[petsc-users] Nodes Communication - Petsc Vec
Medane TCHAKOROM medane.tchakorom at univ-fcomte.fr
Wed Feb 16 09:40:58 CST 2022
Re:
Sorry, but I can't find this file in my installation. I'am using Petsc
3.14.2
Thanks
On 16/02/2022 16:00, Junchao Zhang wrote:
> We could still do it. See the example at petsc/src/vec/is/sf/tests/ex9.c
> --Junchao Zhang
> On Wed, Feb 16, 2022 at 8:47 AM Medane TCHAKOROM
> <medane.tchakorom at univ-fcomte.fr> wrote:
>     Re:
>     It does not apply, because "their communicator must be on the same
>     set of processes" .
>     In my case, I have two disjoint subcomm from PETSC_COMM_WORD with
>     same number of processes.
>     I want to send information (Petsc Vec) from one subcomm to another
>     subcomm.
>     Thanks
>     On 16/02/2022 15:43, Junchao Zhang wrote:
>>     See Notes at
>>     https://petsc.org/main/docs/manualpages/PetscSF/VecScatterCreate.html
>>     Does it apply to your case?
>>     --Junchao Zhang
>>     On Wed, Feb 16, 2022 at 8:12 AM Medane TCHAKOROM
>>         Re:
>>         I forgot to mention that the nodes are in differents
>>         communicators. Does VecScatter functionnality still applies ?
>>         Thanks.
>>         On 16/02/2022 15:03, Matthew Knepley wrote:
>>>         On Wed, Feb 16, 2022 at 8:55 AM Medane TCHAKOROM
>>>             Hello,
>>>             I want to pass a Petsc Vec from one node to another one.
>>>             Is there any
>>>             Petsc method for doing this
>>>         You likely want the VecScatter functionality. There is a
>>>         discussion of this in the manual:
>>>         https://petsc.org/main/docs/manual/vec/?highlight=vecscatter#sec-unstruct
>>>           Thanks,
>>>             Matt
>>>             or should I use MPI_Irecv and MPI_Isend for non-blocking
>>>             communication ?
>>>             When using MPI_Isend, can i send a Petsc Vec, or should
>>>             I get the array
>>>             from it, and then send it ?
>>>             Thanks
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>>         https://www.cse.buffalo.edu/~knepley/
>>>         <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220216/639644a4/attachment.html>
