[petsc-users] Cannot eagerly initialize cuda, as doing so results in cuda error 35 (cudaErrorInsufficientDriver) : CUDA driver version is insufficient for CUDA runtime version
Thu Jan 20 17:47:58 CST 2022
On Thu, Jan 20, 2022 at 6:44 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Thanks, Jed
> On Thu, Jan 20, 2022 at 4:34 PM Jed Brown <jed at jedbrown.org> wrote:
>> You can't create CUDA or Kokkos Vecs if you're running on a node without
>> a GPU.
> I am running the code on compute nodes that do have GPUs.
If you are actually running on GPUs, why would you need lazy
initialization? It would not break with GPUs present.
   Matt
> With PETSc-3.16.1, I  got good speedup by running GAMG on GPUs.  That
> might be a bug of PETSc-main.
> Thanks,
> Fande
> KSPSetUp              13 1.0 6.4400e-01 1.0 2.02e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  5  0  0  0   0  5  0  0  0  3140   64630     15 1.05e+02    5
> 3.49e+01 100
> KSPSolve               1 1.0 1.0109e+00 1.0 3.49e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00  0 87  0  0  0   0 87  0  0  0 34522   69556      4 4.35e-03    1
> 2.38e-03 100
> KSPGMRESOrthog       142 1.0 1.2674e-01 1.0 1.06e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00  0 27  0  0  0   0 27  0  0  0 83755   87801      0 0.00e+00    0
> 0.00e+00 100
> SNESSolve              1 1.0 4.4402e+01 1.0 4.00e+10 1.0 0.0e+00 0.0e+00
> 0.0e+00 21100  0  0  0  21100  0  0  0   901   51365     57 1.10e+03   52
> 8.78e+02 100
> SNESSetUp              1 1.0 3.9101e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> SNESFunctionEval       2 1.0 1.7097e+01 1.0 1.60e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  8  0  0  0  0   8  0  0  0  0     1       0      0 0.00e+00    6
> 1.92e+02  0
> SNESJacobianEval       1 1.0 1.6213e+01 1.0 2.80e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  8  0  0  0  0   8  0  0  0  0     2       0      0 0.00e+00    1
> 3.20e+01  0
> SNESLineSearch         1 1.0 8.5582e+00 1.0 1.24e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  4  0  0  0  0   4  0  0  0  0    14   64153      1 3.20e+01    3
> 9.61e+01 94
> PCGAMGGraph_AGG        5 1.0 3.0509e+00 1.0 8.19e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0    27       0      5 3.49e+01    9
> 7.43e+01  0
> PCGAMGCoarse_AGG       5 1.0 3.8711e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  2  0  0  0  0   2  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> PCGAMGProl_AGG         5 1.0 7.0748e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> PCGAMGPOpt_AGG         5 1.0 1.2904e+00 1.0 2.14e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  1  5  0  0  0   1  5  0  0  0  1661   29807     26 7.15e+02   20
> 2.90e+02 99
> GAMG: createProl       5 1.0 8.9489e+00 1.0 2.22e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  4  6  0  0  0   4  6  0  0  0   249   29666     31 7.50e+02   29
> 3.64e+02 96
>   Graph               10 1.0 3.0478e+00 1.0 8.19e+07 1.0 0.0e+00 0.0e+00
> 7.43e+01  0
>   MIS/Agg              5 1.0 4.1290e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
>   SA: col data         5 1.0 1.9127e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
>   SA: frmProl0         5 1.0 6.2662e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
>   SA: smooth           5 1.0 4.9595e-01 1.0 1.21e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   244    2709     15 1.97e+02   15
> 2.55e+02 90
> GAMG: partLevel        5 1.0 4.7330e-01 1.0 6.98e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  2  0  0  0   0  2  0  0  0  1475    4120      5 1.78e+02   10
