[petsc-users] Cannot eagerly initialize cuda, as doing so results in cuda error 35 (cudaErrorInsufficientDriver) : CUDA driver version is insufficient for CUDA runtime version
Junchao Zhang
junchao.zhang at gmail.com
Mon Jan 31 13:10:48 CST 2022
On Mon, Jan 31, 2022 at 10:50 AM Fande Kong <fdkong.jd at gmail.com> wrote:
> Sorry for the confusion. I thought I explained pretty well :-)
> Good:
> PETSc was linked to /usr/lib64/libcuda for libcuda
> Bad:
> PETSc was linked
> to /apps/local/spack/software/gcc-7.5.0/cuda-10.1.243-v4ymjqcrr7f72qfiuzsstuy5jiajbuey/lib64/stubs
> for libcuda
> My question would be: where should I look for libcuda?
> Our HPC admin told me that I should use the one from /usr/lib64/libcuda
Your admin was correct.
> I am trying to understand why we need to link to "stubs"?
Kokkos needs libcuda.so, so we added this requirement.
> Just to be clear, I am fine with PETSc-main as is since I can use a
> compute node to compile PETSc. However, here I am trying really hard to
> understand where I should look for the right libcuda.
I need your help to find out: Why on compute nodes, did the petsc test
executable find libcuda.so at /apps/local/spack/software/
gcc-7.5.0/cuda-10.1.243-v4ymjqcrr7f72qfiuzsstuy5jiajbuey/lib64/stubs?
Note this path is not in the executable's rpath. Maybe you need to login
to a compute node and do 'env' to list all variables for us to have a look.
> Thanks for your help
> Fande
> On Mon, Jan 31, 2022 at 9:19 AM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Fande,
>> From your configure_main.log
>> cuda:
>> Version: 10.1
>> Includes:
>> -I/apps/local/spack/software/gcc-7.5.0/cuda-10.1.243-v4ymjqcrr7f72qfiuzsstuy5jiajbuey/include
>> Library:
>> -Wl,-rpath,/apps/local/spack/software/gcc-7.5.0/cuda-10.1.243-v4ymjqcrr7f72qfiuzsstuy5jiajbuey/lib64
>> -L/apps/local/spack/software/gcc-7.5.0/cuda-10.1.243-v4ymjqcrr7f72qfiuzsstuy5jiajbuey/lib64
>> -L/apps/local/spack/software/gcc-7.5.0/cuda-10.1.243-v4ymjqcrr7f72qfiuzsstuy5jiajbuey/lib64/stubs
>> -lcudart -lcufft -lcublas -lcusparse -lcusolver -lcurand -lcuda
>> You can see the `stubs` directory is not in rpath. We took a lot of
>> effort to achieve that. You need to double check the reason.
>> --Junchao Zhang
>> On Mon, Jan 31, 2022 at 9:40 AM Fande Kong <fdkong.jd at gmail.com> wrote:
>>> OK,
>>> Finally we resolved the issue. The issue was that there were two
>>> libcuda libs on a GPU compute node: /usr/lib64/libcuda
>>> and /apps/local/spack/software/gcc-7.5.0/cuda-10.1.243-v4ymjqcrr7f72qfiuzsstuy5jiajbuey/lib64/stubs/libcuda.
>>> But on a login node there is one libcuda lib:
>>> We can not see /usr/lib64/libcuda from a login node where I was compiling
>>> the code.
>>> Before the Junchao's commit, we did not have "-Wl,-rpath" to force
>>> PETSc take
>>> A code compiled on a login node could correctly pick up the cuda lib
>>> from /usr/lib64/libcuda at runtime. When with "-Wl,-rpath", the code
>>> always takes the cuda lib from
>>> /apps/local/spack/software/gcc-7.5.0/cuda-10.1.243-v4ymjqcrr7f72qfiuzsstuy5jiajbuey/lib64/stubs/libcuda,
>>> wihch was a bad lib.
>>> Right now, I just compiled code on a compute node instead of a login
>>> node, PETSc was able to pick up the correct lib from /usr/lib64/libcuda,
>>> and everything ran fine.
>>> I am not sure whether or not it is a good idea to search for "stubs"
>>> since the system might have the correct ones in other places. Should not I
>>> do a batch compiling?
>>> Thanks,
>>> Fande
>>> On Wed, Jan 26, 2022 at 1:49 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>> Yes, please see the attached file.
