[petsc-users] Cannot eagerly initialize cuda, as doing so results in cuda error 35 (cudaErrorInsufficientDriver) : CUDA driver version is insufficient for CUDA runtime version
Junchao Zhang
junchao.zhang at gmail.com
Tue Jan 25 23:41:37 CST 2022
Fande, do you have a configure.log with current petsc/main?
--Junchao Zhang
On Tue, Jan 25, 2022 at 10:30 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi Junchao,
> I attached a "bad" configure log and a "good" configure log.
> The "bad" one was on produced at 246ba74192519a5f34fb6e227d1c64364e19ce2c
> and the "good" one at 384645a00975869a1aacbd3169de62ba40cad683
> This good hash is the last good hash that is just the right before the bad
> one.
> I think you could do a comparison between these two logs, and check what
> the differences were.
> Thanks,
> Fande
> On Tue, Jan 25, 2022 at 8:21 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Fande, could you send the configure.log that works (i.e., before this
>> offending commit)?
>> --Junchao Zhang
>> On Tue, Jan 25, 2022 at 8:21 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>> Not sure if this is helpful. I did "git bisect", and here was the result:
>>> [kongf at sawtooth2 petsc]$ git bisect bad
>>> 246ba74192519a5f34fb6e227d1c64364e19ce2c is the first bad commit
>>> commit 246ba74192519a5f34fb6e227d1c64364e19ce2c
>>> Author: Junchao Zhang <jczhang at mcs.anl.gov>
>>> Date: Wed Oct 13 05:32:43 2021 +0000
>>> Config: fix CUDA library and header dirs
>>> :040000 040000 187c86055adb80f53c1d0565a8888704fec43a96
>>> ea1efd7f594fd5e8df54170bc1bc7b00f35e4d5f M config
>>> Started from this commit, and GPU did not work for me on our HPC
>>> Thanks,
>>> Fande
>>> On Tue, Jan 25, 2022 at 7:18 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>>> On Tue, Jan 25, 2022 at 9:04 AM Jacob Faibussowitsch <
>>>> jacob.fai at gmail.com> wrote:
>>>>> Configure should not have an impact here I think. The reason I had you
>>>>> run `cudaGetDeviceCount()` is because this is the CUDA call (and in fact
>>>>> the only CUDA call) in the initialization sequence that returns the error
>>>>> code. There should be no prior CUDA calls. Maybe this is a problem with
>>>>> oversubscribing GPU’s? In the runs that crash, how many ranks are using any
>>>>> given GPU at once? Maybe MPS is required.
>>>> I used one MPI rank.
>>>> Fande
>>>>> Best regards,
>>>>> (Jacob Fai - booss - oh - vitch)
>>>>> On Jan 21, 2022, at 12:01, Fande Kong <fdkong.jd at gmail.com> wrote:
>>>>> Thanks Jacob,
>>>>> On Thu, Jan 20, 2022 at 6:25 PM Jacob Faibussowitsch <
>>>>>> Segfault is caused by the following check at
>>>>>> src/sys/objects/device/impls/cupm/cupmdevice.cxx:349 being a
>>>>>> PetscUnlikelyDebug() rather than just PetscUnlikely():
>>>>>> if (PetscUnlikelyDebug(_defaultDevice < 0)) { // _defaultDevice is in
>>>>>> fact < 0 here and uncaught
>>>>>> To clarify:
>>>>>> “lazy” initialization is not that lazy after all, it still does some
>>>>>> 50% of the initialization that “eager” initialization does. It stops short
>>>>>> initializing the CUDA runtime, checking CUDA aware MPI, gathering device
>>>>>> data, and initializing cublas and friends. Lazy also importantly swallows
>>>>>> any errors that crop up during initialization, storing the resulting error
>>>>>> code for later (specifically _defaultDevice = -init_error_value;).
>>>>>> So whether you initialize lazily or eagerly makes no difference here,
>>>>>> as _defaultDevice will always contain -35.
