[petsc-users] DMPlexCreateSection crashed with larger number of processors
Mike Michell mi.mike1021 at gmail.com
Wed Jul 6 11:56:54 CDT 2022
Hi, I am using DMPlex for a FVM code written in Fortran that uses
DMPlexCreateSection() to prepare an output file in vtu format. A domain of
interest has around 5000 node points and with small number of processors
(such as nproc=3), the DMPlexCreateSection() works fine. However, if a
larger number of procs (such as nproc=20) is used,  DMPlexCreateSection()
crashes with error message below. It looks very similar problem in a
previous PETSc user inquiry: " [petsc-dev] DMPlexCreateSection crash in a
no-boundary corner case
<https://lists.mcs.anl.gov/pipermail/petsc-dev/2013-November/014049.html>"
When I call DMPlexCreateSection(), a nullified pointer "nolabel(:)=>NULL()"
is provided. What is a possible solution to this problem? It looks like
there is a problem with a processor that does not have any boundaries. A
piece of the source code is attached to show how the  DMPlexCreateSection()
is used in the code.
Mike
[16]PETSC ERROR: --------------------- Error Message
[16]PETSC ERROR: Null argument, when expecting valid pointer
[16]PETSC ERROR: Null Pointer: Parameter # 1
[16]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[16]PETSC ERROR: Petsc Release Version 3.17.0, unknown
[16]PETSC ERROR: #1 ISGetLocalSize() at
[16]PETSC ERROR: #2 DMPlexCreateSectionBCDof() at
[16]PETSC ERROR: #3 DMPlexCreateSection() at
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220706/77d94d84/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220706/77d94d84/attachment.obj>
