[petsc-users] hypre / hip usage
    Paul T. Bauman
    ptbauman at gmail.com
    Mon Jan 24 09:16:22 CST 2022
On Mon, Jan 24, 2022 at 8:53 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jan 24, 2022 at 9:24 AM Mark Adams <mfadams at lbl.gov> wrote:
>> What is the fastest way to rebuild hypre? reconfiguring did not work and
>> is slow.
>> I am printf debugging to find this HSA_STATUS_ERROR_MEMORY_FAULT  (no
>> debuggers other than valgrind on Crusher??!?!)
Again, apologies for interjecting, but I wanted to offer a few pointers
here.
1. `rocgdb` will be in your PATH when the `rocm` module is loaded. This is
gdb, but with some extra AMDGPU goodies. AFAIK, you cannot, yet, do
stepping through a kernel in the source (only the ISA), but you can query
device variables in host code, print their values, etc.
1a. Note that multiple threads can be spawned by the HIP runtime.
Furthermore, it's likely the thread you'll be on when you catch the error
is (one of) the runtime thread(s). You'll need to do `info threads` and
then select your host thread to get back to it.
2. To get an accurate stacktrace (meaning get the line in the host code
where the error is actually happening), I recommend setting the following
environment variables for debugging that will force the serialization of
async memcopies and kernel launches:
AMD_SERIALIZE_KERNEL = 3
AMD_SERIALIZE_COPY=3
Paul
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220124/ce682437/attachment.html>
