[petsc-users] Fluid-Structure interaction with multiple DMPlex
Fri Jan 7 07:54:14 CST 2022
On Fri, Jan 7, 2022 at 8:52 AM Thibault Bridel-Bertomeu <
thibault.bridelbertomeu at gmail.com> wrote:
> Hi Matthew,
> Le ven. 7 janv. 2022 à 14:44, Matthew Knepley <knepley at gmail.com> a
> écrit :
>> On Fri, Jan 7, 2022 at 5:46 AM Thibault Bridel-Bertomeu <
>>> Dear all,
>>> First of, happy new year everyone !! All the best !
>> Happy New Year!
>>> I am starting to draft a new project that will be about fluid-structure
>>> interaction: in particular, the idea is to compute the Navier-Stokes (or
>>> Euler nevermind) flow around an object and _at the same time_ compute the
>>> heat equation inside the object.
>>> So basically, I am thinking a mesh of the fluid and a mesh of the
>>> object, both meshes being linked at the fluid - solid interface.
>> First question: Are these meshes intended to match on the interface? If
>> not, this sounds like overset grids or immersed boundary/interface methods.
>> In this case, more than one mesh makes sense to me. If they are intended to
>> match, then I would advocate a single mesh with multiple problems defined
>> on it. I have experimented with this, for example see SNES ex23 where I
>> have a field in only part of the domain. I have a large project to do
>> exactly this in a rocket engine now.
> Yes the way I see it is more of a single mesh with two distinct regions to
> distinguish between the fluid and the solid. I was talking about two meshes
> to try and explain my vision but it seems like it was unclear.
> Imagine if you wish a rectangular box with a sphere inclusion: the sphere
> would be tagged as a solid and the rest of the domain as fluid. Using Gmsh
> volumes for instance.
> Ill check out the SNES example ! Thanks !
>>> First (Matthew maybe ?) do you think it is something that could be done
>>> using two DMPlex's that would somehow be spawned from reading a Gmsh mesh
>>> with two volumes ?
>> You can take a mesh and filter out part of it with DMPlexFilter(). That
>> is not used much so I may have to fix it to do what you want, but that
>> should be easy.
>>> And on one DMPlex we would have finite volume for the fluid, on the
>>> other finite elements for the heat eqn ?
>> I have done this exact thing on a single mesh. It should be no harder on
>> two meshes if you go that route.
>>> Second, is it something that anyone in the community has ever imagined
>>> doing with PETSc DMPlex's ?
>> Yes, I had a combined FV+FEM simulation of magma dynamics (I should make
>> it an example), and currently we are doing FVM+FEM for simulation of a
>> rocket engine.
> Wow so it seems like it’s the exact same thing I would like to achieve as
> the rocket engine example.
> So you have a single mesh and two regions tagged differently, and you use
> the DmPlexFilter to solve FVM and FEM separately ?
With a single mesh, you do not even need DMPlexFilter. You just use the
labels that Gmsh gives you. I think we should be able to get it going in a
straightforward way.
     Matt
> Thanks !
> Thibault
>>   Thanks,
>>      Matt
>>> As I said it is very prospective, I just wanted to have your opinion !!
>>> Thanks very much in advance everyone !!
>>> Cheers,
>>> Thibault
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
>> Eng, MSc, PhD
> Research Engineer
> CEA/CESTA
> 33114 LE BARP
> Tel.: (+33)557046924
> Mob.: (+33)611025322
> Mail: thibault.bridelbertomeu at gmail.com
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220107/c57e238c/attachment-0001.html>
