[petsc-users] Nullspaces
Mark Adams
mfadams at lbl.gov
Wed Jan 19 08:15:31 CST 2022
ILU is LU for this 1D problem and its singular.
ILU might have some logic to deal with a singular system. Not sure. LU
should fail.
You might try -ksp_type preonly and -pc_type lu
And -pc_type jacobi should not have any numerical problems. Try that.
On Wed, Jan 19, 2022 at 7:19 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 19, 2022 at 4:52 AM Marco Cisternino <
> marco.cisternino at optimad.it> wrote:
>> Thank you Matthew.
>> But I cannot get the point. I got the point about the test but to try to
>> explain my doubt I’m going to prepare another toy code.
>> By words…
>> I usually have a finite volume discretization of the Laplace operator
>> with homogeneous Neumann BC on an octree mesh and it reads
>> Aij * xj = bi,
>> being the discretization of
>> Int|Vi(nabla^2 pi dV) = Int|Vi(nabla dot ui)
>> (I omit constants), where Int|Vi(…dV) is a volume integral on the I cell,
>> pi is cell pressure, ui is the cell velocity.
>> The computational domain contains 2 separated sub-domains.
>> Let’s consider 4 cells into the whole domain and 2 cells for each
>> sub-domain.
>> I would expect a null space made of 2 vectors and from your patch they
>> should look like [1/sqrt(2) 1/sqrt(2) 0 0] and [0 0 1/sqrt(2) 1/sqrt(2)],
>> i.e. norm2 = 1 for both.
>> With MatNullSpaceCreate(getCommunicator(), PETSC_TRUE, 0, nullptr,
>> &nullspace) I’m saying that [1/sqrt(4) 1/sqrt(4) 1/sqrt(4) 1/sqrt(4)] is
>> the null space, which is not but it is in the null space.
>> But this is not the case I sent you, not exactly.
>> The case I sent is 1/Vi * Aij * xj = 1/Vi bi, where Vi is the volume of
>> the cell i.
>> Let’s admit that yj is in the null space of of Aij, it should be in the
>> null space of 1/Vi * Aij, therefore Aij*yj = 0 and 1/Vi * Aij*yj = 0 too.
>> But in the framework of the test, this is true with infinite precision.
>> What happens if norm2(Aij*yj) = 10^-15 and Vi = 10^-5? Norm2(1/Vi * Aij
>> * yj) = 10^-10!!! Is yi still in the null space numerically?
>> Let’s say yi is the constant vector over the whole domain, i.e.
>> [1/sqrt(4) 1/sqrt(4) 1/sqrt(4) 1/sqrt(4)]. Should this be in the null space
>> of 1/Vi * Aij, shouldn’t it?
>> An analogous argument should be for the compatibility condition that
>> concerns bi.
>> My current problem is that properly creating the null space for Aij, i.e.
>> [1/sqrt(2) 1/sqrt(2) 0 0] and [0 0 1/sqrt(2) 1/sqrt(2)], allows me to solve
>> and find xi, but multiplying by 1/Vi, I cannot get any solution using both
>> FGMRES+ILU and FGMRE+GAMG.
>> The tiny problem will load Aij, Vi and bi and show the problem by testing
>> the proper null space and trying to solve. I will include the patch to my
>> PETSc version. I hope to come back to you very soon.
> This sounds like a dimensionalization problem to me. It is best to choose
> length (and other) units that make the matrix entries about 1. It seems
> like you are far from this, and it is causing a loss of accuracy (your
> null vector has a residual of about 1e-7).
> Thanks,
> Matt
>> Thank you very much for your support!
>> Marco Cisternino
>> *From:* Matthew Knepley <knepley at gmail.com>
>> *Sent:* martedì 18 gennaio 2022 21:25
>> *To:* Marco Cisternino <marco.cisternino at optimad.it>
>> *Cc:* petsc-users <petsc-users at mcs.anl.gov>
>> *Subject:* Re: [petsc-users] Nullspaces
>> I made a fix for this:
>> https://gitlab.com/petsc/petsc/-/merge_requests/4729
>> Thanks,
>> Matt
>> On Tue, Jan 18, 2022 at 3:20 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>> On Thu, Dec 16, 2021 at 11:09 AM Marco Cisternino <
>> Hello Matthew,
>> as promised I prepared a minimal (112960 rows. I’m not able to produce
>> anything smaller than this and triggering the issue) example of the
>> behavior I was talking about some days ago.
>> What I did is to produce matrix, right hand side and initial solution of
>> the linear system.
>> As I told you before, this linear system is the discretization of the
>> pressure equation of a predictor-corrector method for NS equations in the
>> framework of finite volume method.
>> This case has homogeneous Neumann boundary conditions. Computational
>> domain has two independent and separated sub-domains.
>> I discretize the weak formulation and I divide every row of the linear
>> system by the volume of the relative cell.
>> The underlying mesh is not uniform, therefore cells have different
>> volumes.
>> The issue I’m going to explain does not show up if the mesh is uniform,
>> same volume for all the cells.
