[petsc-users] Cannot eagerly initialize cuda, as doing so results in cuda error 35 (cudaErrorInsufficientDriver) : CUDA driver version is insufficient for CUDA runtime version
Fande Kong fdkong.jd at gmail.com
Wed Jan 19 12:07:20 CST 2022
Thanks, Jacob, and Junchao
The log was attached.  I am using Sawtooth at INL
https://hpc.inl.gov/SitePages/Home.aspx
Fande
On Wed, Jan 19, 2022 at 10:32 AM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> Hi Fande,
> What machine are you running this on? Please attach configure.log so I can
> troubleshoot this.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> On Jan 19, 2022, at 10:04, Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi All,
> Upgraded PETSc from 3.16.1 to the current main branch. I suddenly got the
> following error message:
> 2d_diffusion]$ ../../../moose_test-dbg -i 2d_diffusion_test.i
> -use_gpu_aware_mpi 0 -gpu_mat_type aijcusparse -gpu_vec_type cuda
>  -log_view
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Missing or incorrect user input
> [0]PETSC ERROR: Cannot eagerly initialize cuda, as doing so results in
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.16.3-618-gad32f7e  GIT
> Date: 2022-01-18 16:04:31 +0000
> [0]PETSC ERROR: ../../../moose_test-dbg on a arch-linux-c-opt named r8i3n0
> by kongf Wed Jan 19 08:30:13 2022
> [0]PETSC ERROR: Configure options --with-debugging=no
> --with-shared-libraries=1 --download-fblaslapack=1 --download-metis=1
> --download-ptscotch=1 --download-parmetis=1 --download-mumps=1
> --download-strumpack=1 --download-scalapack=1 --download-slepc=1
> --with-mpi=1 --with-cxx-dialect=C++14 --with-fortran-bindings=0
> --with-sowing=0 --with-64-bit-indices --with-make-np=24 --with-cuda
> --with-cudac=nvcc --with-cuda-arch=70 --download-kokkos=1
> [0]PETSC ERROR: #1 initialize() at
> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:298
> [0]PETSC ERROR: #2 PetscDeviceInitializeTypeFromOptions_Private() at
> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:299
> [0]PETSC ERROR: #3 PetscDeviceInitializeFromOptions_Internal() at
> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/device/interface/device.cxx:425
> [0]PETSC ERROR: #4 PetscInitialize_Common() at
> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/pinit.c:963
> [0]PETSC ERROR: #5 PetscInitialize() at
> /home/kongf/workhome/sawtooth/moosegpu/petsc/src/sys/objects/pinit.c:1238
> [0]PETSC ERROR: #6 SlepcInitialize() at
> /home/kongf/workhome/sawtooth/moosegpu/petsc/arch-linux-c-opt/externalpackages/git.slepc/src/sys/slepcinit.c:275
> [0]PETSC ERROR: #7 LibMeshInit() at ../src/base/libmesh.C:522
> [r8i3n0:mpi_rank_0][MPIDI_CH3_Abort] application called
> MPI_Abort(MPI_COMM_WORLD, 95) - process 0: No such file or directory (2)
> Thanks,
> Fande
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220119/275bd953/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220119/275bd953/attachment-0001.obj>
