[petsc-users] Fortran HDF5 Cannot be found in PETSc-3.16
Danyang Su danyang.su at gmail.com
Mon Feb 28 11:42:58 CST 2022
Hi All,
Does anyone encounter the problem when HDF5 related fortran code cannot
be compiled in PETSc-3.16 because the 'use hdf5' cannot find the
required file?
Compared to HDF5-1.12.0 and earlier versions, some object files (e.g.,
hdf5.mod, hdf5.o) are missing in HDF5-1.12.1 in PETSc-3.16. I checked
the makefile in hdf5 folder in externalpackage, there are some
difference which I guess might cause the problem.
In PETSc-3.15, HDF5-1.12.0
# Make sure that these variables are exported to the Makefiles
F9XMODEXT = mod
F9XMODFLAG = -I
F9XSUFFIXFLAG =
In PETSc-3.16, HDF5-1.12.1
F9XMODEXT =
F9XMODFLAG =
F9XSUFFIXFLAG
The configuration I use in PETSc-3.16 is the same as PETSc-3.15.
./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
--download-mumps --download-scalapack --download-parmetis
--download-metis --download-ptscotch --download-fblaslapack
--download-mpich --download-hypre --download-superlu_dist
--download-hdf5=yes --download-cmake --with-debugging=0 COPTFLAGS="-O2
-march=native -mtune=native" CXXOPTFLAGS="-O2 -march=native
-mtune=native" FOPTFLAGS="-O2 -march=native -mtune=native"
Is this a bug or something wrong in my PETSc configuration?
Danyang
