[petsc-users] DMPlex filter with Face Sets
Thibault Bridel-Bertomeu
thibault.bridelbertomeu at gmail.com
Sat Jan 15 06:07:23 CST 2022
Le ven. 14 janv. 2022 à 15:52, Matthew Knepley <knepley at gmail.com> a écrit :
> On Fri, Jan 14, 2022 at 9:48 AM Lawrence Mitchell <wencel at gmail.com>
> wrote:
>> > On 14 Jan 2022, at 14:12, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Fri, Jan 14, 2022 at 9:07 AM Thibault Bridel-Bertomeu <
>> thibault.bridelbertomeu at gmail.com> wrote:
>> > Also, if we still consider my example with Solid and Fluid, let's image
>> we call DMPlexFilter twice. We then get two new DMs with Solid in one and
>> Fluid in the other one.
>> > The labels will be communicated, so fluidDM will still know Wall,
>> Inlet, Freestream and Outlet and on the other hand, solidDM will still know
>> Wall and Insulation : those two domain share the Wall stratum of the Face
>> Sets.
>> > Can I extract data at the Wall label from the solidDM and transfer it
>> to the Wall label of the fluidDM ?
>> > Yes, conceptually here is how that would work. You iterate over the
>> label, extracting the values you want. You map those points
>> > to points in the original mesh using the subpointMap, and then map them
>> again using the subpointMap from the fluidDM down to it.
>> > Now you can insert the values using the section in the fluidDM. I think
>> the easiest way to do this is to setup a VecScatter (or PetscSF)
>> > from one boundary to the other. Then you would just stick in the two
>> vectors and call VecScatterBegin/End()
>> > If this turns out to be useful, this construction is something we could
>> easily automate in the library.
>> I've needed this too, I think I have some code lying around, let me see
>> if I can port it into DMPlexFilter..
Hi Lawrence,
Thank you so much, that would be great ! Would you mind sending the
original snippet of code, maybe I can figure it out ?
> I did the initial implementation for the label filtering. It is here
> https://gitlab.com/petsc/petsc/-/merge_requests/4717
> Thibault, can you try it on your example? I will not have time to code up
> a nice test until I get home from this conference.
Hi Matt,
Thank you for the quick mod.
It works well, the labels are passed down to the filtered DMPlex as we can
see in the example below :
// Overall plex :
DM Object: CoupledPhysics_Plex 1 MPI processes
type: plex
CoupledPhysics_Plex in 2 dimensions:
Number of 0-cells per rank: 1409
Number of 1-cells per rank: 4084
Number of 2-cells per rank: 2676
Labels:
celltype: 3 strata with value/size (0 (1409), 3 (2676), 1 (4084))
depth: 3 strata with value/size (0 (1409), 1 (4084), 2 (2676))
Cell Sets: 2 strata with value/size (1 (924), 2 (1752))
Solid: 1 strata with value/size (1 (924))
Fluid: 1 strata with value/size (2 (1752))
Face Sets: 5 strata with value/size (4 (60), 3 (40), 7 (20), 5 (40), 6
(20))
Insulation: 1 strata with value/size (4 (60))
Wall: 1 strata with value/size (3 (40))
Outlet: 1 strata with value/size (7 (20))
Freestream: 1 strata with value/size (5 (40))
Inlet: 1 strata with value/size (6 (20))
// Fluid plex :
DM Object: 1 MPI processes
type: plex
DM_0x12471c2f0_1 in 2 dimensions:
Number of 0-cells per rank: 937
Number of 1-cells per rank: 2688
Number of 2-cells per rank: 1752
Labels:
celltype: 3 strata with value/size (0 (937), 1 (2688), 3 (1752))
depth: 3 strata with value/size (0 (937), 1 (2688), 2 (1752))
Cell Sets: 1 strata with value/size (2 (1752))
Solid: 0 strata with value/size ()
Face Sets: 4 strata with value/size (3 (40), 7 (20), 5 (40), 6 (20))
Insulation: 0 strata with value/size ()
// Solid plex :
type: plex
DM_0x12471c2f0_2 in 2 dimensions:
Number of 0-cells per rank: 513
Number of 1-cells per rank: 1436
Number of 2-cells per rank: 924
Labels:
celltype: 3 strata with value/size (0 (513), 1 (1436), 3 (924))
depth: 3 strata with value/size (0 (513), 1 (1436), 2 (924))
Cell Sets: 1 strata with value/size (1 (924))
Fluid: 0 strata with value/size ()
Face Sets: 2 strata with value/size (4 (60), 3 (40))
Outlet: 0 strata with value/size ()
Freestream: 0 strata with value/size ()
Inlet: 0 strata with value/size ()
I think it would be perfect if the 0-sized labels were also completely
filtered out. Is that something that you could add to the
DMPlexFliterLabels_Internal function ?
By the way, I believe there is a typo in the name of the function, it
should read "F*il*ter".
Thanks again !!
Thibault
> Matt
>> Lawrence
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220115/e7d04863/attachment-0001.html>
