[petsc-users] Cannot eagerly initialize cuda, as doing so results in cuda error 35 (cudaErrorInsufficientDriver) : CUDA driver version is insufficient for CUDA runtime version
Fande Kong fdkong.jd at gmail.com
Tue Jan 25 20:18:39 CST 2022
On Tue, Jan 25, 2022 at 9:04 AM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> Configure should not have an impact here I think. The reason I had you run
> `cudaGetDeviceCount()` is because this is the CUDA call (and in fact the
> only CUDA call) in the initialization sequence that returns the error code.
> There should be no prior CUDA calls. Maybe this is a problem with
> oversubscribing GPU’s? In the runs that crash, how many ranks are using any
> given GPU  at once? Maybe MPS is required.
I used one MPI rank.
Fande
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> On Jan 21, 2022, at 12:01, Fande Kong <fdkong.jd at gmail.com> wrote:
> Thanks Jacob,
> On Thu, Jan 20, 2022 at 6:25 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> Segfault is caused by the following check at
>> src/sys/objects/device/impls/cupm/cupmdevice.cxx:349 being a
>> PetscUnlikelyDebug() rather than just PetscUnlikely():
>> if (PetscUnlikelyDebug(_defaultDevice < 0)) { // _defaultDevice is in
>> fact < 0 here and uncaught
>> To clarify:
>> “lazy” initialization is not that lazy after all, it still does some 50%
>> of the initialization that “eager” initialization does. It stops short
>> initializing the CUDA runtime, checking CUDA aware MPI, gathering device
>> data, and initializing cublas and friends. Lazy also importantly swallows
>> any errors that crop up during initialization, storing the resulting error
>> code for later (specifically _defaultDevice = -init_error_value;).
>> So whether you initialize lazily or eagerly makes no difference here, as
>> _defaultDevice will always contain -35.
>> The bigger question is why cudaGetDeviceCount() is returning
>> cudaErrorInsufficientDriver. Can you compile and run
>> #include <cuda_runtime.h>
>> int main()
>>   int ndev;
>>   return cudaGetDeviceCount(&ndev):
>> Then show the value of "echo $?”?
> Modify your code a little to get more information.
> #include <cstdio>
> int main()
>   int ndev;
>   int error = cudaGetDeviceCount(&ndev);
>   printf("ndev %d \n", ndev);
>   printf("error %d \n", error);
>   return 0;
> Results:
> $ ./a.out
> ndev 4
> error 0
> I have not read the PETSc cuda initialization code yet. If I need to guess
> at what was happening. I will naively think that PETSc did not get correct
> GPU information in the configuration because the compiler node does not
> have GPUs, and there was no way to get any GPU device information.
> During the runtime on GPU nodes, PETSc might have incorrect information
> grabbed during configuration and had this kind of false error message.
> Thanks,
> Fande
>> Best regards,
>> On Jan 20, 2022, at 17:47, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jan 20, 2022 at 6:44 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>>> Thanks, Jed
>>> On Thu, Jan 20, 2022 at 4:34 PM Jed Brown <jed at jedbrown.org> wrote:
>>>> You can't create CUDA or Kokkos Vecs if you're running on a node
>>>> without a GPU.
>>> I am running the code on compute nodes that do have GPUs.
>> If you are actually running on GPUs, why would you need lazy
>> initialization? It would not break with GPUs present.
>>    Matt
>>> With PETSc-3.16.1, I  got good speedup by running GAMG on GPUs.  That
>>> might be a bug of PETSc-main.
