[petsc-users] Parallel DMPlex Local to Global Mapping
Matthew Knepley
knepley at gmail.com
Thu Jan 13 06:00:31 CST 2022
On Wed, Jan 12, 2022 at 7:55 PM Ferrand, Jesus A. <FERRANJ2 at my.erau.edu>
wrote:
> Dear PETSc Team:
> Hi! I'm working on a parallel version of a PETSc script that I wrote in
> serial using DMPlex. After calling DMPlexDistribute() each rank is assigned
> its own DAG where the points are numbered locally. For example, If I split
> a 100-cell mesh over 4 processors, each process numbers their cells 0-24 as
> oppossed to something like 0-24, 25-49, 50-74, and 74-99 on ranks 0,1,2,
> and 3 respectively. The same happens for Face, Edge, and Vertex points in
> that the local DAG's renumber the ID's starting with 0 instead of using
> global numbering.
A parallel Plex is a collection of local Plexes connected by a PetscSF,
which tells us which pieces of the mesh are replicated on other processes.
Each Plex is locally numbered. This allows us to expand to any number of
processes without running out of numbers.
> How can I distribute a mesh such that the global numbering is reflected in
> the local DAG's?
You can always create a global numbering of points using
https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexCreatePointNumbering.html
but you should not need to do this.
> If not, what would be the right way to retrieve the global numbering? I've
> seen the term "StarForest" in some [petsc-users] discussion threads
> discussing a similar issue but have little clue as how to use them.
> I've looked at the following functions:
> - DMPlexCreatePointNumbering() - Sounds like what I need, but I don't
> think it will work because I am relying on DMPlexGetDepthStratum() which
> returns bounds in local numbering.
> - DMPlexGetCellNumbering() - Only converts Cells
> - DMPlexGetVertexNumbering() - Only converts Vertices
> Basically, what I want to do is to have a global matrix and have my MPI
> ranks call MatSetValues() on it (with ADD_VALUES as the mode). In my serial
> code I was relying on the global point numbering to build the matrix.
> Without it, I can't do it my way : (. I'm manually assembling a global
> stiffness matrix out of element stiffness matrices to run FEA.
You can do this at least two ways:
1) Right before you call MatSetValues(), use the IS from
CreatePointNumbering() to translate your local numbers to global
numbers/rows.
2) Call
https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexMatSetClosure.html
This is how I set FEM element matrices in the PETSc examples.
Matt
> Any help is much appreciated.
> Sincerely:
> *J.A. Ferrand*
> Embry-Riddle Aeronautical University - Daytona Beach FL
> M.Sc. Aerospace Engineering | May 2022
> B.Sc. Aerospace Engineering
> B.Sc. Computational Mathematics
> Sigma Gamma Tau
> Tau Beta Pi
> Honors Program
> *Phone:* (386)-843-1829
> *Email(s):* ferranj2 at my.erau.edu
> jesus.ferrand at gmail.com
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220113/8885b6ed/attachment.html>
