[petsc-users] A problem with MatFDColoringSetFunction
Barry Smith bsmith at petsc.dev
Mon Jan 10 17:13:23 CST 2022
  This is annoying. You need to pass in a compiler flag to turn off the error conditioner for casting a function pointer. It may be -Wnoerror=cast-function-type just google.
  Barry
> On Jan 10, 2022, at 4:35 PM, Zou, Ling via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi All,
> I would appreciate if you could give some advice for setting the ‘FormFunction’ for the MatFDColoringSetFunction function call.
> I follow what is shown in the example:
> https://petsc.org/release/src/snes/tutorials/ex14.c.html <https://petsc.org/release/src/snes/tutorials/ex14.c.html>
> I setup similar code structure like:
> PetscErrorCode FormFunction(SNES,Vec,Vec,void*);
> Then use it as:
> MatFDColoringSetFunction(fdcoloring, (PetscErrorCode(*)(void))SNESFormFunction, this);
> This works fine on my local MacOS. However, when commit it to a remote repo, the compiler there gives me the following error (where warnings are treated as errors):
> src/base/PETScProblemInterface.C:100:67: error:
> cast between incompatible function types from
> 'PetscErrorCode (*)(SNES, Vec, Vec, void*)' {aka 'int (*)(_p_SNES*, _p_Vec*, _p_Vec*, void*)'}
> to
> 'PetscErrorCode (*)()' {aka 'int (*)()'} [-Werror=cast-function-type]
> Any help is appreciated.
> -Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220110/d98c8ee3/attachment-0001.html>
