[petsc-users] [EXTERNAL] Re: Changes in SNES convergence criteria
Park, Heeho heepark at sandia.gov
Wed Feb 16 18:10:37 CST 2022
HI,
Jenn: Perhaps, we need to have an option to use or not use SNESSetConvergenceTest. I think PFLOTRAN is set to use that function as default no matter what.
Barry: Thank you for your answers. Let me look into the second case deeper. I will have to test this in different machines and debug to see what is causing the issue.
- Heeho Daniel Park
Date: Wednesday, February 16, 2022 at 4:06 PM
To: "Park, Heeho" <heepark at sandia.gov>
Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>, "LaForce, Tara" <tlaforc at sandia.gov>
Subject: [EXTERNAL] Re: [petsc-users] Changes in SNES convergence criteria
On Feb 16, 2022, at 6:28 PM, Park, Heeho via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi Petsc developers,
I’m running into two issues related to SNES convergence criteria. First is setting convergence criteria to a large value. This used to work to effectively turn off RTOL, STOL, ATOL, and use PFLOTRAN’s Newton iteration convergence criteria using INF norms, but this trick does not work anymore ( example 1 ).
So, we set the condition to PETSc convergence criteria (default) AND PFLOTRAN convergence criteria to declare convergence, and get this error ( example 2).
Is there a good way to bypass SNES convergence criteria and use our own?
What’s happening in the second example?
Thank you,
Example 1:
   Do you use SNESSetConvergenceTest? If so, then unless your test uses the PETSc SNES object tolerance values (unlikely), you don't need to change the convergence tolerance values. So you can just not set it to that huge value or any particular value.
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: Relative tolerance 1e+20 must be non-negative and less than 1.0
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.16.4-756-g5b3d650  GIT Date: 2022-02-02 17:48:52 +0000
[0]PETSC ERROR: /data/home/heepark/software/pflotran-bcnew-trd/src/pflotran/pflotran on a intel-c-opt named cb007 by tlaforc
 Tue Feb 15 19:45:39 2022
[0]PETSC ERROR: Configure options --with-petsc-arch=intel-c-opt --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort --with-c
language=c --with-shared-libraries=0 --with-debugging=0 --with-mpi=yes --download-sowing=yes --with-valgrind=yes --with-cmak
e=yes --with-make=yes --with-fblaslaback=yes --with-blaslapack=yes --FFLAGS="-diag-disable 5462" --CFLAGS="-O3 -g" --CXXFLAG
S="-O3 -g" --FFLAGS="-O3 -g" --with-hdf5-include=/data/home/heepark/software/hdf5/build/include --with-hdf5-lib="-L/data/hom
e/heepark/software/hdf5/build/lib -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5" --with-hypre-include=/data/home/heepark/
software/hypre/build/include --with-hypre-lib="-L/data/home/heepark/software/hypre/build/lib -lHYPRE" --with-metis-include=/
data/home/heepark/software/metis/include --with-metis-lib=/data/home/heepark/software/metis/build/libmetis/libmetis.a --with
-parmetis-include=/data/home/heepark/software/parmetis/include --with-parmetis-lib=/data/home/heepark/software/parmetis/buil
d/libparmetis/libparmetis.a --with-scalapack-lib=/data/home/heepark/software/scalapack/build/lib/libscalapack.a --with-hdf5-
fortran-bindings=yes
[0]PETSC ERROR: #1 SNESSetTolerances() at /data/home/heepark/software/petsc-main/src/snes/interface/snes.c:3833
[0]PETSC ERROR: #2 User provided function() at User file:0
Example 2:
  This should never be happening. Perhaps it is caused by memory corruption. Can you run with valgrind to verify no memory issues. If valgrind does not work on your system you can try with the PETSc option -malloc_debug
[0]PETSC ERROR: toranks[39] 40 not in comm size 40
[0]PETSC ERROR: /data/home/heepark/software/pflotran-bcnew-trd/src/pflotran/pflotran on a intel-c-opt named cb007 by tlaforc Wed Feb 16 14:13:12 2022
[0]PETSC ERROR: Configure options --with-petsc-arch=intel-c-opt --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort --with-clanguage=c --with-shared-libraries=0 --with-debugging=0 --with-mpi=yes --download-sowing=yes --with-valgrind=yes --with-cmake=yes --with-make=yes --with-fblaslaback=yes --with-blaslapack=yes --FFLAGS="-diag-disable 5462" --CFLAGS="-O3 -g" --CXXFLAGS="-O3 -g" --FFLAGS="-O3 -g" --with-hdf5-include=/data/home/heepark/software/hdf5/build/include --with-hdf5-lib="-L/data/home/heepark/software/hdf5/build/lib -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5" --with-hypre-include=/data/home/heepark/software/hypre/build/include --with-hypre-lib="-L/data/home/heepark/software/hypre/build/lib -lHYPRE" --with-metis-include=/data/home/heepark/software/metis/include --with-metis-lib=/data/home/heepark/software/metis/build/libmetis/libmetis.a --with-parmetis-include=/data/home/heepark/software/parmetis/include --with-parmetis-lib=/data/home/heepark/software/parmetis/build/libparmetis/libparmetis.a --with-scalapack-lib=/data/home/heepark/software/scalapack/build/lib/libscalapack.a --with-hdf5-fortran-bindings=yes
[0]PETSC ERROR: #1 PetscCommBuildTwoSidedFReq() at /data/home/heepark/software/petsc-main/src/sys/utils/mpits.c:555
[0]PETSC ERROR: #2 MatStashScatterBegin_BTS() at /data/home/heepark/software/petsc-main/src/mat/utils/matstash.c:940
[0]PETSC ERROR: #3 MatStashScatterBegin_Private() at /data/home/heepark/software/petsc-main/src/mat/utils/matstash.c:461
[0]PETSC ERROR: #4 MatAssemblyBegin_MPIAIJ() at /data/home/heepark/software/petsc-main/src/mat/impls/aij/mpi/mpiaij.c:673
[0]PETSC ERROR: #5 MatAssemblyBegin() at /data/home/heepark/software/petsc-main/src/mat/interface/matrix.c:5592
[0]PETSC ERROR: #6 User provided function() at User file:0
[0]PETSC ERROR: #7 oursnesjacobian() at /data/home/heepark/software/petsc-main/src/snes/interface/ftn-custom/zsnesf.c:173
[0]PETSC ERROR: #8 SNESComputeJacobian() at /data/home/heepark/software/petsc-main/src/snes/interface/snes.c:2864
[0]PETSC ERROR: #9 SNESSolve_NEWTONLS() at /data/home/heepark/software/petsc-main/src/snes/impls/ls/ls.c:222
[0]PETSC ERROR: #10 SNESSolve() at /data/home/heepark/software/petsc-main/src/snes/interface/snes.c:4810
[0]PETSC ERROR: #11 User provided function() at User file:0
Heeho Daniel Park
Sandia National Laboratories
Org: 08844, R&D
Work: 505-844-1319
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220217/26959903/attachment-0001.html>