>>>> Fande
>>>> On Wed, Jan 26, 2022 at 11:49 AM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> Do you have the configure.log with main?
>>>>> --Junchao Zhang
>>>>> On Wed, Jan 26, 2022 at 12:26 PM Fande Kong <fdkong.jd at gmail.com>
>>>>> wrote:
>>>>>> I am on the petsc-main
>>>>>> commit 1390d3a27d88add7d79c9b38bf1a895ae5e67af6
>>>>>> Merge: 96c919c d5f3255
>>>>>> Author: Satish Balay <balay at mcs.anl.gov>
>>>>>> Date: Wed Jan 26 10:28:32 2022 -0600
>>>>>> Merge remote-tracking branch 'origin/release'
>>>>>> It is still broken.
>>>>>> Thanks,
>>>>>> Fande
>>>>>> On Wed, Jan 26, 2022 at 7:40 AM Junchao Zhang <
>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>> The good uses the compiler's default library/header path. The bad
>>>>>>> searches from cuda toolkit path and uses rpath linking.
>>>>>>> Though the paths look the same on the login node, they could have
>>>>>>> different behavior on a compute node depending on its environment.
>>>>>>> I think we fixed the issue in cuda.py (i.e., first try the
>>>>>>> compiler's default, then toolkit). That's why I wanted Fande to use
>>>>>>> petsc/main.
>>>>>>> --Junchao Zhang
>>>>>>> On Tue, Jan 25, 2022 at 11:59 PM Barry Smith <bsmith at petsc.dev>
>>>>>>> wrote:
>>>>>>>> bad has extra
>>>>>>>> -lcuda
>>>>>>>> good does not.
>>>>>>>> Try removing the stubs directory and -lcuda from the bad
>>>>>>>> $PETSC_ARCH/lib/petsc/conf/variables and likely the bad will start working.
>>>>>>>> Barry
>>>>>>>> I never liked the stubs stuff.
>>>>>>>> On Jan 25, 2022, at 11:29 PM, Fande Kong <fdkong.jd at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Hi Junchao,
>>>>>>>> I attached a "bad" configure log and a "good" configure log.
>>>>>>>> The "bad" one was on produced
>>>>>>>> at 246ba74192519a5f34fb6e227d1c64364e19ce2c
>>>>>>>> and the "good" one at 384645a00975869a1aacbd3169de62ba40cad683
>>>>>>>> This good hash is the last good hash that is just the right before
>>>>>>>> the bad one.
>>>>>>>> I think you could do a comparison between these two logs, and
>>>>>>>> check what the differences were.
>>>>>>>> Thanks,
>>>>>>>> Fande
>>>>>>>> On Tue, Jan 25, 2022 at 8:21 PM Junchao Zhang <
>>>>>>>>> Fande, could you send the configure.log that works (i.e., before
>>>>>>>>> this offending commit)?
>>>>>>>>> --Junchao Zhang
>>>>>>>>> On Tue, Jan 25, 2022 at 8:21 PM Fande Kong <fdkong.jd at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Not sure if this is helpful. I did "git bisect", and here was the
>>>>>>>>>> result:
>>>>>>>>>> [kongf at sawtooth2 petsc]$ git bisect bad
>>>>>>>>>> 246ba74192519a5f34fb6e227d1c64364e19ce2c is the first bad commit
>>>>>>>>>> commit 246ba74192519a5f34fb6e227d1c64364e19ce2c
>>>>>>>>>> Author: Junchao Zhang <jczhang at mcs.anl.gov>
>>>>>>>>>> Date: Wed Oct 13 05:32:43 2021 +0000
>>>>>>>>>> Config: fix CUDA library and header dirs
>>>>>>>>>> :040000 040000 187c86055adb80f53c1d0565a8888704fec43a96
>>>>>>>>>> ea1efd7f594fd5e8df54170bc1bc7b00f35e4d5f M config
>>>>>>>>>> Started from this commit, and GPU did not work for me on our HPC
>>>>>>>>>> Thanks,
>>>>>>>>>> Fande
>>>>>>>>>> On Tue, Jan 25, 2022 at 7:18 PM Fande Kong <fdkong.jd at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> On Tue, Jan 25, 2022 at 9:04 AM Jacob Faibussowitsch <
>>>>>>>>>>> jacob.fai at gmail.com> wrote:
>>>>>>>>>>>> Configure should not have an impact here I think. The reason I
>>>>>>>>>>>> had you run `cudaGetDeviceCount()` is because this is the CUDA call (and in
>>>>>>>>>>>> fact the only CUDA call) in the initialization sequence that returns the
>>>>>>>>>>>> error code. There should be no prior CUDA calls. Maybe this is a problem
>>>>>>>>>>>> with oversubscribing GPU’s? In the runs that crash, how many ranks are
>>>>>>>>>>>> using any given GPU at once? Maybe MPS is required.
