value (error) -302.035 (2.04978943e-06)
148955 EPS nconv=0 first unconverged value (error) -302.035 (2.02901651e-06)
148956 EPS nconv=0 first unconverged value (error) -302.035 (2.01758767e-06)
148957 EPS nconv=0 first unconverged value (error) -302.035 (2.01758767e-06)
148958 EPS nconv=0 first unconverged value (error) -302.035 (2.08856168e-06)
148959 EPS nconv=0 first unconverged value (error) -302.035 (2.12103737e-06)
148960 EPS nconv=0 first unconverged value (error) -302.035 (1.96085829e-06)
148961 EPS nconv=0 first unconverged value (error) -302.035 (1.88000101e-06)
148962 EPS nconv=0 first unconverged value (error) -302.035 (1.85800910e-06)
148963 EPS nconv=0 first unconverged value (error) -302.035 (1.85800910e-06)
148964 EPS nconv=0 first unconverged value (error) -302.035 (2.17143132e-06)
148965 EPS nconv=0 first unconverged value (error) -302.035 (2.03674896e-06)
148966 EPS nconv=0 first unconverged value (error) -302.035 (1.96541313e-06)
148967 EPS nconv=0 first unconverged value (error) -302.035 (1.95282259e-06)
148968 EPS nconv=0 first unconverged value (error) -302.035 (1.93445213e-06)
148969 EPS nconv=0 first unconverged value (error) -302.035 (1.93445213e-06)
148970 EPS nconv=0 first unconverged value (error) -302.035 (2.03706471e-06)
148971 EPS nconv=0 first unconverged value (error) -302.035 (2.02572096e-06)
148972 EPS nconv=0 first unconverged value (error) -302.035 (1.89944960e-06)
148973 EPS nconv=0 first unconverged value (error) -302.035 (1.87788558e-06)
148974 EPS nconv=0 first unconverged value (error) -302.035 (1.87072284e-06)
148975 EPS nconv=0 first unconverged value (error) -302.035 (1.87072284e-06)
148976 EPS nconv=0 first unconverged value (error) -302.035 (1.96256896e-06)
148977 EPS nconv=0 first unconverged value (error) -302.035 (1.96738303e-06)
148978 EPS nconv=0 first unconverged value (error) -302.035 (1.90608280e-06)
148979 EPS nconv=0 first unconverged value (error) -302.035 (1.85421224e-06)
148980 EPS nconv=0 first unconverged value (error) -302.035 (1.84079746e-06)
148981 EPS nconv=0 first unconverged value (error) -302.035 (1.84079746e-06)
148982 EPS nconv=0 first unconverged value (error) -302.035 (1.89076790e-06)
148983 EPS nconv=0 first unconverged value (error) -302.035 (1.90421857e-06)
148984 EPS nconv=0 first unconverged value (error) -302.035 (1.86175157e-06)
148985 EPS nconv=0 first unconverged value (error) -302.035 (1.83645931e-06)
148986 EPS nconv=0 first unconverged value (error) -302.035 (1.82757028e-06)
148987 EPS nconv=0 first unconverged value (error) -302.035 (1.82757028e-06)
148988 EPS nconv=0 first unconverged value (error) -302.035 (1.88116687e-06)
148989 EPS nconv=0 first unconverged value (error) -302.035 (1.88595607e-06)
148990 EPS nconv=0 first unconverged value (error) -302.035 (1.85608592e-06)
148991 EPS nconv=0 first unconverged value (error) -302.035 (1.83152753e-06)
148992 EPS nconv=0 first unconverged value (error) -302.035 (1.82171927e-06)
148993 EPS nconv=0 first unconverged value (error) -302.035 (1.82171927e-06)
148994 EPS nconv=0 first unconverged value (error) -302.035 (1.91370831e-06)
148995 EPS nconv=0 first unconverged value (error) -302.035 (1.90740453e-06)
148996 EPS nconv=0 first unconverged value (error) -302.035 (1.87116401e-06)
148997 EPS nconv=0 first unconverged value (error) -302.035 (1.84787188e-06)
148998 EPS nconv=0 first unconverged value (error) -302.035 (1.84466050e-06)
148999 EPS nconv=0 first unconverged value (error) -302.035 (1.84466050e-06)
149000 EPS nconv=0 first unconverged value (error) -302.035 (1.85646727e-06)
149001 EPS nconv=0 first unconverged value (error) -302.035 (1.85812106e-06)
149002 EPS nconv=0 first unconverged value (error) -302.035 (1.82476826e-06)
149003 EPS nconv=0 first unconverged value (error) -302.035 (1.81761352e-06)
149004 EPS nconv=0 first unconverged value (error) -302.035 (1.81120679e-06)
149005 EPS nconv=0 first unconverged value (error) -302.035 (1.81120679e-06)
149006 EPS nconv=0 first unconverged value (error) -302.035 (1.92162716e-06)
149007 EPS nconv=0 first unconverged value (error) -302.035 (1.89515335e-06)
149008 EPS nconv=0 first unconverged value (error) -302.035 (1.86568103e-06)
149009 EPS nconv=0 first unconverged value (error) -302.035 (1.85957236e-06)
149010 EPS nconv=0 first unconverged value (error) -302.035 (1.84920266e-06)
149011 EPS nconv=0 first unconverged value (error) -302.035 (1.84920266e-06)
149012 EPS nconv=0 first unconverged value (error) -302.035 (1.88650344e-06)
149013 EPS nconv=0 first unconverged value (error) -302.035 (1.88342775e-06)
149014 EPS nconv=0 first unconverged value (error) -302.035 (1.84854413e-06)
149015 EPS nconv=0 first unconverged value (error) -302.035 (1.83502225e-06)
149016 EPS nconv=0 first unconverged value (error) -302.035 (1.81825331e-06)
149017 EPS nconv=0 first unconverged value (error) -302.035 (1.81825331e-06)
149018 EPS nconv=0 first unconverged value (error) -302.035 (2.04111435e-06)
149019 EPS nconv=0 first unconverged value (error) -302.035 (2.00234669e-06)
149020 EPS nconv=0 first unconverged value (error) -302.035 (1.95485371e-06)
149021 EPS nconv=0 first unconverged value (error) -302.035 (1.91666626e-06)
149022 EPS nconv=0 first unconverged value (error) -302.035 (1.89696483e-06)
149023 EPS nconv=0 first unconverged value (error) -302.035 (1.89696483e-06)
149024 EPS nconv=0 first unconverged value (error) -302.035 (2.04838581e-06)
149025 EPS nconv=0 first unconverged value (error) -302.035 (1.99843845e-06)
149026 EPS nconv=0 first unconverged value (error) -302.035 (1.91986065e-06)
149027 EPS nconv=0 first unconverged value (error) -302.035 (1.90480968e-06)
149028 EPS nconv=0 first unconverged value (error) -302.035 (1.87330827e-06)
149029 EPS nconv=0 first unconverged value (error) -302.035 (1.87330827e-06)
149030 EPS nconv=0 first unconverged value (error) -302.035 (1.87094874e-06)
149031 EPS nconv=0 first unconverged value (error) -302.035 (1.92229113e-06)
149032 EPS nconv=0 first unconverged value (error) -302.035 (1.83978668e-06)
149033 EPS nconv=0 first unconverged value (error) -302.035 (1.81971535e-06)
149034 EPS nconv=0 first unconverged value (error) -302.035 (1.81587036e-06)
149035 EPS nconv=0 first unconverged value (error) -302.035 (1.81587036e-06)
149036 EPS nconv=0 first unconverged value (error) -302.035 (2.00531529e-06)
149037 EPS nconv=0 first unconverged value (error) -302.035 (1.91851002e-06)
149038 EPS nconv=0 first unconverged value (error) -302.035 (1.89704230e-06)
149039 EPS nconv=0 first unconverged value (error) -302.035 (1.88903415e-06)
149040 EPS nconv=0 first unconverged value (error) -302.035 (1.87454069e-06)
149041 EPS nconv=0 first unconverged value (error) -302.035 (1.87454069e-06)
149042 EPS nconv=0 first unconverged value (error) -302.035 (2.16376835e-06)
149043 EPS nconv=0 first unconverged value (error) -302.035 (2.12239980e-06)
149044 EPS nconv=0 first unconverged value (error) -302.035 (2.00204975e-06)
149045 EPS nconv=0 first unconverged value (error) -302.035 (2.01270477e-06)
149046 EPS nconv=0 first unconverged value (error) -302.035 (1.98243465e-06)
149047 EPS nconv=0 first unconverged value (error) -302.035 (1.98243465e-06)
149048 EPS nconv=0 first unconverged value (error) -302.035 (1.96167615e-06)
149049 EPS nconv=0 first unconverged value (error) -302.035 (1.96492332e-06)
149050 EPS nconv=0 first unconverged value (error) -302.035 (1.87909298e-06)
149051 EPS nconv=0 first unconverged value (error) -302.035 (1.85075144e-06)
149052 EPS nconv=0 first unconverged value (error) -302.035 (1.82137175e-06)
149053 EPS nconv=0 first unconverged value (error) -302.035 (1.82137175e-06)
149054 EPS nconv=0 first unconverged value (error) -302.035 (1.88959605e-06)
149055 EPS nconv=0 first unconverged value (error) -302.035 (1.85445816e-06)
149056 EPS nconv=0 first unconverged value (error) -302.035 (1.84053344e-06)
149057 EPS nconv=0 first unconverged value (error) -302.035 (1.83584970e-06)
149058 EPS nconv=0 first unconverged value (error) -302.035 (1.83127163e-06)
149059 EPS nconv=0 first unconverged value (error) -302.035 (1.83127163e-06)
149060 EPS nconv=0 first unconverged value (error) -302.035 (3.89277411e-06)
149061 EPS nconv=0 first unconverged value (error) -302.035 (3.51698767e-06)
149062 EPS nconv=0 first unconverged value (error) -302.035 (3.12888890e-06)
149063 EPS nconv=0 first unconverged value (error) -302.035 (3.09324015e-06)
149064 EPS nconv=0 first unconverged value (error) -302.035 (2.95823332e-06)
149065 EPS nconv=0 first unconverged value (error) -302.035 (2.95823332e-06)
149066 EPS nconv=0 first unconverged value (error) -302.035 (4.06580143e-06)
149067 EPS nconv=0 first unconverged value (error) -302.035 (3.76272952e-06)
149068 EPS nconv=0 first unconverged value (error) -302.035 (3.11965569e-06)
149069 EPS nconv=0 first unconverged value (error) -302.035 (3.03186289e-06)
149070 EPS nconv=0 first unconverged value (error) -302.035 (2.98182211e-06)
149071 EPS nconv=0 first unconverged value (error) -302.035 (2.98182211e-06)
149072 EPS nconv=0 first unconverged value (error) -302.035 (2.92652364e-06)
149073 EPS nconv=0 first unconverged value (error) -302.035 (3.10537070e-06)
149074 EPS nconv=0 first unconverged value (error) -302.035 (2.89988705e-06)
149075 EPS nconv=0 first unconverged value (error) -302.035 (2.22236301e-06)
149076 EPS nconv=0 first unconverged value (error) -302.035 (2.06489526e-06)
149077 EPS nconv=0 first unconverged value (error) -302.035 (2.06489526e-06)
149078 EPS nconv=0 first unconverged value (error) -302.035 (1.86080861e-06)
149079 EPS nconv=0 first unconverged value (error) -302.035 (1.85679443e-06)
149080 EPS nconv=0 first unconverged value (error) -302.035 (1.83453695e-06)
149081 EPS nconv=0 first unconverged value (error) -302.035 (1.80889158e-06)
149082 EPS nconv=0 first unconverged value (error) -302.035 (1.80536773e-06)
149083 EPS nconv=0 first unconverged value (error) -302.035 (1.80536773e-06)
149084 EPS nconv=0 first unconverged value (error) -302.035 (2.15611894e-06)
149085 EPS nconv=0 first unconverged value (error) -302.035 (2.03616982e-06)
149086 EPS nconv=0 first unconverged value (error) -302.035 (1.98694763e-06)
149087 EPS nconv=0 first unconverged value (error) -302.035 (1.97648705e-06)
149088 EPS nconv=0 first unconverged value (error) -302.035 (1.96624109e-06)
149089 EPS nconv=0 first unconverged value (error) -302.035 (1.96624109e-06)
149090 EPS nconv=0 first unconverged value (error) -302.035 (2.14611046e-06)
149091 EPS nconv=0 first unconverged value (error) -302.035 (2.10651929e-06)
149092 EPS nconv=0 first unconverged value (error) -302.035 (1.95176655e-06)
149093 EPS nconv=0 first unconverged value (error) -302.035 (1.92726741e-06)
149094 EPS nconv=0 first unconverged value (error) -302.035 (1.91917989e-06)
149095 EPS nconv=0 first unconverged value (error) -302.035 (1.91917989e-06)
149096 EPS nconv=0 first unconverged value (error) -302.035 (1.95285354e-06)
149097 EPS nconv=0 first unconverged value (error) -302.035 (1.97114866e-06)
149098 EPS nconv=0 first unconverged value (error) -302.035 (1.89123425e-06)
149099 EPS nconv=0 first unconverged value (error) -302.035 (1.85375831e-06)
149100 EPS nconv=0 first unconverged value (error) -302.035 (1.82461365e-06)
149101 EPS nconv=0 first unconverged value (error) -302.035 (1.82461365e-06)
149102 EPS nconv=0 first unconverged value (error) -302.035 (2.58744681e-06)
149103 EPS nconv=0 first unconverged value (error) -302.035 (2.45547589e-06)
149104 EPS nconv=0 first unconverged value (error) -302.035 (2.34553903e-06)
149105 EPS nconv=0 first unconverged value (error) -302.035 (2.25461207e-06)
149106 EPS nconv=0 first unconverged value (error) -302.035 (2.21189364e-06)
149107 EPS nconv=0 first unconverged value (error) -302.035 (2.21189364e-06)
149108 EPS nconv=0 first unconverged value (error) -302.035 (2.64993508e-06)
149109 EPS nconv=0 first unconverged value (error) -302.035 (2.46202934e-06)
149110 EPS nconv=0 first unconverged value (error) -302.035 (2.22506185e-06)
149111 EPS nconv=0 first unconverged value (error) -302.035 (2.17950180e-06)
149112 EPS nconv=0 first unconverged value (error) -302.035 (2.14686058e-06)
149113 EPS nconv=0 first unconverged value (error) -302.035 (2.14686058e-06)
149114 EPS nconv=0 first unconverged value (error) -302.035 (2.17958099e-06)
149115 EPS nconv=0 first unconverged value (error) -302.035 (2.21515084e-06)
149116 EPS nconv=0 first unconverged value (error) -302.035 (2.01701066e-06)
149117 EPS nconv=0 first unconverged value (error) -302.035 (1.95605993e-06)
149118 EPS nconv=0 first unconverged value (error) -302.035 (1.87023074e-06)
149119 EPS nconv=0 first unconverged value (error) -302.035 (1.87023074e-06)
149120 EPS nconv=0 first unconverged value (error) -302.035 (2.30457000e-06)
149121 EPS nconv=0 first unconverged value (error) -302.035 (2.23400325e-06)
149122 EPS nconv=0 first unconverged value (error) -302.035 (2.11267439e-06)
149123 EPS nconv=0 first unconverged value (error) -302.035 (2.04569611e-06)
149124 EPS nconv=0 first unconverged value (error) -302.035 (2.01566348e-06)
149125 EPS nconv=0 first unconverged value (error) -302.035 (2.01566348e-06)
149126 EPS nconv=0 first unconverged value (error) -302.035 (2.67166841e-06)
149127 EPS nconv=0 first unconverged value (error) -302.035 (2.53586495e-06)
149128 EPS nconv=0 first unconverged value (error) -302.035 (2.34382877e-06)
149129 EPS nconv=0 first unconverged value (error) -302.035 (2.26605084e-06)
149130 EPS nconv=0 first unconverged value (error) -302.035 (2.21183710e-06)
149131 EPS nconv=0 first unconverged value (error) -302.035 (2.21183710e-06)
149132 EPS nconv=0 first unconverged value (error) -302.035 (2.26889129e-06)
149133 EPS nconv=0 first unconverged value (error) -302.035 (2.26661340e-06)
149134 EPS nconv=0 first unconverged value (error) -302.035 (2.03198301e-06)
149135 EPS nconv=0 first unconverged value (error) -302.035 (1.90165507e-06)
149136 EPS nconv=0 first unconverged value (error) -302.035 (1.85359259e-06)
149137 EPS nconv=0 first unconverged value (error) -302.035 (1.85359259e-06)
149138 EPS nconv=0 first unconverged value (error) -302.035 (1.97077842e-06)
149139 EPS nconv=0 first unconverged value (error) -302.035 (1.90751082e-06)
149140 EPS nconv=0 first unconverged value (error) -302.035 (1.86688422e-06)
149141 EPS nconv=0 first unconverged value (error) -302.035 (1.83121643e-06)
149142 EPS nconv=0 first unconverged value (error) -302.035 (1.82550256e-06)
149143 EPS nconv=0 first unconverged value (error) -302.035 (1.82550256e-06)
149144 EPS nconv=0 first unconverged value (error) -302.035 (2.09135435e-06)
149145 EPS nconv=0 first unconverged value (error) -302.035 (2.00436910e-06)
149146 EPS nconv=0 first unconverged value (error) -302.035 (1.95419991e-06)
149147 EPS nconv=0 first unconverged value (error) -302.035 (1.95185637e-06)
149148 EPS nconv=0 first unconverged value (error) -302.035 (1.94023854e-06)
149149 EPS nconv=0 first unconverged value (error) -302.035 (1.94023854e-06)
149150 EPS nconv=0 first unconverged value (error) -302.035 (2.22458031e-06)
149151 EPS nconv=0 first unconverged value (error) -302.035 (2.08643409e-06)
149152 EPS nconv=0 first unconverged value (error) -302.035 (1.96294943e-06)
149153 EPS nconv=0 first unconverged value (error) -302.035 (1.94768418e-06)
149154 EPS nconv=0 first unconverged value (error) -302.035 (1.94522070e-06)
149155 EPS nconv=0 first unconverged value (error) -302.035 (1.94522070e-06)
149156 EPS nconv=0 first unconverged value (error) -302.035 (2.35400947e-06)
149157 EPS nconv=0 first unconverged value (error) -302.035 (2.20880610e-06)
149158 EPS nconv=0 first unconverged value (error) -302.035 (2.03236798e-06)
149159 EPS nconv=0 first unconverged value (error) -302.035 (2.00840643e-06)
149160 EPS nconv=0 first unconverged value (error) -302.035 (1.95938397e-06)
149161 EPS nconv=0 first unconverged value (error) -302.035 (1.95938397e-06)
149162 EPS nconv=0 first unconverged value (error) -302.035 (2.49374902e-06)
149163 EPS nconv=0 first unconverged value (error) -302.035 (2.54912597e-06)
149164 EPS nconv=0 first unconverged value (error) -302.035 (2.25764956e-06)
149165 EPS nconv=0 first unconverged value (error) -302.035 (2.22104417e-06)
149166 EPS nconv=0 first unconverged value (error) -302.035 (2.17883107e-06)
149167 EPS nconv=0 first unconverged value (error) -302.035 (2.17883107e-06)
149168 EPS nconv=0 first unconverged value (error) -302.035 (2.35824051e-06)
149169 EPS nconv=0 first unconverged value (error) -302.035 (2.32389623e-06)
149170 EPS nconv=0 first unconverged value (error) -302.035 (2.25094317e-06)
149171 EPS nconv=0 first unconverged value (error) -302.035 (1.94181564e-06)
149172 EPS nconv=0 first unconverged value (error) -302.035 (1.89490988e-06)
149173 EPS nconv=0 first unconverged value (error) -302.035 (1.89490988e-06)
149174 EPS nconv=0 first unconverged value (error) -302.035 (2.15362169e-06)
149175 EPS nconv=0 first unconverged value (error) -302.035 (2.06555915e-06)
149176 EPS nconv=0 first unconverged value (error) -302.035 (1.97081991e-06)
149177 EPS nconv=0 first unconverged value (error) -302.035 (1.89869900e-06)
149178 EPS nconv=0 first unconverged value (error) -302.035 (1.88350372e-06)
149179 EPS nconv=0 first unconverged value (error) -302.035 (1.88350372e-06)
149180 EPS nconv=0 first unconverged value (error) -302.035 (1.87754061e-06)
149181 EPS nconv=0 first unconverged value (error) -302.035 (1.97610914e-06)
149182 EPS nconv=0 first unconverged value (error) -302.035 (1.86485861e-06)
149183 EPS nconv=0 first unconverged value (error) -302.035 (1.82006596e-06)
149184 EPS nconv=0 first unconverged value (error) -302.035 (1.80375484e-06)
149185 EPS nconv=0 first unconverged value (error) -302.035 (1.80375484e-06)
149186 EPS nconv=0 first unconverged value (error) -302.035 (2.46039734e-06)
149187 EPS nconv=0 first unconverged value (error) -302.035 (2.29904978e-06)
149188 EPS nconv=0 first unconverged value (error) -302.035 (2.26491401e-06)
149189 EPS nconv=0 first unconverged value (error) -302.035 (2.23803493e-06)
149190 EPS nconv=0 first unconverged value (error) -302.035 (2.16929400e-06)
149191 EPS nconv=0 first unconverged value (error) -302.035 (2.16929400e-06)
149192 EPS nconv=0 first unconverged value (error) -302.035 (3.19795849e-06)
149193 EPS nconv=0 first unconverged value (error) -302.035 (2.92145804e-06)
149194 EPS nconv=0 first unconverged value (error) -302.035 (2.52048778e-06)
149195 EPS nconv=0 first unconverged value (error) -302.035 (2.49473593e-06)
149196 EPS nconv=0 first unconverged value (error) -302.035 (2.46776604e-06)
149197 EPS nconv=0 first unconverged value (error) -302.035 (2.46776604e-06)
149198 EPS nconv=0 first unconverged value (error) -302.035 (2.61205466e-06)
149199 EPS nconv=0 first unconverged value (error) -302.035 (2.74761133e-06)
149200 EPS nconv=0 first unconverged value (error) -302.035 (2.48235853e-06)
149201 EPS nconv=0 first unconverged value (error) -302.035 (2.23706990e-06)
149202 EPS nconv=0 first unconverged value (error) -302.035 (1.94161316e-06)
149203 EPS nconv=0 first unconverged value (error) -302.035 (1.94161316e-06)
149204 EPS nconv=0 first unconverged value (error) -302.035 (1.98291426e-06)
149205 EPS nconv=0 first unconverged value (error) -302.035 (2.00856110e-06)
149206 EPS nconv=0 first unconverged value (error) -302.035 (1.90249722e-06)
149207 EPS nconv=0 first unconverged value (error) -302.035 (1.85168860e-06)
149208 EPS nconv=0 first unconverged value (error) -302.035 (1.83812302e-06)
149209 EPS nconv=0 first unconverged value (error) -302.035 (1.83812302e-06)
149210 EPS nconv=0 first unconverged value (error) -302.035 (2.29662452e-06)
149211 EPS nconv=0 first unconverged value (error) -302.035 (2.15669252e-06)
149212 EPS nconv=0 first unconverged value (error) -302.035 (2.05592520e-06)
149213 EPS nconv=0 first unconverged value (error) -302.035 (2.04283974e-06)
149214 EPS nconv=0 first unconverged value (error) -302.035 (2.02277781e-06)
149215 EPS nconv=0 first unconverged value (error) -302.035 (2.02277781e-06)
149216 EPS nconv=0 first unconverged value (error) -302.035 (3.25894389e-06)
149217 EPS nconv=0 first unconverged value (error) -302.035 (3.01855269e-06)
149218 EPS nconv=0 first unconverged value (error) -302.035 (2.65163565e-06)
149219 EPS nconv=0 first unconverged value (error) -302.035 (2.53389104e-06)
149220 EPS nconv=0 first unconverged value (error) -302.035 (2.48653258e-06)
149221 EPS nconv=0 first unconverged value (error) -302.035 (2.48653258e-06)
149222 EPS nconv=0 first unconverged value (error) -302.035 (2.45454324e-06)
149223 EPS nconv=0 first unconverged value (error) -302.035 (2.72496829e-06)
149224 EPS nconv=0 first unconverged value (error) -302.035 (2.41436313e-06)
149225 EPS nconv=0 first unconverged value (error) -302.035 (2.11105900e-06)
149226 EPS nconv=0 first unconverged value (error) -302.035 (1.86515647e-06)
149227 EPS nconv=0 first unconverged value (error) -302.035 (1.86515647e-06)
149228 EPS nconv=0 first unconverged value (error) -302.035 (2.67846220e-06)
149229 EPS nconv=0 first unconverged value (error) -302.035 (2.64216905e-06)
149230 EPS nconv=0 first unconverged value (error) -302.035 (2.60214014e-06)
149231 EPS nconv=0 first unconverged value (error) -302.035 (2.49955421e-06)
149232 EPS nconv=0 first unconverged value (error) -302.035 (2.43462655e-06)
149233 EPS nconv=0 first unconverged value (error) -302.035 (2.43462655e-06)
149234 EPS nconv=0 first unconverged value (error) -302.035 (4.10544096e-06)
149235 EPS nconv=0 first unconverged value (error) -302.035 (3.41634709e-06)
149236 EPS nconv=0 first unconverged value (error) -302.035 (3.15068183e-06)
149237 EPS nconv=0 first unconverged value (error) -302.035 (3.13058252e-06)
149238 EPS nconv=0 first unconverged value (error) -302.035 (3.09584896e-06)
149239 EPS nconv=0 first unconverged value (error) -302.035 (3.09584896e-06)
149240 EPS nconv=0 first unconverged value (error) -302.035 (3.96832958e-06)
149241 EPS nconv=0 first unconverged value (error) -302.035 (3.70638618e-06)
149242 EPS nconv=0 first unconverged value (error) -302.035 (2.82503874e-06)
149243 EPS nconv=0 first unconverged value (error) -302.035 (2.88363987e-06)
149244 EPS nconv=0 first unconverged value (error) -302.035 (2.55277910e-06)
149245 EPS nconv=0 first unconverged value (error) -302.035 (2.55277910e-06)
149246 EPS nconv=0 first unconverged value (error) -302.035 (2.49277150e-06)
149247 EPS nconv=0 first unconverged value (error) -302.035 (2.79046560e-06)
149248 EPS nconv=0 first unconverged value (error) -302.035 (2.62971267e-06)
149249 EPS nconv=0 first unconverged value (error) -302.035 (1.96525075e-06)
149250 EPS nconv=0 first unconverged value (error) -302.035 (1.93077014e-06)
149251 EPS nconv=0 first unconverged value (error) -302.035 (1.93077014e-06)
149252 EPS nconv=0 first unconverged value (error) -302.035 (2.37415856e-06)
149253 EPS nconv=0 first unconverged value (error) -302.035 (2.14195052e-06)
149254 EPS nconv=0 first unconverged value (error) -302.035 (2.04159131e-06)
149255 EPS nconv=0 first unconverged value (error) -302.035 (1.93864913e-06)
149256 EPS nconv=0 first unconverged value (error) -302.035 (1.91937480e-06)
149257 EPS nconv=0 first unconverged value (error) -302.035 (1.91937480e-06)
149258 EPS nconv=0 first unconverged value (error) -302.035 (1.94572404e-06)
149259 EPS nconv=0 first unconverged value (error) -302.035 (2.03927710e-06)
149260 EPS nconv=0 first unconverged value (error) -302.035 (1.86448617e-06)
149261 EPS nconv=0 first unconverged value (error) -302.035 (1.82269254e-06)
149262 EPS nconv=0 first unconverged value (error) -302.035 (1.82331473e-06)
149263 EPS nconv=0 first unconverged value (error) -302.035 (1.82331473e-06)
149264 EPS nconv=0 first unconverged value (error) -302.035 (1.97674805e-06)
149265 EPS nconv=0 first unconverged value (error) -302.035 (1.90588081e-06)
149266 EPS nconv=0 first unconverged value (error) -302.035 (1.87500325e-06)
149267 EPS nconv=0 first unconverged value (error) -302.035 (1.87062384e-06)
149268 EPS nconv=0 first unconverged value (error) -302.035 (1.85510227e-06)
149269 EPS nconv=0 first unconverged value (error) -302.035 (1.85510227e-06)
149270 EPS nconv=0 first unconverged value (error) -302.035 (2.46239921e-06)
149271 EPS nconv=0 first unconverged value (error) -302.035 (2.40432270e-06)
149272 EPS nconv=0 first unconverged value (error) -302.035 (2.20901853e-06)
149273 EPS nconv=0 first unconverged value (error) -302.035 (2.17499176e-06)
149274 EPS nconv=0 first unconverged value (error) -302.035 (2.11419548e-06)
149275 EPS nconv=0 first unconverged value (error) -302.035 (2.11419548e-06)
149276 EPS nconv=0 first unconverged value (error) -302.035 (3.27839453e-06)
149277 EPS nconv=0 first unconverged value (error) -302.035 (3.06065611e-06)
149278 EPS nconv=0 first unconverged value (error) -302.035 (2.79812282e-06)
149279 EPS nconv=0 first unconverged value (error) -302.035 (2.76254249e-06)
149280 EPS nconv=0 first unconverged value (error) -302.035 (2.72073284e-06)
149281 EPS nconv=0 first unconverged value (error) -302.035 (2.72073284e-06)
149282 EPS nconv=0 first unconverged value (error) -302.035 (3.02679577e-06)
149283 EPS nconv=0 first unconverged value (error) -302.035 (2.66293809e-06)
149284 EPS nconv=0 first unconverged value (error) -302.035 (2.35104926e-06)
149285 EPS nconv=0 first unconverged value (error) -302.035 (2.24626241e-06)
149286 EPS nconv=0 first unconverged value (error) -302.035 (2.09933305e-06)
149287 EPS nconv=0 first unconverged value (error) -302.035 (2.09933305e-06)
149288 EPS nconv=0 first unconverged value (error) -302.035 (2.93628816e-06)
149289 EPS nconv=0 first unconverged value (error) -302.035 (3.12415154e-06)
149290 EPS nconv=0 first unconverged value (error) -302.035 (2.68969506e-06)
149291 EPS nconv=0 first unconverged value (error) -302.035 (2.37458322e-06)
149292 EPS nconv=0 first unconverged value (error) -302.035 (2.28992948e-06)
149293 EPS nconv=0 first unconverged value (error) -302.035 (2.28992948e-06)
149294 EPS nconv=0 first unconverged value (error) -302.035 (2.44966208e-06)
149295 EPS nconv=0 first unconverged value (error) -302.035 (2.50084536e-06)
149296 EPS nconv=0 first unconverged value (error) -302.035 (2.32553993e-06)
149297 EPS nconv=0 first unconverged value (error) -302.035 (2.10301168e-06)
149298 EPS nconv=0 first unconverged value (error) -302.035 (1.96443203e-06)
149299 EPS nconv=0 first unconverged value (error) -302.035 (1.96443203e-06)
149300 EPS nconv=0 first unconverged value (error) -302.035 (2.86169944e-06)
149301 EPS nconv=0 first unconverged value (error) -302.035 (2.63560937e-06)
149302 EPS nconv=0 first unconverged value (error) -302.035 (2.51195629e-06)
149303 EPS nconv=0 first unconverged value (error) -302.035 (2.48140324e-06)
149304 EPS nconv=0 first unconverged value (error) -302.035 (2.41036821e-06)
149305 EPS nconv=0 first unconverged value (error) -302.035 (2.41036821e-06)
149306 EPS nconv=0 first unconverged value (error) -302.035 (2.51568562e-06)
149307 EPS nconv=0 first unconverged value (error) -302.035 (2.42090845e-06)
149308 EPS nconv=0 first unconverged value (error) -302.035 (2.10576348e-06)
149309 EPS nconv=0 first unconverged value (error) -302.035 (2.02543718e-06)
149310 EPS nconv=0 first unconverged value (error) -302.035 (1.92962987e-06)
149311 EPS nconv=0 first unconverged value (error) -302.035 (1.92962987e-06)
149312 EPS nconv=0 first unconverged value (error) -302.035 (1.93900839e-06)
149313 EPS nconv=0 first unconverged value (error) -302.035 (1.98402407e-06)
149314 EPS nconv=0 first unconverged value (error) -302.035 (1.89206867e-06)
149315 EPS nconv=0 first unconverged value (error) -302.035 (1.85888811e-06)
149316 EPS nconv=0 first unconverged value (error) -302.035 (1.83866354e-06)
149317 EPS nconv=0 first unconverged value (error) -302.035 (1.83866354e-06)
149318 EPS nconv=0 first unconverged value (error) -302.035 (1.91104028e-06)
149319 EPS nconv=0 first unconverged value (error) -302.035 (1.94404688e-06)
149320 EPS nconv=0 first unconverged value (error) -302.035 (1.88410937e-06)
149321 EPS nconv=0 first unconverged value (error) -302.035 (1.86164672e-06)
149322 EPS nconv=0 first unconverged value (error) -302.035 (1.84555746e-06)
149323 EPS nconv=0 first unconverged value (error) -302.035 (1.84555746e-06)
149324 EPS nconv=0 first unconverged value (error) -302.035 (2.64977894e-06)
149325 EPS nconv=0 first unconverged value (error) -302.035 (2.43950578e-06)
149326 EPS nconv=0 first unconverged value (error) -302.035 (2.36409060e-06)
149327 EPS nconv=0 first unconverged value (error) -302.035 (2.29015580e-06)
149328 EPS nconv=0 first unconverged value (error) -302.035 (2.20527813e-06)
149329 EPS nconv=0 first unconverged value (error) -302.035 (2.20527813e-06)
149330 EPS nconv=0 first unconverged value (error) -302.035 (3.45150357e-06)
149331 EPS nconv=0 first unconverged value (error) -302.035 (3.11932995e-06)
149332 EPS nconv=0 first unconverged value (error) -302.035 (2.68273856e-06)
149333 EPS nconv=0 first unconverged value (error) -302.035 (2.64862771e-06)
149334 EPS nconv=0 first unconverged value (error) -302.035 (2.53967495e-06)
149335 EPS nconv=0 first unconverged value (error) -302.035 (2.53967495e-06)
149336 EPS nconv=0 first unconverged value (error) -302.035 (2.51767337e-06)
149337 EPS nconv=0 first unconverged value (error) -302.035 (2.88731002e-06)
149338 EPS nconv=0 first unconverged value (error) -302.035 (2.49531923e-06)
149339 EPS nconv=0 first unconverged value (error) -302.035 (2.12595267e-06)
149340 EPS nconv=0 first unconverged value (error) -302.035 (1.98948673e-06)
149341 EPS nconv=0 first unconverged value (error) -302.035 (1.98948673e-06)
149342 EPS nconv=0 first unconverged value (error) -302.035 (1.99359234e-06)
149343 EPS nconv=0 first unconverged value (error) -302.035 (1.95863411e-06)
149344 EPS nconv=0 first unconverged value (error) -302.035 (1.93679217e-06)
149345 EPS nconv=0 first unconverged value (error) -302.035 (1.91106660e-06)
149346 EPS nconv=0 first unconverged value (error) -302.035 (1.88509970e-06)
149347 EPS nconv=0 first unconverged value (error) -302.035 (1.88509970e-06)
149348 EPS nconv=0 first unconverged value (error) -302.035 (2.99750842e-06)
149349 EPS nconv=0 first unconverged value (error) -302.035 (2.90813793e-06)
149350 EPS nconv=0 first unconverged value (error) -302.035 (2.67628793e-06)
149351 EPS nconv=0 first unconverged value (error) -302.035 (2.57071140e-06)
149352 EPS nconv=0 first unconverged value (error) -302.035 (2.56551163e-06)
149353 EPS nconv=0 first unconverged value (error) -302.035 (2.56551163e-06)
149354 EPS nconv=0 first unconverged value (error) -302.035 (2.70392466e-06)
149355 EPS nconv=0 first unconverged value (error) -302.035 (2.42443016e-06)
149356 EPS nconv=0 first unconverged value (error) -302.035 (2.20329382e-06)
149357 EPS nconv=0 first unconverged value (error) -302.035 (2.05042152e-06)
149358 EPS nconv=0 first unconverged value (error) -302.035 (2.00479886e-06)
149359 EPS nconv=0 first unconverged value (error) -302.035 (2.00479886e-06)
149360 EPS nconv=0 first unconverged value (error) -302.035 (2.02729742e-06)
149361 EPS nconv=0 first unconverged value (error) -302.035 (2.17591031e-06)
149362 EPS nconv=0 first unconverged value (error) -302.035 (1.98018067e-06)
149363 EPS nconv=0 first unconverged value (error) -302.035 (1.91894197e-06)
149364 EPS nconv=0 first unconverged value (error) -302.035 (1.88694492e-06)
149365 EPS nconv=0 first unconverged value (error) -302.035 (1.88694492e-06)
149366 EPS nconv=0 first unconverged value (error) -302.035 (1.85725896e-06)
149367 EPS nconv=0 first unconverged value (error) -302.035 (1.90010257e-06)
149368 EPS nconv=0 first unconverged value (error) -302.035 (1.84320762e-06)
149369 EPS nconv=0 first unconverged value (error) -302.035 (1.81934678e-06)
149370 EPS nconv=0 first unconverged value (error) -302.035 (1.80665216e-06)
149371 EPS nconv=0 first unconverged value (error) -302.035 (1.80665216e-06)
149372 EPS nconv=0 first unconverged value (error) -302.035 (2.13460012e-06)
149373 EPS nconv=0 first unconverged value (error) -302.035 (2.06605418e-06)
149374 EPS nconv=0 first unconverged value (error) -302.035 (2.01908988e-06)
149375 EPS nconv=0 first unconverged value (error) -302.035 (1.99618970e-06)
149376 EPS nconv=0 first unconverged value (error) -302.035 (1.96265215e-06)
149377 EPS nconv=0 first unconverged value (error) -302.035 (1.96265215e-06)
149378 EPS nconv=0 first unconverged value (error) -302.035 (3.11786515e-06)
149379 EPS nconv=0 first unconverged value (error) -302.035 (2.93950822e-06)
149380 EPS nconv=0 first unconverged value (error) -302.035 (2.71599632e-06)
149381 EPS nconv=0 first unconverged value (error) -302.035 (2.72311792e-06)
149382 EPS nconv=0 first unconverged value (error) -302.035 (2.65800775e-06)
149383 EPS nconv=0 first unconverged value (error) -302.035 (2.65800775e-06)
149384 EPS nconv=0 first unconverged value (error) -302.035 (4.07165421e-06)
149385 EPS nconv=0 first unconverged value (error) -302.035 (3.61492547e-06)
149386 EPS nconv=0 first unconverged value (error) -302.035 (3.03224671e-06)
149387 EPS nconv=0 first unconverged value (error) -302.035 (3.00264825e-06)
149388 EPS nconv=0 first unconverged value (error) -302.035 (2.87759145e-06)
149389 EPS nconv=0 first unconverged value (error) -302.035 (2.87759145e-06)
149390 EPS nconv=0 first unconverged value (error) -302.035 (3.90000975e-06)
149391 EPS nconv=0 first unconverged value (error) -302.035 (3.98863146e-06)
149392 EPS nconv=0 first unconverged value (error) -302.035 (3.42791490e-06)
149393 EPS nconv=0 first unconverged value (error) -302.035 (3.10680952e-06)
149394 EPS nconv=0 first unconverged value (error) -302.035 (2.72075426e-06)
149395 EPS nconv=0 first unconverged value (error) -302.035 (2.72075426e-06)
149396 EPS nconv=0 first unconverged value (error) -302.035 (3.45003226e-06)
149397 EPS nconv=0 first unconverged value (error) -302.035 (3.24161528e-06)
149398 EPS nconv=0 first unconverged value (error) -302.035 (2.89565877e-06)
149399 EPS nconv=0 first unconverged value (error) -302.035 (2.83811557e-06)
149400 EPS nconv=0 first unconverged value (error) -302.035 (2.53813915e-06)
149401 EPS nconv=0 first unconverged value (error) -302.035 (2.53813915e-06)
149402 EPS nconv=0 first unconverged value (error) -302.035 (3.36812529e-06)
149403 EPS nconv=0 first unconverged value (error) -302.035 (3.21387581e-06)
149404 EPS nconv=0 first unconverged value (error) -302.035 (2.79695389e-06)
149405 EPS nconv=0 first unconverged value (error) -302.035 (2.69011130e-06)
149406 EPS nconv=0 first unconverged value (error) -302.035 (2.66026413e-06)
149407 EPS nconv=0 first unconverged value (error) -302.035 (2.66026413e-06)
149408 EPS nconv=0 first unconverged value (error) -302.035 (2.95015121e-06)
149409 EPS nconv=0 first unconverged value (error) -302.035 (2.67725351e-06)
149410 EPS nconv=0 first unconverged value (error) -302.035 (2.49963125e-06)
149411 EPS nconv=0 first unconverged value (error) -302.035 (2.30205697e-06)
149412 EPS nconv=0 first unconverged value (error) -302.035 (2.11665596e-06)
149413 EPS nconv=0 first unconverged value (error) -302.035 (2.11665596e-06)
149414 EPS nconv=0 first unconverged value (error) -302.035 (2.54483098e-06)
149415 EPS nconv=0 first unconverged value (error) -302.035 (2.46547839e-06)
149416 EPS nconv=0 first unconverged value (error) -302.035 (2.16710672e-06)
149417 EPS nconv=0 first unconverged value (error) -302.035 (2.07102433e-06)
149418 EPS nconv=0 first unconverged value (error) -302.035 (2.03216662e-06)
149419 EPS nconv=0 first unconverged value (error) -302.035 (2.03216662e-06)
149420 EPS nconv=0 first unconverged value (error) -302.035 (2.06841761e-06)
149421 EPS nconv=0 first unconverged value (error) -302.035 (2.18170583e-06)
149422 EPS nconv=0 first unconverged value (error) -302.035 (1.97765521e-06)
149423 EPS nconv=0 first unconverged value (error) -302.035 (1.94032502e-06)
149424 EPS nconv=0 first unconverged value (error) -302.035 (1.88374782e-06)
149425 EPS nconv=0 first unconverged value (error) -302.035 (1.88374782e-06)
149426 EPS nconv=0 first unconverged value (error) -302.035 (2.02280260e-06)
149427 EPS nconv=0 first unconverged value (error) -302.035 (1.99152819e-06)
149428 EPS nconv=0 first unconverged value (error) -302.035 (1.93835348e-06)
149429 EPS nconv=0 first unconverged value (error) -302.035 (1.92280382e-06)
149430 EPS nconv=0 first unconverged value (error) -302.035 (1.88989894e-06)
149431 EPS nconv=0 first unconverged value (error) -302.035 (1.88989894e-06)
149432 EPS nconv=0 first unconverged value (error) -302.035 (2.44337275e-06)
149433 EPS nconv=0 first unconverged value (error) -302.035 (2.20027337e-06)
149434 EPS nconv=0 first unconverged value (error) -302.035 (2.09526111e-06)
149435 EPS nconv=0 first unconverged value (error) -302.035 (2.04268611e-06)
149436 EPS nconv=0 first unconverged value (error) -302.035 (1.99946744e-06)
149437 EPS nconv=0 first unconverged value (error) -302.035 (1.99946744e-06)
149438 EPS nconv=0 first unconverged value (error) -302.035 (2.04110699e-06)
149439 EPS nconv=0 first unconverged value (error) -302.035 (2.25145401e-06)
149440 EPS nconv=0 first unconverged value (error) -302.035 (1.96822989e-06)
149441 EPS nconv=0 first unconverged value (error) -302.035 (1.90421584e-06)
149442 EPS nconv=0 first unconverged value (error) -302.035 (1.86919240e-06)
149443 EPS nconv=0 first unconverged value (error) -302.035 (1.86919240e-06)
149444 EPS nconv=0 first unconverged value (error) -302.035 (2.00073152e-06)
149445 EPS nconv=0 first unconverged value (error) -302.035 (1.95309365e-06)
149446 EPS nconv=0 first unconverged value (error) -302.035 (1.91350808e-06)
149447 EPS nconv=0 first unconverged value (error) -302.035 (1.91548767e-06)
149448 EPS nconv=0 first unconverged value (error) -302.035 (1.87711452e-06)
149449 EPS nconv=0 first unconverged value (error) -302.035 (1.87711452e-06)
149450 EPS nconv=0 first unconverged value (error) -302.035 (1.89924757e-06)
149451 EPS nconv=0 first unconverged value (error) -302.035 (1.92966304e-06)
149452 EPS nconv=0 first unconverged value (error) -302.035 (1.85692894e-06)
149453 EPS nconv=0 first unconverged value (error) -302.035 (1.83010134e-06)
149454 EPS nconv=0 first unconverged value (error) -302.035 (1.83204779e-06)
149455 EPS nconv=0 first unconverged value (error) -302.035 (1.83204779e-06)
149456 EPS nconv=0 first unconverged value (error) -302.035 (2.05077848e-06)
149457 EPS nconv=0 first unconverged value (error) -302.035 (1.93975876e-06)
149458 EPS nconv=0 first unconverged value (error) -302.035 (1.90582569e-06)
149459 EPS nconv=0 first unconverged value (error) -302.035 (1.89430276e-06)
149460 EPS nconv=0 first unconverged value (error) -302.035 (1.87587971e-06)
149461 EPS nconv=0 first unconverged value (error) -302.035 (1.87587971e-06)
149462 EPS nconv=0 first unconverged value (error) -302.035 (1.88798950e-06)
149463 EPS nconv=0 first unconverged value (error) -302.035 (1.98527532e-06)
149464 EPS nconv=0 first unconverged value (error) -302.035 (1.86193970e-06)
149465 EPS nconv=0 first unconverged value (error) -302.035 (1.82963640e-06)
149466 EPS nconv=0 first unconverged value (error) -302.035 (1.82254149e-06)
149467 EPS nconv=0 first unconverged value (error) -302.035 (1.82254149e-06)
149468 EPS nconv=0 first unconverged value (error) -302.035 (1.86303971e-06)
149469 EPS nconv=0 first unconverged value (error) -302.035 (1.84466921e-06)
149470 EPS nconv=0 first unconverged value (error) -302.035 (1.83172800e-06)
149471 EPS nconv=0 first unconverged value (error) -302.035 (1.83004691e-06)
149472 EPS nconv=0 first unconverged value (error) -302.035 (1.82216627e-06)
149473 EPS nconv=0 first unconverged value (error) -302.035 (1.82216627e-06)
149474 EPS nconv=0 first unconverged value (error) -302.035 (2.22114248e-06)
149475 EPS nconv=0 first unconverged value (error) -302.035 (2.11981258e-06)
149476 EPS nconv=0 first unconverged value (error) -302.035 (2.05107270e-06)
149477 EPS nconv=0 first unconverged value (error) -302.035 (2.03524159e-06)
149478 EPS nconv=0 first unconverged value (error) -302.035 (1.98763413e-06)
149479 EPS nconv=0 first unconverged value (error) -302.035 (1.98763413e-06)
149480 EPS nconv=0 first unconverged value (error) -302.035 (1.98085253e-06)
149481 EPS nconv=0 first unconverged value (error) -302.035 (2.04499011e-06)
149482 EPS nconv=0 first unconverged value (error) -302.035 (1.93012173e-06)
149483 EPS nconv=0 first unconverged value (error) -302.035 (1.87224331e-06)
149484 EPS nconv=0 first unconverged value (error) -302.035 (1.85263039e-06)
149485 EPS nconv=0 first unconverged value (error) -302.035 (1.85263039e-06)
149486 EPS nconv=0 first unconverged value (error) -302.035 (1.92723493e-06)
149487 EPS nconv=0 first unconverged value (error) -302.035 (1.89152653e-06)
149488 EPS nconv=0 first unconverged value (error) -302.035 (1.86917999e-06)
149489 EPS nconv=0 first unconverged value (error) -302.035 (1.85773472e-06)
149490 EPS nconv=0 first unconverged value (error) -302.035 (1.84546159e-06)
149491 EPS nconv=0 first unconverged value (error) -302.035 (1.84546159e-06)
149492 EPS nconv=0 first unconverged value (error) -302.035 (2.57655253e-06)
149493 EPS nconv=0 first unconverged value (error) -302.035 (2.48256213e-06)
149494 EPS nconv=0 first unconverged value (error) -302.035 (2.31244915e-06)
149495 EPS nconv=0 first unconverged value (error) -302.035 (2.31415149e-06)
149496 EPS nconv=0 first unconverged value (error) -302.035 (2.20060134e-06)
149497 EPS nconv=0 first unconverged value (error) -302.035 (2.20060134e-06)
149498 EPS nconv=0 first unconverged value (error) -302.035 (3.30401190e-06)
149499 EPS nconv=0 first unconverged value (error) -302.035 (3.15991031e-06)
149500 EPS nconv=0 first unconverged value (error) -302.035 (2.77008241e-06)
149501 EPS nconv=0 first unconverged value (error) -302.035 (2.73591603e-06)
149502 EPS nconv=0 first unconverged value (error) -302.035 (2.72448370e-06)
149503 EPS nconv=0 first unconverged value (error) -302.035 (2.72448370e-06)
149504 EPS nconv=0 first unconverged value (error) -302.035 (2.80525086e-06)
149505 EPS nconv=0 first unconverged value (error) -302.035 (2.63562666e-06)
149506 EPS nconv=0 first unconverged value (error) -302.035 (2.55250283e-06)
149507 EPS nconv=0 first unconverged value (error) -302.035 (2.25268316e-06)
149508 EPS nconv=0 first unconverged value (error) -302.035 (2.04856523e-06)
149509 EPS nconv=0 first unconverged value (error) -302.035 (2.04856523e-06)
149510 EPS nconv=0 first unconverged value (error) -302.035 (1.94400803e-06)
149511 EPS nconv=0 first unconverged value (error) -302.035 (2.07365044e-06)
149512 EPS nconv=0 first unconverged value (error) -302.035 (1.90785651e-06)
149513 EPS nconv=0 first unconverged value (error) -302.035 (1.84018708e-06)
149514 EPS nconv=0 first unconverged value (error) -302.035 (1.82453479e-06)
149515 EPS nconv=0 first unconverged value (error) -302.035 (1.82453479e-06)
149516 EPS nconv=0 first unconverged value (error) -302.035 (1.81723749e-06)
149517 EPS nconv=0 first unconverged value (error) -302.035 (1.82316310e-06)
149518 EPS nconv=0 first unconverged value (error) -302.035 (1.82444355e-06)
149519 EPS nconv=0 first unconverged value (error) -302.035 (1.80131158e-06)
149520 EPS nconv=0 first unconverged value (error) -302.035 (1.79740352e-06)
149521 EPS nconv=0 first unconverged value (error) -302.035 (1.79740352e-06)
149522 EPS nconv=0 first unconverged value (error) -302.035 (1.80982291e-06)
149523 EPS nconv=0 first unconverged value (error) -302.035 (1.80928330e-06)
149524 EPS nconv=0 first unconverged value (error) -302.035 (1.80297808e-06)
149525 EPS nconv=0 first unconverged value (error) -302.035 (1.79943859e-06)
149526 EPS nconv=0 first unconverged value (error) -302.035 (1.79901236e-06)
149527 EPS nconv=0 first unconverged value (error) -302.035 (1.79901236e-06)
149528 EPS nconv=0 first unconverged value (error) -302.035 (1.80018962e-06)
149529 EPS nconv=0 first unconverged value (error) -302.035 (1.80252694e-06)
149530 EPS nconv=0 first unconverged value (error) -302.035 (1.80018829e-06)
149531 EPS nconv=0 first unconverged value (error) -302.035 (1.79659140e-06)
149532 EPS nconv=0 first unconverged value (error) -302.035 (1.79571797e-06)
149533 EPS nconv=0 first unconverged value (error) -302.035 (1.79571797e-06)
149534 EPS nconv=0 first unconverged value (error) -302.035 (1.81279713e-06)
149535 EPS nconv=0 first unconverged value (error) -302.035 (1.80818196e-06)
149536 EPS nconv=0 first unconverged value (error) -302.035 (1.80635165e-06)
149537 EPS nconv=0 first unconverged value (error) -302.035 (1.80417035e-06)
149538 EPS nconv=0 first unconverged value (error) -302.035 (1.80255282e-06)
149539 EPS nconv=0 first unconverged value (error) -302.035 (1.80255282e-06)
149540 EPS nconv=0 first unconverged value (error) -302.035 (1.81928717e-06)
149541 EPS nconv=0 first unconverged value (error) -302.035 (1.81368127e-06)
149542 EPS nconv=0 first unconverged value (error) -302.035 (1.80547461e-06)
149543 EPS nconv=0 first unconverged value (error) -302.035 (1.80444158e-06)
149544 EPS nconv=0 first unconverged value (error) -302.035 (1.80424172e-06)
149545 EPS nconv=0 first unconverged value (error) -302.035 (1.80424172e-06)
149546 EPS nconv=0 first unconverged value (error) -302.035 (1.94556942e-06)
149547 EPS nconv=0 first unconverged value (error) -302.035 (1.87827573e-06)
149548 EPS nconv=0 first unconverged value (error) -302.035 (1.85162255e-06)
149549 EPS nconv=0 first unconverged value (error) -302.035 (1.84505690e-06)
149550 EPS nconv=0 first unconverged value (error) -302.035 (1.83987727e-06)
149551 EPS nconv=0 first unconverged value (error) -302.035 (1.83987727e-06)
149552 EPS nconv=0 first unconverged value (error) -302.035 (2.40984334e-06)
149553 EPS nconv=0 first unconverged value (error) -302.035 (2.32017565e-06)
149554 EPS nconv=0 first unconverged value (error) -302.035 (2.12638418e-06)
149555 EPS nconv=0 first unconverged value (error) -302.035 (2.07190549e-06)
149556 EPS nconv=0 first unconverged value (error) -302.035 (2.05277292e-06)
149557 EPS nconv=0 first unconverged value (error) -302.035 (2.05277292e-06)
149558 EPS nconv=0 first unconverged value (error) -302.035 (2.39224254e-06)
149559 EPS nconv=0 first unconverged value (error) -302.035 (2.28951419e-06)
149560 EPS nconv=0 first unconverged value (error) -302.035 (2.13999629e-06)
149561 EPS nconv=0 first unconverged value (error) -302.035 (2.16575691e-06)
149562 EPS nconv=0 first unconverged value (error) -302.035 (2.04876572e-06)
149563 EPS nconv=0 first unconverged value (error) -302.035 (2.04876572e-06)
149564 EPS nconv=0 first unconverged value (error) -302.035 (2.15451968e-06)
149565 EPS nconv=0 first unconverged value (error) -302.035 (2.22765937e-06)
149566 EPS nconv=0 first unconverged value (error) -302.035 (2.07121006e-06)
149567 EPS nconv=0 first unconverged value (error) -302.035 (1.91979185e-06)
149568 EPS nconv=0 first unconverged value (error) -302.035 (1.89516528e-06)
149569 EPS nconv=0 first unconverged value (error) -302.035 (1.89516528e-06)
149570 EPS nconv=0 first unconverged value (error) -302.035 (2.61054257e-06)
149571 EPS nconv=0 first unconverged value (error) -302.035 (2.44315974e-06)
149572 EPS nconv=0 first unconverged value (error) -302.035 (2.35760957e-06)
149573 EPS nconv=0 first unconverged value (error) -302.035 (2.26024257e-06)
149574 EPS nconv=0 first unconverged value (error) -302.035 (2.20917169e-06)
149575 EPS nconv=0 first unconverged value (error) -302.035 (2.20917169e-06)
149576 EPS nconv=0 first unconverged value (error) -302.035 (2.18775374e-06)
149577 EPS nconv=0 first unconverged value (error) -302.035 (2.28287579e-06)
149578 EPS nconv=0 first unconverged value (error) -302.035 (2.09990772e-06)
149579 EPS nconv=0 first unconverged value (error) -302.035 (1.84077930e-06)
149580 EPS nconv=0 first unconverged value (error) -302.035 (1.82324669e-06)
149581 EPS nconv=0 first unconverged value (error) -302.035 (1.82324669e-06)
149582 EPS nconv=0 first unconverged value (error) -302.035 (2.10703501e-06)
149583 EPS nconv=0 first unconverged value (error) -302.035 (1.99245800e-06)
149584 EPS nconv=0 first unconverged value (error) -302.035 (1.94477419e-06)
149585 EPS nconv=0 first unconverged value (error) -302.035 (1.91763038e-06)
149586 EPS nconv=0 first unconverged value (error) -302.035 (1.90735026e-06)
149587 EPS nconv=0 first unconverged value (error) -302.035 (1.90735026e-06)
149588 EPS nconv=0 first unconverged value (error) -302.035 (2.25630572e-06)
149589 EPS nconv=0 first unconverged value (error) -302.035 (2.41465725e-06)
149590 EPS nconv=0 first unconverged value (error) -302.035 (2.15877081e-06)
149591 EPS nconv=0 first unconverged value (error) -302.035 (2.00375543e-06)
149592 EPS nconv=0 first unconverged value (error) -302.035 (1.97613676e-06)
149593 EPS nconv=0 first unconverged value (error) -302.035 (1.97613676e-06)
149594 EPS nconv=0 first unconverged value (error) -302.035 (2.01875032e-06)
149595 EPS nconv=0 first unconverged value (error) -302.035 (2.02596384e-06)
149596 EPS nconv=0 first unconverged value (error) -302.035 (1.99370793e-06)
149597 EPS nconv=0 first unconverged value (error) -302.035 (1.85894740e-06)
149598 EPS nconv=0 first unconverged value (error) -302.035 (1.82380897e-06)
149599 EPS nconv=0 first unconverged value (error) -302.035 (1.82380897e-06)
149600 EPS nconv=0 first unconverged value (error) -302.035 (1.83670353e-06)
149601 EPS nconv=0 first unconverged value (error) -302.035 (1.84824824e-06)
149602 EPS nconv=0 first unconverged value (error) -302.035 (1.83022774e-06)
149603 EPS nconv=0 first unconverged value (error) -302.035 (1.81324253e-06)
149604 EPS nconv=0 first unconverged value (error) -302.035 (1.80806276e-06)
149605 EPS nconv=0 first unconverged value (error) -302.035 (1.80806276e-06)
149606 EPS nconv=0 first unconverged value (error) -302.035 (1.89025559e-06)
149607 EPS nconv=0 first unconverged value (error) -302.035 (1.85568550e-06)
149608 EPS nconv=0 first unconverged value (error) -302.035 (1.84598552e-06)
149609 EPS nconv=0 first unconverged value (error) -302.035 (1.84119080e-06)
149610 EPS nconv=0 first unconverged value (error) -302.035 (1.83733172e-06)
149611 EPS nconv=0 first unconverged value (error) -302.035 (1.83733172e-06)
149612 EPS nconv=0 first unconverged value (error) -302.035 (2.28659750e-06)
149613 EPS nconv=0 first unconverged value (error) -302.035 (2.14962644e-06)
149614 EPS nconv=0 first unconverged value (error) -302.035 (2.06205003e-06)
149615 EPS nconv=0 first unconverged value (error) -302.035 (2.03820999e-06)
149616 EPS nconv=0 first unconverged value (error) -302.035 (2.02525176e-06)
149617 EPS nconv=0 first unconverged value (error) -302.035 (2.02525176e-06)
149618 EPS nconv=0 first unconverged value (error) -302.035 (2.05418985e-06)
149619 EPS nconv=0 first unconverged value (error) -302.035 (2.11449581e-06)
149620 EPS nconv=0 first unconverged value (error) -302.035 (1.97192861e-06)
149621 EPS nconv=0 first unconverged value (error) -302.035 (1.89547312e-06)
149622 EPS nconv=0 first unconverged value (error) -302.035 (1.84413879e-06)
149623 EPS nconv=0 first unconverged value (error) -302.035 (1.84413879e-06)
149624 EPS nconv=0 first unconverged value (error) -302.035 (1.90749482e-06)
149625 EPS nconv=0 first unconverged value (error) -302.035 (1.92756266e-06)
149626 EPS nconv=0 first unconverged value (error) -302.035 (1.88759270e-06)
149627 EPS nconv=0 first unconverged value (error) -302.035 (1.84663195e-06)
149628 EPS nconv=0 first unconverged value (error) -302.035 (1.83849038e-06)
149629 EPS nconv=0 first unconverged value (error) -302.035 (1.83849038e-06)
149630 EPS nconv=0 first unconverged value (error) -302.035 (2.12118936e-06)
149631 EPS nconv=0 first unconverged value (error) -302.035 (2.07558389e-06)
149632 EPS nconv=0 first unconverged value (error) -302.035 (2.00847639e-06)
149633 EPS nconv=0 first unconverged value (error) -302.035 (1.95407703e-06)
149634 EPS nconv=0 first unconverged value (error) -302.035 (1.92730067e-06)
149635 EPS nconv=0 first unconverged value (error) -302.035 (1.92730067e-06)
149636 EPS nconv=0 first unconverged value (error) -302.035 (3.44053347e-06)
149637 EPS nconv=0 first unconverged value (error) -302.035 (3.13123549e-06)
149638 EPS nconv=0 first unconverged value (error) -302.035 (2.92281433e-06)
149639 EPS nconv=0 first unconverged value (error) -302.035 (2.75371836e-06)
149640 EPS nconv=0 first unconverged value (error) -302.035 (2.61358288e-06)
149641 EPS nconv=0 first unconverged value (error) -302.035 (2.61358288e-06)
149642 EPS nconv=0 first unconverged value (error) -302.035 (3.73718807e-06)
149643 EPS nconv=0 first unconverged value (error) -302.035 (3.59974702e-06)
149644 EPS nconv=0 first unconverged value (error) -302.035 (2.98341162e-06)
149645 EPS nconv=0 first unconverged value (error) -302.035 (2.85801421e-06)
149646 EPS nconv=0 first unconverged value (error) -302.035 (2.77590984e-06)
149647 EPS nconv=0 first unconverged value (error) -302.035 (2.77590984e-06)
149648 EPS nconv=0 first unconverged value (error) -302.035 (2.71680188e-06)
149649 EPS nconv=0 first unconverged value (error) -302.035 (2.74594417e-06)
149650 EPS nconv=0 first unconverged value (error) -302.035 (2.68295701e-06)
149651 EPS nconv=0 first unconverged value (error) -302.035 (2.19250659e-06)
149652 EPS nconv=0 first unconverged value (error) -302.035 (1.90985854e-06)
149653 EPS nconv=0 first unconverged value (error) -302.035 (1.90985854e-06)
149654 EPS nconv=0 first unconverged value (error) -302.035 (2.43753204e-06)
149655 EPS nconv=0 first unconverged value (error) -302.035 (2.25477477e-06)
149656 EPS nconv=0 first unconverged value (error) -302.035 (2.10865112e-06)
149657 EPS nconv=0 first unconverged value (error) -302.035 (2.04146983e-06)
149658 EPS nconv=0 first unconverged value (error) -302.035 (2.00757639e-06)
149659 EPS nconv=0 first unconverged value (error) -302.035 (2.00757639e-06)
149660 EPS nconv=0 first unconverged value (error) -302.035 (3.01893890e-06)
149661 EPS nconv=0 first unconverged value (error) -302.035 (2.71862881e-06)
149662 EPS nconv=0 first unconverged value (error) -302.035 (2.51030663e-06)
149663 EPS nconv=0 first unconverged value (error) -302.035 (2.49193368e-06)
149664 EPS nconv=0 first unconverged value (error) -302.035 (2.47815355e-06)
149665 EPS nconv=0 first unconverged value (error) -302.035 (2.47815355e-06)
149666 EPS nconv=0 first unconverged value (error) -302.035 (3.30687091e-06)
149667 EPS nconv=0 first unconverged value (error) -302.035 (3.03781758e-06)
149668 EPS nconv=0 first unconverged value (error) -302.035 (2.56249673e-06)
149669 EPS nconv=0 first unconverged value (error) -302.035 (2.47129074e-06)
149670 EPS nconv=0 first unconverged value (error) -302.035 (2.40526196e-06)
149671 EPS nconv=0 first unconverged value (error) -302.035 (2.40526196e-06)
149672 EPS nconv=0 first unconverged value (error) -302.035 (2.39549782e-06)
149673 EPS nconv=0 first unconverged value (error) -302.035 (2.65219837e-06)
149674 EPS nconv=0 first unconverged value (error) -302.035 (2.31094882e-06)
149675 EPS nconv=0 first unconverged value (error) -302.035 (1.95624856e-06)
149676 EPS nconv=0 first unconverged value (error) -302.035 (1.87294455e-06)
149677 EPS nconv=0 first unconverged value (error) -302.035 (1.87294455e-06)
149678 EPS nconv=0 first unconverged value (error) -302.035 (2.64347963e-06)
149679 EPS nconv=0 first unconverged value (error) -302.035 (2.43905172e-06)
149680 EPS nconv=0 first unconverged value (error) -302.035 (2.34216499e-06)
149681 EPS nconv=0 first unconverged value (error) -302.035 (2.33011695e-06)
149682 EPS nconv=0 first unconverged value (error) -302.035 (2.26497863e-06)
149683 EPS nconv=0 first unconverged value (error) -302.035 (2.26497863e-06)
149684 EPS nconv=0 first unconverged value (error) -302.035 (2.24813132e-06)
149685 EPS nconv=0 first unconverged value (error) -302.035 (2.38250078e-06)
149686 EPS nconv=0 first unconverged value (error) -302.035 (2.08710534e-06)
149687 EPS nconv=0 first unconverged value (error) -302.035 (1.89429048e-06)
149688 EPS nconv=0 first unconverged value (error) -302.035 (1.87038252e-06)
149689 EPS nconv=0 first unconverged value (error) -302.035 (1.87038252e-06)
149690 EPS nconv=0 first unconverged value (error) -302.035 (2.59229450e-06)
149691 EPS nconv=0 first unconverged value (error) -302.035 (2.29514947e-06)
149692 EPS nconv=0 first unconverged value (error) -302.035 (2.15148712e-06)
149693 EPS nconv=0 first unconverged value (error) -302.035 (2.06842735e-06)
149694 EPS nconv=0 first unconverged value (error) -302.035 (2.04330464e-06)
149695 EPS nconv=0 first unconverged value (error) -302.035 (2.04330464e-06)
149696 EPS nconv=0 first unconverged value (error) -302.035 (2.95078604e-06)
149697 EPS nconv=0 first unconverged value (error) -302.035 (3.00382178e-06)
149698 EPS nconv=0 first unconverged value (error) -302.035 (2.59945810e-06)
149699 EPS nconv=0 first unconverged value (error) -302.035 (2.44663624e-06)
149700 EPS nconv=0 first unconverged value (error) -302.035 (2.36984091e-06)
149701 EPS nconv=0 first unconverged value (error) -302.035 (2.36984091e-06)
149702 EPS nconv=0 first unconverged value (error) -302.035 (2.45273883e-06)
149703 EPS nconv=0 first unconverged value (error) -302.035 (2.39899792e-06)
149704 EPS nconv=0 first unconverged value (error) -302.035 (2.18681548e-06)
149705 EPS nconv=0 first unconverged value (error) -302.035 (2.02165162e-06)
149706 EPS nconv=0 first unconverged value (error) -302.035 (1.94665250e-06)
149707 EPS nconv=0 first unconverged value (error) -302.035 (1.94665250e-06)
149708 EPS nconv=0 first unconverged value (error) -302.035 (1.94854916e-06)
149709 EPS nconv=0 first unconverged value (error) -302.035 (1.91456408e-06)
149710 EPS nconv=0 first unconverged value (error) -302.035 (1.86434245e-06)
149711 EPS nconv=0 first unconverged value (error) -302.035 (1.83825223e-06)
149712 EPS nconv=0 first unconverged value (error) -302.035 (1.82127637e-06)
149713 EPS nconv=0 first unconverged value (error) -302.035 (1.82127637e-06)
149714 EPS nconv=0 first unconverged value (error) -302.035 (1.89494898e-06)
149715 EPS nconv=0 first unconverged value (error) -302.035 (1.88060066e-06)
149716 EPS nconv=0 first unconverged value (error) -302.035 (1.85631745e-06)
149717 EPS nconv=0 first unconverged value (error) -302.035 (1.83871531e-06)
149718 EPS nconv=0 first unconverged value (error) -302.035 (1.83260013e-06)
149719 EPS nconv=0 first unconverged value (error) -302.035 (1.83260013e-06)
149720 EPS nconv=0 first unconverged value (error) -302.035 (1.96715351e-06)
149721 EPS nconv=0 first unconverged value (error) -302.035 (1.93602857e-06)
149722 EPS nconv=0 first unconverged value (error) -302.035 (1.88977367e-06)
149723 EPS nconv=0 first unconverged value (error) -302.035 (1.88699301e-06)
149724 EPS nconv=0 first unconverged value (error) -302.035 (1.86188150e-06)
149725 EPS nconv=0 first unconverged value (error) -302.035 (1.86188150e-06)
149726 EPS nconv=0 first unconverged value (error) -302.035 (1.90215853e-06)
149727 EPS nconv=0 first unconverged value (error) -302.035 (1.93304208e-06)
149728 EPS nconv=0 first unconverged value (error) -302.035 (1.87591586e-06)
149729 EPS nconv=0 first unconverged value (error) -302.035 (1.84094948e-06)
149730 EPS nconv=0 first unconverged value (error) -302.035 (1.82904275e-06)
149731 EPS nconv=0 first unconverged value (error) -302.035 (1.82904275e-06)
149732 EPS nconv=0 first unconverged value (error) -302.035 (1.81924679e-06)
149733 EPS nconv=0 first unconverged value (error) -302.035 (1.82181038e-06)
149734 EPS nconv=0 first unconverged value (error) -302.035 (1.81008039e-06)
149735 EPS nconv=0 first unconverged value (error) -302.035 (1.80158936e-06)
149736 EPS nconv=0 first unconverged value (error) -302.035 (1.80031139e-06)
149737 EPS nconv=0 first unconverged value (error) -302.035 (1.80031139e-06)
149738 EPS nconv=0 first unconverged value (error) -302.035 (1.87569489e-06)
149739 EPS nconv=0 first unconverged value (error) -302.035 (1.84744123e-06)
149740 EPS nconv=0 first unconverged value (error) -302.035 (1.83554154e-06)
149741 EPS nconv=0 first unconverged value (error) -302.035 (1.82757273e-06)
149742 EPS nconv=0 first unconverged value (error) -302.035 (1.82105502e-06)
149743 EPS nconv=0 first unconverged value (error) -302.035 (1.82105502e-06)
149744 EPS nconv=0 first unconverged value (error) -302.035 (2.57645566e-06)
149745 EPS nconv=0 first unconverged value (error) -302.035 (2.45113398e-06)
149746 EPS nconv=0 first unconverged value (error) -302.035 (2.37650433e-06)
149747 EPS nconv=0 first unconverged value (error) -302.035 (2.33914715e-06)
149748 EPS nconv=0 first unconverged value (error) -302.035 (2.29935133e-06)
149749 EPS nconv=0 first unconverged value (error) -302.035 (2.29935133e-06)
149750 EPS nconv=0 first unconverged value (error) -302.035 (2.34733978e-06)
149751 EPS nconv=0 first unconverged value (error) -302.035 (2.16289753e-06)
149752 EPS nconv=0 first unconverged value (error) -302.035 (2.02141757e-06)
149753 EPS nconv=0 first unconverged value (error) -302.035 (1.91059856e-06)
149754 EPS nconv=0 first unconverged value (error) -302.035 (1.89289738e-06)
149755 EPS nconv=0 first unconverged value (error) -302.035 (1.89289738e-06)
149756 EPS nconv=0 first unconverged value (error) -302.035 (2.93819351e-06)
149757 EPS nconv=0 first unconverged value (error) -302.035 (2.84745997e-06)
149758 EPS nconv=0 first unconverged value (error) -302.035 (2.31962646e-06)
149759 EPS nconv=0 first unconverged value (error) -302.035 (2.28354101e-06)
149760 EPS nconv=0 first unconverged value (error) -302.035 (2.23632919e-06)
149761 EPS nconv=0 first unconverged value (error) -302.035 (2.23632919e-06)
149762 EPS nconv=0 first unconverged value (error) -302.035 (2.38812527e-06)
149763 EPS nconv=0 first unconverged value (error) -302.035 (2.58871860e-06)
149764 EPS nconv=0 first unconverged value (error) -302.035 (2.42746480e-06)
149765 EPS nconv=0 first unconverged value (error) -302.035 (2.01993815e-06)
149766 EPS nconv=0 first unconverged value (error) -302.035 (1.93830391e-06)
149767 EPS nconv=0 first unconverged value (error) -302.035 (1.93830391e-06)
149768 EPS nconv=0 first unconverged value (error) -302.035 (1.93709380e-06)
149769 EPS nconv=0 first unconverged value (error) -302.035 (1.96187078e-06)
149770 EPS nconv=0 first unconverged value (error) -302.035 (1.91123912e-06)
149771 EPS nconv=0 first unconverged value (error) -302.035 (1.83208573e-06)
149772 EPS nconv=0 first unconverged value (error) -302.035 (1.83433298e-06)
149773 EPS nconv=0 first unconverged value (error) -302.035 (1.83433298e-06)
149774 EPS nconv=0 first unconverged value (error) -302.035 (1.87255237e-06)
149775 EPS nconv=0 first unconverged value (error) -302.035 (1.83518005e-06)
149776 EPS nconv=0 first unconverged value (error) -302.035 (1.82871765e-06)
149777 EPS nconv=0 first unconverged value (error) -302.035 (1.82118014e-06)
149778 EPS nconv=0 first unconverged value (error) -302.035 (1.81672518e-06)
149779 EPS nconv=0 first unconverged value (error) -302.035 (1.81672518e-06)
149780 EPS nconv=0 first unconverged value (error) -302.035 (2.04009696e-06)
149781 EPS nconv=0 first unconverged value (error) -302.035 (1.98169184e-06)
149782 EPS nconv=0 first unconverged value (error) -302.035 (1.93262602e-06)
149783 EPS nconv=0 first unconverged value (error) -302.035 (1.88738933e-06)
149784 EPS nconv=0 first unconverged value (error) -302.035 (1.88154802e-06)
149785 EPS nconv=0 first unconverged value (error) -302.035 (1.88154802e-06)
149786 EPS nconv=0 first unconverged value (error) -302.035 (2.00610051e-06)
149787 EPS nconv=0 first unconverged value (error) -302.035 (2.01886186e-06)
149788 EPS nconv=0 first unconverged value (error) -302.035 (1.90196942e-06)
149789 EPS nconv=0 first unconverged value (error) -302.035 (1.91304845e-06)
149790 EPS nconv=0 first unconverged value (error) -302.035 (1.86697198e-06)
149791 EPS nconv=0 first unconverged value (error) -302.035 (1.86697198e-06)
149792 EPS nconv=0 first unconverged value (error) -302.035 (1.86859848e-06)
149793 EPS nconv=0 first unconverged value (error) -302.035 (1.88089578e-06)
149794 EPS nconv=0 first unconverged value (error) -302.035 (1.83048656e-06)
149795 EPS nconv=0 first unconverged value (error) -302.035 (1.81648862e-06)
149796 EPS nconv=0 first unconverged value (error) -302.035 (1.81248102e-06)
149797 EPS nconv=0 first unconverged value (error) -302.035 (1.81248102e-06)
149798 EPS nconv=0 first unconverged value (error) -302.035 (1.80388803e-06)
149799 EPS nconv=0 first unconverged value (error) -302.035 (1.79683603e-06)
149800 EPS nconv=0 first unconverged value (error) -302.035 (1.79543382e-06)
149801 EPS nconv=0 first unconverged value (error) -302.035 (1.79509926e-06)
149802 EPS nconv=0 first unconverged value (error) -302.035 (1.79489414e-06)
149803 EPS nconv=0 first unconverged value (error) -302.035 (1.79489414e-06)
149804 EPS nconv=0 first unconverged value (error) -302.035 (1.99419513e-06)
149805 EPS nconv=0 first unconverged value (error) -302.035 (1.92405190e-06)
149806 EPS nconv=0 first unconverged value (error) -302.035 (1.89347177e-06)
149807 EPS nconv=0 first unconverged value (error) -302.035 (1.87953674e-06)
149808 EPS nconv=0 first unconverged value (error) -302.035 (1.86942835e-06)
149809 EPS nconv=0 first unconverged value (error) -302.035 (1.86942835e-06)
149810 EPS nconv=0 first unconverged value (error) -302.035 (2.07772785e-06)
149811 EPS nconv=0 first unconverged value (error) -302.035 (2.14802168e-06)
149812 EPS nconv=0 first unconverged value (error) -302.035 (2.07309916e-06)
149813 EPS nconv=0 first unconverged value (error) -302.035 (1.93432624e-06)
149814 EPS nconv=0 first unconverged value (error) -302.035 (1.92013929e-06)
149815 EPS nconv=0 first unconverged value (error) -302.035 (1.92013929e-06)
149816 EPS nconv=0 first unconverged value (error) -302.035 (2.19063122e-06)
149817 EPS nconv=0 first unconverged value (error) -302.035 (2.03751534e-06)
149818 EPS nconv=0 first unconverged value (error) -302.035 (1.97437945e-06)
149819 EPS nconv=0 first unconverged value (error) -302.035 (1.96877500e-06)
149820 EPS nconv=0 first unconverged value (error) -302.035 (1.95687002e-06)
149821 EPS nconv=0 first unconverged value (error) -302.035 (1.95687002e-06)
149822 EPS nconv=0 first unconverged value (error) -302.035 (1.95820611e-06)
149823 EPS nconv=0 first unconverged value (error) -302.035 (1.95392804e-06)
149824 EPS nconv=0 first unconverged value (error) -302.035 (1.85240340e-06)
149825 EPS nconv=0 first unconverged value (error) -302.035 (1.82317358e-06)
149826 EPS nconv=0 first unconverged value (error) -302.035 (1.81532132e-06)
149827 EPS nconv=0 first unconverged value (error) -302.035 (1.81532132e-06)
149828 EPS nconv=0 first unconverged value (error) -302.035 (2.07015719e-06)
149829 EPS nconv=0 first unconverged value (error) -302.035 (1.95114470e-06)
149830 EPS nconv=0 first unconverged value (error) -302.035 (1.91240914e-06)
149831 EPS nconv=0 first unconverged value (error) -302.035 (1.90098238e-06)
149832 EPS nconv=0 first unconverged value (error) -302.035 (1.89026915e-06)
149833 EPS nconv=0 first unconverged value (error) -302.035 (1.89026915e-06)
149834 EPS nconv=0 first unconverged value (error) -302.035 (1.98066342e-06)
149835 EPS nconv=0 first unconverged value (error) -302.035 (2.05072567e-06)
149836 EPS nconv=0 first unconverged value (error) -302.035 (1.91862628e-06)
149837 EPS nconv=0 first unconverged value (error) -302.035 (1.87917077e-06)
149838 EPS nconv=0 first unconverged value (error) -302.035 (1.86679004e-06)
149839 EPS nconv=0 first unconverged value (error) -302.035 (1.86679004e-06)
149840 EPS nconv=0 first unconverged value (error) -302.035 (1.85430386e-06)
149841 EPS nconv=0 first unconverged value (error) -302.035 (1.85333964e-06)
149842 EPS nconv=0 first unconverged value (error) -302.035 (1.81811947e-06)
149843 EPS nconv=0 first unconverged value (error) -302.035 (1.80891216e-06)
149844 EPS nconv=0 first unconverged value (error) -302.035 (1.80457273e-06)
149845 EPS nconv=0 first unconverged value (error) -302.035 (1.80457273e-06)
149846 EPS nconv=0 first unconverged value (error) -302.035 (2.98135030e-06)
149847 EPS nconv=0 first unconverged value (error) -302.035 (2.64907112e-06)
149848 EPS nconv=0 first unconverged value (error) -302.035 (2.39795463e-06)
149849 EPS nconv=0 first unconverged value (error) -302.035 (2.31085404e-06)
149850 EPS nconv=0 first unconverged value (error) -302.035 (2.26837162e-06)
149851 EPS nconv=0 first unconverged value (error) -302.035 (2.26837162e-06)
149852 EPS nconv=0 first unconverged value (error) -302.035 (2.68213192e-06)
149853 EPS nconv=0 first unconverged value (error) -302.035 (2.77703534e-06)
149854 EPS nconv=0 first unconverged value (error) -302.035 (2.38837355e-06)
149855 EPS nconv=0 first unconverged value (error) -302.035 (2.17922791e-06)
149856 EPS nconv=0 first unconverged value (error) -302.035 (2.11904558e-06)
149857 EPS nconv=0 first unconverged value (error) -302.035 (2.11904558e-06)
149858 EPS nconv=0 first unconverged value (error) -302.035 (2.21424830e-06)
149859 EPS nconv=0 first unconverged value (error) -302.035 (2.32082749e-06)
149860 EPS nconv=0 first unconverged value (error) -302.035 (2.10599055e-06)
149861 EPS nconv=0 first unconverged value (error) -302.035 (1.92322089e-06)
149862 EPS nconv=0 first unconverged value (error) -302.035 (1.89098300e-06)
149863 EPS nconv=0 first unconverged value (error) -302.035 (1.89098300e-06)
149864 EPS nconv=0 first unconverged value (error) -302.035 (1.91059292e-06)
149865 EPS nconv=0 first unconverged value (error) -302.035 (1.89586279e-06)
149866 EPS nconv=0 first unconverged value (error) -302.035 (1.85024461e-06)
149867 EPS nconv=0 first unconverged value (error) -302.035 (1.82416514e-06)
149868 EPS nconv=0 first unconverged value (error) -302.035 (1.81554670e-06)
149869 EPS nconv=0 first unconverged value (error) -302.035 (1.81554670e-06)
149870 EPS nconv=0 first unconverged value (error) -302.035 (2.08209909e-06)
149871 EPS nconv=0 first unconverged value (error) -302.035 (1.96985299e-06)
149872 EPS nconv=0 first unconverged value (error) -302.035 (1.93355468e-06)
149873 EPS nconv=0 first unconverged value (error) -302.035 (1.91904370e-06)
149874 EPS nconv=0 first unconverged value (error) -302.035 (1.90045257e-06)
149875 EPS nconv=0 first unconverged value (error) -302.035 (1.90045257e-06)
149876 EPS nconv=0 first unconverged value (error) -302.035 (2.14925837e-06)
149877 EPS nconv=0 first unconverged value (error) -302.035 (2.21944039e-06)
149878 EPS nconv=0 first unconverged value (error) -302.035 (2.06512014e-06)
149879 EPS nconv=0 first unconverged value (error) -302.035 (1.97931522e-06)
149880 EPS nconv=0 first unconverged value (error) -302.035 (1.93887011e-06)
149881 EPS nconv=0 first unconverged value (error) -302.035 (1.93887011e-06)
149882 EPS nconv=0 first unconverged value (error) -302.035 (2.64924061e-06)
149883 EPS nconv=0 first unconverged value (error) -302.035 (2.43420517e-06)
149884 EPS nconv=0 first unconverged value (error) -302.035 (2.33267735e-06)
149885 EPS nconv=0 first unconverged value (error) -302.035 (2.33266847e-06)
149886 EPS nconv=0 first unconverged value (error) -302.035 (2.24727570e-06)
149887 EPS nconv=0 first unconverged value (error) -302.035 (2.24727570e-06)
149888 EPS nconv=0 first unconverged value (error) -302.035 (2.22573080e-06)
149889 EPS nconv=0 first unconverged value (error) -302.035 (2.22971682e-06)
149890 EPS nconv=0 first unconverged value (error) -302.035 (1.99900889e-06)
149891 EPS nconv=0 first unconverged value (error) -302.035 (1.91800548e-06)
149892 EPS nconv=0 first unconverged value (error) -302.035 (1.89249000e-06)
149893 EPS nconv=0 first unconverged value (error) -302.035 (1.89249000e-06)
149894 EPS nconv=0 first unconverged value (error) -302.035 (1.80843584e-06)
149895 EPS nconv=0 first unconverged value (error) -302.035 (1.80067819e-06)
149896 EPS nconv=0 first unconverged value (error) -302.035 (1.79799572e-06)
149897 EPS nconv=0 first unconverged value (error) -302.035 (1.79517454e-06)
149898 EPS nconv=0 first unconverged value (error) -302.035 (1.79468739e-06)
149899 EPS nconv=0 first unconverged value (error) -302.035 (1.79468739e-06)
149900 EPS nconv=0 first unconverged value (error) -302.035 (2.29294315e-06)
149901 EPS nconv=0 first unconverged value (error) -302.035 (2.11781596e-06)
149902 EPS nconv=0 first unconverged value (error) -302.035 (2.11055587e-06)
149903 EPS nconv=0 first unconverged value (error) -302.035 (2.08669117e-06)
149904 EPS nconv=0 first unconverged value (error) -302.035 (2.04597430e-06)
149905 EPS nconv=0 first unconverged value (error) -302.035 (2.04597430e-06)
149906 EPS nconv=0 first unconverged value (error) -302.035 (3.62527510e-06)
149907 EPS nconv=0 first unconverged value (error) -302.035 (3.14590583e-06)
149908 EPS nconv=0 first unconverged value (error) -302.035 (2.74858755e-06)
149909 EPS nconv=0 first unconverged value (error) -302.035 (2.66011196e-06)
149910 EPS nconv=0 first unconverged value (error) -302.035 (2.63780847e-06)
149911 EPS nconv=0 first unconverged value (error) -302.035 (2.63780847e-06)
149912 EPS nconv=0 first unconverged value (error) -302.035 (2.65324035e-06)
149913 EPS nconv=0 first unconverged value (error) -302.035 (3.08695658e-06)
149914 EPS nconv=0 first unconverged value (error) -302.035 (2.63185806e-06)
149915 EPS nconv=0 first unconverged value (error) -302.035 (2.31197853e-06)
149916 EPS nconv=0 first unconverged value (error) -302.035 (1.87555434e-06)
149917 EPS nconv=0 first unconverged value (error) -302.035 (1.87555434e-06)
149918 EPS nconv=0 first unconverged value (error) -302.035 (1.90464713e-06)
149919 EPS nconv=0 first unconverged value (error) -302.035 (1.90320755e-06)
149920 EPS nconv=0 first unconverged value (error) -302.035 (1.84471692e-06)
149921 EPS nconv=0 first unconverged value (error) -302.035 (1.81680129e-06)
149922 EPS nconv=0 first unconverged value (error) -302.035 (1.81085306e-06)
149923 EPS nconv=0 first unconverged value (error) -302.035 (1.81085306e-06)
149924 EPS nconv=0 first unconverged value (error) -302.035 (2.70398807e-06)
149925 EPS nconv=0 first unconverged value (error) -302.035 (2.43002141e-06)
149926 EPS nconv=0 first unconverged value (error) -302.035 (2.34604415e-06)
149927 EPS nconv=0 first unconverged value (error) -302.035 (2.28056103e-06)
149928 EPS nconv=0 first unconverged value (error) -302.035 (2.22401814e-06)
149929 EPS nconv=0 first unconverged value (error) -302.035 (2.22401814e-06)
149930 EPS nconv=0 first unconverged value (error) -302.035 (2.50986586e-06)
149931 EPS nconv=0 first unconverged value (error) -302.035 (2.45541881e-06)
149932 EPS nconv=0 first unconverged value (error) -302.035 (2.16394974e-06)
149933 EPS nconv=0 first unconverged value (error) -302.035 (2.09005110e-06)
149934 EPS nconv=0 first unconverged value (error) -302.035 (2.08185013e-06)
149935 EPS nconv=0 first unconverged value (error) -302.035 (2.08185013e-06)
149936 EPS nconv=0 first unconverged value (error) -302.035 (2.22950879e-06)
149937 EPS nconv=0 first unconverged value (error) -302.035 (2.15383498e-06)
149938 EPS nconv=0 first unconverged value (error) -302.035 (2.00752096e-06)
149939 EPS nconv=0 first unconverged value (error) -302.035 (1.94812852e-06)
149940 EPS nconv=0 first unconverged value (error) -302.035 (1.88591761e-06)
149941 EPS nconv=0 first unconverged value (error) -302.035 (1.88591761e-06)
149942 EPS nconv=0 first unconverged value (error) -302.035 (2.48383973e-06)
149943 EPS nconv=0 first unconverged value (error) -302.035 (2.31034474e-06)
149944 EPS nconv=0 first unconverged value (error) -302.035 (2.13453857e-06)
149945 EPS nconv=0 first unconverged value (error) -302.035 (2.08391626e-06)
149946 EPS nconv=0 first unconverged value (error) -302.035 (2.06164907e-06)
149947 EPS nconv=0 first unconverged value (error) -302.035 (2.06164907e-06)
149948 EPS nconv=0 first unconverged value (error) -302.035 (2.77335366e-06)
149949 EPS nconv=0 first unconverged value (error) -302.035 (2.66272693e-06)
149950 EPS nconv=0 first unconverged value (error) -302.035 (2.37665050e-06)
149951 EPS nconv=0 first unconverged value (error) -302.035 (2.26248764e-06)
149952 EPS nconv=0 first unconverged value (error) -302.035 (2.20537753e-06)
149953 EPS nconv=0 first unconverged value (error) -302.035 (2.20537753e-06)
149954 EPS nconv=0 first unconverged value (error) -302.035 (2.69476942e-06)
149955 EPS nconv=0 first unconverged value (error) -302.035 (2.42754393e-06)
149956 EPS nconv=0 first unconverged value (error) -302.035 (2.17591858e-06)
149957 EPS nconv=0 first unconverged value (error) -302.035 (2.10795949e-06)
149958 EPS nconv=0 first unconverged value (error) -302.035 (2.06338785e-06)
149959 EPS nconv=0 first unconverged value (error) -302.035 (2.06338785e-06)
149960 EPS nconv=0 first unconverged value (error) -302.035 (2.01915600e-06)
149961 EPS nconv=0 first unconverged value (error) -302.035 (2.19199691e-06)
149962 EPS nconv=0 first unconverged value (error) -302.035 (1.94027041e-06)
149963 EPS nconv=0 first unconverged value (error) -302.035 (1.86399221e-06)
149964 EPS nconv=0 first unconverged value (error) -302.035 (1.83193969e-06)
149965 EPS nconv=0 first unconverged value (error) -302.035 (1.83193969e-06)
149966 EPS nconv=0 first unconverged value (error) -302.035 (2.24916025e-06)
149967 EPS nconv=0 first unconverged value (error) -302.035 (2.06927794e-06)
149968 EPS nconv=0 first unconverged value (error) -302.035 (1.96585854e-06)
149969 EPS nconv=0 first unconverged value (error) -302.035 (1.96946253e-06)
149970 EPS nconv=0 first unconverged value (error) -302.035 (1.94499015e-06)
149971 EPS nconv=0 first unconverged value (error) -302.035 (1.94499015e-06)
149972 EPS nconv=0 first unconverged value (error) -302.035 (2.65610822e-06)
149973 EPS nconv=0 first unconverged value (error) -302.035 (2.48512421e-06)
149974 EPS nconv=0 first unconverged value (error) -302.035 (2.23936702e-06)
149975 EPS nconv=0 first unconverged value (error) -302.035 (2.20911604e-06)
149976 EPS nconv=0 first unconverged value (error) -302.035 (2.19453223e-06)
149977 EPS nconv=0 first unconverged value (error) -302.035 (2.19453223e-06)
149978 EPS nconv=0 first unconverged value (error) -302.035 (3.11689102e-06)
149979 EPS nconv=0 first unconverged value (error) -302.035 (2.74141578e-06)
149980 EPS nconv=0 first unconverged value (error) -302.035 (2.52260626e-06)
149981 EPS nconv=0 first unconverged value (error) -302.035 (2.37158467e-06)
149982 EPS nconv=0 first unconverged value (error) -302.035 (2.26232758e-06)
149983 EPS nconv=0 first unconverged value (error) -302.035 (2.26232758e-06)
149984 EPS nconv=0 first unconverged value (error) -302.035 (3.99447223e-06)
149985 EPS nconv=0 first unconverged value (error) -302.035 (3.44686987e-06)
149986 EPS nconv=0 first unconverged value (error) -302.035 (2.78748029e-06)
149987 EPS nconv=0 first unconverged value (error) -302.035 (2.81581970e-06)
149988 EPS nconv=0 first unconverged value (error) -302.035 (2.63729330e-06)
149989 EPS nconv=0 first unconverged value (error) -302.035 (2.63729330e-06)
149990 EPS nconv=0 first unconverged value (error) -302.035 (3.50932198e-06)
149991 EPS nconv=0 first unconverged value (error) -302.035 (3.58488751e-06)
149992 EPS nconv=0 first unconverged value (error) -302.035 (2.87502866e-06)
149993 EPS nconv=0 first unconverged value (error) -302.035 (2.64823981e-06)
149994 EPS nconv=0 first unconverged value (error) -302.035 (2.57561407e-06)
149995 EPS nconv=0 first unconverged value (error) -302.035 (2.57561407e-06)
149996 EPS nconv=0 first unconverged value (error) -302.035 (2.80381332e-06)
149997 EPS nconv=0 first unconverged value (error) -302.035 (2.89820455e-06)
149998 EPS nconv=0 first unconverged value (error) -302.035 (2.59502564e-06)
149999 EPS nconv=0 first unconverged value (error) -302.035 (2.08313733e-06)
150000 EPS nconv=0 first unconverged value (error) -302.035 (2.00026038e-06)
150001 EPS nconv=0 first unconverged value (error) -302.035 (2.00026038e-06)
150002 EPS nconv=0 first unconverged value (error) -302.035 (4.42370023e-06)
150003 EPS nconv=0 first unconverged value (error) -302.035 (3.62538025e-06)
150004 EPS nconv=0 first unconverged value (error) -302.035 (3.11409686e-06)
150005 EPS nconv=0 first unconverged value (error) -302.035 (3.02080139e-06)
150006 EPS nconv=0 first unconverged value (error) -302.035 (2.94144804e-06)
150007 EPS nconv=0 first unconverged value (error) -302.035 (2.94144804e-06)
150008 EPS nconv=0 first unconverged value (error) -302.035 (4.64070918e-06)
150009 EPS nconv=0 first unconverged value (error) -302.035 (4.58216267e-06)
150010 EPS nconv=0 first unconverged value (error) -302.035 (3.47834679e-06)
150011 EPS nconv=0 first unconverged value (error) -302.035 (3.39900567e-06)
150012 EPS nconv=0 first unconverged value (error) -302.035 (3.25147949e-06)
150013 EPS nconv=0 first unconverged value (error) -302.035 (3.25147949e-06)
150014 EPS nconv=0 first unconverged value (error) -302.035 (3.16733716e-06)
150015 EPS nconv=0 first unconverged value (error) -302.035 (3.57989446e-06)
150016 EPS nconv=0 first unconverged value (error) -302.035 (2.83968798e-06)
150017 EPS nconv=0 first unconverged value (error) -302.035 (2.11522508e-06)
150018 EPS nconv=0 first unconverged value (error) -302.035 (2.01461753e-06)
150019 EPS nconv=0 first unconverged value (error) -302.035 (2.01461753e-06)
150020 EPS nconv=0 first unconverged value (error) -302.035 (1.91075285e-06)
150021 EPS nconv=0 first unconverged value (error) -302.035 (1.83141585e-06)
150022 EPS nconv=0 first unconverged value (error) -302.035 (1.81423398e-06)
150023 EPS nconv=0 first unconverged value (error) -302.035 (1.80755343e-06)
150024 EPS nconv=0 first unconverged value (error) -302.035 (1.80025309e-06)
150025 EPS nconv=0 first unconverged value (error) -302.035 (1.80025309e-06)
150026 EPS nconv=0 first unconverged value (error) -302.035 (3.03676646e-06)
150027 EPS nconv=0 first unconverged value (error) -302.035 (2.78270339e-06)
150028 EPS nconv=0 first unconverged value (error) -302.035 (2.52390614e-06)
150029 EPS nconv=0 first unconverged value (error) -302.035 (2.45754867e-06)
150030 EPS nconv=0 first unconverged value (error) -302.035 (2.40774074e-06)
150031 EPS nconv=0 first unconverged value (error) -302.035 (2.40774074e-06)
150032 EPS nconv=0 first unconverged value (error) -302.035 (4.34903229e-06)
150033 EPS nconv=0 first unconverged value (error) -302.035 (3.92577270e-06)
150034 EPS nconv=0 first unconverged value (error) -302.035 (3.28093893e-06)
150035 EPS nconv=0 first unconverged value (error) -302.035 (3.23332379e-06)
150036 EPS nconv=0 first unconverged value (error) -302.035 (3.19140908e-06)
150037 EPS nconv=0 first unconverged value (error) -302.035 (3.19140908e-06)
150038 EPS nconv=0 first unconverged value (error) -302.035 (3.33138604e-06)
150039 EPS nconv=0 first unconverged value (error) -302.035 (3.50220079e-06)
150040 EPS nconv=0 first unconverged value (error) -302.035 (3.04626436e-06)
150041 EPS nconv=0 first unconverged value (error) -302.035 (2.31598569e-06)
150042 EPS nconv=0 first unconverged value (error) -302.035 (2.12359273e-06)
150043 EPS nconv=0 first unconverged value (error) -302.035 (2.12359273e-06)
150044 EPS nconv=0 first unconverged value (error) -302.035 (1.97308261e-06)
150045 EPS nconv=0 first unconverged value (error) -302.035 (2.03546248e-06)
150046 EPS nconv=0 first unconverged value (error) -302.035 (1.98487674e-06)
150047 EPS nconv=0 first unconverged value (error) -302.035 (1.86341087e-06)
150048 EPS nconv=0 first unconverged value (error) -302.035 (1.82544836e-06)
150049 EPS nconv=0 first unconverged value (error) -302.035 (1.82544836e-06)
150050 EPS nconv=0 first unconverged value (error) -302.035 (1.85539329e-06)
150051 EPS nconv=0 first unconverged value (error) -302.035 (1.84472965e-06)
150052 EPS nconv=0 first unconverged value (error) -302.035 (1.83020180e-06)
150053 EPS nconv=0 first unconverged value (error) -302.035 (1.83012095e-06)
150054 EPS nconv=0 first unconverged value (error) -302.035 (1.82523955e-06)
150055 EPS nconv=0 first unconverged value (error) -302.035 (1.82523955e-06)
150056 EPS nconv=0 first unconverged value (error) -302.035 (2.87077356e-06)
150057 EPS nconv=0 first unconverged value (error) -302.035 (2.59652760e-06)
150058 EPS nconv=0 first unconverged value (error) -302.035 (2.41372768e-06)
150059 EPS nconv=0 first unconverged value (error) -302.035 (2.31284606e-06)
150060 EPS nconv=0 first unconverged value (error) -302.035 (2.22737293e-06)
150061 EPS nconv=0 first unconverged value (error) -302.035 (2.22737293e-06)
150062 EPS nconv=0 first unconverged value (error) -302.035 (2.81352390e-06)
150063 EPS nconv=0 first unconverged value (error) -302.035 (2.81551054e-06)
150064 EPS nconv=0 first unconverged value (error) -302.035 (2.42927330e-06)
150065 EPS nconv=0 first unconverged value (error) -302.035 (2.17150409e-06)
150066 EPS nconv=0 first unconverged value (error) -302.035 (2.09686305e-06)
150067 EPS nconv=0 first unconverged value (error) -302.035 (2.09686305e-06)
150068 EPS nconv=0 first unconverged value (error) -302.035 (2.11234491e-06)
150069 EPS nconv=0 first unconverged value (error) -302.035 (2.23426014e-06)
150070 EPS nconv=0 first unconverged value (error) -302.035 (2.02667224e-06)
150071 EPS nconv=0 first unconverged value (error) -302.035 (1.89097141e-06)
150072 EPS nconv=0 first unconverged value (error) -302.035 (1.86394535e-06)
150073 EPS nconv=0 first unconverged value (error) -302.035 (1.86394535e-06)
150074 EPS nconv=0 first unconverged value (error) -302.035 (1.84173206e-06)
150075 EPS nconv=0 first unconverged value (error) -302.035 (1.85196759e-06)
150076 EPS nconv=0 first unconverged value (error) -302.035 (1.82011789e-06)
150077 EPS nconv=0 first unconverged value (error) -302.035 (1.80496269e-06)
150078 EPS nconv=0 first unconverged value (error) -302.035 (1.80561348e-06)
150079 EPS nconv=0 first unconverged value (error) -302.035 (1.80561348e-06)
150080 EPS nconv=0 first unconverged value (error) -302.035 (1.86052932e-06)
150081 EPS nconv=0 first unconverged value (error) -302.035 (1.83147097e-06)
150082 EPS nconv=0 first unconverged value (error) -302.035 (1.82038967e-06)
150083 EPS nconv=0 first unconverged value (error) -302.035 (1.81724528e-06)
150084 EPS nconv=0 first unconverged value (error) -302.035 (1.81468949e-06)
150085 EPS nconv=0 first unconverged value (error) -302.035 (1.81468949e-06)
150086 EPS nconv=0 first unconverged value (error) -302.035 (2.39095691e-06)
150087 EPS nconv=0 first unconverged value (error) -302.035 (2.22268151e-06)
150088 EPS nconv=0 first unconverged value (error) -302.035 (2.12296185e-06)
150089 EPS nconv=0 first unconverged value (error) -302.035 (2.08510650e-06)
150090 EPS nconv=0 first unconverged value (error) -302.035 (2.04851910e-06)
150091 EPS nconv=0 first unconverged value (error) -302.035 (2.04851910e-06)
150092 EPS nconv=0 first unconverged value (error) -302.035 (3.33136714e-06)
150093 EPS nconv=0 first unconverged value (error) -302.035 (3.07812423e-06)
150094 EPS nconv=0 first unconverged value (error) -302.035 (2.77899157e-06)
150095 EPS nconv=0 first unconverged value (error) -302.035 (2.73904201e-06)
150096 EPS nconv=0 first unconverged value (error) -302.035 (2.70926373e-06)
150097 EPS nconv=0 first unconverged value (error) -302.035 (2.70926373e-06)
150098 EPS nconv=0 first unconverged value (error) -302.035 (3.85414016e-06)
150099 EPS nconv=0 first unconverged value (error) -302.035 (3.49725295e-06)
150100 EPS nconv=0 first unconverged value (error) -302.035 (2.96873753e-06)
150101 EPS nconv=0 first unconverged value (error) -302.035 (2.94276198e-06)
150102 EPS nconv=0 first unconverged value (error) -302.035 (2.69954827e-06)
150103 EPS nconv=0 first unconverged value (error) -302.035 (2.69954827e-06)
150104 EPS nconv=0 first unconverged value (error) -302.035 (3.01825568e-06)
150105 EPS nconv=0 first unconverged value (error) -302.035 (3.11460263e-06)
150106 EPS nconv=0 first unconverged value (error) -302.035 (2.64020053e-06)
150107 EPS nconv=0 first unconverged value (error) -302.035 (2.30151311e-06)
150108 EPS nconv=0 first unconverged value (error) -302.035 (2.20878128e-06)
150109 EPS nconv=0 first unconverged value (error) -302.035 (2.20878128e-06)
150110 EPS nconv=0 first unconverged value (error) -302.035 (2.14763173e-06)
150111 EPS nconv=0 first unconverged value (error) -302.035 (2.27200205e-06)
150112 EPS nconv=0 first unconverged value (error) -302.035 (2.13939165e-06)
150113 EPS nconv=0 first unconverged value (error) -302.035 (1.94463987e-06)
150114 EPS nconv=0 first unconverged value (error) -302.035 (1.87538604e-06)
150115 EPS nconv=0 first unconverged value (error) -302.035 (1.87538604e-06)
150116 EPS nconv=0 first unconverged value (error) -302.035 (3.04545126e-06)
150117 EPS nconv=0 first unconverged value (error) -302.035 (2.73977470e-06)
150118 EPS nconv=0 first unconverged value (error) -302.035 (2.62483561e-06)
150119 EPS nconv=0 first unconverged value (error) -302.035 (2.47359547e-06)
150120 EPS nconv=0 first unconverged value (error) -302.035 (2.39183444e-06)
150121 EPS nconv=0 first unconverged value (error) -302.035 (2.39183444e-06)
150122 EPS nconv=0 first unconverged value (error) -302.035 (3.73227826e-06)
150123 EPS nconv=0 first unconverged value (error) -302.035 (3.40055348e-06)
150124 EPS nconv=0 first unconverged value (error) -302.035 (2.93758217e-06)
150125 EPS nconv=0 first unconverged value (error) -302.035 (2.90169879e-06)
150126 EPS nconv=0 first unconverged value (error) -302.035 (2.87750820e-06)
150127 EPS nconv=0 first unconverged value (error) -302.035 (2.87750820e-06)
150128 EPS nconv=0 first unconverged value (error) -302.035 (3.86248339e-06)
150129 EPS nconv=0 first unconverged value (error) -302.035 (3.49260864e-06)
150130 EPS nconv=0 first unconverged value (error) -302.035 (2.87150380e-06)
150131 EPS nconv=0 first unconverged value (error) -302.035 (2.76920828e-06)
150132 EPS nconv=0 first unconverged value (error) -302.035 (2.63136084e-06)
150133 EPS nconv=0 first unconverged value (error) -302.035 (2.63136084e-06)
150134 EPS nconv=0 first unconverged value (error) -302.035 (3.21338490e-06)
150135 EPS nconv=0 first unconverged value (error) -302.035 (3.37222108e-06)
150136 EPS nconv=0 first unconverged value (error) -302.035 (2.81066360e-06)
150137 EPS nconv=0 first unconverged value (error) -302.035 (2.26525460e-06)
150138 EPS nconv=0 first unconverged value (error) -302.035 (2.19117618e-06)
150139 EPS nconv=0 first unconverged value (error) -302.035 (2.19117618e-06)
150140 EPS nconv=0 first unconverged value (error) -302.035 (2.16893130e-06)
150141 EPS nconv=0 first unconverged value (error) -302.035 (2.57201066e-06)
150142 EPS nconv=0 first unconverged value (error) -302.035 (2.19269786e-06)
150143 EPS nconv=0 first unconverged value (error) -302.035 (1.96030090e-06)
150144 EPS nconv=0 first unconverged value (error) -302.035 (1.86039556e-06)
150145 EPS nconv=0 first unconverged value (error) -302.035 (1.86039556e-06)
150146 EPS nconv=0 first unconverged value (error) -302.035 (2.02522993e-06)
150147 EPS nconv=0 first unconverged value (error) -302.035 (1.99594112e-06)
150148 EPS nconv=0 first unconverged value (error) -302.035 (1.95957699e-06)
150149 EPS nconv=0 first unconverged value (error) -302.035 (1.95214304e-06)
150150 EPS nconv=0 first unconverged value (error) -302.035 (1.92168593e-06)
150151 EPS nconv=0 first unconverged value (error) -302.035 (1.92168593e-06)
150152 EPS nconv=0 first unconverged value (error) -302.035 (2.13657915e-06)
150153 EPS nconv=0 first unconverged value (error) -302.035 (2.07354673e-06)
150154 EPS nconv=0 first unconverged value (error) -302.035 (1.96820310e-06)
150155 EPS nconv=0 first unconverged value (error) -302.035 (1.95834836e-06)
150156 EPS nconv=0 first unconverged value (error) -302.035 (1.95563667e-06)
150157 EPS nconv=0 first unconverged value (error) -302.035 (1.95563667e-06)
150158 EPS nconv=0 first unconverged value (error) -302.035 (2.64507730e-06)
150159 EPS nconv=0 first unconverged value (error) -302.035 (2.38946135e-06)
150160 EPS nconv=0 first unconverged value (error) -302.035 (2.26916680e-06)
150161 EPS nconv=0 first unconverged value (error) -302.035 (2.08944610e-06)
150162 EPS nconv=0 first unconverged value (error) -302.035 (2.06293475e-06)
150163 EPS nconv=0 first unconverged value (error) -302.035 (2.06293475e-06)
150164 EPS nconv=0 first unconverged value (error) -302.035 (2.58230941e-06)
150165 EPS nconv=0 first unconverged value (error) -302.035 (2.56212616e-06)
150166 EPS nconv=0 first unconverged value (error) -302.035 (2.24857855e-06)
150167 EPS nconv=0 first unconverged value (error) -302.035 (2.08699525e-06)
150168 EPS nconv=0 first unconverged value (error) -302.035 (2.03183103e-06)
150169 EPS nconv=0 first unconverged value (error) -302.035 (2.03183103e-06)
150170 EPS nconv=0 first unconverged value (error) -302.035 (2.63133571e-06)
150171 EPS nconv=0 first unconverged value (error) -302.035 (2.43662873e-06)
150172 EPS nconv=0 first unconverged value (error) -302.035 (2.20794158e-06)
150173 EPS nconv=0 first unconverged value (error) -302.035 (2.17820653e-06)
150174 EPS nconv=0 first unconverged value (error) -302.035 (2.10751661e-06)
150175 EPS nconv=0 first unconverged value (error) -302.035 (2.10751661e-06)
150176 EPS nconv=0 first unconverged value (error) -302.035 (2.55494895e-06)
150177 EPS nconv=0 first unconverged value (error) -302.035 (2.55356409e-06)
150178 EPS nconv=0 first unconverged value (error) -302.035 (2.14702126e-06)
150179 EPS nconv=0 first unconverged value (error) -302.035 (2.10144701e-06)
150180 EPS nconv=0 first unconverged value (error) -302.035 (2.08794389e-06)
150181 EPS nconv=0 first unconverged value (error) -302.035 (2.08794389e-06)
150182 EPS nconv=0 first unconverged value (error) -302.035 (2.11651047e-06)
150183 EPS nconv=0 first unconverged value (error) -302.035 (2.13290235e-06)
150184 EPS nconv=0 first unconverged value (error) -302.035 (2.04819135e-06)
150185 EPS nconv=0 first unconverged value (error) -302.035 (1.88247062e-06)
150186 EPS nconv=0 first unconverged value (error) -302.035 (1.86591782e-06)
150187 EPS nconv=0 first unconverged value (error) -302.035 (1.86591782e-06)
150188 EPS nconv=0 first unconverged value (error) -302.035 (1.84126632e-06)
150189 EPS nconv=0 first unconverged value (error) -302.035 (1.88985742e-06)
150190 EPS nconv=0 first unconverged value (error) -302.035 (1.82846372e-06)
150191 EPS nconv=0 first unconverged value (error) -302.035 (1.80661318e-06)
150192 EPS nconv=0 first unconverged value (error) -302.035 (1.80423598e-06)
150193 EPS nconv=0 first unconverged value (error) -302.035 (1.80423598e-06)
150194 EPS nconv=0 first unconverged value (error) -302.035 (1.93860120e-06)
150195 EPS nconv=0 first unconverged value (error) -302.035 (1.88113614e-06)
150196 EPS nconv=0 first unconverged value (error) -302.035 (1.87209084e-06)
150197 EPS nconv=0 first unconverged value (error) -302.035 (1.87195564e-06)
150198 EPS nconv=0 first unconverged value (error) -302.035 (1.85404817e-06)
150199 EPS nconv=0 first unconverged value (error) -302.035 (1.85404817e-06)
150200 EPS nconv=0 first unconverged value (error) -302.035 (1.94015042e-06)
150201 EPS nconv=0 first unconverged value (error) -302.035 (1.98828017e-06)
150202 EPS nconv=0 first unconverged value (error) -302.035 (1.93168577e-06)
150203 EPS nconv=0 first unconverged value (error) -302.035 (1.86993482e-06)
150204 EPS nconv=0 first unconverged value (error) -302.035 (1.86382183e-06)
150205 EPS nconv=0 first unconverged value (error) -302.035 (1.86382183e-06)
150206 EPS nconv=0 first unconverged value (error) -302.035 (2.58126336e-06)
150207 EPS nconv=0 first unconverged value (error) -302.035 (2.26542425e-06)
150208 EPS nconv=0 first unconverged value (error) -302.035 (2.17577496e-06)
150209 EPS nconv=0 first unconverged value (error) -302.035 (2.14321121e-06)
150210 EPS nconv=0 first unconverged value (error) -302.035 (2.08274144e-06)
150211 EPS nconv=0 first unconverged value (error) -302.035 (2.08274144e-06)
150212 EPS nconv=0 first unconverged value (error) -302.035 (2.70455934e-06)
150213 EPS nconv=0 first unconverged value (error) -302.035 (2.62514560e-06)
150214 EPS nconv=0 first unconverged value (error) -302.035 (2.34617002e-06)
150215 EPS nconv=0 first unconverged value (error) -302.035 (2.31819580e-06)
150216 EPS nconv=0 first unconverged value (error) -302.035 (2.29199801e-06)
150217 EPS nconv=0 first unconverged value (error) -302.035 (2.29199801e-06)
150218 EPS nconv=0 first unconverged value (error) -302.035 (2.24552779e-06)
150219 EPS nconv=0 first unconverged value (error) -302.035 (2.29467980e-06)
150220 EPS nconv=0 first unconverged value (error) -302.035 (2.17832702e-06)
150221 EPS nconv=0 first unconverged value (error) -302.035 (1.97657369e-06)
150222 EPS nconv=0 first unconverged value (error) -302.035 (1.87677655e-06)
150223 EPS nconv=0 first unconverged value (error) -302.035 (1.87677655e-06)
150224 EPS nconv=0 first unconverged value (error) -302.035 (3.28423409e-06)
150225 EPS nconv=0 first unconverged value (error) -302.035 (2.96434267e-06)
150226 EPS nconv=0 first unconverged value (error) -302.035 (2.65179700e-06)
150227 EPS nconv=0 first unconverged value (error) -302.035 (2.53201189e-06)
150228 EPS nconv=0 first unconverged value (error) -302.035 (2.46151453e-06)
150229 EPS nconv=0 first unconverged value (error) -302.035 (2.46151453e-06)
150230 EPS nconv=0 first unconverged value (error) -302.035 (4.75959697e-06)
150231 EPS nconv=0 first unconverged value (error) -302.035 (4.40127051e-06)
150232 EPS nconv=0 first unconverged value (error) -302.035 (3.87927640e-06)
150233 EPS nconv=0 first unconverged value (error) -302.035 (3.76554560e-06)
150234 EPS nconv=0 first unconverged value (error) -302.035 (3.63671672e-06)
150235 EPS nconv=0 first unconverged value (error) -302.035 (3.63671672e-06)
150236 EPS nconv=0 first unconverged value (error) -302.035 (4.00711244e-06)
150237 EPS nconv=0 first unconverged value (error) -302.035 (3.81286614e-06)
150238 EPS nconv=0 first unconverged value (error) -302.035 (3.19979110e-06)
150239 EPS nconv=0 first unconverged value (error) -302.035 (2.77149122e-06)
150240 EPS nconv=0 first unconverged value (error) -302.035 (2.74073276e-06)
150241 EPS nconv=0 first unconverged value (error) -302.035 (2.74073276e-06)
150242 EPS nconv=0 first unconverged value (error) -302.035 (2.77893867e-06)
150243 EPS nconv=0 first unconverged value (error) -302.035 (2.79276952e-06)
150244 EPS nconv=0 first unconverged value (error) -302.035 (2.49906323e-06)
150245 EPS nconv=0 first unconverged value (error) -302.035 (2.10639373e-06)
150246 EPS nconv=0 first unconverged value (error) -302.035 (2.01887332e-06)
150247 EPS nconv=0 first unconverged value (error) -302.035 (2.01887332e-06)
150248 EPS nconv=0 first unconverged value (error) -302.035 (2.10589263e-06)
150249 EPS nconv=0 first unconverged value (error) -302.035 (2.25487746e-06)
150250 EPS nconv=0 first unconverged value (error) -302.035 (2.00834688e-06)
150251 EPS nconv=0 first unconverged value (error) -302.035 (1.89410856e-06)
150252 EPS nconv=0 first unconverged value (error) -302.035 (1.86137305e-06)
150253 EPS nconv=0 first unconverged value (error) -302.035 (1.86137305e-06)
150254 EPS nconv=0 first unconverged value (error) -302.035 (1.84228915e-06)
150255 EPS nconv=0 first unconverged value (error) -302.035 (1.86624496e-06)
150256 EPS nconv=0 first unconverged value (error) -302.035 (1.81800620e-06)
150257 EPS nconv=0 first unconverged value (error) -302.035 (1.80232757e-06)
150258 EPS nconv=0 first unconverged value (error) -302.035 (1.80190872e-06)
150259 EPS nconv=0 first unconverged value (error) -302.035 (1.80190872e-06)
150260 EPS nconv=0 first unconverged value (error) -302.035 (1.80989319e-06)
150261 EPS nconv=0 first unconverged value (error) -302.035 (1.80302956e-06)
150262 EPS nconv=0 first unconverged value (error) -302.035 (1.80167063e-06)
150263 EPS nconv=0 first unconverged value (error) -302.035 (1.80140746e-06)
150264 EPS nconv=0 first unconverged value (error) -302.035 (1.80031523e-06)
150265 EPS nconv=0 first unconverged value (error) -302.035 (1.80031523e-06)
150266 EPS nconv=0 first unconverged value (error) -302.035 (1.88607270e-06)
150267 EPS nconv=0 first unconverged value (error) -302.035 (1.89725562e-06)
150268 EPS nconv=0 first unconverged value (error) -302.035 (1.87053835e-06)
150269 EPS nconv=0 first unconverged value (error) -302.035 (1.84600852e-06)
150270 EPS nconv=0 first unconverged value (error) -302.035 (1.84168480e-06)
150271 EPS nconv=0 first unconverged value (error) -302.035 (1.84168480e-06)
150272 EPS nconv=0 first unconverged value (error) -302.035 (1.99602582e-06)
150273 EPS nconv=0 first unconverged value (error) -302.035 (1.92510343e-06)
150274 EPS nconv=0 first unconverged value (error) -302.035 (1.89492119e-06)
150275 EPS nconv=0 first unconverged value (error) -302.035 (1.88430666e-06)
150276 EPS nconv=0 first unconverged value (error) -302.035 (1.87893158e-06)
150277 EPS nconv=0 first unconverged value (error) -302.035 (1.87893158e-06)
150278 EPS nconv=0 first unconverged value (error) -302.035 (1.92207988e-06)
150279 EPS nconv=0 first unconverged value (error) -302.035 (1.91714149e-06)
150280 EPS nconv=0 first unconverged value (error) -302.035 (1.86143626e-06)
150281 EPS nconv=0 first unconverged value (error) -302.035 (1.85319751e-06)
150282 EPS nconv=0 first unconverged value (error) -302.035 (1.84313993e-06)
150283 EPS nconv=0 first unconverged value (error) -302.035 (1.84313993e-06)
150284 EPS nconv=0 first unconverged value (error) -302.035 (1.83200094e-06)
150285 EPS nconv=0 first unconverged value (error) -302.035 (1.82455790e-06)
150286 EPS nconv=0 first unconverged value (error) -302.035 (1.81046737e-06)
150287 EPS nconv=0 first unconverged value (error) -302.035 (1.80182136e-06)
150288 EPS nconv=0 first unconverged value (error) -302.035 (1.79802161e-06)
150289 EPS nconv=0 first unconverged value (error) -302.035 (1.79802161e-06)
150290 EPS nconv=0 first unconverged value (error) -302.035 (2.36200064e-06)
150291 EPS nconv=0 first unconverged value (error) -302.035 (2.16685554e-06)
150292 EPS nconv=0 first unconverged value (error) -302.035 (2.07407860e-06)
150293 EPS nconv=0 first unconverged value (error) -302.035 (2.03449427e-06)
150294 EPS nconv=0 first unconverged value (error) -302.035 (2.01293061e-06)
150295 EPS nconv=0 first unconverged value (error) -302.035 (2.01293061e-06)
150296 EPS nconv=0 first unconverged value (error) -302.035 (2.83392095e-06)
150297 EPS nconv=0 first unconverged value (error) -302.035 (2.69152700e-06)
150298 EPS nconv=0 first unconverged value (error) -302.035 (2.47306830e-06)
150299 EPS nconv=0 first unconverged value (error) -302.035 (2.44044426e-06)
150300 EPS nconv=0 first unconverged value (error) -302.035 (2.40708876e-06)
150301 EPS nconv=0 first unconverged value (error) -302.035 (2.40708876e-06)
150302 EPS nconv=0 first unconverged value (error) -302.035 (2.38696642e-06)
150303 EPS nconv=0 first unconverged value (error) -302.035 (2.28718912e-06)
150304 EPS nconv=0 first unconverged value (error) -302.035 (2.06191904e-06)
150305 EPS nconv=0 first unconverged value (error) -302.035 (1.89266132e-06)
150306 EPS nconv=0 first unconverged value (error) -302.035 (1.83264910e-06)
150307 EPS nconv=0 first unconverged value (error) -302.035 (1.83264910e-06)
150308 EPS nconv=0 first unconverged value (error) -302.035 (2.21065524e-06)
150309 EPS nconv=0 first unconverged value (error) -302.035 (2.04963345e-06)
150310 EPS nconv=0 first unconverged value (error) -302.035 (1.92848178e-06)
150311 EPS nconv=0 first unconverged value (error) -302.035 (1.90293969e-06)
150312 EPS nconv=0 first unconverged value (error) -302.035 (1.89446834e-06)
150313 EPS nconv=0 first unconverged value (error) -302.035 (1.89446834e-06)
150314 EPS nconv=0 first unconverged value (error) -302.035 (1.97781534e-06)
150315 EPS nconv=0 first unconverged value (error) -302.035 (2.00591042e-06)
150316 EPS nconv=0 first unconverged value (error) -302.035 (1.92763811e-06)
150317 EPS nconv=0 first unconverged value (error) -302.035 (1.87001624e-06)
150318 EPS nconv=0 first unconverged value (error) -302.035 (1.84663746e-06)
150319 EPS nconv=0 first unconverged value (error) -302.035 (1.84663746e-06)
150320 EPS nconv=0 first unconverged value (error) -302.035 (2.23893292e-06)
150321 EPS nconv=0 first unconverged value (error) -302.035 (2.15924111e-06)
150322 EPS nconv=0 first unconverged value (error) -302.035 (2.04035353e-06)
150323 EPS nconv=0 first unconverged value (error) -302.035 (2.03177708e-06)
150324 EPS nconv=0 first unconverged value (error) -302.035 (2.01478383e-06)
150325 EPS nconv=0 first unconverged value (error) -302.035 (2.01478383e-06)
150326 EPS nconv=0 first unconverged value (error) -302.035 (2.07624008e-06)
150327 EPS nconv=0 first unconverged value (error) -302.035 (2.02524232e-06)
150328 EPS nconv=0 first unconverged value (error) -302.035 (1.93252379e-06)
150329 EPS nconv=0 first unconverged value (error) -302.035 (1.87943904e-06)
150330 EPS nconv=0 first unconverged value (error) -302.035 (1.86032479e-06)
150331 EPS nconv=0 first unconverged value (error) -302.035 (1.86032479e-06)
150332 EPS nconv=0 first unconverged value (error) -302.035 (1.85042883e-06)
150333 EPS nconv=0 first unconverged value (error) -302.035 (1.90082449e-06)
150334 EPS nconv=0 first unconverged value (error) -302.035 (1.84843587e-06)
150335 EPS nconv=0 first unconverged value (error) -302.035 (1.81055012e-06)
150336 EPS nconv=0 first unconverged value (error) -302.035 (1.80504897e-06)
150337 EPS nconv=0 first unconverged value (error) -302.035 (1.80504897e-06)
150338 EPS nconv=0 first unconverged value (error) -302.035 (2.15462653e-06)
150339 EPS nconv=0 first unconverged value (error) -302.035 (2.05539362e-06)
150340 EPS nconv=0 first unconverged value (error) -302.035 (1.99914532e-06)
150341 EPS nconv=0 first unconverged value (error) -302.035 (1.99425372e-06)
150342 EPS nconv=0 first unconverged value (error) -302.035 (1.97087865e-06)
150343 EPS nconv=0 first unconverged value (error) -302.035 (1.97087865e-06)
150344 EPS nconv=0 first unconverged value (error) -302.035 (2.03701170e-06)
150345 EPS nconv=0 first unconverged value (error) -302.035 (2.04765269e-06)
150346 EPS nconv=0 first unconverged value (error) -302.035 (1.92592831e-06)
150347 EPS nconv=0 first unconverged value (error) -302.035 (1.87696034e-06)
150348 EPS nconv=0 first unconverged value (error) -302.035 (1.87891624e-06)
150349 EPS nconv=0 first unconverged value (error) -302.035 (1.87891624e-06)
150350 EPS nconv=0 first unconverged value (error) -302.035 (1.86341264e-06)
150351 EPS nconv=0 first unconverged value (error) -302.035 (1.87505957e-06)
150352 EPS nconv=0 first unconverged value (error) -302.035 (1.84732230e-06)
150353 EPS nconv=0 first unconverged value (error) -302.035 (1.82066169e-06)
150354 EPS nconv=0 first unconverged value (error) -302.035 (1.80765185e-06)
150355 EPS nconv=0 first unconverged value (error) -302.035 (1.80765185e-06)
150356 EPS nconv=0 first unconverged value (error) -302.035 (1.89359745e-06)
150357 EPS nconv=0 first unconverged value (error) -302.035 (1.87424978e-06)
150358 EPS nconv=0 first unconverged value (error) -302.035 (1.85862292e-06)
150359 EPS nconv=0 first unconverged value (error) -302.035 (1.84678877e-06)
150360 EPS nconv=0 first unconverged value (error) -302.035 (1.83956007e-06)
150361 EPS nconv=0 first unconverged value (error) -302.035 (1.83956007e-06)
150362 EPS nconv=0 first unconverged value (error) -302.035 (2.08936405e-06)
150363 EPS nconv=0 first unconverged value (error) -302.035 (2.12123026e-06)
150364 EPS nconv=0 first unconverged value (error) -302.035 (2.07536981e-06)
150365 EPS nconv=0 first unconverged value (error) -302.035 (1.93173513e-06)
150366 EPS nconv=0 first unconverged value (error) -302.035 (1.91735500e-06)
150367 EPS nconv=0 first unconverged value (error) -302.035 (1.91735500e-06)
150368 EPS nconv=0 first unconverged value (error) -302.035 (2.03124533e-06)
150369 EPS nconv=0 first unconverged value (error) -302.035 (1.95525786e-06)
150370 EPS nconv=0 first unconverged value (error) -302.035 (1.90118114e-06)
150371 EPS nconv=0 first unconverged value (error) -302.035 (1.89338839e-06)
150372 EPS nconv=0 first unconverged value (error) -302.035 (1.88223037e-06)
150373 EPS nconv=0 first unconverged value (error) -302.035 (1.88223037e-06)
150374 EPS nconv=0 first unconverged value (error) -302.035 (2.54997474e-06)
150375 EPS nconv=0 first unconverged value (error) -302.035 (2.29886557e-06)
150376 EPS nconv=0 first unconverged value (error) -302.035 (2.18172205e-06)
150377 EPS nconv=0 first unconverged value (error) -302.035 (2.13984101e-06)
150378 EPS nconv=0 first unconverged value (error) -302.035 (2.11403055e-06)
150379 EPS nconv=0 first unconverged value (error) -302.035 (2.11403055e-06)
150380 EPS nconv=0 first unconverged value (error) -302.035 (2.99695509e-06)
150381 EPS nconv=0 first unconverged value (error) -302.035 (2.85583385e-06)
150382 EPS nconv=0 first unconverged value (error) -302.035 (2.49531533e-06)
150383 EPS nconv=0 first unconverged value (error) -302.035 (2.42414253e-06)
150384 EPS nconv=0 first unconverged value (error) -302.035 (2.34741581e-06)
150385 EPS nconv=0 first unconverged value (error) -302.035 (2.34741581e-06)
150386 EPS nconv=0 first unconverged value (error) -302.035 (2.39196207e-06)
150387 EPS nconv=0 first unconverged value (error) -302.035 (2.63336465e-06)
150388 EPS nconv=0 first unconverged value (error) -302.035 (2.22056783e-06)
150389 EPS nconv=0 first unconverged value (error) -302.035 (1.92208566e-06)
150390 EPS nconv=0 first unconverged value (error) -302.035 (1.86722920e-06)
150391 EPS nconv=0 first unconverged value (error) -302.035 (1.86722920e-06)
150392 EPS nconv=0 first unconverged value (error) -302.035 (1.88907966e-06)
150393 EPS nconv=0 first unconverged value (error) -302.035 (1.90311265e-06)
150394 EPS nconv=0 first unconverged value (error) -302.035 (1.86244680e-06)
150395 EPS nconv=0 first unconverged value (error) -302.035 (1.84044474e-06)
150396 EPS nconv=0 first unconverged value (error) -302.035 (1.83914507e-06)
150397 EPS nconv=0 first unconverged value (error) -302.035 (1.83914507e-06)
150398 EPS nconv=0 first unconverged value (error) -302.035 (1.82805736e-06)
150399 EPS nconv=0 first unconverged value (error) -302.035 (1.84751371e-06)
150400 EPS nconv=0 first unconverged value (error) -302.035 (1.81427091e-06)
150401 EPS nconv=0 first unconverged value (error) -302.035 (1.80343120e-06)
150402 EPS nconv=0 first unconverged value (error) -302.035 (1.80038375e-06)
150403 EPS nconv=0 first unconverged value (error) -302.035 (1.80038375e-06)
150404 EPS nconv=0 first unconverged value (error) -302.035 (2.17902578e-06)
150405 EPS nconv=0 first unconverged value (error) -302.035 (2.05140680e-06)
150406 EPS nconv=0 first unconverged value (error) -302.035 (1.99469567e-06)
150407 EPS nconv=0 first unconverged value (error) -302.035 (1.97343186e-06)
150408 EPS nconv=0 first unconverged value (error) -302.035 (1.94985878e-06)
150409 EPS nconv=0 first unconverged value (error) -302.035 (1.94985878e-06)
150410 EPS nconv=0 first unconverged value (error) -302.035 (2.06001972e-06)
150411 EPS nconv=0 first unconverged value (error) -302.035 (2.20056500e-06)
150412 EPS nconv=0 first unconverged value (error) -302.035 (2.05685039e-06)
150413 EPS nconv=0 first unconverged value (error) -302.035 (1.87553747e-06)
150414 EPS nconv=0 first unconverged value (error) -302.035 (1.85553668e-06)
150415 EPS nconv=0 first unconverged value (error) -302.035 (1.85553668e-06)
150416 EPS nconv=0 first unconverged value (error) -302.035 (1.94641560e-06)
150417 EPS nconv=0 first unconverged value (error) -302.035 (1.90968760e-06)
150418 EPS nconv=0 first unconverged value (error) -302.035 (1.87431113e-06)
150419 EPS nconv=0 first unconverged value (error) -302.035 (1.85895866e-06)
150420 EPS nconv=0 first unconverged value (error) -302.035 (1.85038539e-06)
150421 EPS nconv=0 first unconverged value (error) -302.035 (1.85038539e-06)
150422 EPS nconv=0 first unconverged value (error) -302.035 (1.95120876e-06)
150423 EPS nconv=0 first unconverged value (error) -302.035 (1.91415420e-06)
150424 EPS nconv=0 first unconverged value (error) -302.035 (1.86484007e-06)
150425 EPS nconv=0 first unconverged value (error) -302.035 (1.85785911e-06)
150426 EPS nconv=0 first unconverged value (error) -302.035 (1.83496542e-06)
150427 EPS nconv=0 first unconverged value (error) -302.035 (1.83496542e-06)
150428 EPS nconv=0 first unconverged value (error) -302.035 (1.82802798e-06)
150429 EPS nconv=0 first unconverged value (error) -302.035 (1.86958427e-06)
150430 EPS nconv=0 first unconverged value (error) -302.035 (1.82029287e-06)
150431 EPS nconv=0 first unconverged value (error) -302.035 (1.80401886e-06)
150432 EPS nconv=0 first unconverged value (error) -302.035 (1.80101373e-06)
150433 EPS nconv=0 first unconverged value (error) -302.035 (1.80101373e-06)
150434 EPS nconv=0 first unconverged value (error) -302.035 (1.79755387e-06)
150435 EPS nconv=0 first unconverged value (error) -302.035 (1.79713211e-06)
150436 EPS nconv=0 first unconverged value (error) -302.035 (1.79658009e-06)
150437 EPS nconv=0 first unconverged value (error) -302.035 (1.79582032e-06)
150438 EPS nconv=0 first unconverged value (error) -302.035 (1.79546421e-06)
150439 EPS nconv=0 first unconverged value (error) -302.035 (1.79546421e-06)
150440 EPS nconv=0 first unconverged value (error) -302.035 (2.04316862e-06)
150441 EPS nconv=0 first unconverged value (error) -302.035 (1.97038338e-06)
150442 EPS nconv=0 first unconverged value (error) -302.035 (1.93023051e-06)
150443 EPS nconv=0 first unconverged value (error) -302.035 (1.90064240e-06)
150444 EPS nconv=0 first unconverged value (error) -302.035 (1.88541449e-06)
150445 EPS nconv=0 first unconverged value (error) -302.035 (1.88541449e-06)
150446 EPS nconv=0 first unconverged value (error) -302.035 (2.10966066e-06)
150447 EPS nconv=0 first unconverged value (error) -302.035 (2.07374554e-06)
150448 EPS nconv=0 first unconverged value (error) -302.035 (1.99293461e-06)
150449 EPS nconv=0 first unconverged value (error) -302.035 (1.97269996e-06)
150450 EPS nconv=0 first unconverged value (error) -302.035 (1.95821201e-06)
150451 EPS nconv=0 first unconverged value (error) -302.035 (1.95821201e-06)
150452 EPS nconv=0 first unconverged value (error) -302.035 (2.11761417e-06)
150453 EPS nconv=0 first unconverged value (error) -302.035 (2.02081058e-06)
150454 EPS nconv=0 first unconverged value (error) -302.035 (1.92589490e-06)
150455 EPS nconv=0 first unconverged value (error) -302.035 (1.94245248e-06)
150456 EPS nconv=0 first unconverged value (error) -302.035 (1.90383191e-06)
150457 EPS nconv=0 first unconverged value (error) -302.035 (1.90383191e-06)
150458 EPS nconv=0 first unconverged value (error) -302.035 (2.03749191e-06)
150459 EPS nconv=0 first unconverged value (error) -302.035 (2.08230274e-06)
150460 EPS nconv=0 first unconverged value (error) -302.035 (1.97521673e-06)
150461 EPS nconv=0 first unconverged value (error) -302.035 (1.91019324e-06)
150462 EPS nconv=0 first unconverged value (error) -302.035 (1.88182701e-06)
150463 EPS nconv=0 first unconverged value (error) -302.035 (1.88182701e-06)
150464 EPS nconv=0 first unconverged value (error) -302.035 (2.82248749e-06)
150465 EPS nconv=0 first unconverged value (error) -302.035 (2.70105442e-06)
150466 EPS nconv=0 first unconverged value (error) -302.035 (2.48755300e-06)
150467 EPS nconv=0 first unconverged value (error) -302.035 (2.42824847e-06)
150468 EPS nconv=0 first unconverged value (error) -302.035 (2.32546733e-06)
150469 EPS nconv=0 first unconverged value (error) -302.035 (2.32546733e-06)
150470 EPS nconv=0 first unconverged value (error) -302.035 (2.47289889e-06)
150471 EPS nconv=0 first unconverged value (error) -302.035 (2.39026208e-06)
150472 EPS nconv=0 first unconverged value (error) -302.035 (2.17402457e-06)
150473 EPS nconv=0 first unconverged value (error) -302.035 (2.02402994e-06)
150474 EPS nconv=0 first unconverged value (error) -302.035 (2.03602356e-06)
150475 EPS nconv=0 first unconverged value (error) -302.035 (2.03602356e-06)
150476 EPS nconv=0 first unconverged value (error) -302.035 (2.23452902e-06)
150477 EPS nconv=0 first unconverged value (error) -302.035 (2.13025702e-06)
150478 EPS nconv=0 first unconverged value (error) -302.035 (2.05470507e-06)
150479 EPS nconv=0 first unconverged value (error) -302.035 (1.92564852e-06)
150480 EPS nconv=0 first unconverged value (error) -302.035 (1.89821715e-06)
150481 EPS nconv=0 first unconverged value (error) -302.035 (1.89821715e-06)
150482 EPS nconv=0 first unconverged value (error) -302.035 (3.47838646e-06)
150483 EPS nconv=0 first unconverged value (error) -302.035 (2.92460529e-06)
150484 EPS nconv=0 first unconverged value (error) -302.035 (2.55076682e-06)
150485 EPS nconv=0 first unconverged value (error) -302.035 (2.46654743e-06)
150486 EPS nconv=0 first unconverged value (error) -302.035 (2.40990529e-06)
150487 EPS nconv=0 first unconverged value (error) -302.035 (2.40990529e-06)
150488 EPS nconv=0 first unconverged value (error) -302.035 (3.32919374e-06)
150489 EPS nconv=0 first unconverged value (error) -302.035 (3.21770728e-06)
150490 EPS nconv=0 first unconverged value (error) -302.035 (2.63736309e-06)
150491 EPS nconv=0 first unconverged value (error) -302.035 (2.58692231e-06)
150492 EPS nconv=0 first unconverged value (error) -302.035 (2.44055914e-06)
150493 EPS nconv=0 first unconverged value (error) -302.035 (2.44055914e-06)
150494 EPS nconv=0 first unconverged value (error) -302.035 (3.43820659e-06)
150495 EPS nconv=0 first unconverged value (error) -302.035 (3.24998426e-06)
150496 EPS nconv=0 first unconverged value (error) -302.035 (2.67490515e-06)
150497 EPS nconv=0 first unconverged value (error) -302.035 (2.48904828e-06)
150498 EPS nconv=0 first unconverged value (error) -302.035 (2.45289699e-06)
150499 EPS nconv=0 first unconverged value (error) -302.035 (2.45289699e-06)
150500 EPS nconv=0 first unconverged value (error) -302.035 (2.56371616e-06)
150501 EPS nconv=0 first unconverged value (error) -302.035 (2.56563828e-06)
150502 EPS nconv=0 first unconverged value (error) -302.035 (2.24691365e-06)
150503 EPS nconv=0 first unconverged value (error) -302.035 (2.03396165e-06)
150504 EPS nconv=0 first unconverged value (error) -302.035 (2.00363571e-06)
150505 EPS nconv=0 first unconverged value (error) -302.035 (2.00363571e-06)
150506 EPS nconv=0 first unconverged value (error) -302.035 (1.90226567e-06)
150507 EPS nconv=0 first unconverged value (error) -302.035 (1.99287063e-06)
150508 EPS nconv=0 first unconverged value (error) -302.035 (1.85816746e-06)
150509 EPS nconv=0 first unconverged value (error) -302.035 (1.81539031e-06)
150510 EPS nconv=0 first unconverged value (error) -302.035 (1.80963774e-06)
150511 EPS nconv=0 first unconverged value (error) -302.035 (1.80963774e-06)
150512 EPS nconv=0 first unconverged value (error) -302.035 (2.24526529e-06)
150513 EPS nconv=0 first unconverged value (error) -302.035 (2.05641068e-06)
150514 EPS nconv=0 first unconverged value (error) -302.035 (2.01400811e-06)
150515 EPS nconv=0 first unconverged value (error) -302.035 (2.00903062e-06)
150516 EPS nconv=0 first unconverged value (error) -302.035 (1.97470695e-06)
150517 EPS nconv=0 first unconverged value (error) -302.035 (1.97470695e-06)
150518 EPS nconv=0 first unconverged value (error) -302.035 (2.02755295e-06)
150519 EPS nconv=0 first unconverged value (error) -302.035 (2.20093456e-06)
150520 EPS nconv=0 first unconverged value (error) -302.035 (1.99075616e-06)
150521 EPS nconv=0 first unconverged value (error) -302.035 (1.85748068e-06)
150522 EPS nconv=0 first unconverged value (error) -302.035 (1.84030929e-06)
150523 EPS nconv=0 first unconverged value (error) -302.035 (1.84030929e-06)
150524 EPS nconv=0 first unconverged value (error) -302.035 (1.95735712e-06)
150525 EPS nconv=0 first unconverged value (error) -302.035 (1.86836349e-06)
150526 EPS nconv=0 first unconverged value (error) -302.035 (1.84399785e-06)
150527 EPS nconv=0 first unconverged value (error) -302.035 (1.83326194e-06)
150528 EPS nconv=0 first unconverged value (error) -302.035 (1.82679398e-06)
150529 EPS nconv=0 first unconverged value (error) -302.035 (1.82679398e-06)
150530 EPS nconv=0 first unconverged value (error) -302.035 (1.91434858e-06)
150531 EPS nconv=0 first unconverged value (error) -302.035 (1.92281446e-06)
150532 EPS nconv=0 first unconverged value (error) -302.035 (1.84749984e-06)
150533 EPS nconv=0 first unconverged value (error) -302.035 (1.84015817e-06)
150534 EPS nconv=0 first unconverged value (error) -302.035 (1.83751244e-06)
150535 EPS nconv=0 first unconverged value (error) -302.035 (1.83751244e-06)
150536 EPS nconv=0 first unconverged value (error) -302.035 (2.86523586e-06)
150537 EPS nconv=0 first unconverged value (error) -302.035 (2.53768465e-06)
150538 EPS nconv=0 first unconverged value (error) -302.035 (2.33232325e-06)
150539 EPS nconv=0 first unconverged value (error) -302.035 (2.33629533e-06)
150540 EPS nconv=0 first unconverged value (error) -302.035 (2.25312237e-06)
150541 EPS nconv=0 first unconverged value (error) -302.035 (2.25312237e-06)
150542 EPS nconv=0 first unconverged value (error) -302.035 (4.94106917e-06)
150543 EPS nconv=0 first unconverged value (error) -302.035 (4.62671851e-06)
150544 EPS nconv=0 first unconverged value (error) -302.035 (3.91545657e-06)
150545 EPS nconv=0 first unconverged value (error) -302.035 (3.76793229e-06)
150546 EPS nconv=0 first unconverged value (error) -302.035 (3.73078722e-06)
150547 EPS nconv=0 first unconverged value (error) -302.035 (3.73078722e-06)
150548 EPS nconv=0 first unconverged value (error) -302.035 (4.24647607e-06)
150549 EPS nconv=0 first unconverged value (error) -302.035 (3.96308317e-06)
150550 EPS nconv=0 first unconverged value (error) -302.035 (3.67941569e-06)
150551 EPS nconv=0 first unconverged value (error) -302.035 (2.88028599e-06)
150552 EPS nconv=0 first unconverged value (error) -302.035 (2.55970285e-06)
150553 EPS nconv=0 first unconverged value (error) -302.035 (2.55970285e-06)
150554 EPS nconv=0 first unconverged value (error) -302.035 (2.43286214e-06)
150555 EPS nconv=0 first unconverged value (error) -302.035 (2.78082002e-06)
150556 EPS nconv=0 first unconverged value (error) -302.035 (2.17773957e-06)
150557 EPS nconv=0 first unconverged value (error) -302.035 (1.98490431e-06)
150558 EPS nconv=0 first unconverged value (error) -302.035 (1.88627101e-06)
150559 EPS nconv=0 first unconverged value (error) -302.035 (1.88627101e-06)
150560 EPS nconv=0 first unconverged value (error) -302.035 (1.84744742e-06)
150561 EPS nconv=0 first unconverged value (error) -302.035 (1.84494613e-06)
150562 EPS nconv=0 first unconverged value (error) -302.035 (1.82401845e-06)
150563 EPS nconv=0 first unconverged value (error) -302.035 (1.81130377e-06)
150564 EPS nconv=0 first unconverged value (error) -302.035 (1.80726828e-06)
150565 EPS nconv=0 first unconverged value (error) -302.035 (1.80726828e-06)
150566 EPS nconv=0 first unconverged value (error) -302.035 (1.95071619e-06)
150567 EPS nconv=0 first unconverged value (error) -302.035 (1.91104878e-06)
150568 EPS nconv=0 first unconverged value (error) -302.035 (1.88435732e-06)
150569 EPS nconv=0 first unconverged value (error) -302.035 (1.85557585e-06)
150570 EPS nconv=0 first unconverged value (error) -302.035 (1.85129330e-06)
150571 EPS nconv=0 first unconverged value (error) -302.035 (1.85129330e-06)
150572 EPS nconv=0 first unconverged value (error) -302.035 (2.40671359e-06)
150573 EPS nconv=0 first unconverged value (error) -302.035 (2.27850559e-06)
150574 EPS nconv=0 first unconverged value (error) -302.035 (2.16207308e-06)
150575 EPS nconv=0 first unconverged value (error) -302.035 (2.13419693e-06)
150576 EPS nconv=0 first unconverged value (error) -302.035 (2.12076811e-06)
150577 EPS nconv=0 first unconverged value (error) -302.035 (2.12076811e-06)
150578 EPS nconv=0 first unconverged value (error) -302.035 (4.02959209e-06)
150579 EPS nconv=0 first unconverged value (error) -302.035 (3.45585336e-06)
150580 EPS nconv=0 first unconverged value (error) -302.035 (3.02541170e-06)
150581 EPS nconv=0 first unconverged value (error) -302.035 (3.00025675e-06)
150582 EPS nconv=0 first unconverged value (error) -302.035 (2.85416563e-06)
150583 EPS nconv=0 first unconverged value (error) -302.035 (2.85416563e-06)
150584 EPS nconv=0 first unconverged value (error) -302.035 (6.08339185e-06)
150585 EPS nconv=0 first unconverged value (error) -302.035 (5.51901152e-06)
150586 EPS nconv=0 first unconverged value (error) -302.035 (4.54359939e-06)
150587 EPS nconv=0 first unconverged value (error) -302.035 (4.41834521e-06)
150588 EPS nconv=0 first unconverged value (error) -302.035 (4.37731701e-06)
150589 EPS nconv=0 first unconverged value (error) -302.035 (4.37731701e-06)
150590 EPS nconv=0 first unconverged value (error) -302.035 (5.35196010e-06)
150591 EPS nconv=0 first unconverged value (error) -302.035 (5.07397677e-06)
150592 EPS nconv=0 first unconverged value (error) -302.035 (4.36890121e-06)
150593 EPS nconv=0 first unconverged value (error) -302.035 (3.64438401e-06)
150594 EPS nconv=0 first unconverged value (error) -302.035 (3.23130105e-06)
150595 EPS nconv=0 first unconverged value (error) -302.035 (3.23130105e-06)
150596 EPS nconv=0 first unconverged value (error) -302.035 (3.77345259e-06)
150597 EPS nconv=0 first unconverged value (error) -302.035 (3.88038057e-06)
150598 EPS nconv=0 first unconverged value (error) -302.035 (2.94364761e-06)
150599 EPS nconv=0 first unconverged value (error) -302.035 (2.66697720e-06)
150600 EPS nconv=0 first unconverged value (error) -302.035 (2.51560288e-06)
150601 EPS nconv=0 first unconverged value (error) -302.035 (2.51560288e-06)
150602 EPS nconv=0 first unconverged value (error) -302.035 (2.37259039e-06)
150603 EPS nconv=0 first unconverged value (error) -302.035 (2.64478468e-06)
150604 EPS nconv=0 first unconverged value (error) -302.035 (2.45047911e-06)
150605 EPS nconv=0 first unconverged value (error) -302.035 (1.92511318e-06)
150606 EPS nconv=0 first unconverged value (error) -302.035 (1.86421894e-06)
150607 EPS nconv=0 first unconverged value (error) -302.035 (1.86421894e-06)
150608 EPS nconv=0 first unconverged value (error) -302.035 (2.11347262e-06)
150609 EPS nconv=0 first unconverged value (error) -302.035 (2.02328319e-06)
150610 EPS nconv=0 first unconverged value (error) -302.035 (1.94139731e-06)
150611 EPS nconv=0 first unconverged value (error) -302.035 (1.88384155e-06)
150612 EPS nconv=0 first unconverged value (error) -302.035 (1.87582482e-06)
150613 EPS nconv=0 first unconverged value (error) -302.035 (1.87582482e-06)
150614 EPS nconv=0 first unconverged value (error) -302.035 (2.93671766e-06)
150615 EPS nconv=0 first unconverged value (error) -302.035 (2.65761078e-06)
150616 EPS nconv=0 first unconverged value (error) -302.035 (2.45728944e-06)
150617 EPS nconv=0 first unconverged value (error) -302.035 (2.38775782e-06)
150618 EPS nconv=0 first unconverged value (error) -302.035 (2.33456524e-06)
150619 EPS nconv=0 first unconverged value (error) -302.035 (2.33456524e-06)
150620 EPS nconv=0 first unconverged value (error) -302.035 (2.84879262e-06)
150621 EPS nconv=0 first unconverged value (error) -302.035 (2.73250785e-06)
150622 EPS nconv=0 first unconverged value (error) -302.035 (2.38647110e-06)
150623 EPS nconv=0 first unconverged value (error) -302.035 (2.31439283e-06)
150624 EPS nconv=0 first unconverged value (error) -302.035 (2.24552668e-06)
150625 EPS nconv=0 first unconverged value (error) -302.035 (2.24552668e-06)
150626 EPS nconv=0 first unconverged value (error) -302.035 (5.36475928e-06)
150627 EPS nconv=0 first unconverged value (error) -302.035 (5.06250717e-06)
150628 EPS nconv=0 first unconverged value (error) -302.035 (4.10630707e-06)
150629 EPS nconv=0 first unconverged value (error) -302.035 (3.58976201e-06)
150630 EPS nconv=0 first unconverged value (error) -302.035 (3.45241239e-06)
150631 EPS nconv=0 first unconverged value (error) -302.035 (3.45241239e-06)
150632 EPS nconv=0 first unconverged value (error) -302.035 (6.05430087e-06)
150633 EPS nconv=0 first unconverged value (error) -302.035 (5.84578955e-06)
150634 EPS nconv=0 first unconverged value (error) -302.035 (4.84306394e-06)
150635 EPS nconv=0 first unconverged value (error) -302.035 (4.46416919e-06)
150636 EPS nconv=0 first unconverged value (error) -302.035 (4.22090034e-06)
150637 EPS nconv=0 first unconverged value (error) -302.035 (4.22090034e-06)
150638 EPS nconv=0 first unconverged value (error) -302.035 (4.19366852e-06)
150639 EPS nconv=0 first unconverged value (error) -302.035 (4.25882863e-06)
