[petsc-users] Fluid-Structure interaction with multiple DMPlex
Sun Jan 9 06:05:32 CST 2022
On Sat, Jan 8, 2022 at 2:13 PM Thibault Bridel-Bertomeu <
thibault.bridelbertomeu at gmail.com> wrote:
> However if you use IMEX for strong coupling of the two physics solved in
> each field, then it means you need to write a single set of PDEs that
> covers everything, don’t you ?
> If I want to solve Euler equations in one PetscDS and heat equation in the
> other one, then I need to write a global set of equations to use the IMEX
> TS , right ?
The way I think about it. You would have explicit terms for Euler, and they
would also be confined to one part of the domain, but that just impacts how
you do the residual integral. You do assemble a combined residual for all
dogs, however, which I think is what you mean.
    Matt
> Thanks,
> Thibault
> Le sam. 8 janv. 2022 à 20:00, Matthew Knepley <knepley at gmail.com> a
> écrit :
>> On Sat, Jan 8, 2022 at 1:30 PM Thibault Bridel-Bertomeu <
>>> Yes I was wondering about different time steps as well because usually
>>> implicit integration moves much faster.
>>> But if it not implemented, then maybe going the « weak coupling » road
>>> with a sub-DM is the way.
>>> Can I ask how you proceed in the rocket engine code you are writing ?
>>> IMEX ?
>> Right now it is IMEX, but we are explicitly substepping particles. Not
>> sure what the final thing will be.
>>   Thanks,
>>     Matt
>>> Thibault
>>> Le sam. 8 janv. 2022 à 19:22, Matthew Knepley <knepley at gmail.com> a
>>> écrit :
>>>> I do not know how. Right now, composable TS does not work all the way.
>>>>   Matt
>>>> On Sat, Jan 8, 2022 at 1:03 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> Can you subcycle with IMEX?
>>>>> On Sat, Jan 8, 2022 at 10:58 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Sat, Jan 8, 2022 at 3:05 AM Thibault Bridel-Bertomeu <
>>>>>>> Le ven. 7 janv. 2022 à 19:45, Thibault Bridel-Bertomeu <
>>>>>>> thibault.bridelbertomeu at gmail.com> a écrit :
>>>>>>>> Le ven. 7 janv. 2022 à 19:23, Matthew Knepley <knepley at gmail.com>
>>>>>>>> a écrit :
>>>>>>>>> On Fri, Jan 7, 2022 at 12:58 PM Thibault Bridel-Bertomeu <
>>>>>>>>>> Le ven. 7 janv. 2022 à 14:54, Matthew Knepley <knepley at gmail.com>
>>>>>>>>>> a écrit :
>>>>>>>>>>> On Fri, Jan 7, 2022 at 8:52 AM Thibault Bridel-Bertomeu <
>>>>>>>>>>>> Hi Matthew,
>>>>>>>>>>>> Le ven. 7 janv. 2022 à 14:44, Matthew Knepley <
>>>>>>>>>>>> knepley at gmail.com> a écrit :
>>>>>>>>>>>>> On Fri, Jan 7, 2022 at 5:46 AM Thibault Bridel-Bertomeu <
>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>> First of, happy new year everyone !! All the best !
>>>>>>>>>>>>> Happy New Year!
>>>>>>>>>>>>>> I am starting to draft a new project that will be about
>>>>>>>>>>>>>> fluid-structure interaction: in particular, the idea is to compute the
>>>>>>>>>>>>>> Navier-Stokes (or Euler nevermind) flow around an object and _at the same
>>>>>>>>>>>>>> time_ compute the heat equation inside the object.
>>>>>>>>>>>>>> So basically, I am thinking a mesh of the fluid and a mesh of
>>>>>>>>>>>>>> the object, both meshes being linked at the fluid - solid interface.
>>>>>>>>>>>>> First question: Are these meshes intended to match on the
>>>>>>>>>>>>> interface? If not, this sounds like overset grids or immersed
>>>>>>>>>>>>> boundary/interface methods. In this case, more than one mesh makes sense to
>>>>>>>>>>>>> me. If they are intended to match, then I would advocate a single mesh with
>>>>>>>>>>>>> multiple problems defined on it. I have experimented with this, for example
>>>>>>>>>>>>> see SNES ex23 where I have a field in only part of the domain. I have a
>>>>>>>>>>>>> large project to do exactly this in a rocket engine now.
>>>>>>>>>>>> Yes the way I see it is more of a single mesh with two distinct
>>>>>>>>>>>> regions to distinguish between the fluid and the solid. I was talking about
>>>>>>>>>>>> two meshes to try and explain my vision but it seems like it was unclear.
>>>>>>>>>>>> Imagine if you wish a rectangular box with a sphere inclusion:
>>>>>>>>>>>> the sphere would be tagged as a solid and the rest of the domain as fluid.
>>>>>>>>>>>> Using Gmsh volumes for instance.
>>>>>>>>>>>> Ill check out the SNES example ! Thanks !
