[petsc-users] PCSetCoordinates does not set coordinates of sub PC (fieldsplit) objects
Nicolás Barnafi
nabw91 at gmail.com
Thu Jan 13 12:14:59 CST 2022
Dear all,
I have created a first implementation. For now it must be called after
setting the fields, eventually I would like to move it to the setup phase.
The implementation seems clean, but it is giving me some memory errors
(free() corrupted unsorted chunks).
You may find the code below. After some work with gdb, I found out that the
errors appears when calling the ISDestroy(&is_coords) line, which to me is
not very clear, as I am indeed within the while scope creating and then
destroying the is_coords object. I would greatly appreciate it if you could
give me a hint on what the problem is.
After debugging this, and working on your suggestion, I will open a PR.
Best regards,
NB
----- CODE ------
static PetscErrorCode PCSetCoordinates_FieldSplit(PC pc, PetscInt dim,
PetscInt nloc, PetscReal coords[])
PetscErrorCode ierr;
PC_FieldSplit *jac = (PC_FieldSplit*)pc->data;
PC_FieldSplitLink ilink_current = jac->head;
PC pc_current;
PetscInt nmin, nmax, ii, ndofs;
PetscInt *owned_dofs; // Indexes owned by this processor
PetscReal *coords_block; // Coordinates to be given to the current PC
IS is_owned;
PetscFunctionBegin;
// Extract matrix ownership range to then compute subindexes for
coordinates. This results in an IS object (is_owned).
// TODO: This would be simpler with a general MatGetOwnershipIS
(currently supported only by Elemental and BLAS matrices).
ierr = MatGetOwnershipRange(pc->mat,&nmin,&nmax);CHKERRQ(ierr);
ndofs = nmax - nmin;
ierr = PetscMalloc1(ndofs, &owned_dofs); CHKERRQ(ierr);
for(PetscInt i=nmin;i<ndofs;++i)
owned_dofs[i] = nmin + i;
ierr = ISCreateGeneral(MPI_COMM_WORLD, ndofs, owned_dofs,
PETSC_OWN_POINTER, &is_owned); CHKERRQ(ierr);
// For each IS, embed it to get local coords indces and then set
coordinates in the subPC.
ii=0;
while(ilink_current)
IS is_coords;
PetscInt ndofs_block;
const PetscInt *block_dofs_enumeration; // Numbering of the dofs
relevant to the current block
ierr = ISEmbed(ilink_current->is, is_owned, PETSC_TRUE, &is_coords);
CHKERRQ(ierr); // Setting drop to TRUE, although it should make no
difference.
ierr = PetscMalloc1(ndofs_block, &coords_block); CHKERRQ(ierr);
ierr = ISGetLocalSize(is_coords, &ndofs_block); CHKERRQ(ierr);
ierr = ISGetIndices(is_coords, &block_dofs_enumeration); CHKERRQ(ierr);
// Having the indices computed and the memory allocated, we can copy
the relevant coords and set them to the subPC.
for(PetscInt dof=0;dof<ndofs_block;++dof)
for(PetscInt d=0;d<dim;++d)
coords_block[dim*dof + d] = coords[dim *
block_dofs_enumeration[dof] + d];
// printf("Dof: %d, Global: %f\n", block_dofs_enumeration[dof],
coords[dim * block_dofs_enumeration[dof] + d]);
ierr = ISRestoreIndices(is_coords, &block_dofs_enumeration);
CHKERRQ(ierr);
ierr = ISDestroy(&is_coords); CHKERRQ(ierr);
ierr = KSPGetPC(ilink_current->ksp, &pc_current); CHKERRQ(ierr);
ierr = PCSetCoordinates(pc_current, dim, ndofs_block, coords_block);
CHKERRQ(ierr);
ierr = PetscFree(coords_block); CHKERRQ(ierr);
if(!pc_current)
SETERRQ(PetscObjectComm((PetscObject)pc),PETSC_ERR_ORDER,"Setting
coordinates to PCFIELDSPLIT but a subPC is null.");
ilink_current = ilink_current->next;
++ii;
ierr = PetscFree(owned_dofs); CHKERRQ(ierr);
PetscFunctionReturn(0);
On Wed, Jan 12, 2022 at 6:22 AM Barry Smith <bsmith at petsc.dev> wrote:
> On Jan 11, 2022, at 9:51 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jan 11, 2022 at 3:31 PM Barry Smith <bsmith at petsc.dev> wrote:
>> Nicolas,
>> For "simple" PCFIELDSPLIT it is possible to pass down the attached
>> coordinate information. By simple I mean where the splitting is done by
>> fields and not by general lists of IS (where one does not have enough
>> information to know what the coordinates would mean to the subPCS).
>> Look in fieldsplit.c PCFieldSplitSetFields_FieldSplit() where it does
>> the KSPCreate(). I think you can do a KSPGetPC() on that ksp and
>> PCSetCoordinates on that PC to supply the coordinates to the subPC. In the
>> function PCFieldSplitSetIS_FieldSplit() you can also attach the coordinates
>> to the subPCs IF defaultsplit is true.
>> Sadly this is not the full story. The outer PC will not have any
>> coordinates because calling PCSetCoordinates on a PCFIELDSPLIT does nothing
>> since fieldsplit doesn't handle coordinates. So you need to do more, you
>> need to provide a PCSetCoordinates_FieldSplit() that saves the coordinates
>> in new entries in the PC_FieldSplit struct and then in
>> PCFieldSplitSetFields_FieldSplit() you need to access those saved values
>> and pass them into the PCSetCoordinates() that you call on the subPCs. Once
>> you write
>> PCSetCoordinates_FieldSplit() you need to call
>> ierr =
>> PetscObjectComposeFunction((PetscObject)pc,"PCSetCoordinates_C",PCSetCoordinates_FieldSplit);CHKERRQ(ierr);
>> inside PCCreate_FieldSplit().
>> Any questions just let us know.
> I will add "Why is this so cumbersome?". This is a workaround in order to
> get geometric information into GAMG. It should really be
> PCGAMGSetCoordinates(), which
> are used to calculate the rigid body modes, and assume a bunch of stuff
> about the coordinate space. This would not help you, because it would still
> force you to pull
> out the correct subPC. The "right" way now to give geometric information
> to a TS/SNES/KSP/PC is through a DM, which are passed down through
> PCFIELDSPLIT,
> PCPATCH, etc. However they are heavier weight than just some coordinates.
> This is not cumbersome at all. It is a simple natural way to pass around
> coordinates to PC's and, when possible, their children.
> Barry
> Note that we could also have a DMGetCoordinates() that pulled
> coordinates from a DM (that happended to have them) in this form associated
> with the PC and the PC could call it to get the coordinates and use them as
> needed. But this simple PCSetCoordinates() is a nice complement to that
> approach.
> Thanks,
> Matt
>> Barry
>> > On Jan 11, 2022, at 11:58 AM, Nicolás Barnafi <nabw91 at gmail.com> wrote:
>> > Dear community,
>> > I am working on a block preconditioner, where one of the blocks uses
>> HYPRE's AMS. As it requires the coordinates of the dofs, I have done so to
>> the PC object. I expected the coordinates to be inherited down to the
>> subblocks, is this not the case? (it seems so as I couldn't find a
>> specialized FIELDSPLIT SetCoordinates function).
>> > If this feature is missing, please give me some hints on where to add
>> the missing function, I would gladly do it. If not, please let me know why
>> it was dismissed, in order to do things the hard way [as in hard-coded ;)].
>> > Kind regards,
>> > Nicolas
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Nicolás Alejandro Barnafi Wittwer
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220113/fccbb444/attachment.html>
