[petsc-users] hypre / hip usage
Paul T. Bauman ptbauman at gmail.com
Fri Jan 21 09:32:37 CST 2022
Dammit, didn't reply-all. Sorry.
On Fri, Jan 21, 2022 at 8:52 AM Paul T. Bauman <ptbauman at gmail.com> wrote:
> On Fri, Jan 21, 2022 at 8:37 AM Jed Brown <jed at jedbrown.org> wrote:
>> "Paul T. Bauman" <ptbauman at gmail.com> writes:
>> > On Fri, Jan 21, 2022 at 8:19 AM Jed Brown <jed at jedbrown.org> wrote:
>> >> Mark Adams <mfadams at lbl.gov> writes:
>> >> > Two questions about hypre on HIP:
>> >> > * I am doing this now. Is this correct?
>> >> >     '--download-hypre',
>> >> >     '--download-hypre-configure-arguments=--enable-unified-memory',
>> > Apologies for interjecting, but I want to point out here that a pretty
>> good
>> > chunk of BoomerAMG is ported to the GPU and you may not need this
>> > unified-memory option. I point this out because you will get
>> substantially
>> > better performance without this option, i.e. using "native" GPU memory.
>> I
>> > do not know the intricacies of the PETSc/HYPRE/GPU interaction so maybe
>> > PETSc won't handle the CPU->GPU memcopies for you (I'm assuming vecs,
>> mats
>> > are assembled on the CPU) in which case you might need the option. And
>> if
>> > you do run into code paths in BoomerAMG that are not ported to the GPU
>> and
>> > you want to use them, I'd be very interested to know what the options
>> are
>> > that are missing a GPU port.
>> We have matrices and vectors assembled on the device and logic to pass
>> the device data to Hypre. Stefano knows the details.
>> Will the option --enable-unified-memory hurt performance if we provide
>> all data on the device?
> Yes. The way HYPRE's memory model is setup is that ALL GPU allocations are
> "native" (i.e. [cuda,hip]Malloc) or, if unified memory is enabled, then ALL
> GPU allocations are unified memory (i.e. [cuda,hip]MallocManaged).
> Regarding HIP, there is an HMM implementation of hipMallocManaged planned,
> but is it not yet delivered AFAIK (and it will *not* support gfx906, e.g.
> RVII, FYI), so, today, under the covers, hipMallocManaged is calling
> hipHostMalloc. So, today, all your unified memory allocations in HYPRE on
> HIP are doing CPU-pinned memory accesses. And performance is just truly
> terrible (as you might expect).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220121/78dc06bb/attachment-0001.html>