>>>>>>>>>>> I used one MPI rank.
>>>>>>>>>>> Fande
>>>>>>>>>>>> Best regards,
>>>>>>>>>>>> (Jacob Fai - booss - oh - vitch)
>>>>>>>>>>>> On Jan 21, 2022, at 12:01, Fande Kong <fdkong.jd at gmail.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>> Thanks Jacob,
>>>>>>>>>>>> On Thu, Jan 20, 2022 at 6:25 PM Jacob Faibussowitsch <
>>>>>>>>>>>>> Segfault is caused by the following check at
>>>>>>>>>>>>> src/sys/objects/device/impls/cupm/cupmdevice.cxx:349 being a
>>>>>>>>>>>>> PetscUnlikelyDebug() rather than just PetscUnlikely():
>>>>>>>>>>>>> if (PetscUnlikelyDebug(_defaultDevice < 0)) { //
>>>>>>>>>>>>> _defaultDevice is in fact < 0 here and uncaught
>>>>>>>>>>>>> To clarify:
>>>>>>>>>>>>> “lazy” initialization is not that lazy after all, it still
>>>>>>>>>>>>> does some 50% of the initialization that “eager” initialization does. It
>>>>>>>>>>>>> stops short initializing the CUDA runtime, checking CUDA aware MPI,
>>>>>>>>>>>>> gathering device data, and initializing cublas and friends. Lazy also
>>>>>>>>>>>>> importantly swallows any errors that crop up during initialization, storing
>>>>>>>>>>>>> the resulting error code for later (specifically _defaultDevice =
>>>>>>>>>>>>> -init_error_value;).
>>>>>>>>>>>>> So whether you initialize lazily or eagerly makes no
>>>>>>>>>>>>> difference here, as _defaultDevice will always contain -35.
>>>>>>>>>>>>> The bigger question is why cudaGetDeviceCount() is returning
>>>>>>>>>>>>> cudaErrorInsufficientDriver. Can you compile and run
>>>>>>>>>>>>> #include <cuda_runtime.h>
>>>>>>>>>>>>> int main()
>>>>>>>>>>>>> int ndev;
>>>>>>>>>>>>> return cudaGetDeviceCount(&ndev):
>>>>>>>>>>>>> Then show the value of "echo $?”?
>>>>>>>>>>>> Modify your code a little to get more information.
>>>>>>>>>>>> #include <cstdio>
>>>>>>>>>>>> int main()
>>>>>>>>>>>> int ndev;
>>>>>>>>>>>> int error = cudaGetDeviceCount(&ndev);
>>>>>>>>>>>> printf("ndev %d \n", ndev);
>>>>>>>>>>>> printf("error %d \n", error);
>>>>>>>>>>>> return 0;
>>>>>>>>>>>> Results:
>>>>>>>>>>>> $ ./a.out
>>>>>>>>>>>> ndev 4
>>>>>>>>>>>> error 0
>>>>>>>>>>>> I have not read the PETSc cuda initialization code yet. If I
>>>>>>>>>>>> need to guess at what was happening. I will naively think that PETSc did
>>>>>>>>>>>> not get correct GPU information in the configuration because the compiler
>>>>>>>>>>>> node does not have GPUs, and there was no way to get any GPU device
>>>>>>>>>>>> information.
>>>>>>>>>>>> During the runtime on GPU nodes, PETSc might have incorrect
>>>>>>>>>>>> information grabbed during configuration and had this kind of false error
>>>>>>>>>>>> message.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Fande
>>>>>>>>>>>>> Best regards,
>>>>>>>>>>>>> On Jan 20, 2022, at 17:47, Matthew Knepley <knepley at gmail.com>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> On Thu, Jan 20, 2022 at 6:44 PM Fande Kong <
>>>>>>>>>>>>>> Thanks, Jed
>>>>>>>>>>>>>> On Thu, Jan 20, 2022 at 4:34 PM Jed Brown <jed at jedbrown.org>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>> You can't create CUDA or Kokkos Vecs if you're running on a
>>>>>>>>>>>>>>> node without a GPU.
