[petsc-users] Question about the performance of KSP solver
    Barry Smith
    bsmith at petsc.dev
    Sun Feb 27 15:31:04 CST 2022
  This would be after the user code is complete, PETSc memory has all been freed and we can put a signal catch around the code to prevent such crashes.
> On Feb 27, 2022, at 4:24 PM, Jed Brown <jed at jedbrown.org> wrote:
> I assume this would be running VecWAXPY on CPU (and GPU) with some empty ranks? I'd be mildly concerned about allocating GPU memory because a crash here would be really bad.
> Barry Smith <bsmith at petsc.dev> writes:
>>   At PetscLogView() the code could see how long the run was, if it was greater than n seconds it could automatically run a few levels of streams (taking presumably well less than a few seconds) and adjust suitable the output. If the user runs, for example, 10min they surely don't mind .5 seconds to get more useful information.
>>> On Feb 27, 2022, at 3:41 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Probably not implied by -log_view alone, but -streams_view or some such doing it automatically would save having to context switch elsewhere to obtain that data.
>>>> We should think about have -log_view automatically running streams on subsets of ranks and using the resulting information to provide guidance to users on interpretating the -log_view output instead of expecting users to run streams themselves on their system and then figuring out what to do.
>>>>> On Feb 27, 2022, at 9:50 AM, Gong Yujie <yc17470 at connect.um.edu.mo> wrote:
>>>>> Hi,
>>>>> I'm using the GMRES with ASM preconditioner with sub-domain solver ILU(2) to solve an elasticity problem. First, I use 16 cores to test the computation time, then use 32 cores to run the same code with the same parameters.  But I just get about 10% speed up. From the log file I found that the computation time of KSPSolve() and MatSolve() just decrease a little bit. My PETSc version is 3.16.0 and use --with-debugging=0 when configure it. The matrix size is about 7*10^6. Some detail of the log is shown below:
>>>>> 16-cores:
>>>>> Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
>>>>>                  Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>>>> MatMult              664 1.0 5.0794e+01 1.6 2.70e+10 1.1 7.1e+04 4.8e+04 1.0e+00  7 13 49 20  0   7 13 49 20  0  8010
>>>>> MatSolve             663 1.0 1.9868e+02 1.1 1.43e+11 1.1 0.0e+00 0.0e+00 0.0e+00 33 70  0  0  0  33 70  0  0  0 10932
>>>>> MatLUFactorNum         1 1.0 6.1501e+00 1.1 1.40e+10 1.1 0.0e+00 0.0e+00 0.0e+00  1  7  0  0  0   1  7  0  0  0 35056
>>>>> MatILUFactorSym        1 1.0 1.5566e+01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>>>>> KSPSetUp               2 1.0 5.9627e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>>> KSPSolve               1 1.0 2.5168e+02 1.0 1.90e+11 1.1 1.4e+05 4.8e+04 1.3e+03 44 93 98 40 89  44 93 98 40 90 11437
>>>>> KSPGMRESOrthog       641 1.0 1.8980e+01 1.7 1.82e+10 1.1 0.0e+00 0.0e+00 6.4e+02  3  9  0  0 43   3  9  0  0 44 14578
>>>>> PCSetUp                2 1.0 2.2480e+01 1.1 1.40e+10 1.1 5.3e+02 6.5e+05 7.0e+00  4  7  0  2  0   4  7  0  2  0  9591
>>>>> PCSetUpOnBlocks        1 1.0 2.1555e+01 1.1 1.40e+10 1.1 0.0e+00 0.0e+00 0.0e+00  3  7  0  0  0   3  7  0  0  0 10002
>>>>> PCApply              663 1.0 2.0296e+02 1.1 1.43e+11 1.1 7.0e+04 4.8e+04 1.0e+00 33 70 49 20  0  33 70 49 20  0 10701
>>>>> PCApplyOnBlocks      663 1.0 1.9908e+02 1.1 1.43e+11 1.1 0.0e+00 0.0e+00 0.0e+00 33 70  0  0  0  33 70  0  0  0 10910
>>>>> 32-cores:
>>>>> MatMult              671 1.0 4.7602e+01 2.0 1.39e+10 1.1 1.7e+05 2.8e+04 1.0e+00  7 13 49 23  0   7 13 49 23  0  8637
>>>>> MatSolve             670 1.0 1.7800e+02 1.1 7.56e+10 1.1 0.0e+00 0.0e+00 0.0e+00 33 71  0  0  0  33 71  0  0  0 12544
>>>>> MatLUFactorNum         1 1.0 3.5714e+00 1.1 7.16e+09 1.1 0.0e+00 0.0e+00 0.0e+00  1  7  0  0  0   1  7  0  0  0 60743
>>>>> MatILUFactorSym        1 1.0 8.4088e+00 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
>>>>> KSPSetUp               2 1.0 3.8060e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>>> KSPSolve               1 1.0 2.1680e+02 1.0 9.95e+10 1.1 3.5e+05 2.8e+04 1.3e+03 44 93 98 47 89  44 93 98 47 90 13592
>>>>> KSPGMRESOrthog       648 1.0 1.6999e+01 2.0 9.39e+09 1.1 0.0e+00 0.0e+00 6.5e+02  2  9  0  0 43   2  9  0  0 44 16450
>>>>> PCSetUp                2 1.0 1.2439e+01 1.1 7.16e+09 1.1 1.3e+03 3.7e+05 7.0e+00  2  7  0  2  0   2  7  0  2  0 17440
>>>>> PCSetUpOnBlocks        1 1.0 1.1876e+01 1.1 7.16e+09 1.1 0.0e+00 0.0e+00 0.0e+00  2  7  0  0  0   2  7  0  0  0 18267
>>>>> PCApply              670 1.0 1.8235e+02 1.1 7.56e+10 1.1 1.7e+05 2.7e+04 1.0e+00 34 71 49 23  0  34 71 49 23  0 12245
>>>>> PCApplyOnBlocks      670 1.0 1.7838e+02 1.1 7.56e+10 1.1 0.0e+00 0.0e+00 0.0e+00 33 71  0  0  0  33 71  0  0  0 12517
>>>>> Hope you can help me!
>>>>> Best Regards,
>>>>> Yujie
