[petsc-users] [EXTERNAL] Re: Question about PCFieldSplit
Jorti, Zakariae zjorti at lanl.gov
Mon Jan 31 09:48:34 CST 2022
Yes, exactly.
Sent: Monday, January 31, 2022 8:47:23 AM
To: Jorti, Zakariae
Cc: petsc-users at mcs.anl.gov; Tang, Xianzhu; Tang, Qi
Subject: Re: [EXTERNAL] Re: [petsc-users] Question about PCFieldSplit
The current behavior is that a single IS is returned for each stratum, so if you have 2 unknowns on vertices, it should still return a single IS including both of those unknowns per vertex. Am I understanding that that's working as expected but you need *two* ISs in that case?
Am Mo., 31. Jan. 2022 um 16:29 Uhr schrieb Jorti, Zakariae <zjorti at lanl.gov<mailto:zjorti at lanl.gov>>:
Hi Patrick,
Thanks for your recent updates on DMStag.
After getting the Finite Difference Coloring to work with our solver, I was testing that DMCreateFieldDecomposition routine that you added last week.
It seems to work fine when there is only one unknown per location (i.e. one unknown on vertices and/or one unknown on edges and/or one unknown on faces and/or one unknown on elements).
That being said, when there is more than one unknown in some location (let's say 2 unknowns on vertices for instance), I could not get the ISs for those two unknowns with that routine.
Should I still rely on PCFieldSplitSetDetectSaddlePoint in this case?
Many thanks once again.
Kind regards,
Zakariae
From: Patrick Sanan <patrick.sanan at gmail.com<mailto:patrick.sanan at gmail.com>>
Sent: Tuesday, January 25, 2022 5:36:17 AM
To: Matthew Knepley
Cc: Jorti, Zakariae; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>; Tang, Xianzhu; Dave May
Subject: [EXTERNAL] Re: [petsc-users] Question about PCFieldSplit
Here is an MR which intends to introduce some logic to support DMCreateFieldDecomposition(). It doesn't use the PetscSection approach, which might be preferable, but nonetheless is a necessary component so It'd like to get it in, even if it has room for further optimization. Hopefully this can be followed fairly soon with some more examples and tests using PCFieldSplit itself.
https://gitlab.com/petsc/petsc/-/merge_requests/4740
Am Mi., 23. Juni 2021 um 12:15 Uhr schrieb Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>:
On Wed, Jun 23, 2021 at 12:51 AM Patrick Sanan <patrick.sanan at gmail.com<mailto:patrick.sanan at gmail.com>> wrote:
Hi Zakariae -
The usual way to do this is to define an IS (index set) with the degrees of freedom of interest for the rows, and another one for the columns, and then use MatCreateSubmatrix [1] .
There's not a particularly convenient way to create an IS with the degrees of freedom corresponding to a particular "stratum" (i.e. elements, faces, edges, or vertices) of a DMStag, but fortunately I believe we have some code to do exactly this in a development branch.
I'll track it down and see if it can quickly be added to the main branch.
Note that an easy way to keep track of this would be to create a section with the different locations as fields. This Section could then
easily create the ISes, and could automatically interface with PCFIELDSPLIT.
     Matt
[1]: https://petsc.org/release/docs/manualpages/Mat/MatCreateSubMatrix.html
Am 22.06.2021 um 22:29 schrieb Jorti, Zakariae <zjorti at lanl.gov<mailto:zjorti at lanl.gov>>:
Hello,
I am working on DMStag and I have one dof on vertices (let us call it V), one dof on edges (let us call it E), one dof on faces ((let us call it F)) and one dof on cells (let us call it C).
I build a matrix on this DM, and I was wondering if there was a way to get blocks (or sub matrices) of this matrix corresponding to specific degrees of freedom, for example rows corresponding to V dofs and columns corresponding to E dofs.
I already asked this question before and the answer I got was I could call PCFieldSplitSetDetectSaddlePoint with the diagonal entries being of the matrix being zero or nonzero.
That worked well. Nonetheless, I am curious to know if there was another alternative that does not require creating a dummy matrix with appropriate diagonal entries and solving a dummy linear system with this matrix to define the splits.
Many thanks.
Best regards,
Zakariae
From: petsc-users <petsc-users-bounces at mcs.anl.gov<mailto:petsc-users-bounces at mcs.anl.gov>> on behalf of Tang, Qi <tangqi at msu.edu<mailto:tangqi at msu.edu>>
Sent: Sunday, April 18, 2021 11:51:59 PM
To: Patrick Sanan
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>; Tang, Xianzhu
Thanks a lot, Patrick. We appreciate your help.
Qi
On Apr 18, 2021, at 11:30 PM, Patrick Sanan <patrick.sanan at gmail.com<mailto:patrick.sanan at gmail.com>> wrote:
We have this functionality in a branch, which I'm working on cleaning up to get to master. It doesn't use PETScSection. Sorry about the delay!
You can only use PCFieldSplitSetDetectSaddlePoint when your diagonal entries being zero or non-zero defines the splits correctly.
Am 17.04.2021 um 21:09 schrieb Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>:
On Fri, Apr 16, 2021 at 8:39 PM Jorti, Zakariae via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I have a DMStag grid with one dof on each edge and face center.
I want to use a PCFieldSplit preconditioner on a Jacobian matrix that I assume is already split but I am not sure how to determine the fields.
In the DMStag examples (ex2.c and ex3.c), the function PCFieldSplitSetDetectSaddlePoint is used to determine those fields based on zero diagonal entries. In my case, I have a Jacobian matrix that does not have zero diagonal entries.
Can I use that PCFieldSplitSetDetectSaddlePoint in this case?
If not, how should I do?
Should I do like this example (https://www.mcs.anl.gov/petsc/petsc-master/src/ksp/ksp/tutorials/ex43.c.html<https://urldefense.com/v3/__https://www.mcs.anl.gov/petsc/petsc-master/src/ksp/ksp/tutorials/ex43.c.html__;!!HXCxUKc!jbBwV2h9luOW4dtBcNh6n_W1ULQnSVeXpxl0Ef1752s4Hlef-nC2JcnksFSO3Q$>):
const PetscInt Bfields[1] = {0},Efields[1] = {1};
KSPGetPC(ksp,&pc);
PCFieldSplitSetBlockSize(pc,2);
PCFieldSplitSetFields(pc,"B",1,Bfields,Bfields); PCFieldSplitSetFields(pc,"E",1,Efields,Efields);
where my B unknowns are defined on face centers and E unknowns are defined on edge centers?
That will not work.That interface only works for colocated fields that you get from DMDA.
Patrick, does DMSTAG use PetscSection? Then the field split would be automatically calculated. If not, does it maintain the
field division so that it could be given to PCFIELDSPLIT as ISes?
     Matt
One last thing, I do not know which field comes first. Is it the one defined for face dofs or edge dofs.
Thank you.
Best regards,
Zakariae
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!HXCxUKc!jbBwV2h9luOW4dtBcNh6n_W1ULQnSVeXpxl0Ef1752s4Hlef-nC2JcmGgSwfag$>
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220131/2202bd4a/attachment-0001.html>
