[petsc-users] PCSetCoordinates does not set coordinates of sub PC (fieldsplit) objects
Nicolás Barnafi
nabw91 at gmail.com
Mon Feb 21 17:20:54 CST 2022
Dear all,
I carried out the required impementation of the PCSetCoordinates for the
fieldsplit and wanted to put it upstream. I am not sure about what could be
missing (if anything), so perhaps I should open the pull request from a
fork in order for you to take a look. Would you advise this or think it is
better if I iterate with someone by email?
Best regards,
Nicolas
On Thu, Jan 13, 2022 at 7:21 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jan 13, 2022 at 1:15 PM Nicolás Barnafi <nabw91 at gmail.com> wrote:
>> Dear all,
>> I have created a first implementation. For now it must be called after
>> setting the fields, eventually I would like to move it to the setup phase.
>> The implementation seems clean, but it is giving me some memory errors
>> (free() corrupted unsorted chunks).
>> You may find the code below. After some work with gdb, I found out that
>> the errors appears when calling the ISDestroy(&is_coords) line, which to me
>> is not very clear, as I am indeed within the while scope creating and then
>> destroying the is_coords object. I would greatly appreciate it if you could
>> give me a hint on what the problem is.
>> After debugging this, and working on your suggestion, I will open a PR.
>> Best regards,
>> NB
>> ----- CODE ------
>> static PetscErrorCode PCSetCoordinates_FieldSplit(PC pc, PetscInt dim,
>> PetscInt nloc, PetscReal coords[])
>> PetscErrorCode ierr;
>> PC_FieldSplit *jac = (PC_FieldSplit*)pc->data;
>> PC_FieldSplitLink ilink_current = jac->head;
>> PC pc_current;
>> PetscInt nmin, nmax, ii, ndofs;
>> PetscInt *owned_dofs; // Indexes owned by this processor
>> PetscReal *coords_block; // Coordinates to be given to the current PC
>> IS is_owned;
>> PetscFunctionBegin;
>> // Extract matrix ownership range to then compute subindexes for
>> coordinates. This results in an IS object (is_owned).
>> // TODO: This would be simpler with a general MatGetOwnershipIS
>> (currently supported only by Elemental and BLAS matrices).
>> ierr = MatGetOwnershipRange(pc->mat,&nmin,&nmax);CHKERRQ(ierr);
>> ndofs = nmax - nmin;
>> ierr = PetscMalloc1(ndofs, &owned_dofs); CHKERRQ(ierr);
>> for(PetscInt i=nmin;i<ndofs;++i)
>> owned_dofs[i] = nmin + i;
>> ierr = ISCreateGeneral(MPI_COMM_WORLD, ndofs, owned_dofs,
>> PETSC_OWN_POINTER, &is_owned); CHKERRQ(ierr);
> Here you tell PETSc to take control of the memory for owned_dofs, but
> below you PetscFree(owned_dofs). This is not compatible.
> You should just destroy the IS when you are done.
> Thanks,
> Matt
>> // For each IS, embed it to get local coords indces and then set
>> coordinates in the subPC.
>> ii=0;
>> while(ilink_current)
>> IS is_coords;
>> PetscInt ndofs_block;
>> const PetscInt *block_dofs_enumeration; // Numbering of the dofs
>> relevant to the current block
>> ierr = ISEmbed(ilink_current->is, is_owned, PETSC_TRUE, &is_coords);
>> CHKERRQ(ierr); // Setting drop to TRUE, although it should make no
>> difference.
>> ierr = PetscMalloc1(ndofs_block, &coords_block); CHKERRQ(ierr);
>> ierr = ISGetLocalSize(is_coords, &ndofs_block); CHKERRQ(ierr);
>> ierr = ISGetIndices(is_coords, &block_dofs_enumeration);
>> CHKERRQ(ierr);
>> // Having the indices computed and the memory allocated, we can copy
>> the relevant coords and set them to the subPC.
