[petsc-users] Strange CUDA failure with a second petscfinalize with PETSc 3.16
Hao DONG
dong-hao at outlook.com
Tue Jan 25 03:42:32 CST 2022
Hi Jacob,
Thanks for the comments – silly that I have overlooked the debugging flag so far. Unfortunately, I am out of office for a couple of days so I cannot confirm the result on my workstation, for now.
However, I have a laptop with nvidia graphic card (old gtx1050, which is actually slower than the cpu in terms of double precision calculation), I have tried to git pull on the laptop from main and re-config as you suggested.
However, using “--with-cxx-dialect=14” throws up an error like:
Unknown C++ dialect: with-cxx-dialect=14
And omitting the “--with-cuda-dialect=cxx14” also gives me a similar complaint with:
CUDA Error: Using CUDA with PetscComplex requires a C++ dialect at least cxx11. Use --with-cxx-dialect=xxx and --with-cuda-dialect=xxx to specify a suitable compiler.
Eventually I was able to configure and compile with the following config setup:
./configure --prefix=/opt/petsc/debug --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --with-scalar-type=complex --with-precision=double --with-cuda-dir=/usr/local/cuda --with-fortran-kernels=1 --with-cxx-dialect=cxx14 --with-cuda-dialect=cxx14 --with-debugging=1
But still, I got the same error regarding cuda (still the error code 97 thing). I attached the configure and output log of my ex11 on my laptop – is there anything that can help pinpoint the problem? I can also confirm that PETSc 3.15.2 works well with my ex11fc code with cuda, on my laptop. Sadly, my laptop setup is based on WSL, which is far from an ideal environment to test CUDA. I will let you know once I get my hands on my workstations.
Cheers,
Hao
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows
From: Jacob Faibussowitsch<mailto:jacob.fai at gmail.com>
Sent: Tuesday, January 25, 2022 1:22 AM
To: Hao DONG<mailto:dong-hao at outlook.com>
Cc: petsc-users<mailto:petsc-users at mcs.anl.gov>; Junchao Zhang<mailto:junchao.zhang at gmail.com>
Subject: Re: [petsc-users] Strange CUDA failure with a second petscfinalize with PETSc 3.16
Hi Hao,
Any luck reproducing the CUDA problem?
Sorry for the long radio silence, I still have not been able to reproduce the problem unfortunately. I have tried on a local machine, and a few larger clusters and all return without errors both with and without cuda…
Can you try pulling the latest version of main, reconfiguring and trying again?
BTW, your configure arguments are a little wonky:
1. --with-clanguage=c - this isn’t needed, PETSc will default to C
2. --with-cxx-dialect=cxx14 --with-cuda-dialect=cxx14 - use --with-cxx-dialect=14 instead, PETSc will detect that you have gnu compilers and enable gnu extensions
3. -with-debugging=1 - this is missing an extra dash, but you also have optimization flags set so maybe just leave this one out
Best regards,
(Jacob Fai - booss - oh - vitch)
On Jan 23, 2022, at 21:29, Hao DONG <dong-hao at outlook.com<mailto:dong-hao at outlook.com>> wrote:
Dear Jacob,
Any luck reproducing the CUDA problem? - just write to check in, in case somehow the response did not reach me (this happens to my colleagues abroad sometimes, probably due to the Wall).
All the best,
Hao
On Jan 19, 2022, at 3:01 PM, Hao DONG <dong-hao at outlook.com<mailto:dong-hao at outlook.com>> wrote:
Thanks Jacob for looking into this –
You can see the updated source code of ex11fc in the attachment – although there is not much that I modified (except for the jabbers I outputted). I also attached the full output (ex11fc.log) along with the configure.log file. It’s an old dual Xeon workstation (one of my “production” machines) with Linux kernel 5.4.0 and gcc 9.3.
I simply ran the code with
mpiexec -np 2 ex11fc -usecuda
for GPU test. And as stated before, calling without the “-usecuda” option shows no errors.
Please let me know if you find anything wrong with the configure/code.
