[petsc-users] Finite difference approximation of Jacobian
Patrick Sanan patrick.sanan at gmail.com
Wed Jan 12 07:53:06 CST 2022
Thanks a lot, all! So given that there's still some debate about whether we
should even use MATPREALLOCATOR or  a better integration of that hash logic
, as in Issue 852, I'll proceed with simply aping what DMDA does (with
apologies for all this code duplication).
One thing I had missed, which I just added, is respect for
DMSetMatrixPreallocation() / -dm_preallocate_only . Now, when that's
activated, the previous behavior should be recovered, but by default it'll
assemble a matrix which can be used for coloring, as is the main objective
of this thread.
Am Mi., 12. Jan. 2022 um 08:53 Uhr schrieb Barry Smith <bsmith at petsc.dev>:
>   Actually given the Subject of this email "Finite difference
> approximation of Jacobian" what I suggested is A complete story anyways for
> Patrick since the user cannot provide numerical values (of course Patrick
> could write a general new hash matrix type and then use it with zeros but
> that is asking a lot of him).
>   Regarding Fande's needs. One could rig things so that later one could
> "flip" back the matrix to again use the hasher for setting values when the
> contacts change.
> > On Jan 12, 2022, at 2:48 AM, Barry Smith <bsmith at petsc.dev> wrote:
> >> On Jan 12, 2022, at 2:22 AM, Jed Brown <jed at jedbrown.org> wrote:
> >> Because if a user jumps right into MatSetValues() and then wants to use
> the result, it better have the values. It's true that DM preallocation
> normally just "inserts zeros" and thus matches what MATPREALLOCATOR does.
> >  I am not saying the user jumps right into MatSetValues(). I am saying
> they do a "value" free assembly to have the preallocation set up and then
> they do the first real assembly; hence very much JUST a refactorization of
> MATPREALLOCATE. So the user is "preallocation-aware" but does not have to
> do anything difficult to determine their pattern analytically.
> >  Of course handling the values also is fine and simplifies user code and
> the conceptual ideas (since preallocation ceases to exist as a concept for
> users). I have no problem with skipping the "JUST a refactorization of
> MATPREALLOCATE code" but for Patrick's current pressing need I think a
> refactorization of MATPREALLOCATE would be fastest to develop hence I
> suggested it.
> >  I did not look at Jed's branch but one way to eliminate the
> preallocation part completely would be to have something like MATHASH and
> then when the first assembly is complete do a MatConvert to AIJ or
> whatever.  The conversion could be hidden inside the assemblyend of the
> hash so the user need not be aware that something different was done the
> first time through.  Doing it this way would easily allow multiple MATHASH*
> implementations (written by different people) that would compete on speed
> and memory usage.  So there could be MatSetType() and a new
> MatSetInitialType() where the initial type would be automatically set to
> some MATHASH if preallocation info is not provided.
> >> Barry Smith <bsmith at petsc.dev> writes:
> >>> Why does it need to handle values?
> >>>> On Jan 12, 2022, at 12:43 AM, Jed Brown <jed at jedbrown.org> wrote:
> >>>> I agree with this and even started a branch jed/mat-hash in (yikes!)
> 2017. I think it should be default if no preallocation functions are
> called. But it isn't exactly the MATPREALLOCATOR code because it needs to
> handle values too. Should not be a lot of code and will essentially remove
> this FAQ and one of the most irritating subtle aspects of new codes using
> PETSc matrices.
> https://petsc.org/release/faq/#assembling-large-sparse-matrices-takes-a-long-time-what-can-i-do-to-make-this-process-faster-or-matsetvalues-is-so-slow-what-can-i-do-to-speed-it-up
> >>>>> I think the MATPREALLOCATOR as a MatType is a cumbersome strange
> thing and would prefer it was just functionality that Mat provided
> directly; for example MatSetOption(mat, preallocator_mode,true);
> matsetvalues,... MatAssemblyBegin/End. Now the matrix has its proper
> nonzero structure of whatever type the user set initially, aij, baij,
> sbaij, .... And the user can now use it efficiently.
> >>>>> Barry
> >>>>> So turning on the option just swaps out temporarily the operations
> for MatSetValues and AssemblyBegin/End to be essentially those in
> MATPREALLOCATOR. The refactorization should take almost no time and would
> be faster than trying to rig dmstag to use MATPREALLOCATOR as is.
> >>>>>> On Jan 11, 2022, at 9:43 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >>>>>> On Tue, Jan 11, 2022 at 12:09 PM Patrick Sanan <
> patrick.sanan at gmail.com <mailto:patrick.sanan at gmail.com>> wrote:
> >>>>>> Working on doing this incrementally, in progress here:
> https://gitlab.com/petsc/petsc/-/merge_requests/4712 <
> https://gitlab.com/petsc/petsc/-/merge_requests/4712>
> >>>>>> This works in 1D for AIJ matrices, assembling a matrix with a
> maximal number of zero entries as dictated by the stencil width (which is
> intended to be very very close to what DMDA would do if you
> >>>>>> associated all the unknowns with a particular grid point, which is
> the way DMStag largely works under the hood).
