[petsc-users] Is old ex10.c (separated matrix and rhs) deprecated?
Barry Smith
bsmith at petsc.dev
Mon Jan 10 13:52:06 CST 2022
You can put them in different files or in the same file. If you put them in the same file you need to know which object comes first the matrix or the vector, this tells you if you should call MatLoad first or VecLoad.
Barry
> On Jan 10, 2022, at 2:33 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi All,
> Back to PETSc-3.8 version, the example ex10.c supports reading matrix and vector from separated files. Is this feature deprecated in the new PETSc version? I have some matrix and rhs to test but could not use ex10 example under new PETSc version.
> Thanks,
> Danyang