Cheers,
Hao
Sent: Wednesday, January 19, 2022 3:38 AM
Cc: Junchao Zhang<mailto:junchao.zhang at gmail.com>; petsc-users<mailto:petsc-users at mcs.anl.gov>
Apologies, forgot to mention in my previous email but can you also include a copy of the full printout of the error message that you get? It will include all the command-line flags that you ran with (if any) so I can exactly mirror your environment.
Best regards,
On Jan 18, 2022, at 14:06, Jacob Faibussowitsch <jacob.fai at gmail.com<mailto:jacob.fai at gmail.com>> wrote:
Can you send your updated source file as well as your configure.log (should be $PETSC_DIR/configure.log). I will see if I can reproduce the error on my end.
Best regards,
On Jan 17, 2022, at 23:06, Hao DONG <dong-hao at outlook.com<mailto:dong-hao at outlook.com>> wrote:
Dear Junchao and Jacob,
Thanks a lot for the response – I also don’t understand why this is related to the device, especially on why the procedure can be successfully finished for *once* – As instructed, I tried to add a CHKERRA() macro after (almost) every petsc line – such as the initialization, mat assemble, ksp create, solve, mat destroy, etc. However, all other petsc commands returns with error code 0. It only gives me a similar (still not very informative) error after I call the petscfinalize (again for the second time), with error code 97:
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: GPU error
[0]PETSC ERROR: cuda error 709 (cudaErrorContextIsDestroyed) : context is destroyed
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.16.3, unknown
[0]PETSC ERROR: ./ex11f on a named stratosphere by donghao Tue Jan 18 11:39:43 2022
[0]PETSC ERROR: Configure options --prefix=/opt/petsc/complex-double-with-cuda --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 COPTFLAGS="-O3 -mavx2" CXXOPTFLAGS="-O3 -mavx2" FOPTFLAGS="-O3 -ffree-line-length-none -mavx2" CUDAOPTFLAGS=-O3 --with-cxx-dialect=cxx14 --with-cuda-dialect=cxx14 --with-scalar-type=complex --with-precision=double --with-cuda-dir=/usr/local/cuda --with-debugging=1
[0]PETSC ERROR: #1 PetscFinalize() at /home/donghao/packages/petsc-current/src/sys/objects/pinit.c:1638
[0]PETSC ERROR: #2 User provided function() at User file:0
I can also confirm that rolling back to petsc 3.15 will *not* see the problem, even with the new nvidia driver. And petsc 3.16.3 with an old nvidia driver (470.42) also get this same error. So it’s probably not connected to the nvidia driver.
Any idea on where I should look at next?
Thanks a lot in advance, and all the best,
Hao
Sent: Sunday, January 16, 2022 12:12 AM
To: Junchao Zhang<mailto:junchao.zhang at gmail.com>
Cc: petsc-users<mailto:petsc-users at mcs.anl.gov>; Hao DONG<mailto:dong-hao at outlook.com>
I don’t quite understand how it is getting to the CUDA error to be honest. None of the code in the stack trace is anywhere near the device code. Reading the error message carefully, it first chokes on PetscLogGetStageLog() from a call to PetscClassIdRegister():
PetscErrorCode PetscLogGetStageLog(PetscStageLog *stageLog)
PetscFunctionBegin;
PetscValidPointer(stageLog,1);
if (!petsc_stageLog) {
fprintf(stderr, "PETSC ERROR: Logging has not been enabled.\nYou might have forgotten to call PetscInitialize().\n");
PETSCABORT(MPI_COMM_WORLD, PETSC_ERR_SUP); // Here
But then jumps to PetscFinalize(). You can also see the "You might have forgotten to call PetscInitialize().” message in the error message, just under the topmost level of the stack trace.
Can you check the value of ierr of each function call (use the CHKERRA() macro to do so)? I suspect the problem here that errors occurring previously in the program are being ignored, leading to the garbled stack trace.
Best regards,
On Jan 14, 2022, at 20:58, Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>> wrote:
Jacob,
Could you have a look as it seems the "invalid device context" is in your newly added module?
Thanks
--Junchao Zhang
On Fri, Jan 14, 2022 at 12:49 AM Hao DONG <dong-hao at outlook.com<mailto:dong-hao at outlook.com>> wrote:
Dear All,
I have encountered a peculiar problem when fiddling with a code with PETSC 3.16.3 (which worked fine with PETSc 3.15). It is a very straight forward PDE-based optimization code which repeatedly solves a linearized PDE problem with KSP in a subroutine (the rest of the code does not contain any PETSc related content). The main program provides the subroutine with an MPI comm. Then I set the comm as PETSC_COMM_WORLD to tell PETSC to attach to it (and detach with it when the solving is finished each time).
