[petsc-users] Does mpiaijkok intend to support 64-bit integers?
Mark Adams
mfadams at lbl.gov
Thu Jan 20 07:49:33 CST 2022
Humm, I was not able to reproduce this on my Mac. Trying Crusher now.
Are you using main? or even a recent release. We did fix a 64 bit int bug
recently in mpiaijkok.
On Thu, Jan 20, 2022 at 12:12 AM Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi All,
> It seems that mpiaijkok does not support 64-bit integers at this time. Do
> we have any motivation for this? Or Is it just a bug?
> Thanks,
> Fande
> petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx(306): error: a
> value of type "MatColumnIndexType *" cannot be assigned to an entity of
> type "int *"
> petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx(308): error: a
> value of type "PetscInt *" cannot be assigned to an entity of type "int *"
> petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx(310): error: a
> petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx(316): error: a
> type "int *"
> petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx(329): error: a
> petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx(331): error: a
> 6 errors detected in the compilation of
> "/tmp/tmpxft_00017e46_00000000-6_mpiaijkok.kokkos.cpp1.ii".
> gmake[3]: *** [arch-linux-c-opt/obj/mat/impls/aij/mpi/kokkos/mpiaijkok.o]
> Error 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220120/585a0ad1/attachment.html>
