[petsc-users] Asking examples about solving DAE in python
Zhang, Hong
hongzhang at anl.gov
Tue Jan 25 14:29:25 CST 2022
The following code should work.
class Pendulum(object):
n = 5
comm = PETSc.COMM_SELF
l = 1.0
m = 1.0
g = 1.0
def initialCondition(self, x):
# mu = self.mu_
#initial condition
theta0= np.pi/3 #starting angle
x0=np.sin(theta0)
y0=-(self.l-x0**2)**.5
lambdaval = 0.1
x[0] = x0
x[1] = y0
x[2] = 0
x[4] = 0
x[5] = lambdaval
x.assemble()
def evalIFunction(self, ts, t, x, xdot, f):
f[0] = x[2]-xdot[0]
f[1] = x[3]-xdot[1]
f[2] = -xdot[2]+x[4]*x[0]/self.m
f[3] = -xdot[3]+x[4]*x[1]/self.m-self.g
f[4] = [x[2]**2 + x[3]**2 + (x[0]**2 + x[1]**2)/self.m*x[4] - x[1] * self.g]
f.assemble()
You do not need to initialize xdot. Only x needs to be initialized.
Hong
On Jan 25, 2022, at 12:03 AM, Xiong, Jing via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Good morning,
Thanks for all your help.
I'm trying to implement a toy example solving a DAE for a Pendulum system and I got two questions:
1. How to set the initial value for xdot?
2. I got the following error information:
* Assertion failed: (!PyErr_Occurred()), function __Pyx_PyCFunction_FastCall, file src/petsc4py.PETSc.c, line 359099.
The system equation is given in https://en.wikipedia.org/wiki/Differential-algebraic_system_of_equations
The formula I used is shown as follows:
<image.png>
I also attached my code below:
import sys, petsc4py
petsc4py.init(sys.argv)
import numpy as np
from petsc4py import PETSc
n = 5
# mu = self.mu_
l = 1.0
m = 1.0
g = 1.0
#initial condition
x0=np.sin(theta0)
y0=-(l-x0**2)**.5
lambdaval = 0.1
x[0] = x0
x[1] = y0
x[4] = lambdaval
x.assemble()
f.setArray ([x[2]-xdot[0]],
[x[3]-xdot[1]],
[-xdot[2]+x[4]*x[0]/m],
[-xdot[3]+x[4]*x[1]/m-g],
[x[2]**2 + x[3]**2 + (x[0]**2 + x[1]**2)/m*x[4] - x[1] * g])
OptDB = PETSc.Options()
ode = Pendulum()
x = PETSc.Vec().createSeq(ode.n, comm=ode.comm)
f = x.duplicate()
ts = PETSc.TS().create(comm=ode.comm)
ts.setType(ts.Type.CN)
ts.setIFunction(ode.evalIFunction, f)
ts.setSaveTrajectory()
ts.setTime(0.0)
ts.setTimeStep(0.001)
ts.setMaxTime(0.5)
ts.setMaxSteps(1000)
ts.setExactFinalTime(PETSc.TS.ExactFinalTime.MATCHSTEP)
ts.setFromOptions()
ode.initialCondition(x)
ts.solve(x)
Best,
Jing
From: Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>>
Sent: Thursday, January 20, 2022 3:05 PM
To: Xiong, Jing <jxiong at anl.gov<mailto:jxiong at anl.gov>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Zhao, Dongbo <dongbo.zhao at anl.gov<mailto:dongbo.zhao at anl.gov>>; Hong, Tianqi <thong at anl.gov<mailto:thong at anl.gov>>
Subject: Re: [petsc-users] Asking examples about solving DAE in python
On Jan 20, 2022, at 4:13 PM, Xiong, Jing via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I hope you are well.
I'm very interested in PETSc and want to explore the possibility of whether it could solve Differential-algebraic equations (DAE) in python. I know there are great examples in C, but I'm struggling to connect the examples in python.
The only example I got right now is for solving ODEs in the paper: PETSc/TS: A Modern Scalable ODE/DAE Solver Library.
And I got the following questions:
1. Is petsc4py the right package to use?
Yes, you need petsc4py for python.
1. Could you give an example for solving DAEs in python?
src/binding/petsc4py/demo/ode/vanderpol.py gives a simple example to demonstrate a variety of PETSc capabilities. The corresponding C version of this example is ex20adj.c in src/ts/tutorials/.
1. How to solve an ODE with explicit methods.
2. How to solve an ODE/DAE with implicit methods.
3. How to use TSAdjoint to calculate adjoint sensitivities.
4. How to do a manual matrix-free implementation (e.g. you may already have a way to differentiate your RHS function to generate the Jacobian-vector product).
1. Is Jacobian must be specified? If not, could your show an example for solving DAEs without specified Jacobian in python?
PETSc can do finite-difference approximations to generate the Jacobian matrix automatically. This may work nicely for small-sized problems. You can also try to use an AD tool to produce the Jacobian-vector product and use it in a matrix-free implementation.
Hong
Thank you for your help.
Best,
Jing
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/02c746ad/attachment-0001.html>