>>>>>>>>>>>>>> I am running the code on compute nodes that do have GPUs.
>>>>>>>>>>>>> If you are actually running on GPUs, why would you need lazy
>>>>>>>>>>>>> initialization? It would not break with GPUs present.
>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>> With PETSc-3.16.1, I got good speedup by running GAMG on
>>>>>>>>>>>>>> GPUs. That might be a bug of PETSc-main.
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Fande
>>>>>>>>>>>>>> KSPSetUp 13 1.0 6.4400e-01 1.0 2.02e+09 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 5 0 0 0 0 5 0 0 0 3140 64630 15
>>>>>>>>>>>>>> 1.05e+02 5 3.49e+01 100
>>>>>>>>>>>>>> KSPSolve 1 1.0 1.0109e+00 1.0 3.49e+10 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 87 0 0 0 0 87 0 0 0 34522 69556 4
>>>>>>>>>>>>>> 4.35e-03 1 2.38e-03 100
>>>>>>>>>>>>>> KSPGMRESOrthog 142 1.0 1.2674e-01 1.0 1.06e+10 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 27 0 0 0 0 27 0 0 0 83755 87801 0
>>>>>>>>>>>>>> 0.00e+00 0 0.00e+00 100
>>>>>>>>>>>>>> SNESSolve 1 1.0 4.4402e+01 1.0 4.00e+10 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 21100 0 0 0 21100 0 0 0 901 51365 57
>>>>>>>>>>>>>> 1.10e+03 52 8.78e+02 100
>>>>>>>>>>>>>> SNESSetUp 1 1.0 3.9101e-05 1.0 0.00e+00 0.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 0
>>>>>>>>>>>>>> 0.00e+00 0 0.00e+00 0
>>>>>>>>>>>>>> SNESFunctionEval 2 1.0 1.7097e+01 1.0 1.60e+07 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 8 0 0 0 0 8 0 0 0 0 1 0 0
>>>>>>>>>>>>>> 0.00e+00 6 1.92e+02 0
>>>>>>>>>>>>>> SNESJacobianEval 1 1.0 1.6213e+01 1.0 2.80e+07 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 8 0 0 0 0 8 0 0 0 0 2 0 0
>>>>>>>>>>>>>> 0.00e+00 1 3.20e+01 0
>>>>>>>>>>>>>> SNESLineSearch 1 1.0 8.5582e+00 1.0 1.24e+08 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 4 0 0 0 0 4 0 0 0 0 14 64153 1
>>>>>>>>>>>>>> 3.20e+01 3 9.61e+01 94
>>>>>>>>>>>>>> PCGAMGGraph_AGG 5 1.0 3.0509e+00 1.0 8.19e+07 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 27 0 5
>>>>>>>>>>>>>> 3.49e+01 9 7.43e+01 0
>>>>>>>>>>>>>> PCGAMGCoarse_AGG 5 1.0 3.8711e+00 1.0 0.00e+00 0.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0 0 0
>>>>>>>>>>>>>> PCGAMGProl_AGG 5 1.0 7.0748e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>> PCGAMGPOpt_AGG 5 1.0 1.2904e+00 1.0 2.14e+09 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 1 5 0 0 0 1 5 0 0 0 1661 29807 26
>>>>>>>>>>>>>> 7.15e+02 20 2.90e+02 99
>>>>>>>>>>>>>> GAMG: createProl 5 1.0 8.9489e+00 1.0 2.22e+09 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 4 6 0 0 0 4 6 0 0 0 249 29666 31
>>>>>>>>>>>>>> 7.50e+02 29 3.64e+02 96
>>>>>>>>>>>>>> Graph 10 1.0 3.0478e+00 1.0 8.19e+07 1.0
>>>>>>>>>>>>>> MIS/Agg 5 1.0 4.1290e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>> SA: col data 5 1.0 1.9127e-02 1.0 0.00e+00 0.0