> >>>>>> Dave, before I get into it, am I correct in my understanding that
> MATPREALLOCATOR would be better here because you would avoid superfluous
> zeros in the sparsity pattern,
> >>>>>> because this routine wouldn't have to assemble the Mat returned by
> DMCreateMatrix()?
> >>>>>> Yes, here is how it works. You throw in all the nonzeros you come
> across. Preallocator is a hash table that can check for duplicates. At the
> end, it returns the sparsity pattern.
> >>>>>> Thanks,
> >>>>>>   Matt
> >>>>>> If this seems like a sane way to go, I will continue to add some
> more tests (in particular periodic BCs not tested yet) and add the code for
> 2D and 3D.
> >>>>>> Am Mo., 13. Dez. 2021 um 20:17 Uhr schrieb Dave May <
> dave.mayhem23 at gmail.com <mailto:dave.mayhem23 at gmail.com>>:
> >>>>>> On Mon, 13 Dec 2021 at 20:13, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
> >>>>>> On Mon, Dec 13, 2021 at 1:52 PM Dave May <dave.mayhem23 at gmail.com
> <mailto:dave.mayhem23 at gmail.com>> wrote:
> >>>>>> On Mon, 13 Dec 2021 at 19:29, Matthew Knepley <knepley at gmail.com
> >>>>>> On Mon, Dec 13, 2021 at 1:16 PM Dave May <dave.mayhem23 at gmail.com
> >>>>>> On Sat 11. Dec 2021 at 22:28, Matthew Knepley <knepley at gmail.com
> >>>>>> On Sat, Dec 11, 2021 at 1:58 PM Tang, Qi <tangqi at msu.edu <mailto:
> tangqi at msu.edu>> wrote:
> >>>>>> Hi,
> >>>>>> Does anyone have comment on finite difference coloring with DMStag?
> We are using DMStag and TS to evolve some nonlinear equations implicitly.
> It would be helpful to have the coloring Jacobian option with that.
> >>>>>> Since DMStag produces the Jacobian connectivity,
> >>>>>> This is incorrect.
> >>>>>> The DMCreateMatrix implementation for DMSTAG only sets the number
> of nonzeros (very inaccurately). It does not insert any zero values and
> thus the nonzero structure is actually not defined.
> >>>>>> That is why coloring doesn’t work.
> >>>>>> Ah, thanks Dave.
> >>>>>> Okay, we should fix that.It is perfectly possible to compute the
> nonzero pattern from the DMStag information.
> >>>>>> Agreed. The API for DMSTAG is complete enough to enable one to
> >>>>>> loop over the cells, and for all quantities defined on the cell
> (centre, face, vertex),
> >>>>>> insert values into the appropriate slot in the matrix.
> >>>>>> Combined with MATPREALLOCATOR, I believe a compact and readable
> >>>>>> code should be possible to write for the preallocation (cf DMDA).
> >>>>>> I think the only caveat with the approach of using all quantities
> defined on the cell is
> >>>>>> It may slightly over allocate depending on how the user wishes to
> impose the boundary condition,
> >>>>>> or slightly over allocate for says Stokes where there is no
> pressure-pressure coupling term.
> >>>>>> Yes, and would not handle higher order stencils.I think the
> overallocating is livable for the first imeplementation.
> >>>>>> Sure, but neither does DMDA.
> >>>>>> The user always has to know what they are doing and set the stencil
> width accordingly.
> >>>>>> I actually had this point listed in my initial email (and the
> stencil growth issue when using FD for nonlinear problems),
> >>>>>> however I deleted it as all the same issue exist in DMDA and no one
> complains (at least not loudly) :D
> >>>>>> Thanks,
> >>>>>>   Matt
> >>>>>> Thanks,
> >>>>>> Dave
> >>>>>> Paging Patrick :)
> >>>>>> Thanks,
> >>>>>>  Matt
> >>>>>> Thanks,
> >>>>>> Dave
> >>>>>> you can use -snes_fd_color_use_mat. It has many options. Here is an
> example of us using that:
> https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex19.c#L898
> <https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex19.c#L898
> >>>>>> Thanks,
> >>>>>>   Matt
> >>>>>> Thanks,
> >>>>>> Qi
> >>>>>>> On Oct 15, 2021, at 3:07 PM, Jorti, Zakariae via petsc-users <
> petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> >>>>>>> Hello,
> >>>>>>> Does the Jacobian approximation using coloring and finite
> differencing of the function evaluation work in DMStag?
> >>>>>>> Thank you.
> >>>>>>> Best regards,
> >>>>>>> Zakariae
> >>>>>> What most experimenters take for granted before they begin their
> experiments lead.
> >>>>>> -- Norbert Wiener
> >>>>>> https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> >>>>>> -- Norbert Wiener
> experiments lead.
> >>>>>> -- Norbert Wiener
> experiments lead.
> >>>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220112/6a2c8196/attachment.html>
