[petsc-users] Creating multiple Vecs with petsc4py
Jed Brown jed at jedbrown.org
Sat Feb 12 07:33:06 CST 2022
VecDuplicateVecs isn't implemented in petsc4py, but it internally just loops over VecDuplicate so you can use
qs = [x.duplicate() for i in range(4)]
y.maxpy(alphas, qs)
where the Python binding here handles qs being a Python array.
Samar Khatiwala <samar.khatiwala at earth.ox.ac.uk> writes:
> Hello,
> I’d like to create an array of Vecs in petsc4py by calling VecDuplicateVecs but I can’t find the corresponding method (I’ve tried various iterations such as q = x.duplicateVecs(4), etc).
> Is this not implemented in petsc4py? One workaround I’ve come up with is something like:
> q={}
> for i in range(0, 3):
>     q[i]=x.duplicate()
> Is there another/better way? And how do I then use PETSc functions that operate on Vecs (e.g., VecMAXPY)? Would I just call VecAXPY in a loop as above?
> Ultimately, what I really want to do is wrap my own C functions with Cython that take an array of Vecs as an argument and then operate on them. (The function needs the entire array
> of Vecs to do its thing so I can’t loop over the elements of the array.) For instance, I want to pass the q above to myCfunc(Vec *q, Vec *qout). How do I go about doing that?
> Thanks very much!
> Best,
> Samar
