[petsc-users] Nullspaces
    Stefano Zampini
    stefano.zampini at gmail.com
    Tue Jan  4 10:39:04 CST 2022
Il Mar 4 Gen 2022, 16:56 Marco Cisternino <marco.cisternino at optimad.it> ha
scritto:
> Hello Mark,
> I analyzed the codes with valgrind, both the real code and the tiny one.
> I obviously used memcheck tool but with full leak check compiling the
> codes with debug info.
> Not considering OpenMPI events (I have no wrappers on the machine I used
> for the analysis), the real code gave zero errors and the tiny one gave this
> ==17911== 905,536 (1,552 direct, 903,984 indirect) bytes in 1 blocks are
> definitely lost in loss record 33 of 33
> ==17911==    at 0x483E340: memalign (in
> /usr/lib/x86_64-linux-gnu/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==17911==    by 0x49CB672: PetscMallocAlign (in
> /usr/lib/x86_64-linux-gnu/libpetsc_real.so.3.12.4)
> ==17911==    by 0x49CBE1D: PetscMallocA (in
> ==17911==    by 0x4B26187: VecCreate (in
> ==17911==    by 0x10940D: main (testNullSpace.cpp:30)
> due to the fact that I forgot to destroy the solution Vec (adding
> VecDestroy(&solution) at the end of the main, the error disappear).
> For both the codes, I analyzed the two ways of passing the constant to the
> null space of the operator, no memory errors but still the same results
> from MatNullSpaceTest, i.e.
> MatNullSpaceCreate(PETSC_COMM_WORLD, PETSC_TRUE, 0, nullptr, &nullspace);
> passes the test while
> Vec* nsp;
> VecDuplicateVecs(solution, 1, &nsp);
> VecSet(nsp[0],1.0);
> VecNormalize(nsp[0], nullptr);
> MatNullSpaceCreate(PETSC_COMM_WORLD, PETSC_FALSE, 1, nsp, &nullspace);
> VecDestroyVecs(1,&nsp);
> PetscFree(nsp);
> does not.
> I hope this can satisfy your doubt about the memory behavior, but please
> do not hesitate to ask for more analysis if it cannot.
> As Matthew said some weeks ago, something should be wrong in the code, I
> would say in the matrix, that’s why I provided the matrix and the way I
> test it.
> Unfortunately, it is hard (read impossible) for me to share the code
> producing the matrix. I hope the minimal code I provided is enough to
> understand something.
Try running slepc to find the smallest eigenvalues.  There should be two
zero eigenvalues,  then inspect the eigenvectors
> Thank you all.
> Marco Cisternino
> *From:* Marco Cisternino
> *Sent:* lunedì 3 gennaio 2022 16:08
> *To:* Mark Adams <mfadams at lbl.gov>
> *Cc:* Matthew Knepley <knepley at gmail.com>; petsc-users <
> petsc-users at mcs.anl.gov>
> *Subject:* RE: [petsc-users] Nullspaces
> We usually analyze the code with valgrind, when important changes are
> implemented.
> I have to admit that this analysis is still not automatic and the case we
> are talking about is not a test case for our workload.
> The test cases we have give no errors in valgrind analysis.
> However, I will analyze both the real code and the tiny one for this case
> with valgrind and report the results.
> Thank you,
> Marco Cisternino
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* lunedì 3 gennaio 2022 15:50
> *To:* Marco Cisternino <marco.cisternino at optimad.it>
> *Subject:* Re: [petsc-users] Nullspaces
> I have not looked at your code, but as a general observation you want to
> have some sort of memory checker, like valgrid for CPUs, in your workflow.
> It is the fastest way to find some classes of bugs.
> On Mon, Jan 3, 2022 at 8:47 AM Marco Cisternino <
> marco.cisternino at optimad.it> wrote:
> Are you talking about the code that produce the linear system or about the
> tiny code that test the null space?
> In the first case, it is absolutely possible, but I would expect no
> problem in the tiny code, do you agree?
> It is important to remark that the real code and the tiny one behave in
> the same way when testing the null space of the operator. I can analyze
> with valgrind and I will, but I would not expect great insights.
> Thanks,
> Marco Cisternino, PhD
> ______________________
> Optimad Engineering Srl
> Via Bligny 5, Torino, Italia.
> +3901119719782
> www.optimad.it
> *Sent:* lunedì 3 gennaio 2022 14:42
> There could be a memory bug that does not cause a noticeable problem until
> it hits some vital data and valgrind might find it on a small problem.
> However you might have a bug like a hardwired buffer size that
> overflows that is in fact not a bug until you get to this large size and in
> that case valgrid would need to be run on the large case and would have a
> good chance of finding it.
> On Mon, Jan 3, 2022 at 4:42 AM Marco Cisternino <
> My comments are between the Mark’s lines and they starts with “#”
> Marco Cisternino
> *Sent:* sabato 25 dicembre 2021 14:59
> If  "triggering the issue" requires a substantial mesh, that makes me
> think there is a logic bug somewhere. Maybe use valgrind.
