[petsc-users] Gmsh 8-noded quadrilateral
Susanne Claus
susanne.claus at onera.fr
Thu Feb 10 14:17:49 CST 2022
Dear Matthew,
Thank you so much.
I have a attached a small 8-noded quadrilateral mesh file (Version 4
ASCII) generated with gmsh 4.8.4.
Best wishes,
Susanne
On 10.02.2022 16:23, Matthew Knepley wrote:
> On Thu, Feb 10, 2022 at 10:12 AM Susanne Claus <susanne.claus at onera.fr>
> wrote:
>> Hello,
>> I am using DMPlex for the mesh structure of a solid mechanics finite
>> element code. I mainly use gmsh as input file format. When I try to
>> read in 8-noded Quadrilaterals (Element type 16 in gmsh) DMPlex tells
>> me that this element type is unknown. However a 9-noded Quadrilateral
>> can be read without problem. On inspecting the plexgmsh.c source code
>> I can see that 8-noded quadrilaterals are deactivated:
>> #if 0
>> 146: {20, GMSH_TRI, 2, 3, 3, 9, NULL},
>> 147: {16, GMSH_QUA, 2, 2, 4, 8, NULL},
>> For our application these 8-noded quadrilateral are very important.
>> Is there any reason why they have not been implemented/deactivated in
>> the dmplex gmsh reader?
> No, we can handle them in the same way I think. Let me look at it.
> Hopefully it is easy.
> Thanks,
> Matt
>> Thank you for all the great work you are doing. PETSc is amazing.
>> Best wishes,
>> Susanne Claus
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ [1]
Susanne Claus
Ingénieur Chercheur
Applied Mathematics and Scientific Computing Group
DTIS
ONERA - The French Aerospace Lab
6 Chemin de la Vauve aux Granges, 91120 Palaiseau
Links:
[1] http://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220210/9b68e53c/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220210/9b68e53c/attachment.png>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220210/9b68e53c/attachment.ksh>
