[petsc-users] A problem with MatFDColoringSetFunction
Barry Smith bsmith at petsc.dev
Tue Jan 11 14:09:11 CST 2022
  Thanks for the alternative.
  @jed does this mean we need to do our casting of functions like this everywhere?
> On Jan 11, 2022, at 12:11 PM, Zou, Ling <lzou at anl.gov> wrote:
> A follow up:
> The compiler option '-Wno-bad-function-cast' did not work for c++. See message below:
> cc1plus: error: command line option '-Wno-bad-function-cast' is valid for C/ObjC but not for C++ [-Werror]
> Credit to David Andrs of INL, here is an alternative solution:
> MatFDColoringSetFunction(fdcoloring,
>   (PetscErrorCode(*)(void))(void(*)(void))SNESFormFunction, this);
> Thanks,
> -Ling
> From: petsc-users <petsc-users-bounces at mcs.anl.gov <mailto:petsc-users-bounces at mcs.anl.gov>> on behalf of Zou, Ling via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Date: Monday, January 10, 2022 at 9:23 PM
> To: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Cc: PETSc <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Subject: Re: [petsc-users] A problem with MatFDColoringSetFunction
> Thank you Barry.
> -Ling
> From: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Date: Monday, January 10, 2022 at 5:13 PM
> To: Zou, Ling <lzou at anl.gov <mailto:lzou at anl.gov>>
>   This is annoying. You need to pass in a compiler flag to turn off the error conditioner for casting a function pointer. It may be -Wnoerror=cast-function-type just google.
>   Barry
> On Jan 10, 2022, at 4:35 PM, Zou, Ling via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi All,
> I would appreciate if you could give some advice for setting the ‘FormFunction’ for the MatFDColoringSetFunction function call.
> I follow what is shown in the example:
> https://petsc.org/release/src/snes/tutorials/ex14.c.html <https://petsc.org/release/src/snes/tutorials/ex14.c.html>
> I setup similar code structure like:
> PetscErrorCode FormFunction(SNES,Vec,Vec,void*);
> Then use it as:
> MatFDColoringSetFunction(fdcoloring, (PetscErrorCode(*)(void))SNESFormFunction, this);
> This works fine on my local MacOS. However, when commit it to a remote repo, the compiler there gives me the following error (where warnings are treated as errors):
> src/base/PETScProblemInterface.C:100:67: error:
> cast between incompatible function types from
> 'PetscErrorCode (*)(SNES, Vec, Vec, void*)' {aka 'int (*)(_p_SNES*, _p_Vec*, _p_Vec*, void*)'}
> to
> 'PetscErrorCode (*)()' {aka 'int (*)()'} [-Werror=cast-function-type]
> Any help is appreciated.
> -Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220111/4931b2b0/attachment-0001.html>
