[petsc-users] DMPlexCreateSection crashed with larger number of processors
Mike Michell mi.mike1021 at gmail.com
Wed Jul 6 14:41:51 CDT 2022
I am passing NULL for IS Permutation as;
call
DMPlexCreateSection(dm_geom,nolabel,pNumComp,pNumDof,numBC,pBcField,pBcCompIS,pBcPointIS,PETSC_NULL_IS,section,ierr)
Should I define non-NULL IS Permutation before I call DMPlexCreateSection()
to avoid the issue?
Mike
On Wed, Jul 6, 2022 at 12:57 PM Mike Michell <mi.mike1021 at gmail.com> wrote:
>> Hi, I am using DMPlex for a FVM code written in Fortran that uses
>> DMPlexCreateSection() to prepare an output file in vtu format. A domain of
>> interest has around 5000 node points and with small number of processors
>> (such as nproc=3), the DMPlexCreateSection() works fine. However, if a
>> larger number of procs (such as nproc=20) is used,  DMPlexCreateSection()
>> crashes with error message below. It looks very similar problem in a
>> previous PETSc user inquiry: " [petsc-dev] DMPlexCreateSection crash in
>> a no-boundary corner case
>> <https://lists.mcs.anl.gov/pipermail/petsc-dev/2013-November/014049.html>
> Yes, the recommendation is not to pass a NULL PetscIS to the AddBoundary()
> routine. Are you doing this?
>   Thanks,
>      Matt
>> When I call DMPlexCreateSection(), a nullified pointer
>> "nolabel(:)=>NULL()" is provided. What is a possible solution to this
>> problem? It looks like there is a problem with a processor that does not
>> have any boundaries. A piece of the source code is attached to show how
>> the  DMPlexCreateSection() is used in the code.
>> Thanks,
>> Mike
>> [16]PETSC ERROR: --------------------- Error Message
>> [16]PETSC ERROR: Null argument, when expecting valid pointer
>> [16]PETSC ERROR: Null Pointer: Parameter # 1
>> [16]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [16]PETSC ERROR: Petsc Release Version 3.17.0, unknown
>> [16]PETSC ERROR: #1 ISGetLocalSize() at
>> [16]PETSC ERROR: #2 DMPlexCreateSectionBCDof() at
>> [16]PETSC ERROR: #3 DMPlexCreateSection() at
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220706/ea5127d9/attachment.html>
