[petsc-users] Error when configuring the PETSC environment
Stefano Zampini stefano.zampini at gmail.com
Tue Jan 25 15:57:33 CST 2022
You should attach configure.log if you want us to take a look at the failure. In any case, you should use gmake that you can install via brew
> On Jan 26, 2022, at 12:53 AM, Peng, Kang <Kang_Peng at uml.edu> wrote:
> Hi PETSc,
> I am trying to configure the PETSC environment in MacOS (Apple M1 pro chip, macOS 12.1), but something went wrong when I executing those command below. I tried many methods but failed to solve it. Could you help me to solve it?
> I’ve been following this instruction to install PETSc and configure the environment, but I can’t do it after changing to the new chip.
> https://www.pflotran.org/documentation/user_guide/how_to/installation/linux.html#linux-install <https://www.pflotran.org/documentation/user_guide/how_to/installation/linux.html#linux-install>
> Error is as follows:
> von at MacBook-Pro-VON petsc % ./configure --CFLAGS='-O3' --CXXFLAGS='-O3' --FFLAGS='-O3' --with-debugging=no --download-mpich=yes --download-hdf5=yes --download-fblaslapack=yes --download-cmake=yes --download-metis=yes --download-parmetis=yes --download-hdf5-fortran-bindings=yes --download-hdf5-configure-arguments="--with-zlib=yes"
>                       Configuring PETSc to compile on your system
> =============================================================================================        ***** WARNING: You have a version of GNU make older than 4.0. It will work,        but may not support all the parallel testing options. You can install the        latest GNU make with your package manager, such as brew or macports, or use        the --download-make option to get the latest GNU make *****        =============================================================================================        =============================================================================================        Running configure on CMAKE; this may take several minutes        =============================================================================================        *******************************************************************************
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> Error running configure on CMAKE
>   File "/Users/von/petsc/config/configure.py", line 465, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File "/Users/von/petsc/config/BuildSystem/config/framework.py", line 1385, in configure
>     self.processChildren()
>   File "/Users/von/petsc/config/BuildSystem/config/framework.py", line 1373, in processChildren
>     self.serialEvaluation(self.childGraph)
>   File "/Users/von/petsc/config/BuildSystem/config/framework.py", line 1348, in serialEvaluation
>     child.configure()
>   File "/Users/von/petsc/config/BuildSystem/config/packages/cmake.py", line 75, in configure
>     config.package.GNUPackage.configure(self)
>   File "/Users/von/petsc/config/BuildSystem/config/package.py", line 1189, in configure
>     self.executeTest(self.configureLibrary)
>   File "/Users/von/petsc/config/BuildSystem/config/base.py", line 138, in executeTest
>     ret = test(*args,**kargs)
>   File "/Users/von/petsc/config/BuildSystem/config/package.py", line 935, in configureLibrary
>     for location, directory, lib, incl in self.generateGuesses():
>   File "/Users/von/petsc/config/BuildSystem/config/package.py", line 509, in generateGuesses
>     d = self.checkDownload()
>   File "/Users/von/petsc/config/BuildSystem/config/package.py", line 643, in checkDownload
>     return self.getInstallDir()
>   File "/Users/von/petsc/config/BuildSystem/config/package.py", line 405, in getInstallDir
>     installDir = self.Install()
>   File "/Users/von/petsc/config/BuildSystem/config/packages/cmake.py", line 47, in Install
>     retdir = config.package.GNUPackage.Install(self)
>   File "/Users/von/petsc/config/BuildSystem/config/package.py", line 1733, in Install
>     raise RuntimeError('Error running configure on ' + self.PACKAGE)
> Finishing configure run at Tue, 25 Jan 2022 16:21:58 -0500
> Thanks,
> Kang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220126/9728b381/attachment.html>