Strangely, I observe a CUDA failure whenever the petscfinalize is called for a *second* time. In other words, the first and second PDE calculations with GPU are fine (with correct solutions). The petsc code just fails after the SECOND petscfinalize command is called. You can also see the PETSC config in the error message:
[1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: GPU error
[1]PETSC ERROR: cuda error 201 (cudaErrorDeviceUninitialized) : invalid device context
[1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.16.3, unknown
[1]PETSC ERROR: maxwell.gpu on a named stratosphere by hao Fri Jan 14 10:21:05 2022
[1]PETSC ERROR: Configure options --prefix=/opt/petsc/complex-double-with-cuda --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 COPTFLAGS="-O3 -mavx2" CXXOPTFLAGS="-O3 -mavx2" FOPTFLAGS="-O3 -ffree-line-length-none -mavx2" CUDAOPTFLAGS=-O3 --with-cxx-dialect=cxx14 --with-cuda-dialect=cxx14 --with-scalar-type=complex --with-precision=double --with-cuda-dir=/usr/local/cuda --with-debugging=1
[1]PETSC ERROR: #1 PetscFinalize() at /home/hao/packages/petsc-current/src/sys/objects/pinit.c:1638
The EXACT line numbers in the error traceback are not available.
Instead the line number of the start of the function is given.
[1] #1 PetscAbortFindSourceFile_Private() at /home/hao/packages/petsc-current/src/sys/error/err.c:35
[1] #2 PetscLogGetStageLog() at /home/hao/packages/petsc-current/src/sys/logging/utils/stagelog.c:29
[1] #3 PetscClassIdRegister() at /home/hao/packages/petsc-current/src/sys/logging/plog.c:2376
[1] #4 MatMFFDInitializePackage() at /home/hao/packages/petsc-current/src/mat/impls/mffd/mffd.c:45
[1] #5 MatInitializePackage() at /home/hao/packages/petsc-current/src/mat/interface/dlregismat.c:163
[1] #6 MatCreate() at /home/hao/packages/petsc-current/src/mat/utils/gcreate.c:77
However, it doesn’t seem to affect the other part of my code, so the code can continue running until it gets to the petsc part again (the *third* time). Unfortunately, it doesn’t give me any further information even if I set the debugging to yes in the configure file. It also worth noting that PETSC without CUDA (i.e. with simple MATMPIAIJ) works perfectly fine.
I am able to re-produce the problem with a toy code modified from ex11f. Please see the attached file (ex11fc.F90) for details. Essentially the code does the same thing as ex11f, but three times with a do loop. To do that I added an extra MPI_INIT/MPI_FINALIZE to ensure that the MPI communicator is not destroyed when PETSC_FINALIZE is called. I used the PetscOptionsHasName utility to check if you have “-usecuda” in the options. So running the code with and without that option can give you a comparison w/o CUDA. I can see that the code also fails after the second loop of the KSP operation. Could you kindly shed some lights on this problem?
I should say that I am not even sure if the problem is from PETSc, as I also accidentally updated the NVIDIA driver (for now it is 510.06 with cuda 11.6). And it is well known that NVIDIA can give you some surprise in the updates (yes, I know I shouldn’t have touched that if it’s not broken). But my CUDA code without PETSC (which basically does the same PDE thing, but with cusparse/cublas directly) seems to work just fine after the update. It is also possible that my petsc code related to CUDA was not quite “legitimate” – I just use:
MatSetType(A, MATMPIAIJCUSPARSE, ierr)
and
MatCreateVecs(A, u, PETSC_NULL_VEC, ierr)
to make the data onto GPU. I would very much appreciate it if you could show me the “right” way to do that.
Hao
<configure.log><ex11fc.F90><ex11fc.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/751501f4/attachment-0001.html>
Desc: configure-xps.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/751501f4/attachment-0002.obj>
Desc: ex11fc-xps.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/751501f4/attachment-0003.obj>