>>>>>>>>>>>>>> SA: frmProl0 5 1.0 6.2662e-01 1.0 0.00e+00 0.0
>>>>>>>>>>>>>> SA: smooth 5 1.0 4.9595e-01 1.0 1.21e+08 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 244 2709 15
>>>>>>>>>>>>>> 1.97e+02 15 2.55e+02 90
>>>>>>>>>>>>>> GAMG: partLevel 5 1.0 4.7330e-01 1.0 6.98e+08 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 2 0 0 0 0 2 0 0 0 1475 4120 5
>>>>>>>>>>>>>> 1.78e+02 10 2.55e+02 100
>>>>>>>>>>>>>> PCGAMG Squ l00 1 1.0 2.6027e+00 1.0 0.00e+00 0.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0 0 0
>>>>>>>>>>>>>> PCGAMG Gal l00 1 1.0 3.8406e-01 1.0 5.48e+08 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 1426 4270 1
>>>>>>>>>>>>>> 1.48e+02 2 2.11e+02 100
>>>>>>>>>>>>>> PCGAMG Opt l00 1 1.0 2.4932e-01 1.0 7.20e+07 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 289 2653 1
>>>>>>>>>>>>>> 6.41e+01 1 1.13e+02 100
>>>>>>>>>>>>>> PCGAMG Gal l01 1 1.0 6.6279e-02 1.0 1.09e+08 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1645 3851 1
>>>>>>>>>>>>>> 2.40e+01 2 3.64e+01 100
>>>>>>>>>>>>>> PCGAMG Opt l01 1 1.0 2.9544e-02 1.0 7.15e+06 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 242 1671 1
>>>>>>>>>>>>>> 4.84e+00 1 1.23e+01 100
>>>>>>>>>>>>>> PCGAMG Gal l02 1 1.0 1.8874e-02 1.0 3.72e+07 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1974 3636 1
>>>>>>>>>>>>>> 5.04e+00 2 6.58e+00 100
>>>>>>>>>>>>>> PCGAMG Opt l02 1 1.0 7.4353e-03 1.0 2.40e+06 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 323 1457 1
>>>>>>>>>>>>>> 7.71e-01 1 2.30e+00 100
>>>>>>>>>>>>>> PCGAMG Gal l03 1 1.0 2.8479e-03 1.0 4.10e+06 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1440 2266 1
>>>>>>>>>>>>>> 4.44e-01 2 5.51e-01 100
>>>>>>>>>>>>>> PCGAMG Opt l03 1 1.0 8.2684e-04 1.0 2.80e+05 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 339 1667 1
>>>>>>>>>>>>>> 6.72e-02 1 2.03e-01 100
>>>>>>>>>>>>>> PCGAMG Gal l04 1 1.0 1.2238e-03 1.0 2.09e+05 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 170 244 1
>>>>>>>>>>>>>> 2.05e-02 2 2.53e-02 100
>>>>>>>>>>>>>> PCGAMG Opt l04 1 1.0 4.1008e-04 1.0 1.77e+04 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 43 165 1
>>>>>>>>>>>>>> 4.49e-03 1 1.19e-02 100
>>>>>>>>>>>>>> PCSetUp 2 1.0 9.9632e+00 1.0 4.95e+09 1.0
>>>>>>>>>>>>>> 0.0e+00 0.0e+00 0.0e+00 5 12 0 0 0 5 12 0 0 0 496 17826 55
>>>>>>>>>>>>>> 1.03e+03 45 6.54e+02 98
>>>>>>>>>>>>>> PCSetUpOnBlocks 44 1.0 9.9087e-04 1.0 2.88e+03 1.0
>>>>>>>>>>>>>>> The point of lazy initialization is to make it possible to
>>>>>>>>>>>>>>> run a solve that doesn't use a GPU in PETSC_ARCH that supports GPUs,
>>>>>>>>>>>>>>> regardless of whether a GPU is actually present.
>>>>>>>>>>>>>>> Fande Kong <fdkong.jd at gmail.com> writes:
>>>>>>>>>>>>>>> > I spoke too soon. It seems that we have trouble creating
>>>>>>>>>>>>>>> cuda/kokkos vecs
>>>>>>>>>>>>>>> > now. Got Segmentation fault.
