[petsc-users] DMPlex filter with Face Sets
    Thibault Bridel-Bertomeu
    thibault.bridelbertomeu at gmail.com
    Sat Jan 15 10:58:55 CST 2022
Le sam. 15 janv. 2022 à 15:23, Jed Brown <jed at jedbrown.org> a écrit :
> Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com> writes:
> > I think it would be perfect if the 0-sized labels were also completely
> > filtered out. Is that something that you could add to the
> > DMPlexFliterLabels_Internal function ?
> Why do you want it filtered? Determining that it's zero sized requires all
> processes agreeing, and DMAddBoundary is collective so *no* ranks can add a
> boundary condition unless the label exists on *all* ranks (even if zero
> sized on many).
Well, an empty boundary condition globally-speaking will not be used -
that’s my main argument for taking it out altogether.
I understand that a bunch of extra Allgather might be too costly if many
calls to DMPlexFilter are made, but  if the users know that they’ll call it
maybe only once or twice, then it would make sense to clean the filtered
pieces. What about an option for the DMPlexFilter set to false by default
to prevent extra MPI comms?
Eng, MSc, PhD
Research Engineer
CEA/CESTA
33114 LE BARP
Tel.: (+33)557046924
Mob.: (+33)611025322
Mail: thibault.bridelbertomeu at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220115/15abc944/attachment-0001.html>
