[petsc-users] Strange CUDA failure with a second petscfinalize with PETSc 3.16
    Jacob Faibussowitsch
    jacob.fai at gmail.com
    Sat Jan 15 10:12:25 CST 2022
I don’t quite understand how it is getting to the CUDA error to be honest. None of the code in the stack trace is anywhere near the device code. Reading the error message carefully, it first chokes on PetscLogGetStageLog() from a call to PetscClassIdRegister():
PetscErrorCode PetscLogGetStageLog(PetscStageLog *stageLog)
  PetscFunctionBegin;
  PetscValidPointer(stageLog,1);
  if (!petsc_stageLog) {
    fprintf(stderr, "PETSC ERROR: Logging has not been enabled.\nYou might have forgotten to call PetscInitialize().\n");
    PETSCABORT(MPI_COMM_WORLD, PETSC_ERR_SUP); // Here
But then jumps to PetscFinalize(). You can also see the "You might have forgotten to call PetscInitialize().” message in the error message, just under the topmost level of the stack trace.
Can you check the value of ierr of each function call (use the CHKERRA() macro to do so)? I suspect the problem here that errors occurring previously in the program are being ignored, leading to the garbled stack trace.
Best regards,
(Jacob Fai - booss - oh - vitch)
> On Jan 14, 2022, at 20:58, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> Jacob,
>    Could you have a look as it seems the "invalid device context" is in your newly added module?
>    Thanks
> --Junchao Zhang
> On Fri, Jan 14, 2022 at 12:49 AM Hao DONG <dong-hao at outlook.com <mailto:dong-hao at outlook.com>> wrote:
> Dear All,
> I have encountered a peculiar problem when fiddling with a code with PETSC 3.16.3 (which worked fine with PETSc 3.15). It is a very straight forward PDE-based optimization code which repeatedly solves a linearized PDE problem with KSP in a subroutine (the rest of the code does not contain any PETSc related content). The main program provides the subroutine with an MPI comm. Then I set the comm as PETSC_COMM_WORLD to tell PETSC to attach to it (and detach with it when the solving is finished each time).
> Strangely, I observe a CUDA failure whenever the petscfinalize is called for a *second* time.  In other words, the first and second PDE calculations with GPU are fine (with correct solutions). The petsc code just fails after the SECOND petscfinalize command is called. You can also see the PETSC config in the error message:
> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [1]PETSC ERROR: GPU error
> [1]PETSC ERROR: cuda error 201 (cudaErrorDeviceUninitialized) : invalid device context
> [1]PETSC ERROR: See https://petsc.org/release/faq/ <https://petsc.org/release/faq/> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.16.3, unknown
> [1]PETSC ERROR: maxwell.gpu on a  named stratosphere by hao Fri Jan 14 10:21:05 2022
> [1]PETSC ERROR: Configure options --prefix=/opt/petsc/complex-double-with-cuda --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 COPTFLAGS="-O3 -mavx2" CXXOPTFLAGS="-O3 -mavx2" FOPTFLAGS="-O3 -ffree-line-length-none -mavx2" CUDAOPTFLAGS=-O3 --with-cxx-dialect=cxx14 --with-cuda-dialect=cxx14 --with-scalar-type=complex --with-precision=double --with-cuda-dir=/usr/local/cuda --with-debugging=1
> [1]PETSC ERROR: #1 PetscFinalize() at /home/hao/packages/petsc-current/src/sys/objects/pinit.c:1638
> The EXACT line numbers in the error traceback are not available.
> Instead the line number of the start of the function is given.
> [1] #1 PetscAbortFindSourceFile_Private() at /home/hao/packages/petsc-current/src/sys/error/err.c:35
> [1] #2 PetscLogGetStageLog() at /home/hao/packages/petsc-current/src/sys/logging/utils/stagelog.c:29
> [1] #3 PetscClassIdRegister() at /home/hao/packages/petsc-current/src/sys/logging/plog.c:2376
> [1] #4 MatMFFDInitializePackage() at /home/hao/packages/petsc-current/src/mat/impls/mffd/mffd.c:45
> [1] #5 MatInitializePackage() at /home/hao/packages/petsc-current/src/mat/interface/dlregismat.c:163
> [1] #6 MatCreate() at /home/hao/packages/petsc-current/src/mat/utils/gcreate.c:77
> However, it doesn’t seem to affect the other part of my code, so the code can continue running until it gets to the petsc part again (the *third* time). Unfortunately, it doesn’t give me any further information even if I set the debugging to yes in the configure file. It also worth noting that PETSC without CUDA (i.e. with simple MATMPIAIJ) works perfectly fine.
> I am able to re-produce the problem with a toy code modified from ex11f. Please see the attached file (ex11fc.F90) for details. Essentially  the code does the same thing as ex11f, but three times with a do loop. To do that I added an extra MPI_INIT/MPI_FINALIZE to ensure that the MPI communicator is not destroyed when PETSC_FINALIZE is called.  I used the PetscOptionsHasName utility to check if you have “-usecuda” in the options. So running the code with and without that option can give you a comparison w/o CUDA. I can see that the code also fails after the second loop of the KSP operation. Could you kindly shed some lights on this problem?
> I should say that I am not even sure if the problem is from PETSc, as I also accidentally updated the NVIDIA driver (for now it is 510.06 with cuda 11.6). And it is well known that NVIDIA can give you some surprise in the updates (yes, I know I shouldn’t have touched that if it’s not broken). But my CUDA code without PETSC (which basically does the same PDE thing, but with cusparse/cublas directly) seems to work just fine after the update. It is also possible that my petsc code related to CUDA was not quite “legitimate” – I just use:
>           MatSetType(A, MATMPIAIJCUSPARSE, ierr)
> and
>           MatCreateVecs(A, u, PETSC_NULL_VEC, ierr)
> to make the data onto GPU. I would very much appreciate it if you could show me the “right” way to do that.
> Thanks a lot in advance, and all the best,
> Hao
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220115/7ceda355/attachment.html>
