[petsc-users] DMPlexInterpolate error nonconforming object sizes
Matthew Knepley
knepley at gmail.com
Sat Jul 2 06:07:38 CDT 2022
On Sat, Jul 2, 2022 at 3:11 AM Prateek Gupta <prateekgupta1709 at gmail.com>
wrote:
> Hi,
> I am trying to create a minimal example of reading nodes and elements from
> a text file and creating dmplex mesh. So far I am following the procedure
> as in plexfluent.c. However, while trying to interpolate the mesh, I get
> the error,
> [0]PETSC ERROR: Nonconforming object sizes
> [0]PETSC ERROR: The number of vertices in first DM 20 != 0 in the second DM
> The call trace looks like this,
> [0]PETSC ERROR: #1 DMPlexCopyCoordinates() line 1448 in
> /build/petsc-zg3KH7/petsc-3.12.4+dfsg1/src/dm/impls/plex/plexinterpolate.c
> [0]PETSC ERROR: #2 DMPlexInterpolate() line 1394 in
> The code snippet for interpolation is exactly same as in plexfluent.c
> except for the petscCall function,
> if (interpolate) {
> DM idm;
> PetscCall(DMPlexInterpolate(*dm, &idm));
> PetscCall(DMDestroy(dm));
> dm = idm;
> dm is the DM object declared within main only. Any help will be
> appreciated. I can guess that the idm object doesn't have memory allocated
> for copying the vertices, but my question is how come it works off-the-bat
> for fluent/gmsh files using functions in plexfluent.c and plexgmsh.c. Is
> there a way to allocate just the vertices? Or do I need to use
> DMPlexSetChart for idm object before interpolating?
My guess is that the first DM is invalid. If you send the code, I will go
through it.
Matt
> Thank you.
> Sincerely,
> Prateek Gupta, PhD
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220702/4172901e/attachment.html>