>>>>>> The bigger question is why cudaGetDeviceCount() is returning
>>>>>> cudaErrorInsufficientDriver. Can you compile and run
>>>>>> #include <cuda_runtime.h>
>>>>>> int main()
>>>>>> int ndev;
>>>>>> return cudaGetDeviceCount(&ndev):
>>>>>> Then show the value of "echo $?”?
>>>>> Modify your code a little to get more information.
>>>>> #include <cstdio>
>>>>> int main()
>>>>> int ndev;
>>>>> int error = cudaGetDeviceCount(&ndev);
>>>>> printf("ndev %d \n", ndev);
>>>>> printf("error %d \n", error);
>>>>> return 0;
>>>>> Results:
>>>>> $ ./a.out
>>>>> ndev 4
>>>>> error 0
>>>>> I have not read the PETSc cuda initialization code yet. If I need to
>>>>> guess at what was happening. I will naively think that PETSc did not get
>>>>> correct GPU information in the configuration because the compiler node does
>>>>> not have GPUs, and there was no way to get any GPU device information.
>>>>> During the runtime on GPU nodes, PETSc might have incorrect
>>>>> information grabbed during configuration and had this kind of false error
>>>>> message.
>>>>> Thanks,
>>>>> Fande
>>>>>> Best regards,
>>>>>> On Jan 20, 2022, at 17:47, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>> On Thu, Jan 20, 2022 at 6:44 PM Fande Kong <fdkong.jd at gmail.com>
>>>>>> wrote:
>>>>>>> Thanks, Jed
>>>>>>> On Thu, Jan 20, 2022 at 4:34 PM Jed Brown <jed at jedbrown.org> wrote:
>>>>>>>> You can't create CUDA or Kokkos Vecs if you're running on a node
>>>>>>>> without a GPU.
>>>>>>> I am running the code on compute nodes that do have GPUs.
>>>>>> If you are actually running on GPUs, why would you need lazy
>>>>>> initialization? It would not break with GPUs present.
>>>>>> Matt
>>>>>>> With PETSc-3.16.1, I got good speedup by running GAMG on GPUs.
>>>>>>> That might be a bug of PETSc-main.
>>>>>>> Thanks,
>>>>>>> Fande
>>>>>>> KSPSetUp 13 1.0 6.4400e-01 1.0 2.02e+09 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 5 0 0 0 0 5 0 0 0 3140 64630 15
>>>>>>> 1.05e+02 5 3.49e+01 100
>>>>>>> KSPSolve 1 1.0 1.0109e+00 1.0 3.49e+10 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 87 0 0 0 0 87 0 0 0 34522 69556 4
>>>>>>> 4.35e-03 1 2.38e-03 100
>>>>>>> KSPGMRESOrthog 142 1.0 1.2674e-01 1.0 1.06e+10 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 27 0 0 0 0 27 0 0 0 83755 87801 0
>>>>>>> 0.00e+00 0 0.00e+00 100
>>>>>>> SNESSolve 1 1.0 4.4402e+01 1.0 4.00e+10 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 21100 0 0 0 21100 0 0 0 901 51365 57
>>>>>>> 1.10e+03 52 8.78e+02 100
>>>>>>> SNESSetUp 1 1.0 3.9101e-05 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 0
>>>>>>> 0.00e+00 0 0.00e+00 0
>>>>>>> SNESFunctionEval 2 1.0 1.7097e+01 1.0 1.60e+07 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 8 0 0 0 0 8 0 0 0 0 1 0 0
>>>>>>> 0.00e+00 6 1.92e+02 0
>>>>>>> SNESJacobianEval 1 1.0 1.6213e+01 1.0 2.80e+07 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 8 0 0 0 0 8 0 0 0 0 2 0 0
>>>>>>> 0.00e+00 1 3.20e+01 0
>>>>>>> SNESLineSearch 1 1.0 8.5582e+00 1.0 1.24e+08 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 4 0 0 0 0 4 0 0 0 0 14 64153 1
>>>>>>> 3.20e+01 3 9.61e+01 94
>>>>>>> PCGAMGGraph_AGG 5 1.0 3.0509e+00 1.0 8.19e+07 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 27 0 5