>>> Thanks,
>>> Fande
>>> KSPSetUp              13 1.0 6.4400e-01 1.0 2.02e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  5  0  0  0   0  5  0  0  0  3140   64630     15 1.05e+02    5
>>> 3.49e+01 100
>>> KSPSolve               1 1.0 1.0109e+00 1.0 3.49e+10 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0 87  0  0  0   0 87  0  0  0 34522   69556      4 4.35e-03    1
>>> 2.38e-03 100
>>> KSPGMRESOrthog       142 1.0 1.2674e-01 1.0 1.06e+10 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0 27  0  0  0   0 27  0  0  0 83755   87801      0 0.00e+00    0
>>> 0.00e+00 100
>>> SNESSolve              1 1.0 4.4402e+01 1.0 4.00e+10 1.0 0.0e+00 0.0e+00
>>> 0.0e+00 21100  0  0  0  21100  0  0  0   901   51365     57 1.10e+03   52
>>> 8.78e+02 100
>>> SNESSetUp              1 1.0 3.9101e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0
>>> 0.00e+00  0
>>> SNESFunctionEval       2 1.0 1.7097e+01 1.0 1.60e+07 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  8  0  0  0  0   8  0  0  0  0     1       0      0 0.00e+00    6
>>> 1.92e+02  0
>>> SNESJacobianEval       1 1.0 1.6213e+01 1.0 2.80e+07 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  8  0  0  0  0   8  0  0  0  0     2       0      0 0.00e+00    1
>>> 3.20e+01  0
>>> SNESLineSearch         1 1.0 8.5582e+00 1.0 1.24e+08 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  4  0  0  0  0   4  0  0  0  0    14   64153      1 3.20e+01    3
>>> 9.61e+01 94
>>> PCGAMGGraph_AGG        5 1.0 3.0509e+00 1.0 8.19e+07 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  1  0  0  0  0   1  0  0  0  0    27       0      5 3.49e+01    9
>>> 7.43e+01  0
>>> PCGAMGCoarse_AGG       5 1.0 3.8711e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00  2  0  0  0  0   2  0  0  0  0     0       0      0 0.00e+00    0
>>> 0.00e+00  0
>>> PCGAMGProl_AGG         5 1.0 7.0748e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.00e+00  0
>>> PCGAMGPOpt_AGG         5 1.0 1.2904e+00 1.0 2.14e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  1  5  0  0  0   1  5  0  0  0  1661   29807     26 7.15e+02   20
>>> 2.90e+02 99
>>> GAMG: createProl       5 1.0 8.9489e+00 1.0 2.22e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  4  6  0  0  0   4  6  0  0  0   249   29666     31 7.50e+02   29
>>> 3.64e+02 96
>>>   Graph               10 1.0 3.0478e+00 1.0 8.19e+07 1.0 0.0e+00
>>> 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    27       0      5
>>> 3.49e+01    9 7.43e+01  0
>>>   MIS/Agg              5 1.0 4.1290e-01 1.0 0.00e+00 0.0 0.0e+00
>>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0
>>> 0.00e+00    0 0.00e+00  0
>>>   SA: col data         5 1.0 1.9127e-02 1.0 0.00e+00 0.0 0.0e+00
>>>   SA: frmProl0         5 1.0 6.2662e-01 1.0 0.00e+00 0.0 0.0e+00
>>>   SA: smooth           5 1.0 4.9595e-01 1.0 1.21e+08 1.0 0.0e+00
>>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   244    2709     15
>>> 1.97e+02   15 2.55e+02 90
>>> GAMG: partLevel        5 1.0 4.7330e-01 1.0 6.98e+08 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  2  0  0  0   0  2  0  0  0  1475    4120      5 1.78e+02   10
>>> 2.55e+02 100
>>> PCGAMG Squ l00         1 1.0 2.6027e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0       0      0 0.00e+00    0
>>> 0.00e+00  0
>>> PCGAMG Gal l00         1 1.0 3.8406e-01 1.0 5.48e+08 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  1  0  0  0   0  1  0  0  0  1426    4270      1 1.48e+02    2
>>> 2.11e+02 100