> # Are you suggesting to use valgrind on this tiny toy code or on the
> original one? However, considering the purpose of the tiny code, i.e.
> testing the constant null space, why there should be a logical bug? Case 1
> passes and case 2 should be exactly the same, shouldn’t be it?
> Also you say you divide by the cell volume. Maybe I am not understanding
> this but that is basically diagonal scaling and that will change the null
> space (ie, not a constant anymore)
> # I agree on this, but it pushes a question: why the case 1 passes the
> test?
> # Thank you, Mark.
> On Thu, Dec 16, 2021 at 11:11 AM Marco Cisternino <
> Hello Matthew,
> as promised I prepared a minimal (112960 rows. I’m not able to produce
> anything smaller than this and triggering the issue) example of the
> behavior I was talking about some days ago.
> What I did is to produce matrix, right hand side and initial solution of
> the linear system.
> As I told you before, this linear system is the discretization of the
> pressure equation of a predictor-corrector method for NS equations in the
> framework of finite volume method.
> This case has homogeneous Neumann boundary conditions. Computational
> domain has two independent and separated sub-domains.
> I discretize the weak formulation and I divide every row of the linear
> system by the volume of the relative cell.
> The underlying mesh is not uniform, therefore cells have different
> volumes.
> The issue I’m going to explain does not show up if the mesh is uniform,
> same volume for all the cells.
> I usually build the null space sub-domain by sub-domain with
> MatNullSpaceCreate(getCommunicator(), PETSC_FALSE, nConstants, constants,
> &nullspace);
> Where nConstants = 2 and constants contains two normalized arrays with
> constant values on degrees of freedom relative to the associated sub-domain
> and zeros elsewhere.
> However, as a test I tried the constant over the whole domain using 2
> alternatives that should produce the same null space:
>    1. MatNullSpaceCreate(getCommunicator(), PETSC_TRUE, 0, nullptr,
>    &nullspace);
>    2. Vec* nsp;
> VecSet(nsp[0],1.0);
> MatNullSpaceCreate(getCommunicator(), PETSC_FALSE, 1, nsp, &nullspace);
> Once I created the null space I test it using:
> MatNullSpaceTest(nullspace, m_A, &isNullSpaceValid);
> The case 1 pass the test while case 2 don’t.
> I have a small code for matrix loading, null spaces creation and testing.
> Unfortunately I cannot implement a small code able to produce that linear
> system.
> As attachment you can find an archive containing the matrix, the initial
> solution (used to manually build the null space) and the rhs (not used in
> the test code) in binary format.
> You can also find the testing code in the same archive.
> I used petsc 3.12(gcc+openMPI) and petsc 3.15.2(intelOneAPI) same results.
> If the attachment is not delivered, I can share a link to it.
> Thanks for any help.
> Marco Cisternino
> +3901119719782
> www.optimad.it
> *From:* Marco Cisternino <marco.cisternino at optimad.it>
> *Sent:* martedì 7 dicembre 2021 19:36
> *To:* Matthew Knepley <knepley at gmail.com>
> *Cc:* petsc-users <petsc-users at mcs.anl.gov>
> I will, as soon as possible...
> Scarica Outlook per Android <https://aka.ms/AAb9ysg>
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Tuesday, December 7, 2021 7:25:43 PM
> On Tue, Dec 7, 2021 at 11:19 AM Marco Cisternino <
> Good morning,
> I’m still struggling with the Poisson equation with Neumann BCs.
> I discretize the equation by finite volume method and I divide every line
> of the linear system by the volume of the cell. I could avoid this
> division, but I’m trying to understand.
> My mesh is not uniform, i.e. cells have different volumes (it is an octree
> mesh).
> Moreover, in my computational domain there are 2 separated sub-domains.
> I build the null space and then I use MatNullSpaceTest to check it.
> If I do this:
> MatNullSpaceCreate(getCommunicator(), PETSC_TRUE, 0, nullptr, &nullspace);
> It works
> This produces the normalized constant vector.
> If I do this:
> Vec nsp;
> VecDuplicate(m_rhs, &nsp);
> VecSet(nsp,1.0);
> VecNormalize(nsp, nullptr);
> MatNullSpaceCreate(getCommunicator(), PETSC_FALSE, 1, &nsp, &nullspace);
> It does not work
> This is also the normalized constant vector.
> So you are saying that these two vectors give different results with
> MatNullSpaceTest()?
> Something must be wrong in the code. Can you send a minimal example of
> this? I will go
> through and debug it.
>   Thanks,
>      Matt
> Probably, I have wrong expectations, but should not it be the same?
> Thanks
> +3901119719782
> www.optimad.it
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220104/8eca9b63/attachment-0001.html>
