[petsc-users] GAMG crash during setup when using multiple GPUs
Junchao Zhang junchao.zhang at gmail.com
Thu Feb 10 13:40:43 CST 2022
Did it fail without GPU at 64 MPI ranks?
--Junchao Zhang
On Thu, Feb 10, 2022 at 1:22 PM Sajid Ali Syed <sasyed at fnal.gov> wrote:
> Hi PETSc-developers,
> I’m seeing the following crash that occurs during the setup phase of the
> preconditioner when using multiple GPUs. The relevant error trace is shown
> below:
> (GTL DEBUG: 26) cuIpcOpenMemHandle: resource already mapped, CUDA_ERROR_ALREADY_MAPPED, line no 272
> [24]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [24]PETSC ERROR: General MPI error
> [24]PETSC ERROR: MPI error 1 Invalid buffer pointer
> [24]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [24]PETSC ERROR: Petsc Development GIT revision: f351d5494b5462f62c419e00645ac2e477b88cae  GIT Date: 2022-02-08 15:08:19 +0000
> [24]PETSC ERROR: #1 PetscSFLinkWaitRequests_MPI() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/vec/is/sf/impls/basic/sfmpi.c:54
> [24]PETSC ERROR: #2 PetscSFLinkFinishCommunication() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/include/../src/vec/is/sf/impls/basic/sfpack.h:274
> [24]PETSC ERROR: #3 PetscSFBcastEnd_Basic() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/vec/is/sf/impls/basic/sfbasic.c:218
> [24]PETSC ERROR: #4 PetscSFBcastEnd() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/vec/is/sf/interface/sf.c:1499
> [24]PETSC ERROR: #5 VecScatterEnd_Internal() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/vec/is/sf/interface/vscat.c:87
> [24]PETSC ERROR: #6 VecScatterEnd() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/vec/is/sf/interface/vscat.c:1366
> [24]PETSC ERROR: #7 MatMult_MPIAIJCUSPARSE() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.cu:302
> [24]PETSC ERROR: #8 MatMult() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/mat/interface/matrix.c:2438
> [24]PETSC ERROR: #9 PCApplyBAorAB() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/ksp/pc/interface/precon.c:730
> [24]PETSC ERROR: #10 KSP_PCApplyBAorAB() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/include/petsc/private/kspimpl.h:421
> [24]PETSC ERROR: #11 KSPGMRESCycle() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/ksp/ksp/impls/gmres/gmres.c:162
> [24]PETSC ERROR: #12 KSPSolve_GMRES() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/ksp/ksp/impls/gmres/gmres.c:247
> [24]PETSC ERROR: #13 KSPSolve_Private() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/ksp/ksp/interface/itfunc.c:925
> [24]PETSC ERROR: #14 KSPSolve() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/ksp/ksp/interface/itfunc.c:1103
> [24]PETSC ERROR: #15 PCGAMGOptProlongator_AGG() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/ksp/pc/impls/gamg/agg.c:1127
> [24]PETSC ERROR: #16 PCSetUp_GAMG() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/ksp/pc/impls/gamg/gamg.c:626
> [24]PETSC ERROR: #17 PCSetUp() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/ksp/pc/interface/precon.c:1017
> [24]PETSC ERROR: #18 KSPSetUp() at /tmp/sajid/spack-stage/spack-stage-petsc-main-mnj56kbexro3fipf6kheyttljzwss7fo/spack-src/src/ksp/ksp/interface/itfunc.c:417
> [24]PETSC ERROR: #19 main() at poisson3d.c:69
> [24]PETSC ERROR: PETSc Option Table entries:
> [24]PETSC ERROR: -dm_mat_type aijcusparse
> [24]PETSC ERROR: -dm_vec_type cuda
> [24]PETSC ERROR: -ksp_monitor
> [24]PETSC ERROR: -ksp_norm_type unpreconditioned
> [24]PETSC ERROR: -ksp_type cg
> [24]PETSC ERROR: -ksp_view
> [24]PETSC ERROR: -log_view
> [24]PETSC ERROR: -mg_levels_esteig_ksp_type cg
> [24]PETSC ERROR: -mg_levels_ksp_type chebyshev
> [24]PETSC ERROR: -mg_levels_pc_type jacobi
> [24]PETSC ERROR: -pc_gamg_agg_nsmooths 1
> [24]PETSC ERROR: -pc_gamg_square_graph 1
> [24]PETSC ERROR: -pc_gamg_threshold 0.0
> [24]PETSC ERROR: -pc_gamg_threshold_scale 0.0
> [24]PETSC ERROR: -pc_gamg_type agg
> [24]PETSC ERROR: -pc_type gamg
> [24]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> Attached with this email is the full error log and the submit script for a
> 8-node/64-GPU/64 MPI rank job. I’ll also note that the same program did not
> crash when using either 2 or 4 nodes (with 8 & 16 GPUs/MPI ranks
> respectively) and attach those logs as well if that helps. Could someone
> let me know what this error means and what can be done to prevent it?
> Thank You,
> Sajid Ali (he/him) | Research Associate
> Scientific Computing Division
> Fermi National Accelerator Laboratory
> s-sajid-ali.github.io
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220210/ba0a03db/attachment.html>