150640 EPS nconv=0 first unconverged value (error) -302.035 (3.62845403e-06)
150641 EPS nconv=0 first unconverged value (error) -302.035 (2.38025731e-06)
150642 EPS nconv=0 first unconverged value (error) -302.035 (2.02623784e-06)
150643 EPS nconv=0 first unconverged value (error) -302.035 (2.02623784e-06)
150644 EPS nconv=0 first unconverged value (error) -302.035 (2.57533878e-06)
150645 EPS nconv=0 first unconverged value (error) -302.035 (2.42717572e-06)
150646 EPS nconv=0 first unconverged value (error) -302.035 (2.28678215e-06)
150647 EPS nconv=0 first unconverged value (error) -302.035 (2.24914438e-06)
150648 EPS nconv=0 first unconverged value (error) -302.035 (2.22653633e-06)
150649 EPS nconv=0 first unconverged value (error) -302.035 (2.22653633e-06)
150650 EPS nconv=0 first unconverged value (error) -302.035 (2.39957820e-06)
150651 EPS nconv=0 first unconverged value (error) -302.035 (2.77134222e-06)
150652 EPS nconv=0 first unconverged value (error) -302.035 (2.46990398e-06)
150653 EPS nconv=0 first unconverged value (error) -302.035 (1.99900225e-06)
150654 EPS nconv=0 first unconverged value (error) -302.035 (1.88686979e-06)
150655 EPS nconv=0 first unconverged value (error) -302.035 (1.88686979e-06)
150656 EPS nconv=0 first unconverged value (error) -302.035 (2.02037452e-06)
150657 EPS nconv=0 first unconverged value (error) -302.035 (2.04524699e-06)
150658 EPS nconv=0 first unconverged value (error) -302.035 (1.94820425e-06)
150659 EPS nconv=0 first unconverged value (error) -302.035 (1.87371805e-06)
150660 EPS nconv=0 first unconverged value (error) -302.035 (1.85726692e-06)
150661 EPS nconv=0 first unconverged value (error) -302.035 (1.85726692e-06)
150662 EPS nconv=0 first unconverged value (error) -302.035 (2.12080195e-06)
150663 EPS nconv=0 first unconverged value (error) -302.035 (2.00284665e-06)
150664 EPS nconv=0 first unconverged value (error) -302.035 (1.95881380e-06)
150665 EPS nconv=0 first unconverged value (error) -302.035 (1.93730974e-06)
150666 EPS nconv=0 first unconverged value (error) -302.035 (1.91530964e-06)
150667 EPS nconv=0 first unconverged value (error) -302.035 (1.91530964e-06)
150668 EPS nconv=0 first unconverged value (error) -302.035 (1.99350482e-06)
150669 EPS nconv=0 first unconverged value (error) -302.035 (2.05840931e-06)
150670 EPS nconv=0 first unconverged value (error) -302.035 (1.90142250e-06)
150671 EPS nconv=0 first unconverged value (error) -302.035 (1.87998207e-06)
150672 EPS nconv=0 first unconverged value (error) -302.035 (1.85269143e-06)
150673 EPS nconv=0 first unconverged value (error) -302.035 (1.85269143e-06)
150674 EPS nconv=0 first unconverged value (error) -302.035 (3.72331706e-06)
150675 EPS nconv=0 first unconverged value (error) -302.035 (3.44845304e-06)
150676 EPS nconv=0 first unconverged value (error) -302.035 (3.07207786e-06)
150677 EPS nconv=0 first unconverged value (error) -302.035 (2.91143372e-06)
150678 EPS nconv=0 first unconverged value (error) -302.035 (2.72648067e-06)
150679 EPS nconv=0 first unconverged value (error) -302.035 (2.72648067e-06)
150680 EPS nconv=0 first unconverged value (error) -302.035 (4.64932837e-06)
150681 EPS nconv=0 first unconverged value (error) -302.035 (4.41466312e-06)
150682 EPS nconv=0 first unconverged value (error) -302.035 (3.87038581e-06)
150683 EPS nconv=0 first unconverged value (error) -302.035 (3.75225940e-06)
150684 EPS nconv=0 first unconverged value (error) -302.035 (3.75745766e-06)
150685 EPS nconv=0 first unconverged value (error) -302.035 (3.75745766e-06)
150686 EPS nconv=0 first unconverged value (error) -302.035 (3.80180057e-06)
150687 EPS nconv=0 first unconverged value (error) -302.035 (3.28828991e-06)
150688 EPS nconv=0 first unconverged value (error) -302.035 (3.10601876e-06)
150689 EPS nconv=0 first unconverged value (error) -302.035 (2.90721867e-06)
150690 EPS nconv=0 first unconverged value (error) -302.035 (2.03560057e-06)
150691 EPS nconv=0 first unconverged value (error) -302.035 (2.03560057e-06)
150692 EPS nconv=0 first unconverged value (error) -302.035 (3.27370467e-06)
150693 EPS nconv=0 first unconverged value (error) -302.035 (2.95851469e-06)
150694 EPS nconv=0 first unconverged value (error) -302.035 (2.66849513e-06)
150695 EPS nconv=0 first unconverged value (error) -302.035 (2.57810764e-06)
150696 EPS nconv=0 first unconverged value (error) -302.035 (2.50593496e-06)
150697 EPS nconv=0 first unconverged value (error) -302.035 (2.50593496e-06)
150698 EPS nconv=0 first unconverged value (error) -302.035 (2.67062706e-06)
150699 EPS nconv=0 first unconverged value (error) -302.035 (2.55434305e-06)
150700 EPS nconv=0 first unconverged value (error) -302.035 (2.28279262e-06)
150701 EPS nconv=0 first unconverged value (error) -302.035 (2.08428240e-06)
150702 EPS nconv=0 first unconverged value (error) -302.035 (2.07330288e-06)
150703 EPS nconv=0 first unconverged value (error) -302.035 (2.07330288e-06)
150704 EPS nconv=0 first unconverged value (error) -302.035 (2.05240922e-06)
150705 EPS nconv=0 first unconverged value (error) -302.035 (2.08036614e-06)
150706 EPS nconv=0 first unconverged value (error) -302.035 (1.95512237e-06)
150707 EPS nconv=0 first unconverged value (error) -302.035 (1.88088158e-06)
150708 EPS nconv=0 first unconverged value (error) -302.035 (1.85776115e-06)
150709 EPS nconv=0 first unconverged value (error) -302.035 (1.85776115e-06)
150710 EPS nconv=0 first unconverged value (error) -302.035 (1.84444717e-06)
150711 EPS nconv=0 first unconverged value (error) -302.035 (1.87258242e-06)
150712 EPS nconv=0 first unconverged value (error) -302.035 (1.83144377e-06)
150713 EPS nconv=0 first unconverged value (error) -302.035 (1.81772939e-06)
150714 EPS nconv=0 first unconverged value (error) -302.035 (1.80937029e-06)
150715 EPS nconv=0 first unconverged value (error) -302.035 (1.80937029e-06)
150716 EPS nconv=0 first unconverged value (error) -302.035 (1.80706392e-06)
150717 EPS nconv=0 first unconverged value (error) -302.035 (1.81975813e-06)
150718 EPS nconv=0 first unconverged value (error) -302.035 (1.80498247e-06)
150719 EPS nconv=0 first unconverged value (error) -302.035 (1.79973890e-06)
150720 EPS nconv=0 first unconverged value (error) -302.035 (1.79710577e-06)
150721 EPS nconv=0 first unconverged value (error) -302.035 (1.79710577e-06)
150722 EPS nconv=0 first unconverged value (error) -302.035 (1.88380310e-06)
150723 EPS nconv=0 first unconverged value (error) -302.035 (1.86051447e-06)
150724 EPS nconv=0 first unconverged value (error) -302.035 (1.84894162e-06)
150725 EPS nconv=0 first unconverged value (error) -302.035 (1.84691311e-06)
150726 EPS nconv=0 first unconverged value (error) -302.035 (1.83435508e-06)
150727 EPS nconv=0 first unconverged value (error) -302.035 (1.83435508e-06)
150728 EPS nconv=0 first unconverged value (error) -302.035 (4.46146749e-06)
150729 EPS nconv=0 first unconverged value (error) -302.035 (4.36958210e-06)
150730 EPS nconv=0 first unconverged value (error) -302.035 (3.83131392e-06)
150731 EPS nconv=0 first unconverged value (error) -302.035 (3.61522001e-06)
150732 EPS nconv=0 first unconverged value (error) -302.035 (3.58784429e-06)
150733 EPS nconv=0 first unconverged value (error) -302.035 (3.58784429e-06)
150734 EPS nconv=0 first unconverged value (error) -302.035 (5.13187145e-06)
150735 EPS nconv=0 first unconverged value (error) -302.035 (4.21735906e-06)
150736 EPS nconv=0 first unconverged value (error) -302.035 (3.87211895e-06)
150737 EPS nconv=0 first unconverged value (error) -302.035 (3.62982307e-06)
150738 EPS nconv=0 first unconverged value (error) -302.035 (3.45384172e-06)
150739 EPS nconv=0 first unconverged value (error) -302.035 (3.45384172e-06)
150740 EPS nconv=0 first unconverged value (error) -302.035 (4.00739198e-06)
150741 EPS nconv=0 first unconverged value (error) -302.035 (3.73813544e-06)
150742 EPS nconv=0 first unconverged value (error) -302.035 (2.65911489e-06)
150743 EPS nconv=0 first unconverged value (error) -302.035 (2.50519642e-06)
150744 EPS nconv=0 first unconverged value (error) -302.035 (2.47903420e-06)
150745 EPS nconv=0 first unconverged value (error) -302.035 (2.47903420e-06)
150746 EPS nconv=0 first unconverged value (error) -302.035 (2.85193620e-06)
150747 EPS nconv=0 first unconverged value (error) -302.035 (3.05975019e-06)
150748 EPS nconv=0 first unconverged value (error) -302.035 (2.67786259e-06)
150749 EPS nconv=0 first unconverged value (error) -302.035 (2.17550674e-06)
150750 EPS nconv=0 first unconverged value (error) -302.035 (2.06305791e-06)
150751 EPS nconv=0 first unconverged value (error) -302.035 (2.06305791e-06)
150752 EPS nconv=0 first unconverged value (error) -302.035 (2.60582189e-06)
150753 EPS nconv=0 first unconverged value (error) -302.035 (2.73584769e-06)
150754 EPS nconv=0 first unconverged value (error) -302.035 (2.37780001e-06)
150755 EPS nconv=0 first unconverged value (error) -302.035 (2.26189391e-06)
150756 EPS nconv=0 first unconverged value (error) -302.035 (2.20945353e-06)
150757 EPS nconv=0 first unconverged value (error) -302.035 (2.20945353e-06)
150758 EPS nconv=0 first unconverged value (error) -302.035 (2.14240102e-06)
150759 EPS nconv=0 first unconverged value (error) -302.035 (2.16480199e-06)
150760 EPS nconv=0 first unconverged value (error) -302.035 (2.00582773e-06)
150761 EPS nconv=0 first unconverged value (error) -302.035 (1.85367048e-06)
150762 EPS nconv=0 first unconverged value (error) -302.035 (1.82528941e-06)
150763 EPS nconv=0 first unconverged value (error) -302.035 (1.82528941e-06)
150764 EPS nconv=0 first unconverged value (error) -302.035 (1.86162582e-06)
150765 EPS nconv=0 first unconverged value (error) -302.035 (1.82628381e-06)
150766 EPS nconv=0 first unconverged value (error) -302.035 (1.81236941e-06)
150767 EPS nconv=0 first unconverged value (error) -302.035 (1.80893172e-06)
150768 EPS nconv=0 first unconverged value (error) -302.035 (1.80775724e-06)
150769 EPS nconv=0 first unconverged value (error) -302.035 (1.80775724e-06)
150770 EPS nconv=0 first unconverged value (error) -302.035 (2.91549068e-06)
150771 EPS nconv=0 first unconverged value (error) -302.035 (2.58483318e-06)
150772 EPS nconv=0 first unconverged value (error) -302.035 (2.35189058e-06)
150773 EPS nconv=0 first unconverged value (error) -302.035 (2.28115647e-06)
150774 EPS nconv=0 first unconverged value (error) -302.035 (2.20504918e-06)
150775 EPS nconv=0 first unconverged value (error) -302.035 (2.20504918e-06)
150776 EPS nconv=0 first unconverged value (error) -302.035 (2.54334441e-06)
150777 EPS nconv=0 first unconverged value (error) -302.035 (2.70481280e-06)
150778 EPS nconv=0 first unconverged value (error) -302.035 (2.38889099e-06)
150779 EPS nconv=0 first unconverged value (error) -302.035 (2.22405800e-06)
150780 EPS nconv=0 first unconverged value (error) -302.035 (2.19481595e-06)
150781 EPS nconv=0 first unconverged value (error) -302.035 (2.19481595e-06)
150782 EPS nconv=0 first unconverged value (error) -302.035 (3.07615859e-06)
150783 EPS nconv=0 first unconverged value (error) -302.035 (2.63733461e-06)
150784 EPS nconv=0 first unconverged value (error) -302.035 (2.48015351e-06)
150785 EPS nconv=0 first unconverged value (error) -302.035 (2.33677518e-06)
150786 EPS nconv=0 first unconverged value (error) -302.035 (2.28185744e-06)
150787 EPS nconv=0 first unconverged value (error) -302.035 (2.28185744e-06)
150788 EPS nconv=0 first unconverged value (error) -302.035 (3.86751651e-06)
150789 EPS nconv=0 first unconverged value (error) -302.035 (3.59627347e-06)
150790 EPS nconv=0 first unconverged value (error) -302.035 (3.06188376e-06)
150791 EPS nconv=0 first unconverged value (error) -302.035 (2.76406277e-06)
150792 EPS nconv=0 first unconverged value (error) -302.035 (2.57574427e-06)
150793 EPS nconv=0 first unconverged value (error) -302.035 (2.57574427e-06)
150794 EPS nconv=0 first unconverged value (error) -302.035 (2.84088017e-06)
150795 EPS nconv=0 first unconverged value (error) -302.035 (3.36605099e-06)
150796 EPS nconv=0 first unconverged value (error) -302.035 (2.79407007e-06)
150797 EPS nconv=0 first unconverged value (error) -302.035 (2.26895290e-06)
150798 EPS nconv=0 first unconverged value (error) -302.035 (2.05784498e-06)
150799 EPS nconv=0 first unconverged value (error) -302.035 (2.05784498e-06)
150800 EPS nconv=0 first unconverged value (error) -302.035 (3.35676494e-06)
150801 EPS nconv=0 first unconverged value (error) -302.035 (3.14462035e-06)
150802 EPS nconv=0 first unconverged value (error) -302.035 (2.94657103e-06)
150803 EPS nconv=0 first unconverged value (error) -302.035 (2.80123803e-06)
150804 EPS nconv=0 first unconverged value (error) -302.035 (2.69843940e-06)
150805 EPS nconv=0 first unconverged value (error) -302.035 (2.69843940e-06)
150806 EPS nconv=0 first unconverged value (error) -302.035 (3.20065945e-06)
150807 EPS nconv=0 first unconverged value (error) -302.035 (3.03326116e-06)
150808 EPS nconv=0 first unconverged value (error) -302.035 (2.47705299e-06)
150809 EPS nconv=0 first unconverged value (error) -302.035 (2.37615354e-06)
150810 EPS nconv=0 first unconverged value (error) -302.035 (2.30554612e-06)
150811 EPS nconv=0 first unconverged value (error) -302.035 (2.30554612e-06)
150812 EPS nconv=0 first unconverged value (error) -302.035 (2.97992625e-06)
150813 EPS nconv=0 first unconverged value (error) -302.035 (2.95245591e-06)
150814 EPS nconv=0 first unconverged value (error) -302.035 (2.52099255e-06)
150815 EPS nconv=0 first unconverged value (error) -302.035 (2.32879926e-06)
150816 EPS nconv=0 first unconverged value (error) -302.035 (2.24759699e-06)
150817 EPS nconv=0 first unconverged value (error) -302.035 (2.24759699e-06)
150818 EPS nconv=0 first unconverged value (error) -302.035 (2.56477666e-06)
150819 EPS nconv=0 first unconverged value (error) -302.035 (2.71677999e-06)
150820 EPS nconv=0 first unconverged value (error) -302.035 (2.32824648e-06)
150821 EPS nconv=0 first unconverged value (error) -302.035 (2.11774407e-06)
150822 EPS nconv=0 first unconverged value (error) -302.035 (2.07414783e-06)
150823 EPS nconv=0 first unconverged value (error) -302.035 (2.07414783e-06)
150824 EPS nconv=0 first unconverged value (error) -302.035 (2.13484297e-06)
150825 EPS nconv=0 first unconverged value (error) -302.035 (2.25884062e-06)
150826 EPS nconv=0 first unconverged value (error) -302.035 (2.00089938e-06)
150827 EPS nconv=0 first unconverged value (error) -302.035 (1.93410097e-06)
150828 EPS nconv=0 first unconverged value (error) -302.035 (1.92615997e-06)
150829 EPS nconv=0 first unconverged value (error) -302.035 (1.92615997e-06)
150830 EPS nconv=0 first unconverged value (error) -302.035 (2.53375027e-06)
150831 EPS nconv=0 first unconverged value (error) -302.035 (2.28827910e-06)
150832 EPS nconv=0 first unconverged value (error) -302.035 (2.15888045e-06)
150833 EPS nconv=0 first unconverged value (error) -302.035 (2.12718297e-06)
150834 EPS nconv=0 first unconverged value (error) -302.035 (2.04869879e-06)
150835 EPS nconv=0 first unconverged value (error) -302.035 (2.04869879e-06)
150836 EPS nconv=0 first unconverged value (error) -302.035 (2.52407475e-06)
150837 EPS nconv=0 first unconverged value (error) -302.035 (2.51739822e-06)
150838 EPS nconv=0 first unconverged value (error) -302.035 (2.21637866e-06)
150839 EPS nconv=0 first unconverged value (error) -302.035 (2.12535658e-06)
150840 EPS nconv=0 first unconverged value (error) -302.035 (2.07574976e-06)
150841 EPS nconv=0 first unconverged value (error) -302.035 (2.07574976e-06)
150842 EPS nconv=0 first unconverged value (error) -302.035 (2.15031182e-06)
150843 EPS nconv=0 first unconverged value (error) -302.035 (2.19996344e-06)
150844 EPS nconv=0 first unconverged value (error) -302.035 (1.98326479e-06)
150845 EPS nconv=0 first unconverged value (error) -302.035 (1.93252979e-06)
150846 EPS nconv=0 first unconverged value (error) -302.035 (1.90882836e-06)
150847 EPS nconv=0 first unconverged value (error) -302.035 (1.90882836e-06)
150848 EPS nconv=0 first unconverged value (error) -302.035 (2.01340522e-06)
150849 EPS nconv=0 first unconverged value (error) -302.035 (2.03373037e-06)
150850 EPS nconv=0 first unconverged value (error) -302.035 (1.92712349e-06)
150851 EPS nconv=0 first unconverged value (error) -302.035 (1.89182177e-06)
150852 EPS nconv=0 first unconverged value (error) -302.035 (1.87207828e-06)
150853 EPS nconv=0 first unconverged value (error) -302.035 (1.87207828e-06)
150854 EPS nconv=0 first unconverged value (error) -302.035 (2.08045715e-06)
150855 EPS nconv=0 first unconverged value (error) -302.035 (2.01777316e-06)
150856 EPS nconv=0 first unconverged value (error) -302.035 (1.93023347e-06)
150857 EPS nconv=0 first unconverged value (error) -302.035 (1.90594730e-06)
150858 EPS nconv=0 first unconverged value (error) -302.035 (1.87433164e-06)
150859 EPS nconv=0 first unconverged value (error) -302.035 (1.87433164e-06)
150860 EPS nconv=0 first unconverged value (error) -302.035 (2.17375381e-06)
150861 EPS nconv=0 first unconverged value (error) -302.035 (2.13168288e-06)
150862 EPS nconv=0 first unconverged value (error) -302.035 (1.99679555e-06)
150863 EPS nconv=0 first unconverged value (error) -302.035 (1.96462913e-06)
150864 EPS nconv=0 first unconverged value (error) -302.035 (1.92892811e-06)
150865 EPS nconv=0 first unconverged value (error) -302.035 (1.92892811e-06)
150866 EPS nconv=0 first unconverged value (error) -302.035 (2.01747830e-06)
150867 EPS nconv=0 first unconverged value (error) -302.035 (2.06100176e-06)
150868 EPS nconv=0 first unconverged value (error) -302.035 (1.92958072e-06)
150869 EPS nconv=0 first unconverged value (error) -302.035 (1.88100343e-06)
150870 EPS nconv=0 first unconverged value (error) -302.035 (1.87038860e-06)
150871 EPS nconv=0 first unconverged value (error) -302.035 (1.87038860e-06)
150872 EPS nconv=0 first unconverged value (error) -302.035 (1.93430372e-06)
150873 EPS nconv=0 first unconverged value (error) -302.035 (1.93975582e-06)
150874 EPS nconv=0 first unconverged value (error) -302.035 (1.87825424e-06)
150875 EPS nconv=0 first unconverged value (error) -302.035 (1.85539243e-06)
150876 EPS nconv=0 first unconverged value (error) -302.035 (1.84402093e-06)
150877 EPS nconv=0 first unconverged value (error) -302.035 (1.84402093e-06)
150878 EPS nconv=0 first unconverged value (error) -302.035 (1.88584421e-06)
150879 EPS nconv=0 first unconverged value (error) -302.035 (1.89088951e-06)
150880 EPS nconv=0 first unconverged value (error) -302.035 (1.83995321e-06)
150881 EPS nconv=0 first unconverged value (error) -302.035 (1.83184110e-06)
150882 EPS nconv=0 first unconverged value (error) -302.035 (1.82560857e-06)
150883 EPS nconv=0 first unconverged value (error) -302.035 (1.82560857e-06)
150884 EPS nconv=0 first unconverged value (error) -302.035 (1.85392869e-06)
150885 EPS nconv=0 first unconverged value (error) -302.035 (1.86425696e-06)
150886 EPS nconv=0 first unconverged value (error) -302.035 (1.82944202e-06)
150887 EPS nconv=0 first unconverged value (error) -302.035 (1.82148896e-06)
150888 EPS nconv=0 first unconverged value (error) -302.035 (1.81419677e-06)
150889 EPS nconv=0 first unconverged value (error) -302.035 (1.81419677e-06)
150890 EPS nconv=0 first unconverged value (error) -302.035 (1.80878309e-06)
150891 EPS nconv=0 first unconverged value (error) -302.035 (1.82043496e-06)
150892 EPS nconv=0 first unconverged value (error) -302.035 (1.80487266e-06)
150893 EPS nconv=0 first unconverged value (error) -302.035 (1.79922083e-06)
150894 EPS nconv=0 first unconverged value (error) -302.035 (1.79906170e-06)
150895 EPS nconv=0 first unconverged value (error) -302.035 (1.79906170e-06)
150896 EPS nconv=0 first unconverged value (error) -302.035 (1.85478355e-06)
150897 EPS nconv=0 first unconverged value (error) -302.035 (1.82844127e-06)
150898 EPS nconv=0 first unconverged value (error) -302.035 (1.82342261e-06)
150899 EPS nconv=0 first unconverged value (error) -302.035 (1.82247825e-06)
150900 EPS nconv=0 first unconverged value (error) -302.035 (1.81621354e-06)
150901 EPS nconv=0 first unconverged value (error) -302.035 (1.81621354e-06)
150902 EPS nconv=0 first unconverged value (error) -302.035 (2.13260378e-06)
150903 EPS nconv=0 first unconverged value (error) -302.035 (2.05331001e-06)
150904 EPS nconv=0 first unconverged value (error) -302.035 (1.97801088e-06)
150905 EPS nconv=0 first unconverged value (error) -302.035 (1.97167930e-06)
150906 EPS nconv=0 first unconverged value (error) -302.035 (1.94358148e-06)
150907 EPS nconv=0 first unconverged value (error) -302.035 (1.94358148e-06)
150908 EPS nconv=0 first unconverged value (error) -302.035 (1.93661215e-06)
150909 EPS nconv=0 first unconverged value (error) -302.035 (2.01248861e-06)
150910 EPS nconv=0 first unconverged value (error) -302.035 (1.91539051e-06)
150911 EPS nconv=0 first unconverged value (error) -302.035 (1.83671276e-06)
150912 EPS nconv=0 first unconverged value (error) -302.035 (1.81114816e-06)
150913 EPS nconv=0 first unconverged value (error) -302.035 (1.81114816e-06)
150914 EPS nconv=0 first unconverged value (error) -302.035 (2.03185428e-06)
150915 EPS nconv=0 first unconverged value (error) -302.035 (1.94866709e-06)
150916 EPS nconv=0 first unconverged value (error) -302.035 (1.91351012e-06)
150917 EPS nconv=0 first unconverged value (error) -302.035 (1.90211913e-06)
150918 EPS nconv=0 first unconverged value (error) -302.035 (1.88473750e-06)
150919 EPS nconv=0 first unconverged value (error) -302.035 (1.88473750e-06)
150920 EPS nconv=0 first unconverged value (error) -302.035 (3.31123523e-06)
150921 EPS nconv=0 first unconverged value (error) -302.035 (3.08448707e-06)
150922 EPS nconv=0 first unconverged value (error) -302.035 (2.95278406e-06)
150923 EPS nconv=0 first unconverged value (error) -302.035 (2.92007170e-06)
150924 EPS nconv=0 first unconverged value (error) -302.035 (2.90850343e-06)
150925 EPS nconv=0 first unconverged value (error) -302.035 (2.90850343e-06)
150926 EPS nconv=0 first unconverged value (error) -302.035 (5.49454858e-06)
150927 EPS nconv=0 first unconverged value (error) -302.035 (4.19463601e-06)
150928 EPS nconv=0 first unconverged value (error) -302.035 (3.58279667e-06)
150929 EPS nconv=0 first unconverged value (error) -302.035 (3.50412882e-06)
150930 EPS nconv=0 first unconverged value (error) -302.035 (3.42299847e-06)
150931 EPS nconv=0 first unconverged value (error) -302.035 (3.42299847e-06)
150932 EPS nconv=0 first unconverged value (error) -302.035 (4.42646027e-06)
150933 EPS nconv=0 first unconverged value (error) -302.035 (4.90807078e-06)
150934 EPS nconv=0 first unconverged value (error) -302.035 (3.42233105e-06)
150935 EPS nconv=0 first unconverged value (error) -302.035 (3.11836786e-06)
150936 EPS nconv=0 first unconverged value (error) -302.035 (2.91418862e-06)
150937 EPS nconv=0 first unconverged value (error) -302.035 (2.91418862e-06)
150938 EPS nconv=0 first unconverged value (error) -302.035 (3.65482977e-06)
150939 EPS nconv=0 first unconverged value (error) -302.035 (3.95923815e-06)
150940 EPS nconv=0 first unconverged value (error) -302.035 (3.30467651e-06)
150941 EPS nconv=0 first unconverged value (error) -302.035 (2.54175003e-06)
150942 EPS nconv=0 first unconverged value (error) -302.035 (2.38074582e-06)
150943 EPS nconv=0 first unconverged value (error) -302.035 (2.38074582e-06)
150944 EPS nconv=0 first unconverged value (error) -302.035 (3.46893763e-06)
150945 EPS nconv=0 first unconverged value (error) -302.035 (3.63313173e-06)
150946 EPS nconv=0 first unconverged value (error) -302.035 (3.11868870e-06)
150947 EPS nconv=0 first unconverged value (error) -302.035 (2.55535657e-06)
150948 EPS nconv=0 first unconverged value (error) -302.035 (2.43781560e-06)
150949 EPS nconv=0 first unconverged value (error) -302.035 (2.43781560e-06)
150950 EPS nconv=0 first unconverged value (error) -302.035 (2.36667152e-06)
150951 EPS nconv=0 first unconverged value (error) -302.035 (2.47414573e-06)
150952 EPS nconv=0 first unconverged value (error) -302.035 (2.24069864e-06)
150953 EPS nconv=0 first unconverged value (error) -302.035 (1.95229330e-06)
150954 EPS nconv=0 first unconverged value (error) -302.035 (1.91199177e-06)
150955 EPS nconv=0 first unconverged value (error) -302.035 (1.91199177e-06)
150956 EPS nconv=0 first unconverged value (error) -302.035 (1.93439988e-06)
150957 EPS nconv=0 first unconverged value (error) -302.035 (1.88633108e-06)
150958 EPS nconv=0 first unconverged value (error) -302.035 (1.85177990e-06)
150959 EPS nconv=0 first unconverged value (error) -302.035 (1.83348235e-06)
150960 EPS nconv=0 first unconverged value (error) -302.035 (1.83051055e-06)
150961 EPS nconv=0 first unconverged value (error) -302.035 (1.83051055e-06)
150962 EPS nconv=0 first unconverged value (error) -302.035 (2.35271410e-06)
150963 EPS nconv=0 first unconverged value (error) -302.035 (2.12647628e-06)
150964 EPS nconv=0 first unconverged value (error) -302.035 (2.03432372e-06)
150965 EPS nconv=0 first unconverged value (error) -302.035 (1.98832035e-06)
150966 EPS nconv=0 first unconverged value (error) -302.035 (1.96710272e-06)
150967 EPS nconv=0 first unconverged value (error) -302.035 (1.96710272e-06)
150968 EPS nconv=0 first unconverged value (error) -302.035 (3.74798755e-06)
150969 EPS nconv=0 first unconverged value (error) -302.035 (3.32441956e-06)
150970 EPS nconv=0 first unconverged value (error) -302.035 (3.00537520e-06)
150971 EPS nconv=0 first unconverged value (error) -302.035 (2.99093940e-06)
150972 EPS nconv=0 first unconverged value (error) -302.035 (2.88597445e-06)
150973 EPS nconv=0 first unconverged value (error) -302.035 (2.88597445e-06)
150974 EPS nconv=0 first unconverged value (error) -302.035 (3.23848007e-06)
150975 EPS nconv=0 first unconverged value (error) -302.035 (3.14238751e-06)
150976 EPS nconv=0 first unconverged value (error) -302.035 (2.49953353e-06)
150977 EPS nconv=0 first unconverged value (error) -302.035 (2.30777220e-06)
150978 EPS nconv=0 first unconverged value (error) -302.035 (2.29492391e-06)
150979 EPS nconv=0 first unconverged value (error) -302.035 (2.29492391e-06)
150980 EPS nconv=0 first unconverged value (error) -302.035 (2.43359837e-06)
150981 EPS nconv=0 first unconverged value (error) -302.035 (2.46779777e-06)
150982 EPS nconv=0 first unconverged value (error) -302.035 (2.31649711e-06)
150983 EPS nconv=0 first unconverged value (error) -302.035 (1.98092255e-06)
150984 EPS nconv=0 first unconverged value (error) -302.035 (1.93677071e-06)
150985 EPS nconv=0 first unconverged value (error) -302.035 (1.93677071e-06)
150986 EPS nconv=0 first unconverged value (error) -302.035 (1.91241530e-06)
150987 EPS nconv=0 first unconverged value (error) -302.035 (2.04721173e-06)
150988 EPS nconv=0 first unconverged value (error) -302.035 (1.88781738e-06)
150989 EPS nconv=0 first unconverged value (error) -302.035 (1.81613520e-06)
150990 EPS nconv=0 first unconverged value (error) -302.035 (1.80768350e-06)
150991 EPS nconv=0 first unconverged value (error) -302.035 (1.80768350e-06)
150992 EPS nconv=0 first unconverged value (error) -302.035 (2.01260164e-06)
150993 EPS nconv=0 first unconverged value (error) -302.035 (1.94302289e-06)
150994 EPS nconv=0 first unconverged value (error) -302.035 (1.92782426e-06)
150995 EPS nconv=0 first unconverged value (error) -302.035 (1.91366079e-06)
150996 EPS nconv=0 first unconverged value (error) -302.035 (1.89285957e-06)
150997 EPS nconv=0 first unconverged value (error) -302.035 (1.89285957e-06)
150998 EPS nconv=0 first unconverged value (error) -302.035 (1.95057824e-06)
150999 EPS nconv=0 first unconverged value (error) -302.035 (1.98523132e-06)
151000 EPS nconv=0 first unconverged value (error) -302.035 (1.89163416e-06)
151001 EPS nconv=0 first unconverged value (error) -302.035 (1.83861696e-06)
151002 EPS nconv=0 first unconverged value (error) -302.035 (1.83311466e-06)
151003 EPS nconv=0 first unconverged value (error) -302.035 (1.83311466e-06)
151004 EPS nconv=0 first unconverged value (error) -302.035 (2.33752746e-06)
151005 EPS nconv=0 first unconverged value (error) -302.035 (2.14286106e-06)
151006 EPS nconv=0 first unconverged value (error) -302.035 (2.02391875e-06)
151007 EPS nconv=0 first unconverged value (error) -302.035 (1.99991467e-06)
151008 EPS nconv=0 first unconverged value (error) -302.035 (1.97418512e-06)
151009 EPS nconv=0 first unconverged value (error) -302.035 (1.97418512e-06)
151010 EPS nconv=0 first unconverged value (error) -302.035 (4.52203676e-06)
151011 EPS nconv=0 first unconverged value (error) -302.035 (3.92991082e-06)
151012 EPS nconv=0 first unconverged value (error) -302.035 (3.55315126e-06)
151013 EPS nconv=0 first unconverged value (error) -302.035 (3.51522640e-06)
151014 EPS nconv=0 first unconverged value (error) -302.035 (3.34265873e-06)
151015 EPS nconv=0 first unconverged value (error) -302.035 (3.34265873e-06)
151016 EPS nconv=0 first unconverged value (error) -302.035 (5.06022320e-06)
151017 EPS nconv=0 first unconverged value (error) -302.035 (4.45703094e-06)
151018 EPS nconv=0 first unconverged value (error) -302.035 (3.67626927e-06)
151019 EPS nconv=0 first unconverged value (error) -302.035 (3.56506985e-06)
151020 EPS nconv=0 first unconverged value (error) -302.035 (3.58804608e-06)
151021 EPS nconv=0 first unconverged value (error) -302.035 (3.58804608e-06)
151022 EPS nconv=0 first unconverged value (error) -302.035 (4.01628581e-06)
151023 EPS nconv=0 first unconverged value (error) -302.035 (4.16403146e-06)
151024 EPS nconv=0 first unconverged value (error) -302.035 (3.29543487e-06)
151025 EPS nconv=0 first unconverged value (error) -302.035 (2.58967359e-06)
151026 EPS nconv=0 first unconverged value (error) -302.035 (2.34802603e-06)
151027 EPS nconv=0 first unconverged value (error) -302.035 (2.34802603e-06)
151028 EPS nconv=0 first unconverged value (error) -302.035 (3.20524713e-06)
151029 EPS nconv=0 first unconverged value (error) -302.035 (3.24158942e-06)
151030 EPS nconv=0 first unconverged value (error) -302.035 (2.77362690e-06)
151031 EPS nconv=0 first unconverged value (error) -302.035 (2.58739912e-06)
151032 EPS nconv=0 first unconverged value (error) -302.035 (2.50285972e-06)
151033 EPS nconv=0 first unconverged value (error) -302.035 (2.50285972e-06)
151034 EPS nconv=0 first unconverged value (error) -302.035 (2.67372317e-06)
151035 EPS nconv=0 first unconverged value (error) -302.035 (2.90511250e-06)
151036 EPS nconv=0 first unconverged value (error) -302.035 (2.45322763e-06)
151037 EPS nconv=0 first unconverged value (error) -302.035 (2.19090914e-06)
151038 EPS nconv=0 first unconverged value (error) -302.035 (2.12896028e-06)
151039 EPS nconv=0 first unconverged value (error) -302.035 (2.12896028e-06)
151040 EPS nconv=0 first unconverged value (error) -302.035 (3.36914205e-06)
151041 EPS nconv=0 first unconverged value (error) -302.035 (3.11848826e-06)
151042 EPS nconv=0 first unconverged value (error) -302.035 (2.82921959e-06)
151043 EPS nconv=0 first unconverged value (error) -302.035 (2.58106641e-06)
151044 EPS nconv=0 first unconverged value (error) -302.035 (2.42486656e-06)
151045 EPS nconv=0 first unconverged value (error) -302.035 (2.42486656e-06)
151046 EPS nconv=0 first unconverged value (error) -302.035 (2.52298320e-06)
151047 EPS nconv=0 first unconverged value (error) -302.035 (2.80441546e-06)
151048 EPS nconv=0 first unconverged value (error) -302.035 (2.42162417e-06)
151049 EPS nconv=0 first unconverged value (error) -302.035 (2.09185473e-06)
151050 EPS nconv=0 first unconverged value (error) -302.035 (1.96835342e-06)
151051 EPS nconv=0 first unconverged value (error) -302.035 (1.96835342e-06)
151052 EPS nconv=0 first unconverged value (error) -302.035 (2.02810706e-06)
151053 EPS nconv=0 first unconverged value (error) -302.035 (2.01685643e-06)
151054 EPS nconv=0 first unconverged value (error) -302.035 (1.95323085e-06)
151055 EPS nconv=0 first unconverged value (error) -302.035 (1.93068608e-06)
151056 EPS nconv=0 first unconverged value (error) -302.035 (1.90887460e-06)
151057 EPS nconv=0 first unconverged value (error) -302.035 (1.90887460e-06)
151058 EPS nconv=0 first unconverged value (error) -302.035 (2.50388750e-06)
151059 EPS nconv=0 first unconverged value (error) -302.035 (2.38596546e-06)
151060 EPS nconv=0 first unconverged value (error) -302.035 (2.29462665e-06)
151061 EPS nconv=0 first unconverged value (error) -302.035 (2.17258426e-06)
151062 EPS nconv=0 first unconverged value (error) -302.035 (2.08952007e-06)
151063 EPS nconv=0 first unconverged value (error) -302.035 (2.08952007e-06)
151064 EPS nconv=0 first unconverged value (error) -302.035 (3.78528454e-06)
151065 EPS nconv=0 first unconverged value (error) -302.035 (3.22311071e-06)
151066 EPS nconv=0 first unconverged value (error) -302.035 (2.92095807e-06)
151067 EPS nconv=0 first unconverged value (error) -302.035 (2.78005715e-06)
151068 EPS nconv=0 first unconverged value (error) -302.035 (2.68419202e-06)
151069 EPS nconv=0 first unconverged value (error) -302.035 (2.68419202e-06)
151070 EPS nconv=0 first unconverged value (error) -302.035 (3.30026177e-06)
151071 EPS nconv=0 first unconverged value (error) -302.035 (3.42881154e-06)
151072 EPS nconv=0 first unconverged value (error) -302.035 (2.71277130e-06)
151073 EPS nconv=0 first unconverged value (error) -302.035 (2.50057262e-06)
151074 EPS nconv=0 first unconverged value (error) -302.035 (2.39226111e-06)
151075 EPS nconv=0 first unconverged value (error) -302.035 (2.39226111e-06)
151076 EPS nconv=0 first unconverged value (error) -302.035 (4.04680587e-06)
151077 EPS nconv=0 first unconverged value (error) -302.035 (3.77894521e-06)
151078 EPS nconv=0 first unconverged value (error) -302.035 (3.23612421e-06)
151079 EPS nconv=0 first unconverged value (error) -302.035 (3.00903934e-06)
151080 EPS nconv=0 first unconverged value (error) -302.035 (2.74051216e-06)
151081 EPS nconv=0 first unconverged value (error) -302.035 (2.74051216e-06)
151082 EPS nconv=0 first unconverged value (error) -302.035 (2.71094719e-06)
151083 EPS nconv=0 first unconverged value (error) -302.035 (3.33543650e-06)
151084 EPS nconv=0 first unconverged value (error) -302.035 (2.58168316e-06)
151085 EPS nconv=0 first unconverged value (error) -302.035 (2.23640668e-06)
151086 EPS nconv=0 first unconverged value (error) -302.035 (2.08643025e-06)
151087 EPS nconv=0 first unconverged value (error) -302.035 (2.08643025e-06)
151088 EPS nconv=0 first unconverged value (error) -302.035 (4.48758191e-06)
151089 EPS nconv=0 first unconverged value (error) -302.035 (3.73490449e-06)
151090 EPS nconv=0 first unconverged value (error) -302.035 (3.48673420e-06)
151091 EPS nconv=0 first unconverged value (error) -302.035 (3.36095657e-06)
151092 EPS nconv=0 first unconverged value (error) -302.035 (3.09598485e-06)
151093 EPS nconv=0 first unconverged value (error) -302.035 (3.09598485e-06)
151094 EPS nconv=0 first unconverged value (error) -302.035 (7.53105892e-06)
151095 EPS nconv=0 first unconverged value (error) -302.035 (6.89159104e-06)
151096 EPS nconv=0 first unconverged value (error) -302.035 (5.93988385e-06)
151097 EPS nconv=0 first unconverged value (error) -302.035 (5.91752233e-06)
151098 EPS nconv=0 first unconverged value (error) -302.035 (5.88827446e-06)
151099 EPS nconv=0 first unconverged value (error) -302.035 (5.88827446e-06)
151100 EPS nconv=0 first unconverged value (error) -302.035 (7.39567086e-06)
151101 EPS nconv=0 first unconverged value (error) -302.035 (5.88986267e-06)
151102 EPS nconv=0 first unconverged value (error) -302.035 (4.66379021e-06)
151103 EPS nconv=0 first unconverged value (error) -302.035 (4.04037227e-06)
151104 EPS nconv=0 first unconverged value (error) -302.035 (3.84693370e-06)
151105 EPS nconv=0 first unconverged value (error) -302.035 (3.84693370e-06)
151106 EPS nconv=0 first unconverged value (error) -302.035 (3.51386103e-06)
151107 EPS nconv=0 first unconverged value (error) -302.035 (4.62667019e-06)
151108 EPS nconv=0 first unconverged value (error) -302.035 (3.40789582e-06)
151109 EPS nconv=0 first unconverged value (error) -302.035 (2.31034943e-06)
151110 EPS nconv=0 first unconverged value (error) -302.035 (2.06302390e-06)
151111 EPS nconv=0 first unconverged value (error) -302.035 (2.06302390e-06)
151112 EPS nconv=0 first unconverged value (error) -302.035 (3.39767056e-06)
151113 EPS nconv=0 first unconverged value (error) -302.035 (2.95882491e-06)
151114 EPS nconv=0 first unconverged value (error) -302.035 (2.87360999e-06)
151115 EPS nconv=0 first unconverged value (error) -302.035 (2.82638788e-06)
151116 EPS nconv=0 first unconverged value (error) -302.035 (2.70424538e-06)
151117 EPS nconv=0 first unconverged value (error) -302.035 (2.70424538e-06)
151118 EPS nconv=0 first unconverged value (error) -302.035 (2.96715924e-06)
151119 EPS nconv=0 first unconverged value (error) -302.035 (3.07432601e-06)
151120 EPS nconv=0 first unconverged value (error) -302.035 (2.32461447e-06)
151121 EPS nconv=0 first unconverged value (error) -302.035 (2.24126668e-06)
151122 EPS nconv=0 first unconverged value (error) -302.035 (2.27494047e-06)
151123 EPS nconv=0 first unconverged value (error) -302.035 (2.27494047e-06)
151124 EPS nconv=0 first unconverged value (error) -302.035 (2.44710457e-06)
151125 EPS nconv=0 first unconverged value (error) -302.035 (2.29180681e-06)
151126 EPS nconv=0 first unconverged value (error) -302.035 (2.17803889e-06)
151127 EPS nconv=0 first unconverged value (error) -302.035 (1.99682853e-06)
151128 EPS nconv=0 first unconverged value (error) -302.035 (1.94479513e-06)
151129 EPS nconv=0 first unconverged value (error) -302.035 (1.94479513e-06)
151130 EPS nconv=0 first unconverged value (error) -302.035 (3.23974563e-06)
151131 EPS nconv=0 first unconverged value (error) -302.035 (2.87035036e-06)
151132 EPS nconv=0 first unconverged value (error) -302.035 (2.64110056e-06)
151133 EPS nconv=0 first unconverged value (error) -302.035 (2.49338075e-06)
151134 EPS nconv=0 first unconverged value (error) -302.035 (2.42508465e-06)
151135 EPS nconv=0 first unconverged value (error) -302.035 (2.42508465e-06)
151136 EPS nconv=0 first unconverged value (error) -302.035 (4.01978660e-06)
151137 EPS nconv=0 first unconverged value (error) -302.035 (3.63839891e-06)
151138 EPS nconv=0 first unconverged value (error) -302.035 (3.16313298e-06)
151139 EPS nconv=0 first unconverged value (error) -302.035 (3.16303550e-06)
151140 EPS nconv=0 first unconverged value (error) -302.035 (2.96737971e-06)
151141 EPS nconv=0 first unconverged value (error) -302.035 (2.96737971e-06)
151142 EPS nconv=0 first unconverged value (error) -302.035 (2.94161769e-06)
151143 EPS nconv=0 first unconverged value (error) -302.035 (3.14308410e-06)
151144 EPS nconv=0 first unconverged value (error) -302.035 (2.28170609e-06)
151145 EPS nconv=0 first unconverged value (error) -302.035 (2.12320790e-06)
151146 EPS nconv=0 first unconverged value (error) -302.035 (2.14963851e-06)
151147 EPS nconv=0 first unconverged value (error) -302.035 (2.14963851e-06)
151148 EPS nconv=0 first unconverged value (error) -302.035 (3.27209407e-06)
151149 EPS nconv=0 first unconverged value (error) -302.035 (2.67639851e-06)
151150 EPS nconv=0 first unconverged value (error) -302.035 (2.43299455e-06)
151151 EPS nconv=0 first unconverged value (error) -302.035 (2.35427869e-06)
151152 EPS nconv=0 first unconverged value (error) -302.035 (2.29303321e-06)
151153 EPS nconv=0 first unconverged value (error) -302.035 (2.29303321e-06)
151154 EPS nconv=0 first unconverged value (error) -302.035 (3.07122095e-06)
151155 EPS nconv=0 first unconverged value (error) -302.035 (3.51140459e-06)
151156 EPS nconv=0 first unconverged value (error) -302.035 (2.75216184e-06)
151157 EPS nconv=0 first unconverged value (error) -302.035 (2.46501515e-06)
151158 EPS nconv=0 first unconverged value (error) -302.035 (2.27588658e-06)
151159 EPS nconv=0 first unconverged value (error) -302.035 (2.27588658e-06)
151160 EPS nconv=0 first unconverged value (error) -302.035 (2.21856834e-06)
151161 EPS nconv=0 first unconverged value (error) -302.035 (2.37654705e-06)
151162 EPS nconv=0 first unconverged value (error) -302.035 (2.09046659e-06)
151163 EPS nconv=0 first unconverged value (error) -302.035 (1.98864937e-06)
151164 EPS nconv=0 first unconverged value (error) -302.035 (1.90554955e-06)
151165 EPS nconv=0 first unconverged value (error) -302.035 (1.90554955e-06)
151166 EPS nconv=0 first unconverged value (error) -302.035 (4.49523988e-06)
151167 EPS nconv=0 first unconverged value (error) -302.035 (3.97514790e-06)
151168 EPS nconv=0 first unconverged value (error) -302.035 (3.61842737e-06)
151169 EPS nconv=0 first unconverged value (error) -302.035 (3.42493577e-06)
151170 EPS nconv=0 first unconverged value (error) -302.035 (3.16008598e-06)
151171 EPS nconv=0 first unconverged value (error) -302.035 (3.16008598e-06)
151172 EPS nconv=0 first unconverged value (error) -302.035 (1.14610519e-05)
151173 EPS nconv=0 first unconverged value (error) -302.035 (1.13098029e-05)
151174 EPS nconv=0 first unconverged value (error) -302.035 (9.17933192e-06)
151175 EPS nconv=0 first unconverged value (error) -302.035 (8.85773129e-06)
151176 EPS nconv=0 first unconverged value (error) -302.035 (8.30265093e-06)
151177 EPS nconv=0 first unconverged value (error) -302.035 (8.30265093e-06)
151178 EPS nconv=0 first unconverged value (error) -302.035 (1.03673998e-05)
151179 EPS nconv=0 first unconverged value (error) -302.035 (9.34637179e-06)
151180 EPS nconv=0 first unconverged value (error) -302.035 (8.56809721e-06)
151181 EPS nconv=0 first unconverged value (error) -302.035 (7.32881903e-06)
151182 EPS nconv=0 first unconverged value (error) -302.035 (6.59773798e-06)
151183 EPS nconv=0 first unconverged value (error) -302.035 (6.59773798e-06)
151184 EPS nconv=0 first unconverged value (error) -302.035 (6.91349365e-06)
151185 EPS nconv=0 first unconverged value (error) -302.035 (6.01547571e-06)
151186 EPS nconv=0 first unconverged value (error) -302.035 (5.08461930e-06)
151187 EPS nconv=0 first unconverged value (error) -302.035 (4.14723324e-06)
151188 EPS nconv=0 first unconverged value (error) -302.035 (3.70474290e-06)
151189 EPS nconv=0 first unconverged value (error) -302.035 (3.70474290e-06)
151190 EPS nconv=0 first unconverged value (error) -302.035 (2.88977643e-06)
151191 EPS nconv=0 first unconverged value (error) -302.035 (3.13675148e-06)
151192 EPS nconv=0 first unconverged value (error) -302.035 (3.20096602e-06)
151193 EPS nconv=0 first unconverged value (error) -302.035 (2.09503104e-06)
151194 EPS nconv=0 first unconverged value (error) -302.035 (1.84280541e-06)
151195 EPS nconv=0 first unconverged value (error) -302.035 (1.84280541e-06)
151196 EPS nconv=0 first unconverged value (error) -302.035 (6.71898226e-06)
151197 EPS nconv=0 first unconverged value (error) -302.035 (6.12379306e-06)
151198 EPS nconv=0 first unconverged value (error) -302.035 (5.62527468e-06)
151199 EPS nconv=0 first unconverged value (error) -302.035 (5.29836079e-06)
151200 EPS nconv=0 first unconverged value (error) -302.035 (5.24122072e-06)
151201 EPS nconv=0 first unconverged value (error) -302.035 (5.24122072e-06)
151202 EPS nconv=0 first unconverged value (error) -302.035 (7.87166076e-06)
151203 EPS nconv=0 first unconverged value (error) -302.035 (5.90704684e-06)
151204 EPS nconv=0 first unconverged value (error) -302.035 (4.84870474e-06)
151205 EPS nconv=0 first unconverged value (error) -302.035 (4.57735477e-06)
151206 EPS nconv=0 first unconverged value (error) -302.035 (4.33741321e-06)
151207 EPS nconv=0 first unconverged value (error) -302.035 (4.33741321e-06)
151208 EPS nconv=0 first unconverged value (error) -302.035 (4.27521125e-06)
151209 EPS nconv=0 first unconverged value (error) -302.035 (5.68797523e-06)
151210 EPS nconv=0 first unconverged value (error) -302.035 (3.73879148e-06)
151211 EPS nconv=0 first unconverged value (error) -302.035 (2.89522725e-06)
151212 EPS nconv=0 first unconverged value (error) -302.035 (2.28994478e-06)
151213 EPS nconv=0 first unconverged value (error) -302.035 (2.28994478e-06)
151214 EPS nconv=0 first unconverged value (error) -302.035 (6.08741571e-06)
151215 EPS nconv=0 first unconverged value (error) -302.035 (5.39070501e-06)
151216 EPS nconv=0 first unconverged value (error) -302.035 (4.71432060e-06)
151217 EPS nconv=0 first unconverged value (error) -302.035 (4.65071901e-06)
151218 EPS nconv=0 first unconverged value (error) -302.035 (4.28545980e-06)
151219 EPS nconv=0 first unconverged value (error) -302.035 (4.28545980e-06)
151220 EPS nconv=0 first unconverged value (error) -302.035 (4.55743887e-06)
151221 EPS nconv=0 first unconverged value (error) -302.035 (5.04315231e-06)
151222 EPS nconv=0 first unconverged value (error) -302.035 (3.98377242e-06)
151223 EPS nconv=0 first unconverged value (error) -302.035 (2.78585215e-06)
151224 EPS nconv=0 first unconverged value (error) -302.035 (2.63035170e-06)
151225 EPS nconv=0 first unconverged value (error) -302.035 (2.63035170e-06)
151226 EPS nconv=0 first unconverged value (error) -302.035 (2.46958261e-06)
151227 EPS nconv=0 first unconverged value (error) -302.035 (2.37954620e-06)
151228 EPS nconv=0 first unconverged value (error) -302.035 (2.11326499e-06)
151229 EPS nconv=0 first unconverged value (error) -302.035 (1.99129403e-06)
151230 EPS nconv=0 first unconverged value (error) -302.035 (1.92546898e-06)
151231 EPS nconv=0 first unconverged value (error) -302.035 (1.92546898e-06)
151232 EPS nconv=0 first unconverged value (error) -302.035 (3.27895251e-06)
151233 EPS nconv=0 first unconverged value (error) -302.035 (2.75487507e-06)
151234 EPS nconv=0 first unconverged value (error) -302.035 (2.54803734e-06)
151235 EPS nconv=0 first unconverged value (error) -302.035 (2.45709812e-06)
151236 EPS nconv=0 first unconverged value (error) -302.035 (2.38099607e-06)
151237 EPS nconv=0 first unconverged value (error) -302.035 (2.38099607e-06)
151238 EPS nconv=0 first unconverged value (error) -302.035 (8.42489432e-06)
151239 EPS nconv=0 first unconverged value (error) -302.035 (8.27029003e-06)
151240 EPS nconv=0 first unconverged value (error) -302.035 (6.93977176e-06)
151241 EPS nconv=0 first unconverged value (error) -302.035 (6.59983087e-06)
151242 EPS nconv=0 first unconverged value (error) -302.035 (6.48609561e-06)
151243 EPS nconv=0 first unconverged value (error) -302.035 (6.48609561e-06)
151244 EPS nconv=0 first unconverged value (error) -302.035 (8.47321943e-06)
151245 EPS nconv=0 first unconverged value (error) -302.035 (6.90287427e-06)
151246 EPS nconv=0 first unconverged value (error) -302.035 (6.13590220e-06)
151247 EPS nconv=0 first unconverged value (error) -302.035 (5.46548059e-06)
151248 EPS nconv=0 first unconverged value (error) -302.035 (4.69121650e-06)
151249 EPS nconv=0 first unconverged value (error) -302.035 (4.69121650e-06)
151250 EPS nconv=0 first unconverged value (error) -302.035 (4.52314442e-06)
151251 EPS nconv=0 first unconverged value (error) -302.035 (5.65320373e-06)
151252 EPS nconv=0 first unconverged value (error) -302.035 (3.89372255e-06)
151253 EPS nconv=0 first unconverged value (error) -302.035 (3.18497767e-06)
151254 EPS nconv=0 first unconverged value (error) -302.035 (2.23086363e-06)
151255 EPS nconv=0 first unconverged value (error) -302.035 (2.23086363e-06)
151256 EPS nconv=0 first unconverged value (error) -302.035 (4.60523642e-06)
151257 EPS nconv=0 first unconverged value (error) -302.035 (4.78721412e-06)
151258 EPS nconv=0 first unconverged value (error) -302.035 (4.16182209e-06)
151259 EPS nconv=0 first unconverged value (error) -302.035 (3.71524261e-06)
151260 EPS nconv=0 first unconverged value (error) -302.035 (3.58665778e-06)
151261 EPS nconv=0 first unconverged value (error) -302.035 (3.58665778e-06)
151262 EPS nconv=0 first unconverged value (error) -302.035 (3.59739810e-06)
151263 EPS nconv=0 first unconverged value (error) -302.035 (3.67928234e-06)
151264 EPS nconv=0 first unconverged value (error) -302.035 (3.52071698e-06)
151265 EPS nconv=0 first unconverged value (error) -302.035 (2.52740037e-06)
151266 EPS nconv=0 first unconverged value (error) -302.035 (2.11085816e-06)
151267 EPS nconv=0 first unconverged value (error) -302.035 (2.11085816e-06)
151268 EPS nconv=0 first unconverged value (error) -302.035 (4.61842144e-06)
151269 EPS nconv=0 first unconverged value (error) -302.035 (4.12042514e-06)
151270 EPS nconv=0 first unconverged value (error) -302.035 (3.91041134e-06)
151271 EPS nconv=0 first unconverged value (error) -302.035 (3.66153593e-06)
151272 EPS nconv=0 first unconverged value (error) -302.035 (3.49614984e-06)
151273 EPS nconv=0 first unconverged value (error) -302.035 (3.49614984e-06)
151274 EPS nconv=0 first unconverged value (error) -302.035 (6.78055221e-06)
151275 EPS nconv=0 first unconverged value (error) -302.035 (5.89885993e-06)
151276 EPS nconv=0 first unconverged value (error) -302.035 (4.94379335e-06)
151277 EPS nconv=0 first unconverged value (error) -302.035 (4.88611443e-06)
151278 EPS nconv=0 first unconverged value (error) -302.035 (4.72594593e-06)
151279 EPS nconv=0 first unconverged value (error) -302.035 (4.72594593e-06)
151280 EPS nconv=0 first unconverged value (error) -302.035 (4.85761996e-06)
151281 EPS nconv=0 first unconverged value (error) -302.035 (5.44101001e-06)
151282 EPS nconv=0 first unconverged value (error) -302.035 (4.34726042e-06)
151283 EPS nconv=0 first unconverged value (error) -302.035 (3.34041309e-06)
151284 EPS nconv=0 first unconverged value (error) -302.035 (2.59281217e-06)
151285 EPS nconv=0 first unconverged value (error) -302.035 (2.59281217e-06)
151286 EPS nconv=0 first unconverged value (error) -302.035 (4.85142175e-06)
151287 EPS nconv=0 first unconverged value (error) -302.035 (4.17858642e-06)
151288 EPS nconv=0 first unconverged value (error) -302.035 (3.75800896e-06)
151289 EPS nconv=0 first unconverged value (error) -302.035 (3.60181996e-06)
151290 EPS nconv=0 first unconverged value (error) -302.035 (3.37728769e-06)
151291 EPS nconv=0 first unconverged value (error) -302.035 (3.37728769e-06)
151292 EPS nconv=0 first unconverged value (error) -302.035 (6.02814440e-06)
151293 EPS nconv=0 first unconverged value (error) -302.035 (5.67389278e-06)
151294 EPS nconv=0 first unconverged value (error) -302.035 (4.63595019e-06)
151295 EPS nconv=0 first unconverged value (error) -302.035 (4.49751242e-06)
151296 EPS nconv=0 first unconverged value (error) -302.035 (4.33339251e-06)
151297 EPS nconv=0 first unconverged value (error) -302.035 (4.33339251e-06)
151298 EPS nconv=0 first unconverged value (error) -302.035 (6.38073881e-06)
151299 EPS nconv=0 first unconverged value (error) -302.035 (6.17196044e-06)
151300 EPS nconv=0 first unconverged value (error) -302.035 (5.22711291e-06)
151301 EPS nconv=0 first unconverged value (error) -302.035 (4.24028784e-06)
151302 EPS nconv=0 first unconverged value (error) -302.035 (3.83216096e-06)
151303 EPS nconv=0 first unconverged value (error) -302.035 (3.83216096e-06)
151304 EPS nconv=0 first unconverged value (error) -302.035 (4.06463354e-06)
151305 EPS nconv=0 first unconverged value (error) -302.035 (4.65175262e-06)
151306 EPS nconv=0 first unconverged value (error) -302.035 (3.93830525e-06)
151307 EPS nconv=0 first unconverged value (error) -302.035 (2.50792772e-06)
151308 EPS nconv=0 first unconverged value (error) -302.035 (2.20170617e-06)
151309 EPS nconv=0 first unconverged value (error) -302.035 (2.20170617e-06)
151310 EPS nconv=0 first unconverged value (error) -302.035 (5.72568142e-06)
151311 EPS nconv=0 first unconverged value (error) -302.035 (4.46239493e-06)
151312 EPS nconv=0 first unconverged value (error) -302.035 (3.93557421e-06)
151313 EPS nconv=0 first unconverged value (error) -302.035 (3.83508789e-06)
151314 EPS nconv=0 first unconverged value (error) -302.035 (3.63934764e-06)
151315 EPS nconv=0 first unconverged value (error) -302.035 (3.63934764e-06)
151316 EPS nconv=0 first unconverged value (error) -302.035 (1.24518939e-05)
151317 EPS nconv=0 first unconverged value (error) -302.035 (1.10934710e-05)
151318 EPS nconv=0 first unconverged value (error) -302.035 (9.33166014e-06)
151319 EPS nconv=0 first unconverged value (error) -302.035 (9.10146688e-06)
151320 EPS nconv=0 first unconverged value (error) -302.035 (8.95942683e-06)
151321 EPS nconv=0 first unconverged value (error) -302.035 (8.95942683e-06)
151322 EPS nconv=0 first unconverged value (error) -302.035 (9.19183099e-06)
151323 EPS nconv=0 first unconverged value (error) -302.035 (9.26380676e-06)
151324 EPS nconv=0 first unconverged value (error) -302.035 (7.77638756e-06)
151325 EPS nconv=0 first unconverged value (error) -302.035 (4.91320605e-06)
151326 EPS nconv=0 first unconverged value (error) -302.035 (3.98351960e-06)
151327 EPS nconv=0 first unconverged value (error) -302.035 (3.98351960e-06)
151328 EPS nconv=0 first unconverged value (error) -302.035 (3.34679251e-06)
151329 EPS nconv=0 first unconverged value (error) -302.035 (3.64057303e-06)
151330 EPS nconv=0 first unconverged value (error) -302.035 (3.16764095e-06)
151331 EPS nconv=0 first unconverged value (error) -302.035 (2.38861562e-06)
151332 EPS nconv=0 first unconverged value (error) -302.035 (2.32487597e-06)
151333 EPS nconv=0 first unconverged value (error) -302.035 (2.32487597e-06)
151334 EPS nconv=0 first unconverged value (error) -302.035 (2.45686055e-06)
151335 EPS nconv=0 first unconverged value (error) -302.035 (2.71480397e-06)
151336 EPS nconv=0 first unconverged value (error) -302.035 (2.21073039e-06)
151337 EPS nconv=0 first unconverged value (error) -302.035 (1.94824856e-06)
151338 EPS nconv=0 first unconverged value (error) -302.035 (1.89462479e-06)
151339 EPS nconv=0 first unconverged value (error) -302.035 (1.89462479e-06)
151340 EPS nconv=0 first unconverged value (error) -302.035 (1.90829420e-06)
151341 EPS nconv=0 first unconverged value (error) -302.035 (1.92102064e-06)
151342 EPS nconv=0 first unconverged value (error) -302.035 (1.86940651e-06)
151343 EPS nconv=0 first unconverged value (error) -302.035 (1.85873720e-06)
151344 EPS nconv=0 first unconverged value (error) -302.035 (1.84594666e-06)
151345 EPS nconv=0 first unconverged value (error) -302.035 (1.84594666e-06)
151346 EPS nconv=0 first unconverged value (error) -302.035 (2.37705871e-06)
151347 EPS nconv=0 first unconverged value (error) -302.035 (2.28455332e-06)
151348 EPS nconv=0 first unconverged value (error) -302.035 (2.17335524e-06)
151349 EPS nconv=0 first unconverged value (error) -302.035 (2.11736560e-06)
151350 EPS nconv=0 first unconverged value (error) -302.035 (2.06684778e-06)
151351 EPS nconv=0 first unconverged value (error) -302.035 (2.06684778e-06)
151352 EPS nconv=0 first unconverged value (error) -302.035 (3.18082675e-06)
151353 EPS nconv=0 first unconverged value (error) -302.035 (2.81538282e-06)
151354 EPS nconv=0 first unconverged value (error) -302.035 (2.61321648e-06)
151355 EPS nconv=0 first unconverged value (error) -302.035 (2.57084563e-06)
151356 EPS nconv=0 first unconverged value (error) -302.035 (2.50918186e-06)
151357 EPS nconv=0 first unconverged value (error) -302.035 (2.50918186e-06)
151358 EPS nconv=0 first unconverged value (error) -302.035 (4.22738693e-06)
151359 EPS nconv=0 first unconverged value (error) -302.035 (3.72739043e-06)
151360 EPS nconv=0 first unconverged value (error) -302.035 (3.06033737e-06)
151361 EPS nconv=0 first unconverged value (error) -302.035 (3.03396751e-06)
151362 EPS nconv=0 first unconverged value (error) -302.035 (2.86904020e-06)
151363 EPS nconv=0 first unconverged value (error) -302.035 (2.86904020e-06)
151364 EPS nconv=0 first unconverged value (error) -302.035 (4.45900235e-06)
151365 EPS nconv=0 first unconverged value (error) -302.035 (4.22786120e-06)
151366 EPS nconv=0 first unconverged value (error) -302.035 (3.47083869e-06)
151367 EPS nconv=0 first unconverged value (error) -302.035 (3.25650220e-06)
151368 EPS nconv=0 first unconverged value (error) -302.035 (2.98351129e-06)
151369 EPS nconv=0 first unconverged value (error) -302.035 (2.98351129e-06)
151370 EPS nconv=0 first unconverged value (error) -302.035 (3.99445269e-06)
151371 EPS nconv=0 first unconverged value (error) -302.035 (4.14684788e-06)
151372 EPS nconv=0 first unconverged value (error) -302.035 (3.38451151e-06)
151373 EPS nconv=0 first unconverged value (error) -302.035 (2.98950299e-06)
151374 EPS nconv=0 first unconverged value (error) -302.035 (2.74835480e-06)
151375 EPS nconv=0 first unconverged value (error) -302.035 (2.74835480e-06)
151376 EPS nconv=0 first unconverged value (error) -302.035 (2.79005941e-06)
151377 EPS nconv=0 first unconverged value (error) -302.035 (2.85255840e-06)
151378 EPS nconv=0 first unconverged value (error) -302.035 (2.39998641e-06)
151379 EPS nconv=0 first unconverged value (error) -302.035 (2.20057775e-06)
151380 EPS nconv=0 first unconverged value (error) -302.035 (2.16016239e-06)
151381 EPS nconv=0 first unconverged value (error) -302.035 (2.16016239e-06)
151382 EPS nconv=0 first unconverged value (error) -302.035 (3.13540201e-06)
151383 EPS nconv=0 first unconverged value (error) -302.035 (2.87336540e-06)
151384 EPS nconv=0 first unconverged value (error) -302.035 (2.58987958e-06)
151385 EPS nconv=0 first unconverged value (error) -302.035 (2.36126423e-06)
151386 EPS nconv=0 first unconverged value (error) -302.035 (2.28891157e-06)
151387 EPS nconv=0 first unconverged value (error) -302.035 (2.28891157e-06)
151388 EPS nconv=0 first unconverged value (error) -302.035 (2.94110695e-06)
151389 EPS nconv=0 first unconverged value (error) -302.035 (3.05534579e-06)
151390 EPS nconv=0 first unconverged value (error) -302.035 (2.50087065e-06)
151391 EPS nconv=0 first unconverged value (error) -302.035 (2.22620034e-06)
151392 EPS nconv=0 first unconverged value (error) -302.035 (2.08566023e-06)
151393 EPS nconv=0 first unconverged value (error) -302.035 (2.08566023e-06)
151394 EPS nconv=0 first unconverged value (error) -302.035 (2.58797552e-06)
151395 EPS nconv=0 first unconverged value (error) -302.035 (2.60160723e-06)
151396 EPS nconv=0 first unconverged value (error) -302.035 (2.29689658e-06)
151397 EPS nconv=0 first unconverged value (error) -302.035 (2.18877187e-06)
151398 EPS nconv=0 first unconverged value (error) -302.035 (2.12445242e-06)
151399 EPS nconv=0 first unconverged value (error) -302.035 (2.12445242e-06)
151400 EPS nconv=0 first unconverged value (error) -302.035 (2.89707156e-06)
151401 EPS nconv=0 first unconverged value (error) -302.035 (2.78613014e-06)
151402 EPS nconv=0 first unconverged value (error) -302.035 (2.59531785e-06)
151403 EPS nconv=0 first unconverged value (error) -302.035 (2.35057766e-06)
151404 EPS nconv=0 first unconverged value (error) -302.035 (2.24846322e-06)
151405 EPS nconv=0 first unconverged value (error) -302.035 (2.24846322e-06)
151406 EPS nconv=0 first unconverged value (error) -302.035 (2.98241740e-06)
151407 EPS nconv=0 first unconverged value (error) -302.035 (2.73708665e-06)
151408 EPS nconv=0 first unconverged value (error) -302.035 (2.51741969e-06)
151409 EPS nconv=0 first unconverged value (error) -302.035 (2.33354665e-06)
151410 EPS nconv=0 first unconverged value (error) -302.035 (2.21543532e-06)
151411 EPS nconv=0 first unconverged value (error) -302.035 (2.21543532e-06)
151412 EPS nconv=0 first unconverged value (error) -302.035 (2.94412015e-06)
151413 EPS nconv=0 first unconverged value (error) -302.035 (2.80223929e-06)
151414 EPS nconv=0 first unconverged value (error) -302.035 (2.37370388e-06)
151415 EPS nconv=0 first unconverged value (error) -302.035 (2.29257566e-06)
151416 EPS nconv=0 first unconverged value (error) -302.035 (2.19326801e-06)
151417 EPS nconv=0 first unconverged value (error) -302.035 (2.19326801e-06)
151418 EPS nconv=0 first unconverged value (error) -302.035 (2.41205060e-06)
151419 EPS nconv=0 first unconverged value (error) -302.035 (2.62761471e-06)
151420 EPS nconv=0 first unconverged value (error) -302.035 (2.28219947e-06)
151421 EPS nconv=0 first unconverged value (error) -302.035 (2.07860139e-06)
151422 EPS nconv=0 first unconverged value (error) -302.035 (2.01526475e-06)
151423 EPS nconv=0 first unconverged value (error) -302.035 (2.01526475e-06)
151424 EPS nconv=0 first unconverged value (error) -302.035 (2.28075953e-06)
151425 EPS nconv=0 first unconverged value (error) -302.035 (2.21375637e-06)
151426 EPS nconv=0 first unconverged value (error) -302.035 (2.12296088e-06)
151427 EPS nconv=0 first unconverged value (error) -302.035 (2.01997572e-06)
151428 EPS nconv=0 first unconverged value (error) -302.035 (1.99231964e-06)
151429 EPS nconv=0 first unconverged value (error) -302.035 (1.99231964e-06)
151430 EPS nconv=0 first unconverged value (error) -302.035 (4.02663377e-06)
151431 EPS nconv=0 first unconverged value (error) -302.035 (3.27613894e-06)
151432 EPS nconv=0 first unconverged value (error) -302.035 (3.03217320e-06)
151433 EPS nconv=0 first unconverged value (error) -302.035 (2.94730529e-06)
151434 EPS nconv=0 first unconverged value (error) -302.035 (2.77009222e-06)
151435 EPS nconv=0 first unconverged value (error) -302.035 (2.77009222e-06)
151436 EPS nconv=0 first unconverged value (error) -302.035 (4.08563021e-06)
151437 EPS nconv=0 first unconverged value (error) -302.035 (4.12279083e-06)
151438 EPS nconv=0 first unconverged value (error) -302.035 (3.07359586e-06)
151439 EPS nconv=0 first unconverged value (error) -302.035 (2.92106528e-06)
151440 EPS nconv=0 first unconverged value (error) -302.035 (2.74156345e-06)
151441 EPS nconv=0 first unconverged value (error) -302.035 (2.74156345e-06)
151442 EPS nconv=0 first unconverged value (error) -302.035 (3.49314490e-06)
151443 EPS nconv=0 first unconverged value (error) -302.035 (3.79937014e-06)
151444 EPS nconv=0 first unconverged value (error) -302.035 (3.19802768e-06)
151445 EPS nconv=0 first unconverged value (error) -302.035 (2.64611309e-06)
151446 EPS nconv=0 first unconverged value (error) -302.035 (2.47780402e-06)
151447 EPS nconv=0 first unconverged value (error) -302.035 (2.47780402e-06)
151448 EPS nconv=0 first unconverged value (error) -302.035 (2.56884173e-06)
151449 EPS nconv=0 first unconverged value (error) -302.035 (2.68613773e-06)
151450 EPS nconv=0 first unconverged value (error) -302.035 (2.38719227e-06)
151451 EPS nconv=0 first unconverged value (error) -302.035 (2.09370563e-06)
151452 EPS nconv=0 first unconverged value (error) -302.035 (2.07300858e-06)
151453 EPS nconv=0 first unconverged value (error) -302.035 (2.07300858e-06)
151454 EPS nconv=0 first unconverged value (error) -302.035 (2.03102902e-06)
151455 EPS nconv=0 first unconverged value (error) -302.035 (2.07802479e-06)
151456 EPS nconv=0 first unconverged value (error) -302.035 (1.94889280e-06)
151457 EPS nconv=0 first unconverged value (error) -302.035 (1.89155978e-06)
151458 EPS nconv=0 first unconverged value (error) -302.035 (1.87317710e-06)
151459 EPS nconv=0 first unconverged value (error) -302.035 (1.87317710e-06)
151460 EPS nconv=0 first unconverged value (error) -302.035 (1.91609357e-06)
151461 EPS nconv=0 first unconverged value (error) -302.035 (1.90878630e-06)
151462 EPS nconv=0 first unconverged value (error) -302.035 (1.85015976e-06)
151463 EPS nconv=0 first unconverged value (error) -302.035 (1.84259523e-06)
151464 EPS nconv=0 first unconverged value (error) -302.035 (1.82566221e-06)
151465 EPS nconv=0 first unconverged value (error) -302.035 (1.82566221e-06)
151466 EPS nconv=0 first unconverged value (error) -302.035 (1.93347926e-06)
151467 EPS nconv=0 first unconverged value (error) -302.035 (1.93405423e-06)
151468 EPS nconv=0 first unconverged value (error) -302.035 (1.87965574e-06)
151469 EPS nconv=0 first unconverged value (error) -302.035 (1.85031610e-06)
151470 EPS nconv=0 first unconverged value (error) -302.035 (1.84076984e-06)
151471 EPS nconv=0 first unconverged value (error) -302.035 (1.84076984e-06)
151472 EPS nconv=0 first unconverged value (error) -302.035 (2.40397495e-06)
151473 EPS nconv=0 first unconverged value (error) -302.035 (2.21125434e-06)
151474 EPS nconv=0 first unconverged value (error) -302.035 (2.15961857e-06)
151475 EPS nconv=0 first unconverged value (error) -302.035 (2.13916059e-06)
151476 EPS nconv=0 first unconverged value (error) -302.035 (2.05930510e-06)
151477 EPS nconv=0 first unconverged value (error) -302.035 (2.05930510e-06)
151478 EPS nconv=0 first unconverged value (error) -302.035 (3.38021284e-06)
151479 EPS nconv=0 first unconverged value (error) -302.035 (3.05698938e-06)
151480 EPS nconv=0 first unconverged value (error) -302.035 (2.71391254e-06)
151481 EPS nconv=0 first unconverged value (error) -302.035 (2.71608518e-06)
151482 EPS nconv=0 first unconverged value (error) -302.035 (2.58729323e-06)
151483 EPS nconv=0 first unconverged value (error) -302.035 (2.58729323e-06)
151484 EPS nconv=0 first unconverged value (error) -302.035 (2.51824132e-06)
151485 EPS nconv=0 first unconverged value (error) -302.035 (2.79817187e-06)
151486 EPS nconv=0 first unconverged value (error) -302.035 (2.33959461e-06)
151487 EPS nconv=0 first unconverged value (error) -302.035 (1.99020278e-06)
151488 EPS nconv=0 first unconverged value (error) -302.035 (1.93527371e-06)
151489 EPS nconv=0 first unconverged value (error) -302.035 (1.93527371e-06)
151490 EPS nconv=0 first unconverged value (error) -302.035 (1.85146201e-06)
151491 EPS nconv=0 first unconverged value (error) -302.035 (1.82997511e-06)
151492 EPS nconv=0 first unconverged value (error) -302.035 (1.82414008e-06)
151493 EPS nconv=0 first unconverged value (error) -302.035 (1.82034883e-06)
151494 EPS nconv=0 first unconverged value (error) -302.035 (1.81673361e-06)
151495 EPS nconv=0 first unconverged value (error) -302.035 (1.81673361e-06)
151496 EPS nconv=0 first unconverged value (error) -302.035 (1.93729609e-06)
151497 EPS nconv=0 first unconverged value (error) -302.035 (1.92525474e-06)
151498 EPS nconv=0 first unconverged value (error) -302.035 (1.88538174e-06)
151499 EPS nconv=0 first unconverged value (error) -302.035 (1.85673359e-06)
151500 EPS nconv=0 first unconverged value (error) -302.035 (1.84896332e-06)
151501 EPS nconv=0 first unconverged value (error) -302.035 (1.84896332e-06)
151502 EPS nconv=0 first unconverged value (error) -302.035 (2.44640658e-06)
151503 EPS nconv=0 first unconverged value (error) -302.035 (2.31763820e-06)
151504 EPS nconv=0 first unconverged value (error) -302.035 (2.23687473e-06)
151505 EPS nconv=0 first unconverged value (error) -302.035 (2.11120777e-06)
151506 EPS nconv=0 first unconverged value (error) -302.035 (2.08195803e-06)
151507 EPS nconv=0 first unconverged value (error) -302.035 (2.08195803e-06)
151508 EPS nconv=0 first unconverged value (error) -302.035 (2.15667698e-06)
151509 EPS nconv=0 first unconverged value (error) -302.035 (2.17320619e-06)
151510 EPS nconv=0 first unconverged value (error) -302.035 (1.97804167e-06)
151511 EPS nconv=0 first unconverged value (error) -302.035 (1.90596935e-06)
151512 EPS nconv=0 first unconverged value (error) -302.035 (1.89158113e-06)
151513 EPS nconv=0 first unconverged value (error) -302.035 (1.89158113e-06)
151514 EPS nconv=0 first unconverged value (error) -302.035 (1.99018931e-06)
151515 EPS nconv=0 first unconverged value (error) -302.035 (1.95092938e-06)
151516 EPS nconv=0 first unconverged value (error) -302.035 (1.90438599e-06)
151517 EPS nconv=0 first unconverged value (error) -302.035 (1.86954376e-06)
151518 EPS nconv=0 first unconverged value (error) -302.035 (1.85633683e-06)
151519 EPS nconv=0 first unconverged value (error) -302.035 (1.85633683e-06)
151520 EPS nconv=0 first unconverged value (error) -302.035 (1.86016239e-06)
151521 EPS nconv=0 first unconverged value (error) -302.035 (1.90075869e-06)
151522 EPS nconv=0 first unconverged value (error) -302.035 (1.84716669e-06)
151523 EPS nconv=0 first unconverged value (error) -302.035 (1.81833120e-06)
151524 EPS nconv=0 first unconverged value (error) -302.035 (1.80976193e-06)
151525 EPS nconv=0 first unconverged value (error) -302.035 (1.80976193e-06)
151526 EPS nconv=0 first unconverged value (error) -302.035 (2.67220209e-06)
151527 EPS nconv=0 first unconverged value (error) -302.035 (2.43512371e-06)
151528 EPS nconv=0 first unconverged value (error) -302.035 (2.36219183e-06)
151529 EPS nconv=0 first unconverged value (error) -302.035 (2.32572592e-06)
151530 EPS nconv=0 first unconverged value (error) -302.035 (2.22630497e-06)
151531 EPS nconv=0 first unconverged value (error) -302.035 (2.22630497e-06)
151532 EPS nconv=0 first unconverged value (error) -302.035 (2.44797347e-06)
151533 EPS nconv=0 first unconverged value (error) -302.035 (2.46245736e-06)
151534 EPS nconv=0 first unconverged value (error) -302.035 (2.16205705e-06)
151535 EPS nconv=0 first unconverged value (error) -302.035 (2.11873145e-06)
151536 EPS nconv=0 first unconverged value (error) -302.035 (2.10449936e-06)
151537 EPS nconv=0 first unconverged value (error) -302.035 (2.10449936e-06)
151538 EPS nconv=0 first unconverged value (error) -302.035 (2.09121190e-06)
151539 EPS nconv=0 first unconverged value (error) -302.035 (2.00034055e-06)
151540 EPS nconv=0 first unconverged value (error) -302.035 (1.97070683e-06)
151541 EPS nconv=0 first unconverged value (error) -302.035 (1.88269903e-06)
151542 EPS nconv=0 first unconverged value (error) -302.035 (1.83830240e-06)
151543 EPS nconv=0 first unconverged value (error) -302.035 (1.83830240e-06)
151544 EPS nconv=0 first unconverged value (error) -302.035 (1.84618052e-06)
151545 EPS nconv=0 first unconverged value (error) -302.035 (1.86857586e-06)
151546 EPS nconv=0 first unconverged value (error) -302.035 (1.83742262e-06)
151547 EPS nconv=0 first unconverged value (error) -302.035 (1.81648381e-06)
151548 EPS nconv=0 first unconverged value (error) -302.035 (1.81387998e-06)
151549 EPS nconv=0 first unconverged value (error) -302.035 (1.81387998e-06)
151550 EPS nconv=0 first unconverged value (error) -302.035 (2.09833213e-06)
151551 EPS nconv=0 first unconverged value (error) -302.035 (2.01819310e-06)
151552 EPS nconv=0 first unconverged value (error) -302.035 (2.00043096e-06)
151553 EPS nconv=0 first unconverged value (error) -302.035 (1.97079152e-06)
151554 EPS nconv=0 first unconverged value (error) -302.035 (1.92946510e-06)
151555 EPS nconv=0 first unconverged value (error) -302.035 (1.92946510e-06)
151556 EPS nconv=0 first unconverged value (error) -302.035 (2.04337641e-06)
151557 EPS nconv=0 first unconverged value (error) -302.035 (2.03900843e-06)
151558 EPS nconv=0 first unconverged value (error) -302.035 (1.92628157e-06)
151559 EPS nconv=0 first unconverged value (error) -302.035 (1.91634555e-06)
151560 EPS nconv=0 first unconverged value (error) -302.035 (1.89966912e-06)
151561 EPS nconv=0 first unconverged value (error) -302.035 (1.89966912e-06)
151562 EPS nconv=0 first unconverged value (error) -302.035 (1.95411669e-06)
151563 EPS nconv=0 first unconverged value (error) -302.035 (1.91227631e-06)
151564 EPS nconv=0 first unconverged value (error) -302.035 (1.86835160e-06)
151565 EPS nconv=0 first unconverged value (error) -302.035 (1.86218972e-06)
151566 EPS nconv=0 first unconverged value (error) -302.035 (1.83670691e-06)
151567 EPS nconv=0 first unconverged value (error) -302.035 (1.83670691e-06)
151568 EPS nconv=0 first unconverged value (error) -302.035 (2.28242012e-06)
151569 EPS nconv=0 first unconverged value (error) -302.035 (2.14383922e-06)
151570 EPS nconv=0 first unconverged value (error) -302.035 (2.02048158e-06)
151571 EPS nconv=0 first unconverged value (error) -302.035 (1.95690442e-06)
151572 EPS nconv=0 first unconverged value (error) -302.035 (1.93911975e-06)
151573 EPS nconv=0 first unconverged value (error) -302.035 (1.93911975e-06)
151574 EPS nconv=0 first unconverged value (error) -302.035 (2.77047007e-06)
151575 EPS nconv=0 first unconverged value (error) -302.035 (2.63097336e-06)
151576 EPS nconv=0 first unconverged value (error) -302.035 (2.44060983e-06)
151577 EPS nconv=0 first unconverged value (error) -302.035 (2.42906500e-06)
151578 EPS nconv=0 first unconverged value (error) -302.035 (2.32969609e-06)
151579 EPS nconv=0 first unconverged value (error) -302.035 (2.32969609e-06)
151580 EPS nconv=0 first unconverged value (error) -302.035 (2.31522749e-06)
151581 EPS nconv=0 first unconverged value (error) -302.035 (2.25681844e-06)
151582 EPS nconv=0 first unconverged value (error) -302.035 (1.99015199e-06)
151583 EPS nconv=0 first unconverged value (error) -302.035 (1.87300930e-06)
151584 EPS nconv=0 first unconverged value (error) -302.035 (1.86429942e-06)
151585 EPS nconv=0 first unconverged value (error) -302.035 (1.86429942e-06)
151586 EPS nconv=0 first unconverged value (error) -302.035 (1.86209910e-06)
151587 EPS nconv=0 first unconverged value (error) -302.035 (1.84075106e-06)
151588 EPS nconv=0 first unconverged value (error) -302.035 (1.83470923e-06)
151589 EPS nconv=0 first unconverged value (error) -302.035 (1.82369107e-06)
151590 EPS nconv=0 first unconverged value (error) -302.035 (1.81533621e-06)
151591 EPS nconv=0 first unconverged value (error) -302.035 (1.81533621e-06)
151592 EPS nconv=0 first unconverged value (error) -302.035 (1.99808919e-06)
151593 EPS nconv=0 first unconverged value (error) -302.035 (1.96839382e-06)
151594 EPS nconv=0 first unconverged value (error) -302.035 (1.89313988e-06)
151595 EPS nconv=0 first unconverged value (error) -302.035 (1.87307725e-06)
151596 EPS nconv=0 first unconverged value (error) -302.035 (1.86173720e-06)
151597 EPS nconv=0 first unconverged value (error) -302.035 (1.86173720e-06)
151598 EPS nconv=0 first unconverged value (error) -302.035 (1.97197171e-06)
151599 EPS nconv=0 first unconverged value (error) -302.035 (1.99006428e-06)
151600 EPS nconv=0 first unconverged value (error) -302.035 (1.92996872e-06)
151601 EPS nconv=0 first unconverged value (error) -302.035 (1.87284633e-06)
151602 EPS nconv=0 first unconverged value (error) -302.035 (1.85335336e-06)
151603 EPS nconv=0 first unconverged value (error) -302.035 (1.85335336e-06)
151604 EPS nconv=0 first unconverged value (error) -302.035 (2.14446356e-06)
151605 EPS nconv=0 first unconverged value (error) -302.035 (2.10360066e-06)
151606 EPS nconv=0 first unconverged value (error) -302.035 (2.06409186e-06)
151607 EPS nconv=0 first unconverged value (error) -302.035 (1.99091055e-06)
151608 EPS nconv=0 first unconverged value (error) -302.035 (1.95622919e-06)
151609 EPS nconv=0 first unconverged value (error) -302.035 (1.95622919e-06)
151610 EPS nconv=0 first unconverged value (error) -302.035 (2.41912593e-06)
151611 EPS nconv=0 first unconverged value (error) -302.035 (2.26768493e-06)
151612 EPS nconv=0 first unconverged value (error) -302.035 (2.14273334e-06)
151613 EPS nconv=0 first unconverged value (error) -302.035 (2.16476890e-06)
151614 EPS nconv=0 first unconverged value (error) -302.035 (2.08794742e-06)
151615 EPS nconv=0 first unconverged value (error) -302.035 (2.08794742e-06)
151616 EPS nconv=0 first unconverged value (error) -302.035 (2.85565355e-06)
151617 EPS nconv=0 first unconverged value (error) -302.035 (2.67708626e-06)
151618 EPS nconv=0 first unconverged value (error) -302.035 (2.37229279e-06)
151619 EPS nconv=0 first unconverged value (error) -302.035 (2.29943618e-06)
151620 EPS nconv=0 first unconverged value (error) -302.035 (2.22784742e-06)
151621 EPS nconv=0 first unconverged value (error) -302.035 (2.22784742e-06)
151622 EPS nconv=0 first unconverged value (error) -302.035 (2.18501550e-06)
151623 EPS nconv=0 first unconverged value (error) -302.035 (2.40142598e-06)
151624 EPS nconv=0 first unconverged value (error) -302.035 (2.21991736e-06)
151625 EPS nconv=0 first unconverged value (error) -302.035 (1.95317703e-06)
151626 EPS nconv=0 first unconverged value (error) -302.035 (1.87778413e-06)
151627 EPS nconv=0 first unconverged value (error) -302.035 (1.87778413e-06)
151628 EPS nconv=0 first unconverged value (error) -302.035 (2.05790609e-06)
151629 EPS nconv=0 first unconverged value (error) -302.035 (1.96092271e-06)
151630 EPS nconv=0 first unconverged value (error) -302.035 (1.92423876e-06)
151631 EPS nconv=0 first unconverged value (error) -302.035 (1.89796508e-06)
151632 EPS nconv=0 first unconverged value (error) -302.035 (1.88134899e-06)
151633 EPS nconv=0 first unconverged value (error) -302.035 (1.88134899e-06)
151634 EPS nconv=0 first unconverged value (error) -302.035 (3.30592667e-06)
151635 EPS nconv=0 first unconverged value (error) -302.035 (3.15769427e-06)
151636 EPS nconv=0 first unconverged value (error) -302.035 (2.99016011e-06)
151637 EPS nconv=0 first unconverged value (error) -302.035 (2.93553528e-06)
151638 EPS nconv=0 first unconverged value (error) -302.035 (2.92487893e-06)
151639 EPS nconv=0 first unconverged value (error) -302.035 (2.92487893e-06)
151640 EPS nconv=0 first unconverged value (error) -302.035 (3.79502310e-06)
151641 EPS nconv=0 first unconverged value (error) -302.035 (2.95533010e-06)
151642 EPS nconv=0 first unconverged value (error) -302.035 (2.62292726e-06)
151643 EPS nconv=0 first unconverged value (error) -302.035 (2.59404238e-06)
151644 EPS nconv=0 first unconverged value (error) -302.035 (2.46640048e-06)
151645 EPS nconv=0 first unconverged value (error) -302.035 (2.46640048e-06)
151646 EPS nconv=0 first unconverged value (error) -302.035 (2.58549101e-06)
151647 EPS nconv=0 first unconverged value (error) -302.035 (2.87552259e-06)
151648 EPS nconv=0 first unconverged value (error) -302.035 (2.28383355e-06)
151649 EPS nconv=0 first unconverged value (error) -302.035 (1.97979679e-06)
151650 EPS nconv=0 first unconverged value (error) -302.035 (1.92028632e-06)
151651 EPS nconv=0 first unconverged value (error) -302.035 (1.92028632e-06)
151652 EPS nconv=0 first unconverged value (error) -302.035 (2.90646104e-06)
151653 EPS nconv=0 first unconverged value (error) -302.035 (2.65792981e-06)
151654 EPS nconv=0 first unconverged value (error) -302.035 (2.53666376e-06)
151655 EPS nconv=0 first unconverged value (error) -302.035 (2.47708100e-06)
151656 EPS nconv=0 first unconverged value (error) -302.035 (2.42790309e-06)
151657 EPS nconv=0 first unconverged value (error) -302.035 (2.42790309e-06)
151658 EPS nconv=0 first unconverged value (error) -302.035 (2.79989280e-06)
151659 EPS nconv=0 first unconverged value (error) -302.035 (2.68438636e-06)
151660 EPS nconv=0 first unconverged value (error) -302.035 (2.24832182e-06)
151661 EPS nconv=0 first unconverged value (error) -302.035 (2.17724011e-06)
151662 EPS nconv=0 first unconverged value (error) -302.035 (2.15739811e-06)
151663 EPS nconv=0 first unconverged value (error) -302.035 (2.15739811e-06)
151664 EPS nconv=0 first unconverged value (error) -302.035 (2.12056969e-06)
151665 EPS nconv=0 first unconverged value (error) -302.035 (2.11516611e-06)
151666 EPS nconv=0 first unconverged value (error) -302.035 (1.99426182e-06)
151667 EPS nconv=0 first unconverged value (error) -302.035 (1.86907220e-06)
151668 EPS nconv=0 first unconverged value (error) -302.035 (1.84196547e-06)
151669 EPS nconv=0 first unconverged value (error) -302.035 (1.84196547e-06)
151670 EPS nconv=0 first unconverged value (error) -302.035 (1.85103363e-06)
151671 EPS nconv=0 first unconverged value (error) -302.035 (1.81863430e-06)
151672 EPS nconv=0 first unconverged value (error) -302.035 (1.80638619e-06)
151673 EPS nconv=0 first unconverged value (error) -302.035 (1.80384884e-06)
151674 EPS nconv=0 first unconverged value (error) -302.035 (1.80225714e-06)
151675 EPS nconv=0 first unconverged value (error) -302.035 (1.80225714e-06)
151676 EPS nconv=0 first unconverged value (error) -302.035 (1.91401957e-06)
151677 EPS nconv=0 first unconverged value (error) -302.035 (1.90203021e-06)
151678 EPS nconv=0 first unconverged value (error) -302.035 (1.87185614e-06)
151679 EPS nconv=0 first unconverged value (error) -302.035 (1.85074225e-06)
151680 EPS nconv=0 first unconverged value (error) -302.035 (1.84950191e-06)
151681 EPS nconv=0 first unconverged value (error) -302.035 (1.84950191e-06)
151682 EPS nconv=0 first unconverged value (error) -302.035 (2.05429988e-06)
151683 EPS nconv=0 first unconverged value (error) -302.035 (1.97542500e-06)
151684 EPS nconv=0 first unconverged value (error) -302.035 (1.94285722e-06)
151685 EPS nconv=0 first unconverged value (error) -302.035 (1.87973800e-06)
151686 EPS nconv=0 first unconverged value (error) -302.035 (1.87130385e-06)
151687 EPS nconv=0 first unconverged value (error) -302.035 (1.87130385e-06)
151688 EPS nconv=0 first unconverged value (error) -302.035 (2.32105980e-06)
151689 EPS nconv=0 first unconverged value (error) -302.035 (2.15228840e-06)
151690 EPS nconv=0 first unconverged value (error) -302.035 (2.05540110e-06)
151691 EPS nconv=0 first unconverged value (error) -302.035 (2.04343691e-06)
151692 EPS nconv=0 first unconverged value (error) -302.035 (2.02829554e-06)
151693 EPS nconv=0 first unconverged value (error) -302.035 (2.02829554e-06)
151694 EPS nconv=0 first unconverged value (error) -302.035 (2.47966202e-06)
151695 EPS nconv=0 first unconverged value (error) -302.035 (2.36679079e-06)
151696 EPS nconv=0 first unconverged value (error) -302.035 (2.14535520e-06)
151697 EPS nconv=0 first unconverged value (error) -302.035 (2.14700063e-06)
151698 EPS nconv=0 first unconverged value (error) -302.035 (2.13668683e-06)
151699 EPS nconv=0 first unconverged value (error) -302.035 (2.13668683e-06)
151700 EPS nconv=0 first unconverged value (error) -302.035 (2.10490368e-06)
151701 EPS nconv=0 first unconverged value (error) -302.035 (2.15571347e-06)
151702 EPS nconv=0 first unconverged value (error) -302.035 (1.99380344e-06)
151703 EPS nconv=0 first unconverged value (error) -302.035 (1.86911878e-06)
151704 EPS nconv=0 first unconverged value (error) -302.035 (1.81277098e-06)
151705 EPS nconv=0 first unconverged value (error) -302.035 (1.81277098e-06)
151706 EPS nconv=0 first unconverged value (error) -302.035 (1.80789662e-06)
151707 EPS nconv=0 first unconverged value (error) -302.035 (1.80295158e-06)
151708 EPS nconv=0 first unconverged value (error) -302.035 (1.79775078e-06)
151709 EPS nconv=0 first unconverged value (error) -302.035 (1.79515994e-06)
151710 EPS nconv=0 first unconverged value (error) -302.035 (1.79440213e-06)
151711 EPS nconv=0 first unconverged value (error) -302.035 (1.79440213e-06)
151712 EPS nconv=0 first unconverged value (error) -302.035 (3.70215249e-06)
151713 EPS nconv=0 first unconverged value (error) -302.035 (3.19121976e-06)
151714 EPS nconv=0 first unconverged value (error) -302.035 (3.09990878e-06)
151715 EPS nconv=0 first unconverged value (error) -302.035 (3.07468559e-06)
151716 EPS nconv=0 first unconverged value (error) -302.035 (2.99042197e-06)
151717 EPS nconv=0 first unconverged value (error) -302.035 (2.99042197e-06)
151718 EPS nconv=0 first unconverged value (error) -302.035 (3.67441463e-06)
151719 EPS nconv=0 first unconverged value (error) -302.035 (3.30055237e-06)
151720 EPS nconv=0 first unconverged value (error) -302.035 (2.57191879e-06)
151721 EPS nconv=0 first unconverged value (error) -302.035 (2.51677476e-06)
151722 EPS nconv=0 first unconverged value (error) -302.035 (2.49474751e-06)
151723 EPS nconv=0 first unconverged value (error) -302.035 (2.49474751e-06)
151724 EPS nconv=0 first unconverged value (error) -302.035 (2.53872666e-06)
151725 EPS nconv=0 first unconverged value (error) -302.035 (2.68323568e-06)
151726 EPS nconv=0 first unconverged value (error) -302.035 (2.51604579e-06)
151727 EPS nconv=0 first unconverged value (error) -302.035 (2.08991573e-06)
151728 EPS nconv=0 first unconverged value (error) -302.035 (1.95152848e-06)
151729 EPS nconv=0 first unconverged value (error) -302.035 (1.95152848e-06)
151730 EPS nconv=0 first unconverged value (error) -302.035 (2.32679065e-06)
151731 EPS nconv=0 first unconverged value (error) -302.035 (2.20007130e-06)
151732 EPS nconv=0 first unconverged value (error) -302.035 (2.14637612e-06)
151733 EPS nconv=0 first unconverged value (error) -302.035 (2.09662149e-06)
151734 EPS nconv=0 first unconverged value (error) -302.035 (2.04336588e-06)
151735 EPS nconv=0 first unconverged value (error) -302.035 (2.04336588e-06)
151736 EPS nconv=0 first unconverged value (error) -302.035 (2.45650888e-06)
151737 EPS nconv=0 first unconverged value (error) -302.035 (2.39504476e-06)
151738 EPS nconv=0 first unconverged value (error) -302.035 (2.17217254e-06)
151739 EPS nconv=0 first unconverged value (error) -302.035 (2.15782683e-06)
151740 EPS nconv=0 first unconverged value (error) -302.035 (2.13566506e-06)
151741 EPS nconv=0 first unconverged value (error) -302.035 (2.13566506e-06)
151742 EPS nconv=0 first unconverged value (error) -302.035 (2.72052039e-06)
151743 EPS nconv=0 first unconverged value (error) -302.035 (2.56813934e-06)
151744 EPS nconv=0 first unconverged value (error) -302.035 (2.32201110e-06)
151745 EPS nconv=0 first unconverged value (error) -302.035 (2.19313362e-06)
151746 EPS nconv=0 first unconverged value (error) -302.035 (2.09466966e-06)
151747 EPS nconv=0 first unconverged value (error) -302.035 (2.09466966e-06)
151748 EPS nconv=0 first unconverged value (error) -302.035 (2.06704970e-06)
151749 EPS nconv=0 first unconverged value (error) -302.035 (2.25986635e-06)
151750 EPS nconv=0 first unconverged value (error) -302.035 (2.04251335e-06)
151751 EPS nconv=0 first unconverged value (error) -302.035 (1.87087747e-06)
151752 EPS nconv=0 first unconverged value (error) -302.035 (1.83829106e-06)
151753 EPS nconv=0 first unconverged value (error) -302.035 (1.83829106e-06)
151754 EPS nconv=0 first unconverged value (error) -302.035 (1.83916080e-06)
151755 EPS nconv=0 first unconverged value (error) -302.035 (1.82923082e-06)
151756 EPS nconv=0 first unconverged value (error) -302.035 (1.82458176e-06)
151757 EPS nconv=0 first unconverged value (error) -302.035 (1.81850018e-06)
151758 EPS nconv=0 first unconverged value (error) -302.035 (1.81455635e-06)
151759 EPS nconv=0 first unconverged value (error) -302.035 (1.81455635e-06)
151760 EPS nconv=0 first unconverged value (error) -302.035 (1.94927061e-06)
151761 EPS nconv=0 first unconverged value (error) -302.035 (1.92189093e-06)
151762 EPS nconv=0 first unconverged value (error) -302.035 (1.88298293e-06)
151763 EPS nconv=0 first unconverged value (error) -302.035 (1.86243407e-06)
151764 EPS nconv=0 first unconverged value (error) -302.035 (1.85295026e-06)
151765 EPS nconv=0 first unconverged value (error) -302.035 (1.85295026e-06)
151766 EPS nconv=0 first unconverged value (error) -302.035 (2.16352403e-06)
151767 EPS nconv=0 first unconverged value (error) -302.035 (2.07504944e-06)
151768 EPS nconv=0 first unconverged value (error) -302.035 (1.98092129e-06)
151769 EPS nconv=0 first unconverged value (error) -302.035 (1.97914815e-06)
151770 EPS nconv=0 first unconverged value (error) -302.035 (1.95084833e-06)
151771 EPS nconv=0 first unconverged value (error) -302.035 (1.95084833e-06)
151772 EPS nconv=0 first unconverged value (error) -302.035 (2.18397998e-06)
151773 EPS nconv=0 first unconverged value (error) -302.035 (2.15415468e-06)
151774 EPS nconv=0 first unconverged value (error) -302.035 (2.00468356e-06)
151775 EPS nconv=0 first unconverged value (error) -302.035 (1.98159870e-06)
151776 EPS nconv=0 first unconverged value (error) -302.035 (1.93914845e-06)
151777 EPS nconv=0 first unconverged value (error) -302.035 (1.93914845e-06)
151778 EPS nconv=0 first unconverged value (error) -302.035 (1.94235878e-06)
151779 EPS nconv=0 first unconverged value (error) -302.035 (1.97319656e-06)
151780 EPS nconv=0 first unconverged value (error) -302.035 (1.91235882e-06)
151781 EPS nconv=0 first unconverged value (error) -302.035 (1.84866795e-06)
151782 EPS nconv=0 first unconverged value (error) -302.035 (1.82865350e-06)
151783 EPS nconv=0 first unconverged value (error) -302.035 (1.82865350e-06)
151784 EPS nconv=0 first unconverged value (error) -302.035 (1.93367243e-06)
151785 EPS nconv=0 first unconverged value (error) -302.035 (1.90160901e-06)
151786 EPS nconv=0 first unconverged value (error) -302.035 (1.86878062e-06)
151787 EPS nconv=0 first unconverged value (error) -302.035 (1.86001532e-06)
151788 EPS nconv=0 first unconverged value (error) -302.035 (1.85433536e-06)
151789 EPS nconv=0 first unconverged value (error) -302.035 (1.85433536e-06)
151790 EPS nconv=0 first unconverged value (error) -302.035 (1.97959012e-06)
151791 EPS nconv=0 first unconverged value (error) -302.035 (1.91655857e-06)
151792 EPS nconv=0 first unconverged value (error) -302.035 (1.87539071e-06)
151793 EPS nconv=0 first unconverged value (error) -302.035 (1.88016672e-06)
151794 EPS nconv=0 first unconverged value (error) -302.035 (1.85608836e-06)
151795 EPS nconv=0 first unconverged value (error) -302.035 (1.85608836e-06)
151796 EPS nconv=0 first unconverged value (error) -302.035 (2.73385559e-06)
151797 EPS nconv=0 first unconverged value (error) -302.035 (2.67303945e-06)
151798 EPS nconv=0 first unconverged value (error) -302.035 (2.36866201e-06)
151799 EPS nconv=0 first unconverged value (error) -302.035 (2.28093003e-06)
151800 EPS nconv=0 first unconverged value (error) -302.035 (2.25568384e-06)
151801 EPS nconv=0 first unconverged value (error) -302.035 (2.25568384e-06)
151802 EPS nconv=0 first unconverged value (error) -302.035 (2.26552825e-06)
151803 EPS nconv=0 first unconverged value (error) -302.035 (2.37708484e-06)
151804 EPS nconv=0 first unconverged value (error) -302.035 (2.27422609e-06)
151805 EPS nconv=0 first unconverged value (error) -302.035 (2.01514858e-06)
151806 EPS nconv=0 first unconverged value (error) -302.035 (1.86621252e-06)
151807 EPS nconv=0 first unconverged value (error) -302.035 (1.86621252e-06)
151808 EPS nconv=0 first unconverged value (error) -302.035 (2.16462489e-06)
151809 EPS nconv=0 first unconverged value (error) -302.035 (2.20635952e-06)
151810 EPS nconv=0 first unconverged value (error) -302.035 (2.14390506e-06)
151811 EPS nconv=0 first unconverged value (error) -302.035 (2.04691195e-06)
151812 EPS nconv=0 first unconverged value (error) -302.035 (2.01490560e-06)
151813 EPS nconv=0 first unconverged value (error) -302.035 (2.01490560e-06)
151814 EPS nconv=0 first unconverged value (error) -302.035 (2.27781839e-06)
151815 EPS nconv=0 first unconverged value (error) -302.035 (2.12480351e-06)
151816 EPS nconv=0 first unconverged value (error) -302.035 (2.09762538e-06)
151817 EPS nconv=0 first unconverged value (error) -302.035 (2.00295791e-06)
151818 EPS nconv=0 first unconverged value (error) -302.035 (1.93046557e-06)
151819 EPS nconv=0 first unconverged value (error) -302.035 (1.93046557e-06)
151820 EPS nconv=0 first unconverged value (error) -302.035 (1.96985701e-06)
151821 EPS nconv=0 first unconverged value (error) -302.035 (2.03872959e-06)
151822 EPS nconv=0 first unconverged value (error) -302.035 (1.92980858e-06)
151823 EPS nconv=0 first unconverged value (error) -302.035 (1.86823519e-06)
151824 EPS nconv=0 first unconverged value (error) -302.035 (1.85278878e-06)
151825 EPS nconv=0 first unconverged value (error) -302.035 (1.85278878e-06)
151826 EPS nconv=0 first unconverged value (error) -302.035 (2.12787091e-06)
151827 EPS nconv=0 first unconverged value (error) -302.035 (2.03322166e-06)
151828 EPS nconv=0 first unconverged value (error) -302.035 (2.01910285e-06)
151829 EPS nconv=0 first unconverged value (error) -302.035 (1.97128233e-06)
151830 EPS nconv=0 first unconverged value (error) -302.035 (1.93515060e-06)
151831 EPS nconv=0 first unconverged value (error) -302.035 (1.93515060e-06)
151832 EPS nconv=0 first unconverged value (error) -302.035 (1.93015207e-06)
151833 EPS nconv=0 first unconverged value (error) -302.035 (1.99247537e-06)
151834 EPS nconv=0 first unconverged value (error) -302.035 (1.85983073e-06)
151835 EPS nconv=0 first unconverged value (error) -302.035 (1.83650209e-06)
151836 EPS nconv=0 first unconverged value (error) -302.035 (1.82984519e-06)
151837 EPS nconv=0 first unconverged value (error) -302.035 (1.82984519e-06)
151838 EPS nconv=0 first unconverged value (error) -302.035 (1.88264180e-06)
151839 EPS nconv=0 first unconverged value (error) -302.035 (1.85095766e-06)
151840 EPS nconv=0 first unconverged value (error) -302.035 (1.83420459e-06)
151841 EPS nconv=0 first unconverged value (error) -302.035 (1.83238936e-06)
151842 EPS nconv=0 first unconverged value (error) -302.035 (1.82580747e-06)
151843 EPS nconv=0 first unconverged value (error) -302.035 (1.82580747e-06)
151844 EPS nconv=0 first unconverged value (error) -302.035 (2.08155260e-06)
151845 EPS nconv=0 first unconverged value (error) -302.035 (2.10384932e-06)
151846 EPS nconv=0 first unconverged value (error) -302.035 (2.02022495e-06)
151847 EPS nconv=0 first unconverged value (error) -302.035 (1.94378392e-06)
151848 EPS nconv=0 first unconverged value (error) -302.035 (1.92270593e-06)
151849 EPS nconv=0 first unconverged value (error) -302.035 (1.92270593e-06)
151850 EPS nconv=0 first unconverged value (error) -302.035 (1.92291893e-06)
151851 EPS nconv=0 first unconverged value (error) -302.035 (1.93076357e-06)
151852 EPS nconv=0 first unconverged value (error) -302.035 (1.90474893e-06)
151853 EPS nconv=0 first unconverged value (error) -302.035 (1.86118830e-06)
151854 EPS nconv=0 first unconverged value (error) -302.035 (1.82268954e-06)
151855 EPS nconv=0 first unconverged value (error) -302.035 (1.82268954e-06)
151856 EPS nconv=0 first unconverged value (error) -302.035 (1.87973191e-06)
151857 EPS nconv=0 first unconverged value (error) -302.035 (1.85892660e-06)
151858 EPS nconv=0 first unconverged value (error) -302.035 (1.84762038e-06)
151859 EPS nconv=0 first unconverged value (error) -302.035 (1.83903517e-06)
151860 EPS nconv=0 first unconverged value (error) -302.035 (1.83256779e-06)
151861 EPS nconv=0 first unconverged value (error) -302.035 (1.83256779e-06)
151862 EPS nconv=0 first unconverged value (error) -302.035 (1.83164690e-06)
151863 EPS nconv=0 first unconverged value (error) -302.035 (1.85047318e-06)
151864 EPS nconv=0 first unconverged value (error) -302.035 (1.82550548e-06)
151865 EPS nconv=0 first unconverged value (error) -302.035 (1.81028733e-06)
151866 EPS nconv=0 first unconverged value (error) -302.035 (1.80310864e-06)
151867 EPS nconv=0 first unconverged value (error) -302.035 (1.80310864e-06)
151868 EPS nconv=0 first unconverged value (error) -302.035 (1.90092109e-06)
151869 EPS nconv=0 first unconverged value (error) -302.035 (1.87361843e-06)
151870 EPS nconv=0 first unconverged value (error) -302.035 (1.85935448e-06)
151871 EPS nconv=0 first unconverged value (error) -302.035 (1.85279859e-06)
151872 EPS nconv=0 first unconverged value (error) -302.035 (1.84184331e-06)
151873 EPS nconv=0 first unconverged value (error) -302.035 (1.84184331e-06)
151874 EPS nconv=0 first unconverged value (error) -302.035 (2.09385442e-06)
151875 EPS nconv=0 first unconverged value (error) -302.035 (2.01591587e-06)
151876 EPS nconv=0 first unconverged value (error) -302.035 (1.96210888e-06)
151877 EPS nconv=0 first unconverged value (error) -302.035 (1.96110686e-06)
151878 EPS nconv=0 first unconverged value (error) -302.035 (1.95975560e-06)
151879 EPS nconv=0 first unconverged value (error) -302.035 (1.95975560e-06)
151880 EPS nconv=0 first unconverged value (error) -302.035 (1.95816321e-06)
151881 EPS nconv=0 first unconverged value (error) -302.035 (1.93936450e-06)
151882 EPS nconv=0 first unconverged value (error) -302.035 (1.86686695e-06)
151883 EPS nconv=0 first unconverged value (error) -302.035 (1.83499812e-06)
151884 EPS nconv=0 first unconverged value (error) -302.035 (1.82735739e-06)
151885 EPS nconv=0 first unconverged value (error) -302.035 (1.82735739e-06)
151886 EPS nconv=0 first unconverged value (error) -302.035 (1.98518398e-06)
151887 EPS nconv=0 first unconverged value (error) -302.035 (1.91774720e-06)
151888 EPS nconv=0 first unconverged value (error) -302.035 (1.88304691e-06)
151889 EPS nconv=0 first unconverged value (error) -302.035 (1.86639968e-06)
151890 EPS nconv=0 first unconverged value (error) -302.035 (1.85828622e-06)
151891 EPS nconv=0 first unconverged value (error) -302.035 (1.85828622e-06)
151892 EPS nconv=0 first unconverged value (error) -302.035 (1.89446535e-06)
151893 EPS nconv=0 first unconverged value (error) -302.035 (1.96726931e-06)
151894 EPS nconv=0 first unconverged value (error) -302.035 (1.87154285e-06)
151895 EPS nconv=0 first unconverged value (error) -302.035 (1.84312254e-06)
151896 EPS nconv=0 first unconverged value (error) -302.035 (1.82492940e-06)
151897 EPS nconv=0 first unconverged value (error) -302.035 (1.82492940e-06)
151898 EPS nconv=0 first unconverged value (error) -302.035 (1.95234488e-06)
151899 EPS nconv=0 first unconverged value (error) -302.035 (1.93233797e-06)
151900 EPS nconv=0 first unconverged value (error) -302.035 (1.90835508e-06)
151901 EPS nconv=0 first unconverged value (error) -302.035 (1.88614203e-06)
151902 EPS nconv=0 first unconverged value (error) -302.035 (1.86939895e-06)
151903 EPS nconv=0 first unconverged value (error) -302.035 (1.86939895e-06)
151904 EPS nconv=0 first unconverged value (error) -302.035 (1.86704035e-06)
151905 EPS nconv=0 first unconverged value (error) -302.035 (1.86611963e-06)
151906 EPS nconv=0 first unconverged value (error) -302.035 (1.84727788e-06)
151907 EPS nconv=0 first unconverged value (error) -302.035 (1.80747389e-06)
151908 EPS nconv=0 first unconverged value (error) -302.035 (1.80539808e-06)
151909 EPS nconv=0 first unconverged value (error) -302.035 (1.80539808e-06)
151910 EPS nconv=0 first unconverged value (error) -302.035 (1.81587851e-06)
151911 EPS nconv=0 first unconverged value (error) -302.035 (1.80729444e-06)
151912 EPS nconv=0 first unconverged value (error) -302.035 (1.80448553e-06)
151913 EPS nconv=0 first unconverged value (error) -302.035 (1.80289265e-06)
151914 EPS nconv=0 first unconverged value (error) -302.035 (1.80195908e-06)
151915 EPS nconv=0 first unconverged value (error) -302.035 (1.80195908e-06)
151916 EPS nconv=0 first unconverged value (error) -302.035 (1.85289242e-06)
151917 EPS nconv=0 first unconverged value (error) -302.035 (1.84388332e-06)
151918 EPS nconv=0 first unconverged value (error) -302.035 (1.83112694e-06)
151919 EPS nconv=0 first unconverged value (error) -302.035 (1.82974232e-06)
151920 EPS nconv=0 first unconverged value (error) -302.035 (1.82813338e-06)
151921 EPS nconv=0 first unconverged value (error) -302.035 (1.82813338e-06)
151922 EPS nconv=0 first unconverged value (error) -302.035 (1.93056427e-06)
151923 EPS nconv=0 first unconverged value (error) -302.035 (1.89632063e-06)
151924 EPS nconv=0 first unconverged value (error) -302.035 (1.86486094e-06)
151925 EPS nconv=0 first unconverged value (error) -302.035 (1.83734500e-06)
151926 EPS nconv=0 first unconverged value (error) -302.035 (1.83160969e-06)
151927 EPS nconv=0 first unconverged value (error) -302.035 (1.83160969e-06)
151928 EPS nconv=0 first unconverged value (error) -302.035 (1.87283941e-06)
151929 EPS nconv=0 first unconverged value (error) -302.035 (1.86610435e-06)
151930 EPS nconv=0 first unconverged value (error) -302.035 (1.84645350e-06)
151931 EPS nconv=0 first unconverged value (error) -302.035 (1.82248669e-06)
151932 EPS nconv=0 first unconverged value (error) -302.035 (1.81794292e-06)
151933 EPS nconv=0 first unconverged value (error) -302.035 (1.81794292e-06)
151934 EPS nconv=0 first unconverged value (error) -302.035 (1.81159133e-06)
151935 EPS nconv=0 first unconverged value (error) -302.035 (1.81915191e-06)
151936 EPS nconv=0 first unconverged value (error) -302.035 (1.80299648e-06)
151937 EPS nconv=0 first unconverged value (error) -302.035 (1.79894978e-06)
151938 EPS nconv=0 first unconverged value (error) -302.035 (1.79616170e-06)
151939 EPS nconv=0 first unconverged value (error) -302.035 (1.79616170e-06)
151940 EPS nconv=0 first unconverged value (error) -302.035 (1.79867969e-06)
151941 EPS nconv=0 first unconverged value (error) -302.035 (1.79784792e-06)
151942 EPS nconv=0 first unconverged value (error) -302.035 (1.79681873e-06)
151943 EPS nconv=0 first unconverged value (error) -302.035 (1.79660844e-06)
151944 EPS nconv=0 first unconverged value (error) -302.035 (1.79639067e-06)
151945 EPS nconv=0 first unconverged value (error) -302.035 (1.79639067e-06)
151946 EPS nconv=0 first unconverged value (error) -302.035 (1.94532832e-06)
151947 EPS nconv=0 first unconverged value (error) -302.035 (1.89915330e-06)
151948 EPS nconv=0 first unconverged value (error) -302.035 (1.88381702e-06)
151949 EPS nconv=0 first unconverged value (error) -302.035 (1.86472849e-06)
151950 EPS nconv=0 first unconverged value (error) -302.035 (1.85366005e-06)
151951 EPS nconv=0 first unconverged value (error) -302.035 (1.85366005e-06)
151952 EPS nconv=0 first unconverged value (error) -302.035 (1.93848505e-06)
151953 EPS nconv=0 first unconverged value (error) -302.035 (1.92685161e-06)
151954 EPS nconv=0 first unconverged value (error) -302.035 (1.87348097e-06)
151955 EPS nconv=0 first unconverged value (error) -302.035 (1.86506633e-06)
151956 EPS nconv=0 first unconverged value (error) -302.035 (1.86386315e-06)
151957 EPS nconv=0 first unconverged value (error) -302.035 (1.86386315e-06)
151958 EPS nconv=0 first unconverged value (error) -302.035 (2.06282926e-06)
151959 EPS nconv=0 first unconverged value (error) -302.035 (1.95608930e-06)
151960 EPS nconv=0 first unconverged value (error) -302.035 (1.90562067e-06)
151961 EPS nconv=0 first unconverged value (error) -302.035 (1.88753015e-06)
151962 EPS nconv=0 first unconverged value (error) -302.035 (1.86824521e-06)
151963 EPS nconv=0 first unconverged value (error) -302.035 (1.86824521e-06)
151964 EPS nconv=0 first unconverged value (error) -302.035 (1.95114162e-06)
151965 EPS nconv=0 first unconverged value (error) -302.035 (2.00654926e-06)
151966 EPS nconv=0 first unconverged value (error) -302.035 (1.90081695e-06)
151967 EPS nconv=0 first unconverged value (error) -302.035 (1.84137358e-06)
151968 EPS nconv=0 first unconverged value (error) -302.035 (1.83764887e-06)
151969 EPS nconv=0 first unconverged value (error) -302.035 (1.83764887e-06)
151970 EPS nconv=0 first unconverged value (error) -302.035 (1.83189740e-06)
151971 EPS nconv=0 first unconverged value (error) -302.035 (1.87019948e-06)
151972 EPS nconv=0 first unconverged value (error) -302.035 (1.83368371e-06)
151973 EPS nconv=0 first unconverged value (error) -302.035 (1.80967357e-06)
151974 EPS nconv=0 first unconverged value (error) -302.035 (1.80284476e-06)
151975 EPS nconv=0 first unconverged value (error) -302.035 (1.80284476e-06)
151976 EPS nconv=0 first unconverged value (error) -302.035 (1.80230576e-06)
151977 EPS nconv=0 first unconverged value (error) -302.035 (1.79943152e-06)
151978 EPS nconv=0 first unconverged value (error) -302.035 (1.79752367e-06)
151979 EPS nconv=0 first unconverged value (error) -302.035 (1.79682442e-06)
151980 EPS nconv=0 first unconverged value (error) -302.035 (1.79610433e-06)
151981 EPS nconv=0 first unconverged value (error) -302.035 (1.79610433e-06)
151982 EPS nconv=0 first unconverged value (error) -302.035 (2.05510023e-06)
151983 EPS nconv=0 first unconverged value (error) -302.035 (1.96187848e-06)
151984 EPS nconv=0 first unconverged value (error) -302.035 (1.90574197e-06)
151985 EPS nconv=0 first unconverged value (error) -302.035 (1.89670934e-06)
151986 EPS nconv=0 first unconverged value (error) -302.035 (1.88457713e-06)
151987 EPS nconv=0 first unconverged value (error) -302.035 (1.88457713e-06)
151988 EPS nconv=0 first unconverged value (error) -302.035 (2.13295737e-06)
151989 EPS nconv=0 first unconverged value (error) -302.035 (2.10368557e-06)
151990 EPS nconv=0 first unconverged value (error) -302.035 (1.98845412e-06)
151991 EPS nconv=0 first unconverged value (error) -302.035 (1.96510273e-06)
151992 EPS nconv=0 first unconverged value (error) -302.035 (1.95176743e-06)
151993 EPS nconv=0 first unconverged value (error) -302.035 (1.95176743e-06)
151994 EPS nconv=0 first unconverged value (error) -302.035 (1.94938519e-06)
151995 EPS nconv=0 first unconverged value (error) -302.035 (1.95875964e-06)
151996 EPS nconv=0 first unconverged value (error) -302.035 (1.87733347e-06)
151997 EPS nconv=0 first unconverged value (error) -302.035 (1.83418995e-06)
151998 EPS nconv=0 first unconverged value (error) -302.035 (1.81765593e-06)
151999 EPS nconv=0 first unconverged value (error) -302.035 (1.81765593e-06)
152000 EPS nconv=0 first unconverged value (error) -302.035 (1.80793381e-06)
152001 EPS nconv=0 first unconverged value (error) -302.035 (1.81067602e-06)
152002 EPS nconv=0 first unconverged value (error) -302.035 (1.80530597e-06)
152003 EPS nconv=0 first unconverged value (error) -302.035 (1.79965389e-06)
152004 EPS nconv=0 first unconverged value (error) -302.035 (1.79613187e-06)
152005 EPS nconv=0 first unconverged value (error) -302.035 (1.79613187e-06)
152006 EPS nconv=0 first unconverged value (error) -302.035 (1.79473242e-06)
152007 EPS nconv=0 first unconverged value (error) -302.035 (1.79469757e-06)
152008 EPS nconv=0 first unconverged value (error) -302.035 (1.79463511e-06)
152009 EPS nconv=0 first unconverged value (error) -302.035 (1.79423892e-06)
152010 EPS nconv=0 first unconverged value (error) -302.035 (1.79420315e-06)
152011 EPS nconv=0 first unconverged value (error) -302.035 (1.79420315e-06)
152012 EPS nconv=0 first unconverged value (error) -302.035 (1.80309205e-06)
152013 EPS nconv=0 first unconverged value (error) -302.035 (1.80156317e-06)
152014 EPS nconv=0 first unconverged value (error) -302.035 (1.80027592e-06)
152015 EPS nconv=0 first unconverged value (error) -302.035 (1.79924611e-06)
152016 EPS nconv=0 first unconverged value (error) -302.035 (1.79900476e-06)
152017 EPS nconv=0 first unconverged value (error) -302.035 (1.79900476e-06)
152018 EPS nconv=0 first unconverged value (error) -302.035 (1.79891573e-06)
152019 EPS nconv=0 first unconverged value (error) -302.035 (1.79793466e-06)
152020 EPS nconv=0 first unconverged value (error) -302.035 (1.79654666e-06)
152021 EPS nconv=0 first unconverged value (error) -302.035 (1.79454346e-06)
152022 EPS nconv=0 first unconverged value (error) -302.035 (1.79413622e-06)
152023 EPS nconv=0 first unconverged value (error) -302.035 (1.79413622e-06)
152024 EPS nconv=0 first unconverged value (error) -302.035 (1.93827384e-06)
152025 EPS nconv=0 first unconverged value (error) -302.035 (1.92597962e-06)
152026 EPS nconv=0 first unconverged value (error) -302.035 (1.91171802e-06)
152027 EPS nconv=0 first unconverged value (error) -302.035 (1.90488109e-06)
152028 EPS nconv=0 first unconverged value (error) -302.035 (1.90060785e-06)
152029 EPS nconv=0 first unconverged value (error) -302.035 (1.90060785e-06)
152030 EPS nconv=0 first unconverged value (error) -302.035 (1.91794671e-06)
152031 EPS nconv=0 first unconverged value (error) -302.035 (1.86025879e-06)
152032 EPS nconv=0 first unconverged value (error) -302.035 (1.84594722e-06)
152033 EPS nconv=0 first unconverged value (error) -302.035 (1.80781516e-06)
152034 EPS nconv=0 first unconverged value (error) -302.035 (1.80089645e-06)
152035 EPS nconv=0 first unconverged value (error) -302.035 (1.80089645e-06)
152036 EPS nconv=0 first unconverged value (error) -302.035 (1.81468634e-06)
152037 EPS nconv=0 first unconverged value (error) -302.035 (1.81408705e-06)
152038 EPS nconv=0 first unconverged value (error) -302.035 (1.80989729e-06)
152039 EPS nconv=0 first unconverged value (error) -302.035 (1.80522267e-06)
152040 EPS nconv=0 first unconverged value (error) -302.035 (1.80285566e-06)
152041 EPS nconv=0 first unconverged value (error) -302.035 (1.80285566e-06)
152042 EPS nconv=0 first unconverged value (error) -302.035 (1.81053505e-06)
152043 EPS nconv=0 first unconverged value (error) -302.035 (1.80749876e-06)
152044 EPS nconv=0 first unconverged value (error) -302.035 (1.80398953e-06)
152045 EPS nconv=0 first unconverged value (error) -302.035 (1.80217212e-06)
152046 EPS nconv=0 first unconverged value (error) -302.035 (1.79953833e-06)
152047 EPS nconv=0 first unconverged value (error) -302.035 (1.79953833e-06)
152048 EPS nconv=0 first unconverged value (error) -302.035 (1.91873731e-06)
152049 EPS nconv=0 first unconverged value (error) -302.035 (1.92687754e-06)
152050 EPS nconv=0 first unconverged value (error) -302.035 (1.89565539e-06)
152051 EPS nconv=0 first unconverged value (error) -302.035 (1.85961652e-06)
152052 EPS nconv=0 first unconverged value (error) -302.035 (1.85472287e-06)
152053 EPS nconv=0 first unconverged value (error) -302.035 (1.85472287e-06)
152054 EPS nconv=0 first unconverged value (error) -302.035 (1.98732867e-06)
152055 EPS nconv=0 first unconverged value (error) -302.035 (1.95563282e-06)
152056 EPS nconv=0 first unconverged value (error) -302.035 (1.91510849e-06)
152057 EPS nconv=0 first unconverged value (error) -302.035 (1.89515248e-06)
152058 EPS nconv=0 first unconverged value (error) -302.035 (1.87386726e-06)
152059 EPS nconv=0 first unconverged value (error) -302.035 (1.87386726e-06)
152060 EPS nconv=0 first unconverged value (error) -302.035 (1.91071867e-06)
152061 EPS nconv=0 first unconverged value (error) -302.035 (1.88615591e-06)
152062 EPS nconv=0 first unconverged value (error) -302.035 (1.86150488e-06)
152063 EPS nconv=0 first unconverged value (error) -302.035 (1.83143686e-06)
152064 EPS nconv=0 first unconverged value (error) -302.035 (1.82261758e-06)
152065 EPS nconv=0 first unconverged value (error) -302.035 (1.82261758e-06)
152066 EPS nconv=0 first unconverged value (error) -302.035 (1.96025932e-06)
152067 EPS nconv=0 first unconverged value (error) -302.035 (1.92627966e-06)
152068 EPS nconv=0 first unconverged value (error) -302.035 (1.89059142e-06)
152069 EPS nconv=0 first unconverged value (error) -302.035 (1.85815374e-06)
152070 EPS nconv=0 first unconverged value (error) -302.035 (1.85124822e-06)
152071 EPS nconv=0 first unconverged value (error) -302.035 (1.85124822e-06)
152072 EPS nconv=0 first unconverged value (error) -302.035 (1.85144006e-06)
152073 EPS nconv=0 first unconverged value (error) -302.035 (1.91214979e-06)
152074 EPS nconv=0 first unconverged value (error) -302.035 (1.85538784e-06)
152075 EPS nconv=0 first unconverged value (error) -302.035 (1.81484200e-06)
152076 EPS nconv=0 first unconverged value (error) -302.035 (1.80528060e-06)
152077 EPS nconv=0 first unconverged value (error) -302.035 (1.80528060e-06)
152078 EPS nconv=0 first unconverged value (error) -302.035 (1.98829934e-06)
152079 EPS nconv=0 first unconverged value (error) -302.035 (1.92682083e-06)
152080 EPS nconv=0 first unconverged value (error) -302.035 (1.91521832e-06)
152081 EPS nconv=0 first unconverged value (error) -302.035 (1.90918804e-06)
152082 EPS nconv=0 first unconverged value (error) -302.035 (1.88534309e-06)
152083 EPS nconv=0 first unconverged value (error) -302.035 (1.88534309e-06)
152084 EPS nconv=0 first unconverged value (error) -302.035 (1.94940708e-06)
152085 EPS nconv=0 first unconverged value (error) -302.035 (1.93096116e-06)
152086 EPS nconv=0 first unconverged value (error) -302.035 (1.86573269e-06)
152087 EPS nconv=0 first unconverged value (error) -302.035 (1.85084000e-06)
152088 EPS nconv=0 first unconverged value (error) -302.035 (1.84723347e-06)
152089 EPS nconv=0 first unconverged value (error) -302.035 (1.84723347e-06)
152090 EPS nconv=0 first unconverged value (error) -302.035 (1.85854356e-06)
152091 EPS nconv=0 first unconverged value (error) -302.035 (1.84923653e-06)
152092 EPS nconv=0 first unconverged value (error) -302.035 (1.82355033e-06)
152093 EPS nconv=0 first unconverged value (error) -302.035 (1.81361584e-06)
152094 EPS nconv=0 first unconverged value (error) -302.035 (1.81007863e-06)
152095 EPS nconv=0 first unconverged value (error) -302.035 (1.81007863e-06)
152096 EPS nconv=0 first unconverged value (error) -302.035 (2.20973177e-06)
152097 EPS nconv=0 first unconverged value (error) -302.035 (2.06879926e-06)
152098 EPS nconv=0 first unconverged value (error) -302.035 (1.99324273e-06)
152099 EPS nconv=0 first unconverged value (error) -302.035 (1.95078081e-06)
152100 EPS nconv=0 first unconverged value (error) -302.035 (1.92978605e-06)
152101 EPS nconv=0 first unconverged value (error) -302.035 (1.92978605e-06)
152102 EPS nconv=0 first unconverged value (error) -302.035 (1.93294406e-06)
152103 EPS nconv=0 first unconverged value (error) -302.035 (2.10620783e-06)
152104 EPS nconv=0 first unconverged value (error) -302.035 (1.94837193e-06)
152105 EPS nconv=0 first unconverged value (error) -302.035 (1.84112175e-06)
152106 EPS nconv=0 first unconverged value (error) -302.035 (1.81854118e-06)
152107 EPS nconv=0 first unconverged value (error) -302.035 (1.81854118e-06)
152108 EPS nconv=0 first unconverged value (error) -302.035 (1.98102691e-06)
152109 EPS nconv=0 first unconverged value (error) -302.035 (1.93579121e-06)
152110 EPS nconv=0 first unconverged value (error) -302.035 (1.92503283e-06)
152111 EPS nconv=0 first unconverged value (error) -302.035 (1.91510556e-06)
152112 EPS nconv=0 first unconverged value (error) -302.035 (1.89344567e-06)
152113 EPS nconv=0 first unconverged value (error) -302.035 (1.89344567e-06)
152114 EPS nconv=0 first unconverged value (error) -302.035 (1.92526827e-06)
152115 EPS nconv=0 first unconverged value (error) -302.035 (1.90481367e-06)
152116 EPS nconv=0 first unconverged value (error) -302.035 (1.85267431e-06)
152117 EPS nconv=0 first unconverged value (error) -302.035 (1.84024274e-06)
152118 EPS nconv=0 first unconverged value (error) -302.035 (1.83334998e-06)
152119 EPS nconv=0 first unconverged value (error) -302.035 (1.83334998e-06)
152120 EPS nconv=0 first unconverged value (error) -302.035 (2.16790722e-06)
152121 EPS nconv=0 first unconverged value (error) -302.035 (2.05924958e-06)
152122 EPS nconv=0 first unconverged value (error) -302.035 (1.97665723e-06)
152123 EPS nconv=0 first unconverged value (error) -302.035 (1.95628412e-06)
152124 EPS nconv=0 first unconverged value (error) -302.035 (1.93895121e-06)
152125 EPS nconv=0 first unconverged value (error) -302.035 (1.93895121e-06)
152126 EPS nconv=0 first unconverged value (error) -302.035 (1.99266535e-06)
152127 EPS nconv=0 first unconverged value (error) -302.035 (2.13217388e-06)
152128 EPS nconv=0 first unconverged value (error) -302.035 (1.99968209e-06)
152129 EPS nconv=0 first unconverged value (error) -302.035 (1.85783686e-06)
152130 EPS nconv=0 first unconverged value (error) -302.035 (1.83365375e-06)
152131 EPS nconv=0 first unconverged value (error) -302.035 (1.83365375e-06)
152132 EPS nconv=0 first unconverged value (error) -302.035 (1.86202689e-06)
152133 EPS nconv=0 first unconverged value (error) -302.035 (1.86242737e-06)
152134 EPS nconv=0 first unconverged value (error) -302.035 (1.84521343e-06)
152135 EPS nconv=0 first unconverged value (error) -302.035 (1.83341167e-06)
152136 EPS nconv=0 first unconverged value (error) -302.035 (1.82707004e-06)
152137 EPS nconv=0 first unconverged value (error) -302.035 (1.82707004e-06)
152138 EPS nconv=0 first unconverged value (error) -302.035 (1.87668129e-06)
152139 EPS nconv=0 first unconverged value (error) -302.035 (1.87356414e-06)
152140 EPS nconv=0 first unconverged value (error) -302.035 (1.85641829e-06)
152141 EPS nconv=0 first unconverged value (error) -302.035 (1.82936242e-06)
152142 EPS nconv=0 first unconverged value (error) -302.035 (1.81965660e-06)
152143 EPS nconv=0 first unconverged value (error) -302.035 (1.81965660e-06)
152144 EPS nconv=0 first unconverged value (error) -302.035 (1.85588813e-06)
152145 EPS nconv=0 first unconverged value (error) -302.035 (1.85887984e-06)
152146 EPS nconv=0 first unconverged value (error) -302.035 (1.83729343e-06)
152147 EPS nconv=0 first unconverged value (error) -302.035 (1.82048219e-06)
152148 EPS nconv=0 first unconverged value (error) -302.035 (1.81705612e-06)
152149 EPS nconv=0 first unconverged value (error) -302.035 (1.81705612e-06)
152150 EPS nconv=0 first unconverged value (error) -302.035 (1.96683083e-06)
152151 EPS nconv=0 first unconverged value (error) -302.035 (1.93069084e-06)
152152 EPS nconv=0 first unconverged value (error) -302.035 (1.90122138e-06)
152153 EPS nconv=0 first unconverged value (error) -302.035 (1.87537445e-06)
152154 EPS nconv=0 first unconverged value (error) -302.035 (1.85781662e-06)
152155 EPS nconv=0 first unconverged value (error) -302.035 (1.85781662e-06)
152156 EPS nconv=0 first unconverged value (error) -302.035 (1.85315029e-06)
152157 EPS nconv=0 first unconverged value (error) -302.035 (1.89473595e-06)
152158 EPS nconv=0 first unconverged value (error) -302.035 (1.84460298e-06)
152159 EPS nconv=0 first unconverged value (error) -302.035 (1.81624082e-06)
152160 EPS nconv=0 first unconverged value (error) -302.035 (1.80967188e-06)
152161 EPS nconv=0 first unconverged value (error) -302.035 (1.80967188e-06)
152162 EPS nconv=0 first unconverged value (error) -302.035 (1.92978725e-06)
152163 EPS nconv=0 first unconverged value (error) -302.035 (1.88613820e-06)
152164 EPS nconv=0 first unconverged value (error) -302.035 (1.87127486e-06)
152165 EPS nconv=0 first unconverged value (error) -302.035 (1.86308664e-06)
152166 EPS nconv=0 first unconverged value (error) -302.035 (1.84903193e-06)
152167 EPS nconv=0 first unconverged value (error) -302.035 (1.84903193e-06)
152168 EPS nconv=0 first unconverged value (error) -302.035 (1.85820212e-06)
152169 EPS nconv=0 first unconverged value (error) -302.035 (1.89997497e-06)
152170 EPS nconv=0 first unconverged value (error) -302.035 (1.85181747e-06)
152171 EPS nconv=0 first unconverged value (error) -302.035 (1.81696742e-06)
152172 EPS nconv=0 first unconverged value (error) -302.035 (1.80942375e-06)
152173 EPS nconv=0 first unconverged value (error) -302.035 (1.80942375e-06)
152174 EPS nconv=0 first unconverged value (error) -302.035 (2.19188119e-06)
152175 EPS nconv=0 first unconverged value (error) -302.035 (2.08164357e-06)
152176 EPS nconv=0 first unconverged value (error) -302.035 (2.03386804e-06)
152177 EPS nconv=0 first unconverged value (error) -302.035 (2.00613754e-06)
152178 EPS nconv=0 first unconverged value (error) -302.035 (1.97122997e-06)
152179 EPS nconv=0 first unconverged value (error) -302.035 (1.97122997e-06)
152180 EPS nconv=0 first unconverged value (error) -302.035 (1.96974071e-06)
152181 EPS nconv=0 first unconverged value (error) -302.035 (2.04412421e-06)
152182 EPS nconv=0 first unconverged value (error) -302.035 (1.92656297e-06)
152183 EPS nconv=0 first unconverged value (error) -302.035 (1.85474025e-06)
152184 EPS nconv=0 first unconverged value (error) -302.035 (1.83432055e-06)
152185 EPS nconv=0 first unconverged value (error) -302.035 (1.83432055e-06)
152186 EPS nconv=0 first unconverged value (error) -302.035 (2.13060848e-06)
152187 EPS nconv=0 first unconverged value (error) -302.035 (2.03535957e-06)
152188 EPS nconv=0 first unconverged value (error) -302.035 (1.99136858e-06)
152189 EPS nconv=0 first unconverged value (error) -302.035 (1.96645532e-06)
152190 EPS nconv=0 first unconverged value (error) -302.035 (1.93769902e-06)
152191 EPS nconv=0 first unconverged value (error) -302.035 (1.93769902e-06)
152192 EPS nconv=0 first unconverged value (error) -302.035 (1.98142744e-06)
152193 EPS nconv=0 first unconverged value (error) -302.035 (2.06352228e-06)
152194 EPS nconv=0 first unconverged value (error) -302.035 (1.95386702e-06)
152195 EPS nconv=0 first unconverged value (error) -302.035 (1.86229048e-06)
152196 EPS nconv=0 first unconverged value (error) -302.035 (1.84048639e-06)
152197 EPS nconv=0 first unconverged value (error) -302.035 (1.84048639e-06)
152198 EPS nconv=0 first unconverged value (error) -302.035 (2.29263136e-06)
152199 EPS nconv=0 first unconverged value (error) -302.035 (2.15420487e-06)
152200 EPS nconv=0 first unconverged value (error) -302.035 (2.10919037e-06)
152201 EPS nconv=0 first unconverged value (error) -302.035 (2.05768306e-06)
152202 EPS nconv=0 first unconverged value (error) -302.035 (2.01770467e-06)
152203 EPS nconv=0 first unconverged value (error) -302.035 (2.01770467e-06)
152204 EPS nconv=0 first unconverged value (error) -302.035 (2.01454458e-06)
152205 EPS nconv=0 first unconverged value (error) -302.035 (2.09308013e-06)
152206 EPS nconv=0 first unconverged value (error) -302.035 (1.95457801e-06)
152207 EPS nconv=0 first unconverged value (error) -302.035 (1.91241885e-06)
152208 EPS nconv=0 first unconverged value (error) -302.035 (1.84075822e-06)
152209 EPS nconv=0 first unconverged value (error) -302.035 (1.84075822e-06)
152210 EPS nconv=0 first unconverged value (error) -302.035 (2.06187699e-06)
152211 EPS nconv=0 first unconverged value (error) -302.035 (2.00686604e-06)
152212 EPS nconv=0 first unconverged value (error) -302.035 (1.97507273e-06)
152213 EPS nconv=0 first unconverged value (error) -302.035 (1.95879382e-06)
152214 EPS nconv=0 first unconverged value (error) -302.035 (1.92604085e-06)
152215 EPS nconv=0 first unconverged value (error) -302.035 (1.92604085e-06)
152216 EPS nconv=0 first unconverged value (error) -302.035 (1.92483508e-06)
152217 EPS nconv=0 first unconverged value (error) -302.035 (1.95029539e-06)
152218 EPS nconv=0 first unconverged value (error) -302.035 (1.88506140e-06)
152219 EPS nconv=0 first unconverged value (error) -302.035 (1.84500255e-06)
152220 EPS nconv=0 first unconverged value (error) -302.035 (1.82120130e-06)
152221 EPS nconv=0 first unconverged value (error) -302.035 (1.82120130e-06)
152222 EPS nconv=0 first unconverged value (error) -302.035 (1.93066525e-06)
152223 EPS nconv=0 first unconverged value (error) -302.035 (1.90285216e-06)
152224 EPS nconv=0 first unconverged value (error) -302.035 (1.87709206e-06)
152225 EPS nconv=0 first unconverged value (error) -302.035 (1.86638463e-06)
152226 EPS nconv=0 first unconverged value (error) -302.035 (1.85376689e-06)
152227 EPS nconv=0 first unconverged value (error) -302.035 (1.85376689e-06)
152228 EPS nconv=0 first unconverged value (error) -302.035 (1.86825297e-06)
152229 EPS nconv=0 first unconverged value (error) -302.035 (1.88890308e-06)
152230 EPS nconv=0 first unconverged value (error) -302.035 (1.84932569e-06)
152231 EPS nconv=0 first unconverged value (error) -302.035 (1.83580102e-06)
152232 EPS nconv=0 first unconverged value (error) -302.035 (1.81801821e-06)
152233 EPS nconv=0 first unconverged value (error) -302.035 (1.81801821e-06)
152234 EPS nconv=0 first unconverged value (error) -302.035 (1.88165319e-06)
152235 EPS nconv=0 first unconverged value (error) -302.035 (1.86943822e-06)
152236 EPS nconv=0 first unconverged value (error) -302.035 (1.85739066e-06)
152237 EPS nconv=0 first unconverged value (error) -302.035 (1.84018665e-06)
152238 EPS nconv=0 first unconverged value (error) -302.035 (1.83070640e-06)
152239 EPS nconv=0 first unconverged value (error) -302.035 (1.83070640e-06)
152240 EPS nconv=0 first unconverged value (error) -302.035 (1.98234689e-06)
152241 EPS nconv=0 first unconverged value (error) -302.035 (1.92584114e-06)
152242 EPS nconv=0 first unconverged value (error) -302.035 (1.89681722e-06)
152243 EPS nconv=0 first unconverged value (error) -302.035 (1.87216079e-06)
152244 EPS nconv=0 first unconverged value (error) -302.035 (1.85809495e-06)
152245 EPS nconv=0 first unconverged value (error) -302.035 (1.85809495e-06)
152246 EPS nconv=0 first unconverged value (error) -302.035 (2.02555614e-06)
152247 EPS nconv=0 first unconverged value (error) -302.035 (2.00909468e-06)
152248 EPS nconv=0 first unconverged value (error) -302.035 (1.93723558e-06)
152249 EPS nconv=0 first unconverged value (error) -302.035 (1.91227778e-06)
152250 EPS nconv=0 first unconverged value (error) -302.035 (1.88129067e-06)
152251 EPS nconv=0 first unconverged value (error) -302.035 (1.88129067e-06)
152252 EPS nconv=0 first unconverged value (error) -302.035 (1.94841718e-06)
152253 EPS nconv=0 first unconverged value (error) -302.035 (1.97924254e-06)
152254 EPS nconv=0 first unconverged value (error) -302.035 (1.90397948e-06)
152255 EPS nconv=0 first unconverged value (error) -302.035 (1.87081148e-06)
152256 EPS nconv=0 first unconverged value (error) -302.035 (1.85298238e-06)
152257 EPS nconv=0 first unconverged value (error) -302.035 (1.85298238e-06)
152258 EPS nconv=0 first unconverged value (error) -302.035 (1.93655575e-06)
152259 EPS nconv=0 first unconverged value (error) -302.035 (1.92268549e-06)
152260 EPS nconv=0 first unconverged value (error) -302.035 (1.88666758e-06)
152261 EPS nconv=0 first unconverged value (error) -302.035 (1.86106607e-06)
152262 EPS nconv=0 first unconverged value (error) -302.035 (1.84675522e-06)
152263 EPS nconv=0 first unconverged value (error) -302.035 (1.84675522e-06)
152264 EPS nconv=0 first unconverged value (error) -302.035 (1.91286880e-06)
152265 EPS nconv=0 first unconverged value (error) -302.035 (1.90426319e-06)
152266 EPS nconv=0 first unconverged value (error) -302.035 (1.86826042e-06)
152267 EPS nconv=0 first unconverged value (error) -302.035 (1.84286842e-06)
152268 EPS nconv=0 first unconverged value (error) -302.035 (1.83533023e-06)
152269 EPS nconv=0 first unconverged value (error) -302.035 (1.83533023e-06)
152270 EPS nconv=0 first unconverged value (error) -302.035 (2.00304381e-06)
152271 EPS nconv=0 first unconverged value (error) -302.035 (1.96971501e-06)
152272 EPS nconv=0 first unconverged value (error) -302.035 (1.92200587e-06)
152273 EPS nconv=0 first unconverged value (error) -302.035 (1.89161070e-06)
152274 EPS nconv=0 first unconverged value (error) -302.035 (1.87183900e-06)
152275 EPS nconv=0 first unconverged value (error) -302.035 (1.87183900e-06)
152276 EPS nconv=0 first unconverged value (error) -302.035 (1.97265044e-06)
152277 EPS nconv=0 first unconverged value (error) -302.035 (1.97400775e-06)
152278 EPS nconv=0 first unconverged value (error) -302.035 (1.89850912e-06)
152279 EPS nconv=0 first unconverged value (error) -302.035 (1.88549491e-06)
152280 EPS nconv=0 first unconverged value (error) -302.035 (1.86010427e-06)
152281 EPS nconv=0 first unconverged value (error) -302.035 (1.86010427e-06)
152282 EPS nconv=0 first unconverged value (error) -302.035 (1.94929347e-06)
152283 EPS nconv=0 first unconverged value (error) -302.035 (1.95925113e-06)
152284 EPS nconv=0 first unconverged value (error) -302.035 (1.90014363e-06)
152285 EPS nconv=0 first unconverged value (error) -302.035 (1.86967830e-06)
152286 EPS nconv=0 first unconverged value (error) -302.035 (1.85602528e-06)
152287 EPS nconv=0 first unconverged value (error) -302.035 (1.85602528e-06)
152288 EPS nconv=0 first unconverged value (error) -302.035 (1.89066681e-06)
152289 EPS nconv=0 first unconverged value (error) -302.035 (1.88466975e-06)
152290 EPS nconv=0 first unconverged value (error) -302.035 (1.85454084e-06)
152291 EPS nconv=0 first unconverged value (error) -302.035 (1.83222914e-06)
152292 EPS nconv=0 first unconverged value (error) -302.035 (1.82663792e-06)
152293 EPS nconv=0 first unconverged value (error) -302.035 (1.82663792e-06)
152294 EPS nconv=0 first unconverged value (error) -302.035 (1.91076627e-06)
152295 EPS nconv=0 first unconverged value (error) -302.035 (1.89990461e-06)
152296 EPS nconv=0 first unconverged value (error) -302.035 (1.86995005e-06)
152297 EPS nconv=0 first unconverged value (error) -302.035 (1.84479089e-06)
152298 EPS nconv=0 first unconverged value (error) -302.035 (1.83461193e-06)
152299 EPS nconv=0 first unconverged value (error) -302.035 (1.83461193e-06)
152300 EPS nconv=0 first unconverged value (error) -302.035 (1.95688354e-06)
152301 EPS nconv=0 first unconverged value (error) -302.035 (1.93689488e-06)
152302 EPS nconv=0 first unconverged value (error) -302.035 (1.88801549e-06)
152303 EPS nconv=0 first unconverged value (error) -302.035 (1.87912889e-06)
152304 EPS nconv=0 first unconverged value (error) -302.035 (1.86068410e-06)
152305 EPS nconv=0 first unconverged value (error) -302.035 (1.86068410e-06)
152306 EPS nconv=0 first unconverged value (error) -302.035 (1.90238416e-06)
152307 EPS nconv=0 first unconverged value (error) -302.035 (1.92958063e-06)
152308 EPS nconv=0 first unconverged value (error) -302.035 (1.87460591e-06)
152309 EPS nconv=0 first unconverged value (error) -302.035 (1.84183519e-06)
152310 EPS nconv=0 first unconverged value (error) -302.035 (1.83196278e-06)
152311 EPS nconv=0 first unconverged value (error) -302.035 (1.83196278e-06)
152312 EPS nconv=0 first unconverged value (error) -302.035 (1.82794634e-06)
152313 EPS nconv=0 first unconverged value (error) -302.035 (1.83196453e-06)
152314 EPS nconv=0 first unconverged value (error) -302.035 (1.81754581e-06)
152315 EPS nconv=0 first unconverged value (error) -302.035 (1.80750684e-06)
152316 EPS nconv=0 first unconverged value (error) -302.035 (1.80563303e-06)
152317 EPS nconv=0 first unconverged value (error) -302.035 (1.80563303e-06)
152318 EPS nconv=0 first unconverged value (error) -302.035 (1.81944191e-06)
152319 EPS nconv=0 first unconverged value (error) -302.035 (1.81919431e-06)
152320 EPS nconv=0 first unconverged value (error) -302.035 (1.81167560e-06)
152321 EPS nconv=0 first unconverged value (error) -302.035 (1.80518328e-06)
152322 EPS nconv=0 first unconverged value (error) -302.035 (1.80223374e-06)
152323 EPS nconv=0 first unconverged value (error) -302.035 (1.80223374e-06)
152324 EPS nconv=0 first unconverged value (error) -302.035 (1.89589908e-06)
152325 EPS nconv=0 first unconverged value (error) -302.035 (1.87519363e-06)