>>> PCGAMG Opt l00         1 1.0 2.4932e-01 1.0 7.20e+07 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   289    2653      1 6.41e+01    1
>>> 1.13e+02 100
>>> PCGAMG Gal l01         1 1.0 6.6279e-02 1.0 1.09e+08 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1645    3851      1 2.40e+01    2
>>> 3.64e+01 100
>>> PCGAMG Opt l01         1 1.0 2.9544e-02 1.0 7.15e+06 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   242    1671      1 4.84e+00    1
>>> 1.23e+01 100
>>> PCGAMG Gal l02         1 1.0 1.8874e-02 1.0 3.72e+07 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1974    3636      1 5.04e+00    2
>>> 6.58e+00 100
>>> PCGAMG Opt l02         1 1.0 7.4353e-03 1.0 2.40e+06 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   323    1457      1 7.71e-01    1
>>> 2.30e+00 100
>>> PCGAMG Gal l03         1 1.0 2.8479e-03 1.0 4.10e+06 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1440    2266      1 4.44e-01    2
>>> 5.51e-01 100
>>> PCGAMG Opt l03         1 1.0 8.2684e-04 1.0 2.80e+05 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   339    1667      1 6.72e-02    1
>>> 2.03e-01 100
>>> PCGAMG Gal l04         1 1.0 1.2238e-03 1.0 2.09e+05 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0   170     244      1 2.05e-02    2
>>> 2.53e-02 100
>>> PCGAMG Opt l04         1 1.0 4.1008e-04 1.0 1.77e+04 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0    43     165      1 4.49e-03    1
>>> 1.19e-02 100
>>> PCSetUp                2 1.0 9.9632e+00 1.0 4.95e+09 1.0 0.0e+00 0.0e+00
>>> 0.0e+00  5 12  0  0  0   5 12  0  0  0   496   17826     55 1.03e+03   45
>>> 6.54e+02 98
>>> PCSetUpOnBlocks       44 1.0 9.9087e-04 1.0 2.88e+03 1.0
>>>> The point of lazy initialization is to make it possible to run a solve
>>>> that doesn't use a GPU in PETSC_ARCH that supports GPUs, regardless of
>>>> whether a GPU is actually present.
>>>> Fande Kong <fdkong.jd at gmail.com> writes:
>>>> > I spoke too soon. It seems that we have trouble creating cuda/kokkos
>>>> vecs
>>>> > now. Got Segmentation fault.
>>>> > Thanks,
>>>> > Fande
>>>> > Program received signal SIGSEGV, Segmentation fault.
>>>> > 0x00002aaab5558b11 in
>>>> Petsc::CUPMDevice<(Petsc::CUPMDeviceType)0>::CUPMDeviceInternal::initialize
>>>> > (this=0x1) at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:54
>>>> > 54 PetscErrorCode CUPMDevice<T>::CUPMDeviceInternal::initialize()
>>>> noexcept
>>>> > Missing separate debuginfos, use: debuginfo-install
>>>> > bzip2-libs-1.0.6-13.el7.x86_64 elfutils-libelf-0.176-5.el7.x86_64
>>>> > elfutils-libs-0.176-5.el7.x86_64 glibc-2.17-325.el7_9.x86_64
>>>> > libX11-1.6.7-4.el7_9.x86_64 libXau-1.0.8-2.1.el7.x86_64
>>>> > libattr-2.4.46-13.el7.x86_64 libcap-2.22-11.el7.x86_64
>>>> > libibmad-5.4.0.MLNX20190423.1d917ae-0.1.49224.x86_64
>>>> > libibumad-43.1.1.MLNX20200211.078947f-0.1.49224.x86_64
>>>> > libibverbs-41mlnx1-OFED.4.9.0.0.7.49224.x86_64
>>>> > libmlx4-41mlnx1-OFED.4.7.3.0.3.49224.x86_64
>>>> > libmlx5-41mlnx1-OFED.4.9.0.1.2.49224.x86_64 libnl3-3.2.28-4.el7.x86_64
>>>> > librdmacm-41mlnx1-OFED.4.7.3.0.6.49224.x86_64
>>>> > librxe-41mlnx1-OFED.4.4.2.4.6.49224.x86_64 libxcb-1.13-1.el7.x86_64
>>>> > libxml2-2.9.1-6.el7_9.6.x86_64 numactl-libs-2.0.12-5.el7.x86_64
>>>> > systemd-libs-219-78.el7_9.3.x86_64 xz-libs-5.2.2-1.el7.x86_64
>>>> > zlib-1.2.7-19.el7_9.x86_64
>>>> > (gdb) bt
>>>> > #0  0x00002aaab5558b11 in
>>>> > (this=0x1) at
>>>> > #1  0x00002aaab5558db7 in
>>>> > Petsc::CUPMDevice<(Petsc::CUPMDeviceType)0>::getDevice
>>>> > (this=this at entry=0x2aaab7f37b70