>> for(PetscInt dof=0;dof<ndofs_block;++dof)
>> for(PetscInt d=0;d<dim;++d)
>> coords_block[dim*dof + d] = coords[dim *
>> block_dofs_enumeration[dof] + d];
>> // printf("Dof: %d, Global: %f\n", block_dofs_enumeration[dof],
>> coords[dim * block_dofs_enumeration[dof] + d]);
>> ierr = ISRestoreIndices(is_coords, &block_dofs_enumeration);
>> CHKERRQ(ierr);
>> ierr = ISDestroy(&is_coords); CHKERRQ(ierr);
>> ierr = KSPGetPC(ilink_current->ksp, &pc_current); CHKERRQ(ierr);
>> ierr = PCSetCoordinates(pc_current, dim, ndofs_block, coords_block);
>> CHKERRQ(ierr);
>> ierr = PetscFree(coords_block); CHKERRQ(ierr);
>> if(!pc_current)
>> SETERRQ(PetscObjectComm((PetscObject)pc),PETSC_ERR_ORDER,"Setting
>> coordinates to PCFIELDSPLIT but a subPC is null.");
>> ilink_current = ilink_current->next;
>> ++ii;
>> ierr = PetscFree(owned_dofs); CHKERRQ(ierr);
>> PetscFunctionReturn(0);
>> On Wed, Jan 12, 2022 at 6:22 AM Barry Smith <bsmith at petsc.dev> wrote:
>>> On Jan 11, 2022, at 9:51 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Tue, Jan 11, 2022 at 3:31 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>> Nicolas,
>>>> For "simple" PCFIELDSPLIT it is possible to pass down the attached
>>>> coordinate information. By simple I mean where the splitting is done by
>>>> fields and not by general lists of IS (where one does not have enough
>>>> information to know what the coordinates would mean to the subPCS).
>>>> Look in fieldsplit.c PCFieldSplitSetFields_FieldSplit() where it
>>>> does the KSPCreate(). I think you can do a KSPGetPC() on that ksp and
>>>> PCSetCoordinates on that PC to supply the coordinates to the subPC. In the
>>>> function PCFieldSplitSetIS_FieldSplit() you can also attach the coordinates
>>>> to the subPCs IF defaultsplit is true.
>>>> Sadly this is not the full story. The outer PC will not have any
>>>> coordinates because calling PCSetCoordinates on a PCFIELDSPLIT does nothing
>>>> since fieldsplit doesn't handle coordinates. So you need to do more, you
>>>> need to provide a PCSetCoordinates_FieldSplit() that saves the coordinates
>>>> in new entries in the PC_FieldSplit struct and then in
>>>> PCFieldSplitSetFields_FieldSplit() you need to access those saved values
>>>> and pass them into the PCSetCoordinates() that you call on the subPCs. Once
>>>> you write
>>>> PCSetCoordinates_FieldSplit() you need to call
>>>> ierr =
>>>> PetscObjectComposeFunction((PetscObject)pc,"PCSetCoordinates_C",PCSetCoordinates_FieldSplit);CHKERRQ(ierr);
>>>> inside PCCreate_FieldSplit().
>>>> Any questions just let us know.
>>> I will add "Why is this so cumbersome?". This is a workaround in order
>>> to get geometric information into GAMG. It should really be
>>> PCGAMGSetCoordinates(), which
>>> are used to calculate the rigid body modes, and assume a bunch of stuff
>>> about the coordinate space. This would not help you, because it would still
>>> force you to pull
>>> out the correct subPC. The "right" way now to give geometric information
>>> to a TS/SNES/KSP/PC is through a DM, which are passed down through
>>> PCFIELDSPLIT,
>>> PCPATCH, etc. However they are heavier weight than just some coordinates.
>>> This is not cumbersome at all. It is a simple natural way to pass
>>> around coordinates to PC's and, when possible, their children.
>>> Barry
>>> Note that we could also have a DMGetCoordinates() that pulled
>>> coordinates from a DM (that happended to have them) in this form associated
>>> with the PC and the PC could call it to get the coordinates and use them as
>>> needed. But this simple PCSetCoordinates() is a nice complement to that
>>> approach.
>>> Thanks,
>>> Matt
>>>> Barry
>>>> > On Jan 11, 2022, at 11:58 AM, Nicolás Barnafi <nabw91 at gmail.com>
>>>> wrote:
>>>> > Dear community,
>>>> > I am working on a block preconditioner, where one of the blocks uses
>>>> HYPRE's AMS. As it requires the coordinates of the dofs, I have done so to
>>>> the PC object. I expected the coordinates to be inherited down to the
>>>> subblocks, is this not the case? (it seems so as I couldn't find a
>>>> specialized FIELDSPLIT SetCoordinates function).
>>>> > If this feature is missing, please give me some hints on where to add
>>>> the missing function, I would gladly do it. If not, please let me know why
>>>> it was dismissed, in order to do things the hard way [as in hard-coded ;)].
>>>> > Kind regards,
>>>> > Nicolas
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> Nicolás Alejandro Barnafi Wittwer
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220222/01d09faf/attachment-0001.html>