> 2.55e+02 100
> PCGAMG Squ l00         1 1.0 2.6027e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  1  0  0  0  0   1  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> PCGAMG Gal l00         1 1.0 3.8406e-01 1.0 5.48e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   0  1  0  0  0  1426    4270      1 1.48e+02    2
> 2.11e+02 100
> PCGAMG Opt l00         1 1.0 2.4932e-01 1.0 7.20e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   289    2653      1 6.41e+01    1
> 1.13e+02 100
> PCGAMG Gal l01         1 1.0 6.6279e-02 1.0 1.09e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1645    3851      1 2.40e+01    2
> 3.64e+01 100
> PCGAMG Opt l01         1 1.0 2.9544e-02 1.0 7.15e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   242    1671      1 4.84e+00    1
> 1.23e+01 100
> PCGAMG Gal l02         1 1.0 1.8874e-02 1.0 3.72e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1974    3636      1 5.04e+00    2
> 6.58e+00 100
> PCGAMG Opt l02         1 1.0 7.4353e-03 1.0 2.40e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   323    1457      1 7.71e-01    1
> 2.30e+00 100
> PCGAMG Gal l03         1 1.0 2.8479e-03 1.0 4.10e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0  1440    2266      1 4.44e-01    2
> 5.51e-01 100
> PCGAMG Opt l03         1 1.0 8.2684e-04 1.0 2.80e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   339    1667      1 6.72e-02    1
> 2.03e-01 100
> PCGAMG Gal l04         1 1.0 1.2238e-03 1.0 2.09e+05 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0   170     244      1 2.05e-02    2
> 2.53e-02 100
> PCGAMG Opt l04         1 1.0 4.1008e-04 1.0 1.77e+04 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0    43     165      1 4.49e-03    1
> 1.19e-02 100
> PCSetUp                2 1.0 9.9632e+00 1.0 4.95e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  5 12  0  0  0   5 12  0  0  0   496   17826     55 1.03e+03   45
> 6.54e+02 98
> PCSetUpOnBlocks       44 1.0 9.9087e-04 1.0 2.88e+03 1.0
>> The point of lazy initialization is to make it possible to run a solve
>> that doesn't use a GPU in PETSC_ARCH that supports GPUs, regardless of
>> whether a GPU is actually present.
>> Fande Kong <fdkong.jd at gmail.com> writes:
>> > I spoke too soon. It seems that we have trouble creating cuda/kokkos
>> vecs
>> > now. Got Segmentation fault.
>> > Thanks,
>> > Fande
>> > Program received signal SIGSEGV, Segmentation fault.
>> > 0x00002aaab5558b11 in
>> Petsc::CUPMDevice<(Petsc::CUPMDeviceType)0>::CUPMDeviceInternal::initialize
>> > (this=0x1) at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:54
>> > 54 PetscErrorCode CUPMDevice<T>::CUPMDeviceInternal::initialize()
>> noexcept
>> > Missing separate debuginfos, use: debuginfo-install
>> > bzip2-libs-1.0.6-13.el7.x86_64 elfutils-libelf-0.176-5.el7.x86_64
>> > elfutils-libs-0.176-5.el7.x86_64 glibc-2.17-325.el7_9.x86_64
>> > libX11-1.6.7-4.el7_9.x86_64 libXau-1.0.8-2.1.el7.x86_64
>> > libattr-2.4.46-13.el7.x86_64 libcap-2.22-11.el7.x86_64
>> > libibmad-5.4.0.MLNX20190423.1d917ae-0.1.49224.x86_64
>> > libibumad-43.1.1.MLNX20200211.078947f-0.1.49224.x86_64
>> > libibverbs-41mlnx1-OFED.4.9.0.0.7.49224.x86_64
>> > libmlx4-41mlnx1-OFED.4.7.3.0.3.49224.x86_64
>> > libmlx5-41mlnx1-OFED.4.9.0.1.2.49224.x86_64 libnl3-3.2.28-4.el7.x86_64
>> > librdmacm-41mlnx1-OFED.4.7.3.0.6.49224.x86_64
>> > librxe-41mlnx1-OFED.4.4.2.4.6.49224.x86_64 libxcb-1.13-1.el7.x86_64
>> > libxml2-2.9.1-6.el7_9.6.x86_64 numactl-libs-2.0.12-5.el7.x86_64
>> > systemd-libs-219-78.el7_9.3.x86_64 xz-libs-5.2.2-1.el7.x86_64
>> > zlib-1.2.7-19.el7_9.x86_64
>> > (gdb) bt