>>>>>>> 3.49e+01 9 7.43e+01 0
>>>>>>> PCGAMGCoarse_AGG 5 1.0 3.8711e+00 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0 0 0
>>>>>>> PCGAMGProl_AGG 5 1.0 7.0748e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> PCGAMGPOpt_AGG 5 1.0 1.2904e+00 1.0 2.14e+09 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 1 5 0 0 0 1 5 0 0 0 1661 29807 26
>>>>>>> 7.15e+02 20 2.90e+02 99
>>>>>>> GAMG: createProl 5 1.0 8.9489e+00 1.0 2.22e+09 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 4 6 0 0 0 4 6 0 0 0 249 29666 31
>>>>>>> 7.50e+02 29 3.64e+02 96
>>>>>>> Graph 10 1.0 3.0478e+00 1.0 8.19e+07 1.0 0.0e+00
>>>>>>> MIS/Agg 5 1.0 4.1290e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> SA: col data 5 1.0 1.9127e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> SA: frmProl0 5 1.0 6.2662e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> SA: smooth 5 1.0 4.9595e-01 1.0 1.21e+08 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 244 2709 15
>>>>>>> 1.97e+02 15 2.55e+02 90
>>>>>>> GAMG: partLevel 5 1.0 4.7330e-01 1.0 6.98e+08 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 2 0 0 0 0 2 0 0 0 1475 4120 5
>>>>>>> 1.78e+02 10 2.55e+02 100
>>>>>>> PCGAMG Squ l00 1 1.0 2.6027e+00 1.0 0.00e+00 0.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0 0 0
>>>>>>> PCGAMG Gal l00 1 1.0 3.8406e-01 1.0 5.48e+08 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 1426 4270 1
>>>>>>> 1.48e+02 2 2.11e+02 100
>>>>>>> PCGAMG Opt l00 1 1.0 2.4932e-01 1.0 7.20e+07 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 289 2653 1
>>>>>>> 6.41e+01 1 1.13e+02 100
>>>>>>> PCGAMG Gal l01 1 1.0 6.6279e-02 1.0 1.09e+08 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1645 3851 1
>>>>>>> 2.40e+01 2 3.64e+01 100
>>>>>>> PCGAMG Opt l01 1 1.0 2.9544e-02 1.0 7.15e+06 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 242 1671 1
>>>>>>> 4.84e+00 1 1.23e+01 100
>>>>>>> PCGAMG Gal l02 1 1.0 1.8874e-02 1.0 3.72e+07 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1974 3636 1
>>>>>>> 5.04e+00 2 6.58e+00 100
>>>>>>> PCGAMG Opt l02 1 1.0 7.4353e-03 1.0 2.40e+06 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 323 1457 1
>>>>>>> 7.71e-01 1 2.30e+00 100
>>>>>>> PCGAMG Gal l03 1 1.0 2.8479e-03 1.0 4.10e+06 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1440 2266 1
>>>>>>> 4.44e-01 2 5.51e-01 100
>>>>>>> PCGAMG Opt l03 1 1.0 8.2684e-04 1.0 2.80e+05 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 339 1667 1
>>>>>>> 6.72e-02 1 2.03e-01 100
>>>>>>> PCGAMG Gal l04 1 1.0 1.2238e-03 1.0 2.09e+05 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 170 244 1
>>>>>>> 2.05e-02 2 2.53e-02 100
>>>>>>> PCGAMG Opt l04 1 1.0 4.1008e-04 1.0 1.77e+04 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 43 165 1
>>>>>>> 4.49e-03 1 1.19e-02 100
>>>>>>> PCSetUp 2 1.0 9.9632e+00 1.0 4.95e+09 1.0 0.0e+00
>>>>>>> 0.0e+00 0.0e+00 5 12 0 0 0 5 12 0 0 0 496 17826 55
>>>>>>> 1.03e+03 45 6.54e+02 98
>>>>>>> PCSetUpOnBlocks 44 1.0 9.9087e-04 1.0 2.88e+03 1.0
>>>>>>>> The point of lazy initialization is to make it possible to run a
>>>>>>>> solve that doesn't use a GPU in PETSC_ARCH that supports GPUs, regardless
>>>>>>>> of whether a GPU is actually present.