152326 EPS nconv=0 first unconverged value (error) -302.035 (1.85626711e-06)
152327 EPS nconv=0 first unconverged value (error) -302.035 (1.85119952e-06)
152328 EPS nconv=0 first unconverged value (error) -302.035 (1.83883269e-06)
152329 EPS nconv=0 first unconverged value (error) -302.035 (1.83883269e-06)
152330 EPS nconv=0 first unconverged value (error) -302.035 (1.84899411e-06)
152331 EPS nconv=0 first unconverged value (error) -302.035 (1.86548769e-06)
152332 EPS nconv=0 first unconverged value (error) -302.035 (1.83564147e-06)
152333 EPS nconv=0 first unconverged value (error) -302.035 (1.81698156e-06)
152334 EPS nconv=0 first unconverged value (error) -302.035 (1.81093079e-06)
152335 EPS nconv=0 first unconverged value (error) -302.035 (1.81093079e-06)
152336 EPS nconv=0 first unconverged value (error) -302.035 (1.79815753e-06)
152337 EPS nconv=0 first unconverged value (error) -302.035 (1.80016522e-06)
152338 EPS nconv=0 first unconverged value (error) -302.035 (1.79722802e-06)
152339 EPS nconv=0 first unconverged value (error) -302.035 (1.79543212e-06)
152340 EPS nconv=0 first unconverged value (error) -302.035 (1.79515601e-06)
152341 EPS nconv=0 first unconverged value (error) -302.035 (1.79515601e-06)
152342 EPS nconv=0 first unconverged value (error) -302.035 (1.80604450e-06)
152343 EPS nconv=0 first unconverged value (error) -302.035 (1.80062572e-06)
152344 EPS nconv=0 first unconverged value (error) -302.035 (1.79967678e-06)
152345 EPS nconv=0 first unconverged value (error) -302.035 (1.79918142e-06)
152346 EPS nconv=0 first unconverged value (error) -302.035 (1.79791007e-06)
152347 EPS nconv=0 first unconverged value (error) -302.035 (1.79791007e-06)
152348 EPS nconv=0 first unconverged value (error) -302.035 (1.80943835e-06)
152349 EPS nconv=0 first unconverged value (error) -302.035 (1.81116335e-06)
152350 EPS nconv=0 first unconverged value (error) -302.035 (1.80444111e-06)
152351 EPS nconv=0 first unconverged value (error) -302.035 (1.80340677e-06)
152352 EPS nconv=0 first unconverged value (error) -302.035 (1.80157552e-06)
152353 EPS nconv=0 first unconverged value (error) -302.035 (1.80157552e-06)
152354 EPS nconv=0 first unconverged value (error) -302.035 (1.81255521e-06)
152355 EPS nconv=0 first unconverged value (error) -302.035 (1.80724820e-06)
152356 EPS nconv=0 first unconverged value (error) -302.035 (1.80345828e-06)
152357 EPS nconv=0 first unconverged value (error) -302.035 (1.80243909e-06)
152358 EPS nconv=0 first unconverged value (error) -302.035 (1.80064051e-06)
152359 EPS nconv=0 first unconverged value (error) -302.035 (1.80064051e-06)
152360 EPS nconv=0 first unconverged value (error) -302.035 (1.82258364e-06)
152361 EPS nconv=0 first unconverged value (error) -302.035 (1.81784854e-06)
152362 EPS nconv=0 first unconverged value (error) -302.035 (1.81086715e-06)
152363 EPS nconv=0 first unconverged value (error) -302.035 (1.80534792e-06)
152364 EPS nconv=0 first unconverged value (error) -302.035 (1.80366377e-06)
152365 EPS nconv=0 first unconverged value (error) -302.035 (1.80366377e-06)
152366 EPS nconv=0 first unconverged value (error) -302.035 (1.86093168e-06)
152367 EPS nconv=0 first unconverged value (error) -302.035 (1.84229038e-06)
152368 EPS nconv=0 first unconverged value (error) -302.035 (1.83039952e-06)
152369 EPS nconv=0 first unconverged value (error) -302.035 (1.82524953e-06)
152370 EPS nconv=0 first unconverged value (error) -302.035 (1.81603090e-06)
152371 EPS nconv=0 first unconverged value (error) -302.035 (1.81603090e-06)
152372 EPS nconv=0 first unconverged value (error) -302.035 (1.93924250e-06)
152373 EPS nconv=0 first unconverged value (error) -302.035 (1.93015211e-06)
152374 EPS nconv=0 first unconverged value (error) -302.035 (1.88620302e-06)
152375 EPS nconv=0 first unconverged value (error) -302.035 (1.87435134e-06)
152376 EPS nconv=0 first unconverged value (error) -302.035 (1.85823926e-06)
152377 EPS nconv=0 first unconverged value (error) -302.035 (1.85823926e-06)
152378 EPS nconv=0 first unconverged value (error) -302.035 (1.87481359e-06)
152379 EPS nconv=0 first unconverged value (error) -302.035 (1.87852469e-06)
152380 EPS nconv=0 first unconverged value (error) -302.035 (1.84372567e-06)
152381 EPS nconv=0 first unconverged value (error) -302.035 (1.82446409e-06)
152382 EPS nconv=0 first unconverged value (error) -302.035 (1.81697123e-06)
152383 EPS nconv=0 first unconverged value (error) -302.035 (1.81697123e-06)
152384 EPS nconv=0 first unconverged value (error) -302.035 (1.81346292e-06)
152385 EPS nconv=0 first unconverged value (error) -302.035 (1.81740615e-06)
152386 EPS nconv=0 first unconverged value (error) -302.035 (1.80757365e-06)
152387 EPS nconv=0 first unconverged value (error) -302.035 (1.80293614e-06)
152388 EPS nconv=0 first unconverged value (error) -302.035 (1.80125768e-06)
152389 EPS nconv=0 first unconverged value (error) -302.035 (1.80125768e-06)
152390 EPS nconv=0 first unconverged value (error) -302.035 (1.80464002e-06)
152391 EPS nconv=0 first unconverged value (error) -302.035 (1.80513219e-06)
152392 EPS nconv=0 first unconverged value (error) -302.035 (1.79992638e-06)
152393 EPS nconv=0 first unconverged value (error) -302.035 (1.79809799e-06)
152394 EPS nconv=0 first unconverged value (error) -302.035 (1.79671611e-06)
152395 EPS nconv=0 first unconverged value (error) -302.035 (1.79671611e-06)
152396 EPS nconv=0 first unconverged value (error) -302.035 (2.00370237e-06)
152397 EPS nconv=0 first unconverged value (error) -302.035 (1.96025452e-06)
152398 EPS nconv=0 first unconverged value (error) -302.035 (1.92287427e-06)
152399 EPS nconv=0 first unconverged value (error) -302.035 (1.91601802e-06)
152400 EPS nconv=0 first unconverged value (error) -302.035 (1.88984134e-06)
152401 EPS nconv=0 first unconverged value (error) -302.035 (1.88984134e-06)
152402 EPS nconv=0 first unconverged value (error) -302.035 (1.89755192e-06)
152403 EPS nconv=0 first unconverged value (error) -302.035 (1.92355330e-06)
152404 EPS nconv=0 first unconverged value (error) -302.035 (1.87432735e-06)
152405 EPS nconv=0 first unconverged value (error) -302.035 (1.82821351e-06)
152406 EPS nconv=0 first unconverged value (error) -302.035 (1.82425199e-06)
152407 EPS nconv=0 first unconverged value (error) -302.035 (1.82425199e-06)
152408 EPS nconv=0 first unconverged value (error) -302.035 (1.82741340e-06)
152409 EPS nconv=0 first unconverged value (error) -302.035 (1.81725580e-06)
152410 EPS nconv=0 first unconverged value (error) -302.035 (1.81384484e-06)
152411 EPS nconv=0 first unconverged value (error) -302.035 (1.80864891e-06)
152412 EPS nconv=0 first unconverged value (error) -302.035 (1.80611309e-06)
152413 EPS nconv=0 first unconverged value (error) -302.035 (1.80611309e-06)
152414 EPS nconv=0 first unconverged value (error) -302.035 (1.80817587e-06)
152415 EPS nconv=0 first unconverged value (error) -302.035 (1.81604413e-06)
152416 EPS nconv=0 first unconverged value (error) -302.035 (1.80364424e-06)
152417 EPS nconv=0 first unconverged value (error) -302.035 (1.80058807e-06)
152418 EPS nconv=0 first unconverged value (error) -302.035 (1.79782182e-06)
152419 EPS nconv=0 first unconverged value (error) -302.035 (1.79782182e-06)
152420 EPS nconv=0 first unconverged value (error) -302.035 (1.96685438e-06)
152421 EPS nconv=0 first unconverged value (error) -302.035 (1.93572553e-06)
152422 EPS nconv=0 first unconverged value (error) -302.035 (1.90198647e-06)
152423 EPS nconv=0 first unconverged value (error) -302.035 (1.89466942e-06)
152424 EPS nconv=0 first unconverged value (error) -302.035 (1.87245985e-06)
152425 EPS nconv=0 first unconverged value (error) -302.035 (1.87245985e-06)
152426 EPS nconv=0 first unconverged value (error) -302.035 (1.93980382e-06)
152427 EPS nconv=0 first unconverged value (error) -302.035 (1.95125136e-06)
152428 EPS nconv=0 first unconverged value (error) -302.035 (1.91176039e-06)
152429 EPS nconv=0 first unconverged value (error) -302.035 (1.86151529e-06)
152430 EPS nconv=0 first unconverged value (error) -302.035 (1.84894657e-06)
152431 EPS nconv=0 first unconverged value (error) -302.035 (1.84894657e-06)
152432 EPS nconv=0 first unconverged value (error) -302.035 (1.87433949e-06)
152433 EPS nconv=0 first unconverged value (error) -302.035 (1.86687128e-06)
152434 EPS nconv=0 first unconverged value (error) -302.035 (1.84945592e-06)
152435 EPS nconv=0 first unconverged value (error) -302.035 (1.82450242e-06)
152436 EPS nconv=0 first unconverged value (error) -302.035 (1.82064833e-06)
152437 EPS nconv=0 first unconverged value (error) -302.035 (1.82064833e-06)
152438 EPS nconv=0 first unconverged value (error) -302.035 (1.84803854e-06)
152439 EPS nconv=0 first unconverged value (error) -302.035 (1.84539631e-06)
152440 EPS nconv=0 first unconverged value (error) -302.035 (1.82238421e-06)
152441 EPS nconv=0 first unconverged value (error) -302.035 (1.81739538e-06)
152442 EPS nconv=0 first unconverged value (error) -302.035 (1.81135202e-06)
152443 EPS nconv=0 first unconverged value (error) -302.035 (1.81135202e-06)
152444 EPS nconv=0 first unconverged value (error) -302.035 (1.87685153e-06)
152445 EPS nconv=0 first unconverged value (error) -302.035 (1.88249648e-06)
152446 EPS nconv=0 first unconverged value (error) -302.035 (1.85066608e-06)
152447 EPS nconv=0 first unconverged value (error) -302.035 (1.83542865e-06)
152448 EPS nconv=0 first unconverged value (error) -302.035 (1.82560514e-06)
152449 EPS nconv=0 first unconverged value (error) -302.035 (1.82560514e-06)
152450 EPS nconv=0 first unconverged value (error) -302.035 (1.99152920e-06)
152451 EPS nconv=0 first unconverged value (error) -302.035 (1.93348017e-06)
152452 EPS nconv=0 first unconverged value (error) -302.035 (1.91052095e-06)
152453 EPS nconv=0 first unconverged value (error) -302.035 (1.89221278e-06)
152454 EPS nconv=0 first unconverged value (error) -302.035 (1.87715559e-06)
152455 EPS nconv=0 first unconverged value (error) -302.035 (1.87715559e-06)
152456 EPS nconv=0 first unconverged value (error) -302.035 (1.86790153e-06)
152457 EPS nconv=0 first unconverged value (error) -302.035 (1.91551461e-06)
152458 EPS nconv=0 first unconverged value (error) -302.035 (1.84203012e-06)
152459 EPS nconv=0 first unconverged value (error) -302.035 (1.81794648e-06)
152460 EPS nconv=0 first unconverged value (error) -302.035 (1.81478536e-06)
152461 EPS nconv=0 first unconverged value (error) -302.035 (1.81478536e-06)
152462 EPS nconv=0 first unconverged value (error) -302.035 (1.83782990e-06)
152463 EPS nconv=0 first unconverged value (error) -302.035 (1.82113453e-06)
152464 EPS nconv=0 first unconverged value (error) -302.035 (1.81437638e-06)
152465 EPS nconv=0 first unconverged value (error) -302.035 (1.81282086e-06)
152466 EPS nconv=0 first unconverged value (error) -302.035 (1.80968446e-06)
152467 EPS nconv=0 first unconverged value (error) -302.035 (1.80968446e-06)
152468 EPS nconv=0 first unconverged value (error) -302.035 (1.81333670e-06)
152469 EPS nconv=0 first unconverged value (error) -302.035 (1.82581432e-06)
152470 EPS nconv=0 first unconverged value (error) -302.035 (1.80735663e-06)
152471 EPS nconv=0 first unconverged value (error) -302.035 (1.80239254e-06)
152472 EPS nconv=0 first unconverged value (error) -302.035 (1.80020413e-06)
152473 EPS nconv=0 first unconverged value (error) -302.035 (1.80020413e-06)
152474 EPS nconv=0 first unconverged value (error) -302.035 (1.82486637e-06)
152475 EPS nconv=0 first unconverged value (error) -302.035 (1.81777240e-06)
152476 EPS nconv=0 first unconverged value (error) -302.035 (1.81328220e-06)
152477 EPS nconv=0 first unconverged value (error) -302.035 (1.81078583e-06)
152478 EPS nconv=0 first unconverged value (error) -302.035 (1.80620272e-06)
152479 EPS nconv=0 first unconverged value (error) -302.035 (1.80620272e-06)
152480 EPS nconv=0 first unconverged value (error) -302.035 (1.89716332e-06)
152481 EPS nconv=0 first unconverged value (error) -302.035 (1.87794541e-06)
152482 EPS nconv=0 first unconverged value (error) -302.035 (1.85233785e-06)
152483 EPS nconv=0 first unconverged value (error) -302.035 (1.83904565e-06)
152484 EPS nconv=0 first unconverged value (error) -302.035 (1.82852847e-06)
152485 EPS nconv=0 first unconverged value (error) -302.035 (1.82852847e-06)
152486 EPS nconv=0 first unconverged value (error) -302.035 (1.82626833e-06)
152487 EPS nconv=0 first unconverged value (error) -302.035 (1.84945755e-06)
152488 EPS nconv=0 first unconverged value (error) -302.035 (1.82230583e-06)
152489 EPS nconv=0 first unconverged value (error) -302.035 (1.80889999e-06)
152490 EPS nconv=0 first unconverged value (error) -302.035 (1.80502726e-06)
152491 EPS nconv=0 first unconverged value (error) -302.035 (1.80502726e-06)
152492 EPS nconv=0 first unconverged value (error) -302.035 (1.79532069e-06)
152493 EPS nconv=0 first unconverged value (error) -302.035 (1.79487266e-06)
152494 EPS nconv=0 first unconverged value (error) -302.035 (1.79454708e-06)
152495 EPS nconv=0 first unconverged value (error) -302.035 (1.79436500e-06)
152496 EPS nconv=0 first unconverged value (error) -302.035 (1.79423979e-06)
152497 EPS nconv=0 first unconverged value (error) -302.035 (1.79423979e-06)
152498 EPS nconv=0 first unconverged value (error) -302.035 (1.90246132e-06)
152499 EPS nconv=0 first unconverged value (error) -302.035 (1.86762646e-06)
152500 EPS nconv=0 first unconverged value (error) -302.035 (1.85673053e-06)
152501 EPS nconv=0 first unconverged value (error) -302.035 (1.84807696e-06)
152502 EPS nconv=0 first unconverged value (error) -302.035 (1.83751080e-06)
152503 EPS nconv=0 first unconverged value (error) -302.035 (1.83751080e-06)
152504 EPS nconv=0 first unconverged value (error) -302.035 (1.86379643e-06)
152505 EPS nconv=0 first unconverged value (error) -302.035 (1.88824432e-06)
152506 EPS nconv=0 first unconverged value (error) -302.035 (1.85370981e-06)
152507 EPS nconv=0 first unconverged value (error) -302.035 (1.82446471e-06)
152508 EPS nconv=0 first unconverged value (error) -302.035 (1.81638414e-06)
152509 EPS nconv=0 first unconverged value (error) -302.035 (1.81638414e-06)
152510 EPS nconv=0 first unconverged value (error) -302.035 (1.92772106e-06)
152511 EPS nconv=0 first unconverged value (error) -302.035 (1.88930489e-06)
152512 EPS nconv=0 first unconverged value (error) -302.035 (1.87226270e-06)
152513 EPS nconv=0 first unconverged value (error) -302.035 (1.86200493e-06)
152514 EPS nconv=0 first unconverged value (error) -302.035 (1.84666105e-06)
152515 EPS nconv=0 first unconverged value (error) -302.035 (1.84666105e-06)
152516 EPS nconv=0 first unconverged value (error) -302.035 (2.10023149e-06)
152517 EPS nconv=0 first unconverged value (error) -302.035 (2.12102065e-06)
152518 EPS nconv=0 first unconverged value (error) -302.035 (2.08007606e-06)
152519 EPS nconv=0 first unconverged value (error) -302.035 (1.96791850e-06)
152520 EPS nconv=0 first unconverged value (error) -302.035 (1.94359613e-06)
152521 EPS nconv=0 first unconverged value (error) -302.035 (1.94359613e-06)
152522 EPS nconv=0 first unconverged value (error) -302.035 (1.94341030e-06)
152523 EPS nconv=0 first unconverged value (error) -302.035 (1.91192801e-06)
152524 EPS nconv=0 first unconverged value (error) -302.035 (1.86577440e-06)
152525 EPS nconv=0 first unconverged value (error) -302.035 (1.82357914e-06)
152526 EPS nconv=0 first unconverged value (error) -302.035 (1.81068399e-06)
152527 EPS nconv=0 first unconverged value (error) -302.035 (1.81068399e-06)
152528 EPS nconv=0 first unconverged value (error) -302.035 (2.10233816e-06)
152529 EPS nconv=0 first unconverged value (error) -302.035 (2.03631585e-06)
152530 EPS nconv=0 first unconverged value (error) -302.035 (1.97870422e-06)
152531 EPS nconv=0 first unconverged value (error) -302.035 (1.94385933e-06)
152532 EPS nconv=0 first unconverged value (error) -302.035 (1.92937093e-06)
152533 EPS nconv=0 first unconverged value (error) -302.035 (1.92937093e-06)
152534 EPS nconv=0 first unconverged value (error) -302.035 (1.94295824e-06)
152535 EPS nconv=0 first unconverged value (error) -302.035 (2.00029619e-06)
152536 EPS nconv=0 first unconverged value (error) -302.035 (1.92734623e-06)
152537 EPS nconv=0 first unconverged value (error) -302.035 (1.85334484e-06)
152538 EPS nconv=0 first unconverged value (error) -302.035 (1.82139116e-06)
152539 EPS nconv=0 first unconverged value (error) -302.035 (1.82139116e-06)
152540 EPS nconv=0 first unconverged value (error) -302.035 (2.07755727e-06)
152541 EPS nconv=0 first unconverged value (error) -302.035 (2.03790919e-06)
152542 EPS nconv=0 first unconverged value (error) -302.035 (2.00816860e-06)
152543 EPS nconv=0 first unconverged value (error) -302.035 (1.98099540e-06)
152544 EPS nconv=0 first unconverged value (error) -302.035 (1.95145803e-06)
152545 EPS nconv=0 first unconverged value (error) -302.035 (1.95145803e-06)
152546 EPS nconv=0 first unconverged value (error) -302.035 (1.96494755e-06)
152547 EPS nconv=0 first unconverged value (error) -302.035 (1.95834104e-06)
152548 EPS nconv=0 first unconverged value (error) -302.035 (1.92416256e-06)
152549 EPS nconv=0 first unconverged value (error) -302.035 (1.84899628e-06)
152550 EPS nconv=0 first unconverged value (error) -302.035 (1.82828216e-06)
152551 EPS nconv=0 first unconverged value (error) -302.035 (1.82828216e-06)
152552 EPS nconv=0 first unconverged value (error) -302.035 (2.10438344e-06)
152553 EPS nconv=0 first unconverged value (error) -302.035 (2.02806794e-06)
152554 EPS nconv=0 first unconverged value (error) -302.035 (1.98449507e-06)
152555 EPS nconv=0 first unconverged value (error) -302.035 (1.94696398e-06)
152556 EPS nconv=0 first unconverged value (error) -302.035 (1.92761554e-06)
152557 EPS nconv=0 first unconverged value (error) -302.035 (1.92761554e-06)
152558 EPS nconv=0 first unconverged value (error) -302.035 (1.96356058e-06)
152559 EPS nconv=0 first unconverged value (error) -302.035 (2.04099101e-06)
152560 EPS nconv=0 first unconverged value (error) -302.035 (1.96539522e-06)
152561 EPS nconv=0 first unconverged value (error) -302.035 (1.86137613e-06)
152562 EPS nconv=0 first unconverged value (error) -302.035 (1.83197263e-06)
152563 EPS nconv=0 first unconverged value (error) -302.035 (1.83197263e-06)
152564 EPS nconv=0 first unconverged value (error) -302.035 (1.84163788e-06)
152565 EPS nconv=0 first unconverged value (error) -302.035 (1.83309354e-06)
152566 EPS nconv=0 first unconverged value (error) -302.035 (1.81756901e-06)
152567 EPS nconv=0 first unconverged value (error) -302.035 (1.81569432e-06)
152568 EPS nconv=0 first unconverged value (error) -302.035 (1.81257362e-06)
152569 EPS nconv=0 first unconverged value (error) -302.035 (1.81257362e-06)
152570 EPS nconv=0 first unconverged value (error) -302.035 (1.81347425e-06)
152571 EPS nconv=0 first unconverged value (error) -302.035 (1.81351664e-06)
152572 EPS nconv=0 first unconverged value (error) -302.035 (1.80756170e-06)
152573 EPS nconv=0 first unconverged value (error) -302.035 (1.80359656e-06)
152574 EPS nconv=0 first unconverged value (error) -302.035 (1.79930301e-06)
152575 EPS nconv=0 first unconverged value (error) -302.035 (1.79930301e-06)
152576 EPS nconv=0 first unconverged value (error) -302.035 (2.08539664e-06)
152577 EPS nconv=0 first unconverged value (error) -302.035 (2.04181487e-06)
152578 EPS nconv=0 first unconverged value (error) -302.035 (1.99176425e-06)
152579 EPS nconv=0 first unconverged value (error) -302.035 (1.94464942e-06)
152580 EPS nconv=0 first unconverged value (error) -302.035 (1.91842995e-06)
152581 EPS nconv=0 first unconverged value (error) -302.035 (1.91842995e-06)
152582 EPS nconv=0 first unconverged value (error) -302.035 (1.91795665e-06)
152583 EPS nconv=0 first unconverged value (error) -302.035 (1.97235232e-06)
152584 EPS nconv=0 first unconverged value (error) -302.035 (1.92457377e-06)
152585 EPS nconv=0 first unconverged value (error) -302.035 (1.84980368e-06)
152586 EPS nconv=0 first unconverged value (error) -302.035 (1.81669822e-06)
152587 EPS nconv=0 first unconverged value (error) -302.035 (1.81669822e-06)
152588 EPS nconv=0 first unconverged value (error) -302.035 (1.83025197e-06)
152589 EPS nconv=0 first unconverged value (error) -302.035 (1.82660126e-06)
152590 EPS nconv=0 first unconverged value (error) -302.035 (1.82031271e-06)
152591 EPS nconv=0 first unconverged value (error) -302.035 (1.81540003e-06)
152592 EPS nconv=0 first unconverged value (error) -302.035 (1.81175529e-06)
152593 EPS nconv=0 first unconverged value (error) -302.035 (1.81175529e-06)
152594 EPS nconv=0 first unconverged value (error) -302.035 (1.84598451e-06)
152595 EPS nconv=0 first unconverged value (error) -302.035 (1.83113066e-06)
152596 EPS nconv=0 first unconverged value (error) -302.035 (1.82033563e-06)
152597 EPS nconv=0 first unconverged value (error) -302.035 (1.81710431e-06)
152598 EPS nconv=0 first unconverged value (error) -302.035 (1.81331915e-06)
152599 EPS nconv=0 first unconverged value (error) -302.035 (1.81331915e-06)
152600 EPS nconv=0 first unconverged value (error) -302.035 (2.13255187e-06)
152601 EPS nconv=0 first unconverged value (error) -302.035 (2.10025849e-06)
152602 EPS nconv=0 first unconverged value (error) -302.035 (2.01222788e-06)
152603 EPS nconv=0 first unconverged value (error) -302.035 (1.95919418e-06)
152604 EPS nconv=0 first unconverged value (error) -302.035 (1.94018496e-06)
152605 EPS nconv=0 first unconverged value (error) -302.035 (1.94018496e-06)
152606 EPS nconv=0 first unconverged value (error) -302.035 (2.12209262e-06)
152607 EPS nconv=0 first unconverged value (error) -302.035 (2.12819457e-06)
152608 EPS nconv=0 first unconverged value (error) -302.035 (2.07161855e-06)
152609 EPS nconv=0 first unconverged value (error) -302.035 (2.00348610e-06)
152610 EPS nconv=0 first unconverged value (error) -302.035 (1.92703608e-06)
152611 EPS nconv=0 first unconverged value (error) -302.035 (1.92703608e-06)
152612 EPS nconv=0 first unconverged value (error) -302.035 (1.91529858e-06)
152613 EPS nconv=0 first unconverged value (error) -302.035 (1.88736164e-06)
152614 EPS nconv=0 first unconverged value (error) -302.035 (1.85738571e-06)
152615 EPS nconv=0 first unconverged value (error) -302.035 (1.82481148e-06)
152616 EPS nconv=0 first unconverged value (error) -302.035 (1.80648176e-06)
152617 EPS nconv=0 first unconverged value (error) -302.035 (1.80648176e-06)
152618 EPS nconv=0 first unconverged value (error) -302.035 (1.86412697e-06)
152619 EPS nconv=0 first unconverged value (error) -302.035 (1.82933471e-06)
152620 EPS nconv=0 first unconverged value (error) -302.035 (1.81667796e-06)
152621 EPS nconv=0 first unconverged value (error) -302.035 (1.81265759e-06)
152622 EPS nconv=0 first unconverged value (error) -302.035 (1.81004992e-06)
152623 EPS nconv=0 first unconverged value (error) -302.035 (1.81004992e-06)
152624 EPS nconv=0 first unconverged value (error) -302.035 (1.82570849e-06)
152625 EPS nconv=0 first unconverged value (error) -302.035 (1.84363834e-06)
152626 EPS nconv=0 first unconverged value (error) -302.035 (1.82387244e-06)
152627 EPS nconv=0 first unconverged value (error) -302.035 (1.80447351e-06)
152628 EPS nconv=0 first unconverged value (error) -302.035 (1.80243164e-06)
152629 EPS nconv=0 first unconverged value (error) -302.035 (1.80243164e-06)
152630 EPS nconv=0 first unconverged value (error) -302.035 (1.80044063e-06)
152631 EPS nconv=0 first unconverged value (error) -302.035 (1.79928276e-06)
152632 EPS nconv=0 first unconverged value (error) -302.035 (1.79633566e-06)
152633 EPS nconv=0 first unconverged value (error) -302.035 (1.79475687e-06)
152634 EPS nconv=0 first unconverged value (error) -302.035 (1.79423935e-06)
152635 EPS nconv=0 first unconverged value (error) -302.035 (1.79423935e-06)
152636 EPS nconv=0 first unconverged value (error) -302.035 (1.80702342e-06)
152637 EPS nconv=0 first unconverged value (error) -302.035 (1.80240298e-06)
152638 EPS nconv=0 first unconverged value (error) -302.035 (1.80122557e-06)
152639 EPS nconv=0 first unconverged value (error) -302.035 (1.79968460e-06)
152640 EPS nconv=0 first unconverged value (error) -302.035 (1.79887699e-06)
152641 EPS nconv=0 first unconverged value (error) -302.035 (1.79887699e-06)
152642 EPS nconv=0 first unconverged value (error) -302.035 (1.80170978e-06)
152643 EPS nconv=0 first unconverged value (error) -302.035 (1.80535470e-06)
152644 EPS nconv=0 first unconverged value (error) -302.035 (1.80187276e-06)
152645 EPS nconv=0 first unconverged value (error) -302.035 (1.79667574e-06)
152646 EPS nconv=0 first unconverged value (error) -302.035 (1.79598693e-06)
152647 EPS nconv=0 first unconverged value (error) -302.035 (1.79598693e-06)
152648 EPS nconv=0 first unconverged value (error) -302.035 (1.81022150e-06)
152649 EPS nconv=0 first unconverged value (error) -302.035 (1.80363231e-06)
152650 EPS nconv=0 first unconverged value (error) -302.035 (1.80206044e-06)
152651 EPS nconv=0 first unconverged value (error) -302.035 (1.80126863e-06)
152652 EPS nconv=0 first unconverged value (error) -302.035 (1.80053130e-06)
152653 EPS nconv=0 first unconverged value (error) -302.035 (1.80053130e-06)
152654 EPS nconv=0 first unconverged value (error) -302.035 (1.84486266e-06)
152655 EPS nconv=0 first unconverged value (error) -302.035 (1.82628444e-06)
152656 EPS nconv=0 first unconverged value (error) -302.035 (1.81575562e-06)
152657 EPS nconv=0 first unconverged value (error) -302.035 (1.81453496e-06)
152658 EPS nconv=0 first unconverged value (error) -302.035 (1.81394816e-06)
152659 EPS nconv=0 first unconverged value (error) -302.035 (1.81394816e-06)
152660 EPS nconv=0 first unconverged value (error) -302.035 (2.15171273e-06)
152661 EPS nconv=0 first unconverged value (error) -302.035 (2.04271481e-06)
152662 EPS nconv=0 first unconverged value (error) -302.035 (1.94951764e-06)
152663 EPS nconv=0 first unconverged value (error) -302.035 (1.90695319e-06)
152664 EPS nconv=0 first unconverged value (error) -302.035 (1.89651689e-06)
152665 EPS nconv=0 first unconverged value (error) -302.035 (1.89651689e-06)
152666 EPS nconv=0 first unconverged value (error) -302.035 (2.02344559e-06)
152667 EPS nconv=0 first unconverged value (error) -302.035 (2.06532875e-06)
152668 EPS nconv=0 first unconverged value (error) -302.035 (1.96122259e-06)
152669 EPS nconv=0 first unconverged value (error) -302.035 (1.91589087e-06)
152670 EPS nconv=0 first unconverged value (error) -302.035 (1.88121148e-06)
152671 EPS nconv=0 first unconverged value (error) -302.035 (1.88121148e-06)
152672 EPS nconv=0 first unconverged value (error) -302.035 (1.86866784e-06)
152673 EPS nconv=0 first unconverged value (error) -302.035 (1.87783132e-06)
152674 EPS nconv=0 first unconverged value (error) -302.035 (1.84070772e-06)
152675 EPS nconv=0 first unconverged value (error) -302.035 (1.81376261e-06)
152676 EPS nconv=0 first unconverged value (error) -302.035 (1.80260907e-06)
152677 EPS nconv=0 first unconverged value (error) -302.035 (1.80260907e-06)
152678 EPS nconv=0 first unconverged value (error) -302.035 (1.79884001e-06)
152679 EPS nconv=0 first unconverged value (error) -302.035 (1.79930382e-06)
152680 EPS nconv=0 first unconverged value (error) -302.035 (1.79672863e-06)
152681 EPS nconv=0 first unconverged value (error) -302.035 (1.79556474e-06)
152682 EPS nconv=0 first unconverged value (error) -302.035 (1.79559490e-06)
152683 EPS nconv=0 first unconverged value (error) -302.035 (1.79559490e-06)
152684 EPS nconv=0 first unconverged value (error) -302.035 (2.30134451e-06)
152685 EPS nconv=0 first unconverged value (error) -302.035 (2.04743032e-06)
152686 EPS nconv=0 first unconverged value (error) -302.035 (2.00138920e-06)
152687 EPS nconv=0 first unconverged value (error) -302.035 (1.97488871e-06)
152688 EPS nconv=0 first unconverged value (error) -302.035 (1.94345884e-06)
152689 EPS nconv=0 first unconverged value (error) -302.035 (1.94345884e-06)
152690 EPS nconv=0 first unconverged value (error) -302.035 (1.97938467e-06)
152691 EPS nconv=0 first unconverged value (error) -302.035 (2.22634887e-06)
152692 EPS nconv=0 first unconverged value (error) -302.035 (1.95008730e-06)
152693 EPS nconv=0 first unconverged value (error) -302.035 (1.85555758e-06)
152694 EPS nconv=0 first unconverged value (error) -302.035 (1.83888487e-06)
152695 EPS nconv=0 first unconverged value (error) -302.035 (1.83888487e-06)
152696 EPS nconv=0 first unconverged value (error) -302.035 (1.87776146e-06)
152697 EPS nconv=0 first unconverged value (error) -302.035 (1.85981100e-06)
152698 EPS nconv=0 first unconverged value (error) -302.035 (1.84438117e-06)
152699 EPS nconv=0 first unconverged value (error) -302.035 (1.84084254e-06)
152700 EPS nconv=0 first unconverged value (error) -302.035 (1.82756956e-06)
152701 EPS nconv=0 first unconverged value (error) -302.035 (1.82756956e-06)
152702 EPS nconv=0 first unconverged value (error) -302.035 (1.92048751e-06)
152703 EPS nconv=0 first unconverged value (error) -302.035 (1.89330099e-06)
152704 EPS nconv=0 first unconverged value (error) -302.035 (1.86176746e-06)
152705 EPS nconv=0 first unconverged value (error) -302.035 (1.85834529e-06)
152706 EPS nconv=0 first unconverged value (error) -302.035 (1.85654462e-06)
152707 EPS nconv=0 first unconverged value (error) -302.035 (1.85654462e-06)
152708 EPS nconv=0 first unconverged value (error) -302.035 (2.29198522e-06)
152709 EPS nconv=0 first unconverged value (error) -302.035 (2.10025244e-06)
152710 EPS nconv=0 first unconverged value (error) -302.035 (2.01905997e-06)
152711 EPS nconv=0 first unconverged value (error) -302.035 (1.98876579e-06)
152712 EPS nconv=0 first unconverged value (error) -302.035 (1.97620089e-06)
152713 EPS nconv=0 first unconverged value (error) -302.035 (1.97620089e-06)
152714 EPS nconv=0 first unconverged value (error) -302.035 (2.03889146e-06)
152715 EPS nconv=0 first unconverged value (error) -302.035 (2.12065095e-06)
152716 EPS nconv=0 first unconverged value (error) -302.035 (1.91787329e-06)
152717 EPS nconv=0 first unconverged value (error) -302.035 (1.86143812e-06)
152718 EPS nconv=0 first unconverged value (error) -302.035 (1.84003958e-06)
152719 EPS nconv=0 first unconverged value (error) -302.035 (1.84003958e-06)
152720 EPS nconv=0 first unconverged value (error) -302.035 (1.93243894e-06)
152721 EPS nconv=0 first unconverged value (error) -302.035 (1.92522753e-06)
152722 EPS nconv=0 first unconverged value (error) -302.035 (1.88817952e-06)
152723 EPS nconv=0 first unconverged value (error) -302.035 (1.86741251e-06)
152724 EPS nconv=0 first unconverged value (error) -302.035 (1.85019968e-06)
152725 EPS nconv=0 first unconverged value (error) -302.035 (1.85019968e-06)
152726 EPS nconv=0 first unconverged value (error) -302.035 (1.86833421e-06)
152727 EPS nconv=0 first unconverged value (error) -302.035 (1.89561866e-06)
152728 EPS nconv=0 first unconverged value (error) -302.035 (1.84391446e-06)
152729 EPS nconv=0 first unconverged value (error) -302.035 (1.81706266e-06)
152730 EPS nconv=0 first unconverged value (error) -302.035 (1.81633326e-06)
152731 EPS nconv=0 first unconverged value (error) -302.035 (1.81633326e-06)
152732 EPS nconv=0 first unconverged value (error) -302.035 (2.24160099e-06)
152733 EPS nconv=0 first unconverged value (error) -302.035 (2.05552843e-06)
152734 EPS nconv=0 first unconverged value (error) -302.035 (2.01981709e-06)
152735 EPS nconv=0 first unconverged value (error) -302.035 (1.99658114e-06)
152736 EPS nconv=0 first unconverged value (error) -302.035 (1.95908741e-06)
152737 EPS nconv=0 first unconverged value (error) -302.035 (1.95908741e-06)
152738 EPS nconv=0 first unconverged value (error) -302.035 (2.00407841e-06)
152739 EPS nconv=0 first unconverged value (error) -302.035 (2.11608466e-06)
152740 EPS nconv=0 first unconverged value (error) -302.035 (1.92376905e-06)
152741 EPS nconv=0 first unconverged value (error) -302.035 (1.87857974e-06)
152742 EPS nconv=0 first unconverged value (error) -302.035 (1.87072016e-06)
152743 EPS nconv=0 first unconverged value (error) -302.035 (1.87072016e-06)
152744 EPS nconv=0 first unconverged value (error) -302.035 (2.03526101e-06)
152745 EPS nconv=0 first unconverged value (error) -302.035 (1.95816870e-06)
152746 EPS nconv=0 first unconverged value (error) -302.035 (1.90430779e-06)
152747 EPS nconv=0 first unconverged value (error) -302.035 (1.89246630e-06)
152748 EPS nconv=0 first unconverged value (error) -302.035 (1.87065740e-06)
152749 EPS nconv=0 first unconverged value (error) -302.035 (1.87065740e-06)
152750 EPS nconv=0 first unconverged value (error) -302.035 (1.95616156e-06)
152751 EPS nconv=0 first unconverged value (error) -302.035 (1.98079831e-06)
152752 EPS nconv=0 first unconverged value (error) -302.035 (1.89179792e-06)
152753 EPS nconv=0 first unconverged value (error) -302.035 (1.85124647e-06)
152754 EPS nconv=0 first unconverged value (error) -302.035 (1.83831909e-06)
152755 EPS nconv=0 first unconverged value (error) -302.035 (1.83831909e-06)
152756 EPS nconv=0 first unconverged value (error) -302.035 (2.33666584e-06)
152757 EPS nconv=0 first unconverged value (error) -302.035 (2.18033261e-06)
152758 EPS nconv=0 first unconverged value (error) -302.035 (2.11717218e-06)
152759 EPS nconv=0 first unconverged value (error) -302.035 (2.08269188e-06)
152760 EPS nconv=0 first unconverged value (error) -302.035 (2.01448851e-06)
152761 EPS nconv=0 first unconverged value (error) -302.035 (2.01448851e-06)
152762 EPS nconv=0 first unconverged value (error) -302.035 (2.07788359e-06)
152763 EPS nconv=0 first unconverged value (error) -302.035 (2.15896228e-06)
152764 EPS nconv=0 first unconverged value (error) -302.035 (1.96057756e-06)
152765 EPS nconv=0 first unconverged value (error) -302.035 (1.90975493e-06)
152766 EPS nconv=0 first unconverged value (error) -302.035 (1.89770469e-06)
152767 EPS nconv=0 first unconverged value (error) -302.035 (1.89770469e-06)
152768 EPS nconv=0 first unconverged value (error) -302.035 (1.89556136e-06)
152769 EPS nconv=0 first unconverged value (error) -302.035 (1.87801726e-06)
152770 EPS nconv=0 first unconverged value (error) -302.035 (1.84080586e-06)
152771 EPS nconv=0 first unconverged value (error) -302.035 (1.82669189e-06)
152772 EPS nconv=0 first unconverged value (error) -302.035 (1.81972484e-06)
152773 EPS nconv=0 first unconverged value (error) -302.035 (1.81972484e-06)
152774 EPS nconv=0 first unconverged value (error) -302.035 (1.90353765e-06)
152775 EPS nconv=0 first unconverged value (error) -302.035 (1.89084790e-06)
152776 EPS nconv=0 first unconverged value (error) -302.035 (1.85565176e-06)
152777 EPS nconv=0 first unconverged value (error) -302.035 (1.83762215e-06)
152778 EPS nconv=0 first unconverged value (error) -302.035 (1.83479673e-06)
152779 EPS nconv=0 first unconverged value (error) -302.035 (1.83479673e-06)
152780 EPS nconv=0 first unconverged value (error) -302.035 (2.01793373e-06)
152781 EPS nconv=0 first unconverged value (error) -302.035 (1.98132753e-06)
152782 EPS nconv=0 first unconverged value (error) -302.035 (1.93641254e-06)
152783 EPS nconv=0 first unconverged value (error) -302.035 (1.90003770e-06)
152784 EPS nconv=0 first unconverged value (error) -302.035 (1.87639889e-06)
152785 EPS nconv=0 first unconverged value (error) -302.035 (1.87639889e-06)
152786 EPS nconv=0 first unconverged value (error) -302.035 (2.21271670e-06)
152787 EPS nconv=0 first unconverged value (error) -302.035 (2.16362001e-06)
152788 EPS nconv=0 first unconverged value (error) -302.035 (2.06049162e-06)
152789 EPS nconv=0 first unconverged value (error) -302.035 (2.02387750e-06)
152790 EPS nconv=0 first unconverged value (error) -302.035 (1.99874194e-06)
152791 EPS nconv=0 first unconverged value (error) -302.035 (1.99874194e-06)
152792 EPS nconv=0 first unconverged value (error) -302.035 (2.00371797e-06)
152793 EPS nconv=0 first unconverged value (error) -302.035 (2.02672657e-06)
152794 EPS nconv=0 first unconverged value (error) -302.035 (1.90149247e-06)
152795 EPS nconv=0 first unconverged value (error) -302.035 (1.85786684e-06)
152796 EPS nconv=0 first unconverged value (error) -302.035 (1.84861369e-06)
152797 EPS nconv=0 first unconverged value (error) -302.035 (1.84861369e-06)
152798 EPS nconv=0 first unconverged value (error) -302.035 (1.81389029e-06)
152799 EPS nconv=0 first unconverged value (error) -302.035 (1.81613751e-06)
152800 EPS nconv=0 first unconverged value (error) -302.035 (1.80797561e-06)
152801 EPS nconv=0 first unconverged value (error) -302.035 (1.80048153e-06)
152802 EPS nconv=0 first unconverged value (error) -302.035 (1.80006400e-06)
152803 EPS nconv=0 first unconverged value (error) -302.035 (1.80006400e-06)
152804 EPS nconv=0 first unconverged value (error) -302.035 (1.98882084e-06)
152805 EPS nconv=0 first unconverged value (error) -302.035 (1.90511925e-06)
152806 EPS nconv=0 first unconverged value (error) -302.035 (1.89294057e-06)
152807 EPS nconv=0 first unconverged value (error) -302.035 (1.88135725e-06)
152808 EPS nconv=0 first unconverged value (error) -302.035 (1.86478543e-06)
152809 EPS nconv=0 first unconverged value (error) -302.035 (1.86478543e-06)
152810 EPS nconv=0 first unconverged value (error) -302.035 (1.92377341e-06)
152811 EPS nconv=0 first unconverged value (error) -302.035 (1.99457034e-06)
152812 EPS nconv=0 first unconverged value (error) -302.035 (1.88987654e-06)
152813 EPS nconv=0 first unconverged value (error) -302.035 (1.85856174e-06)
152814 EPS nconv=0 first unconverged value (error) -302.035 (1.84378780e-06)
152815 EPS nconv=0 first unconverged value (error) -302.035 (1.84378780e-06)
152816 EPS nconv=0 first unconverged value (error) -302.035 (2.17419538e-06)
152817 EPS nconv=0 first unconverged value (error) -302.035 (2.07409518e-06)
152818 EPS nconv=0 first unconverged value (error) -302.035 (2.01262349e-06)
152819 EPS nconv=0 first unconverged value (error) -302.035 (1.98496147e-06)
152820 EPS nconv=0 first unconverged value (error) -302.035 (1.95208175e-06)
152821 EPS nconv=0 first unconverged value (error) -302.035 (1.95208175e-06)
152822 EPS nconv=0 first unconverged value (error) -302.035 (1.95774888e-06)
152823 EPS nconv=0 first unconverged value (error) -302.035 (2.01038217e-06)
152824 EPS nconv=0 first unconverged value (error) -302.035 (1.90762847e-06)
152825 EPS nconv=0 first unconverged value (error) -302.035 (1.85651464e-06)
152826 EPS nconv=0 first unconverged value (error) -302.035 (1.84615483e-06)
152827 EPS nconv=0 first unconverged value (error) -302.035 (1.84615483e-06)
152828 EPS nconv=0 first unconverged value (error) -302.035 (1.99221425e-06)
152829 EPS nconv=0 first unconverged value (error) -302.035 (1.92757447e-06)
152830 EPS nconv=0 first unconverged value (error) -302.035 (1.90412619e-06)
152831 EPS nconv=0 first unconverged value (error) -302.035 (1.88429162e-06)
152832 EPS nconv=0 first unconverged value (error) -302.035 (1.86495403e-06)
152833 EPS nconv=0 first unconverged value (error) -302.035 (1.86495403e-06)
152834 EPS nconv=0 first unconverged value (error) -302.035 (1.99447128e-06)
152835 EPS nconv=0 first unconverged value (error) -302.035 (2.00671155e-06)
152836 EPS nconv=0 first unconverged value (error) -302.035 (1.91502671e-06)
152837 EPS nconv=0 first unconverged value (error) -302.035 (1.90507430e-06)
152838 EPS nconv=0 first unconverged value (error) -302.035 (1.87617108e-06)
152839 EPS nconv=0 first unconverged value (error) -302.035 (1.87617108e-06)
152840 EPS nconv=0 first unconverged value (error) -302.035 (2.50725948e-06)
152841 EPS nconv=0 first unconverged value (error) -302.035 (2.41157321e-06)
152842 EPS nconv=0 first unconverged value (error) -302.035 (2.24722966e-06)
152843 EPS nconv=0 first unconverged value (error) -302.035 (2.20851599e-06)
152844 EPS nconv=0 first unconverged value (error) -302.035 (2.11914959e-06)
152845 EPS nconv=0 first unconverged value (error) -302.035 (2.11914959e-06)
152846 EPS nconv=0 first unconverged value (error) -302.035 (2.19802595e-06)
152847 EPS nconv=0 first unconverged value (error) -302.035 (2.24383485e-06)
152848 EPS nconv=0 first unconverged value (error) -302.035 (2.11411459e-06)
152849 EPS nconv=0 first unconverged value (error) -302.035 (1.97421336e-06)
152850 EPS nconv=0 first unconverged value (error) -302.035 (1.93837865e-06)
152851 EPS nconv=0 first unconverged value (error) -302.035 (1.93837865e-06)
152852 EPS nconv=0 first unconverged value (error) -302.035 (1.98924712e-06)
152853 EPS nconv=0 first unconverged value (error) -302.035 (1.95513011e-06)
152854 EPS nconv=0 first unconverged value (error) -302.035 (1.91229499e-06)
152855 EPS nconv=0 first unconverged value (error) -302.035 (1.88361477e-06)
152856 EPS nconv=0 first unconverged value (error) -302.035 (1.86041034e-06)
152857 EPS nconv=0 first unconverged value (error) -302.035 (1.86041034e-06)
152858 EPS nconv=0 first unconverged value (error) -302.035 (1.94980187e-06)
152859 EPS nconv=0 first unconverged value (error) -302.035 (1.94994675e-06)
152860 EPS nconv=0 first unconverged value (error) -302.035 (1.87726945e-06)
152861 EPS nconv=0 first unconverged value (error) -302.035 (1.86583853e-06)
152862 EPS nconv=0 first unconverged value (error) -302.035 (1.84384498e-06)
152863 EPS nconv=0 first unconverged value (error) -302.035 (1.84384498e-06)
152864 EPS nconv=0 first unconverged value (error) -302.035 (2.19871275e-06)
152865 EPS nconv=0 first unconverged value (error) -302.035 (2.14237172e-06)
152866 EPS nconv=0 first unconverged value (error) -302.035 (2.04083662e-06)
152867 EPS nconv=0 first unconverged value (error) -302.035 (2.02341232e-06)
152868 EPS nconv=0 first unconverged value (error) -302.035 (1.97146547e-06)
152869 EPS nconv=0 first unconverged value (error) -302.035 (1.97146547e-06)
152870 EPS nconv=0 first unconverged value (error) -302.035 (1.97872984e-06)
152871 EPS nconv=0 first unconverged value (error) -302.035 (2.04213402e-06)
152872 EPS nconv=0 first unconverged value (error) -302.035 (1.95904727e-06)
152873 EPS nconv=0 first unconverged value (error) -302.035 (1.87158537e-06)
152874 EPS nconv=0 first unconverged value (error) -302.035 (1.85800235e-06)
152875 EPS nconv=0 first unconverged value (error) -302.035 (1.85800235e-06)
152876 EPS nconv=0 first unconverged value (error) -302.035 (1.83885334e-06)
152877 EPS nconv=0 first unconverged value (error) -302.035 (1.82759367e-06)
152878 EPS nconv=0 first unconverged value (error) -302.035 (1.82009635e-06)
152879 EPS nconv=0 first unconverged value (error) -302.035 (1.81322882e-06)
152880 EPS nconv=0 first unconverged value (error) -302.035 (1.81001215e-06)
152881 EPS nconv=0 first unconverged value (error) -302.035 (1.81001215e-06)
152882 EPS nconv=0 first unconverged value (error) -302.035 (1.94801245e-06)
152883 EPS nconv=0 first unconverged value (error) -302.035 (1.90206752e-06)
152884 EPS nconv=0 first unconverged value (error) -302.035 (1.87325901e-06)
152885 EPS nconv=0 first unconverged value (error) -302.035 (1.85833913e-06)
152886 EPS nconv=0 first unconverged value (error) -302.035 (1.84700282e-06)
152887 EPS nconv=0 first unconverged value (error) -302.035 (1.84700282e-06)
152888 EPS nconv=0 first unconverged value (error) -302.035 (2.26702223e-06)
152889 EPS nconv=0 first unconverged value (error) -302.035 (2.22369271e-06)
152890 EPS nconv=0 first unconverged value (error) -302.035 (2.09103549e-06)
152891 EPS nconv=0 first unconverged value (error) -302.035 (2.05304436e-06)
152892 EPS nconv=0 first unconverged value (error) -302.035 (1.99937299e-06)
152893 EPS nconv=0 first unconverged value (error) -302.035 (1.99937299e-06)
152894 EPS nconv=0 first unconverged value (error) -302.035 (1.98564686e-06)
152895 EPS nconv=0 first unconverged value (error) -302.035 (2.05980764e-06)
152896 EPS nconv=0 first unconverged value (error) -302.035 (1.96269167e-06)
152897 EPS nconv=0 first unconverged value (error) -302.035 (1.88286507e-06)
152898 EPS nconv=0 first unconverged value (error) -302.035 (1.86520751e-06)
152899 EPS nconv=0 first unconverged value (error) -302.035 (1.86520751e-06)
152900 EPS nconv=0 first unconverged value (error) -302.035 (1.80879502e-06)
152901 EPS nconv=0 first unconverged value (error) -302.035 (1.80401539e-06)
152902 EPS nconv=0 first unconverged value (error) -302.035 (1.80198620e-06)
152903 EPS nconv=0 first unconverged value (error) -302.035 (1.80060964e-06)
152904 EPS nconv=0 first unconverged value (error) -302.035 (1.79895182e-06)
152905 EPS nconv=0 first unconverged value (error) -302.035 (1.79895182e-06)
152906 EPS nconv=0 first unconverged value (error) -302.035 (1.81363891e-06)
152907 EPS nconv=0 first unconverged value (error) -302.035 (1.81042480e-06)
152908 EPS nconv=0 first unconverged value (error) -302.035 (1.80381135e-06)
152909 EPS nconv=0 first unconverged value (error) -302.035 (1.80167909e-06)
152910 EPS nconv=0 first unconverged value (error) -302.035 (1.79997732e-06)
152911 EPS nconv=0 first unconverged value (error) -302.035 (1.79997732e-06)
152912 EPS nconv=0 first unconverged value (error) -302.035 (2.24960182e-06)
152913 EPS nconv=0 first unconverged value (error) -302.035 (2.16730689e-06)
152914 EPS nconv=0 first unconverged value (error) -302.035 (2.08024805e-06)
152915 EPS nconv=0 first unconverged value (error) -302.035 (2.05824079e-06)
152916 EPS nconv=0 first unconverged value (error) -302.035 (1.99278155e-06)
152917 EPS nconv=0 first unconverged value (error) -302.035 (1.99278155e-06)
152918 EPS nconv=0 first unconverged value (error) -302.035 (2.00058440e-06)
152919 EPS nconv=0 first unconverged value (error) -302.035 (2.08193813e-06)
152920 EPS nconv=0 first unconverged value (error) -302.035 (1.98914534e-06)
152921 EPS nconv=0 first unconverged value (error) -302.035 (1.88412662e-06)
152922 EPS nconv=0 first unconverged value (error) -302.035 (1.87088114e-06)
152923 EPS nconv=0 first unconverged value (error) -302.035 (1.87088114e-06)
152924 EPS nconv=0 first unconverged value (error) -302.035 (1.80457343e-06)
152925 EPS nconv=0 first unconverged value (error) -302.035 (1.80216462e-06)
152926 EPS nconv=0 first unconverged value (error) -302.035 (1.79885241e-06)
152927 EPS nconv=0 first unconverged value (error) -302.035 (1.79750234e-06)
152928 EPS nconv=0 first unconverged value (error) -302.035 (1.79706166e-06)
152929 EPS nconv=0 first unconverged value (error) -302.035 (1.79706166e-06)
152930 EPS nconv=0 first unconverged value (error) -302.035 (1.93857453e-06)
152931 EPS nconv=0 first unconverged value (error) -302.035 (1.87356580e-06)
152932 EPS nconv=0 first unconverged value (error) -302.035 (1.85011944e-06)
152933 EPS nconv=0 first unconverged value (error) -302.035 (1.84555466e-06)
152934 EPS nconv=0 first unconverged value (error) -302.035 (1.83752781e-06)
152935 EPS nconv=0 first unconverged value (error) -302.035 (1.83752781e-06)
152936 EPS nconv=0 first unconverged value (error) -302.035 (2.04244200e-06)
152937 EPS nconv=0 first unconverged value (error) -302.035 (2.10523405e-06)
152938 EPS nconv=0 first unconverged value (error) -302.035 (1.98284650e-06)
152939 EPS nconv=0 first unconverged value (error) -302.035 (1.93922300e-06)
152940 EPS nconv=0 first unconverged value (error) -302.035 (1.91053539e-06)
152941 EPS nconv=0 first unconverged value (error) -302.035 (1.91053539e-06)
152942 EPS nconv=0 first unconverged value (error) -302.035 (1.90685587e-06)
152943 EPS nconv=0 first unconverged value (error) -302.035 (1.90407881e-06)
152944 EPS nconv=0 first unconverged value (error) -302.035 (1.89873038e-06)
152945 EPS nconv=0 first unconverged value (error) -302.035 (1.82277110e-06)
152946 EPS nconv=0 first unconverged value (error) -302.035 (1.82486897e-06)
152947 EPS nconv=0 first unconverged value (error) -302.035 (1.82486897e-06)
152948 EPS nconv=0 first unconverged value (error) -302.035 (1.79715702e-06)
152949 EPS nconv=0 first unconverged value (error) -302.035 (1.79524619e-06)
152950 EPS nconv=0 first unconverged value (error) -302.035 (1.79445458e-06)
152951 EPS nconv=0 first unconverged value (error) -302.035 (1.79420038e-06)
152952 EPS nconv=0 first unconverged value (error) -302.035 (1.79421969e-06)
152953 EPS nconv=0 first unconverged value (error) -302.035 (1.79421969e-06)
152954 EPS nconv=0 first unconverged value (error) -302.035 (1.84804426e-06)
152955 EPS nconv=0 first unconverged value (error) -302.035 (1.81892764e-06)
152956 EPS nconv=0 first unconverged value (error) -302.035 (1.81273988e-06)
152957 EPS nconv=0 first unconverged value (error) -302.035 (1.81067701e-06)
152958 EPS nconv=0 first unconverged value (error) -302.035 (1.80899222e-06)
152959 EPS nconv=0 first unconverged value (error) -302.035 (1.80899222e-06)
152960 EPS nconv=0 first unconverged value (error) -302.035 (1.91562171e-06)
152961 EPS nconv=0 first unconverged value (error) -302.035 (1.90011379e-06)
152962 EPS nconv=0 first unconverged value (error) -302.035 (1.87089060e-06)
152963 EPS nconv=0 first unconverged value (error) -302.035 (1.86673831e-06)
152964 EPS nconv=0 first unconverged value (error) -302.035 (1.86469329e-06)
152965 EPS nconv=0 first unconverged value (error) -302.035 (1.86469329e-06)
152966 EPS nconv=0 first unconverged value (error) -302.035 (1.93658684e-06)
152967 EPS nconv=0 first unconverged value (error) -302.035 (1.90407465e-06)
152968 EPS nconv=0 first unconverged value (error) -302.035 (1.86356912e-06)
152969 EPS nconv=0 first unconverged value (error) -302.035 (1.82428173e-06)
152970 EPS nconv=0 first unconverged value (error) -302.035 (1.81596302e-06)
152971 EPS nconv=0 first unconverged value (error) -302.035 (1.81596302e-06)
152972 EPS nconv=0 first unconverged value (error) -302.035 (1.81598855e-06)
152973 EPS nconv=0 first unconverged value (error) -302.035 (1.83715547e-06)
152974 EPS nconv=0 first unconverged value (error) -302.035 (1.81856248e-06)
152975 EPS nconv=0 first unconverged value (error) -302.035 (1.80140522e-06)
152976 EPS nconv=0 first unconverged value (error) -302.035 (1.79833222e-06)
152977 EPS nconv=0 first unconverged value (error) -302.035 (1.79833222e-06)
152978 EPS nconv=0 first unconverged value (error) -302.035 (1.83511599e-06)
152979 EPS nconv=0 first unconverged value (error) -302.035 (1.82077162e-06)
152980 EPS nconv=0 first unconverged value (error) -302.035 (1.81769564e-06)
152981 EPS nconv=0 first unconverged value (error) -302.035 (1.81789705e-06)
152982 EPS nconv=0 first unconverged value (error) -302.035 (1.81231279e-06)
152983 EPS nconv=0 first unconverged value (error) -302.035 (1.81231279e-06)
152984 EPS nconv=0 first unconverged value (error) -302.035 (1.82536895e-06)
152985 EPS nconv=0 first unconverged value (error) -302.035 (1.83966119e-06)
152986 EPS nconv=0 first unconverged value (error) -302.035 (1.82065814e-06)
152987 EPS nconv=0 first unconverged value (error) -302.035 (1.80648946e-06)
152988 EPS nconv=0 first unconverged value (error) -302.035 (1.80355367e-06)
152989 EPS nconv=0 first unconverged value (error) -302.035 (1.80355367e-06)
152990 EPS nconv=0 first unconverged value (error) -302.035 (1.98101838e-06)
152991 EPS nconv=0 first unconverged value (error) -302.035 (1.89499773e-06)
152992 EPS nconv=0 first unconverged value (error) -302.035 (1.86755781e-06)
152993 EPS nconv=0 first unconverged value (error) -302.035 (1.86074238e-06)
152994 EPS nconv=0 first unconverged value (error) -302.035 (1.85284312e-06)
152995 EPS nconv=0 first unconverged value (error) -302.035 (1.85284312e-06)
152996 EPS nconv=0 first unconverged value (error) -302.035 (2.06391669e-06)
152997 EPS nconv=0 first unconverged value (error) -302.035 (2.09992499e-06)
152998 EPS nconv=0 first unconverged value (error) -302.035 (1.96931098e-06)
152999 EPS nconv=0 first unconverged value (error) -302.035 (1.88870960e-06)
153000 EPS nconv=0 first unconverged value (error) -302.035 (1.87222481e-06)
153001 EPS nconv=0 first unconverged value (error) -302.035 (1.87222481e-06)
153002 EPS nconv=0 first unconverged value (error) -302.035 (2.10024092e-06)
153003 EPS nconv=0 first unconverged value (error) -302.035 (2.07180350e-06)
153004 EPS nconv=0 first unconverged value (error) -302.035 (2.00641112e-06)
153005 EPS nconv=0 first unconverged value (error) -302.035 (1.96531050e-06)
153006 EPS nconv=0 first unconverged value (error) -302.035 (1.94275101e-06)
153007 EPS nconv=0 first unconverged value (error) -302.035 (1.94275101e-06)
153008 EPS nconv=0 first unconverged value (error) -302.035 (1.98852632e-06)
153009 EPS nconv=0 first unconverged value (error) -302.035 (2.00991745e-06)
153010 EPS nconv=0 first unconverged value (error) -302.035 (1.91717121e-06)
153011 EPS nconv=0 first unconverged value (error) -302.035 (1.85481690e-06)
153012 EPS nconv=0 first unconverged value (error) -302.035 (1.83873711e-06)
153013 EPS nconv=0 first unconverged value (error) -302.035 (1.83873711e-06)
153014 EPS nconv=0 first unconverged value (error) -302.035 (2.18568896e-06)
153015 EPS nconv=0 first unconverged value (error) -302.035 (2.03266222e-06)
153016 EPS nconv=0 first unconverged value (error) -302.035 (1.95267934e-06)
153017 EPS nconv=0 first unconverged value (error) -302.035 (1.93321853e-06)
153018 EPS nconv=0 first unconverged value (error) -302.035 (1.92263749e-06)
153019 EPS nconv=0 first unconverged value (error) -302.035 (1.92263749e-06)
153020 EPS nconv=0 first unconverged value (error) -302.035 (2.26396813e-06)
153021 EPS nconv=0 first unconverged value (error) -302.035 (2.31401095e-06)
153022 EPS nconv=0 first unconverged value (error) -302.035 (2.10390770e-06)
153023 EPS nconv=0 first unconverged value (error) -302.035 (1.97362529e-06)
153024 EPS nconv=0 first unconverged value (error) -302.035 (1.93446372e-06)
153025 EPS nconv=0 first unconverged value (error) -302.035 (1.93446372e-06)
153026 EPS nconv=0 first unconverged value (error) -302.035 (2.07154340e-06)
153027 EPS nconv=0 first unconverged value (error) -302.035 (2.11541004e-06)
153028 EPS nconv=0 first unconverged value (error) -302.035 (1.99286633e-06)
153029 EPS nconv=0 first unconverged value (error) -302.035 (1.93952806e-06)
153030 EPS nconv=0 first unconverged value (error) -302.035 (1.93534566e-06)
153031 EPS nconv=0 first unconverged value (error) -302.035 (1.93534566e-06)
153032 EPS nconv=0 first unconverged value (error) -302.035 (2.02362137e-06)
153033 EPS nconv=0 first unconverged value (error) -302.035 (1.97164910e-06)
153034 EPS nconv=0 first unconverged value (error) -302.035 (1.91493754e-06)
153035 EPS nconv=0 first unconverged value (error) -302.035 (1.87323521e-06)
153036 EPS nconv=0 first unconverged value (error) -302.035 (1.85620250e-06)
153037 EPS nconv=0 first unconverged value (error) -302.035 (1.85620250e-06)
153038 EPS nconv=0 first unconverged value (error) -302.035 (2.11035716e-06)
153039 EPS nconv=0 first unconverged value (error) -302.035 (2.03726158e-06)
153040 EPS nconv=0 first unconverged value (error) -302.035 (1.93138776e-06)
153041 EPS nconv=0 first unconverged value (error) -302.035 (1.90629375e-06)
153042 EPS nconv=0 first unconverged value (error) -302.035 (1.89581664e-06)
153043 EPS nconv=0 first unconverged value (error) -302.035 (1.89581664e-06)
153044 EPS nconv=0 first unconverged value (error) -302.035 (2.14454719e-06)
153045 EPS nconv=0 first unconverged value (error) -302.035 (2.18585037e-06)
153046 EPS nconv=0 first unconverged value (error) -302.035 (2.04182816e-06)
153047 EPS nconv=0 first unconverged value (error) -302.035 (1.95101885e-06)
153048 EPS nconv=0 first unconverged value (error) -302.035 (1.91169197e-06)
153049 EPS nconv=0 first unconverged value (error) -302.035 (1.91169197e-06)
153050 EPS nconv=0 first unconverged value (error) -302.035 (1.96639181e-06)
153051 EPS nconv=0 first unconverged value (error) -302.035 (2.00712981e-06)
153052 EPS nconv=0 first unconverged value (error) -302.035 (1.91340155e-06)
153053 EPS nconv=0 first unconverged value (error) -302.035 (1.87451349e-06)
153054 EPS nconv=0 first unconverged value (error) -302.035 (1.87130324e-06)
153055 EPS nconv=0 first unconverged value (error) -302.035 (1.87130324e-06)
153056 EPS nconv=0 first unconverged value (error) -302.035 (1.90873529e-06)
153057 EPS nconv=0 first unconverged value (error) -302.035 (1.87235484e-06)
153058 EPS nconv=0 first unconverged value (error) -302.035 (1.84772403e-06)
153059 EPS nconv=0 first unconverged value (error) -302.035 (1.83800983e-06)
153060 EPS nconv=0 first unconverged value (error) -302.035 (1.83010718e-06)
153061 EPS nconv=0 first unconverged value (error) -302.035 (1.83010718e-06)
153062 EPS nconv=0 first unconverged value (error) -302.035 (2.09672632e-06)
153063 EPS nconv=0 first unconverged value (error) -302.035 (2.01664751e-06)
153064 EPS nconv=0 first unconverged value (error) -302.035 (1.92412294e-06)
153065 EPS nconv=0 first unconverged value (error) -302.035 (1.90074807e-06)
153066 EPS nconv=0 first unconverged value (error) -302.035 (1.88628455e-06)
153067 EPS nconv=0 first unconverged value (error) -302.035 (1.88628455e-06)
153068 EPS nconv=0 first unconverged value (error) -302.035 (2.20038607e-06)
153069 EPS nconv=0 first unconverged value (error) -302.035 (2.22435254e-06)
153070 EPS nconv=0 first unconverged value (error) -302.035 (2.08632750e-06)
153071 EPS nconv=0 first unconverged value (error) -302.035 (1.99834237e-06)
153072 EPS nconv=0 first unconverged value (error) -302.035 (1.94503601e-06)
153073 EPS nconv=0 first unconverged value (error) -302.035 (1.94503601e-06)
153074 EPS nconv=0 first unconverged value (error) -302.035 (1.96549760e-06)
153075 EPS nconv=0 first unconverged value (error) -302.035 (2.02112946e-06)
153076 EPS nconv=0 first unconverged value (error) -302.035 (1.91310353e-06)
153077 EPS nconv=0 first unconverged value (error) -302.035 (1.86240248e-06)
153078 EPS nconv=0 first unconverged value (error) -302.035 (1.85734735e-06)
153079 EPS nconv=0 first unconverged value (error) -302.035 (1.85734735e-06)
153080 EPS nconv=0 first unconverged value (error) -302.035 (1.84338283e-06)
153081 EPS nconv=0 first unconverged value (error) -302.035 (1.83010400e-06)
153082 EPS nconv=0 first unconverged value (error) -302.035 (1.81828877e-06)
153083 EPS nconv=0 first unconverged value (error) -302.035 (1.81287928e-06)
153084 EPS nconv=0 first unconverged value (error) -302.035 (1.80871166e-06)
153085 EPS nconv=0 first unconverged value (error) -302.035 (1.80871166e-06)
153086 EPS nconv=0 first unconverged value (error) -302.035 (1.99327385e-06)
153087 EPS nconv=0 first unconverged value (error) -302.035 (1.93587362e-06)
153088 EPS nconv=0 first unconverged value (error) -302.035 (1.89305340e-06)
153089 EPS nconv=0 first unconverged value (error) -302.035 (1.87578758e-06)
153090 EPS nconv=0 first unconverged value (error) -302.035 (1.86297992e-06)
153091 EPS nconv=0 first unconverged value (error) -302.035 (1.86297992e-06)
153092 EPS nconv=0 first unconverged value (error) -302.035 (2.00260423e-06)
153093 EPS nconv=0 first unconverged value (error) -302.035 (2.04981557e-06)
153094 EPS nconv=0 first unconverged value (error) -302.035 (1.95538628e-06)
153095 EPS nconv=0 first unconverged value (error) -302.035 (1.89162430e-06)
153096 EPS nconv=0 first unconverged value (error) -302.035 (1.86381991e-06)
153097 EPS nconv=0 first unconverged value (error) -302.035 (1.86381991e-06)
153098 EPS nconv=0 first unconverged value (error) -302.035 (2.01619135e-06)
153099 EPS nconv=0 first unconverged value (error) -302.035 (2.01964683e-06)
153100 EPS nconv=0 first unconverged value (error) -302.035 (1.97506311e-06)
153101 EPS nconv=0 first unconverged value (error) -302.035 (1.92232760e-06)
153102 EPS nconv=0 first unconverged value (error) -302.035 (1.89439373e-06)
153103 EPS nconv=0 first unconverged value (error) -302.035 (1.89439373e-06)
153104 EPS nconv=0 first unconverged value (error) -302.035 (1.88042692e-06)
153105 EPS nconv=0 first unconverged value (error) -302.035 (1.87763941e-06)
153106 EPS nconv=0 first unconverged value (error) -302.035 (1.84006218e-06)
153107 EPS nconv=0 first unconverged value (error) -302.035 (1.82602146e-06)
153108 EPS nconv=0 first unconverged value (error) -302.035 (1.82052113e-06)
153109 EPS nconv=0 first unconverged value (error) -302.035 (1.82052113e-06)
153110 EPS nconv=0 first unconverged value (error) -302.035 (1.96488015e-06)
153111 EPS nconv=0 first unconverged value (error) -302.035 (1.90940835e-06)
153112 EPS nconv=0 first unconverged value (error) -302.035 (1.87642857e-06)
153113 EPS nconv=0 first unconverged value (error) -302.035 (1.86179778e-06)
153114 EPS nconv=0 first unconverged value (error) -302.035 (1.85118115e-06)
153115 EPS nconv=0 first unconverged value (error) -302.035 (1.85118115e-06)
153116 EPS nconv=0 first unconverged value (error) -302.035 (1.92476570e-06)
153117 EPS nconv=0 first unconverged value (error) -302.035 (2.00563473e-06)
153118 EPS nconv=0 first unconverged value (error) -302.035 (1.92481606e-06)
153119 EPS nconv=0 first unconverged value (error) -302.035 (1.86043155e-06)
153120 EPS nconv=0 first unconverged value (error) -302.035 (1.84428863e-06)
153121 EPS nconv=0 first unconverged value (error) -302.035 (1.84428863e-06)
153122 EPS nconv=0 first unconverged value (error) -302.035 (2.06620555e-06)
153123 EPS nconv=0 first unconverged value (error) -302.035 (2.02006943e-06)
153124 EPS nconv=0 first unconverged value (error) -302.035 (2.03512743e-06)
153125 EPS nconv=0 first unconverged value (error) -302.035 (1.95506315e-06)
153126 EPS nconv=0 first unconverged value (error) -302.035 (1.91815957e-06)
153127 EPS nconv=0 first unconverged value (error) -302.035 (1.91815957e-06)
153128 EPS nconv=0 first unconverged value (error) -302.035 (2.01674446e-06)
153129 EPS nconv=0 first unconverged value (error) -302.035 (1.95687735e-06)
153130 EPS nconv=0 first unconverged value (error) -302.035 (1.89616157e-06)
153131 EPS nconv=0 first unconverged value (error) -302.035 (1.89167878e-06)
153132 EPS nconv=0 first unconverged value (error) -302.035 (1.88183256e-06)
153133 EPS nconv=0 first unconverged value (error) -302.035 (1.88183256e-06)
153134 EPS nconv=0 first unconverged value (error) -302.035 (1.91830502e-06)
153135 EPS nconv=0 first unconverged value (error) -302.035 (1.90249944e-06)
153136 EPS nconv=0 first unconverged value (error) -302.035 (1.84218316e-06)
153137 EPS nconv=0 first unconverged value (error) -302.035 (1.83803709e-06)
153138 EPS nconv=0 first unconverged value (error) -302.035 (1.82417522e-06)
153139 EPS nconv=0 first unconverged value (error) -302.035 (1.82417522e-06)
153140 EPS nconv=0 first unconverged value (error) -302.035 (1.86351294e-06)
153141 EPS nconv=0 first unconverged value (error) -302.035 (1.88211730e-06)
153142 EPS nconv=0 first unconverged value (error) -302.035 (1.84560356e-06)
153143 EPS nconv=0 first unconverged value (error) -302.035 (1.82831867e-06)
153144 EPS nconv=0 first unconverged value (error) -302.035 (1.81986196e-06)
153145 EPS nconv=0 first unconverged value (error) -302.035 (1.81986196e-06)
153146 EPS nconv=0 first unconverged value (error) -302.035 (1.81691634e-06)
153147 EPS nconv=0 first unconverged value (error) -302.035 (1.82839395e-06)
153148 EPS nconv=0 first unconverged value (error) -302.035 (1.81690873e-06)
153149 EPS nconv=0 first unconverged value (error) -302.035 (1.80143018e-06)
153150 EPS nconv=0 first unconverged value (error) -302.035 (1.79780281e-06)
153151 EPS nconv=0 first unconverged value (error) -302.035 (1.79780281e-06)
153152 EPS nconv=0 first unconverged value (error) -302.035 (1.93549344e-06)
153153 EPS nconv=0 first unconverged value (error) -302.035 (1.89113631e-06)
153154 EPS nconv=0 first unconverged value (error) -302.035 (1.88759127e-06)
153155 EPS nconv=0 first unconverged value (error) -302.035 (1.87348060e-06)
153156 EPS nconv=0 first unconverged value (error) -302.035 (1.86009404e-06)
153157 EPS nconv=0 first unconverged value (error) -302.035 (1.86009404e-06)
153158 EPS nconv=0 first unconverged value (error) -302.035 (2.15175690e-06)
153159 EPS nconv=0 first unconverged value (error) -302.035 (2.20891540e-06)
153160 EPS nconv=0 first unconverged value (error) -302.035 (2.09883241e-06)
153161 EPS nconv=0 first unconverged value (error) -302.035 (2.01203290e-06)
153162 EPS nconv=0 first unconverged value (error) -302.035 (1.98583452e-06)
153163 EPS nconv=0 first unconverged value (error) -302.035 (1.98583452e-06)
153164 EPS nconv=0 first unconverged value (error) -302.035 (2.00436056e-06)
153165 EPS nconv=0 first unconverged value (error) -302.035 (1.94207538e-06)
153166 EPS nconv=0 first unconverged value (error) -302.035 (1.94140486e-06)
153167 EPS nconv=0 first unconverged value (error) -302.035 (1.84109166e-06)
153168 EPS nconv=0 first unconverged value (error) -302.035 (1.83054334e-06)
153169 EPS nconv=0 first unconverged value (error) -302.035 (1.83054334e-06)
153170 EPS nconv=0 first unconverged value (error) -302.035 (1.93042549e-06)
153171 EPS nconv=0 first unconverged value (error) -302.035 (1.88508638e-06)
153172 EPS nconv=0 first unconverged value (error) -302.035 (1.87214211e-06)
153173 EPS nconv=0 first unconverged value (error) -302.035 (1.85380380e-06)
153174 EPS nconv=0 first unconverged value (error) -302.035 (1.84537943e-06)
153175 EPS nconv=0 first unconverged value (error) -302.035 (1.84537943e-06)
153176 EPS nconv=0 first unconverged value (error) -302.035 (1.84379017e-06)
153177 EPS nconv=0 first unconverged value (error) -302.035 (1.88557740e-06)
153178 EPS nconv=0 first unconverged value (error) -302.035 (1.82679771e-06)
153179 EPS nconv=0 first unconverged value (error) -302.035 (1.81452189e-06)
153180 EPS nconv=0 first unconverged value (error) -302.035 (1.80390612e-06)
153181 EPS nconv=0 first unconverged value (error) -302.035 (1.80390612e-06)
153182 EPS nconv=0 first unconverged value (error) -302.035 (2.24322553e-06)
153183 EPS nconv=0 first unconverged value (error) -302.035 (2.16815530e-06)
153184 EPS nconv=0 first unconverged value (error) -302.035 (2.08663861e-06)
153185 EPS nconv=0 first unconverged value (error) -302.035 (2.07265359e-06)
153186 EPS nconv=0 first unconverged value (error) -302.035 (2.01550016e-06)
153187 EPS nconv=0 first unconverged value (error) -302.035 (2.01550016e-06)
153188 EPS nconv=0 first unconverged value (error) -302.035 (2.01288625e-06)
153189 EPS nconv=0 first unconverged value (error) -302.035 (2.06149070e-06)
153190 EPS nconv=0 first unconverged value (error) -302.035 (2.00549513e-06)
153191 EPS nconv=0 first unconverged value (error) -302.035 (1.83746257e-06)
153192 EPS nconv=0 first unconverged value (error) -302.035 (1.81916726e-06)
153193 EPS nconv=0 first unconverged value (error) -302.035 (1.81916726e-06)
153194 EPS nconv=0 first unconverged value (error) -302.035 (2.07002737e-06)
153195 EPS nconv=0 first unconverged value (error) -302.035 (1.97854932e-06)
153196 EPS nconv=0 first unconverged value (error) -302.035 (1.98277800e-06)
153197 EPS nconv=0 first unconverged value (error) -302.035 (1.95019370e-06)
153198 EPS nconv=0 first unconverged value (error) -302.035 (1.93670639e-06)
153199 EPS nconv=0 first unconverged value (error) -302.035 (1.93670639e-06)
153200 EPS nconv=0 first unconverged value (error) -302.035 (1.94332748e-06)
153201 EPS nconv=0 first unconverged value (error) -302.035 (1.95133297e-06)
153202 EPS nconv=0 first unconverged value (error) -302.035 (1.86054586e-06)
153203 EPS nconv=0 first unconverged value (error) -302.035 (1.83124695e-06)
153204 EPS nconv=0 first unconverged value (error) -302.035 (1.81311001e-06)
153205 EPS nconv=0 first unconverged value (error) -302.035 (1.81311001e-06)
153206 EPS nconv=0 first unconverged value (error) -302.035 (1.95501405e-06)
153207 EPS nconv=0 first unconverged value (error) -302.035 (1.92075457e-06)
153208 EPS nconv=0 first unconverged value (error) -302.035 (1.88697377e-06)
153209 EPS nconv=0 first unconverged value (error) -302.035 (1.88274753e-06)
153210 EPS nconv=0 first unconverged value (error) -302.035 (1.87584317e-06)
153211 EPS nconv=0 first unconverged value (error) -302.035 (1.87584317e-06)
153212 EPS nconv=0 first unconverged value (error) -302.035 (1.91093645e-06)
153213 EPS nconv=0 first unconverged value (error) -302.035 (1.89678129e-06)
153214 EPS nconv=0 first unconverged value (error) -302.035 (1.85032707e-06)
153215 EPS nconv=0 first unconverged value (error) -302.035 (1.82825529e-06)
153216 EPS nconv=0 first unconverged value (error) -302.035 (1.82225851e-06)
153217 EPS nconv=0 first unconverged value (error) -302.035 (1.82225851e-06)
153218 EPS nconv=0 first unconverged value (error) -302.035 (2.18116441e-06)
153219 EPS nconv=0 first unconverged value (error) -302.035 (2.09953301e-06)
153220 EPS nconv=0 first unconverged value (error) -302.035 (2.03492196e-06)
153221 EPS nconv=0 first unconverged value (error) -302.035 (1.97467866e-06)
153222 EPS nconv=0 first unconverged value (error) -302.035 (1.94721343e-06)
153223 EPS nconv=0 first unconverged value (error) -302.035 (1.94721343e-06)
153224 EPS nconv=0 first unconverged value (error) -302.035 (1.94649766e-06)
153225 EPS nconv=0 first unconverged value (error) -302.035 (2.05361243e-06)
153226 EPS nconv=0 first unconverged value (error) -302.035 (1.94302115e-06)
153227 EPS nconv=0 first unconverged value (error) -302.035 (1.85748472e-06)
153228 EPS nconv=0 first unconverged value (error) -302.035 (1.82413839e-06)
153229 EPS nconv=0 first unconverged value (error) -302.035 (1.82413839e-06)
153230 EPS nconv=0 first unconverged value (error) -302.035 (1.94627411e-06)
153231 EPS nconv=0 first unconverged value (error) -302.035 (1.90936912e-06)
153232 EPS nconv=0 first unconverged value (error) -302.035 (1.90064304e-06)
153233 EPS nconv=0 first unconverged value (error) -302.035 (1.89029317e-06)
153234 EPS nconv=0 first unconverged value (error) -302.035 (1.87053900e-06)
153235 EPS nconv=0 first unconverged value (error) -302.035 (1.87053900e-06)
153236 EPS nconv=0 first unconverged value (error) -302.035 (1.87223264e-06)
153237 EPS nconv=0 first unconverged value (error) -302.035 (1.87386039e-06)
153238 EPS nconv=0 first unconverged value (error) -302.035 (1.83478532e-06)
153239 EPS nconv=0 first unconverged value (error) -302.035 (1.82235145e-06)
153240 EPS nconv=0 first unconverged value (error) -302.035 (1.81304510e-06)
153241 EPS nconv=0 first unconverged value (error) -302.035 (1.81304510e-06)
153242 EPS nconv=0 first unconverged value (error) -302.035 (2.27562995e-06)
153243 EPS nconv=0 first unconverged value (error) -302.035 (2.15347002e-06)
153244 EPS nconv=0 first unconverged value (error) -302.035 (2.06000977e-06)
153245 EPS nconv=0 first unconverged value (error) -302.035 (2.02930570e-06)
153246 EPS nconv=0 first unconverged value (error) -302.035 (1.99343579e-06)
153247 EPS nconv=0 first unconverged value (error) -302.035 (1.99343579e-06)
153248 EPS nconv=0 first unconverged value (error) -302.035 (1.99543511e-06)
153249 EPS nconv=0 first unconverged value (error) -302.035 (2.15590049e-06)
153250 EPS nconv=0 first unconverged value (error) -302.035 (2.01509152e-06)
153251 EPS nconv=0 first unconverged value (error) -302.035 (1.86740756e-06)
153252 EPS nconv=0 first unconverged value (error) -302.035 (1.84009685e-06)
153253 EPS nconv=0 first unconverged value (error) -302.035 (1.84009685e-06)
153254 EPS nconv=0 first unconverged value (error) -302.035 (2.03380757e-06)
153255 EPS nconv=0 first unconverged value (error) -302.035 (1.96068004e-06)
153256 EPS nconv=0 first unconverged value (error) -302.035 (1.94446681e-06)
153257 EPS nconv=0 first unconverged value (error) -302.035 (1.92696227e-06)
153258 EPS nconv=0 first unconverged value (error) -302.035 (1.90208816e-06)
153259 EPS nconv=0 first unconverged value (error) -302.035 (1.90208816e-06)
153260 EPS nconv=0 first unconverged value (error) -302.035 (1.94813823e-06)
153261 EPS nconv=0 first unconverged value (error) -302.035 (1.95325141e-06)
153262 EPS nconv=0 first unconverged value (error) -302.035 (1.87947361e-06)
153263 EPS nconv=0 first unconverged value (error) -302.035 (1.86517178e-06)
153264 EPS nconv=0 first unconverged value (error) -302.035 (1.85363809e-06)
153265 EPS nconv=0 first unconverged value (error) -302.035 (1.85363809e-06)
153266 EPS nconv=0 first unconverged value (error) -302.035 (2.21291414e-06)
153267 EPS nconv=0 first unconverged value (error) -302.035 (2.11365387e-06)
153268 EPS nconv=0 first unconverged value (error) -302.035 (2.01784316e-06)
153269 EPS nconv=0 first unconverged value (error) -302.035 (1.97656878e-06)
153270 EPS nconv=0 first unconverged value (error) -302.035 (1.94598871e-06)
153271 EPS nconv=0 first unconverged value (error) -302.035 (1.94598871e-06)
153272 EPS nconv=0 first unconverged value (error) -302.035 (1.95259876e-06)
153273 EPS nconv=0 first unconverged value (error) -302.035 (2.05802388e-06)
153274 EPS nconv=0 first unconverged value (error) -302.035 (1.93700659e-06)
153275 EPS nconv=0 first unconverged value (error) -302.035 (1.85087807e-06)
153276 EPS nconv=0 first unconverged value (error) -302.035 (1.83460442e-06)
153277 EPS nconv=0 first unconverged value (error) -302.035 (1.83460442e-06)
153278 EPS nconv=0 first unconverged value (error) -302.035 (1.91869938e-06)
153279 EPS nconv=0 first unconverged value (error) -302.035 (1.88379595e-06)
153280 EPS nconv=0 first unconverged value (error) -302.035 (1.87274293e-06)
153281 EPS nconv=0 first unconverged value (error) -302.035 (1.86236993e-06)
153282 EPS nconv=0 first unconverged value (error) -302.035 (1.84734232e-06)
153283 EPS nconv=0 first unconverged value (error) -302.035 (1.84734232e-06)
153284 EPS nconv=0 first unconverged value (error) -302.035 (2.26399028e-06)
153285 EPS nconv=0 first unconverged value (error) -302.035 (2.14878108e-06)
153286 EPS nconv=0 first unconverged value (error) -302.035 (2.06103059e-06)
153287 EPS nconv=0 first unconverged value (error) -302.035 (2.03599039e-06)
153288 EPS nconv=0 first unconverged value (error) -302.035 (1.99430841e-06)
153289 EPS nconv=0 first unconverged value (error) -302.035 (1.99430841e-06)
153290 EPS nconv=0 first unconverged value (error) -302.035 (2.24459286e-06)
153291 EPS nconv=0 first unconverged value (error) -302.035 (2.30531486e-06)
153292 EPS nconv=0 first unconverged value (error) -302.035 (2.10846547e-06)
153293 EPS nconv=0 first unconverged value (error) -302.035 (1.97306806e-06)
153294 EPS nconv=0 first unconverged value (error) -302.035 (1.94648856e-06)
153295 EPS nconv=0 first unconverged value (error) -302.035 (1.94648856e-06)
153296 EPS nconv=0 first unconverged value (error) -302.035 (2.02909708e-06)
153297 EPS nconv=0 first unconverged value (error) -302.035 (2.03154834e-06)
153298 EPS nconv=0 first unconverged value (error) -302.035 (1.95391134e-06)
153299 EPS nconv=0 first unconverged value (error) -302.035 (1.89203543e-06)
153300 EPS nconv=0 first unconverged value (error) -302.035 (1.87705990e-06)
153301 EPS nconv=0 first unconverged value (error) -302.035 (1.87705990e-06)
153302 EPS nconv=0 first unconverged value (error) -302.035 (1.85442450e-06)
153303 EPS nconv=0 first unconverged value (error) -302.035 (1.91408538e-06)
153304 EPS nconv=0 first unconverged value (error) -302.035 (1.84712449e-06)
153305 EPS nconv=0 first unconverged value (error) -302.035 (1.81779133e-06)
153306 EPS nconv=0 first unconverged value (error) -302.035 (1.80819002e-06)
153307 EPS nconv=0 first unconverged value (error) -302.035 (1.80819002e-06)
153308 EPS nconv=0 first unconverged value (error) -302.035 (2.55475840e-06)
153309 EPS nconv=0 first unconverged value (error) -302.035 (2.38555963e-06)
153310 EPS nconv=0 first unconverged value (error) -302.035 (2.28307083e-06)
153311 EPS nconv=0 first unconverged value (error) -302.035 (2.24501095e-06)
153312 EPS nconv=0 first unconverged value (error) -302.035 (2.15869568e-06)
153313 EPS nconv=0 first unconverged value (error) -302.035 (2.15869568e-06)
153314 EPS nconv=0 first unconverged value (error) -302.035 (2.22893279e-06)
153315 EPS nconv=0 first unconverged value (error) -302.035 (2.37528927e-06)
153316 EPS nconv=0 first unconverged value (error) -302.035 (2.21012184e-06)
153317 EPS nconv=0 first unconverged value (error) -302.035 (1.93941912e-06)
153318 EPS nconv=0 first unconverged value (error) -302.035 (1.91406771e-06)
153319 EPS nconv=0 first unconverged value (error) -302.035 (1.91406771e-06)
153320 EPS nconv=0 first unconverged value (error) -302.035 (2.13390281e-06)
153321 EPS nconv=0 first unconverged value (error) -302.035 (2.02882063e-06)
153322 EPS nconv=0 first unconverged value (error) -302.035 (1.97588135e-06)
153323 EPS nconv=0 first unconverged value (error) -302.035 (1.94192191e-06)
153324 EPS nconv=0 first unconverged value (error) -302.035 (1.92093697e-06)
153325 EPS nconv=0 first unconverged value (error) -302.035 (1.92093697e-06)
153326 EPS nconv=0 first unconverged value (error) -302.035 (1.95541855e-06)
153327 EPS nconv=0 first unconverged value (error) -302.035 (2.02708255e-06)
153328 EPS nconv=0 first unconverged value (error) -302.035 (1.90642371e-06)
153329 EPS nconv=0 first unconverged value (error) -302.035 (1.87365996e-06)
153330 EPS nconv=0 first unconverged value (error) -302.035 (1.84368325e-06)
153331 EPS nconv=0 first unconverged value (error) -302.035 (1.84368325e-06)
153332 EPS nconv=0 first unconverged value (error) -302.035 (2.45255850e-06)
153333 EPS nconv=0 first unconverged value (error) -302.035 (2.36758781e-06)
153334 EPS nconv=0 first unconverged value (error) -302.035 (2.24305008e-06)
153335 EPS nconv=0 first unconverged value (error) -302.035 (2.18812286e-06)
153336 EPS nconv=0 first unconverged value (error) -302.035 (2.11049015e-06)
153337 EPS nconv=0 first unconverged value (error) -302.035 (2.11049015e-06)
153338 EPS nconv=0 first unconverged value (error) -302.035 (2.12542601e-06)
153339 EPS nconv=0 first unconverged value (error) -302.035 (2.19368352e-06)
153340 EPS nconv=0 first unconverged value (error) -302.035 (2.07370569e-06)
153341 EPS nconv=0 first unconverged value (error) -302.035 (1.91312064e-06)
153342 EPS nconv=0 first unconverged value (error) -302.035 (1.88230267e-06)
153343 EPS nconv=0 first unconverged value (error) -302.035 (1.88230267e-06)
153344 EPS nconv=0 first unconverged value (error) -302.035 (1.97558435e-06)
153345 EPS nconv=0 first unconverged value (error) -302.035 (1.91467437e-06)
153346 EPS nconv=0 first unconverged value (error) -302.035 (1.89890076e-06)
153347 EPS nconv=0 first unconverged value (error) -302.035 (1.88245127e-06)
153348 EPS nconv=0 first unconverged value (error) -302.035 (1.86605203e-06)
153349 EPS nconv=0 first unconverged value (error) -302.035 (1.86605203e-06)
153350 EPS nconv=0 first unconverged value (error) -302.035 (1.88879764e-06)
153351 EPS nconv=0 first unconverged value (error) -302.035 (1.93723169e-06)
153352 EPS nconv=0 first unconverged value (error) -302.035 (1.86695320e-06)
153353 EPS nconv=0 first unconverged value (error) -302.035 (1.84176099e-06)
153354 EPS nconv=0 first unconverged value (error) -302.035 (1.82209066e-06)
153355 EPS nconv=0 first unconverged value (error) -302.035 (1.82209066e-06)
153356 EPS nconv=0 first unconverged value (error) -302.035 (2.73800685e-06)
153357 EPS nconv=0 first unconverged value (error) -302.035 (2.57443813e-06)
153358 EPS nconv=0 first unconverged value (error) -302.035 (2.42314690e-06)
153359 EPS nconv=0 first unconverged value (error) -302.035 (2.39006444e-06)
153360 EPS nconv=0 first unconverged value (error) -302.035 (2.27586103e-06)
153361 EPS nconv=0 first unconverged value (error) -302.035 (2.27586103e-06)
153362 EPS nconv=0 first unconverged value (error) -302.035 (2.26945597e-06)
153363 EPS nconv=0 first unconverged value (error) -302.035 (2.35941009e-06)
153364 EPS nconv=0 first unconverged value (error) -302.035 (2.18221008e-06)
153365 EPS nconv=0 first unconverged value (error) -302.035 (1.95037374e-06)
153366 EPS nconv=0 first unconverged value (error) -302.035 (1.91779092e-06)
153367 EPS nconv=0 first unconverged value (error) -302.035 (1.91779092e-06)
153368 EPS nconv=0 first unconverged value (error) -302.035 (2.04166901e-06)
153369 EPS nconv=0 first unconverged value (error) -302.035 (1.95092265e-06)
153370 EPS nconv=0 first unconverged value (error) -302.035 (1.92421289e-06)
153371 EPS nconv=0 first unconverged value (error) -302.035 (1.90448272e-06)
153372 EPS nconv=0 first unconverged value (error) -302.035 (1.88975849e-06)
153373 EPS nconv=0 first unconverged value (error) -302.035 (1.88975849e-06)
153374 EPS nconv=0 first unconverged value (error) -302.035 (1.92840917e-06)
153375 EPS nconv=0 first unconverged value (error) -302.035 (1.97021059e-06)
153376 EPS nconv=0 first unconverged value (error) -302.035 (1.86894354e-06)
153377 EPS nconv=0 first unconverged value (error) -302.035 (1.84786389e-06)
153378 EPS nconv=0 first unconverged value (error) -302.035 (1.83279443e-06)
153379 EPS nconv=0 first unconverged value (error) -302.035 (1.83279443e-06)
153380 EPS nconv=0 first unconverged value (error) -302.035 (2.82745840e-06)
153381 EPS nconv=0 first unconverged value (error) -302.035 (2.63629026e-06)
153382 EPS nconv=0 first unconverged value (error) -302.035 (2.48232861e-06)
153383 EPS nconv=0 first unconverged value (error) -302.035 (2.46039523e-06)
153384 EPS nconv=0 first unconverged value (error) -302.035 (2.37085312e-06)
153385 EPS nconv=0 first unconverged value (error) -302.035 (2.37085312e-06)
153386 EPS nconv=0 first unconverged value (error) -302.035 (2.36891826e-06)
153387 EPS nconv=0 first unconverged value (error) -302.035 (2.35865290e-06)
153388 EPS nconv=0 first unconverged value (error) -302.035 (2.13610051e-06)
153389 EPS nconv=0 first unconverged value (error) -302.035 (1.90916979e-06)
153390 EPS nconv=0 first unconverged value (error) -302.035 (1.89045955e-06)
153391 EPS nconv=0 first unconverged value (error) -302.035 (1.89045955e-06)
153392 EPS nconv=0 first unconverged value (error) -302.035 (1.93232556e-06)
153393 EPS nconv=0 first unconverged value (error) -302.035 (1.88044122e-06)
153394 EPS nconv=0 first unconverged value (error) -302.035 (1.86599592e-06)
153395 EPS nconv=0 first unconverged value (error) -302.035 (1.85485195e-06)
153396 EPS nconv=0 first unconverged value (error) -302.035 (1.84784452e-06)
153397 EPS nconv=0 first unconverged value (error) -302.035 (1.84784452e-06)
153398 EPS nconv=0 first unconverged value (error) -302.035 (1.96593273e-06)
153399 EPS nconv=0 first unconverged value (error) -302.035 (1.93129955e-06)
153400 EPS nconv=0 first unconverged value (error) -302.035 (1.87016186e-06)
153401 EPS nconv=0 first unconverged value (error) -302.035 (1.86071172e-06)
153402 EPS nconv=0 first unconverged value (error) -302.035 (1.84260107e-06)
153403 EPS nconv=0 first unconverged value (error) -302.035 (1.84260107e-06)
153404 EPS nconv=0 first unconverged value (error) -302.035 (2.70795853e-06)
153405 EPS nconv=0 first unconverged value (error) -302.035 (2.64487437e-06)
153406 EPS nconv=0 first unconverged value (error) -302.035 (2.46402384e-06)
153407 EPS nconv=0 first unconverged value (error) -302.035 (2.41593444e-06)
153408 EPS nconv=0 first unconverged value (error) -302.035 (2.32075508e-06)
153409 EPS nconv=0 first unconverged value (error) -302.035 (2.32075508e-06)
153410 EPS nconv=0 first unconverged value (error) -302.035 (2.46431936e-06)
153411 EPS nconv=0 first unconverged value (error) -302.035 (2.35380451e-06)
153412 EPS nconv=0 first unconverged value (error) -302.035 (2.17051461e-06)
153413 EPS nconv=0 first unconverged value (error) -302.035 (2.01315809e-06)
153414 EPS nconv=0 first unconverged value (error) -302.035 (1.97203380e-06)
153415 EPS nconv=0 first unconverged value (error) -302.035 (1.97203380e-06)
153416 EPS nconv=0 first unconverged value (error) -302.035 (1.99312517e-06)
153417 EPS nconv=0 first unconverged value (error) -302.035 (1.96539004e-06)
153418 EPS nconv=0 first unconverged value (error) -302.035 (1.92275943e-06)
153419 EPS nconv=0 first unconverged value (error) -302.035 (1.86941750e-06)
153420 EPS nconv=0 first unconverged value (error) -302.035 (1.86614891e-06)
153421 EPS nconv=0 first unconverged value (error) -302.035 (1.86614891e-06)
153422 EPS nconv=0 first unconverged value (error) -302.035 (2.02967628e-06)
153423 EPS nconv=0 first unconverged value (error) -302.035 (1.95958710e-06)
153424 EPS nconv=0 first unconverged value (error) -302.035 (1.90498007e-06)
153425 EPS nconv=0 first unconverged value (error) -302.035 (1.87867803e-06)
153426 EPS nconv=0 first unconverged value (error) -302.035 (1.84981925e-06)
153427 EPS nconv=0 first unconverged value (error) -302.035 (1.84981925e-06)
153428 EPS nconv=0 first unconverged value (error) -302.035 (2.38932934e-06)
153429 EPS nconv=0 first unconverged value (error) -302.035 (2.38695160e-06)
153430 EPS nconv=0 first unconverged value (error) -302.035 (2.24317545e-06)
153431 EPS nconv=0 first unconverged value (error) -302.035 (2.18919081e-06)
153432 EPS nconv=0 first unconverged value (error) -302.035 (2.11247121e-06)
153433 EPS nconv=0 first unconverged value (error) -302.035 (2.11247121e-06)
153434 EPS nconv=0 first unconverged value (error) -302.035 (2.29611403e-06)
153435 EPS nconv=0 first unconverged value (error) -302.035 (2.21332816e-06)
153436 EPS nconv=0 first unconverged value (error) -302.035 (2.08466334e-06)
153437 EPS nconv=0 first unconverged value (error) -302.035 (2.00701366e-06)
153438 EPS nconv=0 first unconverged value (error) -302.035 (1.97242755e-06)
153439 EPS nconv=0 first unconverged value (error) -302.035 (1.97242755e-06)
153440 EPS nconv=0 first unconverged value (error) -302.035 (2.11133265e-06)
153441 EPS nconv=0 first unconverged value (error) -302.035 (2.05442862e-06)
153442 EPS nconv=0 first unconverged value (error) -302.035 (1.98283762e-06)
153443 EPS nconv=0 first unconverged value (error) -302.035 (1.92255963e-06)
153444 EPS nconv=0 first unconverged value (error) -302.035 (1.90557074e-06)
153445 EPS nconv=0 first unconverged value (error) -302.035 (1.90557074e-06)
153446 EPS nconv=0 first unconverged value (error) -302.035 (2.00843829e-06)
153447 EPS nconv=0 first unconverged value (error) -302.035 (2.00358495e-06)
153448 EPS nconv=0 first unconverged value (error) -302.035 (1.91572047e-06)
153449 EPS nconv=0 first unconverged value (error) -302.035 (1.86950837e-06)
153450 EPS nconv=0 first unconverged value (error) -302.035 (1.84104089e-06)
153451 EPS nconv=0 first unconverged value (error) -302.035 (1.84104089e-06)
153452 EPS nconv=0 first unconverged value (error) -302.035 (2.18664887e-06)
153453 EPS nconv=0 first unconverged value (error) -302.035 (2.14305529e-06)
153454 EPS nconv=0 first unconverged value (error) -302.035 (2.06691670e-06)
153455 EPS nconv=0 first unconverged value (error) -302.035 (2.02322391e-06)
153456 EPS nconv=0 first unconverged value (error) -302.035 (1.97966270e-06)
153457 EPS nconv=0 first unconverged value (error) -302.035 (1.97966270e-06)
153458 EPS nconv=0 first unconverged value (error) -302.035 (2.02794346e-06)
153459 EPS nconv=0 first unconverged value (error) -302.035 (2.02493129e-06)
153460 EPS nconv=0 first unconverged value (error) -302.035 (1.92401898e-06)
153461 EPS nconv=0 first unconverged value (error) -302.035 (1.87502259e-06)
153462 EPS nconv=0 first unconverged value (error) -302.035 (1.85982493e-06)
153463 EPS nconv=0 first unconverged value (error) -302.035 (1.85982493e-06)
153464 EPS nconv=0 first unconverged value (error) -302.035 (2.21118762e-06)
153465 EPS nconv=0 first unconverged value (error) -302.035 (2.09798403e-06)
153466 EPS nconv=0 first unconverged value (error) -302.035 (2.03310923e-06)
153467 EPS nconv=0 first unconverged value (error) -302.035 (1.99447698e-06)
153468 EPS nconv=0 first unconverged value (error) -302.035 (1.96823061e-06)
153469 EPS nconv=0 first unconverged value (error) -302.035 (1.96823061e-06)
153470 EPS nconv=0 first unconverged value (error) -302.035 (2.14063214e-06)
153471 EPS nconv=0 first unconverged value (error) -302.035 (2.13228842e-06)
153472 EPS nconv=0 first unconverged value (error) -302.035 (1.99565247e-06)
153473 EPS nconv=0 first unconverged value (error) -302.035 (1.94601028e-06)
153474 EPS nconv=0 first unconverged value (error) -302.035 (1.89309806e-06)
153475 EPS nconv=0 first unconverged value (error) -302.035 (1.89309806e-06)
153476 EPS nconv=0 first unconverged value (error) -302.035 (2.11651364e-06)
153477 EPS nconv=0 first unconverged value (error) -302.035 (2.12719898e-06)
153478 EPS nconv=0 first unconverged value (error) -302.035 (2.02936595e-06)
153479 EPS nconv=0 first unconverged value (error) -302.035 (1.98725918e-06)
153480 EPS nconv=0 first unconverged value (error) -302.035 (1.93243210e-06)
153481 EPS nconv=0 first unconverged value (error) -302.035 (1.93243210e-06)
153482 EPS nconv=0 first unconverged value (error) -302.035 (1.94353992e-06)
153483 EPS nconv=0 first unconverged value (error) -302.035 (1.96020979e-06)
153484 EPS nconv=0 first unconverged value (error) -302.035 (1.89883436e-06)
153485 EPS nconv=0 first unconverged value (error) -302.035 (1.85970259e-06)
153486 EPS nconv=0 first unconverged value (error) -302.035 (1.83978124e-06)
153487 EPS nconv=0 first unconverged value (error) -302.035 (1.83978124e-06)
153488 EPS nconv=0 first unconverged value (error) -302.035 (1.97768555e-06)
153489 EPS nconv=0 first unconverged value (error) -302.035 (1.93772569e-06)
153490 EPS nconv=0 first unconverged value (error) -302.035 (1.90472485e-06)
153491 EPS nconv=0 first unconverged value (error) -302.035 (1.88381582e-06)
153492 EPS nconv=0 first unconverged value (error) -302.035 (1.86679756e-06)
153493 EPS nconv=0 first unconverged value (error) -302.035 (1.86679756e-06)
153494 EPS nconv=0 first unconverged value (error) -302.035 (2.68932468e-06)
153495 EPS nconv=0 first unconverged value (error) -302.035 (2.43113999e-06)
153496 EPS nconv=0 first unconverged value (error) -302.035 (2.29490383e-06)
153497 EPS nconv=0 first unconverged value (error) -302.035 (2.22192401e-06)
153498 EPS nconv=0 first unconverged value (error) -302.035 (2.12837573e-06)
153499 EPS nconv=0 first unconverged value (error) -302.035 (2.12837573e-06)
153500 EPS nconv=0 first unconverged value (error) -302.035 (2.11130925e-06)
153501 EPS nconv=0 first unconverged value (error) -302.035 (2.41856308e-06)
153502 EPS nconv=0 first unconverged value (error) -302.035 (2.06342339e-06)
153503 EPS nconv=0 first unconverged value (error) -302.035 (1.92385753e-06)
153504 EPS nconv=0 first unconverged value (error) -302.035 (1.87975730e-06)
153505 EPS nconv=0 first unconverged value (error) -302.035 (1.87975730e-06)
153506 EPS nconv=0 first unconverged value (error) -302.035 (1.99437978e-06)
153507 EPS nconv=0 first unconverged value (error) -302.035 (1.93252845e-06)
153508 EPS nconv=0 first unconverged value (error) -302.035 (1.91022625e-06)
153509 EPS nconv=0 first unconverged value (error) -302.035 (1.90544032e-06)
153510 EPS nconv=0 first unconverged value (error) -302.035 (1.88046364e-06)
153511 EPS nconv=0 first unconverged value (error) -302.035 (1.88046364e-06)
153512 EPS nconv=0 first unconverged value (error) -302.035 (1.93641795e-06)
153513 EPS nconv=0 first unconverged value (error) -302.035 (1.94291194e-06)
153514 EPS nconv=0 first unconverged value (error) -302.035 (1.87229279e-06)
153515 EPS nconv=0 first unconverged value (error) -302.035 (1.85832054e-06)
153516 EPS nconv=0 first unconverged value (error) -302.035 (1.84905814e-06)
153517 EPS nconv=0 first unconverged value (error) -302.035 (1.84905814e-06)
153518 EPS nconv=0 first unconverged value (error) -302.035 (2.64742567e-06)
153519 EPS nconv=0 first unconverged value (error) -302.035 (2.40379661e-06)
153520 EPS nconv=0 first unconverged value (error) -302.035 (2.25957206e-06)
153521 EPS nconv=0 first unconverged value (error) -302.035 (2.20192787e-06)
153522 EPS nconv=0 first unconverged value (error) -302.035 (2.13251744e-06)
153523 EPS nconv=0 first unconverged value (error) -302.035 (2.13251744e-06)
153524 EPS nconv=0 first unconverged value (error) -302.035 (2.17649759e-06)
153525 EPS nconv=0 first unconverged value (error) -302.035 (2.40255276e-06)
153526 EPS nconv=0 first unconverged value (error) -302.035 (2.09684369e-06)
153527 EPS nconv=0 first unconverged value (error) -302.035 (1.95697198e-06)
153528 EPS nconv=0 first unconverged value (error) -302.035 (1.90191037e-06)
153529 EPS nconv=0 first unconverged value (error) -302.035 (1.90191037e-06)
153530 EPS nconv=0 first unconverged value (error) -302.035 (1.94760428e-06)
153531 EPS nconv=0 first unconverged value (error) -302.035 (1.90113173e-06)
153532 EPS nconv=0 first unconverged value (error) -302.035 (1.88004221e-06)
153533 EPS nconv=0 first unconverged value (error) -302.035 (1.87359905e-06)
153534 EPS nconv=0 first unconverged value (error) -302.035 (1.85480511e-06)
153535 EPS nconv=0 first unconverged value (error) -302.035 (1.85480511e-06)
153536 EPS nconv=0 first unconverged value (error) -302.035 (1.85219182e-06)
153537 EPS nconv=0 first unconverged value (error) -302.035 (1.87796926e-06)
153538 EPS nconv=0 first unconverged value (error) -302.035 (1.82806858e-06)
153539 EPS nconv=0 first unconverged value (error) -302.035 (1.81513847e-06)
153540 EPS nconv=0 first unconverged value (error) -302.035 (1.81035263e-06)
153541 EPS nconv=0 first unconverged value (error) -302.035 (1.81035263e-06)
153542 EPS nconv=0 first unconverged value (error) -302.035 (2.64623629e-06)
153543 EPS nconv=0 first unconverged value (error) -302.035 (2.36212931e-06)
153544 EPS nconv=0 first unconverged value (error) -302.035 (2.22951830e-06)
153545 EPS nconv=0 first unconverged value (error) -302.035 (2.20542195e-06)
153546 EPS nconv=0 first unconverged value (error) -302.035 (2.13012260e-06)
153547 EPS nconv=0 first unconverged value (error) -302.035 (2.13012260e-06)
153548 EPS nconv=0 first unconverged value (error) -302.035 (2.12831269e-06)
153549 EPS nconv=0 first unconverged value (error) -302.035 (2.39060464e-06)
153550 EPS nconv=0 first unconverged value (error) -302.035 (2.06859711e-06)
153551 EPS nconv=0 first unconverged value (error) -302.035 (1.91160606e-06)
153552 EPS nconv=0 first unconverged value (error) -302.035 (1.88365872e-06)
153553 EPS nconv=0 first unconverged value (error) -302.035 (1.88365872e-06)
153554 EPS nconv=0 first unconverged value (error) -302.035 (1.93276706e-06)
153555 EPS nconv=0 first unconverged value (error) -302.035 (1.88557610e-06)
153556 EPS nconv=0 first unconverged value (error) -302.035 (1.87163885e-06)
153557 EPS nconv=0 first unconverged value (error) -302.035 (1.86713095e-06)
153558 EPS nconv=0 first unconverged value (error) -302.035 (1.85200890e-06)
153559 EPS nconv=0 first unconverged value (error) -302.035 (1.85200890e-06)
153560 EPS nconv=0 first unconverged value (error) -302.035 (2.25802289e-06)
153561 EPS nconv=0 first unconverged value (error) -302.035 (2.20038493e-06)
153562 EPS nconv=0 first unconverged value (error) -302.035 (2.14840475e-06)
153563 EPS nconv=0 first unconverged value (error) -302.035 (2.13951234e-06)
153564 EPS nconv=0 first unconverged value (error) -302.035 (2.13350597e-06)
153565 EPS nconv=0 first unconverged value (error) -302.035 (2.13350597e-06)
153566 EPS nconv=0 first unconverged value (error) -302.035 (2.23611106e-06)
153567 EPS nconv=0 first unconverged value (error) -302.035 (1.97419807e-06)
153568 EPS nconv=0 first unconverged value (error) -302.035 (1.90445205e-06)
153569 EPS nconv=0 first unconverged value (error) -302.035 (1.87261146e-06)
153570 EPS nconv=0 first unconverged value (error) -302.035 (1.85518011e-06)
153571 EPS nconv=0 first unconverged value (error) -302.035 (1.85518011e-06)
153572 EPS nconv=0 first unconverged value (error) -302.035 (2.01462593e-06)
153573 EPS nconv=0 first unconverged value (error) -302.035 (2.00389886e-06)
153574 EPS nconv=0 first unconverged value (error) -302.035 (1.90688079e-06)
153575 EPS nconv=0 first unconverged value (error) -302.035 (1.88035568e-06)
153576 EPS nconv=0 first unconverged value (error) -302.035 (1.87673286e-06)
153577 EPS nconv=0 first unconverged value (error) -302.035 (1.87673286e-06)
153578 EPS nconv=0 first unconverged value (error) -302.035 (1.94601214e-06)
153579 EPS nconv=0 first unconverged value (error) -302.035 (1.96411374e-06)
153580 EPS nconv=0 first unconverged value (error) -302.035 (1.90264047e-06)
153581 EPS nconv=0 first unconverged value (error) -302.035 (1.84914635e-06)
153582 EPS nconv=0 first unconverged value (error) -302.035 (1.83070673e-06)
153583 EPS nconv=0 first unconverged value (error) -302.035 (1.83070673e-06)
153584 EPS nconv=0 first unconverged value (error) -302.035 (2.09714257e-06)
153585 EPS nconv=0 first unconverged value (error) -302.035 (2.07042043e-06)
153586 EPS nconv=0 first unconverged value (error) -302.035 (1.99653952e-06)
153587 EPS nconv=0 first unconverged value (error) -302.035 (1.96687207e-06)
153588 EPS nconv=0 first unconverged value (error) -302.035 (1.93139891e-06)
153589 EPS nconv=0 first unconverged value (error) -302.035 (1.93139891e-06)
153590 EPS nconv=0 first unconverged value (error) -302.035 (2.28060202e-06)
153591 EPS nconv=0 first unconverged value (error) -302.035 (2.33202989e-06)
153592 EPS nconv=0 first unconverged value (error) -302.035 (2.21002800e-06)
153593 EPS nconv=0 first unconverged value (error) -302.035 (2.07645157e-06)
153594 EPS nconv=0 first unconverged value (error) -302.035 (2.01242191e-06)
153595 EPS nconv=0 first unconverged value (error) -302.035 (2.01242191e-06)
153596 EPS nconv=0 first unconverged value (error) -302.035 (2.01268225e-06)
153597 EPS nconv=0 first unconverged value (error) -302.035 (1.97768263e-06)
153598 EPS nconv=0 first unconverged value (error) -302.035 (1.92564150e-06)
153599 EPS nconv=0 first unconverged value (error) -302.035 (1.85802307e-06)
153600 EPS nconv=0 first unconverged value (error) -302.035 (1.85329175e-06)
153601 EPS nconv=0 first unconverged value (error) -302.035 (1.85329175e-06)
153602 EPS nconv=0 first unconverged value (error) -302.035 (1.80890325e-06)
153603 EPS nconv=0 first unconverged value (error) -302.035 (1.80871049e-06)
153604 EPS nconv=0 first unconverged value (error) -302.035 (1.79962786e-06)
153605 EPS nconv=0 first unconverged value (error) -302.035 (1.79738498e-06)
153606 EPS nconv=0 first unconverged value (error) -302.035 (1.79575977e-06)
153607 EPS nconv=0 first unconverged value (error) -302.035 (1.79575977e-06)
153608 EPS nconv=0 first unconverged value (error) -302.035 (2.00105240e-06)
153609 EPS nconv=0 first unconverged value (error) -302.035 (1.94763519e-06)
153610 EPS nconv=0 first unconverged value (error) -302.035 (1.91415024e-06)
153611 EPS nconv=0 first unconverged value (error) -302.035 (1.90232670e-06)
153612 EPS nconv=0 first unconverged value (error) -302.035 (1.88949681e-06)
153613 EPS nconv=0 first unconverged value (error) -302.035 (1.88949681e-06)
153614 EPS nconv=0 first unconverged value (error) -302.035 (2.04291020e-06)
153615 EPS nconv=0 first unconverged value (error) -302.035 (1.99026276e-06)
153616 EPS nconv=0 first unconverged value (error) -302.035 (1.90531495e-06)
153617 EPS nconv=0 first unconverged value (error) -302.035 (1.89638768e-06)
153618 EPS nconv=0 first unconverged value (error) -302.035 (1.88431609e-06)
153619 EPS nconv=0 first unconverged value (error) -302.035 (1.88431609e-06)
153620 EPS nconv=0 first unconverged value (error) -302.035 (1.90582319e-06)
153621 EPS nconv=0 first unconverged value (error) -302.035 (1.93291785e-06)
153622 EPS nconv=0 first unconverged value (error) -302.035 (1.88224036e-06)
153623 EPS nconv=0 first unconverged value (error) -302.035 (1.83414117e-06)
153624 EPS nconv=0 first unconverged value (error) -302.035 (1.81946913e-06)
153625 EPS nconv=0 first unconverged value (error) -302.035 (1.81946913e-06)
153626 EPS nconv=0 first unconverged value (error) -302.035 (1.90341631e-06)
153627 EPS nconv=0 first unconverged value (error) -302.035 (1.88775916e-06)
153628 EPS nconv=0 first unconverged value (error) -302.035 (1.87255363e-06)
153629 EPS nconv=0 first unconverged value (error) -302.035 (1.84441473e-06)
153630 EPS nconv=0 first unconverged value (error) -302.035 (1.83798255e-06)
153631 EPS nconv=0 first unconverged value (error) -302.035 (1.83798255e-06)
153632 EPS nconv=0 first unconverged value (error) -302.035 (1.99634925e-06)
153633 EPS nconv=0 first unconverged value (error) -302.035 (1.97813068e-06)
153634 EPS nconv=0 first unconverged value (error) -302.035 (1.95963249e-06)
153635 EPS nconv=0 first unconverged value (error) -302.035 (1.88624232e-06)
153636 EPS nconv=0 first unconverged value (error) -302.035 (1.87621445e-06)
153637 EPS nconv=0 first unconverged value (error) -302.035 (1.87621445e-06)
153638 EPS nconv=0 first unconverged value (error) -302.035 (1.92163291e-06)
153639 EPS nconv=0 first unconverged value (error) -302.035 (1.94769150e-06)
153640 EPS nconv=0 first unconverged value (error) -302.035 (1.88425784e-06)
153641 EPS nconv=0 first unconverged value (error) -302.035 (1.84643037e-06)
153642 EPS nconv=0 first unconverged value (error) -302.035 (1.83825041e-06)
153643 EPS nconv=0 first unconverged value (error) -302.035 (1.83825041e-06)
153644 EPS nconv=0 first unconverged value (error) -302.035 (1.82274080e-06)
153645 EPS nconv=0 first unconverged value (error) -302.035 (1.82615108e-06)
153646 EPS nconv=0 first unconverged value (error) -302.035 (1.80811375e-06)
153647 EPS nconv=0 first unconverged value (error) -302.035 (1.80284921e-06)
153648 EPS nconv=0 first unconverged value (error) -302.035 (1.79952417e-06)
153649 EPS nconv=0 first unconverged value (error) -302.035 (1.79952417e-06)
153650 EPS nconv=0 first unconverged value (error) -302.035 (1.81431944e-06)
153651 EPS nconv=0 first unconverged value (error) -302.035 (1.80958809e-06)
153652 EPS nconv=0 first unconverged value (error) -302.035 (1.80444220e-06)
153653 EPS nconv=0 first unconverged value (error) -302.035 (1.80402755e-06)
153654 EPS nconv=0 first unconverged value (error) -302.035 (1.80216616e-06)
153655 EPS nconv=0 first unconverged value (error) -302.035 (1.80216616e-06)
153656 EPS nconv=0 first unconverged value (error) -302.035 (1.91912803e-06)
153657 EPS nconv=0 first unconverged value (error) -302.035 (1.88909887e-06)
153658 EPS nconv=0 first unconverged value (error) -302.035 (1.85953612e-06)
153659 EPS nconv=0 first unconverged value (error) -302.035 (1.84844167e-06)
153660 EPS nconv=0 first unconverged value (error) -302.035 (1.83834236e-06)
153661 EPS nconv=0 first unconverged value (error) -302.035 (1.83834236e-06)
153662 EPS nconv=0 first unconverged value (error) -302.035 (1.91887165e-06)
153663 EPS nconv=0 first unconverged value (error) -302.035 (1.90621220e-06)
153664 EPS nconv=0 first unconverged value (error) -302.035 (1.86936001e-06)
153665 EPS nconv=0 first unconverged value (error) -302.035 (1.86053237e-06)
153666 EPS nconv=0 first unconverged value (error) -302.035 (1.84892070e-06)
153667 EPS nconv=0 first unconverged value (error) -302.035 (1.84892070e-06)
153668 EPS nconv=0 first unconverged value (error) -302.035 (1.85426710e-06)
153669 EPS nconv=0 first unconverged value (error) -302.035 (1.84496251e-06)
153670 EPS nconv=0 first unconverged value (error) -302.035 (1.81615085e-06)
153671 EPS nconv=0 first unconverged value (error) -302.035 (1.80656726e-06)
153672 EPS nconv=0 first unconverged value (error) -302.035 (1.80427934e-06)
153673 EPS nconv=0 first unconverged value (error) -302.035 (1.80427934e-06)
153674 EPS nconv=0 first unconverged value (error) -302.035 (1.80916727e-06)
153675 EPS nconv=0 first unconverged value (error) -302.035 (1.80242025e-06)
153676 EPS nconv=0 first unconverged value (error) -302.035 (1.79923971e-06)
153677 EPS nconv=0 first unconverged value (error) -302.035 (1.79764439e-06)
153678 EPS nconv=0 first unconverged value (error) -302.035 (1.79684865e-06)
153679 EPS nconv=0 first unconverged value (error) -302.035 (1.79684865e-06)
153680 EPS nconv=0 first unconverged value (error) -302.035 (2.03167114e-06)
153681 EPS nconv=0 first unconverged value (error) -302.035 (1.92074054e-06)
153682 EPS nconv=0 first unconverged value (error) -302.035 (1.89765899e-06)
153683 EPS nconv=0 first unconverged value (error) -302.035 (1.88727691e-06)
153684 EPS nconv=0 first unconverged value (error) -302.035 (1.87055926e-06)
153685 EPS nconv=0 first unconverged value (error) -302.035 (1.87055926e-06)
153686 EPS nconv=0 first unconverged value (error) -302.035 (1.89962952e-06)
153687 EPS nconv=0 first unconverged value (error) -302.035 (1.95605092e-06)
153688 EPS nconv=0 first unconverged value (error) -302.035 (1.85594231e-06)
153689 EPS nconv=0 first unconverged value (error) -302.035 (1.83999919e-06)
153690 EPS nconv=0 first unconverged value (error) -302.035 (1.82952622e-06)
153691 EPS nconv=0 first unconverged value (error) -302.035 (1.82952622e-06)
153692 EPS nconv=0 first unconverged value (error) -302.035 (1.94504460e-06)
153693 EPS nconv=0 first unconverged value (error) -302.035 (1.90461363e-06)
153694 EPS nconv=0 first unconverged value (error) -302.035 (1.87304571e-06)
153695 EPS nconv=0 first unconverged value (error) -302.035 (1.85836821e-06)
153696 EPS nconv=0 first unconverged value (error) -302.035 (1.84898053e-06)
153697 EPS nconv=0 first unconverged value (error) -302.035 (1.84898053e-06)
153698 EPS nconv=0 first unconverged value (error) -302.035 (1.96280256e-06)
153699 EPS nconv=0 first unconverged value (error) -302.035 (1.93678889e-06)
153700 EPS nconv=0 first unconverged value (error) -302.035 (1.90563934e-06)
153701 EPS nconv=0 first unconverged value (error) -302.035 (1.85351800e-06)
153702 EPS nconv=0 first unconverged value (error) -302.035 (1.84216065e-06)
153703 EPS nconv=0 first unconverged value (error) -302.035 (1.84216065e-06)
153704 EPS nconv=0 first unconverged value (error) -302.035 (1.89522215e-06)
153705 EPS nconv=0 first unconverged value (error) -302.035 (1.90302797e-06)
153706 EPS nconv=0 first unconverged value (error) -302.035 (1.85834536e-06)
153707 EPS nconv=0 first unconverged value (error) -302.035 (1.84079943e-06)
153708 EPS nconv=0 first unconverged value (error) -302.035 (1.82383689e-06)
153709 EPS nconv=0 first unconverged value (error) -302.035 (1.82383689e-06)
153710 EPS nconv=0 first unconverged value (error) -302.035 (1.89178083e-06)
153711 EPS nconv=0 first unconverged value (error) -302.035 (1.87899971e-06)
153712 EPS nconv=0 first unconverged value (error) -302.035 (1.85592451e-06)
153713 EPS nconv=0 first unconverged value (error) -302.035 (1.84410833e-06)
153714 EPS nconv=0 first unconverged value (error) -302.035 (1.83507776e-06)
153715 EPS nconv=0 first unconverged value (error) -302.035 (1.83507776e-06)
153716 EPS nconv=0 first unconverged value (error) -302.035 (1.90239161e-06)
153717 EPS nconv=0 first unconverged value (error) -302.035 (1.88171551e-06)
153718 EPS nconv=0 first unconverged value (error) -302.035 (1.84775395e-06)
153719 EPS nconv=0 first unconverged value (error) -302.035 (1.84039188e-06)
153720 EPS nconv=0 first unconverged value (error) -302.035 (1.83494032e-06)
153721 EPS nconv=0 first unconverged value (error) -302.035 (1.83494032e-06)
153722 EPS nconv=0 first unconverged value (error) -302.035 (1.89252013e-06)
153723 EPS nconv=0 first unconverged value (error) -302.035 (1.88440994e-06)
153724 EPS nconv=0 first unconverged value (error) -302.035 (1.84737095e-06)
153725 EPS nconv=0 first unconverged value (error) -302.035 (1.83099306e-06)
153726 EPS nconv=0 first unconverged value (error) -302.035 (1.82004063e-06)
153727 EPS nconv=0 first unconverged value (error) -302.035 (1.82004063e-06)
153728 EPS nconv=0 first unconverged value (error) -302.035 (1.84998355e-06)
153729 EPS nconv=0 first unconverged value (error) -302.035 (1.84277136e-06)
153730 EPS nconv=0 first unconverged value (error) -302.035 (1.84012747e-06)
153731 EPS nconv=0 first unconverged value (error) -302.035 (1.82187435e-06)
153732 EPS nconv=0 first unconverged value (error) -302.035 (1.80953039e-06)
153733 EPS nconv=0 first unconverged value (error) -302.035 (1.80953039e-06)
153734 EPS nconv=0 first unconverged value (error) -302.035 (1.89049591e-06)
153735 EPS nconv=0 first unconverged value (error) -302.035 (1.86678111e-06)
153736 EPS nconv=0 first unconverged value (error) -302.035 (1.85871554e-06)
153737 EPS nconv=0 first unconverged value (error) -302.035 (1.84219359e-06)
153738 EPS nconv=0 first unconverged value (error) -302.035 (1.83701434e-06)
153739 EPS nconv=0 first unconverged value (error) -302.035 (1.83701434e-06)
153740 EPS nconv=0 first unconverged value (error) -302.035 (1.91351826e-06)
153741 EPS nconv=0 first unconverged value (error) -302.035 (1.88879538e-06)
153742 EPS nconv=0 first unconverged value (error) -302.035 (1.84254409e-06)
153743 EPS nconv=0 first unconverged value (error) -302.035 (1.84380192e-06)
153744 EPS nconv=0 first unconverged value (error) -302.035 (1.83328051e-06)
153745 EPS nconv=0 first unconverged value (error) -302.035 (1.83328051e-06)
153746 EPS nconv=0 first unconverged value (error) -302.035 (1.85817117e-06)
153747 EPS nconv=0 first unconverged value (error) -302.035 (1.88244086e-06)
153748 EPS nconv=0 first unconverged value (error) -302.035 (1.83311196e-06)
153749 EPS nconv=0 first unconverged value (error) -302.035 (1.81948067e-06)
153750 EPS nconv=0 first unconverged value (error) -302.035 (1.81294950e-06)
153751 EPS nconv=0 first unconverged value (error) -302.035 (1.81294950e-06)
153752 EPS nconv=0 first unconverged value (error) -302.035 (1.80976464e-06)
153753 EPS nconv=0 first unconverged value (error) -302.035 (1.81446695e-06)
153754 EPS nconv=0 first unconverged value (error) -302.035 (1.81174056e-06)
153755 EPS nconv=0 first unconverged value (error) -302.035 (1.79851748e-06)
153756 EPS nconv=0 first unconverged value (error) -302.035 (1.79829780e-06)
153757 EPS nconv=0 first unconverged value (error) -302.035 (1.79829780e-06)
153758 EPS nconv=0 first unconverged value (error) -302.035 (1.83549833e-06)
153759 EPS nconv=0 first unconverged value (error) -302.035 (1.81711358e-06)
153760 EPS nconv=0 first unconverged value (error) -302.035 (1.81785090e-06)
153761 EPS nconv=0 first unconverged value (error) -302.035 (1.81354353e-06)
153762 EPS nconv=0 first unconverged value (error) -302.035 (1.81000380e-06)
153763 EPS nconv=0 first unconverged value (error) -302.035 (1.81000380e-06)
153764 EPS nconv=0 first unconverged value (error) -302.035 (1.82599709e-06)
153765 EPS nconv=0 first unconverged value (error) -302.035 (1.82974162e-06)
153766 EPS nconv=0 first unconverged value (error) -302.035 (1.80932651e-06)
153767 EPS nconv=0 first unconverged value (error) -302.035 (1.80954570e-06)
153768 EPS nconv=0 first unconverged value (error) -302.035 (1.80725108e-06)
153769 EPS nconv=0 first unconverged value (error) -302.035 (1.80725108e-06)
153770 EPS nconv=0 first unconverged value (error) -302.035 (1.80423691e-06)
153771 EPS nconv=0 first unconverged value (error) -302.035 (1.80371752e-06)
153772 EPS nconv=0 first unconverged value (error) -302.035 (1.79946256e-06)
153773 EPS nconv=0 first unconverged value (error) -302.035 (1.79654359e-06)
153774 EPS nconv=0 first unconverged value (error) -302.035 (1.79577944e-06)
153775 EPS nconv=0 first unconverged value (error) -302.035 (1.79577944e-06)
153776 EPS nconv=0 first unconverged value (error) -302.035 (1.85080122e-06)
153777 EPS nconv=0 first unconverged value (error) -302.035 (1.82969507e-06)
153778 EPS nconv=0 first unconverged value (error) -302.035 (1.82226283e-06)
153779 EPS nconv=0 first unconverged value (error) -302.035 (1.81642470e-06)
153780 EPS nconv=0 first unconverged value (error) -302.035 (1.81323703e-06)
153781 EPS nconv=0 first unconverged value (error) -302.035 (1.81323703e-06)
153782 EPS nconv=0 first unconverged value (error) -302.035 (1.81886234e-06)
153783 EPS nconv=0 first unconverged value (error) -302.035 (1.83458507e-06)
153784 EPS nconv=0 first unconverged value (error) -302.035 (1.81346252e-06)
153785 EPS nconv=0 first unconverged value (error) -302.035 (1.80370033e-06)
153786 EPS nconv=0 first unconverged value (error) -302.035 (1.80180575e-06)
153787 EPS nconv=0 first unconverged value (error) -302.035 (1.80180575e-06)
153788 EPS nconv=0 first unconverged value (error) -302.035 (1.80217822e-06)
153789 EPS nconv=0 first unconverged value (error) -302.035 (1.79952185e-06)
153790 EPS nconv=0 first unconverged value (error) -302.035 (1.79728151e-06)
153791 EPS nconv=0 first unconverged value (error) -302.035 (1.79666772e-06)
153792 EPS nconv=0 first unconverged value (error) -302.035 (1.79545401e-06)
153793 EPS nconv=0 first unconverged value (error) -302.035 (1.79545401e-06)
153794 EPS nconv=0 first unconverged value (error) -302.035 (1.81021149e-06)
153795 EPS nconv=0 first unconverged value (error) -302.035 (1.81023334e-06)
153796 EPS nconv=0 first unconverged value (error) -302.035 (1.80510690e-06)
153797 EPS nconv=0 first unconverged value (error) -302.035 (1.80179450e-06)
153798 EPS nconv=0 first unconverged value (error) -302.035 (1.80041211e-06)
153799 EPS nconv=0 first unconverged value (error) -302.035 (1.80041211e-06)
153800 EPS nconv=0 first unconverged value (error) -302.035 (1.80058829e-06)
153801 EPS nconv=0 first unconverged value (error) -302.035 (1.80268756e-06)
153802 EPS nconv=0 first unconverged value (error) -302.035 (1.80085422e-06)
153803 EPS nconv=0 first unconverged value (error) -302.035 (1.79600704e-06)
153804 EPS nconv=0 first unconverged value (error) -302.035 (1.79528059e-06)
153805 EPS nconv=0 first unconverged value (error) -302.035 (1.79528059e-06)
153806 EPS nconv=0 first unconverged value (error) -302.035 (1.79901916e-06)
153807 EPS nconv=0 first unconverged value (error) -302.035 (1.79732575e-06)
153808 EPS nconv=0 first unconverged value (error) -302.035 (1.79703339e-06)
153809 EPS nconv=0 first unconverged value (error) -302.035 (1.79653919e-06)
153810 EPS nconv=0 first unconverged value (error) -302.035 (1.79609201e-06)
153811 EPS nconv=0 first unconverged value (error) -302.035 (1.79609201e-06)
153812 EPS nconv=0 first unconverged value (error) -302.035 (1.80424689e-06)
153813 EPS nconv=0 first unconverged value (error) -302.035 (1.80129894e-06)
153814 EPS nconv=0 first unconverged value (error) -302.035 (1.79842114e-06)
153815 EPS nconv=0 first unconverged value (error) -302.035 (1.79751990e-06)
153816 EPS nconv=0 first unconverged value (error) -302.035 (1.79691632e-06)
153817 EPS nconv=0 first unconverged value (error) -302.035 (1.79691632e-06)
153818 EPS nconv=0 first unconverged value (error) -302.035 (1.81562559e-06)
153819 EPS nconv=0 first unconverged value (error) -302.035 (1.81391196e-06)
153820 EPS nconv=0 first unconverged value (error) -302.035 (1.80568206e-06)
153821 EPS nconv=0 first unconverged value (error) -302.035 (1.80312979e-06)
153822 EPS nconv=0 first unconverged value (error) -302.035 (1.80166606e-06)
153823 EPS nconv=0 first unconverged value (error) -302.035 (1.80166606e-06)
153824 EPS nconv=0 first unconverged value (error) -302.035 (1.80151880e-06)
153825 EPS nconv=0 first unconverged value (error) -302.035 (1.80709692e-06)
153826 EPS nconv=0 first unconverged value (error) -302.035 (1.80234471e-06)
153827 EPS nconv=0 first unconverged value (error) -302.035 (1.79664752e-06)
153828 EPS nconv=0 first unconverged value (error) -302.035 (1.79590441e-06)
153829 EPS nconv=0 first unconverged value (error) -302.035 (1.79590441e-06)
153830 EPS nconv=0 first unconverged value (error) -302.035 (1.80846399e-06)
153831 EPS nconv=0 first unconverged value (error) -302.035 (1.80342139e-06)
153832 EPS nconv=0 first unconverged value (error) -302.035 (1.80262943e-06)
153833 EPS nconv=0 first unconverged value (error) -302.035 (1.80134776e-06)
153834 EPS nconv=0 first unconverged value (error) -302.035 (1.79972470e-06)
153835 EPS nconv=0 first unconverged value (error) -302.035 (1.79972470e-06)
153836 EPS nconv=0 first unconverged value (error) -302.035 (1.80168725e-06)
153837 EPS nconv=0 first unconverged value (error) -302.035 (1.80375593e-06)
153838 EPS nconv=0 first unconverged value (error) -302.035 (1.79803369e-06)
153839 EPS nconv=0 first unconverged value (error) -302.035 (1.79768359e-06)
153840 EPS nconv=0 first unconverged value (error) -302.035 (1.79617337e-06)
153841 EPS nconv=0 first unconverged value (error) -302.035 (1.79617337e-06)
153842 EPS nconv=0 first unconverged value (error) -302.035 (1.82262750e-06)
153843 EPS nconv=0 first unconverged value (error) -302.035 (1.81880518e-06)
153844 EPS nconv=0 first unconverged value (error) -302.035 (1.81023645e-06)
153845 EPS nconv=0 first unconverged value (error) -302.035 (1.80822796e-06)
153846 EPS nconv=0 first unconverged value (error) -302.035 (1.80496051e-06)
153847 EPS nconv=0 first unconverged value (error) -302.035 (1.80496051e-06)
153848 EPS nconv=0 first unconverged value (error) -302.035 (1.81170013e-06)
153849 EPS nconv=0 first unconverged value (error) -302.035 (1.81944561e-06)
153850 EPS nconv=0 first unconverged value (error) -302.035 (1.81537226e-06)
153851 EPS nconv=0 first unconverged value (error) -302.035 (1.80250005e-06)
153852 EPS nconv=0 first unconverged value (error) -302.035 (1.80109016e-06)
153853 EPS nconv=0 first unconverged value (error) -302.035 (1.80109016e-06)
153854 EPS nconv=0 first unconverged value (error) -302.035 (1.83539008e-06)
153855 EPS nconv=0 first unconverged value (error) -302.035 (1.81941746e-06)
153856 EPS nconv=0 first unconverged value (error) -302.035 (1.81916761e-06)
153857 EPS nconv=0 first unconverged value (error) -302.035 (1.81460031e-06)
153858 EPS nconv=0 first unconverged value (error) -302.035 (1.81026905e-06)
153859 EPS nconv=0 first unconverged value (error) -302.035 (1.81026905e-06)
153860 EPS nconv=0 first unconverged value (error) -302.035 (1.87411419e-06)
153861 EPS nconv=0 first unconverged value (error) -302.035 (1.85221057e-06)
153862 EPS nconv=0 first unconverged value (error) -302.035 (1.83861011e-06)
153863 EPS nconv=0 first unconverged value (error) -302.035 (1.83394009e-06)
153864 EPS nconv=0 first unconverged value (error) -302.035 (1.83225491e-06)
153865 EPS nconv=0 first unconverged value (error) -302.035 (1.83225491e-06)
153866 EPS nconv=0 first unconverged value (error) -302.035 (1.85071859e-06)
153867 EPS nconv=0 first unconverged value (error) -302.035 (1.84869344e-06)
153868 EPS nconv=0 first unconverged value (error) -302.035 (1.82378628e-06)
153869 EPS nconv=0 first unconverged value (error) -302.035 (1.82504370e-06)
153870 EPS nconv=0 first unconverged value (error) -302.035 (1.80514636e-06)
153871 EPS nconv=0 first unconverged value (error) -302.035 (1.80514636e-06)
153872 EPS nconv=0 first unconverged value (error) -302.035 (1.84027471e-06)
153873 EPS nconv=0 first unconverged value (error) -302.035 (1.85099115e-06)
153874 EPS nconv=0 first unconverged value (error) -302.035 (1.82990163e-06)
153875 EPS nconv=0 first unconverged value (error) -302.035 (1.81798068e-06)
153876 EPS nconv=0 first unconverged value (error) -302.035 (1.81360950e-06)
153877 EPS nconv=0 first unconverged value (error) -302.035 (1.81360950e-06)
153878 EPS nconv=0 first unconverged value (error) -302.035 (1.85971094e-06)
153879 EPS nconv=0 first unconverged value (error) -302.035 (1.85110752e-06)
153880 EPS nconv=0 first unconverged value (error) -302.035 (1.85645565e-06)
153881 EPS nconv=0 first unconverged value (error) -302.035 (1.82584786e-06)
153882 EPS nconv=0 first unconverged value (error) -302.035 (1.81942996e-06)
153883 EPS nconv=0 first unconverged value (error) -302.035 (1.81942996e-06)
153884 EPS nconv=0 first unconverged value (error) -302.035 (1.83339828e-06)
153885 EPS nconv=0 first unconverged value (error) -302.035 (1.83249383e-06)
153886 EPS nconv=0 first unconverged value (error) -302.035 (1.81907048e-06)
153887 EPS nconv=0 first unconverged value (error) -302.035 (1.80908059e-06)
153888 EPS nconv=0 first unconverged value (error) -302.035 (1.80394779e-06)
153889 EPS nconv=0 first unconverged value (error) -302.035 (1.80394779e-06)
153890 EPS nconv=0 first unconverged value (error) -302.035 (1.84949236e-06)
153891 EPS nconv=0 first unconverged value (error) -302.035 (1.83688886e-06)
153892 EPS nconv=0 first unconverged value (error) -302.035 (1.82262548e-06)
153893 EPS nconv=0 first unconverged value (error) -302.035 (1.82046467e-06)
153894 EPS nconv=0 first unconverged value (error) -302.035 (1.81867408e-06)
153895 EPS nconv=0 first unconverged value (error) -302.035 (1.81867408e-06)
153896 EPS nconv=0 first unconverged value (error) -302.035 (1.82169505e-06)
153897 EPS nconv=0 first unconverged value (error) -302.035 (1.82764243e-06)
153898 EPS nconv=0 first unconverged value (error) -302.035 (1.81665879e-06)
153899 EPS nconv=0 first unconverged value (error) -302.035 (1.80201721e-06)
153900 EPS nconv=0 first unconverged value (error) -302.035 (1.79693163e-06)
153901 EPS nconv=0 first unconverged value (error) -302.035 (1.79693163e-06)
153902 EPS nconv=0 first unconverged value (error) -302.035 (1.79897501e-06)
153903 EPS nconv=0 first unconverged value (error) -302.035 (1.79838734e-06)
153904 EPS nconv=0 first unconverged value (error) -302.035 (1.79759670e-06)
153905 EPS nconv=0 first unconverged value (error) -302.035 (1.79673953e-06)
153906 EPS nconv=0 first unconverged value (error) -302.035 (1.79629238e-06)
153907 EPS nconv=0 first unconverged value (error) -302.035 (1.79629238e-06)
153908 EPS nconv=0 first unconverged value (error) -302.035 (1.82302434e-06)
153909 EPS nconv=0 first unconverged value (error) -302.035 (1.81501761e-06)
153910 EPS nconv=0 first unconverged value (error) -302.035 (1.80948833e-06)
153911 EPS nconv=0 first unconverged value (error) -302.035 (1.80892035e-06)
153912 EPS nconv=0 first unconverged value (error) -302.035 (1.80716813e-06)
153913 EPS nconv=0 first unconverged value (error) -302.035 (1.80716813e-06)
153914 EPS nconv=0 first unconverged value (error) -302.035 (1.87081332e-06)
153915 EPS nconv=0 first unconverged value (error) -302.035 (1.86404713e-06)
153916 EPS nconv=0 first unconverged value (error) -302.035 (1.84687941e-06)
153917 EPS nconv=0 first unconverged value (error) -302.035 (1.82171494e-06)
153918 EPS nconv=0 first unconverged value (error) -302.035 (1.81734169e-06)
153919 EPS nconv=0 first unconverged value (error) -302.035 (1.81734169e-06)
153920 EPS nconv=0 first unconverged value (error) -302.035 (1.92625235e-06)
153921 EPS nconv=0 first unconverged value (error) -302.035 (1.91863622e-06)
153922 EPS nconv=0 first unconverged value (error) -302.035 (1.89982174e-06)
153923 EPS nconv=0 first unconverged value (error) -302.035 (1.87298227e-06)
153924 EPS nconv=0 first unconverged value (error) -302.035 (1.86501445e-06)
153925 EPS nconv=0 first unconverged value (error) -302.035 (1.86501445e-06)
153926 EPS nconv=0 first unconverged value (error) -302.035 (1.87384260e-06)
153927 EPS nconv=0 first unconverged value (error) -302.035 (1.84526972e-06)
153928 EPS nconv=0 first unconverged value (error) -302.035 (1.81766186e-06)
153929 EPS nconv=0 first unconverged value (error) -302.035 (1.80911777e-06)
153930 EPS nconv=0 first unconverged value (error) -302.035 (1.80586642e-06)
153931 EPS nconv=0 first unconverged value (error) -302.035 (1.80586642e-06)
153932 EPS nconv=0 first unconverged value (error) -302.035 (2.00601717e-06)
153933 EPS nconv=0 first unconverged value (error) -302.035 (1.95007480e-06)
153934 EPS nconv=0 first unconverged value (error) -302.035 (1.90336032e-06)
153935 EPS nconv=0 first unconverged value (error) -302.035 (1.87760373e-06)
153936 EPS nconv=0 first unconverged value (error) -302.035 (1.87081260e-06)
153937 EPS nconv=0 first unconverged value (error) -302.035 (1.87081260e-06)
153938 EPS nconv=0 first unconverged value (error) -302.035 (2.07098743e-06)
153939 EPS nconv=0 first unconverged value (error) -302.035 (1.96428388e-06)
153940 EPS nconv=0 first unconverged value (error) -302.035 (1.92597691e-06)
153941 EPS nconv=0 first unconverged value (error) -302.035 (1.91836401e-06)
153942 EPS nconv=0 first unconverged value (error) -302.035 (1.89603941e-06)
153943 EPS nconv=0 first unconverged value (error) -302.035 (1.89603941e-06)
153944 EPS nconv=0 first unconverged value (error) -302.035 (1.88969060e-06)
153945 EPS nconv=0 first unconverged value (error) -302.035 (1.94666747e-06)
153946 EPS nconv=0 first unconverged value (error) -302.035 (1.82788086e-06)
153947 EPS nconv=0 first unconverged value (error) -302.035 (1.81690084e-06)
153948 EPS nconv=0 first unconverged value (error) -302.035 (1.80833154e-06)
153949 EPS nconv=0 first unconverged value (error) -302.035 (1.80833154e-06)
153950 EPS nconv=0 first unconverged value (error) -302.035 (2.09423495e-06)
153951 EPS nconv=0 first unconverged value (error) -302.035 (1.99239427e-06)
153952 EPS nconv=0 first unconverged value (error) -302.035 (1.92928614e-06)
153953 EPS nconv=0 first unconverged value (error) -302.035 (1.92000819e-06)
153954 EPS nconv=0 first unconverged value (error) -302.035 (1.90937008e-06)
153955 EPS nconv=0 first unconverged value (error) -302.035 (1.90937008e-06)
153956 EPS nconv=0 first unconverged value (error) -302.035 (2.11810612e-06)
153957 EPS nconv=0 first unconverged value (error) -302.035 (2.09908265e-06)
153958 EPS nconv=0 first unconverged value (error) -302.035 (1.98493233e-06)
153959 EPS nconv=0 first unconverged value (error) -302.035 (1.95463483e-06)
153960 EPS nconv=0 first unconverged value (error) -302.035 (1.95313856e-06)
153961 EPS nconv=0 first unconverged value (error) -302.035 (1.95313856e-06)
153962 EPS nconv=0 first unconverged value (error) -302.035 (2.18698059e-06)
153963 EPS nconv=0 first unconverged value (error) -302.035 (2.08738830e-06)
153964 EPS nconv=0 first unconverged value (error) -302.035 (1.98846045e-06)
153965 EPS nconv=0 first unconverged value (error) -302.035 (1.88505570e-06)
153966 EPS nconv=0 first unconverged value (error) -302.035 (1.87285463e-06)
153967 EPS nconv=0 first unconverged value (error) -302.035 (1.87285463e-06)
153968 EPS nconv=0 first unconverged value (error) -302.035 (1.97483630e-06)
153969 EPS nconv=0 first unconverged value (error) -302.035 (2.02492672e-06)
153970 EPS nconv=0 first unconverged value (error) -302.035 (1.89663628e-06)
153971 EPS nconv=0 first unconverged value (error) -302.035 (1.85764256e-06)
153972 EPS nconv=0 first unconverged value (error) -302.035 (1.84820450e-06)
153973 EPS nconv=0 first unconverged value (error) -302.035 (1.84820450e-06)
153974 EPS nconv=0 first unconverged value (error) -302.035 (1.87249768e-06)
153975 EPS nconv=0 first unconverged value (error) -302.035 (1.94764830e-06)
153976 EPS nconv=0 first unconverged value (error) -302.035 (1.86233128e-06)
153977 EPS nconv=0 first unconverged value (error) -302.035 (1.81915055e-06)
153978 EPS nconv=0 first unconverged value (error) -302.035 (1.81220690e-06)
153979 EPS nconv=0 first unconverged value (error) -302.035 (1.81220690e-06)
153980 EPS nconv=0 first unconverged value (error) -302.035 (1.94336550e-06)
153981 EPS nconv=0 first unconverged value (error) -302.035 (1.89841857e-06)
153982 EPS nconv=0 first unconverged value (error) -302.035 (1.87809516e-06)
153983 EPS nconv=0 first unconverged value (error) -302.035 (1.87065490e-06)
153984 EPS nconv=0 first unconverged value (error) -302.035 (1.86133074e-06)
153985 EPS nconv=0 first unconverged value (error) -302.035 (1.86133074e-06)
153986 EPS nconv=0 first unconverged value (error) -302.035 (1.86390013e-06)
153987 EPS nconv=0 first unconverged value (error) -302.035 (1.88025050e-06)
153988 EPS nconv=0 first unconverged value (error) -302.035 (1.82772754e-06)
153989 EPS nconv=0 first unconverged value (error) -302.035 (1.81836860e-06)
153990 EPS nconv=0 first unconverged value (error) -302.035 (1.80391594e-06)
153991 EPS nconv=0 first unconverged value (error) -302.035 (1.80391594e-06)
153992 EPS nconv=0 first unconverged value (error) -302.035 (1.85523163e-06)
153993 EPS nconv=0 first unconverged value (error) -302.035 (1.84024996e-06)
153994 EPS nconv=0 first unconverged value (error) -302.035 (1.83242498e-06)
153995 EPS nconv=0 first unconverged value (error) -302.035 (1.82802081e-06)
153996 EPS nconv=0 first unconverged value (error) -302.035 (1.82224820e-06)
153997 EPS nconv=0 first unconverged value (error) -302.035 (1.82224820e-06)
153998 EPS nconv=0 first unconverged value (error) -302.035 (1.93686054e-06)
153999 EPS nconv=0 first unconverged value (error) -302.035 (1.97162828e-06)
154000 EPS nconv=0 first unconverged value (error) -302.035 (1.91805171e-06)
154001 EPS nconv=0 first unconverged value (error) -302.035 (1.86994087e-06)
154002 EPS nconv=0 first unconverged value (error) -302.035 (1.85517283e-06)
154003 EPS nconv=0 first unconverged value (error) -302.035 (1.85517283e-06)
154004 EPS nconv=0 first unconverged value (error) -302.035 (1.86712852e-06)
154005 EPS nconv=0 first unconverged value (error) -302.035 (1.86150384e-06)
154006 EPS nconv=0 first unconverged value (error) -302.035 (1.85015053e-06)
154007 EPS nconv=0 first unconverged value (error) -302.035 (1.82024966e-06)
154008 EPS nconv=0 first unconverged value (error) -302.035 (1.81152411e-06)
154009 EPS nconv=0 first unconverged value (error) -302.035 (1.81152411e-06)
154010 EPS nconv=0 first unconverged value (error) -302.035 (1.84608060e-06)
