[petsc-users] mkl_cpardiso halt on petsc-3.16.x
Gong Ding gongding at cn.cogenda.com
Thu Feb 24 20:56:56 CST 2022
Hi all,
On petsc3.12, I successfully run the linear solver mkl cpardiso on
parallel environment.  However, with the exactly same code, petsc-3.16 halt
[0] PCSetUp(): Setting up PC for first time
MKL_CPARDISO Options:
   -mat_mkl_cpardiso_65 <now 0 : formerly 0>: Suggested number of
threads to use within MKL_CPARDISO (None)
   -mat_mkl_cpardiso_66 <now 1 : formerly 1>: Maximum number of factors
with identical sparsity structure that must be kept in memory at the
same time (None)
   -mat_mkl_cpardiso_67 <now 1 : formerly 1>: Indicates the actual
matrix for the solution phase (None)
   -mat_mkl_cpardiso_68 <now 0 : formerly 0>: Message level information
(None)
   -mat_mkl_cpardiso_69 <now 11 : formerly 11>: Defines the matrix type
(None)
   -mat_mkl_cpardiso_1 <now 1 : formerly 1>: Use default values (None)
<--------- halt here
Regards
Gong Ding
