[petsc-users] Error when configuring the PETSC environment
Matthew Knepley
knepley at gmail.com
Tue Jan 25 18:07:03 CST 2022
On Tue, Jan 25, 2022 at 5:05 PM Peng, Kang <Kang_Peng at uml.edu> wrote:
> The blue word in the last Email is part of the configure.log file, this
> time I put the whole file in the attachment.
> I actually tried to install it via brew, but it still failed. And I could
> follow Pflotran's installation tutorial on my old computer before, but I
> don't know why it doesn't work now.
CMake does not like your Clang compiler, Can you specify it explicitly
using --with-cc=<compiler>
Matt
Running configure on CMAKE; this may take
several minutes
Executing: ./configure --prefix=/Users/von/petsc/arch-darwin-c-opt
--parallel=8 -- -DCMAKE_USE_OPENSSL=OFF
stdout:
CMake 3.20.1, Copyright 2000-2021 Kitware, Inc. and Contributors
Found Clang toolchain
Error when bootstrapping CMake:
Cannot find appropriate C compiler on this system.
Please specify one using environment variable CC.
See cmake_bootstrap.log for compilers attempted.
Log of errors:
/Users/von/petsc/arch-darwin-c-opt/externalpackages/cmake-3.20.1/Bootstrap.cmk/cmake_bootstrap.log
> 2022年1月25日 16:57,Stefano Zampini <stefano.zampini at gmail.com> 写道:
> *This e-mail originated from outside the UMass Lowell network.*
> You should attach configure.log if you want us to take a look at the
> failure. In any case, you should use gmake that you can install via brew
> On Jan 26, 2022, at 12:53 AM, Peng, Kang <Kang_Peng at uml.edu> wrote:
> Hi PETSc,
> I am trying to configure the PETSC environment in MacOS (Apple M1 pro
> chip, macOS 12.1), but something went wrong when I executing those command
> below. I tried many methods but failed to solve it. Could you help me to
> solve it?
> I’ve been following this instruction to install PETSc and configure the
> environment, but I can’t do it after changing to the new chip.
> https://www.pflotran.org/documentation/user_guide/how_to/installation/linux.html#linux-install
> <https://urldefense.com/v3/__https://www.pflotran.org/documentation/user_guide/how_to/installation/linux.html*linux-install__;Iw!!PVKG_VDCxu5g!6y-kcFG7ScjxFIz3MDNNqeQcRa_acHzAh8K-XeflKjdgncNiRv0NQc_1Bg3urZphgg$>
> Error is as follows:
> von at MacBook-Pro-VON petsc % ./configure --CFLAGS='-O3' --CXXFLAGS='-O3'
> --FFLAGS='-O3' --with-debugging=no --download-mpich=yes --download-hdf5=yes
> --download-fblaslapack=yes --download-cmake=yes --download-metis=yes
> --download-parmetis=yes --download-hdf5-fortran-bindings=yes
> --download-hdf5-configure-arguments="--with-zlib=yes"
> Configuring PETSc to compile on your system
> ***** WARNING: You have a version of GNU make older than 4.0. It will
> work,
> but may not support all the parallel testing options.
> You can install the
> latest GNU make with your package
> manager, such as brew or macports, or use
> the
> --download-make option to get the latest GNU make *****
> Running configure on CMAKE; this may take several minutes
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> Error running configure on CMAKE
> details):
> File "/Users/von/petsc/config/configure.py", line 465, in petsc_configure
> framework.configure(out = sys.stdout)
> File "/Users/von/petsc/config/BuildSystem/config/framework.py", line
> 1385, in configure
> self.processChildren()
> 1373, in processChildren
> self.serialEvaluation(self.childGraph)
> 1348, in serialEvaluation
> child.configure()
> File "/Users/von/petsc/config/BuildSystem/config/packages/cmake.py",
> line 75, in configure
> config.package.GNUPackage.configure(self)
> File "/Users/von/petsc/config/BuildSystem/config/package.py", line 1189,
> in configure
> self.executeTest(self.configureLibrary)
> File "/Users/von/petsc/config/BuildSystem/config/base.py", line 138, in
> executeTest
> ret = test(*args,**kargs)
> File "/Users/von/petsc/config/BuildSystem/config/package.py", line 935,
> in configureLibrary
> for location, directory, lib, incl in self.generateGuesses():
> File "/Users/von/petsc/config/BuildSystem/config/package.py", line 509,
> in generateGuesses
> d = self.checkDownload()
> File "/Users/von/petsc/config/BuildSystem/config/package.py", line 643,
> in checkDownload
> return self.getInstallDir()
> File "/Users/von/petsc/config/BuildSystem/config/package.py", line 405,
> in getInstallDir
> installDir = self.Install()
> line 47, in Install
> retdir = config.package.GNUPackage.Install(self)
> File "/Users/von/petsc/config/BuildSystem/config/package.py", line 1733,
> in Install
> raise RuntimeError('Error running configure on ' + self.PACKAGE)
> Finishing configure run at Tue, 25 Jan 2022 16:21:58 -0500
> Thanks,
> Kang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/61f75d28/attachment.html>