>>>>>>>> Fande Kong <fdkong.jd at gmail.com> writes:
>>>>>>>> > I spoke too soon. It seems that we have trouble creating
>>>>>>>> cuda/kokkos vecs
>>>>>>>> > now. Got Segmentation fault.
>>>>>>>> > Thanks,
>>>>>>>> > Fande
>>>>>>>> > Program received signal SIGSEGV, Segmentation fault.
>>>>>>>> > 0x00002aaab5558b11 in
>>>>>>>> Petsc::CUPMDevice<(Petsc::CUPMDeviceType)0>::CUPMDeviceInternal::initialize
>>>>>>>> > (this=0x1) at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:54
>>>>>>>> > 54 PetscErrorCode CUPMDevice<T>::CUPMDeviceInternal::initialize()
>>>>>>>> noexcept
>>>>>>>> > Missing separate debuginfos, use: debuginfo-install
>>>>>>>> > bzip2-libs-1.0.6-13.el7.x86_64 elfutils-libelf-0.176-5.el7.x86_64
>>>>>>>> > elfutils-libs-0.176-5.el7.x86_64 glibc-2.17-325.el7_9.x86_64
>>>>>>>> > libX11-1.6.7-4.el7_9.x86_64 libXau-1.0.8-2.1.el7.x86_64
>>>>>>>> > libattr-2.4.46-13.el7.x86_64 libcap-2.22-11.el7.x86_64
>>>>>>>> > libibmad-5.4.0.MLNX20190423.1d917ae-0.1.49224.x86_64
>>>>>>>> > libibumad-43.1.1.MLNX20200211.078947f-0.1.49224.x86_64
>>>>>>>> > libibverbs-41mlnx1-OFED.4.9.0.0.7.49224.x86_64
>>>>>>>> > libmlx4-41mlnx1-OFED.4.7.3.0.3.49224.x86_64
>>>>>>>> > libmlx5-41mlnx1-OFED.4.9.0.1.2.49224.x86_64
>>>>>>>> libnl3-3.2.28-4.el7.x86_64
>>>>>>>> > librdmacm-41mlnx1-OFED.4.7.3.0.6.49224.x86_64
>>>>>>>> > librxe-41mlnx1-OFED.4.4.2.4.6.49224.x86_64
>>>>>>>> libxcb-1.13-1.el7.x86_64
>>>>>>>> > libxml2-2.9.1-6.el7_9.6.x86_64 numactl-libs-2.0.12-5.el7.x86_64
>>>>>>>> > systemd-libs-219-78.el7_9.3.x86_64 xz-libs-5.2.2-1.el7.x86_64
>>>>>>>> > zlib-1.2.7-19.el7_9.x86_64
>>>>>>>> > (gdb) bt
>>>>>>>> > #0 0x00002aaab5558b11 in
>>>>>>>> > (this=0x1) at
>>>>>>>> > #1 0x00002aaab5558db7 in
>>>>>>>> > Petsc::CUPMDevice<(Petsc::CUPMDeviceType)0>::getDevice
>>>>>>>> > (this=this at entry=0x2aaab7f37b70
>>>>>>>> > <CUDADevice>, device=0x115da00, id=-35, id at entry=-1) at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:344
>>>>>>>> > #2 0x00002aaab55577de in PetscDeviceCreate (type=type at entry
>>>>>>>> =PETSC_DEVICE_CUDA,
>>>>>>>> > devid=devid at entry=-1, device=device at entry=0x2aaab7f37b48
>>>>>>>> > <defaultDevices+8>) at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:107
>>>>>>>> > #3 0x00002aaab5557b3a in
>>>>>>>> PetscDeviceInitializeDefaultDevice_Internal
>>>>>>>> > (type=type at entry=PETSC_DEVICE_CUDA,
>>>>>>>> defaultDeviceId=defaultDeviceId at entry=-1)
>>>>>>>> > at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:273
>>>>>>>> > #4 0x00002aaab5557bf6 in PetscDeviceInitialize
>>>>>>>> > (type=type at entry=PETSC_DEVICE_CUDA)
>>>>>>>> > at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:234
>>>>>>>> > #5 0x00002aaab5661fcd in VecCreate_SeqCUDA (V=0x115d150) at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/impls/seq/seqcuda/veccuda.c:244