>> > #0  0x00002aaab5558b11 in
>> > (this=0x1) at
>> > #1  0x00002aaab5558db7 in
>> > Petsc::CUPMDevice<(Petsc::CUPMDeviceType)0>::getDevice
>> > (this=this at entry=0x2aaab7f37b70
>> > <CUDADevice>, device=0x115da00, id=-35, id at entry=-1) at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:344
>> > #2  0x00002aaab55577de in PetscDeviceCreate (type=type at entry
>> =PETSC_DEVICE_CUDA,
>> > devid=devid at entry=-1, device=device at entry=0x2aaab7f37b48
>> > <defaultDevices+8>) at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:107
>> > #3  0x00002aaab5557b3a in PetscDeviceInitializeDefaultDevice_Internal
>> > (type=type at entry=PETSC_DEVICE_CUDA,
>> defaultDeviceId=defaultDeviceId at entry=-1)
>> > at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:273
>> > #4  0x00002aaab5557bf6 in PetscDeviceInitialize
>> > (type=type at entry=PETSC_DEVICE_CUDA)
>> > at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:234
>> > #5  0x00002aaab5661fcd in VecCreate_SeqCUDA (V=0x115d150) at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/impls/seq/seqcuda/veccuda.c:244
>> > #6  0x00002aaab5649b40 in VecSetType (vec=vec at entry=0x115d150,
>> > method=method at entry=0x2aaab70b45b8 "seqcuda") at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vecreg.c:93
>> > #7  0x00002aaab579c33f in VecCreate_CUDA (v=0x115d150) at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/impls/mpi/mpicuda/
>> > mpicuda.cu:214
>> > #8  0x00002aaab5649b40 in VecSetType (vec=vec at entry=0x115d150,
>> > method=method at entry=0x7fffffff9260 "cuda") at
>> > #9  0x00002aaab5648bf1 in VecSetTypeFromOptions_Private (vec=0x115d150,
>> > PetscOptionsObject=0x7fffffff9210) at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vector.c:1263
>> > #10 VecSetFromOptions (vec=0x115d150) at
>> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/vec/vec/interface/vector.c:1297
>> > #11 0x00002aaab02ef227 in libMesh::PetscVector<double>::init
>> > (this=0x11cd1a0, n=441, n_local=441, fast=false,
>> ptype=libMesh::PARALLEL)
>> > at
>> /home/kongf/workhome/sawtooth/moosegpu/scripts/../libmesh/installed/include/libmesh/petsc_vector.h:693
>> > On Thu, Jan 20, 2022 at 1:09 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> >> Thanks, Jed,
>> >> This worked!
>> >> Fande
>> >> On Wed, Jan 19, 2022 at 11:03 PM Jed Brown <jed at jedbrown.org> wrote:
>> >>> > On Wed, Jan 19, 2022 at 11:39 AM Jacob Faibussowitsch <
>> >>> jacob.fai at gmail.com>
>> >>> > wrote:
>> >>> >> Are you running on login nodes or compute nodes (I can’t seem to
>> tell
>> >>> from
>> >>> >> the configure.log)?
>> >>> > I was compiling codes on login nodes, and running codes on compute
>> >>> nodes.
>> >>> > Login nodes do not have GPUs, but compute nodes do have GPUs.
>> >>> > Just to be clear, the same thing (code, machine) with PETSc-3.16.1
>> >>> worked
>> >>> > perfectly. I have this trouble with PETSc-main.
>> >>> I assume you can
>> >>> export PETSC_OPTIONS='-device_enable lazy'
>> >>> and it'll work.
>> >>> I think this should be the default. The main complaint is that timing
>> the
>> >>> first GPU-using event isn't accurate if it includes initialization,
>> but I
>> >>> think this is mostly hypothetical because you can't trust any timing
>> that
>> >>> doesn't preload in some form and the first GPU-using event will almost
>> >>> always be something uninteresting so I think it will rarely lead to
>> >>> confusion. Meanwhile, eager initialization is viscerally disruptive
>> for
>> >>> lots of people.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220120/fe894247/attachment-0001.html>