154011 EPS nconv=0 first unconverged value (error) -302.035 (1.81840752e-06)
154012 EPS nconv=0 first unconverged value (error) -302.035 (1.81150089e-06)
154013 EPS nconv=0 first unconverged value (error) -302.035 (1.80969962e-06)
154014 EPS nconv=0 first unconverged value (error) -302.035 (1.80801980e-06)
154015 EPS nconv=0 first unconverged value (error) -302.035 (1.80801980e-06)
154016 EPS nconv=0 first unconverged value (error) -302.035 (1.88240356e-06)
154017 EPS nconv=0 first unconverged value (error) -302.035 (1.86706854e-06)
154018 EPS nconv=0 first unconverged value (error) -302.035 (1.83919561e-06)
154019 EPS nconv=0 first unconverged value (error) -302.035 (1.82472371e-06)
154020 EPS nconv=0 first unconverged value (error) -302.035 (1.82128579e-06)
154021 EPS nconv=0 first unconverged value (error) -302.035 (1.82128579e-06)
154022 EPS nconv=0 first unconverged value (error) -302.035 (1.82284576e-06)
154023 EPS nconv=0 first unconverged value (error) -302.035 (1.84585320e-06)
154024 EPS nconv=0 first unconverged value (error) -302.035 (1.81882847e-06)
154025 EPS nconv=0 first unconverged value (error) -302.035 (1.80554269e-06)
154026 EPS nconv=0 first unconverged value (error) -302.035 (1.80007489e-06)
154027 EPS nconv=0 first unconverged value (error) -302.035 (1.80007489e-06)
154028 EPS nconv=0 first unconverged value (error) -302.035 (1.80032487e-06)
154029 EPS nconv=0 first unconverged value (error) -302.035 (1.79964388e-06)
154030 EPS nconv=0 first unconverged value (error) -302.035 (1.79752746e-06)
154031 EPS nconv=0 first unconverged value (error) -302.035 (1.79711182e-06)
154032 EPS nconv=0 first unconverged value (error) -302.035 (1.79629496e-06)
154033 EPS nconv=0 first unconverged value (error) -302.035 (1.79629496e-06)
154034 EPS nconv=0 first unconverged value (error) -302.035 (1.82455811e-06)
154035 EPS nconv=0 first unconverged value (error) -302.035 (1.81281137e-06)
154036 EPS nconv=0 first unconverged value (error) -302.035 (1.80659052e-06)
154037 EPS nconv=0 first unconverged value (error) -302.035 (1.80509909e-06)
154038 EPS nconv=0 first unconverged value (error) -302.035 (1.80409053e-06)
154039 EPS nconv=0 first unconverged value (error) -302.035 (1.80409053e-06)
154040 EPS nconv=0 first unconverged value (error) -302.035 (1.89605792e-06)
154041 EPS nconv=0 first unconverged value (error) -302.035 (1.88004369e-06)
154042 EPS nconv=0 first unconverged value (error) -302.035 (1.84642545e-06)
154043 EPS nconv=0 first unconverged value (error) -302.035 (1.82817214e-06)
154044 EPS nconv=0 first unconverged value (error) -302.035 (1.82459378e-06)
154045 EPS nconv=0 first unconverged value (error) -302.035 (1.82459378e-06)
154046 EPS nconv=0 first unconverged value (error) -302.035 (1.83810739e-06)
154047 EPS nconv=0 first unconverged value (error) -302.035 (1.85849950e-06)
154048 EPS nconv=0 first unconverged value (error) -302.035 (1.83183396e-06)
154049 EPS nconv=0 first unconverged value (error) -302.035 (1.81004169e-06)
154050 EPS nconv=0 first unconverged value (error) -302.035 (1.80735569e-06)
154051 EPS nconv=0 first unconverged value (error) -302.035 (1.80735569e-06)
154052 EPS nconv=0 first unconverged value (error) -302.035 (1.81953963e-06)
154053 EPS nconv=0 first unconverged value (error) -302.035 (1.80965050e-06)
154054 EPS nconv=0 first unconverged value (error) -302.035 (1.80230277e-06)
154055 EPS nconv=0 first unconverged value (error) -302.035 (1.80102021e-06)
154056 EPS nconv=0 first unconverged value (error) -302.035 (1.79958726e-06)
154057 EPS nconv=0 first unconverged value (error) -302.035 (1.79958726e-06)
154058 EPS nconv=0 first unconverged value (error) -302.035 (1.82701137e-06)
154059 EPS nconv=0 first unconverged value (error) -302.035 (1.81401989e-06)
154060 EPS nconv=0 first unconverged value (error) -302.035 (1.80557905e-06)
154061 EPS nconv=0 first unconverged value (error) -302.035 (1.80430778e-06)
154062 EPS nconv=0 first unconverged value (error) -302.035 (1.80311433e-06)
154063 EPS nconv=0 first unconverged value (error) -302.035 (1.80311433e-06)
154064 EPS nconv=0 first unconverged value (error) -302.035 (1.82491422e-06)
154065 EPS nconv=0 first unconverged value (error) -302.035 (1.82501411e-06)
154066 EPS nconv=0 first unconverged value (error) -302.035 (1.80987267e-06)
154067 EPS nconv=0 first unconverged value (error) -302.035 (1.80920027e-06)
154068 EPS nconv=0 first unconverged value (error) -302.035 (1.80358054e-06)
154069 EPS nconv=0 first unconverged value (error) -302.035 (1.80358054e-06)
154070 EPS nconv=0 first unconverged value (error) -302.035 (2.09365798e-06)
154071 EPS nconv=0 first unconverged value (error) -302.035 (2.07077285e-06)
154072 EPS nconv=0 first unconverged value (error) -302.035 (1.98320597e-06)
154073 EPS nconv=0 first unconverged value (error) -302.035 (1.97801047e-06)
154074 EPS nconv=0 first unconverged value (error) -302.035 (1.96304917e-06)
154075 EPS nconv=0 first unconverged value (error) -302.035 (1.96304917e-06)
154076 EPS nconv=0 first unconverged value (error) -302.035 (2.11583609e-06)
154077 EPS nconv=0 first unconverged value (error) -302.035 (2.03351834e-06)
154078 EPS nconv=0 first unconverged value (error) -302.035 (1.96233028e-06)
154079 EPS nconv=0 first unconverged value (error) -302.035 (1.95031694e-06)
154080 EPS nconv=0 first unconverged value (error) -302.035 (1.91773445e-06)
154081 EPS nconv=0 first unconverged value (error) -302.035 (1.91773445e-06)
154082 EPS nconv=0 first unconverged value (error) -302.035 (2.04093037e-06)
154083 EPS nconv=0 first unconverged value (error) -302.035 (2.06672082e-06)
154084 EPS nconv=0 first unconverged value (error) -302.035 (1.98665227e-06)
154085 EPS nconv=0 first unconverged value (error) -302.035 (1.87582641e-06)
154086 EPS nconv=0 first unconverged value (error) -302.035 (1.85940652e-06)
154087 EPS nconv=0 first unconverged value (error) -302.035 (1.85940652e-06)
154088 EPS nconv=0 first unconverged value (error) -302.035 (1.92369436e-06)
154089 EPS nconv=0 first unconverged value (error) -302.035 (1.94662962e-06)
154090 EPS nconv=0 first unconverged value (error) -302.035 (1.89758750e-06)
154091 EPS nconv=0 first unconverged value (error) -302.035 (1.86059746e-06)
154092 EPS nconv=0 first unconverged value (error) -302.035 (1.84759197e-06)
154093 EPS nconv=0 first unconverged value (error) -302.035 (1.84759197e-06)
154094 EPS nconv=0 first unconverged value (error) -302.035 (2.10302563e-06)
154095 EPS nconv=0 first unconverged value (error) -302.035 (2.05650456e-06)
154096 EPS nconv=0 first unconverged value (error) -302.035 (1.99381335e-06)
154097 EPS nconv=0 first unconverged value (error) -302.035 (1.94237794e-06)
154098 EPS nconv=0 first unconverged value (error) -302.035 (1.91107645e-06)
154099 EPS nconv=0 first unconverged value (error) -302.035 (1.91107645e-06)
154100 EPS nconv=0 first unconverged value (error) -302.035 (1.90944652e-06)
154101 EPS nconv=0 first unconverged value (error) -302.035 (1.97412691e-06)
154102 EPS nconv=0 first unconverged value (error) -302.035 (1.86053685e-06)
154103 EPS nconv=0 first unconverged value (error) -302.035 (1.83398396e-06)
154104 EPS nconv=0 first unconverged value (error) -302.035 (1.82824783e-06)
154105 EPS nconv=0 first unconverged value (error) -302.035 (1.82824783e-06)
154106 EPS nconv=0 first unconverged value (error) -302.035 (1.90214566e-06)
154107 EPS nconv=0 first unconverged value (error) -302.035 (1.85594929e-06)
154108 EPS nconv=0 first unconverged value (error) -302.035 (1.84145285e-06)
154109 EPS nconv=0 first unconverged value (error) -302.035 (1.84003793e-06)
154110 EPS nconv=0 first unconverged value (error) -302.035 (1.83032405e-06)
154111 EPS nconv=0 first unconverged value (error) -302.035 (1.83032405e-06)
154112 EPS nconv=0 first unconverged value (error) -302.035 (2.14485481e-06)
154113 EPS nconv=0 first unconverged value (error) -302.035 (2.10531814e-06)
154114 EPS nconv=0 first unconverged value (error) -302.035 (2.00558992e-06)
154115 EPS nconv=0 first unconverged value (error) -302.035 (1.98884816e-06)
154116 EPS nconv=0 first unconverged value (error) -302.035 (1.96614671e-06)
154117 EPS nconv=0 first unconverged value (error) -302.035 (1.96614671e-06)
154118 EPS nconv=0 first unconverged value (error) -302.035 (1.95366731e-06)
154119 EPS nconv=0 first unconverged value (error) -302.035 (1.99628884e-06)
154120 EPS nconv=0 first unconverged value (error) -302.035 (1.94017598e-06)
154121 EPS nconv=0 first unconverged value (error) -302.035 (1.83667073e-06)
154122 EPS nconv=0 first unconverged value (error) -302.035 (1.82822819e-06)
154123 EPS nconv=0 first unconverged value (error) -302.035 (1.82822819e-06)
154124 EPS nconv=0 first unconverged value (error) -302.035 (2.04574986e-06)
154125 EPS nconv=0 first unconverged value (error) -302.035 (1.95423824e-06)
154126 EPS nconv=0 first unconverged value (error) -302.035 (1.93299106e-06)
154127 EPS nconv=0 first unconverged value (error) -302.035 (1.90798542e-06)
154128 EPS nconv=0 first unconverged value (error) -302.035 (1.88968886e-06)
154129 EPS nconv=0 first unconverged value (error) -302.035 (1.88968886e-06)
154130 EPS nconv=0 first unconverged value (error) -302.035 (2.39725158e-06)
154131 EPS nconv=0 first unconverged value (error) -302.035 (2.32475756e-06)
154132 EPS nconv=0 first unconverged value (error) -302.035 (2.17746287e-06)
154133 EPS nconv=0 first unconverged value (error) -302.035 (2.17777767e-06)
154134 EPS nconv=0 first unconverged value (error) -302.035 (2.14804066e-06)
154135 EPS nconv=0 first unconverged value (error) -302.035 (2.14804066e-06)
154136 EPS nconv=0 first unconverged value (error) -302.035 (2.27228096e-06)
154137 EPS nconv=0 first unconverged value (error) -302.035 (2.24683885e-06)
154138 EPS nconv=0 first unconverged value (error) -302.035 (2.12624475e-06)
154139 EPS nconv=0 first unconverged value (error) -302.035 (1.91855666e-06)
154140 EPS nconv=0 first unconverged value (error) -302.035 (1.87698881e-06)
154141 EPS nconv=0 first unconverged value (error) -302.035 (1.87698881e-06)
154142 EPS nconv=0 first unconverged value (error) -302.035 (1.88432720e-06)
154143 EPS nconv=0 first unconverged value (error) -302.035 (1.89857781e-06)
154144 EPS nconv=0 first unconverged value (error) -302.035 (1.86746919e-06)
154145 EPS nconv=0 first unconverged value (error) -302.035 (1.83161185e-06)
154146 EPS nconv=0 first unconverged value (error) -302.035 (1.82729593e-06)
154147 EPS nconv=0 first unconverged value (error) -302.035 (1.82729593e-06)
154148 EPS nconv=0 first unconverged value (error) -302.035 (1.85392669e-06)
154149 EPS nconv=0 first unconverged value (error) -302.035 (1.86441867e-06)
154150 EPS nconv=0 first unconverged value (error) -302.035 (1.85252387e-06)
154151 EPS nconv=0 first unconverged value (error) -302.035 (1.81750782e-06)
154152 EPS nconv=0 first unconverged value (error) -302.035 (1.80955747e-06)
154153 EPS nconv=0 first unconverged value (error) -302.035 (1.80955747e-06)
154154 EPS nconv=0 first unconverged value (error) -302.035 (2.18877886e-06)
154155 EPS nconv=0 first unconverged value (error) -302.035 (2.11964651e-06)
154156 EPS nconv=0 first unconverged value (error) -302.035 (2.05049912e-06)
154157 EPS nconv=0 first unconverged value (error) -302.035 (2.02588153e-06)
154158 EPS nconv=0 first unconverged value (error) -302.035 (1.99639884e-06)
154159 EPS nconv=0 first unconverged value (error) -302.035 (1.99639884e-06)
154160 EPS nconv=0 first unconverged value (error) -302.035 (2.02282411e-06)
154161 EPS nconv=0 first unconverged value (error) -302.035 (2.03310466e-06)
154162 EPS nconv=0 first unconverged value (error) -302.035 (1.95650002e-06)
154163 EPS nconv=0 first unconverged value (error) -302.035 (1.89616033e-06)
154164 EPS nconv=0 first unconverged value (error) -302.035 (1.86614746e-06)
154165 EPS nconv=0 first unconverged value (error) -302.035 (1.86614746e-06)
154166 EPS nconv=0 first unconverged value (error) -302.035 (1.86426976e-06)
154167 EPS nconv=0 first unconverged value (error) -302.035 (1.87621604e-06)
154168 EPS nconv=0 first unconverged value (error) -302.035 (1.85011646e-06)
154169 EPS nconv=0 first unconverged value (error) -302.035 (1.81812873e-06)
154170 EPS nconv=0 first unconverged value (error) -302.035 (1.81271591e-06)
154171 EPS nconv=0 first unconverged value (error) -302.035 (1.81271591e-06)
154172 EPS nconv=0 first unconverged value (error) -302.035 (1.81344603e-06)
154173 EPS nconv=0 first unconverged value (error) -302.035 (1.82187086e-06)
154174 EPS nconv=0 first unconverged value (error) -302.035 (1.81195068e-06)
154175 EPS nconv=0 first unconverged value (error) -302.035 (1.80275865e-06)
154176 EPS nconv=0 first unconverged value (error) -302.035 (1.79973680e-06)
154177 EPS nconv=0 first unconverged value (error) -302.035 (1.79973680e-06)
154178 EPS nconv=0 first unconverged value (error) -302.035 (1.86570885e-06)
154179 EPS nconv=0 first unconverged value (error) -302.035 (1.84930536e-06)
154180 EPS nconv=0 first unconverged value (error) -302.035 (1.83976102e-06)
154181 EPS nconv=0 first unconverged value (error) -302.035 (1.83128950e-06)
154182 EPS nconv=0 first unconverged value (error) -302.035 (1.82447755e-06)
154183 EPS nconv=0 first unconverged value (error) -302.035 (1.82447755e-06)
154184 EPS nconv=0 first unconverged value (error) -302.035 (1.82426838e-06)
154185 EPS nconv=0 first unconverged value (error) -302.035 (1.83559301e-06)
154186 EPS nconv=0 first unconverged value (error) -302.035 (1.81352679e-06)
154187 EPS nconv=0 first unconverged value (error) -302.035 (1.80507847e-06)
154188 EPS nconv=0 first unconverged value (error) -302.035 (1.80134077e-06)
154189 EPS nconv=0 first unconverged value (error) -302.035 (1.80134077e-06)
154190 EPS nconv=0 first unconverged value (error) -302.035 (1.80664769e-06)
154191 EPS nconv=0 first unconverged value (error) -302.035 (1.80236043e-06)
154192 EPS nconv=0 first unconverged value (error) -302.035 (1.80055292e-06)
154193 EPS nconv=0 first unconverged value (error) -302.035 (1.79994859e-06)
154194 EPS nconv=0 first unconverged value (error) -302.035 (1.79884993e-06)
154195 EPS nconv=0 first unconverged value (error) -302.035 (1.79884993e-06)
154196 EPS nconv=0 first unconverged value (error) -302.035 (2.35123471e-06)
154197 EPS nconv=0 first unconverged value (error) -302.035 (2.22871741e-06)
154198 EPS nconv=0 first unconverged value (error) -302.035 (2.16000024e-06)
154199 EPS nconv=0 first unconverged value (error) -302.035 (2.13987701e-06)
154200 EPS nconv=0 first unconverged value (error) -302.035 (2.10321353e-06)
154201 EPS nconv=0 first unconverged value (error) -302.035 (2.10321353e-06)
154202 EPS nconv=0 first unconverged value (error) -302.035 (2.94692814e-06)
154203 EPS nconv=0 first unconverged value (error) -302.035 (2.69428536e-06)
154204 EPS nconv=0 first unconverged value (error) -302.035 (2.37893714e-06)
154205 EPS nconv=0 first unconverged value (error) -302.035 (2.35532892e-06)
154206 EPS nconv=0 first unconverged value (error) -302.035 (2.34682784e-06)
154207 EPS nconv=0 first unconverged value (error) -302.035 (2.34682784e-06)
154208 EPS nconv=0 first unconverged value (error) -302.035 (2.37031742e-06)
154209 EPS nconv=0 first unconverged value (error) -302.035 (2.48356997e-06)
154210 EPS nconv=0 first unconverged value (error) -302.035 (2.30094540e-06)
154211 EPS nconv=0 first unconverged value (error) -302.035 (2.03282369e-06)
154212 EPS nconv=0 first unconverged value (error) -302.035 (1.91775054e-06)
154213 EPS nconv=0 first unconverged value (error) -302.035 (1.91775054e-06)
154214 EPS nconv=0 first unconverged value (error) -302.035 (2.25262341e-06)
154215 EPS nconv=0 first unconverged value (error) -302.035 (2.13798054e-06)
154216 EPS nconv=0 first unconverged value (error) -302.035 (2.07951906e-06)
154217 EPS nconv=0 first unconverged value (error) -302.035 (2.03829241e-06)
154218 EPS nconv=0 first unconverged value (error) -302.035 (2.00808408e-06)
154219 EPS nconv=0 first unconverged value (error) -302.035 (2.00808408e-06)
154220 EPS nconv=0 first unconverged value (error) -302.035 (2.04650274e-06)
154221 EPS nconv=0 first unconverged value (error) -302.035 (2.18386902e-06)
154222 EPS nconv=0 first unconverged value (error) -302.035 (1.97798382e-06)
154223 EPS nconv=0 first unconverged value (error) -302.035 (1.89457261e-06)
154224 EPS nconv=0 first unconverged value (error) -302.035 (1.85632023e-06)
154225 EPS nconv=0 first unconverged value (error) -302.035 (1.85632023e-06)
154226 EPS nconv=0 first unconverged value (error) -302.035 (2.50279115e-06)
154227 EPS nconv=0 first unconverged value (error) -302.035 (2.32731975e-06)
154228 EPS nconv=0 first unconverged value (error) -302.035 (2.19636385e-06)
154229 EPS nconv=0 first unconverged value (error) -302.035 (2.16224297e-06)
154230 EPS nconv=0 first unconverged value (error) -302.035 (2.10072016e-06)
154231 EPS nconv=0 first unconverged value (error) -302.035 (2.10072016e-06)
154232 EPS nconv=0 first unconverged value (error) -302.035 (2.71187885e-06)
154233 EPS nconv=0 first unconverged value (error) -302.035 (2.71618685e-06)
154234 EPS nconv=0 first unconverged value (error) -302.035 (2.43212467e-06)
154235 EPS nconv=0 first unconverged value (error) -302.035 (2.39344760e-06)
154236 EPS nconv=0 first unconverged value (error) -302.035 (2.34300088e-06)
154237 EPS nconv=0 first unconverged value (error) -302.035 (2.34300088e-06)
154238 EPS nconv=0 first unconverged value (error) -302.035 (2.46984349e-06)
154239 EPS nconv=0 first unconverged value (error) -302.035 (2.33053475e-06)
154240 EPS nconv=0 first unconverged value (error) -302.035 (2.21258057e-06)
154241 EPS nconv=0 first unconverged value (error) -302.035 (1.96939884e-06)
154242 EPS nconv=0 first unconverged value (error) -302.035 (1.90867277e-06)
154243 EPS nconv=0 first unconverged value (error) -302.035 (1.90867277e-06)
154244 EPS nconv=0 first unconverged value (error) -302.035 (1.91148081e-06)
154245 EPS nconv=0 first unconverged value (error) -302.035 (1.96067662e-06)
154246 EPS nconv=0 first unconverged value (error) -302.035 (1.90981361e-06)
154247 EPS nconv=0 first unconverged value (error) -302.035 (1.84742154e-06)
154248 EPS nconv=0 first unconverged value (error) -302.035 (1.83670943e-06)
154249 EPS nconv=0 first unconverged value (error) -302.035 (1.83670943e-06)
154250 EPS nconv=0 first unconverged value (error) -302.035 (2.00036657e-06)
154251 EPS nconv=0 first unconverged value (error) -302.035 (1.94888362e-06)
154252 EPS nconv=0 first unconverged value (error) -302.035 (1.93462919e-06)
154253 EPS nconv=0 first unconverged value (error) -302.035 (1.90512426e-06)
154254 EPS nconv=0 first unconverged value (error) -302.035 (1.87873233e-06)
154255 EPS nconv=0 first unconverged value (error) -302.035 (1.87873233e-06)
154256 EPS nconv=0 first unconverged value (error) -302.035 (1.87814955e-06)
154257 EPS nconv=0 first unconverged value (error) -302.035 (1.91341776e-06)
154258 EPS nconv=0 first unconverged value (error) -302.035 (1.84268887e-06)
154259 EPS nconv=0 first unconverged value (error) -302.035 (1.83086156e-06)
154260 EPS nconv=0 first unconverged value (error) -302.035 (1.81884634e-06)
154261 EPS nconv=0 first unconverged value (error) -302.035 (1.81884634e-06)
154262 EPS nconv=0 first unconverged value (error) -302.035 (2.24858872e-06)
154263 EPS nconv=0 first unconverged value (error) -302.035 (2.12828345e-06)
154264 EPS nconv=0 first unconverged value (error) -302.035 (2.03255245e-06)
154265 EPS nconv=0 first unconverged value (error) -302.035 (2.01634913e-06)
154266 EPS nconv=0 first unconverged value (error) -302.035 (1.97537818e-06)
154267 EPS nconv=0 first unconverged value (error) -302.035 (1.97537818e-06)
154268 EPS nconv=0 first unconverged value (error) -302.035 (2.84571753e-06)
154269 EPS nconv=0 first unconverged value (error) -302.035 (2.74980669e-06)
154270 EPS nconv=0 first unconverged value (error) -302.035 (2.49462267e-06)
154271 EPS nconv=0 first unconverged value (error) -302.035 (2.48279254e-06)
154272 EPS nconv=0 first unconverged value (error) -302.035 (2.42930985e-06)
154273 EPS nconv=0 first unconverged value (error) -302.035 (2.42930985e-06)
154274 EPS nconv=0 first unconverged value (error) -302.035 (2.49205972e-06)
154275 EPS nconv=0 first unconverged value (error) -302.035 (2.43583309e-06)
154276 EPS nconv=0 first unconverged value (error) -302.035 (2.26191326e-06)
154277 EPS nconv=0 first unconverged value (error) -302.035 (1.91627873e-06)
154278 EPS nconv=0 first unconverged value (error) -302.035 (1.88202595e-06)
154279 EPS nconv=0 first unconverged value (error) -302.035 (1.88202595e-06)
154280 EPS nconv=0 first unconverged value (error) -302.035 (1.91556091e-06)
154281 EPS nconv=0 first unconverged value (error) -302.035 (1.90753817e-06)
154282 EPS nconv=0 first unconverged value (error) -302.035 (1.86272106e-06)
154283 EPS nconv=0 first unconverged value (error) -302.035 (1.84621404e-06)
154284 EPS nconv=0 first unconverged value (error) -302.035 (1.84151362e-06)
154285 EPS nconv=0 first unconverged value (error) -302.035 (1.84151362e-06)
154286 EPS nconv=0 first unconverged value (error) -302.035 (1.97321292e-06)
154287 EPS nconv=0 first unconverged value (error) -302.035 (1.98239617e-06)
154288 EPS nconv=0 first unconverged value (error) -302.035 (1.91122084e-06)
154289 EPS nconv=0 first unconverged value (error) -302.035 (1.86517130e-06)
154290 EPS nconv=0 first unconverged value (error) -302.035 (1.84798318e-06)
154291 EPS nconv=0 first unconverged value (error) -302.035 (1.84798318e-06)
154292 EPS nconv=0 first unconverged value (error) -302.035 (1.95108748e-06)
154293 EPS nconv=0 first unconverged value (error) -302.035 (1.95615724e-06)
154294 EPS nconv=0 first unconverged value (error) -302.035 (1.89345461e-06)
154295 EPS nconv=0 first unconverged value (error) -302.035 (1.87149722e-06)
154296 EPS nconv=0 first unconverged value (error) -302.035 (1.87201728e-06)
154297 EPS nconv=0 first unconverged value (error) -302.035 (1.87201728e-06)
154298 EPS nconv=0 first unconverged value (error) -302.035 (1.94755583e-06)
154299 EPS nconv=0 first unconverged value (error) -302.035 (1.91663704e-06)
154300 EPS nconv=0 first unconverged value (error) -302.035 (1.87003261e-06)
154301 EPS nconv=0 first unconverged value (error) -302.035 (1.83758666e-06)
154302 EPS nconv=0 first unconverged value (error) -302.035 (1.82860876e-06)
154303 EPS nconv=0 first unconverged value (error) -302.035 (1.82860876e-06)
154304 EPS nconv=0 first unconverged value (error) -302.035 (1.86562393e-06)
154305 EPS nconv=0 first unconverged value (error) -302.035 (1.88131139e-06)
154306 EPS nconv=0 first unconverged value (error) -302.035 (1.83198150e-06)
154307 EPS nconv=0 first unconverged value (error) -302.035 (1.81944526e-06)
154308 EPS nconv=0 first unconverged value (error) -302.035 (1.81811143e-06)
154309 EPS nconv=0 first unconverged value (error) -302.035 (1.81811143e-06)
154310 EPS nconv=0 first unconverged value (error) -302.035 (1.88929781e-06)
154311 EPS nconv=0 first unconverged value (error) -302.035 (1.87789930e-06)
154312 EPS nconv=0 first unconverged value (error) -302.035 (1.85020580e-06)
154313 EPS nconv=0 first unconverged value (error) -302.035 (1.83545771e-06)
154314 EPS nconv=0 first unconverged value (error) -302.035 (1.82618006e-06)
154315 EPS nconv=0 first unconverged value (error) -302.035 (1.82618006e-06)
154316 EPS nconv=0 first unconverged value (error) -302.035 (1.82668869e-06)
154317 EPS nconv=0 first unconverged value (error) -302.035 (1.84950961e-06)
154318 EPS nconv=0 first unconverged value (error) -302.035 (1.81504748e-06)
154319 EPS nconv=0 first unconverged value (error) -302.035 (1.80484133e-06)
154320 EPS nconv=0 first unconverged value (error) -302.035 (1.80551974e-06)
154321 EPS nconv=0 first unconverged value (error) -302.035 (1.80551974e-06)
154322 EPS nconv=0 first unconverged value (error) -302.035 (1.92940811e-06)
154323 EPS nconv=0 first unconverged value (error) -302.035 (1.86749210e-06)
154324 EPS nconv=0 first unconverged value (error) -302.035 (1.85151743e-06)
154325 EPS nconv=0 first unconverged value (error) -302.035 (1.84880355e-06)
154326 EPS nconv=0 first unconverged value (error) -302.035 (1.83754438e-06)
154327 EPS nconv=0 first unconverged value (error) -302.035 (1.83754438e-06)
154328 EPS nconv=0 first unconverged value (error) -302.035 (1.96873728e-06)
154329 EPS nconv=0 first unconverged value (error) -302.035 (1.98800789e-06)
154330 EPS nconv=0 first unconverged value (error) -302.035 (1.90340665e-06)
154331 EPS nconv=0 first unconverged value (error) -302.035 (1.86389463e-06)
154332 EPS nconv=0 first unconverged value (error) -302.035 (1.85436199e-06)
154333 EPS nconv=0 first unconverged value (error) -302.035 (1.85436199e-06)
154334 EPS nconv=0 first unconverged value (error) -302.035 (1.86026197e-06)
154335 EPS nconv=0 first unconverged value (error) -302.035 (1.88568257e-06)
154336 EPS nconv=0 first unconverged value (error) -302.035 (1.84254116e-06)
154337 EPS nconv=0 first unconverged value (error) -302.035 (1.81884167e-06)
154338 EPS nconv=0 first unconverged value (error) -302.035 (1.81384437e-06)
154339 EPS nconv=0 first unconverged value (error) -302.035 (1.81384437e-06)
154340 EPS nconv=0 first unconverged value (error) -302.035 (1.90600645e-06)
154341 EPS nconv=0 first unconverged value (error) -302.035 (1.87640164e-06)
154342 EPS nconv=0 first unconverged value (error) -302.035 (1.86036385e-06)
154343 EPS nconv=0 first unconverged value (error) -302.035 (1.84363595e-06)
154344 EPS nconv=0 first unconverged value (error) -302.035 (1.83486189e-06)
154345 EPS nconv=0 first unconverged value (error) -302.035 (1.83486189e-06)
154346 EPS nconv=0 first unconverged value (error) -302.035 (1.83514389e-06)
154347 EPS nconv=0 first unconverged value (error) -302.035 (1.86288225e-06)
154348 EPS nconv=0 first unconverged value (error) -302.035 (1.82026487e-06)
154349 EPS nconv=0 first unconverged value (error) -302.035 (1.80951807e-06)
154350 EPS nconv=0 first unconverged value (error) -302.035 (1.80399342e-06)
154351 EPS nconv=0 first unconverged value (error) -302.035 (1.80399342e-06)
154352 EPS nconv=0 first unconverged value (error) -302.035 (1.85993270e-06)
154353 EPS nconv=0 first unconverged value (error) -302.035 (1.83824302e-06)
154354 EPS nconv=0 first unconverged value (error) -302.035 (1.82990385e-06)
154355 EPS nconv=0 first unconverged value (error) -302.035 (1.82492418e-06)
154356 EPS nconv=0 first unconverged value (error) -302.035 (1.81946958e-06)
154357 EPS nconv=0 first unconverged value (error) -302.035 (1.81946958e-06)
154358 EPS nconv=0 first unconverged value (error) -302.035 (1.87890260e-06)
154359 EPS nconv=0 first unconverged value (error) -302.035 (1.89553019e-06)
154360 EPS nconv=0 first unconverged value (error) -302.035 (1.86808165e-06)
154361 EPS nconv=0 first unconverged value (error) -302.035 (1.83665317e-06)
154362 EPS nconv=0 first unconverged value (error) -302.035 (1.83323946e-06)
154363 EPS nconv=0 first unconverged value (error) -302.035 (1.83323946e-06)
154364 EPS nconv=0 first unconverged value (error) -302.035 (1.85665918e-06)
154365 EPS nconv=0 first unconverged value (error) -302.035 (1.82999306e-06)
154366 EPS nconv=0 first unconverged value (error) -302.035 (1.81521056e-06)
154367 EPS nconv=0 first unconverged value (error) -302.035 (1.81378312e-06)
154368 EPS nconv=0 first unconverged value (error) -302.035 (1.81097349e-06)
154369 EPS nconv=0 first unconverged value (error) -302.035 (1.81097349e-06)
154370 EPS nconv=0 first unconverged value (error) -302.035 (2.04479558e-06)
154371 EPS nconv=0 first unconverged value (error) -302.035 (1.95093350e-06)
154372 EPS nconv=0 first unconverged value (error) -302.035 (1.89361375e-06)
154373 EPS nconv=0 first unconverged value (error) -302.035 (1.88044687e-06)
154374 EPS nconv=0 first unconverged value (error) -302.035 (1.87134995e-06)
154375 EPS nconv=0 first unconverged value (error) -302.035 (1.87134995e-06)
154376 EPS nconv=0 first unconverged value (error) -302.035 (1.87870547e-06)
154377 EPS nconv=0 first unconverged value (error) -302.035 (1.97610083e-06)
154378 EPS nconv=0 first unconverged value (error) -302.035 (1.87606582e-06)
154379 EPS nconv=0 first unconverged value (error) -302.035 (1.82025091e-06)
154380 EPS nconv=0 first unconverged value (error) -302.035 (1.80817463e-06)
154381 EPS nconv=0 first unconverged value (error) -302.035 (1.80817463e-06)
154382 EPS nconv=0 first unconverged value (error) -302.035 (1.80296040e-06)
154383 EPS nconv=0 first unconverged value (error) -302.035 (1.80596005e-06)
154384 EPS nconv=0 first unconverged value (error) -302.035 (1.79976059e-06)
154385 EPS nconv=0 first unconverged value (error) -302.035 (1.79678783e-06)
154386 EPS nconv=0 first unconverged value (error) -302.035 (1.79622822e-06)
154387 EPS nconv=0 first unconverged value (error) -302.035 (1.79622822e-06)
154388 EPS nconv=0 first unconverged value (error) -302.035 (1.83398717e-06)
154389 EPS nconv=0 first unconverged value (error) -302.035 (1.82295778e-06)
154390 EPS nconv=0 first unconverged value (error) -302.035 (1.81437999e-06)
154391 EPS nconv=0 first unconverged value (error) -302.035 (1.81001664e-06)
154392 EPS nconv=0 first unconverged value (error) -302.035 (1.80776584e-06)
154393 EPS nconv=0 first unconverged value (error) -302.035 (1.80776584e-06)
154394 EPS nconv=0 first unconverged value (error) -302.035 (2.24065455e-06)
154395 EPS nconv=0 first unconverged value (error) -302.035 (2.16007890e-06)
154396 EPS nconv=0 first unconverged value (error) -302.035 (2.08974616e-06)
154397 EPS nconv=0 first unconverged value (error) -302.035 (2.02564988e-06)
154398 EPS nconv=0 first unconverged value (error) -302.035 (2.00663864e-06)
154399 EPS nconv=0 first unconverged value (error) -302.035 (2.00663864e-06)
154400 EPS nconv=0 first unconverged value (error) -302.035 (2.14585638e-06)
154401 EPS nconv=0 first unconverged value (error) -302.035 (2.17743897e-06)
154402 EPS nconv=0 first unconverged value (error) -302.035 (2.07498048e-06)
154403 EPS nconv=0 first unconverged value (error) -302.035 (1.89964021e-06)
154404 EPS nconv=0 first unconverged value (error) -302.035 (1.86278114e-06)
154405 EPS nconv=0 first unconverged value (error) -302.035 (1.86278114e-06)
154406 EPS nconv=0 first unconverged value (error) -302.035 (2.18314267e-06)
154407 EPS nconv=0 first unconverged value (error) -302.035 (2.04905725e-06)
154408 EPS nconv=0 first unconverged value (error) -302.035 (1.98780472e-06)
154409 EPS nconv=0 first unconverged value (error) -302.035 (1.98329145e-06)
154410 EPS nconv=0 first unconverged value (error) -302.035 (1.98033803e-06)
154411 EPS nconv=0 first unconverged value (error) -302.035 (1.98033803e-06)
154412 EPS nconv=0 first unconverged value (error) -302.035 (2.61217420e-06)
154413 EPS nconv=0 first unconverged value (error) -302.035 (2.40125705e-06)
154414 EPS nconv=0 first unconverged value (error) -302.035 (2.19659013e-06)
154415 EPS nconv=0 first unconverged value (error) -302.035 (2.18218623e-06)
154416 EPS nconv=0 first unconverged value (error) -302.035 (2.17509580e-06)
154417 EPS nconv=0 first unconverged value (error) -302.035 (2.17509580e-06)
154418 EPS nconv=0 first unconverged value (error) -302.035 (2.16577004e-06)
154419 EPS nconv=0 first unconverged value (error) -302.035 (2.27738128e-06)
154420 EPS nconv=0 first unconverged value (error) -302.035 (2.06419550e-06)
154421 EPS nconv=0 first unconverged value (error) -302.035 (1.88364078e-06)
154422 EPS nconv=0 first unconverged value (error) -302.035 (1.84242946e-06)
154423 EPS nconv=0 first unconverged value (error) -302.035 (1.84242946e-06)
154424 EPS nconv=0 first unconverged value (error) -302.035 (1.82773661e-06)
154425 EPS nconv=0 first unconverged value (error) -302.035 (1.83068639e-06)
154426 EPS nconv=0 first unconverged value (error) -302.035 (1.81869249e-06)
154427 EPS nconv=0 first unconverged value (error) -302.035 (1.80984757e-06)
154428 EPS nconv=0 first unconverged value (error) -302.035 (1.80762683e-06)
154429 EPS nconv=0 first unconverged value (error) -302.035 (1.80762683e-06)
154430 EPS nconv=0 first unconverged value (error) -302.035 (1.86127772e-06)
154431 EPS nconv=0 first unconverged value (error) -302.035 (1.85331873e-06)
154432 EPS nconv=0 first unconverged value (error) -302.035 (1.84325434e-06)
154433 EPS nconv=0 first unconverged value (error) -302.035 (1.82788317e-06)
154434 EPS nconv=0 first unconverged value (error) -302.035 (1.82210110e-06)
154435 EPS nconv=0 first unconverged value (error) -302.035 (1.82210110e-06)
154436 EPS nconv=0 first unconverged value (error) -302.035 (1.96887458e-06)
154437 EPS nconv=0 first unconverged value (error) -302.035 (1.96464091e-06)
154438 EPS nconv=0 first unconverged value (error) -302.035 (1.92995104e-06)
154439 EPS nconv=0 first unconverged value (error) -302.035 (1.87244928e-06)
154440 EPS nconv=0 first unconverged value (error) -302.035 (1.86408125e-06)
154441 EPS nconv=0 first unconverged value (error) -302.035 (1.86408125e-06)
154442 EPS nconv=0 first unconverged value (error) -302.035 (2.11185598e-06)
154443 EPS nconv=0 first unconverged value (error) -302.035 (1.98651511e-06)
154444 EPS nconv=0 first unconverged value (error) -302.035 (1.93006385e-06)
154445 EPS nconv=0 first unconverged value (error) -302.035 (1.93131336e-06)
154446 EPS nconv=0 first unconverged value (error) -302.035 (1.91373986e-06)
154447 EPS nconv=0 first unconverged value (error) -302.035 (1.91373986e-06)
154448 EPS nconv=0 first unconverged value (error) -302.035 (1.90630691e-06)
154449 EPS nconv=0 first unconverged value (error) -302.035 (1.98008337e-06)
154450 EPS nconv=0 first unconverged value (error) -302.035 (1.86313902e-06)
154451 EPS nconv=0 first unconverged value (error) -302.035 (1.83384699e-06)
154452 EPS nconv=0 first unconverged value (error) -302.035 (1.82246886e-06)
154453 EPS nconv=0 first unconverged value (error) -302.035 (1.82246886e-06)
154454 EPS nconv=0 first unconverged value (error) -302.035 (1.81214515e-06)
154455 EPS nconv=0 first unconverged value (error) -302.035 (1.80686719e-06)
154456 EPS nconv=0 first unconverged value (error) -302.035 (1.80352027e-06)
154457 EPS nconv=0 first unconverged value (error) -302.035 (1.80211094e-06)
154458 EPS nconv=0 first unconverged value (error) -302.035 (1.80038860e-06)
154459 EPS nconv=0 first unconverged value (error) -302.035 (1.80038860e-06)
154460 EPS nconv=0 first unconverged value (error) -302.035 (2.60953303e-06)
154461 EPS nconv=0 first unconverged value (error) -302.035 (2.50497285e-06)
154462 EPS nconv=0 first unconverged value (error) -302.035 (2.35734313e-06)
154463 EPS nconv=0 first unconverged value (error) -302.035 (2.32393780e-06)
154464 EPS nconv=0 first unconverged value (error) -302.035 (2.31395621e-06)
154465 EPS nconv=0 first unconverged value (error) -302.035 (2.31395621e-06)
154466 EPS nconv=0 first unconverged value (error) -302.035 (3.11299659e-06)
154467 EPS nconv=0 first unconverged value (error) -302.035 (2.63489502e-06)
154468 EPS nconv=0 first unconverged value (error) -302.035 (2.37729603e-06)
154469 EPS nconv=0 first unconverged value (error) -302.035 (2.32674379e-06)
154470 EPS nconv=0 first unconverged value (error) -302.035 (2.28847616e-06)
154471 EPS nconv=0 first unconverged value (error) -302.035 (2.28847616e-06)
154472 EPS nconv=0 first unconverged value (error) -302.035 (2.73250305e-06)
154473 EPS nconv=0 first unconverged value (error) -302.035 (2.88970614e-06)
154474 EPS nconv=0 first unconverged value (error) -302.035 (2.32417850e-06)
154475 EPS nconv=0 first unconverged value (error) -302.035 (2.22671220e-06)
154476 EPS nconv=0 first unconverged value (error) -302.035 (2.13273447e-06)
154477 EPS nconv=0 first unconverged value (error) -302.035 (2.13273447e-06)
154478 EPS nconv=0 first unconverged value (error) -302.035 (2.06861456e-06)
154479 EPS nconv=0 first unconverged value (error) -302.035 (2.22328224e-06)
154480 EPS nconv=0 first unconverged value (error) -302.035 (2.12751330e-06)
154481 EPS nconv=0 first unconverged value (error) -302.035 (1.87443308e-06)
154482 EPS nconv=0 first unconverged value (error) -302.035 (1.82673491e-06)
154483 EPS nconv=0 first unconverged value (error) -302.035 (1.82673491e-06)
154484 EPS nconv=0 first unconverged value (error) -302.035 (1.82620819e-06)
154485 EPS nconv=0 first unconverged value (error) -302.035 (1.82990829e-06)
154486 EPS nconv=0 first unconverged value (error) -302.035 (1.81550429e-06)
154487 EPS nconv=0 first unconverged value (error) -302.035 (1.80023445e-06)
154488 EPS nconv=0 first unconverged value (error) -302.035 (1.79875780e-06)
154489 EPS nconv=0 first unconverged value (error) -302.035 (1.79875780e-06)
154490 EPS nconv=0 first unconverged value (error) -302.035 (2.15551791e-06)
154491 EPS nconv=0 first unconverged value (error) -302.035 (1.99765187e-06)
154492 EPS nconv=0 first unconverged value (error) -302.035 (1.96915072e-06)
154493 EPS nconv=0 first unconverged value (error) -302.035 (1.95232158e-06)
154494 EPS nconv=0 first unconverged value (error) -302.035 (1.92673303e-06)
154495 EPS nconv=0 first unconverged value (error) -302.035 (1.92673303e-06)
154496 EPS nconv=0 first unconverged value (error) -302.035 (2.19138339e-06)
154497 EPS nconv=0 first unconverged value (error) -302.035 (2.18612259e-06)
154498 EPS nconv=0 first unconverged value (error) -302.035 (1.98519244e-06)
154499 EPS nconv=0 first unconverged value (error) -302.035 (1.98061777e-06)
154500 EPS nconv=0 first unconverged value (error) -302.035 (1.96322420e-06)
154501 EPS nconv=0 first unconverged value (error) -302.035 (1.96322420e-06)
154502 EPS nconv=0 first unconverged value (error) -302.035 (2.15457637e-06)
154503 EPS nconv=0 first unconverged value (error) -302.035 (2.15165532e-06)
154504 EPS nconv=0 first unconverged value (error) -302.035 (2.04483118e-06)
154505 EPS nconv=0 first unconverged value (error) -302.035 (1.93776928e-06)
154506 EPS nconv=0 first unconverged value (error) -302.035 (1.90529105e-06)
154507 EPS nconv=0 first unconverged value (error) -302.035 (1.90529105e-06)
154508 EPS nconv=0 first unconverged value (error) -302.035 (2.16508167e-06)
154509 EPS nconv=0 first unconverged value (error) -302.035 (2.09893675e-06)
154510 EPS nconv=0 first unconverged value (error) -302.035 (2.02268457e-06)
154511 EPS nconv=0 first unconverged value (error) -302.035 (1.94738917e-06)
154512 EPS nconv=0 first unconverged value (error) -302.035 (1.93071004e-06)
154513 EPS nconv=0 first unconverged value (error) -302.035 (1.93071004e-06)
154514 EPS nconv=0 first unconverged value (error) -302.035 (2.07235599e-06)
154515 EPS nconv=0 first unconverged value (error) -302.035 (2.15082091e-06)
154516 EPS nconv=0 first unconverged value (error) -302.035 (1.99279657e-06)
154517 EPS nconv=0 first unconverged value (error) -302.035 (1.91502041e-06)
154518 EPS nconv=0 first unconverged value (error) -302.035 (1.88012405e-06)
154519 EPS nconv=0 first unconverged value (error) -302.035 (1.88012405e-06)
154520 EPS nconv=0 first unconverged value (error) -302.035 (2.26724358e-06)
154521 EPS nconv=0 first unconverged value (error) -302.035 (2.18735869e-06)
154522 EPS nconv=0 first unconverged value (error) -302.035 (2.06564695e-06)
154523 EPS nconv=0 first unconverged value (error) -302.035 (2.02825540e-06)
154524 EPS nconv=0 first unconverged value (error) -302.035 (2.00395535e-06)
154525 EPS nconv=0 first unconverged value (error) -302.035 (2.00395535e-06)
154526 EPS nconv=0 first unconverged value (error) -302.035 (2.23544708e-06)
154527 EPS nconv=0 first unconverged value (error) -302.035 (2.21947196e-06)
154528 EPS nconv=0 first unconverged value (error) -302.035 (2.03414894e-06)
154529 EPS nconv=0 first unconverged value (error) -302.035 (1.99094571e-06)
154530 EPS nconv=0 first unconverged value (error) -302.035 (1.95553854e-06)
154531 EPS nconv=0 first unconverged value (error) -302.035 (1.95553854e-06)
154532 EPS nconv=0 first unconverged value (error) -302.035 (2.10271156e-06)
154533 EPS nconv=0 first unconverged value (error) -302.035 (2.15477933e-06)
154534 EPS nconv=0 first unconverged value (error) -302.035 (2.02504860e-06)
154535 EPS nconv=0 first unconverged value (error) -302.035 (1.91963152e-06)
154536 EPS nconv=0 first unconverged value (error) -302.035 (1.88420897e-06)
154537 EPS nconv=0 first unconverged value (error) -302.035 (1.88420897e-06)
154538 EPS nconv=0 first unconverged value (error) -302.035 (1.96541769e-06)
154539 EPS nconv=0 first unconverged value (error) -302.035 (1.97208591e-06)
154540 EPS nconv=0 first unconverged value (error) -302.035 (1.91678997e-06)
154541 EPS nconv=0 first unconverged value (error) -302.035 (1.86310631e-06)
154542 EPS nconv=0 first unconverged value (error) -302.035 (1.83985827e-06)
154543 EPS nconv=0 first unconverged value (error) -302.035 (1.83985827e-06)
154544 EPS nconv=0 first unconverged value (error) -302.035 (1.95552154e-06)
154545 EPS nconv=0 first unconverged value (error) -302.035 (1.93477544e-06)
154546 EPS nconv=0 first unconverged value (error) -302.035 (1.89842073e-06)
154547 EPS nconv=0 first unconverged value (error) -302.035 (1.87885570e-06)
154548 EPS nconv=0 first unconverged value (error) -302.035 (1.85824731e-06)
154549 EPS nconv=0 first unconverged value (error) -302.035 (1.85824731e-06)
154550 EPS nconv=0 first unconverged value (error) -302.035 (1.95244903e-06)
154551 EPS nconv=0 first unconverged value (error) -302.035 (1.94301001e-06)
154552 EPS nconv=0 first unconverged value (error) -302.035 (1.87634748e-06)
154553 EPS nconv=0 first unconverged value (error) -302.035 (1.87500050e-06)
154554 EPS nconv=0 first unconverged value (error) -302.035 (1.85740969e-06)
154555 EPS nconv=0 first unconverged value (error) -302.035 (1.85740969e-06)
154556 EPS nconv=0 first unconverged value (error) -302.035 (1.91926941e-06)
154557 EPS nconv=0 first unconverged value (error) -302.035 (1.92033425e-06)
154558 EPS nconv=0 first unconverged value (error) -302.035 (1.88070549e-06)
154559 EPS nconv=0 first unconverged value (error) -302.035 (1.84503539e-06)
154560 EPS nconv=0 first unconverged value (error) -302.035 (1.83087884e-06)
154561 EPS nconv=0 first unconverged value (error) -302.035 (1.83087884e-06)
154562 EPS nconv=0 first unconverged value (error) -302.035 (1.82711991e-06)
154563 EPS nconv=0 first unconverged value (error) -302.035 (1.84284425e-06)
154564 EPS nconv=0 first unconverged value (error) -302.035 (1.82750347e-06)
154565 EPS nconv=0 first unconverged value (error) -302.035 (1.80851739e-06)
154566 EPS nconv=0 first unconverged value (error) -302.035 (1.80272084e-06)
154567 EPS nconv=0 first unconverged value (error) -302.035 (1.80272084e-06)
154568 EPS nconv=0 first unconverged value (error) -302.035 (1.94776339e-06)
154569 EPS nconv=0 first unconverged value (error) -302.035 (1.89906702e-06)
154570 EPS nconv=0 first unconverged value (error) -302.035 (1.88823029e-06)
154571 EPS nconv=0 first unconverged value (error) -302.035 (1.87437410e-06)
154572 EPS nconv=0 first unconverged value (error) -302.035 (1.85841557e-06)
154573 EPS nconv=0 first unconverged value (error) -302.035 (1.85841557e-06)
154574 EPS nconv=0 first unconverged value (error) -302.035 (2.08665106e-06)
154575 EPS nconv=0 first unconverged value (error) -302.035 (2.02631595e-06)
154576 EPS nconv=0 first unconverged value (error) -302.035 (1.97618274e-06)
154577 EPS nconv=0 first unconverged value (error) -302.035 (1.97461992e-06)
154578 EPS nconv=0 first unconverged value (error) -302.035 (1.96224663e-06)
154579 EPS nconv=0 first unconverged value (error) -302.035 (1.96224663e-06)
154580 EPS nconv=0 first unconverged value (error) -302.035 (1.94836122e-06)
154581 EPS nconv=0 first unconverged value (error) -302.035 (1.91751128e-06)
154582 EPS nconv=0 first unconverged value (error) -302.035 (1.85298160e-06)
154583 EPS nconv=0 first unconverged value (error) -302.035 (1.85020842e-06)
154584 EPS nconv=0 first unconverged value (error) -302.035 (1.81422806e-06)
154585 EPS nconv=0 first unconverged value (error) -302.035 (1.81422806e-06)
154586 EPS nconv=0 first unconverged value (error) -302.035 (2.53464018e-06)
154587 EPS nconv=0 first unconverged value (error) -302.035 (2.51959537e-06)
154588 EPS nconv=0 first unconverged value (error) -302.035 (2.25544117e-06)
154589 EPS nconv=0 first unconverged value (error) -302.035 (2.19251227e-06)
154590 EPS nconv=0 first unconverged value (error) -302.035 (2.14481166e-06)
154591 EPS nconv=0 first unconverged value (error) -302.035 (2.14481166e-06)
154592 EPS nconv=0 first unconverged value (error) -302.035 (2.55971727e-06)
154593 EPS nconv=0 first unconverged value (error) -302.035 (2.44341125e-06)
154594 EPS nconv=0 first unconverged value (error) -302.035 (2.33626816e-06)
154595 EPS nconv=0 first unconverged value (error) -302.035 (2.16700984e-06)
154596 EPS nconv=0 first unconverged value (error) -302.035 (2.11442893e-06)
154597 EPS nconv=0 first unconverged value (error) -302.035 (2.11442893e-06)
154598 EPS nconv=0 first unconverged value (error) -302.035 (2.10997387e-06)
154599 EPS nconv=0 first unconverged value (error) -302.035 (2.10555034e-06)
154600 EPS nconv=0 first unconverged value (error) -302.035 (1.93588307e-06)
154601 EPS nconv=0 first unconverged value (error) -302.035 (1.85636735e-06)
154602 EPS nconv=0 first unconverged value (error) -302.035 (1.83758928e-06)
154603 EPS nconv=0 first unconverged value (error) -302.035 (1.83758928e-06)
154604 EPS nconv=0 first unconverged value (error) -302.035 (2.09736946e-06)
154605 EPS nconv=0 first unconverged value (error) -302.035 (2.01813019e-06)
154606 EPS nconv=0 first unconverged value (error) -302.035 (1.96087863e-06)
154607 EPS nconv=0 first unconverged value (error) -302.035 (1.94414998e-06)
154608 EPS nconv=0 first unconverged value (error) -302.035 (1.93399757e-06)
154609 EPS nconv=0 first unconverged value (error) -302.035 (1.93399757e-06)
154610 EPS nconv=0 first unconverged value (error) -302.035 (2.77310402e-06)
154611 EPS nconv=0 first unconverged value (error) -302.035 (2.52642855e-06)
154612 EPS nconv=0 first unconverged value (error) -302.035 (2.33377225e-06)
154613 EPS nconv=0 first unconverged value (error) -302.035 (2.30684684e-06)
154614 EPS nconv=0 first unconverged value (error) -302.035 (2.26352055e-06)
154615 EPS nconv=0 first unconverged value (error) -302.035 (2.26352055e-06)
154616 EPS nconv=0 first unconverged value (error) -302.035 (2.26009658e-06)
154617 EPS nconv=0 first unconverged value (error) -302.035 (2.44860402e-06)
154618 EPS nconv=0 first unconverged value (error) -302.035 (2.14814428e-06)
154619 EPS nconv=0 first unconverged value (error) -302.035 (1.89212829e-06)
154620 EPS nconv=0 first unconverged value (error) -302.035 (1.85368853e-06)
154621 EPS nconv=0 first unconverged value (error) -302.035 (1.85368853e-06)
154622 EPS nconv=0 first unconverged value (error) -302.035 (3.11391022e-06)
154623 EPS nconv=0 first unconverged value (error) -302.035 (2.73920836e-06)
154624 EPS nconv=0 first unconverged value (error) -302.035 (2.52490191e-06)
154625 EPS nconv=0 first unconverged value (error) -302.035 (2.44498885e-06)
154626 EPS nconv=0 first unconverged value (error) -302.035 (2.38906500e-06)
154627 EPS nconv=0 first unconverged value (error) -302.035 (2.38906500e-06)
154628 EPS nconv=0 first unconverged value (error) -302.035 (2.75630151e-06)
154629 EPS nconv=0 first unconverged value (error) -302.035 (2.90145873e-06)
154630 EPS nconv=0 first unconverged value (error) -302.035 (2.45601930e-06)
154631 EPS nconv=0 first unconverged value (error) -302.035 (2.29079276e-06)
154632 EPS nconv=0 first unconverged value (error) -302.035 (2.23004298e-06)
154633 EPS nconv=0 first unconverged value (error) -302.035 (2.23004298e-06)
154634 EPS nconv=0 first unconverged value (error) -302.035 (2.72850914e-06)
154635 EPS nconv=0 first unconverged value (error) -302.035 (2.66111297e-06)
154636 EPS nconv=0 first unconverged value (error) -302.035 (2.35001755e-06)
154637 EPS nconv=0 first unconverged value (error) -302.035 (2.10449645e-06)
154638 EPS nconv=0 first unconverged value (error) -302.035 (2.04776064e-06)
154639 EPS nconv=0 first unconverged value (error) -302.035 (2.04776064e-06)
154640 EPS nconv=0 first unconverged value (error) -302.035 (2.03578118e-06)
154641 EPS nconv=0 first unconverged value (error) -302.035 (2.22119876e-06)
154642 EPS nconv=0 first unconverged value (error) -302.035 (2.06408805e-06)
154643 EPS nconv=0 first unconverged value (error) -302.035 (1.87118524e-06)
154644 EPS nconv=0 first unconverged value (error) -302.035 (1.83955501e-06)
154645 EPS nconv=0 first unconverged value (error) -302.035 (1.83955501e-06)
154646 EPS nconv=0 first unconverged value (error) -302.035 (2.10419449e-06)
154647 EPS nconv=0 first unconverged value (error) -302.035 (2.01990626e-06)
154648 EPS nconv=0 first unconverged value (error) -302.035 (2.00053503e-06)
154649 EPS nconv=0 first unconverged value (error) -302.035 (1.97304506e-06)
154650 EPS nconv=0 first unconverged value (error) -302.035 (1.94367406e-06)
154651 EPS nconv=0 first unconverged value (error) -302.035 (1.94367406e-06)
154652 EPS nconv=0 first unconverged value (error) -302.035 (2.75531204e-06)
154653 EPS nconv=0 first unconverged value (error) -302.035 (2.56880988e-06)
154654 EPS nconv=0 first unconverged value (error) -302.035 (2.43088789e-06)
154655 EPS nconv=0 first unconverged value (error) -302.035 (2.40030506e-06)
154656 EPS nconv=0 first unconverged value (error) -302.035 (2.39340081e-06)
154657 EPS nconv=0 first unconverged value (error) -302.035 (2.39340081e-06)
154658 EPS nconv=0 first unconverged value (error) -302.035 (2.38712852e-06)
154659 EPS nconv=0 first unconverged value (error) -302.035 (2.27098047e-06)
154660 EPS nconv=0 first unconverged value (error) -302.035 (2.12261085e-06)
154661 EPS nconv=0 first unconverged value (error) -302.035 (2.01785591e-06)
154662 EPS nconv=0 first unconverged value (error) -302.035 (1.92758158e-06)
154663 EPS nconv=0 first unconverged value (error) -302.035 (1.92758158e-06)
154664 EPS nconv=0 first unconverged value (error) -302.035 (2.07409486e-06)
154665 EPS nconv=0 first unconverged value (error) -302.035 (2.02237148e-06)
154666 EPS nconv=0 first unconverged value (error) -302.035 (1.95087526e-06)
154667 EPS nconv=0 first unconverged value (error) -302.035 (1.92105902e-06)
154668 EPS nconv=0 first unconverged value (error) -302.035 (1.90825002e-06)
154669 EPS nconv=0 first unconverged value (error) -302.035 (1.90825002e-06)
154670 EPS nconv=0 first unconverged value (error) -302.035 (2.59397604e-06)
154671 EPS nconv=0 first unconverged value (error) -302.035 (2.47323835e-06)
154672 EPS nconv=0 first unconverged value (error) -302.035 (2.26815141e-06)
154673 EPS nconv=0 first unconverged value (error) -302.035 (2.22259470e-06)
154674 EPS nconv=0 first unconverged value (error) -302.035 (2.19107804e-06)
154675 EPS nconv=0 first unconverged value (error) -302.035 (2.19107804e-06)
154676 EPS nconv=0 first unconverged value (error) -302.035 (2.56623815e-06)
154677 EPS nconv=0 first unconverged value (error) -302.035 (2.42130406e-06)
154678 EPS nconv=0 first unconverged value (error) -302.035 (2.15030692e-06)
154679 EPS nconv=0 first unconverged value (error) -302.035 (2.07899628e-06)
154680 EPS nconv=0 first unconverged value (error) -302.035 (2.03960339e-06)
154681 EPS nconv=0 first unconverged value (error) -302.035 (2.03960339e-06)
154682 EPS nconv=0 first unconverged value (error) -302.035 (2.61527919e-06)
154683 EPS nconv=0 first unconverged value (error) -302.035 (2.55318085e-06)
154684 EPS nconv=0 first unconverged value (error) -302.035 (2.21238160e-06)
154685 EPS nconv=0 first unconverged value (error) -302.035 (2.13324864e-06)
154686 EPS nconv=0 first unconverged value (error) -302.035 (2.07978729e-06)
154687 EPS nconv=0 first unconverged value (error) -302.035 (2.07978729e-06)
154688 EPS nconv=0 first unconverged value (error) -302.035 (2.05238467e-06)
154689 EPS nconv=0 first unconverged value (error) -302.035 (2.33817075e-06)
154690 EPS nconv=0 first unconverged value (error) -302.035 (2.16753982e-06)
154691 EPS nconv=0 first unconverged value (error) -302.035 (1.85941038e-06)
154692 EPS nconv=0 first unconverged value (error) -302.035 (1.81407446e-06)
154693 EPS nconv=0 first unconverged value (error) -302.035 (1.81407446e-06)
154694 EPS nconv=0 first unconverged value (error) -302.035 (1.80401043e-06)
154695 EPS nconv=0 first unconverged value (error) -302.035 (1.80258439e-06)
154696 EPS nconv=0 first unconverged value (error) -302.035 (1.80249063e-06)
154697 EPS nconv=0 first unconverged value (error) -302.035 (1.80056460e-06)
154698 EPS nconv=0 first unconverged value (error) -302.035 (1.79991397e-06)
154699 EPS nconv=0 first unconverged value (error) -302.035 (1.79991397e-06)
154700 EPS nconv=0 first unconverged value (error) -302.035 (2.46048664e-06)
154701 EPS nconv=0 first unconverged value (error) -302.035 (2.31016138e-06)
154702 EPS nconv=0 first unconverged value (error) -302.035 (2.23135989e-06)
154703 EPS nconv=0 first unconverged value (error) -302.035 (2.09639708e-06)
154704 EPS nconv=0 first unconverged value (error) -302.035 (2.07868416e-06)
154705 EPS nconv=0 first unconverged value (error) -302.035 (2.07868416e-06)
154706 EPS nconv=0 first unconverged value (error) -302.035 (2.82943565e-06)
154707 EPS nconv=0 first unconverged value (error) -302.035 (2.62197186e-06)
154708 EPS nconv=0 first unconverged value (error) -302.035 (2.37275392e-06)
154709 EPS nconv=0 first unconverged value (error) -302.035 (2.33193336e-06)
154710 EPS nconv=0 first unconverged value (error) -302.035 (2.23174069e-06)
154711 EPS nconv=0 first unconverged value (error) -302.035 (2.23174069e-06)
154712 EPS nconv=0 first unconverged value (error) -302.035 (2.48002199e-06)
154713 EPS nconv=0 first unconverged value (error) -302.035 (2.63939348e-06)
154714 EPS nconv=0 first unconverged value (error) -302.035 (2.29710069e-06)
154715 EPS nconv=0 first unconverged value (error) -302.035 (2.08580631e-06)
154716 EPS nconv=0 first unconverged value (error) -302.035 (2.00910823e-06)
154717 EPS nconv=0 first unconverged value (error) -302.035 (2.00910823e-06)
154718 EPS nconv=0 first unconverged value (error) -302.035 (3.02932774e-06)
154719 EPS nconv=0 first unconverged value (error) -302.035 (2.72626709e-06)
154720 EPS nconv=0 first unconverged value (error) -302.035 (2.49956075e-06)
154721 EPS nconv=0 first unconverged value (error) -302.035 (2.42439283e-06)
154722 EPS nconv=0 first unconverged value (error) -302.035 (2.32194582e-06)
154723 EPS nconv=0 first unconverged value (error) -302.035 (2.32194582e-06)
154724 EPS nconv=0 first unconverged value (error) -302.035 (2.69632508e-06)
154725 EPS nconv=0 first unconverged value (error) -302.035 (2.89841654e-06)
154726 EPS nconv=0 first unconverged value (error) -302.035 (2.41233369e-06)
154727 EPS nconv=0 first unconverged value (error) -302.035 (2.24917232e-06)
154728 EPS nconv=0 first unconverged value (error) -302.035 (2.15673320e-06)
154729 EPS nconv=0 first unconverged value (error) -302.035 (2.15673320e-06)
154730 EPS nconv=0 first unconverged value (error) -302.035 (2.44227788e-06)
154731 EPS nconv=0 first unconverged value (error) -302.035 (2.45699095e-06)
154732 EPS nconv=0 first unconverged value (error) -302.035 (2.25643360e-06)
154733 EPS nconv=0 first unconverged value (error) -302.035 (2.08883750e-06)
154734 EPS nconv=0 first unconverged value (error) -302.035 (2.00610381e-06)
154735 EPS nconv=0 first unconverged value (error) -302.035 (2.00610381e-06)
154736 EPS nconv=0 first unconverged value (error) -302.035 (2.01468538e-06)
154737 EPS nconv=0 first unconverged value (error) -302.035 (2.10683465e-06)
154738 EPS nconv=0 first unconverged value (error) -302.035 (1.96793424e-06)
154739 EPS nconv=0 first unconverged value (error) -302.035 (1.89084632e-06)
154740 EPS nconv=0 first unconverged value (error) -302.035 (1.85984243e-06)
154741 EPS nconv=0 first unconverged value (error) -302.035 (1.85984243e-06)
154742 EPS nconv=0 first unconverged value (error) -302.035 (1.90916095e-06)
154743 EPS nconv=0 first unconverged value (error) -302.035 (1.87140621e-06)
154744 EPS nconv=0 first unconverged value (error) -302.035 (1.85664930e-06)
154745 EPS nconv=0 first unconverged value (error) -302.035 (1.85114756e-06)
154746 EPS nconv=0 first unconverged value (error) -302.035 (1.83777008e-06)
154747 EPS nconv=0 first unconverged value (error) -302.035 (1.83777008e-06)
154748 EPS nconv=0 first unconverged value (error) -302.035 (2.04628181e-06)
154749 EPS nconv=0 first unconverged value (error) -302.035 (2.02320137e-06)
154750 EPS nconv=0 first unconverged value (error) -302.035 (1.95402730e-06)
154751 EPS nconv=0 first unconverged value (error) -302.035 (1.92226943e-06)
154752 EPS nconv=0 first unconverged value (error) -302.035 (1.89292923e-06)
154753 EPS nconv=0 first unconverged value (error) -302.035 (1.89292923e-06)
154754 EPS nconv=0 first unconverged value (error) -302.035 (2.03442886e-06)
154755 EPS nconv=0 first unconverged value (error) -302.035 (2.01072782e-06)
154756 EPS nconv=0 first unconverged value (error) -302.035 (1.93903100e-06)
154757 EPS nconv=0 first unconverged value (error) -302.035 (1.91919438e-06)
154758 EPS nconv=0 first unconverged value (error) -302.035 (1.89496283e-06)
154759 EPS nconv=0 first unconverged value (error) -302.035 (1.89496283e-06)
154760 EPS nconv=0 first unconverged value (error) -302.035 (1.88196260e-06)
154761 EPS nconv=0 first unconverged value (error) -302.035 (1.89430583e-06)
154762 EPS nconv=0 first unconverged value (error) -302.035 (1.85518161e-06)
154763 EPS nconv=0 first unconverged value (error) -302.035 (1.83100533e-06)
154764 EPS nconv=0 first unconverged value (error) -302.035 (1.81992174e-06)
154765 EPS nconv=0 first unconverged value (error) -302.035 (1.81992174e-06)
154766 EPS nconv=0 first unconverged value (error) -302.035 (1.98564603e-06)
154767 EPS nconv=0 first unconverged value (error) -302.035 (1.92483328e-06)
154768 EPS nconv=0 first unconverged value (error) -302.035 (1.90014330e-06)
154769 EPS nconv=0 first unconverged value (error) -302.035 (1.88130530e-06)
154770 EPS nconv=0 first unconverged value (error) -302.035 (1.86500596e-06)
154771 EPS nconv=0 first unconverged value (error) -302.035 (1.86500596e-06)
154772 EPS nconv=0 first unconverged value (error) -302.035 (2.06367437e-06)
154773 EPS nconv=0 first unconverged value (error) -302.035 (2.04020954e-06)
154774 EPS nconv=0 first unconverged value (error) -302.035 (1.96250680e-06)
154775 EPS nconv=0 first unconverged value (error) -302.035 (1.95753226e-06)
154776 EPS nconv=0 first unconverged value (error) -302.035 (1.94219601e-06)
154777 EPS nconv=0 first unconverged value (error) -302.035 (1.94219601e-06)
154778 EPS nconv=0 first unconverged value (error) -302.035 (2.64930765e-06)
154779 EPS nconv=0 first unconverged value (error) -302.035 (2.53294701e-06)
154780 EPS nconv=0 first unconverged value (error) -302.035 (2.35204327e-06)
154781 EPS nconv=0 first unconverged value (error) -302.035 (2.21789219e-06)
154782 EPS nconv=0 first unconverged value (error) -302.035 (2.18875382e-06)
154783 EPS nconv=0 first unconverged value (error) -302.035 (2.18875382e-06)
154784 EPS nconv=0 first unconverged value (error) -302.035 (3.01468383e-06)
154785 EPS nconv=0 first unconverged value (error) -302.035 (2.67335657e-06)
154786 EPS nconv=0 first unconverged value (error) -302.035 (2.49808701e-06)
154787 EPS nconv=0 first unconverged value (error) -302.035 (2.44073273e-06)
154788 EPS nconv=0 first unconverged value (error) -302.035 (2.36631263e-06)
154789 EPS nconv=0 first unconverged value (error) -302.035 (2.36631263e-06)
154790 EPS nconv=0 first unconverged value (error) -302.035 (2.47701943e-06)
154791 EPS nconv=0 first unconverged value (error) -302.035 (2.46212154e-06)
154792 EPS nconv=0 first unconverged value (error) -302.035 (2.10156778e-06)
154793 EPS nconv=0 first unconverged value (error) -302.035 (2.09609827e-06)
154794 EPS nconv=0 first unconverged value (error) -302.035 (1.94371707e-06)
154795 EPS nconv=0 first unconverged value (error) -302.035 (1.94371707e-06)
154796 EPS nconv=0 first unconverged value (error) -302.035 (1.91247757e-06)
154797 EPS nconv=0 first unconverged value (error) -302.035 (1.96433831e-06)
154798 EPS nconv=0 first unconverged value (error) -302.035 (1.92519148e-06)
154799 EPS nconv=0 first unconverged value (error) -302.035 (1.84596048e-06)
154800 EPS nconv=0 first unconverged value (error) -302.035 (1.82201078e-06)
154801 EPS nconv=0 first unconverged value (error) -302.035 (1.82201078e-06)
154802 EPS nconv=0 first unconverged value (error) -302.035 (1.81518158e-06)
154803 EPS nconv=0 first unconverged value (error) -302.035 (1.81953284e-06)
154804 EPS nconv=0 first unconverged value (error) -302.035 (1.81115808e-06)
154805 EPS nconv=0 first unconverged value (error) -302.035 (1.80398078e-06)
154806 EPS nconv=0 first unconverged value (error) -302.035 (1.80084300e-06)
154807 EPS nconv=0 first unconverged value (error) -302.035 (1.80084300e-06)
154808 EPS nconv=0 first unconverged value (error) -302.035 (1.85476022e-06)
154809 EPS nconv=0 first unconverged value (error) -302.035 (1.83934063e-06)
154810 EPS nconv=0 first unconverged value (error) -302.035 (1.83149210e-06)
154811 EPS nconv=0 first unconverged value (error) -302.035 (1.82505131e-06)
154812 EPS nconv=0 first unconverged value (error) -302.035 (1.81960554e-06)
154813 EPS nconv=0 first unconverged value (error) -302.035 (1.81960554e-06)
154814 EPS nconv=0 first unconverged value (error) -302.035 (2.13494856e-06)
154815 EPS nconv=0 first unconverged value (error) -302.035 (2.02279204e-06)
154816 EPS nconv=0 first unconverged value (error) -302.035 (1.95215727e-06)
154817 EPS nconv=0 first unconverged value (error) -302.035 (1.93794841e-06)
154818 EPS nconv=0 first unconverged value (error) -302.035 (1.91911383e-06)
154819 EPS nconv=0 first unconverged value (error) -302.035 (1.91911383e-06)
154820 EPS nconv=0 first unconverged value (error) -302.035 (1.93900471e-06)
154821 EPS nconv=0 first unconverged value (error) -302.035 (2.00636315e-06)
154822 EPS nconv=0 first unconverged value (error) -302.035 (1.89297748e-06)
154823 EPS nconv=0 first unconverged value (error) -302.035 (1.84690270e-06)
154824 EPS nconv=0 first unconverged value (error) -302.035 (1.83131243e-06)
154825 EPS nconv=0 first unconverged value (error) -302.035 (1.83131243e-06)
154826 EPS nconv=0 first unconverged value (error) -302.035 (1.86167774e-06)
154827 EPS nconv=0 first unconverged value (error) -302.035 (1.85298535e-06)
154828 EPS nconv=0 first unconverged value (error) -302.035 (1.83483586e-06)
154829 EPS nconv=0 first unconverged value (error) -302.035 (1.82027521e-06)
154830 EPS nconv=0 first unconverged value (error) -302.035 (1.81238260e-06)
154831 EPS nconv=0 first unconverged value (error) -302.035 (1.81238260e-06)
154832 EPS nconv=0 first unconverged value (error) -302.035 (2.27369830e-06)
154833 EPS nconv=0 first unconverged value (error) -302.035 (2.10491450e-06)
154834 EPS nconv=0 first unconverged value (error) -302.035 (2.04847129e-06)
154835 EPS nconv=0 first unconverged value (error) -302.035 (2.01208368e-06)
154836 EPS nconv=0 first unconverged value (error) -302.035 (1.99047148e-06)
154837 EPS nconv=0 first unconverged value (error) -302.035 (1.99047148e-06)
154838 EPS nconv=0 first unconverged value (error) -302.035 (2.63463245e-06)
154839 EPS nconv=0 first unconverged value (error) -302.035 (2.48867488e-06)
154840 EPS nconv=0 first unconverged value (error) -302.035 (2.24180845e-06)
154841 EPS nconv=0 first unconverged value (error) -302.035 (2.26495138e-06)
154842 EPS nconv=0 first unconverged value (error) -302.035 (2.17235654e-06)
154843 EPS nconv=0 first unconverged value (error) -302.035 (2.17235654e-06)
154844 EPS nconv=0 first unconverged value (error) -302.035 (2.35183793e-06)
154845 EPS nconv=0 first unconverged value (error) -302.035 (2.53942964e-06)
154846 EPS nconv=0 first unconverged value (error) -302.035 (2.24662720e-06)
154847 EPS nconv=0 first unconverged value (error) -302.035 (2.00438987e-06)
154848 EPS nconv=0 first unconverged value (error) -302.035 (1.93199612e-06)
154849 EPS nconv=0 first unconverged value (error) -302.035 (1.93199612e-06)
154850 EPS nconv=0 first unconverged value (error) -302.035 (2.36503478e-06)
154851 EPS nconv=0 first unconverged value (error) -302.035 (2.22771229e-06)
154852 EPS nconv=0 first unconverged value (error) -302.035 (2.13974794e-06)
154853 EPS nconv=0 first unconverged value (error) -302.035 (2.09147433e-06)
154854 EPS nconv=0 first unconverged value (error) -302.035 (2.05180387e-06)
154855 EPS nconv=0 first unconverged value (error) -302.035 (2.05180387e-06)
154856 EPS nconv=0 first unconverged value (error) -302.035 (2.02728509e-06)
154857 EPS nconv=0 first unconverged value (error) -302.035 (2.17817371e-06)
154858 EPS nconv=0 first unconverged value (error) -302.035 (1.96620870e-06)
154859 EPS nconv=0 first unconverged value (error) -302.035 (1.87207640e-06)
154860 EPS nconv=0 first unconverged value (error) -302.035 (1.84628910e-06)
154861 EPS nconv=0 first unconverged value (error) -302.035 (1.84628910e-06)
154862 EPS nconv=0 first unconverged value (error) -302.035 (2.64029261e-06)
154863 EPS nconv=0 first unconverged value (error) -302.035 (2.38996141e-06)
154864 EPS nconv=0 first unconverged value (error) -302.035 (2.25593036e-06)
154865 EPS nconv=0 first unconverged value (error) -302.035 (2.19176090e-06)
154866 EPS nconv=0 first unconverged value (error) -302.035 (2.13018388e-06)
154867 EPS nconv=0 first unconverged value (error) -302.035 (2.13018388e-06)
154868 EPS nconv=0 first unconverged value (error) -302.035 (3.93720618e-06)
154869 EPS nconv=0 first unconverged value (error) -302.035 (3.85703956e-06)
154870 EPS nconv=0 first unconverged value (error) -302.035 (3.52015980e-06)
154871 EPS nconv=0 first unconverged value (error) -302.035 (3.44888257e-06)
154872 EPS nconv=0 first unconverged value (error) -302.035 (3.39648546e-06)
154873 EPS nconv=0 first unconverged value (error) -302.035 (3.39648546e-06)
154874 EPS nconv=0 first unconverged value (error) -302.035 (3.31254544e-06)
154875 EPS nconv=0 first unconverged value (error) -302.035 (2.81740461e-06)
154876 EPS nconv=0 first unconverged value (error) -302.035 (2.71996242e-06)
154877 EPS nconv=0 first unconverged value (error) -302.035 (2.19551664e-06)
154878 EPS nconv=0 first unconverged value (error) -302.035 (1.98012223e-06)
154879 EPS nconv=0 first unconverged value (error) -302.035 (1.98012223e-06)
154880 EPS nconv=0 first unconverged value (error) -302.035 (2.01864748e-06)
154881 EPS nconv=0 first unconverged value (error) -302.035 (1.91435738e-06)
154882 EPS nconv=0 first unconverged value (error) -302.035 (1.86646333e-06)
154883 EPS nconv=0 first unconverged value (error) -302.035 (1.84359323e-06)
154884 EPS nconv=0 first unconverged value (error) -302.035 (1.83551370e-06)
154885 EPS nconv=0 first unconverged value (error) -302.035 (1.83551370e-06)
154886 EPS nconv=0 first unconverged value (error) -302.035 (2.76672523e-06)
154887 EPS nconv=0 first unconverged value (error) -302.035 (2.58282374e-06)
154888 EPS nconv=0 first unconverged value (error) -302.035 (2.44810874e-06)
154889 EPS nconv=0 first unconverged value (error) -302.035 (2.43583337e-06)
154890 EPS nconv=0 first unconverged value (error) -302.035 (2.40739356e-06)
154891 EPS nconv=0 first unconverged value (error) -302.035 (2.40739356e-06)
154892 EPS nconv=0 first unconverged value (error) -302.035 (2.87927558e-06)
154893 EPS nconv=0 first unconverged value (error) -302.035 (2.55578427e-06)
154894 EPS nconv=0 first unconverged value (error) -302.035 (2.22875495e-06)
154895 EPS nconv=0 first unconverged value (error) -302.035 (2.17118582e-06)
154896 EPS nconv=0 first unconverged value (error) -302.035 (2.12192398e-06)
154897 EPS nconv=0 first unconverged value (error) -302.035 (2.12192398e-06)
154898 EPS nconv=0 first unconverged value (error) -302.035 (2.28284370e-06)
154899 EPS nconv=0 first unconverged value (error) -302.035 (2.37793591e-06)
154900 EPS nconv=0 first unconverged value (error) -302.035 (2.13656743e-06)
154901 EPS nconv=0 first unconverged value (error) -302.035 (2.01666886e-06)
154902 EPS nconv=0 first unconverged value (error) -302.035 (1.94416635e-06)
154903 EPS nconv=0 first unconverged value (error) -302.035 (1.94416635e-06)
154904 EPS nconv=0 first unconverged value (error) -302.035 (2.04425760e-06)
154905 EPS nconv=0 first unconverged value (error) -302.035 (2.11649010e-06)
154906 EPS nconv=0 first unconverged value (error) -302.035 (2.03821547e-06)
154907 EPS nconv=0 first unconverged value (error) -302.035 (1.89360432e-06)
154908 EPS nconv=0 first unconverged value (error) -302.035 (1.86658161e-06)
154909 EPS nconv=0 first unconverged value (error) -302.035 (1.86658161e-06)
154910 EPS nconv=0 first unconverged value (error) -302.035 (1.89660331e-06)
154911 EPS nconv=0 first unconverged value (error) -302.035 (1.89138329e-06)
154912 EPS nconv=0 first unconverged value (error) -302.035 (1.86048851e-06)
154913 EPS nconv=0 first unconverged value (error) -302.035 (1.82391032e-06)
154914 EPS nconv=0 first unconverged value (error) -302.035 (1.81666952e-06)
154915 EPS nconv=0 first unconverged value (error) -302.035 (1.81666952e-06)
154916 EPS nconv=0 first unconverged value (error) -302.035 (1.81080326e-06)
154917 EPS nconv=0 first unconverged value (error) -302.035 (1.80534325e-06)
154918 EPS nconv=0 first unconverged value (error) -302.035 (1.79942759e-06)
154919 EPS nconv=0 first unconverged value (error) -302.035 (1.79663172e-06)
154920 EPS nconv=0 first unconverged value (error) -302.035 (1.79616148e-06)
154921 EPS nconv=0 first unconverged value (error) -302.035 (1.79616148e-06)
154922 EPS nconv=0 first unconverged value (error) -302.035 (2.27609354e-06)
154923 EPS nconv=0 first unconverged value (error) -302.035 (2.07775991e-06)
154924 EPS nconv=0 first unconverged value (error) -302.035 (2.00871120e-06)
154925 EPS nconv=0 first unconverged value (error) -302.035 (1.97828315e-06)
154926 EPS nconv=0 first unconverged value (error) -302.035 (1.95380748e-06)
154927 EPS nconv=0 first unconverged value (error) -302.035 (1.95380748e-06)
154928 EPS nconv=0 first unconverged value (error) -302.035 (3.24565029e-06)
154929 EPS nconv=0 first unconverged value (error) -302.035 (2.90194049e-06)
154930 EPS nconv=0 first unconverged value (error) -302.035 (2.57728479e-06)
154931 EPS nconv=0 first unconverged value (error) -302.035 (2.55342455e-06)
154932 EPS nconv=0 first unconverged value (error) -302.035 (2.50058785e-06)
154933 EPS nconv=0 first unconverged value (error) -302.035 (2.50058785e-06)
154934 EPS nconv=0 first unconverged value (error) -302.035 (3.00010753e-06)
154935 EPS nconv=0 first unconverged value (error) -302.035 (2.89097170e-06)
154936 EPS nconv=0 first unconverged value (error) -302.035 (2.44380118e-06)
154937 EPS nconv=0 first unconverged value (error) -302.035 (2.27635837e-06)
154938 EPS nconv=0 first unconverged value (error) -302.035 (2.20853190e-06)
154939 EPS nconv=0 first unconverged value (error) -302.035 (2.20853190e-06)
154940 EPS nconv=0 first unconverged value (error) -302.035 (2.14972214e-06)
154941 EPS nconv=0 first unconverged value (error) -302.035 (2.36178447e-06)
154942 EPS nconv=0 first unconverged value (error) -302.035 (2.07016837e-06)
154943 EPS nconv=0 first unconverged value (error) -302.035 (1.90638549e-06)
154944 EPS nconv=0 first unconverged value (error) -302.035 (1.85885857e-06)
154945 EPS nconv=0 first unconverged value (error) -302.035 (1.85885857e-06)
154946 EPS nconv=0 first unconverged value (error) -302.035 (1.90663776e-06)
154947 EPS nconv=0 first unconverged value (error) -302.035 (1.88086473e-06)
154948 EPS nconv=0 first unconverged value (error) -302.035 (1.84331807e-06)
154949 EPS nconv=0 first unconverged value (error) -302.035 (1.83605932e-06)
154950 EPS nconv=0 first unconverged value (error) -302.035 (1.83184671e-06)
154951 EPS nconv=0 first unconverged value (error) -302.035 (1.83184671e-06)
154952 EPS nconv=0 first unconverged value (error) -302.035 (2.05396742e-06)
154953 EPS nconv=0 first unconverged value (error) -302.035 (1.95748583e-06)
154954 EPS nconv=0 first unconverged value (error) -302.035 (1.91277077e-06)
154955 EPS nconv=0 first unconverged value (error) -302.035 (1.91249562e-06)
154956 EPS nconv=0 first unconverged value (error) -302.035 (1.90889197e-06)
154957 EPS nconv=0 first unconverged value (error) -302.035 (1.90889197e-06)
154958 EPS nconv=0 first unconverged value (error) -302.035 (2.78139324e-06)
154959 EPS nconv=0 first unconverged value (error) -302.035 (2.48463894e-06)
154960 EPS nconv=0 first unconverged value (error) -302.035 (2.20749325e-06)
154961 EPS nconv=0 first unconverged value (error) -302.035 (2.22543541e-06)
154962 EPS nconv=0 first unconverged value (error) -302.035 (2.16128416e-06)
154963 EPS nconv=0 first unconverged value (error) -302.035 (2.16128416e-06)
154964 EPS nconv=0 first unconverged value (error) -302.035 (2.24824597e-06)
154965 EPS nconv=0 first unconverged value (error) -302.035 (2.56018214e-06)
154966 EPS nconv=0 first unconverged value (error) -302.035 (2.19766382e-06)
154967 EPS nconv=0 first unconverged value (error) -302.035 (1.99193750e-06)
154968 EPS nconv=0 first unconverged value (error) -302.035 (1.94768165e-06)
154969 EPS nconv=0 first unconverged value (error) -302.035 (1.94768165e-06)
154970 EPS nconv=0 first unconverged value (error) -302.035 (1.89034918e-06)
154971 EPS nconv=0 first unconverged value (error) -302.035 (1.89780379e-06)
154972 EPS nconv=0 first unconverged value (error) -302.035 (1.89986252e-06)
154973 EPS nconv=0 first unconverged value (error) -302.035 (1.81250805e-06)
154974 EPS nconv=0 first unconverged value (error) -302.035 (1.80946262e-06)
154975 EPS nconv=0 first unconverged value (error) -302.035 (1.80946262e-06)
154976 EPS nconv=0 first unconverged value (error) -302.035 (1.81859309e-06)
154977 EPS nconv=0 first unconverged value (error) -302.035 (1.80990323e-06)
154978 EPS nconv=0 first unconverged value (error) -302.035 (1.80575608e-06)
154979 EPS nconv=0 first unconverged value (error) -302.035 (1.80122845e-06)
154980 EPS nconv=0 first unconverged value (error) -302.035 (1.80062113e-06)
154981 EPS nconv=0 first unconverged value (error) -302.035 (1.80062113e-06)
154982 EPS nconv=0 first unconverged value (error) -302.035 (1.80424799e-06)
154983 EPS nconv=0 first unconverged value (error) -302.035 (1.81528494e-06)
154984 EPS nconv=0 first unconverged value (error) -302.035 (1.80392044e-06)
154985 EPS nconv=0 first unconverged value (error) -302.035 (1.79763000e-06)
154986 EPS nconv=0 first unconverged value (error) -302.035 (1.79590028e-06)
154987 EPS nconv=0 first unconverged value (error) -302.035 (1.79590028e-06)
154988 EPS nconv=0 first unconverged value (error) -302.035 (1.81264070e-06)
154989 EPS nconv=0 first unconverged value (error) -302.035 (1.80873531e-06)
154990 EPS nconv=0 first unconverged value (error) -302.035 (1.80598585e-06)
154991 EPS nconv=0 first unconverged value (error) -302.035 (1.80555513e-06)
154992 EPS nconv=0 first unconverged value (error) -302.035 (1.80326066e-06)
154993 EPS nconv=0 first unconverged value (error) -302.035 (1.80326066e-06)
154994 EPS nconv=0 first unconverged value (error) -302.035 (1.94050737e-06)
154995 EPS nconv=0 first unconverged value (error) -302.035 (1.91311499e-06)
154996 EPS nconv=0 first unconverged value (error) -302.035 (1.88362469e-06)
154997 EPS nconv=0 first unconverged value (error) -302.035 (1.87422513e-06)
154998 EPS nconv=0 first unconverged value (error) -302.035 (1.86827110e-06)
154999 EPS nconv=0 first unconverged value (error) -302.035 (1.86827110e-06)
155000 EPS nconv=0 first unconverged value (error) -302.035 (2.01694760e-06)
155001 EPS nconv=0 first unconverged value (error) -302.035 (1.93867118e-06)
155002 EPS nconv=0 first unconverged value (error) -302.035 (1.89816406e-06)
155003 EPS nconv=0 first unconverged value (error) -302.035 (1.88421306e-06)
155004 EPS nconv=0 first unconverged value (error) -302.035 (1.87158333e-06)
155005 EPS nconv=0 first unconverged value (error) -302.035 (1.87158333e-06)
155006 EPS nconv=0 first unconverged value (error) -302.035 (1.86779410e-06)
155007 EPS nconv=0 first unconverged value (error) -302.035 (1.92098275e-06)
155008 EPS nconv=0 first unconverged value (error) -302.035 (1.83676565e-06)
155009 EPS nconv=0 first unconverged value (error) -302.035 (1.80422287e-06)
155010 EPS nconv=0 first unconverged value (error) -302.035 (1.80130971e-06)
155011 EPS nconv=0 first unconverged value (error) -302.035 (1.80130971e-06)
155012 EPS nconv=0 first unconverged value (error) -302.035 (1.97632613e-06)
155013 EPS nconv=0 first unconverged value (error) -302.035 (1.90558329e-06)
155014 EPS nconv=0 first unconverged value (error) -302.035 (1.89115952e-06)
155015 EPS nconv=0 first unconverged value (error) -302.035 (1.88358084e-06)
155016 EPS nconv=0 first unconverged value (error) -302.035 (1.87732966e-06)
155017 EPS nconv=0 first unconverged value (error) -302.035 (1.87732966e-06)
155018 EPS nconv=0 first unconverged value (error) -302.035 (1.87551926e-06)
155019 EPS nconv=0 first unconverged value (error) -302.035 (1.92703267e-06)
155020 EPS nconv=0 first unconverged value (error) -302.035 (1.84405135e-06)
155021 EPS nconv=0 first unconverged value (error) -302.035 (1.81896944e-06)
155022 EPS nconv=0 first unconverged value (error) -302.035 (1.80704725e-06)
155023 EPS nconv=0 first unconverged value (error) -302.035 (1.80704725e-06)
155024 EPS nconv=0 first unconverged value (error) -302.035 (2.22589793e-06)
155025 EPS nconv=0 first unconverged value (error) -302.035 (2.14325310e-06)
155026 EPS nconv=0 first unconverged value (error) -302.035 (2.02950226e-06)
155027 EPS nconv=0 first unconverged value (error) -302.035 (1.99094250e-06)
155028 EPS nconv=0 first unconverged value (error) -302.035 (1.96597502e-06)
155029 EPS nconv=0 first unconverged value (error) -302.035 (1.96597502e-06)
155030 EPS nconv=0 first unconverged value (error) -302.035 (2.05200727e-06)
155031 EPS nconv=0 first unconverged value (error) -302.035 (2.09524282e-06)
155032 EPS nconv=0 first unconverged value (error) -302.035 (2.00978774e-06)
155033 EPS nconv=0 first unconverged value (error) -302.035 (1.89849114e-06)
155034 EPS nconv=0 first unconverged value (error) -302.035 (1.88316479e-06)
155035 EPS nconv=0 first unconverged value (error) -302.035 (1.88316479e-06)
155036 EPS nconv=0 first unconverged value (error) -302.035 (2.11467897e-06)
155037 EPS nconv=0 first unconverged value (error) -302.035 (2.06027675e-06)
155038 EPS nconv=0 first unconverged value (error) -302.035 (1.96830420e-06)
155039 EPS nconv=0 first unconverged value (error) -302.035 (1.89603452e-06)
155040 EPS nconv=0 first unconverged value (error) -302.035 (1.88527116e-06)
155041 EPS nconv=0 first unconverged value (error) -302.035 (1.88527116e-06)
155042 EPS nconv=0 first unconverged value (error) -302.035 (1.88591357e-06)
155043 EPS nconv=0 first unconverged value (error) -302.035 (1.96927844e-06)
155044 EPS nconv=0 first unconverged value (error) -302.035 (1.88622312e-06)
155045 EPS nconv=0 first unconverged value (error) -302.035 (1.82833432e-06)
155046 EPS nconv=0 first unconverged value (error) -302.035 (1.80375467e-06)
155047 EPS nconv=0 first unconverged value (error) -302.035 (1.80375467e-06)
155048 EPS nconv=0 first unconverged value (error) -302.035 (1.85570931e-06)
155049 EPS nconv=0 first unconverged value (error) -302.035 (1.84701543e-06)
155050 EPS nconv=0 first unconverged value (error) -302.035 (1.84033102e-06)
155051 EPS nconv=0 first unconverged value (error) -302.035 (1.83636758e-06)
155052 EPS nconv=0 first unconverged value (error) -302.035 (1.83030524e-06)
155053 EPS nconv=0 first unconverged value (error) -302.035 (1.83030524e-06)
155054 EPS nconv=0 first unconverged value (error) -302.035 (1.83120573e-06)
155055 EPS nconv=0 first unconverged value (error) -302.035 (1.82499311e-06)
155056 EPS nconv=0 first unconverged value (error) -302.035 (1.81489456e-06)
155057 EPS nconv=0 first unconverged value (error) -302.035 (1.80060599e-06)
155058 EPS nconv=0 first unconverged value (error) -302.035 (1.79976739e-06)
155059 EPS nconv=0 first unconverged value (error) -302.035 (1.79976739e-06)
155060 EPS nconv=0 first unconverged value (error) -302.035 (1.80047927e-06)
155061 EPS nconv=0 first unconverged value (error) -302.035 (1.79859937e-06)
155062 EPS nconv=0 first unconverged value (error) -302.035 (1.79766798e-06)
155063 EPS nconv=0 first unconverged value (error) -302.035 (1.79632001e-06)
155064 EPS nconv=0 first unconverged value (error) -302.035 (1.79580745e-06)
155065 EPS nconv=0 first unconverged value (error) -302.035 (1.79580745e-06)
155066 EPS nconv=0 first unconverged value (error) -302.035 (1.98476396e-06)
155067 EPS nconv=0 first unconverged value (error) -302.035 (1.90300676e-06)
155068 EPS nconv=0 first unconverged value (error) -302.035 (1.87781925e-06)
155069 EPS nconv=0 first unconverged value (error) -302.035 (1.86025471e-06)
155070 EPS nconv=0 first unconverged value (error) -302.035 (1.85568446e-06)
155071 EPS nconv=0 first unconverged value (error) -302.035 (1.85568446e-06)
155072 EPS nconv=0 first unconverged value (error) -302.035 (1.96038727e-06)
155073 EPS nconv=0 first unconverged value (error) -302.035 (1.96852137e-06)
155074 EPS nconv=0 first unconverged value (error) -302.035 (1.89460693e-06)
155075 EPS nconv=0 first unconverged value (error) -302.035 (1.88562369e-06)
155076 EPS nconv=0 first unconverged value (error) -302.035 (1.87576481e-06)
155077 EPS nconv=0 first unconverged value (error) -302.035 (1.87576481e-06)
155078 EPS nconv=0 first unconverged value (error) -302.035 (2.01332327e-06)
155079 EPS nconv=0 first unconverged value (error) -302.035 (2.00116008e-06)
155080 EPS nconv=0 first unconverged value (error) -302.035 (1.92005690e-06)
155081 EPS nconv=0 first unconverged value (error) -302.035 (1.87783142e-06)
155082 EPS nconv=0 first unconverged value (error) -302.035 (1.85498979e-06)
155083 EPS nconv=0 first unconverged value (error) -302.035 (1.85498979e-06)
155084 EPS nconv=0 first unconverged value (error) -302.035 (1.96682393e-06)
155085 EPS nconv=0 first unconverged value (error) -302.035 (1.96379751e-06)
155086 EPS nconv=0 first unconverged value (error) -302.035 (1.92165159e-06)
155087 EPS nconv=0 first unconverged value (error) -302.035 (1.85782507e-06)
155088 EPS nconv=0 first unconverged value (error) -302.035 (1.84802863e-06)
155089 EPS nconv=0 first unconverged value (error) -302.035 (1.84802863e-06)
155090 EPS nconv=0 first unconverged value (error) -302.035 (1.84518997e-06)
155091 EPS nconv=0 first unconverged value (error) -302.035 (1.88535061e-06)
155092 EPS nconv=0 first unconverged value (error) -302.035 (1.83746427e-06)
155093 EPS nconv=0 first unconverged value (error) -302.035 (1.81361661e-06)
155094 EPS nconv=0 first unconverged value (error) -302.035 (1.80860486e-06)
155095 EPS nconv=0 first unconverged value (error) -302.035 (1.80860486e-06)
155096 EPS nconv=0 first unconverged value (error) -302.035 (1.91474632e-06)
155097 EPS nconv=0 first unconverged value (error) -302.035 (1.86769456e-06)
155098 EPS nconv=0 first unconverged value (error) -302.035 (1.85599736e-06)
155099 EPS nconv=0 first unconverged value (error) -302.035 (1.85228290e-06)
155100 EPS nconv=0 first unconverged value (error) -302.035 (1.83939817e-06)
155101 EPS nconv=0 first unconverged value (error) -302.035 (1.83939817e-06)
155102 EPS nconv=0 first unconverged value (error) -302.035 (1.86462048e-06)
155103 EPS nconv=0 first unconverged value (error) -302.035 (1.88661321e-06)
155104 EPS nconv=0 first unconverged value (error) -302.035 (1.83469363e-06)
155105 EPS nconv=0 first unconverged value (error) -302.035 (1.82759849e-06)
155106 EPS nconv=0 first unconverged value (error) -302.035 (1.82890922e-06)
155107 EPS nconv=0 first unconverged value (error) -302.035 (1.82890922e-06)
155108 EPS nconv=0 first unconverged value (error) -302.035 (2.22715180e-06)
155109 EPS nconv=0 first unconverged value (error) -302.035 (2.04254835e-06)
155110 EPS nconv=0 first unconverged value (error) -302.035 (1.97217395e-06)
155111 EPS nconv=0 first unconverged value (error) -302.035 (1.95048667e-06)
155112 EPS nconv=0 first unconverged value (error) -302.035 (1.92188773e-06)
155113 EPS nconv=0 first unconverged value (error) -302.035 (1.92188773e-06)
155114 EPS nconv=0 first unconverged value (error) -302.035 (2.02569702e-06)
155115 EPS nconv=0 first unconverged value (error) -302.035 (2.14662140e-06)
155116 EPS nconv=0 first unconverged value (error) -302.035 (1.95425841e-06)
155117 EPS nconv=0 first unconverged value (error) -302.035 (1.89174407e-06)
155118 EPS nconv=0 first unconverged value (error) -302.035 (1.88651180e-06)
155119 EPS nconv=0 first unconverged value (error) -302.035 (1.88651180e-06)
155120 EPS nconv=0 first unconverged value (error) -302.035 (1.87910819e-06)
155121 EPS nconv=0 first unconverged value (error) -302.035 (1.85583904e-06)
155122 EPS nconv=0 first unconverged value (error) -302.035 (1.83288540e-06)
155123 EPS nconv=0 first unconverged value (error) -302.035 (1.80655211e-06)
155124 EPS nconv=0 first unconverged value (error) -302.035 (1.80242951e-06)
155125 EPS nconv=0 first unconverged value (error) -302.035 (1.80242951e-06)
155126 EPS nconv=0 first unconverged value (error) -302.035 (1.99125076e-06)
155127 EPS nconv=0 first unconverged value (error) -302.035 (1.90765780e-06)
155128 EPS nconv=0 first unconverged value (error) -302.035 (1.88597190e-06)
155129 EPS nconv=0 first unconverged value (error) -302.035 (1.86777524e-06)
155130 EPS nconv=0 first unconverged value (error) -302.035 (1.86259379e-06)
155131 EPS nconv=0 first unconverged value (error) -302.035 (1.86259379e-06)
155132 EPS nconv=0 first unconverged value (error) -302.035 (1.93194612e-06)
155133 EPS nconv=0 first unconverged value (error) -302.035 (2.02786480e-06)
155134 EPS nconv=0 first unconverged value (error) -302.035 (1.91868082e-06)
155135 EPS nconv=0 first unconverged value (error) -302.035 (1.85535407e-06)
155136 EPS nconv=0 first unconverged value (error) -302.035 (1.83707719e-06)
155137 EPS nconv=0 first unconverged value (error) -302.035 (1.83707719e-06)
155138 EPS nconv=0 first unconverged value (error) -302.035 (1.89681882e-06)
155139 EPS nconv=0 first unconverged value (error) -302.035 (1.88003535e-06)
155140 EPS nconv=0 first unconverged value (error) -302.035 (1.86059960e-06)
155141 EPS nconv=0 first unconverged value (error) -302.035 (1.85103866e-06)
155142 EPS nconv=0 first unconverged value (error) -302.035 (1.84005469e-06)
155143 EPS nconv=0 first unconverged value (error) -302.035 (1.84005469e-06)
155144 EPS nconv=0 first unconverged value (error) -302.035 (1.83559521e-06)
155145 EPS nconv=0 first unconverged value (error) -302.035 (1.83089900e-06)
155146 EPS nconv=0 first unconverged value (error) -302.035 (1.81701700e-06)
155147 EPS nconv=0 first unconverged value (error) -302.035 (1.80390792e-06)
155148 EPS nconv=0 first unconverged value (error) -302.035 (1.80335396e-06)
155149 EPS nconv=0 first unconverged value (error) -302.035 (1.80335396e-06)
155150 EPS nconv=0 first unconverged value (error) -302.035 (2.07994508e-06)
155151 EPS nconv=0 first unconverged value (error) -302.035 (1.95425808e-06)
155152 EPS nconv=0 first unconverged value (error) -302.035 (1.92019022e-06)
155153 EPS nconv=0 first unconverged value (error) -302.035 (1.89873131e-06)
155154 EPS nconv=0 first unconverged value (error) -302.035 (1.88491373e-06)
155155 EPS nconv=0 first unconverged value (error) -302.035 (1.88491373e-06)
155156 EPS nconv=0 first unconverged value (error) -302.035 (1.89309027e-06)
155157 EPS nconv=0 first unconverged value (error) -302.035 (1.99590126e-06)
155158 EPS nconv=0 first unconverged value (error) -302.035 (1.88034655e-06)
155159 EPS nconv=0 first unconverged value (error) -302.035 (1.82533230e-06)
155160 EPS nconv=0 first unconverged value (error) -302.035 (1.81337448e-06)
155161 EPS nconv=0 first unconverged value (error) -302.035 (1.81337448e-06)
155162 EPS nconv=0 first unconverged value (error) -302.035 (1.93425177e-06)
155163 EPS nconv=0 first unconverged value (error) -302.035 (1.89666346e-06)
155164 EPS nconv=0 first unconverged value (error) -302.035 (1.87829652e-06)
155165 EPS nconv=0 first unconverged value (error) -302.035 (1.86985031e-06)
155166 EPS nconv=0 first unconverged value (error) -302.035 (1.85973888e-06)
155167 EPS nconv=0 first unconverged value (error) -302.035 (1.85973888e-06)
155168 EPS nconv=0 first unconverged value (error) -302.035 (2.00266091e-06)
155169 EPS nconv=0 first unconverged value (error) -302.035 (1.95311503e-06)
155170 EPS nconv=0 first unconverged value (error) -302.035 (1.89670612e-06)
155171 EPS nconv=0 first unconverged value (error) -302.035 (1.89210821e-06)
155172 EPS nconv=0 first unconverged value (error) -302.035 (1.88198972e-06)
155173 EPS nconv=0 first unconverged value (error) -302.035 (1.88198972e-06)
155174 EPS nconv=0 first unconverged value (error) -302.035 (2.05289997e-06)
155175 EPS nconv=0 first unconverged value (error) -302.035 (2.03746311e-06)
155176 EPS nconv=0 first unconverged value (error) -302.035 (1.94440912e-06)
155177 EPS nconv=0 first unconverged value (error) -302.035 (1.87931230e-06)
155178 EPS nconv=0 first unconverged value (error) -302.035 (1.86340899e-06)
155179 EPS nconv=0 first unconverged value (error) -302.035 (1.86340899e-06)
155180 EPS nconv=0 first unconverged value (error) -302.035 (1.85818861e-06)
155181 EPS nconv=0 first unconverged value (error) -302.035 (1.91309181e-06)
155182 EPS nconv=0 first unconverged value (error) -302.035 (1.86639444e-06)
155183 EPS nconv=0 first unconverged value (error) -302.035 (1.81796414e-06)
155184 EPS nconv=0 first unconverged value (error) -302.035 (1.81037434e-06)
155185 EPS nconv=0 first unconverged value (error) -302.035 (1.81037434e-06)
155186 EPS nconv=0 first unconverged value (error) -302.035 (1.93914326e-06)
155187 EPS nconv=0 first unconverged value (error) -302.035 (1.89221121e-06)
155188 EPS nconv=0 first unconverged value (error) -302.035 (1.88600003e-06)
155189 EPS nconv=0 first unconverged value (error) -302.035 (1.87254531e-06)
155190 EPS nconv=0 first unconverged value (error) -302.035 (1.85379048e-06)
155191 EPS nconv=0 first unconverged value (error) -302.035 (1.85379048e-06)
155192 EPS nconv=0 first unconverged value (error) -302.035 (1.87612941e-06)
155193 EPS nconv=0 first unconverged value (error) -302.035 (1.88815343e-06)
155194 EPS nconv=0 first unconverged value (error) -302.035 (1.83930099e-06)
155195 EPS nconv=0 first unconverged value (error) -302.035 (1.83225037e-06)
155196 EPS nconv=0 first unconverged value (error) -302.035 (1.82329583e-06)
155197 EPS nconv=0 first unconverged value (error) -302.035 (1.82329583e-06)
155198 EPS nconv=0 first unconverged value (error) -302.035 (2.17681841e-06)
155199 EPS nconv=0 first unconverged value (error) -302.035 (2.08744975e-06)
155200 EPS nconv=0 first unconverged value (error) -302.035 (2.00696986e-06)
155201 EPS nconv=0 first unconverged value (error) -302.035 (1.99005674e-06)
155202 EPS nconv=0 first unconverged value (error) -302.035 (1.95382575e-06)
155203 EPS nconv=0 first unconverged value (error) -302.035 (1.95382575e-06)
155204 EPS nconv=0 first unconverged value (error) -302.035 (1.95317592e-06)
155205 EPS nconv=0 first unconverged value (error) -302.035 (2.05265584e-06)
155206 EPS nconv=0 first unconverged value (error) -302.035 (1.95868128e-06)
155207 EPS nconv=0 first unconverged value (error) -302.035 (1.85924918e-06)
155208 EPS nconv=0 first unconverged value (error) -302.035 (1.84025119e-06)
155209 EPS nconv=0 first unconverged value (error) -302.035 (1.84025119e-06)
155210 EPS nconv=0 first unconverged value (error) -302.035 (1.96449127e-06)
155211 EPS nconv=0 first unconverged value (error) -302.035 (1.91192246e-06)
155212 EPS nconv=0 first unconverged value (error) -302.035 (1.89816496e-06)
155213 EPS nconv=0 first unconverged value (error) -302.035 (1.88023078e-06)
155214 EPS nconv=0 first unconverged value (error) -302.035 (1.86242163e-06)
155215 EPS nconv=0 first unconverged value (error) -302.035 (1.86242163e-06)
155216 EPS nconv=0 first unconverged value (error) -302.035 (1.88668952e-06)
155217 EPS nconv=0 first unconverged value (error) -302.035 (1.91577634e-06)
155218 EPS nconv=0 first unconverged value (error) -302.035 (1.85604420e-06)
155219 EPS nconv=0 first unconverged value (error) -302.035 (1.84911962e-06)
155220 EPS nconv=0 first unconverged value (error) -302.035 (1.82805892e-06)
155221 EPS nconv=0 first unconverged value (error) -302.035 (1.82805892e-06)
155222 EPS nconv=0 first unconverged value (error) -302.035 (2.34708977e-06)
155223 EPS nconv=0 first unconverged value (error) -302.035 (2.28719260e-06)
155224 EPS nconv=0 first unconverged value (error) -302.035 (2.16388516e-06)
155225 EPS nconv=0 first unconverged value (error) -302.035 (2.10582897e-06)
155226 EPS nconv=0 first unconverged value (error) -302.035 (2.04701661e-06)
155227 EPS nconv=0 first unconverged value (error) -302.035 (2.04701661e-06)
155228 EPS nconv=0 first unconverged value (error) -302.035 (2.37035416e-06)
155229 EPS nconv=0 first unconverged value (error) -302.035 (2.33346703e-06)
155230 EPS nconv=0 first unconverged value (error) -302.035 (2.19707155e-06)
155231 EPS nconv=0 first unconverged value (error) -302.035 (2.12829712e-06)
155232 EPS nconv=0 first unconverged value (error) -302.035 (2.09833168e-06)
155233 EPS nconv=0 first unconverged value (error) -302.035 (2.09833168e-06)
155234 EPS nconv=0 first unconverged value (error) -302.035 (2.08792702e-06)
155235 EPS nconv=0 first unconverged value (error) -302.035 (2.00391654e-06)
155236 EPS nconv=0 first unconverged value (error) -302.035 (1.96314503e-06)
155237 EPS nconv=0 first unconverged value (error) -302.035 (1.86735093e-06)
155238 EPS nconv=0 first unconverged value (error) -302.035 (1.82231530e-06)
155239 EPS nconv=0 first unconverged value (error) -302.035 (1.82231530e-06)
155240 EPS nconv=0 first unconverged value (error) -302.035 (1.82340098e-06)
155241 EPS nconv=0 first unconverged value (error) -302.035 (1.82872744e-06)
155242 EPS nconv=0 first unconverged value (error) -302.035 (1.81421378e-06)
155243 EPS nconv=0 first unconverged value (error) -302.035 (1.80882980e-06)
155244 EPS nconv=0 first unconverged value (error) -302.035 (1.80707137e-06)
155245 EPS nconv=0 first unconverged value (error) -302.035 (1.80707137e-06)
155246 EPS nconv=0 first unconverged value (error) -302.035 (1.98747179e-06)
155247 EPS nconv=0 first unconverged value (error) -302.035 (1.93063741e-06)
155248 EPS nconv=0 first unconverged value (error) -302.035 (1.90537218e-06)
155249 EPS nconv=0 first unconverged value (error) -302.035 (1.89200073e-06)
155250 EPS nconv=0 first unconverged value (error) -302.035 (1.87645427e-06)
155251 EPS nconv=0 first unconverged value (error) -302.035 (1.87645427e-06)
155252 EPS nconv=0 first unconverged value (error) -302.035 (1.88269808e-06)
155253 EPS nconv=0 first unconverged value (error) -302.035 (1.91399976e-06)
155254 EPS nconv=0 first unconverged value (error) -302.035 (1.85470784e-06)
155255 EPS nconv=0 first unconverged value (error) -302.035 (1.82405754e-06)
155256 EPS nconv=0 first unconverged value (error) -302.035 (1.81634164e-06)
155257 EPS nconv=0 first unconverged value (error) -302.035 (1.81634164e-06)
155258 EPS nconv=0 first unconverged value (error) -302.035 (1.99287207e-06)
155259 EPS nconv=0 first unconverged value (error) -302.035 (1.93282306e-06)
155260 EPS nconv=0 first unconverged value (error) -302.035 (1.90436837e-06)
155261 EPS nconv=0 first unconverged value (error) -302.035 (1.89161200e-06)
155262 EPS nconv=0 first unconverged value (error) -302.035 (1.87368594e-06)
155263 EPS nconv=0 first unconverged value (error) -302.035 (1.87368594e-06)
155264 EPS nconv=0 first unconverged value (error) -302.035 (1.90202601e-06)
155265 EPS nconv=0 first unconverged value (error) -302.035 (1.92925961e-06)
155266 EPS nconv=0 first unconverged value (error) -302.035 (1.86869856e-06)
155267 EPS nconv=0 first unconverged value (error) -302.035 (1.84292659e-06)
155268 EPS nconv=0 first unconverged value (error) -302.035 (1.83058405e-06)
155269 EPS nconv=0 first unconverged value (error) -302.035 (1.83058405e-06)
155270 EPS nconv=0 first unconverged value (error) -302.035 (2.11807730e-06)
155271 EPS nconv=0 first unconverged value (error) -302.035 (2.03777227e-06)
155272 EPS nconv=0 first unconverged value (error) -302.035 (1.98996671e-06)
155273 EPS nconv=0 first unconverged value (error) -302.035 (1.95679836e-06)
155274 EPS nconv=0 first unconverged value (error) -302.035 (1.92263022e-06)
155275 EPS nconv=0 first unconverged value (error) -302.035 (1.92263022e-06)
155276 EPS nconv=0 first unconverged value (error) -302.035 (1.95151564e-06)
155277 EPS nconv=0 first unconverged value (error) -302.035 (2.01160357e-06)
155278 EPS nconv=0 first unconverged value (error) -302.035 (1.91726570e-06)
155279 EPS nconv=0 first unconverged value (error) -302.035 (1.87656968e-06)
155280 EPS nconv=0 first unconverged value (error) -302.035 (1.84781034e-06)
155281 EPS nconv=0 first unconverged value (error) -302.035 (1.84781034e-06)
155282 EPS nconv=0 first unconverged value (error) -302.035 (1.96276207e-06)
155283 EPS nconv=0 first unconverged value (error) -302.035 (1.92880470e-06)
155284 EPS nconv=0 first unconverged value (error) -302.035 (1.89994744e-06)
155285 EPS nconv=0 first unconverged value (error) -302.035 (1.88185916e-06)
155286 EPS nconv=0 first unconverged value (error) -302.035 (1.86091868e-06)
155287 EPS nconv=0 first unconverged value (error) -302.035 (1.86091868e-06)
155288 EPS nconv=0 first unconverged value (error) -302.035 (1.89898820e-06)
155289 EPS nconv=0 first unconverged value (error) -302.035 (1.90236397e-06)
155290 EPS nconv=0 first unconverged value (error) -302.035 (1.86346774e-06)
155291 EPS nconv=0 first unconverged value (error) -302.035 (1.84700809e-06)
155292 EPS nconv=0 first unconverged value (error) -302.035 (1.82890809e-06)
155293 EPS nconv=0 first unconverged value (error) -302.035 (1.82890809e-06)
155294 EPS nconv=0 first unconverged value (error) -302.035 (2.07978382e-06)
155295 EPS nconv=0 first unconverged value (error) -302.035 (2.02440563e-06)
155296 EPS nconv=0 first unconverged value (error) -302.035 (1.97806094e-06)
155297 EPS nconv=0 first unconverged value (error) -302.035 (1.93993216e-06)
155298 EPS nconv=0 first unconverged value (error) -302.035 (1.91393069e-06)
155299 EPS nconv=0 first unconverged value (error) -302.035 (1.91393069e-06)
155300 EPS nconv=0 first unconverged value (error) -302.035 (1.98534297e-06)
155301 EPS nconv=0 first unconverged value (error) -302.035 (2.02786264e-06)
155302 EPS nconv=0 first unconverged value (error) -302.035 (1.93539697e-06)
155303 EPS nconv=0 first unconverged value (error) -302.035 (1.89622961e-06)
155304 EPS nconv=0 first unconverged value (error) -302.035 (1.86526849e-06)
155305 EPS nconv=0 first unconverged value (error) -302.035 (1.86526849e-06)
155306 EPS nconv=0 first unconverged value (error) -302.035 (2.03526661e-06)
155307 EPS nconv=0 first unconverged value (error) -302.035 (1.99479566e-06)
155308 EPS nconv=0 first unconverged value (error) -302.035 (1.94588257e-06)
155309 EPS nconv=0 first unconverged value (error) -302.035 (1.91909625e-06)
155310 EPS nconv=0 first unconverged value (error) -302.035 (1.89060457e-06)
155311 EPS nconv=0 first unconverged value (error) -302.035 (1.89060457e-06)
155312 EPS nconv=0 first unconverged value (error) -302.035 (1.89277516e-06)
155313 EPS nconv=0 first unconverged value (error) -302.035 (1.92194065e-06)
155314 EPS nconv=0 first unconverged value (error) -302.035 (1.87381678e-06)
155315 EPS nconv=0 first unconverged value (error) -302.035 (1.84102508e-06)
155316 EPS nconv=0 first unconverged value (error) -302.035 (1.82516198e-06)
155317 EPS nconv=0 first unconverged value (error) -302.035 (1.82516198e-06)
155318 EPS nconv=0 first unconverged value (error) -302.035 (2.02535969e-06)
155319 EPS nconv=0 first unconverged value (error) -302.035 (1.96234848e-06)
155320 EPS nconv=0 first unconverged value (error) -302.035 (1.93414040e-06)
155321 EPS nconv=0 first unconverged value (error) -302.035 (1.91306710e-06)
155322 EPS nconv=0 first unconverged value (error) -302.035 (1.88656538e-06)
155323 EPS nconv=0 first unconverged value (error) -302.035 (1.88656538e-06)
155324 EPS nconv=0 first unconverged value (error) -302.035 (1.94272681e-06)
155325 EPS nconv=0 first unconverged value (error) -302.035 (1.97434646e-06)
155326 EPS nconv=0 first unconverged value (error) -302.035 (1.89668746e-06)
155327 EPS nconv=0 first unconverged value (error) -302.035 (1.87101141e-06)
155328 EPS nconv=0 first unconverged value (error) -302.035 (1.84972767e-06)
155329 EPS nconv=0 first unconverged value (error) -302.035 (1.84972767e-06)
155330 EPS nconv=0 first unconverged value (error) -302.035 (2.02807166e-06)
155331 EPS nconv=0 first unconverged value (error) -302.035 (1.99832018e-06)
155332 EPS nconv=0 first unconverged value (error) -302.035 (1.94325141e-06)
155333 EPS nconv=0 first unconverged value (error) -302.035 (1.90709735e-06)
155334 EPS nconv=0 first unconverged value (error) -302.035 (1.88131237e-06)
155335 EPS nconv=0 first unconverged value (error) -302.035 (1.88131237e-06)
155336 EPS nconv=0 first unconverged value (error) -302.035 (1.88885697e-06)
155337 EPS nconv=0 first unconverged value (error) -302.035 (1.92601467e-06)
155338 EPS nconv=0 first unconverged value (error) -302.035 (1.87683386e-06)
155339 EPS nconv=0 first unconverged value (error) -302.035 (1.84100981e-06)
155340 EPS nconv=0 first unconverged value (error) -302.035 (1.82331795e-06)
155341 EPS nconv=0 first unconverged value (error) -302.035 (1.82331795e-06)
155342 EPS nconv=0 first unconverged value (error) -302.035 (1.93659211e-06)
155343 EPS nconv=0 first unconverged value (error) -302.035 (1.89313252e-06)
155344 EPS nconv=0 first unconverged value (error) -302.035 (1.87718790e-06)
155345 EPS nconv=0 first unconverged value (error) -302.035 (1.86859741e-06)
155346 EPS nconv=0 first unconverged value (error) -302.035 (1.85049098e-06)
155347 EPS nconv=0 first unconverged value (error) -302.035 (1.85049098e-06)
155348 EPS nconv=0 first unconverged value (error) -302.035 (1.85035746e-06)
155349 EPS nconv=0 first unconverged value (error) -302.035 (1.88817397e-06)
155350 EPS nconv=0 first unconverged value (error) -302.035 (1.84063894e-06)
155351 EPS nconv=0 first unconverged value (error) -302.035 (1.82182681e-06)
155352 EPS nconv=0 first unconverged value (error) -302.035 (1.81161299e-06)
155353 EPS nconv=0 first unconverged value (error) -302.035 (1.81161299e-06)
155354 EPS nconv=0 first unconverged value (error) -302.035 (1.97440515e-06)
155355 EPS nconv=0 first unconverged value (error) -302.035 (1.92534299e-06)
155356 EPS nconv=0 first unconverged value (error) -302.035 (1.89368776e-06)
155357 EPS nconv=0 first unconverged value (error) -302.035 (1.88554731e-06)
155358 EPS nconv=0 first unconverged value (error) -302.035 (1.86470579e-06)
155359 EPS nconv=0 first unconverged value (error) -302.035 (1.86470579e-06)
155360 EPS nconv=0 first unconverged value (error) -302.035 (1.96558658e-06)
155361 EPS nconv=0 first unconverged value (error) -302.035 (1.95406109e-06)
155362 EPS nconv=0 first unconverged value (error) -302.035 (1.89758349e-06)
155363 EPS nconv=0 first unconverged value (error) -302.035 (1.87551210e-06)
155364 EPS nconv=0 first unconverged value (error) -302.035 (1.86598572e-06)
155365 EPS nconv=0 first unconverged value (error) -302.035 (1.86598572e-06)
155366 EPS nconv=0 first unconverged value (error) -302.035 (1.94825030e-06)
155367 EPS nconv=0 first unconverged value (error) -302.035 (1.93598028e-06)
155368 EPS nconv=0 first unconverged value (error) -302.035 (1.88208761e-06)
155369 EPS nconv=0 first unconverged value (error) -302.035 (1.85538643e-06)
155370 EPS nconv=0 first unconverged value (error) -302.035 (1.84067736e-06)
155371 EPS nconv=0 first unconverged value (error) -302.035 (1.84067736e-06)
155372 EPS nconv=0 first unconverged value (error) -302.035 (1.86290968e-06)
155373 EPS nconv=0 first unconverged value (error) -302.035 (1.87600821e-06)
155374 EPS nconv=0 first unconverged value (error) -302.035 (1.83471229e-06)
155375 EPS nconv=0 first unconverged value (error) -302.035 (1.82341924e-06)
155376 EPS nconv=0 first unconverged value (error) -302.035 (1.81853463e-06)
155377 EPS nconv=0 first unconverged value (error) -302.035 (1.81853463e-06)
155378 EPS nconv=0 first unconverged value (error) -302.035 (1.87791456e-06)
155379 EPS nconv=0 first unconverged value (error) -302.035 (1.86889074e-06)
155380 EPS nconv=0 first unconverged value (error) -302.035 (1.84613569e-06)
155381 EPS nconv=0 first unconverged value (error) -302.035 (1.83412934e-06)
155382 EPS nconv=0 first unconverged value (error) -302.035 (1.82411425e-06)
155383 EPS nconv=0 first unconverged value (error) -302.035 (1.82411425e-06)
155384 EPS nconv=0 first unconverged value (error) -302.035 (1.96412643e-06)
155385 EPS nconv=0 first unconverged value (error) -302.035 (1.91730724e-06)
155386 EPS nconv=0 first unconverged value (error) -302.035 (1.88589058e-06)
155387 EPS nconv=0 first unconverged value (error) -302.035 (1.87430680e-06)
155388 EPS nconv=0 first unconverged value (error) -302.035 (1.86302358e-06)
155389 EPS nconv=0 first unconverged value (error) -302.035 (1.86302358e-06)
155390 EPS nconv=0 first unconverged value (error) -302.035 (1.85473457e-06)
155391 EPS nconv=0 first unconverged value (error) -302.035 (1.89940929e-06)
155392 EPS nconv=0 first unconverged value (error) -302.035 (1.83976187e-06)
155393 EPS nconv=0 first unconverged value (error) -302.035 (1.81972192e-06)
155394 EPS nconv=0 first unconverged value (error) -302.035 (1.81312548e-06)
155395 EPS nconv=0 first unconverged value (error) -302.035 (1.81312548e-06)
155396 EPS nconv=0 first unconverged value (error) -302.035 (2.10394647e-06)
155397 EPS nconv=0 first unconverged value (error) -302.035 (2.00541540e-06)
155398 EPS nconv=0 first unconverged value (error) -302.035 (1.95506902e-06)
155399 EPS nconv=0 first unconverged value (error) -302.035 (1.93925847e-06)
155400 EPS nconv=0 first unconverged value (error) -302.035 (1.90832505e-06)
155401 EPS nconv=0 first unconverged value (error) -302.035 (1.90832505e-06)
155402 EPS nconv=0 first unconverged value (error) -302.035 (2.26028858e-06)
155403 EPS nconv=0 first unconverged value (error) -302.035 (2.25293456e-06)
155404 EPS nconv=0 first unconverged value (error) -302.035 (2.11176536e-06)
155405 EPS nconv=0 first unconverged value (error) -302.035 (2.09593467e-06)
155406 EPS nconv=0 first unconverged value (error) -302.035 (2.09197890e-06)
155407 EPS nconv=0 first unconverged value (error) -302.035 (2.09197890e-06)
155408 EPS nconv=0 first unconverged value (error) -302.035 (2.06820483e-06)
155409 EPS nconv=0 first unconverged value (error) -302.035 (1.96766661e-06)
155410 EPS nconv=0 first unconverged value (error) -302.035 (1.91577315e-06)
155411 EPS nconv=0 first unconverged value (error) -302.035 (1.83460352e-06)
155412 EPS nconv=0 first unconverged value (error) -302.035 (1.81698086e-06)
155413 EPS nconv=0 first unconverged value (error) -302.035 (1.81698086e-06)
155414 EPS nconv=0 first unconverged value (error) -302.035 (1.80580893e-06)
155415 EPS nconv=0 first unconverged value (error) -302.035 (1.80193102e-06)
155416 EPS nconv=0 first unconverged value (error) -302.035 (1.79926748e-06)
155417 EPS nconv=0 first unconverged value (error) -302.035 (1.79850916e-06)
155418 EPS nconv=0 first unconverged value (error) -302.035 (1.79820176e-06)
155419 EPS nconv=0 first unconverged value (error) -302.035 (1.79820176e-06)
155420 EPS nconv=0 first unconverged value (error) -302.035 (1.80951305e-06)
155421 EPS nconv=0 first unconverged value (error) -302.035 (1.81318269e-06)
155422 EPS nconv=0 first unconverged value (error) -302.035 (1.80405166e-06)
155423 EPS nconv=0 first unconverged value (error) -302.035 (1.80164182e-06)
155424 EPS nconv=0 first unconverged value (error) -302.035 (1.80069614e-06)
155425 EPS nconv=0 first unconverged value (error) -302.035 (1.80069614e-06)
155426 EPS nconv=0 first unconverged value (error) -302.035 (1.82349669e-06)
155427 EPS nconv=0 first unconverged value (error) -302.035 (1.81816183e-06)
155428 EPS nconv=0 first unconverged value (error) -302.035 (1.81279400e-06)
155429 EPS nconv=0 first unconverged value (error) -302.035 (1.80628970e-06)
155430 EPS nconv=0 first unconverged value (error) -302.035 (1.80239805e-06)
155431 EPS nconv=0 first unconverged value (error) -302.035 (1.80239805e-06)
155432 EPS nconv=0 first unconverged value (error) -302.035 (1.94561291e-06)
155433 EPS nconv=0 first unconverged value (error) -302.035 (1.89141426e-06)
155434 EPS nconv=0 first unconverged value (error) -302.035 (1.86122575e-06)
155435 EPS nconv=0 first unconverged value (error) -302.035 (1.84691089e-06)
155436 EPS nconv=0 first unconverged value (error) -302.035 (1.84485423e-06)
155437 EPS nconv=0 first unconverged value (error) -302.035 (1.84485423e-06)
155438 EPS nconv=0 first unconverged value (error) -302.035 (1.85036103e-06)
155439 EPS nconv=0 first unconverged value (error) -302.035 (1.89863970e-06)
155440 EPS nconv=0 first unconverged value (error) -302.035 (1.83786338e-06)
155441 EPS nconv=0 first unconverged value (error) -302.035 (1.82107502e-06)
155442 EPS nconv=0 first unconverged value (error) -302.035 (1.80372456e-06)
155443 EPS nconv=0 first unconverged value (error) -302.035 (1.80372456e-06)
155444 EPS nconv=0 first unconverged value (error) -302.035 (1.81331282e-06)
155445 EPS nconv=0 first unconverged value (error) -302.035 (1.81468943e-06)
155446 EPS nconv=0 first unconverged value (error) -302.035 (1.80807670e-06)
155447 EPS nconv=0 first unconverged value (error) -302.035 (1.80735797e-06)
155448 EPS nconv=0 first unconverged value (error) -302.035 (1.80399748e-06)
155449 EPS nconv=0 first unconverged value (error) -302.035 (1.80399748e-06)
155450 EPS nconv=0 first unconverged value (error) -302.035 (1.83143901e-06)
155451 EPS nconv=0 first unconverged value (error) -302.035 (1.81739318e-06)
155452 EPS nconv=0 first unconverged value (error) -302.035 (1.81303136e-06)
155453 EPS nconv=0 first unconverged value (error) -302.035 (1.81018299e-06)
155454 EPS nconv=0 first unconverged value (error) -302.035 (1.80666777e-06)
155455 EPS nconv=0 first unconverged value (error) -302.035 (1.80666777e-06)
155456 EPS nconv=0 first unconverged value (error) -302.035 (1.80389230e-06)
155457 EPS nconv=0 first unconverged value (error) -302.035 (1.81441055e-06)
155458 EPS nconv=0 first unconverged value (error) -302.035 (1.79986292e-06)
155459 EPS nconv=0 first unconverged value (error) -302.035 (1.79654532e-06)
155460 EPS nconv=0 first unconverged value (error) -302.035 (1.79652486e-06)
155461 EPS nconv=0 first unconverged value (error) -302.035 (1.79652486e-06)
155462 EPS nconv=0 first unconverged value (error) -302.035 (1.97123286e-06)
155463 EPS nconv=0 first unconverged value (error) -302.035 (1.89005720e-06)
155464 EPS nconv=0 first unconverged value (error) -302.035 (1.87203676e-06)
155465 EPS nconv=0 first unconverged value (error) -302.035 (1.86925483e-06)
155466 EPS nconv=0 first unconverged value (error) -302.035 (1.85466978e-06)
155467 EPS nconv=0 first unconverged value (error) -302.035 (1.85466978e-06)
155468 EPS nconv=0 first unconverged value (error) -302.035 (1.86550410e-06)
155469 EPS nconv=0 first unconverged value (error) -302.035 (1.91462156e-06)
155470 EPS nconv=0 first unconverged value (error) -302.035 (1.83661861e-06)
155471 EPS nconv=0 first unconverged value (error) -302.035 (1.81565396e-06)
155472 EPS nconv=0 first unconverged value (error) -302.035 (1.81703584e-06)
155473 EPS nconv=0 first unconverged value (error) -302.035 (1.81703584e-06)
155474 EPS nconv=0 first unconverged value (error) -302.035 (2.23334332e-06)
155475 EPS nconv=0 first unconverged value (error) -302.035 (2.03334392e-06)
155476 EPS nconv=0 first unconverged value (error) -302.035 (1.98743454e-06)
155477 EPS nconv=0 first unconverged value (error) -302.035 (1.96714861e-06)
155478 EPS nconv=0 first unconverged value (error) -302.035 (1.93408824e-06)
155479 EPS nconv=0 first unconverged value (error) -302.035 (1.93408824e-06)
155480 EPS nconv=0 first unconverged value (error) -302.035 (2.59846514e-06)
155481 EPS nconv=0 first unconverged value (error) -302.035 (2.74048094e-06)
155482 EPS nconv=0 first unconverged value (error) -302.035 (2.40300524e-06)
155483 EPS nconv=0 first unconverged value (error) -302.035 (2.29671830e-06)
155484 EPS nconv=0 first unconverged value (error) -302.035 (2.22947024e-06)
155485 EPS nconv=0 first unconverged value (error) -302.035 (2.22947024e-06)
155486 EPS nconv=0 first unconverged value (error) -302.035 (2.24787524e-06)
155487 EPS nconv=0 first unconverged value (error) -302.035 (2.22389044e-06)
155488 EPS nconv=0 first unconverged value (error) -302.035 (2.28161012e-06)
155489 EPS nconv=0 first unconverged value (error) -302.035 (1.99364645e-06)
155490 EPS nconv=0 first unconverged value (error) -302.035 (1.86542126e-06)
155491 EPS nconv=0 first unconverged value (error) -302.035 (1.86542126e-06)
155492 EPS nconv=0 first unconverged value (error) -302.035 (1.91215477e-06)
155493 EPS nconv=0 first unconverged value (error) -302.035 (1.90718575e-06)
155494 EPS nconv=0 first unconverged value (error) -302.035 (1.90200650e-06)
155495 EPS nconv=0 first unconverged value (error) -302.035 (1.86681938e-06)
155496 EPS nconv=0 first unconverged value (error) -302.035 (1.85526048e-06)
155497 EPS nconv=0 first unconverged value (error) -302.035 (1.85526048e-06)
155498 EPS nconv=0 first unconverged value (error) -302.035 (1.87510585e-06)
155499 EPS nconv=0 first unconverged value (error) -302.035 (1.88342775e-06)
155500 EPS nconv=0 first unconverged value (error) -302.035 (1.84187002e-06)
155501 EPS nconv=0 first unconverged value (error) -302.035 (1.82729852e-06)
155502 EPS nconv=0 first unconverged value (error) -302.035 (1.81954817e-06)
155503 EPS nconv=0 first unconverged value (error) -302.035 (1.81954817e-06)
155504 EPS nconv=0 first unconverged value (error) -302.035 (1.85624322e-06)
155505 EPS nconv=0 first unconverged value (error) -302.035 (1.84977903e-06)
155506 EPS nconv=0 first unconverged value (error) -302.035 (1.83131454e-06)
155507 EPS nconv=0 first unconverged value (error) -302.035 (1.82005931e-06)
155508 EPS nconv=0 first unconverged value (error) -302.035 (1.81496823e-06)
155509 EPS nconv=0 first unconverged value (error) -302.035 (1.81496823e-06)
155510 EPS nconv=0 first unconverged value (error) -302.035 (1.93543154e-06)
155511 EPS nconv=0 first unconverged value (error) -302.035 (1.92736992e-06)
155512 EPS nconv=0 first unconverged value (error) -302.035 (1.89365935e-06)
155513 EPS nconv=0 first unconverged value (error) -302.035 (1.86946885e-06)
155514 EPS nconv=0 first unconverged value (error) -302.035 (1.85820126e-06)
155515 EPS nconv=0 first unconverged value (error) -302.035 (1.85820126e-06)
155516 EPS nconv=0 first unconverged value (error) -302.035 (1.95767187e-06)
155517 EPS nconv=0 first unconverged value (error) -302.035 (1.93081807e-06)
155518 EPS nconv=0 first unconverged value (error) -302.035 (1.89258050e-06)
155519 EPS nconv=0 first unconverged value (error) -302.035 (1.86486567e-06)
155520 EPS nconv=0 first unconverged value (error) -302.035 (1.84822507e-06)
155521 EPS nconv=0 first unconverged value (error) -302.035 (1.84822507e-06)
155522 EPS nconv=0 first unconverged value (error) -302.035 (1.96485216e-06)
155523 EPS nconv=0 first unconverged value (error) -302.035 (1.95723528e-06)
155524 EPS nconv=0 first unconverged value (error) -302.035 (1.88615258e-06)
155525 EPS nconv=0 first unconverged value (error) -302.035 (1.86835132e-06)
155526 EPS nconv=0 first unconverged value (error) -302.035 (1.85857310e-06)
155527 EPS nconv=0 first unconverged value (error) -302.035 (1.85857310e-06)
155528 EPS nconv=0 first unconverged value (error) -302.035 (1.88497400e-06)
155529 EPS nconv=0 first unconverged value (error) -302.035 (1.91294457e-06)
155530 EPS nconv=0 first unconverged value (error) -302.035 (1.86103513e-06)
155531 EPS nconv=0 first unconverged value (error) -302.035 (1.83056684e-06)
155532 EPS nconv=0 first unconverged value (error) -302.035 (1.81849446e-06)
155533 EPS nconv=0 first unconverged value (error) -302.035 (1.81849446e-06)
155534 EPS nconv=0 first unconverged value (error) -302.035 (2.00186825e-06)
155535 EPS nconv=0 first unconverged value (error) -302.035 (1.96687407e-06)
155536 EPS nconv=0 first unconverged value (error) -302.035 (1.93507568e-06)
155537 EPS nconv=0 first unconverged value (error) -302.035 (1.91681489e-06)
155538 EPS nconv=0 first unconverged value (error) -302.035 (1.89302660e-06)
155539 EPS nconv=0 first unconverged value (error) -302.035 (1.89302660e-06)
155540 EPS nconv=0 first unconverged value (error) -302.035 (1.92434845e-06)
155541 EPS nconv=0 first unconverged value (error) -302.035 (1.92717026e-06)
155542 EPS nconv=0 first unconverged value (error) -302.035 (1.87064966e-06)
155543 EPS nconv=0 first unconverged value (error) -302.035 (1.84732474e-06)
155544 EPS nconv=0 first unconverged value (error) -302.035 (1.83370346e-06)
155545 EPS nconv=0 first unconverged value (error) -302.035 (1.83370346e-06)
155546 EPS nconv=0 first unconverged value (error) -302.035 (1.98958306e-06)
155547 EPS nconv=0 first unconverged value (error) -302.035 (1.94341815e-06)
155548 EPS nconv=0 first unconverged value (error) -302.035 (1.89751728e-06)
155549 EPS nconv=0 first unconverged value (error) -302.035 (1.88187155e-06)
155550 EPS nconv=0 first unconverged value (error) -302.035 (1.86722516e-06)
155551 EPS nconv=0 first unconverged value (error) -302.035 (1.86722516e-06)
155552 EPS nconv=0 first unconverged value (error) -302.035 (1.89930341e-06)
155553 EPS nconv=0 first unconverged value (error) -302.035 (1.93705758e-06)
155554 EPS nconv=0 first unconverged value (error) -302.035 (1.87475451e-06)
155555 EPS nconv=0 first unconverged value (error) -302.035 (1.83741443e-06)
155556 EPS nconv=0 first unconverged value (error) -302.035 (1.82182720e-06)
155557 EPS nconv=0 first unconverged value (error) -302.035 (1.82182720e-06)
155558 EPS nconv=0 first unconverged value (error) -302.035 (1.98445563e-06)
155559 EPS nconv=0 first unconverged value (error) -302.035 (1.95176763e-06)
155560 EPS nconv=0 first unconverged value (error) -302.035 (1.92359937e-06)
155561 EPS nconv=0 first unconverged value (error) -302.035 (1.90635853e-06)
155562 EPS nconv=0 first unconverged value (error) -302.035 (1.88312747e-06)
155563 EPS nconv=0 first unconverged value (error) -302.035 (1.88312747e-06)
155564 EPS nconv=0 first unconverged value (error) -302.035 (1.91392370e-06)
155565 EPS nconv=0 first unconverged value (error) -302.035 (1.91559905e-06)
155566 EPS nconv=0 first unconverged value (error) -302.035 (1.86383331e-06)
155567 EPS nconv=0 first unconverged value (error) -302.035 (1.84521238e-06)
155568 EPS nconv=0 first unconverged value (error) -302.035 (1.83257473e-06)
155569 EPS nconv=0 first unconverged value (error) -302.035 (1.83257473e-06)
155570 EPS nconv=0 first unconverged value (error) -302.035 (1.93669930e-06)
155571 EPS nconv=0 first unconverged value (error) -302.035 (1.90784681e-06)
155572 EPS nconv=0 first unconverged value (error) -302.035 (1.87210160e-06)
155573 EPS nconv=0 first unconverged value (error) -302.035 (1.85726766e-06)
155574 EPS nconv=0 first unconverged value (error) -302.035 (1.84662721e-06)
155575 EPS nconv=0 first unconverged value (error) -302.035 (1.84662721e-06)
155576 EPS nconv=0 first unconverged value (error) -302.035 (1.87988141e-06)
155577 EPS nconv=0 first unconverged value (error) -302.035 (1.90177878e-06)
155578 EPS nconv=0 first unconverged value (error) -302.035 (1.85662343e-06)
155579 EPS nconv=0 first unconverged value (error) -302.035 (1.83023410e-06)
155580 EPS nconv=0 first unconverged value (error) -302.035 (1.81893805e-06)
155581 EPS nconv=0 first unconverged value (error) -302.035 (1.81893805e-06)
155582 EPS nconv=0 first unconverged value (error) -302.035 (1.97767272e-06)
155583 EPS nconv=0 first unconverged value (error) -302.035 (1.94972377e-06)
155584 EPS nconv=0 first unconverged value (error) -302.035 (1.92109628e-06)
155585 EPS nconv=0 first unconverged value (error) -302.035 (1.90073170e-06)
155586 EPS nconv=0 first unconverged value (error) -302.035 (1.87777363e-06)
155587 EPS nconv=0 first unconverged value (error) -302.035 (1.87777363e-06)
155588 EPS nconv=0 first unconverged value (error) -302.035 (1.87557541e-06)
155589 EPS nconv=0 first unconverged value (error) -302.035 (1.88975379e-06)
155590 EPS nconv=0 first unconverged value (error) -302.035 (1.84309238e-06)
155591 EPS nconv=0 first unconverged value (error) -302.035 (1.82767798e-06)
155592 EPS nconv=0 first unconverged value (error) -302.035 (1.81858903e-06)
155593 EPS nconv=0 first unconverged value (error) -302.035 (1.81858903e-06)
155594 EPS nconv=0 first unconverged value (error) -302.035 (1.86141763e-06)
155595 EPS nconv=0 first unconverged value (error) -302.035 (1.84143042e-06)
155596 EPS nconv=0 first unconverged value (error) -302.035 (1.82903008e-06)
155597 EPS nconv=0 first unconverged value (error) -302.035 (1.82370851e-06)
155598 EPS nconv=0 first unconverged value (error) -302.035 (1.81830895e-06)
155599 EPS nconv=0 first unconverged value (error) -302.035 (1.81830895e-06)
155600 EPS nconv=0 first unconverged value (error) -302.035 (1.82036049e-06)
155601 EPS nconv=0 first unconverged value (error) -302.035 (1.83921481e-06)
155602 EPS nconv=0 first unconverged value (error) -302.035 (1.81787611e-06)
155603 EPS nconv=0 first unconverged value (error) -302.035 (1.80462888e-06)
155604 EPS nconv=0 first unconverged value (error) -302.035 (1.80024542e-06)
155605 EPS nconv=0 first unconverged value (error) -302.035 (1.80024542e-06)
155606 EPS nconv=0 first unconverged value (error) -302.035 (1.89785427e-06)
155607 EPS nconv=0 first unconverged value (error) -302.035 (1.87089105e-06)
155608 EPS nconv=0 first unconverged value (error) -302.035 (1.86212764e-06)
155609 EPS nconv=0 first unconverged value (error) -302.035 (1.85514083e-06)
155610 EPS nconv=0 first unconverged value (error) -302.035 (1.84210809e-06)
155611 EPS nconv=0 first unconverged value (error) -302.035 (1.84210809e-06)
155612 EPS nconv=0 first unconverged value (error) -302.035 (1.85017481e-06)
155613 EPS nconv=0 first unconverged value (error) -302.035 (1.85396890e-06)
155614 EPS nconv=0 first unconverged value (error) -302.035 (1.82563573e-06)
155615 EPS nconv=0 first unconverged value (error) -302.035 (1.81437083e-06)
155616 EPS nconv=0 first unconverged value (error) -302.035 (1.81275468e-06)
155617 EPS nconv=0 first unconverged value (error) -302.035 (1.81275468e-06)
155618 EPS nconv=0 first unconverged value (error) -302.035 (1.91512506e-06)
155619 EPS nconv=0 first unconverged value (error) -302.035 (1.87217539e-06)
155620 EPS nconv=0 first unconverged value (error) -302.035 (1.84707185e-06)
155621 EPS nconv=0 first unconverged value (error) -302.035 (1.83851177e-06)
155622 EPS nconv=0 first unconverged value (error) -302.035 (1.83031460e-06)
155623 EPS nconv=0 first unconverged value (error) -302.035 (1.83031460e-06)
155624 EPS nconv=0 first unconverged value (error) -302.035 (1.83160890e-06)
155625 EPS nconv=0 first unconverged value (error) -302.035 (1.87524410e-06)
155626 EPS nconv=0 first unconverged value (error) -302.035 (1.83216710e-06)
155627 EPS nconv=0 first unconverged value (error) -302.035 (1.80774220e-06)
155628 EPS nconv=0 first unconverged value (error) -302.035 (1.80142260e-06)
155629 EPS nconv=0 first unconverged value (error) -302.035 (1.80142260e-06)
155630 EPS nconv=0 first unconverged value (error) -302.035 (1.94272239e-06)
155631 EPS nconv=0 first unconverged value (error) -302.035 (1.90535775e-06)
155632 EPS nconv=0 first unconverged value (error) -302.035 (1.89638520e-06)
155633 EPS nconv=0 first unconverged value (error) -302.035 (1.89344121e-06)
155634 EPS nconv=0 first unconverged value (error) -302.035 (1.87069583e-06)
155635 EPS nconv=0 first unconverged value (error) -302.035 (1.87069583e-06)
155636 EPS nconv=0 first unconverged value (error) -302.035 (1.91263268e-06)
155637 EPS nconv=0 first unconverged value (error) -302.035 (1.91037788e-06)
155638 EPS nconv=0 first unconverged value (error) -302.035 (1.87527606e-06)
155639 EPS nconv=0 first unconverged value (error) -302.035 (1.84435391e-06)
155640 EPS nconv=0 first unconverged value (error) -302.035 (1.83472910e-06)
155641 EPS nconv=0 first unconverged value (error) -302.035 (1.83472910e-06)
155642 EPS nconv=0 first unconverged value (error) -302.035 (1.98678684e-06)
155643 EPS nconv=0 first unconverged value (error) -302.035 (1.91899793e-06)
155644 EPS nconv=0 first unconverged value (error) -302.035 (1.87347409e-06)
155645 EPS nconv=0 first unconverged value (error) -302.035 (1.86249707e-06)
155646 EPS nconv=0 first unconverged value (error) -302.035 (1.85288998e-06)
155647 EPS nconv=0 first unconverged value (error) -302.035 (1.85288998e-06)
155648 EPS nconv=0 first unconverged value (error) -302.035 (1.86501878e-06)
155649 EPS nconv=0 first unconverged value (error) -302.035 (1.93128857e-06)
155650 EPS nconv=0 first unconverged value (error) -302.035 (1.85865887e-06)
155651 EPS nconv=0 first unconverged value (error) -302.035 (1.82461321e-06)
155652 EPS nconv=0 first unconverged value (error) -302.035 (1.81122864e-06)
155653 EPS nconv=0 first unconverged value (error) -302.035 (1.81122864e-06)
155654 EPS nconv=0 first unconverged value (error) -302.035 (1.98846988e-06)
155655 EPS nconv=0 first unconverged value (error) -302.035 (1.95273181e-06)
155656 EPS nconv=0 first unconverged value (error) -302.035 (1.93898721e-06)
155657 EPS nconv=0 first unconverged value (error) -302.035 (1.92706399e-06)
155658 EPS nconv=0 first unconverged value (error) -302.035 (1.89376636e-06)
155659 EPS nconv=0 first unconverged value (error) -302.035 (1.89376636e-06)
155660 EPS nconv=0 first unconverged value (error) -302.035 (1.97767178e-06)
155661 EPS nconv=0 first unconverged value (error) -302.035 (1.94569971e-06)
155662 EPS nconv=0 first unconverged value (error) -302.035 (1.89081620e-06)
155663 EPS nconv=0 first unconverged value (error) -302.035 (1.87993797e-06)
155664 EPS nconv=0 first unconverged value (error) -302.035 (1.88032325e-06)
155665 EPS nconv=0 first unconverged value (error) -302.035 (1.88032325e-06)
155666 EPS nconv=0 first unconverged value (error) -302.035 (1.98825838e-06)
155667 EPS nconv=0 first unconverged value (error) -302.035 (1.90513795e-06)
155668 EPS nconv=0 first unconverged value (error) -302.035 (1.86835590e-06)
155669 EPS nconv=0 first unconverged value (error) -302.035 (1.84327732e-06)
155670 EPS nconv=0 first unconverged value (error) -302.035 (1.83606098e-06)
155671 EPS nconv=0 first unconverged value (error) -302.035 (1.83606098e-06)
155672 EPS nconv=0 first unconverged value (error) -302.035 (1.86348859e-06)
155673 EPS nconv=0 first unconverged value (error) -302.035 (1.90729611e-06)
155674 EPS nconv=0 first unconverged value (error) -302.035 (1.84136080e-06)
155675 EPS nconv=0 first unconverged value (error) -302.035 (1.81764202e-06)
155676 EPS nconv=0 first unconverged value (error) -302.035 (1.81253253e-06)
155677 EPS nconv=0 first unconverged value (error) -302.035 (1.81253253e-06)
155678 EPS nconv=0 first unconverged value (error) -302.035 (1.92614764e-06)
155679 EPS nconv=0 first unconverged value (error) -302.035 (1.91093474e-06)
155680 EPS nconv=0 first unconverged value (error) -302.035 (1.88396437e-06)
155681 EPS nconv=0 first unconverged value (error) -302.035 (1.87791595e-06)
155682 EPS nconv=0 first unconverged value (error) -302.035 (1.86078253e-06)
155683 EPS nconv=0 first unconverged value (error) -302.035 (1.86078253e-06)
155684 EPS nconv=0 first unconverged value (error) -302.035 (1.88070875e-06)
155685 EPS nconv=0 first unconverged value (error) -302.035 (1.87457757e-06)
155686 EPS nconv=0 first unconverged value (error) -302.035 (1.84028839e-06)
155687 EPS nconv=0 first unconverged value (error) -302.035 (1.82434898e-06)
155688 EPS nconv=0 first unconverged value (error) -302.035 (1.81307395e-06)
155689 EPS nconv=0 first unconverged value (error) -302.035 (1.81307395e-06)
155690 EPS nconv=0 first unconverged value (error) -302.035 (1.98806260e-06)
155691 EPS nconv=0 first unconverged value (error) -302.035 (1.91920598e-06)
155692 EPS nconv=0 first unconverged value (error) -302.035 (1.88369735e-06)
155693 EPS nconv=0 first unconverged value (error) -302.035 (1.86521761e-06)
155694 EPS nconv=0 first unconverged value (error) -302.035 (1.85594593e-06)
155695 EPS nconv=0 first unconverged value (error) -302.035 (1.85594593e-06)
155696 EPS nconv=0 first unconverged value (error) -302.035 (1.88976126e-06)
