[petsc-users] Question about the performance of KSP solver
Mark Adams mfadams at lbl.gov
Sun Feb 27 09:24:16 CST 2022
Ah, "cores". Jed is right if these are cores on one socket.
On Sun, Feb 27, 2022 at 10:16 AM Jed Brown <jed at jedbrown.org> wrote:
> This is pretty typical. You see the factorization time is significantly
> better (because their more compute-limited) but MatMult and MatSolve are
> about the same because they are limited by memory bandwidth. On most modern
> architectures, the bandwidth is saturated with 16 cores or so.
> https://petsc.org/release/faq/#what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup
> If you haven't yet, I recommend trying to use AMG for this problem. You
> should call MatSetNearNullSpace() to set the rigid body modes and then use
> -pc_type gamg or (with external packages -pc_type ml and -pc_type hypre).
> The iteration count should be much less and solves reasonably fast.
> If you're interested in using different data structures, our experience is
> that we can solve similar problem sizes using Q2 elements in a few seconds
> (2-10) on a single node.
> Gong Yujie <yc17470 at connect.um.edu.mo> writes:
> > Hi,
> > I'm using the GMRES with ASM preconditioner with sub-domain solver
> ILU(2) to solve an elasticity problem. First, I use 16 cores to test the
> computation time, then use 32 cores to run the same code with the same
> parameters.  But I just get about 10% speed up. From the log file I found
> that the computation time of KSPSolve() and MatSolve() just decrease a
> little bit. My PETSc version is 3.16.0 and use --with-debugging=0 when
> configure it. The matrix size is about 7*10^6. Some detail of the log is
> shown below:
> > 16-cores:
> > Event                Count      Time (sec)     Flop
>         --- Global ---  --- Stage ----  Total
> >                    Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen
> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> > MatMult              664 1.0 5.0794e+01 1.6 2.70e+10 1.1 7.1e+04 4.8e+04
> 1.0e+00  7 13 49 20  0   7 13 49 20  0  8010
> > MatSolve             663 1.0 1.9868e+02 1.1 1.43e+11 1.1 0.0e+00 0.0e+00
> 0.0e+00 33 70  0  0  0  33 70  0  0  0 10932
> > MatLUFactorNum         1 1.0 6.1501e+00 1.1 1.40e+10 1.1 0.0e+00 0.0e+00
> 0.0e+00  1  7  0  0  0   1  7  0  0  0 35056
> > MatILUFactorSym        1 1.0 1.5566e+01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
> > KSPSetUp               2 1.0 5.9627e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
> > KSPSolve               1 1.0 2.5168e+02 1.0 1.90e+11 1.1 1.4e+05 4.8e+04
> 1.3e+03 44 93 98 40 89  44 93 98 40 90 11437
> > KSPGMRESOrthog       641 1.0 1.8980e+01 1.7 1.82e+10 1.1 0.0e+00 0.0e+00
> 6.4e+02  3  9  0  0 43   3  9  0  0 44 14578
> > PCSetUp                2 1.0 2.2480e+01 1.1 1.40e+10 1.1 5.3e+02 6.5e+05
> 7.0e+00  4  7  0  2  0   4  7  0  2  0  9591
> > PCSetUpOnBlocks        1 1.0 2.1555e+01 1.1 1.40e+10 1.1 0.0e+00 0.0e+00
> 0.0e+00  3  7  0  0  0   3  7  0  0  0 10002
> > PCApply              663 1.0 2.0296e+02 1.1 1.43e+11 1.1 7.0e+04 4.8e+04
> 1.0e+00 33 70 49 20  0  33 70 49 20  0 10701
> > PCApplyOnBlocks      663 1.0 1.9908e+02 1.1 1.43e+11 1.1 0.0e+00 0.0e+00
> 0.0e+00 33 70  0  0  0  33 70  0  0  0 10910
> > 32-cores:
> > MatMult              671 1.0 4.7602e+01 2.0 1.39e+10 1.1 1.7e+05 2.8e+04
> 1.0e+00  7 13 49 23  0   7 13 49 23  0  8637
> > MatSolve             670 1.0 1.7800e+02 1.1 7.56e+10 1.1 0.0e+00 0.0e+00
> 0.0e+00 33 71  0  0  0  33 71  0  0  0 12544
> > MatLUFactorNum         1 1.0 3.5714e+00 1.1 7.16e+09 1.1 0.0e+00 0.0e+00
> 0.0e+00  1  7  0  0  0   1  7  0  0  0 60743
> > MatILUFactorSym        1 1.0 8.4088e+00 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPSetUp               2 1.0 3.8060e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
> > KSPSolve               1 1.0 2.1680e+02 1.0 9.95e+10 1.1 3.5e+05 2.8e+04
> 1.3e+03 44 93 98 47 89  44 93 98 47 90 13592
> > KSPGMRESOrthog       648 1.0 1.6999e+01 2.0 9.39e+09 1.1 0.0e+00 0.0e+00
> 6.5e+02  2  9  0  0 43   2  9  0  0 44 16450
> > PCSetUp                2 1.0 1.2439e+01 1.1 7.16e+09 1.1 1.3e+03 3.7e+05
> 7.0e+00  2  7  0  2  0   2  7  0  2  0 17440
> > PCSetUpOnBlocks        1 1.0 1.1876e+01 1.1 7.16e+09 1.1 0.0e+00 0.0e+00
> 0.0e+00  2  7  0  0  0   2  7  0  0  0 18267
> > PCApply              670 1.0 1.8235e+02 1.1 7.56e+10 1.1 1.7e+05 2.7e+04
> 1.0e+00 34 71 49 23  0  34 71 49 23  0 12245
> > PCApplyOnBlocks      670 1.0 1.7838e+02 1.1 7.56e+10 1.1 0.0e+00 0.0e+00
> 0.0e+00 33 71  0  0  0  33 71  0  0  0 12517
> > Hope you can help me!
> > Best Regards,
> > Yujie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220227/91ff1e56/attachment-0001.html>