>>>>>>>>>>>>>> First (Matthew maybe ?) do you think it is something that
>>>>>>>>>>>>>> could be done using two DMPlex's that would somehow be spawned from reading
>>>>>>>>>>>>>> a Gmsh mesh with two volumes ?
>>>>>>>>>>>>> You can take a mesh and filter out part of it with
>>>>>>>>>>>>> DMPlexFilter(). That is not used much so I may have to fix it to do what
>>>>>>>>>>>>> you want, but that should be easy.
>>>>>>>>>>>>>> And on one DMPlex we would have finite volume for the fluid,
>>>>>>>>>>>>>> on the other finite elements for the heat eqn ?
>>>>>>>>>>>>> I have done this exact thing on a single mesh. It should be no
>>>>>>>>>>>>> harder on two meshes if you go that route.
>>>>>>>>>>>>>> Second, is it something that anyone in the community has ever
>>>>>>>>>>>>>> imagined doing with PETSc DMPlex's ?
>>>>>>>>>>>>> Yes, I had a combined FV+FEM simulation of magma dynamics (I
>>>>>>>>>>>>> should make it an example), and currently we are doing FVM+FEM for
>>>>>>>>>>>>> simulation of a rocket engine.
>>>>>>>>>>>> Wow so it seems like it’s the exact same thing I would like to
>>>>>>>>>>>> achieve as the rocket engine example.
>>>>>>>>>>>> So you have a single mesh and two regions tagged differently,
>>>>>>>>>>>> and you use the DmPlexFilter to solve FVM and FEM separately ?
>>>>>>>>>>> With a single mesh, you do not even need DMPlexFilter. You just
>>>>>>>>>>> use the labels that Gmsh gives you. I think we should be able to get it
>>>>>>>>>>> going in a straightforward way.
>>>>>>>>>> Ok then ! Thanks ! I’ll give it a shot and see what happens !
>>>>>>>>>> Setting up the FVM and FEM discretizations will pass by
>>>>>>>>>> DMSetField right ? With a single mesh tagged with two different regions, it
>>>>>>>>>> should show up as two fields, is that correct ?
>>>>>>>>> Yes, the idea is as follows. Each field also has a label argument
>>>>>>>>> that is the support of the field in the domain. Then we create PetscDS
>>>>>>>>> objects for each
>>>>>>>>> separate set of overlapping fields. The current algorithm is not
>>>>>>>>> complete I think, so let me know if this step fails.
>>>>>>>> Ok, thanks.
>>>>>>>> I’ll let you know and share snippets when I have something started !
>>>>>>>> Talk soon ! Thanks !
>>>>>>> Hi Matthew,
>>>>>>> I thought about a little something else : what about setting two
>>>>>>> different TS, one for each field of the DM ? Most probably the fluid part
>>>>>>> would be solved with an explicit time stepping whereas the solid part with
>>>>>>> the heat equation would benefit from implicit time stepping. TSSetDM does
>>>>>>> not allow a field specification, is there a way to hack that so that each
>>>>>>> field has its own TS ?
>>>>>> I see at least two options here:
>>>>>> 1. Split the problems:
>>>>>>     You can use DMCreateSubDM() to split off part of a problem and
>>>>>> use a solver on that. I have done this for problems with weak coupling.
>>>>>> 2. Use IMEX
>>>>>>     For strong coupling, I have used the IMEX TSes in PETSc. You put
>>>>>> the explicit terms in the RHS, and the implicit in the IFunction.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Thanks
>>>>>>> Thibault
>>>>>>>> Thibault
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> Thanks,
>>>>>>>>>> Thibault
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>> Thanks !
>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>> As I said it is very prospective, I just wanted to have your
>>>>>>>>>>>>>> opinion !!
>>>>>>>>>>>>>> Thanks very much in advance everyone !!
>>>>>>>>>>>>>> Cheers,
>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>>>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>>>> Research Engineer
>>>>>>>>>>>> CEA/CESTA
>>>>>>>>>>>> 33114 LE BARP
>>>>>>>>>>>> Tel.: (+33)557046924
>>>>>>>>>>>> Mob.: (+33)611025322
>>>>>>>>>>>> Mail: thibault.bridelbertomeu at gmail.com
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>> Research Engineer
>>>>>>>>>> CEA/CESTA
>>>>>>>>>> 33114 LE BARP
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>> Research Engineer
>>>>>>>> CEA/CESTA
>>>>>>>> 33114 LE BARP
>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>> Research Engineer
>>>>>>> CEA/CESTA
>>>>>>> 33114 LE BARP
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>>>> Eng, MSc, PhD
>>> Research Engineer
>>> CEA/CESTA
>>> 33114 LE BARP
>> experiments lead.
>> -- Norbert Wiener
>> Eng, MSc, PhD
> Research Engineer
> CEA/CESTA
> 33114 LE BARP
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220109/7dc20ca4/attachment-0001.html>