155697 EPS nconv=0 first unconverged value (error) -302.035 (1.93203811e-06)
155698 EPS nconv=0 first unconverged value (error) -302.035 (1.86150081e-06)
155699 EPS nconv=0 first unconverged value (error) -302.035 (1.83840575e-06)
155700 EPS nconv=0 first unconverged value (error) -302.035 (1.82332750e-06)
155701 EPS nconv=0 first unconverged value (error) -302.035 (1.82332750e-06)
155702 EPS nconv=0 first unconverged value (error) -302.035 (1.94963405e-06)
155703 EPS nconv=0 first unconverged value (error) -302.035 (1.93648752e-06)
155704 EPS nconv=0 first unconverged value (error) -302.035 (1.90449333e-06)
155705 EPS nconv=0 first unconverged value (error) -302.035 (1.88515406e-06)
155706 EPS nconv=0 first unconverged value (error) -302.035 (1.86354176e-06)
155707 EPS nconv=0 first unconverged value (error) -302.035 (1.86354176e-06)
155708 EPS nconv=0 first unconverged value (error) -302.035 (1.88078019e-06)
155709 EPS nconv=0 first unconverged value (error) -302.035 (1.87703861e-06)
155710 EPS nconv=0 first unconverged value (error) -302.035 (1.84741639e-06)
155711 EPS nconv=0 first unconverged value (error) -302.035 (1.83086326e-06)
155712 EPS nconv=0 first unconverged value (error) -302.035 (1.82160907e-06)
155713 EPS nconv=0 first unconverged value (error) -302.035 (1.82160907e-06)
155714 EPS nconv=0 first unconverged value (error) -302.035 (1.94390612e-06)
155715 EPS nconv=0 first unconverged value (error) -302.035 (1.90062577e-06)
155716 EPS nconv=0 first unconverged value (error) -302.035 (1.87353601e-06)
155717 EPS nconv=0 first unconverged value (error) -302.035 (1.85967021e-06)
155718 EPS nconv=0 first unconverged value (error) -302.035 (1.84735024e-06)
155719 EPS nconv=0 first unconverged value (error) -302.035 (1.84735024e-06)
155720 EPS nconv=0 first unconverged value (error) -302.035 (1.93054651e-06)
155721 EPS nconv=0 first unconverged value (error) -302.035 (1.94809923e-06)
155722 EPS nconv=0 first unconverged value (error) -302.035 (1.88273617e-06)
155723 EPS nconv=0 first unconverged value (error) -302.035 (1.86969349e-06)
155724 EPS nconv=0 first unconverged value (error) -302.035 (1.84750831e-06)
155725 EPS nconv=0 first unconverged value (error) -302.035 (1.84750831e-06)
155726 EPS nconv=0 first unconverged value (error) -302.035 (1.96287969e-06)
155727 EPS nconv=0 first unconverged value (error) -302.035 (1.96340536e-06)
155728 EPS nconv=0 first unconverged value (error) -302.035 (1.91837310e-06)
155729 EPS nconv=0 first unconverged value (error) -302.035 (1.88620047e-06)
155730 EPS nconv=0 first unconverged value (error) -302.035 (1.86031493e-06)
155731 EPS nconv=0 first unconverged value (error) -302.035 (1.86031493e-06)
155732 EPS nconv=0 first unconverged value (error) -302.035 (1.86877417e-06)
155733 EPS nconv=0 first unconverged value (error) -302.035 (1.86741829e-06)
155734 EPS nconv=0 first unconverged value (error) -302.035 (1.84771512e-06)
155735 EPS nconv=0 first unconverged value (error) -302.035 (1.82428192e-06)
155736 EPS nconv=0 first unconverged value (error) -302.035 (1.81651885e-06)
155737 EPS nconv=0 first unconverged value (error) -302.035 (1.81651885e-06)
155738 EPS nconv=0 first unconverged value (error) -302.035 (1.88365122e-06)
155739 EPS nconv=0 first unconverged value (error) -302.035 (1.85365724e-06)
155740 EPS nconv=0 first unconverged value (error) -302.035 (1.84213175e-06)
155741 EPS nconv=0 first unconverged value (error) -302.035 (1.83376981e-06)
155742 EPS nconv=0 first unconverged value (error) -302.035 (1.82573656e-06)
155743 EPS nconv=0 first unconverged value (error) -302.035 (1.82573656e-06)
155744 EPS nconv=0 first unconverged value (error) -302.035 (2.04382538e-06)
155745 EPS nconv=0 first unconverged value (error) -302.035 (2.00764923e-06)
155746 EPS nconv=0 first unconverged value (error) -302.035 (1.93978791e-06)
155747 EPS nconv=0 first unconverged value (error) -302.035 (1.92899910e-06)
155748 EPS nconv=0 first unconverged value (error) -302.035 (1.90389725e-06)
155749 EPS nconv=0 first unconverged value (error) -302.035 (1.90389725e-06)
155750 EPS nconv=0 first unconverged value (error) -302.035 (1.99294192e-06)
155751 EPS nconv=0 first unconverged value (error) -302.035 (2.03195072e-06)
155752 EPS nconv=0 first unconverged value (error) -302.035 (1.96030617e-06)
155753 EPS nconv=0 first unconverged value (error) -302.035 (1.87434141e-06)
155754 EPS nconv=0 first unconverged value (error) -302.035 (1.85866742e-06)
155755 EPS nconv=0 first unconverged value (error) -302.035 (1.85866742e-06)
155756 EPS nconv=0 first unconverged value (error) -302.035 (1.85985308e-06)
155757 EPS nconv=0 first unconverged value (error) -302.035 (1.85395733e-06)
155758 EPS nconv=0 first unconverged value (error) -302.035 (1.83824406e-06)
155759 EPS nconv=0 first unconverged value (error) -302.035 (1.81827106e-06)
155760 EPS nconv=0 first unconverged value (error) -302.035 (1.81558734e-06)
155761 EPS nconv=0 first unconverged value (error) -302.035 (1.81558734e-06)
155762 EPS nconv=0 first unconverged value (error) -302.035 (1.80602492e-06)
155763 EPS nconv=0 first unconverged value (error) -302.035 (1.81398430e-06)
155764 EPS nconv=0 first unconverged value (error) -302.035 (1.80342418e-06)
155765 EPS nconv=0 first unconverged value (error) -302.035 (1.80001876e-06)
155766 EPS nconv=0 first unconverged value (error) -302.035 (1.79696358e-06)
155767 EPS nconv=0 first unconverged value (error) -302.035 (1.79696358e-06)
155768 EPS nconv=0 first unconverged value (error) -302.035 (2.26155350e-06)
155769 EPS nconv=0 first unconverged value (error) -302.035 (2.18128778e-06)
155770 EPS nconv=0 first unconverged value (error) -302.035 (2.09340222e-06)
155771 EPS nconv=0 first unconverged value (error) -302.035 (2.06684260e-06)
155772 EPS nconv=0 first unconverged value (error) -302.035 (2.00639585e-06)
155773 EPS nconv=0 first unconverged value (error) -302.035 (2.00639585e-06)
155774 EPS nconv=0 first unconverged value (error) -302.035 (2.00645903e-06)
155775 EPS nconv=0 first unconverged value (error) -302.035 (2.09726855e-06)
155776 EPS nconv=0 first unconverged value (error) -302.035 (2.01582204e-06)
155777 EPS nconv=0 first unconverged value (error) -302.035 (1.86895287e-06)
155778 EPS nconv=0 first unconverged value (error) -302.035 (1.85180582e-06)
155779 EPS nconv=0 first unconverged value (error) -302.035 (1.85180582e-06)
155780 EPS nconv=0 first unconverged value (error) -302.035 (1.85238444e-06)
155781 EPS nconv=0 first unconverged value (error) -302.035 (1.83035151e-06)
155782 EPS nconv=0 first unconverged value (error) -302.035 (1.82293673e-06)
155783 EPS nconv=0 first unconverged value (error) -302.035 (1.81808266e-06)
155784 EPS nconv=0 first unconverged value (error) -302.035 (1.81417917e-06)
155785 EPS nconv=0 first unconverged value (error) -302.035 (1.81417917e-06)
155786 EPS nconv=0 first unconverged value (error) -302.035 (1.85386364e-06)
155787 EPS nconv=0 first unconverged value (error) -302.035 (1.85296574e-06)
155788 EPS nconv=0 first unconverged value (error) -302.035 (1.82486717e-06)
155789 EPS nconv=0 first unconverged value (error) -302.035 (1.81882657e-06)
155790 EPS nconv=0 first unconverged value (error) -302.035 (1.81265448e-06)
155791 EPS nconv=0 first unconverged value (error) -302.035 (1.81265448e-06)
155792 EPS nconv=0 first unconverged value (error) -302.035 (2.12842530e-06)
155793 EPS nconv=0 first unconverged value (error) -302.035 (2.08700838e-06)
155794 EPS nconv=0 first unconverged value (error) -302.035 (2.02540553e-06)
155795 EPS nconv=0 first unconverged value (error) -302.035 (1.99698737e-06)
155796 EPS nconv=0 first unconverged value (error) -302.035 (1.95489217e-06)
155797 EPS nconv=0 first unconverged value (error) -302.035 (1.95489217e-06)
155798 EPS nconv=0 first unconverged value (error) -302.035 (2.00413159e-06)
155799 EPS nconv=0 first unconverged value (error) -302.035 (1.99908283e-06)
155800 EPS nconv=0 first unconverged value (error) -302.035 (1.93330709e-06)
155801 EPS nconv=0 first unconverged value (error) -302.035 (1.88597464e-06)
155802 EPS nconv=0 first unconverged value (error) -302.035 (1.87845605e-06)
155803 EPS nconv=0 first unconverged value (error) -302.035 (1.87845605e-06)
155804 EPS nconv=0 first unconverged value (error) -302.035 (1.89418026e-06)
155805 EPS nconv=0 first unconverged value (error) -302.035 (1.84794755e-06)
155806 EPS nconv=0 first unconverged value (error) -302.035 (1.83825823e-06)
155807 EPS nconv=0 first unconverged value (error) -302.035 (1.82353341e-06)
155808 EPS nconv=0 first unconverged value (error) -302.035 (1.81873606e-06)
155809 EPS nconv=0 first unconverged value (error) -302.035 (1.81873606e-06)
155810 EPS nconv=0 first unconverged value (error) -302.035 (1.85857986e-06)
155811 EPS nconv=0 first unconverged value (error) -302.035 (1.85572699e-06)
155812 EPS nconv=0 first unconverged value (error) -302.035 (1.83196781e-06)
155813 EPS nconv=0 first unconverged value (error) -302.035 (1.81994131e-06)
155814 EPS nconv=0 first unconverged value (error) -302.035 (1.81404128e-06)
155815 EPS nconv=0 first unconverged value (error) -302.035 (1.81404128e-06)
155816 EPS nconv=0 first unconverged value (error) -302.035 (1.92541449e-06)
155817 EPS nconv=0 first unconverged value (error) -302.035 (1.92806926e-06)
155818 EPS nconv=0 first unconverged value (error) -302.035 (1.88102334e-06)
155819 EPS nconv=0 first unconverged value (error) -302.035 (1.87062369e-06)
155820 EPS nconv=0 first unconverged value (error) -302.035 (1.85306714e-06)
155821 EPS nconv=0 first unconverged value (error) -302.035 (1.85306714e-06)
155822 EPS nconv=0 first unconverged value (error) -302.035 (1.93350320e-06)
155823 EPS nconv=0 first unconverged value (error) -302.035 (1.93497743e-06)
155824 EPS nconv=0 first unconverged value (error) -302.035 (1.91259215e-06)
155825 EPS nconv=0 first unconverged value (error) -302.035 (1.86937160e-06)
155826 EPS nconv=0 first unconverged value (error) -302.035 (1.85167877e-06)
155827 EPS nconv=0 first unconverged value (error) -302.035 (1.85167877e-06)
155828 EPS nconv=0 first unconverged value (error) -302.035 (1.85372747e-06)
155829 EPS nconv=0 first unconverged value (error) -302.035 (1.84918556e-06)
155830 EPS nconv=0 first unconverged value (error) -302.035 (1.82578541e-06)
155831 EPS nconv=0 first unconverged value (error) -302.035 (1.81009821e-06)
155832 EPS nconv=0 first unconverged value (error) -302.035 (1.81034300e-06)
155833 EPS nconv=0 first unconverged value (error) -302.035 (1.81034300e-06)
155834 EPS nconv=0 first unconverged value (error) -302.035 (1.80550607e-06)
155835 EPS nconv=0 first unconverged value (error) -302.035 (1.80727917e-06)
155836 EPS nconv=0 first unconverged value (error) -302.035 (1.80073158e-06)
155837 EPS nconv=0 first unconverged value (error) -302.035 (1.79922140e-06)
155838 EPS nconv=0 first unconverged value (error) -302.035 (1.79664837e-06)
155839 EPS nconv=0 first unconverged value (error) -302.035 (1.79664837e-06)
155840 EPS nconv=0 first unconverged value (error) -302.035 (1.83604717e-06)
155841 EPS nconv=0 first unconverged value (error) -302.035 (1.83058336e-06)
155842 EPS nconv=0 first unconverged value (error) -302.035 (1.82221187e-06)
155843 EPS nconv=0 first unconverged value (error) -302.035 (1.81956843e-06)
155844 EPS nconv=0 first unconverged value (error) -302.035 (1.81359009e-06)
155845 EPS nconv=0 first unconverged value (error) -302.035 (1.81359009e-06)
155846 EPS nconv=0 first unconverged value (error) -302.035 (1.94422966e-06)
155847 EPS nconv=0 first unconverged value (error) -302.035 (1.93232431e-06)
155848 EPS nconv=0 first unconverged value (error) -302.035 (1.90644685e-06)
155849 EPS nconv=0 first unconverged value (error) -302.035 (1.90715499e-06)
155850 EPS nconv=0 first unconverged value (error) -302.035 (1.89883283e-06)
155851 EPS nconv=0 first unconverged value (error) -302.035 (1.89883283e-06)
155852 EPS nconv=0 first unconverged value (error) -302.035 (1.92614861e-06)
155853 EPS nconv=0 first unconverged value (error) -302.035 (1.87147661e-06)
155854 EPS nconv=0 first unconverged value (error) -302.035 (1.85660433e-06)
155855 EPS nconv=0 first unconverged value (error) -302.035 (1.82440342e-06)
155856 EPS nconv=0 first unconverged value (error) -302.035 (1.81099052e-06)
155857 EPS nconv=0 first unconverged value (error) -302.035 (1.81099052e-06)
155858 EPS nconv=0 first unconverged value (error) -302.035 (1.84543200e-06)
155859 EPS nconv=0 first unconverged value (error) -302.035 (1.84030840e-06)
155860 EPS nconv=0 first unconverged value (error) -302.035 (1.82758364e-06)
155861 EPS nconv=0 first unconverged value (error) -302.035 (1.81902913e-06)
155862 EPS nconv=0 first unconverged value (error) -302.035 (1.81558765e-06)
155863 EPS nconv=0 first unconverged value (error) -302.035 (1.81558765e-06)
155864 EPS nconv=0 first unconverged value (error) -302.035 (1.95836643e-06)
155865 EPS nconv=0 first unconverged value (error) -302.035 (1.93373624e-06)
155866 EPS nconv=0 first unconverged value (error) -302.035 (1.91066292e-06)
155867 EPS nconv=0 first unconverged value (error) -302.035 (1.88381666e-06)
155868 EPS nconv=0 first unconverged value (error) -302.035 (1.86541270e-06)
155869 EPS nconv=0 first unconverged value (error) -302.035 (1.86541270e-06)
155870 EPS nconv=0 first unconverged value (error) -302.035 (1.89570901e-06)
155871 EPS nconv=0 first unconverged value (error) -302.035 (1.90899889e-06)
155872 EPS nconv=0 first unconverged value (error) -302.035 (1.86138795e-06)
155873 EPS nconv=0 first unconverged value (error) -302.035 (1.84404425e-06)
155874 EPS nconv=0 first unconverged value (error) -302.035 (1.83261057e-06)
155875 EPS nconv=0 first unconverged value (error) -302.035 (1.83261057e-06)
155876 EPS nconv=0 first unconverged value (error) -302.035 (2.00460881e-06)
155877 EPS nconv=0 first unconverged value (error) -302.035 (1.96008930e-06)
155878 EPS nconv=0 first unconverged value (error) -302.035 (1.91488071e-06)
155879 EPS nconv=0 first unconverged value (error) -302.035 (1.88809664e-06)
155880 EPS nconv=0 first unconverged value (error) -302.035 (1.86974449e-06)
155881 EPS nconv=0 first unconverged value (error) -302.035 (1.86974449e-06)
155882 EPS nconv=0 first unconverged value (error) -302.035 (1.91103000e-06)
155883 EPS nconv=0 first unconverged value (error) -302.035 (1.92768855e-06)
155884 EPS nconv=0 first unconverged value (error) -302.035 (1.89518879e-06)
155885 EPS nconv=0 first unconverged value (error) -302.035 (1.85387596e-06)
155886 EPS nconv=0 first unconverged value (error) -302.035 (1.82988573e-06)
155887 EPS nconv=0 first unconverged value (error) -302.035 (1.82988573e-06)
155888 EPS nconv=0 first unconverged value (error) -302.035 (1.86982489e-06)
155889 EPS nconv=0 first unconverged value (error) -302.035 (1.85774628e-06)
155890 EPS nconv=0 first unconverged value (error) -302.035 (1.86190213e-06)
155891 EPS nconv=0 first unconverged value (error) -302.035 (1.83106955e-06)
155892 EPS nconv=0 first unconverged value (error) -302.035 (1.82700711e-06)
155893 EPS nconv=0 first unconverged value (error) -302.035 (1.82700711e-06)
155894 EPS nconv=0 first unconverged value (error) -302.035 (1.85727294e-06)
155895 EPS nconv=0 first unconverged value (error) -302.035 (1.86501536e-06)
155896 EPS nconv=0 first unconverged value (error) -302.035 (1.83884871e-06)
155897 EPS nconv=0 first unconverged value (error) -302.035 (1.82486380e-06)
155898 EPS nconv=0 first unconverged value (error) -302.035 (1.81574947e-06)
155899 EPS nconv=0 first unconverged value (error) -302.035 (1.81574947e-06)
155900 EPS nconv=0 first unconverged value (error) -302.035 (1.81624961e-06)
155901 EPS nconv=0 first unconverged value (error) -302.035 (1.81713641e-06)
155902 EPS nconv=0 first unconverged value (error) -302.035 (1.80494858e-06)
155903 EPS nconv=0 first unconverged value (error) -302.035 (1.80118019e-06)
155904 EPS nconv=0 first unconverged value (error) -302.035 (1.79860518e-06)
155905 EPS nconv=0 first unconverged value (error) -302.035 (1.79860518e-06)
155906 EPS nconv=0 first unconverged value (error) -302.035 (1.91875326e-06)
155907 EPS nconv=0 first unconverged value (error) -302.035 (1.89362529e-06)
155908 EPS nconv=0 first unconverged value (error) -302.035 (1.86490196e-06)
155909 EPS nconv=0 first unconverged value (error) -302.035 (1.85301895e-06)
155910 EPS nconv=0 first unconverged value (error) -302.035 (1.84463254e-06)
155911 EPS nconv=0 first unconverged value (error) -302.035 (1.84463254e-06)
155912 EPS nconv=0 first unconverged value (error) -302.035 (1.86017000e-06)
155913 EPS nconv=0 first unconverged value (error) -302.035 (1.87228454e-06)
155914 EPS nconv=0 first unconverged value (error) -302.035 (1.84568191e-06)
155915 EPS nconv=0 first unconverged value (error) -302.035 (1.82108357e-06)
155916 EPS nconv=0 first unconverged value (error) -302.035 (1.81040836e-06)
155917 EPS nconv=0 first unconverged value (error) -302.035 (1.81040836e-06)
155918 EPS nconv=0 first unconverged value (error) -302.035 (1.80563364e-06)
155919 EPS nconv=0 first unconverged value (error) -302.035 (1.80617190e-06)
155920 EPS nconv=0 first unconverged value (error) -302.035 (1.79878060e-06)
155921 EPS nconv=0 first unconverged value (error) -302.035 (1.79669061e-06)
155922 EPS nconv=0 first unconverged value (error) -302.035 (1.79591196e-06)
155923 EPS nconv=0 first unconverged value (error) -302.035 (1.79591196e-06)
155924 EPS nconv=0 first unconverged value (error) -302.035 (1.93397302e-06)
155925 EPS nconv=0 first unconverged value (error) -302.035 (1.88647084e-06)
155926 EPS nconv=0 first unconverged value (error) -302.035 (1.85909295e-06)
155927 EPS nconv=0 first unconverged value (error) -302.035 (1.85142732e-06)
155928 EPS nconv=0 first unconverged value (error) -302.035 (1.84634237e-06)
155929 EPS nconv=0 first unconverged value (error) -302.035 (1.84634237e-06)
155930 EPS nconv=0 first unconverged value (error) -302.035 (1.84581119e-06)
155931 EPS nconv=0 first unconverged value (error) -302.035 (1.89060548e-06)
155932 EPS nconv=0 first unconverged value (error) -302.035 (1.84191744e-06)
155933 EPS nconv=0 first unconverged value (error) -302.035 (1.80770619e-06)
155934 EPS nconv=0 first unconverged value (error) -302.035 (1.80240638e-06)
155935 EPS nconv=0 first unconverged value (error) -302.035 (1.80240638e-06)
155936 EPS nconv=0 first unconverged value (error) -302.035 (2.01244241e-06)
155937 EPS nconv=0 first unconverged value (error) -302.035 (1.97646745e-06)
155938 EPS nconv=0 first unconverged value (error) -302.035 (1.92107500e-06)
155939 EPS nconv=0 first unconverged value (error) -302.035 (1.89113458e-06)
155940 EPS nconv=0 first unconverged value (error) -302.035 (1.88100967e-06)
155941 EPS nconv=0 first unconverged value (error) -302.035 (1.88100967e-06)
155942 EPS nconv=0 first unconverged value (error) -302.035 (1.88432798e-06)
155943 EPS nconv=0 first unconverged value (error) -302.035 (1.94143513e-06)
155944 EPS nconv=0 first unconverged value (error) -302.035 (1.90691774e-06)
155945 EPS nconv=0 first unconverged value (error) -302.035 (1.82015955e-06)
155946 EPS nconv=0 first unconverged value (error) -302.035 (1.80040506e-06)
155947 EPS nconv=0 first unconverged value (error) -302.035 (1.80040506e-06)
155948 EPS nconv=0 first unconverged value (error) -302.035 (2.13057682e-06)
155949 EPS nconv=0 first unconverged value (error) -302.035 (2.09142830e-06)
155950 EPS nconv=0 first unconverged value (error) -302.035 (2.03871529e-06)
155951 EPS nconv=0 first unconverged value (error) -302.035 (2.00845636e-06)
155952 EPS nconv=0 first unconverged value (error) -302.035 (1.98375514e-06)
155953 EPS nconv=0 first unconverged value (error) -302.035 (1.98375514e-06)
155954 EPS nconv=0 first unconverged value (error) -302.035 (2.14024034e-06)
155955 EPS nconv=0 first unconverged value (error) -302.035 (2.06807709e-06)
155956 EPS nconv=0 first unconverged value (error) -302.035 (1.97978368e-06)
155957 EPS nconv=0 first unconverged value (error) -302.035 (1.95138409e-06)
155958 EPS nconv=0 first unconverged value (error) -302.035 (1.91592428e-06)
155959 EPS nconv=0 first unconverged value (error) -302.035 (1.91592428e-06)
155960 EPS nconv=0 first unconverged value (error) -302.035 (1.91147461e-06)
155961 EPS nconv=0 first unconverged value (error) -302.035 (1.92550516e-06)
155962 EPS nconv=0 first unconverged value (error) -302.035 (1.89023445e-06)
155963 EPS nconv=0 first unconverged value (error) -302.035 (1.82621235e-06)
155964 EPS nconv=0 first unconverged value (error) -302.035 (1.81153085e-06)
155965 EPS nconv=0 first unconverged value (error) -302.035 (1.81153085e-06)
155966 EPS nconv=0 first unconverged value (error) -302.035 (1.83427969e-06)
155967 EPS nconv=0 first unconverged value (error) -302.035 (1.82662501e-06)
155968 EPS nconv=0 first unconverged value (error) -302.035 (1.81659909e-06)
155969 EPS nconv=0 first unconverged value (error) -302.035 (1.81562364e-06)
155970 EPS nconv=0 first unconverged value (error) -302.035 (1.81158994e-06)
155971 EPS nconv=0 first unconverged value (error) -302.035 (1.81158994e-06)
155972 EPS nconv=0 first unconverged value (error) -302.035 (1.83663226e-06)
155973 EPS nconv=0 first unconverged value (error) -302.035 (1.85641438e-06)
155974 EPS nconv=0 first unconverged value (error) -302.035 (1.83689119e-06)
155975 EPS nconv=0 first unconverged value (error) -302.035 (1.80995871e-06)
155976 EPS nconv=0 first unconverged value (error) -302.035 (1.80603920e-06)
155977 EPS nconv=0 first unconverged value (error) -302.035 (1.80603920e-06)
155978 EPS nconv=0 first unconverged value (error) -302.035 (1.81128258e-06)
155979 EPS nconv=0 first unconverged value (error) -302.035 (1.81023299e-06)
155980 EPS nconv=0 first unconverged value (error) -302.035 (1.80625390e-06)
155981 EPS nconv=0 first unconverged value (error) -302.035 (1.80189898e-06)
155982 EPS nconv=0 first unconverged value (error) -302.035 (1.80131122e-06)
155983 EPS nconv=0 first unconverged value (error) -302.035 (1.80131122e-06)
155984 EPS nconv=0 first unconverged value (error) -302.035 (1.80672171e-06)
155985 EPS nconv=0 first unconverged value (error) -302.035 (1.80175512e-06)
155986 EPS nconv=0 first unconverged value (error) -302.035 (1.79818113e-06)
155987 EPS nconv=0 first unconverged value (error) -302.035 (1.79794966e-06)
155988 EPS nconv=0 first unconverged value (error) -302.035 (1.79731522e-06)
155989 EPS nconv=0 first unconverged value (error) -302.035 (1.79731522e-06)
155990 EPS nconv=0 first unconverged value (error) -302.035 (1.81335118e-06)
155991 EPS nconv=0 first unconverged value (error) -302.035 (1.80886349e-06)
155992 EPS nconv=0 first unconverged value (error) -302.035 (1.80428816e-06)
155993 EPS nconv=0 first unconverged value (error) -302.035 (1.80147691e-06)
155994 EPS nconv=0 first unconverged value (error) -302.035 (1.80100645e-06)
155995 EPS nconv=0 first unconverged value (error) -302.035 (1.80100645e-06)
155996 EPS nconv=0 first unconverged value (error) -302.035 (1.82915780e-06)
155997 EPS nconv=0 first unconverged value (error) -302.035 (1.82457197e-06)
155998 EPS nconv=0 first unconverged value (error) -302.035 (1.81772693e-06)
155999 EPS nconv=0 first unconverged value (error) -302.035 (1.80561636e-06)
156000 EPS nconv=0 first unconverged value (error) -302.035 (1.80344759e-06)
156001 EPS nconv=0 first unconverged value (error) -302.035 (1.80344759e-06)
156002 EPS nconv=0 first unconverged value (error) -302.035 (1.87397949e-06)
156003 EPS nconv=0 first unconverged value (error) -302.035 (1.86256622e-06)
156004 EPS nconv=0 first unconverged value (error) -302.035 (1.84991641e-06)
156005 EPS nconv=0 first unconverged value (error) -302.035 (1.83943307e-06)
156006 EPS nconv=0 first unconverged value (error) -302.035 (1.83731571e-06)
156007 EPS nconv=0 first unconverged value (error) -302.035 (1.83731571e-06)
156008 EPS nconv=0 first unconverged value (error) -302.035 (1.83307975e-06)
156009 EPS nconv=0 first unconverged value (error) -302.035 (1.83156867e-06)
156010 EPS nconv=0 first unconverged value (error) -302.035 (1.81168576e-06)
156011 EPS nconv=0 first unconverged value (error) -302.035 (1.80898787e-06)
156012 EPS nconv=0 first unconverged value (error) -302.035 (1.80155996e-06)
156013 EPS nconv=0 first unconverged value (error) -302.035 (1.80155996e-06)
156014 EPS nconv=0 first unconverged value (error) -302.035 (1.97367508e-06)
156015 EPS nconv=0 first unconverged value (error) -302.035 (1.94278708e-06)
156016 EPS nconv=0 first unconverged value (error) -302.035 (1.89773075e-06)
156017 EPS nconv=0 first unconverged value (error) -302.035 (1.88090517e-06)
156018 EPS nconv=0 first unconverged value (error) -302.035 (1.86863132e-06)
156019 EPS nconv=0 first unconverged value (error) -302.035 (1.86863132e-06)
156020 EPS nconv=0 first unconverged value (error) -302.035 (1.90936932e-06)
156021 EPS nconv=0 first unconverged value (error) -302.035 (1.92485588e-06)
156022 EPS nconv=0 first unconverged value (error) -302.035 (1.88788127e-06)
156023 EPS nconv=0 first unconverged value (error) -302.035 (1.84720814e-06)
156024 EPS nconv=0 first unconverged value (error) -302.035 (1.83512914e-06)
156025 EPS nconv=0 first unconverged value (error) -302.035 (1.83512914e-06)
156026 EPS nconv=0 first unconverged value (error) -302.035 (1.83178047e-06)
156027 EPS nconv=0 first unconverged value (error) -302.035 (1.82326342e-06)
156028 EPS nconv=0 first unconverged value (error) -302.035 (1.80881625e-06)
156029 EPS nconv=0 first unconverged value (error) -302.035 (1.80011749e-06)
156030 EPS nconv=0 first unconverged value (error) -302.035 (1.79956458e-06)
156031 EPS nconv=0 first unconverged value (error) -302.035 (1.79956458e-06)
156032 EPS nconv=0 first unconverged value (error) -302.035 (2.01628486e-06)
156033 EPS nconv=0 first unconverged value (error) -302.035 (1.89563988e-06)
156034 EPS nconv=0 first unconverged value (error) -302.035 (1.86878650e-06)
156035 EPS nconv=0 first unconverged value (error) -302.035 (1.85925644e-06)
156036 EPS nconv=0 first unconverged value (error) -302.035 (1.85464706e-06)
156037 EPS nconv=0 first unconverged value (error) -302.035 (1.85464706e-06)
156038 EPS nconv=0 first unconverged value (error) -302.035 (1.85360224e-06)
156039 EPS nconv=0 first unconverged value (error) -302.035 (1.97479245e-06)
156040 EPS nconv=0 first unconverged value (error) -302.035 (1.84255947e-06)
156041 EPS nconv=0 first unconverged value (error) -302.035 (1.80959933e-06)
156042 EPS nconv=0 first unconverged value (error) -302.035 (1.79880424e-06)
156043 EPS nconv=0 first unconverged value (error) -302.035 (1.79880424e-06)
156044 EPS nconv=0 first unconverged value (error) -302.035 (1.86645806e-06)
156045 EPS nconv=0 first unconverged value (error) -302.035 (1.85421767e-06)
156046 EPS nconv=0 first unconverged value (error) -302.035 (1.84588947e-06)
156047 EPS nconv=0 first unconverged value (error) -302.035 (1.84167233e-06)
156048 EPS nconv=0 first unconverged value (error) -302.035 (1.83610943e-06)
156049 EPS nconv=0 first unconverged value (error) -302.035 (1.83610943e-06)
156050 EPS nconv=0 first unconverged value (error) -302.035 (1.87309364e-06)
156051 EPS nconv=0 first unconverged value (error) -302.035 (1.85395914e-06)
156052 EPS nconv=0 first unconverged value (error) -302.035 (1.82795698e-06)
156053 EPS nconv=0 first unconverged value (error) -302.035 (1.82213782e-06)
156054 EPS nconv=0 first unconverged value (error) -302.035 (1.82024671e-06)
156055 EPS nconv=0 first unconverged value (error) -302.035 (1.82024671e-06)
156056 EPS nconv=0 first unconverged value (error) -302.035 (1.85009598e-06)
156057 EPS nconv=0 first unconverged value (error) -302.035 (1.84549222e-06)
156058 EPS nconv=0 first unconverged value (error) -302.035 (1.83459180e-06)
156059 EPS nconv=0 first unconverged value (error) -302.035 (1.81536924e-06)
156060 EPS nconv=0 first unconverged value (error) -302.035 (1.80783717e-06)
156061 EPS nconv=0 first unconverged value (error) -302.035 (1.80783717e-06)
156062 EPS nconv=0 first unconverged value (error) -302.035 (1.96676008e-06)
156063 EPS nconv=0 first unconverged value (error) -302.035 (1.93084298e-06)
156064 EPS nconv=0 first unconverged value (error) -302.035 (1.86150357e-06)
156065 EPS nconv=0 first unconverged value (error) -302.035 (1.84570311e-06)
156066 EPS nconv=0 first unconverged value (error) -302.035 (1.84065432e-06)
156067 EPS nconv=0 first unconverged value (error) -302.035 (1.84065432e-06)
156068 EPS nconv=0 first unconverged value (error) -302.035 (1.85426420e-06)
156069 EPS nconv=0 first unconverged value (error) -302.035 (1.88055377e-06)
156070 EPS nconv=0 first unconverged value (error) -302.035 (1.83641444e-06)
156071 EPS nconv=0 first unconverged value (error) -302.035 (1.81501405e-06)
156072 EPS nconv=0 first unconverged value (error) -302.035 (1.81004922e-06)
156073 EPS nconv=0 first unconverged value (error) -302.035 (1.81004922e-06)
156074 EPS nconv=0 first unconverged value (error) -302.035 (1.80979239e-06)
156075 EPS nconv=0 first unconverged value (error) -302.035 (1.80986745e-06)
156076 EPS nconv=0 first unconverged value (error) -302.035 (1.80083859e-06)
156077 EPS nconv=0 first unconverged value (error) -302.035 (1.79840352e-06)
156078 EPS nconv=0 first unconverged value (error) -302.035 (1.79735958e-06)
156079 EPS nconv=0 first unconverged value (error) -302.035 (1.79735958e-06)
156080 EPS nconv=0 first unconverged value (error) -302.035 (1.85881542e-06)
156081 EPS nconv=0 first unconverged value (error) -302.035 (1.83087049e-06)
156082 EPS nconv=0 first unconverged value (error) -302.035 (1.81840929e-06)
156083 EPS nconv=0 first unconverged value (error) -302.035 (1.81604146e-06)
156084 EPS nconv=0 first unconverged value (error) -302.035 (1.81463224e-06)
156085 EPS nconv=0 first unconverged value (error) -302.035 (1.81463224e-06)
156086 EPS nconv=0 first unconverged value (error) -302.035 (1.81873610e-06)
156087 EPS nconv=0 first unconverged value (error) -302.035 (1.85088295e-06)
156088 EPS nconv=0 first unconverged value (error) -302.035 (1.81483665e-06)
156089 EPS nconv=0 first unconverged value (error) -302.035 (1.79919576e-06)
156090 EPS nconv=0 first unconverged value (error) -302.035 (1.79717990e-06)
156091 EPS nconv=0 first unconverged value (error) -302.035 (1.79717990e-06)
156092 EPS nconv=0 first unconverged value (error) -302.035 (1.81180888e-06)
156093 EPS nconv=0 first unconverged value (error) -302.035 (1.80627792e-06)
156094 EPS nconv=0 first unconverged value (error) -302.035 (1.80355683e-06)
156095 EPS nconv=0 first unconverged value (error) -302.035 (1.80243767e-06)
156096 EPS nconv=0 first unconverged value (error) -302.035 (1.80157943e-06)
156097 EPS nconv=0 first unconverged value (error) -302.035 (1.80157943e-06)
156098 EPS nconv=0 first unconverged value (error) -302.035 (1.81112964e-06)
156099 EPS nconv=0 first unconverged value (error) -302.035 (1.80907426e-06)
156100 EPS nconv=0 first unconverged value (error) -302.035 (1.80179748e-06)
156101 EPS nconv=0 first unconverged value (error) -302.035 (1.80048714e-06)
156102 EPS nconv=0 first unconverged value (error) -302.035 (1.79954142e-06)
156103 EPS nconv=0 first unconverged value (error) -302.035 (1.79954142e-06)
156104 EPS nconv=0 first unconverged value (error) -302.035 (1.87406147e-06)
156105 EPS nconv=0 first unconverged value (error) -302.035 (1.85508409e-06)
156106 EPS nconv=0 first unconverged value (error) -302.035 (1.83556444e-06)
156107 EPS nconv=0 first unconverged value (error) -302.035 (1.82761646e-06)
156108 EPS nconv=0 first unconverged value (error) -302.035 (1.82160564e-06)
156109 EPS nconv=0 first unconverged value (error) -302.035 (1.82160564e-06)
156110 EPS nconv=0 first unconverged value (error) -302.035 (1.89884420e-06)
156111 EPS nconv=0 first unconverged value (error) -302.035 (1.89294543e-06)
156112 EPS nconv=0 first unconverged value (error) -302.035 (1.85289651e-06)
156113 EPS nconv=0 first unconverged value (error) -302.035 (1.84388217e-06)
156114 EPS nconv=0 first unconverged value (error) -302.035 (1.83130645e-06)
156115 EPS nconv=0 first unconverged value (error) -302.035 (1.83130645e-06)
156116 EPS nconv=0 first unconverged value (error) -302.035 (2.09629758e-06)
156117 EPS nconv=0 first unconverged value (error) -302.035 (2.07362548e-06)
156118 EPS nconv=0 first unconverged value (error) -302.035 (1.98619691e-06)
156119 EPS nconv=0 first unconverged value (error) -302.035 (1.96625006e-06)
156120 EPS nconv=0 first unconverged value (error) -302.035 (1.93316451e-06)
156121 EPS nconv=0 first unconverged value (error) -302.035 (1.93316451e-06)
156122 EPS nconv=0 first unconverged value (error) -302.035 (1.96458399e-06)
156123 EPS nconv=0 first unconverged value (error) -302.035 (1.95443317e-06)
156124 EPS nconv=0 first unconverged value (error) -302.035 (1.91186952e-06)
156125 EPS nconv=0 first unconverged value (error) -302.035 (1.85402431e-06)
156126 EPS nconv=0 first unconverged value (error) -302.035 (1.85640893e-06)
156127 EPS nconv=0 first unconverged value (error) -302.035 (1.85640893e-06)
156128 EPS nconv=0 first unconverged value (error) -302.035 (1.92904782e-06)
156129 EPS nconv=0 first unconverged value (error) -302.035 (1.88057976e-06)
156130 EPS nconv=0 first unconverged value (error) -302.035 (1.86539315e-06)
156131 EPS nconv=0 first unconverged value (error) -302.035 (1.84052689e-06)
156132 EPS nconv=0 first unconverged value (error) -302.035 (1.82892917e-06)
156133 EPS nconv=0 first unconverged value (error) -302.035 (1.82892917e-06)
156134 EPS nconv=0 first unconverged value (error) -302.035 (1.93930114e-06)
156135 EPS nconv=0 first unconverged value (error) -302.035 (1.94310701e-06)
156136 EPS nconv=0 first unconverged value (error) -302.035 (1.87438274e-06)
156137 EPS nconv=0 first unconverged value (error) -302.035 (1.87027215e-06)
156138 EPS nconv=0 first unconverged value (error) -302.035 (1.85302098e-06)
156139 EPS nconv=0 first unconverged value (error) -302.035 (1.85302098e-06)
156140 EPS nconv=0 first unconverged value (error) -302.035 (2.07438487e-06)
156141 EPS nconv=0 first unconverged value (error) -302.035 (2.07667211e-06)
156142 EPS nconv=0 first unconverged value (error) -302.035 (1.99412473e-06)
156143 EPS nconv=0 first unconverged value (error) -302.035 (1.96068119e-06)
156144 EPS nconv=0 first unconverged value (error) -302.035 (1.91414311e-06)
156145 EPS nconv=0 first unconverged value (error) -302.035 (1.91414311e-06)
156146 EPS nconv=0 first unconverged value (error) -302.035 (1.92938677e-06)
156147 EPS nconv=0 first unconverged value (error) -302.035 (1.93496619e-06)
156148 EPS nconv=0 first unconverged value (error) -302.035 (1.88420748e-06)
156149 EPS nconv=0 first unconverged value (error) -302.035 (1.83983244e-06)
156150 EPS nconv=0 first unconverged value (error) -302.035 (1.83148131e-06)
156151 EPS nconv=0 first unconverged value (error) -302.035 (1.83148131e-06)
156152 EPS nconv=0 first unconverged value (error) -302.035 (1.86896111e-06)
156153 EPS nconv=0 first unconverged value (error) -302.035 (1.83730323e-06)
156154 EPS nconv=0 first unconverged value (error) -302.035 (1.83204440e-06)
156155 EPS nconv=0 first unconverged value (error) -302.035 (1.82655164e-06)
156156 EPS nconv=0 first unconverged value (error) -302.035 (1.81911024e-06)
156157 EPS nconv=0 first unconverged value (error) -302.035 (1.81911024e-06)
156158 EPS nconv=0 first unconverged value (error) -302.035 (1.82422231e-06)
156159 EPS nconv=0 first unconverged value (error) -302.035 (1.84686772e-06)
156160 EPS nconv=0 first unconverged value (error) -302.035 (1.81070328e-06)
156161 EPS nconv=0 first unconverged value (error) -302.035 (1.80574237e-06)
156162 EPS nconv=0 first unconverged value (error) -302.035 (1.80082547e-06)
156163 EPS nconv=0 first unconverged value (error) -302.035 (1.80082547e-06)
156164 EPS nconv=0 first unconverged value (error) -302.035 (2.11307771e-06)
156165 EPS nconv=0 first unconverged value (error) -302.035 (2.04133196e-06)
156166 EPS nconv=0 first unconverged value (error) -302.035 (1.98352808e-06)
156167 EPS nconv=0 first unconverged value (error) -302.035 (1.98038040e-06)
156168 EPS nconv=0 first unconverged value (error) -302.035 (1.94428579e-06)
156169 EPS nconv=0 first unconverged value (error) -302.035 (1.94428579e-06)
156170 EPS nconv=0 first unconverged value (error) -302.035 (2.01366957e-06)
156171 EPS nconv=0 first unconverged value (error) -302.035 (2.01446553e-06)
156172 EPS nconv=0 first unconverged value (error) -302.035 (1.92112664e-06)
156173 EPS nconv=0 first unconverged value (error) -302.035 (1.88078664e-06)
156174 EPS nconv=0 first unconverged value (error) -302.035 (1.88107266e-06)
156175 EPS nconv=0 first unconverged value (error) -302.035 (1.88107266e-06)
156176 EPS nconv=0 first unconverged value (error) -302.035 (2.04252581e-06)
156177 EPS nconv=0 first unconverged value (error) -302.035 (1.96894862e-06)
156178 EPS nconv=0 first unconverged value (error) -302.035 (1.92304996e-06)
156179 EPS nconv=0 first unconverged value (error) -302.035 (1.87556728e-06)
156180 EPS nconv=0 first unconverged value (error) -302.035 (1.85942348e-06)
156181 EPS nconv=0 first unconverged value (error) -302.035 (1.85942348e-06)
156182 EPS nconv=0 first unconverged value (error) -302.035 (1.86498999e-06)
156183 EPS nconv=0 first unconverged value (error) -302.035 (1.94017601e-06)
156184 EPS nconv=0 first unconverged value (error) -302.035 (1.84483878e-06)
156185 EPS nconv=0 first unconverged value (error) -302.035 (1.81732163e-06)
156186 EPS nconv=0 first unconverged value (error) -302.035 (1.80763044e-06)
156187 EPS nconv=0 first unconverged value (error) -302.035 (1.80763044e-06)
156188 EPS nconv=0 first unconverged value (error) -302.035 (2.26384475e-06)
156189 EPS nconv=0 first unconverged value (error) -302.035 (2.11607669e-06)
156190 EPS nconv=0 first unconverged value (error) -302.035 (2.07253560e-06)
156191 EPS nconv=0 first unconverged value (error) -302.035 (2.07755356e-06)
156192 EPS nconv=0 first unconverged value (error) -302.035 (2.01601001e-06)
156193 EPS nconv=0 first unconverged value (error) -302.035 (2.01601001e-06)
156194 EPS nconv=0 first unconverged value (error) -302.035 (2.17963743e-06)
156195 EPS nconv=0 first unconverged value (error) -302.035 (2.18152622e-06)
156196 EPS nconv=0 first unconverged value (error) -302.035 (1.99044922e-06)
156197 EPS nconv=0 first unconverged value (error) -302.035 (1.97264656e-06)
156198 EPS nconv=0 first unconverged value (error) -302.035 (1.97533823e-06)
156199 EPS nconv=0 first unconverged value (error) -302.035 (1.97533823e-06)
156200 EPS nconv=0 first unconverged value (error) -302.035 (2.15564480e-06)
156201 EPS nconv=0 first unconverged value (error) -302.035 (2.06394309e-06)
156202 EPS nconv=0 first unconverged value (error) -302.035 (2.00389148e-06)
156203 EPS nconv=0 first unconverged value (error) -302.035 (1.90368617e-06)
156204 EPS nconv=0 first unconverged value (error) -302.035 (1.87709169e-06)
156205 EPS nconv=0 first unconverged value (error) -302.035 (1.87709169e-06)
156206 EPS nconv=0 first unconverged value (error) -302.035 (1.89940297e-06)
156207 EPS nconv=0 first unconverged value (error) -302.035 (1.99058274e-06)
156208 EPS nconv=0 first unconverged value (error) -302.035 (1.87454595e-06)
156209 EPS nconv=0 first unconverged value (error) -302.035 (1.83429807e-06)
156210 EPS nconv=0 first unconverged value (error) -302.035 (1.83090403e-06)
156211 EPS nconv=0 first unconverged value (error) -302.035 (1.83090403e-06)
156212 EPS nconv=0 first unconverged value (error) -302.035 (2.11031194e-06)
156213 EPS nconv=0 first unconverged value (error) -302.035 (2.01392884e-06)
156214 EPS nconv=0 first unconverged value (error) -302.035 (1.97548545e-06)
156215 EPS nconv=0 first unconverged value (error) -302.035 (1.95188493e-06)
156216 EPS nconv=0 first unconverged value (error) -302.035 (1.91489685e-06)
156217 EPS nconv=0 first unconverged value (error) -302.035 (1.91489685e-06)
156218 EPS nconv=0 first unconverged value (error) -302.035 (1.91970873e-06)
156219 EPS nconv=0 first unconverged value (error) -302.035 (1.97720336e-06)
156220 EPS nconv=0 first unconverged value (error) -302.035 (1.85500049e-06)
156221 EPS nconv=0 first unconverged value (error) -302.035 (1.83527171e-06)
156222 EPS nconv=0 first unconverged value (error) -302.035 (1.82792604e-06)
156223 EPS nconv=0 first unconverged value (error) -302.035 (1.82792604e-06)
156224 EPS nconv=0 first unconverged value (error) -302.035 (1.99772370e-06)
156225 EPS nconv=0 first unconverged value (error) -302.035 (1.91616223e-06)
156226 EPS nconv=0 first unconverged value (error) -302.035 (1.88324879e-06)
156227 EPS nconv=0 first unconverged value (error) -302.035 (1.88164906e-06)
156228 EPS nconv=0 first unconverged value (error) -302.035 (1.86422938e-06)
156229 EPS nconv=0 first unconverged value (error) -302.035 (1.86422938e-06)
156230 EPS nconv=0 first unconverged value (error) -302.035 (1.93433182e-06)
156231 EPS nconv=0 first unconverged value (error) -302.035 (1.98031883e-06)
156232 EPS nconv=0 first unconverged value (error) -302.035 (1.88163618e-06)
156233 EPS nconv=0 first unconverged value (error) -302.035 (1.85376090e-06)
156234 EPS nconv=0 first unconverged value (error) -302.035 (1.84939526e-06)
156235 EPS nconv=0 first unconverged value (error) -302.035 (1.84939526e-06)
156236 EPS nconv=0 first unconverged value (error) -302.035 (1.98468286e-06)
156237 EPS nconv=0 first unconverged value (error) -302.035 (1.93130304e-06)
156238 EPS nconv=0 first unconverged value (error) -302.035 (1.90496021e-06)
156239 EPS nconv=0 first unconverged value (error) -302.035 (1.87936957e-06)
156240 EPS nconv=0 first unconverged value (error) -302.035 (1.85436451e-06)
156241 EPS nconv=0 first unconverged value (error) -302.035 (1.85436451e-06)
156242 EPS nconv=0 first unconverged value (error) -302.035 (2.02339358e-06)
156243 EPS nconv=0 first unconverged value (error) -302.035 (1.99431728e-06)
156244 EPS nconv=0 first unconverged value (error) -302.035 (1.91225034e-06)
156245 EPS nconv=0 first unconverged value (error) -302.035 (1.89060788e-06)
156246 EPS nconv=0 first unconverged value (error) -302.035 (1.87895524e-06)
156247 EPS nconv=0 first unconverged value (error) -302.035 (1.87895524e-06)
156248 EPS nconv=0 first unconverged value (error) -302.035 (1.86163961e-06)
156249 EPS nconv=0 first unconverged value (error) -302.035 (1.92891471e-06)
156250 EPS nconv=0 first unconverged value (error) -302.035 (1.86159894e-06)
156251 EPS nconv=0 first unconverged value (error) -302.035 (1.82728802e-06)
156252 EPS nconv=0 first unconverged value (error) -302.035 (1.80745882e-06)
156253 EPS nconv=0 first unconverged value (error) -302.035 (1.80745882e-06)
156254 EPS nconv=0 first unconverged value (error) -302.035 (1.92800094e-06)
156255 EPS nconv=0 first unconverged value (error) -302.035 (1.90413169e-06)
156256 EPS nconv=0 first unconverged value (error) -302.035 (1.88693512e-06)
156257 EPS nconv=0 first unconverged value (error) -302.035 (1.88127628e-06)
156258 EPS nconv=0 first unconverged value (error) -302.035 (1.86141271e-06)
156259 EPS nconv=0 first unconverged value (error) -302.035 (1.86141271e-06)
156260 EPS nconv=0 first unconverged value (error) -302.035 (2.00870262e-06)
156261 EPS nconv=0 first unconverged value (error) -302.035 (1.98078418e-06)
156262 EPS nconv=0 first unconverged value (error) -302.035 (1.91689701e-06)
156263 EPS nconv=0 first unconverged value (error) -302.035 (1.91225938e-06)
156264 EPS nconv=0 first unconverged value (error) -302.035 (1.90067235e-06)
156265 EPS nconv=0 first unconverged value (error) -302.035 (1.90067235e-06)
156266 EPS nconv=0 first unconverged value (error) -302.035 (1.94336862e-06)
156267 EPS nconv=0 first unconverged value (error) -302.035 (1.92198831e-06)
156268 EPS nconv=0 first unconverged value (error) -302.035 (1.90148452e-06)
156269 EPS nconv=0 first unconverged value (error) -302.035 (1.84787798e-06)
156270 EPS nconv=0 first unconverged value (error) -302.035 (1.82951699e-06)
156271 EPS nconv=0 first unconverged value (error) -302.035 (1.82951699e-06)
156272 EPS nconv=0 first unconverged value (error) -302.035 (2.09281975e-06)
156273 EPS nconv=0 first unconverged value (error) -302.035 (2.00459235e-06)
156274 EPS nconv=0 first unconverged value (error) -302.035 (1.96427654e-06)
156275 EPS nconv=0 first unconverged value (error) -302.035 (1.94113737e-06)
156276 EPS nconv=0 first unconverged value (error) -302.035 (1.92027139e-06)
156277 EPS nconv=0 first unconverged value (error) -302.035 (1.92027139e-06)
156278 EPS nconv=0 first unconverged value (error) -302.035 (1.94445746e-06)
156279 EPS nconv=0 first unconverged value (error) -302.035 (2.03766503e-06)
156280 EPS nconv=0 first unconverged value (error) -302.035 (1.92258204e-06)
156281 EPS nconv=0 first unconverged value (error) -302.035 (1.86335252e-06)
156282 EPS nconv=0 first unconverged value (error) -302.035 (1.83034384e-06)
156283 EPS nconv=0 first unconverged value (error) -302.035 (1.83034384e-06)
156284 EPS nconv=0 first unconverged value (error) -302.035 (2.04678473e-06)
156285 EPS nconv=0 first unconverged value (error) -302.035 (1.99868885e-06)
156286 EPS nconv=0 first unconverged value (error) -302.035 (1.93456914e-06)
156287 EPS nconv=0 first unconverged value (error) -302.035 (1.92926924e-06)
156288 EPS nconv=0 first unconverged value (error) -302.035 (1.90667579e-06)
156289 EPS nconv=0 first unconverged value (error) -302.035 (1.90667579e-06)
156290 EPS nconv=0 first unconverged value (error) -302.035 (1.94398047e-06)
156291 EPS nconv=0 first unconverged value (error) -302.035 (1.97540102e-06)
156292 EPS nconv=0 first unconverged value (error) -302.035 (1.91779886e-06)
156293 EPS nconv=0 first unconverged value (error) -302.035 (1.86798972e-06)
156294 EPS nconv=0 first unconverged value (error) -302.035 (1.85283784e-06)
156295 EPS nconv=0 first unconverged value (error) -302.035 (1.85283784e-06)
156296 EPS nconv=0 first unconverged value (error) -302.035 (2.21449846e-06)
156297 EPS nconv=0 first unconverged value (error) -302.035 (2.10654421e-06)
156298 EPS nconv=0 first unconverged value (error) -302.035 (2.05644484e-06)
156299 EPS nconv=0 first unconverged value (error) -302.035 (1.98058281e-06)
156300 EPS nconv=0 first unconverged value (error) -302.035 (1.94586794e-06)
156301 EPS nconv=0 first unconverged value (error) -302.035 (1.94586794e-06)
156302 EPS nconv=0 first unconverged value (error) -302.035 (2.13257984e-06)
156303 EPS nconv=0 first unconverged value (error) -302.035 (2.18490884e-06)
156304 EPS nconv=0 first unconverged value (error) -302.035 (2.02771970e-06)
156305 EPS nconv=0 first unconverged value (error) -302.035 (2.00867455e-06)
156306 EPS nconv=0 first unconverged value (error) -302.035 (1.96045004e-06)
156307 EPS nconv=0 first unconverged value (error) -302.035 (1.96045004e-06)
156308 EPS nconv=0 first unconverged value (error) -302.035 (1.97916617e-06)
156309 EPS nconv=0 first unconverged value (error) -302.035 (1.91470893e-06)
156310 EPS nconv=0 first unconverged value (error) -302.035 (1.88469111e-06)
156311 EPS nconv=0 first unconverged value (error) -302.035 (1.83715055e-06)
156312 EPS nconv=0 first unconverged value (error) -302.035 (1.82777855e-06)
156313 EPS nconv=0 first unconverged value (error) -302.035 (1.82777855e-06)
156314 EPS nconv=0 first unconverged value (error) -302.035 (1.88228592e-06)
156315 EPS nconv=0 first unconverged value (error) -302.035 (1.86176243e-06)
156316 EPS nconv=0 first unconverged value (error) -302.035 (1.85380624e-06)
156317 EPS nconv=0 first unconverged value (error) -302.035 (1.83187518e-06)
156318 EPS nconv=0 first unconverged value (error) -302.035 (1.82838648e-06)
156319 EPS nconv=0 first unconverged value (error) -302.035 (1.82838648e-06)
156320 EPS nconv=0 first unconverged value (error) -302.035 (2.09866352e-06)
156321 EPS nconv=0 first unconverged value (error) -302.035 (2.01252748e-06)
156322 EPS nconv=0 first unconverged value (error) -302.035 (1.97602688e-06)
156323 EPS nconv=0 first unconverged value (error) -302.035 (1.92803415e-06)
156324 EPS nconv=0 first unconverged value (error) -302.035 (1.90207896e-06)
156325 EPS nconv=0 first unconverged value (error) -302.035 (1.90207896e-06)
156326 EPS nconv=0 first unconverged value (error) -302.035 (2.01675617e-06)
156327 EPS nconv=0 first unconverged value (error) -302.035 (2.08448195e-06)
156328 EPS nconv=0 first unconverged value (error) -302.035 (1.94096954e-06)
156329 EPS nconv=0 first unconverged value (error) -302.035 (1.90488020e-06)
156330 EPS nconv=0 first unconverged value (error) -302.035 (1.87613116e-06)
156331 EPS nconv=0 first unconverged value (error) -302.035 (1.87613116e-06)
156332 EPS nconv=0 first unconverged value (error) -302.035 (1.85911338e-06)
156333 EPS nconv=0 first unconverged value (error) -302.035 (1.87798373e-06)
156334 EPS nconv=0 first unconverged value (error) -302.035 (1.83927841e-06)
156335 EPS nconv=0 first unconverged value (error) -302.035 (1.81423632e-06)
156336 EPS nconv=0 first unconverged value (error) -302.035 (1.80844813e-06)
156337 EPS nconv=0 first unconverged value (error) -302.035 (1.80844813e-06)
156338 EPS nconv=0 first unconverged value (error) -302.035 (1.86886850e-06)
156339 EPS nconv=0 first unconverged value (error) -302.035 (1.84847988e-06)
156340 EPS nconv=0 first unconverged value (error) -302.035 (1.83561571e-06)
156341 EPS nconv=0 first unconverged value (error) -302.035 (1.82667489e-06)
156342 EPS nconv=0 first unconverged value (error) -302.035 (1.82180836e-06)
156343 EPS nconv=0 first unconverged value (error) -302.035 (1.82180836e-06)
156344 EPS nconv=0 first unconverged value (error) -302.035 (2.06510694e-06)
156345 EPS nconv=0 first unconverged value (error) -302.035 (1.98509398e-06)
156346 EPS nconv=0 first unconverged value (error) -302.035 (1.93805707e-06)
156347 EPS nconv=0 first unconverged value (error) -302.035 (1.90566562e-06)
156348 EPS nconv=0 first unconverged value (error) -302.035 (1.88734610e-06)
156349 EPS nconv=0 first unconverged value (error) -302.035 (1.88734610e-06)
156350 EPS nconv=0 first unconverged value (error) -302.035 (1.94313078e-06)
156351 EPS nconv=0 first unconverged value (error) -302.035 (2.02971280e-06)
156352 EPS nconv=0 first unconverged value (error) -302.035 (1.92221766e-06)
156353 EPS nconv=0 first unconverged value (error) -302.035 (1.85083380e-06)
156354 EPS nconv=0 first unconverged value (error) -302.035 (1.83994685e-06)
156355 EPS nconv=0 first unconverged value (error) -302.035 (1.83994685e-06)
156356 EPS nconv=0 first unconverged value (error) -302.035 (1.84973401e-06)
156357 EPS nconv=0 first unconverged value (error) -302.035 (1.84126715e-06)
156358 EPS nconv=0 first unconverged value (error) -302.035 (1.81972431e-06)
156359 EPS nconv=0 first unconverged value (error) -302.035 (1.81424639e-06)
156360 EPS nconv=0 first unconverged value (error) -302.035 (1.81241943e-06)
156361 EPS nconv=0 first unconverged value (error) -302.035 (1.81241943e-06)
156362 EPS nconv=0 first unconverged value (error) -302.035 (1.81808317e-06)
156363 EPS nconv=0 first unconverged value (error) -302.035 (1.82225687e-06)
156364 EPS nconv=0 first unconverged value (error) -302.035 (1.80639777e-06)
156365 EPS nconv=0 first unconverged value (error) -302.035 (1.80307922e-06)
156366 EPS nconv=0 first unconverged value (error) -302.035 (1.80033301e-06)
156367 EPS nconv=0 first unconverged value (error) -302.035 (1.80033301e-06)
156368 EPS nconv=0 first unconverged value (error) -302.035 (2.00129914e-06)
156369 EPS nconv=0 first unconverged value (error) -302.035 (1.95258174e-06)
156370 EPS nconv=0 first unconverged value (error) -302.035 (1.91851097e-06)
156371 EPS nconv=0 first unconverged value (error) -302.035 (1.90826370e-06)
156372 EPS nconv=0 first unconverged value (error) -302.035 (1.88155939e-06)
156373 EPS nconv=0 first unconverged value (error) -302.035 (1.88155939e-06)
156374 EPS nconv=0 first unconverged value (error) -302.035 (1.96867456e-06)
156375 EPS nconv=0 first unconverged value (error) -302.035 (2.02254391e-06)
156376 EPS nconv=0 first unconverged value (error) -302.035 (1.98326410e-06)
156377 EPS nconv=0 first unconverged value (error) -302.035 (1.86711143e-06)
156378 EPS nconv=0 first unconverged value (error) -302.035 (1.85067887e-06)
156379 EPS nconv=0 first unconverged value (error) -302.035 (1.85067887e-06)
156380 EPS nconv=0 first unconverged value (error) -302.035 (1.83899141e-06)
156381 EPS nconv=0 first unconverged value (error) -302.035 (1.82456924e-06)
156382 EPS nconv=0 first unconverged value (error) -302.035 (1.80843430e-06)
156383 EPS nconv=0 first unconverged value (error) -302.035 (1.80375881e-06)
156384 EPS nconv=0 first unconverged value (error) -302.035 (1.80033992e-06)
156385 EPS nconv=0 first unconverged value (error) -302.035 (1.80033992e-06)
156386 EPS nconv=0 first unconverged value (error) -302.035 (1.81205107e-06)
156387 EPS nconv=0 first unconverged value (error) -302.035 (1.80355265e-06)
156388 EPS nconv=0 first unconverged value (error) -302.035 (1.79978374e-06)
156389 EPS nconv=0 first unconverged value (error) -302.035 (1.79716768e-06)
156390 EPS nconv=0 first unconverged value (error) -302.035 (1.79650890e-06)
156391 EPS nconv=0 first unconverged value (error) -302.035 (1.79650890e-06)
156392 EPS nconv=0 first unconverged value (error) -302.035 (1.87111299e-06)
156393 EPS nconv=0 first unconverged value (error) -302.035 (1.86363848e-06)
156394 EPS nconv=0 first unconverged value (error) -302.035 (1.85348763e-06)
156395 EPS nconv=0 first unconverged value (error) -302.035 (1.84397787e-06)
156396 EPS nconv=0 first unconverged value (error) -302.035 (1.83923645e-06)
156397 EPS nconv=0 first unconverged value (error) -302.035 (1.83923645e-06)
156398 EPS nconv=0 first unconverged value (error) -302.035 (1.86604178e-06)
156399 EPS nconv=0 first unconverged value (error) -302.035 (1.83840427e-06)
156400 EPS nconv=0 first unconverged value (error) -302.035 (1.81972501e-06)
156401 EPS nconv=0 first unconverged value (error) -302.035 (1.81580727e-06)
156402 EPS nconv=0 first unconverged value (error) -302.035 (1.81504018e-06)
156403 EPS nconv=0 first unconverged value (error) -302.035 (1.81504018e-06)
156404 EPS nconv=0 first unconverged value (error) -302.035 (1.85910319e-06)
156405 EPS nconv=0 first unconverged value (error) -302.035 (1.84566035e-06)
156406 EPS nconv=0 first unconverged value (error) -302.035 (1.82724722e-06)
156407 EPS nconv=0 first unconverged value (error) -302.035 (1.82185451e-06)
156408 EPS nconv=0 first unconverged value (error) -302.035 (1.81767404e-06)
156409 EPS nconv=0 first unconverged value (error) -302.035 (1.81767404e-06)
156410 EPS nconv=0 first unconverged value (error) -302.035 (2.06989699e-06)
156411 EPS nconv=0 first unconverged value (error) -302.035 (1.93974887e-06)
156412 EPS nconv=0 first unconverged value (error) -302.035 (1.89185865e-06)
156413 EPS nconv=0 first unconverged value (error) -302.035 (1.88158306e-06)
156414 EPS nconv=0 first unconverged value (error) -302.035 (1.87212491e-06)
156415 EPS nconv=0 first unconverged value (error) -302.035 (1.87212491e-06)
156416 EPS nconv=0 first unconverged value (error) -302.035 (1.92625433e-06)
156417 EPS nconv=0 first unconverged value (error) -302.035 (2.01942908e-06)
156418 EPS nconv=0 first unconverged value (error) -302.035 (1.89657614e-06)
156419 EPS nconv=0 first unconverged value (error) -302.035 (1.84369333e-06)
156420 EPS nconv=0 first unconverged value (error) -302.035 (1.82870454e-06)
156421 EPS nconv=0 first unconverged value (error) -302.035 (1.82870454e-06)
156422 EPS nconv=0 first unconverged value (error) -302.035 (1.84937643e-06)
156423 EPS nconv=0 first unconverged value (error) -302.035 (1.85257304e-06)
156424 EPS nconv=0 first unconverged value (error) -302.035 (1.82865507e-06)
156425 EPS nconv=0 first unconverged value (error) -302.035 (1.82125230e-06)
156426 EPS nconv=0 first unconverged value (error) -302.035 (1.81426076e-06)
156427 EPS nconv=0 first unconverged value (error) -302.035 (1.81426076e-06)
156428 EPS nconv=0 first unconverged value (error) -302.035 (1.81288263e-06)
156429 EPS nconv=0 first unconverged value (error) -302.035 (1.82540151e-06)
156430 EPS nconv=0 first unconverged value (error) -302.035 (1.80795299e-06)
156431 EPS nconv=0 first unconverged value (error) -302.035 (1.80163210e-06)
156432 EPS nconv=0 first unconverged value (error) -302.035 (1.79849306e-06)
156433 EPS nconv=0 first unconverged value (error) -302.035 (1.79849306e-06)
156434 EPS nconv=0 first unconverged value (error) -302.035 (2.20161561e-06)
156435 EPS nconv=0 first unconverged value (error) -302.035 (2.03838751e-06)
156436 EPS nconv=0 first unconverged value (error) -302.035 (1.98638597e-06)
156437 EPS nconv=0 first unconverged value (error) -302.035 (1.97509344e-06)
156438 EPS nconv=0 first unconverged value (error) -302.035 (1.93994109e-06)
156439 EPS nconv=0 first unconverged value (error) -302.035 (1.93994109e-06)
156440 EPS nconv=0 first unconverged value (error) -302.035 (2.16535226e-06)
156441 EPS nconv=0 first unconverged value (error) -302.035 (2.32037604e-06)
156442 EPS nconv=0 first unconverged value (error) -302.035 (2.08631130e-06)
156443 EPS nconv=0 first unconverged value (error) -302.035 (1.98566724e-06)
156444 EPS nconv=0 first unconverged value (error) -302.035 (1.92366171e-06)
156445 EPS nconv=0 first unconverged value (error) -302.035 (1.92366171e-06)
156446 EPS nconv=0 first unconverged value (error) -302.035 (1.98786658e-06)
156447 EPS nconv=0 first unconverged value (error) -302.035 (1.99361191e-06)
156448 EPS nconv=0 first unconverged value (error) -302.035 (1.93290749e-06)
156449 EPS nconv=0 first unconverged value (error) -302.035 (1.88832031e-06)
156450 EPS nconv=0 first unconverged value (error) -302.035 (1.87048106e-06)
156451 EPS nconv=0 first unconverged value (error) -302.035 (1.87048106e-06)
156452 EPS nconv=0 first unconverged value (error) -302.035 (1.88863950e-06)
156453 EPS nconv=0 first unconverged value (error) -302.035 (1.86294332e-06)
156454 EPS nconv=0 first unconverged value (error) -302.035 (1.82959833e-06)
156455 EPS nconv=0 first unconverged value (error) -302.035 (1.82149352e-06)
156456 EPS nconv=0 first unconverged value (error) -302.035 (1.81817871e-06)
156457 EPS nconv=0 first unconverged value (error) -302.035 (1.81817871e-06)
156458 EPS nconv=0 first unconverged value (error) -302.035 (2.14484023e-06)
156459 EPS nconv=0 first unconverged value (error) -302.035 (2.02039400e-06)
156460 EPS nconv=0 first unconverged value (error) -302.035 (1.95801486e-06)
156461 EPS nconv=0 first unconverged value (error) -302.035 (1.93874374e-06)
156462 EPS nconv=0 first unconverged value (error) -302.035 (1.91749371e-06)
156463 EPS nconv=0 first unconverged value (error) -302.035 (1.91749371e-06)
156464 EPS nconv=0 first unconverged value (error) -302.035 (1.94213055e-06)
156465 EPS nconv=0 first unconverged value (error) -302.035 (2.06438793e-06)
156466 EPS nconv=0 first unconverged value (error) -302.035 (1.90052684e-06)
156467 EPS nconv=0 first unconverged value (error) -302.035 (1.85113717e-06)
156468 EPS nconv=0 first unconverged value (error) -302.035 (1.82714391e-06)
156469 EPS nconv=0 first unconverged value (error) -302.035 (1.82714391e-06)
156470 EPS nconv=0 first unconverged value (error) -302.035 (1.91048147e-06)
156471 EPS nconv=0 first unconverged value (error) -302.035 (1.88143114e-06)
156472 EPS nconv=0 first unconverged value (error) -302.035 (1.86695537e-06)
156473 EPS nconv=0 first unconverged value (error) -302.035 (1.86081749e-06)
156474 EPS nconv=0 first unconverged value (error) -302.035 (1.84725013e-06)
156475 EPS nconv=0 first unconverged value (error) -302.035 (1.84725013e-06)
156476 EPS nconv=0 first unconverged value (error) -302.035 (1.93797393e-06)
156477 EPS nconv=0 first unconverged value (error) -302.035 (1.89911882e-06)
156478 EPS nconv=0 first unconverged value (error) -302.035 (1.85931276e-06)
156479 EPS nconv=0 first unconverged value (error) -302.035 (1.85316248e-06)
156480 EPS nconv=0 first unconverged value (error) -302.035 (1.84609910e-06)
156481 EPS nconv=0 first unconverged value (error) -302.035 (1.84609910e-06)
156482 EPS nconv=0 first unconverged value (error) -302.035 (1.90490109e-06)
156483 EPS nconv=0 first unconverged value (error) -302.035 (1.89863750e-06)
156484 EPS nconv=0 first unconverged value (error) -302.035 (1.85251437e-06)
156485 EPS nconv=0 first unconverged value (error) -302.035 (1.83848912e-06)
156486 EPS nconv=0 first unconverged value (error) -302.035 (1.82731323e-06)
156487 EPS nconv=0 first unconverged value (error) -302.035 (1.82731323e-06)
156488 EPS nconv=0 first unconverged value (error) -302.035 (2.07798107e-06)
156489 EPS nconv=0 first unconverged value (error) -302.035 (1.99017435e-06)
156490 EPS nconv=0 first unconverged value (error) -302.035 (1.93679585e-06)
156491 EPS nconv=0 first unconverged value (error) -302.035 (1.92162358e-06)
156492 EPS nconv=0 first unconverged value (error) -302.035 (1.89352715e-06)
156493 EPS nconv=0 first unconverged value (error) -302.035 (1.89352715e-06)
156494 EPS nconv=0 first unconverged value (error) -302.035 (1.89026941e-06)
156495 EPS nconv=0 first unconverged value (error) -302.035 (1.98785290e-06)
156496 EPS nconv=0 first unconverged value (error) -302.035 (1.87243805e-06)
156497 EPS nconv=0 first unconverged value (error) -302.035 (1.84164928e-06)
156498 EPS nconv=0 first unconverged value (error) -302.035 (1.81906160e-06)
156499 EPS nconv=0 first unconverged value (error) -302.035 (1.81906160e-06)
156500 EPS nconv=0 first unconverged value (error) -302.035 (2.63051980e-06)
156501 EPS nconv=0 first unconverged value (error) -302.035 (2.45839036e-06)
156502 EPS nconv=0 first unconverged value (error) -302.035 (2.31654550e-06)
156503 EPS nconv=0 first unconverged value (error) -302.035 (2.29545635e-06)
156504 EPS nconv=0 first unconverged value (error) -302.035 (2.18783515e-06)
156505 EPS nconv=0 first unconverged value (error) -302.035 (2.18783515e-06)
156506 EPS nconv=0 first unconverged value (error) -302.035 (2.18249833e-06)
156507 EPS nconv=0 first unconverged value (error) -302.035 (2.34413072e-06)
156508 EPS nconv=0 first unconverged value (error) -302.035 (2.12989604e-06)
156509 EPS nconv=0 first unconverged value (error) -302.035 (1.91323937e-06)
156510 EPS nconv=0 first unconverged value (error) -302.035 (1.90118655e-06)
156511 EPS nconv=0 first unconverged value (error) -302.035 (1.90118655e-06)
156512 EPS nconv=0 first unconverged value (error) -302.035 (2.06460864e-06)
156513 EPS nconv=0 first unconverged value (error) -302.035 (1.95807272e-06)
156514 EPS nconv=0 first unconverged value (error) -302.035 (1.92579645e-06)
156515 EPS nconv=0 first unconverged value (error) -302.035 (1.90787448e-06)
156516 EPS nconv=0 first unconverged value (error) -302.035 (1.89021321e-06)
156517 EPS nconv=0 first unconverged value (error) -302.035 (1.89021321e-06)
156518 EPS nconv=0 first unconverged value (error) -302.035 (2.21090646e-06)
156519 EPS nconv=0 first unconverged value (error) -302.035 (2.23624075e-06)
156520 EPS nconv=0 first unconverged value (error) -302.035 (2.09598075e-06)
156521 EPS nconv=0 first unconverged value (error) -302.035 (2.06903486e-06)
156522 EPS nconv=0 first unconverged value (error) -302.035 (2.05059128e-06)
156523 EPS nconv=0 first unconverged value (error) -302.035 (2.05059128e-06)
156524 EPS nconv=0 first unconverged value (error) -302.035 (2.35531899e-06)
156525 EPS nconv=0 first unconverged value (error) -302.035 (2.19983561e-06)
156526 EPS nconv=0 first unconverged value (error) -302.035 (2.16631581e-06)
156527 EPS nconv=0 first unconverged value (error) -302.035 (2.00535952e-06)
156528 EPS nconv=0 first unconverged value (error) -302.035 (1.94830587e-06)
156529 EPS nconv=0 first unconverged value (error) -302.035 (1.94830587e-06)
156530 EPS nconv=0 first unconverged value (error) -302.035 (2.20047697e-06)
156531 EPS nconv=0 first unconverged value (error) -302.035 (2.14410709e-06)
156532 EPS nconv=0 first unconverged value (error) -302.035 (2.03881499e-06)
156533 EPS nconv=0 first unconverged value (error) -302.035 (1.96822806e-06)
156534 EPS nconv=0 first unconverged value (error) -302.035 (1.94507686e-06)
156535 EPS nconv=0 first unconverged value (error) -302.035 (1.94507686e-06)
156536 EPS nconv=0 first unconverged value (error) -302.035 (1.92393626e-06)
156537 EPS nconv=0 first unconverged value (error) -302.035 (2.01807368e-06)
156538 EPS nconv=0 first unconverged value (error) -302.035 (1.95233095e-06)
156539 EPS nconv=0 first unconverged value (error) -302.035 (1.84912463e-06)
156540 EPS nconv=0 first unconverged value (error) -302.035 (1.81261956e-06)
156541 EPS nconv=0 first unconverged value (error) -302.035 (1.81261956e-06)
156542 EPS nconv=0 first unconverged value (error) -302.035 (2.31634920e-06)
156543 EPS nconv=0 first unconverged value (error) -302.035 (2.24057099e-06)
156544 EPS nconv=0 first unconverged value (error) -302.035 (2.20182495e-06)
156545 EPS nconv=0 first unconverged value (error) -302.035 (2.16307859e-06)
156546 EPS nconv=0 first unconverged value (error) -302.035 (2.10833784e-06)
156547 EPS nconv=0 first unconverged value (error) -302.035 (2.10833784e-06)
156548 EPS nconv=0 first unconverged value (error) -302.035 (2.11654331e-06)
156549 EPS nconv=0 first unconverged value (error) -302.035 (2.09520348e-06)
156550 EPS nconv=0 first unconverged value (error) -302.035 (2.00800589e-06)
156551 EPS nconv=0 first unconverged value (error) -302.035 (1.88585673e-06)
156552 EPS nconv=0 first unconverged value (error) -302.035 (1.85209087e-06)
156553 EPS nconv=0 first unconverged value (error) -302.035 (1.85209087e-06)
156554 EPS nconv=0 first unconverged value (error) -302.035 (1.99801403e-06)
156555 EPS nconv=0 first unconverged value (error) -302.035 (1.93318306e-06)
156556 EPS nconv=0 first unconverged value (error) -302.035 (1.89018964e-06)
156557 EPS nconv=0 first unconverged value (error) -302.035 (1.87751095e-06)
156558 EPS nconv=0 first unconverged value (error) -302.035 (1.87015534e-06)
156559 EPS nconv=0 first unconverged value (error) -302.035 (1.87015534e-06)
156560 EPS nconv=0 first unconverged value (error) -302.035 (2.00395053e-06)
156561 EPS nconv=0 first unconverged value (error) -302.035 (2.00416061e-06)
156562 EPS nconv=0 first unconverged value (error) -302.035 (1.91629027e-06)
156563 EPS nconv=0 first unconverged value (error) -302.035 (1.89370909e-06)
156564 EPS nconv=0 first unconverged value (error) -302.035 (1.86899260e-06)
156565 EPS nconv=0 first unconverged value (error) -302.035 (1.86899260e-06)
156566 EPS nconv=0 first unconverged value (error) -302.035 (2.21815315e-06)
156567 EPS nconv=0 first unconverged value (error) -302.035 (2.21581248e-06)
156568 EPS nconv=0 first unconverged value (error) -302.035 (2.13195946e-06)
156569 EPS nconv=0 first unconverged value (error) -302.035 (2.06861477e-06)
156570 EPS nconv=0 first unconverged value (error) -302.035 (2.01437889e-06)
156571 EPS nconv=0 first unconverged value (error) -302.035 (2.01437889e-06)
156572 EPS nconv=0 first unconverged value (error) -302.035 (2.02453578e-06)
156573 EPS nconv=0 first unconverged value (error) -302.035 (1.96419729e-06)
156574 EPS nconv=0 first unconverged value (error) -302.035 (1.89212696e-06)
156575 EPS nconv=0 first unconverged value (error) -302.035 (1.85661959e-06)
156576 EPS nconv=0 first unconverged value (error) -302.035 (1.84245801e-06)
156577 EPS nconv=0 first unconverged value (error) -302.035 (1.84245801e-06)
156578 EPS nconv=0 first unconverged value (error) -302.035 (1.81718763e-06)
156579 EPS nconv=0 first unconverged value (error) -302.035 (1.82743780e-06)
156580 EPS nconv=0 first unconverged value (error) -302.035 (1.81238020e-06)
156581 EPS nconv=0 first unconverged value (error) -302.035 (1.80385885e-06)
156582 EPS nconv=0 first unconverged value (error) -302.035 (1.80107265e-06)
156583 EPS nconv=0 first unconverged value (error) -302.035 (1.80107265e-06)
156584 EPS nconv=0 first unconverged value (error) -302.035 (1.98967254e-06)
156585 EPS nconv=0 first unconverged value (error) -302.035 (1.91516275e-06)
156586 EPS nconv=0 first unconverged value (error) -302.035 (1.89812341e-06)
156587 EPS nconv=0 first unconverged value (error) -302.035 (1.89405667e-06)
156588 EPS nconv=0 first unconverged value (error) -302.035 (1.86919703e-06)
156589 EPS nconv=0 first unconverged value (error) -302.035 (1.86919703e-06)
156590 EPS nconv=0 first unconverged value (error) -302.035 (2.01252856e-06)
156591 EPS nconv=0 first unconverged value (error) -302.035 (2.08975933e-06)
156592 EPS nconv=0 first unconverged value (error) -302.035 (1.98332717e-06)
156593 EPS nconv=0 first unconverged value (error) -302.035 (1.91345901e-06)
156594 EPS nconv=0 first unconverged value (error) -302.035 (1.89226575e-06)
156595 EPS nconv=0 first unconverged value (error) -302.035 (1.89226575e-06)
156596 EPS nconv=0 first unconverged value (error) -302.035 (1.93648850e-06)
156597 EPS nconv=0 first unconverged value (error) -302.035 (1.90005876e-06)
156598 EPS nconv=0 first unconverged value (error) -302.035 (1.87965129e-06)
156599 EPS nconv=0 first unconverged value (error) -302.035 (1.84960176e-06)
156600 EPS nconv=0 first unconverged value (error) -302.035 (1.82064582e-06)
156601 EPS nconv=0 first unconverged value (error) -302.035 (1.82064582e-06)
156602 EPS nconv=0 first unconverged value (error) -302.035 (1.82133096e-06)
156603 EPS nconv=0 first unconverged value (error) -302.035 (1.83569270e-06)
156604 EPS nconv=0 first unconverged value (error) -302.035 (1.81304506e-06)
156605 EPS nconv=0 first unconverged value (error) -302.035 (1.80497250e-06)
156606 EPS nconv=0 first unconverged value (error) -302.035 (1.80356773e-06)
156607 EPS nconv=0 first unconverged value (error) -302.035 (1.80356773e-06)
156608 EPS nconv=0 first unconverged value (error) -302.035 (2.09621677e-06)
156609 EPS nconv=0 first unconverged value (error) -302.035 (1.97511026e-06)
156610 EPS nconv=0 first unconverged value (error) -302.035 (1.93392553e-06)
156611 EPS nconv=0 first unconverged value (error) -302.035 (1.92062357e-06)
156612 EPS nconv=0 first unconverged value (error) -302.035 (1.89546562e-06)
156613 EPS nconv=0 first unconverged value (error) -302.035 (1.89546562e-06)
156614 EPS nconv=0 first unconverged value (error) -302.035 (1.96635472e-06)
156615 EPS nconv=0 first unconverged value (error) -302.035 (2.09394322e-06)
156616 EPS nconv=0 first unconverged value (error) -302.035 (1.94916189e-06)
156617 EPS nconv=0 first unconverged value (error) -302.035 (1.85869931e-06)
156618 EPS nconv=0 first unconverged value (error) -302.035 (1.84194633e-06)
156619 EPS nconv=0 first unconverged value (error) -302.035 (1.84194633e-06)
156620 EPS nconv=0 first unconverged value (error) -302.035 (1.89117703e-06)
156621 EPS nconv=0 first unconverged value (error) -302.035 (1.87757745e-06)
156622 EPS nconv=0 first unconverged value (error) -302.035 (1.86141191e-06)
156623 EPS nconv=0 first unconverged value (error) -302.035 (1.84750774e-06)
156624 EPS nconv=0 first unconverged value (error) -302.035 (1.83216831e-06)
156625 EPS nconv=0 first unconverged value (error) -302.035 (1.83216831e-06)
156626 EPS nconv=0 first unconverged value (error) -302.035 (1.83112270e-06)
156627 EPS nconv=0 first unconverged value (error) -302.035 (1.84228185e-06)
156628 EPS nconv=0 first unconverged value (error) -302.035 (1.82002460e-06)
156629 EPS nconv=0 first unconverged value (error) -302.035 (1.80520048e-06)
156630 EPS nconv=0 first unconverged value (error) -302.035 (1.80196301e-06)
156631 EPS nconv=0 first unconverged value (error) -302.035 (1.80196301e-06)
156632 EPS nconv=0 first unconverged value (error) -302.035 (1.82255272e-06)
156633 EPS nconv=0 first unconverged value (error) -302.035 (1.81101848e-06)
156634 EPS nconv=0 first unconverged value (error) -302.035 (1.80652066e-06)
156635 EPS nconv=0 first unconverged value (error) -302.035 (1.80559276e-06)
156636 EPS nconv=0 first unconverged value (error) -302.035 (1.80388950e-06)
156637 EPS nconv=0 first unconverged value (error) -302.035 (1.80388950e-06)
156638 EPS nconv=0 first unconverged value (error) -302.035 (1.91126289e-06)
156639 EPS nconv=0 first unconverged value (error) -302.035 (1.89829944e-06)
156640 EPS nconv=0 first unconverged value (error) -302.035 (1.86139900e-06)
156641 EPS nconv=0 first unconverged value (error) -302.035 (1.84275157e-06)
156642 EPS nconv=0 first unconverged value (error) -302.035 (1.83233475e-06)
156643 EPS nconv=0 first unconverged value (error) -302.035 (1.83233475e-06)
156644 EPS nconv=0 first unconverged value (error) -302.035 (1.83100834e-06)
156645 EPS nconv=0 first unconverged value (error) -302.035 (1.86160690e-06)
156646 EPS nconv=0 first unconverged value (error) -302.035 (1.83473824e-06)
156647 EPS nconv=0 first unconverged value (error) -302.035 (1.80801900e-06)
156648 EPS nconv=0 first unconverged value (error) -302.035 (1.80405136e-06)
156649 EPS nconv=0 first unconverged value (error) -302.035 (1.80405136e-06)
156650 EPS nconv=0 first unconverged value (error) -302.035 (1.81990937e-06)
156651 EPS nconv=0 first unconverged value (error) -302.035 (1.80840740e-06)
156652 EPS nconv=0 first unconverged value (error) -302.035 (1.80626496e-06)
156653 EPS nconv=0 first unconverged value (error) -302.035 (1.80505347e-06)
156654 EPS nconv=0 first unconverged value (error) -302.035 (1.80224591e-06)
156655 EPS nconv=0 first unconverged value (error) -302.035 (1.80224591e-06)
156656 EPS nconv=0 first unconverged value (error) -302.035 (1.80403516e-06)
156657 EPS nconv=0 first unconverged value (error) -302.035 (1.81091792e-06)
156658 EPS nconv=0 first unconverged value (error) -302.035 (1.80142799e-06)
156659 EPS nconv=0 first unconverged value (error) -302.035 (1.79810856e-06)
156660 EPS nconv=0 first unconverged value (error) -302.035 (1.79724537e-06)
156661 EPS nconv=0 first unconverged value (error) -302.035 (1.79724537e-06)
156662 EPS nconv=0 first unconverged value (error) -302.035 (1.91041411e-06)
156663 EPS nconv=0 first unconverged value (error) -302.035 (1.87092602e-06)
156664 EPS nconv=0 first unconverged value (error) -302.035 (1.84653084e-06)
156665 EPS nconv=0 first unconverged value (error) -302.035 (1.84245425e-06)
156666 EPS nconv=0 first unconverged value (error) -302.035 (1.83240802e-06)
156667 EPS nconv=0 first unconverged value (error) -302.035 (1.83240802e-06)
156668 EPS nconv=0 first unconverged value (error) -302.035 (1.83091894e-06)
156669 EPS nconv=0 first unconverged value (error) -302.035 (1.86837620e-06)
156670 EPS nconv=0 first unconverged value (error) -302.035 (1.83178196e-06)
156671 EPS nconv=0 first unconverged value (error) -302.035 (1.80302343e-06)
156672 EPS nconv=0 first unconverged value (error) -302.035 (1.80121465e-06)
156673 EPS nconv=0 first unconverged value (error) -302.035 (1.80121465e-06)
156674 EPS nconv=0 first unconverged value (error) -302.035 (1.80395381e-06)
156675 EPS nconv=0 first unconverged value (error) -302.035 (1.80029927e-06)
156676 EPS nconv=0 first unconverged value (error) -302.035 (1.79933244e-06)
156677 EPS nconv=0 first unconverged value (error) -302.035 (1.79858111e-06)
156678 EPS nconv=0 first unconverged value (error) -302.035 (1.79772796e-06)
156679 EPS nconv=0 first unconverged value (error) -302.035 (1.79772796e-06)
156680 EPS nconv=0 first unconverged value (error) -302.035 (1.79789959e-06)
156681 EPS nconv=0 first unconverged value (error) -302.035 (1.79873003e-06)
156682 EPS nconv=0 first unconverged value (error) -302.035 (1.79530972e-06)
156683 EPS nconv=0 first unconverged value (error) -302.035 (1.79475472e-06)
156684 EPS nconv=0 first unconverged value (error) -302.035 (1.79454022e-06)
156685 EPS nconv=0 first unconverged value (error) -302.035 (1.79454022e-06)
156686 EPS nconv=0 first unconverged value (error) -302.035 (2.00816977e-06)
156687 EPS nconv=0 first unconverged value (error) -302.035 (1.93805208e-06)
156688 EPS nconv=0 first unconverged value (error) -302.035 (1.89743310e-06)
156689 EPS nconv=0 first unconverged value (error) -302.035 (1.89308964e-06)
156690 EPS nconv=0 first unconverged value (error) -302.035 (1.88201233e-06)
156691 EPS nconv=0 first unconverged value (error) -302.035 (1.88201233e-06)
156692 EPS nconv=0 first unconverged value (error) -302.035 (1.99938881e-06)
156693 EPS nconv=0 first unconverged value (error) -302.035 (2.04334756e-06)
156694 EPS nconv=0 first unconverged value (error) -302.035 (1.95017261e-06)
156695 EPS nconv=0 first unconverged value (error) -302.035 (1.84869308e-06)
156696 EPS nconv=0 first unconverged value (error) -302.035 (1.83892676e-06)
156697 EPS nconv=0 first unconverged value (error) -302.035 (1.83892676e-06)
156698 EPS nconv=0 first unconverged value (error) -302.035 (1.83648447e-06)
156699 EPS nconv=0 first unconverged value (error) -302.035 (1.86386261e-06)
156700 EPS nconv=0 first unconverged value (error) -302.035 (1.83267613e-06)
156701 EPS nconv=0 first unconverged value (error) -302.035 (1.81591510e-06)
156702 EPS nconv=0 first unconverged value (error) -302.035 (1.80469921e-06)
156703 EPS nconv=0 first unconverged value (error) -302.035 (1.80469921e-06)
156704 EPS nconv=0 first unconverged value (error) -302.035 (1.80071925e-06)
156705 EPS nconv=0 first unconverged value (error) -302.035 (1.80047519e-06)
156706 EPS nconv=0 first unconverged value (error) -302.035 (1.79794995e-06)
156707 EPS nconv=0 first unconverged value (error) -302.035 (1.79639716e-06)
156708 EPS nconv=0 first unconverged value (error) -302.035 (1.79566681e-06)
156709 EPS nconv=0 first unconverged value (error) -302.035 (1.79566681e-06)
156710 EPS nconv=0 first unconverged value (error) -302.035 (1.96260578e-06)
156711 EPS nconv=0 first unconverged value (error) -302.035 (1.90793804e-06)
156712 EPS nconv=0 first unconverged value (error) -302.035 (1.87581355e-06)
156713 EPS nconv=0 first unconverged value (error) -302.035 (1.86428473e-06)
156714 EPS nconv=0 first unconverged value (error) -302.035 (1.85783357e-06)
156715 EPS nconv=0 first unconverged value (error) -302.035 (1.85783357e-06)
156716 EPS nconv=0 first unconverged value (error) -302.035 (1.94051412e-06)
156717 EPS nconv=0 first unconverged value (error) -302.035 (1.97280322e-06)
156718 EPS nconv=0 first unconverged value (error) -302.035 (1.90619451e-06)
156719 EPS nconv=0 first unconverged value (error) -302.035 (1.83939850e-06)
156720 EPS nconv=0 first unconverged value (error) -302.035 (1.83023971e-06)
156721 EPS nconv=0 first unconverged value (error) -302.035 (1.83023971e-06)
156722 EPS nconv=0 first unconverged value (error) -302.035 (1.94082001e-06)
156723 EPS nconv=0 first unconverged value (error) -302.035 (1.93493488e-06)
156724 EPS nconv=0 first unconverged value (error) -302.035 (1.91259793e-06)
156725 EPS nconv=0 first unconverged value (error) -302.035 (1.87952486e-06)
156726 EPS nconv=0 first unconverged value (error) -302.035 (1.86961937e-06)
156727 EPS nconv=0 first unconverged value (error) -302.035 (1.86961937e-06)
156728 EPS nconv=0 first unconverged value (error) -302.035 (1.87515522e-06)
156729 EPS nconv=0 first unconverged value (error) -302.035 (1.85235220e-06)
156730 EPS nconv=0 first unconverged value (error) -302.035 (1.82205940e-06)
156731 EPS nconv=0 first unconverged value (error) -302.035 (1.82513698e-06)
156732 EPS nconv=0 first unconverged value (error) -302.035 (1.81397261e-06)
156733 EPS nconv=0 first unconverged value (error) -302.035 (1.81397261e-06)
156734 EPS nconv=0 first unconverged value (error) -302.035 (1.95440875e-06)
156735 EPS nconv=0 first unconverged value (error) -302.035 (1.90773453e-06)
156736 EPS nconv=0 first unconverged value (error) -302.035 (1.87154736e-06)
156737 EPS nconv=0 first unconverged value (error) -302.035 (1.86172682e-06)
156738 EPS nconv=0 first unconverged value (error) -302.035 (1.85027866e-06)
156739 EPS nconv=0 first unconverged value (error) -302.035 (1.85027866e-06)
156740 EPS nconv=0 first unconverged value (error) -302.035 (1.93272287e-06)
156741 EPS nconv=0 first unconverged value (error) -302.035 (1.94154883e-06)
156742 EPS nconv=0 first unconverged value (error) -302.035 (1.88106997e-06)
156743 EPS nconv=0 first unconverged value (error) -302.035 (1.86825229e-06)
156744 EPS nconv=0 first unconverged value (error) -302.035 (1.84129624e-06)
156745 EPS nconv=0 first unconverged value (error) -302.035 (1.84129624e-06)
156746 EPS nconv=0 first unconverged value (error) -302.035 (1.84700758e-06)
156747 EPS nconv=0 first unconverged value (error) -302.035 (1.86602922e-06)
156748 EPS nconv=0 first unconverged value (error) -302.035 (1.84140575e-06)
156749 EPS nconv=0 first unconverged value (error) -302.035 (1.81525341e-06)
156750 EPS nconv=0 first unconverged value (error) -302.035 (1.80929998e-06)
156751 EPS nconv=0 first unconverged value (error) -302.035 (1.80929998e-06)
156752 EPS nconv=0 first unconverged value (error) -302.035 (1.84982049e-06)
156753 EPS nconv=0 first unconverged value (error) -302.035 (1.82271687e-06)
156754 EPS nconv=0 first unconverged value (error) -302.035 (1.81841181e-06)
156755 EPS nconv=0 first unconverged value (error) -302.035 (1.81095712e-06)
156756 EPS nconv=0 first unconverged value (error) -302.035 (1.80672778e-06)
156757 EPS nconv=0 first unconverged value (error) -302.035 (1.80672778e-06)
156758 EPS nconv=0 first unconverged value (error) -302.035 (1.91160078e-06)
156759 EPS nconv=0 first unconverged value (error) -302.035 (1.89492508e-06)
156760 EPS nconv=0 first unconverged value (error) -302.035 (1.86332501e-06)
156761 EPS nconv=0 first unconverged value (error) -302.035 (1.85007569e-06)
156762 EPS nconv=0 first unconverged value (error) -302.035 (1.83742538e-06)
156763 EPS nconv=0 first unconverged value (error) -302.035 (1.83742538e-06)
156764 EPS nconv=0 first unconverged value (error) -302.035 (1.97420430e-06)
156765 EPS nconv=0 first unconverged value (error) -302.035 (1.94983102e-06)
156766 EPS nconv=0 first unconverged value (error) -302.035 (1.90636609e-06)
156767 EPS nconv=0 first unconverged value (error) -302.035 (1.89191354e-06)
156768 EPS nconv=0 first unconverged value (error) -302.035 (1.86778657e-06)
156769 EPS nconv=0 first unconverged value (error) -302.035 (1.86778657e-06)
156770 EPS nconv=0 first unconverged value (error) -302.035 (2.10810247e-06)
156771 EPS nconv=0 first unconverged value (error) -302.035 (2.07333661e-06)
156772 EPS nconv=0 first unconverged value (error) -302.035 (1.99289519e-06)
156773 EPS nconv=0 first unconverged value (error) -302.035 (1.98977946e-06)
156774 EPS nconv=0 first unconverged value (error) -302.035 (1.96815442e-06)
156775 EPS nconv=0 first unconverged value (error) -302.035 (1.96815442e-06)
156776 EPS nconv=0 first unconverged value (error) -302.035 (2.04994456e-06)
156777 EPS nconv=0 first unconverged value (error) -302.035 (1.98218676e-06)
156778 EPS nconv=0 first unconverged value (error) -302.035 (1.94970884e-06)
156779 EPS nconv=0 first unconverged value (error) -302.035 (1.90680968e-06)
156780 EPS nconv=0 first unconverged value (error) -302.035 (1.85205619e-06)
156781 EPS nconv=0 first unconverged value (error) -302.035 (1.85205619e-06)
156782 EPS nconv=0 first unconverged value (error) -302.035 (1.84428262e-06)
156783 EPS nconv=0 first unconverged value (error) -302.035 (1.88480546e-06)
156784 EPS nconv=0 first unconverged value (error) -302.035 (1.84294870e-06)
156785 EPS nconv=0 first unconverged value (error) -302.035 (1.81375738e-06)
156786 EPS nconv=0 first unconverged value (error) -302.035 (1.80694895e-06)
156787 EPS nconv=0 first unconverged value (error) -302.035 (1.80694895e-06)
156788 EPS nconv=0 first unconverged value (error) -302.035 (1.81946804e-06)
156789 EPS nconv=0 first unconverged value (error) -302.035 (1.81891856e-06)
156790 EPS nconv=0 first unconverged value (error) -302.035 (1.81043271e-06)
156791 EPS nconv=0 first unconverged value (error) -302.035 (1.80976308e-06)
156792 EPS nconv=0 first unconverged value (error) -302.035 (1.80594592e-06)
156793 EPS nconv=0 first unconverged value (error) -302.035 (1.80594592e-06)
156794 EPS nconv=0 first unconverged value (error) -302.035 (1.80873652e-06)
156795 EPS nconv=0 first unconverged value (error) -302.035 (1.80664905e-06)
156796 EPS nconv=0 first unconverged value (error) -302.035 (1.80079487e-06)
156797 EPS nconv=0 first unconverged value (error) -302.035 (1.79945512e-06)
156798 EPS nconv=0 first unconverged value (error) -302.035 (1.79875264e-06)
156799 EPS nconv=0 first unconverged value (error) -302.035 (1.79875264e-06)
156800 EPS nconv=0 first unconverged value (error) -302.035 (1.94442663e-06)
156801 EPS nconv=0 first unconverged value (error) -302.035 (1.88303931e-06)
156802 EPS nconv=0 first unconverged value (error) -302.035 (1.86142876e-06)
156803 EPS nconv=0 first unconverged value (error) -302.035 (1.84660737e-06)
156804 EPS nconv=0 first unconverged value (error) -302.035 (1.83969540e-06)
156805 EPS nconv=0 first unconverged value (error) -302.035 (1.83969540e-06)
156806 EPS nconv=0 first unconverged value (error) -302.035 (1.84455631e-06)
156807 EPS nconv=0 first unconverged value (error) -302.035 (1.90358789e-06)
156808 EPS nconv=0 first unconverged value (error) -302.035 (1.83634662e-06)
156809 EPS nconv=0 first unconverged value (error) -302.035 (1.81310095e-06)
156810 EPS nconv=0 first unconverged value (error) -302.035 (1.80206909e-06)
156811 EPS nconv=0 first unconverged value (error) -302.035 (1.80206909e-06)
156812 EPS nconv=0 first unconverged value (error) -302.035 (1.90008655e-06)
156813 EPS nconv=0 first unconverged value (error) -302.035 (1.88043952e-06)
156814 EPS nconv=0 first unconverged value (error) -302.035 (1.86699023e-06)
156815 EPS nconv=0 first unconverged value (error) -302.035 (1.86578632e-06)
156816 EPS nconv=0 first unconverged value (error) -302.035 (1.85374776e-06)
156817 EPS nconv=0 first unconverged value (error) -302.035 (1.85374776e-06)
156818 EPS nconv=0 first unconverged value (error) -302.035 (1.99891565e-06)
156819 EPS nconv=0 first unconverged value (error) -302.035 (1.93377945e-06)
156820 EPS nconv=0 first unconverged value (error) -302.035 (1.88573031e-06)
156821 EPS nconv=0 first unconverged value (error) -302.035 (1.88178453e-06)
156822 EPS nconv=0 first unconverged value (error) -302.035 (1.87917435e-06)
156823 EPS nconv=0 first unconverged value (error) -302.035 (1.87917435e-06)
156824 EPS nconv=0 first unconverged value (error) -302.035 (2.06533824e-06)
156825 EPS nconv=0 first unconverged value (error) -302.035 (2.01798410e-06)
156826 EPS nconv=0 first unconverged value (error) -302.035 (1.94495749e-06)
156827 EPS nconv=0 first unconverged value (error) -302.035 (1.88209666e-06)
156828 EPS nconv=0 first unconverged value (error) -302.035 (1.86313044e-06)
156829 EPS nconv=0 first unconverged value (error) -302.035 (1.86313044e-06)
156830 EPS nconv=0 first unconverged value (error) -302.035 (1.96522311e-06)
156831 EPS nconv=0 first unconverged value (error) -302.035 (1.99711305e-06)
156832 EPS nconv=0 first unconverged value (error) -302.035 (1.90325590e-06)
156833 EPS nconv=0 first unconverged value (error) -302.035 (1.85493227e-06)
156834 EPS nconv=0 first unconverged value (error) -302.035 (1.83536367e-06)
156835 EPS nconv=0 first unconverged value (error) -302.035 (1.83536367e-06)
156836 EPS nconv=0 first unconverged value (error) -302.035 (1.95036621e-06)
156837 EPS nconv=0 first unconverged value (error) -302.035 (1.93895584e-06)
156838 EPS nconv=0 first unconverged value (error) -302.035 (1.89674770e-06)
156839 EPS nconv=0 first unconverged value (error) -302.035 (1.89363981e-06)
156840 EPS nconv=0 first unconverged value (error) -302.035 (1.87940059e-06)
156841 EPS nconv=0 first unconverged value (error) -302.035 (1.87940059e-06)
156842 EPS nconv=0 first unconverged value (error) -302.035 (1.86921172e-06)
156843 EPS nconv=0 first unconverged value (error) -302.035 (1.86890481e-06)
156844 EPS nconv=0 first unconverged value (error) -302.035 (1.83805945e-06)
156845 EPS nconv=0 first unconverged value (error) -302.035 (1.81762414e-06)
156846 EPS nconv=0 first unconverged value (error) -302.035 (1.81545215e-06)
156847 EPS nconv=0 first unconverged value (error) -302.035 (1.81545215e-06)
156848 EPS nconv=0 first unconverged value (error) -302.035 (2.13656602e-06)
156849 EPS nconv=0 first unconverged value (error) -302.035 (2.00807062e-06)
156850 EPS nconv=0 first unconverged value (error) -302.035 (1.95402146e-06)
156851 EPS nconv=0 first unconverged value (error) -302.035 (1.92365891e-06)
156852 EPS nconv=0 first unconverged value (error) -302.035 (1.90576754e-06)
156853 EPS nconv=0 first unconverged value (error) -302.035 (1.90576754e-06)
156854 EPS nconv=0 first unconverged value (error) -302.035 (2.01160716e-06)
156855 EPS nconv=0 first unconverged value (error) -302.035 (2.09321582e-06)
156856 EPS nconv=0 first unconverged value (error) -302.035 (1.94839699e-06)
156857 EPS nconv=0 first unconverged value (error) -302.035 (1.91465759e-06)
156858 EPS nconv=0 first unconverged value (error) -302.035 (1.88071725e-06)
156859 EPS nconv=0 first unconverged value (error) -302.035 (1.88071725e-06)
156860 EPS nconv=0 first unconverged value (error) -302.035 (1.90409945e-06)
156861 EPS nconv=0 first unconverged value (error) -302.035 (1.90667170e-06)
156862 EPS nconv=0 first unconverged value (error) -302.035 (1.88948126e-06)
156863 EPS nconv=0 first unconverged value (error) -302.035 (1.83009738e-06)
156864 EPS nconv=0 first unconverged value (error) -302.035 (1.81903053e-06)
156865 EPS nconv=0 first unconverged value (error) -302.035 (1.81903053e-06)
156866 EPS nconv=0 first unconverged value (error) -302.035 (1.81522057e-06)
156867 EPS nconv=0 first unconverged value (error) -302.035 (1.81392803e-06)
156868 EPS nconv=0 first unconverged value (error) -302.035 (1.80690079e-06)
156869 EPS nconv=0 first unconverged value (error) -302.035 (1.79967809e-06)
156870 EPS nconv=0 first unconverged value (error) -302.035 (1.79908889e-06)
156871 EPS nconv=0 first unconverged value (error) -302.035 (1.79908889e-06)
156872 EPS nconv=0 first unconverged value (error) -302.035 (2.05279249e-06)
156873 EPS nconv=0 first unconverged value (error) -302.035 (1.94092253e-06)
156874 EPS nconv=0 first unconverged value (error) -302.035 (1.91138776e-06)
156875 EPS nconv=0 first unconverged value (error) -302.035 (1.89326250e-06)
156876 EPS nconv=0 first unconverged value (error) -302.035 (1.88040139e-06)
156877 EPS nconv=0 first unconverged value (error) -302.035 (1.88040139e-06)
156878 EPS nconv=0 first unconverged value (error) -302.035 (2.32168421e-06)
156879 EPS nconv=0 first unconverged value (error) -302.035 (2.25184076e-06)
156880 EPS nconv=0 first unconverged value (error) -302.035 (2.06731612e-06)
156881 EPS nconv=0 first unconverged value (error) -302.035 (2.05317992e-06)
156882 EPS nconv=0 first unconverged value (error) -302.035 (2.01498277e-06)
156883 EPS nconv=0 first unconverged value (error) -302.035 (2.01498277e-06)
156884 EPS nconv=0 first unconverged value (error) -302.035 (2.02346145e-06)
156885 EPS nconv=0 first unconverged value (error) -302.035 (2.11442609e-06)
156886 EPS nconv=0 first unconverged value (error) -302.035 (1.98820837e-06)
156887 EPS nconv=0 first unconverged value (error) -302.035 (1.87428189e-06)
156888 EPS nconv=0 first unconverged value (error) -302.035 (1.84555399e-06)
156889 EPS nconv=0 first unconverged value (error) -302.035 (1.84555399e-06)
156890 EPS nconv=0 first unconverged value (error) -302.035 (2.09709678e-06)
156891 EPS nconv=0 first unconverged value (error) -302.035 (2.03444382e-06)
156892 EPS nconv=0 first unconverged value (error) -302.035 (1.96789822e-06)
156893 EPS nconv=0 first unconverged value (error) -302.035 (1.92141774e-06)
156894 EPS nconv=0 first unconverged value (error) -302.035 (1.90271234e-06)
156895 EPS nconv=0 first unconverged value (error) -302.035 (1.90271234e-06)
156896 EPS nconv=0 first unconverged value (error) -302.035 (1.90284392e-06)
156897 EPS nconv=0 first unconverged value (error) -302.035 (2.01139945e-06)
156898 EPS nconv=0 first unconverged value (error) -302.035 (1.90571190e-06)
156899 EPS nconv=0 first unconverged value (error) -302.035 (1.83479796e-06)
156900 EPS nconv=0 first unconverged value (error) -302.035 (1.81631151e-06)
156901 EPS nconv=0 first unconverged value (error) -302.035 (1.81631151e-06)
156902 EPS nconv=0 first unconverged value (error) -302.035 (2.21296193e-06)
156903 EPS nconv=0 first unconverged value (error) -302.035 (2.10354868e-06)
156904 EPS nconv=0 first unconverged value (error) -302.035 (2.04421445e-06)
156905 EPS nconv=0 first unconverged value (error) -302.035 (2.00920550e-06)
156906 EPS nconv=0 first unconverged value (error) -302.035 (1.96728990e-06)
156907 EPS nconv=0 first unconverged value (error) -302.035 (1.96728990e-06)
156908 EPS nconv=0 first unconverged value (error) -302.035 (2.00349309e-06)
156909 EPS nconv=0 first unconverged value (error) -302.035 (2.09284474e-06)
156910 EPS nconv=0 first unconverged value (error) -302.035 (1.97856096e-06)
156911 EPS nconv=0 first unconverged value (error) -302.035 (1.87196448e-06)
156912 EPS nconv=0 first unconverged value (error) -302.035 (1.85260144e-06)
156913 EPS nconv=0 first unconverged value (error) -302.035 (1.85260144e-06)
156914 EPS nconv=0 first unconverged value (error) -302.035 (1.91188911e-06)
156915 EPS nconv=0 first unconverged value (error) -302.035 (1.86777088e-06)
156916 EPS nconv=0 first unconverged value (error) -302.035 (1.85270551e-06)
156917 EPS nconv=0 first unconverged value (error) -302.035 (1.84754085e-06)
156918 EPS nconv=0 first unconverged value (error) -302.035 (1.84176379e-06)
156919 EPS nconv=0 first unconverged value (error) -302.035 (1.84176379e-06)
156920 EPS nconv=0 first unconverged value (error) -302.035 (1.87542643e-06)
156921 EPS nconv=0 first unconverged value (error) -302.035 (1.86665350e-06)
156922 EPS nconv=0 first unconverged value (error) -302.035 (1.83683786e-06)
156923 EPS nconv=0 first unconverged value (error) -302.035 (1.82380646e-06)
156924 EPS nconv=0 first unconverged value (error) -302.035 (1.82102195e-06)
156925 EPS nconv=0 first unconverged value (error) -302.035 (1.82102195e-06)
156926 EPS nconv=0 first unconverged value (error) -302.035 (2.27223656e-06)
156927 EPS nconv=0 first unconverged value (error) -302.035 (2.10881659e-06)
156928 EPS nconv=0 first unconverged value (error) -302.035 (2.02421500e-06)
156929 EPS nconv=0 first unconverged value (error) -302.035 (1.98349286e-06)
156930 EPS nconv=0 first unconverged value (error) -302.035 (1.95609085e-06)
156931 EPS nconv=0 first unconverged value (error) -302.035 (1.95609085e-06)
156932 EPS nconv=0 first unconverged value (error) -302.035 (2.03769678e-06)
156933 EPS nconv=0 first unconverged value (error) -302.035 (2.20438397e-06)
156934 EPS nconv=0 first unconverged value (error) -302.035 (2.01476774e-06)
156935 EPS nconv=0 first unconverged value (error) -302.035 (1.89380307e-06)
156936 EPS nconv=0 first unconverged value (error) -302.035 (1.86266114e-06)
156937 EPS nconv=0 first unconverged value (error) -302.035 (1.86266114e-06)
156938 EPS nconv=0 first unconverged value (error) -302.035 (2.07050477e-06)
156939 EPS nconv=0 first unconverged value (error) -302.035 (2.04045771e-06)
156940 EPS nconv=0 first unconverged value (error) -302.035 (1.99222750e-06)
156941 EPS nconv=0 first unconverged value (error) -302.035 (1.95421297e-06)
156942 EPS nconv=0 first unconverged value (error) -302.035 (1.92458657e-06)
156943 EPS nconv=0 first unconverged value (error) -302.035 (1.92458657e-06)
156944 EPS nconv=0 first unconverged value (error) -302.035 (1.96065541e-06)
156945 EPS nconv=0 first unconverged value (error) -302.035 (1.94655387e-06)
156946 EPS nconv=0 first unconverged value (error) -302.035 (1.87505162e-06)
156947 EPS nconv=0 first unconverged value (error) -302.035 (1.86363955e-06)
156948 EPS nconv=0 first unconverged value (error) -302.035 (1.84806571e-06)
156949 EPS nconv=0 first unconverged value (error) -302.035 (1.84806571e-06)
156950 EPS nconv=0 first unconverged value (error) -302.035 (2.37298696e-06)
156951 EPS nconv=0 first unconverged value (error) -302.035 (2.25109679e-06)
156952 EPS nconv=0 first unconverged value (error) -302.035 (2.09229934e-06)
156953 EPS nconv=0 first unconverged value (error) -302.035 (2.04812946e-06)
156954 EPS nconv=0 first unconverged value (error) -302.035 (2.00785327e-06)
156955 EPS nconv=0 first unconverged value (error) -302.035 (2.00785327e-06)
156956 EPS nconv=0 first unconverged value (error) -302.035 (2.15405301e-06)
156957 EPS nconv=0 first unconverged value (error) -302.035 (2.29449015e-06)
156958 EPS nconv=0 first unconverged value (error) -302.035 (2.11277378e-06)
156959 EPS nconv=0 first unconverged value (error) -302.035 (1.92817067e-06)
156960 EPS nconv=0 first unconverged value (error) -302.035 (1.88293318e-06)
156961 EPS nconv=0 first unconverged value (error) -302.035 (1.88293318e-06)
156962 EPS nconv=0 first unconverged value (error) -302.035 (2.15120245e-06)
156963 EPS nconv=0 first unconverged value (error) -302.035 (2.11307895e-06)
156964 EPS nconv=0 first unconverged value (error) -302.035 (2.06587599e-06)
156965 EPS nconv=0 first unconverged value (error) -302.035 (2.01155118e-06)
156966 EPS nconv=0 first unconverged value (error) -302.035 (1.95782497e-06)
156967 EPS nconv=0 first unconverged value (error) -302.035 (1.95782497e-06)
156968 EPS nconv=0 first unconverged value (error) -302.035 (1.98376673e-06)
156969 EPS nconv=0 first unconverged value (error) -302.035 (1.99306904e-06)
156970 EPS nconv=0 first unconverged value (error) -302.035 (1.88731864e-06)
156971 EPS nconv=0 first unconverged value (error) -302.035 (1.87954129e-06)
156972 EPS nconv=0 first unconverged value (error) -302.035 (1.85701136e-06)
156973 EPS nconv=0 first unconverged value (error) -302.035 (1.85701136e-06)
156974 EPS nconv=0 first unconverged value (error) -302.035 (2.33931675e-06)
156975 EPS nconv=0 first unconverged value (error) -302.035 (2.20201582e-06)
156976 EPS nconv=0 first unconverged value (error) -302.035 (2.06487793e-06)
156977 EPS nconv=0 first unconverged value (error) -302.035 (2.03806353e-06)
156978 EPS nconv=0 first unconverged value (error) -302.035 (1.99337758e-06)
156979 EPS nconv=0 first unconverged value (error) -302.035 (1.99337758e-06)
156980 EPS nconv=0 first unconverged value (error) -302.035 (2.27221467e-06)
156981 EPS nconv=0 first unconverged value (error) -302.035 (2.31453936e-06)
156982 EPS nconv=0 first unconverged value (error) -302.035 (2.13446716e-06)
156983 EPS nconv=0 first unconverged value (error) -302.035 (2.01167272e-06)
156984 EPS nconv=0 first unconverged value (error) -302.035 (1.95254375e-06)
156985 EPS nconv=0 first unconverged value (error) -302.035 (1.95254375e-06)
156986 EPS nconv=0 first unconverged value (error) -302.035 (2.49208521e-06)
156987 EPS nconv=0 first unconverged value (error) -302.035 (2.47623593e-06)
156988 EPS nconv=0 first unconverged value (error) -302.035 (2.33053443e-06)
156989 EPS nconv=0 first unconverged value (error) -302.035 (2.21890177e-06)
156990 EPS nconv=0 first unconverged value (error) -302.035 (2.11297944e-06)
156991 EPS nconv=0 first unconverged value (error) -302.035 (2.11297944e-06)
156992 EPS nconv=0 first unconverged value (error) -302.035 (2.15081339e-06)
156993 EPS nconv=0 first unconverged value (error) -302.035 (2.17302747e-06)
156994 EPS nconv=0 first unconverged value (error) -302.035 (2.00674698e-06)
156995 EPS nconv=0 first unconverged value (error) -302.035 (1.95279889e-06)
156996 EPS nconv=0 first unconverged value (error) -302.035 (1.92213727e-06)
156997 EPS nconv=0 first unconverged value (error) -302.035 (1.92213727e-06)
156998 EPS nconv=0 first unconverged value (error) -302.035 (2.07596062e-06)
156999 EPS nconv=0 first unconverged value (error) -302.035 (1.98085456e-06)
157000 EPS nconv=0 first unconverged value (error) -302.035 (1.92219714e-06)
157001 EPS nconv=0 first unconverged value (error) -302.035 (1.90642221e-06)
157002 EPS nconv=0 first unconverged value (error) -302.035 (1.88788644e-06)
157003 EPS nconv=0 first unconverged value (error) -302.035 (1.88788644e-06)
157004 EPS nconv=0 first unconverged value (error) -302.035 (1.89818082e-06)
157005 EPS nconv=0 first unconverged value (error) -302.035 (1.99174988e-06)
157006 EPS nconv=0 first unconverged value (error) -302.035 (1.89345848e-06)
157007 EPS nconv=0 first unconverged value (error) -302.035 (1.84086706e-06)
157008 EPS nconv=0 first unconverged value (error) -302.035 (1.82251790e-06)
157009 EPS nconv=0 first unconverged value (error) -302.035 (1.82251790e-06)
157010 EPS nconv=0 first unconverged value (error) -302.035 (2.21604524e-06)
157011 EPS nconv=0 first unconverged value (error) -302.035 (2.11247655e-06)
157012 EPS nconv=0 first unconverged value (error) -302.035 (2.08241677e-06)
157013 EPS nconv=0 first unconverged value (error) -302.035 (2.06100869e-06)
157014 EPS nconv=0 first unconverged value (error) -302.035 (1.99820579e-06)
157015 EPS nconv=0 first unconverged value (error) -302.035 (1.99820579e-06)
157016 EPS nconv=0 first unconverged value (error) -302.035 (2.20714993e-06)
157017 EPS nconv=0 first unconverged value (error) -302.035 (2.18399854e-06)
157018 EPS nconv=0 first unconverged value (error) -302.035 (2.05310054e-06)
157019 EPS nconv=0 first unconverged value (error) -302.035 (2.02071640e-06)
157020 EPS nconv=0 first unconverged value (error) -302.035 (2.01437639e-06)
157021 EPS nconv=0 first unconverged value (error) -302.035 (2.01437639e-06)
157022 EPS nconv=0 first unconverged value (error) -302.035 (2.22675241e-06)
157023 EPS nconv=0 first unconverged value (error) -302.035 (2.06479489e-06)
157024 EPS nconv=0 first unconverged value (error) -302.035 (2.01656237e-06)
157025 EPS nconv=0 first unconverged value (error) -302.035 (1.94381900e-06)
157026 EPS nconv=0 first unconverged value (error) -302.035 (1.90730298e-06)
157027 EPS nconv=0 first unconverged value (error) -302.035 (1.90730298e-06)
157028 EPS nconv=0 first unconverged value (error) -302.035 (1.96259694e-06)
157029 EPS nconv=0 first unconverged value (error) -302.035 (2.04141391e-06)
157030 EPS nconv=0 first unconverged value (error) -302.035 (1.92038994e-06)
157031 EPS nconv=0 first unconverged value (error) -302.035 (1.86806166e-06)
157032 EPS nconv=0 first unconverged value (error) -302.035 (1.85291755e-06)
157033 EPS nconv=0 first unconverged value (error) -302.035 (1.85291755e-06)
157034 EPS nconv=0 first unconverged value (error) -302.035 (2.01889468e-06)
157035 EPS nconv=0 first unconverged value (error) -302.035 (1.98288647e-06)
157036 EPS nconv=0 first unconverged value (error) -302.035 (1.93449399e-06)
157037 EPS nconv=0 first unconverged value (error) -302.035 (1.92031364e-06)
157038 EPS nconv=0 first unconverged value (error) -302.035 (1.89432271e-06)
157039 EPS nconv=0 first unconverged value (error) -302.035 (1.89432271e-06)
157040 EPS nconv=0 first unconverged value (error) -302.035 (1.90132396e-06)
157041 EPS nconv=0 first unconverged value (error) -302.035 (1.92083376e-06)
157042 EPS nconv=0 first unconverged value (error) -302.035 (1.85529008e-06)
157043 EPS nconv=0 first unconverged value (error) -302.035 (1.83762005e-06)
157044 EPS nconv=0 first unconverged value (error) -302.035 (1.82854853e-06)
157045 EPS nconv=0 first unconverged value (error) -302.035 (1.82854853e-06)
157046 EPS nconv=0 first unconverged value (error) -302.035 (2.25430176e-06)
157047 EPS nconv=0 first unconverged value (error) -302.035 (2.10466624e-06)
157048 EPS nconv=0 first unconverged value (error) -302.035 (2.02580070e-06)
157049 EPS nconv=0 first unconverged value (error) -302.035 (2.00303281e-06)
157050 EPS nconv=0 first unconverged value (error) -302.035 (1.96467870e-06)
157051 EPS nconv=0 first unconverged value (error) -302.035 (1.96467870e-06)
157052 EPS nconv=0 first unconverged value (error) -302.035 (1.96639857e-06)
157053 EPS nconv=0 first unconverged value (error) -302.035 (2.12487409e-06)
157054 EPS nconv=0 first unconverged value (error) -302.035 (1.95337045e-06)
157055 EPS nconv=0 first unconverged value (error) -302.035 (1.86943927e-06)
157056 EPS nconv=0 first unconverged value (error) -302.035 (1.84086904e-06)
157057 EPS nconv=0 first unconverged value (error) -302.035 (1.84086904e-06)
157058 EPS nconv=0 first unconverged value (error) -302.035 (1.94395576e-06)
157059 EPS nconv=0 first unconverged value (error) -302.035 (1.90376006e-06)
157060 EPS nconv=0 first unconverged value (error) -302.035 (1.89020132e-06)
157061 EPS nconv=0 first unconverged value (error) -302.035 (1.88283714e-06)
157062 EPS nconv=0 first unconverged value (error) -302.035 (1.86082328e-06)
157063 EPS nconv=0 first unconverged value (error) -302.035 (1.86082328e-06)
157064 EPS nconv=0 first unconverged value (error) -302.035 (1.93172721e-06)
157065 EPS nconv=0 first unconverged value (error) -302.035 (1.93368455e-06)
157066 EPS nconv=0 first unconverged value (error) -302.035 (1.89069588e-06)
157067 EPS nconv=0 first unconverged value (error) -302.035 (1.85815426e-06)
157068 EPS nconv=0 first unconverged value (error) -302.035 (1.84772858e-06)
157069 EPS nconv=0 first unconverged value (error) -302.035 (1.84772858e-06)
157070 EPS nconv=0 first unconverged value (error) -302.035 (2.05282390e-06)
157071 EPS nconv=0 first unconverged value (error) -302.035 (1.99401130e-06)
157072 EPS nconv=0 first unconverged value (error) -302.035 (1.92963126e-06)
157073 EPS nconv=0 first unconverged value (error) -302.035 (1.90557326e-06)
157074 EPS nconv=0 first unconverged value (error) -302.035 (1.88494091e-06)
157075 EPS nconv=0 first unconverged value (error) -302.035 (1.88494091e-06)
157076 EPS nconv=0 first unconverged value (error) -302.035 (1.92845292e-06)
157077 EPS nconv=0 first unconverged value (error) -302.035 (1.99440037e-06)
157078 EPS nconv=0 first unconverged value (error) -302.035 (1.89897811e-06)
157079 EPS nconv=0 first unconverged value (error) -302.035 (1.84942928e-06)
157080 EPS nconv=0 first unconverged value (error) -302.035 (1.83461066e-06)
157081 EPS nconv=0 first unconverged value (error) -302.035 (1.83461066e-06)
157082 EPS nconv=0 first unconverged value (error) -302.035 (1.95034288e-06)
157083 EPS nconv=0 first unconverged value (error) -302.035 (1.93621332e-06)
157084 EPS nconv=0 first unconverged value (error) -302.035 (1.90621521e-06)
157085 EPS nconv=0 first unconverged value (error) -302.035 (1.87937218e-06)
157086 EPS nconv=0 first unconverged value (error) -302.035 (1.85777213e-06)
157087 EPS nconv=0 first unconverged value (error) -302.035 (1.85777213e-06)
157088 EPS nconv=0 first unconverged value (error) -302.035 (1.85894985e-06)
157089 EPS nconv=0 first unconverged value (error) -302.035 (1.87749186e-06)
157090 EPS nconv=0 first unconverged value (error) -302.035 (1.83716445e-06)
157091 EPS nconv=0 first unconverged value (error) -302.035 (1.82088060e-06)
157092 EPS nconv=0 first unconverged value (error) -302.035 (1.81875460e-06)
157093 EPS nconv=0 first unconverged value (error) -302.035 (1.81875460e-06)
157094 EPS nconv=0 first unconverged value (error) -302.035 (2.17794596e-06)
157095 EPS nconv=0 first unconverged value (error) -302.035 (2.04372050e-06)
157096 EPS nconv=0 first unconverged value (error) -302.035 (1.98438589e-06)
157097 EPS nconv=0 first unconverged value (error) -302.035 (1.95772027e-06)
157098 EPS nconv=0 first unconverged value (error) -302.035 (1.92547771e-06)
157099 EPS nconv=0 first unconverged value (error) -302.035 (1.92547771e-06)
157100 EPS nconv=0 first unconverged value (error) -302.035 (1.92479025e-06)
157101 EPS nconv=0 first unconverged value (error) -302.035 (2.05955414e-06)
157102 EPS nconv=0 first unconverged value (error) -302.035 (1.91561362e-06)
157103 EPS nconv=0 first unconverged value (error) -302.035 (1.85336694e-06)
157104 EPS nconv=0 first unconverged value (error) -302.035 (1.83075520e-06)
157105 EPS nconv=0 first unconverged value (error) -302.035 (1.83075520e-06)
157106 EPS nconv=0 first unconverged value (error) -302.035 (1.96678754e-06)
157107 EPS nconv=0 first unconverged value (error) -302.035 (1.91587922e-06)
157108 EPS nconv=0 first unconverged value (error) -302.035 (1.89992126e-06)
157109 EPS nconv=0 first unconverged value (error) -302.035 (1.89732178e-06)
157110 EPS nconv=0 first unconverged value (error) -302.035 (1.87093599e-06)
157111 EPS nconv=0 first unconverged value (error) -302.035 (1.87093599e-06)
157112 EPS nconv=0 first unconverged value (error) -302.035 (1.87073736e-06)
157113 EPS nconv=0 first unconverged value (error) -302.035 (1.89756564e-06)
157114 EPS nconv=0 first unconverged value (error) -302.035 (1.84402744e-06)
157115 EPS nconv=0 first unconverged value (error) -302.035 (1.82534631e-06)
157116 EPS nconv=0 first unconverged value (error) -302.035 (1.82218868e-06)
157117 EPS nconv=0 first unconverged value (error) -302.035 (1.82218868e-06)
157118 EPS nconv=0 first unconverged value (error) -302.035 (2.29766303e-06)
157119 EPS nconv=0 first unconverged value (error) -302.035 (2.11359177e-06)
157120 EPS nconv=0 first unconverged value (error) -302.035 (2.03354980e-06)
157121 EPS nconv=0 first unconverged value (error) -302.035 (2.00596534e-06)
157122 EPS nconv=0 first unconverged value (error) -302.035 (1.96275119e-06)
157123 EPS nconv=0 first unconverged value (error) -302.035 (1.96275119e-06)
157124 EPS nconv=0 first unconverged value (error) -302.035 (2.24685342e-06)
157125 EPS nconv=0 first unconverged value (error) -302.035 (2.25974655e-06)
157126 EPS nconv=0 first unconverged value (error) -302.035 (2.05664753e-06)
157127 EPS nconv=0 first unconverged value (error) -302.035 (1.98597096e-06)
157128 EPS nconv=0 first unconverged value (error) -302.035 (1.96398790e-06)
157129 EPS nconv=0 first unconverged value (error) -302.035 (1.96398790e-06)
157130 EPS nconv=0 first unconverged value (error) -302.035 (1.97028344e-06)
157131 EPS nconv=0 first unconverged value (error) -302.035 (2.04596289e-06)
157132 EPS nconv=0 first unconverged value (error) -302.035 (1.87778224e-06)
157133 EPS nconv=0 first unconverged value (error) -302.035 (1.83585127e-06)
157134 EPS nconv=0 first unconverged value (error) -302.035 (1.82136417e-06)
157135 EPS nconv=0 first unconverged value (error) -302.035 (1.82136417e-06)
157136 EPS nconv=0 first unconverged value (error) -302.035 (2.50799197e-06)
157137 EPS nconv=0 first unconverged value (error) -302.035 (2.32337627e-06)
157138 EPS nconv=0 first unconverged value (error) -302.035 (2.17861120e-06)
157139 EPS nconv=0 first unconverged value (error) -302.035 (2.12949306e-06)
157140 EPS nconv=0 first unconverged value (error) -302.035 (2.09913566e-06)
157141 EPS nconv=0 first unconverged value (error) -302.035 (2.09913566e-06)
157142 EPS nconv=0 first unconverged value (error) -302.035 (2.21915822e-06)
157143 EPS nconv=0 first unconverged value (error) -302.035 (2.32065360e-06)
157144 EPS nconv=0 first unconverged value (error) -302.035 (2.09509199e-06)
157145 EPS nconv=0 first unconverged value (error) -302.035 (1.96929864e-06)
157146 EPS nconv=0 first unconverged value (error) -302.035 (1.92015673e-06)
157147 EPS nconv=0 first unconverged value (error) -302.035 (1.92015673e-06)
157148 EPS nconv=0 first unconverged value (error) -302.035 (2.09580124e-06)
157149 EPS nconv=0 first unconverged value (error) -302.035 (2.11531530e-06)
157150 EPS nconv=0 first unconverged value (error) -302.035 (2.00823592e-06)
157151 EPS nconv=0 first unconverged value (error) -302.035 (1.90102902e-06)
157152 EPS nconv=0 first unconverged value (error) -302.035 (1.88333175e-06)
157153 EPS nconv=0 first unconverged value (error) -302.035 (1.88333175e-06)
157154 EPS nconv=0 first unconverged value (error) -302.035 (1.87978161e-06)
157155 EPS nconv=0 first unconverged value (error) -302.035 (1.94491536e-06)
157156 EPS nconv=0 first unconverged value (error) -302.035 (1.88569877e-06)
157157 EPS nconv=0 first unconverged value (error) -302.035 (1.83460449e-06)
157158 EPS nconv=0 first unconverged value (error) -302.035 (1.81214208e-06)
157159 EPS nconv=0 first unconverged value (error) -302.035 (1.81214208e-06)
157160 EPS nconv=0 first unconverged value (error) -302.035 (1.97755326e-06)
157161 EPS nconv=0 first unconverged value (error) -302.035 (1.91750938e-06)
157162 EPS nconv=0 first unconverged value (error) -302.035 (1.90010169e-06)
157163 EPS nconv=0 first unconverged value (error) -302.035 (1.88741123e-06)
157164 EPS nconv=0 first unconverged value (error) -302.035 (1.86983421e-06)
157165 EPS nconv=0 first unconverged value (error) -302.035 (1.86983421e-06)
157166 EPS nconv=0 first unconverged value (error) -302.035 (2.00537617e-06)
157167 EPS nconv=0 first unconverged value (error) -302.035 (1.99668808e-06)
157168 EPS nconv=0 first unconverged value (error) -302.035 (1.91228688e-06)
157169 EPS nconv=0 first unconverged value (error) -302.035 (1.89330360e-06)
157170 EPS nconv=0 first unconverged value (error) -302.035 (1.89193253e-06)
157171 EPS nconv=0 first unconverged value (error) -302.035 (1.89193253e-06)
157172 EPS nconv=0 first unconverged value (error) -302.035 (1.90947136e-06)
157173 EPS nconv=0 first unconverged value (error) -302.035 (1.87724295e-06)
157174 EPS nconv=0 first unconverged value (error) -302.035 (1.83851107e-06)
157175 EPS nconv=0 first unconverged value (error) -302.035 (1.82440360e-06)
157176 EPS nconv=0 first unconverged value (error) -302.035 (1.81446192e-06)
157177 EPS nconv=0 first unconverged value (error) -302.035 (1.81446192e-06)
157178 EPS nconv=0 first unconverged value (error) -302.035 (2.08178275e-06)
157179 EPS nconv=0 first unconverged value (error) -302.035 (2.01317416e-06)
157180 EPS nconv=0 first unconverged value (error) -302.035 (1.93877298e-06)
157181 EPS nconv=0 first unconverged value (error) -302.035 (1.90719238e-06)
157182 EPS nconv=0 first unconverged value (error) -302.035 (1.89517850e-06)
157183 EPS nconv=0 first unconverged value (error) -302.035 (1.89517850e-06)
157184 EPS nconv=0 first unconverged value (error) -302.035 (2.51896176e-06)
157185 EPS nconv=0 first unconverged value (error) -302.035 (2.43119416e-06)
157186 EPS nconv=0 first unconverged value (error) -302.035 (2.25951905e-06)
157187 EPS nconv=0 first unconverged value (error) -302.035 (2.24740948e-06)
157188 EPS nconv=0 first unconverged value (error) -302.035 (2.19380710e-06)
157189 EPS nconv=0 first unconverged value (error) -302.035 (2.19380710e-06)
157190 EPS nconv=0 first unconverged value (error) -302.035 (2.24530374e-06)
157191 EPS nconv=0 first unconverged value (error) -302.035 (2.18016379e-06)
157192 EPS nconv=0 first unconverged value (error) -302.035 (2.00340844e-06)
157193 EPS nconv=0 first unconverged value (error) -302.035 (1.91035424e-06)
157194 EPS nconv=0 first unconverged value (error) -302.035 (1.86871695e-06)
157195 EPS nconv=0 first unconverged value (error) -302.035 (1.86871695e-06)
157196 EPS nconv=0 first unconverged value (error) -302.035 (1.86209784e-06)
157197 EPS nconv=0 first unconverged value (error) -302.035 (1.86260097e-06)
157198 EPS nconv=0 first unconverged value (error) -302.035 (1.84229470e-06)
157199 EPS nconv=0 first unconverged value (error) -302.035 (1.81385039e-06)
157200 EPS nconv=0 first unconverged value (error) -302.035 (1.80665462e-06)
157201 EPS nconv=0 first unconverged value (error) -302.035 (1.80665462e-06)
157202 EPS nconv=0 first unconverged value (error) -302.035 (1.81202944e-06)
157203 EPS nconv=0 first unconverged value (error) -302.035 (1.80536423e-06)
157204 EPS nconv=0 first unconverged value (error) -302.035 (1.80114488e-06)
157205 EPS nconv=0 first unconverged value (error) -302.035 (1.79943211e-06)
157206 EPS nconv=0 first unconverged value (error) -302.035 (1.79763178e-06)
157207 EPS nconv=0 first unconverged value (error) -302.035 (1.79763178e-06)
157208 EPS nconv=0 first unconverged value (error) -302.035 (1.97557672e-06)
157209 EPS nconv=0 first unconverged value (error) -302.035 (1.92142299e-06)
157210 EPS nconv=0 first unconverged value (error) -302.035 (1.89449493e-06)
157211 EPS nconv=0 first unconverged value (error) -302.035 (1.88866825e-06)
157212 EPS nconv=0 first unconverged value (error) -302.035 (1.87004880e-06)
157213 EPS nconv=0 first unconverged value (error) -302.035 (1.87004880e-06)
157214 EPS nconv=0 first unconverged value (error) -302.035 (2.22736695e-06)
157215 EPS nconv=0 first unconverged value (error) -302.035 (2.25167437e-06)
157216 EPS nconv=0 first unconverged value (error) -302.035 (2.13791823e-06)
157217 EPS nconv=0 first unconverged value (error) -302.035 (1.99266251e-06)
157218 EPS nconv=0 first unconverged value (error) -302.035 (1.97948416e-06)
157219 EPS nconv=0 first unconverged value (error) -302.035 (1.97948416e-06)
157220 EPS nconv=0 first unconverged value (error) -302.035 (2.16187019e-06)
157221 EPS nconv=0 first unconverged value (error) -302.035 (2.07931104e-06)
157222 EPS nconv=0 first unconverged value (error) -302.035 (1.99266222e-06)
157223 EPS nconv=0 first unconverged value (error) -302.035 (1.93817074e-06)
157224 EPS nconv=0 first unconverged value (error) -302.035 (1.90378116e-06)
157225 EPS nconv=0 first unconverged value (error) -302.035 (1.90378116e-06)
157226 EPS nconv=0 first unconverged value (error) -302.035 (1.98858496e-06)
157227 EPS nconv=0 first unconverged value (error) -302.035 (2.01688965e-06)
157228 EPS nconv=0 first unconverged value (error) -302.035 (1.89678742e-06)
157229 EPS nconv=0 first unconverged value (error) -302.035 (1.86070420e-06)
157230 EPS nconv=0 first unconverged value (error) -302.035 (1.83944303e-06)
157231 EPS nconv=0 first unconverged value (error) -302.035 (1.83944303e-06)
157232 EPS nconv=0 first unconverged value (error) -302.035 (2.10818923e-06)
157233 EPS nconv=0 first unconverged value (error) -302.035 (2.03297835e-06)
157234 EPS nconv=0 first unconverged value (error) -302.035 (1.96432055e-06)
157235 EPS nconv=0 first unconverged value (error) -302.035 (1.92139105e-06)
157236 EPS nconv=0 first unconverged value (error) -302.035 (1.90065151e-06)
157237 EPS nconv=0 first unconverged value (error) -302.035 (1.90065151e-06)
157238 EPS nconv=0 first unconverged value (error) -302.035 (1.91822979e-06)
157239 EPS nconv=0 first unconverged value (error) -302.035 (1.99820431e-06)
157240 EPS nconv=0 first unconverged value (error) -302.035 (1.91819696e-06)
157241 EPS nconv=0 first unconverged value (error) -302.035 (1.83555143e-06)
157242 EPS nconv=0 first unconverged value (error) -302.035 (1.82408926e-06)
157243 EPS nconv=0 first unconverged value (error) -302.035 (1.82408926e-06)
157244 EPS nconv=0 first unconverged value (error) -302.035 (1.81575555e-06)
157245 EPS nconv=0 first unconverged value (error) -302.035 (1.81816615e-06)
157246 EPS nconv=0 first unconverged value (error) -302.035 (1.80915602e-06)
157247 EPS nconv=0 first unconverged value (error) -302.035 (1.80401003e-06)
157248 EPS nconv=0 first unconverged value (error) -302.035 (1.80243314e-06)
157249 EPS nconv=0 first unconverged value (error) -302.035 (1.80243314e-06)
157250 EPS nconv=0 first unconverged value (error) -302.035 (1.80094643e-06)
157251 EPS nconv=0 first unconverged value (error) -302.035 (1.80224188e-06)
157252 EPS nconv=0 first unconverged value (error) -302.035 (1.79763004e-06)
157253 EPS nconv=0 first unconverged value (error) -302.035 (1.79635353e-06)
157254 EPS nconv=0 first unconverged value (error) -302.035 (1.79566388e-06)
157255 EPS nconv=0 first unconverged value (error) -302.035 (1.79566388e-06)
157256 EPS nconv=0 first unconverged value (error) -302.035 (2.98123110e-06)
157257 EPS nconv=0 first unconverged value (error) -302.035 (2.69574657e-06)
157258 EPS nconv=0 first unconverged value (error) -302.035 (2.47292407e-06)
157259 EPS nconv=0 first unconverged value (error) -302.035 (2.40749761e-06)
157260 EPS nconv=0 first unconverged value (error) -302.035 (2.31075330e-06)
157261 EPS nconv=0 first unconverged value (error) -302.035 (2.31075330e-06)
157262 EPS nconv=0 first unconverged value (error) -302.035 (2.51947712e-06)
157263 EPS nconv=0 first unconverged value (error) -302.035 (2.66868458e-06)
157264 EPS nconv=0 first unconverged value (error) -302.035 (2.35601817e-06)
157265 EPS nconv=0 first unconverged value (error) -302.035 (2.12773724e-06)
157266 EPS nconv=0 first unconverged value (error) -302.035 (2.08694213e-06)
157267 EPS nconv=0 first unconverged value (error) -302.035 (2.08694213e-06)
157268 EPS nconv=0 first unconverged value (error) -302.035 (2.00750675e-06)
157269 EPS nconv=0 first unconverged value (error) -302.035 (1.96233198e-06)
157270 EPS nconv=0 first unconverged value (error) -302.035 (1.89674603e-06)
157271 EPS nconv=0 first unconverged value (error) -302.035 (1.84140378e-06)
157272 EPS nconv=0 first unconverged value (error) -302.035 (1.83306535e-06)
157273 EPS nconv=0 first unconverged value (error) -302.035 (1.83306535e-06)
157274 EPS nconv=0 first unconverged value (error) -302.035 (2.11359284e-06)
157275 EPS nconv=0 first unconverged value (error) -302.035 (2.01038437e-06)
157276 EPS nconv=0 first unconverged value (error) -302.035 (1.95056688e-06)
157277 EPS nconv=0 first unconverged value (error) -302.035 (1.91876197e-06)
157278 EPS nconv=0 first unconverged value (error) -302.035 (1.90457642e-06)
157279 EPS nconv=0 first unconverged value (error) -302.035 (1.90457642e-06)
157280 EPS nconv=0 first unconverged value (error) -302.035 (2.02056932e-06)
157281 EPS nconv=0 first unconverged value (error) -302.035 (2.17386647e-06)
157282 EPS nconv=0 first unconverged value (error) -302.035 (2.03581632e-06)
157283 EPS nconv=0 first unconverged value (error) -302.035 (1.88330702e-06)
157284 EPS nconv=0 first unconverged value (error) -302.035 (1.85562878e-06)
157285 EPS nconv=0 first unconverged value (error) -302.035 (1.85562878e-06)
157286 EPS nconv=0 first unconverged value (error) -302.035 (1.86880643e-06)
157287 EPS nconv=0 first unconverged value (error) -302.035 (1.86913242e-06)
157288 EPS nconv=0 first unconverged value (error) -302.035 (1.85389739e-06)
157289 EPS nconv=0 first unconverged value (error) -302.035 (1.83039669e-06)
157290 EPS nconv=0 first unconverged value (error) -302.035 (1.81762135e-06)
157291 EPS nconv=0 first unconverged value (error) -302.035 (1.81762135e-06)
157292 EPS nconv=0 first unconverged value (error) -302.035 (1.91661004e-06)
157293 EPS nconv=0 first unconverged value (error) -302.035 (1.86210192e-06)
157294 EPS nconv=0 first unconverged value (error) -302.035 (1.84688536e-06)
157295 EPS nconv=0 first unconverged value (error) -302.035 (1.84169504e-06)
157296 EPS nconv=0 first unconverged value (error) -302.035 (1.83776279e-06)
157297 EPS nconv=0 first unconverged value (error) -302.035 (1.83776279e-06)
157298 EPS nconv=0 first unconverged value (error) -302.035 (2.38309238e-06)
157299 EPS nconv=0 first unconverged value (error) -302.035 (2.23866819e-06)
157300 EPS nconv=0 first unconverged value (error) -302.035 (2.08761857e-06)
157301 EPS nconv=0 first unconverged value (error) -302.035 (1.99630482e-06)
157302 EPS nconv=0 first unconverged value (error) -302.035 (1.98491572e-06)
157303 EPS nconv=0 first unconverged value (error) -302.035 (1.98491572e-06)
157304 EPS nconv=0 first unconverged value (error) -302.035 (1.99657274e-06)
157305 EPS nconv=0 first unconverged value (error) -302.035 (2.19082156e-06)
157306 EPS nconv=0 first unconverged value (error) -302.035 (1.99570447e-06)
157307 EPS nconv=0 first unconverged value (error) -302.035 (1.86724145e-06)
157308 EPS nconv=0 first unconverged value (error) -302.035 (1.82116159e-06)
157309 EPS nconv=0 first unconverged value (error) -302.035 (1.82116159e-06)
157310 EPS nconv=0 first unconverged value (error) -302.035 (1.82704942e-06)
157311 EPS nconv=0 first unconverged value (error) -302.035 (1.82522682e-06)
157312 EPS nconv=0 first unconverged value (error) -302.035 (1.82127643e-06)
157313 EPS nconv=0 first unconverged value (error) -302.035 (1.81678316e-06)
157314 EPS nconv=0 first unconverged value (error) -302.035 (1.81076575e-06)
157315 EPS nconv=0 first unconverged value (error) -302.035 (1.81076575e-06)
157316 EPS nconv=0 first unconverged value (error) -302.035 (1.87295793e-06)
157317 EPS nconv=0 first unconverged value (error) -302.035 (1.85733701e-06)
157318 EPS nconv=0 first unconverged value (error) -302.035 (1.83957758e-06)
157319 EPS nconv=0 first unconverged value (error) -302.035 (1.82818523e-06)
157320 EPS nconv=0 first unconverged value (error) -302.035 (1.82444039e-06)
157321 EPS nconv=0 first unconverged value (error) -302.035 (1.82444039e-06)
157322 EPS nconv=0 first unconverged value (error) -302.035 (1.98517880e-06)
157323 EPS nconv=0 first unconverged value (error) -302.035 (1.94054098e-06)
157324 EPS nconv=0 first unconverged value (error) -302.035 (1.90312908e-06)
157325 EPS nconv=0 first unconverged value (error) -302.035 (1.86446191e-06)
157326 EPS nconv=0 first unconverged value (error) -302.035 (1.85382269e-06)
157327 EPS nconv=0 first unconverged value (error) -302.035 (1.85382269e-06)
157328 EPS nconv=0 first unconverged value (error) -302.035 (1.85242673e-06)
157329 EPS nconv=0 first unconverged value (error) -302.035 (1.90132264e-06)
157330 EPS nconv=0 first unconverged value (error) -302.035 (1.84663308e-06)
157331 EPS nconv=0 first unconverged value (error) -302.035 (1.81730191e-06)
157332 EPS nconv=0 first unconverged value (error) -302.035 (1.80608132e-06)
157333 EPS nconv=0 first unconverged value (error) -302.035 (1.80608132e-06)
157334 EPS nconv=0 first unconverged value (error) -302.035 (1.80486213e-06)
157335 EPS nconv=0 first unconverged value (error) -302.035 (1.80102406e-06)
157336 EPS nconv=0 first unconverged value (error) -302.035 (1.79890449e-06)
157337 EPS nconv=0 first unconverged value (error) -302.035 (1.79783088e-06)
157338 EPS nconv=0 first unconverged value (error) -302.035 (1.79683253e-06)
157339 EPS nconv=0 first unconverged value (error) -302.035 (1.79683253e-06)
157340 EPS nconv=0 first unconverged value (error) -302.035 (1.97087030e-06)
157341 EPS nconv=0 first unconverged value (error) -302.035 (1.90908501e-06)
157342 EPS nconv=0 first unconverged value (error) -302.035 (1.89232556e-06)
157343 EPS nconv=0 first unconverged value (error) -302.035 (1.87766294e-06)
157344 EPS nconv=0 first unconverged value (error) -302.035 (1.87220932e-06)
157345 EPS nconv=0 first unconverged value (error) -302.035 (1.87220932e-06)
157346 EPS nconv=0 first unconverged value (error) -302.035 (1.86961887e-06)
157347 EPS nconv=0 first unconverged value (error) -302.035 (1.89497273e-06)
157348 EPS nconv=0 first unconverged value (error) -302.035 (1.82816171e-06)
157349 EPS nconv=0 first unconverged value (error) -302.035 (1.80436306e-06)
157350 EPS nconv=0 first unconverged value (error) -302.035 (1.80065173e-06)
157351 EPS nconv=0 first unconverged value (error) -302.035 (1.80065173e-06)
157352 EPS nconv=0 first unconverged value (error) -302.035 (1.79585081e-06)
157353 EPS nconv=0 first unconverged value (error) -302.035 (1.79605100e-06)
157354 EPS nconv=0 first unconverged value (error) -302.035 (1.79487672e-06)
157355 EPS nconv=0 first unconverged value (error) -302.035 (1.79417509e-06)
157356 EPS nconv=0 first unconverged value (error) -302.035 (1.79406264e-06)
157357 EPS nconv=0 first unconverged value (error) -302.035 (1.79406264e-06)
157358 EPS nconv=0 first unconverged value (error) -302.035 (1.97087450e-06)
157359 EPS nconv=0 first unconverged value (error) -302.035 (1.89408592e-06)
157360 EPS nconv=0 first unconverged value (error) -302.035 (1.88433539e-06)
157361 EPS nconv=0 first unconverged value (error) -302.035 (1.86724255e-06)
157362 EPS nconv=0 first unconverged value (error) -302.035 (1.85431100e-06)
157363 EPS nconv=0 first unconverged value (error) -302.035 (1.85431100e-06)
157364 EPS nconv=0 first unconverged value (error) -302.035 (1.92050379e-06)
157365 EPS nconv=0 first unconverged value (error) -302.035 (1.94250894e-06)
157366 EPS nconv=0 first unconverged value (error) -302.035 (1.87062979e-06)
157367 EPS nconv=0 first unconverged value (error) -302.035 (1.86077600e-06)
157368 EPS nconv=0 first unconverged value (error) -302.035 (1.85239354e-06)
157369 EPS nconv=0 first unconverged value (error) -302.035 (1.85239354e-06)
157370 EPS nconv=0 first unconverged value (error) -302.035 (1.85998104e-06)
157371 EPS nconv=0 first unconverged value (error) -302.035 (1.84019316e-06)
157372 EPS nconv=0 first unconverged value (error) -302.035 (1.81974086e-06)
157373 EPS nconv=0 first unconverged value (error) -302.035 (1.80954369e-06)
157374 EPS nconv=0 first unconverged value (error) -302.035 (1.80469239e-06)
157375 EPS nconv=0 first unconverged value (error) -302.035 (1.80469239e-06)
157376 EPS nconv=0 first unconverged value (error) -302.035 (2.28630548e-06)
157377 EPS nconv=0 first unconverged value (error) -302.035 (2.11827450e-06)
157378 EPS nconv=0 first unconverged value (error) -302.035 (2.01414140e-06)
157379 EPS nconv=0 first unconverged value (error) -302.035 (1.97813455e-06)
157380 EPS nconv=0 first unconverged value (error) -302.035 (1.96209681e-06)
157381 EPS nconv=0 first unconverged value (error) -302.035 (1.96209681e-06)