>>>> > <CUDADevice>, device=0x115da00, id=-35, id at entry=-1) at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:344
>>>> > #2  0x00002aaab55577de in PetscDeviceCreate (type=type at entry
>>>> =PETSC_DEVICE_CUDA,
>>>> > devid=devid at entry=-1, device=device at entry=0x2aaab7f37b48
>>>> > <defaultDevices+8>) at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:107
>>>> > #3  0x00002aaab5557b3a in PetscDeviceInitializeDefaultDevice_Internal
>>>> > (type=type at entry=PETSC_DEVICE_CUDA,
>>>> defaultDeviceId=defaultDeviceId at entry=-1)
>>>> > at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:273
>>>> > #4  0x00002aaab5557bf6 in PetscDeviceInitialize
>>>> > (type=type at entry=PETSC_DEVICE_CUDA)
>>>> > at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:234
>>>> > #5  0x00002aaab5661fcd in VecCreate_SeqCUDA (V=0x115d150) at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/impls/seq/seqcuda/veccuda.c:244
>>>> > #6  0x00002aaab5649b40 in VecSetType (vec=vec at entry=0x115d150,
>>>> > method=method at entry=0x2aaab70b45b8 "seqcuda") at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vecreg.c:93
>>>> > #7  0x00002aaab579c33f in VecCreate_CUDA (v=0x115d150) at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/impls/mpi/mpicuda/
>>>> > mpicuda.cu:214
>>>> > #8  0x00002aaab5649b40 in VecSetType (vec=vec at entry=0x115d150,
>>>> > method=method at entry=0x7fffffff9260 "cuda") at
>>>> > #9  0x00002aaab5648bf1 in VecSetTypeFromOptions_Private
>>>> (vec=0x115d150,
>>>> > PetscOptionsObject=0x7fffffff9210) at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vector.c:1263
>>>> > #10 VecSetFromOptions (vec=0x115d150) at
>>>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vector.c:1297
>>>> > #11 0x00002aaab02ef227 in libMesh::PetscVector<double>::init
>>>> > (this=0x11cd1a0, n=441, n_local=441, fast=false,
>>>> ptype=libMesh::PARALLEL)
>>>> > at
>>>> /home/kongf/workhome/sawtooth/moosegpu/scripts/../libmesh/installed/include/libmesh/petsc_vector.h:693
>>>> > On Thu, Jan 20, 2022 at 1:09 PM Fande Kong <fdkong.jd at gmail.com>
>>>> wrote:
>>>> >> Thanks, Jed,
>>>> >> This worked!
>>>> >> Fande
>>>> >> On Wed, Jan 19, 2022 at 11:03 PM Jed Brown <jed at jedbrown.org> wrote:
>>>> >>> > On Wed, Jan 19, 2022 at 11:39 AM Jacob Faibussowitsch <
>>>> >>> > wrote:
>>>> >>> >> Are you running on login nodes or compute nodes (I can’t seem to
>>>> tell
>>>> >>> from
>>>> >>> >> the configure.log)?
>>>> >>> > I was compiling codes on login nodes, and running codes on compute
>>>> >>> nodes.
>>>> >>> > Login nodes do not have GPUs, but compute nodes do have GPUs.
>>>> >>> > Just to be clear, the same thing (code, machine) with PETSc-3.16.1
>>>> >>> worked
>>>> >>> > perfectly. I have this trouble with PETSc-main.
>>>> >>> I assume you can
>>>> >>> export PETSC_OPTIONS='-device_enable lazy'
>>>> >>> and it'll work.
>>>> >>> I think this should be the default. The main complaint is that
>>>> timing the
>>>> >>> first GPU-using event isn't accurate if it includes initialization,
>>>> but I
>>>> >>> think this is mostly hypothetical because you can't trust any
>>>> timing that
>>>> >>> doesn't preload in some form and the first GPU-using event will
>>>> almost
>>>> >>> always be something uninteresting so I think it will rarely lead to
>>>> >>> confusion. Meanwhile, eager initialization is viscerally disruptive
>>>> for
>>>> >>> lots of people.
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/d0d9177d/attachment-0001.html>