>>>>>>>>>>>>>>> > Thanks,
>>>>>>>>>>>>>>> > Fande
>>>>>>>>>>>>>>> > Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>>>>>>>> > 0x00002aaab5558b11 in
>>>>>>>>>>>>>>> Petsc::CUPMDevice<(Petsc::CUPMDeviceType)0>::CUPMDeviceInternal::initialize
>>>>>>>>>>>>>>> > (this=0x1) at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:54
>>>>>>>>>>>>>>> > 54 PetscErrorCode
>>>>>>>>>>>>>>> CUPMDevice<T>::CUPMDeviceInternal::initialize() noexcept
>>>>>>>>>>>>>>> > Missing separate debuginfos, use: debuginfo-install
>>>>>>>>>>>>>>> > bzip2-libs-1.0.6-13.el7.x86_64
>>>>>>>>>>>>>>> elfutils-libelf-0.176-5.el7.x86_64
>>>>>>>>>>>>>>> > elfutils-libs-0.176-5.el7.x86_64
>>>>>>>>>>>>>>> glibc-2.17-325.el7_9.x86_64
>>>>>>>>>>>>>>> > libX11-1.6.7-4.el7_9.x86_64 libXau-1.0.8-2.1.el7.x86_64
>>>>>>>>>>>>>>> > libattr-2.4.46-13.el7.x86_64 libcap-2.22-11.el7.x86_64
>>>>>>>>>>>>>>> > libibmad-5.4.0.MLNX20190423.1d917ae-0.1.49224.x86_64
>>>>>>>>>>>>>>> > libibumad-43.1.1.MLNX20200211.078947f-0.1.49224.x86_64
>>>>>>>>>>>>>>> > libibverbs-41mlnx1-OFED.4.9.0.0.7.49224.x86_64
>>>>>>>>>>>>>>> > libmlx4-41mlnx1-OFED.4.7.3.0.3.49224.x86_64
>>>>>>>>>>>>>>> > libmlx5-41mlnx1-OFED.4.9.0.1.2.49224.x86_64
>>>>>>>>>>>>>>> libnl3-3.2.28-4.el7.x86_64
>>>>>>>>>>>>>>> > librdmacm-41mlnx1-OFED.4.7.3.0.6.49224.x86_64
>>>>>>>>>>>>>>> > librxe-41mlnx1-OFED.4.4.2.4.6.49224.x86_64
>>>>>>>>>>>>>>> libxcb-1.13-1.el7.x86_64
>>>>>>>>>>>>>>> > libxml2-2.9.1-6.el7_9.6.x86_64
>>>>>>>>>>>>>>> numactl-libs-2.0.12-5.el7.x86_64
>>>>>>>>>>>>>>> > systemd-libs-219-78.el7_9.3.x86_64
>>>>>>>>>>>>>>> xz-libs-5.2.2-1.el7.x86_64
>>>>>>>>>>>>>>> > zlib-1.2.7-19.el7_9.x86_64
>>>>>>>>>>>>>>> > (gdb) bt
>>>>>>>>>>>>>>> > #0 0x00002aaab5558b11 in
>>>>>>>>>>>>>>> > (this=0x1) at
>>>>>>>>>>>>>>> > #1 0x00002aaab5558db7 in
>>>>>>>>>>>>>>> > Petsc::CUPMDevice<(Petsc::CUPMDeviceType)0>::getDevice
>>>>>>>>>>>>>>> > (this=this at entry=0x2aaab7f37b70
>>>>>>>>>>>>>>> > <CUDADevice>, device=0x115da00, id=-35, id at entry=-1) at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:344
>>>>>>>>>>>>>>> > #2 0x00002aaab55577de in PetscDeviceCreate
>>>>>>>>>>>>>>> (type=type at entry=PETSC_DEVICE_CUDA,
>>>>>>>>>>>>>>> > devid=devid at entry=-1, device=device at entry=0x2aaab7f37b48
>>>>>>>>>>>>>>> > <defaultDevices+8>) at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:107
>>>>>>>>>>>>>>> > #3 0x00002aaab5557b3a in
>>>>>>>>>>>>>>> PetscDeviceInitializeDefaultDevice_Internal
>>>>>>>>>>>>>>> defaultDeviceId=defaultDeviceId at entry=-1)
>>>>>>>>>>>>>>> > at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:273
>>>>>>>>>>>>>>> > #4 0x00002aaab5557bf6 in PetscDeviceInitialize
>>>>>>>>>>>>>>> > (type=type at entry=PETSC_DEVICE_CUDA)
>>>>>>>>>>>>>>> > at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:234
>>>>>>>>>>>>>>> > #5 0x00002aaab5661fcd in VecCreate_SeqCUDA (V=0x115d150)
>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/impls/seq/seqcuda/veccuda.c:244
>>>>>>>>>>>>>>> > #6 0x00002aaab5649b40 in VecSetType (vec=vec at entry
>>>>>>>>>>>>>>> =0x115d150,