157382 EPS nconv=0 first unconverged value (error) -302.035 (2.01221183e-06)
157383 EPS nconv=0 first unconverged value (error) -302.035 (2.18191268e-06)
157384 EPS nconv=0 first unconverged value (error) -302.035 (1.98671192e-06)
157385 EPS nconv=0 first unconverged value (error) -302.035 (1.89816297e-06)
157386 EPS nconv=0 first unconverged value (error) -302.035 (1.85272215e-06)
157387 EPS nconv=0 first unconverged value (error) -302.035 (1.85272215e-06)
157388 EPS nconv=0 first unconverged value (error) -302.035 (1.88072882e-06)
157389 EPS nconv=0 first unconverged value (error) -302.035 (1.89458057e-06)
157390 EPS nconv=0 first unconverged value (error) -302.035 (1.85855568e-06)
157391 EPS nconv=0 first unconverged value (error) -302.035 (1.83712086e-06)
157392 EPS nconv=0 first unconverged value (error) -302.035 (1.82458879e-06)
157393 EPS nconv=0 first unconverged value (error) -302.035 (1.82458879e-06)
157394 EPS nconv=0 first unconverged value (error) -302.035 (2.29231121e-06)
157395 EPS nconv=0 first unconverged value (error) -302.035 (2.12812887e-06)
157396 EPS nconv=0 first unconverged value (error) -302.035 (2.05553898e-06)
157397 EPS nconv=0 first unconverged value (error) -302.035 (2.03231165e-06)
157398 EPS nconv=0 first unconverged value (error) -302.035 (2.00013536e-06)
157399 EPS nconv=0 first unconverged value (error) -302.035 (2.00013536e-06)
157400 EPS nconv=0 first unconverged value (error) -302.035 (2.14340499e-06)
157401 EPS nconv=0 first unconverged value (error) -302.035 (2.32736649e-06)
157402 EPS nconv=0 first unconverged value (error) -302.035 (2.10559943e-06)
157403 EPS nconv=0 first unconverged value (error) -302.035 (1.90570262e-06)
157404 EPS nconv=0 first unconverged value (error) -302.035 (1.86385406e-06)
157405 EPS nconv=0 first unconverged value (error) -302.035 (1.86385406e-06)
157406 EPS nconv=0 first unconverged value (error) -302.035 (1.85888656e-06)
157407 EPS nconv=0 first unconverged value (error) -302.035 (1.85159558e-06)
157408 EPS nconv=0 first unconverged value (error) -302.035 (1.83010224e-06)
157409 EPS nconv=0 first unconverged value (error) -302.035 (1.81243174e-06)
157410 EPS nconv=0 first unconverged value (error) -302.035 (1.80571047e-06)
157411 EPS nconv=0 first unconverged value (error) -302.035 (1.80571047e-06)
157412 EPS nconv=0 first unconverged value (error) -302.035 (1.79690727e-06)
157413 EPS nconv=0 first unconverged value (error) -302.035 (1.79588326e-06)
157414 EPS nconv=0 first unconverged value (error) -302.035 (1.79519527e-06)
157415 EPS nconv=0 first unconverged value (error) -302.035 (1.79449535e-06)
157416 EPS nconv=0 first unconverged value (error) -302.035 (1.79415022e-06)
157417 EPS nconv=0 first unconverged value (error) -302.035 (1.79415022e-06)
157418 EPS nconv=0 first unconverged value (error) -302.035 (1.91409738e-06)
157419 EPS nconv=0 first unconverged value (error) -302.035 (1.86919940e-06)
157420 EPS nconv=0 first unconverged value (error) -302.035 (1.85422586e-06)
157421 EPS nconv=0 first unconverged value (error) -302.035 (1.84155406e-06)
157422 EPS nconv=0 first unconverged value (error) -302.035 (1.83338594e-06)
157423 EPS nconv=0 first unconverged value (error) -302.035 (1.83338594e-06)
157424 EPS nconv=0 first unconverged value (error) -302.035 (1.86811795e-06)
157425 EPS nconv=0 first unconverged value (error) -302.035 (1.88829772e-06)
157426 EPS nconv=0 first unconverged value (error) -302.035 (1.84341380e-06)
157427 EPS nconv=0 first unconverged value (error) -302.035 (1.84125103e-06)
157428 EPS nconv=0 first unconverged value (error) -302.035 (1.82405724e-06)
157429 EPS nconv=0 first unconverged value (error) -302.035 (1.82405724e-06)
157430 EPS nconv=0 first unconverged value (error) -302.035 (1.86289407e-06)
157431 EPS nconv=0 first unconverged value (error) -302.035 (1.86077378e-06)
157432 EPS nconv=0 first unconverged value (error) -302.035 (1.84123817e-06)
157433 EPS nconv=0 first unconverged value (error) -302.035 (1.82579592e-06)
157434 EPS nconv=0 first unconverged value (error) -302.035 (1.81877829e-06)
157435 EPS nconv=0 first unconverged value (error) -302.035 (1.81877829e-06)
157436 EPS nconv=0 first unconverged value (error) -302.035 (1.81716232e-06)
157437 EPS nconv=0 first unconverged value (error) -302.035 (1.81482433e-06)
157438 EPS nconv=0 first unconverged value (error) -302.035 (1.81265863e-06)
157439 EPS nconv=0 first unconverged value (error) -302.035 (1.80246001e-06)
157440 EPS nconv=0 first unconverged value (error) -302.035 (1.79935013e-06)
157441 EPS nconv=0 first unconverged value (error) -302.035 (1.79935013e-06)
157442 EPS nconv=0 first unconverged value (error) -302.035 (1.80794644e-06)
157443 EPS nconv=0 first unconverged value (error) -302.035 (1.80309663e-06)
157444 EPS nconv=0 first unconverged value (error) -302.035 (1.80231468e-06)
157445 EPS nconv=0 first unconverged value (error) -302.035 (1.80031248e-06)
157446 EPS nconv=0 first unconverged value (error) -302.035 (1.79915538e-06)
157447 EPS nconv=0 first unconverged value (error) -302.035 (1.79915538e-06)
157448 EPS nconv=0 first unconverged value (error) -302.035 (2.24942804e-06)
157449 EPS nconv=0 first unconverged value (error) -302.035 (2.18829895e-06)
157450 EPS nconv=0 first unconverged value (error) -302.035 (2.13785554e-06)
157451 EPS nconv=0 first unconverged value (error) -302.035 (2.10047166e-06)
157452 EPS nconv=0 first unconverged value (error) -302.035 (2.08410680e-06)
157453 EPS nconv=0 first unconverged value (error) -302.035 (2.08410680e-06)
157454 EPS nconv=0 first unconverged value (error) -302.035 (2.06887743e-06)
157455 EPS nconv=0 first unconverged value (error) -302.035 (1.99615047e-06)
157456 EPS nconv=0 first unconverged value (error) -302.035 (1.91130878e-06)
157457 EPS nconv=0 first unconverged value (error) -302.035 (1.80461560e-06)
157458 EPS nconv=0 first unconverged value (error) -302.035 (1.80356754e-06)
157459 EPS nconv=0 first unconverged value (error) -302.035 (1.80356754e-06)
157460 EPS nconv=0 first unconverged value (error) -302.035 (2.11700754e-06)
157461 EPS nconv=0 first unconverged value (error) -302.035 (1.96588922e-06)
157462 EPS nconv=0 first unconverged value (error) -302.035 (1.91215275e-06)
157463 EPS nconv=0 first unconverged value (error) -302.035 (1.88375402e-06)
157464 EPS nconv=0 first unconverged value (error) -302.035 (1.87565004e-06)
157465 EPS nconv=0 first unconverged value (error) -302.035 (1.87565004e-06)
157466 EPS nconv=0 first unconverged value (error) -302.035 (1.88034806e-06)
157467 EPS nconv=0 first unconverged value (error) -302.035 (2.00855431e-06)
157468 EPS nconv=0 first unconverged value (error) -302.035 (1.88346028e-06)
157469 EPS nconv=0 first unconverged value (error) -302.035 (1.80668266e-06)
157470 EPS nconv=0 first unconverged value (error) -302.035 (1.79844706e-06)
157471 EPS nconv=0 first unconverged value (error) -302.035 (1.79844706e-06)
157472 EPS nconv=0 first unconverged value (error) -302.035 (1.80420799e-06)
157473 EPS nconv=0 first unconverged value (error) -302.035 (1.80174630e-06)
157474 EPS nconv=0 first unconverged value (error) -302.035 (1.79937418e-06)
157475 EPS nconv=0 first unconverged value (error) -302.035 (1.79862416e-06)
157476 EPS nconv=0 first unconverged value (error) -302.035 (1.79755822e-06)
157477 EPS nconv=0 first unconverged value (error) -302.035 (1.79755822e-06)
157478 EPS nconv=0 first unconverged value (error) -302.035 (2.25017111e-06)
157479 EPS nconv=0 first unconverged value (error) -302.035 (2.05924283e-06)
157480 EPS nconv=0 first unconverged value (error) -302.035 (1.98243932e-06)
157481 EPS nconv=0 first unconverged value (error) -302.035 (1.95510402e-06)
157482 EPS nconv=0 first unconverged value (error) -302.035 (1.94306199e-06)
157483 EPS nconv=0 first unconverged value (error) -302.035 (1.94306199e-06)
157484 EPS nconv=0 first unconverged value (error) -302.035 (2.04785605e-06)
157485 EPS nconv=0 first unconverged value (error) -302.035 (2.13937703e-06)
157486 EPS nconv=0 first unconverged value (error) -302.035 (1.95018498e-06)
157487 EPS nconv=0 first unconverged value (error) -302.035 (1.91382650e-06)
157488 EPS nconv=0 first unconverged value (error) -302.035 (1.88392350e-06)
157489 EPS nconv=0 first unconverged value (error) -302.035 (1.88392350e-06)
157490 EPS nconv=0 first unconverged value (error) -302.035 (2.08615932e-06)
157491 EPS nconv=0 first unconverged value (error) -302.035 (2.04758947e-06)
157492 EPS nconv=0 first unconverged value (error) -302.035 (1.93769013e-06)
157493 EPS nconv=0 first unconverged value (error) -302.035 (1.93950993e-06)
157494 EPS nconv=0 first unconverged value (error) -302.035 (1.92046154e-06)
157495 EPS nconv=0 first unconverged value (error) -302.035 (1.92046154e-06)
157496 EPS nconv=0 first unconverged value (error) -302.035 (1.90925106e-06)
157497 EPS nconv=0 first unconverged value (error) -302.035 (1.95595653e-06)
157498 EPS nconv=0 first unconverged value (error) -302.035 (1.91976283e-06)
157499 EPS nconv=0 first unconverged value (error) -302.035 (1.81549905e-06)
157500 EPS nconv=0 first unconverged value (error) -302.035 (1.80741415e-06)
157501 EPS nconv=0 first unconverged value (error) -302.035 (1.80741415e-06)
157502 EPS nconv=0 first unconverged value (error) -302.035 (2.50965692e-06)
157503 EPS nconv=0 first unconverged value (error) -302.035 (2.24497706e-06)
157504 EPS nconv=0 first unconverged value (error) -302.035 (2.18299974e-06)
157505 EPS nconv=0 first unconverged value (error) -302.035 (2.11488435e-06)
157506 EPS nconv=0 first unconverged value (error) -302.035 (2.07909710e-06)
157507 EPS nconv=0 first unconverged value (error) -302.035 (2.07909710e-06)
157508 EPS nconv=0 first unconverged value (error) -302.035 (2.81520163e-06)
157509 EPS nconv=0 first unconverged value (error) -302.035 (2.66611558e-06)
157510 EPS nconv=0 first unconverged value (error) -302.035 (2.37359598e-06)
157511 EPS nconv=0 first unconverged value (error) -302.035 (2.34533900e-06)
157512 EPS nconv=0 first unconverged value (error) -302.035 (2.33477421e-06)
157513 EPS nconv=0 first unconverged value (error) -302.035 (2.33477421e-06)
157514 EPS nconv=0 first unconverged value (error) -302.035 (3.00571351e-06)
157515 EPS nconv=0 first unconverged value (error) -302.035 (2.74591547e-06)
157516 EPS nconv=0 first unconverged value (error) -302.035 (2.38788220e-06)
157517 EPS nconv=0 first unconverged value (error) -302.035 (2.34994077e-06)
157518 EPS nconv=0 first unconverged value (error) -302.035 (2.20844409e-06)
157519 EPS nconv=0 first unconverged value (error) -302.035 (2.20844409e-06)
157520 EPS nconv=0 first unconverged value (error) -302.035 (2.71267656e-06)
157521 EPS nconv=0 first unconverged value (error) -302.035 (3.06933329e-06)
157522 EPS nconv=0 first unconverged value (error) -302.035 (2.59762627e-06)
157523 EPS nconv=0 first unconverged value (error) -302.035 (2.14961381e-06)
157524 EPS nconv=0 first unconverged value (error) -302.035 (2.08094792e-06)
157525 EPS nconv=0 first unconverged value (error) -302.035 (2.08094792e-06)
157526 EPS nconv=0 first unconverged value (error) -302.035 (2.06887367e-06)
157527 EPS nconv=0 first unconverged value (error) -302.035 (2.23264079e-06)
157528 EPS nconv=0 first unconverged value (error) -302.035 (2.05344491e-06)
157529 EPS nconv=0 first unconverged value (error) -302.035 (1.89681076e-06)
157530 EPS nconv=0 first unconverged value (error) -302.035 (1.85697483e-06)
157531 EPS nconv=0 first unconverged value (error) -302.035 (1.85697483e-06)
157532 EPS nconv=0 first unconverged value (error) -302.035 (2.33037982e-06)
157533 EPS nconv=0 first unconverged value (error) -302.035 (2.19560861e-06)
157534 EPS nconv=0 first unconverged value (error) -302.035 (2.12059063e-06)
157535 EPS nconv=0 first unconverged value (error) -302.035 (2.04980609e-06)
157536 EPS nconv=0 first unconverged value (error) -302.035 (2.00680214e-06)
157537 EPS nconv=0 first unconverged value (error) -302.035 (2.00680214e-06)
157538 EPS nconv=0 first unconverged value (error) -302.035 (3.51447415e-06)
157539 EPS nconv=0 first unconverged value (error) -302.035 (3.12829690e-06)
157540 EPS nconv=0 first unconverged value (error) -302.035 (2.79420858e-06)
157541 EPS nconv=0 first unconverged value (error) -302.035 (2.76761578e-06)
157542 EPS nconv=0 first unconverged value (error) -302.035 (2.72552376e-06)
157543 EPS nconv=0 first unconverged value (error) -302.035 (2.72552376e-06)
157544 EPS nconv=0 first unconverged value (error) -302.035 (2.70929298e-06)
157545 EPS nconv=0 first unconverged value (error) -302.035 (2.84029907e-06)
157546 EPS nconv=0 first unconverged value (error) -302.035 (2.35174906e-06)
157547 EPS nconv=0 first unconverged value (error) -302.035 (1.99936466e-06)
157548 EPS nconv=0 first unconverged value (error) -302.035 (1.89493601e-06)
157549 EPS nconv=0 first unconverged value (error) -302.035 (1.89493601e-06)
157550 EPS nconv=0 first unconverged value (error) -302.035 (2.03374667e-06)
157551 EPS nconv=0 first unconverged value (error) -302.035 (1.97246179e-06)
157552 EPS nconv=0 first unconverged value (error) -302.035 (1.94954714e-06)
157553 EPS nconv=0 first unconverged value (error) -302.035 (1.93131400e-06)
157554 EPS nconv=0 first unconverged value (error) -302.035 (1.91490312e-06)
157555 EPS nconv=0 first unconverged value (error) -302.035 (1.91490312e-06)
157556 EPS nconv=0 first unconverged value (error) -302.035 (3.38145266e-06)
157557 EPS nconv=0 first unconverged value (error) -302.035 (3.21586453e-06)
157558 EPS nconv=0 first unconverged value (error) -302.035 (2.87688206e-06)
157559 EPS nconv=0 first unconverged value (error) -302.035 (2.86927636e-06)
157560 EPS nconv=0 first unconverged value (error) -302.035 (2.80931471e-06)
157561 EPS nconv=0 first unconverged value (error) -302.035 (2.80931471e-06)
157562 EPS nconv=0 first unconverged value (error) -302.035 (4.32664252e-06)
157563 EPS nconv=0 first unconverged value (error) -302.035 (3.58602418e-06)
157564 EPS nconv=0 first unconverged value (error) -302.035 (3.00120252e-06)
157565 EPS nconv=0 first unconverged value (error) -302.035 (3.00153841e-06)
157566 EPS nconv=0 first unconverged value (error) -302.035 (2.90420071e-06)
157567 EPS nconv=0 first unconverged value (error) -302.035 (2.90420071e-06)
157568 EPS nconv=0 first unconverged value (error) -302.035 (4.33296454e-06)
157569 EPS nconv=0 first unconverged value (error) -302.035 (4.45278723e-06)
157570 EPS nconv=0 first unconverged value (error) -302.035 (3.50619699e-06)
157571 EPS nconv=0 first unconverged value (error) -302.035 (3.08820120e-06)
157572 EPS nconv=0 first unconverged value (error) -302.035 (2.93505277e-06)
157573 EPS nconv=0 first unconverged value (error) -302.035 (2.93505277e-06)
157574 EPS nconv=0 first unconverged value (error) -302.035 (3.61260480e-06)
157575 EPS nconv=0 first unconverged value (error) -302.035 (3.50028977e-06)
157576 EPS nconv=0 first unconverged value (error) -302.035 (3.07898905e-06)
157577 EPS nconv=0 first unconverged value (error) -302.035 (2.81771999e-06)
157578 EPS nconv=0 first unconverged value (error) -302.035 (2.47933884e-06)
157579 EPS nconv=0 first unconverged value (error) -302.035 (2.47933884e-06)
157580 EPS nconv=0 first unconverged value (error) -302.035 (2.42010788e-06)
157581 EPS nconv=0 first unconverged value (error) -302.035 (2.60516189e-06)
157582 EPS nconv=0 first unconverged value (error) -302.035 (2.19881717e-06)
157583 EPS nconv=0 first unconverged value (error) -302.035 (1.98457430e-06)
157584 EPS nconv=0 first unconverged value (error) -302.035 (1.95991028e-06)
157585 EPS nconv=0 first unconverged value (error) -302.035 (1.95991028e-06)
157586 EPS nconv=0 first unconverged value (error) -302.035 (1.99856187e-06)
157587 EPS nconv=0 first unconverged value (error) -302.035 (1.94890364e-06)
157588 EPS nconv=0 first unconverged value (error) -302.035 (1.93267508e-06)
157589 EPS nconv=0 first unconverged value (error) -302.035 (1.87228242e-06)
157590 EPS nconv=0 first unconverged value (error) -302.035 (1.85396131e-06)
157591 EPS nconv=0 first unconverged value (error) -302.035 (1.85396131e-06)
157592 EPS nconv=0 first unconverged value (error) -302.035 (2.14521920e-06)
157593 EPS nconv=0 first unconverged value (error) -302.035 (2.11837898e-06)
157594 EPS nconv=0 first unconverged value (error) -302.035 (1.99552132e-06)
157595 EPS nconv=0 first unconverged value (error) -302.035 (1.93333080e-06)
157596 EPS nconv=0 first unconverged value (error) -302.035 (1.91037800e-06)
157597 EPS nconv=0 first unconverged value (error) -302.035 (1.91037800e-06)
157598 EPS nconv=0 first unconverged value (error) -302.035 (1.98933642e-06)
157599 EPS nconv=0 first unconverged value (error) -302.035 (2.01083970e-06)
157600 EPS nconv=0 first unconverged value (error) -302.035 (1.93583677e-06)
157601 EPS nconv=0 first unconverged value (error) -302.035 (1.87548543e-06)
157602 EPS nconv=0 first unconverged value (error) -302.035 (1.85803201e-06)
157603 EPS nconv=0 first unconverged value (error) -302.035 (1.85803201e-06)
157604 EPS nconv=0 first unconverged value (error) -302.035 (1.92024897e-06)
157605 EPS nconv=0 first unconverged value (error) -302.035 (1.92067085e-06)
157606 EPS nconv=0 first unconverged value (error) -302.035 (1.87280006e-06)
157607 EPS nconv=0 first unconverged value (error) -302.035 (1.84985370e-06)
157608 EPS nconv=0 first unconverged value (error) -302.035 (1.83759278e-06)
157609 EPS nconv=0 first unconverged value (error) -302.035 (1.83759278e-06)
157610 EPS nconv=0 first unconverged value (error) -302.035 (1.91656608e-06)
157611 EPS nconv=0 first unconverged value (error) -302.035 (1.89286472e-06)
157612 EPS nconv=0 first unconverged value (error) -302.035 (1.85520164e-06)
157613 EPS nconv=0 first unconverged value (error) -302.035 (1.83515846e-06)
157614 EPS nconv=0 first unconverged value (error) -302.035 (1.82296679e-06)
157615 EPS nconv=0 first unconverged value (error) -302.035 (1.82296679e-06)
157616 EPS nconv=0 first unconverged value (error) -302.035 (1.81517553e-06)
157617 EPS nconv=0 first unconverged value (error) -302.035 (1.84268169e-06)
157618 EPS nconv=0 first unconverged value (error) -302.035 (1.81007723e-06)
157619 EPS nconv=0 first unconverged value (error) -302.035 (1.80124253e-06)
157620 EPS nconv=0 first unconverged value (error) -302.035 (1.79736322e-06)
157621 EPS nconv=0 first unconverged value (error) -302.035 (1.79736322e-06)
157622 EPS nconv=0 first unconverged value (error) -302.035 (1.79424786e-06)
157623 EPS nconv=0 first unconverged value (error) -302.035 (1.79398901e-06)
157624 EPS nconv=0 first unconverged value (error) -302.035 (1.79373278e-06)
157625 EPS nconv=0 first unconverged value (error) -302.035 (1.79352553e-06)
157626 EPS nconv=0 first unconverged value (error) -302.035 (1.79347221e-06)
157627 EPS nconv=0 first unconverged value (error) -302.035 (1.79347221e-06)
157628 EPS nconv=0 first unconverged value (error) -302.035 (1.91689062e-06)
157629 EPS nconv=0 first unconverged value (error) -302.035 (1.87507352e-06)
157630 EPS nconv=0 first unconverged value (error) -302.035 (1.86874901e-06)
157631 EPS nconv=0 first unconverged value (error) -302.035 (1.85864324e-06)
157632 EPS nconv=0 first unconverged value (error) -302.035 (1.84787237e-06)
157633 EPS nconv=0 first unconverged value (error) -302.035 (1.84787237e-06)
157634 EPS nconv=0 first unconverged value (error) -302.035 (2.09955513e-06)
157635 EPS nconv=0 first unconverged value (error) -302.035 (2.01392177e-06)
157636 EPS nconv=0 first unconverged value (error) -302.035 (1.95025544e-06)
157637 EPS nconv=0 first unconverged value (error) -302.035 (1.94702315e-06)
157638 EPS nconv=0 first unconverged value (error) -302.035 (1.93557656e-06)
157639 EPS nconv=0 first unconverged value (error) -302.035 (1.93557656e-06)
157640 EPS nconv=0 first unconverged value (error) -302.035 (2.14285166e-06)
157641 EPS nconv=0 first unconverged value (error) -302.035 (2.09153843e-06)
157642 EPS nconv=0 first unconverged value (error) -302.035 (1.95680570e-06)
157643 EPS nconv=0 first unconverged value (error) -302.035 (1.94609971e-06)
157644 EPS nconv=0 first unconverged value (error) -302.035 (1.91303051e-06)
157645 EPS nconv=0 first unconverged value (error) -302.035 (1.91303051e-06)
157646 EPS nconv=0 first unconverged value (error) -302.035 (1.91828631e-06)
157647 EPS nconv=0 first unconverged value (error) -302.035 (1.96284708e-06)
157648 EPS nconv=0 first unconverged value (error) -302.035 (1.90967451e-06)
157649 EPS nconv=0 first unconverged value (error) -302.035 (1.84190808e-06)
157650 EPS nconv=0 first unconverged value (error) -302.035 (1.81807364e-06)
157651 EPS nconv=0 first unconverged value (error) -302.035 (1.81807364e-06)
157652 EPS nconv=0 first unconverged value (error) -302.035 (1.85840775e-06)
157653 EPS nconv=0 first unconverged value (error) -302.035 (1.83497069e-06)
157654 EPS nconv=0 first unconverged value (error) -302.035 (1.82211805e-06)
157655 EPS nconv=0 first unconverged value (error) -302.035 (1.81707231e-06)
157656 EPS nconv=0 first unconverged value (error) -302.035 (1.81561925e-06)
157657 EPS nconv=0 first unconverged value (error) -302.035 (1.81561925e-06)
157658 EPS nconv=0 first unconverged value (error) -302.035 (2.03560410e-06)
157659 EPS nconv=0 first unconverged value (error) -302.035 (1.93307050e-06)
157660 EPS nconv=0 first unconverged value (error) -302.035 (1.89557704e-06)
157661 EPS nconv=0 first unconverged value (error) -302.035 (1.89663865e-06)
157662 EPS nconv=0 first unconverged value (error) -302.035 (1.88482465e-06)
157663 EPS nconv=0 first unconverged value (error) -302.035 (1.88482465e-06)
157664 EPS nconv=0 first unconverged value (error) -302.035 (2.11174905e-06)
157665 EPS nconv=0 first unconverged value (error) -302.035 (2.11337907e-06)
157666 EPS nconv=0 first unconverged value (error) -302.035 (1.94518498e-06)
157667 EPS nconv=0 first unconverged value (error) -302.035 (1.93652280e-06)
157668 EPS nconv=0 first unconverged value (error) -302.035 (1.91485853e-06)
157669 EPS nconv=0 first unconverged value (error) -302.035 (1.91485853e-06)
157670 EPS nconv=0 first unconverged value (error) -302.035 (1.92837224e-06)
157671 EPS nconv=0 first unconverged value (error) -302.035 (1.97604282e-06)
157672 EPS nconv=0 first unconverged value (error) -302.035 (1.92635691e-06)
157673 EPS nconv=0 first unconverged value (error) -302.035 (1.85102300e-06)
157674 EPS nconv=0 first unconverged value (error) -302.035 (1.83178335e-06)
157675 EPS nconv=0 first unconverged value (error) -302.035 (1.83178335e-06)
157676 EPS nconv=0 first unconverged value (error) -302.035 (1.98092904e-06)
157677 EPS nconv=0 first unconverged value (error) -302.035 (1.95952758e-06)
157678 EPS nconv=0 first unconverged value (error) -302.035 (1.93914321e-06)
157679 EPS nconv=0 first unconverged value (error) -302.035 (1.87776373e-06)
157680 EPS nconv=0 first unconverged value (error) -302.035 (1.86569200e-06)
157681 EPS nconv=0 first unconverged value (error) -302.035 (1.86569200e-06)
157682 EPS nconv=0 first unconverged value (error) -302.035 (2.62741530e-06)
157683 EPS nconv=0 first unconverged value (error) -302.035 (2.46735122e-06)
157684 EPS nconv=0 first unconverged value (error) -302.035 (2.32443196e-06)
157685 EPS nconv=0 first unconverged value (error) -302.035 (2.24096303e-06)
157686 EPS nconv=0 first unconverged value (error) -302.035 (2.16978981e-06)
157687 EPS nconv=0 first unconverged value (error) -302.035 (2.16978981e-06)
157688 EPS nconv=0 first unconverged value (error) -302.035 (2.15303003e-06)
157689 EPS nconv=0 first unconverged value (error) -302.035 (2.27114398e-06)
157690 EPS nconv=0 first unconverged value (error) -302.035 (2.08641896e-06)
157691 EPS nconv=0 first unconverged value (error) -302.035 (1.89522766e-06)
157692 EPS nconv=0 first unconverged value (error) -302.035 (1.82535918e-06)
157693 EPS nconv=0 first unconverged value (error) -302.035 (1.82535918e-06)
157694 EPS nconv=0 first unconverged value (error) -302.035 (1.81278619e-06)
157695 EPS nconv=0 first unconverged value (error) -302.035 (1.80890708e-06)
157696 EPS nconv=0 first unconverged value (error) -302.035 (1.80669274e-06)
157697 EPS nconv=0 first unconverged value (error) -302.035 (1.80614766e-06)
157698 EPS nconv=0 first unconverged value (error) -302.035 (1.80486328e-06)
157699 EPS nconv=0 first unconverged value (error) -302.035 (1.80486328e-06)
157700 EPS nconv=0 first unconverged value (error) -302.035 (1.85117287e-06)
157701 EPS nconv=0 first unconverged value (error) -302.035 (1.83712820e-06)
157702 EPS nconv=0 first unconverged value (error) -302.035 (1.82417023e-06)
157703 EPS nconv=0 first unconverged value (error) -302.035 (1.81719152e-06)
157704 EPS nconv=0 first unconverged value (error) -302.035 (1.81446072e-06)
157705 EPS nconv=0 first unconverged value (error) -302.035 (1.81446072e-06)
157706 EPS nconv=0 first unconverged value (error) -302.035 (1.98387087e-06)
157707 EPS nconv=0 first unconverged value (error) -302.035 (1.94687050e-06)
157708 EPS nconv=0 first unconverged value (error) -302.035 (1.90797324e-06)
157709 EPS nconv=0 first unconverged value (error) -302.035 (1.87865570e-06)
157710 EPS nconv=0 first unconverged value (error) -302.035 (1.86749339e-06)
157711 EPS nconv=0 first unconverged value (error) -302.035 (1.86749339e-06)
157712 EPS nconv=0 first unconverged value (error) -302.035 (1.93504083e-06)
157713 EPS nconv=0 first unconverged value (error) -302.035 (1.93031503e-06)
157714 EPS nconv=0 first unconverged value (error) -302.035 (1.86927328e-06)
157715 EPS nconv=0 first unconverged value (error) -302.035 (1.86463709e-06)
157716 EPS nconv=0 first unconverged value (error) -302.035 (1.83716039e-06)
157717 EPS nconv=0 first unconverged value (error) -302.035 (1.83716039e-06)
157718 EPS nconv=0 first unconverged value (error) -302.035 (2.00513819e-06)
157719 EPS nconv=0 first unconverged value (error) -302.035 (1.99402914e-06)
157720 EPS nconv=0 first unconverged value (error) -302.035 (1.94109828e-06)
157721 EPS nconv=0 first unconverged value (error) -302.035 (1.91554590e-06)
157722 EPS nconv=0 first unconverged value (error) -302.035 (1.89053627e-06)
157723 EPS nconv=0 first unconverged value (error) -302.035 (1.89053627e-06)
157724 EPS nconv=0 first unconverged value (error) -302.035 (1.94916497e-06)
157725 EPS nconv=0 first unconverged value (error) -302.035 (1.93452175e-06)
157726 EPS nconv=0 first unconverged value (error) -302.035 (1.88012362e-06)
157727 EPS nconv=0 first unconverged value (error) -302.035 (1.85218746e-06)
157728 EPS nconv=0 first unconverged value (error) -302.035 (1.83465366e-06)
157729 EPS nconv=0 first unconverged value (error) -302.035 (1.83465366e-06)
157730 EPS nconv=0 first unconverged value (error) -302.035 (2.13144867e-06)
157731 EPS nconv=0 first unconverged value (error) -302.035 (2.01820630e-06)
157732 EPS nconv=0 first unconverged value (error) -302.035 (1.96944427e-06)
157733 EPS nconv=0 first unconverged value (error) -302.035 (1.95293942e-06)
157734 EPS nconv=0 first unconverged value (error) -302.035 (1.92938935e-06)
157735 EPS nconv=0 first unconverged value (error) -302.035 (1.92938935e-06)
157736 EPS nconv=0 first unconverged value (error) -302.035 (1.94921303e-06)
157737 EPS nconv=0 first unconverged value (error) -302.035 (2.03526905e-06)
157738 EPS nconv=0 first unconverged value (error) -302.035 (1.88868256e-06)
157739 EPS nconv=0 first unconverged value (error) -302.035 (1.85210933e-06)
157740 EPS nconv=0 first unconverged value (error) -302.035 (1.83729781e-06)
157741 EPS nconv=0 first unconverged value (error) -302.035 (1.83729781e-06)
157742 EPS nconv=0 first unconverged value (error) -302.035 (1.82777092e-06)
157743 EPS nconv=0 first unconverged value (error) -302.035 (1.81406665e-06)
157744 EPS nconv=0 first unconverged value (error) -302.035 (1.80662677e-06)
157745 EPS nconv=0 first unconverged value (error) -302.035 (1.80457682e-06)
157746 EPS nconv=0 first unconverged value (error) -302.035 (1.80275268e-06)
157747 EPS nconv=0 first unconverged value (error) -302.035 (1.80275268e-06)
157748 EPS nconv=0 first unconverged value (error) -302.035 (1.83129634e-06)
157749 EPS nconv=0 first unconverged value (error) -302.035 (1.82287890e-06)
157750 EPS nconv=0 first unconverged value (error) -302.035 (1.81038766e-06)
157751 EPS nconv=0 first unconverged value (error) -302.035 (1.80839057e-06)
157752 EPS nconv=0 first unconverged value (error) -302.035 (1.80678120e-06)
157753 EPS nconv=0 first unconverged value (error) -302.035 (1.80678120e-06)
157754 EPS nconv=0 first unconverged value (error) -302.035 (2.01588561e-06)
157755 EPS nconv=0 first unconverged value (error) -302.035 (1.93821544e-06)
157756 EPS nconv=0 first unconverged value (error) -302.035 (1.89896470e-06)
157757 EPS nconv=0 first unconverged value (error) -302.035 (1.89520747e-06)
157758 EPS nconv=0 first unconverged value (error) -302.035 (1.87786430e-06)
157759 EPS nconv=0 first unconverged value (error) -302.035 (1.87786430e-06)
157760 EPS nconv=0 first unconverged value (error) -302.035 (2.10191397e-06)
157761 EPS nconv=0 first unconverged value (error) -302.035 (2.05744765e-06)
157762 EPS nconv=0 first unconverged value (error) -302.035 (1.95630140e-06)
157763 EPS nconv=0 first unconverged value (error) -302.035 (1.94340509e-06)
157764 EPS nconv=0 first unconverged value (error) -302.035 (1.92881470e-06)
157765 EPS nconv=0 first unconverged value (error) -302.035 (1.92881470e-06)
157766 EPS nconv=0 first unconverged value (error) -302.035 (2.12785961e-06)
157767 EPS nconv=0 first unconverged value (error) -302.035 (2.07942591e-06)
157768 EPS nconv=0 first unconverged value (error) -302.035 (1.96354008e-06)
157769 EPS nconv=0 first unconverged value (error) -302.035 (1.93401066e-06)
157770 EPS nconv=0 first unconverged value (error) -302.035 (1.92029620e-06)
157771 EPS nconv=0 first unconverged value (error) -302.035 (1.92029620e-06)
157772 EPS nconv=0 first unconverged value (error) -302.035 (1.90879881e-06)
157773 EPS nconv=0 first unconverged value (error) -302.035 (1.96424789e-06)
157774 EPS nconv=0 first unconverged value (error) -302.035 (1.87558241e-06)
157775 EPS nconv=0 first unconverged value (error) -302.035 (1.83661600e-06)
157776 EPS nconv=0 first unconverged value (error) -302.035 (1.82648843e-06)
157777 EPS nconv=0 first unconverged value (error) -302.035 (1.82648843e-06)
157778 EPS nconv=0 first unconverged value (error) -302.035 (2.20811777e-06)
157779 EPS nconv=0 first unconverged value (error) -302.035 (2.07617663e-06)
157780 EPS nconv=0 first unconverged value (error) -302.035 (2.01121866e-06)
157781 EPS nconv=0 first unconverged value (error) -302.035 (1.99572010e-06)
157782 EPS nconv=0 first unconverged value (error) -302.035 (1.97211681e-06)
157783 EPS nconv=0 first unconverged value (error) -302.035 (1.97211681e-06)
157784 EPS nconv=0 first unconverged value (error) -302.035 (1.96214179e-06)
157785 EPS nconv=0 first unconverged value (error) -302.035 (2.04637870e-06)
157786 EPS nconv=0 first unconverged value (error) -302.035 (1.91224328e-06)
157787 EPS nconv=0 first unconverged value (error) -302.035 (1.85011886e-06)
157788 EPS nconv=0 first unconverged value (error) -302.035 (1.83750666e-06)
157789 EPS nconv=0 first unconverged value (error) -302.035 (1.83750666e-06)
157790 EPS nconv=0 first unconverged value (error) -302.035 (1.83218889e-06)
157791 EPS nconv=0 first unconverged value (error) -302.035 (1.82185719e-06)
157792 EPS nconv=0 first unconverged value (error) -302.035 (1.81177218e-06)
157793 EPS nconv=0 first unconverged value (error) -302.035 (1.80944291e-06)
157794 EPS nconv=0 first unconverged value (error) -302.035 (1.80647740e-06)
157795 EPS nconv=0 first unconverged value (error) -302.035 (1.80647740e-06)
157796 EPS nconv=0 first unconverged value (error) -302.035 (1.85492730e-06)
157797 EPS nconv=0 first unconverged value (error) -302.035 (1.84767479e-06)
157798 EPS nconv=0 first unconverged value (error) -302.035 (1.83120044e-06)
157799 EPS nconv=0 first unconverged value (error) -302.035 (1.81756780e-06)
157800 EPS nconv=0 first unconverged value (error) -302.035 (1.81242361e-06)
157801 EPS nconv=0 first unconverged value (error) -302.035 (1.81242361e-06)
157802 EPS nconv=0 first unconverged value (error) -302.035 (2.35651060e-06)
157803 EPS nconv=0 first unconverged value (error) -302.035 (2.21507350e-06)
157804 EPS nconv=0 first unconverged value (error) -302.035 (2.13243397e-06)
157805 EPS nconv=0 first unconverged value (error) -302.035 (2.10219934e-06)
157806 EPS nconv=0 first unconverged value (error) -302.035 (2.04715965e-06)
157807 EPS nconv=0 first unconverged value (error) -302.035 (2.04715965e-06)
157808 EPS nconv=0 first unconverged value (error) -302.035 (2.29619536e-06)
157809 EPS nconv=0 first unconverged value (error) -302.035 (2.26898924e-06)
157810 EPS nconv=0 first unconverged value (error) -302.035 (2.06746985e-06)
157811 EPS nconv=0 first unconverged value (error) -302.035 (2.04298061e-06)
157812 EPS nconv=0 first unconverged value (error) -302.035 (2.00724947e-06)
157813 EPS nconv=0 first unconverged value (error) -302.035 (2.00724947e-06)
157814 EPS nconv=0 first unconverged value (error) -302.035 (2.24329713e-06)
157815 EPS nconv=0 first unconverged value (error) -302.035 (2.14990943e-06)
157816 EPS nconv=0 first unconverged value (error) -302.035 (2.04680557e-06)
157817 EPS nconv=0 first unconverged value (error) -302.035 (1.99563899e-06)
157818 EPS nconv=0 first unconverged value (error) -302.035 (1.95659612e-06)
157819 EPS nconv=0 first unconverged value (error) -302.035 (1.95659612e-06)
157820 EPS nconv=0 first unconverged value (error) -302.035 (2.30817388e-06)
157821 EPS nconv=0 first unconverged value (error) -302.035 (2.23687800e-06)
157822 EPS nconv=0 first unconverged value (error) -302.035 (2.10503188e-06)
157823 EPS nconv=0 first unconverged value (error) -302.035 (1.99812535e-06)
157824 EPS nconv=0 first unconverged value (error) -302.035 (1.95816197e-06)
157825 EPS nconv=0 first unconverged value (error) -302.035 (1.95816197e-06)
157826 EPS nconv=0 first unconverged value (error) -302.035 (1.94147360e-06)
157827 EPS nconv=0 first unconverged value (error) -302.035 (2.12489385e-06)
157828 EPS nconv=0 first unconverged value (error) -302.035 (1.90616624e-06)
157829 EPS nconv=0 first unconverged value (error) -302.035 (1.85186263e-06)
157830 EPS nconv=0 first unconverged value (error) -302.035 (1.83552015e-06)
157831 EPS nconv=0 first unconverged value (error) -302.035 (1.83552015e-06)
157832 EPS nconv=0 first unconverged value (error) -302.035 (1.81869062e-06)
157833 EPS nconv=0 first unconverged value (error) -302.035 (1.81097782e-06)
157834 EPS nconv=0 first unconverged value (error) -302.035 (1.80732211e-06)
157835 EPS nconv=0 first unconverged value (error) -302.035 (1.80739811e-06)
157836 EPS nconv=0 first unconverged value (error) -302.035 (1.80378624e-06)
157837 EPS nconv=0 first unconverged value (error) -302.035 (1.80378624e-06)
157838 EPS nconv=0 first unconverged value (error) -302.035 (2.01168099e-06)
157839 EPS nconv=0 first unconverged value (error) -302.035 (2.03859595e-06)
157840 EPS nconv=0 first unconverged value (error) -302.035 (2.00391900e-06)
157841 EPS nconv=0 first unconverged value (error) -302.035 (1.96182207e-06)
157842 EPS nconv=0 first unconverged value (error) -302.035 (1.95222140e-06)
157843 EPS nconv=0 first unconverged value (error) -302.035 (1.95222140e-06)
157844 EPS nconv=0 first unconverged value (error) -302.035 (2.22551800e-06)
157845 EPS nconv=0 first unconverged value (error) -302.035 (2.01774047e-06)
157846 EPS nconv=0 first unconverged value (error) -302.035 (1.97329178e-06)
157847 EPS nconv=0 first unconverged value (error) -302.035 (1.97388173e-06)
157848 EPS nconv=0 first unconverged value (error) -302.035 (1.94348487e-06)
157849 EPS nconv=0 first unconverged value (error) -302.035 (1.94348487e-06)
157850 EPS nconv=0 first unconverged value (error) -302.035 (4.00900297e-06)
157851 EPS nconv=0 first unconverged value (error) -302.035 (3.72412014e-06)
157852 EPS nconv=0 first unconverged value (error) -302.035 (3.06436122e-06)
157853 EPS nconv=0 first unconverged value (error) -302.035 (2.93836078e-06)
157854 EPS nconv=0 first unconverged value (error) -302.035 (2.88400297e-06)
157855 EPS nconv=0 first unconverged value (error) -302.035 (2.88400297e-06)
157856 EPS nconv=0 first unconverged value (error) -302.035 (3.42659119e-06)
157857 EPS nconv=0 first unconverged value (error) -302.035 (3.53318454e-06)
157858 EPS nconv=0 first unconverged value (error) -302.035 (3.09467601e-06)
157859 EPS nconv=0 first unconverged value (error) -302.035 (2.64838243e-06)
157860 EPS nconv=0 first unconverged value (error) -302.035 (2.23838976e-06)
157861 EPS nconv=0 first unconverged value (error) -302.035 (2.23838976e-06)
157862 EPS nconv=0 first unconverged value (error) -302.035 (2.25873830e-06)
157863 EPS nconv=0 first unconverged value (error) -302.035 (2.60397536e-06)
157864 EPS nconv=0 first unconverged value (error) -302.035 (2.38053529e-06)
157865 EPS nconv=0 first unconverged value (error) -302.035 (1.93421207e-06)
157866 EPS nconv=0 first unconverged value (error) -302.035 (1.89653757e-06)
157867 EPS nconv=0 first unconverged value (error) -302.035 (1.89653757e-06)
157868 EPS nconv=0 first unconverged value (error) -302.035 (1.97465325e-06)
157869 EPS nconv=0 first unconverged value (error) -302.035 (1.89936636e-06)
157870 EPS nconv=0 first unconverged value (error) -302.035 (1.90907157e-06)
157871 EPS nconv=0 first unconverged value (error) -302.035 (1.84589584e-06)
157872 EPS nconv=0 first unconverged value (error) -302.035 (1.83269631e-06)
157873 EPS nconv=0 first unconverged value (error) -302.035 (1.83269631e-06)
157874 EPS nconv=0 first unconverged value (error) -302.035 (2.45588996e-06)
157875 EPS nconv=0 first unconverged value (error) -302.035 (2.23622310e-06)
157876 EPS nconv=0 first unconverged value (error) -302.035 (2.11976993e-06)
157877 EPS nconv=0 first unconverged value (error) -302.035 (2.06863725e-06)
157878 EPS nconv=0 first unconverged value (error) -302.035 (2.01661543e-06)
157879 EPS nconv=0 first unconverged value (error) -302.035 (2.01661543e-06)
157880 EPS nconv=0 first unconverged value (error) -302.035 (2.01972717e-06)
157881 EPS nconv=0 first unconverged value (error) -302.035 (2.25686259e-06)
157882 EPS nconv=0 first unconverged value (error) -302.035 (2.02477546e-06)
157883 EPS nconv=0 first unconverged value (error) -302.035 (1.85922700e-06)
157884 EPS nconv=0 first unconverged value (error) -302.035 (1.83557838e-06)
157885 EPS nconv=0 first unconverged value (error) -302.035 (1.83557838e-06)
157886 EPS nconv=0 first unconverged value (error) -302.035 (2.66576667e-06)
157887 EPS nconv=0 first unconverged value (error) -302.035 (2.36893369e-06)
157888 EPS nconv=0 first unconverged value (error) -302.035 (2.29027298e-06)
157889 EPS nconv=0 first unconverged value (error) -302.035 (2.24740493e-06)
157890 EPS nconv=0 first unconverged value (error) -302.035 (2.16446157e-06)
157891 EPS nconv=0 first unconverged value (error) -302.035 (2.16446157e-06)
157892 EPS nconv=0 first unconverged value (error) -302.035 (2.18083940e-06)
157893 EPS nconv=0 first unconverged value (error) -302.035 (2.32879332e-06)
157894 EPS nconv=0 first unconverged value (error) -302.035 (2.04031060e-06)
157895 EPS nconv=0 first unconverged value (error) -302.035 (1.93818693e-06)
157896 EPS nconv=0 first unconverged value (error) -302.035 (1.88746372e-06)
157897 EPS nconv=0 first unconverged value (error) -302.035 (1.88746372e-06)
157898 EPS nconv=0 first unconverged value (error) -302.035 (1.91559589e-06)
157899 EPS nconv=0 first unconverged value (error) -302.035 (1.87819907e-06)
157900 EPS nconv=0 first unconverged value (error) -302.035 (1.85714410e-06)
157901 EPS nconv=0 first unconverged value (error) -302.035 (1.84900541e-06)
157902 EPS nconv=0 first unconverged value (error) -302.035 (1.83410819e-06)
157903 EPS nconv=0 first unconverged value (error) -302.035 (1.83410819e-06)
157904 EPS nconv=0 first unconverged value (error) -302.035 (2.47689411e-06)
157905 EPS nconv=0 first unconverged value (error) -302.035 (2.39426258e-06)
157906 EPS nconv=0 first unconverged value (error) -302.035 (2.25761338e-06)
157907 EPS nconv=0 first unconverged value (error) -302.035 (2.11878790e-06)
157908 EPS nconv=0 first unconverged value (error) -302.035 (2.08033374e-06)
157909 EPS nconv=0 first unconverged value (error) -302.035 (2.08033374e-06)
157910 EPS nconv=0 first unconverged value (error) -302.035 (2.22497296e-06)
157911 EPS nconv=0 first unconverged value (error) -302.035 (2.36359232e-06)
157912 EPS nconv=0 first unconverged value (error) -302.035 (2.22827214e-06)
157913 EPS nconv=0 first unconverged value (error) -302.035 (1.97797517e-06)
157914 EPS nconv=0 first unconverged value (error) -302.035 (1.92558761e-06)
157915 EPS nconv=0 first unconverged value (error) -302.035 (1.92558761e-06)
157916 EPS nconv=0 first unconverged value (error) -302.035 (2.32473429e-06)
157917 EPS nconv=0 first unconverged value (error) -302.035 (2.18634484e-06)
157918 EPS nconv=0 first unconverged value (error) -302.035 (2.05554409e-06)
157919 EPS nconv=0 first unconverged value (error) -302.035 (2.03365914e-06)
157920 EPS nconv=0 first unconverged value (error) -302.035 (1.98677966e-06)
157921 EPS nconv=0 first unconverged value (error) -302.035 (1.98677966e-06)
157922 EPS nconv=0 first unconverged value (error) -302.035 (2.01554137e-06)
157923 EPS nconv=0 first unconverged value (error) -302.035 (2.10894286e-06)
157924 EPS nconv=0 first unconverged value (error) -302.035 (1.98240396e-06)
157925 EPS nconv=0 first unconverged value (error) -302.035 (1.87778392e-06)
157926 EPS nconv=0 first unconverged value (error) -302.035 (1.85932465e-06)
157927 EPS nconv=0 first unconverged value (error) -302.035 (1.85932465e-06)
157928 EPS nconv=0 first unconverged value (error) -302.035 (2.24348904e-06)
157929 EPS nconv=0 first unconverged value (error) -302.035 (2.05220028e-06)
157930 EPS nconv=0 first unconverged value (error) -302.035 (1.98729478e-06)
157931 EPS nconv=0 first unconverged value (error) -302.035 (1.95243524e-06)
157932 EPS nconv=0 first unconverged value (error) -302.035 (1.92706339e-06)
157933 EPS nconv=0 first unconverged value (error) -302.035 (1.92706339e-06)
157934 EPS nconv=0 first unconverged value (error) -302.035 (2.14574395e-06)
157935 EPS nconv=0 first unconverged value (error) -302.035 (2.28093532e-06)
157936 EPS nconv=0 first unconverged value (error) -302.035 (2.08006577e-06)
157937 EPS nconv=0 first unconverged value (error) -302.035 (1.92999341e-06)
157938 EPS nconv=0 first unconverged value (error) -302.035 (1.92956754e-06)
157939 EPS nconv=0 first unconverged value (error) -302.035 (1.92956754e-06)
157940 EPS nconv=0 first unconverged value (error) -302.035 (2.24187284e-06)
157941 EPS nconv=0 first unconverged value (error) -302.035 (2.09855718e-06)
157942 EPS nconv=0 first unconverged value (error) -302.035 (2.01749697e-06)
157943 EPS nconv=0 first unconverged value (error) -302.035 (2.01892000e-06)
157944 EPS nconv=0 first unconverged value (error) -302.035 (1.96204607e-06)
157945 EPS nconv=0 first unconverged value (error) -302.035 (1.96204607e-06)
157946 EPS nconv=0 first unconverged value (error) -302.035 (1.99181639e-06)
157947 EPS nconv=0 first unconverged value (error) -302.035 (2.06213806e-06)
157948 EPS nconv=0 first unconverged value (error) -302.035 (1.86836157e-06)
157949 EPS nconv=0 first unconverged value (error) -302.035 (1.85554294e-06)
157950 EPS nconv=0 first unconverged value (error) -302.035 (1.85041696e-06)
157951 EPS nconv=0 first unconverged value (error) -302.035 (1.85041696e-06)
157952 EPS nconv=0 first unconverged value (error) -302.035 (1.83475799e-06)
157953 EPS nconv=0 first unconverged value (error) -302.035 (1.83187323e-06)
157954 EPS nconv=0 first unconverged value (error) -302.035 (1.81897567e-06)
157955 EPS nconv=0 first unconverged value (error) -302.035 (1.80541054e-06)
157956 EPS nconv=0 first unconverged value (error) -302.035 (1.80355203e-06)
157957 EPS nconv=0 first unconverged value (error) -302.035 (1.80355203e-06)
157958 EPS nconv=0 first unconverged value (error) -302.035 (2.44441934e-06)
157959 EPS nconv=0 first unconverged value (error) -302.035 (2.21505576e-06)
157960 EPS nconv=0 first unconverged value (error) -302.035 (2.13709610e-06)
157961 EPS nconv=0 first unconverged value (error) -302.035 (2.11001593e-06)
157962 EPS nconv=0 first unconverged value (error) -302.035 (2.04740052e-06)
157963 EPS nconv=0 first unconverged value (error) -302.035 (2.04740052e-06)
157964 EPS nconv=0 first unconverged value (error) -302.035 (2.57467016e-06)
157965 EPS nconv=0 first unconverged value (error) -302.035 (2.80033273e-06)
157966 EPS nconv=0 first unconverged value (error) -302.035 (2.52695786e-06)
157967 EPS nconv=0 first unconverged value (error) -302.035 (2.17616152e-06)
157968 EPS nconv=0 first unconverged value (error) -302.035 (2.12814614e-06)
157969 EPS nconv=0 first unconverged value (error) -302.035 (2.12814614e-06)
157970 EPS nconv=0 first unconverged value (error) -302.035 (2.09889825e-06)
157971 EPS nconv=0 first unconverged value (error) -302.035 (2.06316461e-06)
157972 EPS nconv=0 first unconverged value (error) -302.035 (1.97107749e-06)
157973 EPS nconv=0 first unconverged value (error) -302.035 (1.89025241e-06)
157974 EPS nconv=0 first unconverged value (error) -302.035 (1.82536055e-06)
157975 EPS nconv=0 first unconverged value (error) -302.035 (1.82536055e-06)
157976 EPS nconv=0 first unconverged value (error) -302.035 (2.12714713e-06)
157977 EPS nconv=0 first unconverged value (error) -302.035 (2.02291881e-06)
157978 EPS nconv=0 first unconverged value (error) -302.035 (1.97783673e-06)
157979 EPS nconv=0 first unconverged value (error) -302.035 (1.93868993e-06)
157980 EPS nconv=0 first unconverged value (error) -302.035 (1.92625740e-06)
157981 EPS nconv=0 first unconverged value (error) -302.035 (1.92625740e-06)
157982 EPS nconv=0 first unconverged value (error) -302.035 (2.08672875e-06)
157983 EPS nconv=0 first unconverged value (error) -302.035 (2.07268320e-06)
157984 EPS nconv=0 first unconverged value (error) -302.035 (1.99613084e-06)
157985 EPS nconv=0 first unconverged value (error) -302.035 (1.90289861e-06)
157986 EPS nconv=0 first unconverged value (error) -302.035 (1.88215039e-06)
157987 EPS nconv=0 first unconverged value (error) -302.035 (1.88215039e-06)
157988 EPS nconv=0 first unconverged value (error) -302.035 (2.46979625e-06)
157989 EPS nconv=0 first unconverged value (error) -302.035 (2.29761747e-06)
157990 EPS nconv=0 first unconverged value (error) -302.035 (2.16489360e-06)
157991 EPS nconv=0 first unconverged value (error) -302.035 (2.12377644e-06)
157992 EPS nconv=0 first unconverged value (error) -302.035 (2.07892362e-06)
157993 EPS nconv=0 first unconverged value (error) -302.035 (2.07892362e-06)
157994 EPS nconv=0 first unconverged value (error) -302.035 (2.07599599e-06)
157995 EPS nconv=0 first unconverged value (error) -302.035 (2.20944412e-06)
157996 EPS nconv=0 first unconverged value (error) -302.035 (2.03032806e-06)
157997 EPS nconv=0 first unconverged value (error) -302.035 (1.87931863e-06)
157998 EPS nconv=0 first unconverged value (error) -302.035 (1.83857304e-06)
157999 EPS nconv=0 first unconverged value (error) -302.035 (1.83857304e-06)
158000 EPS nconv=0 first unconverged value (error) -302.035 (1.95292037e-06)
158001 EPS nconv=0 first unconverged value (error) -302.035 (1.89545149e-06)
158002 EPS nconv=0 first unconverged value (error) -302.035 (1.87126338e-06)
158003 EPS nconv=0 first unconverged value (error) -302.035 (1.85868726e-06)
158004 EPS nconv=0 first unconverged value (error) -302.035 (1.85051523e-06)
158005 EPS nconv=0 first unconverged value (error) -302.035 (1.85051523e-06)
158006 EPS nconv=0 first unconverged value (error) -302.035 (1.97382331e-06)
158007 EPS nconv=0 first unconverged value (error) -302.035 (2.01441992e-06)
158008 EPS nconv=0 first unconverged value (error) -302.035 (1.95773159e-06)
158009 EPS nconv=0 first unconverged value (error) -302.035 (1.85959639e-06)
158010 EPS nconv=0 first unconverged value (error) -302.035 (1.84509557e-06)
158011 EPS nconv=0 first unconverged value (error) -302.035 (1.84509557e-06)
158012 EPS nconv=0 first unconverged value (error) -302.035 (1.84811929e-06)
158013 EPS nconv=0 first unconverged value (error) -302.035 (1.85593111e-06)
158014 EPS nconv=0 first unconverged value (error) -302.035 (1.83358883e-06)
158015 EPS nconv=0 first unconverged value (error) -302.035 (1.81785310e-06)
158016 EPS nconv=0 first unconverged value (error) -302.035 (1.80492528e-06)
158017 EPS nconv=0 first unconverged value (error) -302.035 (1.80492528e-06)
158018 EPS nconv=0 first unconverged value (error) -302.035 (2.40252898e-06)
158019 EPS nconv=0 first unconverged value (error) -302.035 (2.15824326e-06)
158020 EPS nconv=0 first unconverged value (error) -302.035 (2.07019346e-06)
158021 EPS nconv=0 first unconverged value (error) -302.035 (2.04175589e-06)
158022 EPS nconv=0 first unconverged value (error) -302.035 (1.99619724e-06)
158023 EPS nconv=0 first unconverged value (error) -302.035 (1.99619724e-06)
158024 EPS nconv=0 first unconverged value (error) -302.035 (1.99327436e-06)
158025 EPS nconv=0 first unconverged value (error) -302.035 (2.21229890e-06)
158026 EPS nconv=0 first unconverged value (error) -302.035 (2.00577769e-06)
158027 EPS nconv=0 first unconverged value (error) -302.035 (1.81643273e-06)
158028 EPS nconv=0 first unconverged value (error) -302.035 (1.81526001e-06)
158029 EPS nconv=0 first unconverged value (error) -302.035 (1.81526001e-06)
158030 EPS nconv=0 first unconverged value (error) -302.035 (1.93758755e-06)
158031 EPS nconv=0 first unconverged value (error) -302.035 (1.86000408e-06)
158032 EPS nconv=0 first unconverged value (error) -302.035 (1.84368471e-06)
158033 EPS nconv=0 first unconverged value (error) -302.035 (1.83902716e-06)
158034 EPS nconv=0 first unconverged value (error) -302.035 (1.83541407e-06)
158035 EPS nconv=0 first unconverged value (error) -302.035 (1.83541407e-06)
158036 EPS nconv=0 first unconverged value (error) -302.035 (2.07830102e-06)
158037 EPS nconv=0 first unconverged value (error) -302.035 (2.08178720e-06)
158038 EPS nconv=0 first unconverged value (error) -302.035 (1.97024809e-06)
158039 EPS nconv=0 first unconverged value (error) -302.035 (1.89999450e-06)
158040 EPS nconv=0 first unconverged value (error) -302.035 (1.88620807e-06)
158041 EPS nconv=0 first unconverged value (error) -302.035 (1.88620807e-06)
158042 EPS nconv=0 first unconverged value (error) -302.035 (1.89179830e-06)
158043 EPS nconv=0 first unconverged value (error) -302.035 (1.92503998e-06)
158044 EPS nconv=0 first unconverged value (error) -302.035 (1.85855114e-06)
158045 EPS nconv=0 first unconverged value (error) -302.035 (1.80846805e-06)
158046 EPS nconv=0 first unconverged value (error) -302.035 (1.80635875e-06)
158047 EPS nconv=0 first unconverged value (error) -302.035 (1.80635875e-06)
158048 EPS nconv=0 first unconverged value (error) -302.035 (2.91693579e-06)
158049 EPS nconv=0 first unconverged value (error) -302.035 (2.47833392e-06)
158050 EPS nconv=0 first unconverged value (error) -302.035 (2.47980083e-06)
158051 EPS nconv=0 first unconverged value (error) -302.035 (2.37673008e-06)
158052 EPS nconv=0 first unconverged value (error) -302.035 (2.31163084e-06)
158053 EPS nconv=0 first unconverged value (error) -302.035 (2.31163084e-06)
158054 EPS nconv=0 first unconverged value (error) -302.035 (3.33001358e-06)
158055 EPS nconv=0 first unconverged value (error) -302.035 (3.49579828e-06)
158056 EPS nconv=0 first unconverged value (error) -302.035 (3.11084944e-06)
158057 EPS nconv=0 first unconverged value (error) -302.035 (2.51692937e-06)
158058 EPS nconv=0 first unconverged value (error) -302.035 (2.43613737e-06)
158059 EPS nconv=0 first unconverged value (error) -302.035 (2.43613737e-06)
158060 EPS nconv=0 first unconverged value (error) -302.035 (3.33763299e-06)
158061 EPS nconv=0 first unconverged value (error) -302.035 (2.83444624e-06)
158062 EPS nconv=0 first unconverged value (error) -302.035 (2.53332942e-06)
158063 EPS nconv=0 first unconverged value (error) -302.035 (2.52531164e-06)
158064 EPS nconv=0 first unconverged value (error) -302.035 (2.44886344e-06)
158065 EPS nconv=0 first unconverged value (error) -302.035 (2.44886344e-06)
158066 EPS nconv=0 first unconverged value (error) -302.035 (2.47799035e-06)
158067 EPS nconv=0 first unconverged value (error) -302.035 (2.63052034e-06)
158068 EPS nconv=0 first unconverged value (error) -302.035 (2.05937195e-06)
158069 EPS nconv=0 first unconverged value (error) -302.035 (1.98174610e-06)
158070 EPS nconv=0 first unconverged value (error) -302.035 (1.94745384e-06)
158071 EPS nconv=0 first unconverged value (error) -302.035 (1.94745384e-06)
158072 EPS nconv=0 first unconverged value (error) -302.035 (1.83748520e-06)
158073 EPS nconv=0 first unconverged value (error) -302.035 (1.82014332e-06)
158074 EPS nconv=0 first unconverged value (error) -302.035 (1.80999098e-06)
158075 EPS nconv=0 first unconverged value (error) -302.035 (1.79899402e-06)
158076 EPS nconv=0 first unconverged value (error) -302.035 (1.79623987e-06)
158077 EPS nconv=0 first unconverged value (error) -302.035 (1.79623987e-06)
158078 EPS nconv=0 first unconverged value (error) -302.035 (1.79665330e-06)
158079 EPS nconv=0 first unconverged value (error) -302.035 (1.79585813e-06)
158080 EPS nconv=0 first unconverged value (error) -302.035 (1.79450144e-06)
158081 EPS nconv=0 first unconverged value (error) -302.035 (1.79395182e-06)
158082 EPS nconv=0 first unconverged value (error) -302.035 (1.79384847e-06)
158083 EPS nconv=0 first unconverged value (error) -302.035 (1.79384847e-06)
158084 EPS nconv=0 first unconverged value (error) -302.035 (2.85055682e-06)
158085 EPS nconv=0 first unconverged value (error) -302.035 (2.48410398e-06)
158086 EPS nconv=0 first unconverged value (error) -302.035 (2.37188475e-06)
158087 EPS nconv=0 first unconverged value (error) -302.035 (2.29010565e-06)
158088 EPS nconv=0 first unconverged value (error) -302.035 (2.25742595e-06)
158089 EPS nconv=0 first unconverged value (error) -302.035 (2.25742595e-06)
158090 EPS nconv=0 first unconverged value (error) -302.035 (2.31428043e-06)
158091 EPS nconv=0 first unconverged value (error) -302.035 (2.49854009e-06)
158092 EPS nconv=0 first unconverged value (error) -302.035 (2.09128198e-06)
158093 EPS nconv=0 first unconverged value (error) -302.035 (1.93054352e-06)
158094 EPS nconv=0 first unconverged value (error) -302.035 (1.89897318e-06)
158095 EPS nconv=0 first unconverged value (error) -302.035 (1.89897318e-06)
158096 EPS nconv=0 first unconverged value (error) -302.035 (2.56184608e-06)
158097 EPS nconv=0 first unconverged value (error) -302.035 (2.33979217e-06)
158098 EPS nconv=0 first unconverged value (error) -302.035 (2.21726334e-06)
158099 EPS nconv=0 first unconverged value (error) -302.035 (2.20007476e-06)
158100 EPS nconv=0 first unconverged value (error) -302.035 (2.15601692e-06)
158101 EPS nconv=0 first unconverged value (error) -302.035 (2.15601692e-06)
158102 EPS nconv=0 first unconverged value (error) -302.035 (2.78486525e-06)
158103 EPS nconv=0 first unconverged value (error) -302.035 (2.85483007e-06)
158104 EPS nconv=0 first unconverged value (error) -302.035 (2.46806112e-06)
158105 EPS nconv=0 first unconverged value (error) -302.035 (2.19385066e-06)
158106 EPS nconv=0 first unconverged value (error) -302.035 (2.13585621e-06)
158107 EPS nconv=0 first unconverged value (error) -302.035 (2.13585621e-06)
158108 EPS nconv=0 first unconverged value (error) -302.035 (3.47952159e-06)
158109 EPS nconv=0 first unconverged value (error) -302.035 (3.10590324e-06)
158110 EPS nconv=0 first unconverged value (error) -302.035 (2.89926356e-06)
158111 EPS nconv=0 first unconverged value (error) -302.035 (2.73347847e-06)
158112 EPS nconv=0 first unconverged value (error) -302.035 (2.51594833e-06)
158113 EPS nconv=0 first unconverged value (error) -302.035 (2.51594833e-06)
158114 EPS nconv=0 first unconverged value (error) -302.035 (2.85911334e-06)
158115 EPS nconv=0 first unconverged value (error) -302.035 (3.00678776e-06)
158116 EPS nconv=0 first unconverged value (error) -302.035 (2.49012445e-06)
158117 EPS nconv=0 first unconverged value (error) -302.035 (2.36391887e-06)
158118 EPS nconv=0 first unconverged value (error) -302.035 (2.19497630e-06)
158119 EPS nconv=0 first unconverged value (error) -302.035 (2.19497630e-06)
158120 EPS nconv=0 first unconverged value (error) -302.035 (2.05660240e-06)
158121 EPS nconv=0 first unconverged value (error) -302.035 (2.09737550e-06)
158122 EPS nconv=0 first unconverged value (error) -302.035 (1.97743535e-06)
158123 EPS nconv=0 first unconverged value (error) -302.035 (1.86495508e-06)
158124 EPS nconv=0 first unconverged value (error) -302.035 (1.85908314e-06)
158125 EPS nconv=0 first unconverged value (error) -302.035 (1.85908314e-06)
158126 EPS nconv=0 first unconverged value (error) -302.035 (2.04613906e-06)
158127 EPS nconv=0 first unconverged value (error) -302.035 (1.91161971e-06)
158128 EPS nconv=0 first unconverged value (error) -302.035 (1.89573627e-06)
158129 EPS nconv=0 first unconverged value (error) -302.035 (1.87930603e-06)
158130 EPS nconv=0 first unconverged value (error) -302.035 (1.86502271e-06)
158131 EPS nconv=0 first unconverged value (error) -302.035 (1.86502271e-06)
158132 EPS nconv=0 first unconverged value (error) -302.035 (3.47386509e-06)
158133 EPS nconv=0 first unconverged value (error) -302.035 (3.12696648e-06)
158134 EPS nconv=0 first unconverged value (error) -302.035 (2.86658593e-06)
158135 EPS nconv=0 first unconverged value (error) -302.035 (2.63853426e-06)
158136 EPS nconv=0 first unconverged value (error) -302.035 (2.52269608e-06)
158137 EPS nconv=0 first unconverged value (error) -302.035 (2.52269608e-06)
158138 EPS nconv=0 first unconverged value (error) -302.035 (2.59855803e-06)
158139 EPS nconv=0 first unconverged value (error) -302.035 (2.88941798e-06)
158140 EPS nconv=0 first unconverged value (error) -302.035 (2.44593844e-06)
158141 EPS nconv=0 first unconverged value (error) -302.035 (2.11603512e-06)
158142 EPS nconv=0 first unconverged value (error) -302.035 (2.03878110e-06)
158143 EPS nconv=0 first unconverged value (error) -302.035 (2.03878110e-06)
158144 EPS nconv=0 first unconverged value (error) -302.035 (2.00452945e-06)
158145 EPS nconv=0 first unconverged value (error) -302.035 (1.97729155e-06)
158146 EPS nconv=0 first unconverged value (error) -302.035 (1.90644943e-06)
158147 EPS nconv=0 first unconverged value (error) -302.035 (1.86517511e-06)
158148 EPS nconv=0 first unconverged value (error) -302.035 (1.83694845e-06)
158149 EPS nconv=0 first unconverged value (error) -302.035 (1.83694845e-06)
158150 EPS nconv=0 first unconverged value (error) -302.035 (2.84070509e-06)
158151 EPS nconv=0 first unconverged value (error) -302.035 (2.44438448e-06)
158152 EPS nconv=0 first unconverged value (error) -302.035 (2.29601489e-06)
158153 EPS nconv=0 first unconverged value (error) -302.035 (2.21312330e-06)
158154 EPS nconv=0 first unconverged value (error) -302.035 (2.18343866e-06)
158155 EPS nconv=0 first unconverged value (error) -302.035 (2.18343866e-06)
158156 EPS nconv=0 first unconverged value (error) -302.035 (3.36782247e-06)
158157 EPS nconv=0 first unconverged value (error) -302.035 (3.09588961e-06)
158158 EPS nconv=0 first unconverged value (error) -302.035 (2.54472227e-06)
158159 EPS nconv=0 first unconverged value (error) -302.035 (2.52921482e-06)
158160 EPS nconv=0 first unconverged value (error) -302.035 (2.39850800e-06)
158161 EPS nconv=0 first unconverged value (error) -302.035 (2.39850800e-06)
158162 EPS nconv=0 first unconverged value (error) -302.035 (2.41113107e-06)
158163 EPS nconv=0 first unconverged value (error) -302.035 (2.91253956e-06)
158164 EPS nconv=0 first unconverged value (error) -302.035 (2.29525917e-06)
158165 EPS nconv=0 first unconverged value (error) -302.035 (1.96713313e-06)
158166 EPS nconv=0 first unconverged value (error) -302.035 (1.93391381e-06)
158167 EPS nconv=0 first unconverged value (error) -302.035 (1.93391381e-06)
158168 EPS nconv=0 first unconverged value (error) -302.035 (1.83687010e-06)
158169 EPS nconv=0 first unconverged value (error) -302.035 (1.81462812e-06)
158170 EPS nconv=0 first unconverged value (error) -302.035 (1.80665094e-06)
158171 EPS nconv=0 first unconverged value (error) -302.035 (1.80005722e-06)
158172 EPS nconv=0 first unconverged value (error) -302.035 (1.79637415e-06)
158173 EPS nconv=0 first unconverged value (error) -302.035 (1.79637415e-06)
158174 EPS nconv=0 first unconverged value (error) -302.035 (1.82133902e-06)
158175 EPS nconv=0 first unconverged value (error) -302.035 (1.81251715e-06)
158176 EPS nconv=0 first unconverged value (error) -302.035 (1.80774028e-06)
158177 EPS nconv=0 first unconverged value (error) -302.035 (1.80610327e-06)
158178 EPS nconv=0 first unconverged value (error) -302.035 (1.80527498e-06)
158179 EPS nconv=0 first unconverged value (error) -302.035 (1.80527498e-06)
158180 EPS nconv=0 first unconverged value (error) -302.035 (2.16989271e-06)
158181 EPS nconv=0 first unconverged value (error) -302.035 (2.01968494e-06)
158182 EPS nconv=0 first unconverged value (error) -302.035 (1.95849050e-06)
158183 EPS nconv=0 first unconverged value (error) -302.035 (1.95066869e-06)
158184 EPS nconv=0 first unconverged value (error) -302.035 (1.93818105e-06)
158185 EPS nconv=0 first unconverged value (error) -302.035 (1.93818105e-06)
158186 EPS nconv=0 first unconverged value (error) -302.035 (1.93894844e-06)
158187 EPS nconv=0 first unconverged value (error) -302.035 (2.07853601e-06)
158188 EPS nconv=0 first unconverged value (error) -302.035 (1.91373970e-06)
158189 EPS nconv=0 first unconverged value (error) -302.035 (1.81985277e-06)
158190 EPS nconv=0 first unconverged value (error) -302.035 (1.80547106e-06)
158191 EPS nconv=0 first unconverged value (error) -302.035 (1.80547106e-06)
158192 EPS nconv=0 first unconverged value (error) -302.035 (1.82917257e-06)
158193 EPS nconv=0 first unconverged value (error) -302.035 (1.81785586e-06)
158194 EPS nconv=0 first unconverged value (error) -302.035 (1.81103010e-06)
158195 EPS nconv=0 first unconverged value (error) -302.035 (1.81062676e-06)
158196 EPS nconv=0 first unconverged value (error) -302.035 (1.80931356e-06)
158197 EPS nconv=0 first unconverged value (error) -302.035 (1.80931356e-06)
158198 EPS nconv=0 first unconverged value (error) -302.035 (2.04991398e-06)
158199 EPS nconv=0 first unconverged value (error) -302.035 (1.99592460e-06)
158200 EPS nconv=0 first unconverged value (error) -302.035 (1.93512193e-06)
158201 EPS nconv=0 first unconverged value (error) -302.035 (1.88155076e-06)
158202 EPS nconv=0 first unconverged value (error) -302.035 (1.87169158e-06)
158203 EPS nconv=0 first unconverged value (error) -302.035 (1.87169158e-06)
158204 EPS nconv=0 first unconverged value (error) -302.035 (1.92630251e-06)
158205 EPS nconv=0 first unconverged value (error) -302.035 (2.01409258e-06)
158206 EPS nconv=0 first unconverged value (error) -302.035 (1.92871984e-06)
158207 EPS nconv=0 first unconverged value (error) -302.035 (1.82718789e-06)
158208 EPS nconv=0 first unconverged value (error) -302.035 (1.81920038e-06)
158209 EPS nconv=0 first unconverged value (error) -302.035 (1.81920038e-06)
158210 EPS nconv=0 first unconverged value (error) -302.035 (1.87108924e-06)
158211 EPS nconv=0 first unconverged value (error) -302.035 (1.85240130e-06)
158212 EPS nconv=0 first unconverged value (error) -302.035 (1.82698880e-06)
158213 EPS nconv=0 first unconverged value (error) -302.035 (1.82164784e-06)
158214 EPS nconv=0 first unconverged value (error) -302.035 (1.81855503e-06)
158215 EPS nconv=0 first unconverged value (error) -302.035 (1.81855503e-06)
158216 EPS nconv=0 first unconverged value (error) -302.035 (1.93213060e-06)
158217 EPS nconv=0 first unconverged value (error) -302.035 (1.88087007e-06)
158218 EPS nconv=0 first unconverged value (error) -302.035 (1.84352835e-06)
158219 EPS nconv=0 first unconverged value (error) -302.035 (1.83757394e-06)
158220 EPS nconv=0 first unconverged value (error) -302.035 (1.82978121e-06)
158221 EPS nconv=0 first unconverged value (error) -302.035 (1.82978121e-06)
158222 EPS nconv=0 first unconverged value (error) -302.035 (2.18520630e-06)
158223 EPS nconv=0 first unconverged value (error) -302.035 (2.16204255e-06)
158224 EPS nconv=0 first unconverged value (error) -302.035 (2.00442554e-06)
158225 EPS nconv=0 first unconverged value (error) -302.035 (1.94332210e-06)
158226 EPS nconv=0 first unconverged value (error) -302.035 (1.92727863e-06)
158227 EPS nconv=0 first unconverged value (error) -302.035 (1.92727863e-06)
158228 EPS nconv=0 first unconverged value (error) -302.035 (2.21688536e-06)
158229 EPS nconv=0 first unconverged value (error) -302.035 (2.15216099e-06)
158230 EPS nconv=0 first unconverged value (error) -302.035 (2.04152366e-06)
158231 EPS nconv=0 first unconverged value (error) -302.035 (1.97161708e-06)
158232 EPS nconv=0 first unconverged value (error) -302.035 (1.95378775e-06)
158233 EPS nconv=0 first unconverged value (error) -302.035 (1.95378775e-06)
158234 EPS nconv=0 first unconverged value (error) -302.035 (2.14029143e-06)
158235 EPS nconv=0 first unconverged value (error) -302.035 (2.09380092e-06)
158236 EPS nconv=0 first unconverged value (error) -302.035 (1.93129594e-06)
158237 EPS nconv=0 first unconverged value (error) -302.035 (1.90513754e-06)
158238 EPS nconv=0 first unconverged value (error) -302.035 (1.90827763e-06)
158239 EPS nconv=0 first unconverged value (error) -302.035 (1.90827763e-06)
158240 EPS nconv=0 first unconverged value (error) -302.035 (2.30050523e-06)
158241 EPS nconv=0 first unconverged value (error) -302.035 (2.08335433e-06)
158242 EPS nconv=0 first unconverged value (error) -302.035 (1.98845939e-06)
158243 EPS nconv=0 first unconverged value (error) -302.035 (1.95921041e-06)
158244 EPS nconv=0 first unconverged value (error) -302.035 (1.94574245e-06)
158245 EPS nconv=0 first unconverged value (error) -302.035 (1.94574245e-06)
158246 EPS nconv=0 first unconverged value (error) -302.035 (1.93160768e-06)
158247 EPS nconv=0 first unconverged value (error) -302.035 (2.13339908e-06)
158248 EPS nconv=0 first unconverged value (error) -302.035 (1.89378536e-06)
158249 EPS nconv=0 first unconverged value (error) -302.035 (1.83523874e-06)
158250 EPS nconv=0 first unconverged value (error) -302.035 (1.82738458e-06)
158251 EPS nconv=0 first unconverged value (error) -302.035 (1.82738458e-06)
158252 EPS nconv=0 first unconverged value (error) -302.035 (1.95176473e-06)
158253 EPS nconv=0 first unconverged value (error) -302.035 (1.89032387e-06)
158254 EPS nconv=0 first unconverged value (error) -302.035 (1.87350503e-06)
158255 EPS nconv=0 first unconverged value (error) -302.035 (1.86546960e-06)
158256 EPS nconv=0 first unconverged value (error) -302.035 (1.85422719e-06)
158257 EPS nconv=0 first unconverged value (error) -302.035 (1.85422719e-06)
158258 EPS nconv=0 first unconverged value (error) -302.035 (1.86231030e-06)
158259 EPS nconv=0 first unconverged value (error) -302.035 (1.90539084e-06)
158260 EPS nconv=0 first unconverged value (error) -302.035 (1.84534116e-06)
158261 EPS nconv=0 first unconverged value (error) -302.035 (1.81150303e-06)
158262 EPS nconv=0 first unconverged value (error) -302.035 (1.80936857e-06)
158263 EPS nconv=0 first unconverged value (error) -302.035 (1.80936857e-06)
158264 EPS nconv=0 first unconverged value (error) -302.035 (2.14864079e-06)
158265 EPS nconv=0 first unconverged value (error) -302.035 (1.99538594e-06)
158266 EPS nconv=0 first unconverged value (error) -302.035 (1.95078154e-06)
158267 EPS nconv=0 first unconverged value (error) -302.035 (1.93297818e-06)
158268 EPS nconv=0 first unconverged value (error) -302.035 (1.91013715e-06)
158269 EPS nconv=0 first unconverged value (error) -302.035 (1.91013715e-06)
158270 EPS nconv=0 first unconverged value (error) -302.035 (2.00383211e-06)
158271 EPS nconv=0 first unconverged value (error) -302.035 (2.13379579e-06)
158272 EPS nconv=0 first unconverged value (error) -302.035 (1.97027776e-06)
158273 EPS nconv=0 first unconverged value (error) -302.035 (1.86391848e-06)
158274 EPS nconv=0 first unconverged value (error) -302.035 (1.84466339e-06)
158275 EPS nconv=0 first unconverged value (error) -302.035 (1.84466339e-06)
158276 EPS nconv=0 first unconverged value (error) -302.035 (1.88902433e-06)
158277 EPS nconv=0 first unconverged value (error) -302.035 (1.87585222e-06)
158278 EPS nconv=0 first unconverged value (error) -302.035 (1.84853233e-06)
158279 EPS nconv=0 first unconverged value (error) -302.035 (1.84261600e-06)
158280 EPS nconv=0 first unconverged value (error) -302.035 (1.83108742e-06)
158281 EPS nconv=0 first unconverged value (error) -302.035 (1.83108742e-06)
158282 EPS nconv=0 first unconverged value (error) -302.035 (2.08832960e-06)
158283 EPS nconv=0 first unconverged value (error) -302.035 (2.01875767e-06)
158284 EPS nconv=0 first unconverged value (error) -302.035 (1.95094187e-06)
158285 EPS nconv=0 first unconverged value (error) -302.035 (1.90389914e-06)
158286 EPS nconv=0 first unconverged value (error) -302.035 (1.88647493e-06)
158287 EPS nconv=0 first unconverged value (error) -302.035 (1.88647493e-06)
158288 EPS nconv=0 first unconverged value (error) -302.035 (1.88473502e-06)
158289 EPS nconv=0 first unconverged value (error) -302.035 (1.95482530e-06)
158290 EPS nconv=0 first unconverged value (error) -302.035 (1.87129281e-06)
158291 EPS nconv=0 first unconverged value (error) -302.035 (1.82363109e-06)
158292 EPS nconv=0 first unconverged value (error) -302.035 (1.81648568e-06)
158293 EPS nconv=0 first unconverged value (error) -302.035 (1.81648568e-06)
158294 EPS nconv=0 first unconverged value (error) -302.035 (2.78068971e-06)
158295 EPS nconv=0 first unconverged value (error) -302.035 (2.42038417e-06)
158296 EPS nconv=0 first unconverged value (error) -302.035 (2.32295209e-06)
158297 EPS nconv=0 first unconverged value (error) -302.035 (2.28645035e-06)
158298 EPS nconv=0 first unconverged value (error) -302.035 (2.18756164e-06)
158299 EPS nconv=0 first unconverged value (error) -302.035 (2.18756164e-06)
158300 EPS nconv=0 first unconverged value (error) -302.035 (2.26040655e-06)
158301 EPS nconv=0 first unconverged value (error) -302.035 (2.46184130e-06)
158302 EPS nconv=0 first unconverged value (error) -302.035 (2.09813429e-06)
158303 EPS nconv=0 first unconverged value (error) -302.035 (1.98204308e-06)
158304 EPS nconv=0 first unconverged value (error) -302.035 (1.96428227e-06)
158305 EPS nconv=0 first unconverged value (error) -302.035 (1.96428227e-06)
158306 EPS nconv=0 first unconverged value (error) -302.035 (1.99076770e-06)
158307 EPS nconv=0 first unconverged value (error) -302.035 (1.91482701e-06)
158308 EPS nconv=0 first unconverged value (error) -302.035 (1.89538401e-06)
158309 EPS nconv=0 first unconverged value (error) -302.035 (1.85408439e-06)
158310 EPS nconv=0 first unconverged value (error) -302.035 (1.83218884e-06)
158311 EPS nconv=0 first unconverged value (error) -302.035 (1.83218884e-06)
158312 EPS nconv=0 first unconverged value (error) -302.035 (2.34524439e-06)
158313 EPS nconv=0 first unconverged value (error) -302.035 (2.20977168e-06)
158314 EPS nconv=0 first unconverged value (error) -302.035 (2.12938225e-06)
158315 EPS nconv=0 first unconverged value (error) -302.035 (2.04877921e-06)
158316 EPS nconv=0 first unconverged value (error) -302.035 (2.02480723e-06)
158317 EPS nconv=0 first unconverged value (error) -302.035 (2.02480723e-06)
158318 EPS nconv=0 first unconverged value (error) -302.035 (2.30148153e-06)
158319 EPS nconv=0 first unconverged value (error) -302.035 (2.41742984e-06)
158320 EPS nconv=0 first unconverged value (error) -302.035 (2.20149884e-06)
158321 EPS nconv=0 first unconverged value (error) -302.035 (1.98558250e-06)
158322 EPS nconv=0 first unconverged value (error) -302.035 (1.95629677e-06)
158323 EPS nconv=0 first unconverged value (error) -302.035 (1.95629677e-06)
158324 EPS nconv=0 first unconverged value (error) -302.035 (2.88905765e-06)
158325 EPS nconv=0 first unconverged value (error) -302.035 (2.50139525e-06)
158326 EPS nconv=0 first unconverged value (error) -302.035 (2.36237288e-06)
158327 EPS nconv=0 first unconverged value (error) -302.035 (2.34770766e-06)
158328 EPS nconv=0 first unconverged value (error) -302.035 (2.29575846e-06)
158329 EPS nconv=0 first unconverged value (error) -302.035 (2.29575846e-06)
158330 EPS nconv=0 first unconverged value (error) -302.035 (2.36925568e-06)
158331 EPS nconv=0 first unconverged value (error) -302.035 (2.54678646e-06)
158332 EPS nconv=0 first unconverged value (error) -302.035 (2.12232207e-06)
158333 EPS nconv=0 first unconverged value (error) -302.035 (1.94083639e-06)
158334 EPS nconv=0 first unconverged value (error) -302.035 (1.93720694e-06)
158335 EPS nconv=0 first unconverged value (error) -302.035 (1.93720694e-06)
158336 EPS nconv=0 first unconverged value (error) -302.035 (1.90303346e-06)
158337 EPS nconv=0 first unconverged value (error) -302.035 (1.86547703e-06)
158338 EPS nconv=0 first unconverged value (error) -302.035 (1.84119909e-06)
158339 EPS nconv=0 first unconverged value (error) -302.035 (1.83240519e-06)
158340 EPS nconv=0 first unconverged value (error) -302.035 (1.82127864e-06)
158341 EPS nconv=0 first unconverged value (error) -302.035 (1.82127864e-06)
158342 EPS nconv=0 first unconverged value (error) -302.035 (2.19396715e-06)
158343 EPS nconv=0 first unconverged value (error) -302.035 (2.11686394e-06)
158344 EPS nconv=0 first unconverged value (error) -302.035 (2.05057562e-06)
158345 EPS nconv=0 first unconverged value (error) -302.035 (2.02871082e-06)
158346 EPS nconv=0 first unconverged value (error) -302.035 (2.01692684e-06)
158347 EPS nconv=0 first unconverged value (error) -302.035 (2.01692684e-06)
158348 EPS nconv=0 first unconverged value (error) -302.035 (2.39589901e-06)
158349 EPS nconv=0 first unconverged value (error) -302.035 (2.25207013e-06)
158350 EPS nconv=0 first unconverged value (error) -302.035 (2.13451759e-06)
158351 EPS nconv=0 first unconverged value (error) -302.035 (2.01918938e-06)
158352 EPS nconv=0 first unconverged value (error) -302.035 (1.96671176e-06)
158353 EPS nconv=0 first unconverged value (error) -302.035 (1.96671176e-06)
158354 EPS nconv=0 first unconverged value (error) -302.035 (2.04131334e-06)
158355 EPS nconv=0 first unconverged value (error) -302.035 (2.12613906e-06)
158356 EPS nconv=0 first unconverged value (error) -302.035 (1.94844098e-06)
158357 EPS nconv=0 first unconverged value (error) -302.035 (1.87232176e-06)
158358 EPS nconv=0 first unconverged value (error) -302.035 (1.86939114e-06)
158359 EPS nconv=0 first unconverged value (error) -302.035 (1.86939114e-06)
158360 EPS nconv=0 first unconverged value (error) -302.035 (2.33163092e-06)
158361 EPS nconv=0 first unconverged value (error) -302.035 (2.15287794e-06)
158362 EPS nconv=0 first unconverged value (error) -302.035 (2.07243814e-06)
158363 EPS nconv=0 first unconverged value (error) -302.035 (2.03976889e-06)
158364 EPS nconv=0 first unconverged value (error) -302.035 (1.96356165e-06)
158365 EPS nconv=0 first unconverged value (error) -302.035 (1.96356165e-06)
158366 EPS nconv=0 first unconverged value (error) -302.035 (1.96338530e-06)
158367 EPS nconv=0 first unconverged value (error) -302.035 (2.13827839e-06)
158368 EPS nconv=0 first unconverged value (error) -302.035 (1.94589654e-06)
158369 EPS nconv=0 first unconverged value (error) -302.035 (1.84235895e-06)
158370 EPS nconv=0 first unconverged value (error) -302.035 (1.82548965e-06)
158371 EPS nconv=0 first unconverged value (error) -302.035 (1.82548965e-06)
158372 EPS nconv=0 first unconverged value (error) -302.035 (2.15806544e-06)
158373 EPS nconv=0 first unconverged value (error) -302.035 (2.00398275e-06)
158374 EPS nconv=0 first unconverged value (error) -302.035 (1.96795269e-06)
158375 EPS nconv=0 first unconverged value (error) -302.035 (1.95375380e-06)
158376 EPS nconv=0 first unconverged value (error) -302.035 (1.92875270e-06)
158377 EPS nconv=0 first unconverged value (error) -302.035 (1.92875270e-06)
158378 EPS nconv=0 first unconverged value (error) -302.035 (2.41592508e-06)
158379 EPS nconv=0 first unconverged value (error) -302.035 (2.47649058e-06)
158380 EPS nconv=0 first unconverged value (error) -302.035 (2.21150564e-06)
158381 EPS nconv=0 first unconverged value (error) -302.035 (2.04354894e-06)
158382 EPS nconv=0 first unconverged value (error) -302.035 (2.01118487e-06)
158383 EPS nconv=0 first unconverged value (error) -302.035 (2.01118487e-06)
158384 EPS nconv=0 first unconverged value (error) -302.035 (2.05740917e-06)
158385 EPS nconv=0 first unconverged value (error) -302.035 (2.10750643e-06)
158386 EPS nconv=0 first unconverged value (error) -302.035 (1.98431677e-06)
158387 EPS nconv=0 first unconverged value (error) -302.035 (1.89689314e-06)
158388 EPS nconv=0 first unconverged value (error) -302.035 (1.86923159e-06)
158389 EPS nconv=0 first unconverged value (error) -302.035 (1.86923159e-06)
158390 EPS nconv=0 first unconverged value (error) -302.035 (2.26807193e-06)
158391 EPS nconv=0 first unconverged value (error) -302.035 (2.13375754e-06)
158392 EPS nconv=0 first unconverged value (error) -302.035 (2.08384323e-06)
158393 EPS nconv=0 first unconverged value (error) -302.035 (2.02429848e-06)
158394 EPS nconv=0 first unconverged value (error) -302.035 (1.97748990e-06)
158395 EPS nconv=0 first unconverged value (error) -302.035 (1.97748990e-06)
158396 EPS nconv=0 first unconverged value (error) -302.035 (2.83646342e-06)
158397 EPS nconv=0 first unconverged value (error) -302.035 (2.76754864e-06)
158398 EPS nconv=0 first unconverged value (error) -302.035 (2.54204419e-06)
158399 EPS nconv=0 first unconverged value (error) -302.035 (2.28960724e-06)
158400 EPS nconv=0 first unconverged value (error) -302.035 (2.26032315e-06)
158401 EPS nconv=0 first unconverged value (error) -302.035 (2.26032315e-06)
158402 EPS nconv=0 first unconverged value (error) -302.035 (3.31502438e-06)
158403 EPS nconv=0 first unconverged value (error) -302.035 (2.80258796e-06)
158404 EPS nconv=0 first unconverged value (error) -302.035 (2.52848545e-06)
158405 EPS nconv=0 first unconverged value (error) -302.035 (2.50371763e-06)
158406 EPS nconv=0 first unconverged value (error) -302.035 (2.39927654e-06)
158407 EPS nconv=0 first unconverged value (error) -302.035 (2.39927654e-06)
158408 EPS nconv=0 first unconverged value (error) -302.035 (2.37297752e-06)
158409 EPS nconv=0 first unconverged value (error) -302.035 (2.86919819e-06)
158410 EPS nconv=0 first unconverged value (error) -302.035 (2.14048511e-06)
158411 EPS nconv=0 first unconverged value (error) -302.035 (2.00518673e-06)
158412 EPS nconv=0 first unconverged value (error) -302.035 (1.92065806e-06)
158413 EPS nconv=0 first unconverged value (error) -302.035 (1.92065806e-06)
158414 EPS nconv=0 first unconverged value (error) -302.035 (1.84399854e-06)
158415 EPS nconv=0 first unconverged value (error) -302.035 (1.81590718e-06)
158416 EPS nconv=0 first unconverged value (error) -302.035 (1.81737819e-06)
158417 EPS nconv=0 first unconverged value (error) -302.035 (1.80358895e-06)
158418 EPS nconv=0 first unconverged value (error) -302.035 (1.79955032e-06)
158419 EPS nconv=0 first unconverged value (error) -302.035 (1.79955032e-06)
158420 EPS nconv=0 first unconverged value (error) -302.035 (2.00864810e-06)
158421 EPS nconv=0 first unconverged value (error) -302.035 (1.95988016e-06)
158422 EPS nconv=0 first unconverged value (error) -302.035 (1.93710196e-06)
158423 EPS nconv=0 first unconverged value (error) -302.035 (1.91302293e-06)
158424 EPS nconv=0 first unconverged value (error) -302.035 (1.89602256e-06)
158425 EPS nconv=0 first unconverged value (error) -302.035 (1.89602256e-06)
158426 EPS nconv=0 first unconverged value (error) -302.035 (2.26287542e-06)
158427 EPS nconv=0 first unconverged value (error) -302.035 (2.12027365e-06)
158428 EPS nconv=0 first unconverged value (error) -302.035 (2.01382037e-06)
158429 EPS nconv=0 first unconverged value (error) -302.035 (2.00794832e-06)
158430 EPS nconv=0 first unconverged value (error) -302.035 (1.96957359e-06)
158431 EPS nconv=0 first unconverged value (error) -302.035 (1.96957359e-06)
158432 EPS nconv=0 first unconverged value (error) -302.035 (2.12995034e-06)
158433 EPS nconv=0 first unconverged value (error) -302.035 (2.21465022e-06)
158434 EPS nconv=0 first unconverged value (error) -302.035 (2.02725533e-06)
158435 EPS nconv=0 first unconverged value (error) -302.035 (1.94721057e-06)
158436 EPS nconv=0 first unconverged value (error) -302.035 (1.92352214e-06)
158437 EPS nconv=0 first unconverged value (error) -302.035 (1.92352214e-06)
158438 EPS nconv=0 first unconverged value (error) -302.035 (2.94753885e-06)
158439 EPS nconv=0 first unconverged value (error) -302.035 (2.52720565e-06)
158440 EPS nconv=0 first unconverged value (error) -302.035 (2.41930509e-06)
158441 EPS nconv=0 first unconverged value (error) -302.035 (2.31035007e-06)
158442 EPS nconv=0 first unconverged value (error) -302.035 (2.19545276e-06)
158443 EPS nconv=0 first unconverged value (error) -302.035 (2.19545276e-06)
158444 EPS nconv=0 first unconverged value (error) -302.035 (2.19436916e-06)
158445 EPS nconv=0 first unconverged value (error) -302.035 (2.50042263e-06)
158446 EPS nconv=0 first unconverged value (error) -302.035 (2.06391804e-06)
158447 EPS nconv=0 first unconverged value (error) -302.035 (1.98989473e-06)
158448 EPS nconv=0 first unconverged value (error) -302.035 (1.91362483e-06)
158449 EPS nconv=0 first unconverged value (error) -302.035 (1.91362483e-06)
158450 EPS nconv=0 first unconverged value (error) -302.035 (2.45122970e-06)
158451 EPS nconv=0 first unconverged value (error) -302.035 (2.23325454e-06)
158452 EPS nconv=0 first unconverged value (error) -302.035 (2.13803220e-06)
158453 EPS nconv=0 first unconverged value (error) -302.035 (2.10711086e-06)
158454 EPS nconv=0 first unconverged value (error) -302.035 (2.05325545e-06)
158455 EPS nconv=0 first unconverged value (error) -302.035 (2.05325545e-06)
158456 EPS nconv=0 first unconverged value (error) -302.035 (2.35022896e-06)
158457 EPS nconv=0 first unconverged value (error) -302.035 (2.64962990e-06)
158458 EPS nconv=0 first unconverged value (error) -302.035 (2.40175425e-06)
158459 EPS nconv=0 first unconverged value (error) -302.035 (1.97672370e-06)
158460 EPS nconv=0 first unconverged value (error) -302.035 (1.95323343e-06)
158461 EPS nconv=0 first unconverged value (error) -302.035 (1.95323343e-06)
158462 EPS nconv=0 first unconverged value (error) -302.035 (2.75381413e-06)
158463 EPS nconv=0 first unconverged value (error) -302.035 (2.49902043e-06)
158464 EPS nconv=0 first unconverged value (error) -302.035 (2.50134753e-06)
158465 EPS nconv=0 first unconverged value (error) -302.035 (2.38782623e-06)
158466 EPS nconv=0 first unconverged value (error) -302.035 (2.33785856e-06)
158467 EPS nconv=0 first unconverged value (error) -302.035 (2.33785856e-06)
158468 EPS nconv=0 first unconverged value (error) -302.035 (2.77119253e-06)
158469 EPS nconv=0 first unconverged value (error) -302.035 (2.46220426e-06)
158470 EPS nconv=0 first unconverged value (error) -302.035 (2.13639683e-06)
158471 EPS nconv=0 first unconverged value (error) -302.035 (2.12251086e-06)
158472 EPS nconv=0 first unconverged value (error) -302.035 (2.10528506e-06)
158473 EPS nconv=0 first unconverged value (error) -302.035 (2.10528506e-06)
158474 EPS nconv=0 first unconverged value (error) -302.035 (2.61187770e-06)
158475 EPS nconv=0 first unconverged value (error) -302.035 (2.60880154e-06)
158476 EPS nconv=0 first unconverged value (error) -302.035 (2.25178498e-06)
158477 EPS nconv=0 first unconverged value (error) -302.035 (2.11444167e-06)
158478 EPS nconv=0 first unconverged value (error) -302.035 (2.04527735e-06)
158479 EPS nconv=0 first unconverged value (error) -302.035 (2.04527735e-06)
158480 EPS nconv=0 first unconverged value (error) -302.035 (2.44269720e-06)
158481 EPS nconv=0 first unconverged value (error) -302.035 (2.53432852e-06)
158482 EPS nconv=0 first unconverged value (error) -302.035 (2.20604159e-06)
158483 EPS nconv=0 first unconverged value (error) -302.035 (2.06744213e-06)
158484 EPS nconv=0 first unconverged value (error) -302.035 (1.98592948e-06)
158485 EPS nconv=0 first unconverged value (error) -302.035 (1.98592948e-06)
158486 EPS nconv=0 first unconverged value (error) -302.035 (2.22908528e-06)
158487 EPS nconv=0 first unconverged value (error) -302.035 (2.22609374e-06)
158488 EPS nconv=0 first unconverged value (error) -302.035 (2.12308737e-06)
158489 EPS nconv=0 first unconverged value (error) -302.035 (2.04651053e-06)
158490 EPS nconv=0 first unconverged value (error) -302.035 (2.02778167e-06)
158491 EPS nconv=0 first unconverged value (error) -302.035 (2.02778167e-06)
158492 EPS nconv=0 first unconverged value (error) -302.035 (2.59372520e-06)
158493 EPS nconv=0 first unconverged value (error) -302.035 (2.26024644e-06)
158494 EPS nconv=0 first unconverged value (error) -302.035 (2.15203736e-06)
158495 EPS nconv=0 first unconverged value (error) -302.035 (2.09208377e-06)
158496 EPS nconv=0 first unconverged value (error) -302.035 (2.04744476e-06)
158497 EPS nconv=0 first unconverged value (error) -302.035 (2.04744476e-06)
158498 EPS nconv=0 first unconverged value (error) -302.035 (2.01357155e-06)
158499 EPS nconv=0 first unconverged value (error) -302.035 (2.26555868e-06)
158500 EPS nconv=0 first unconverged value (error) -302.035 (1.95038577e-06)
158501 EPS nconv=0 first unconverged value (error) -302.035 (1.90073160e-06)
158502 EPS nconv=0 first unconverged value (error) -302.035 (1.85496065e-06)
158503 EPS nconv=0 first unconverged value (error) -302.035 (1.85496065e-06)
158504 EPS nconv=0 first unconverged value (error) -302.035 (2.49444935e-06)
158505 EPS nconv=0 first unconverged value (error) -302.035 (2.33358842e-06)
158506 EPS nconv=0 first unconverged value (error) -302.035 (2.19832383e-06)
158507 EPS nconv=0 first unconverged value (error) -302.035 (2.20281878e-06)
158508 EPS nconv=0 first unconverged value (error) -302.035 (2.10508275e-06)
158509 EPS nconv=0 first unconverged value (error) -302.035 (2.10508275e-06)
158510 EPS nconv=0 first unconverged value (error) -302.035 (2.59018037e-06)
158511 EPS nconv=0 first unconverged value (error) -302.035 (2.70454745e-06)
158512 EPS nconv=0 first unconverged value (error) -302.035 (2.56820086e-06)
158513 EPS nconv=0 first unconverged value (error) -302.035 (2.21749937e-06)
158514 EPS nconv=0 first unconverged value (error) -302.035 (2.15368321e-06)
158515 EPS nconv=0 first unconverged value (error) -302.035 (2.15368321e-06)
158516 EPS nconv=0 first unconverged value (error) -302.035 (2.80650232e-06)
158517 EPS nconv=0 first unconverged value (error) -302.035 (2.42024715e-06)
158518 EPS nconv=0 first unconverged value (error) -302.035 (2.26975126e-06)
158519 EPS nconv=0 first unconverged value (error) -302.035 (2.21758279e-06)
158520 EPS nconv=0 first unconverged value (error) -302.035 (2.12843912e-06)
158521 EPS nconv=0 first unconverged value (error) -302.035 (2.12843912e-06)
158522 EPS nconv=0 first unconverged value (error) -302.035 (2.15302813e-06)
158523 EPS nconv=0 first unconverged value (error) -302.035 (2.45541025e-06)
158524 EPS nconv=0 first unconverged value (error) -302.035 (2.04194022e-06)
158525 EPS nconv=0 first unconverged value (error) -302.035 (1.93634083e-06)
158526 EPS nconv=0 first unconverged value (error) -302.035 (1.87264817e-06)
158527 EPS nconv=0 first unconverged value (error) -302.035 (1.87264817e-06)
158528 EPS nconv=0 first unconverged value (error) -302.035 (1.81713686e-06)
158529 EPS nconv=0 first unconverged value (error) -302.035 (1.82132590e-06)
158530 EPS nconv=0 first unconverged value (error) -302.035 (1.80949514e-06)
158531 EPS nconv=0 first unconverged value (error) -302.035 (1.80423242e-06)
158532 EPS nconv=0 first unconverged value (error) -302.035 (1.79967565e-06)
158533 EPS nconv=0 first unconverged value (error) -302.035 (1.79967565e-06)
158534 EPS nconv=0 first unconverged value (error) -302.035 (1.93021624e-06)
158535 EPS nconv=0 first unconverged value (error) -302.035 (1.89513495e-06)
158536 EPS nconv=0 first unconverged value (error) -302.035 (1.88187356e-06)
158537 EPS nconv=0 first unconverged value (error) -302.035 (1.87065173e-06)
158538 EPS nconv=0 first unconverged value (error) -302.035 (1.85491832e-06)
158539 EPS nconv=0 first unconverged value (error) -302.035 (1.85491832e-06)
158540 EPS nconv=0 first unconverged value (error) -302.035 (2.15045855e-06)
158541 EPS nconv=0 first unconverged value (error) -302.035 (2.03233822e-06)
158542 EPS nconv=0 first unconverged value (error) -302.035 (1.96891322e-06)
158543 EPS nconv=0 first unconverged value (error) -302.035 (1.94785767e-06)
158544 EPS nconv=0 first unconverged value (error) -302.035 (1.92819342e-06)
158545 EPS nconv=0 first unconverged value (error) -302.035 (1.92819342e-06)
158546 EPS nconv=0 first unconverged value (error) -302.035 (1.92116971e-06)
158547 EPS nconv=0 first unconverged value (error) -302.035 (2.01185448e-06)
158548 EPS nconv=0 first unconverged value (error) -302.035 (1.88805974e-06)
158549 EPS nconv=0 first unconverged value (error) -302.035 (1.85736977e-06)
158550 EPS nconv=0 first unconverged value (error) -302.035 (1.81974294e-06)
158551 EPS nconv=0 first unconverged value (error) -302.035 (1.81974294e-06)
158552 EPS nconv=0 first unconverged value (error) -302.035 (2.78194062e-06)
158553 EPS nconv=0 first unconverged value (error) -302.035 (2.55358034e-06)
158554 EPS nconv=0 first unconverged value (error) -302.035 (2.41091039e-06)
158555 EPS nconv=0 first unconverged value (error) -302.035 (2.37275445e-06)
158556 EPS nconv=0 first unconverged value (error) -302.035 (2.26966021e-06)
158557 EPS nconv=0 first unconverged value (error) -302.035 (2.26966021e-06)
158558 EPS nconv=0 first unconverged value (error) -302.035 (2.26083461e-06)
158559 EPS nconv=0 first unconverged value (error) -302.035 (2.39440784e-06)
158560 EPS nconv=0 first unconverged value (error) -302.035 (2.20015783e-06)
158561 EPS nconv=0 first unconverged value (error) -302.035 (1.88112010e-06)
158562 EPS nconv=0 first unconverged value (error) -302.035 (1.88898777e-06)
158563 EPS nconv=0 first unconverged value (error) -302.035 (1.88898777e-06)
158564 EPS nconv=0 first unconverged value (error) -302.035 (1.83633312e-06)
158565 EPS nconv=0 first unconverged value (error) -302.035 (1.81451392e-06)
158566 EPS nconv=0 first unconverged value (error) -302.035 (1.80394189e-06)
158567 EPS nconv=0 first unconverged value (error) -302.035 (1.79992040e-06)
158568 EPS nconv=0 first unconverged value (error) -302.035 (1.79854383e-06)
158569 EPS nconv=0 first unconverged value (error) -302.035 (1.79854383e-06)
158570 EPS nconv=0 first unconverged value (error) -302.035 (2.55658642e-06)
158571 EPS nconv=0 first unconverged value (error) -302.035 (2.27445711e-06)
158572 EPS nconv=0 first unconverged value (error) -302.035 (2.19523118e-06)
158573 EPS nconv=0 first unconverged value (error) -302.035 (2.09265264e-06)
158574 EPS nconv=0 first unconverged value (error) -302.035 (2.06700242e-06)
158575 EPS nconv=0 first unconverged value (error) -302.035 (2.06700242e-06)
158576 EPS nconv=0 first unconverged value (error) -302.035 (2.08988541e-06)
158577 EPS nconv=0 first unconverged value (error) -302.035 (2.38069625e-06)
158578 EPS nconv=0 first unconverged value (error) -302.035 (2.03839889e-06)
158579 EPS nconv=0 first unconverged value (error) -302.035 (1.90276604e-06)
158580 EPS nconv=0 first unconverged value (error) -302.035 (1.81785582e-06)
158581 EPS nconv=0 first unconverged value (error) -302.035 (1.81785582e-06)
158582 EPS nconv=0 first unconverged value (error) -302.035 (1.92858308e-06)
158583 EPS nconv=0 first unconverged value (error) -302.035 (1.93379771e-06)
158584 EPS nconv=0 first unconverged value (error) -302.035 (1.88176139e-06)
158585 EPS nconv=0 first unconverged value (error) -302.035 (1.87527589e-06)
158586 EPS nconv=0 first unconverged value (error) -302.035 (1.86849345e-06)
158587 EPS nconv=0 first unconverged value (error) -302.035 (1.86849345e-06)
158588 EPS nconv=0 first unconverged value (error) -302.035 (2.69308538e-06)
158589 EPS nconv=0 first unconverged value (error) -302.035 (2.39393473e-06)
158590 EPS nconv=0 first unconverged value (error) -302.035 (2.19182062e-06)
158591 EPS nconv=0 first unconverged value (error) -302.035 (2.18993719e-06)
158592 EPS nconv=0 first unconverged value (error) -302.035 (2.14134200e-06)
158593 EPS nconv=0 first unconverged value (error) -302.035 (2.14134200e-06)
158594 EPS nconv=0 first unconverged value (error) -302.035 (2.51646111e-06)
158595 EPS nconv=0 first unconverged value (error) -302.035 (2.85912590e-06)
158596 EPS nconv=0 first unconverged value (error) -302.035 (2.42825960e-06)
158597 EPS nconv=0 first unconverged value (error) -302.035 (2.06402164e-06)
158598 EPS nconv=0 first unconverged value (error) -302.035 (2.00984277e-06)
158599 EPS nconv=0 first unconverged value (error) -302.035 (2.00984277e-06)
158600 EPS nconv=0 first unconverged value (error) -302.035 (2.12508556e-06)
158601 EPS nconv=0 first unconverged value (error) -302.035 (2.13596876e-06)
158602 EPS nconv=0 first unconverged value (error) -302.035 (2.12252506e-06)
158603 EPS nconv=0 first unconverged value (error) -302.035 (1.90008438e-06)
158604 EPS nconv=0 first unconverged value (error) -302.035 (1.85717342e-06)
158605 EPS nconv=0 first unconverged value (error) -302.035 (1.85717342e-06)
158606 EPS nconv=0 first unconverged value (error) -302.035 (2.38611743e-06)
158607 EPS nconv=0 first unconverged value (error) -302.035 (2.16314467e-06)
158608 EPS nconv=0 first unconverged value (error) -302.035 (2.09643863e-06)
158609 EPS nconv=0 first unconverged value (error) -302.035 (2.02132129e-06)
158610 EPS nconv=0 first unconverged value (error) -302.035 (1.98598057e-06)
158611 EPS nconv=0 first unconverged value (error) -302.035 (1.98598057e-06)
158612 EPS nconv=0 first unconverged value (error) -302.035 (2.48984286e-06)
158613 EPS nconv=0 first unconverged value (error) -302.035 (2.57762580e-06)
158614 EPS nconv=0 first unconverged value (error) -302.035 (2.29133115e-06)
158615 EPS nconv=0 first unconverged value (error) -302.035 (2.08445285e-06)
158616 EPS nconv=0 first unconverged value (error) -302.035 (2.07030524e-06)
158617 EPS nconv=0 first unconverged value (error) -302.035 (2.07030524e-06)
158618 EPS nconv=0 first unconverged value (error) -302.035 (2.33997419e-06)
158619 EPS nconv=0 first unconverged value (error) -302.035 (2.20759367e-06)
158620 EPS nconv=0 first unconverged value (error) -302.035 (2.05084936e-06)
158621 EPS nconv=0 first unconverged value (error) -302.035 (1.99131587e-06)
158622 EPS nconv=0 first unconverged value (error) -302.035 (1.97465129e-06)
158623 EPS nconv=0 first unconverged value (error) -302.035 (1.97465129e-06)
158624 EPS nconv=0 first unconverged value (error) -302.035 (1.96673513e-06)
158625 EPS nconv=0 first unconverged value (error) -302.035 (2.07178409e-06)
158626 EPS nconv=0 first unconverged value (error) -302.035 (1.86953474e-06)
158627 EPS nconv=0 first unconverged value (error) -302.035 (1.83561722e-06)
158628 EPS nconv=0 first unconverged value (error) -302.035 (1.81595343e-06)
158629 EPS nconv=0 first unconverged value (error) -302.035 (1.81595343e-06)
158630 EPS nconv=0 first unconverged value (error) -302.035 (1.95298285e-06)
158631 EPS nconv=0 first unconverged value (error) -302.035 (1.87154664e-06)
158632 EPS nconv=0 first unconverged value (error) -302.035 (1.83769225e-06)
158633 EPS nconv=0 first unconverged value (error) -302.035 (1.83142467e-06)
158634 EPS nconv=0 first unconverged value (error) -302.035 (1.82770100e-06)
158635 EPS nconv=0 first unconverged value (error) -302.035 (1.82770100e-06)
158636 EPS nconv=0 first unconverged value (error) -302.035 (2.74314768e-06)
158637 EPS nconv=0 first unconverged value (error) -302.035 (2.59826665e-06)
158638 EPS nconv=0 first unconverged value (error) -302.035 (2.39980811e-06)
158639 EPS nconv=0 first unconverged value (error) -302.035 (2.23266938e-06)
158640 EPS nconv=0 first unconverged value (error) -302.035 (2.21191929e-06)
158641 EPS nconv=0 first unconverged value (error) -302.035 (2.21191929e-06)
158642 EPS nconv=0 first unconverged value (error) -302.035 (2.48184583e-06)
158643 EPS nconv=0 first unconverged value (error) -302.035 (2.68310822e-06)
158644 EPS nconv=0 first unconverged value (error) -302.035 (2.39158227e-06)
158645 EPS nconv=0 first unconverged value (error) -302.035 (1.99681937e-06)
158646 EPS nconv=0 first unconverged value (error) -302.035 (1.95167656e-06)
158647 EPS nconv=0 first unconverged value (error) -302.035 (1.95167656e-06)
158648 EPS nconv=0 first unconverged value (error) -302.035 (2.41194431e-06)
158649 EPS nconv=0 first unconverged value (error) -302.035 (2.18515809e-06)
158650 EPS nconv=0 first unconverged value (error) -302.035 (2.11654114e-06)
158651 EPS nconv=0 first unconverged value (error) -302.035 (2.05995343e-06)
158652 EPS nconv=0 first unconverged value (error) -302.035 (2.02676330e-06)
158653 EPS nconv=0 first unconverged value (error) -302.035 (2.02676330e-06)
158654 EPS nconv=0 first unconverged value (error) -302.035 (2.01344136e-06)
158655 EPS nconv=0 first unconverged value (error) -302.035 (2.12364776e-06)
158656 EPS nconv=0 first unconverged value (error) -302.035 (1.90283991e-06)
158657 EPS nconv=0 first unconverged value (error) -302.035 (1.86114221e-06)
158658 EPS nconv=0 first unconverged value (error) -302.035 (1.83206643e-06)
158659 EPS nconv=0 first unconverged value (error) -302.035 (1.83206643e-06)
158660 EPS nconv=0 first unconverged value (error) -302.035 (2.11179523e-06)
158661 EPS nconv=0 first unconverged value (error) -302.035 (1.99283401e-06)
158662 EPS nconv=0 first unconverged value (error) -302.035 (1.94171634e-06)
158663 EPS nconv=0 first unconverged value (error) -302.035 (1.91504785e-06)
158664 EPS nconv=0 first unconverged value (error) -302.035 (1.89329278e-06)
158665 EPS nconv=0 first unconverged value (error) -302.035 (1.89329278e-06)
158666 EPS nconv=0 first unconverged value (error) -302.035 (3.14780736e-06)
158667 EPS nconv=0 first unconverged value (error) -302.035 (3.26109861e-06)
158668 EPS nconv=0 first unconverged value (error) -302.035 (3.09766888e-06)
158669 EPS nconv=0 first unconverged value (error) -302.035 (2.70042477e-06)
158670 EPS nconv=0 first unconverged value (error) -302.035 (2.66954611e-06)
158671 EPS nconv=0 first unconverged value (error) -302.035 (2.66954611e-06)
158672 EPS nconv=0 first unconverged value (error) -302.035 (2.97250470e-06)
158673 EPS nconv=0 first unconverged value (error) -302.035 (2.49027981e-06)
158674 EPS nconv=0 first unconverged value (error) -302.035 (2.23766025e-06)
158675 EPS nconv=0 first unconverged value (error) -302.035 (2.14994058e-06)
158676 EPS nconv=0 first unconverged value (error) -302.035 (2.10181772e-06)
158677 EPS nconv=0 first unconverged value (error) -302.035 (2.10181772e-06)
158678 EPS nconv=0 first unconverged value (error) -302.035 (2.10707258e-06)
158679 EPS nconv=0 first unconverged value (error) -302.035 (2.15786852e-06)
158680 EPS nconv=0 first unconverged value (error) -302.035 (1.98867460e-06)
158681 EPS nconv=0 first unconverged value (error) -302.035 (1.89260692e-06)
158682 EPS nconv=0 first unconverged value (error) -302.035 (1.83105316e-06)
158683 EPS nconv=0 first unconverged value (error) -302.035 (1.83105316e-06)
158684 EPS nconv=0 first unconverged value (error) -302.035 (2.42623515e-06)
158685 EPS nconv=0 first unconverged value (error) -302.035 (2.30081893e-06)
158686 EPS nconv=0 first unconverged value (error) -302.035 (2.23273758e-06)
158687 EPS nconv=0 first unconverged value (error) -302.035 (2.17665936e-06)
158688 EPS nconv=0 first unconverged value (error) -302.035 (2.12257989e-06)
158689 EPS nconv=0 first unconverged value (error) -302.035 (2.12257989e-06)
158690 EPS nconv=0 first unconverged value (error) -302.035 (3.59593477e-06)
158691 EPS nconv=0 first unconverged value (error) -302.035 (3.28608887e-06)
158692 EPS nconv=0 first unconverged value (error) -302.035 (2.95803813e-06)
158693 EPS nconv=0 first unconverged value (error) -302.035 (2.94129924e-06)
158694 EPS nconv=0 first unconverged value (error) -302.035 (2.90420757e-06)
158695 EPS nconv=0 first unconverged value (error) -302.035 (2.90420757e-06)
158696 EPS nconv=0 first unconverged value (error) -302.035 (2.90235763e-06)
158697 EPS nconv=0 first unconverged value (error) -302.035 (2.77464899e-06)
158698 EPS nconv=0 first unconverged value (error) -302.035 (2.43389009e-06)
158699 EPS nconv=0 first unconverged value (error) -302.035 (2.07975987e-06)
158700 EPS nconv=0 first unconverged value (error) -302.035 (1.93234868e-06)
158701 EPS nconv=0 first unconverged value (error) -302.035 (1.93234868e-06)
158702 EPS nconv=0 first unconverged value (error) -302.035 (1.82468266e-06)
158703 EPS nconv=0 first unconverged value (error) -302.035 (1.81217379e-06)
158704 EPS nconv=0 first unconverged value (error) -302.035 (1.80458368e-06)
158705 EPS nconv=0 first unconverged value (error) -302.035 (1.79841309e-06)
158706 EPS nconv=0 first unconverged value (error) -302.035 (1.79763192e-06)
158707 EPS nconv=0 first unconverged value (error) -302.035 (1.79763192e-06)
158708 EPS nconv=0 first unconverged value (error) -302.035 (2.03002239e-06)
158709 EPS nconv=0 first unconverged value (error) -302.035 (1.94209945e-06)
158710 EPS nconv=0 first unconverged value (error) -302.035 (1.92598211e-06)
158711 EPS nconv=0 first unconverged value (error) -302.035 (1.90922716e-06)
158712 EPS nconv=0 first unconverged value (error) -302.035 (1.90225351e-06)
158713 EPS nconv=0 first unconverged value (error) -302.035 (1.90225351e-06)
158714 EPS nconv=0 first unconverged value (error) -302.035 (1.99252193e-06)
158715 EPS nconv=0 first unconverged value (error) -302.035 (2.01235120e-06)
158716 EPS nconv=0 first unconverged value (error) -302.035 (1.92723359e-06)
158717 EPS nconv=0 first unconverged value (error) -302.035 (1.84653377e-06)
158718 EPS nconv=0 first unconverged value (error) -302.035 (1.83415086e-06)
158719 EPS nconv=0 first unconverged value (error) -302.035 (1.83415086e-06)
158720 EPS nconv=0 first unconverged value (error) -302.035 (1.82949249e-06)
158721 EPS nconv=0 first unconverged value (error) -302.035 (1.83614424e-06)
158722 EPS nconv=0 first unconverged value (error) -302.035 (1.81352099e-06)
158723 EPS nconv=0 first unconverged value (error) -302.035 (1.80557226e-06)
158724 EPS nconv=0 first unconverged value (error) -302.035 (1.79964393e-06)
158725 EPS nconv=0 first unconverged value (error) -302.035 (1.79964393e-06)
158726 EPS nconv=0 first unconverged value (error) -302.035 (1.80674804e-06)
158727 EPS nconv=0 first unconverged value (error) -302.035 (1.80367350e-06)
158728 EPS nconv=0 first unconverged value (error) -302.035 (1.80163356e-06)
158729 EPS nconv=0 first unconverged value (error) -302.035 (1.80061692e-06)
158730 EPS nconv=0 first unconverged value (error) -302.035 (1.79955054e-06)
158731 EPS nconv=0 first unconverged value (error) -302.035 (1.79955054e-06)
158732 EPS nconv=0 first unconverged value (error) -302.035 (3.64765978e-06)
158733 EPS nconv=0 first unconverged value (error) -302.035 (3.54266482e-06)
158734 EPS nconv=0 first unconverged value (error) -302.035 (3.38042442e-06)
158735 EPS nconv=0 first unconverged value (error) -302.035 (3.15683701e-06)
158736 EPS nconv=0 first unconverged value (error) -302.035 (3.13241897e-06)
158737 EPS nconv=0 first unconverged value (error) -302.035 (3.13241897e-06)
158738 EPS nconv=0 first unconverged value (error) -302.035 (3.14705498e-06)
158739 EPS nconv=0 first unconverged value (error) -302.035 (2.65294287e-06)
158740 EPS nconv=0 first unconverged value (error) -302.035 (2.56265029e-06)
158741 EPS nconv=0 first unconverged value (error) -302.035 (2.08668533e-06)
158742 EPS nconv=0 first unconverged value (error) -302.035 (1.91301853e-06)
158743 EPS nconv=0 first unconverged value (error) -302.035 (1.91301853e-06)
158744 EPS nconv=0 first unconverged value (error) -302.035 (1.89312660e-06)
158745 EPS nconv=0 first unconverged value (error) -302.035 (1.90624894e-06)
158746 EPS nconv=0 first unconverged value (error) -302.035 (1.84824031e-06)
158747 EPS nconv=0 first unconverged value (error) -302.035 (1.82337469e-06)
158748 EPS nconv=0 first unconverged value (error) -302.035 (1.81095944e-06)
158749 EPS nconv=0 first unconverged value (error) -302.035 (1.81095944e-06)
158750 EPS nconv=0 first unconverged value (error) -302.035 (2.40602064e-06)
158751 EPS nconv=0 first unconverged value (error) -302.035 (2.20311565e-06)
158752 EPS nconv=0 first unconverged value (error) -302.035 (2.11763336e-06)
158753 EPS nconv=0 first unconverged value (error) -302.035 (2.06905792e-06)
158754 EPS nconv=0 first unconverged value (error) -302.035 (2.03334813e-06)
158755 EPS nconv=0 first unconverged value (error) -302.035 (2.03334813e-06)
158756 EPS nconv=0 first unconverged value (error) -302.035 (2.05494857e-06)
158757 EPS nconv=0 first unconverged value (error) -302.035 (2.30389858e-06)
158758 EPS nconv=0 first unconverged value (error) -302.035 (2.06714630e-06)
158759 EPS nconv=0 first unconverged value (error) -302.035 (1.86182581e-06)
158760 EPS nconv=0 first unconverged value (error) -302.035 (1.82500779e-06)
158761 EPS nconv=0 first unconverged value (error) -302.035 (1.82500779e-06)
158762 EPS nconv=0 first unconverged value (error) -302.035 (1.80207411e-06)
158763 EPS nconv=0 first unconverged value (error) -302.035 (1.80227593e-06)
158764 EPS nconv=0 first unconverged value (error) -302.035 (1.79611359e-06)
158765 EPS nconv=0 first unconverged value (error) -302.035 (1.79481539e-06)
158766 EPS nconv=0 first unconverged value (error) -302.035 (1.79416135e-06)
158767 EPS nconv=0 first unconverged value (error) -302.035 (1.79416135e-06)
158768 EPS nconv=0 first unconverged value (error) -302.035 (1.79577825e-06)
158769 EPS nconv=0 first unconverged value (error) -302.035 (1.79495818e-06)
158770 EPS nconv=0 first unconverged value (error) -302.035 (1.79465996e-06)
158771 EPS nconv=0 first unconverged value (error) -302.035 (1.79459016e-06)
158772 EPS nconv=0 first unconverged value (error) -302.035 (1.79448929e-06)
158773 EPS nconv=0 first unconverged value (error) -302.035 (1.79448929e-06)
158774 EPS nconv=0 first unconverged value (error) -302.035 (2.75936954e-06)
158775 EPS nconv=0 first unconverged value (error) -302.035 (2.57837343e-06)
158776 EPS nconv=0 first unconverged value (error) -302.035 (2.45578359e-06)
158777 EPS nconv=0 first unconverged value (error) -302.035 (2.36157148e-06)
158778 EPS nconv=0 first unconverged value (error) -302.035 (2.34377106e-06)
158779 EPS nconv=0 first unconverged value (error) -302.035 (2.34377106e-06)
158780 EPS nconv=0 first unconverged value (error) -302.035 (2.42371213e-06)
158781 EPS nconv=0 first unconverged value (error) -302.035 (2.35198480e-06)
158782 EPS nconv=0 first unconverged value (error) -302.035 (2.13053552e-06)
158783 EPS nconv=0 first unconverged value (error) -302.035 (2.02817691e-06)
158784 EPS nconv=0 first unconverged value (error) -302.035 (1.90692718e-06)
158785 EPS nconv=0 first unconverged value (error) -302.035 (1.90692718e-06)
158786 EPS nconv=0 first unconverged value (error) -302.035 (2.19637967e-06)
158787 EPS nconv=0 first unconverged value (error) -302.035 (2.30975972e-06)
158788 EPS nconv=0 first unconverged value (error) -302.035 (2.11892504e-06)
158789 EPS nconv=0 first unconverged value (error) -302.035 (1.98413634e-06)
158790 EPS nconv=0 first unconverged value (error) -302.035 (1.95923985e-06)
158791 EPS nconv=0 first unconverged value (error) -302.035 (1.95923985e-06)
158792 EPS nconv=0 first unconverged value (error) -302.035 (2.07224320e-06)
158793 EPS nconv=0 first unconverged value (error) -302.035 (2.07619941e-06)
158794 EPS nconv=0 first unconverged value (error) -302.035 (2.05522935e-06)
158795 EPS nconv=0 first unconverged value (error) -302.035 (1.93821823e-06)
158796 EPS nconv=0 first unconverged value (error) -302.035 (1.87593968e-06)
158797 EPS nconv=0 first unconverged value (error) -302.035 (1.87593968e-06)
158798 EPS nconv=0 first unconverged value (error) -302.035 (2.61973500e-06)
158799 EPS nconv=0 first unconverged value (error) -302.035 (2.47310858e-06)
158800 EPS nconv=0 first unconverged value (error) -302.035 (2.44205145e-06)
158801 EPS nconv=0 first unconverged value (error) -302.035 (2.25192816e-06)
158802 EPS nconv=0 first unconverged value (error) -302.035 (2.19047981e-06)
158803 EPS nconv=0 first unconverged value (error) -302.035 (2.19047981e-06)
158804 EPS nconv=0 first unconverged value (error) -302.035 (2.51540130e-06)
158805 EPS nconv=0 first unconverged value (error) -302.035 (2.42998558e-06)
158806 EPS nconv=0 first unconverged value (error) -302.035 (2.11469637e-06)
158807 EPS nconv=0 first unconverged value (error) -302.035 (2.07902196e-06)
158808 EPS nconv=0 first unconverged value (error) -302.035 (2.05120064e-06)
158809 EPS nconv=0 first unconverged value (error) -302.035 (2.05120064e-06)
158810 EPS nconv=0 first unconverged value (error) -302.035 (2.04067118e-06)
158811 EPS nconv=0 first unconverged value (error) -302.035 (2.07809568e-06)
158812 EPS nconv=0 first unconverged value (error) -302.035 (1.95345320e-06)
158813 EPS nconv=0 first unconverged value (error) -302.035 (1.87327744e-06)
158814 EPS nconv=0 first unconverged value (error) -302.035 (1.83798261e-06)
158815 EPS nconv=0 first unconverged value (error) -302.035 (1.83798261e-06)
158816 EPS nconv=0 first unconverged value (error) -302.035 (2.78720389e-06)
158817 EPS nconv=0 first unconverged value (error) -302.035 (2.49265904e-06)
158818 EPS nconv=0 first unconverged value (error) -302.035 (2.39373691e-06)
158819 EPS nconv=0 first unconverged value (error) -302.035 (2.29590766e-06)
158820 EPS nconv=0 first unconverged value (error) -302.035 (2.21683788e-06)
158821 EPS nconv=0 first unconverged value (error) -302.035 (2.21683788e-06)
158822 EPS nconv=0 first unconverged value (error) -302.035 (2.95078922e-06)
158823 EPS nconv=0 first unconverged value (error) -302.035 (2.89596006e-06)
158824 EPS nconv=0 first unconverged value (error) -302.035 (2.47487807e-06)
158825 EPS nconv=0 first unconverged value (error) -302.035 (2.45361762e-06)
158826 EPS nconv=0 first unconverged value (error) -302.035 (2.35815778e-06)
158827 EPS nconv=0 first unconverged value (error) -302.035 (2.35815778e-06)
158828 EPS nconv=0 first unconverged value (error) -302.035 (2.28819641e-06)
158829 EPS nconv=0 first unconverged value (error) -302.035 (2.38838267e-06)
158830 EPS nconv=0 first unconverged value (error) -302.035 (2.14121085e-06)
158831 EPS nconv=0 first unconverged value (error) -302.035 (1.93361153e-06)
158832 EPS nconv=0 first unconverged value (error) -302.035 (1.86095569e-06)
158833 EPS nconv=0 first unconverged value (error) -302.035 (1.86095569e-06)
158834 EPS nconv=0 first unconverged value (error) -302.035 (1.81760750e-06)
158835 EPS nconv=0 first unconverged value (error) -302.035 (1.80843698e-06)
158836 EPS nconv=0 first unconverged value (error) -302.035 (1.80679205e-06)
158837 EPS nconv=0 first unconverged value (error) -302.035 (1.80391492e-06)
158838 EPS nconv=0 first unconverged value (error) -302.035 (1.80147929e-06)
158839 EPS nconv=0 first unconverged value (error) -302.035 (1.80147929e-06)
158840 EPS nconv=0 first unconverged value (error) -302.035 (1.87060457e-06)
158841 EPS nconv=0 first unconverged value (error) -302.035 (1.86486314e-06)
158842 EPS nconv=0 first unconverged value (error) -302.035 (1.84636927e-06)
158843 EPS nconv=0 first unconverged value (error) -302.035 (1.84140508e-06)
158844 EPS nconv=0 first unconverged value (error) -302.035 (1.83575992e-06)
158845 EPS nconv=0 first unconverged value (error) -302.035 (1.83575992e-06)
158846 EPS nconv=0 first unconverged value (error) -302.035 (2.04038144e-06)
158847 EPS nconv=0 first unconverged value (error) -302.035 (2.01029823e-06)
158848 EPS nconv=0 first unconverged value (error) -302.035 (1.98067361e-06)
158849 EPS nconv=0 first unconverged value (error) -302.035 (1.89907143e-06)
158850 EPS nconv=0 first unconverged value (error) -302.035 (1.88336673e-06)
158851 EPS nconv=0 first unconverged value (error) -302.035 (1.88336673e-06)
158852 EPS nconv=0 first unconverged value (error) -302.035 (1.98927898e-06)
158853 EPS nconv=0 first unconverged value (error) -302.035 (1.96020125e-06)
158854 EPS nconv=0 first unconverged value (error) -302.035 (1.91160738e-06)
158855 EPS nconv=0 first unconverged value (error) -302.035 (1.89199207e-06)
158856 EPS nconv=0 first unconverged value (error) -302.035 (1.87863493e-06)
158857 EPS nconv=0 first unconverged value (error) -302.035 (1.87863493e-06)
158858 EPS nconv=0 first unconverged value (error) -302.035 (1.95889069e-06)
158859 EPS nconv=0 first unconverged value (error) -302.035 (1.90208075e-06)
158860 EPS nconv=0 first unconverged value (error) -302.035 (1.84535371e-06)
158861 EPS nconv=0 first unconverged value (error) -302.035 (1.84469371e-06)
158862 EPS nconv=0 first unconverged value (error) -302.035 (1.83430446e-06)
158863 EPS nconv=0 first unconverged value (error) -302.035 (1.83430446e-06)
158864 EPS nconv=0 first unconverged value (error) -302.035 (1.98369220e-06)
158865 EPS nconv=0 first unconverged value (error) -302.035 (1.98542952e-06)
158866 EPS nconv=0 first unconverged value (error) -302.035 (1.90522375e-06)
158867 EPS nconv=0 first unconverged value (error) -302.035 (1.87242815e-06)
158868 EPS nconv=0 first unconverged value (error) -302.035 (1.85738230e-06)
158869 EPS nconv=0 first unconverged value (error) -302.035 (1.85738230e-06)
158870 EPS nconv=0 first unconverged value (error) -302.035 (1.97206095e-06)
158871 EPS nconv=0 first unconverged value (error) -302.035 (1.98826956e-06)
158872 EPS nconv=0 first unconverged value (error) -302.035 (1.92755409e-06)
158873 EPS nconv=0 first unconverged value (error) -302.035 (1.89143016e-06)
158874 EPS nconv=0 first unconverged value (error) -302.035 (1.86436694e-06)
158875 EPS nconv=0 first unconverged value (error) -302.035 (1.86436694e-06)
158876 EPS nconv=0 first unconverged value (error) -302.035 (1.86138945e-06)
158877 EPS nconv=0 first unconverged value (error) -302.035 (1.85957941e-06)
158878 EPS nconv=0 first unconverged value (error) -302.035 (1.83782757e-06)
158879 EPS nconv=0 first unconverged value (error) -302.035 (1.81439837e-06)
158880 EPS nconv=0 first unconverged value (error) -302.035 (1.81139401e-06)
158881 EPS nconv=0 first unconverged value (error) -302.035 (1.81139401e-06)
158882 EPS nconv=0 first unconverged value (error) -302.035 (2.41028723e-06)
158883 EPS nconv=0 first unconverged value (error) -302.035 (2.14658210e-06)
158884 EPS nconv=0 first unconverged value (error) -302.035 (2.07310092e-06)
158885 EPS nconv=0 first unconverged value (error) -302.035 (2.02744053e-06)
158886 EPS nconv=0 first unconverged value (error) -302.035 (1.99039301e-06)
158887 EPS nconv=0 first unconverged value (error) -302.035 (1.99039301e-06)
158888 EPS nconv=0 first unconverged value (error) -302.035 (2.15481955e-06)
158889 EPS nconv=0 first unconverged value (error) -302.035 (2.29199627e-06)
158890 EPS nconv=0 first unconverged value (error) -302.035 (2.03569271e-06)
158891 EPS nconv=0 first unconverged value (error) -302.035 (1.99611934e-06)
158892 EPS nconv=0 first unconverged value (error) -302.035 (1.95644613e-06)
158893 EPS nconv=0 first unconverged value (error) -302.035 (1.95644613e-06)
158894 EPS nconv=0 first unconverged value (error) -302.035 (2.00617082e-06)
158895 EPS nconv=0 first unconverged value (error) -302.035 (1.94941820e-06)
158896 EPS nconv=0 first unconverged value (error) -302.035 (1.89827396e-06)
158897 EPS nconv=0 first unconverged value (error) -302.035 (1.88101532e-06)
158898 EPS nconv=0 first unconverged value (error) -302.035 (1.85304468e-06)
158899 EPS nconv=0 first unconverged value (error) -302.035 (1.85304468e-06)
158900 EPS nconv=0 first unconverged value (error) -302.035 (2.47660739e-06)
158901 EPS nconv=0 first unconverged value (error) -302.035 (2.45043013e-06)
158902 EPS nconv=0 first unconverged value (error) -302.035 (2.27023047e-06)
158903 EPS nconv=0 first unconverged value (error) -302.035 (2.12422729e-06)
158904 EPS nconv=0 first unconverged value (error) -302.035 (2.08591947e-06)
158905 EPS nconv=0 first unconverged value (error) -302.035 (2.08591947e-06)
158906 EPS nconv=0 first unconverged value (error) -302.035 (2.44222836e-06)
158907 EPS nconv=0 first unconverged value (error) -302.035 (2.43381607e-06)
158908 EPS nconv=0 first unconverged value (error) -302.035 (2.26826633e-06)
158909 EPS nconv=0 first unconverged value (error) -302.035 (2.14828831e-06)
158910 EPS nconv=0 first unconverged value (error) -302.035 (2.08312282e-06)
158911 EPS nconv=0 first unconverged value (error) -302.035 (2.08312282e-06)
158912 EPS nconv=0 first unconverged value (error) -302.035 (2.17969771e-06)
158913 EPS nconv=0 first unconverged value (error) -302.035 (2.09058467e-06)
158914 EPS nconv=0 first unconverged value (error) -302.035 (1.99393547e-06)
158915 EPS nconv=0 first unconverged value (error) -302.035 (1.90565899e-06)
158916 EPS nconv=0 first unconverged value (error) -302.035 (1.86766565e-06)
158917 EPS nconv=0 first unconverged value (error) -302.035 (1.86766565e-06)
158918 EPS nconv=0 first unconverged value (error) -302.035 (2.15922377e-06)
158919 EPS nconv=0 first unconverged value (error) -302.035 (2.05726092e-06)
158920 EPS nconv=0 first unconverged value (error) -302.035 (1.99171466e-06)
158921 EPS nconv=0 first unconverged value (error) -302.035 (1.95258162e-06)
158922 EPS nconv=0 first unconverged value (error) -302.035 (1.93885905e-06)
158923 EPS nconv=0 first unconverged value (error) -302.035 (1.93885905e-06)
158924 EPS nconv=0 first unconverged value (error) -302.035 (2.48832156e-06)
158925 EPS nconv=0 first unconverged value (error) -302.035 (2.32373345e-06)
158926 EPS nconv=0 first unconverged value (error) -302.035 (2.12265840e-06)
158927 EPS nconv=0 first unconverged value (error) -302.035 (2.11015323e-06)
158928 EPS nconv=0 first unconverged value (error) -302.035 (2.02266521e-06)
158929 EPS nconv=0 first unconverged value (error) -302.035 (2.02266521e-06)
158930 EPS nconv=0 first unconverged value (error) -302.035 (2.52737893e-06)
158931 EPS nconv=0 first unconverged value (error) -302.035 (2.61056504e-06)
158932 EPS nconv=0 first unconverged value (error) -302.035 (2.32765625e-06)
158933 EPS nconv=0 first unconverged value (error) -302.035 (2.25337035e-06)
158934 EPS nconv=0 first unconverged value (error) -302.035 (2.15673030e-06)
158935 EPS nconv=0 first unconverged value (error) -302.035 (2.15673030e-06)
158936 EPS nconv=0 first unconverged value (error) -302.035 (2.14659941e-06)
158937 EPS nconv=0 first unconverged value (error) -302.035 (2.15245397e-06)
158938 EPS nconv=0 first unconverged value (error) -302.035 (2.03121635e-06)
158939 EPS nconv=0 first unconverged value (error) -302.035 (1.93272851e-06)
158940 EPS nconv=0 first unconverged value (error) -302.035 (1.88199453e-06)
158941 EPS nconv=0 first unconverged value (error) -302.035 (1.88199453e-06)
158942 EPS nconv=0 first unconverged value (error) -302.035 (2.27009811e-06)
158943 EPS nconv=0 first unconverged value (error) -302.035 (2.15138123e-06)
158944 EPS nconv=0 first unconverged value (error) -302.035 (2.08116234e-06)
158945 EPS nconv=0 first unconverged value (error) -302.035 (2.03159173e-06)
158946 EPS nconv=0 first unconverged value (error) -302.035 (1.99591090e-06)
158947 EPS nconv=0 first unconverged value (error) -302.035 (1.99591090e-06)
158948 EPS nconv=0 first unconverged value (error) -302.035 (3.04316254e-06)
158949 EPS nconv=0 first unconverged value (error) -302.035 (2.73492546e-06)
158950 EPS nconv=0 first unconverged value (error) -302.035 (2.47608675e-06)
158951 EPS nconv=0 first unconverged value (error) -302.035 (2.44726301e-06)
158952 EPS nconv=0 first unconverged value (error) -302.035 (2.27886468e-06)
158953 EPS nconv=0 first unconverged value (error) -302.035 (2.27886468e-06)
158954 EPS nconv=0 first unconverged value (error) -302.035 (2.36863310e-06)
158955 EPS nconv=0 first unconverged value (error) -302.035 (2.68571511e-06)
158956 EPS nconv=0 first unconverged value (error) -302.035 (2.25139868e-06)
158957 EPS nconv=0 first unconverged value (error) -302.035 (2.09053292e-06)
158958 EPS nconv=0 first unconverged value (error) -302.035 (2.06722362e-06)
158959 EPS nconv=0 first unconverged value (error) -302.035 (2.06722362e-06)
158960 EPS nconv=0 first unconverged value (error) -302.035 (1.90413943e-06)
158961 EPS nconv=0 first unconverged value (error) -302.035 (1.88429077e-06)
158962 EPS nconv=0 first unconverged value (error) -302.035 (1.86397536e-06)
158963 EPS nconv=0 first unconverged value (error) -302.035 (1.83213092e-06)
158964 EPS nconv=0 first unconverged value (error) -302.035 (1.81133578e-06)
158965 EPS nconv=0 first unconverged value (error) -302.035 (1.81133578e-06)
158966 EPS nconv=0 first unconverged value (error) -302.035 (1.84980901e-06)
158967 EPS nconv=0 first unconverged value (error) -302.035 (1.82495516e-06)
158968 EPS nconv=0 first unconverged value (error) -302.035 (1.81766129e-06)
158969 EPS nconv=0 first unconverged value (error) -302.035 (1.81401448e-06)
158970 EPS nconv=0 first unconverged value (error) -302.035 (1.81085978e-06)
158971 EPS nconv=0 first unconverged value (error) -302.035 (1.81085978e-06)
158972 EPS nconv=0 first unconverged value (error) -302.035 (1.86637083e-06)
158973 EPS nconv=0 first unconverged value (error) -302.035 (1.86830339e-06)
158974 EPS nconv=0 first unconverged value (error) -302.035 (1.83643795e-06)
158975 EPS nconv=0 first unconverged value (error) -302.035 (1.81777086e-06)
158976 EPS nconv=0 first unconverged value (error) -302.035 (1.81418834e-06)
158977 EPS nconv=0 first unconverged value (error) -302.035 (1.81418834e-06)
158978 EPS nconv=0 first unconverged value (error) -302.035 (2.73369672e-06)
158979 EPS nconv=0 first unconverged value (error) -302.035 (2.51496681e-06)
158980 EPS nconv=0 first unconverged value (error) -302.035 (2.38072806e-06)
158981 EPS nconv=0 first unconverged value (error) -302.035 (2.35778126e-06)
158982 EPS nconv=0 first unconverged value (error) -302.035 (2.28071635e-06)
158983 EPS nconv=0 first unconverged value (error) -302.035 (2.28071635e-06)
158984 EPS nconv=0 first unconverged value (error) -302.035 (2.37802096e-06)
158985 EPS nconv=0 first unconverged value (error) -302.035 (2.37722531e-06)
158986 EPS nconv=0 first unconverged value (error) -302.035 (2.10095548e-06)
158987 EPS nconv=0 first unconverged value (error) -302.035 (1.99186592e-06)
158988 EPS nconv=0 first unconverged value (error) -302.035 (1.95232085e-06)
158989 EPS nconv=0 first unconverged value (error) -302.035 (1.95232085e-06)
158990 EPS nconv=0 first unconverged value (error) -302.035 (1.99029305e-06)
158991 EPS nconv=0 first unconverged value (error) -302.035 (1.97114204e-06)
158992 EPS nconv=0 first unconverged value (error) -302.035 (1.92809739e-06)
158993 EPS nconv=0 first unconverged value (error) -302.035 (1.85372332e-06)
158994 EPS nconv=0 first unconverged value (error) -302.035 (1.84238234e-06)
158995 EPS nconv=0 first unconverged value (error) -302.035 (1.84238234e-06)
158996 EPS nconv=0 first unconverged value (error) -302.035 (2.36195768e-06)
158997 EPS nconv=0 first unconverged value (error) -302.035 (2.14953488e-06)
158998 EPS nconv=0 first unconverged value (error) -302.035 (2.11001940e-06)
158999 EPS nconv=0 first unconverged value (error) -302.035 (2.03367057e-06)
159000 EPS nconv=0 first unconverged value (error) -302.035 (1.99968766e-06)
159001 EPS nconv=0 first unconverged value (error) -302.035 (1.99968766e-06)
159002 EPS nconv=0 first unconverged value (error) -302.035 (1.99724438e-06)
159003 EPS nconv=0 first unconverged value (error) -302.035 (2.21138389e-06)
159004 EPS nconv=0 first unconverged value (error) -302.035 (1.90011330e-06)
159005 EPS nconv=0 first unconverged value (error) -302.035 (1.88855524e-06)
159006 EPS nconv=0 first unconverged value (error) -302.035 (1.84513057e-06)
159007 EPS nconv=0 first unconverged value (error) -302.035 (1.84513057e-06)
159008 EPS nconv=0 first unconverged value (error) -302.035 (2.45704201e-06)
159009 EPS nconv=0 first unconverged value (error) -302.035 (2.30017257e-06)
159010 EPS nconv=0 first unconverged value (error) -302.035 (2.13680300e-06)
159011 EPS nconv=0 first unconverged value (error) -302.035 (2.14537540e-06)
159012 EPS nconv=0 first unconverged value (error) -302.035 (2.06321669e-06)
159013 EPS nconv=0 first unconverged value (error) -302.035 (2.06321669e-06)
159014 EPS nconv=0 first unconverged value (error) -302.035 (2.17614022e-06)
159015 EPS nconv=0 first unconverged value (error) -302.035 (2.24955991e-06)
159016 EPS nconv=0 first unconverged value (error) -302.035 (2.09817531e-06)
159017 EPS nconv=0 first unconverged value (error) -302.035 (1.97798169e-06)
159018 EPS nconv=0 first unconverged value (error) -302.035 (1.97146371e-06)
159019 EPS nconv=0 first unconverged value (error) -302.035 (1.97146371e-06)
159020 EPS nconv=0 first unconverged value (error) -302.035 (2.43421654e-06)
159021 EPS nconv=0 first unconverged value (error) -302.035 (2.12543697e-06)
159022 EPS nconv=0 first unconverged value (error) -302.035 (2.06290154e-06)
159023 EPS nconv=0 first unconverged value (error) -302.035 (2.07853496e-06)
159024 EPS nconv=0 first unconverged value (error) -302.035 (1.98778345e-06)
159025 EPS nconv=0 first unconverged value (error) -302.035 (1.98778345e-06)
159026 EPS nconv=0 first unconverged value (error) -302.035 (2.07088001e-06)
159027 EPS nconv=0 first unconverged value (error) -302.035 (2.26457439e-06)
159028 EPS nconv=0 first unconverged value (error) -302.035 (2.00013816e-06)
159029 EPS nconv=0 first unconverged value (error) -302.035 (1.91158779e-06)
159030 EPS nconv=0 first unconverged value (error) -302.035 (1.88132472e-06)
159031 EPS nconv=0 first unconverged value (error) -302.035 (1.88132472e-06)
159032 EPS nconv=0 first unconverged value (error) -302.035 (2.78778691e-06)
159033 EPS nconv=0 first unconverged value (error) -302.035 (2.42941094e-06)
159034 EPS nconv=0 first unconverged value (error) -302.035 (2.35465814e-06)
159035 EPS nconv=0 first unconverged value (error) -302.035 (2.28601769e-06)
159036 EPS nconv=0 first unconverged value (error) -302.035 (2.19079701e-06)
159037 EPS nconv=0 first unconverged value (error) -302.035 (2.19079701e-06)
159038 EPS nconv=0 first unconverged value (error) -302.035 (2.19045610e-06)
159039 EPS nconv=0 first unconverged value (error) -302.035 (2.42002054e-06)
159040 EPS nconv=0 first unconverged value (error) -302.035 (2.02618082e-06)
159041 EPS nconv=0 first unconverged value (error) -302.035 (1.93240032e-06)
159042 EPS nconv=0 first unconverged value (error) -302.035 (1.91266256e-06)
159043 EPS nconv=0 first unconverged value (error) -302.035 (1.91266256e-06)
159044 EPS nconv=0 first unconverged value (error) -302.035 (2.45855331e-06)
159045 EPS nconv=0 first unconverged value (error) -302.035 (2.20886953e-06)
159046 EPS nconv=0 first unconverged value (error) -302.035 (2.11546759e-06)
159047 EPS nconv=0 first unconverged value (error) -302.035 (2.10625307e-06)
159048 EPS nconv=0 first unconverged value (error) -302.035 (2.04487357e-06)
159049 EPS nconv=0 first unconverged value (error) -302.035 (2.04487357e-06)
159050 EPS nconv=0 first unconverged value (error) -302.035 (2.09613750e-06)
159051 EPS nconv=0 first unconverged value (error) -302.035 (2.30643200e-06)
159052 EPS nconv=0 first unconverged value (error) -302.035 (2.04751356e-06)
159053 EPS nconv=0 first unconverged value (error) -302.035 (1.89180893e-06)
159054 EPS nconv=0 first unconverged value (error) -302.035 (1.87566583e-06)
159055 EPS nconv=0 first unconverged value (error) -302.035 (1.87566583e-06)
159056 EPS nconv=0 first unconverged value (error) -302.035 (3.01568296e-06)
159057 EPS nconv=0 first unconverged value (error) -302.035 (2.58020825e-06)
159058 EPS nconv=0 first unconverged value (error) -302.035 (2.49059782e-06)
159059 EPS nconv=0 first unconverged value (error) -302.035 (2.47002117e-06)
159060 EPS nconv=0 first unconverged value (error) -302.035 (2.35047715e-06)
159061 EPS nconv=0 first unconverged value (error) -302.035 (2.35047715e-06)
159062 EPS nconv=0 first unconverged value (error) -302.035 (3.43444909e-06)
159063 EPS nconv=0 first unconverged value (error) -302.035 (3.32544115e-06)
159064 EPS nconv=0 first unconverged value (error) -302.035 (2.94085439e-06)
159065 EPS nconv=0 first unconverged value (error) -302.035 (2.89204018e-06)
159066 EPS nconv=0 first unconverged value (error) -302.035 (2.88382647e-06)
159067 EPS nconv=0 first unconverged value (error) -302.035 (2.88382647e-06)