>>>>>>>> > #6 0x00002aaab5649b40 in VecSetType (vec=vec at entry=0x115d150,
>>>>>>>> > method=method at entry=0x2aaab70b45b8 "seqcuda") at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vecreg.c:93
>>>>>>>> > #7 0x00002aaab579c33f in VecCreate_CUDA (v=0x115d150) at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/impls/mpi/mpicuda/
>>>>>>>> > mpicuda.cu:214
>>>>>>>> > #8 0x00002aaab5649b40 in VecSetType (vec=vec at entry=0x115d150,
>>>>>>>> > method=method at entry=0x7fffffff9260 "cuda") at
>>>>>>>> > #9 0x00002aaab5648bf1 in VecSetTypeFromOptions_Private
>>>>>>>> (vec=0x115d150,
>>>>>>>> > PetscOptionsObject=0x7fffffff9210) at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vector.c:1263
>>>>>>>> > #10 VecSetFromOptions (vec=0x115d150) at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vector.c:1297
>>>>>>>> > #11 0x00002aaab02ef227 in libMesh::PetscVector<double>::init
>>>>>>>> > (this=0x11cd1a0, n=441, n_local=441, fast=false,
>>>>>>>> ptype=libMesh::PARALLEL)
>>>>>>>> > at
>>>>>>>> /home/kongf/workhome/sawtooth/moosegpu/scripts/../libmesh/installed/include/libmesh/petsc_vector.h:693
>>>>>>>> > On Thu, Jan 20, 2022 at 1:09 PM Fande Kong <fdkong.jd at gmail.com>
>>>>>>>> wrote:
>>>>>>>> >> Thanks, Jed,
>>>>>>>> >> This worked!
>>>>>>>> >> Fande
>>>>>>>> >> On Wed, Jan 19, 2022 at 11:03 PM Jed Brown <jed at jedbrown.org>
>>>>>>>> >>> > On Wed, Jan 19, 2022 at 11:39 AM Jacob Faibussowitsch <
>>>>>>>> >>> > wrote:
>>>>>>>> >>> >> Are you running on login nodes or compute nodes (I can’t
>>>>>>>> seem to tell
>>>>>>>> >>> from
>>>>>>>> >>> >> the configure.log)?
>>>>>>>> >>> > I was compiling codes on login nodes, and running codes on
>>>>>>>> compute
>>>>>>>> >>> nodes.
>>>>>>>> >>> > Login nodes do not have GPUs, but compute nodes do have GPUs.
>>>>>>>> >>> > Just to be clear, the same thing (code, machine) with
>>>>>>>> PETSc-3.16.1
>>>>>>>> >>> worked
>>>>>>>> >>> > perfectly. I have this trouble with PETSc-main.
>>>>>>>> >>> I assume you can
>>>>>>>> >>> export PETSC_OPTIONS='-device_enable lazy'
>>>>>>>> >>> and it'll work.
>>>>>>>> >>> I think this should be the default. The main complaint is that
>>>>>>>> timing the
>>>>>>>> >>> first GPU-using event isn't accurate if it includes
>>>>>>>> initialization, but I
>>>>>>>> >>> think this is mostly hypothetical because you can't trust any
>>>>>>>> timing that
>>>>>>>> >>> doesn't preload in some form and the first GPU-using event will
>>>>>>>> almost
>>>>>>>> >>> always be something uninteresting so I think it will rarely
>>>>>>>> lead to
>>>>>>>> >>> confusion. Meanwhile, eager initialization is viscerally
>>>>>>>> disruptive for
>>>>>>>> >>> lots of people.
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/08d3f741/attachment-0001.html>
