[petsc-users] Creating dmplex in every rank and redistributing
Mon Jul 11 06:49:36 CDT 2022
On Mon, Jul 11, 2022 at 5:54 AM Prateek Gupta <prateekgupta1709 at gmail.com>
wrote:
> Thanks Matt.
> While looking into the function, I noted PetscHSetI and related functions
> but couldn't find their docs (404 error). Have these functions and data
> types deprecated?
No. These are a bit complicated because they are made by the preprocessor
from a 3rd party package.
We broke the links when we moved all the documentation to Sphinx. I will
see if I can fix them.
      Matt
> Thank you.
> Sincerely,
> Prateek Gupta
> On Mon, Jul 4, 2022 at 6:09 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Jul 4, 2022 at 2:29 AM Prateek Gupta <prateekgupta1709 at gmail.com>
>> wrote:
>>> Hi,
>>> Using dmplex, I am trying to create an example where I can start with a
>>> poor distribution of an unstructured mesh (reading from a file in parallel)
>>> and then use redistribution to optimize it.
>> You can call DMPlexDistribute() on any mesh, including a parallel one.
>>> I know that I can call ReBalanceSharedPoints on an already created
>>> distribution from dmplexDistribute. But is it possible to initialize a
>>> dmplex from each rank (each rank initializes its own chunk of the mesh) and
>>> then call this function?
>> Yes, this is done in
>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexCreateFromCellListParallelPetsc/
>> It is not trivial to do by hand, so I would look at that code first if
>> you want to do that.
>>> Most of the numbering in dmplex DAG representation is local, but while
>>> reading from a file in parallel, I only have access to global numbering of
>>> nodes. Do I need to reassign this to a local numbering? Is there a
>>> datastructure within petsc that can help with this?
>>> Thank you.
>>> Sincerely,
>>> Prateek Gupta, PhD
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220711/2b5fae7f/attachment.html>