159068 EPS nconv=0 first unconverged value (error) -302.035 (3.59450164e-06)
159069 EPS nconv=0 first unconverged value (error) -302.035 (2.82875159e-06)
159070 EPS nconv=0 first unconverged value (error) -302.035 (2.61406374e-06)
159071 EPS nconv=0 first unconverged value (error) -302.035 (2.57769649e-06)
159072 EPS nconv=0 first unconverged value (error) -302.035 (2.31642711e-06)
159073 EPS nconv=0 first unconverged value (error) -302.035 (2.31642711e-06)
159074 EPS nconv=0 first unconverged value (error) -302.035 (2.34762838e-06)
159075 EPS nconv=0 first unconverged value (error) -302.035 (2.46042565e-06)
159076 EPS nconv=0 first unconverged value (error) -302.035 (1.99662103e-06)
159077 EPS nconv=0 first unconverged value (error) -302.035 (1.89408985e-06)
159078 EPS nconv=0 first unconverged value (error) -302.035 (1.87942006e-06)
159079 EPS nconv=0 first unconverged value (error) -302.035 (1.87942006e-06)
159080 EPS nconv=0 first unconverged value (error) -302.035 (2.96824357e-06)
159081 EPS nconv=0 first unconverged value (error) -302.035 (2.55729549e-06)
159082 EPS nconv=0 first unconverged value (error) -302.035 (2.44429126e-06)
159083 EPS nconv=0 first unconverged value (error) -302.035 (2.42092589e-06)
159084 EPS nconv=0 first unconverged value (error) -302.035 (2.32385296e-06)
159085 EPS nconv=0 first unconverged value (error) -302.035 (2.32385296e-06)
159086 EPS nconv=0 first unconverged value (error) -302.035 (2.66432462e-06)
159087 EPS nconv=0 first unconverged value (error) -302.035 (2.67126212e-06)
159088 EPS nconv=0 first unconverged value (error) -302.035 (2.20586631e-06)
159089 EPS nconv=0 first unconverged value (error) -302.035 (2.11686079e-06)
159090 EPS nconv=0 first unconverged value (error) -302.035 (2.11763829e-06)
159091 EPS nconv=0 first unconverged value (error) -302.035 (2.11763829e-06)
159092 EPS nconv=0 first unconverged value (error) -302.035 (2.97479974e-06)
159093 EPS nconv=0 first unconverged value (error) -302.035 (2.61036624e-06)
159094 EPS nconv=0 first unconverged value (error) -302.035 (2.40582569e-06)
159095 EPS nconv=0 first unconverged value (error) -302.035 (2.37033941e-06)
159096 EPS nconv=0 first unconverged value (error) -302.035 (2.25860735e-06)
159097 EPS nconv=0 first unconverged value (error) -302.035 (2.25860735e-06)
159098 EPS nconv=0 first unconverged value (error) -302.035 (2.21337052e-06)
159099 EPS nconv=0 first unconverged value (error) -302.035 (2.49153629e-06)
159100 EPS nconv=0 first unconverged value (error) -302.035 (2.03306547e-06)
159101 EPS nconv=0 first unconverged value (error) -302.035 (1.88138166e-06)
159102 EPS nconv=0 first unconverged value (error) -302.035 (1.86382794e-06)
159103 EPS nconv=0 first unconverged value (error) -302.035 (1.86382794e-06)
159104 EPS nconv=0 first unconverged value (error) -302.035 (2.70556385e-06)
159105 EPS nconv=0 first unconverged value (error) -302.035 (2.33584776e-06)
159106 EPS nconv=0 first unconverged value (error) -302.035 (2.23481919e-06)
159107 EPS nconv=0 first unconverged value (error) -302.035 (2.21289849e-06)
159108 EPS nconv=0 first unconverged value (error) -302.035 (2.15532427e-06)
159109 EPS nconv=0 first unconverged value (error) -302.035 (2.15532427e-06)
159110 EPS nconv=0 first unconverged value (error) -302.035 (2.24938541e-06)
159111 EPS nconv=0 first unconverged value (error) -302.035 (2.51823719e-06)
159112 EPS nconv=0 first unconverged value (error) -302.035 (2.13837073e-06)
159113 EPS nconv=0 first unconverged value (error) -302.035 (1.90044571e-06)
159114 EPS nconv=0 first unconverged value (error) -302.035 (1.88125532e-06)
159115 EPS nconv=0 first unconverged value (error) -302.035 (1.88125532e-06)
159116 EPS nconv=0 first unconverged value (error) -302.035 (1.96299020e-06)
159117 EPS nconv=0 first unconverged value (error) -302.035 (1.92567873e-06)
159118 EPS nconv=0 first unconverged value (error) -302.035 (1.90191860e-06)
159119 EPS nconv=0 first unconverged value (error) -302.035 (1.86482064e-06)
159120 EPS nconv=0 first unconverged value (error) -302.035 (1.84239700e-06)
159121 EPS nconv=0 first unconverged value (error) -302.035 (1.84239700e-06)
159122 EPS nconv=0 first unconverged value (error) -302.035 (1.94008893e-06)
159123 EPS nconv=0 first unconverged value (error) -302.035 (1.92666113e-06)
159124 EPS nconv=0 first unconverged value (error) -302.035 (1.86115282e-06)
159125 EPS nconv=0 first unconverged value (error) -302.035 (1.83507934e-06)
159126 EPS nconv=0 first unconverged value (error) -302.035 (1.83085551e-06)
159127 EPS nconv=0 first unconverged value (error) -302.035 (1.83085551e-06)
159128 EPS nconv=0 first unconverged value (error) -302.035 (2.65279743e-06)
159129 EPS nconv=0 first unconverged value (error) -302.035 (2.40256455e-06)
159130 EPS nconv=0 first unconverged value (error) -302.035 (2.26723176e-06)
159131 EPS nconv=0 first unconverged value (error) -302.035 (2.24060183e-06)
159132 EPS nconv=0 first unconverged value (error) -302.035 (2.15359854e-06)
159133 EPS nconv=0 first unconverged value (error) -302.035 (2.15359854e-06)
159134 EPS nconv=0 first unconverged value (error) -302.035 (2.60792346e-06)
159135 EPS nconv=0 first unconverged value (error) -302.035 (2.53327574e-06)
159136 EPS nconv=0 first unconverged value (error) -302.035 (2.25634811e-06)
159137 EPS nconv=0 first unconverged value (error) -302.035 (2.17480795e-06)
159138 EPS nconv=0 first unconverged value (error) -302.035 (2.16398379e-06)
159139 EPS nconv=0 first unconverged value (error) -302.035 (2.16398379e-06)
159140 EPS nconv=0 first unconverged value (error) -302.035 (2.74158467e-06)
159141 EPS nconv=0 first unconverged value (error) -302.035 (2.48992322e-06)
159142 EPS nconv=0 first unconverged value (error) -302.035 (2.24084067e-06)
159143 EPS nconv=0 first unconverged value (error) -302.035 (2.18453825e-06)
159144 EPS nconv=0 first unconverged value (error) -302.035 (2.08322403e-06)
159145 EPS nconv=0 first unconverged value (error) -302.035 (2.08322403e-06)
159146 EPS nconv=0 first unconverged value (error) -302.035 (2.06488168e-06)
159147 EPS nconv=0 first unconverged value (error) -302.035 (2.29177549e-06)
159148 EPS nconv=0 first unconverged value (error) -302.035 (2.00528176e-06)
159149 EPS nconv=0 first unconverged value (error) -302.035 (1.89343499e-06)
159150 EPS nconv=0 first unconverged value (error) -302.035 (1.85300681e-06)
159151 EPS nconv=0 first unconverged value (error) -302.035 (1.85300681e-06)
159152 EPS nconv=0 first unconverged value (error) -302.035 (1.90096598e-06)
159153 EPS nconv=0 first unconverged value (error) -302.035 (1.86275211e-06)
159154 EPS nconv=0 first unconverged value (error) -302.035 (1.84724173e-06)
159155 EPS nconv=0 first unconverged value (error) -302.035 (1.84272258e-06)
159156 EPS nconv=0 first unconverged value (error) -302.035 (1.83405675e-06)
159157 EPS nconv=0 first unconverged value (error) -302.035 (1.83405675e-06)
159158 EPS nconv=0 first unconverged value (error) -302.035 (1.83504770e-06)
159159 EPS nconv=0 first unconverged value (error) -302.035 (1.84886872e-06)
159160 EPS nconv=0 first unconverged value (error) -302.035 (1.82086942e-06)
159161 EPS nconv=0 first unconverged value (error) -302.035 (1.80756763e-06)
159162 EPS nconv=0 first unconverged value (error) -302.035 (1.80580423e-06)
159163 EPS nconv=0 first unconverged value (error) -302.035 (1.80580423e-06)
159164 EPS nconv=0 first unconverged value (error) -302.035 (2.06995218e-06)
159165 EPS nconv=0 first unconverged value (error) -302.035 (1.96081768e-06)
159166 EPS nconv=0 first unconverged value (error) -302.035 (1.91696433e-06)
159167 EPS nconv=0 first unconverged value (error) -302.035 (1.90002294e-06)
159168 EPS nconv=0 first unconverged value (error) -302.035 (1.87928799e-06)
159169 EPS nconv=0 first unconverged value (error) -302.035 (1.87928799e-06)
159170 EPS nconv=0 first unconverged value (error) -302.035 (1.89525701e-06)
159171 EPS nconv=0 first unconverged value (error) -302.035 (2.01177676e-06)
159172 EPS nconv=0 first unconverged value (error) -302.035 (1.89661634e-06)
159173 EPS nconv=0 first unconverged value (error) -302.035 (1.83044602e-06)
159174 EPS nconv=0 first unconverged value (error) -302.035 (1.81928924e-06)
159175 EPS nconv=0 first unconverged value (error) -302.035 (1.81928924e-06)
159176 EPS nconv=0 first unconverged value (error) -302.035 (1.94894289e-06)
159177 EPS nconv=0 first unconverged value (error) -302.035 (1.89744329e-06)
159178 EPS nconv=0 first unconverged value (error) -302.035 (1.88259149e-06)
159179 EPS nconv=0 first unconverged value (error) -302.035 (1.87946694e-06)
159180 EPS nconv=0 first unconverged value (error) -302.035 (1.86123551e-06)
159181 EPS nconv=0 first unconverged value (error) -302.035 (1.86123551e-06)
159182 EPS nconv=0 first unconverged value (error) -302.035 (2.16772957e-06)
159183 EPS nconv=0 first unconverged value (error) -302.035 (2.10679664e-06)
159184 EPS nconv=0 first unconverged value (error) -302.035 (2.04381105e-06)
159185 EPS nconv=0 first unconverged value (error) -302.035 (1.96436075e-06)
159186 EPS nconv=0 first unconverged value (error) -302.035 (1.94671472e-06)
159187 EPS nconv=0 first unconverged value (error) -302.035 (1.94671472e-06)
159188 EPS nconv=0 first unconverged value (error) -302.035 (2.12792101e-06)
159189 EPS nconv=0 first unconverged value (error) -302.035 (2.07003973e-06)
159190 EPS nconv=0 first unconverged value (error) -302.035 (1.94319012e-06)
159191 EPS nconv=0 first unconverged value (error) -302.035 (1.93058648e-06)
159192 EPS nconv=0 first unconverged value (error) -302.035 (1.90421068e-06)
159193 EPS nconv=0 first unconverged value (error) -302.035 (1.90421068e-06)
159194 EPS nconv=0 first unconverged value (error) -302.035 (1.93329237e-06)
159195 EPS nconv=0 first unconverged value (error) -302.035 (1.97257577e-06)
159196 EPS nconv=0 first unconverged value (error) -302.035 (1.87471911e-06)
159197 EPS nconv=0 first unconverged value (error) -302.035 (1.85608827e-06)
159198 EPS nconv=0 first unconverged value (error) -302.035 (1.82595462e-06)
159199 EPS nconv=0 first unconverged value (error) -302.035 (1.82595462e-06)
159200 EPS nconv=0 first unconverged value (error) -302.035 (2.09647560e-06)
159201 EPS nconv=0 first unconverged value (error) -302.035 (2.07869185e-06)
159202 EPS nconv=0 first unconverged value (error) -302.035 (2.00246857e-06)
159203 EPS nconv=0 first unconverged value (error) -302.035 (1.95830786e-06)
159204 EPS nconv=0 first unconverged value (error) -302.035 (1.93441333e-06)
159205 EPS nconv=0 first unconverged value (error) -302.035 (1.93441333e-06)
159206 EPS nconv=0 first unconverged value (error) -302.035 (2.36716230e-06)
159207 EPS nconv=0 first unconverged value (error) -302.035 (2.24664002e-06)
159208 EPS nconv=0 first unconverged value (error) -302.035 (2.12868950e-06)
159209 EPS nconv=0 first unconverged value (error) -302.035 (2.09834633e-06)
159210 EPS nconv=0 first unconverged value (error) -302.035 (2.08679574e-06)
159211 EPS nconv=0 first unconverged value (error) -302.035 (2.08679574e-06)
159212 EPS nconv=0 first unconverged value (error) -302.035 (2.36395080e-06)
159213 EPS nconv=0 first unconverged value (error) -302.035 (2.24377986e-06)
159214 EPS nconv=0 first unconverged value (error) -302.035 (2.09530676e-06)
159215 EPS nconv=0 first unconverged value (error) -302.035 (1.98943623e-06)
159216 EPS nconv=0 first unconverged value (error) -302.035 (1.95982726e-06)
159217 EPS nconv=0 first unconverged value (error) -302.035 (1.95982726e-06)
159218 EPS nconv=0 first unconverged value (error) -302.035 (2.69604645e-06)
159219 EPS nconv=0 first unconverged value (error) -302.035 (2.37202134e-06)
159220 EPS nconv=0 first unconverged value (error) -302.035 (2.18737930e-06)
159221 EPS nconv=0 first unconverged value (error) -302.035 (2.13347142e-06)
159222 EPS nconv=0 first unconverged value (error) -302.035 (2.08181274e-06)
159223 EPS nconv=0 first unconverged value (error) -302.035 (2.08181274e-06)
159224 EPS nconv=0 first unconverged value (error) -302.035 (2.07818805e-06)
159225 EPS nconv=0 first unconverged value (error) -302.035 (2.37046525e-06)
159226 EPS nconv=0 first unconverged value (error) -302.035 (2.04369772e-06)
159227 EPS nconv=0 first unconverged value (error) -302.035 (1.92578393e-06)
159228 EPS nconv=0 first unconverged value (error) -302.035 (1.84986740e-06)
159229 EPS nconv=0 first unconverged value (error) -302.035 (1.84986740e-06)
159230 EPS nconv=0 first unconverged value (error) -302.035 (1.95262208e-06)
159231 EPS nconv=0 first unconverged value (error) -302.035 (1.88045402e-06)
159232 EPS nconv=0 first unconverged value (error) -302.035 (1.87351976e-06)
159233 EPS nconv=0 first unconverged value (error) -302.035 (1.85777737e-06)
159234 EPS nconv=0 first unconverged value (error) -302.035 (1.84179206e-06)
159235 EPS nconv=0 first unconverged value (error) -302.035 (1.84179206e-06)
159236 EPS nconv=0 first unconverged value (error) -302.035 (2.03852133e-06)
159237 EPS nconv=0 first unconverged value (error) -302.035 (2.01925290e-06)
159238 EPS nconv=0 first unconverged value (error) -302.035 (1.96578335e-06)
159239 EPS nconv=0 first unconverged value (error) -302.035 (1.89429921e-06)
159240 EPS nconv=0 first unconverged value (error) -302.035 (1.88555609e-06)
159241 EPS nconv=0 first unconverged value (error) -302.035 (1.88555609e-06)
159242 EPS nconv=0 first unconverged value (error) -302.035 (1.90357228e-06)
159243 EPS nconv=0 first unconverged value (error) -302.035 (1.94630358e-06)
159244 EPS nconv=0 first unconverged value (error) -302.035 (1.86942426e-06)
159245 EPS nconv=0 first unconverged value (error) -302.035 (1.83372996e-06)
159246 EPS nconv=0 first unconverged value (error) -302.035 (1.82497831e-06)
159247 EPS nconv=0 first unconverged value (error) -302.035 (1.82497831e-06)
159248 EPS nconv=0 first unconverged value (error) -302.035 (2.34267686e-06)
159249 EPS nconv=0 first unconverged value (error) -302.035 (2.14284041e-06)
159250 EPS nconv=0 first unconverged value (error) -302.035 (2.08038835e-06)
159251 EPS nconv=0 first unconverged value (error) -302.035 (2.06400260e-06)
159252 EPS nconv=0 first unconverged value (error) -302.035 (2.01512726e-06)
159253 EPS nconv=0 first unconverged value (error) -302.035 (2.01512726e-06)
159254 EPS nconv=0 first unconverged value (error) -302.035 (2.19786174e-06)
159255 EPS nconv=0 first unconverged value (error) -302.035 (2.35111759e-06)
159256 EPS nconv=0 first unconverged value (error) -302.035 (2.16006365e-06)
159257 EPS nconv=0 first unconverged value (error) -302.035 (1.91895956e-06)
159258 EPS nconv=0 first unconverged value (error) -302.035 (1.90728883e-06)
159259 EPS nconv=0 first unconverged value (error) -302.035 (1.90728883e-06)
159260 EPS nconv=0 first unconverged value (error) -302.035 (1.88320002e-06)
159261 EPS nconv=0 first unconverged value (error) -302.035 (1.87452504e-06)
159262 EPS nconv=0 first unconverged value (error) -302.035 (1.83740718e-06)
159263 EPS nconv=0 first unconverged value (error) -302.035 (1.82410266e-06)
159264 EPS nconv=0 first unconverged value (error) -302.035 (1.80809461e-06)
159265 EPS nconv=0 first unconverged value (error) -302.035 (1.80809461e-06)
159266 EPS nconv=0 first unconverged value (error) -302.035 (2.03475869e-06)
159267 EPS nconv=0 first unconverged value (error) -302.035 (1.98972503e-06)
159268 EPS nconv=0 first unconverged value (error) -302.035 (1.93087557e-06)
159269 EPS nconv=0 first unconverged value (error) -302.035 (1.91454190e-06)
159270 EPS nconv=0 first unconverged value (error) -302.035 (1.89792881e-06)
159271 EPS nconv=0 first unconverged value (error) -302.035 (1.89792881e-06)
159272 EPS nconv=0 first unconverged value (error) -302.035 (2.99394467e-06)
159273 EPS nconv=0 first unconverged value (error) -302.035 (2.75205122e-06)
159274 EPS nconv=0 first unconverged value (error) -302.035 (2.61987388e-06)
159275 EPS nconv=0 first unconverged value (error) -302.035 (2.34119050e-06)
159276 EPS nconv=0 first unconverged value (error) -302.035 (2.28326524e-06)
159277 EPS nconv=0 first unconverged value (error) -302.035 (2.28326524e-06)
159278 EPS nconv=0 first unconverged value (error) -302.035 (2.27284345e-06)
159279 EPS nconv=0 first unconverged value (error) -302.035 (2.53956022e-06)
159280 EPS nconv=0 first unconverged value (error) -302.035 (2.17425771e-06)
159281 EPS nconv=0 first unconverged value (error) -302.035 (1.92986965e-06)
159282 EPS nconv=0 first unconverged value (error) -302.035 (1.85309952e-06)
159283 EPS nconv=0 first unconverged value (error) -302.035 (1.85309952e-06)
159284 EPS nconv=0 first unconverged value (error) -302.035 (2.16484906e-06)
159285 EPS nconv=0 first unconverged value (error) -302.035 (2.06974696e-06)
159286 EPS nconv=0 first unconverged value (error) -302.035 (2.01747446e-06)
159287 EPS nconv=0 first unconverged value (error) -302.035 (1.99449907e-06)
159288 EPS nconv=0 first unconverged value (error) -302.035 (1.96835269e-06)
159289 EPS nconv=0 first unconverged value (error) -302.035 (1.96835269e-06)
159290 EPS nconv=0 first unconverged value (error) -302.035 (2.69417877e-06)
159291 EPS nconv=0 first unconverged value (error) -302.035 (2.71408555e-06)
159292 EPS nconv=0 first unconverged value (error) -302.035 (2.58674222e-06)
159293 EPS nconv=0 first unconverged value (error) -302.035 (2.19492139e-06)
159294 EPS nconv=0 first unconverged value (error) -302.035 (2.15702121e-06)
159295 EPS nconv=0 first unconverged value (error) -302.035 (2.15702121e-06)
159296 EPS nconv=0 first unconverged value (error) -302.035 (2.39752698e-06)
159297 EPS nconv=0 first unconverged value (error) -302.035 (2.42947626e-06)
159298 EPS nconv=0 first unconverged value (error) -302.035 (2.35327341e-06)
159299 EPS nconv=0 first unconverged value (error) -302.035 (2.05782064e-06)
159300 EPS nconv=0 first unconverged value (error) -302.035 (1.99923390e-06)
159301 EPS nconv=0 first unconverged value (error) -302.035 (1.99923390e-06)
159302 EPS nconv=0 first unconverged value (error) -302.035 (1.97325653e-06)
159303 EPS nconv=0 first unconverged value (error) -302.035 (1.92945974e-06)
159304 EPS nconv=0 first unconverged value (error) -302.035 (1.85721448e-06)
159305 EPS nconv=0 first unconverged value (error) -302.035 (1.83637257e-06)
159306 EPS nconv=0 first unconverged value (error) -302.035 (1.82294986e-06)
159307 EPS nconv=0 first unconverged value (error) -302.035 (1.82294986e-06)
159308 EPS nconv=0 first unconverged value (error) -302.035 (1.95027596e-06)
159309 EPS nconv=0 first unconverged value (error) -302.035 (1.92213925e-06)
159310 EPS nconv=0 first unconverged value (error) -302.035 (1.87572929e-06)
159311 EPS nconv=0 first unconverged value (error) -302.035 (1.85686144e-06)
159312 EPS nconv=0 first unconverged value (error) -302.035 (1.84494157e-06)
159313 EPS nconv=0 first unconverged value (error) -302.035 (1.84494157e-06)
159314 EPS nconv=0 first unconverged value (error) -302.035 (1.85439137e-06)
159315 EPS nconv=0 first unconverged value (error) -302.035 (1.86913664e-06)
159316 EPS nconv=0 first unconverged value (error) -302.035 (1.84297189e-06)
159317 EPS nconv=0 first unconverged value (error) -302.035 (1.81700480e-06)
159318 EPS nconv=0 first unconverged value (error) -302.035 (1.80888344e-06)
159319 EPS nconv=0 first unconverged value (error) -302.035 (1.80888344e-06)
159320 EPS nconv=0 first unconverged value (error) -302.035 (1.80474012e-06)
159321 EPS nconv=0 first unconverged value (error) -302.035 (1.80762948e-06)
159322 EPS nconv=0 first unconverged value (error) -302.035 (1.80308868e-06)
159323 EPS nconv=0 first unconverged value (error) -302.035 (1.79754740e-06)
159324 EPS nconv=0 first unconverged value (error) -302.035 (1.79639473e-06)
159325 EPS nconv=0 first unconverged value (error) -302.035 (1.79639473e-06)
159326 EPS nconv=0 first unconverged value (error) -302.035 (1.83260619e-06)
159327 EPS nconv=0 first unconverged value (error) -302.035 (1.81869193e-06)
159328 EPS nconv=0 first unconverged value (error) -302.035 (1.81167142e-06)
159329 EPS nconv=0 first unconverged value (error) -302.035 (1.80907206e-06)
159330 EPS nconv=0 first unconverged value (error) -302.035 (1.80668621e-06)
159331 EPS nconv=0 first unconverged value (error) -302.035 (1.80668621e-06)
159332 EPS nconv=0 first unconverged value (error) -302.035 (1.81425015e-06)
159333 EPS nconv=0 first unconverged value (error) -302.035 (1.83271841e-06)
159334 EPS nconv=0 first unconverged value (error) -302.035 (1.81483179e-06)
159335 EPS nconv=0 first unconverged value (error) -302.035 (1.80143062e-06)
159336 EPS nconv=0 first unconverged value (error) -302.035 (1.79843669e-06)
159337 EPS nconv=0 first unconverged value (error) -302.035 (1.79843669e-06)
159338 EPS nconv=0 first unconverged value (error) -302.035 (1.90190181e-06)
159339 EPS nconv=0 first unconverged value (error) -302.035 (1.87333818e-06)
159340 EPS nconv=0 first unconverged value (error) -302.035 (1.85868160e-06)
159341 EPS nconv=0 first unconverged value (error) -302.035 (1.85655702e-06)
159342 EPS nconv=0 first unconverged value (error) -302.035 (1.84612406e-06)
159343 EPS nconv=0 first unconverged value (error) -302.035 (1.84612406e-06)
159344 EPS nconv=0 first unconverged value (error) -302.035 (1.91063279e-06)
159345 EPS nconv=0 first unconverged value (error) -302.035 (1.89081493e-06)
159346 EPS nconv=0 first unconverged value (error) -302.035 (1.84944171e-06)
159347 EPS nconv=0 first unconverged value (error) -302.035 (1.84470008e-06)
159348 EPS nconv=0 first unconverged value (error) -302.035 (1.83897409e-06)
159349 EPS nconv=0 first unconverged value (error) -302.035 (1.83897409e-06)
159350 EPS nconv=0 first unconverged value (error) -302.035 (1.91418843e-06)
159351 EPS nconv=0 first unconverged value (error) -302.035 (1.90114879e-06)
159352 EPS nconv=0 first unconverged value (error) -302.035 (1.86744190e-06)
159353 EPS nconv=0 first unconverged value (error) -302.035 (1.85316614e-06)
159354 EPS nconv=0 first unconverged value (error) -302.035 (1.83820543e-06)
159355 EPS nconv=0 first unconverged value (error) -302.035 (1.83820543e-06)
159356 EPS nconv=0 first unconverged value (error) -302.035 (1.83259609e-06)
159357 EPS nconv=0 first unconverged value (error) -302.035 (1.85662651e-06)
159358 EPS nconv=0 first unconverged value (error) -302.035 (1.82899756e-06)
159359 EPS nconv=0 first unconverged value (error) -302.035 (1.80394447e-06)
159360 EPS nconv=0 first unconverged value (error) -302.035 (1.79839199e-06)
159361 EPS nconv=0 first unconverged value (error) -302.035 (1.79839199e-06)
159362 EPS nconv=0 first unconverged value (error) -302.035 (1.79596805e-06)
159363 EPS nconv=0 first unconverged value (error) -302.035 (1.79662054e-06)
159364 EPS nconv=0 first unconverged value (error) -302.035 (1.79571401e-06)
159365 EPS nconv=0 first unconverged value (error) -302.035 (1.79447801e-06)
159366 EPS nconv=0 first unconverged value (error) -302.035 (1.79403122e-06)
159367 EPS nconv=0 first unconverged value (error) -302.035 (1.79403122e-06)
159368 EPS nconv=0 first unconverged value (error) -302.035 (1.79558302e-06)
159369 EPS nconv=0 first unconverged value (error) -302.035 (1.79505401e-06)
159370 EPS nconv=0 first unconverged value (error) -302.035 (1.79458202e-06)
159371 EPS nconv=0 first unconverged value (error) -302.035 (1.79434890e-06)
159372 EPS nconv=0 first unconverged value (error) -302.035 (1.79418664e-06)
159373 EPS nconv=0 first unconverged value (error) -302.035 (1.79418664e-06)
159374 EPS nconv=0 first unconverged value (error) -302.035 (1.88365747e-06)
159375 EPS nconv=0 first unconverged value (error) -302.035 (1.87912759e-06)
159376 EPS nconv=0 first unconverged value (error) -302.035 (1.85316290e-06)
159377 EPS nconv=0 first unconverged value (error) -302.035 (1.84093437e-06)
159378 EPS nconv=0 first unconverged value (error) -302.035 (1.83960365e-06)
159379 EPS nconv=0 first unconverged value (error) -302.035 (1.83960365e-06)
159380 EPS nconv=0 first unconverged value (error) -302.035 (1.92561889e-06)
159381 EPS nconv=0 first unconverged value (error) -302.035 (1.90994460e-06)
159382 EPS nconv=0 first unconverged value (error) -302.035 (1.90502221e-06)
159383 EPS nconv=0 first unconverged value (error) -302.035 (1.83872636e-06)
159384 EPS nconv=0 first unconverged value (error) -302.035 (1.83541724e-06)
159385 EPS nconv=0 first unconverged value (error) -302.035 (1.83541724e-06)
159386 EPS nconv=0 first unconverged value (error) -302.035 (2.28916179e-06)
159387 EPS nconv=0 first unconverged value (error) -302.035 (2.14359984e-06)
159388 EPS nconv=0 first unconverged value (error) -302.035 (2.14839128e-06)
159389 EPS nconv=0 first unconverged value (error) -302.035 (2.03526855e-06)
159390 EPS nconv=0 first unconverged value (error) -302.035 (2.01144498e-06)
159391 EPS nconv=0 first unconverged value (error) -302.035 (2.01144498e-06)
159392 EPS nconv=0 first unconverged value (error) -302.035 (2.71171432e-06)
159393 EPS nconv=0 first unconverged value (error) -302.035 (2.44742979e-06)
159394 EPS nconv=0 first unconverged value (error) -302.035 (2.28772115e-06)
159395 EPS nconv=0 first unconverged value (error) -302.035 (2.26147929e-06)
159396 EPS nconv=0 first unconverged value (error) -302.035 (2.22940206e-06)
159397 EPS nconv=0 first unconverged value (error) -302.035 (2.22940206e-06)
159398 EPS nconv=0 first unconverged value (error) -302.035 (2.39064048e-06)
159399 EPS nconv=0 first unconverged value (error) -302.035 (2.50296360e-06)
159400 EPS nconv=0 first unconverged value (error) -302.035 (2.17944407e-06)
159401 EPS nconv=0 first unconverged value (error) -302.035 (2.08323988e-06)
159402 EPS nconv=0 first unconverged value (error) -302.035 (1.95402964e-06)
159403 EPS nconv=0 first unconverged value (error) -302.035 (1.95402964e-06)
159404 EPS nconv=0 first unconverged value (error) -302.035 (2.46904593e-06)
159405 EPS nconv=0 first unconverged value (error) -302.035 (2.37410300e-06)
159406 EPS nconv=0 first unconverged value (error) -302.035 (2.21072566e-06)
159407 EPS nconv=0 first unconverged value (error) -302.035 (2.14167236e-06)
159408 EPS nconv=0 first unconverged value (error) -302.035 (2.08661917e-06)
159409 EPS nconv=0 first unconverged value (error) -302.035 (2.08661917e-06)
159410 EPS nconv=0 first unconverged value (error) -302.035 (3.43621379e-06)
159411 EPS nconv=0 first unconverged value (error) -302.035 (3.05375573e-06)
159412 EPS nconv=0 first unconverged value (error) -302.035 (2.71849988e-06)
159413 EPS nconv=0 first unconverged value (error) -302.035 (2.73946219e-06)
159414 EPS nconv=0 first unconverged value (error) -302.035 (2.59727395e-06)
159415 EPS nconv=0 first unconverged value (error) -302.035 (2.59727395e-06)
159416 EPS nconv=0 first unconverged value (error) -302.035 (3.20236096e-06)
159417 EPS nconv=0 first unconverged value (error) -302.035 (3.24794457e-06)
159418 EPS nconv=0 first unconverged value (error) -302.035 (2.66856201e-06)
159419 EPS nconv=0 first unconverged value (error) -302.035 (2.56632952e-06)
159420 EPS nconv=0 first unconverged value (error) -302.035 (2.50083913e-06)
159421 EPS nconv=0 first unconverged value (error) -302.035 (2.50083913e-06)
159422 EPS nconv=0 first unconverged value (error) -302.035 (2.36602720e-06)
159423 EPS nconv=0 first unconverged value (error) -302.035 (2.32984428e-06)
159424 EPS nconv=0 first unconverged value (error) -302.035 (2.24174838e-06)
159425 EPS nconv=0 first unconverged value (error) -302.035 (1.96242656e-06)
159426 EPS nconv=0 first unconverged value (error) -302.035 (1.85830269e-06)
159427 EPS nconv=0 first unconverged value (error) -302.035 (1.85830269e-06)
159428 EPS nconv=0 first unconverged value (error) -302.035 (2.35260583e-06)
159429 EPS nconv=0 first unconverged value (error) -302.035 (2.21221881e-06)
159430 EPS nconv=0 first unconverged value (error) -302.035 (2.09252872e-06)
159431 EPS nconv=0 first unconverged value (error) -302.035 (2.03158084e-06)
159432 EPS nconv=0 first unconverged value (error) -302.035 (2.00503127e-06)
159433 EPS nconv=0 first unconverged value (error) -302.035 (2.00503127e-06)
159434 EPS nconv=0 first unconverged value (error) -302.035 (2.55552656e-06)
159435 EPS nconv=0 first unconverged value (error) -302.035 (2.40165976e-06)
159436 EPS nconv=0 first unconverged value (error) -302.035 (2.22382321e-06)
159437 EPS nconv=0 first unconverged value (error) -302.035 (2.25558622e-06)
159438 EPS nconv=0 first unconverged value (error) -302.035 (2.18568719e-06)
159439 EPS nconv=0 first unconverged value (error) -302.035 (2.18568719e-06)
159440 EPS nconv=0 first unconverged value (error) -302.035 (2.35140327e-06)
159441 EPS nconv=0 first unconverged value (error) -302.035 (2.29063027e-06)
159442 EPS nconv=0 first unconverged value (error) -302.035 (2.09082124e-06)
159443 EPS nconv=0 first unconverged value (error) -302.035 (1.99287998e-06)
159444 EPS nconv=0 first unconverged value (error) -302.035 (1.97649883e-06)
159445 EPS nconv=0 first unconverged value (error) -302.035 (1.97649883e-06)
159446 EPS nconv=0 first unconverged value (error) -302.035 (1.93059396e-06)
159447 EPS nconv=0 first unconverged value (error) -302.035 (1.99524729e-06)
159448 EPS nconv=0 first unconverged value (error) -302.035 (1.93934883e-06)
159449 EPS nconv=0 first unconverged value (error) -302.035 (1.84473416e-06)
159450 EPS nconv=0 first unconverged value (error) -302.035 (1.81206676e-06)
159451 EPS nconv=0 first unconverged value (error) -302.035 (1.81206676e-06)
159452 EPS nconv=0 first unconverged value (error) -302.035 (1.80413274e-06)
159453 EPS nconv=0 first unconverged value (error) -302.035 (1.80242219e-06)
159454 EPS nconv=0 first unconverged value (error) -302.035 (1.80077592e-06)
159455 EPS nconv=0 first unconverged value (error) -302.035 (1.80013794e-06)
159456 EPS nconv=0 first unconverged value (error) -302.035 (1.79942683e-06)
159457 EPS nconv=0 first unconverged value (error) -302.035 (1.79942683e-06)
159458 EPS nconv=0 first unconverged value (error) -302.035 (2.38842487e-06)
159459 EPS nconv=0 first unconverged value (error) -302.035 (2.24640918e-06)
159460 EPS nconv=0 first unconverged value (error) -302.035 (2.19099537e-06)
159461 EPS nconv=0 first unconverged value (error) -302.035 (2.06030074e-06)
159462 EPS nconv=0 first unconverged value (error) -302.035 (2.04220471e-06)
159463 EPS nconv=0 first unconverged value (error) -302.035 (2.04220471e-06)
159464 EPS nconv=0 first unconverged value (error) -302.035 (3.38474235e-06)
159465 EPS nconv=0 first unconverged value (error) -302.035 (3.06858281e-06)
159466 EPS nconv=0 first unconverged value (error) -302.035 (2.80012717e-06)
159467 EPS nconv=0 first unconverged value (error) -302.035 (2.73285445e-06)
159468 EPS nconv=0 first unconverged value (error) -302.035 (2.65167525e-06)
159469 EPS nconv=0 first unconverged value (error) -302.035 (2.65167525e-06)
159470 EPS nconv=0 first unconverged value (error) -302.035 (3.06766845e-06)
159471 EPS nconv=0 first unconverged value (error) -302.035 (3.06249060e-06)
159472 EPS nconv=0 first unconverged value (error) -302.035 (2.70009268e-06)
159473 EPS nconv=0 first unconverged value (error) -302.035 (2.29784970e-06)
159474 EPS nconv=0 first unconverged value (error) -302.035 (2.16566420e-06)
159475 EPS nconv=0 first unconverged value (error) -302.035 (2.16566420e-06)
159476 EPS nconv=0 first unconverged value (error) -302.035 (2.10943314e-06)
159477 EPS nconv=0 first unconverged value (error) -302.035 (2.12337727e-06)
159478 EPS nconv=0 first unconverged value (error) -302.035 (1.93578997e-06)
159479 EPS nconv=0 first unconverged value (error) -302.035 (1.85692414e-06)
159480 EPS nconv=0 first unconverged value (error) -302.035 (1.83103203e-06)
159481 EPS nconv=0 first unconverged value (error) -302.035 (1.83103203e-06)
159482 EPS nconv=0 first unconverged value (error) -302.035 (2.54160196e-06)
159483 EPS nconv=0 first unconverged value (error) -302.035 (2.21478044e-06)
159484 EPS nconv=0 first unconverged value (error) -302.035 (2.11471408e-06)
159485 EPS nconv=0 first unconverged value (error) -302.035 (2.08391880e-06)
159486 EPS nconv=0 first unconverged value (error) -302.035 (2.04396258e-06)
159487 EPS nconv=0 first unconverged value (error) -302.035 (2.04396258e-06)
159488 EPS nconv=0 first unconverged value (error) -302.035 (2.08279205e-06)
159489 EPS nconv=0 first unconverged value (error) -302.035 (2.23674894e-06)
159490 EPS nconv=0 first unconverged value (error) -302.035 (1.97049072e-06)
159491 EPS nconv=0 first unconverged value (error) -302.035 (1.87798600e-06)
159492 EPS nconv=0 first unconverged value (error) -302.035 (1.86955182e-06)
159493 EPS nconv=0 first unconverged value (error) -302.035 (1.86955182e-06)
159494 EPS nconv=0 first unconverged value (error) -302.035 (2.76651707e-06)
159495 EPS nconv=0 first unconverged value (error) -302.035 (2.44035508e-06)
159496 EPS nconv=0 first unconverged value (error) -302.035 (2.31434460e-06)
159497 EPS nconv=0 first unconverged value (error) -302.035 (2.29341495e-06)
159498 EPS nconv=0 first unconverged value (error) -302.035 (2.23456714e-06)
159499 EPS nconv=0 first unconverged value (error) -302.035 (2.23456714e-06)
159500 EPS nconv=0 first unconverged value (error) -302.035 (2.59189940e-06)
159501 EPS nconv=0 first unconverged value (error) -302.035 (2.81871896e-06)
159502 EPS nconv=0 first unconverged value (error) -302.035 (2.40917088e-06)
159503 EPS nconv=0 first unconverged value (error) -302.035 (2.05494701e-06)
159504 EPS nconv=0 first unconverged value (error) -302.035 (1.99474814e-06)
159505 EPS nconv=0 first unconverged value (error) -302.035 (1.99474814e-06)
159506 EPS nconv=0 first unconverged value (error) -302.035 (2.38171973e-06)
159507 EPS nconv=0 first unconverged value (error) -302.035 (2.26127285e-06)
159508 EPS nconv=0 first unconverged value (error) -302.035 (2.13378019e-06)
159509 EPS nconv=0 first unconverged value (error) -302.035 (2.09300572e-06)
159510 EPS nconv=0 first unconverged value (error) -302.035 (2.04013176e-06)
159511 EPS nconv=0 first unconverged value (error) -302.035 (2.04013176e-06)
159512 EPS nconv=0 first unconverged value (error) -302.035 (2.18307801e-06)
159513 EPS nconv=0 first unconverged value (error) -302.035 (2.17217813e-06)
159514 EPS nconv=0 first unconverged value (error) -302.035 (1.97987953e-06)
159515 EPS nconv=0 first unconverged value (error) -302.035 (1.92962181e-06)
159516 EPS nconv=0 first unconverged value (error) -302.035 (1.90473246e-06)
159517 EPS nconv=0 first unconverged value (error) -302.035 (1.90473246e-06)
159518 EPS nconv=0 first unconverged value (error) -302.035 (3.31498678e-06)
159519 EPS nconv=0 first unconverged value (error) -302.035 (2.80426746e-06)
159520 EPS nconv=0 first unconverged value (error) -302.035 (2.62227921e-06)
159521 EPS nconv=0 first unconverged value (error) -302.035 (2.55070121e-06)
159522 EPS nconv=0 first unconverged value (error) -302.035 (2.49002954e-06)
159523 EPS nconv=0 first unconverged value (error) -302.035 (2.49002954e-06)
159524 EPS nconv=0 first unconverged value (error) -302.035 (2.45697743e-06)
159525 EPS nconv=0 first unconverged value (error) -302.035 (2.77050424e-06)
159526 EPS nconv=0 first unconverged value (error) -302.035 (2.20012212e-06)
159527 EPS nconv=0 first unconverged value (error) -302.035 (1.96990919e-06)
159528 EPS nconv=0 first unconverged value (error) -302.035 (1.89732540e-06)
159529 EPS nconv=0 first unconverged value (error) -302.035 (1.89732540e-06)
159530 EPS nconv=0 first unconverged value (error) -302.035 (2.62099145e-06)
159531 EPS nconv=0 first unconverged value (error) -302.035 (2.37075482e-06)
159532 EPS nconv=0 first unconverged value (error) -302.035 (2.26325068e-06)
159533 EPS nconv=0 first unconverged value (error) -302.035 (2.23819708e-06)
159534 EPS nconv=0 first unconverged value (error) -302.035 (2.16773042e-06)
159535 EPS nconv=0 first unconverged value (error) -302.035 (2.16773042e-06)
159536 EPS nconv=0 first unconverged value (error) -302.035 (2.45020309e-06)
159537 EPS nconv=0 first unconverged value (error) -302.035 (2.41860385e-06)
159538 EPS nconv=0 first unconverged value (error) -302.035 (2.15099385e-06)
159539 EPS nconv=0 first unconverged value (error) -302.035 (2.10724461e-06)
159540 EPS nconv=0 first unconverged value (error) -302.035 (2.09483112e-06)
159541 EPS nconv=0 first unconverged value (error) -302.035 (2.09483112e-06)
159542 EPS nconv=0 first unconverged value (error) -302.035 (4.05231544e-06)
159543 EPS nconv=0 first unconverged value (error) -302.035 (3.31948735e-06)
159544 EPS nconv=0 first unconverged value (error) -302.035 (2.90449244e-06)
159545 EPS nconv=0 first unconverged value (error) -302.035 (2.84030883e-06)
159546 EPS nconv=0 first unconverged value (error) -302.035 (2.74475080e-06)
159547 EPS nconv=0 first unconverged value (error) -302.035 (2.74475080e-06)
159548 EPS nconv=0 first unconverged value (error) -302.035 (2.76229607e-06)
159549 EPS nconv=0 first unconverged value (error) -302.035 (3.60257850e-06)
159550 EPS nconv=0 first unconverged value (error) -302.035 (2.78684672e-06)
159551 EPS nconv=0 first unconverged value (error) -302.035 (2.06459083e-06)
159552 EPS nconv=0 first unconverged value (error) -302.035 (1.93675113e-06)
159553 EPS nconv=0 first unconverged value (error) -302.035 (1.93675113e-06)
159554 EPS nconv=0 first unconverged value (error) -302.035 (2.57013519e-06)
159555 EPS nconv=0 first unconverged value (error) -302.035 (2.36940700e-06)
159556 EPS nconv=0 first unconverged value (error) -302.035 (2.28739702e-06)
159557 EPS nconv=0 first unconverged value (error) -302.035 (2.18971039e-06)
159558 EPS nconv=0 first unconverged value (error) -302.035 (2.11905132e-06)
159559 EPS nconv=0 first unconverged value (error) -302.035 (2.11905132e-06)
159560 EPS nconv=0 first unconverged value (error) -302.035 (2.34162064e-06)
159561 EPS nconv=0 first unconverged value (error) -302.035 (2.51284767e-06)
159562 EPS nconv=0 first unconverged value (error) -302.035 (2.26966789e-06)
159563 EPS nconv=0 first unconverged value (error) -302.035 (2.01385452e-06)
159564 EPS nconv=0 first unconverged value (error) -302.035 (1.97724732e-06)
159565 EPS nconv=0 first unconverged value (error) -302.035 (1.97724732e-06)
159566 EPS nconv=0 first unconverged value (error) -302.035 (2.55028011e-06)
159567 EPS nconv=0 first unconverged value (error) -302.035 (2.26411749e-06)
159568 EPS nconv=0 first unconverged value (error) -302.035 (2.15382290e-06)
159569 EPS nconv=0 first unconverged value (error) -302.035 (2.12444761e-06)
159570 EPS nconv=0 first unconverged value (error) -302.035 (2.08800995e-06)
159571 EPS nconv=0 first unconverged value (error) -302.035 (2.08800995e-06)
159572 EPS nconv=0 first unconverged value (error) -302.035 (2.51830031e-06)
159573 EPS nconv=0 first unconverged value (error) -302.035 (2.55118583e-06)
159574 EPS nconv=0 first unconverged value (error) -302.035 (2.26571832e-06)
159575 EPS nconv=0 first unconverged value (error) -302.035 (2.11722550e-06)
159576 EPS nconv=0 first unconverged value (error) -302.035 (2.05232713e-06)
159577 EPS nconv=0 first unconverged value (error) -302.035 (2.05232713e-06)
159578 EPS nconv=0 first unconverged value (error) -302.035 (2.27146367e-06)
159579 EPS nconv=0 first unconverged value (error) -302.035 (2.22861011e-06)
159580 EPS nconv=0 first unconverged value (error) -302.035 (2.05550428e-06)
159581 EPS nconv=0 first unconverged value (error) -302.035 (2.02413698e-06)
159582 EPS nconv=0 first unconverged value (error) -302.035 (1.97554302e-06)
159583 EPS nconv=0 first unconverged value (error) -302.035 (1.97554302e-06)
159584 EPS nconv=0 first unconverged value (error) -302.035 (2.49776068e-06)
159585 EPS nconv=0 first unconverged value (error) -302.035 (2.38873055e-06)
159586 EPS nconv=0 first unconverged value (error) -302.035 (2.21634360e-06)
159587 EPS nconv=0 first unconverged value (error) -302.035 (2.16334034e-06)
159588 EPS nconv=0 first unconverged value (error) -302.035 (2.11856662e-06)
159589 EPS nconv=0 first unconverged value (error) -302.035 (2.11856662e-06)
159590 EPS nconv=0 first unconverged value (error) -302.035 (2.70078602e-06)
159591 EPS nconv=0 first unconverged value (error) -302.035 (2.48630353e-06)
159592 EPS nconv=0 first unconverged value (error) -302.035 (2.26627976e-06)
159593 EPS nconv=0 first unconverged value (error) -302.035 (2.21805752e-06)
159594 EPS nconv=0 first unconverged value (error) -302.035 (2.13570896e-06)
159595 EPS nconv=0 first unconverged value (error) -302.035 (2.13570896e-06)
159596 EPS nconv=0 first unconverged value (error) -302.035 (2.33866170e-06)
159597 EPS nconv=0 first unconverged value (error) -302.035 (2.49498447e-06)
159598 EPS nconv=0 first unconverged value (error) -302.035 (2.17029093e-06)
159599 EPS nconv=0 first unconverged value (error) -302.035 (2.09596369e-06)
159600 EPS nconv=0 first unconverged value (error) -302.035 (2.02473146e-06)
159601 EPS nconv=0 first unconverged value (error) -302.035 (2.02473146e-06)
159602 EPS nconv=0 first unconverged value (error) -302.035 (2.01953250e-06)
159603 EPS nconv=0 first unconverged value (error) -302.035 (2.03188867e-06)
159604 EPS nconv=0 first unconverged value (error) -302.035 (1.94365473e-06)
159605 EPS nconv=0 first unconverged value (error) -302.035 (1.89310328e-06)
159606 EPS nconv=0 first unconverged value (error) -302.035 (1.87086718e-06)
159607 EPS nconv=0 first unconverged value (error) -302.035 (1.87086718e-06)
159608 EPS nconv=0 first unconverged value (error) -302.035 (1.89805825e-06)
159609 EPS nconv=0 first unconverged value (error) -302.035 (1.88685200e-06)
159610 EPS nconv=0 first unconverged value (error) -302.035 (1.85306141e-06)
159611 EPS nconv=0 first unconverged value (error) -302.035 (1.84009964e-06)
159612 EPS nconv=0 first unconverged value (error) -302.035 (1.83549861e-06)
159613 EPS nconv=0 first unconverged value (error) -302.035 (1.83549861e-06)
159614 EPS nconv=0 first unconverged value (error) -302.035 (2.86603052e-06)
159615 EPS nconv=0 first unconverged value (error) -302.035 (2.47354530e-06)
159616 EPS nconv=0 first unconverged value (error) -302.035 (2.34236977e-06)
159617 EPS nconv=0 first unconverged value (error) -302.035 (2.28975148e-06)
159618 EPS nconv=0 first unconverged value (error) -302.035 (2.20083693e-06)
159619 EPS nconv=0 first unconverged value (error) -302.035 (2.20083693e-06)
159620 EPS nconv=0 first unconverged value (error) -302.035 (2.38827257e-06)
159621 EPS nconv=0 first unconverged value (error) -302.035 (2.63282533e-06)
159622 EPS nconv=0 first unconverged value (error) -302.035 (2.19320691e-06)
159623 EPS nconv=0 first unconverged value (error) -302.035 (2.11914341e-06)
159624 EPS nconv=0 first unconverged value (error) -302.035 (2.03831374e-06)
159625 EPS nconv=0 first unconverged value (error) -302.035 (2.03831374e-06)
159626 EPS nconv=0 first unconverged value (error) -302.035 (2.10257712e-06)
159627 EPS nconv=0 first unconverged value (error) -302.035 (2.09371220e-06)
159628 EPS nconv=0 first unconverged value (error) -302.035 (1.99899782e-06)
159629 EPS nconv=0 first unconverged value (error) -302.035 (1.95111066e-06)
159630 EPS nconv=0 first unconverged value (error) -302.035 (1.91902677e-06)
159631 EPS nconv=0 first unconverged value (error) -302.035 (1.91902677e-06)
159632 EPS nconv=0 first unconverged value (error) -302.035 (1.92644864e-06)
159633 EPS nconv=0 first unconverged value (error) -302.035 (1.95321881e-06)
159634 EPS nconv=0 first unconverged value (error) -302.035 (1.90384578e-06)
159635 EPS nconv=0 first unconverged value (error) -302.035 (1.83700593e-06)
159636 EPS nconv=0 first unconverged value (error) -302.035 (1.82890319e-06)
159637 EPS nconv=0 first unconverged value (error) -302.035 (1.82890319e-06)
159638 EPS nconv=0 first unconverged value (error) -302.035 (2.56619862e-06)
159639 EPS nconv=0 first unconverged value (error) -302.035 (2.27745969e-06)
159640 EPS nconv=0 first unconverged value (error) -302.035 (2.18485715e-06)
159641 EPS nconv=0 first unconverged value (error) -302.035 (2.12720292e-06)
159642 EPS nconv=0 first unconverged value (error) -302.035 (2.06821144e-06)
159643 EPS nconv=0 first unconverged value (error) -302.035 (2.06821144e-06)
159644 EPS nconv=0 first unconverged value (error) -302.035 (2.36773785e-06)
159645 EPS nconv=0 first unconverged value (error) -302.035 (2.61523556e-06)
159646 EPS nconv=0 first unconverged value (error) -302.035 (2.30556187e-06)
159647 EPS nconv=0 first unconverged value (error) -302.035 (2.08120983e-06)
159648 EPS nconv=0 first unconverged value (error) -302.035 (2.01860273e-06)
159649 EPS nconv=0 first unconverged value (error) -302.035 (2.01860273e-06)
159650 EPS nconv=0 first unconverged value (error) -302.035 (1.99185189e-06)
159651 EPS nconv=0 first unconverged value (error) -302.035 (1.93332264e-06)
159652 EPS nconv=0 first unconverged value (error) -302.035 (1.84776685e-06)
159653 EPS nconv=0 first unconverged value (error) -302.035 (1.82731831e-06)
159654 EPS nconv=0 first unconverged value (error) -302.035 (1.81519601e-06)
159655 EPS nconv=0 first unconverged value (error) -302.035 (1.81519601e-06)
159656 EPS nconv=0 first unconverged value (error) -302.035 (1.96723107e-06)
159657 EPS nconv=0 first unconverged value (error) -302.035 (1.89949009e-06)
159658 EPS nconv=0 first unconverged value (error) -302.035 (1.86745990e-06)
159659 EPS nconv=0 first unconverged value (error) -302.035 (1.85710766e-06)
159660 EPS nconv=0 first unconverged value (error) -302.035 (1.85209904e-06)
159661 EPS nconv=0 first unconverged value (error) -302.035 (1.85209904e-06)
159662 EPS nconv=0 first unconverged value (error) -302.035 (1.97573974e-06)
159663 EPS nconv=0 first unconverged value (error) -302.035 (2.02823150e-06)
159664 EPS nconv=0 first unconverged value (error) -302.035 (1.92652250e-06)
159665 EPS nconv=0 first unconverged value (error) -302.035 (1.85515784e-06)
159666 EPS nconv=0 first unconverged value (error) -302.035 (1.84219649e-06)
159667 EPS nconv=0 first unconverged value (error) -302.035 (1.84219649e-06)
159668 EPS nconv=0 first unconverged value (error) -302.035 (2.07710618e-06)
159669 EPS nconv=0 first unconverged value (error) -302.035 (2.04172102e-06)
159670 EPS nconv=0 first unconverged value (error) -302.035 (1.99726083e-06)
159671 EPS nconv=0 first unconverged value (error) -302.035 (1.97769599e-06)
159672 EPS nconv=0 first unconverged value (error) -302.035 (1.93553434e-06)
159673 EPS nconv=0 first unconverged value (error) -302.035 (1.93553434e-06)
159674 EPS nconv=0 first unconverged value (error) -302.035 (2.31625442e-06)
159675 EPS nconv=0 first unconverged value (error) -302.035 (2.18353535e-06)
159676 EPS nconv=0 first unconverged value (error) -302.035 (2.05205028e-06)
159677 EPS nconv=0 first unconverged value (error) -302.035 (2.04222320e-06)
159678 EPS nconv=0 first unconverged value (error) -302.035 (2.01158293e-06)
159679 EPS nconv=0 first unconverged value (error) -302.035 (2.01158293e-06)
159680 EPS nconv=0 first unconverged value (error) -302.035 (2.08576099e-06)
159681 EPS nconv=0 first unconverged value (error) -302.035 (2.13760146e-06)
159682 EPS nconv=0 first unconverged value (error) -302.035 (2.01330843e-06)
159683 EPS nconv=0 first unconverged value (error) -302.035 (1.92808601e-06)
159684 EPS nconv=0 first unconverged value (error) -302.035 (1.87646526e-06)
159685 EPS nconv=0 first unconverged value (error) -302.035 (1.87646526e-06)
159686 EPS nconv=0 first unconverged value (error) -302.035 (2.26795777e-06)
159687 EPS nconv=0 first unconverged value (error) -302.035 (2.15437056e-06)
159688 EPS nconv=0 first unconverged value (error) -302.035 (2.07718804e-06)
159689 EPS nconv=0 first unconverged value (error) -302.035 (2.04044202e-06)
159690 EPS nconv=0 first unconverged value (error) -302.035 (1.99637978e-06)
159691 EPS nconv=0 first unconverged value (error) -302.035 (1.99637978e-06)
159692 EPS nconv=0 first unconverged value (error) -302.035 (2.51227185e-06)
159693 EPS nconv=0 first unconverged value (error) -302.035 (2.40402575e-06)
159694 EPS nconv=0 first unconverged value (error) -302.035 (2.24842924e-06)
159695 EPS nconv=0 first unconverged value (error) -302.035 (2.24383539e-06)
159696 EPS nconv=0 first unconverged value (error) -302.035 (2.19984319e-06)
159697 EPS nconv=0 first unconverged value (error) -302.035 (2.19984319e-06)
159698 EPS nconv=0 first unconverged value (error) -302.035 (2.23518752e-06)
159699 EPS nconv=0 first unconverged value (error) -302.035 (2.16104447e-06)
159700 EPS nconv=0 first unconverged value (error) -302.035 (2.01584870e-06)
159701 EPS nconv=0 first unconverged value (error) -302.035 (1.97928919e-06)
159702 EPS nconv=0 first unconverged value (error) -302.035 (1.90563786e-06)
159703 EPS nconv=0 first unconverged value (error) -302.035 (1.90563786e-06)
159704 EPS nconv=0 first unconverged value (error) -302.035 (1.88449303e-06)
159705 EPS nconv=0 first unconverged value (error) -302.035 (1.92595010e-06)
159706 EPS nconv=0 first unconverged value (error) -302.035 (1.88867320e-06)
159707 EPS nconv=0 first unconverged value (error) -302.035 (1.82808504e-06)
159708 EPS nconv=0 first unconverged value (error) -302.035 (1.81635440e-06)
159709 EPS nconv=0 first unconverged value (error) -302.035 (1.81635440e-06)
159710 EPS nconv=0 first unconverged value (error) -302.035 (2.60290771e-06)
159711 EPS nconv=0 first unconverged value (error) -302.035 (2.38381987e-06)
159712 EPS nconv=0 first unconverged value (error) -302.035 (2.31580754e-06)
159713 EPS nconv=0 first unconverged value (error) -302.035 (2.21023269e-06)
159714 EPS nconv=0 first unconverged value (error) -302.035 (2.14173488e-06)
159715 EPS nconv=0 first unconverged value (error) -302.035 (2.14173488e-06)
159716 EPS nconv=0 first unconverged value (error) -302.035 (2.23402582e-06)
159717 EPS nconv=0 first unconverged value (error) -302.035 (2.29417067e-06)
159718 EPS nconv=0 first unconverged value (error) -302.035 (2.05892895e-06)
159719 EPS nconv=0 first unconverged value (error) -302.035 (1.97837887e-06)
159720 EPS nconv=0 first unconverged value (error) -302.035 (1.96720050e-06)
159721 EPS nconv=0 first unconverged value (error) -302.035 (1.96720050e-06)
159722 EPS nconv=0 first unconverged value (error) -302.035 (1.95354777e-06)
159723 EPS nconv=0 first unconverged value (error) -302.035 (1.89787873e-06)
159724 EPS nconv=0 first unconverged value (error) -302.035 (1.88498075e-06)
159725 EPS nconv=0 first unconverged value (error) -302.035 (1.84956938e-06)
159726 EPS nconv=0 first unconverged value (error) -302.035 (1.83346680e-06)
159727 EPS nconv=0 first unconverged value (error) -302.035 (1.83346680e-06)
159728 EPS nconv=0 first unconverged value (error) -302.035 (1.86329134e-06)
159729 EPS nconv=0 first unconverged value (error) -302.035 (1.87163275e-06)
159730 EPS nconv=0 first unconverged value (error) -302.035 (1.84447414e-06)
159731 EPS nconv=0 first unconverged value (error) -302.035 (1.81720204e-06)
159732 EPS nconv=0 first unconverged value (error) -302.035 (1.81405762e-06)
159733 EPS nconv=0 first unconverged value (error) -302.035 (1.81405762e-06)
159734 EPS nconv=0 first unconverged value (error) -302.035 (2.49741437e-06)
159735 EPS nconv=0 first unconverged value (error) -302.035 (2.19826068e-06)
159736 EPS nconv=0 first unconverged value (error) -302.035 (2.15311334e-06)
159737 EPS nconv=0 first unconverged value (error) -302.035 (2.14515438e-06)
159738 EPS nconv=0 first unconverged value (error) -302.035 (2.12294078e-06)
159739 EPS nconv=0 first unconverged value (error) -302.035 (2.12294078e-06)
159740 EPS nconv=0 first unconverged value (error) -302.035 (2.71681332e-06)
159741 EPS nconv=0 first unconverged value (error) -302.035 (2.72793416e-06)
159742 EPS nconv=0 first unconverged value (error) -302.035 (2.33510527e-06)
159743 EPS nconv=0 first unconverged value (error) -302.035 (2.04811890e-06)
159744 EPS nconv=0 first unconverged value (error) -302.035 (2.02627159e-06)
159745 EPS nconv=0 first unconverged value (error) -302.035 (2.02627159e-06)
159746 EPS nconv=0 first unconverged value (error) -302.035 (2.13553785e-06)
159747 EPS nconv=0 first unconverged value (error) -302.035 (2.26153314e-06)
159748 EPS nconv=0 first unconverged value (error) -302.035 (2.04200159e-06)
159749 EPS nconv=0 first unconverged value (error) -302.035 (1.93400156e-06)
159750 EPS nconv=0 first unconverged value (error) -302.035 (1.87679516e-06)
159751 EPS nconv=0 first unconverged value (error) -302.035 (1.87679516e-06)
159752 EPS nconv=0 first unconverged value (error) -302.035 (1.87484048e-06)
159753 EPS nconv=0 first unconverged value (error) -302.035 (1.89930258e-06)
159754 EPS nconv=0 first unconverged value (error) -302.035 (1.85746644e-06)
159755 EPS nconv=0 first unconverged value (error) -302.035 (1.83966021e-06)
159756 EPS nconv=0 first unconverged value (error) -302.035 (1.82182868e-06)
159757 EPS nconv=0 first unconverged value (error) -302.035 (1.82182868e-06)
159758 EPS nconv=0 first unconverged value (error) -302.035 (1.93391985e-06)
159759 EPS nconv=0 first unconverged value (error) -302.035 (1.90060039e-06)
159760 EPS nconv=0 first unconverged value (error) -302.035 (1.86627533e-06)
159761 EPS nconv=0 first unconverged value (error) -302.035 (1.85094234e-06)
159762 EPS nconv=0 first unconverged value (error) -302.035 (1.84133301e-06)
159763 EPS nconv=0 first unconverged value (error) -302.035 (1.84133301e-06)
159764 EPS nconv=0 first unconverged value (error) -302.035 (2.62606080e-06)
159765 EPS nconv=0 first unconverged value (error) -302.035 (2.39186683e-06)
159766 EPS nconv=0 first unconverged value (error) -302.035 (2.21424849e-06)
159767 EPS nconv=0 first unconverged value (error) -302.035 (2.15106686e-06)
159768 EPS nconv=0 first unconverged value (error) -302.035 (2.11582386e-06)
159769 EPS nconv=0 first unconverged value (error) -302.035 (2.11582386e-06)
159770 EPS nconv=0 first unconverged value (error) -302.035 (2.14211139e-06)
159771 EPS nconv=0 first unconverged value (error) -302.035 (2.42581034e-06)
159772 EPS nconv=0 first unconverged value (error) -302.035 (2.14505082e-06)
159773 EPS nconv=0 first unconverged value (error) -302.035 (1.88354072e-06)
159774 EPS nconv=0 first unconverged value (error) -302.035 (1.85501946e-06)
159775 EPS nconv=0 first unconverged value (error) -302.035 (1.85501946e-06)
159776 EPS nconv=0 first unconverged value (error) -302.035 (1.90942084e-06)
159777 EPS nconv=0 first unconverged value (error) -302.035 (1.87778113e-06)
159778 EPS nconv=0 first unconverged value (error) -302.035 (1.85913620e-06)
159779 EPS nconv=0 first unconverged value (error) -302.035 (1.85314563e-06)
159780 EPS nconv=0 first unconverged value (error) -302.035 (1.84735288e-06)
159781 EPS nconv=0 first unconverged value (error) -302.035 (1.84735288e-06)
159782 EPS nconv=0 first unconverged value (error) -302.035 (1.98978351e-06)
159783 EPS nconv=0 first unconverged value (error) -302.035 (1.93366572e-06)
159784 EPS nconv=0 first unconverged value (error) -302.035 (1.87876941e-06)
159785 EPS nconv=0 first unconverged value (error) -302.035 (1.87421398e-06)
159786 EPS nconv=0 first unconverged value (error) -302.035 (1.86954478e-06)
159787 EPS nconv=0 first unconverged value (error) -302.035 (1.86954478e-06)
159788 EPS nconv=0 first unconverged value (error) -302.035 (2.41000880e-06)
159789 EPS nconv=0 first unconverged value (error) -302.035 (2.25584612e-06)
159790 EPS nconv=0 first unconverged value (error) -302.035 (2.09181973e-06)
159791 EPS nconv=0 first unconverged value (error) -302.035 (2.03789224e-06)
159792 EPS nconv=0 first unconverged value (error) -302.035 (2.00358296e-06)
159793 EPS nconv=0 first unconverged value (error) -302.035 (2.00358296e-06)
159794 EPS nconv=0 first unconverged value (error) -302.035 (2.00839856e-06)
159795 EPS nconv=0 first unconverged value (error) -302.035 (2.21753070e-06)
159796 EPS nconv=0 first unconverged value (error) -302.035 (2.00046143e-06)
159797 EPS nconv=0 first unconverged value (error) -302.035 (1.85193326e-06)
159798 EPS nconv=0 first unconverged value (error) -302.035 (1.83246326e-06)
159799 EPS nconv=0 first unconverged value (error) -302.035 (1.83246326e-06)
159800 EPS nconv=0 first unconverged value (error) -302.035 (1.86691068e-06)
159801 EPS nconv=0 first unconverged value (error) -302.035 (1.84916832e-06)
159802 EPS nconv=0 first unconverged value (error) -302.035 (1.84327399e-06)
159803 EPS nconv=0 first unconverged value (error) -302.035 (1.83603003e-06)
159804 EPS nconv=0 first unconverged value (error) -302.035 (1.82737587e-06)
159805 EPS nconv=0 first unconverged value (error) -302.035 (1.82737587e-06)
159806 EPS nconv=0 first unconverged value (error) -302.035 (1.84764968e-06)
159807 EPS nconv=0 first unconverged value (error) -302.035 (1.85870886e-06)
159808 EPS nconv=0 first unconverged value (error) -302.035 (1.82847223e-06)
159809 EPS nconv=0 first unconverged value (error) -302.035 (1.81629528e-06)
159810 EPS nconv=0 first unconverged value (error) -302.035 (1.80845143e-06)
159811 EPS nconv=0 first unconverged value (error) -302.035 (1.80845143e-06)
159812 EPS nconv=0 first unconverged value (error) -302.035 (2.41798466e-06)
159813 EPS nconv=0 first unconverged value (error) -302.035 (2.24519625e-06)
159814 EPS nconv=0 first unconverged value (error) -302.035 (2.10505392e-06)
159815 EPS nconv=0 first unconverged value (error) -302.035 (2.07514526e-06)
159816 EPS nconv=0 first unconverged value (error) -302.035 (2.03240519e-06)
159817 EPS nconv=0 first unconverged value (error) -302.035 (2.03240519e-06)
159818 EPS nconv=0 first unconverged value (error) -302.035 (2.18457094e-06)
159819 EPS nconv=0 first unconverged value (error) -302.035 (2.34980998e-06)
159820 EPS nconv=0 first unconverged value (error) -302.035 (2.20605602e-06)
159821 EPS nconv=0 first unconverged value (error) -302.035 (1.91943679e-06)
159822 EPS nconv=0 first unconverged value (error) -302.035 (1.88938175e-06)
159823 EPS nconv=0 first unconverged value (error) -302.035 (1.88938175e-06)
159824 EPS nconv=0 first unconverged value (error) -302.035 (1.87015836e-06)
159825 EPS nconv=0 first unconverged value (error) -302.035 (1.89877129e-06)
159826 EPS nconv=0 first unconverged value (error) -302.035 (1.85627119e-06)
159827 EPS nconv=0 first unconverged value (error) -302.035 (1.82382849e-06)
159828 EPS nconv=0 first unconverged value (error) -302.035 (1.81531509e-06)
159829 EPS nconv=0 first unconverged value (error) -302.035 (1.81531509e-06)
159830 EPS nconv=0 first unconverged value (error) -302.035 (1.89982638e-06)
159831 EPS nconv=0 first unconverged value (error) -302.035 (1.84485670e-06)
159832 EPS nconv=0 first unconverged value (error) -302.035 (1.83500868e-06)
159833 EPS nconv=0 first unconverged value (error) -302.035 (1.82836826e-06)
159834 EPS nconv=0 first unconverged value (error) -302.035 (1.82441186e-06)
159835 EPS nconv=0 first unconverged value (error) -302.035 (1.82441186e-06)
159836 EPS nconv=0 first unconverged value (error) -302.035 (2.25717572e-06)
159837 EPS nconv=0 first unconverged value (error) -302.035 (2.11917420e-06)
159838 EPS nconv=0 first unconverged value (error) -302.035 (2.00753356e-06)
159839 EPS nconv=0 first unconverged value (error) -302.035 (1.95146305e-06)
159840 EPS nconv=0 first unconverged value (error) -302.035 (1.93723314e-06)
159841 EPS nconv=0 first unconverged value (error) -302.035 (1.93723314e-06)
159842 EPS nconv=0 first unconverged value (error) -302.035 (2.04337746e-06)
159843 EPS nconv=0 first unconverged value (error) -302.035 (2.17183910e-06)
159844 EPS nconv=0 first unconverged value (error) -302.035 (1.98291520e-06)
159845 EPS nconv=0 first unconverged value (error) -302.035 (1.91104111e-06)
159846 EPS nconv=0 first unconverged value (error) -302.035 (1.85533782e-06)
159847 EPS nconv=0 first unconverged value (error) -302.035 (1.85533782e-06)
159848 EPS nconv=0 first unconverged value (error) -302.035 (1.98540010e-06)
159849 EPS nconv=0 first unconverged value (error) -302.035 (1.95173997e-06)
159850 EPS nconv=0 first unconverged value (error) -302.035 (1.91231193e-06)
159851 EPS nconv=0 first unconverged value (error) -302.035 (1.87630244e-06)
159852 EPS nconv=0 first unconverged value (error) -302.035 (1.85920954e-06)
159853 EPS nconv=0 first unconverged value (error) -302.035 (1.85920954e-06)
159854 EPS nconv=0 first unconverged value (error) -302.035 (1.99777361e-06)
159855 EPS nconv=0 first unconverged value (error) -302.035 (1.96345634e-06)
159856 EPS nconv=0 first unconverged value (error) -302.035 (1.89097207e-06)
159857 EPS nconv=0 first unconverged value (error) -302.035 (1.87743292e-06)
159858 EPS nconv=0 first unconverged value (error) -302.035 (1.86315763e-06)
159859 EPS nconv=0 first unconverged value (error) -302.035 (1.86315763e-06)
159860 EPS nconv=0 first unconverged value (error) -302.035 (2.24258037e-06)
159861 EPS nconv=0 first unconverged value (error) -302.035 (2.16173445e-06)
159862 EPS nconv=0 first unconverged value (error) -302.035 (2.01995165e-06)
159863 EPS nconv=0 first unconverged value (error) -302.035 (1.99422639e-06)
159864 EPS nconv=0 first unconverged value (error) -302.035 (1.95233893e-06)
159865 EPS nconv=0 first unconverged value (error) -302.035 (1.95233893e-06)
159866 EPS nconv=0 first unconverged value (error) -302.035 (2.41620001e-06)
159867 EPS nconv=0 first unconverged value (error) -302.035 (2.53839669e-06)
159868 EPS nconv=0 first unconverged value (error) -302.035 (2.34898648e-06)
159869 EPS nconv=0 first unconverged value (error) -302.035 (2.11528312e-06)
159870 EPS nconv=0 first unconverged value (error) -302.035 (2.05437970e-06)
159871 EPS nconv=0 first unconverged value (error) -302.035 (2.05437970e-06)
159872 EPS nconv=0 first unconverged value (error) -302.035 (2.06816046e-06)
159873 EPS nconv=0 first unconverged value (error) -302.035 (2.05516952e-06)
159874 EPS nconv=0 first unconverged value (error) -302.035 (2.00973805e-06)
159875 EPS nconv=0 first unconverged value (error) -302.035 (1.90490828e-06)
159876 EPS nconv=0 first unconverged value (error) -302.035 (1.86283623e-06)
159877 EPS nconv=0 first unconverged value (error) -302.035 (1.86283623e-06)
159878 EPS nconv=0 first unconverged value (error) -302.035 (1.92839697e-06)
159879 EPS nconv=0 first unconverged value (error) -302.035 (1.88704440e-06)
159880 EPS nconv=0 first unconverged value (error) -302.035 (1.86853697e-06)
159881 EPS nconv=0 first unconverged value (error) -302.035 (1.85609804e-06)
159882 EPS nconv=0 first unconverged value (error) -302.035 (1.84631829e-06)
159883 EPS nconv=0 first unconverged value (error) -302.035 (1.84631829e-06)
159884 EPS nconv=0 first unconverged value (error) -302.035 (2.29300209e-06)
159885 EPS nconv=0 first unconverged value (error) -302.035 (2.12371884e-06)
159886 EPS nconv=0 first unconverged value (error) -302.035 (2.00764919e-06)
159887 EPS nconv=0 first unconverged value (error) -302.035 (1.97736900e-06)
159888 EPS nconv=0 first unconverged value (error) -302.035 (1.95411729e-06)
159889 EPS nconv=0 first unconverged value (error) -302.035 (1.95411729e-06)
159890 EPS nconv=0 first unconverged value (error) -302.035 (2.24471017e-06)
159891 EPS nconv=0 first unconverged value (error) -302.035 (2.40326731e-06)
159892 EPS nconv=0 first unconverged value (error) -302.035 (2.21159300e-06)
159893 EPS nconv=0 first unconverged value (error) -302.035 (1.98298731e-06)
159894 EPS nconv=0 first unconverged value (error) -302.035 (1.94459431e-06)
159895 EPS nconv=0 first unconverged value (error) -302.035 (1.94459431e-06)
159896 EPS nconv=0 first unconverged value (error) -302.035 (1.99756894e-06)
159897 EPS nconv=0 first unconverged value (error) -302.035 (1.99343366e-06)
159898 EPS nconv=0 first unconverged value (error) -302.035 (1.93269894e-06)
159899 EPS nconv=0 first unconverged value (error) -302.035 (1.87817605e-06)
159900 EPS nconv=0 first unconverged value (error) -302.035 (1.84241439e-06)
159901 EPS nconv=0 first unconverged value (error) -302.035 (1.84241439e-06)
159902 EPS nconv=0 first unconverged value (error) -302.035 (1.90250897e-06)
159903 EPS nconv=0 first unconverged value (error) -302.035 (1.85980245e-06)
159904 EPS nconv=0 first unconverged value (error) -302.035 (1.83811214e-06)
159905 EPS nconv=0 first unconverged value (error) -302.035 (1.82636758e-06)
159906 EPS nconv=0 first unconverged value (error) -302.035 (1.82023442e-06)
159907 EPS nconv=0 first unconverged value (error) -302.035 (1.82023442e-06)
159908 EPS nconv=0 first unconverged value (error) -302.035 (2.31937442e-06)
159909 EPS nconv=0 first unconverged value (error) -302.035 (2.18138215e-06)
159910 EPS nconv=0 first unconverged value (error) -302.035 (2.06685775e-06)
159911 EPS nconv=0 first unconverged value (error) -302.035 (2.02915476e-06)
159912 EPS nconv=0 first unconverged value (error) -302.035 (1.98062601e-06)
159913 EPS nconv=0 first unconverged value (error) -302.035 (1.98062601e-06)
159914 EPS nconv=0 first unconverged value (error) -302.035 (2.35925117e-06)
159915 EPS nconv=0 first unconverged value (error) -302.035 (2.36522607e-06)
159916 EPS nconv=0 first unconverged value (error) -302.035 (2.16413940e-06)
159917 EPS nconv=0 first unconverged value (error) -302.035 (2.11925831e-06)
159918 EPS nconv=0 first unconverged value (error) -302.035 (2.08219215e-06)
159919 EPS nconv=0 first unconverged value (error) -302.035 (2.08219215e-06)
159920 EPS nconv=0 first unconverged value (error) -302.035 (2.06060696e-06)
159921 EPS nconv=0 first unconverged value (error) -302.035 (2.05464802e-06)
159922 EPS nconv=0 first unconverged value (error) -302.035 (2.00252600e-06)
159923 EPS nconv=0 first unconverged value (error) -302.035 (1.88246398e-06)
159924 EPS nconv=0 first unconverged value (error) -302.035 (1.82595010e-06)
159925 EPS nconv=0 first unconverged value (error) -302.035 (1.82595010e-06)
159926 EPS nconv=0 first unconverged value (error) -302.035 (2.09960100e-06)
159927 EPS nconv=0 first unconverged value (error) -302.035 (2.06898566e-06)
159928 EPS nconv=0 first unconverged value (error) -302.035 (2.02416633e-06)
159929 EPS nconv=0 first unconverged value (error) -302.035 (1.96949371e-06)
159930 EPS nconv=0 first unconverged value (error) -302.035 (1.95160961e-06)
159931 EPS nconv=0 first unconverged value (error) -302.035 (1.95160961e-06)
159932 EPS nconv=0 first unconverged value (error) -302.035 (2.15264348e-06)
159933 EPS nconv=0 first unconverged value (error) -302.035 (2.10186796e-06)
159934 EPS nconv=0 first unconverged value (error) -302.035 (2.03329236e-06)
159935 EPS nconv=0 first unconverged value (error) -302.035 (2.00714224e-06)
159936 EPS nconv=0 first unconverged value (error) -302.035 (1.95995287e-06)
159937 EPS nconv=0 first unconverged value (error) -302.035 (1.95995287e-06)
159938 EPS nconv=0 first unconverged value (error) -302.035 (1.98069791e-06)
159939 EPS nconv=0 first unconverged value (error) -302.035 (1.99137176e-06)
159940 EPS nconv=0 first unconverged value (error) -302.035 (1.91754533e-06)
159941 EPS nconv=0 first unconverged value (error) -302.035 (1.83457193e-06)
159942 EPS nconv=0 first unconverged value (error) -302.035 (1.82434861e-06)
159943 EPS nconv=0 first unconverged value (error) -302.035 (1.82434861e-06)
159944 EPS nconv=0 first unconverged value (error) -302.035 (1.82130538e-06)
159945 EPS nconv=0 first unconverged value (error) -302.035 (1.82853557e-06)
159946 EPS nconv=0 first unconverged value (error) -302.035 (1.81893626e-06)
159947 EPS nconv=0 first unconverged value (error) -302.035 (1.80171275e-06)
159948 EPS nconv=0 first unconverged value (error) -302.035 (1.79783218e-06)
159949 EPS nconv=0 first unconverged value (error) -302.035 (1.79783218e-06)
159950 EPS nconv=0 first unconverged value (error) -302.035 (2.01694223e-06)
159951 EPS nconv=0 first unconverged value (error) -302.035 (1.93252235e-06)
159952 EPS nconv=0 first unconverged value (error) -302.035 (1.92455051e-06)
159953 EPS nconv=0 first unconverged value (error) -302.035 (1.90907273e-06)
159954 EPS nconv=0 first unconverged value (error) -302.035 (1.88797859e-06)
159955 EPS nconv=0 first unconverged value (error) -302.035 (1.88797859e-06)
159956 EPS nconv=0 first unconverged value (error) -302.035 (1.88766435e-06)
159957 EPS nconv=0 first unconverged value (error) -302.035 (1.94299337e-06)
159958 EPS nconv=0 first unconverged value (error) -302.035 (1.85135004e-06)
159959 EPS nconv=0 first unconverged value (error) -302.035 (1.82055038e-06)
159960 EPS nconv=0 first unconverged value (error) -302.035 (1.81476682e-06)
159961 EPS nconv=0 first unconverged value (error) -302.035 (1.81476682e-06)
159962 EPS nconv=0 first unconverged value (error) -302.035 (1.82253765e-06)
159963 EPS nconv=0 first unconverged value (error) -302.035 (1.81055139e-06)
159964 EPS nconv=0 first unconverged value (error) -302.035 (1.80693506e-06)
159965 EPS nconv=0 first unconverged value (error) -302.035 (1.80571155e-06)
159966 EPS nconv=0 first unconverged value (error) -302.035 (1.80382228e-06)
159967 EPS nconv=0 first unconverged value (error) -302.035 (1.80382228e-06)
159968 EPS nconv=0 first unconverged value (error) -302.035 (1.99679996e-06)
159969 EPS nconv=0 first unconverged value (error) -302.035 (1.94196877e-06)
159970 EPS nconv=0 first unconverged value (error) -302.035 (1.88518613e-06)
159971 EPS nconv=0 first unconverged value (error) -302.035 (1.88586877e-06)
159972 EPS nconv=0 first unconverged value (error) -302.035 (1.87055873e-06)
159973 EPS nconv=0 first unconverged value (error) -302.035 (1.87055873e-06)
159974 EPS nconv=0 first unconverged value (error) -302.035 (1.92829349e-06)
159975 EPS nconv=0 first unconverged value (error) -302.035 (2.00481917e-06)
159976 EPS nconv=0 first unconverged value (error) -302.035 (1.93321887e-06)
159977 EPS nconv=0 first unconverged value (error) -302.035 (1.83346071e-06)
159978 EPS nconv=0 first unconverged value (error) -302.035 (1.82796449e-06)
159979 EPS nconv=0 first unconverged value (error) -302.035 (1.82796449e-06)
159980 EPS nconv=0 first unconverged value (error) -302.035 (1.95782686e-06)
159981 EPS nconv=0 first unconverged value (error) -302.035 (1.88621351e-06)
159982 EPS nconv=0 first unconverged value (error) -302.035 (1.87565164e-06)
159983 EPS nconv=0 first unconverged value (error) -302.035 (1.86186715e-06)
159984 EPS nconv=0 first unconverged value (error) -302.035 (1.85312721e-06)
159985 EPS nconv=0 first unconverged value (error) -302.035 (1.85312721e-06)
159986 EPS nconv=0 first unconverged value (error) -302.035 (1.98456887e-06)
159987 EPS nconv=0 first unconverged value (error) -302.035 (1.96601215e-06)
159988 EPS nconv=0 first unconverged value (error) -302.035 (1.87006103e-06)
159989 EPS nconv=0 first unconverged value (error) -302.035 (1.86850569e-06)
159990 EPS nconv=0 first unconverged value (error) -302.035 (1.85111386e-06)
159991 EPS nconv=0 first unconverged value (error) -302.035 (1.85111386e-06)
159992 EPS nconv=0 first unconverged value (error) -302.035 (1.85128167e-06)
159993 EPS nconv=0 first unconverged value (error) -302.035 (1.90703867e-06)
159994 EPS nconv=0 first unconverged value (error) -302.035 (1.83674613e-06)
159995 EPS nconv=0 first unconverged value (error) -302.035 (1.81569031e-06)
159996 EPS nconv=0 first unconverged value (error) -302.035 (1.80638797e-06)
159997 EPS nconv=0 first unconverged value (error) -302.035 (1.80638797e-06)
159998 EPS nconv=0 first unconverged value (error) -302.035 (1.83048438e-06)
159999 EPS nconv=0 first unconverged value (error) -302.035 (1.81758625e-06)
160000 EPS nconv=0 first unconverged value (error) -302.035 (1.81406220e-06)
160001 EPS nconv=0 first unconverged value (error) -302.035 (1.81002677e-06)
160002 EPS nconv=0 first unconverged value (error) -302.035 (1.80676970e-06)
160003 EPS nconv=0 first unconverged value (error) -302.035 (1.80676970e-06)
160004 EPS nconv=0 first unconverged value (error) -302.035 (2.00679873e-06)
160005 EPS nconv=0 first unconverged value (error) -302.035 (1.94210359e-06)
160006 EPS nconv=0 first unconverged value (error) -302.035 (1.90674993e-06)
160007 EPS nconv=0 first unconverged value (error) -302.035 (1.87848431e-06)
160008 EPS nconv=0 first unconverged value (error) -302.035 (1.86799848e-06)
160009 EPS nconv=0 first unconverged value (error) -302.035 (1.86799848e-06)
160010 EPS nconv=0 first unconverged value (error) -302.035 (2.04145799e-06)
160011 EPS nconv=0 first unconverged value (error) -302.035 (1.99589516e-06)
160012 EPS nconv=0 first unconverged value (error) -302.035 (1.90936151e-06)
160013 EPS nconv=0 first unconverged value (error) -302.035 (1.89787522e-06)
160014 EPS nconv=0 first unconverged value (error) -302.035 (1.87730987e-06)
160015 EPS nconv=0 first unconverged value (error) -302.035 (1.87730987e-06)
160016 EPS nconv=0 first unconverged value (error) -302.035 (1.89442396e-06)
160017 EPS nconv=0 first unconverged value (error) -302.035 (1.93969564e-06)
160018 EPS nconv=0 first unconverged value (error) -302.035 (1.84904512e-06)
160019 EPS nconv=0 first unconverged value (error) -302.035 (1.83476780e-06)
160020 EPS nconv=0 first unconverged value (error) -302.035 (1.81740920e-06)
160021 EPS nconv=0 first unconverged value (error) -302.035 (1.81740920e-06)
160022 EPS nconv=0 first unconverged value (error) -302.035 (1.88908442e-06)
160023 EPS nconv=0 first unconverged value (error) -302.035 (1.85684129e-06)
160024 EPS nconv=0 first unconverged value (error) -302.035 (1.83631588e-06)
160025 EPS nconv=0 first unconverged value (error) -302.035 (1.83390012e-06)
160026 EPS nconv=0 first unconverged value (error) -302.035 (1.82595182e-06)
160027 EPS nconv=0 first unconverged value (error) -302.035 (1.82595182e-06)
160028 EPS nconv=0 first unconverged value (error) -302.035 (1.87871955e-06)
160029 EPS nconv=0 first unconverged value (error) -302.035 (1.89408148e-06)
160030 EPS nconv=0 first unconverged value (error) -302.035 (1.85579051e-06)
160031 EPS nconv=0 first unconverged value (error) -302.035 (1.82726875e-06)
160032 EPS nconv=0 first unconverged value (error) -302.035 (1.82293809e-06)
160033 EPS nconv=0 first unconverged value (error) -302.035 (1.82293809e-06)
160034 EPS nconv=0 first unconverged value (error) -302.035 (2.02626671e-06)
160035 EPS nconv=0 first unconverged value (error) -302.035 (1.94178741e-06)
160036 EPS nconv=0 first unconverged value (error) -302.035 (1.91778518e-06)
160037 EPS nconv=0 first unconverged value (error) -302.035 (1.89722966e-06)
160038 EPS nconv=0 first unconverged value (error) -302.035 (1.87549177e-06)
160039 EPS nconv=0 first unconverged value (error) -302.035 (1.87549177e-06)
160040 EPS nconv=0 first unconverged value (error) -302.035 (1.89014472e-06)
160041 EPS nconv=0 first unconverged value (error) -302.035 (1.93557970e-06)
160042 EPS nconv=0 first unconverged value (error) -302.035 (1.85049247e-06)
160043 EPS nconv=0 first unconverged value (error) -302.035 (1.83233167e-06)
160044 EPS nconv=0 first unconverged value (error) -302.035 (1.82077684e-06)
160045 EPS nconv=0 first unconverged value (error) -302.035 (1.82077684e-06)
160046 EPS nconv=0 first unconverged value (error) -302.035 (1.84038089e-06)
160047 EPS nconv=0 first unconverged value (error) -302.035 (1.83084994e-06)
160048 EPS nconv=0 first unconverged value (error) -302.035 (1.81681925e-06)
160049 EPS nconv=0 first unconverged value (error) -302.035 (1.81224384e-06)
160050 EPS nconv=0 first unconverged value (error) -302.035 (1.80768486e-06)
160051 EPS nconv=0 first unconverged value (error) -302.035 (1.80768486e-06)
160052 EPS nconv=0 first unconverged value (error) -302.035 (2.18576909e-06)
160053 EPS nconv=0 first unconverged value (error) -302.035 (2.07593715e-06)
160054 EPS nconv=0 first unconverged value (error) -302.035 (2.01617657e-06)
160055 EPS nconv=0 first unconverged value (error) -302.035 (1.99135732e-06)
160056 EPS nconv=0 first unconverged value (error) -302.035 (1.96023167e-06)
160057 EPS nconv=0 first unconverged value (error) -302.035 (1.96023167e-06)
160058 EPS nconv=0 first unconverged value (error) -302.035 (2.34185722e-06)
160059 EPS nconv=0 first unconverged value (error) -302.035 (2.22096035e-06)
160060 EPS nconv=0 first unconverged value (error) -302.035 (2.06092570e-06)
160061 EPS nconv=0 first unconverged value (error) -302.035 (2.02416762e-06)
160062 EPS nconv=0 first unconverged value (error) -302.035 (2.01561088e-06)
160063 EPS nconv=0 first unconverged value (error) -302.035 (2.01561088e-06)
160064 EPS nconv=0 first unconverged value (error) -302.035 (2.00452894e-06)
160065 EPS nconv=0 first unconverged value (error) -302.035 (2.07764592e-06)
160066 EPS nconv=0 first unconverged value (error) -302.035 (1.93041588e-06)
160067 EPS nconv=0 first unconverged value (error) -302.035 (1.88182011e-06)
160068 EPS nconv=0 first unconverged value (error) -302.035 (1.84877289e-06)
160069 EPS nconv=0 first unconverged value (error) -302.035 (1.84877289e-06)
160070 EPS nconv=0 first unconverged value (error) -302.035 (1.97667443e-06)
160071 EPS nconv=0 first unconverged value (error) -302.035 (1.93647469e-06)
160072 EPS nconv=0 first unconverged value (error) -302.035 (1.87994904e-06)
160073 EPS nconv=0 first unconverged value (error) -302.035 (1.87690153e-06)
160074 EPS nconv=0 first unconverged value (error) -302.035 (1.85876381e-06)
160075 EPS nconv=0 first unconverged value (error) -302.035 (1.85876381e-06)
160076 EPS nconv=0 first unconverged value (error) -302.035 (2.16609567e-06)
160077 EPS nconv=0 first unconverged value (error) -302.035 (2.23433402e-06)
160078 EPS nconv=0 first unconverged value (error) -302.035 (2.14056620e-06)
160079 EPS nconv=0 first unconverged value (error) -302.035 (1.96942521e-06)
160080 EPS nconv=0 first unconverged value (error) -302.035 (1.94471956e-06)
160081 EPS nconv=0 first unconverged value (error) -302.035 (1.94471956e-06)
160082 EPS nconv=0 first unconverged value (error) -302.035 (2.20558309e-06)
160083 EPS nconv=0 first unconverged value (error) -302.035 (2.13256795e-06)
160084 EPS nconv=0 first unconverged value (error) -302.035 (2.07415044e-06)
160085 EPS nconv=0 first unconverged value (error) -302.035 (1.99925230e-06)
160086 EPS nconv=0 first unconverged value (error) -302.035 (1.96058520e-06)
160087 EPS nconv=0 first unconverged value (error) -302.035 (1.96058520e-06)
160088 EPS nconv=0 first unconverged value (error) -302.035 (2.15902234e-06)
160089 EPS nconv=0 first unconverged value (error) -302.035 (2.06148199e-06)
160090 EPS nconv=0 first unconverged value (error) -302.035 (1.94586144e-06)
160091 EPS nconv=0 first unconverged value (error) -302.035 (1.91197775e-06)
160092 EPS nconv=0 first unconverged value (error) -302.035 (1.88185655e-06)
160093 EPS nconv=0 first unconverged value (error) -302.035 (1.88185655e-06)
160094 EPS nconv=0 first unconverged value (error) -302.035 (2.02649360e-06)
160095 EPS nconv=0 first unconverged value (error) -302.035 (2.00477998e-06)
160096 EPS nconv=0 first unconverged value (error) -302.035 (1.90589248e-06)
160097 EPS nconv=0 first unconverged value (error) -302.035 (1.86973332e-06)
160098 EPS nconv=0 first unconverged value (error) -302.035 (1.86076406e-06)
160099 EPS nconv=0 first unconverged value (error) -302.035 (1.86076406e-06)
160100 EPS nconv=0 first unconverged value (error) -302.035 (2.01771602e-06)
160101 EPS nconv=0 first unconverged value (error) -302.035 (1.97073833e-06)
160102 EPS nconv=0 first unconverged value (error) -302.035 (1.90898912e-06)
160103 EPS nconv=0 first unconverged value (error) -302.035 (1.88428267e-06)
160104 EPS nconv=0 first unconverged value (error) -302.035 (1.85974431e-06)
160105 EPS nconv=0 first unconverged value (error) -302.035 (1.85974431e-06)
160106 EPS nconv=0 first unconverged value (error) -302.035 (1.87081948e-06)
160107 EPS nconv=0 first unconverged value (error) -302.035 (1.90452070e-06)
160108 EPS nconv=0 first unconverged value (error) -302.035 (1.83261346e-06)
160109 EPS nconv=0 first unconverged value (error) -302.035 (1.82279798e-06)
160110 EPS nconv=0 first unconverged value (error) -302.035 (1.81819480e-06)
160111 EPS nconv=0 first unconverged value (error) -302.035 (1.81819480e-06)
160112 EPS nconv=0 first unconverged value (error) -302.035 (1.97910496e-06)
160113 EPS nconv=0 first unconverged value (error) -302.035 (1.90896134e-06)
160114 EPS nconv=0 first unconverged value (error) -302.035 (1.87148982e-06)
160115 EPS nconv=0 first unconverged value (error) -302.035 (1.86809502e-06)
160116 EPS nconv=0 first unconverged value (error) -302.035 (1.85664836e-06)
160117 EPS nconv=0 first unconverged value (error) -302.035 (1.85664836e-06)
160118 EPS nconv=0 first unconverged value (error) -302.035 (2.21133984e-06)
160119 EPS nconv=0 first unconverged value (error) -302.035 (2.10429157e-06)
160120 EPS nconv=0 first unconverged value (error) -302.035 (1.99130324e-06)
160121 EPS nconv=0 first unconverged value (error) -302.035 (1.97684931e-06)
160122 EPS nconv=0 first unconverged value (error) -302.035 (1.94989933e-06)
160123 EPS nconv=0 first unconverged value (error) -302.035 (1.94989933e-06)
160124 EPS nconv=0 first unconverged value (error) -302.035 (2.44990164e-06)
160125 EPS nconv=0 first unconverged value (error) -302.035 (2.31937721e-06)
160126 EPS nconv=0 first unconverged value (error) -302.035 (2.13541190e-06)
160127 EPS nconv=0 first unconverged value (error) -302.035 (2.10836746e-06)
160128 EPS nconv=0 first unconverged value (error) -302.035 (2.08610212e-06)
160129 EPS nconv=0 first unconverged value (error) -302.035 (2.08610212e-06)
160130 EPS nconv=0 first unconverged value (error) -302.035 (2.20169727e-06)
160131 EPS nconv=0 first unconverged value (error) -302.035 (2.24245746e-06)
160132 EPS nconv=0 first unconverged value (error) -302.035 (2.03718659e-06)
160133 EPS nconv=0 first unconverged value (error) -302.035 (1.97028804e-06)
160134 EPS nconv=0 first unconverged value (error) -302.035 (1.93492470e-06)
160135 EPS nconv=0 first unconverged value (error) -302.035 (1.93492470e-06)
160136 EPS nconv=0 first unconverged value (error) -302.035 (2.22188293e-06)
160137 EPS nconv=0 first unconverged value (error) -302.035 (2.08434617e-06)
160138 EPS nconv=0 first unconverged value (error) -302.035 (1.97620743e-06)
160139 EPS nconv=0 first unconverged value (error) -302.035 (1.94228283e-06)
160140 EPS nconv=0 first unconverged value (error) -302.035 (1.93546512e-06)
160141 EPS nconv=0 first unconverged value (error) -302.035 (1.93546512e-06)
160142 EPS nconv=0 first unconverged value (error) -302.035 (1.92752701e-06)
160143 EPS nconv=0 first unconverged value (error) -302.035 (2.03353517e-06)
160144 EPS nconv=0 first unconverged value (error) -302.035 (1.88942504e-06)
160145 EPS nconv=0 first unconverged value (error) -302.035 (1.84918516e-06)
160146 EPS nconv=0 first unconverged value (error) -302.035 (1.83575131e-06)
160147 EPS nconv=0 first unconverged value (error) -302.035 (1.83575131e-06)
160148 EPS nconv=0 first unconverged value (error) -302.035 (1.96523383e-06)
160149 EPS nconv=0 first unconverged value (error) -302.035 (1.90095319e-06)
160150 EPS nconv=0 first unconverged value (error) -302.035 (1.87667709e-06)
160151 EPS nconv=0 first unconverged value (error) -302.035 (1.87119842e-06)
160152 EPS nconv=0 first unconverged value (error) -302.035 (1.85676395e-06)
160153 EPS nconv=0 first unconverged value (error) -302.035 (1.85676395e-06)
160154 EPS nconv=0 first unconverged value (error) -302.035 (1.93068060e-06)
160155 EPS nconv=0 first unconverged value (error) -302.035 (1.91768941e-06)
160156 EPS nconv=0 first unconverged value (error) -302.035 (1.86336981e-06)
160157 EPS nconv=0 first unconverged value (error) -302.035 (1.86442231e-06)
160158 EPS nconv=0 first unconverged value (error) -302.035 (1.84068808e-06)
160159 EPS nconv=0 first unconverged value (error) -302.035 (1.84068808e-06)
160160 EPS nconv=0 first unconverged value (error) -302.035 (2.42737812e-06)
160161 EPS nconv=0 first unconverged value (error) -302.035 (2.25912261e-06)
160162 EPS nconv=0 first unconverged value (error) -302.035 (2.10742515e-06)
160163 EPS nconv=0 first unconverged value (error) -302.035 (2.09110163e-06)
160164 EPS nconv=0 first unconverged value (error) -302.035 (2.03552223e-06)
160165 EPS nconv=0 first unconverged value (error) -302.035 (2.03552223e-06)
160166 EPS nconv=0 first unconverged value (error) -302.035 (2.20651823e-06)
160167 EPS nconv=0 first unconverged value (error) -302.035 (2.25909987e-06)
160168 EPS nconv=0 first unconverged value (error) -302.035 (2.06363297e-06)
160169 EPS nconv=0 first unconverged value (error) -302.035 (1.98099029e-06)
160170 EPS nconv=0 first unconverged value (error) -302.035 (1.96002442e-06)
160171 EPS nconv=0 first unconverged value (error) -302.035 (1.96002442e-06)
160172 EPS nconv=0 first unconverged value (error) -302.035 (2.12531100e-06)
160173 EPS nconv=0 first unconverged value (error) -302.035 (2.07775928e-06)
160174 EPS nconv=0 first unconverged value (error) -302.035 (1.96905414e-06)
160175 EPS nconv=0 first unconverged value (error) -302.035 (1.93820520e-06)
160176 EPS nconv=0 first unconverged value (error) -302.035 (1.91786283e-06)
160177 EPS nconv=0 first unconverged value (error) -302.035 (1.91786283e-06)
160178 EPS nconv=0 first unconverged value (error) -302.035 (1.94346165e-06)
160179 EPS nconv=0 first unconverged value (error) -302.035 (2.00051348e-06)
160180 EPS nconv=0 first unconverged value (error) -302.035 (1.89325259e-06)
160181 EPS nconv=0 first unconverged value (error) -302.035 (1.85712139e-06)
160182 EPS nconv=0 first unconverged value (error) -302.035 (1.83886737e-06)
160183 EPS nconv=0 first unconverged value (error) -302.035 (1.83886737e-06)
160184 EPS nconv=0 first unconverged value (error) -302.035 (1.95661359e-06)
160185 EPS nconv=0 first unconverged value (error) -302.035 (1.92926429e-06)
160186 EPS nconv=0 first unconverged value (error) -302.035 (1.87642576e-06)
160187 EPS nconv=0 first unconverged value (error) -302.035 (1.86509916e-06)
160188 EPS nconv=0 first unconverged value (error) -302.035 (1.84747779e-06)
160189 EPS nconv=0 first unconverged value (error) -302.035 (1.84747779e-06)
160190 EPS nconv=0 first unconverged value (error) -302.035 (1.87299022e-06)
160191 EPS nconv=0 first unconverged value (error) -302.035 (1.90135573e-06)
160192 EPS nconv=0 first unconverged value (error) -302.035 (1.84840295e-06)
160193 EPS nconv=0 first unconverged value (error) -302.035 (1.82599003e-06)
160194 EPS nconv=0 first unconverged value (error) -302.035 (1.82352216e-06)
160195 EPS nconv=0 first unconverged value (error) -302.035 (1.82352216e-06)
160196 EPS nconv=0 first unconverged value (error) -302.035 (1.87717516e-06)
160197 EPS nconv=0 first unconverged value (error) -302.035 (1.85414652e-06)
160198 EPS nconv=0 first unconverged value (error) -302.035 (1.83415655e-06)
160199 EPS nconv=0 first unconverged value (error) -302.035 (1.83174199e-06)
160200 EPS nconv=0 first unconverged value (error) -302.035 (1.82528105e-06)
160201 EPS nconv=0 first unconverged value (error) -302.035 (1.82528105e-06)
160202 EPS nconv=0 first unconverged value (error) -302.035 (1.89783048e-06)
160203 EPS nconv=0 first unconverged value (error) -302.035 (1.88100088e-06)
160204 EPS nconv=0 first unconverged value (error) -302.035 (1.84516318e-06)
160205 EPS nconv=0 first unconverged value (error) -302.035 (1.83377196e-06)
160206 EPS nconv=0 first unconverged value (error) -302.035 (1.82178671e-06)
160207 EPS nconv=0 first unconverged value (error) -302.035 (1.82178671e-06)
160208 EPS nconv=0 first unconverged value (error) -302.035 (2.10094555e-06)
160209 EPS nconv=0 first unconverged value (error) -302.035 (2.02683619e-06)
160210 EPS nconv=0 first unconverged value (error) -302.035 (1.94633249e-06)
160211 EPS nconv=0 first unconverged value (error) -302.035 (1.92837580e-06)
160212 EPS nconv=0 first unconverged value (error) -302.035 (1.89960472e-06)
160213 EPS nconv=0 first unconverged value (error) -302.035 (1.89960472e-06)
160214 EPS nconv=0 first unconverged value (error) -302.035 (1.92141055e-06)
160215 EPS nconv=0 first unconverged value (error) -302.035 (1.99462806e-06)
160216 EPS nconv=0 first unconverged value (error) -302.035 (1.87981306e-06)
160217 EPS nconv=0 first unconverged value (error) -302.035 (1.83852018e-06)
160218 EPS nconv=0 first unconverged value (error) -302.035 (1.83659088e-06)
160219 EPS nconv=0 first unconverged value (error) -302.035 (1.83659088e-06)
160220 EPS nconv=0 first unconverged value (error) -302.035 (1.83258922e-06)
160221 EPS nconv=0 first unconverged value (error) -302.035 (1.82491356e-06)
160222 EPS nconv=0 first unconverged value (error) -302.035 (1.81186669e-06)
160223 EPS nconv=0 first unconverged value (error) -302.035 (1.80950976e-06)
160224 EPS nconv=0 first unconverged value (error) -302.035 (1.80767796e-06)
160225 EPS nconv=0 first unconverged value (error) -302.035 (1.80767796e-06)
160226 EPS nconv=0 first unconverged value (error) -302.035 (1.85343569e-06)
160227 EPS nconv=0 first unconverged value (error) -302.035 (1.83673572e-06)
160228 EPS nconv=0 first unconverged value (error) -302.035 (1.82114267e-06)
160229 EPS nconv=0 first unconverged value (error) -302.035 (1.81595706e-06)
160230 EPS nconv=0 first unconverged value (error) -302.035 (1.81029110e-06)
160231 EPS nconv=0 first unconverged value (error) -302.035 (1.81029110e-06)
160232 EPS nconv=0 first unconverged value (error) -302.035 (1.88843849e-06)
160233 EPS nconv=0 first unconverged value (error) -302.035 (1.88231675e-06)
160234 EPS nconv=0 first unconverged value (error) -302.035 (1.84222657e-06)
160235 EPS nconv=0 first unconverged value (error) -302.035 (1.83274087e-06)
160236 EPS nconv=0 first unconverged value (error) -302.035 (1.82386462e-06)
160237 EPS nconv=0 first unconverged value (error) -302.035 (1.82386462e-06)
160238 EPS nconv=0 first unconverged value (error) -302.035 (2.07940447e-06)
160239 EPS nconv=0 first unconverged value (error) -302.035 (2.01162150e-06)
160240 EPS nconv=0 first unconverged value (error) -302.035 (1.95486571e-06)
160241 EPS nconv=0 first unconverged value (error) -302.035 (1.94445346e-06)
160242 EPS nconv=0 first unconverged value (error) -302.035 (1.91648615e-06)
160243 EPS nconv=0 first unconverged value (error) -302.035 (1.91648615e-06)
160244 EPS nconv=0 first unconverged value (error) -302.035 (1.93429066e-06)
160245 EPS nconv=0 first unconverged value (error) -302.035 (1.96546803e-06)
160246 EPS nconv=0 first unconverged value (error) -302.035 (1.87197827e-06)
160247 EPS nconv=0 first unconverged value (error) -302.035 (1.84512861e-06)
160248 EPS nconv=0 first unconverged value (error) -302.035 (1.84985282e-06)
160249 EPS nconv=0 first unconverged value (error) -302.035 (1.84985282e-06)
160250 EPS nconv=0 first unconverged value (error) -302.035 (1.82988569e-06)
160251 EPS nconv=0 first unconverged value (error) -302.035 (1.83499641e-06)
160252 EPS nconv=0 first unconverged value (error) -302.035 (1.81164271e-06)
160253 EPS nconv=0 first unconverged value (error) -302.035 (1.80704995e-06)
160254 EPS nconv=0 first unconverged value (error) -302.035 (1.80295819e-06)
160255 EPS nconv=0 first unconverged value (error) -302.035 (1.80295819e-06)
160256 EPS nconv=0 first unconverged value (error) -302.035 (1.92262435e-06)
160257 EPS nconv=0 first unconverged value (error) -302.035 (1.88271007e-06)
160258 EPS nconv=0 first unconverged value (error) -302.035 (1.85341108e-06)
160259 EPS nconv=0 first unconverged value (error) -302.035 (1.84476626e-06)
160260 EPS nconv=0 first unconverged value (error) -302.035 (1.83421034e-06)
160261 EPS nconv=0 first unconverged value (error) -302.035 (1.83421034e-06)
160262 EPS nconv=0 first unconverged value (error) -302.035 (1.99086460e-06)
160263 EPS nconv=0 first unconverged value (error) -302.035 (1.99238891e-06)
160264 EPS nconv=0 first unconverged value (error) -302.035 (1.92184223e-06)
160265 EPS nconv=0 first unconverged value (error) -302.035 (1.89365067e-06)
160266 EPS nconv=0 first unconverged value (error) -302.035 (1.88096526e-06)
160267 EPS nconv=0 first unconverged value (error) -302.035 (1.88096526e-06)
160268 EPS nconv=0 first unconverged value (error) -302.035 (2.01739252e-06)
160269 EPS nconv=0 first unconverged value (error) -302.035 (1.94299823e-06)
160270 EPS nconv=0 first unconverged value (error) -302.035 (1.88545615e-06)
160271 EPS nconv=0 first unconverged value (error) -302.035 (1.88180126e-06)
160272 EPS nconv=0 first unconverged value (error) -302.035 (1.87070388e-06)
160273 EPS nconv=0 first unconverged value (error) -302.035 (1.87070388e-06)
160274 EPS nconv=0 first unconverged value (error) -302.035 (1.86044385e-06)
160275 EPS nconv=0 first unconverged value (error) -302.035 (1.91304532e-06)
160276 EPS nconv=0 first unconverged value (error) -302.035 (1.83331448e-06)
160277 EPS nconv=0 first unconverged value (error) -302.035 (1.81833796e-06)
160278 EPS nconv=0 first unconverged value (error) -302.035 (1.81233731e-06)
160279 EPS nconv=0 first unconverged value (error) -302.035 (1.81233731e-06)
160280 EPS nconv=0 first unconverged value (error) -302.035 (1.79832897e-06)
160281 EPS nconv=0 first unconverged value (error) -302.035 (1.79997212e-06)
160282 EPS nconv=0 first unconverged value (error) -302.035 (1.79591162e-06)
160283 EPS nconv=0 first unconverged value (error) -302.035 (1.79494665e-06)
160284 EPS nconv=0 first unconverged value (error) -302.035 (1.79459728e-06)
160285 EPS nconv=0 first unconverged value (error) -302.035 (1.79459728e-06)
160286 EPS nconv=0 first unconverged value (error) -302.035 (1.80062584e-06)
160287 EPS nconv=0 first unconverged value (error) -302.035 (1.79951605e-06)
160288 EPS nconv=0 first unconverged value (error) -302.035 (1.79776077e-06)
160289 EPS nconv=0 first unconverged value (error) -302.035 (1.79719943e-06)
160290 EPS nconv=0 first unconverged value (error) -302.035 (1.79647685e-06)
160291 EPS nconv=0 first unconverged value (error) -302.035 (1.79647685e-06)
160292 EPS nconv=0 first unconverged value (error) -302.035 (2.76387533e-06)
160293 EPS nconv=0 first unconverged value (error) -302.035 (2.53755910e-06)
160294 EPS nconv=0 first unconverged value (error) -302.035 (2.39044408e-06)
160295 EPS nconv=0 first unconverged value (error) -302.035 (2.35825140e-06)
160296 EPS nconv=0 first unconverged value (error) -302.035 (2.26847871e-06)
160297 EPS nconv=0 first unconverged value (error) -302.035 (2.26847871e-06)
160298 EPS nconv=0 first unconverged value (error) -302.035 (2.37238562e-06)
160299 EPS nconv=0 first unconverged value (error) -302.035 (2.40900114e-06)
160300 EPS nconv=0 first unconverged value (error) -302.035 (2.15784343e-06)
160301 EPS nconv=0 first unconverged value (error) -302.035 (2.00752281e-06)
160302 EPS nconv=0 first unconverged value (error) -302.035 (2.00362277e-06)
160303 EPS nconv=0 first unconverged value (error) -302.035 (2.00362277e-06)
160304 EPS nconv=0 first unconverged value (error) -302.035 (1.91140722e-06)
160305 EPS nconv=0 first unconverged value (error) -302.035 (1.93679879e-06)
160306 EPS nconv=0 first unconverged value (error) -302.035 (1.85137245e-06)
160307 EPS nconv=0 first unconverged value (error) -302.035 (1.81922464e-06)
160308 EPS nconv=0 first unconverged value (error) -302.035 (1.80763375e-06)
160309 EPS nconv=0 first unconverged value (error) -302.035 (1.80763375e-06)
160310 EPS nconv=0 first unconverged value (error) -302.035 (1.82006817e-06)
160311 EPS nconv=0 first unconverged value (error) -302.035 (1.81270786e-06)
160312 EPS nconv=0 first unconverged value (error) -302.035 (1.80950989e-06)
160313 EPS nconv=0 first unconverged value (error) -302.035 (1.80845025e-06)
160314 EPS nconv=0 first unconverged value (error) -302.035 (1.80643268e-06)
160315 EPS nconv=0 first unconverged value (error) -302.035 (1.80643268e-06)
160316 EPS nconv=0 first unconverged value (error) -302.035 (1.80983486e-06)
160317 EPS nconv=0 first unconverged value (error) -302.035 (1.82438645e-06)
160318 EPS nconv=0 first unconverged value (error) -302.035 (1.80727549e-06)
160319 EPS nconv=0 first unconverged value (error) -302.035 (1.79819511e-06)
160320 EPS nconv=0 first unconverged value (error) -302.035 (1.79797719e-06)
160321 EPS nconv=0 first unconverged value (error) -302.035 (1.79797719e-06)
160322 EPS nconv=0 first unconverged value (error) -302.035 (1.85031169e-06)
160323 EPS nconv=0 first unconverged value (error) -302.035 (1.82284152e-06)
160324 EPS nconv=0 first unconverged value (error) -302.035 (1.81867416e-06)
160325 EPS nconv=0 first unconverged value (error) -302.035 (1.81876906e-06)
160326 EPS nconv=0 first unconverged value (error) -302.035 (1.81376779e-06)
160327 EPS nconv=0 first unconverged value (error) -302.035 (1.81376779e-06)
160328 EPS nconv=0 first unconverged value (error) -302.035 (1.95660649e-06)
160329 EPS nconv=0 first unconverged value (error) -302.035 (1.92894719e-06)
160330 EPS nconv=0 first unconverged value (error) -302.035 (1.88003698e-06)
160331 EPS nconv=0 first unconverged value (error) -302.035 (1.86790014e-06)
160332 EPS nconv=0 first unconverged value (error) -302.035 (1.86446672e-06)
160333 EPS nconv=0 first unconverged value (error) -302.035 (1.86446672e-06)
160334 EPS nconv=0 first unconverged value (error) -302.035 (1.92509596e-06)
160335 EPS nconv=0 first unconverged value (error) -302.035 (1.90355621e-06)
160336 EPS nconv=0 first unconverged value (error) -302.035 (1.87326047e-06)
160337 EPS nconv=0 first unconverged value (error) -302.035 (1.85648466e-06)
160338 EPS nconv=0 first unconverged value (error) -302.035 (1.83575420e-06)
160339 EPS nconv=0 first unconverged value (error) -302.035 (1.83575420e-06)
160340 EPS nconv=0 first unconverged value (error) -302.035 (1.85769770e-06)
160341 EPS nconv=0 first unconverged value (error) -302.035 (1.87711970e-06)
160342 EPS nconv=0 first unconverged value (error) -302.035 (1.83269393e-06)
160343 EPS nconv=0 first unconverged value (error) -302.035 (1.81587788e-06)
160344 EPS nconv=0 first unconverged value (error) -302.035 (1.81219391e-06)
160345 EPS nconv=0 first unconverged value (error) -302.035 (1.81219391e-06)
160346 EPS nconv=0 first unconverged value (error) -302.035 (1.81245555e-06)
160347 EPS nconv=0 first unconverged value (error) -302.035 (1.81256890e-06)
160348 EPS nconv=0 first unconverged value (error) -302.035 (1.80410128e-06)
160349 EPS nconv=0 first unconverged value (error) -302.035 (1.80136229e-06)
160350 EPS nconv=0 first unconverged value (error) -302.035 (1.79879215e-06)
160351 EPS nconv=0 first unconverged value (error) -302.035 (1.79879215e-06)
160352 EPS nconv=0 first unconverged value (error) -302.035 (1.80134798e-06)
160353 EPS nconv=0 first unconverged value (error) -302.035 (1.80102616e-06)
160354 EPS nconv=0 first unconverged value (error) -302.035 (1.79660848e-06)
160355 EPS nconv=0 first unconverged value (error) -302.035 (1.79619002e-06)
160356 EPS nconv=0 first unconverged value (error) -302.035 (1.79584162e-06)
160357 EPS nconv=0 first unconverged value (error) -302.035 (1.79584162e-06)
160358 EPS nconv=0 first unconverged value (error) -302.035 (1.80581795e-06)
160359 EPS nconv=0 first unconverged value (error) -302.035 (1.80120248e-06)
160360 EPS nconv=0 first unconverged value (error) -302.035 (1.79817148e-06)
160361 EPS nconv=0 first unconverged value (error) -302.035 (1.79766779e-06)
160362 EPS nconv=0 first unconverged value (error) -302.035 (1.79691890e-06)
160363 EPS nconv=0 first unconverged value (error) -302.035 (1.79691890e-06)
160364 EPS nconv=0 first unconverged value (error) -302.035 (1.80084605e-06)
160365 EPS nconv=0 first unconverged value (error) -302.035 (1.80478316e-06)
160366 EPS nconv=0 first unconverged value (error) -302.035 (1.79879575e-06)
160367 EPS nconv=0 first unconverged value (error) -302.035 (1.79579219e-06)
160368 EPS nconv=0 first unconverged value (error) -302.035 (1.79543906e-06)
160369 EPS nconv=0 first unconverged value (error) -302.035 (1.79543906e-06)
160370 EPS nconv=0 first unconverged value (error) -302.035 (1.79474011e-06)
160371 EPS nconv=0 first unconverged value (error) -302.035 (1.79568149e-06)
160372 EPS nconv=0 first unconverged value (error) -302.035 (1.79439539e-06)
160373 EPS nconv=0 first unconverged value (error) -302.035 (1.79384535e-06)
160374 EPS nconv=0 first unconverged value (error) -302.035 (1.79360622e-06)
160375 EPS nconv=0 first unconverged value (error) -302.035 (1.79360622e-06)
160376 EPS nconv=0 first unconverged value (error) -302.035 (1.79556594e-06)
160377 EPS nconv=0 first unconverged value (error) -302.035 (1.79481660e-06)
160378 EPS nconv=0 first unconverged value (error) -302.035 (1.79447569e-06)
160379 EPS nconv=0 first unconverged value (error) -302.035 (1.79434964e-06)
160380 EPS nconv=0 first unconverged value (error) -302.035 (1.79413626e-06)
160381 EPS nconv=0 first unconverged value (error) -302.035 (1.79413626e-06)
160382 EPS nconv=0 first unconverged value (error) -302.035 (1.79453276e-06)
160383 EPS nconv=0 first unconverged value (error) -302.035 (1.79488134e-06)
160384 EPS nconv=0 first unconverged value (error) -302.035 (1.79409113e-06)
160385 EPS nconv=0 first unconverged value (error) -302.035 (1.79373849e-06)
160386 EPS nconv=0 first unconverged value (error) -302.035 (1.79374042e-06)
160387 EPS nconv=0 first unconverged value (error) -302.035 (1.79374042e-06)
160388 EPS nconv=0 first unconverged value (error) -302.035 (2.02211978e-06)
160389 EPS nconv=0 first unconverged value (error) -302.035 (1.91956121e-06)
160390 EPS nconv=0 first unconverged value (error) -302.035 (1.88271426e-06)
160391 EPS nconv=0 first unconverged value (error) -302.035 (1.87034957e-06)
160392 EPS nconv=0 first unconverged value (error) -302.035 (1.86188698e-06)
160393 EPS nconv=0 first unconverged value (error) -302.035 (1.86188698e-06)
160394 EPS nconv=0 first unconverged value (error) -302.035 (1.94919071e-06)
160395 EPS nconv=0 first unconverged value (error) -302.035 (2.00985635e-06)
160396 EPS nconv=0 first unconverged value (error) -302.035 (1.91251060e-06)
160397 EPS nconv=0 first unconverged value (error) -302.035 (1.89411793e-06)
160398 EPS nconv=0 first unconverged value (error) -302.035 (1.88133009e-06)
160399 EPS nconv=0 first unconverged value (error) -302.035 (1.88133009e-06)
160400 EPS nconv=0 first unconverged value (error) -302.035 (1.88649374e-06)
160401 EPS nconv=0 first unconverged value (error) -302.035 (1.83493371e-06)
160402 EPS nconv=0 first unconverged value (error) -302.035 (1.82082768e-06)
160403 EPS nconv=0 first unconverged value (error) -302.035 (1.81104028e-06)
160404 EPS nconv=0 first unconverged value (error) -302.035 (1.80990305e-06)
160405 EPS nconv=0 first unconverged value (error) -302.035 (1.80990305e-06)
160406 EPS nconv=0 first unconverged value (error) -302.035 (1.82306095e-06)
160407 EPS nconv=0 first unconverged value (error) -302.035 (1.81278261e-06)
160408 EPS nconv=0 first unconverged value (error) -302.035 (1.80711041e-06)
160409 EPS nconv=0 first unconverged value (error) -302.035 (1.80287533e-06)
160410 EPS nconv=0 first unconverged value (error) -302.035 (1.80078715e-06)
160411 EPS nconv=0 first unconverged value (error) -302.035 (1.80078715e-06)
160412 EPS nconv=0 first unconverged value (error) -302.035 (2.56566873e-06)
160413 EPS nconv=0 first unconverged value (error) -302.035 (2.31620088e-06)
160414 EPS nconv=0 first unconverged value (error) -302.035 (2.20545284e-06)
160415 EPS nconv=0 first unconverged value (error) -302.035 (2.16134303e-06)
160416 EPS nconv=0 first unconverged value (error) -302.035 (2.09198780e-06)
160417 EPS nconv=0 first unconverged value (error) -302.035 (2.09198780e-06)
160418 EPS nconv=0 first unconverged value (error) -302.035 (2.16020867e-06)
160419 EPS nconv=0 first unconverged value (error) -302.035 (2.31918197e-06)
160420 EPS nconv=0 first unconverged value (error) -302.035 (2.07234490e-06)
160421 EPS nconv=0 first unconverged value (error) -302.035 (1.96337599e-06)
160422 EPS nconv=0 first unconverged value (error) -302.035 (1.94503974e-06)
160423 EPS nconv=0 first unconverged value (error) -302.035 (1.94503974e-06)
160424 EPS nconv=0 first unconverged value (error) -302.035 (1.88852347e-06)
160425 EPS nconv=0 first unconverged value (error) -302.035 (1.86376796e-06)
160426 EPS nconv=0 first unconverged value (error) -302.035 (1.85261243e-06)
160427 EPS nconv=0 first unconverged value (error) -302.035 (1.82219249e-06)
160428 EPS nconv=0 first unconverged value (error) -302.035 (1.81062511e-06)
160429 EPS nconv=0 first unconverged value (error) -302.035 (1.81062511e-06)
160430 EPS nconv=0 first unconverged value (error) -302.035 (1.86278957e-06)
160431 EPS nconv=0 first unconverged value (error) -302.035 (1.84414322e-06)
160432 EPS nconv=0 first unconverged value (error) -302.035 (1.82827918e-06)
160433 EPS nconv=0 first unconverged value (error) -302.035 (1.82216229e-06)
160434 EPS nconv=0 first unconverged value (error) -302.035 (1.81916406e-06)
160435 EPS nconv=0 first unconverged value (error) -302.035 (1.81916406e-06)
160436 EPS nconv=0 first unconverged value (error) -302.035 (2.04642223e-06)
160437 EPS nconv=0 first unconverged value (error) -302.035 (2.02466901e-06)
160438 EPS nconv=0 first unconverged value (error) -302.035 (1.98483026e-06)
160439 EPS nconv=0 first unconverged value (error) -302.035 (1.91987871e-06)
160440 EPS nconv=0 first unconverged value (error) -302.035 (1.89306859e-06)
160441 EPS nconv=0 first unconverged value (error) -302.035 (1.89306859e-06)
160442 EPS nconv=0 first unconverged value (error) -302.035 (1.89916321e-06)
160443 EPS nconv=0 first unconverged value (error) -302.035 (1.93324063e-06)
160444 EPS nconv=0 first unconverged value (error) -302.035 (1.87842204e-06)
160445 EPS nconv=0 first unconverged value (error) -302.035 (1.82496983e-06)
160446 EPS nconv=0 first unconverged value (error) -302.035 (1.82222639e-06)
160447 EPS nconv=0 first unconverged value (error) -302.035 (1.82222639e-06)
160448 EPS nconv=0 first unconverged value (error) -302.035 (1.92185773e-06)
160449 EPS nconv=0 first unconverged value (error) -302.035 (1.87122196e-06)
160450 EPS nconv=0 first unconverged value (error) -302.035 (1.86265456e-06)
160451 EPS nconv=0 first unconverged value (error) -302.035 (1.85088981e-06)
160452 EPS nconv=0 first unconverged value (error) -302.035 (1.84087445e-06)
160453 EPS nconv=0 first unconverged value (error) -302.035 (1.84087445e-06)
160454 EPS nconv=0 first unconverged value (error) -302.035 (2.09325652e-06)
160455 EPS nconv=0 first unconverged value (error) -302.035 (2.05054087e-06)
160456 EPS nconv=0 first unconverged value (error) -302.035 (1.99428346e-06)
160457 EPS nconv=0 first unconverged value (error) -302.035 (1.96438291e-06)
160458 EPS nconv=0 first unconverged value (error) -302.035 (1.94340552e-06)
160459 EPS nconv=0 first unconverged value (error) -302.035 (1.94340552e-06)
160460 EPS nconv=0 first unconverged value (error) -302.035 (2.17300698e-06)
160461 EPS nconv=0 first unconverged value (error) -302.035 (2.16941468e-06)
160462 EPS nconv=0 first unconverged value (error) -302.035 (2.08420652e-06)
160463 EPS nconv=0 first unconverged value (error) -302.035 (1.97124461e-06)
160464 EPS nconv=0 first unconverged value (error) -302.035 (1.91067862e-06)
160465 EPS nconv=0 first unconverged value (error) -302.035 (1.91067862e-06)
160466 EPS nconv=0 first unconverged value (error) -302.035 (1.91922720e-06)
160467 EPS nconv=0 first unconverged value (error) -302.035 (1.96055333e-06)
160468 EPS nconv=0 first unconverged value (error) -302.035 (1.89120063e-06)
160469 EPS nconv=0 first unconverged value (error) -302.035 (1.84238997e-06)
160470 EPS nconv=0 first unconverged value (error) -302.035 (1.83783504e-06)
160471 EPS nconv=0 first unconverged value (error) -302.035 (1.83783504e-06)
160472 EPS nconv=0 first unconverged value (error) -302.035 (1.83050474e-06)
160473 EPS nconv=0 first unconverged value (error) -302.035 (1.82387384e-06)
160474 EPS nconv=0 first unconverged value (error) -302.035 (1.81229940e-06)
160475 EPS nconv=0 first unconverged value (error) -302.035 (1.80727890e-06)
160476 EPS nconv=0 first unconverged value (error) -302.035 (1.80145725e-06)
160477 EPS nconv=0 first unconverged value (error) -302.035 (1.80145725e-06)
160478 EPS nconv=0 first unconverged value (error) -302.035 (1.89174960e-06)
160479 EPS nconv=0 first unconverged value (error) -302.035 (1.88267168e-06)
160480 EPS nconv=0 first unconverged value (error) -302.035 (1.86333067e-06)
160481 EPS nconv=0 first unconverged value (error) -302.035 (1.85033319e-06)
160482 EPS nconv=0 first unconverged value (error) -302.035 (1.84005813e-06)
160483 EPS nconv=0 first unconverged value (error) -302.035 (1.84005813e-06)
160484 EPS nconv=0 first unconverged value (error) -302.035 (1.84190745e-06)
160485 EPS nconv=0 first unconverged value (error) -302.035 (1.84673712e-06)
160486 EPS nconv=0 first unconverged value (error) -302.035 (1.82580166e-06)
160487 EPS nconv=0 first unconverged value (error) -302.035 (1.81478049e-06)
160488 EPS nconv=0 first unconverged value (error) -302.035 (1.80479490e-06)
160489 EPS nconv=0 first unconverged value (error) -302.035 (1.80479490e-06)
160490 EPS nconv=0 first unconverged value (error) -302.035 (1.83622863e-06)
160491 EPS nconv=0 first unconverged value (error) -302.035 (1.82032811e-06)
160492 EPS nconv=0 first unconverged value (error) -302.035 (1.81363498e-06)
160493 EPS nconv=0 first unconverged value (error) -302.035 (1.81053262e-06)
160494 EPS nconv=0 first unconverged value (error) -302.035 (1.80811212e-06)
160495 EPS nconv=0 first unconverged value (error) -302.035 (1.80811212e-06)
160496 EPS nconv=0 first unconverged value (error) -302.035 (1.82376330e-06)
160497 EPS nconv=0 first unconverged value (error) -302.035 (1.82915399e-06)
160498 EPS nconv=0 first unconverged value (error) -302.035 (1.81508537e-06)
160499 EPS nconv=0 first unconverged value (error) -302.035 (1.80310119e-06)
160500 EPS nconv=0 first unconverged value (error) -302.035 (1.80038517e-06)
160501 EPS nconv=0 first unconverged value (error) -302.035 (1.80038517e-06)
160502 EPS nconv=0 first unconverged value (error) -302.035 (2.06829031e-06)
160503 EPS nconv=0 first unconverged value (error) -302.035 (1.99230899e-06)
160504 EPS nconv=0 first unconverged value (error) -302.035 (1.95824083e-06)
160505 EPS nconv=0 first unconverged value (error) -302.035 (1.93881164e-06)
160506 EPS nconv=0 first unconverged value (error) -302.035 (1.91203154e-06)
160507 EPS nconv=0 first unconverged value (error) -302.035 (1.91203154e-06)
160508 EPS nconv=0 first unconverged value (error) -302.035 (2.69541144e-06)
160509 EPS nconv=0 first unconverged value (error) -302.035 (2.43532327e-06)
160510 EPS nconv=0 first unconverged value (error) -302.035 (2.26566212e-06)
160511 EPS nconv=0 first unconverged value (error) -302.035 (2.26219417e-06)
160512 EPS nconv=0 first unconverged value (error) -302.035 (2.23507521e-06)
160513 EPS nconv=0 first unconverged value (error) -302.035 (2.23507521e-06)
160514 EPS nconv=0 first unconverged value (error) -302.035 (2.85993505e-06)
160515 EPS nconv=0 first unconverged value (error) -302.035 (2.70528199e-06)
160516 EPS nconv=0 first unconverged value (error) -302.035 (2.27585195e-06)
160517 EPS nconv=0 first unconverged value (error) -302.035 (2.27265397e-06)
160518 EPS nconv=0 first unconverged value (error) -302.035 (2.18816013e-06)
160519 EPS nconv=0 first unconverged value (error) -302.035 (2.18816013e-06)
160520 EPS nconv=0 first unconverged value (error) -302.035 (2.29638804e-06)
160521 EPS nconv=0 first unconverged value (error) -302.035 (2.57079749e-06)
160522 EPS nconv=0 first unconverged value (error) -302.035 (2.35567918e-06)
160523 EPS nconv=0 first unconverged value (error) -302.035 (1.96374558e-06)
160524 EPS nconv=0 first unconverged value (error) -302.035 (1.91164392e-06)
160525 EPS nconv=0 first unconverged value (error) -302.035 (1.91164392e-06)
160526 EPS nconv=0 first unconverged value (error) -302.035 (1.88245453e-06)
160527 EPS nconv=0 first unconverged value (error) -302.035 (1.90687792e-06)
160528 EPS nconv=0 first unconverged value (error) -302.035 (1.86775678e-06)
160529 EPS nconv=0 first unconverged value (error) -302.035 (1.81487096e-06)
160530 EPS nconv=0 first unconverged value (error) -302.035 (1.80188936e-06)
160531 EPS nconv=0 first unconverged value (error) -302.035 (1.80188936e-06)
160532 EPS nconv=0 first unconverged value (error) -302.035 (1.79490511e-06)
160533 EPS nconv=0 first unconverged value (error) -302.035 (1.79369893e-06)
160534 EPS nconv=0 first unconverged value (error) -302.035 (1.79335910e-06)
160535 EPS nconv=0 first unconverged value (error) -302.035 (1.79310785e-06)
160536 EPS nconv=0 first unconverged value (error) -302.035 (1.79300929e-06)
160537 EPS nconv=0 first unconverged value (error) -302.035 (1.79300929e-06)
160538 EPS nconv=0 first unconverged value (error) -302.035 (1.92086417e-06)
160539 EPS nconv=0 first unconverged value (error) -302.035 (1.87291680e-06)
160540 EPS nconv=0 first unconverged value (error) -302.035 (1.85732325e-06)
160541 EPS nconv=0 first unconverged value (error) -302.035 (1.85164510e-06)
160542 EPS nconv=0 first unconverged value (error) -302.035 (1.84643964e-06)
160543 EPS nconv=0 first unconverged value (error) -302.035 (1.84643964e-06)
160544 EPS nconv=0 first unconverged value (error) -302.035 (1.95668239e-06)
160545 EPS nconv=0 first unconverged value (error) -302.035 (1.91471445e-06)
160546 EPS nconv=0 first unconverged value (error) -302.035 (1.86394241e-06)
160547 EPS nconv=0 first unconverged value (error) -302.035 (1.85617200e-06)
160548 EPS nconv=0 first unconverged value (error) -302.035 (1.85335077e-06)
160549 EPS nconv=0 first unconverged value (error) -302.035 (1.85335077e-06)
160550 EPS nconv=0 first unconverged value (error) -302.035 (2.50216163e-06)
160551 EPS nconv=0 first unconverged value (error) -302.035 (2.26063743e-06)
160552 EPS nconv=0 first unconverged value (error) -302.035 (2.14901168e-06)
160553 EPS nconv=0 first unconverged value (error) -302.035 (2.13455856e-06)
160554 EPS nconv=0 first unconverged value (error) -302.035 (2.11735535e-06)
160555 EPS nconv=0 first unconverged value (error) -302.035 (2.11735535e-06)
160556 EPS nconv=0 first unconverged value (error) -302.035 (2.22675596e-06)
160557 EPS nconv=0 first unconverged value (error) -302.035 (2.29759009e-06)
160558 EPS nconv=0 first unconverged value (error) -302.035 (2.01851167e-06)
160559 EPS nconv=0 first unconverged value (error) -302.035 (1.94683059e-06)
160560 EPS nconv=0 first unconverged value (error) -302.035 (1.90421815e-06)
160561 EPS nconv=0 first unconverged value (error) -302.035 (1.90421815e-06)
160562 EPS nconv=0 first unconverged value (error) -302.035 (2.15706054e-06)
160563 EPS nconv=0 first unconverged value (error) -302.035 (2.07737304e-06)
160564 EPS nconv=0 first unconverged value (error) -302.035 (1.99226585e-06)
160565 EPS nconv=0 first unconverged value (error) -302.035 (1.97196029e-06)
160566 EPS nconv=0 first unconverged value (error) -302.035 (1.93755458e-06)
160567 EPS nconv=0 first unconverged value (error) -302.035 (1.93755458e-06)
160568 EPS nconv=0 first unconverged value (error) -302.035 (1.99954698e-06)
160569 EPS nconv=0 first unconverged value (error) -302.035 (2.00274565e-06)
160570 EPS nconv=0 first unconverged value (error) -302.035 (1.92413898e-06)
160571 EPS nconv=0 first unconverged value (error) -302.035 (1.88450613e-06)
160572 EPS nconv=0 first unconverged value (error) -302.035 (1.85616055e-06)
160573 EPS nconv=0 first unconverged value (error) -302.035 (1.85616055e-06)
160574 EPS nconv=0 first unconverged value (error) -302.035 (2.89652306e-06)
160575 EPS nconv=0 first unconverged value (error) -302.035 (2.73680399e-06)
160576 EPS nconv=0 first unconverged value (error) -302.035 (2.43095068e-06)
160577 EPS nconv=0 first unconverged value (error) -302.035 (2.39449281e-06)
160578 EPS nconv=0 first unconverged value (error) -302.035 (2.34598716e-06)
160579 EPS nconv=0 first unconverged value (error) -302.035 (2.34598716e-06)
160580 EPS nconv=0 first unconverged value (error) -302.035 (2.33310434e-06)
160581 EPS nconv=0 first unconverged value (error) -302.035 (2.45605107e-06)
160582 EPS nconv=0 first unconverged value (error) -302.035 (2.28233492e-06)
160583 EPS nconv=0 first unconverged value (error) -302.035 (1.95901612e-06)
160584 EPS nconv=0 first unconverged value (error) -302.035 (1.88825162e-06)
160585 EPS nconv=0 first unconverged value (error) -302.035 (1.88825162e-06)
160586 EPS nconv=0 first unconverged value (error) -302.035 (2.38924189e-06)
160587 EPS nconv=0 first unconverged value (error) -302.035 (2.28284193e-06)
160588 EPS nconv=0 first unconverged value (error) -302.035 (2.14078126e-06)
160589 EPS nconv=0 first unconverged value (error) -302.035 (2.11532732e-06)
160590 EPS nconv=0 first unconverged value (error) -302.035 (2.09916806e-06)
160591 EPS nconv=0 first unconverged value (error) -302.035 (2.09916806e-06)
160592 EPS nconv=0 first unconverged value (error) -302.035 (2.07776008e-06)
160593 EPS nconv=0 first unconverged value (error) -302.035 (2.12134020e-06)
160594 EPS nconv=0 first unconverged value (error) -302.035 (2.02373183e-06)
160595 EPS nconv=0 first unconverged value (error) -302.035 (1.88345578e-06)
160596 EPS nconv=0 first unconverged value (error) -302.035 (1.83643010e-06)
160597 EPS nconv=0 first unconverged value (error) -302.035 (1.83643010e-06)
160598 EPS nconv=0 first unconverged value (error) -302.035 (1.90106319e-06)
160599 EPS nconv=0 first unconverged value (error) -302.035 (1.88991041e-06)
160600 EPS nconv=0 first unconverged value (error) -302.035 (1.84965395e-06)
160601 EPS nconv=0 first unconverged value (error) -302.035 (1.84488809e-06)
160602 EPS nconv=0 first unconverged value (error) -302.035 (1.83859607e-06)
160603 EPS nconv=0 first unconverged value (error) -302.035 (1.83859607e-06)
160604 EPS nconv=0 first unconverged value (error) -302.035 (2.15922673e-06)
160605 EPS nconv=0 first unconverged value (error) -302.035 (2.10168609e-06)
160606 EPS nconv=0 first unconverged value (error) -302.035 (2.05677289e-06)
160607 EPS nconv=0 first unconverged value (error) -302.035 (1.95116323e-06)
160608 EPS nconv=0 first unconverged value (error) -302.035 (1.92616961e-06)
160609 EPS nconv=0 first unconverged value (error) -302.035 (1.92616961e-06)
160610 EPS nconv=0 first unconverged value (error) -302.035 (2.00816936e-06)
160611 EPS nconv=0 first unconverged value (error) -302.035 (2.06052892e-06)
160612 EPS nconv=0 first unconverged value (error) -302.035 (1.93807584e-06)
160613 EPS nconv=0 first unconverged value (error) -302.035 (1.86578461e-06)
160614 EPS nconv=0 first unconverged value (error) -302.035 (1.84885379e-06)
160615 EPS nconv=0 first unconverged value (error) -302.035 (1.84885379e-06)
160616 EPS nconv=0 first unconverged value (error) -302.035 (1.83709613e-06)
160617 EPS nconv=0 first unconverged value (error) -302.035 (1.83149355e-06)
160618 EPS nconv=0 first unconverged value (error) -302.035 (1.81889480e-06)
160619 EPS nconv=0 first unconverged value (error) -302.035 (1.81492574e-06)
160620 EPS nconv=0 first unconverged value (error) -302.035 (1.79999331e-06)
160621 EPS nconv=0 first unconverged value (error) -302.035 (1.79999331e-06)
160622 EPS nconv=0 first unconverged value (error) -302.035 (1.88984212e-06)
160623 EPS nconv=0 first unconverged value (error) -302.035 (1.88326922e-06)
160624 EPS nconv=0 first unconverged value (error) -302.035 (1.85714385e-06)
160625 EPS nconv=0 first unconverged value (error) -302.035 (1.84605831e-06)
160626 EPS nconv=0 first unconverged value (error) -302.035 (1.83906915e-06)
160627 EPS nconv=0 first unconverged value (error) -302.035 (1.83906915e-06)
160628 EPS nconv=0 first unconverged value (error) -302.035 (3.22024690e-06)
160629 EPS nconv=0 first unconverged value (error) -302.035 (2.83342497e-06)
160630 EPS nconv=0 first unconverged value (error) -302.035 (2.62761642e-06)
160631 EPS nconv=0 first unconverged value (error) -302.035 (2.55176573e-06)
160632 EPS nconv=0 first unconverged value (error) -302.035 (2.53102637e-06)
160633 EPS nconv=0 first unconverged value (error) -302.035 (2.53102637e-06)
160634 EPS nconv=0 first unconverged value (error) -302.035 (2.64881618e-06)
160635 EPS nconv=0 first unconverged value (error) -302.035 (2.73818280e-06)
160636 EPS nconv=0 first unconverged value (error) -302.035 (2.29060165e-06)
160637 EPS nconv=0 first unconverged value (error) -302.035 (2.16777616e-06)
160638 EPS nconv=0 first unconverged value (error) -302.035 (1.95936793e-06)
160639 EPS nconv=0 first unconverged value (error) -302.035 (1.95936793e-06)
160640 EPS nconv=0 first unconverged value (error) -302.035 (1.99991039e-06)
160641 EPS nconv=0 first unconverged value (error) -302.035 (1.97253078e-06)
160642 EPS nconv=0 first unconverged value (error) -302.035 (1.88458517e-06)
160643 EPS nconv=0 first unconverged value (error) -302.035 (1.84794551e-06)
160644 EPS nconv=0 first unconverged value (error) -302.035 (1.83539114e-06)
160645 EPS nconv=0 first unconverged value (error) -302.035 (1.83539114e-06)
160646 EPS nconv=0 first unconverged value (error) -302.035 (1.85257943e-06)
160647 EPS nconv=0 first unconverged value (error) -302.035 (1.86157989e-06)
160648 EPS nconv=0 first unconverged value (error) -302.035 (1.85616524e-06)
160649 EPS nconv=0 first unconverged value (error) -302.035 (1.81627049e-06)
160650 EPS nconv=0 first unconverged value (error) -302.035 (1.80830131e-06)
160651 EPS nconv=0 first unconverged value (error) -302.035 (1.80830131e-06)
160652 EPS nconv=0 first unconverged value (error) -302.035 (2.85231780e-06)
160653 EPS nconv=0 first unconverged value (error) -302.035 (2.84046954e-06)
160654 EPS nconv=0 first unconverged value (error) -302.035 (2.67442967e-06)
160655 EPS nconv=0 first unconverged value (error) -302.035 (2.48332084e-06)
160656 EPS nconv=0 first unconverged value (error) -302.035 (2.42896098e-06)
160657 EPS nconv=0 first unconverged value (error) -302.035 (2.42896098e-06)
160658 EPS nconv=0 first unconverged value (error) -302.035 (2.90019555e-06)
160659 EPS nconv=0 first unconverged value (error) -302.035 (2.55322395e-06)
160660 EPS nconv=0 first unconverged value (error) -302.035 (2.37731468e-06)
160661 EPS nconv=0 first unconverged value (error) -302.035 (2.26201098e-06)
160662 EPS nconv=0 first unconverged value (error) -302.035 (2.18704812e-06)
160663 EPS nconv=0 first unconverged value (error) -302.035 (2.18704812e-06)
160664 EPS nconv=0 first unconverged value (error) -302.035 (2.46062601e-06)
160665 EPS nconv=0 first unconverged value (error) -302.035 (2.53019317e-06)
160666 EPS nconv=0 first unconverged value (error) -302.035 (2.18151639e-06)
160667 EPS nconv=0 first unconverged value (error) -302.035 (2.13575805e-06)
160668 EPS nconv=0 first unconverged value (error) -302.035 (1.99400527e-06)
160669 EPS nconv=0 first unconverged value (error) -302.035 (1.99400527e-06)
160670 EPS nconv=0 first unconverged value (error) -302.035 (1.94616970e-06)
160671 EPS nconv=0 first unconverged value (error) -302.035 (1.97306417e-06)
160672 EPS nconv=0 first unconverged value (error) -302.035 (1.94807379e-06)
160673 EPS nconv=0 first unconverged value (error) -302.035 (1.81807631e-06)
160674 EPS nconv=0 first unconverged value (error) -302.035 (1.79903572e-06)
160675 EPS nconv=0 first unconverged value (error) -302.035 (1.79903572e-06)
160676 EPS nconv=0 first unconverged value (error) -302.035 (3.02937310e-06)
160677 EPS nconv=0 first unconverged value (error) -302.035 (2.95025644e-06)
160678 EPS nconv=0 first unconverged value (error) -302.035 (2.70377548e-06)
160679 EPS nconv=0 first unconverged value (error) -302.035 (2.55629000e-06)
160680 EPS nconv=0 first unconverged value (error) -302.035 (2.53003224e-06)
160681 EPS nconv=0 first unconverged value (error) -302.035 (2.53003224e-06)
160682 EPS nconv=0 first unconverged value (error) -302.035 (2.63658822e-06)
160683 EPS nconv=0 first unconverged value (error) -302.035 (2.45116359e-06)
160684 EPS nconv=0 first unconverged value (error) -302.035 (2.32568402e-06)
160685 EPS nconv=0 first unconverged value (error) -302.035 (2.04500333e-06)
160686 EPS nconv=0 first unconverged value (error) -302.035 (1.95140377e-06)
160687 EPS nconv=0 first unconverged value (error) -302.035 (1.95140377e-06)
160688 EPS nconv=0 first unconverged value (error) -302.035 (2.18606075e-06)
160689 EPS nconv=0 first unconverged value (error) -302.035 (2.19666764e-06)
160690 EPS nconv=0 first unconverged value (error) -302.035 (2.00443657e-06)
160691 EPS nconv=0 first unconverged value (error) -302.035 (1.96940494e-06)
160692 EPS nconv=0 first unconverged value (error) -302.035 (1.93938593e-06)
160693 EPS nconv=0 first unconverged value (error) -302.035 (1.93938593e-06)
160694 EPS nconv=0 first unconverged value (error) -302.035 (1.98780528e-06)
160695 EPS nconv=0 first unconverged value (error) -302.035 (2.02002688e-06)
160696 EPS nconv=0 first unconverged value (error) -302.035 (1.95686358e-06)
160697 EPS nconv=0 first unconverged value (error) -302.035 (1.84962748e-06)
160698 EPS nconv=0 first unconverged value (error) -302.035 (1.82980030e-06)
160699 EPS nconv=0 first unconverged value (error) -302.035 (1.82980030e-06)
160700 EPS nconv=0 first unconverged value (error) -302.035 (1.82173319e-06)
160701 EPS nconv=0 first unconverged value (error) -302.035 (1.83142642e-06)
160702 EPS nconv=0 first unconverged value (error) -302.035 (1.81501933e-06)
160703 EPS nconv=0 first unconverged value (error) -302.035 (1.80072376e-06)
160704 EPS nconv=0 first unconverged value (error) -302.035 (1.80096004e-06)
160705 EPS nconv=0 first unconverged value (error) -302.035 (1.80096004e-06)
160706 EPS nconv=0 first unconverged value (error) -302.035 (1.82230174e-06)
160707 EPS nconv=0 first unconverged value (error) -302.035 (1.80791987e-06)
160708 EPS nconv=0 first unconverged value (error) -302.035 (1.80450677e-06)
160709 EPS nconv=0 first unconverged value (error) -302.035 (1.80382196e-06)
160710 EPS nconv=0 first unconverged value (error) -302.035 (1.80167501e-06)
160711 EPS nconv=0 first unconverged value (error) -302.035 (1.80167501e-06)
160712 EPS nconv=0 first unconverged value (error) -302.035 (2.24274912e-06)
160713 EPS nconv=0 first unconverged value (error) -302.035 (2.22887424e-06)
160714 EPS nconv=0 first unconverged value (error) -302.035 (2.11794889e-06)
160715 EPS nconv=0 first unconverged value (error) -302.035 (2.05298442e-06)
160716 EPS nconv=0 first unconverged value (error) -302.035 (2.02600940e-06)
160717 EPS nconv=0 first unconverged value (error) -302.035 (2.02600940e-06)
160718 EPS nconv=0 first unconverged value (error) -302.035 (2.25137451e-06)
160719 EPS nconv=0 first unconverged value (error) -302.035 (2.15458643e-06)
160720 EPS nconv=0 first unconverged value (error) -302.035 (2.06954628e-06)
160721 EPS nconv=0 first unconverged value (error) -302.035 (2.02371306e-06)
160722 EPS nconv=0 first unconverged value (error) -302.035 (1.99511229e-06)
160723 EPS nconv=0 first unconverged value (error) -302.035 (1.99511229e-06)
160724 EPS nconv=0 first unconverged value (error) -302.035 (2.44927254e-06)
160725 EPS nconv=0 first unconverged value (error) -302.035 (2.31628892e-06)
160726 EPS nconv=0 first unconverged value (error) -302.035 (2.18090859e-06)
160727 EPS nconv=0 first unconverged value (error) -302.035 (2.17090517e-06)
160728 EPS nconv=0 first unconverged value (error) -302.035 (2.07310830e-06)
160729 EPS nconv=0 first unconverged value (error) -302.035 (2.07310830e-06)
160730 EPS nconv=0 first unconverged value (error) -302.035 (2.22971682e-06)
160731 EPS nconv=0 first unconverged value (error) -302.035 (2.28340686e-06)
160732 EPS nconv=0 first unconverged value (error) -302.035 (2.12212258e-06)
160733 EPS nconv=0 first unconverged value (error) -302.035 (1.91700420e-06)
160734 EPS nconv=0 first unconverged value (error) -302.035 (1.88147427e-06)
160735 EPS nconv=0 first unconverged value (error) -302.035 (1.88147427e-06)
160736 EPS nconv=0 first unconverged value (error) -302.035 (2.00824295e-06)
160737 EPS nconv=0 first unconverged value (error) -302.035 (1.98391112e-06)
160738 EPS nconv=0 first unconverged value (error) -302.035 (1.95895468e-06)
160739 EPS nconv=0 first unconverged value (error) -302.035 (1.90834433e-06)
160740 EPS nconv=0 first unconverged value (error) -302.035 (1.89246329e-06)
160741 EPS nconv=0 first unconverged value (error) -302.035 (1.89246329e-06)
160742 EPS nconv=0 first unconverged value (error) -302.035 (1.95500738e-06)
160743 EPS nconv=0 first unconverged value (error) -302.035 (1.92144803e-06)
160744 EPS nconv=0 first unconverged value (error) -302.035 (1.86963421e-06)
160745 EPS nconv=0 first unconverged value (error) -302.035 (1.85288968e-06)
160746 EPS nconv=0 first unconverged value (error) -302.035 (1.84373575e-06)
160747 EPS nconv=0 first unconverged value (error) -302.035 (1.84373575e-06)
160748 EPS nconv=0 first unconverged value (error) -302.035 (1.84219422e-06)
160749 EPS nconv=0 first unconverged value (error) -302.035 (1.84249316e-06)
160750 EPS nconv=0 first unconverged value (error) -302.035 (1.82158084e-06)
160751 EPS nconv=0 first unconverged value (error) -302.035 (1.81123541e-06)
160752 EPS nconv=0 first unconverged value (error) -302.035 (1.80686549e-06)
