[petsc-users] hypre / hip usage
Mark Adams mfadams at lbl.gov
Fri Jan 21 10:23:53 CST 2022
On Fri, Jan 21, 2022 at 11:14 AM Jed Brown <jed at jedbrown.org> wrote:
> "Paul T. Bauman" <ptbauman at gmail.com> writes:
> > On Fri, Jan 21, 2022 at 8:52 AM Paul T. Bauman <ptbauman at gmail.com>
> wrote:
> >> Yes. The way HYPRE's memory model is setup is that ALL GPU allocations
> are
> >> "native" (i.e. [cuda,hip]Malloc) or, if unified memory is enabled, then
> ALL
> >> GPU allocations are unified memory (i.e. [cuda,hip]MallocManaged).
> >> Regarding HIP, there is an HMM implementation of hipMallocManaged
> planned,
> >> but is it not yet delivered AFAIK (and it will *not* support gfx906,
> e.g.
> >> RVII, FYI), so, today, under the covers, hipMallocManaged is calling
> >> hipHostMalloc. So, today, all your unified memory allocations in HYPRE
> on
> >> HIP are doing CPU-pinned memory accesses. And performance is just truly
> >> terrible (as you might expect).
> Thanks for this important bit of information.
> And it sounds like when we add support to hand off Kokkos matrices and
> vectors (our current support for matrices on ROCm devices uses Kokkos) or
> add direct support for hipSparse, we'll avoid touching host memory in
> assembly-to-solve with hypre.
It does not look like anyone has made Hypre work with HIP. Stafano added a
runex19_hypre_hip target 4 months ago and hypre.py has some HIP things.
I have a user that would like to try this, no hurry but, can I get an idea
of a plan for this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220121/8474b30c/attachment.html>
