[petsc-users] Hypre in Petsc
sijie tang
sjtang1223 at gmail.com
Tue Jan 25 22:37:50 CST 2022
I have a question about, I want to use AMG as a solver in PETSc, but from the user manual, I find that AMG only can be used as a preconditioner. Am I right?
So I want to use the boomerAMG in HYPRE as the solver, Can I use the function like VecHYPRE_IJVectorCreate (Petsc function) in these links?
https://petsc.org/release/src/vec/vec/impls/hypre/vhyp.c <https://petsc.org/release/src/vec/vec/impls/hypre/vhyp.c>. (It Creates hypre ijvector from Petsc vector)
https://petsc.org/main/src/mat/impls/hypre/mhypre.c.html <https://petsc.org/main/src/mat/impls/hypre/mhypre.c.html> (It Creates hypre ijmatrix from Petsc matrix)
But there is a another question: how to transfer the vector/matrix structure from hypre back petsc ?
I don’t find any function for that work, Do you know what function can work, or do I implement this function by myself?
Sijie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/ef07a156/attachment.html>