>> I usually build the null space sub-domain by sub-domain with
>> MatNullSpaceCreate(getCommunicator(), PETSC_FALSE, nConstants, constants,
>> &nullspace);
>> Where nConstants = 2 and constants contains two normalized arrays with
>> constant values on degrees of freedom relative to the associated sub-domain
>> and zeros elsewhere.
>> However, as a test I tried the constant over the whole domain using 2
>> alternatives that should produce the same null space:
>> 1. MatNullSpaceCreate(getCommunicator(), PETSC_TRUE, 0, nullptr,
>> &nullspace);
>> 2. Vec* nsp;
>> VecDuplicateVecs(solution, 1, &nsp);
>> VecSet(nsp[0],1.0);
>> VecNormalize(nsp[0], nullptr);
>> MatNullSpaceCreate(getCommunicator(), PETSC_FALSE, 1, nsp, &nullspace);
>> Once I created the null space I test it using:
>> MatNullSpaceTest(nullspace, m_A, &isNullSpaceValid);
>> The case 1 pass the test while case 2 don’t.
>> I have a small code for matrix loading, null spaces creation and testing.
>> Unfortunately I cannot implement a small code able to produce that linear
>> system.
>> As attachment you can find an archive containing the matrix, the initial
>> solution (used to manually build the null space) and the rhs (not used in
>> the test code) in binary format.
>> You can also find the testing code in the same archive.
>> I used petsc 3.12(gcc+openMPI) and petsc 3.15.2(intelOneAPI) same results.
>> If the attachment is not delivered, I can share a link to it.
>> Marco, please forgive me for taking so long to get to your issue. It has
>> been crazy.
>> You are correct, we had a bug. it is in MatNullSpaceTest. The
>> normalization for the constant vector was wrong:
>> diff --git a/src/mat/interface/matnull.c b/src/mat/interface/matnull.c
>> index f8ab2925988..0c4c3855be0 100644
>> --- a/src/mat/interface/matnull.c
>> +++ b/src/mat/interface/matnull.c
>> @@ -429,7 +429,7 @@ PetscErrorCode MatNullSpaceTest(MatNullSpace sp,Mat
>> mat,PetscBool *isNull)
>> if (sp->has_cnst) {
>> ierr = VecDuplicate(l,&r);CHKERRQ(ierr);
>> ierr = VecGetSize(l,&N);CHKERRQ(ierr);
>> - sum = 1.0/N;
>> + sum = 1.0/PetscSqrtReal(N);
>> ierr = VecSet(l,sum);CHKERRQ(ierr);
>> ierr = MatMult(mat,l,r);CHKERRQ(ierr);
>> ierr = VecNorm(r,NORM_2,&nrm);CHKERRQ(ierr);
>> With this fix, your two cases give the same answer, namely that the
>> constant vector is not a null vector of your
>> operator, but it is close, as your can see
>> using -mat_null_space_test_view.
>> Thanks,
>> Matt
>> Thanks for any help.
>> Marco Cisternino
>> Marco Cisternino, PhD
>> ______________________
>> Optimad Engineering Srl
>> Via Bligny 5, Torino, Italia.
>> +3901119719782
>> www.optimad.it
>> *From:* Marco Cisternino <marco.cisternino at optimad.it>
>> *Sent:* martedì 7 dicembre 2021 19:36
>> *To:* Matthew Knepley <knepley at gmail.com>
>> I will, as soon as possible...
>> Scarica Outlook per Android <https://aka.ms/AAb9ysg>
>> *Sent:* Tuesday, December 7, 2021 7:25:43 PM
>> On Tue, Dec 7, 2021 at 11:19 AM Marco Cisternino <
>> Good morning,
>> I’m still struggling with the Poisson equation with Neumann BCs.
>> I discretize the equation by finite volume method and I divide every line
>> of the linear system by the volume of the cell. I could avoid this
>> division, but I’m trying to understand.
>> My mesh is not uniform, i.e. cells have different volumes (it is an
>> octree mesh).
>> Moreover, in my computational domain there are 2 separated sub-domains.
>> I build the null space and then I use MatNullSpaceTest to check it.
>> If I do this:
>> MatNullSpaceCreate(getCommunicator(), PETSC_TRUE, 0, nullptr, &nullspace);
>> It works
>> This produces the normalized constant vector.
>> If I do this:
>> Vec nsp;
>> VecDuplicate(m_rhs, &nsp);
>> VecSet(nsp,1.0);
>> VecNormalize(nsp, nullptr);
>> MatNullSpaceCreate(getCommunicator(), PETSC_FALSE, 1, &nsp, &nullspace);
>> It does not work
>> This is also the normalized constant vector.
>> So you are saying that these two vectors give different results with
>> MatNullSpaceTest()?
>> Something must be wrong in the code. Can you send a minimal example of
>> this? I will go
>> through and debug it.
>> Thanks,
>> Matt
>> Probably, I have wrong expectations, but should not it be the same?
>> Thanks
>> +3901119719782
>> www.optimad.it
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220119/744ecb00/attachment-0001.html>