>>>>>>>>>>>>>>> > method=method at entry=0x2aaab70b45b8 "seqcuda") at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vecreg.c:93
>>>>>>>>>>>>>>> > #7 0x00002aaab579c33f in VecCreate_CUDA (v=0x115d150) at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/impls/mpi/mpicuda/
>>>>>>>>>>>>>>> > mpicuda.cu:214
>>>>>>>>>>>>>>> > #8 0x00002aaab5649b40 in VecSetType (vec=vec at entry
>>>>>>>>>>>>>>> =0x115d150,
>>>>>>>>>>>>>>> > method=method at entry=0x7fffffff9260 "cuda") at
>>>>>>>>>>>>>>> > #9 0x00002aaab5648bf1 in VecSetTypeFromOptions_Private
>>>>>>>>>>>>>>> (vec=0x115d150,
>>>>>>>>>>>>>>> > PetscOptionsObject=0x7fffffff9210) at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vector.c:1263
>>>>>>>>>>>>>>> > #10 VecSetFromOptions (vec=0x115d150) at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vector.c:1297
>>>>>>>>>>>>>>> > #11 0x00002aaab02ef227 in
>>>>>>>>>>>>>>> libMesh::PetscVector<double>::init
>>>>>>>>>>>>>>> > (this=0x11cd1a0, n=441, n_local=441, fast=false,
>>>>>>>>>>>>>>> ptype=libMesh::PARALLEL)
>>>>>>>>>>>>>>> > at
>>>>>>>>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/scripts/../libmesh/installed/include/libmesh/petsc_vector.h:693
>>>>>>>>>>>>>>> > On Thu, Jan 20, 2022 at 1:09 PM Fande Kong <
>>>>>>>>>>>>>>> >> Thanks, Jed,
>>>>>>>>>>>>>>> >> This worked!
>>>>>>>>>>>>>>> >> Fande
>>>>>>>>>>>>>>> >> On Wed, Jan 19, 2022 at 11:03 PM Jed Brown <
>>>>>>>>>>>>>>> >>> > On Wed, Jan 19, 2022 at 11:39 AM Jacob Faibussowitsch <
>>>>>>>>>>>>>>> >>> > wrote:
>>>>>>>>>>>>>>> >>> >> Are you running on login nodes or compute nodes (I
>>>>>>>>>>>>>>> can’t seem to tell
>>>>>>>>>>>>>>> >>> from
>>>>>>>>>>>>>>> >>> >> the configure.log)?
>>>>>>>>>>>>>>> >>> > I was compiling codes on login nodes, and running
>>>>>>>>>>>>>>> codes on compute
>>>>>>>>>>>>>>> >>> nodes.
>>>>>>>>>>>>>>> >>> > Login nodes do not have GPUs, but compute nodes do
>>>>>>>>>>>>>>> have GPUs.
>>>>>>>>>>>>>>> >>> > Just to be clear, the same thing (code, machine) with
>>>>>>>>>>>>>>> PETSc-3.16.1
>>>>>>>>>>>>>>> >>> worked
>>>>>>>>>>>>>>> >>> > perfectly. I have this trouble with PETSc-main.
>>>>>>>>>>>>>>> >>> I assume you can
>>>>>>>>>>>>>>> >>> export PETSC_OPTIONS='-device_enable lazy'
>>>>>>>>>>>>>>> >>> and it'll work.
>>>>>>>>>>>>>>> >>> I think this should be the default. The main complaint
>>>>>>>>>>>>>>> is that timing the
>>>>>>>>>>>>>>> >>> first GPU-using event isn't accurate if it includes
>>>>>>>>>>>>>>> initialization, but I
>>>>>>>>>>>>>>> >>> think this is mostly hypothetical because you can't
>>>>>>>>>>>>>>> trust any timing that
>>>>>>>>>>>>>>> >>> doesn't preload in some form and the first GPU-using
>>>>>>>>>>>>>>> event will almost
>>>>>>>>>>>>>>> >>> always be something uninteresting so I think it will
>>>>>>>>>>>>>>> rarely lead to
>>>>>>>>>>>>>>> >>> confusion. Meanwhile, eager initialization is viscerally
>>>>>>>>>>>>>>> disruptive for
>>>>>>>>>>>>>>> >>> lots of people.
>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>>>> <configure_bad.log><configure_good.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220131/c2cb86ea/attachment-0001.html>