160753 EPS nconv=0 first unconverged value (error) -302.035 (1.80686549e-06)
160754 EPS nconv=0 first unconverged value (error) -302.035 (2.26650642e-06)
160755 EPS nconv=0 first unconverged value (error) -302.035 (2.11746545e-06)
160756 EPS nconv=0 first unconverged value (error) -302.035 (2.03711539e-06)
160757 EPS nconv=0 first unconverged value (error) -302.035 (2.00584896e-06)
160758 EPS nconv=0 first unconverged value (error) -302.035 (1.97801720e-06)
160759 EPS nconv=0 first unconverged value (error) -302.035 (1.97801720e-06)
160760 EPS nconv=0 first unconverged value (error) -302.035 (1.98348195e-06)
160761 EPS nconv=0 first unconverged value (error) -302.035 (2.09713625e-06)
160762 EPS nconv=0 first unconverged value (error) -302.035 (1.94760127e-06)
160763 EPS nconv=0 first unconverged value (error) -302.035 (1.86654343e-06)
160764 EPS nconv=0 first unconverged value (error) -302.035 (1.83281536e-06)
160765 EPS nconv=0 first unconverged value (error) -302.035 (1.83281536e-06)
160766 EPS nconv=0 first unconverged value (error) -302.035 (1.85945870e-06)
160767 EPS nconv=0 first unconverged value (error) -302.035 (1.84792867e-06)
160768 EPS nconv=0 first unconverged value (error) -302.035 (1.83158027e-06)
160769 EPS nconv=0 first unconverged value (error) -302.035 (1.82794247e-06)
160770 EPS nconv=0 first unconverged value (error) -302.035 (1.82579946e-06)
160771 EPS nconv=0 first unconverged value (error) -302.035 (1.82579946e-06)
160772 EPS nconv=0 first unconverged value (error) -302.035 (2.09075603e-06)
160773 EPS nconv=0 first unconverged value (error) -302.035 (1.99961968e-06)
160774 EPS nconv=0 first unconverged value (error) -302.035 (1.95332036e-06)
160775 EPS nconv=0 first unconverged value (error) -302.035 (1.89534182e-06)
160776 EPS nconv=0 first unconverged value (error) -302.035 (1.88100130e-06)
160777 EPS nconv=0 first unconverged value (error) -302.035 (1.88100130e-06)
160778 EPS nconv=0 first unconverged value (error) -302.035 (1.98354047e-06)
160779 EPS nconv=0 first unconverged value (error) -302.035 (2.05829504e-06)
160780 EPS nconv=0 first unconverged value (error) -302.035 (1.94095248e-06)
160781 EPS nconv=0 first unconverged value (error) -302.035 (1.88236086e-06)
160782 EPS nconv=0 first unconverged value (error) -302.035 (1.85934835e-06)
160783 EPS nconv=0 first unconverged value (error) -302.035 (1.85934835e-06)
160784 EPS nconv=0 first unconverged value (error) -302.035 (1.91106857e-06)
160785 EPS nconv=0 first unconverged value (error) -302.035 (1.89549522e-06)
160786 EPS nconv=0 first unconverged value (error) -302.035 (1.87089849e-06)
160787 EPS nconv=0 first unconverged value (error) -302.035 (1.84002456e-06)
160788 EPS nconv=0 first unconverged value (error) -302.035 (1.82189154e-06)
160789 EPS nconv=0 first unconverged value (error) -302.035 (1.82189154e-06)
160790 EPS nconv=0 first unconverged value (error) -302.035 (2.84988857e-06)
160791 EPS nconv=0 first unconverged value (error) -302.035 (2.58258819e-06)
160792 EPS nconv=0 first unconverged value (error) -302.035 (2.47559712e-06)
160793 EPS nconv=0 first unconverged value (error) -302.035 (2.40077634e-06)
160794 EPS nconv=0 first unconverged value (error) -302.035 (2.34340756e-06)
160795 EPS nconv=0 first unconverged value (error) -302.035 (2.34340756e-06)
160796 EPS nconv=0 first unconverged value (error) -302.035 (2.35448886e-06)
160797 EPS nconv=0 first unconverged value (error) -302.035 (2.40784873e-06)
160798 EPS nconv=0 first unconverged value (error) -302.035 (2.10983368e-06)
160799 EPS nconv=0 first unconverged value (error) -302.035 (2.01649513e-06)
160800 EPS nconv=0 first unconverged value (error) -302.035 (1.91007762e-06)
160801 EPS nconv=0 first unconverged value (error) -302.035 (1.91007762e-06)
160802 EPS nconv=0 first unconverged value (error) -302.035 (2.05411974e-06)
160803 EPS nconv=0 first unconverged value (error) -302.035 (2.02831841e-06)
160804 EPS nconv=0 first unconverged value (error) -302.035 (1.94118398e-06)
160805 EPS nconv=0 first unconverged value (error) -302.035 (1.91442922e-06)
160806 EPS nconv=0 first unconverged value (error) -302.035 (1.89522753e-06)
160807 EPS nconv=0 first unconverged value (error) -302.035 (1.89522753e-06)
160808 EPS nconv=0 first unconverged value (error) -302.035 (2.60807273e-06)
160809 EPS nconv=0 first unconverged value (error) -302.035 (2.49232369e-06)
160810 EPS nconv=0 first unconverged value (error) -302.035 (2.40856571e-06)
160811 EPS nconv=0 first unconverged value (error) -302.035 (2.13365041e-06)
160812 EPS nconv=0 first unconverged value (error) -302.035 (2.08997460e-06)
160813 EPS nconv=0 first unconverged value (error) -302.035 (2.08997460e-06)
160814 EPS nconv=0 first unconverged value (error) -302.035 (2.22630327e-06)
160815 EPS nconv=0 first unconverged value (error) -302.035 (2.34030530e-06)
160816 EPS nconv=0 first unconverged value (error) -302.035 (2.09179446e-06)
160817 EPS nconv=0 first unconverged value (error) -302.035 (1.98746375e-06)
160818 EPS nconv=0 first unconverged value (error) -302.035 (1.93643881e-06)
160819 EPS nconv=0 first unconverged value (error) -302.035 (1.93643881e-06)
160820 EPS nconv=0 first unconverged value (error) -302.035 (1.98325283e-06)
160821 EPS nconv=0 first unconverged value (error) -302.035 (1.92061046e-06)
160822 EPS nconv=0 first unconverged value (error) -302.035 (1.87581752e-06)
160823 EPS nconv=0 first unconverged value (error) -302.035 (1.85629597e-06)
160824 EPS nconv=0 first unconverged value (error) -302.035 (1.83279135e-06)
160825 EPS nconv=0 first unconverged value (error) -302.035 (1.83279135e-06)
160826 EPS nconv=0 first unconverged value (error) -302.035 (2.07246261e-06)
160827 EPS nconv=0 first unconverged value (error) -302.035 (2.04177416e-06)
160828 EPS nconv=0 first unconverged value (error) -302.035 (1.96728583e-06)
160829 EPS nconv=0 first unconverged value (error) -302.035 (1.92306424e-06)
160830 EPS nconv=0 first unconverged value (error) -302.035 (1.91388993e-06)
160831 EPS nconv=0 first unconverged value (error) -302.035 (1.91388993e-06)
160832 EPS nconv=0 first unconverged value (error) -302.035 (2.66299651e-06)
160833 EPS nconv=0 first unconverged value (error) -302.035 (2.32418351e-06)
160834 EPS nconv=0 first unconverged value (error) -302.035 (2.19781149e-06)
160835 EPS nconv=0 first unconverged value (error) -302.035 (2.16953762e-06)
160836 EPS nconv=0 first unconverged value (error) -302.035 (2.11180275e-06)
160837 EPS nconv=0 first unconverged value (error) -302.035 (2.11180275e-06)
160838 EPS nconv=0 first unconverged value (error) -302.035 (2.18813481e-06)
160839 EPS nconv=0 first unconverged value (error) -302.035 (2.50919011e-06)
160840 EPS nconv=0 first unconverged value (error) -302.035 (2.09453570e-06)
160841 EPS nconv=0 first unconverged value (error) -302.035 (1.96321648e-06)
160842 EPS nconv=0 first unconverged value (error) -302.035 (1.92003215e-06)
160843 EPS nconv=0 first unconverged value (error) -302.035 (1.92003215e-06)
160844 EPS nconv=0 first unconverged value (error) -302.035 (1.87254885e-06)
160845 EPS nconv=0 first unconverged value (error) -302.035 (1.84744880e-06)
160846 EPS nconv=0 first unconverged value (error) -302.035 (1.83060693e-06)
160847 EPS nconv=0 first unconverged value (error) -302.035 (1.82228856e-06)
160848 EPS nconv=0 first unconverged value (error) -302.035 (1.81318888e-06)
160849 EPS nconv=0 first unconverged value (error) -302.035 (1.81318888e-06)
160850 EPS nconv=0 first unconverged value (error) -302.035 (1.87339241e-06)
160851 EPS nconv=0 first unconverged value (error) -302.035 (1.86138555e-06)
160852 EPS nconv=0 first unconverged value (error) -302.035 (1.83866201e-06)
160853 EPS nconv=0 first unconverged value (error) -302.035 (1.82783255e-06)
160854 EPS nconv=0 first unconverged value (error) -302.035 (1.82371896e-06)
160855 EPS nconv=0 first unconverged value (error) -302.035 (1.82371896e-06)
160856 EPS nconv=0 first unconverged value (error) -302.035 (2.93352202e-06)
160857 EPS nconv=0 first unconverged value (error) -302.035 (2.59006525e-06)
160858 EPS nconv=0 first unconverged value (error) -302.035 (2.49108453e-06)
160859 EPS nconv=0 first unconverged value (error) -302.035 (2.41677339e-06)
160860 EPS nconv=0 first unconverged value (error) -302.035 (2.29461997e-06)
160861 EPS nconv=0 first unconverged value (error) -302.035 (2.29461997e-06)
160862 EPS nconv=0 first unconverged value (error) -302.035 (2.36325354e-06)
160863 EPS nconv=0 first unconverged value (error) -302.035 (2.54219291e-06)
160864 EPS nconv=0 first unconverged value (error) -302.035 (2.11519347e-06)
160865 EPS nconv=0 first unconverged value (error) -302.035 (1.99310456e-06)
160866 EPS nconv=0 first unconverged value (error) -302.035 (1.96016714e-06)
160867 EPS nconv=0 first unconverged value (error) -302.035 (1.96016714e-06)
160868 EPS nconv=0 first unconverged value (error) -302.035 (1.92843080e-06)
160869 EPS nconv=0 first unconverged value (error) -302.035 (1.93513170e-06)
160870 EPS nconv=0 first unconverged value (error) -302.035 (1.87183259e-06)
160871 EPS nconv=0 first unconverged value (error) -302.035 (1.84691266e-06)
160872 EPS nconv=0 first unconverged value (error) -302.035 (1.81827003e-06)
160873 EPS nconv=0 first unconverged value (error) -302.035 (1.81827003e-06)
160874 EPS nconv=0 first unconverged value (error) -302.035 (1.93325007e-06)
160875 EPS nconv=0 first unconverged value (error) -302.035 (1.94208627e-06)
160876 EPS nconv=0 first unconverged value (error) -302.035 (1.90957727e-06)
160877 EPS nconv=0 first unconverged value (error) -302.035 (1.87583328e-06)
160878 EPS nconv=0 first unconverged value (error) -302.035 (1.86236927e-06)
160879 EPS nconv=0 first unconverged value (error) -302.035 (1.86236927e-06)
160880 EPS nconv=0 first unconverged value (error) -302.035 (3.08845684e-06)
160881 EPS nconv=0 first unconverged value (error) -302.035 (2.69341652e-06)
160882 EPS nconv=0 first unconverged value (error) -302.035 (2.52954669e-06)
160883 EPS nconv=0 first unconverged value (error) -302.035 (2.49334242e-06)
160884 EPS nconv=0 first unconverged value (error) -302.035 (2.44709167e-06)
160885 EPS nconv=0 first unconverged value (error) -302.035 (2.44709167e-06)
160886 EPS nconv=0 first unconverged value (error) -302.035 (2.58684614e-06)
160887 EPS nconv=0 first unconverged value (error) -302.035 (2.61074826e-06)
160888 EPS nconv=0 first unconverged value (error) -302.035 (2.23222956e-06)
160889 EPS nconv=0 first unconverged value (error) -302.035 (2.02151466e-06)
160890 EPS nconv=0 first unconverged value (error) -302.035 (2.00937640e-06)
160891 EPS nconv=0 first unconverged value (error) -302.035 (2.00937640e-06)
160892 EPS nconv=0 first unconverged value (error) -302.035 (2.05085973e-06)
160893 EPS nconv=0 first unconverged value (error) -302.035 (2.00523987e-06)
160894 EPS nconv=0 first unconverged value (error) -302.035 (1.95255244e-06)
160895 EPS nconv=0 first unconverged value (error) -302.035 (1.87676214e-06)
160896 EPS nconv=0 first unconverged value (error) -302.035 (1.83074665e-06)
160897 EPS nconv=0 first unconverged value (error) -302.035 (1.83074665e-06)
160898 EPS nconv=0 first unconverged value (error) -302.035 (1.84879726e-06)
160899 EPS nconv=0 first unconverged value (error) -302.035 (1.84614631e-06)
160900 EPS nconv=0 first unconverged value (error) -302.035 (1.83217007e-06)
160901 EPS nconv=0 first unconverged value (error) -302.035 (1.82424801e-06)
160902 EPS nconv=0 first unconverged value (error) -302.035 (1.81992371e-06)
160903 EPS nconv=0 first unconverged value (error) -302.035 (1.81992371e-06)
160904 EPS nconv=0 first unconverged value (error) -302.035 (1.81941139e-06)
160905 EPS nconv=0 first unconverged value (error) -302.035 (1.83907495e-06)
160906 EPS nconv=0 first unconverged value (error) -302.035 (1.81364650e-06)
160907 EPS nconv=0 first unconverged value (error) -302.035 (1.80516162e-06)
160908 EPS nconv=0 first unconverged value (error) -302.035 (1.79918657e-06)
160909 EPS nconv=0 first unconverged value (error) -302.035 (1.79918657e-06)
160910 EPS nconv=0 first unconverged value (error) -302.035 (1.95320149e-06)
160911 EPS nconv=0 first unconverged value (error) -302.035 (1.89720074e-06)
160912 EPS nconv=0 first unconverged value (error) -302.035 (1.86701045e-06)
160913 EPS nconv=0 first unconverged value (error) -302.035 (1.85988517e-06)
160914 EPS nconv=0 first unconverged value (error) -302.035 (1.84916163e-06)
160915 EPS nconv=0 first unconverged value (error) -302.035 (1.84916163e-06)
160916 EPS nconv=0 first unconverged value (error) -302.035 (1.93214846e-06)
160917 EPS nconv=0 first unconverged value (error) -302.035 (1.98679036e-06)
160918 EPS nconv=0 first unconverged value (error) -302.035 (1.92496593e-06)
160919 EPS nconv=0 first unconverged value (error) -302.035 (1.84531231e-06)
160920 EPS nconv=0 first unconverged value (error) -302.035 (1.83545307e-06)
160921 EPS nconv=0 first unconverged value (error) -302.035 (1.83545307e-06)
160922 EPS nconv=0 first unconverged value (error) -302.035 (1.98929697e-06)
160923 EPS nconv=0 first unconverged value (error) -302.035 (1.92759244e-06)
160924 EPS nconv=0 first unconverged value (error) -302.035 (1.90206119e-06)
160925 EPS nconv=0 first unconverged value (error) -302.035 (1.88821517e-06)
160926 EPS nconv=0 first unconverged value (error) -302.035 (1.87397534e-06)
160927 EPS nconv=0 first unconverged value (error) -302.035 (1.87397534e-06)
160928 EPS nconv=0 first unconverged value (error) -302.035 (1.89897028e-06)
160929 EPS nconv=0 first unconverged value (error) -302.035 (1.90507684e-06)
160930 EPS nconv=0 first unconverged value (error) -302.035 (1.83731493e-06)
160931 EPS nconv=0 first unconverged value (error) -302.035 (1.82153189e-06)
160932 EPS nconv=0 first unconverged value (error) -302.035 (1.81815509e-06)
160933 EPS nconv=0 first unconverged value (error) -302.035 (1.81815509e-06)
160934 EPS nconv=0 first unconverged value (error) -302.035 (1.97359250e-06)
160935 EPS nconv=0 first unconverged value (error) -302.035 (1.90187569e-06)
160936 EPS nconv=0 first unconverged value (error) -302.035 (1.85701193e-06)
160937 EPS nconv=0 first unconverged value (error) -302.035 (1.85305037e-06)
160938 EPS nconv=0 first unconverged value (error) -302.035 (1.84631102e-06)
160939 EPS nconv=0 first unconverged value (error) -302.035 (1.84631102e-06)
160940 EPS nconv=0 first unconverged value (error) -302.035 (2.19993658e-06)
160941 EPS nconv=0 first unconverged value (error) -302.035 (2.21633790e-06)
160942 EPS nconv=0 first unconverged value (error) -302.035 (2.06681301e-06)
160943 EPS nconv=0 first unconverged value (error) -302.035 (1.97256999e-06)
160944 EPS nconv=0 first unconverged value (error) -302.035 (1.95046246e-06)
160945 EPS nconv=0 first unconverged value (error) -302.035 (1.95046246e-06)
160946 EPS nconv=0 first unconverged value (error) -302.035 (2.05357349e-06)
160947 EPS nconv=0 first unconverged value (error) -302.035 (2.05022526e-06)
160948 EPS nconv=0 first unconverged value (error) -302.035 (1.99542282e-06)
160949 EPS nconv=0 first unconverged value (error) -302.035 (1.93823857e-06)
160950 EPS nconv=0 first unconverged value (error) -302.035 (1.88455975e-06)
160951 EPS nconv=0 first unconverged value (error) -302.035 (1.88455975e-06)
160952 EPS nconv=0 first unconverged value (error) -302.035 (2.63612209e-06)
160953 EPS nconv=0 first unconverged value (error) -302.035 (2.27484214e-06)
160954 EPS nconv=0 first unconverged value (error) -302.035 (2.17124427e-06)
160955 EPS nconv=0 first unconverged value (error) -302.035 (2.10507074e-06)
160956 EPS nconv=0 first unconverged value (error) -302.035 (2.08051695e-06)
160957 EPS nconv=0 first unconverged value (error) -302.035 (2.08051695e-06)
160958 EPS nconv=0 first unconverged value (error) -302.035 (2.08404841e-06)
160959 EPS nconv=0 first unconverged value (error) -302.035 (2.25820492e-06)
160960 EPS nconv=0 first unconverged value (error) -302.035 (1.95412298e-06)
160961 EPS nconv=0 first unconverged value (error) -302.035 (1.88517991e-06)
160962 EPS nconv=0 first unconverged value (error) -302.035 (1.86930403e-06)
160963 EPS nconv=0 first unconverged value (error) -302.035 (1.86930403e-06)
160964 EPS nconv=0 first unconverged value (error) -302.035 (2.10866419e-06)
160965 EPS nconv=0 first unconverged value (error) -302.035 (1.98486907e-06)
160966 EPS nconv=0 first unconverged value (error) -302.035 (1.92273176e-06)
160967 EPS nconv=0 first unconverged value (error) -302.035 (1.91667672e-06)
160968 EPS nconv=0 first unconverged value (error) -302.035 (1.89167645e-06)
160969 EPS nconv=0 first unconverged value (error) -302.035 (1.89167645e-06)
160970 EPS nconv=0 first unconverged value (error) -302.035 (1.95319568e-06)
160971 EPS nconv=0 first unconverged value (error) -302.035 (2.07397974e-06)
160972 EPS nconv=0 first unconverged value (error) -302.035 (1.95195570e-06)
160973 EPS nconv=0 first unconverged value (error) -302.035 (1.85166309e-06)
160974 EPS nconv=0 first unconverged value (error) -302.035 (1.85007250e-06)
160975 EPS nconv=0 first unconverged value (error) -302.035 (1.85007250e-06)
160976 EPS nconv=0 first unconverged value (error) -302.035 (2.90330614e-06)
160977 EPS nconv=0 first unconverged value (error) -302.035 (2.45801922e-06)
160978 EPS nconv=0 first unconverged value (error) -302.035 (2.39246806e-06)
160979 EPS nconv=0 first unconverged value (error) -302.035 (2.36149488e-06)
160980 EPS nconv=0 first unconverged value (error) -302.035 (2.26464782e-06)
160981 EPS nconv=0 first unconverged value (error) -302.035 (2.26464782e-06)
160982 EPS nconv=0 first unconverged value (error) -302.035 (2.56524965e-06)
160983 EPS nconv=0 first unconverged value (error) -302.035 (2.80008563e-06)
160984 EPS nconv=0 first unconverged value (error) -302.035 (2.26904465e-06)
160985 EPS nconv=0 first unconverged value (error) -302.035 (2.12737158e-06)
160986 EPS nconv=0 first unconverged value (error) -302.035 (2.04636004e-06)
160987 EPS nconv=0 first unconverged value (error) -302.035 (2.04636004e-06)
160988 EPS nconv=0 first unconverged value (error) -302.035 (1.98444513e-06)
160989 EPS nconv=0 first unconverged value (error) -302.035 (2.01803883e-06)
160990 EPS nconv=0 first unconverged value (error) -302.035 (1.89398208e-06)
160991 EPS nconv=0 first unconverged value (error) -302.035 (1.84280401e-06)
160992 EPS nconv=0 first unconverged value (error) -302.035 (1.82913201e-06)
160993 EPS nconv=0 first unconverged value (error) -302.035 (1.82913201e-06)
160994 EPS nconv=0 first unconverged value (error) -302.035 (2.00428485e-06)
160995 EPS nconv=0 first unconverged value (error) -302.035 (1.94199183e-06)
160996 EPS nconv=0 first unconverged value (error) -302.035 (1.89412622e-06)
160997 EPS nconv=0 first unconverged value (error) -302.035 (1.88250035e-06)
160998 EPS nconv=0 first unconverged value (error) -302.035 (1.86560071e-06)
160999 EPS nconv=0 first unconverged value (error) -302.035 (1.86560071e-06)
161000 EPS nconv=0 first unconverged value (error) -302.035 (2.44520192e-06)
161001 EPS nconv=0 first unconverged value (error) -302.035 (2.39285261e-06)
161002 EPS nconv=0 first unconverged value (error) -302.035 (2.27630746e-06)
161003 EPS nconv=0 first unconverged value (error) -302.035 (2.09152755e-06)
161004 EPS nconv=0 first unconverged value (error) -302.035 (2.04946067e-06)
161005 EPS nconv=0 first unconverged value (error) -302.035 (2.04946067e-06)
161006 EPS nconv=0 first unconverged value (error) -302.035 (3.10659683e-06)
161007 EPS nconv=0 first unconverged value (error) -302.035 (2.89358869e-06)
161008 EPS nconv=0 first unconverged value (error) -302.035 (2.73523780e-06)
161009 EPS nconv=0 first unconverged value (error) -302.035 (2.71738522e-06)
161010 EPS nconv=0 first unconverged value (error) -302.035 (2.64558986e-06)
161011 EPS nconv=0 first unconverged value (error) -302.035 (2.64558986e-06)
161012 EPS nconv=0 first unconverged value (error) -302.035 (2.64144520e-06)
161013 EPS nconv=0 first unconverged value (error) -302.035 (2.30230646e-06)
161014 EPS nconv=0 first unconverged value (error) -302.035 (2.00354297e-06)
161015 EPS nconv=0 first unconverged value (error) -302.035 (1.92621345e-06)
161016 EPS nconv=0 first unconverged value (error) -302.035 (1.88815917e-06)
161017 EPS nconv=0 first unconverged value (error) -302.035 (1.88815917e-06)
161018 EPS nconv=0 first unconverged value (error) -302.035 (2.16771742e-06)
161019 EPS nconv=0 first unconverged value (error) -302.035 (1.98964287e-06)
161020 EPS nconv=0 first unconverged value (error) -302.035 (1.91288581e-06)
161021 EPS nconv=0 first unconverged value (error) -302.035 (1.87942110e-06)
161022 EPS nconv=0 first unconverged value (error) -302.035 (1.87134669e-06)
161023 EPS nconv=0 first unconverged value (error) -302.035 (1.87134669e-06)
161024 EPS nconv=0 first unconverged value (error) -302.035 (2.55340799e-06)
161025 EPS nconv=0 first unconverged value (error) -302.035 (2.42766533e-06)
161026 EPS nconv=0 first unconverged value (error) -302.035 (2.26158976e-06)
161027 EPS nconv=0 first unconverged value (error) -302.035 (2.20860156e-06)
161028 EPS nconv=0 first unconverged value (error) -302.035 (2.17173715e-06)
161029 EPS nconv=0 first unconverged value (error) -302.035 (2.17173715e-06)
161030 EPS nconv=0 first unconverged value (error) -302.035 (2.31872350e-06)
161031 EPS nconv=0 first unconverged value (error) -302.035 (2.40631725e-06)
161032 EPS nconv=0 first unconverged value (error) -302.035 (2.20587835e-06)
161033 EPS nconv=0 first unconverged value (error) -302.035 (1.92875307e-06)
161034 EPS nconv=0 first unconverged value (error) -302.035 (1.86887462e-06)
161035 EPS nconv=0 first unconverged value (error) -302.035 (1.86887462e-06)
161036 EPS nconv=0 first unconverged value (error) -302.035 (2.27169705e-06)
161037 EPS nconv=0 first unconverged value (error) -302.035 (2.16947405e-06)
161038 EPS nconv=0 first unconverged value (error) -302.035 (2.07114209e-06)
161039 EPS nconv=0 first unconverged value (error) -302.035 (2.00121263e-06)
161040 EPS nconv=0 first unconverged value (error) -302.035 (1.97243770e-06)
161041 EPS nconv=0 first unconverged value (error) -302.035 (1.97243770e-06)
161042 EPS nconv=0 first unconverged value (error) -302.035 (2.71876481e-06)
161043 EPS nconv=0 first unconverged value (error) -302.035 (2.66859504e-06)
161044 EPS nconv=0 first unconverged value (error) -302.035 (2.49305150e-06)
161045 EPS nconv=0 first unconverged value (error) -302.035 (2.22579866e-06)
161046 EPS nconv=0 first unconverged value (error) -302.035 (2.14120252e-06)
161047 EPS nconv=0 first unconverged value (error) -302.035 (2.14120252e-06)
161048 EPS nconv=0 first unconverged value (error) -302.035 (3.04276235e-06)
161049 EPS nconv=0 first unconverged value (error) -302.035 (2.90431299e-06)
161050 EPS nconv=0 first unconverged value (error) -302.035 (2.69221570e-06)
161051 EPS nconv=0 first unconverged value (error) -302.035 (2.58142629e-06)
161052 EPS nconv=0 first unconverged value (error) -302.035 (2.45041393e-06)
161053 EPS nconv=0 first unconverged value (error) -302.035 (2.45041393e-06)
161054 EPS nconv=0 first unconverged value (error) -302.035 (2.39933386e-06)
161055 EPS nconv=0 first unconverged value (error) -302.035 (2.37712906e-06)
161056 EPS nconv=0 first unconverged value (error) -302.035 (2.07376612e-06)
161057 EPS nconv=0 first unconverged value (error) -302.035 (1.98213222e-06)
161058 EPS nconv=0 first unconverged value (error) -302.035 (1.92112425e-06)
161059 EPS nconv=0 first unconverged value (error) -302.035 (1.92112425e-06)
161060 EPS nconv=0 first unconverged value (error) -302.035 (2.04502148e-06)
161061 EPS nconv=0 first unconverged value (error) -302.035 (1.93238202e-06)
161062 EPS nconv=0 first unconverged value (error) -302.035 (1.89444510e-06)
161063 EPS nconv=0 first unconverged value (error) -302.035 (1.86926888e-06)
161064 EPS nconv=0 first unconverged value (error) -302.035 (1.86048083e-06)
161065 EPS nconv=0 first unconverged value (error) -302.035 (1.86048083e-06)
161066 EPS nconv=0 first unconverged value (error) -302.035 (2.60616249e-06)
161067 EPS nconv=0 first unconverged value (error) -302.035 (2.39764484e-06)
161068 EPS nconv=0 first unconverged value (error) -302.035 (2.28458571e-06)
161069 EPS nconv=0 first unconverged value (error) -302.035 (2.08920189e-06)
161070 EPS nconv=0 first unconverged value (error) -302.035 (2.07521408e-06)
161071 EPS nconv=0 first unconverged value (error) -302.035 (2.07521408e-06)
161072 EPS nconv=0 first unconverged value (error) -302.035 (2.07083997e-06)
161073 EPS nconv=0 first unconverged value (error) -302.035 (2.29422817e-06)
161074 EPS nconv=0 first unconverged value (error) -302.035 (1.96651417e-06)
161075 EPS nconv=0 first unconverged value (error) -302.035 (1.86771618e-06)
161076 EPS nconv=0 first unconverged value (error) -302.035 (1.81974798e-06)
161077 EPS nconv=0 first unconverged value (error) -302.035 (1.81974798e-06)
161078 EPS nconv=0 first unconverged value (error) -302.035 (3.63965235e-06)
161079 EPS nconv=0 first unconverged value (error) -302.035 (3.25649209e-06)
161080 EPS nconv=0 first unconverged value (error) -302.035 (3.07306569e-06)
161081 EPS nconv=0 first unconverged value (error) -302.035 (2.94306127e-06)
161082 EPS nconv=0 first unconverged value (error) -302.035 (2.81271905e-06)
161083 EPS nconv=0 first unconverged value (error) -302.035 (2.81271905e-06)
161084 EPS nconv=0 first unconverged value (error) -302.035 (3.01843317e-06)
161085 EPS nconv=0 first unconverged value (error) -302.035 (3.30208095e-06)
161086 EPS nconv=0 first unconverged value (error) -302.035 (2.86859801e-06)
161087 EPS nconv=0 first unconverged value (error) -302.035 (2.10961754e-06)
161088 EPS nconv=0 first unconverged value (error) -302.035 (2.00083052e-06)
161089 EPS nconv=0 first unconverged value (error) -302.035 (2.00083052e-06)
161090 EPS nconv=0 first unconverged value (error) -302.035 (2.26911841e-06)
161091 EPS nconv=0 first unconverged value (error) -302.035 (2.17515819e-06)
161092 EPS nconv=0 first unconverged value (error) -302.035 (2.18242469e-06)
161093 EPS nconv=0 first unconverged value (error) -302.035 (2.04319342e-06)
161094 EPS nconv=0 first unconverged value (error) -302.035 (2.02696059e-06)
161095 EPS nconv=0 first unconverged value (error) -302.035 (2.02696059e-06)
161096 EPS nconv=0 first unconverged value (error) -302.035 (2.27539675e-06)
161097 EPS nconv=0 first unconverged value (error) -302.035 (2.13240809e-06)
161098 EPS nconv=0 first unconverged value (error) -302.035 (1.99303372e-06)
161099 EPS nconv=0 first unconverged value (error) -302.035 (1.96853246e-06)
161100 EPS nconv=0 first unconverged value (error) -302.035 (1.94145179e-06)
161101 EPS nconv=0 first unconverged value (error) -302.035 (1.94145179e-06)
161102 EPS nconv=0 first unconverged value (error) -302.035 (2.27219479e-06)
161103 EPS nconv=0 first unconverged value (error) -302.035 (2.24680089e-06)
161104 EPS nconv=0 first unconverged value (error) -302.035 (2.06938102e-06)
161105 EPS nconv=0 first unconverged value (error) -302.035 (2.03831371e-06)
161106 EPS nconv=0 first unconverged value (error) -302.035 (1.98499909e-06)
161107 EPS nconv=0 first unconverged value (error) -302.035 (1.98499909e-06)
161108 EPS nconv=0 first unconverged value (error) -302.035 (3.13595312e-06)
161109 EPS nconv=0 first unconverged value (error) -302.035 (3.01624968e-06)
161110 EPS nconv=0 first unconverged value (error) -302.035 (2.67471680e-06)
161111 EPS nconv=0 first unconverged value (error) -302.035 (2.52120376e-06)
161112 EPS nconv=0 first unconverged value (error) -302.035 (2.38691764e-06)
161113 EPS nconv=0 first unconverged value (error) -302.035 (2.38691764e-06)
161114 EPS nconv=0 first unconverged value (error) -302.035 (2.39989028e-06)
161115 EPS nconv=0 first unconverged value (error) -302.035 (2.53852998e-06)
161116 EPS nconv=0 first unconverged value (error) -302.035 (2.33771323e-06)
161117 EPS nconv=0 first unconverged value (error) -302.035 (2.01762433e-06)
161118 EPS nconv=0 first unconverged value (error) -302.035 (1.96665614e-06)
161119 EPS nconv=0 first unconverged value (error) -302.035 (1.96665614e-06)
161120 EPS nconv=0 first unconverged value (error) -302.035 (1.94617833e-06)
161121 EPS nconv=0 first unconverged value (error) -302.035 (1.89299308e-06)
161122 EPS nconv=0 first unconverged value (error) -302.035 (1.85964623e-06)
161123 EPS nconv=0 first unconverged value (error) -302.035 (1.84676786e-06)
161124 EPS nconv=0 first unconverged value (error) -302.035 (1.83083666e-06)
161125 EPS nconv=0 first unconverged value (error) -302.035 (1.83083666e-06)
161126 EPS nconv=0 first unconverged value (error) -302.035 (2.12798860e-06)
161127 EPS nconv=0 first unconverged value (error) -302.035 (2.08090108e-06)
161128 EPS nconv=0 first unconverged value (error) -302.035 (2.00296271e-06)
161129 EPS nconv=0 first unconverged value (error) -302.035 (1.94390668e-06)
161130 EPS nconv=0 first unconverged value (error) -302.035 (1.92343672e-06)
161131 EPS nconv=0 first unconverged value (error) -302.035 (1.92343672e-06)
161132 EPS nconv=0 first unconverged value (error) -302.035 (3.60233568e-06)
161133 EPS nconv=0 first unconverged value (error) -302.035 (3.08502038e-06)
161134 EPS nconv=0 first unconverged value (error) -302.035 (2.86984900e-06)
161135 EPS nconv=0 first unconverged value (error) -302.035 (2.80182151e-06)
161136 EPS nconv=0 first unconverged value (error) -302.035 (2.65476697e-06)
161137 EPS nconv=0 first unconverged value (error) -302.035 (2.65476697e-06)
161138 EPS nconv=0 first unconverged value (error) -302.035 (2.69945718e-06)
161139 EPS nconv=0 first unconverged value (error) -302.035 (3.06704110e-06)
161140 EPS nconv=0 first unconverged value (error) -302.035 (2.44499937e-06)
161141 EPS nconv=0 first unconverged value (error) -302.035 (2.15119288e-06)
161142 EPS nconv=0 first unconverged value (error) -302.035 (2.01424214e-06)
161143 EPS nconv=0 first unconverged value (error) -302.035 (2.01424214e-06)
161144 EPS nconv=0 first unconverged value (error) -302.035 (1.87826087e-06)
161145 EPS nconv=0 first unconverged value (error) -302.035 (1.86922350e-06)
161146 EPS nconv=0 first unconverged value (error) -302.035 (1.84451609e-06)
161147 EPS nconv=0 first unconverged value (error) -302.035 (1.83706190e-06)
161148 EPS nconv=0 first unconverged value (error) -302.035 (1.82447679e-06)
161149 EPS nconv=0 first unconverged value (error) -302.035 (1.82447679e-06)
161150 EPS nconv=0 first unconverged value (error) -302.035 (2.13582151e-06)
161151 EPS nconv=0 first unconverged value (error) -302.035 (2.08558167e-06)
161152 EPS nconv=0 first unconverged value (error) -302.035 (2.01019434e-06)
161153 EPS nconv=0 first unconverged value (error) -302.035 (1.97707640e-06)
161154 EPS nconv=0 first unconverged value (error) -302.035 (1.94409719e-06)
161155 EPS nconv=0 first unconverged value (error) -302.035 (1.94409719e-06)
161156 EPS nconv=0 first unconverged value (error) -302.035 (2.44079353e-06)
161157 EPS nconv=0 first unconverged value (error) -302.035 (2.41793436e-06)
161158 EPS nconv=0 first unconverged value (error) -302.035 (2.30627355e-06)
161159 EPS nconv=0 first unconverged value (error) -302.035 (2.10865798e-06)
161160 EPS nconv=0 first unconverged value (error) -302.035 (2.06216956e-06)
161161 EPS nconv=0 first unconverged value (error) -302.035 (2.06216956e-06)
161162 EPS nconv=0 first unconverged value (error) -302.035 (2.62928734e-06)
161163 EPS nconv=0 first unconverged value (error) -302.035 (2.45202081e-06)
161164 EPS nconv=0 first unconverged value (error) -302.035 (2.30927564e-06)
161165 EPS nconv=0 first unconverged value (error) -302.035 (2.23208769e-06)
161166 EPS nconv=0 first unconverged value (error) -302.035 (2.16561210e-06)
161167 EPS nconv=0 first unconverged value (error) -302.035 (2.16561210e-06)
161168 EPS nconv=0 first unconverged value (error) -302.035 (2.44062754e-06)
161169 EPS nconv=0 first unconverged value (error) -302.035 (2.42260295e-06)
161170 EPS nconv=0 first unconverged value (error) -302.035 (2.19070587e-06)
161171 EPS nconv=0 first unconverged value (error) -302.035 (2.13387328e-06)
161172 EPS nconv=0 first unconverged value (error) -302.035 (2.03220091e-06)
161173 EPS nconv=0 first unconverged value (error) -302.035 (2.03220091e-06)
161174 EPS nconv=0 first unconverged value (error) -302.035 (1.96270206e-06)
161175 EPS nconv=0 first unconverged value (error) -302.035 (2.02695756e-06)
161176 EPS nconv=0 first unconverged value (error) -302.035 (1.88346185e-06)
161177 EPS nconv=0 first unconverged value (error) -302.035 (1.85918618e-06)
161178 EPS nconv=0 first unconverged value (error) -302.035 (1.83564354e-06)
161179 EPS nconv=0 first unconverged value (error) -302.035 (1.83564354e-06)
161180 EPS nconv=0 first unconverged value (error) -302.035 (1.79961034e-06)
161181 EPS nconv=0 first unconverged value (error) -302.035 (1.79921888e-06)
161182 EPS nconv=0 first unconverged value (error) -302.035 (1.79750728e-06)
161183 EPS nconv=0 first unconverged value (error) -302.035 (1.79488324e-06)
161184 EPS nconv=0 first unconverged value (error) -302.035 (1.79417533e-06)
161185 EPS nconv=0 first unconverged value (error) -302.035 (1.79417533e-06)
161186 EPS nconv=0 first unconverged value (error) -302.035 (2.69915419e-06)
161187 EPS nconv=0 first unconverged value (error) -302.035 (2.44970619e-06)
161188 EPS nconv=0 first unconverged value (error) -302.035 (2.41112320e-06)
161189 EPS nconv=0 first unconverged value (error) -302.035 (2.30384233e-06)
161190 EPS nconv=0 first unconverged value (error) -302.035 (2.22222525e-06)
161191 EPS nconv=0 first unconverged value (error) -302.035 (2.22222525e-06)
161192 EPS nconv=0 first unconverged value (error) -302.035 (2.63544441e-06)
161193 EPS nconv=0 first unconverged value (error) -302.035 (2.85339079e-06)
161194 EPS nconv=0 first unconverged value (error) -302.035 (2.51483450e-06)
161195 EPS nconv=0 first unconverged value (error) -302.035 (2.20758377e-06)
161196 EPS nconv=0 first unconverged value (error) -302.035 (2.09228103e-06)
161197 EPS nconv=0 first unconverged value (error) -302.035 (2.09228103e-06)
161198 EPS nconv=0 first unconverged value (error) -302.035 (2.12775152e-06)
161199 EPS nconv=0 first unconverged value (error) -302.035 (2.14728654e-06)
161200 EPS nconv=0 first unconverged value (error) -302.035 (2.08905540e-06)
161201 EPS nconv=0 first unconverged value (error) -302.035 (1.96109428e-06)
161202 EPS nconv=0 first unconverged value (error) -302.035 (1.85845231e-06)
161203 EPS nconv=0 first unconverged value (error) -302.035 (1.85845231e-06)
161204 EPS nconv=0 first unconverged value (error) -302.035 (1.97452500e-06)
161205 EPS nconv=0 first unconverged value (error) -302.035 (1.92451493e-06)
161206 EPS nconv=0 first unconverged value (error) -302.035 (1.88603592e-06)
161207 EPS nconv=0 first unconverged value (error) -302.035 (1.86894208e-06)
161208 EPS nconv=0 first unconverged value (error) -302.035 (1.86014075e-06)
161209 EPS nconv=0 first unconverged value (error) -302.035 (1.86014075e-06)
161210 EPS nconv=0 first unconverged value (error) -302.035 (2.79305231e-06)
161211 EPS nconv=0 first unconverged value (error) -302.035 (2.56841918e-06)
161212 EPS nconv=0 first unconverged value (error) -302.035 (2.40401844e-06)
161213 EPS nconv=0 first unconverged value (error) -302.035 (2.28119828e-06)
161214 EPS nconv=0 first unconverged value (error) -302.035 (2.21696171e-06)
161215 EPS nconv=0 first unconverged value (error) -302.035 (2.21696171e-06)
161216 EPS nconv=0 first unconverged value (error) -302.035 (2.22598589e-06)
161217 EPS nconv=0 first unconverged value (error) -302.035 (2.47293757e-06)
161218 EPS nconv=0 first unconverged value (error) -302.035 (2.21321079e-06)
161219 EPS nconv=0 first unconverged value (error) -302.035 (1.99282602e-06)
161220 EPS nconv=0 first unconverged value (error) -302.035 (1.90119110e-06)
161221 EPS nconv=0 first unconverged value (error) -302.035 (1.90119110e-06)
161222 EPS nconv=0 first unconverged value (error) -302.035 (1.84929458e-06)
161223 EPS nconv=0 first unconverged value (error) -302.035 (1.83787760e-06)
161224 EPS nconv=0 first unconverged value (error) -302.035 (1.82943831e-06)
161225 EPS nconv=0 first unconverged value (error) -302.035 (1.82515350e-06)
161226 EPS nconv=0 first unconverged value (error) -302.035 (1.81785398e-06)
161227 EPS nconv=0 first unconverged value (error) -302.035 (1.81785398e-06)
161228 EPS nconv=0 first unconverged value (error) -302.035 (2.26488457e-06)
161229 EPS nconv=0 first unconverged value (error) -302.035 (2.17262853e-06)
161230 EPS nconv=0 first unconverged value (error) -302.035 (2.09152202e-06)
161231 EPS nconv=0 first unconverged value (error) -302.035 (2.07195985e-06)
161232 EPS nconv=0 first unconverged value (error) -302.035 (2.03713712e-06)
161233 EPS nconv=0 first unconverged value (error) -302.035 (2.03713712e-06)
161234 EPS nconv=0 first unconverged value (error) -302.035 (2.74006943e-06)
161235 EPS nconv=0 first unconverged value (error) -302.035 (2.76157187e-06)
161236 EPS nconv=0 first unconverged value (error) -302.035 (2.54719625e-06)
161237 EPS nconv=0 first unconverged value (error) -302.035 (2.18785811e-06)
161238 EPS nconv=0 first unconverged value (error) -302.035 (2.14080516e-06)
161239 EPS nconv=0 first unconverged value (error) -302.035 (2.14080516e-06)
161240 EPS nconv=0 first unconverged value (error) -302.035 (2.15829537e-06)
161241 EPS nconv=0 first unconverged value (error) -302.035 (2.23241404e-06)
161242 EPS nconv=0 first unconverged value (error) -302.035 (2.15205806e-06)
161243 EPS nconv=0 first unconverged value (error) -302.035 (1.94676598e-06)
161244 EPS nconv=0 first unconverged value (error) -302.035 (1.88388144e-06)
161245 EPS nconv=0 first unconverged value (error) -302.035 (1.88388144e-06)
161246 EPS nconv=0 first unconverged value (error) -302.035 (1.91657185e-06)
161247 EPS nconv=0 first unconverged value (error) -302.035 (1.85101829e-06)
161248 EPS nconv=0 first unconverged value (error) -302.035 (1.83431321e-06)
161249 EPS nconv=0 first unconverged value (error) -302.035 (1.82280586e-06)
161250 EPS nconv=0 first unconverged value (error) -302.035 (1.81770879e-06)
161251 EPS nconv=0 first unconverged value (error) -302.035 (1.81770879e-06)
161252 EPS nconv=0 first unconverged value (error) -302.035 (1.82180511e-06)
161253 EPS nconv=0 first unconverged value (error) -302.035 (1.83909317e-06)
161254 EPS nconv=0 first unconverged value (error) -302.035 (1.81463329e-06)
161255 EPS nconv=0 first unconverged value (error) -302.035 (1.80700500e-06)
161256 EPS nconv=0 first unconverged value (error) -302.035 (1.80297701e-06)
161257 EPS nconv=0 first unconverged value (error) -302.035 (1.80297701e-06)
161258 EPS nconv=0 first unconverged value (error) -302.035 (3.10755898e-06)
161259 EPS nconv=0 first unconverged value (error) -302.035 (2.80157331e-06)
161260 EPS nconv=0 first unconverged value (error) -302.035 (2.59996206e-06)
161261 EPS nconv=0 first unconverged value (error) -302.035 (2.56464242e-06)
161262 EPS nconv=0 first unconverged value (error) -302.035 (2.39620619e-06)
161263 EPS nconv=0 first unconverged value (error) -302.035 (2.39620619e-06)
161264 EPS nconv=0 first unconverged value (error) -302.035 (2.42133507e-06)
161265 EPS nconv=0 first unconverged value (error) -302.035 (2.72550892e-06)
161266 EPS nconv=0 first unconverged value (error) -302.035 (2.39639530e-06)
161267 EPS nconv=0 first unconverged value (error) -302.035 (2.02677157e-06)
161268 EPS nconv=0 first unconverged value (error) -302.035 (1.99243221e-06)
161269 EPS nconv=0 first unconverged value (error) -302.035 (1.99243221e-06)
161270 EPS nconv=0 first unconverged value (error) -302.035 (2.26533457e-06)
161271 EPS nconv=0 first unconverged value (error) -302.035 (2.08270784e-06)
161272 EPS nconv=0 first unconverged value (error) -302.035 (2.02899394e-06)
161273 EPS nconv=0 first unconverged value (error) -302.035 (1.99970804e-06)
161274 EPS nconv=0 first unconverged value (error) -302.035 (1.96210784e-06)
161275 EPS nconv=0 first unconverged value (error) -302.035 (1.96210784e-06)
161276 EPS nconv=0 first unconverged value (error) -302.035 (2.55191509e-06)
161277 EPS nconv=0 first unconverged value (error) -302.035 (2.68185047e-06)
161278 EPS nconv=0 first unconverged value (error) -302.035 (2.45325604e-06)
161279 EPS nconv=0 first unconverged value (error) -302.035 (2.24281381e-06)
161280 EPS nconv=0 first unconverged value (error) -302.035 (2.17455947e-06)
161281 EPS nconv=0 first unconverged value (error) -302.035 (2.17455947e-06)
161282 EPS nconv=0 first unconverged value (error) -302.035 (2.28181925e-06)
161283 EPS nconv=0 first unconverged value (error) -302.035 (2.13488328e-06)
161284 EPS nconv=0 first unconverged value (error) -302.035 (2.01187181e-06)
161285 EPS nconv=0 first unconverged value (error) -302.035 (1.93765263e-06)
161286 EPS nconv=0 first unconverged value (error) -302.035 (1.92052701e-06)
161287 EPS nconv=0 first unconverged value (error) -302.035 (1.92052701e-06)
161288 EPS nconv=0 first unconverged value (error) -302.035 (1.92878214e-06)
161289 EPS nconv=0 first unconverged value (error) -302.035 (1.93695578e-06)
161290 EPS nconv=0 first unconverged value (error) -302.035 (1.87038236e-06)
161291 EPS nconv=0 first unconverged value (error) -302.035 (1.84173354e-06)
161292 EPS nconv=0 first unconverged value (error) -302.035 (1.83665668e-06)
161293 EPS nconv=0 first unconverged value (error) -302.035 (1.83665668e-06)
161294 EPS nconv=0 first unconverged value (error) -302.035 (1.81728185e-06)
161295 EPS nconv=0 first unconverged value (error) -302.035 (1.81871676e-06)
161296 EPS nconv=0 first unconverged value (error) -302.035 (1.80538774e-06)
161297 EPS nconv=0 first unconverged value (error) -302.035 (1.79938729e-06)
161298 EPS nconv=0 first unconverged value (error) -302.035 (1.79758557e-06)
161299 EPS nconv=0 first unconverged value (error) -302.035 (1.79758557e-06)
161300 EPS nconv=0 first unconverged value (error) -302.035 (2.35217344e-06)
161301 EPS nconv=0 first unconverged value (error) -302.035 (2.17278733e-06)
161302 EPS nconv=0 first unconverged value (error) -302.035 (2.12440556e-06)
161303 EPS nconv=0 first unconverged value (error) -302.035 (2.10440971e-06)
161304 EPS nconv=0 first unconverged value (error) -302.035 (2.07433686e-06)
161305 EPS nconv=0 first unconverged value (error) -302.035 (2.07433686e-06)
161306 EPS nconv=0 first unconverged value (error) -302.035 (2.28309907e-06)
161307 EPS nconv=0 first unconverged value (error) -302.035 (2.33168257e-06)
161308 EPS nconv=0 first unconverged value (error) -302.035 (2.09674497e-06)
161309 EPS nconv=0 first unconverged value (error) -302.035 (1.90872208e-06)
161310 EPS nconv=0 first unconverged value (error) -302.035 (1.88984952e-06)
161311 EPS nconv=0 first unconverged value (error) -302.035 (1.88984952e-06)
161312 EPS nconv=0 first unconverged value (error) -302.035 (1.89685458e-06)
161313 EPS nconv=0 first unconverged value (error) -302.035 (1.92548612e-06)
161314 EPS nconv=0 first unconverged value (error) -302.035 (1.89552353e-06)
161315 EPS nconv=0 first unconverged value (error) -302.035 (1.82895379e-06)
161316 EPS nconv=0 first unconverged value (error) -302.035 (1.81761612e-06)
161317 EPS nconv=0 first unconverged value (error) -302.035 (1.81761612e-06)
161318 EPS nconv=0 first unconverged value (error) -302.035 (2.55288585e-06)
161319 EPS nconv=0 first unconverged value (error) -302.035 (2.28735410e-06)
161320 EPS nconv=0 first unconverged value (error) -302.035 (2.23909469e-06)
161321 EPS nconv=0 first unconverged value (error) -302.035 (2.20076894e-06)
161322 EPS nconv=0 first unconverged value (error) -302.035 (2.15280216e-06)
161323 EPS nconv=0 first unconverged value (error) -302.035 (2.15280216e-06)
161324 EPS nconv=0 first unconverged value (error) -302.035 (4.24889332e-06)
161325 EPS nconv=0 first unconverged value (error) -302.035 (4.25096320e-06)
161326 EPS nconv=0 first unconverged value (error) -302.035 (3.69118019e-06)
161327 EPS nconv=0 first unconverged value (error) -302.035 (3.24125428e-06)
161328 EPS nconv=0 first unconverged value (error) -302.035 (3.14693213e-06)
161329 EPS nconv=0 first unconverged value (error) -302.035 (3.14693213e-06)
161330 EPS nconv=0 first unconverged value (error) -302.035 (3.24398170e-06)
161331 EPS nconv=0 first unconverged value (error) -302.035 (3.11775576e-06)
161332 EPS nconv=0 first unconverged value (error) -302.035 (2.68254313e-06)
161333 EPS nconv=0 first unconverged value (error) -302.035 (2.18088656e-06)
161334 EPS nconv=0 first unconverged value (error) -302.035 (2.02863873e-06)
161335 EPS nconv=0 first unconverged value (error) -302.035 (2.02863873e-06)
161336 EPS nconv=0 first unconverged value (error) -302.035 (2.57387022e-06)
161337 EPS nconv=0 first unconverged value (error) -302.035 (2.42533740e-06)
161338 EPS nconv=0 first unconverged value (error) -302.035 (2.21990892e-06)
161339 EPS nconv=0 first unconverged value (error) -302.035 (2.09005226e-06)
161340 EPS nconv=0 first unconverged value (error) -302.035 (2.01619766e-06)
161341 EPS nconv=0 first unconverged value (error) -302.035 (2.01619766e-06)
161342 EPS nconv=0 first unconverged value (error) -302.035 (2.28168502e-06)
161343 EPS nconv=0 first unconverged value (error) -302.035 (2.26656781e-06)
161344 EPS nconv=0 first unconverged value (error) -302.035 (2.07293405e-06)
161345 EPS nconv=0 first unconverged value (error) -302.035 (2.01458963e-06)
161346 EPS nconv=0 first unconverged value (error) -302.035 (1.97635829e-06)
161347 EPS nconv=0 first unconverged value (error) -302.035 (1.97635829e-06)
161348 EPS nconv=0 first unconverged value (error) -302.035 (2.19997816e-06)
161349 EPS nconv=0 first unconverged value (error) -302.035 (2.11830671e-06)
161350 EPS nconv=0 first unconverged value (error) -302.035 (1.99000118e-06)
161351 EPS nconv=0 first unconverged value (error) -302.035 (1.96098012e-06)
161352 EPS nconv=0 first unconverged value (error) -302.035 (1.92864676e-06)
161353 EPS nconv=0 first unconverged value (error) -302.035 (1.92864676e-06)
161354 EPS nconv=0 first unconverged value (error) -302.035 (1.96858983e-06)
161355 EPS nconv=0 first unconverged value (error) -302.035 (1.96437788e-06)
161356 EPS nconv=0 first unconverged value (error) -302.035 (1.88481752e-06)
161357 EPS nconv=0 first unconverged value (error) -302.035 (1.83847031e-06)
161358 EPS nconv=0 first unconverged value (error) -302.035 (1.83398470e-06)
161359 EPS nconv=0 first unconverged value (error) -302.035 (1.83398470e-06)
161360 EPS nconv=0 first unconverged value (error) -302.035 (1.81974652e-06)
161361 EPS nconv=0 first unconverged value (error) -302.035 (1.84222701e-06)
161362 EPS nconv=0 first unconverged value (error) -302.035 (1.81852541e-06)
161363 EPS nconv=0 first unconverged value (error) -302.035 (1.80132663e-06)
161364 EPS nconv=0 first unconverged value (error) -302.035 (1.79793700e-06)
161365 EPS nconv=0 first unconverged value (error) -302.035 (1.79793700e-06)
161366 EPS nconv=0 first unconverged value (error) -302.035 (2.37823885e-06)
161367 EPS nconv=0 first unconverged value (error) -302.035 (2.17956544e-06)
161368 EPS nconv=0 first unconverged value (error) -302.035 (2.15412431e-06)
161369 EPS nconv=0 first unconverged value (error) -302.035 (2.11736847e-06)
161370 EPS nconv=0 first unconverged value (error) -302.035 (2.05842565e-06)
161371 EPS nconv=0 first unconverged value (error) -302.035 (2.05842565e-06)
161372 EPS nconv=0 first unconverged value (error) -302.035 (2.06467449e-06)
161373 EPS nconv=0 first unconverged value (error) -302.035 (2.18275637e-06)
161374 EPS nconv=0 first unconverged value (error) -302.035 (1.98345328e-06)
161375 EPS nconv=0 first unconverged value (error) -302.035 (1.86811455e-06)
161376 EPS nconv=0 first unconverged value (error) -302.035 (1.84625787e-06)
161377 EPS nconv=0 first unconverged value (error) -302.035 (1.84625787e-06)
161378 EPS nconv=0 first unconverged value (error) -302.035 (2.23573579e-06)
161379 EPS nconv=0 first unconverged value (error) -302.035 (2.07143390e-06)
161380 EPS nconv=0 first unconverged value (error) -302.035 (1.99903954e-06)
161381 EPS nconv=0 first unconverged value (error) -302.035 (1.97194990e-06)
161382 EPS nconv=0 first unconverged value (error) -302.035 (1.94920438e-06)
161383 EPS nconv=0 first unconverged value (error) -302.035 (1.94920438e-06)
161384 EPS nconv=0 first unconverged value (error) -302.035 (2.68326794e-06)
161385 EPS nconv=0 first unconverged value (error) -302.035 (2.65535611e-06)
161386 EPS nconv=0 first unconverged value (error) -302.035 (2.44925168e-06)
161387 EPS nconv=0 first unconverged value (error) -302.035 (2.20113140e-06)
161388 EPS nconv=0 first unconverged value (error) -302.035 (2.14970434e-06)
161389 EPS nconv=0 first unconverged value (error) -302.035 (2.14970434e-06)
161390 EPS nconv=0 first unconverged value (error) -302.035 (2.31056442e-06)
161391 EPS nconv=0 first unconverged value (error) -302.035 (2.46767896e-06)
161392 EPS nconv=0 first unconverged value (error) -302.035 (2.30332275e-06)
161393 EPS nconv=0 first unconverged value (error) -302.035 (1.94187439e-06)
161394 EPS nconv=0 first unconverged value (error) -302.035 (1.88840471e-06)
161395 EPS nconv=0 first unconverged value (error) -302.035 (1.88840471e-06)
161396 EPS nconv=0 first unconverged value (error) -302.035 (2.14034760e-06)
161397 EPS nconv=0 first unconverged value (error) -302.035 (2.01420543e-06)
161398 EPS nconv=0 first unconverged value (error) -302.035 (1.96593879e-06)
161399 EPS nconv=0 first unconverged value (error) -302.035 (1.96289661e-06)
161400 EPS nconv=0 first unconverged value (error) -302.035 (1.95808089e-06)
161401 EPS nconv=0 first unconverged value (error) -302.035 (1.95808089e-06)
161402 EPS nconv=0 first unconverged value (error) -302.035 (1.98769925e-06)
161403 EPS nconv=0 first unconverged value (error) -302.035 (1.94421954e-06)
161404 EPS nconv=0 first unconverged value (error) -302.035 (1.85685123e-06)
161405 EPS nconv=0 first unconverged value (error) -302.035 (1.84228934e-06)
161406 EPS nconv=0 first unconverged value (error) -302.035 (1.83315234e-06)
161407 EPS nconv=0 first unconverged value (error) -302.035 (1.83315234e-06)
161408 EPS nconv=0 first unconverged value (error) -302.035 (2.27954714e-06)
161409 EPS nconv=0 first unconverged value (error) -302.035 (2.02965479e-06)
161410 EPS nconv=0 first unconverged value (error) -302.035 (1.95030056e-06)
161411 EPS nconv=0 first unconverged value (error) -302.035 (1.92220060e-06)
161412 EPS nconv=0 first unconverged value (error) -302.035 (1.90846006e-06)
161413 EPS nconv=0 first unconverged value (error) -302.035 (1.90846006e-06)
161414 EPS nconv=0 first unconverged value (error) -302.035 (1.90737877e-06)
161415 EPS nconv=0 first unconverged value (error) -302.035 (2.12472819e-06)
161416 EPS nconv=0 first unconverged value (error) -302.035 (1.90725791e-06)
161417 EPS nconv=0 first unconverged value (error) -302.035 (1.82370684e-06)
161418 EPS nconv=0 first unconverged value (error) -302.035 (1.80776322e-06)
161419 EPS nconv=0 first unconverged value (error) -302.035 (1.80776322e-06)
161420 EPS nconv=0 first unconverged value (error) -302.035 (2.32190273e-06)
161421 EPS nconv=0 first unconverged value (error) -302.035 (2.19602303e-06)
161422 EPS nconv=0 first unconverged value (error) -302.035 (2.14854897e-06)
161423 EPS nconv=0 first unconverged value (error) -302.035 (2.14891139e-06)
161424 EPS nconv=0 first unconverged value (error) -302.035 (2.09235554e-06)
161425 EPS nconv=0 first unconverged value (error) -302.035 (2.09235554e-06)
161426 EPS nconv=0 first unconverged value (error) -302.035 (3.33384137e-06)
161427 EPS nconv=0 first unconverged value (error) -302.035 (3.15718428e-06)
161428 EPS nconv=0 first unconverged value (error) -302.035 (2.93220541e-06)
161429 EPS nconv=0 first unconverged value (error) -302.035 (2.48940336e-06)
161430 EPS nconv=0 first unconverged value (error) -302.035 (2.37813570e-06)
161431 EPS nconv=0 first unconverged value (error) -302.035 (2.37813570e-06)
161432 EPS nconv=0 first unconverged value (error) -302.035 (2.73653627e-06)
161433 EPS nconv=0 first unconverged value (error) -302.035 (2.71888935e-06)
161434 EPS nconv=0 first unconverged value (error) -302.035 (2.37443607e-06)
161435 EPS nconv=0 first unconverged value (error) -302.035 (2.20206397e-06)
161436 EPS nconv=0 first unconverged value (error) -302.035 (2.15972353e-06)
161437 EPS nconv=0 first unconverged value (error) -302.035 (2.15972353e-06)
161438 EPS nconv=0 first unconverged value (error) -302.035 (2.43273695e-06)
161439 EPS nconv=0 first unconverged value (error) -302.035 (2.40991425e-06)
161440 EPS nconv=0 first unconverged value (error) -302.035 (2.10643024e-06)
161441 EPS nconv=0 first unconverged value (error) -302.035 (1.97174292e-06)
161442 EPS nconv=0 first unconverged value (error) -302.035 (1.90600173e-06)
161443 EPS nconv=0 first unconverged value (error) -302.035 (1.90600173e-06)
161444 EPS nconv=0 first unconverged value (error) -302.035 (1.87211902e-06)
161445 EPS nconv=0 first unconverged value (error) -302.035 (1.92464145e-06)
161446 EPS nconv=0 first unconverged value (error) -302.035 (1.84003493e-06)
161447 EPS nconv=0 first unconverged value (error) -302.035 (1.82332283e-06)
161448 EPS nconv=0 first unconverged value (error) -302.035 (1.80783178e-06)
161449 EPS nconv=0 first unconverged value (error) -302.035 (1.80783178e-06)
161450 EPS nconv=0 first unconverged value (error) -302.035 (2.07965866e-06)
161451 EPS nconv=0 first unconverged value (error) -302.035 (2.00818646e-06)
161452 EPS nconv=0 first unconverged value (error) -302.035 (1.94849148e-06)
161453 EPS nconv=0 first unconverged value (error) -302.035 (1.94122694e-06)
161454 EPS nconv=0 first unconverged value (error) -302.035 (1.90625028e-06)
161455 EPS nconv=0 first unconverged value (error) -302.035 (1.90625028e-06)
161456 EPS nconv=0 first unconverged value (error) -302.035 (2.09919452e-06)
161457 EPS nconv=0 first unconverged value (error) -302.035 (2.11911697e-06)
161458 EPS nconv=0 first unconverged value (error) -302.035 (2.06116906e-06)
161459 EPS nconv=0 first unconverged value (error) -302.035 (1.94449575e-06)
161460 EPS nconv=0 first unconverged value (error) -302.035 (1.91972842e-06)
161461 EPS nconv=0 first unconverged value (error) -302.035 (1.91972842e-06)
161462 EPS nconv=0 first unconverged value (error) -302.035 (2.25344024e-06)
161463 EPS nconv=0 first unconverged value (error) -302.035 (2.08382657e-06)
161464 EPS nconv=0 first unconverged value (error) -302.035 (1.99745841e-06)
161465 EPS nconv=0 first unconverged value (error) -302.035 (1.98367542e-06)
161466 EPS nconv=0 first unconverged value (error) -302.035 (1.96368025e-06)
161467 EPS nconv=0 first unconverged value (error) -302.035 (1.96368025e-06)
161468 EPS nconv=0 first unconverged value (error) -302.035 (2.32354124e-06)
161469 EPS nconv=0 first unconverged value (error) -302.035 (2.31867603e-06)
161470 EPS nconv=0 first unconverged value (error) -302.035 (2.12264549e-06)
161471 EPS nconv=0 first unconverged value (error) -302.035 (2.04747394e-06)
161472 EPS nconv=0 first unconverged value (error) -302.035 (2.01975563e-06)
161473 EPS nconv=0 first unconverged value (error) -302.035 (2.01975563e-06)
161474 EPS nconv=0 first unconverged value (error) -302.035 (2.15236001e-06)
161475 EPS nconv=0 first unconverged value (error) -302.035 (2.13220880e-06)
161476 EPS nconv=0 first unconverged value (error) -302.035 (1.99094954e-06)
161477 EPS nconv=0 first unconverged value (error) -302.035 (1.87876114e-06)
161478 EPS nconv=0 first unconverged value (error) -302.035 (1.84089408e-06)
161479 EPS nconv=0 first unconverged value (error) -302.035 (1.84089408e-06)
161480 EPS nconv=0 first unconverged value (error) -302.035 (1.83879241e-06)
161481 EPS nconv=0 first unconverged value (error) -302.035 (1.86929400e-06)
161482 EPS nconv=0 first unconverged value (error) -302.035 (1.82943709e-06)
161483 EPS nconv=0 first unconverged value (error) -302.035 (1.81358073e-06)
161484 EPS nconv=0 first unconverged value (error) -302.035 (1.80372721e-06)
161485 EPS nconv=0 first unconverged value (error) -302.035 (1.80372721e-06)
161486 EPS nconv=0 first unconverged value (error) -302.035 (1.84192970e-06)
161487 EPS nconv=0 first unconverged value (error) -302.035 (1.82830085e-06)
161488 EPS nconv=0 first unconverged value (error) -302.035 (1.82031056e-06)
161489 EPS nconv=0 first unconverged value (error) -302.035 (1.81716554e-06)
161490 EPS nconv=0 first unconverged value (error) -302.035 (1.81242027e-06)
161491 EPS nconv=0 first unconverged value (error) -302.035 (1.81242027e-06)
161492 EPS nconv=0 first unconverged value (error) -302.035 (1.82874463e-06)
161493 EPS nconv=0 first unconverged value (error) -302.035 (1.82257754e-06)
161494 EPS nconv=0 first unconverged value (error) -302.035 (1.81048954e-06)
161495 EPS nconv=0 first unconverged value (error) -302.035 (1.80791399e-06)
161496 EPS nconv=0 first unconverged value (error) -302.035 (1.80712175e-06)
161497 EPS nconv=0 first unconverged value (error) -302.035 (1.80712175e-06)
161498 EPS nconv=0 first unconverged value (error) -302.035 (2.32120093e-06)
161499 EPS nconv=0 first unconverged value (error) -302.035 (2.10726266e-06)
161500 EPS nconv=0 first unconverged value (error) -302.035 (2.03125274e-06)
161501 EPS nconv=0 first unconverged value (error) -302.035 (1.99393200e-06)
161502 EPS nconv=0 first unconverged value (error) -302.035 (1.96445647e-06)
161503 EPS nconv=0 first unconverged value (error) -302.035 (1.96445647e-06)
161504 EPS nconv=0 first unconverged value (error) -302.035 (2.53766432e-06)
161505 EPS nconv=0 first unconverged value (error) -302.035 (2.47472823e-06)
161506 EPS nconv=0 first unconverged value (error) -302.035 (2.22146583e-06)
161507 EPS nconv=0 first unconverged value (error) -302.035 (2.20437978e-06)
161508 EPS nconv=0 first unconverged value (error) -302.035 (2.15200822e-06)
161509 EPS nconv=0 first unconverged value (error) -302.035 (2.15200822e-06)
161510 EPS nconv=0 first unconverged value (error) -302.035 (2.32893123e-06)
161511 EPS nconv=0 first unconverged value (error) -302.035 (2.30540033e-06)
161512 EPS nconv=0 first unconverged value (error) -302.035 (2.10576682e-06)
161513 EPS nconv=0 first unconverged value (error) -302.035 (2.03424416e-06)
161514 EPS nconv=0 first unconverged value (error) -302.035 (2.01235269e-06)
161515 EPS nconv=0 first unconverged value (error) -302.035 (2.01235269e-06)
161516 EPS nconv=0 first unconverged value (error) -302.035 (2.48222568e-06)
161517 EPS nconv=0 first unconverged value (error) -302.035 (2.39163133e-06)
161518 EPS nconv=0 first unconverged value (error) -302.035 (2.20700178e-06)
161519 EPS nconv=0 first unconverged value (error) -302.035 (2.03329393e-06)
161520 EPS nconv=0 first unconverged value (error) -302.035 (1.99855849e-06)
161521 EPS nconv=0 first unconverged value (error) -302.035 (1.99855849e-06)
161522 EPS nconv=0 first unconverged value (error) -302.035 (2.08399081e-06)
161523 EPS nconv=0 first unconverged value (error) -302.035 (2.29227122e-06)
161524 EPS nconv=0 first unconverged value (error) -302.035 (2.07226638e-06)
161525 EPS nconv=0 first unconverged value (error) -302.035 (1.91713934e-06)
161526 EPS nconv=0 first unconverged value (error) -302.035 (1.89833886e-06)
161527 EPS nconv=0 first unconverged value (error) -302.035 (1.89833886e-06)
161528 EPS nconv=0 first unconverged value (error) -302.035 (1.85435410e-06)
161529 EPS nconv=0 first unconverged value (error) -302.035 (1.87174558e-06)
161530 EPS nconv=0 first unconverged value (error) -302.035 (1.82629485e-06)
161531 EPS nconv=0 first unconverged value (error) -302.035 (1.81323553e-06)
161532 EPS nconv=0 first unconverged value (error) -302.035 (1.80495593e-06)
161533 EPS nconv=0 first unconverged value (error) -302.035 (1.80495593e-06)
161534 EPS nconv=0 first unconverged value (error) -302.035 (1.92620095e-06)
161535 EPS nconv=0 first unconverged value (error) -302.035 (1.88909807e-06)
161536 EPS nconv=0 first unconverged value (error) -302.035 (1.86076172e-06)
161537 EPS nconv=0 first unconverged value (error) -302.035 (1.85288093e-06)
161538 EPS nconv=0 first unconverged value (error) -302.035 (1.84340984e-06)
161539 EPS nconv=0 first unconverged value (error) -302.035 (1.84340984e-06)
161540 EPS nconv=0 first unconverged value (error) -302.035 (3.65837151e-06)
161541 EPS nconv=0 first unconverged value (error) -302.035 (3.40556932e-06)
161542 EPS nconv=0 first unconverged value (error) -302.035 (3.04754568e-06)
161543 EPS nconv=0 first unconverged value (error) -302.035 (2.96879528e-06)
161544 EPS nconv=0 first unconverged value (error) -302.035 (2.85188051e-06)
161545 EPS nconv=0 first unconverged value (error) -302.035 (2.85188051e-06)
161546 EPS nconv=0 first unconverged value (error) -302.035 (2.86648889e-06)
161547 EPS nconv=0 first unconverged value (error) -302.035 (2.95917627e-06)
161548 EPS nconv=0 first unconverged value (error) -302.035 (2.66958849e-06)
161549 EPS nconv=0 first unconverged value (error) -302.035 (2.05454527e-06)
161550 EPS nconv=0 first unconverged value (error) -302.035 (2.01924738e-06)
161551 EPS nconv=0 first unconverged value (error) -302.035 (2.01924738e-06)
161552 EPS nconv=0 first unconverged value (error) -302.035 (2.03309022e-06)
161553 EPS nconv=0 first unconverged value (error) -302.035 (1.99906026e-06)
161554 EPS nconv=0 first unconverged value (error) -302.035 (1.91256908e-06)
161555 EPS nconv=0 first unconverged value (error) -302.035 (1.87771776e-06)
161556 EPS nconv=0 first unconverged value (error) -302.035 (1.84498780e-06)
161557 EPS nconv=0 first unconverged value (error) -302.035 (1.84498780e-06)
161558 EPS nconv=0 first unconverged value (error) -302.035 (1.84093979e-06)
161559 EPS nconv=0 first unconverged value (error) -302.035 (1.87952492e-06)
161560 EPS nconv=0 first unconverged value (error) -302.035 (1.85172666e-06)
161561 EPS nconv=0 first unconverged value (error) -302.035 (1.80953334e-06)
161562 EPS nconv=0 first unconverged value (error) -302.035 (1.80202348e-06)
161563 EPS nconv=0 first unconverged value (error) -302.035 (1.80202348e-06)
161564 EPS nconv=0 first unconverged value (error) -302.035 (2.36066057e-06)
161565 EPS nconv=0 first unconverged value (error) -302.035 (2.14757998e-06)
161566 EPS nconv=0 first unconverged value (error) -302.035 (2.12808259e-06)
161567 EPS nconv=0 first unconverged value (error) -302.035 (2.09377298e-06)
161568 EPS nconv=0 first unconverged value (error) -302.035 (2.06024808e-06)
161569 EPS nconv=0 first unconverged value (error) -302.035 (2.06024808e-06)
161570 EPS nconv=0 first unconverged value (error) -302.035 (2.49179293e-06)
161571 EPS nconv=0 first unconverged value (error) -302.035 (2.58038840e-06)
161572 EPS nconv=0 first unconverged value (error) -302.035 (2.36799791e-06)
161573 EPS nconv=0 first unconverged value (error) -302.035 (2.05166278e-06)
161574 EPS nconv=0 first unconverged value (error) -302.035 (2.01575436e-06)
161575 EPS nconv=0 first unconverged value (error) -302.035 (2.01575436e-06)
161576 EPS nconv=0 first unconverged value (error) -302.035 (2.50676150e-06)
161577 EPS nconv=0 first unconverged value (error) -302.035 (2.32992645e-06)
161578 EPS nconv=0 first unconverged value (error) -302.035 (2.19542730e-06)
161579 EPS nconv=0 first unconverged value (error) -302.035 (2.16072027e-06)
161580 EPS nconv=0 first unconverged value (error) -302.035 (2.12906830e-06)
161581 EPS nconv=0 first unconverged value (error) -302.035 (2.12906830e-06)
161582 EPS nconv=0 first unconverged value (error) -302.035 (2.12088724e-06)
161583 EPS nconv=0 first unconverged value (error) -302.035 (2.09983177e-06)
161584 EPS nconv=0 first unconverged value (error) -302.035 (1.91713585e-06)
161585 EPS nconv=0 first unconverged value (error) -302.035 (1.85246948e-06)
161586 EPS nconv=0 first unconverged value (error) -302.035 (1.83977207e-06)
161587 EPS nconv=0 first unconverged value (error) -302.035 (1.83977207e-06)
161588 EPS nconv=0 first unconverged value (error) -302.035 (1.86801257e-06)
161589 EPS nconv=0 first unconverged value (error) -302.035 (1.84275791e-06)
161590 EPS nconv=0 first unconverged value (error) -302.035 (1.82517513e-06)
161591 EPS nconv=0 first unconverged value (error) -302.035 (1.82169795e-06)
161592 EPS nconv=0 first unconverged value (error) -302.035 (1.81913642e-06)
161593 EPS nconv=0 first unconverged value (error) -302.035 (1.81913642e-06)
161594 EPS nconv=0 first unconverged value (error) -302.035 (1.96308638e-06)
161595 EPS nconv=0 first unconverged value (error) -302.035 (1.96038344e-06)
161596 EPS nconv=0 first unconverged value (error) -302.035 (1.90769169e-06)
161597 EPS nconv=0 first unconverged value (error) -302.035 (1.90634960e-06)
161598 EPS nconv=0 first unconverged value (error) -302.035 (1.88865880e-06)
161599 EPS nconv=0 first unconverged value (error) -302.035 (1.88865880e-06)
161600 EPS nconv=0 first unconverged value (error) -302.035 (1.88319905e-06)
161601 EPS nconv=0 first unconverged value (error) -302.035 (1.86552784e-06)
161602 EPS nconv=0 first unconverged value (error) -302.035 (1.85138666e-06)
161603 EPS nconv=0 first unconverged value (error) -302.035 (1.80943188e-06)
161604 EPS nconv=0 first unconverged value (error) -302.035 (1.80858238e-06)
161605 EPS nconv=0 first unconverged value (error) -302.035 (1.80858238e-06)
161606 EPS nconv=0 first unconverged value (error) -302.035 (2.18176390e-06)
161607 EPS nconv=0 first unconverged value (error) -302.035 (1.98287237e-06)
161608 EPS nconv=0 first unconverged value (error) -302.035 (1.93985872e-06)
161609 EPS nconv=0 first unconverged value (error) -302.035 (1.90900158e-06)
161610 EPS nconv=0 first unconverged value (error) -302.035 (1.89943558e-06)
161611 EPS nconv=0 first unconverged value (error) -302.035 (1.89943558e-06)
161612 EPS nconv=0 first unconverged value (error) -302.035 (1.90572524e-06)
161613 EPS nconv=0 first unconverged value (error) -302.035 (2.06275693e-06)
161614 EPS nconv=0 first unconverged value (error) -302.035 (1.88728032e-06)
161615 EPS nconv=0 first unconverged value (error) -302.035 (1.83618246e-06)
161616 EPS nconv=0 first unconverged value (error) -302.035 (1.81203123e-06)
161617 EPS nconv=0 first unconverged value (error) -302.035 (1.81203123e-06)
161618 EPS nconv=0 first unconverged value (error) -302.035 (2.12067675e-06)
161619 EPS nconv=0 first unconverged value (error) -302.035 (2.08510859e-06)
161620 EPS nconv=0 first unconverged value (error) -302.035 (2.03226863e-06)
161621 EPS nconv=0 first unconverged value (error) -302.035 (2.02129786e-06)
161622 EPS nconv=0 first unconverged value (error) -302.035 (1.99413685e-06)
161623 EPS nconv=0 first unconverged value (error) -302.035 (1.99413685e-06)
161624 EPS nconv=0 first unconverged value (error) -302.035 (2.31290891e-06)
161625 EPS nconv=0 first unconverged value (error) -302.035 (2.22709166e-06)
161626 EPS nconv=0 first unconverged value (error) -302.035 (2.11880414e-06)
161627 EPS nconv=0 first unconverged value (error) -302.035 (1.95873932e-06)
161628 EPS nconv=0 first unconverged value (error) -302.035 (1.92299709e-06)
161629 EPS nconv=0 first unconverged value (error) -302.035 (1.92299709e-06)
161630 EPS nconv=0 first unconverged value (error) -302.035 (1.96541473e-06)
161631 EPS nconv=0 first unconverged value (error) -302.035 (2.03471554e-06)
161632 EPS nconv=0 first unconverged value (error) -302.035 (1.94635694e-06)
161633 EPS nconv=0 first unconverged value (error) -302.035 (1.85430674e-06)
161634 EPS nconv=0 first unconverged value (error) -302.035 (1.83730798e-06)
161635 EPS nconv=0 first unconverged value (error) -302.035 (1.83730798e-06)
161636 EPS nconv=0 first unconverged value (error) -302.035 (1.83665648e-06)
161637 EPS nconv=0 first unconverged value (error) -302.035 (1.84211923e-06)
161638 EPS nconv=0 first unconverged value (error) -302.035 (1.82073721e-06)
161639 EPS nconv=0 first unconverged value (error) -302.035 (1.80502228e-06)
161640 EPS nconv=0 first unconverged value (error) -302.035 (1.79828636e-06)
161641 EPS nconv=0 first unconverged value (error) -302.035 (1.79828636e-06)
161642 EPS nconv=0 first unconverged value (error) -302.035 (1.79656143e-06)
161643 EPS nconv=0 first unconverged value (error) -302.035 (1.79839566e-06)
161644 EPS nconv=0 first unconverged value (error) -302.035 (1.79526421e-06)
161645 EPS nconv=0 first unconverged value (error) -302.035 (1.79455689e-06)
161646 EPS nconv=0 first unconverged value (error) -302.035 (1.79422300e-06)
161647 EPS nconv=0 first unconverged value (error) -302.035 (1.79422300e-06)
161648 EPS nconv=0 first unconverged value (error) -302.035 (2.41711064e-06)
161649 EPS nconv=0 first unconverged value (error) -302.035 (2.20196848e-06)
161650 EPS nconv=0 first unconverged value (error) -302.035 (2.10600920e-06)
161651 EPS nconv=0 first unconverged value (error) -302.035 (2.08175438e-06)
161652 EPS nconv=0 first unconverged value (error) -302.035 (2.02361774e-06)
161653 EPS nconv=0 first unconverged value (error) -302.035 (2.02361774e-06)
161654 EPS nconv=0 first unconverged value (error) -302.035 (2.34246746e-06)
161655 EPS nconv=0 first unconverged value (error) -302.035 (2.35324374e-06)
161656 EPS nconv=0 first unconverged value (error) -302.035 (2.17408289e-06)
161657 EPS nconv=0 first unconverged value (error) -302.035 (2.14160833e-06)
161658 EPS nconv=0 first unconverged value (error) -302.035 (2.11474930e-06)
161659 EPS nconv=0 first unconverged value (error) -302.035 (2.11474930e-06)
161660 EPS nconv=0 first unconverged value (error) -302.035 (2.34929194e-06)
161661 EPS nconv=0 first unconverged value (error) -302.035 (2.17618588e-06)
161662 EPS nconv=0 first unconverged value (error) -302.035 (2.07772278e-06)
161663 EPS nconv=0 first unconverged value (error) -302.035 (2.02483285e-06)
161664 EPS nconv=0 first unconverged value (error) -302.035 (1.98167228e-06)
161665 EPS nconv=0 first unconverged value (error) -302.035 (1.98167228e-06)
161666 EPS nconv=0 first unconverged value (error) -302.035 (2.16141332e-06)
161667 EPS nconv=0 first unconverged value (error) -302.035 (2.18581127e-06)
161668 EPS nconv=0 first unconverged value (error) -302.035 (2.09956980e-06)
161669 EPS nconv=0 first unconverged value (error) -302.035 (1.91164419e-06)
161670 EPS nconv=0 first unconverged value (error) -302.035 (1.88827137e-06)
161671 EPS nconv=0 first unconverged value (error) -302.035 (1.88827137e-06)
161672 EPS nconv=0 first unconverged value (error) -302.035 (2.24342429e-06)
161673 EPS nconv=0 first unconverged value (error) -302.035 (2.24165122e-06)
161674 EPS nconv=0 first unconverged value (error) -302.035 (2.10381339e-06)
161675 EPS nconv=0 first unconverged value (error) -302.035 (2.03557735e-06)
161676 EPS nconv=0 first unconverged value (error) -302.035 (1.97272790e-06)
161677 EPS nconv=0 first unconverged value (error) -302.035 (1.97272790e-06)
161678 EPS nconv=0 first unconverged value (error) -302.035 (2.03502911e-06)
161679 EPS nconv=0 first unconverged value (error) -302.035 (2.04580021e-06)
161680 EPS nconv=0 first unconverged value (error) -302.035 (1.95419171e-06)
161681 EPS nconv=0 first unconverged value (error) -302.035 (1.90792487e-06)
161682 EPS nconv=0 first unconverged value (error) -302.035 (1.87205336e-06)
161683 EPS nconv=0 first unconverged value (error) -302.035 (1.87205336e-06)
161684 EPS nconv=0 first unconverged value (error) -302.035 (1.89378067e-06)
161685 EPS nconv=0 first unconverged value (error) -302.035 (1.89507239e-06)
161686 EPS nconv=0 first unconverged value (error) -302.035 (1.84962080e-06)
161687 EPS nconv=0 first unconverged value (error) -302.035 (1.83461190e-06)
161688 EPS nconv=0 first unconverged value (error) -302.035 (1.82420545e-06)
161689 EPS nconv=0 first unconverged value (error) -302.035 (1.82420545e-06)
161690 EPS nconv=0 first unconverged value (error) -302.035 (2.41778125e-06)
161691 EPS nconv=0 first unconverged value (error) -302.035 (2.36502870e-06)
161692 EPS nconv=0 first unconverged value (error) -302.035 (2.18569865e-06)
161693 EPS nconv=0 first unconverged value (error) -302.035 (2.12125621e-06)
161694 EPS nconv=0 first unconverged value (error) -302.035 (2.06907082e-06)
161695 EPS nconv=0 first unconverged value (error) -302.035 (2.06907082e-06)
161696 EPS nconv=0 first unconverged value (error) -302.035 (2.09737636e-06)
161697 EPS nconv=0 first unconverged value (error) -302.035 (2.17546408e-06)
161698 EPS nconv=0 first unconverged value (error) -302.035 (2.09149154e-06)
161699 EPS nconv=0 first unconverged value (error) -302.035 (1.88180539e-06)
161700 EPS nconv=0 first unconverged value (error) -302.035 (1.86069548e-06)
161701 EPS nconv=0 first unconverged value (error) -302.035 (1.86069548e-06)
161702 EPS nconv=0 first unconverged value (error) -302.035 (1.98902875e-06)
161703 EPS nconv=0 first unconverged value (error) -302.035 (1.89055782e-06)
161704 EPS nconv=0 first unconverged value (error) -302.035 (1.87133476e-06)
161705 EPS nconv=0 first unconverged value (error) -302.035 (1.85578226e-06)
161706 EPS nconv=0 first unconverged value (error) -302.035 (1.83935881e-06)
161707 EPS nconv=0 first unconverged value (error) -302.035 (1.83935881e-06)
161708 EPS nconv=0 first unconverged value (error) -302.035 (2.53426131e-06)
161709 EPS nconv=0 first unconverged value (error) -302.035 (2.53791869e-06)
161710 EPS nconv=0 first unconverged value (error) -302.035 (2.40305383e-06)
161711 EPS nconv=0 first unconverged value (error) -302.035 (2.26735933e-06)
161712 EPS nconv=0 first unconverged value (error) -302.035 (2.22042723e-06)
161713 EPS nconv=0 first unconverged value (error) -302.035 (2.22042723e-06)
161714 EPS nconv=0 first unconverged value (error) -302.035 (2.52554400e-06)
161715 EPS nconv=0 first unconverged value (error) -302.035 (2.31060494e-06)
161716 EPS nconv=0 first unconverged value (error) -302.035 (2.12564452e-06)
161717 EPS nconv=0 first unconverged value (error) -302.035 (2.03056234e-06)
161718 EPS nconv=0 first unconverged value (error) -302.035 (2.02404915e-06)
161719 EPS nconv=0 first unconverged value (error) -302.035 (2.02404915e-06)
161720 EPS nconv=0 first unconverged value (error) -302.035 (2.03835976e-06)
161721 EPS nconv=0 first unconverged value (error) -302.035 (2.09629805e-06)
161722 EPS nconv=0 first unconverged value (error) -302.035 (1.96069303e-06)
161723 EPS nconv=0 first unconverged value (error) -302.035 (1.89344444e-06)
161724 EPS nconv=0 first unconverged value (error) -302.035 (1.84753086e-06)
161725 EPS nconv=0 first unconverged value (error) -302.035 (1.84753086e-06)
161726 EPS nconv=0 first unconverged value (error) -302.035 (2.61493179e-06)
161727 EPS nconv=0 first unconverged value (error) -302.035 (2.42995729e-06)
161728 EPS nconv=0 first unconverged value (error) -302.035 (2.25583540e-06)
161729 EPS nconv=0 first unconverged value (error) -302.035 (2.17960259e-06)
161730 EPS nconv=0 first unconverged value (error) -302.035 (2.13355497e-06)
161731 EPS nconv=0 first unconverged value (error) -302.035 (2.13355497e-06)
161732 EPS nconv=0 first unconverged value (error) -302.035 (2.49464444e-06)
161733 EPS nconv=0 first unconverged value (error) -302.035 (2.84005632e-06)
161734 EPS nconv=0 first unconverged value (error) -302.035 (2.56656419e-06)
161735 EPS nconv=0 first unconverged value (error) -302.035 (2.05693723e-06)
161736 EPS nconv=0 first unconverged value (error) -302.035 (1.99421877e-06)
161737 EPS nconv=0 first unconverged value (error) -302.035 (1.99421877e-06)
161738 EPS nconv=0 first unconverged value (error) -302.035 (1.97429189e-06)
161739 EPS nconv=0 first unconverged value (error) -302.035 (1.99018639e-06)
161740 EPS nconv=0 first unconverged value (error) -302.035 (1.88833014e-06)
161741 EPS nconv=0 first unconverged value (error) -302.035 (1.82084728e-06)
161742 EPS nconv=0 first unconverged value (error) -302.035 (1.80438448e-06)
161743 EPS nconv=0 first unconverged value (error) -302.035 (1.80438448e-06)
161744 EPS nconv=0 first unconverged value (error) -302.035 (2.23726210e-06)
161745 EPS nconv=0 first unconverged value (error) -302.035 (1.99696678e-06)
161746 EPS nconv=0 first unconverged value (error) -302.035 (1.97514502e-06)
161747 EPS nconv=0 first unconverged value (error) -302.035 (1.94705194e-06)
161748 EPS nconv=0 first unconverged value (error) -302.035 (1.92880062e-06)
161749 EPS nconv=0 first unconverged value (error) -302.035 (1.92880062e-06)
161750 EPS nconv=0 first unconverged value (error) -302.035 (1.97737190e-06)
161751 EPS nconv=0 first unconverged value (error) -302.035 (2.04725854e-06)
161752 EPS nconv=0 first unconverged value (error) -302.035 (1.87207928e-06)
161753 EPS nconv=0 first unconverged value (error) -302.035 (1.85384604e-06)
161754 EPS nconv=0 first unconverged value (error) -302.035 (1.84423797e-06)
161755 EPS nconv=0 first unconverged value (error) -302.035 (1.84423797e-06)
161756 EPS nconv=0 first unconverged value (error) -302.035 (2.03407147e-06)
161757 EPS nconv=0 first unconverged value (error) -302.035 (1.99075341e-06)
161758 EPS nconv=0 first unconverged value (error) -302.035 (1.92340969e-06)
161759 EPS nconv=0 first unconverged value (error) -302.035 (1.90986728e-06)
161760 EPS nconv=0 first unconverged value (error) -302.035 (1.89116869e-06)
161761 EPS nconv=0 first unconverged value (error) -302.035 (1.89116869e-06)
161762 EPS nconv=0 first unconverged value (error) -302.035 (2.53788383e-06)
161763 EPS nconv=0 first unconverged value (error) -302.035 (2.48110071e-06)
161764 EPS nconv=0 first unconverged value (error) -302.035 (2.29282093e-06)
161765 EPS nconv=0 first unconverged value (error) -302.035 (2.13047656e-06)
161766 EPS nconv=0 first unconverged value (error) -302.035 (2.08482712e-06)
161767 EPS nconv=0 first unconverged value (error) -302.035 (2.08482712e-06)
161768 EPS nconv=0 first unconverged value (error) -302.035 (2.10698071e-06)
161769 EPS nconv=0 first unconverged value (error) -302.035 (2.23133378e-06)
161770 EPS nconv=0 first unconverged value (error) -302.035 (2.07500938e-06)
161771 EPS nconv=0 first unconverged value (error) -302.035 (1.90462656e-06)
161772 EPS nconv=0 first unconverged value (error) -302.035 (1.86869992e-06)
161773 EPS nconv=0 first unconverged value (error) -302.035 (1.86869992e-06)
161774 EPS nconv=0 first unconverged value (error) -302.035 (1.83013834e-06)
161775 EPS nconv=0 first unconverged value (error) -302.035 (1.81783475e-06)
161776 EPS nconv=0 first unconverged value (error) -302.035 (1.80301859e-06)
161777 EPS nconv=0 first unconverged value (error) -302.035 (1.79677515e-06)
161778 EPS nconv=0 first unconverged value (error) -302.035 (1.79451409e-06)
161779 EPS nconv=0 first unconverged value (error) -302.035 (1.79451409e-06)
161780 EPS nconv=0 first unconverged value (error) -302.035 (1.83271097e-06)
161781 EPS nconv=0 first unconverged value (error) -302.035 (1.82291206e-06)
161782 EPS nconv=0 first unconverged value (error) -302.035 (1.81447676e-06)
161783 EPS nconv=0 first unconverged value (error) -302.035 (1.81034373e-06)
161784 EPS nconv=0 first unconverged value (error) -302.035 (1.80789040e-06)
161785 EPS nconv=0 first unconverged value (error) -302.035 (1.80789040e-06)
161786 EPS nconv=0 first unconverged value (error) -302.035 (1.85069328e-06)
161787 EPS nconv=0 first unconverged value (error) -302.035 (1.85584971e-06)
161788 EPS nconv=0 first unconverged value (error) -302.035 (1.84531761e-06)
161789 EPS nconv=0 first unconverged value (error) -302.035 (1.81837576e-06)
161790 EPS nconv=0 first unconverged value (error) -302.035 (1.81355944e-06)
161791 EPS nconv=0 first unconverged value (error) -302.035 (1.81355944e-06)
161792 EPS nconv=0 first unconverged value (error) -302.035 (2.58131382e-06)
161793 EPS nconv=0 first unconverged value (error) -302.035 (2.43716462e-06)
161794 EPS nconv=0 first unconverged value (error) -302.035 (2.41218018e-06)
161795 EPS nconv=0 first unconverged value (error) -302.035 (2.32927593e-06)
161796 EPS nconv=0 first unconverged value (error) -302.035 (2.28555278e-06)
161797 EPS nconv=0 first unconverged value (error) -302.035 (2.28555278e-06)
161798 EPS nconv=0 first unconverged value (error) -302.035 (2.45088800e-06)
161799 EPS nconv=0 first unconverged value (error) -302.035 (2.25378870e-06)
161800 EPS nconv=0 first unconverged value (error) -302.035 (2.01306112e-06)
161801 EPS nconv=0 first unconverged value (error) -302.035 (1.97756313e-06)
161802 EPS nconv=0 first unconverged value (error) -302.035 (1.96056142e-06)
161803 EPS nconv=0 first unconverged value (error) -302.035 (1.96056142e-06)
161804 EPS nconv=0 first unconverged value (error) -302.035 (1.95171944e-06)
161805 EPS nconv=0 first unconverged value (error) -302.035 (1.97386459e-06)
161806 EPS nconv=0 first unconverged value (error) -302.035 (1.91003081e-06)
161807 EPS nconv=0 first unconverged value (error) -302.035 (1.83917335e-06)
161808 EPS nconv=0 first unconverged value (error) -302.035 (1.80891011e-06)
161809 EPS nconv=0 first unconverged value (error) -302.035 (1.80891011e-06)
161810 EPS nconv=0 first unconverged value (error) -302.035 (1.96922479e-06)
161811 EPS nconv=0 first unconverged value (error) -302.035 (1.94219370e-06)
161812 EPS nconv=0 first unconverged value (error) -302.035 (1.91962789e-06)
161813 EPS nconv=0 first unconverged value (error) -302.035 (1.89755613e-06)
161814 EPS nconv=0 first unconverged value (error) -302.035 (1.88610294e-06)
161815 EPS nconv=0 first unconverged value (error) -302.035 (1.88610294e-06)
161816 EPS nconv=0 first unconverged value (error) -302.035 (2.21906363e-06)
161817 EPS nconv=0 first unconverged value (error) -302.035 (2.13024850e-06)
161818 EPS nconv=0 first unconverged value (error) -302.035 (2.03125435e-06)
161819 EPS nconv=0 first unconverged value (error) -302.035 (2.02475317e-06)
161820 EPS nconv=0 first unconverged value (error) -302.035 (2.01527628e-06)
161821 EPS nconv=0 first unconverged value (error) -302.035 (2.01527628e-06)
161822 EPS nconv=0 first unconverged value (error) -302.035 (2.00830642e-06)
161823 EPS nconv=0 first unconverged value (error) -302.035 (2.02665051e-06)
161824 EPS nconv=0 first unconverged value (error) -302.035 (1.94734659e-06)
161825 EPS nconv=0 first unconverged value (error) -302.035 (1.86986288e-06)
161826 EPS nconv=0 first unconverged value (error) -302.035 (1.83864729e-06)
161827 EPS nconv=0 first unconverged value (error) -302.035 (1.83864729e-06)
161828 EPS nconv=0 first unconverged value (error) -302.035 (1.83472666e-06)
161829 EPS nconv=0 first unconverged value (error) -302.035 (1.81270187e-06)
161830 EPS nconv=0 first unconverged value (error) -302.035 (1.80494433e-06)
161831 EPS nconv=0 first unconverged value (error) -302.035 (1.80158521e-06)
161832 EPS nconv=0 first unconverged value (error) -302.035 (1.80017090e-06)
161833 EPS nconv=0 first unconverged value (error) -302.035 (1.80017090e-06)
161834 EPS nconv=0 first unconverged value (error) -302.035 (1.80221478e-06)
161835 EPS nconv=0 first unconverged value (error) -302.035 (1.81247841e-06)
161836 EPS nconv=0 first unconverged value (error) -302.035 (1.80326151e-06)
161837 EPS nconv=0 first unconverged value (error) -302.035 (1.79609637e-06)
161838 EPS nconv=0 first unconverged value (error) -302.035 (1.79439710e-06)
161839 EPS nconv=0 first unconverged value (error) -302.035 (1.79439710e-06)
161840 EPS nconv=0 first unconverged value (error) -302.035 (2.11492861e-06)
161841 EPS nconv=0 first unconverged value (error) -302.035 (2.00637093e-06)
161842 EPS nconv=0 first unconverged value (error) -302.035 (1.97884117e-06)
161843 EPS nconv=0 first unconverged value (error) -302.035 (1.97021897e-06)
161844 EPS nconv=0 first unconverged value (error) -302.035 (1.95711559e-06)
161845 EPS nconv=0 first unconverged value (error) -302.035 (1.95711559e-06)
161846 EPS nconv=0 first unconverged value (error) -302.035 (2.05319494e-06)
161847 EPS nconv=0 first unconverged value (error) -302.035 (2.10456707e-06)
161848 EPS nconv=0 first unconverged value (error) -302.035 (1.95378186e-06)
161849 EPS nconv=0 first unconverged value (error) -302.035 (1.83201027e-06)
161850 EPS nconv=0 first unconverged value (error) -302.035 (1.82003437e-06)
161851 EPS nconv=0 first unconverged value (error) -302.035 (1.82003437e-06)
161852 EPS nconv=0 first unconverged value (error) -302.035 (2.58283543e-06)
161853 EPS nconv=0 first unconverged value (error) -302.035 (2.42379126e-06)
161854 EPS nconv=0 first unconverged value (error) -302.035 (2.25727034e-06)
161855 EPS nconv=0 first unconverged value (error) -302.035 (2.22016395e-06)
161856 EPS nconv=0 first unconverged value (error) -302.035 (2.19485958e-06)
161857 EPS nconv=0 first unconverged value (error) -302.035 (2.19485958e-06)
161858 EPS nconv=0 first unconverged value (error) -302.035 (2.26260787e-06)
161859 EPS nconv=0 first unconverged value (error) -302.035 (2.28983099e-06)
161860 EPS nconv=0 first unconverged value (error) -302.035 (2.09185033e-06)
161861 EPS nconv=0 first unconverged value (error) -302.035 (1.93105718e-06)
161862 EPS nconv=0 first unconverged value (error) -302.035 (1.91414001e-06)
161863 EPS nconv=0 first unconverged value (error) -302.035 (1.91414001e-06)
161864 EPS nconv=0 first unconverged value (error) -302.035 (2.16244527e-06)
161865 EPS nconv=0 first unconverged value (error) -302.035 (2.02247981e-06)
161866 EPS nconv=0 first unconverged value (error) -302.035 (1.93780580e-06)
161867 EPS nconv=0 first unconverged value (error) -302.035 (1.91797060e-06)
161868 EPS nconv=0 first unconverged value (error) -302.035 (1.89350927e-06)
161869 EPS nconv=0 first unconverged value (error) -302.035 (1.89350927e-06)
161870 EPS nconv=0 first unconverged value (error) -302.035 (2.21000906e-06)
161871 EPS nconv=0 first unconverged value (error) -302.035 (2.24665527e-06)
161872 EPS nconv=0 first unconverged value (error) -302.035 (2.10966432e-06)
161873 EPS nconv=0 first unconverged value (error) -302.035 (1.96199048e-06)
161874 EPS nconv=0 first unconverged value (error) -302.035 (1.94615675e-06)
161875 EPS nconv=0 first unconverged value (error) -302.035 (1.94615675e-06)
161876 EPS nconv=0 first unconverged value (error) -302.035 (3.09463259e-06)
161877 EPS nconv=0 first unconverged value (error) -302.035 (2.73693487e-06)
161878 EPS nconv=0 first unconverged value (error) -302.035 (2.52890589e-06)
161879 EPS nconv=0 first unconverged value (error) -302.035 (2.48529356e-06)
161880 EPS nconv=0 first unconverged value (error) -302.035 (2.35642161e-06)
161881 EPS nconv=0 first unconverged value (error) -302.035 (2.35642161e-06)
161882 EPS nconv=0 first unconverged value (error) -302.035 (2.45363123e-06)
161883 EPS nconv=0 first unconverged value (error) -302.035 (2.72579578e-06)
161884 EPS nconv=0 first unconverged value (error) -302.035 (2.32850371e-06)
161885 EPS nconv=0 first unconverged value (error) -302.035 (1.98921650e-06)
161886 EPS nconv=0 first unconverged value (error) -302.035 (1.96234308e-06)
161887 EPS nconv=0 first unconverged value (error) -302.035 (1.96234308e-06)
161888 EPS nconv=0 first unconverged value (error) -302.035 (2.40747086e-06)
161889 EPS nconv=0 first unconverged value (error) -302.035 (2.08908936e-06)
161890 EPS nconv=0 first unconverged value (error) -302.035 (2.02635628e-06)
161891 EPS nconv=0 first unconverged value (error) -302.035 (1.98621341e-06)
161892 EPS nconv=0 first unconverged value (error) -302.035 (1.94999056e-06)
161893 EPS nconv=0 first unconverged value (error) -302.035 (1.94999056e-06)
161894 EPS nconv=0 first unconverged value (error) -302.035 (2.16091196e-06)
161895 EPS nconv=0 first unconverged value (error) -302.035 (2.27860726e-06)
161896 EPS nconv=0 first unconverged value (error) -302.035 (2.02325319e-06)
161897 EPS nconv=0 first unconverged value (error) -302.035 (1.94952843e-06)
161898 EPS nconv=0 first unconverged value (error) -302.035 (1.92236285e-06)
161899 EPS nconv=0 first unconverged value (error) -302.035 (1.92236285e-06)
161900 EPS nconv=0 first unconverged value (error) -302.035 (3.48236687e-06)
161901 EPS nconv=0 first unconverged value (error) -302.035 (3.00049343e-06)
161902 EPS nconv=0 first unconverged value (error) -302.035 (2.81189548e-06)
161903 EPS nconv=0 first unconverged value (error) -302.035 (2.80191361e-06)
161904 EPS nconv=0 first unconverged value (error) -302.035 (2.62660920e-06)
161905 EPS nconv=0 first unconverged value (error) -302.035 (2.62660920e-06)
161906 EPS nconv=0 first unconverged value (error) -302.035 (2.59333215e-06)
161907 EPS nconv=0 first unconverged value (error) -302.035 (2.90669581e-06)
161908 EPS nconv=0 first unconverged value (error) -302.035 (2.33902948e-06)
161909 EPS nconv=0 first unconverged value (error) -302.035 (1.97860649e-06)
161910 EPS nconv=0 first unconverged value (error) -302.035 (1.97630267e-06)
161911 EPS nconv=0 first unconverged value (error) -302.035 (1.97630267e-06)
161912 EPS nconv=0 first unconverged value (error) -302.035 (2.39966092e-06)
161913 EPS nconv=0 first unconverged value (error) -302.035 (2.07396922e-06)
161914 EPS nconv=0 first unconverged value (error) -302.035 (2.01247716e-06)
161915 EPS nconv=0 first unconverged value (error) -302.035 (1.98921341e-06)
161916 EPS nconv=0 first unconverged value (error) -302.035 (1.96216395e-06)
161917 EPS nconv=0 first unconverged value (error) -302.035 (1.96216395e-06)
161918 EPS nconv=0 first unconverged value (error) -302.035 (2.14471933e-06)
161919 EPS nconv=0 first unconverged value (error) -302.035 (2.39063858e-06)
161920 EPS nconv=0 first unconverged value (error) -302.035 (2.09821009e-06)
161921 EPS nconv=0 first unconverged value (error) -302.035 (1.90396028e-06)
161922 EPS nconv=0 first unconverged value (error) -302.035 (1.87956482e-06)
161923 EPS nconv=0 first unconverged value (error) -302.035 (1.87956482e-06)
161924 EPS nconv=0 first unconverged value (error) -302.035 (2.31213204e-06)
161925 EPS nconv=0 first unconverged value (error) -302.035 (2.22261122e-06)
161926 EPS nconv=0 first unconverged value (error) -302.035 (2.14586680e-06)
161927 EPS nconv=0 first unconverged value (error) -302.035 (2.08013656e-06)
161928 EPS nconv=0 first unconverged value (error) -302.035 (2.03158333e-06)
161929 EPS nconv=0 first unconverged value (error) -302.035 (2.03158333e-06)
161930 EPS nconv=0 first unconverged value (error) -302.035 (2.30460376e-06)
161931 EPS nconv=0 first unconverged value (error) -302.035 (2.16192682e-06)
161932 EPS nconv=0 first unconverged value (error) -302.035 (1.99413323e-06)
161933 EPS nconv=0 first unconverged value (error) -302.035 (1.92693192e-06)
161934 EPS nconv=0 first unconverged value (error) -302.035 (1.91095891e-06)
161935 EPS nconv=0 first unconverged value (error) -302.035 (1.91095891e-06)
161936 EPS nconv=0 first unconverged value (error) -302.035 (2.03285675e-06)
161937 EPS nconv=0 first unconverged value (error) -302.035 (2.02906295e-06)
161938 EPS nconv=0 first unconverged value (error) -302.035 (1.91916285e-06)
161939 EPS nconv=0 first unconverged value (error) -302.035 (1.88323524e-06)
161940 EPS nconv=0 first unconverged value (error) -302.035 (1.85394517e-06)
161941 EPS nconv=0 first unconverged value (error) -302.035 (1.85394517e-06)
161942 EPS nconv=0 first unconverged value (error) -302.035 (2.64703192e-06)
161943 EPS nconv=0 first unconverged value (error) -302.035 (2.44435745e-06)
161944 EPS nconv=0 first unconverged value (error) -302.035 (2.30222442e-06)
161945 EPS nconv=0 first unconverged value (error) -302.035 (2.26443421e-06)
161946 EPS nconv=0 first unconverged value (error) -302.035 (2.21203729e-06)
161947 EPS nconv=0 first unconverged value (error) -302.035 (2.21203729e-06)
161948 EPS nconv=0 first unconverged value (error) -302.035 (2.26038209e-06)
161949 EPS nconv=0 first unconverged value (error) -302.035 (2.27365703e-06)
161950 EPS nconv=0 first unconverged value (error) -302.035 (2.04324587e-06)
161951 EPS nconv=0 first unconverged value (error) -302.035 (1.93576824e-06)
161952 EPS nconv=0 first unconverged value (error) -302.035 (1.92795016e-06)
161953 EPS nconv=0 first unconverged value (error) -302.035 (1.92795016e-06)
161954 EPS nconv=0 first unconverged value (error) -302.035 (2.86036414e-06)
161955 EPS nconv=0 first unconverged value (error) -302.035 (2.48313935e-06)
161956 EPS nconv=0 first unconverged value (error) -302.035 (2.25299240e-06)
161957 EPS nconv=0 first unconverged value (error) -302.035 (2.20830024e-06)
161958 EPS nconv=0 first unconverged value (error) -302.035 (2.15338064e-06)
161959 EPS nconv=0 first unconverged value (error) -302.035 (2.15338064e-06)
161960 EPS nconv=0 first unconverged value (error) -302.035 (2.35837648e-06)
161961 EPS nconv=0 first unconverged value (error) -302.035 (2.75675698e-06)
161962 EPS nconv=0 first unconverged value (error) -302.035 (2.31126241e-06)
161963 EPS nconv=0 first unconverged value (error) -302.035 (1.95120629e-06)
161964 EPS nconv=0 first unconverged value (error) -302.035 (1.90314632e-06)
161965 EPS nconv=0 first unconverged value (error) -302.035 (1.90314632e-06)
161966 EPS nconv=0 first unconverged value (error) -302.035 (3.32106116e-06)
161967 EPS nconv=0 first unconverged value (error) -302.035 (2.96713798e-06)
161968 EPS nconv=0 first unconverged value (error) -302.035 (2.80306076e-06)
161969 EPS nconv=0 first unconverged value (error) -302.035 (2.70351123e-06)
161970 EPS nconv=0 first unconverged value (error) -302.035 (2.57418177e-06)
161971 EPS nconv=0 first unconverged value (error) -302.035 (2.57418177e-06)
161972 EPS nconv=0 first unconverged value (error) -302.035 (2.72532247e-06)
161973 EPS nconv=0 first unconverged value (error) -302.035 (2.95353935e-06)
161974 EPS nconv=0 first unconverged value (error) -302.035 (2.52244400e-06)
161975 EPS nconv=0 first unconverged value (error) -302.035 (1.91703178e-06)
161976 EPS nconv=0 first unconverged value (error) -302.035 (1.92421602e-06)
161977 EPS nconv=0 first unconverged value (error) -302.035 (1.92421602e-06)
161978 EPS nconv=0 first unconverged value (error) -302.035 (2.63605115e-06)
161979 EPS nconv=0 first unconverged value (error) -302.035 (2.18410083e-06)
161980 EPS nconv=0 first unconverged value (error) -302.035 (2.16604242e-06)
161981 EPS nconv=0 first unconverged value (error) -302.035 (2.14426458e-06)
161982 EPS nconv=0 first unconverged value (error) -302.035 (2.10657883e-06)
161983 EPS nconv=0 first unconverged value (error) -302.035 (2.10657883e-06)
161984 EPS nconv=0 first unconverged value (error) -302.035 (2.36952411e-06)
161985 EPS nconv=0 first unconverged value (error) -302.035 (2.48978949e-06)
161986 EPS nconv=0 first unconverged value (error) -302.035 (2.00465976e-06)
161987 EPS nconv=0 first unconverged value (error) -302.035 (1.99221282e-06)
161988 EPS nconv=0 first unconverged value (error) -302.035 (1.97138375e-06)
161989 EPS nconv=0 first unconverged value (error) -302.035 (1.97138375e-06)
161990 EPS nconv=0 first unconverged value (error) -302.035 (1.98735450e-06)
161991 EPS nconv=0 first unconverged value (error) -302.035 (2.03929482e-06)
161992 EPS nconv=0 first unconverged value (error) -302.035 (1.93197589e-06)
161993 EPS nconv=0 first unconverged value (error) -302.035 (1.88706883e-06)
161994 EPS nconv=0 first unconverged value (error) -302.035 (1.84929482e-06)
161995 EPS nconv=0 first unconverged value (error) -302.035 (1.84929482e-06)
161996 EPS nconv=0 first unconverged value (error) -302.035 (2.07396517e-06)
161997 EPS nconv=0 first unconverged value (error) -302.035 (1.99578403e-06)
161998 EPS nconv=0 first unconverged value (error) -302.035 (1.94281248e-06)
161999 EPS nconv=0 first unconverged value (error) -302.035 (1.93925415e-06)
162000 EPS nconv=0 first unconverged value (error) -302.035 (1.90445702e-06)
162001 EPS nconv=0 first unconverged value (error) -302.035 (1.90445702e-06)
162002 EPS nconv=0 first unconverged value (error) -302.035 (1.89967080e-06)
162003 EPS nconv=0 first unconverged value (error) -302.035 (1.93302253e-06)
162004 EPS nconv=0 first unconverged value (error) -302.035 (1.85926720e-06)
162005 EPS nconv=0 first unconverged value (error) -302.035 (1.82838982e-06)
162006 EPS nconv=0 first unconverged value (error) -302.035 (1.82435528e-06)
162007 EPS nconv=0 first unconverged value (error) -302.035 (1.82435528e-06)
162008 EPS nconv=0 first unconverged value (error) -302.035 (3.20977957e-06)
162009 EPS nconv=0 first unconverged value (error) -302.035 (2.65330617e-06)
162010 EPS nconv=0 first unconverged value (error) -302.035 (2.47710691e-06)
162011 EPS nconv=0 first unconverged value (error) -302.035 (2.39541198e-06)
162012 EPS nconv=0 first unconverged value (error) -302.035 (2.28954303e-06)
162013 EPS nconv=0 first unconverged value (error) -302.035 (2.28954303e-06)
162014 EPS nconv=0 first unconverged value (error) -302.035 (2.87292160e-06)
162015 EPS nconv=0 first unconverged value (error) -302.035 (3.04539371e-06)
162016 EPS nconv=0 first unconverged value (error) -302.035 (2.57373192e-06)
162017 EPS nconv=0 first unconverged value (error) -302.035 (2.44024945e-06)
162018 EPS nconv=0 first unconverged value (error) -302.035 (2.35781416e-06)
162019 EPS nconv=0 first unconverged value (error) -302.035 (2.35781416e-06)
162020 EPS nconv=0 first unconverged value (error) -302.035 (3.07587241e-06)
162021 EPS nconv=0 first unconverged value (error) -302.035 (2.74684608e-06)
162022 EPS nconv=0 first unconverged value (error) -302.035 (2.45871335e-06)
162023 EPS nconv=0 first unconverged value (error) -302.035 (2.46425244e-06)
162024 EPS nconv=0 first unconverged value (error) -302.035 (2.32566611e-06)
162025 EPS nconv=0 first unconverged value (error) -302.035 (2.32566611e-06)
162026 EPS nconv=0 first unconverged value (error) -302.035 (2.37424756e-06)
162027 EPS nconv=0 first unconverged value (error) -302.035 (2.63252369e-06)
162028 EPS nconv=0 first unconverged value (error) -302.035 (2.25914287e-06)
162029 EPS nconv=0 first unconverged value (error) -302.035 (1.99981569e-06)
162030 EPS nconv=0 first unconverged value (error) -302.035 (1.94307320e-06)
162031 EPS nconv=0 first unconverged value (error) -302.035 (1.94307320e-06)
162032 EPS nconv=0 first unconverged value (error) -302.035 (3.80131530e-06)
162033 EPS nconv=0 first unconverged value (error) -302.035 (3.08386935e-06)
162034 EPS nconv=0 first unconverged value (error) -302.035 (2.91164418e-06)
162035 EPS nconv=0 first unconverged value (error) -302.035 (2.86688002e-06)
162036 EPS nconv=0 first unconverged value (error) -302.035 (2.68242122e-06)
162037 EPS nconv=0 first unconverged value (error) -302.035 (2.68242122e-06)
162038 EPS nconv=0 first unconverged value (error) -302.035 (3.53250349e-06)
162039 EPS nconv=0 first unconverged value (error) -302.035 (3.96757850e-06)
162040 EPS nconv=0 first unconverged value (error) -302.035 (3.13943426e-06)
162041 EPS nconv=0 first unconverged value (error) -302.035 (2.79493547e-06)
162042 EPS nconv=0 first unconverged value (error) -302.035 (2.65148015e-06)
162043 EPS nconv=0 first unconverged value (error) -302.035 (2.65148015e-06)
162044 EPS nconv=0 first unconverged value (error) -302.035 (3.28620235e-06)
162045 EPS nconv=0 first unconverged value (error) -302.035 (2.86519813e-06)
162046 EPS nconv=0 first unconverged value (error) -302.035 (2.57037009e-06)
162047 EPS nconv=0 first unconverged value (error) -302.035 (2.51402162e-06)
162048 EPS nconv=0 first unconverged value (error) -302.035 (2.35058569e-06)
162049 EPS nconv=0 first unconverged value (error) -302.035 (2.35058569e-06)
162050 EPS nconv=0 first unconverged value (error) -302.035 (2.35869248e-06)
162051 EPS nconv=0 first unconverged value (error) -302.035 (2.51027741e-06)
162052 EPS nconv=0 first unconverged value (error) -302.035 (2.13692385e-06)
162053 EPS nconv=0 first unconverged value (error) -302.035 (1.96759520e-06)
162054 EPS nconv=0 first unconverged value (error) -302.035 (1.94715912e-06)
162055 EPS nconv=0 first unconverged value (error) -302.035 (1.94715912e-06)
162056 EPS nconv=0 first unconverged value (error) -302.035 (3.25770626e-06)
162057 EPS nconv=0 first unconverged value (error) -302.035 (2.74874026e-06)
162058 EPS nconv=0 first unconverged value (error) -302.035 (2.59896075e-06)
162059 EPS nconv=0 first unconverged value (error) -302.035 (2.54509126e-06)
162060 EPS nconv=0 first unconverged value (error) -302.035 (2.40243360e-06)
162061 EPS nconv=0 first unconverged value (error) -302.035 (2.40243360e-06)
162062 EPS nconv=0 first unconverged value (error) -302.035 (2.57642649e-06)
162063 EPS nconv=0 first unconverged value (error) -302.035 (3.08508905e-06)
162064 EPS nconv=0 first unconverged value (error) -302.035 (2.53267162e-06)
162065 EPS nconv=0 first unconverged value (error) -302.035 (2.11142512e-06)
162066 EPS nconv=0 first unconverged value (error) -302.035 (2.05561789e-06)
162067 EPS nconv=0 first unconverged value (error) -302.035 (2.05561789e-06)
162068 EPS nconv=0 first unconverged value (error) -302.035 (2.38226679e-06)
162069 EPS nconv=0 first unconverged value (error) -302.035 (2.14582570e-06)
162070 EPS nconv=0 first unconverged value (error) -302.035 (2.08224809e-06)
162071 EPS nconv=0 first unconverged value (error) -302.035 (2.05351144e-06)
162072 EPS nconv=0 first unconverged value (error) -302.035 (2.01169099e-06)
162073 EPS nconv=0 first unconverged value (error) -302.035 (2.01169099e-06)
162074 EPS nconv=0 first unconverged value (error) -302.035 (2.04139812e-06)
162075 EPS nconv=0 first unconverged value (error) -302.035 (2.08311436e-06)
162076 EPS nconv=0 first unconverged value (error) -302.035 (1.91973797e-06)
162077 EPS nconv=0 first unconverged value (error) -302.035 (1.85839745e-06)
162078 EPS nconv=0 first unconverged value (error) -302.035 (1.85463248e-06)
162079 EPS nconv=0 first unconverged value (error) -302.035 (1.85463248e-06)
162080 EPS nconv=0 first unconverged value (error) -302.035 (2.55720215e-06)
162081 EPS nconv=0 first unconverged value (error) -302.035 (2.23668902e-06)
162082 EPS nconv=0 first unconverged value (error) -302.035 (2.09197584e-06)
162083 EPS nconv=0 first unconverged value (error) -302.035 (2.05005396e-06)
162084 EPS nconv=0 first unconverged value (error) -302.035 (2.01962105e-06)
162085 EPS nconv=0 first unconverged value (error) -302.035 (2.01962105e-06)
162086 EPS nconv=0 first unconverged value (error) -302.035 (2.55819939e-06)
162087 EPS nconv=0 first unconverged value (error) -302.035 (2.74562671e-06)
162088 EPS nconv=0 first unconverged value (error) -302.035 (2.32184161e-06)
162089 EPS nconv=0 first unconverged value (error) -302.035 (2.10222194e-06)
162090 EPS nconv=0 first unconverged value (error) -302.035 (2.05800394e-06)
162091 EPS nconv=0 first unconverged value (error) -302.035 (2.05800394e-06)
162092 EPS nconv=0 first unconverged value (error) -302.035 (2.03561748e-06)
162093 EPS nconv=0 first unconverged value (error) -302.035 (2.18885157e-06)
162094 EPS nconv=0 first unconverged value (error) -302.035 (2.00300272e-06)
162095 EPS nconv=0 first unconverged value (error) -302.035 (1.84336093e-06)
162096 EPS nconv=0 first unconverged value (error) -302.035 (1.84278181e-06)
162097 EPS nconv=0 first unconverged value (error) -302.035 (1.84278181e-06)
162098 EPS nconv=0 first unconverged value (error) -302.035 (2.85103609e-06)
162099 EPS nconv=0 first unconverged value (error) -302.035 (2.34245453e-06)
162100 EPS nconv=0 first unconverged value (error) -302.035 (2.28249292e-06)
162101 EPS nconv=0 first unconverged value (error) -302.035 (2.23560165e-06)
162102 EPS nconv=0 first unconverged value (error) -302.035 (2.17129395e-06)
162103 EPS nconv=0 first unconverged value (error) -302.035 (2.17129395e-06)
162104 EPS nconv=0 first unconverged value (error) -302.035 (2.51117557e-06)
162105 EPS nconv=0 first unconverged value (error) -302.035 (2.85146147e-06)
162106 EPS nconv=0 first unconverged value (error) -302.035 (2.42244122e-06)
162107 EPS nconv=0 first unconverged value (error) -302.035 (1.99825092e-06)
162108 EPS nconv=0 first unconverged value (error) -302.035 (1.96702888e-06)
162109 EPS nconv=0 first unconverged value (error) -302.035 (1.96702888e-06)
162110 EPS nconv=0 first unconverged value (error) -302.035 (2.06872109e-06)
162111 EPS nconv=0 first unconverged value (error) -302.035 (2.03414106e-06)
162112 EPS nconv=0 first unconverged value (error) -302.035 (1.94331096e-06)
162113 EPS nconv=0 first unconverged value (error) -302.035 (1.92465023e-06)
162114 EPS nconv=0 first unconverged value (error) -302.035 (1.87555121e-06)
162115 EPS nconv=0 first unconverged value (error) -302.035 (1.87555121e-06)
162116 EPS nconv=0 first unconverged value (error) -302.035 (1.86626285e-06)
162117 EPS nconv=0 first unconverged value (error) -302.035 (1.86882724e-06)
162118 EPS nconv=0 first unconverged value (error) -302.035 (1.83028462e-06)
162119 EPS nconv=0 first unconverged value (error) -302.035 (1.81428309e-06)
162120 EPS nconv=0 first unconverged value (error) -302.035 (1.80331476e-06)
162121 EPS nconv=0 first unconverged value (error) -302.035 (1.80331476e-06)
162122 EPS nconv=0 first unconverged value (error) -302.035 (1.82845636e-06)
162123 EPS nconv=0 first unconverged value (error) -302.035 (1.81521244e-06)
162124 EPS nconv=0 first unconverged value (error) -302.035 (1.80893090e-06)
162125 EPS nconv=0 first unconverged value (error) -302.035 (1.80583978e-06)
162126 EPS nconv=0 first unconverged value (error) -302.035 (1.80357743e-06)
162127 EPS nconv=0 first unconverged value (error) -302.035 (1.80357743e-06)
162128 EPS nconv=0 first unconverged value (error) -302.035 (2.20710732e-06)
162129 EPS nconv=0 first unconverged value (error) -302.035 (2.15570100e-06)
162130 EPS nconv=0 first unconverged value (error) -302.035 (2.10082190e-06)
162131 EPS nconv=0 first unconverged value (error) -302.035 (2.02186606e-06)
162132 EPS nconv=0 first unconverged value (error) -302.035 (2.01499548e-06)
162133 EPS nconv=0 first unconverged value (error) -302.035 (2.01499548e-06)
162134 EPS nconv=0 first unconverged value (error) -302.035 (2.14695854e-06)
162135 EPS nconv=0 first unconverged value (error) -302.035 (2.10968261e-06)
162136 EPS nconv=0 first unconverged value (error) -302.035 (2.06110182e-06)
162137 EPS nconv=0 first unconverged value (error) -302.035 (1.88668989e-06)
162138 EPS nconv=0 first unconverged value (error) -302.035 (1.86566918e-06)
162139 EPS nconv=0 first unconverged value (error) -302.035 (1.86566918e-06)
162140 EPS nconv=0 first unconverged value (error) -302.035 (1.87188806e-06)
162141 EPS nconv=0 first unconverged value (error) -302.035 (1.87645075e-06)
162142 EPS nconv=0 first unconverged value (error) -302.035 (1.82821892e-06)
162143 EPS nconv=0 first unconverged value (error) -302.035 (1.82124487e-06)
162144 EPS nconv=0 first unconverged value (error) -302.035 (1.81280847e-06)
162145 EPS nconv=0 first unconverged value (error) -302.035 (1.81280847e-06)
162146 EPS nconv=0 first unconverged value (error) -302.035 (2.28568606e-06)
162147 EPS nconv=0 first unconverged value (error) -302.035 (2.19281422e-06)
162148 EPS nconv=0 first unconverged value (error) -302.035 (2.04185954e-06)
162149 EPS nconv=0 first unconverged value (error) -302.035 (1.99379617e-06)
162150 EPS nconv=0 first unconverged value (error) -302.035 (1.97650056e-06)
162151 EPS nconv=0 first unconverged value (error) -302.035 (1.97650056e-06)
162152 EPS nconv=0 first unconverged value (error) -302.035 (2.12580005e-06)
162153 EPS nconv=0 first unconverged value (error) -302.035 (2.27316938e-06)
162154 EPS nconv=0 first unconverged value (error) -302.035 (2.17731698e-06)
162155 EPS nconv=0 first unconverged value (error) -302.035 (1.90410327e-06)
162156 EPS nconv=0 first unconverged value (error) -302.035 (1.86713786e-06)
162157 EPS nconv=0 first unconverged value (error) -302.035 (1.86713786e-06)
162158 EPS nconv=0 first unconverged value (error) -302.035 (1.85975155e-06)
162159 EPS nconv=0 first unconverged value (error) -302.035 (1.87663287e-06)
162160 EPS nconv=0 first unconverged value (error) -302.035 (1.84915898e-06)
162161 EPS nconv=0 first unconverged value (error) -302.035 (1.81926936e-06)
162162 EPS nconv=0 first unconverged value (error) -302.035 (1.81229517e-06)
162163 EPS nconv=0 first unconverged value (error) -302.035 (1.81229517e-06)
162164 EPS nconv=0 first unconverged value (error) -302.035 (2.18947221e-06)
162165 EPS nconv=0 first unconverged value (error) -302.035 (2.05294679e-06)
162166 EPS nconv=0 first unconverged value (error) -302.035 (1.99577320e-06)
162167 EPS nconv=0 first unconverged value (error) -302.035 (1.97298877e-06)
162168 EPS nconv=0 first unconverged value (error) -302.035 (1.94240115e-06)
162169 EPS nconv=0 first unconverged value (error) -302.035 (1.94240115e-06)
162170 EPS nconv=0 first unconverged value (error) -302.035 (2.48903780e-06)
162171 EPS nconv=0 first unconverged value (error) -302.035 (2.64717737e-06)
162172 EPS nconv=0 first unconverged value (error) -302.035 (2.42739329e-06)
162173 EPS nconv=0 first unconverged value (error) -302.035 (2.14388963e-06)
162174 EPS nconv=0 first unconverged value (error) -302.035 (2.12274595e-06)
162175 EPS nconv=0 first unconverged value (error) -302.035 (2.12274595e-06)
162176 EPS nconv=0 first unconverged value (error) -302.035 (2.18888104e-06)
162177 EPS nconv=0 first unconverged value (error) -302.035 (2.09800134e-06)
162178 EPS nconv=0 first unconverged value (error) -302.035 (2.01644037e-06)
162179 EPS nconv=0 first unconverged value (error) -302.035 (1.91239171e-06)
162180 EPS nconv=0 first unconverged value (error) -302.035 (1.85534619e-06)
162181 EPS nconv=0 first unconverged value (error) -302.035 (1.85534619e-06)
162182 EPS nconv=0 first unconverged value (error) -302.035 (1.96653525e-06)
162183 EPS nconv=0 first unconverged value (error) -302.035 (1.92711736e-06)
162184 EPS nconv=0 first unconverged value (error) -302.035 (1.87761277e-06)
162185 EPS nconv=0 first unconverged value (error) -302.035 (1.83859119e-06)
162186 EPS nconv=0 first unconverged value (error) -302.035 (1.82843053e-06)
162187 EPS nconv=0 first unconverged value (error) -302.035 (1.82843053e-06)
162188 EPS nconv=0 first unconverged value (error) -302.035 (1.82769679e-06)
162189 EPS nconv=0 first unconverged value (error) -302.035 (1.84445300e-06)
162190 EPS nconv=0 first unconverged value (error) -302.035 (1.81819787e-06)
162191 EPS nconv=0 first unconverged value (error) -302.035 (1.80735006e-06)
162192 EPS nconv=0 first unconverged value (error) -302.035 (1.80167119e-06)
162193 EPS nconv=0 first unconverged value (error) -302.035 (1.80167119e-06)
162194 EPS nconv=0 first unconverged value (error) -302.035 (1.80103835e-06)
162195 EPS nconv=0 first unconverged value (error) -302.035 (1.80244158e-06)
162196 EPS nconv=0 first unconverged value (error) -302.035 (1.79923375e-06)
162197 EPS nconv=0 first unconverged value (error) -302.035 (1.79695869e-06)
162198 EPS nconv=0 first unconverged value (error) -302.035 (1.79612380e-06)
162199 EPS nconv=0 first unconverged value (error) -302.035 (1.79612380e-06)
162200 EPS nconv=0 first unconverged value (error) -302.035 (1.87045783e-06)
162201 EPS nconv=0 first unconverged value (error) -302.035 (1.84279809e-06)
162202 EPS nconv=0 first unconverged value (error) -302.035 (1.83553562e-06)
162203 EPS nconv=0 first unconverged value (error) -302.035 (1.82859629e-06)
162204 EPS nconv=0 first unconverged value (error) -302.035 (1.82184166e-06)
162205 EPS nconv=0 first unconverged value (error) -302.035 (1.82184166e-06)
162206 EPS nconv=0 first unconverged value (error) -302.035 (1.83892155e-06)
162207 EPS nconv=0 first unconverged value (error) -302.035 (1.84989645e-06)
162208 EPS nconv=0 first unconverged value (error) -302.035 (1.82093623e-06)
162209 EPS nconv=0 first unconverged value (error) -302.035 (1.81647318e-06)
162210 EPS nconv=0 first unconverged value (error) -302.035 (1.80782422e-06)
162211 EPS nconv=0 first unconverged value (error) -302.035 (1.80782422e-06)
162212 EPS nconv=0 first unconverged value (error) -302.035 (1.80475069e-06)
162213 EPS nconv=0 first unconverged value (error) -302.035 (1.80707090e-06)
162214 EPS nconv=0 first unconverged value (error) -302.035 (1.80003246e-06)
162215 EPS nconv=0 first unconverged value (error) -302.035 (1.79758380e-06)
162216 EPS nconv=0 first unconverged value (error) -302.035 (1.79714564e-06)
162217 EPS nconv=0 first unconverged value (error) -302.035 (1.79714564e-06)
162218 EPS nconv=0 first unconverged value (error) -302.035 (1.79822223e-06)
162219 EPS nconv=0 first unconverged value (error) -302.035 (1.79736091e-06)
162220 EPS nconv=0 first unconverged value (error) -302.035 (1.79634728e-06)
162221 EPS nconv=0 first unconverged value (error) -302.035 (1.79543354e-06)
162222 EPS nconv=0 first unconverged value (error) -302.035 (1.79492451e-06)
162223 EPS nconv=0 first unconverged value (error) -302.035 (1.79492451e-06)
162224 EPS nconv=0 first unconverged value (error) -302.035 (1.91441115e-06)
162225 EPS nconv=0 first unconverged value (error) -302.035 (1.87679961e-06)
162226 EPS nconv=0 first unconverged value (error) -302.035 (1.85810779e-06)
162227 EPS nconv=0 first unconverged value (error) -302.035 (1.84829449e-06)
162228 EPS nconv=0 first unconverged value (error) -302.035 (1.83902774e-06)
162229 EPS nconv=0 first unconverged value (error) -302.035 (1.83902774e-06)
162230 EPS nconv=0 first unconverged value (error) -302.035 (2.11089592e-06)
162231 EPS nconv=0 first unconverged value (error) -302.035 (2.12813809e-06)
162232 EPS nconv=0 first unconverged value (error) -302.035 (2.04533972e-06)
162233 EPS nconv=0 first unconverged value (error) -302.035 (1.94162926e-06)
162234 EPS nconv=0 first unconverged value (error) -302.035 (1.92151543e-06)
162235 EPS nconv=0 first unconverged value (error) -302.035 (1.92151543e-06)
162236 EPS nconv=0 first unconverged value (error) -302.035 (1.91759912e-06)
162237 EPS nconv=0 first unconverged value (error) -302.035 (1.95261767e-06)
162238 EPS nconv=0 first unconverged value (error) -302.035 (1.91457496e-06)
162239 EPS nconv=0 first unconverged value (error) -302.035 (1.81010800e-06)
162240 EPS nconv=0 first unconverged value (error) -302.035 (1.79945543e-06)
162241 EPS nconv=0 first unconverged value (error) -302.035 (1.79945543e-06)
162242 EPS nconv=0 first unconverged value (error) -302.035 (1.85368366e-06)
162243 EPS nconv=0 first unconverged value (error) -302.035 (1.83768736e-06)
162244 EPS nconv=0 first unconverged value (error) -302.035 (1.83580381e-06)
162245 EPS nconv=0 first unconverged value (error) -302.035 (1.83131567e-06)
162246 EPS nconv=0 first unconverged value (error) -302.035 (1.82966472e-06)
162247 EPS nconv=0 first unconverged value (error) -302.035 (1.82966472e-06)
162248 EPS nconv=0 first unconverged value (error) -302.035 (2.17375116e-06)
162249 EPS nconv=0 first unconverged value (error) -302.035 (2.01450769e-06)
162250 EPS nconv=0 first unconverged value (error) -302.035 (1.93528670e-06)
162251 EPS nconv=0 first unconverged value (error) -302.035 (1.92520109e-06)
162252 EPS nconv=0 first unconverged value (error) -302.035 (1.91555027e-06)
162253 EPS nconv=0 first unconverged value (error) -302.035 (1.91555027e-06)
162254 EPS nconv=0 first unconverged value (error) -302.035 (2.07666448e-06)
162255 EPS nconv=0 first unconverged value (error) -302.035 (2.16376954e-06)
162256 EPS nconv=0 first unconverged value (error) -302.035 (1.98865647e-06)
162257 EPS nconv=0 first unconverged value (error) -302.035 (1.94036135e-06)
162258 EPS nconv=0 first unconverged value (error) -302.035 (1.92713311e-06)
162259 EPS nconv=0 first unconverged value (error) -302.035 (1.92713311e-06)
162260 EPS nconv=0 first unconverged value (error) -302.035 (2.19054687e-06)
162261 EPS nconv=0 first unconverged value (error) -302.035 (2.04912604e-06)
162262 EPS nconv=0 first unconverged value (error) -302.035 (1.98905275e-06)
162263 EPS nconv=0 first unconverged value (error) -302.035 (1.97930216e-06)
162264 EPS nconv=0 first unconverged value (error) -302.035 (1.93448447e-06)
162265 EPS nconv=0 first unconverged value (error) -302.035 (1.93448447e-06)
162266 EPS nconv=0 first unconverged value (error) -302.035 (1.93864898e-06)
162267 EPS nconv=0 first unconverged value (error) -302.035 (1.99043687e-06)
162268 EPS nconv=0 first unconverged value (error) -302.035 (1.88388126e-06)
162269 EPS nconv=0 first unconverged value (error) -302.035 (1.83861957e-06)
162270 EPS nconv=0 first unconverged value (error) -302.035 (1.83352780e-06)
162271 EPS nconv=0 first unconverged value (error) -302.035 (1.83352780e-06)
162272 EPS nconv=0 first unconverged value (error) -302.035 (1.98979145e-06)
162273 EPS nconv=0 first unconverged value (error) -302.035 (1.90079318e-06)
162274 EPS nconv=0 first unconverged value (error) -302.035 (1.86893183e-06)
162275 EPS nconv=0 first unconverged value (error) -302.035 (1.86948158e-06)
162276 EPS nconv=0 first unconverged value (error) -302.035 (1.85480850e-06)
162277 EPS nconv=0 first unconverged value (error) -302.035 (1.85480850e-06)
162278 EPS nconv=0 first unconverged value (error) -302.035 (2.02329281e-06)
162279 EPS nconv=0 first unconverged value (error) -302.035 (2.02295302e-06)
162280 EPS nconv=0 first unconverged value (error) -302.035 (1.91542210e-06)
162281 EPS nconv=0 first unconverged value (error) -302.035 (1.90646344e-06)
162282 EPS nconv=0 first unconverged value (error) -302.035 (1.89747812e-06)
162283 EPS nconv=0 first unconverged value (error) -302.035 (1.89747812e-06)
162284 EPS nconv=0 first unconverged value (error) -302.035 (1.88782737e-06)
162285 EPS nconv=0 first unconverged value (error) -302.035 (1.91516888e-06)
162286 EPS nconv=0 first unconverged value (error) -302.035 (1.89610759e-06)
162287 EPS nconv=0 first unconverged value (error) -302.035 (1.82185448e-06)
162288 EPS nconv=0 first unconverged value (error) -302.035 (1.80859776e-06)
162289 EPS nconv=0 first unconverged value (error) -302.035 (1.80859776e-06)
162290 EPS nconv=0 first unconverged value (error) -302.035 (1.80691128e-06)
162291 EPS nconv=0 first unconverged value (error) -302.035 (1.80041155e-06)
162292 EPS nconv=0 first unconverged value (error) -302.035 (1.79727409e-06)
162293 EPS nconv=0 first unconverged value (error) -302.035 (1.79562453e-06)
162294 EPS nconv=0 first unconverged value (error) -302.035 (1.79523452e-06)
162295 EPS nconv=0 first unconverged value (error) -302.035 (1.79523452e-06)
162296 EPS nconv=0 first unconverged value (error) -302.035 (2.18940620e-06)
162297 EPS nconv=0 first unconverged value (error) -302.035 (2.05521981e-06)
162298 EPS nconv=0 first unconverged value (error) -302.035 (2.01586276e-06)
162299 EPS nconv=0 first unconverged value (error) -302.035 (1.99239418e-06)
162300 EPS nconv=0 first unconverged value (error) -302.035 (1.97910587e-06)
162301 EPS nconv=0 first unconverged value (error) -302.035 (1.97910587e-06)
162302 EPS nconv=0 first unconverged value (error) -302.035 (2.00089185e-06)
162303 EPS nconv=0 first unconverged value (error) -302.035 (2.03012774e-06)
162304 EPS nconv=0 first unconverged value (error) -302.035 (1.89135856e-06)
162305 EPS nconv=0 first unconverged value (error) -302.035 (1.85085381e-06)
162306 EPS nconv=0 first unconverged value (error) -302.035 (1.82883820e-06)
162307 EPS nconv=0 first unconverged value (error) -302.035 (1.82883820e-06)
162308 EPS nconv=0 first unconverged value (error) -302.035 (1.90912593e-06)
162309 EPS nconv=0 first unconverged value (error) -302.035 (1.89615459e-06)
162310 EPS nconv=0 first unconverged value (error) -302.035 (1.85924538e-06)
162311 EPS nconv=0 first unconverged value (error) -302.035 (1.84045568e-06)
162312 EPS nconv=0 first unconverged value (error) -302.035 (1.82753063e-06)
162313 EPS nconv=0 first unconverged value (error) -302.035 (1.82753063e-06)
162314 EPS nconv=0 first unconverged value (error) -302.035 (1.89190342e-06)
162315 EPS nconv=0 first unconverged value (error) -302.035 (1.88391926e-06)
162316 EPS nconv=0 first unconverged value (error) -302.035 (1.84013282e-06)
162317 EPS nconv=0 first unconverged value (error) -302.035 (1.82926109e-06)
162318 EPS nconv=0 first unconverged value (error) -302.035 (1.81858035e-06)
162319 EPS nconv=0 first unconverged value (error) -302.035 (1.81858035e-06)
162320 EPS nconv=0 first unconverged value (error) -302.035 (2.86635389e-06)
Type set to gd
Solution method: gd
nev: Number of requested eigenvalues: 3
ncv: maximum dimension of the subspace can be used by the solver: -2
mpd: maximum dimension allowed for the projected problem: -2
Stopping condition: tol=-2, maxit=-2
Initial size of subspace is 3
Number of vectors to be added to the searching space in every iteratioN: 3
Time used in sovle matrix: 873895.906 s
Number of iterations of the method: 162320
Matrix dimension is: 81160
Number of converged eigenpairs: 0
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
/public/home/jrf/works/ecMRCI-worktree/testGAcomm/MRCI on a named g14r3n12 with 96 processors, by jrf Wed Jul 13 10:09:58 2022
Using Petsc Release Version 3.15.1, Jun 17, 2021
Max Max/Min Avg Total
Time (sec): 1.726e+03 1.000 1.726e+03
Objects: 3.356e+06 1.000 3.355e+06
Flop: 9.760e+11 2.843 4.923e+11 4.726e+13
Flop/sec: 5.654e+08 2.843 2.852e+08 2.738e+10
MPI Messages: 3.598e+07 1.000 3.598e+07 3.454e+09
MPI Message Lengths: 2.172e+11 2.142 4.376e+03 1.512e+13
MPI Reductions: 3.794e+06 1.000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flop
and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total Count %Total Avg %Total Count %Total
0: Main Stage: 1.7262e+03 100.0% 4.7262e+13 100.0% 3.454e+09 100.0% 4.376e+03 100.0% 3.794e+06 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flop: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
AvgLen: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flop in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event Count Time (sec) Flop --- Global --- --- Stage ---- Total
Max Ratio Max Ratio Max Ratio Mess AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSided 2 1.0 8.4439e+021859783.6 0.00e+00 0.0 9.1e+03 4.0e+00 2.0e+00 26 0 0 0 0 26 0 0 0 0 0
BuildTwoSidedF 1 1.0 8.4439e+026644315.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 26 0 0 0 0 26 0 0 0 0 0
MatMult 378752 1.0 5.8503e+02 1.4 7.37e+11 4.5 3.5e+09 4.4e+03 1.0e+00 28 63100100 0 28 63100100 0 51044
MatSolve 757498 1.0 8.4558e+01 2.0 1.36e+11 2.2 0.0e+00 0.0e+00 0.0e+00 3 16 0 0 0 3 16 0 0 0 88040
MatLUFactorNum 1 1.0 5.3938e-03 4.0 6.42e+06 4.8 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 38424
MatILUFactorSym 1 1.0 2.7343e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyBegin 1 1.0 8.4439e+025237966.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00 26 0 0 0 0 26 0 0 0 0 0
MatAssemblyEnd 1 1.0 3.1113e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRowIJ 1 1.0 4.3900e-0619.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 4.2451e-05 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatZeroEntries 189373 1.0 3.4318e-01 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecCopy 1893745 1.0 1.0324e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 757499 1.0 5.3548e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 378752 1.0 3.8795e+01 2.2 0.00e+00 0.0 3.5e+09 4.4e+03 1.0e+00 1 0100100 0 1 0100100 0 0
VecScatterEnd 378752 1.0 3.3263e+02 5.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 15 0 0 0 0 15 0 0 0 0 0
VecSetRandom 3 1.0 1.0076e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecReduceArith 1271514 1.0 9.2767e-01 1.4 2.15e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 222352
VecReduceComm 892765 1.0 3.9618e+01 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 8.9e+05 2 0 0 0 24 2 0 0 0 24 0
SFSetGraph 1 1.0 1.2829e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFSetUp 1 1.0 2.1332e-03 1.1 0.00e+00 0.0 1.8e+04 1.1e+03 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
SFPack 378752 1.0 2.5830e+01 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
SFUnpack 378752 1.0 1.4309e-01 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
EPSSetUp 1 1.0 1.1256e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.7e+01 0 0 0 0 0 0 0 0 0 0 0
EPSSolve 1 1.0 8.7392e+02 1.0 9.76e+11 2.8 3.5e+09 4.4e+03 3.8e+06 51100100100100 51100100100100 54080
STSetUp 1 1.0 7.4052e-0512.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
STComputeOperatr 1 1.0 1.6901e-05 8.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BVCreate 378753 1.0 3.7957e+01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.1e+06 2 0 0 0 30 2 0 0 0 30 0
BVCopy 757498 1.0 5.7302e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BVMultVec 2522649 1.0 1.2929e+01 1.4 4.77e+10 1.0 0.0e+00 0.0e+00 0.0e+00 1 10 0 0 0 1 10 0 0 0 354129
BVMultInPlace 432855 1.0 8.2530e+00 1.1 1.60e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 3 0 0 0 0 3 0 0 0 186229
BVDot 649284 1.0 1.8630e+02 6.0 1.86e+10 1.0 0.0e+00 0.0e+00 6.5e+05 8 4 0 0 17 8 4 0 0 17 9570
BVDotVec 1115868 1.0 5.9760e+01 2.7 1.89e+10 1.0 0.0e+00 0.0e+00 1.1e+06 3 4 0 0 29 3 4 0 0 29 30264
BVOrthogonalizeV 378752 1.0 3.4070e+01 1.5 3.52e+10 1.0 0.0e+00 0.0e+00 7.4e+05 2 7 0 0 19 2 7 0 0 19 99049
BVScale 514019 1.0 4.1113e-01 1.6 4.35e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 101471
BVSetRandom 3 1.0 1.3902e-04 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
BVMatProject 514017 1.0 2.0423e+02 3.8 1.86e+10 1.0 0.0e+00 0.0e+00 6.5e+05 9 4 0 0 17 9 4 0 0 17 8730
DSSolve 162321 1.0 9.7458e+00 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
DSVectors 757498 1.0 3.6482e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
DSOther 351693 1.0 8.2294e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSetUp 1 1.0 2.2830e-0549.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 757498 1.0 8.6914e+01 2.0 1.36e+11 2.2 0.0e+00 0.0e+00 0.0e+00 3 16 0 0 0 3 16 0 0 0 85653
PCSetUp 2 1.0 5.7365e-03 3.3 6.42e+06 4.8 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 36128
PCApply 757498 1.0 8.8212e+01 1.9 1.36e+11 2.2 0.0e+00 0.0e+00 0.0e+00 3 16 0 0 0 3 16 0 0 0 84395
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Matrix 1460896 1460896 5156045016 0.
Vector 1515021 1515021 15472228320 0.
Index Set 5 5 305664 0.
Star Forest Graph 1 1 1224 0.
EPS Solver 1 1 3468 0.
Spectral Transform 1 1 908 0.
Viewer 2 1 848 0.
Basis Vectors 378754 378754 836290896 0.
Region 1 1 680 0.
Direct Solver 1 1 20156 0.
Krylov Solver 2 2 3200 0.
Preconditioner 2 2 1936 0.
PetscRandom 1 1 670 0.
Average time to get PetscTime(): 4.7e-08
Average time for MPI_Barrier(): 1.87806e-05
Average time for zero size MPI_Send(): 5.00703e-06
#PETSc Option Table entries:
-eps_gd_blocksize 3
-eps_gd_initial_size 3
-eps_monitor
-eps_ncv PETSC_DEFAULT
-eps_type gd
-log_view
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
rank 8Time used for building and solve ec-Hamiltonian is 1729.42 s
rank 9Time used for building and solve ec-Hamiltonian is 1729.31 s
rank 13Time used for building and solve ec-Hamiltonian is 1728.82 s
Configure options: --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --with-blaslapack=1 --with-blaslapack-dir=/public/software/compiler/intel/oneapi/mkl/2021.3.0 --with-64-bit-blas-indices=0 --with-boost=1 --with-boost-dir=/public/home/jrf/tools/boost_1_73_0/gcc7.3.1 --prefix=/public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug --with-valgrind-dir=/public/home/jrf/tools/valgrind --LDFLAGS=-Wl,-rpath=/opt/rh/devtoolset-7/root/usr/lib64 -Wl,-rpath=/opt/rh/devtoolset-7/root/usr/lib --with-64-bit-indices=0 --with-petsc-arch=gcc7.3.1-32indices-nodebug --with-debugging=no
Libraries compiled on 2022-06-14 01:43:59 on login05
Machine characteristics: Linux-3.10.0-957.el7.x86_64-x86_64-with-centos
Using PETSc directory: /public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug
Using PETSc arch:
Using C compiler: mpicc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O
Using Fortran compiler: mpif90 -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O
Using include paths: -I/public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug/include -I/public/home/jrf/tools/boost_1_73_0/gcc7.3.1/include -I/public/home/jrf/tools/valgrind/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug/lib -L/public/home/jrf/tools/petsc3.15.1/gcc7.3.1-32indices-nodebug/lib -lpetsc -Wl,-rpath,/public/software/compiler/intel/oneapi/mkl/2021.3.0/lib/intel64 -L/public/software/compiler/intel/oneapi/mkl/2021.3.0/lib/intel64 -Wl,-rpath,/opt/hpc/software/mpi/hwloc/lib -L/opt/hpc/software/mpi/hwloc/lib -Wl,-rpath,/opt/hpc/software/mpi/hpcx/v2.7.4/gcc-7.3.1/lib -L/opt/hpc/software/mpi/hpcx/v2.7.4/gcc-7.3.1/lib -Wl,-rpath,/opt/rh/devtoolset-7/root/usr/lib/gcc/x86_64-redhat-linux/7 -L/opt/rh/devtoolset-7/root/usr/lib/gcc/x86_64-redhat-linux/7 -Wl,-rpath,/opt/rh/devtoolset-7/root/usr/lib64 -L/opt/rh/devtoolset-7/root/usr/lib64 -Wl,-rpath,/opt/hpc/software/mpi/hpcx/v2.7.4/sharp/lib -L/opt/hpc/software/mpi/hpcx/v2.7.4/sharp/lib -Wl,-rpath,/opt/hpc/software/mpi/hpcx/v2.7.4/hcoll/lib -L/opt/hpc/software/mpi/hpcx/v2.7.4/hcoll/lib -Wl,-rpath,/opt/hpc/software/mpi/hpcx/v2.7.4/ucx_without_rocm/lib -L/opt/hpc/software/mpi/hpcx/v2.7.4/ucx_without_rocm/lib -Wl,-rpath,/opt/rh/devtoolset-7/root/usr/lib -L/opt/rh/devtoolset-7/root/usr/lib -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lm -lX11 -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lquadmath -lstdc++ -ldl
