[petsc-users] PETSc MUMPS interface
Varun Hiremath
varunhiremath at gmail.com
Sun Jan 16 03:40:16 CST 2022
Hi Hong,
Thank you, this is very helpful!
Using this method I am able to get the memory estimates before the actual
solve, however, I think my code may be causing the symbolic
factorization to be run twice. Attached is my code where I am using SLEPc
to compute eigenvalues, and I use MUMPS for factorization. I have commented
above the code that computes the memory estimates, could you please check
and tell me if this would cause the symbolic factor to be computed twice (a
second time inside EPSSolve?), as I am seeing a slight increase in the
overall computation time?
Varun
On Wed, Jan 12, 2022 at 7:58 AM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> PCFactorSetMatSolverType(pc,MATSOLVERMUMPS);
> PCFactorSetUpMatSolverType(pc);
> PCFactorGetMatrix(pc,&F);
> MatLUFactorSymbolic(F,A,...)
> You must provide row and column permutations etc,
> petsc/src/mat/tests/ex125.c may give you a clue on how to get these
> inputs.
> Hong
> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of
> Junchao Zhang <junchao.zhang at gmail.com>
> *Sent:* Wednesday, January 12, 2022 9:03 AM
> *To:* Varun Hiremath <varunhiremath at gmail.com>
> *Cc:* Peder Jørgensgaard Olesen via petsc-users <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] PETSc MUMPS interface
> Calling PCSetUp() before KSPSetUp()?
> --Junchao Zhang
> On Wed, Jan 12, 2022 at 3:00 AM Varun Hiremath <varunhiremath at gmail.com>
> wrote:
> Hi All,
> I want to collect MUMPS memory estimates based on the initial
> symbolic factorization analysis before the actual numerical factorization
> starts to check if the estimated memory requirements fit the available
> memory.
> I am following the steps from
> https://petsc.org/main/src/ksp/ksp/tutorials/ex52.c.html
> KSPSetUp(ksp);
> MatMumpsGetInfog(F,...)
> But it appears KSPSetUp calls both symbolic and numerical factorization.
> So is there some other way to get these statistics before the actual
> factorization starts?
> Thanks,
> Varun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220116/935dd954/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220116/935dd954/attachment.obj>
